Просмотров в теме 289224   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 20.08.2020, 06:25 Автор темы   721
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original GeekVape Aegis Boost 40W 1500mAh VW Pod System Kit Luxury Edition original price $40.99, now only $34.99
The Original GeekVape Aegis Boost Pod System Vape Kit Luxury Edition, constructed of Zinc Alloy & Leather & Silicone, is a lightest and toughest pod mod. GeekVape Aegis Boost Pod Vape Kit Luxury Edition works with 1500mAh battery with max 40W output. GeekVape Aegis Boost Luxury Edition adopts AS chip with IP67 waterproof, shockproof and dustproof and 0.42 inch OLED screen to show the vaping data clearly. Aegis Boost cartridge maintains two separate mesh coil (0.6ohm / 0.4ohm) to support MTL and DTL vaping. Aegis Boost pod comes with 3.7ml with top filling design.
Original Wotofo OFRF NexMESH Pro Sub Ohm Tank Clearomizer Vape Atomizer original price $34.95, now only $23.99
Original Wotofo OFRF NexMesh Pro Tank Vape Atomizer is an upgraded version of nexMESH Sub Ohm Vape Tank. It is famous as the first mesh coil and parallel coil combo core in the world, which will bring you the ultimate awesome taste. And it features ergonomic 810 Delrin drip tip, convenient top filling system and the most compatible 510 threading connection. Besides, it adopts adjustable bottom airflow so you can choose the flavor and cloud you like. Moreover, compatible with H15 Coil, H12 Coil, H11 Coil and H13 Coil (H15 Coil / H12 Coil included, H11 Coil / H13 Coil not included), you are allowed to obtain DIY fun via H17 RDC (RBA Deck not included). Last but not least, the tank features 4.5ml straight PCTG tube and 6.0ml bubble glass tube when it comes with single coil head, and 3.5ml straight PCTG tube and 5.0ml bubble glass tube when it utilizes dual coil head.
Original Smoant Pasito II 2 V2 Replacement Empty Pod Cartridge(1 PC) $5.99
The Original Smoant Pasito II Pod Cartridge is specially designed for Smoant Pasito II Pod System Vape Kit. It can hold 6.0ml large e-juice capacity, which can guarantee your long-lasting vape. And it features ergonomic 510 drip tip and the most compatible 510 connector. In addition, it adopts convenient side filling system and top airflow design for smooth flavor. Besides, it is compatible with all Pasito and Knight 80 Coils, and the newly designed K3 0.6ohm Half-DTL coil. 1 PC in each pack.
Original Smoant VIKII Pod System Replacement Pod Cartridge(2 PCS) $6.99
The Original Smoant VIKII Replacement Pod cartridge is suitable for Smoant VIKII Pod System Vape Kit. Smoant VIKII Pod cartridge is made of PCTG, and holds 2.0ml capacity with side filling design and 1.2ohm Kanthal wire with tea tree fiber cotton for pure flavor. Smoant VIKII adopts both-side connection design for stable vaping.
Original Smoant Pasito II 2 Pod System Replacement Coil Base(1 PC) $2.99
The Original Smoant Pasito II V2 2 Replacement Base is designed for Smoant Pasito II V2 2 Pod System Vape Kit. With the Smoant Pasito II V2 2 base, Smoant Pasito II V2 2 pods can be compatible with Smoant Pasito 2 coils. The Smoant Pasito II Base is specially designed for Smoant Pasito II Kit / Smoant Pasito II Cartridge. The Smoant Pasito II base is the most part between Smoant Pasito II battery and Smoant Pasito II pod.
Original Smoant Pasito II V2 2 510 Adapter Connector for 510 RDA / RTA / RDTA Sub Ohm Tank $4.99
The Smoant Pasito II V2 2 510 Adapter is suitable for Smoant Pasito II V2 2 Pod System Vape Starter Kit. With this 510 adapter, you can use RDA / RTA / Sub Ohm Tank Vape Atomizer on the Smoant Pasito II V2 2 Pod System.
Original Smoant K-1 Mesh Coil Head for Pasito II / Pasito / Knight 80 Pod System(3 PCS) $6.99
The Original Smoant K-1 0.3ohm Mesh Coil head is applicable to Smoant Pasito II Kit, Pasito Kit and Knight 80 Pod System Vape Kit.
Original Smoant K-2 Dual Mesh Coil Head for Pasito II / Pasito / Knight 80 Pod System(3 PCS) $7.99
The Original Smoant K-2 0.4ohm Dual Mesh Coil Head is applicable to Smoant Pasito II Kit, Pasito Kit and Knight 80 Pod System Vape Kit.
Original Smoant K-3 Half-DTL Mesh Coil Head for Pasito II / Pasito / Knight 80 Pod System(3 PCS) $6.99
The Original Smoant K-3 0.6ohm Half-DTL Mesh Coil Head is applicable to Smoant Pasito II Kit, Pasito Kit and Knight 80 Pod System Vape Kit.
Original Smoant K-RBA Coil Deck for Pasito II / Pasito / Knight 80 Pod System(1 PC) $6.99
The Original Smoant K-RBA Coil Deck is suitable for Pasito II / Pasito / Knight 80 Pod System Vape Starter Kit. The RBA is best for 0.3~2.0ohm.
3FVAPE вне форума   Вверх
Старый 20.08.2020, 06:30 Автор темы   722
3FVAPE
Original Wotofo OFRF NexMESH Pro Tank Replacement H11 Single Conical Coil Head(3 PCS) original price $14.95, now only $7.99
The Original Wotofo H11 Single Conical Coil Head is compatible with Wotofo nexMESH Pro Tank / Wotofo nexM Pro Tank Vape Atomizer. It is a kind of single conical coil with 0.2ohm resistance,
Original Wotofo OFRF NexMESH Pro Tank Replacement H12 Clapton Mesh Coil Head(3 PCS) original price $14.95, now only $7.99
The Original Wotofo H12 Clapton Mesh Coil Head is compatible with Wotofo nexMESH Pro Tank / Wotofo nexM Pro Tank Vape Atomizer. It is a kind of Clapton Mesh coil with 0.2ohm resistance,
Original Wotofo OFRF NexMESH Pro Tank Replacement H13 Single Conical Coil Head(3 PCS) original price $14.95, now only $7.99
The Original Wotofo H13 Single Conical Coil Head is compatible with Wotofo nexMESH Pro Tank / Wotofo nexM Pro Tank Vape Atomizer. It is a kind of Single Conical Coil with 0.15ohm resistance,
Original Wotofo OFRF NexMESH Pro Tank Replacement H15 Single Mesh + Wire Dual Coil Head(3 PCS) original price $14.95, now only $7.99
The Original Wotofo H15 Single Mesh + Wire Dual Coil Head is compatible with Wotofo nexMESH Pro Tank / Wotofo nexM Pro Tank Vape Atomizer. It is a kind of Single Mesh + Wire Dual Coil with 0.15ohm resistance,
Original Wotofo H17 RBA Rebuildable Deck Coil for NexMESH Pro Tank original price $14.95, now only $7.99
This Original Wotofo H17 RBA Rebuildable Deck Coil is perfectly compatible with Wotofo NexMESH Pro Tank Vape Atomizer. The RBA rebuildable deck features honeycomb air intake system and two-post coil securing structure to make rebuilding as easy as pie.
Original Wotofo NexMESH Pro Tank Straight Tank Tube $2.59
This Wotofo NexMESH Straight Tank Tube is made from PCTG with 3.5ml juice capacity. It is designed for Wotofo NexMESH Pro Tank Vape Atomizer.
This Wotofo NexMESH Straight Tank Tube is made from PCTG with 4.5ml juice capacity. It is designed for Wotofo NexMESH Pro Tank Vape Atomizer.
Original Wotofo NexMESH Pro Tank Bubble Tank Tube $2.59
This Wotofo NexMESH Bubble Tank Tube is made from Glass with 5.0ml juice capacity. It is designed for Wotofo NexMESH Pro Tank Vape Atomizer.
This Wotofo NexMESH Bubble Tank Tube is made from Glass with 6.0ml juice capacity. It is designed for Wotofo NexMESH Pro Tank Vape Atomizer.
Original Reewape AS317 510 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $1.49
The Original Reewape AS317 510 Drip Tip is made from stainless steel and is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer.
Старый 21.08.2020, 05:08 Автор темы   723
3FVAPE
Original Timesvape Heavy Hitter Vape Mechanical Mod $70.00
The Timesvape Heavy Hitter Mechanical mod is a made-in-heaven collaboration, designed by Heavy Metal Vapor and TenaciousTXVapes and made by Timesvape, features a gold-plated copper contact and floating battery setting. The Heavy Hitter Mod is a sure win for Mech heads. Three great minds have joined forces to create what could arguably be the toughest affordable mech mod on the market today. The Hard Hitter mechanical mod has excellent features including a 28mm body tapered to 26mm at 510 level to accommodate 26mm atomizers, however, a 28mm top section is easily switched by simply unscrewing the underside contacts is a cup and ball type system which reduces the chance of hot buttons caused by arching as the surface area is greatly increased, all contacts are solid copper with gold plating to not only create greater conductivity but low maintenance. As with all mechanical mods the protections are very minimal, the creators have done what they can to create a safer job with this mod, Delrin lined inserts and a 1/4 turn lock knob come with the risk of short circuit due to un- noticed battery tears (please check all batteries before use) and auto-ignition much less achievable. Heavy Hitter mechanical mod is designed to accommodate 20700 and 21700 batteries (not included), no need to tune for different batteries, battery tuning is self-adjusting to accommodate tolerances in batteries between each brand.
Original Eleaf Pico Compaq 60W VW Pod Mod Kit $38.99
The Original Eleaf Pico Compaq is a newly designed pod mod device, which has a similar style to the Pico series but has some upgrades and innovations on the basis of the original. The exterior of Eleaf Pico Compaq Pod Mod Vape Kit has a beautiful embedded panel, the appearance of a small ergonomic box, which gives you a comfortable and smooth feel when you hold it in your palm. There is a battery cover on the bottom to accommodate a 18650 battery (not included), and fast charging through newly improved the USB Type-C port for faster charging. Eleaf Pico Compaq can fire up to 60 watts of power. The biggest change is that Eleaf Pico Compaq is equipped with a pod on its top, and juice filling through its side or bottom. The design of the pod is to simplify. The new Eleaf Pico Compaq Pod Kit brings you simplicity, versatility, and a stable vaping experience!
Original Rincoe Manto Max 228W Triple AIO TC VW Pod System Kit $30.99
The Original Rincoe Manto Max TC Pod Vape Kit is coming with its powerful functions. The Rincoe Manto Max Kit satisfies most vapers' fantasy of multi-system devices. The Rincoe Manto Max works with dual 18650 batteries (not included), firing to a max output of 228W. The Rincoe Manto Max adopts temperature adjustment function too. The 510 adapter that comes with the package can turn the Manto Max Pod Kit into a dual-18650 Box MOD for 510 threading RDA / RTA / RDTA / Sub Ohm tank Vape Atomizer. When loaded with RDTA cartridges, the Rincoe Manto Max helps users get a better DIY vaping experience. The Rincoe Manto Max features patent MECHMAN chipset for multiple device protections. the high definition 0.96-inch color screen shows all vape data clearly. The Rincoe Manto Max Cartridge has 8.0ml large capacity for ample juice storage.
Original Oumier Voocean 80 80W VW Pod Mod Kit $35.99
Original Oumier Voocean 80 Pod Mod Vape Kit a beautiful new pod kit, with many innovative designs. Inspired by the beauty and form of flowing water. Compact size and polished zinc alloy housing provide a comfortable grip while being easy to carry. Voocean 80 is powered by a single 18650 battery (not included) to achieve a power output range of 5~80W. It is charged through the Micro USB port under the control panel. Open the bottom thread battery cover to replace and install the external battery. In addition, Voocean 80 Kit has an advanced integrated safety mechanism including low power / over-charge / over-temperature protection. The top of the Oumier Voocean 80 Kit is a refillable 4.0ml e-liquid capacity cartridge, made of healthy PCTG material. The pod cartridge has a replaceable drip tip on the top. It uses the bottom-filling juice method, first, removes the pod from the device, and then open the cartridge bottom silicone plug to fill. Voocean 80 Kit comes with two different Plug and Play meshed coils. This includes a 0.8ohm mesh coil and the new 0.2ohm mesh coil rated for 50 to 80 watts. Two types of mesh coil design ensure that the juice is completely atomized, bringing you a better flavor, thick clouds, and a smooth throat. It is your perfect nicotine salt device. The most innovative design of Voocean 80 is its airflow adjustment. Just switch the pods, you can enjoy the maximum or minimum airflow as needed. Airflow adjustment level from 0~10 level. With its innovative airflow control system, Voocean 80 can have excellent flavor and easy cloud production.
Старый 21.08.2020, 05:11 Автор темы   724
3FVAPE
Original OBS Cube-S 80 VW Box Mod + Cube Tank Atomizer Vape Kit original price $55.99, now only $37.99
OBS Cube-S VW Mod Vape Kit consists of Cube-S Mod and Cube Tank. Cube-S VW Vape Box Mod comes with a curved appearance design and is made by new leather material, which make it anti-scratch and anti-perspiration. Designed with the newly upgraded chip, the ignition speed is only 0.001s. 5~80W adjustable power will bring you big clouds and rich flavor. Cube-S Box Mod is powered by external 18650 battery (not included) and adopts Type-C charging. The e-juice capacity is 4.0ml and there is an adjustable air inlet system to offer the optimal flavor with smooth airflow. Two M1 0.2ohm Mesh Coils are included in the package.
Original Rincoe Manto Max 228W Replacement RBA Coil Head Deck(1 PC) $6.99
The Original Rincoe Manto Max 228W Replacement RBA Coil head deck is designed for Rincoe Manto Max 228W AIO Vape Mod Pod Kit for DIY fun.
Original Rincoe Manto Max 228W Replacement Triple Mesh Coil(3 PCS) $8.99
The Original Rincoe Manto Max 228W Replacement Coil head is designed for Rincoe Manto Max 228W AIO Vape Mod Pod Kit. The Rincoe Manto Max 228W Triple mesh coil 0.15ohm for 80~100W.
Original Rincoe Manto Max 228W Replacement Dual Mesh Coil(3 PCS) $7.99
The Original Rincoe Manto Max 228W Replacement Coil head is designed for Rincoe Manto Max 228W AIO Vape Mod Pod Kit. The Rincoe Manto Max 228W Dual mesh coil 0.2ohm for 60~75W.
Original Rincoe Manto Max 228W Replacement Single Mesh Coil(3 PCS) $7.99
The Original Rincoe Manto Max 228W Replacement Coil head is designed for Rincoe Manto Max 228W AIO Vape Mod Pod Kit. The Rincoe Manto Max 228W single mesh coil 0.3ohm best for 50~70W.
Original Rincoe Manto Max 228W Replacement RDTA Vape Pod Cartridge $8.99
Original Rincoe Manto Max 228W Replacement RDTA is designed for Rincoe Manto Max 228W AIO Mod Pod Vape Kit. Rincoe Manto Max 228W RDTA comes with build deck for dual coil building.
Original Rincoe Manto Max 228W Pod Kit Replacement Empty Pod Cartridge(3 PCS) $2.99
The Original Rincoe Manto Max 228W Replacement Empty Pod is designed for Rincoe Manto Max 228W AIO Mod Pod Vape Kit. Rincoe Manto Max Empty Pod comes with visible 8.0ml capacity. Rincoe Manto Max Empty cartridge adopts top-refill design and is compatible with Rincoe Single / Dual / Triple Mesh Coil and RBA deck (not included) for vapor cloud.
Original Rincoe Manto Max 228W Replacement 510 Adapter for 510 RDA / RTA / RDTA Vape Atomizer $2.99
Original Rincoe Manto Max 228W Replacement 510 Adapter is designed for Rincoe Manto Max 228W AIO Vape Mod Pod Kit to be compatible with 510 RDA / RTA / RDTA / Sub Ohm Tank Vape atomizers.
Original Eleaf Pico Compaq Pod Mod Kit Replacement Empty Pod Cartridge(3 PCS) $5.99
The Original Eleaf Pico Compaq Replacement Pod Cartridge is specially designed for the Eleaf Pico Compaq Pod Vape Mod Kit. The cartridge can hold up to 3.8ml of e-liquid and uses a side filling system to fill the pod. All you need to do is pull the plug from the pod cartridge to expose the filling hole. The cartridge is paired with GTL Mesh Coil in a plug-and-play manner from the bottom. The Pico Compaq Pod Cartridge can protect the mouthpiece from dust pollution through the cover cap included with the kit. Eleaf Pico Compaq Pod Cartridge is provided in a practical three-piece package.
Original Eleaf Pico Compaq Replacement GTL Coil Head for Pico Compaq Kit / Pico Compaq Pod Cartridge(5 PCS) $11.99
Original Eleaf Pico Compaq Replacement GTL Coil is a mesh coil head that combines high-quality kanthal mesh wire and organic cotton, suitable for Eleaf Pico Compaq Kit. The resistance is 0.4ohm, and adopt mesh structure, which can have a greater degree of contact with the cotton that absorbs the juice, thereby forming a dense cloud. It designed for direct to lung vaping, with excellent taste and strong vapor emission. Comes in a package of five replacement coils.
Старый 22.08.2020, 04:49 Автор темы   725
3FVAPE
Original OBS Cube-S 80W VW Box Mod $34.99
The Original OBS Cube-S VW Vape Box Mod comes with a curved appearance design and is made by new leather material, which make it anti-scratch and anti-perspiration. Designed with the newly upgraded chip, the ignition speed is only 0.001s. 5~80W adjustable power will bring you big clouds and rich flavor. Cube-S Box Mod is powered by external 18650 battery (not included) and adopts Type-C charging.
El Thunder V4 Vape Mechanical Mod Clone $14.99
The El Thunder V4 Vape Mechanical Mod Clone is constructed from brass and powered by 1 x 18650 / 20700 / 21700 battery (not included). The Mechanical Mod is with spring-loaded fire button.
Original Hippovape B'Adapt 40W RBA VW Pod System Kit $44.99
The Original Hippovape B'Adapt AIO Pod System Vape Pod Kit adopts water-proof chipset for a long-lasting and stable performance. Powered by an external 18350 battery (not included), the Hippovape B'Adapt fires to an adjustable wattage from 1W to 40W. The Hippovape B'Adapt Vape Mod Kit comes with 4 output modes of Power mode, Volts mode, Temperature mode and Bypass mode. You are capable of choosing the suitable mode as you wish. The Hippovape B'Adapt Pod Vape Mod Kit is a rebuildable pod kit for easy single coil building. The dome-shaped chimney is best for MTL vape. You can control the air inlet with the AFC holes at the deck base.
Original AVCTVape 100% Organic Cotton for RDA / RTA / RDTA Vape Atomizer(10 PCS) $3.99
The Original AVCTVape 100% Organic Cotton is great for RDA / RTA / RDTA Vape Atomizer. The cotton is in 10mm diameter and 100mm length, total 10 PCS, The AVCTVAPe ordinary vape cotton is made of 100% Organic Cotton and natural cotton material. Produced in a safe and hygienic environment through a unique purification technology. Remove the impurities of cotton fiber and develop an extremely tasting vape cotton, even reaching medical level. Cotton fully shows the original taste of e-juice, without any other e-juice smell.
Original AVCTVape 20 PCS Shoelace Vape Cotton + 4 PCS Ordinary Cotton for RDA / RTA / RDTA Vape Atomizer $4.99
The Original AVCTVape Vape cotton pack included 20 PCS Shoelace Vape Cotton and 4 PCS Ordinary Cotton. The 100% Organic Cotton is great for RDA / RTA / RDTA Vape Atomizer. The AVCTVAPE shoelace vape cotton is specially designed for keen vaper's only, use 100% natural purified Cotton material. Under safe sanitation environment, after a unique purification progress technology. Remove the impurities of cotton fiber itself, developing an extremely tasted vape cotton, even reached the medical level. While vaping, the shoelace vape cotton completely showed up the e-juice original flavor, no any other smell of the e-juice expressed.
Original VapeSoon Protective Case Sleeve for Voopoo Drag X Pod System Vape Kit $2.59
The Original VapeSoon Protective Case Sleeve is made from silicone and is suitable for Voopoo Drag X Pod System Vape Kit.
Original VapeSoon Protective Case Sleeve for Voopoo Drag S Pod System Vape Kit $2.59
The Original VapeSoon Protective Case Sleeve is made from silicone and is suitable for Voopoo Drag S Pod System Vape Kit.
Original VapeSoon Protective Case Sleeve for GeekVape Aegis Pod System Vape Kit $2.59
The Original VapeSoon Protective Case Sleeve is made from silicone and is suitable for GeekVape Aegis Pod System Vape Kit.
Original VapeSoon Replacement PnP-TM1 Mesh Coil Head for VOOPOO VINCI R/VINCI/DRAG S/DRAG X Vape Kit(20~25W) $7.99
The VapeSoon Replacement PnP-TM1 Mesh Coil Heads is suitable for VOOPOO DRAG X VW Mod Pod Vape Kit as replacement parts. The PnP-VM6 Mesh Coil features 0.6ohm coil resistance that power range from 20W to 25W, and the suggested E-liquid Nicotine < = 35mg. 5 PCS / Pack.
Original VapeSoon Meshwork Mesh Sheet Coil for Mesh RDA / RTA / RDTA Vape Atomizer(10 PCS) $1.99
The Original VapeSoon Meshwork Mesh Sheet Coil is made from Ni80 with 0.17ohm resistance. It is suitable for Mesh RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack:
The Original VapeSoon Meshwork Mesh Sheet Coil is made from Kanthal A1 with 0.2ohm resistance. It is suitable for Mesh RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack:
Старый 24.08.2020, 04:19 Автор темы   726
3FVAPE
Original Lost Vape Gemini Hybrid Pod System Kit $36.00
The Original Lost Vape Gemini Hybrid Vape Kit is a compact pod mod kit that is powered by single 18650 battery (not included) with 80W max. It is designed with 0.96 inch color TFT display screen and you can choose the perfect color in 6 options. It comes with a 2 IN 1 hybrid device: Pod Mode with Ultra Boost Coil Pod, Mod Mode with 510 adaptor for tank (tank not included). The Gemini Hybrid Pod has 4.0ml e-juice capacity and features dual e-liquid viewing window. Gemini Hybrid is compatible with Ultra Boost Coils. The Gemini Hybrid 80W pod mod is easily intuitive used and available to generate tasty clouds. Continuing the meticulously crafted for the best vape experience.
Старый 25.08.2020, 05:03 Автор темы   727
3FVAPE
Original Vapor Storm Puma 200W TC VW Vape Box Mod $32.99
The Original Vapor Storm Puma VW Vape Box Mod has sleek appearance and is versatile with its multiple output modes. Powered by dual high rate 18650 batteries (not included), it is able to reach 200W in wattage mode. In temperature control mode, Puma supports Ni, Ti, SS316 and TCR. In bypass mode, the output can even be higher than 200W and the maximum is 230W. Puma will definitely provide you with different vaping experience.
Original Uwell Crown 3 III Sub Ohm Tank Clearomizer Vape Atomizer original price $24.99, now only $9.99
The Original Uwell Crown 3 III Sub Ohm Tank Clearomizer Vape Atomizer is the modernized rendition of the trendsetting Crown series, elevating the sub-ohm segment with top-tier chassis design featuring 5ml juice capacity, threaded top-fill, and introducing the innovative plug-pull Crown III replacement coils. An improvement in chimney and structural design greatly reduces the amount of e-juice condensation, which diminishes leakage potential. Following in trends with modern power delivery, the 0.25-ohm Crown III SUS316 parallel coil features a wattage range of 80 to 90W, with a 0.5 ohm rated for 70 to 80W. Airflow for the Crown III is arranged in dual air slots configuration around the base of the chassis, providing ample cooling properties throughout the structure. Heralding the newest generation of Crown atomizers, the Uwell Crown III Sub Ohm Tank heralds a class-leading flagship platform.
Original HorizonTech Falcon King Sub-Ohm Tank Clearomizer Vape Atomizer $27.99
The Horizon Falcon King Sub Ohm Tank Vape Atomizer is new version of HorizonTech Falcon series, which features large 6ml E-juice capacity can meet your daily vaping need. Horizon Falcon King Tank adopts durable Pyrex glass and high quality stainless steel material, plus resin drip tip. The refilling design of Falcon King tank is very special, click the button to open top cap. Falcon King Atomizer is compatible with new coils of M-Dual 0.38ohm mech coil and M1+ 0.16ohm mesh coil, which are made of bamboo fiber to bring you better flavor and longer lifespan. Furthermore, Falcon King Tank is able to compatible with all of falcon coils. The Horizon Falcon King Sub-Ohm Tank Atomizer is with massive dual adjustable airflow control and top-filling system for improving leakage protection.
Original Auguse Khaos RDTA with BF Pin $32.99
The Original Auguse Khaos RDTA Rebuildable Dripping Tank Vape Atomizer comes with bottom BF Pin for RDA to be compatible with bottom feeder mod. And comes with standard 510 center pin for RTA.
[Ships from Battery Warehouse] Authentic Listman IMR 18650 2800mAh 30A Flat Top Li-ion Rechargeable Battery(2 PCS) $10.99
The Original Listman IMR 18650 2800mAh 30A Flat Top Li-ion Rechargeable Battery is suitable for Vape Box Mod / Mechanical Mod.
[Ships from Battery Warehouse] Original Listman IMR 18650 3500mAh 30A Flat Top Li-ion Rechargeable Battery(2 PCS) $13.99
The Original Listman IMR 18650 3500mAh 30A Flat Top Li-ion Rechargeable Battery is suitable for Vape Box Mod / Mechanical Mod.
[Ships from Battery Warehouse] Original Listman IMR 20700 4200mAh 30A Flat Top Li-ion Rechargeable Battery(2 PCS) $14.99
The Original Listman IMR 20700 4200mAh 30A Flat Top Li-ion Rechargeable Battery is suitable for Vape Box Mod / Mechanical Mod.
[Ships from Battery Warehouse] Original Samsung INR21700-40T 4000mAh 3.7V Lithium-ion Rechargeable Cell Battery(1 PC) $9.99
The Original Samsung INR21700-40T 4000mAh 3.7V Lithium-ion Rechargeable Cell Battery is suitable for Vape Box Mod / Mechanical Mod.
Старый 25.08.2020, 05:07 Автор темы   728
3FVAPE
Original Hellvape HC01 Ni90 Dual Core Fused Clapton Coil for RDA / RTA / RDTA Vape Atomizer(10 PCS) $4.99
The Original Hellvape HC01 Ni90 Dual Core Fused Clapton Coil is suitable for RDA / RTA / RDTA Vape Atomizer. The Fused Clapton Coil is made with 26GA x 2 + 36GA Ni90 wires
Original Uwell Replacement Coils for Crown III 3 / Crown III 3 Mini Tank Vape Atomizer(4 PCS) $9.99
The Original Uwell Replacement Coils are vertically orientated parallel coils with organic cotton made for the Crown III 3 / Crown III 3 Mini Tank Vape Atomizer. The 0.5ohm resistance is best for 70W to 80W.
Original Uwell UN2 Meshed Coil for Crown III 3 / Crown III 3 Mini Tank Vape Atomizer(4 PCS) $10.59
The Original Uwell Replacement UN2 Meshed Coil are vertically orientated parallel coils with organic cotton made for the Crown III 3 / Crown III 3 Mini Tank Vape Atomizer. The 0.23ohm resistance is best for 65W to 75W.
Original Uwell Replacement Coils for Crown III 3 / Crown III 3 Mini Tank Vape Atomizer(4 PCS) $10.59
The Original Uwell Replacement Coils are vertically orientated parallel coils with organic cotton made for the Crown III 3 / Crown III 3 Mini Tank Vape Atomizer. The 0.25ohm resistance is best for 80W to 90W.
Original Vandy Vape Kylin M Mesh Coil Cotton Laces for RDA / RTA / RDTA Vape Atomizer(10 PCS) $2.99
Vandyvape Kylin M Cotton is inspired by the ever increasing needs of fast cotton preparation for your rebuilding convenience. The cotton we selected are of long fibers so that it wicks smooth and it's not easy to pull apart. It's much easier to thread the cotton through the coils. The Mesh Coil Cotton Laces are sold in a pack of 10. Each lace has a length of 60mm and diameter of 6mm. The cotton is guaranteed without pesticides and conditioned without chemical products.
Original Coil Master B2 Battery Carrier Protective Box for Dual 18650 Battery Cells $1.99
The Coil Master B2 battery carrier is a protective boxes for 18650 sized batteries. Each carrier features a snap lock ensuring your batteries remain secure while you're on the move. The B2 battery carrier is made of high quality polypropylene plastic, the battery carriers will prevent accidental discharge and damage to the batteries while inside. These carriers are a convenient and safe solution to carrying your batteries.
Original Coil Master Stainless Steel + Bent Ceramic Tip Tweezers for E-Cigarettes / RDA / RTA / RDTA Vape Atomizer $4.99
The Coil Master Bent Tip Tweezer can withstand the high temperature when you dry fire your coil. Making coil building so much easier. It is a great and handle tool if you are into rebuildable atomizers.
Original SMOKTech Pyrex Bulb Bubble Glass Tank Tube for SMOK Stick V9 Max Vape Mod Kit $2.59
The SMOK Pyrex Glass Bulb Bubble Tank Tube #8 is suitable for Stick V9 Max Vape Mod Kit. It comes with bulb 8.5ml juice capacity.
ULTON Bilux RBA Clone with PCTG Tank for dotMod dotAIO Pod System Vape Kit $24.99
The ULTON Bilux RBA Clone comes with PCTG Tank is Suitable for dotMod dotAIO Pod System.
Старый 26.08.2020, 04:29 Автор темы   729
3FVAPE
Original Lost Vape Centaurus DNA 250C 200W Mod original price $169.99, now only $123.99
The Lost Vape Centaurus DNA 250C TC VW Box Vape Mod features the high-end Evolv DNA 250C chipset with high accuracy and super-fast response time. It is powered by dual 18650 batteries (Not included), delivers a maximum power of 200W and supports VW / TC (Ni80, Ni90, Ti, SS316, TCR), Custom Curve modes. The device has a handy 0.91 inch TFT display screen to easily read out the essential parameters. Centaurus Mod can be charged via the USB port and includes an adapter that is compatible with the power bank.
Original VOOPOO V.SUIT VW Pod System Kit $29.99
The Original VOOPOO V.SUIT Pod System Vape Kit is equipped with a 1200mAh built-in battery. It integrates the powerful GENE Chip into the main body of V.SUIT to satisfy performance experience. Thanks to the GENE chip, V.SUIT can generate a maximum power of 40 watts. Voopoo V.SUIT pod vape kit integrates a 0.54-inch OLED screen, where you can check the parameter settings and the number of puffs. Of course, V.SUIT is equipped with a new PnP MTL pod, thanks to the new PnP-TR1 and PnP-TM2 Coil, these coils are specifically designed to achieve the purest MTL vaping. V.SUIT PnP MTL Pod has a capacity of 2.0ml, it can also support PnP coils of 0.3ohm and above, whether it is H-DL or MTL, you can find the most suitable choice. In addition to the pods in the package, V.SUIT also supports PnP Pod Cartridge for H-DL vaping.
Original Vaporesso GEN X 220W TC VW Box Mod + NRG-S Tank Vape Kit $79.99
The Original Vaporesso GEN X 220W VW Box Mod Vape, the first vaping device that combines the aircraft-grade aluminum material with CNC machining, brings impressive smooth hand-feel revealing its luxurious gene. Focusing on the details, it gives an extremely simple yet stylish design. By featuring the cutting-edge AXON CHIP and GT mesh coils, the GEN X empowers you a superior vaping experience for every puff consistently.
Original VOOPOO V.THRU Pro Replacement Pod Cartridge with 1.2ohm GENE Helix Coil(2 PCS) $7.99
The VOOPOO V.THRU Pro Pod Cartridge is with 1.2ohm GENE Helix Coil and holds a capacity of 3.0ml, filling from the side. V.THRU Pro Pod also has an independent one-way condensation space inside to prevent leakage. The top mouthpiece of the pod adopts a 360 degree fully-fit design, brings a full range of fitting lip comfort.
Original VOOPOO PnP MTL Pod Cartridge for V.SUIT Kit / DRAG X Kit / DRAG S Vape Kit(2 PCS) $9.99
The VOOPOO PnP MTL Pod cartridge has 2.0ml juice capacity with replaceable coil system. The VOOPOO PnP MTL Pod is best for mouth-to lung vape. You can install the new PnP-TR1 / PnP-TM2 mesh coils (coils not included) in it, and it is also compatible with PNP coil. The VOOPOO PnP MTL Pod is perfect for VOOPOO V.SUIT Kit / VOOPOO DRAG X Kit / VOOPOO DRAG S Kit.
Original VOOPOO V.THRU Pro Replacement Pod Cartridge with 0.7ohm Mesh Coil(2 PCS) $7.99
The VOOPOO V.THRU Pro Pod Cartridge is with Mesh 0.7ohm Coil and holds a capacity of 3.0ml, filling from the side. V.THRU Pro Pod also has an independent one-way condensation space inside to prevent leakage. The top mouthpiece of the pod adopts a 360 degree fully-fit design, brings a full range of fitting lip comfort.
510 Adapter Connector for GeekVape Aegis Boost Plus 40W Pod System Vape Kit $3.99
The 510 Adapter Connector is suitable for GeekVape Aegis Boost Plus 40W Pod System Vape Kit Vape Kit. It can switch your GeekVape Aegis Boost Plus 40W Pod System to a normal box mod to use any 510 thread RTA / RDA / RDTA / Sub Ohm Tank Vape atomizer.
WAVE MTL 510 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $2.99
The KF Wave MTL 510 Drip tip Clone is with diamond lathed surface, extremely smooth for a very comfortable and pleasant vape experience. Compliments the KF Lite, Prime, and Mini V3 nicely but will look amazing on just about any atomizer with a standard 510 drip tip compatible.
Старый 27.08.2020, 04:22 Автор темы   730
3FVAPE
Vapor Storm Subverter 200W Box Mod $40.99
The Original Vapor Storm Subverter Box Mod, powered by dual 18650 batteries (not included), can reach maximum wattage to 200W. The side panels has many geometrical cut-outs and becomes aesthetic pattern. The mod comes with a 0.96 inch colorful display and big fire button. The resistance allowed is from 0.05 to 3ohm (VW), 0.05 to 1ohm (TC).
Vapeasy Meca DIY BF Squonk Mechanical Mod Clone $45.99
The Vapeasy Meca DIY BF Squonk Mechanical Box Mod Clone is constructed from PCTG and stainless steel. You can find with the DIY Box a complete kit with screws and 2 plates. One superior plate for the connection with a One BF connector. It is entirely assembled with insulators and a connection strip. The plate is made in Stainless Steel and the connection strip. The inferior plate is also in Stainless Steel.
Vapeasy Sprint BF RDA Clone $14.99
The Vapeasy Sprint BF RDA Rebuildable Dripping Vape Atomizer Clone is made from 316 stainless steel and comes with white POM 510 drip tip. The Sprint BF RDA Clone is with dual-pole for single coil building. Comes with BF pin, it is ready for Bottom Feeder / Squonker Mod.
VOOPOO PnP-TR1 Regular Coil Head for PnP MTL Pod Cartridge(5 PCS) $12.99
The Original VOOPOO PnP-TR1 Regular Coil Head is with 1.2ohm resistance and is best for PnP MTL Pod Cartridge.
VOOPOO PnP-TM2 Single Mesh Coil Head for PnP MTL Pod Cartridge(5 PCS) $12.99
The Original VOOPOO PnP-TM2 Single Mesh Coil Head is with 0.8ohm resistance and is best for PnP MTL Pod Cartridge.
[Ships from Battery Warehouse] Original HOCO J63 Velocity PD + QC3.0 Wireless Charging Power Bank(5900mAh) $25.99
The Original HOCO J63 Velocity PD + QC3.0 Wireless Charging Power Bank is with large Capacity: 10000mAh 37Wh Rated capacity: 5900mAh. It is convenient to charge your phone wirelessly.
Старый 28.08.2020, 04:28 Автор темы   731
3FVAPE
Original Vaporesso GEN X 220W Box Mod $56.99
Original Vaporesso GEN X 220W Box Mod provides a high-end vape box mod with excellent performance and quality. In terms of appearance, GEN X 220 Vape Box Mod adopts the aircraft-grade aluminum material and CNC machining craftsmanship. In terms of performance, GEN X Mod is powered by dual high-rate 18650 batteries (not included), with a maximum output power of up to 220W, and multiple working modes to meet your different e-cigarette needs. It integrates a fast-charging system and is equipped with a 0.91 OLED screen display. You display the e-cigarette data and charging status clearly. GEN X Mod internally integrates a powerful AXON chip that provides a user-friendly operating system. The Pulse Mode will continuously give vapers a hit throughout the puff (every 0.02s); Power Eco Mode conserves the battery life for even longer-lasting power; Smart TC Mode scans the coil in use and will automatically preset to the recommended degrees Fahrenheit based on the coil material detected. DIY Mode where you can access advanced settings like variable wattage (VW), variable temperature (VT), variable voltage (VV), complete control wattage (CCW), bypass (BP), and super player (SP). Plus, the AXON Chip has all the standard safety protections you want in your vape mod.
C2MNT COSMONAUT V2 RDA Clone with BF Pin $7.99
The C2MNT V2 RDA Vape Atomizer Clone is constructed from Stainless Steel measuring in 24mm diameter. The RDA features postless build deck and top cap heat sink design. It supports signature blade Airflow Control (AFC) and compatible with the Layer Cake deck. The RDA comes with bottom feeder pin for Squonk Ready.
Original Oumier Wasp Nano S Dual-Coil RDA with BF Pin original price $19.99, now only $14.99
The Original Oumier Wasp Nano S Dual-Coil RDA Atomizer is the dual-coil version of the one of the best single-coil WASP NANO RDA. The Oumier Wasp Nano S Dual-Coil RDA is a versatile, fantastic performing RDA that is a strong pick for the vaper looking for an easy build and well-turn vape experience.
ULTON Nibiru MTL / RDL RTA Clone $27.59
The Nibiru RTA Rebuildable Tank Vape Atomizer Clone is constructed from 316 stainless steel and frosted glass tank with 2.7 / 3.1ml capacity. The Nibiru RTA Clone is with single coil building deck and airflow adjustable from 0.8mm to 1.8mm, supports MTL / RDL vaping. Comes with 3 different chimneys.
Sprint BF RDA Clone $12.95
The Sprint BF RDA Rebuildable Dripping Vape Atomizer Clone is made from 316 stainless steel and comes with white POM 510 drip tip. The Sprint BF RDA Clone is with dual-pole for single coil building. Comes with BF pin, it is ready for Bottom Feeder / Squonker Mod.
Original Nevoks Veego Pod System Kit $26.99
The Original Nevoks Veego Pod System Vape Starter Kit is powered by built-in 1100mAh battery, and supports 2A Type-C fast chargingit's fast ignition speed brings you a powerful vaping experience. The most compact structural design, Veego pod cartridge has a special airflow adjustment design, which can meet your different needs for MTL / DTL. The new SPL coil makes the flavor smoother and more enjoyable. And the innovative dust-proof design is also a new surprise for you. Nevoks Veego Pod System Vape Starter kit has an easily adjustable airflow system. Without pulling out pod, adjustable airflow ring at the bottom can be rotated to adjust the input. NEVOKS SPL coil which can make the flavor more smoother and enjoyable. High-quality cotton is synthesized by the optimal proportion. The electric heating wire with mesh structure makes the heating more uniform.
Original Nevoks SPL-11 Regular Coil Head for Nevoks Veego Pod System / Pod Cartridge(5 PCS) $9.99
The Original Nevoks SPL-11 Regular Coil Head is suitable for Nevoks Veego Pod System Vape Kit / Pod Cartridge. The coil is with 1.0ohm resistance and comes with 5 PCS / Pack.
Original Nevoks SPL-11 Mesh Coil Head for Nevoks Veego Pod System / Pod Cartridge(5 PCS) $9.99
The Original Nevoks SPL-11 Mesh Coil Head is suitable for Nevoks Veego Pod System Vape Kit / Pod Cartridge. The coil is with 0.6ohm resistance and comes with 5 PCS / Pack.
Original Nevoks Veego Pod System Replacement Pod Cartridge(2 PCS) $7.99
The Original Nevoks Veego Pod System Replacement Pod Cartridge has a special airflow adjustment design, which can meet your different needs for MTL / DTL. It is compatible with the new SPL coil which makes the flavor smoother and more enjoyable.
Старый 31.08.2020, 04:36 Автор темы   732
3FVAPE
Original Innokin GO S Disposable Tank Vape Atomizer $3.69
The Go S is an MTL - Mouth to Lung disposable atomizer with a built-in 1.6ohm coil and 2.0ml tank capacity. Made of high quality PCTG plastic with high temperatures durability. The Adjustable Airflow System is inserted through the triple inlet provided by the atomizer and with the help of the rotating ring located at the bottom of the atomizer we can precisely adjust it to the level we want.
Original Joyetech Tralus Pod System Kit $29.99
The Original Joyetech Tralus Pod System Vape Starter Kit is constructed from durable Zinc Alloy + PA. It has excellent durability and wear resistance. Tralus Kit has a built-in battery with a capacity of 800mAh. This battery allows you to vape in the power range of 5 to 20 watts. Tralus uses a user-friendly one-key operation mechanism. Only use the fire button on the front of the device to turn on and off the device or adjust the wattage. The power can be adjusted by pressing the fire button three times. Joyetech Tralus Pod Kit comes with a refillable cartridge, features a bottom filling system that can hold 2.0ml of your favorite electronic juice. The Pod cartridge is transparent and fully visible, so you can observe the e-liquid level at any time. Joyetech Tralus pod cartridge is compatible with replaceable EZ Series coil heads to vaporize both nicotine salts and freebase e-juice. The pre-installed 0.6ohm EZ Coil is specially designed for DL, 1.2ohm EZ Coil supports MTL vape. In addition, the Joyetech Tralus Pod vape kit can automatically detect the type of coil used and resistance to match with the output, creating the ideal conditions to maximize the efficiency of the coil.
Original Aleader 510 Drip Tip(10 PCS) $10.99
The Original Aleader 510 Drip Tip is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer. The drip tip is made from stainless steel and resin. 10 PCS / Pack, ships in random color
Original Aleader 510 Drip Tip(10 PCS) $8.99
The Original Aleader 510 Drip Tip is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer. The drip tip is made from resin. 10 PCS / Pack, ships in random color
Original Aleader 810 Drip Tip(10 PCS) $7.99
The Original Aleader 810 Drip Tip is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer. The drip tip is made from resin. 10 PCS / Pack, ships in random color
Original Aleader 810 Drip Tip(10 PCS) $8.99
Original YouDe UD Kanthal A1 Heating Resistance Wire(30 Feet) $2.59
The Original YouDe UD Kanthal A1 heating resistance wire is perfect for RBA / RTA / RDA Vape atomizers. The wire is made from Kanthal A1. It features 26GA gauge and 0.4mm diameter, which will be a good choice for DIY.
Original Hellvape H7-03 Replacement Mesh Coil for Hellbeast Sub Ohm Tank Vape Atomizer(5 PCS) $11.99
The Original HellVape HellBeast Sub Ohm Tank Replacement 0.15ohm Mesh Coils is introduced with the dynamic HellBeast Tank, providing exceptional flavor and cloud production with the 0.15ohm H7-03 Mesh Coils. It also features compatibility with SMOK TFV8 Baby Coils and Vaporesso GT Coils. 5 PCS / Pack.
Старый 01.09.2020, 04:51 Автор темы   733
3FVAPE
Original Vandy Vape Pulse V2 95W Squonk Box Mod original price $64.99, now only $44.93
The Original Vandy Vape Pulse V2 II 95W TC VW BF Squonk Squeeze Vape Box Mod is the latest in the Pulse line, culminating the best aspects of previous versions, and incorporating the same waterproof technology from the Swell Mod. Weve created an excellent bottom fill system for the bottle, that keeps it locked in place, and directly in line with the 510 to eliminate potential issues with plumbing inside the mod to transfer juice from one side to the other. With refined lines and ergonomics, this Pulse has everything youve been asking for!
Armor Mech V2 BF Bottom Feeder Squonk Mechanical Box Mod Clone $52.99
The Armor Mech V2 Mechanical Box Vape Mod Clone is a BF Squonk Mechanical Mod, which comes with side fire button, and custom bottle system. A 24mm inset catch cup surrounds the 510 connector, and an included matching 22mm insert ring allows users to seat either a 22mm or 24mm diameter atomizer into the top plate, or flip the ring for a completely flush mounting surface for larger diameter atomizers and beauty rings.
SXK Sputnik MTL RTA Clone original price $25.90, now only $23.90
The SXK Sputnik RTA Vape Atomizer Clone is an MTL RTA designed to be efficient, simple, functional. The Tank is in polished transparent black PMMA, it has the refill from the bottom and has a capacity of 3.8ml. The Sputnik includes the 6 x 0.6mm Air Disk which guarantees a shot with a range comparable to a 1.2mm hole.
Original Joyetech Tralus EZ Pod System Replacement Empty Pod Cartridge(5 PCS) $13.99
The Original Joyetech Tralus EZ Pod Cartridge is specially designed for Joyetech Tralus Pod System Vape Starter Kit and holds 2.0ml capacity. There is a filling hole on the bottom side of the ink cartridge, which is used to fill the ink cartridge and is closed with a silicone plug to prevent leakage. There is an airflow valve on the side of the cartridge, which can adjust the airflow rate according to personal vaping preference. In addition, the Tralus EZ Pod Cartridge is compatible with the EZ coil series (coils not included), including the newly designed EZ 0.6ohm coil for DL vaping. The bottom press-in connection that makes coil changes incredibly easy and fast.
Original Lost Vape Gemini Hybrid Kit Replacement Empty Pod Cartridge(1 PC) $3.99
The Original Lost Vape Gemini Hybrid Pod System Vape Kit Replacement Pod Cartridge has 4.0ml e-juice capacity and is designed for Vape Gemini Hybrid Pod Kit. Featuring silicone stoppered side fill system and dual e-liquid viewing windows, It is easy and convenient to use. Gemini Hybrid Pod is compatible with Ultra Boost Coils (not included), which will provide you various vaping experience. It is an empty pod cartridge without coil. 1 PC each pack.
Original Golisi S4 2.0A Smart Charger with LCD Screen for 20700 / 26650 / 18650 / NiMH / NiCd Battery $29.99
The Original Golisi S4: the next generation of O-series chargers with 4-slot and 2A fast charging. The S4 Smart Charger features an upgraded micro-processor, enabling the large LCD screen to show functions clearly. Golisi S4 is compatible with 20700, 26650, 18650 Li-ion batteries and nearly all cylinder-shaped rechargeable batteries, even charging different batteries at the same time. Together with a large LCD display and 0.5A / 1.0A / 2.0A output options, the S4 Smart Charger will give you a faster and safer charging experience. This is Aug plug Version
Original Golisi i4 USB Charger with LCD Screen for 18650 / 21700 / 26650 Battery $23.99
The Original Golisi i4 is a latest charger with 4-slot and 2A fast charging. It has a USB power port with DC 5V / 2A power input. What's more, it is compatible with almost all types of cylinder shape rechargeable batteries such as 18650, 21700 and 26650 batteries, even charging different batteries at the same time. Together with a large HD LCD display and 0.5A / 1.0A / 2.0A output options, the i4 Smart Charger will give you a faster and safer charging experience.
Старый 02.09.2020, 04:51 Автор темы   734
3FVAPE
Steam Crave Aromamizer Supreme V3 RDTA Advanced Kit original price $69.99, now only $53.99
Original Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer is an upgraded version of the original series. It follows the previous basic concepts and has some practical improvements, such as honeycomb airflow. Aromamizer Supreme V3 RDTA is a high-quality multifunctional Rebuildable Dripper Tank Atomizer. Aromamizer Supreme V3 RDTA is made of stainless steel and Pyrex glass precisely processed, 25 mm diameter is smaller and easier to use than previous products. The Aromamizer Supreme V3 RDTA has a modular structure, so it can be designed individually, whether it is a 6.0ml or 7.0ml tank glass or an optional deck. It can be used very flexibly and can be converted immediately. It can be used as an RTA or RDA, or it can be equipped with another chimney. A single-coil deck is pre-installed, and fresh air is fed to it from below and from the side, thus ensuring an excellent taste and ample vapor. Compared to its predecessor, the Supreme V3 has an improved airflow, which offers even more options in the DL area and, together with the single-coil deck, gets everything out of the winding. The airflow is installed in a honeycomb design, which can be adjusted continuously in one row, two rows, or three rows. Pre-installed a single-coil deck, and comes with postless deck and mesh deck. The Aromamizer Supreme V3 RDTA is compatible with the decks of the Aromamizer Supreme V2 RDTA.
Steam Crave Aromamizer Supreme V3 RDTA Basic Kit original price $54.99, now only $38.99
Original Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer is an upgraded version of the original series. It follows the previous basic concepts and has some practical improvements, such as honeycomb airflow. Aromamizer Supreme V3 RDTA is a high-quality multifunctional Rebuildable Dripper Tank Atomizer. Aromamizer Supreme V3 RDTA is made of stainless steel and Pyrex glass precisely processed, 25 mm diameter is smaller and easier to use than previous products. The Aromamizer Supreme V3 RDTA has a modular structure, so it can be designed individually, whether it is a 6.0ml or 7.0ml tank glass or an optional deck. It can be used very flexibly and can be converted immediately. It can be used as an RTA or RDA, or it can be equipped with another chimney. A single-coil deck is pre-installed, and fresh air is fed to it from below and from the side, thus ensuring an excellent taste and ample vapor. Compared to its predecessor, the Supreme V3 has an improved airflow, which offers even more options in the DL area and, together with the single-coil deck, gets everything out of the winding. The airflow is installed in a honeycomb design, which can be adjusted continuously in one row, two rows, or three rows. In addition to a single-coil deck. The Aromamizer Supreme V3 RDTA is compatible with the decks of the Aromamizer Supreme V2 RDTA.
Original PILLAR Sprint Pod System Kit $11.99
The Original PILLAR Sprint Pod System Vape Kit brings portability, and this small and compact Pod Kit fits lightly between your fingers. PILLAR Sprint kit is packed with a fixed 400mAh large capacity battery, to help achieve great performance and longer run time. Equipped with Type-C port on the side of the device, only 1 hour for a full charge. Sprint Kit uses intuitive and simple one-button operation. Quickly click the fire button 5 times to turn on / off the device, safe and reliable. Sprint adopt 3.2~4.2V voltage output, for an intense and rich flavor experience, and boasts multiple safety protection features. Sprint Pod Cartridge has an easy-to-access refill system with a juice capacity of 2.0ml. Simple side filling method and internal airflow structure designed to perfect leakproof tendency. Pod bottom airflow intake for smoother airflow and flavor boost.
Original PILLAR Mignon Pod System Kit $9.99
The Original PILLAR Mignon Pod System is an ultra-small and stealthy vape pod with a very stylish and simple appearance and compact structure. The weight of the body is only 16g, and the package comes with a lanyard, which is light and easy to carry. PILLAR Mignon is the world's first refillable rechargeable but seems like a disposable e-cigarette. PILLAR Mignon can be refillable and rechargeable to use which is an all-in-one device. PILLAR Mignon features a 280mAh battery capacity with a micro USB charge port. It is draw activated, just vape without pressing any buttons, enjoy the real cigarette inhaling experience with this easy to use pod system. And the Mignon has multiple security protections to provide a safe and reliable experience. The PILLAR Mignon battery is firmly connected to the refillable pod. The pod has a juice capacity of 1.5ml. Open the silicone plug on the side of the device to refill. The refillable pod integrates an atomizing core and adopts a unique airway design, coupled with a voltage of 3.2~4.2V, which can accurately control the taste of atomization and make you feel unexpectedly fully taste.
SXK Sputnik RTA Replacement Air Disk(2 PCS) original price $6.90, now only $5.50
The Replacement Air Disk is suaible for SXK Sputnik RTA Vape Atomizer Clone. Comes with 2 PCS / Pack, One is 6 x 0.8mm and the other is 4 x 0.6mm.
SXK Tank Tube + Chimney + Top Cap Top Filling Kit for Dvarw FL 22mm RTA original price $12.90, now only $11.50
The SXK Top Filling Kit includes PC Tank Tube and 316 stainless steel Chimney and Top Cap. The tank tube holds 3.5ml capacity and is suitable for 22mm Dvarw MTL FL Facelift RTA Vape Atomizer
SXK Sputnik RTA Clone Replacement Tank Tube + Drip Tip Kit original price $12.90, now only $10.90
The Replacement Tank Tube and Drip Tip Kit is made from Ultem / PEI with 3.8ml capacity. It is suaible for SXK Sputnik RTA Vape Atomizer Clone.
SXK Top Filling Tank Tube Oil Bunker for Dvarw FL 22mm RTA $5.70
The SXK Top Filling Tank Tube Oil Bunker is made from PC with 3.5ml capacity and is suitable for 22mm Dvarw MTL FL Facelift RTA Vape Atomizer.
Старый 03.09.2020, 04:29 Автор темы   735
3FVAPE
Original Asmodus Colossal 80W Box Mod original price $49.99, now only $38.99
The Original Asmodus Colossal 80W Mod is a beast of a single battery mod (BATTERY NOT INCLUDED) that is perfect for when you are on the go. This petite mod features an advanced chipset with a new and improved UI and is sure to impress due to the incredible portability combined with the massive power. The Colossal features a full firing mode suite, including variable voltage, curve mode, temperature control presets for Ni200 nickel, titanium, and stainless steel heating elements as well as adjustable TCR and TFR modes. The Colossal also utilizes an Asmodus developed "battery safe connection" on the positive battery port which provides a safer, more secure connection by encasing the port with a plastic rim which forces the battery to stay in place. A USB port (for firmware updating) has been implemented as well to ensure that your mod is always up to date.
Cthulhu Artemis MTL RTA original price $36.00, now only $29.99
The Original Cthulhu Artemis MTL RTA is a painstaking collaboration from Cthulhu MOD and George Batareykin. The Cthulhu Artemis MTL RTA shows the unique temperament that a real RTA should have. The slender drip tip reminds you all the time that Cthulhu Artemis is a more suitable RTA for MTL vape. The dome-shape chimney of Cthulhu Artemis brings better flavor and throat hit to vapers too. The sturdy 304 stainless steel construction makes Cthulhu Artemis more stable and strong in daily use. The asymmetric posts and 22mm diameter of Cthulhu Artemis provides an easy way for single coil building. Five sizes of airflow holes at the base bottom allow users to freely adjust from 0.8mm to 2.7mm. Meanwhile the Cthulhu Artemis comes with replaceable air pins with different sizes. After free arrangement, users will experience up to 25 airflow settings.
Original Steam Crave Supreme Mesh Deck $11.99
The Original Steam Crave Replacement Supreme Mesh building RBA Deck is made of stainless steel and it is compatible with Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer as a replacement part.
Original Steam Crave Velocity Deck $8.99
The Original Steam Crave Replacement Velocity Style building RBA Deck is made of stainless steel and it is compatible with Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer as a replacement part.
Original Steam Crave Postless Deck $8.99
The Original Steam Crave Replacement Postless building RBA Deck is made of stainless steel and it is compatible with Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer as a replacement part.
Original Steam Crave Single Coil Deck $9.99
The Original Steam Crave Replacement Single Coil building RBA Deck is made of stainless steel and it is compatible with Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer as a replacement part.
Original Steam Crave Aromamizer Supreme V3 Replacement Mesh Shoelace Cotton(10 PCS) $3.99
The Original Steam Crave Aromamizer Supreme V3 RDTA Replacement Mesh Shoelace Cotton is convenient to use.
Original Steam Crave Aromamizer Supreme V3 RDTA Replacement Mesh Strips(10 PCS) $3.99
The Steam Crave Replacement Mesh Strips is made from Kanthal A1 in honeycomb shape with 0.2ohm resistance, and is suitable for Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer
Original Steam Crave Aromamizer Supreme V3 RDTA Replacement Bubble Glass Tank Tube(2 PCS) $6.99
The Steam Crave Bubble glass tank tube holds 7.0ml and is suitable for Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer
Original Steam Crave Aromamizer Supreme V3 RDTA Replacement Straight Glass Tank Tube(2 PCS) $3.59
The Steam Crave straight glass tank tube holds 6.0ml and is suitable for Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer
Original Steam Crave Aromamizer Supreme V3 RDTA Replacement Small Bore 810 Drip Tip $2.99
The Steam Crave Small bore 810 drip tip is made from resin and best for Steam Crave Aromamizer Supreme V3 RDTA Vape Atomizer
Старый 04.09.2020, 06:27 Автор темы   736
3FVAPE
Original Vaporesso Gen S 220W Vape Box Mod $48.99
The Vaporesso Gen S 220W TC VW Variable Wattage Vape Box Mod is powered by 2 x 18650 Batteries (Not included, sold separately) with 220W Max Output. and equipped with 0.91" OLED Screen to display the data of this device for you in detail, and the intelligent AXON chip, GEN S makes advanced devices more accessible to users. GEN S truly realizes the power isn't just for the pros.
AIVAPE Scale MTL RTA original price $40.99, now only $33.99
The Original AIVAPE Scale MTL RTA Rebuildable Tank Vape Atomizer is made from stainless steel in 22mm diameter. Comes with dual glass tank tube to hold 2.0ml / 4.0ml. The Scale MTL RTA with top refilling system and Anti-skid patterns design. With separating side and bottom airflow adjustments for MTL (mouthpiece to lung) vaping. The RTA deck is with dual pole for single coil building.
Original Vaporesso Gen S Mod Kit $60.99
The Vaporesso Gen S Mod Kit consists of Gen S 220W VW Vape Box Mod and NRG-S Tank Atomizer, which is powered by 2 x 18650 Batteries (Not included, sold separately) with 220W Max Output, and equipped with the intelligent AXON chip, GEN S makes advanced devices more accessible to users. Gen S Mod Kit comes with a 8ml glass tube (Pre-installed), a spare 5ml glass tube and two Coils: GT4 Meshed Coil 0.15ohm, 50~75W and GT4 Meshd Coil, 0.18ohm, 50~85W to meet your daily vaping. The GEN S matches an upgraded NRG-S tank with the GT MESHED and GT4 MESHED coils included, keeping giving extra power for every flavor punch. GEN S truly realizes the power isn't just for the pros.
Original Oumier Voocean 80W Replacement Pod Cartridge(1 PC) $4.99
The Original Oumier Voocean 80W Pod Cartridge is design for Voocean 80W Pod System Vape Mod Kit, it is a 4.0ml e-liquid capacity cartridge hat can be refillable. Made from PCTG, the tank is much healthier and hygienic. The pod cartridge is with Magnetic Pod Connection. The pod cartridge gives you better flavor, great clouds and smooth throat hit.
SXK Replacement Top Cap for Flash e-Vapor V4.5S+ RTA original price $6.50, now only $5.50
The SXK Replacement Top Cap is made from PEI and is suitable for Flash e-Vapor V4.5S+ RTA Vape Atomizer.
Старый 05.09.2020, 04:28 Автор темы   737
3FVAPE
Original ULTRONER Alieno Vape Box Mod original price $169.00, now only $159.00
The Original ULTRONER Alieno 60W TC VW Vape Box Mod is made from Stabilized Wood and Stainless Steel. The Alieno box mod Powered by Evolv DNA 60 chipset to supports max. 60W output. The Ergonomic design makes it more convenient to use and supports replacement battery tube (not included). The redesigned top cap adapts to 24mm atomizer
Original ULTRONER Alieno Vape Box Mod original price $139.00, now only $129.00
The Original ULTRONER Alieno 70W TC VW Vape Box Mod is made from Stabilized Wood and Stainless Steel. The Alieno box mod Powered by SEVO-70 chipset to supports max. 70W output. The Ergonomic design makes it more convenient to use and supports replacement battery tube (not included). The redesigned top cap adapts to 24mm atomizer
Original OBS Cube Pro Vape Box Mod original price $49.99, now only $39.99
The Original OBS Cube Pro Box Mod is constructed of Glass & Zinc Alloy with curved trihedral profile for comfortable hand feeling. OBS Cube Pro 80W Box Mod features fingerprint security system and 0.96" high definition colored LED screen to show vaping data clearly. OBS Cube Pro works with built-in 3000mAh battery with max 80W output.
Original OBS Cube Pro Mod Kit original price $59.99, now only $49.99
The Original OBS Cube Pro 80W 3000mAh Vape Starter Kit consists of OBS Cube Pro Mod and OBS Cube Tank. OBS Cube Pro Box Mod is constructed of Glass & Zinc Alloy with curved trihedral profile for comfortable hand feeling. OBS Cube Pro 80W Box Mod features fingerprint security system and 0.96" high definition colored LED screen to show vaping data clearly. OBS Cube Pro works with built-in 3000mAh battery with max 80W output. OBS Cube Sub Ohm Tank, made of SS304, comes with 4.0ml capacity with top filling design and M1 0.2ohm Mesh Coil for huge clouds. OBS Cube adopts adjustable bottom airflow system.
Original ULTRONER Alieno SEVO 70 / DNA 60 Box Mod Replacement Hollow-out 18650 Battery Tube original price $14.90, now only $12.90
The Replacement Hollow-out 18650 Battery Tube is made from Stainless Steel and suitable for ULTRONER Alieno SEVO 70 Box Mod and ULTRONER Alieno DNA 60 Box Mod. Holds 1 x 18650 battery (not included)
Original ULTRONER Alieno SEVO 70 / DNA 60 Box Mod Replacement knurled 18650 Battery Tube original price $14.90, now only $12.90
The Replacement knurled 18650 Battery Tube is made from Stainless Steel and suitable for ULTRONER Alieno SEVO 70 Box Mod and ULTRONER Alieno DNA 60 Box Mod. Holds 1 x 18650 battery (not included)
Старый 07.09.2020, 04:30 Автор темы   738
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original ULTRONER Alieno 70W Vape Box Mod original price $139.00, now only $129.00
Original ULTRONER Alieno 60W Vape Box Mod original price $169.00, now only $159.00
Ukeri Brave Pod System Kit $16.99
Original Ukeri Brave 40W Pod System Vape Starter Kit is a lightweight and smart All-in-one device with a smooth and integrated body, compact structure, and unique integrated mouthpiece design. Power by a 1500mAh built-in battery, it can provide a long-lasting vaping experience, and max output power can be up to 40W, which can provide a powerful vaping effect for you. There is a large intuitive activation button on the control surface, a TFT screen, a pair of adjustment buttons, and the Micro USB port at the bottom. The Ukeri Brave Pod System Vape Kit integrates a refillable pod with a capacity of 3.5ml. It can be easily refilled with juice through the filling port on the back of the cartridge. And the pod cartridge adopts a transparent design to check the remaining e-liquid. There are air holes on the side of the device, and the adjustment module can be slid up and down to adjust the airflow. You can make appropriate adjustments according to your needs to get comforted with every inhalation. It is compatible with four different types of coils, providing high-quality performance and flavor satisfaction.
Ukeri Brave Replacement Empty Pod Cartridge $3.99
The Original Ukeri Brave Replacement empty Pod Cartridge is a set of crafted 3.5mL pods engineered for the Ukeri Brave Pod System Kit, featuring a pod-based airflow control switch. With side filling design, you can easily fill the e-juice in one step without disassembling the cartridge. And the transparent design makes every drop of e-liquid visible. Brave Pod is equipped with an airflow control switch that can meter the inlet airflow, which allows you to adjust the amount of airflow to get comforted with every inhalation. The pod cartridge is compatible with Ukeri V1 / V2 / S1 / S2 Mesh Coil (coils not included) to bring an excellent flavor experience.
Original Ukeri V1 Mesh Coil Head for Brave / Magik Pod System Vape Starter Kit(5 PCS) $7.99
The Original Ukeri Brave Mesh Coil is compatible with Brave Pod System Vape Starter Kit and Magik Pod System Vape Starter Kit. The 0.3ohm V1 Mesh Coil is with 20W to 50W power range and best at 35W. The coil comes with 5 PCS / Pack.
Original Ukeri V2 Mesh Coil Head for Brave / Magik Pod System Vape Starter Kit(5 PCS) $7.99
The Original Ukeri Brave Mesh Coil is compatible with Brave Pod System Vape Starter Kit and Magik Pod System Vape Starter Kit. The 0.6ohm V2 Mesh Coil is with 15W to 25W power range and best at 22W. The coil comes with 5 PCS / Pack.
Original Ukeri S1 Mesh Coil Head for Brave / Magik Pod System Vape Starter Kit(5 PCS) $7.99
The Original Ukeri Brave Mesh Coil is compatible with Brave Pod System Vape Starter Kit and Magik Pod System Vape Starter Kit. The 0.3ohm S1 Mesh Coil is with 20W to 50W power range and best at 35W. The coil comes with 5 PCS / Pack.
Original Ukeri S2 Mesh Coil Head for Brave / Magik Pod System Vape Starter Kit(5 PCS) $7.99
The Original Ukeri Brave Mesh Coil is compatible with Brave Pod System Vape Starter Kit and Magik Pod System Vape Starter Kit. The 0.6ohm S2 Mesh Coil is with 15W to 25W power range and best at 22W. The coil comes with 5 PCS / Pack.
Старый 08.09.2020, 05:31 Автор темы   739
3FVAPE
SXK Monarchy J3S MTL RTA Clone original price $28.90, now only $25.90
The SXK Monarchy Monarch J3S MTL RTA Rebuildable Tank Vape Atomizer Clone is made from 316 Stainless Steel and PCTG tank with 22mm diameter and holds 2.5ml capacity. The SXK Monarch J3S MTL RTA Clone is with single coil deck and bottom airflow control for MTL vaping.
Kizoku Limit MTL RTA Renaissance Edition $32.99
The Original KIZOKU Limit MTL RTA Vape Atomizer is an innovative RTA with e-juice capacity of 3ml. The Limit RTA is designed with child lock on top and the valve leak structure in the slot for the convenience and efficiency. And it is a single-coil RTA that can be easily operated. You can also have fun of DIY coils with the tool bag. The airflow adjustment only makes the flavor and clouds flexible for MTL / DL vaping. With the stainless steel material, it will be your best RTA for brilliant vaping. The Renaissance Edition of Kizoku Limit MTL RTA, which is inherits from the Limit MTL RTA. The Kizoku Limit MTL RTA Renaissance Edition adds the European classic floral design to pay homage to the European classic and give you a great visual enjoyment. And the Renaissance Edition of Kizoku Limit MTL RTA comes with the extra tank accessories, such as drip tip, top cap and tube made of brand-new PCTG materials, that makes more easier to use and brings you more vaping fun. Featuring the advanced processing technology of stainless steel and the child-lock design on the top cap without oil leakage, the Renaissance Edition of Kizoku Limit MTL RTA will bring you more incredible vaping pleasure.
Original KIZOKU Limit Vape Atomizer Replacement Coil Heads(5 PCS) $7.99
The Original KIZOKU Limit Replacement KCL1 0.7ohm Coil head is made for KIZOKU Limit MTL RTA Original Edition and Renaissance Edition. Featuring advanced bass material with chrome plated, the KIZOKU Limit Coil is easy to clean and durable to use. And the Limit KCL1 coil possesses a unique inner structure making the e-juice penetrate into cotton easily and providing the purer flavor.
The Original KIZOKU Limit Replacement KCL1 1.8ohm Coil head is made for KIZOKU Limit MTL RTA Original Edition and Renaissance Edition. Featuring advanced bass material with chrome plated, the KIZOKU Limit Coil is easy to clean and durable to use. And the Limit KCL1 coil possesses a unique inner structure making the e-juice penetrate into cotton easily and providing the purer flavor.
3FVAPE вне форума   Вверх
Старый 09.09.2020, 04:41 Автор темы   740
3FVAPE
Hcigar E-Pod Pod System Kit $14.99
The Original Hcigar E-Pod Pod System Vape Starter Kit is a small and powerful device that makes vape easier and brings excellent MTL experience. Hcigar E-Pod Pod System is constructed from 304 stainless steel and the pod cartridge made of PCTG, safe, durable, and not easy to corrode. Lightweight and portable appearance provide a comfortable hand grip and easy operation. E-Pod is equipped with a 650mAh rechargeable battery to meet daily vape power consumption. It has a button-less design and uses a draw-activated firing mechanism to provide a simpler way of vape and freely enjoy the vaping taste. Moreover, it adopts 3.2V constant voltage output that is more matched with nicotine salt. At the top is a magnetically connected 2.0mL pod cartridge, offering an integrated coil design, presenting a leakproof pod construction, holding the e-juice within the 2.0mL pod cartridge, refillable via hidden fill ports disguised by the mouthpiece cover. The cartridge is filled with double holes, the air pressure is more stable, and the e-liquid is filled more smoothly. E-Pod pod Cartridge also uses fish lips design nozzle to fit your lips better. The 0.8ohm Mesh coil is integrated inside the cartridge, which can maximize the e-liquid taste and bring excellent MTL vaping.
Hotcig Kubi Tank Atomizer / Pod Cartridge for Kubi Stick Kit $6.99
The Original Hotcig Kubi Stick Tank / pod cartridge comes with easy refilling system. Featuring leakage-proof design and food grade material, the Hotcig Kubi Stick Tank brings a superior vaping experience to you. Compatible with Hotcig Kubi Stick Coil (not included). 1 PC each pack.
Hotcig Kubi Stick Kit / Pod Cartridge Replacement Magnetic Cap $2.59
The Original Hotcig Kubi Stick Magnetic Cap is made of high-quality food grade materials. The Kubi Stick Magnetic Cap is designed for Hotcig Kubi Stick Kit / Hotcig Kubi Stick Pod Cartridge. It is easy to clean and install.
Hotcig Coil Head for Kubi Pod System Vape Kit(5 PCS) $8.99
The Original replacement coil is suitable for Hotcig Kubi Stick Pen Starter Kit. The Hotcig Kubi Stick Coil features 1.2ohm for better vaping. Comes with 5 PCS / Pack.
Время генерации страницы 0.43872 секунды с 15 запросами
