302497
822
681
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original SMOKTech SMOK Mag 40W 1300mAh VW Pod System Kit $31.99
The Original SMOKTech SMOK Mag Pod is the magic combo of Mag and Pod Mod that brings more experiences you want. It selects the best traits of the Mag series and refines it into this superb pod mod. It is equipped with a built-in 1300mAh battery and comes standard with two RPM coils offering the best flavor and excellent vapor production. It's pod cartridge comes with replaceable 510 drip tip and two RPM coils for the best flavor. Mag Pod ingenious childproof top refill cap adopted in the top-filling system, simplifies the filling process and ensures a safe. ![]() Original Asmodus Dachi 2-in-1 80W VW Pod System Kit original price $49.99, now only $29.99 The Original Asmodus Dachi 2-in-1 80 VW Mod Pod System Vape Starter Kit supports wattage adjustable from 5.0W to 80W. The pod Cartridge holds 4.0ml capacity and comes with 3 coils: 0.5ohm: 25~35W / 1.2ohm: 10~15W / 0.15ohm: 40~50W. ![]() Original Asmodus Dachi 2 in 1 Pod Mod Vape Kit Replacement Coil Heads - 0.15ohm(5 PCS) $12.99 Original Asmodus Dachi 2 in 1 Pod System Mod Vape Kit Replacement Coil Heads is with 0.15ohm resistance and supports 40~50W. 5 PCS / Pack ![]() Original Asmodus Dachi 2 in 1 Pod Mod Vape Kit Replacement Coil Heads - 0.5ohm(5 PCS) $11.99 Original Asmodus Dachi 2 in 1 Pod System Mod Vape Kit Replacement Coil Heads is with 0.5ohm resistance and supports 25~35W. 5 PCS / Pack ![]() Original Asmodus Dachi 2 in 1 Pod Mod Vape Kit Replacement Coil Heads - 1.2ohm(5 PCS) $11.99 Original Asmodus Dachi 2 in 1 Pod System Mod Vape Kit Replacement Coil Heads is with 1.2ohm resistance and supports 10~15W. 5 PCS / Pack ![]() Original SMOKTech SMOK Mag 40W Pod System Kit Replacement Empty RPM Pod Cartridge(3 PCS) $6.99 The Original SMOK Mag Replacement Empty RPM Pod Cartridge is suitable for SMOK Mag 40W 1300mAh Pod System vape Kit. SMOK Mag features top-refill design with childproof push cap to prevent oil leakage and two airflow channels for more air and huge vapor. SMOK Mag cartridge comes with replaceable 510 drip tip and 3.0ml capacity with visible oil level window.
682
SXK Holy Atty Patibulum Unleashed MTL RTA Clone(Replica) original price $25.90, now only $23.90
SXK Holy Atty Patibulum Unleashed MTL RTA rebuildable tank vape atomizer Clone is made from 316 stainless steel and PEI tank, in 22mm diameter and holds 3.5ml capacity. The SXK HolyAtty Patibulum Unleashed MTL RTA Clone is with dual posts deck for single coil building. The single coil deck and redesigned chamber is dedicated to pure MTL use (indirect inhalation). The airflow system is hidden under the atomizer. The airflow of the Unleashed no longer having separate bearings, will be adjusted more finely than on its predecessor, still thanks to an air-disk ranging from 0.6mm to slightly more than 2.5mm opening. The air outlet located under the coil has 3 holes of 1.2 mm. ![]() Original SMOKTech SMOK Novo X 25W 800mAh VW Pod System Kit $25.98 The Original SMOK Novo X, which is a stylish and ergonomic pod system powered by an 800mAh battery. It has an adjustable power range of 1~25 watts and uses two 2.0ml 0.8ohm MTL pods, allowing you to obtain a satisfying throat hit. The Novo X adopts a small power button and OLED display to present a fresh look and offer more possibilities worth exploring. ![]() Original G-Taste Mesh Sheet Coil for GeekVape Zeus X RTA(10 PCS) $1.99 The Original G-TASTE Mesh Sheet Coil is suitable for GeekVape Zeus X RTA. Compared to the original Zeus mesh coil, 0.16ohm round grid mesh coil,whose grid are smaller, which creates purer and denser flavors than the original one. And the wicking process will be much easier since theres no serrated edges, so there wont be any stuck cotton. With the installation of G-taste Mesh coil, youll be able to explore the taste world more deeply and freely. ![]() Original G-Taste Mesh Sheet Coil for GeekVape Zeus X RTA(10 PCS) $1.99 The Original G-TASTE Mesh Sheet Coil is suitable for GeekVape Zeus X RTA. Compared to the original Zeus mesh coil, 0.18ohm hexagon grid mesh coil,whose grid are smaller, which creates purer and denser flavors than the original one. And the wicking process will be much easier since theres no serrated edges, so there wont be any stuck cotton. With the installation of G-taste Mesh coil, youll be able to explore the taste world more deeply and freely. ![]() Original GAS Mods Kree 24 RTA Replacement Tank Tube $2.69 The Original GAS Mods Kree 24 RTA Replacement Tank Tube holds 3.5ml capacity.
683
Original GAS Mods Kree 24 RTA Replacement Tank Tube $2.99
The Original GAS Mods Kree 24 RTA Replacement Tank Tube holds 5.5ml capacity. ![]() Original SMOKTech SMOK Novo X Pod System Kit Replacement Pod Cartridge with DC 0.8ohm MTL Coil(3 PCS) $8.33 The Original SMOK Novo X 2.0ml replacement pod is designed for SMOK Novo X pod system vape starter kit, Comes with a dual-coil DC MTL 0.8ohm pod, allowing you to enjoy top level MTL vaping with satisfying throat hit. The pod has a capacity of 2.0ml and boasts a versatile design that suits all preferences. ![]() Original SMOKTech SMOK Novo X Pod System Kit Replacement Pod Cartridge with Meshed 0.8ohm Coil(3 PCS) $8.83 The Original SMOK Novo X 2.0ml replacement pod is designed for SMOK Novo X pod system vape starter kit, Comes with a single-mesh 0.8ohm pod, with Largest heating area and supports Excellent flavor and dense vapor. The pod has a capacity of 2.0ml and boasts a versatile design that suits all preferences. ![]() Original YDDZ 510 Thread Adapter Connector for Billet / SXK BB 70W / DNA 60W Box Mod Vape Kit $6.99 The YDDZ A1 510 Thread Adapter Connector is designed for Billet / SXK BB 70W / DNA 60W Box Mod Vape Kit as a replacement part, which is made from POM (Black Part) and Stainless Steel (Silver Part). With this 510 adapter, you can use 510 atomizer (RTA / RDA / RDTA / Tank) on your Billet / SXK BB 70W / DNA 60W Box Mod Vape Kit. ![]() Replacement Top Cap Tank Tube for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer $5.99 The Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Top Cap Tank Tube is made from PMMA. The tank holds 2.0ml capacity. ![]() Replacement Top Cap Tank Tube for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer $5.99 The Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Top Cap Tank Tube is made from PMMA. The tank holds 3.5ml capacity. ![]() Replacement Top Cap Tank Tube for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer $5.99 The Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Top Cap Tank Tube is made from PMMA. The tank holds 5.0ml capacity.
684
Original Coiland MTL RDTA $34.90
The Original Coiland RDTA Vape Atomizer s a repairable atomizer made of 316L stainless steel designed for a MTL single coil mouth-to-lung vaping mode. The Coiland RDTA construction deck is double post and has an adjustable airflow port located on top of the RDTA that draws air directly into the deck allowing direct contact with the resistance. Going even further in depth with the Coiland, this atomizer measures 24mm in base diameter, allowing compatibility with most, if not a wide variety of vaping mods on the market. The Coiland can be filled with liquid E through a friction fit top cap. This top fill design and can accommodate a maximum of 2.0ml with the straight glass tank section pre-installed. Airflow can enter the RDTA through a single adjustable airflow port located in the top cap section of the atomizer. This air flow control port measures 2mm in diameter and can be closed completely. For a better flavor, the control includes 4 air discs (0.8 / 1.2 / 1.5 / 2.0). ![]() Original Steam Crave Hadron 220 VW Box Mod + Ragnar RDTA Atomizer Premium Combo Limited Edition Vape Kit original price $182.90, now only $135.99 The Steam Crave Hadron 220 Mod, adopted the innovative YiHi SX480 chipset, is powered by Dual 18650 / 21700 batteries (Not included) with a maximum output power of 220W. The large OLED screen displays pertinent vaping data, including power output, battery life, puff, flavor mode, etc. Detailed and simple user interface. The Hadron 220 Mod is perfect match with Aromamizer Plus, Glaz V2 and other atomizers with diameter from 25mm to 35mm. The Steam Crave Aromamizer Ragnar RDTA is constructed from Stainless Steel (body) and Glass (tank tube) in 35mm Diameter. The RDTA comes with a postless deck with bottom honeycomb air holes. The smooth airflow system can provide you a medium and high power vaping, which supports 80% side airflow and 20% bottom airflow. As for the chamber reducer, it is actually a deck adaptor, with this adaptor, you can use mesh deck of Aromamizer Plus, and you can also use other decks of Aromamizer Plus like Postless Deck, Series Deck, Velocity Deck, and Single Coil Deck.(Not included) But, we recommend that you choose MESH DECK to get a good vaping experience! The RDTA comes with 22mm wide bore 810 drip tip and a large E-liquid tube of 18ml Capacity. It is worthy to say that Ragnar RDTA is perfect match with HADRON 220 MOD. ![]() Original VOOPOO PnP Pod Tank + PnP Empty Pod Cartridge $14.39 The Original VOOPOO PnP Pod Tank comes with PnP Empty Pod Cartridge and PnP-VM1 coil: 0.3ohm (40~60W) / PnP-VM6 coil: 0.15ohm (60~80W) in 4.5ml. And the PnP pod tank is Compatible with All PnP Coils. ![]() Original VXV Soulmate RDTA / RDA Pod Cartridge for Vaporesso Target PM 80 & SE Pod System original price $14.99, now only $12.99 The Original VXV Soulmate RDTA / RDA Pod Cartridge come with RDTA tank (5.0ml) and RDA top cap. It has a flavorful and removable easy building single coil RDTA Pod, unscrew the deck, it will be a 510 adapter. It is suitable for Vaporesso Target PM 80 & SE Pod System ![]() Original VXV Soulmate RDTA / RDA Pod Cartridge for SMOKTech Fetch Pro Pod System original price $14.99, now only $12.99 The Original VXV Soulmate RDTA / RDA Pod Cartridge come with RDTA tank (5.5ml) and RDA top cap. It has a flavorful and removable easy building single coil RDTA Pod, unscrew the deck, it will be a 510 adapter. It is suitable for SMOKTech SMOK Fetch Pro Pod System ![]() Original VXV Soulmate RDTA / RDA Pod Cartridge for VOOPOO Drag S / VOOPOO Drag X Pod System original price $14.99, now only $12.99 The Original VXV Soulmate RDTA / RDA Pod Cartridge come with RDTA tank (3.5ml) and RDA top cap. It has a flavorful and removable easy building single coil RDTA Pod, unscrew the deck, it will be a 510 adapter. It is suitable for VOOPOO Drag S / VOOPOO Drag X Pod System
685
Taifun GX MTL/DL RDTA Clone(Replica) $21.99
The Taifun GX MTL/DL RDTA Clone is constructed from 316 Stainless Steel and Glass material in 23mm Diameter featuring a flavour-focused interchangeable air flow system, easy-build coil winding deck, and SS liquid feeder cables to quickly deliver liquid to the deck down to every last drop in your tank. It also features a modular structure that allows the build deck to be removed from the lower tank and airflow section to allow easy user access to the wicks and the changeable air disks. Moreover, the RDTA supports MTL vaping and DL vaping experience and comes with 4ml E-juice capacity glass tank tube. ![]() Original Steam Crave Aromamizer Ragnar RDTA original price $82.99, now only $61.13 The Steam Crave Aromamizer Ragnar RDTA Advanced Kit includes Ragnar basic kit, 25ml glass tube with extension chimney, mesh deck kit and velocity deck. Steam Crave Aromamizer Ragnar RDTA, is a self-winding tank atomizer with 35mm diameter and 18ml large capacity. Aromamizer Ragnar RDTA is compatible with Steam Crave Aromamizer plus decks(mesh deck and velocity deck included) for different DIY fun due to chamber reducer. Steam Crave Aromamizer Ragnar features adjustable smooth bottom and side airflow for medium or high power vaping (80% side airflow and 20% bottom airflow). Aromamizer Ragnar adopts postless deck with bottom honeycomb air holes. The Steam Crave Aromamizer Ragnar RDTA is constructed from Stainless Steel (body) and Glass (tank tube) in 35mm Diameter. The RDTA comes with a postless deck with bottom honeycomb air holes. The smooth airflow system can provide you a medium and high power vaping, which supports 80% side airflow and 20% bottom airflow. As for the chamber reducer, it is actually a deck adaptor, with this adaptor, you can use mesh deck of Aromamizer Plus, and you can also use other decks of Aromamizer Plus like Postless Deck, Series Deck, Velocity Deck, and Single Coil Deck.(Not included) But, we recommend that you choose MESH DECK to get a good vaping experience! The RDTA comes with 22mm wide bore 810 drip tip and a large E-liquid tube of 18ml Capacity. ![]() Holy Atty Patibulum Unleashed MTL RTA Clone(Replica) $13.99 Holy Atty Patibulum Unleashed MTL RTA rebuildable tank vape atomizer Clone is made from 316 stainless steel and PEI tank, in 22mm diameter and holds 3.5ml capacity. The HolyAtty Patibulum Unleashed MTL RTA Clone is with dual posts deck for single coil building. The single coil deck and redesigned chamber is dedicated to pure MTL use (indirect inhalation). The airflow system is hidden under the atomizer. The airflow of the Unleashed no longer having separate bearings, will be adjusted more finely than on its predecessor, still thanks to an air-disk ranging from 0.6mm to slightly more than 2.5mm opening. The air outlet located under the coil has 3 holes of 1.2 mm. ![]() Original Innokin Coolfire Z50 50W 2100mAh VW Box Mod Vape Kit with Zlide Tank $47.99 The Original Innokin Coolfire Z50 VW Kit With Zlide Tube Tank with simple and elegant appearance. The Innokin Coolfire Z50 is the next generation in the internationally bestselling line of Innokin CoolFire vaporizers. And the Innokin Coolfire Z50 Kit comes with large 2100mAh inbuilt battery which provide the high power vaping for you. And the Innokin Coolfire Z50 possesses the 6.0-50.0W adjustable power system. In addition, Innokin Coolfire Z50 Mod is designed for real life that is easy to use with great buttons and a bright OLED screen. You can get 1A fast charging with micro USB and possesses integrated safety protections. The Innokin Zlide Tube Tank comes with the child safety locking system design, and the Innokin Zlide Tube is easy to fill without leakage. With Innokin's bestselling Z-Coils: 1.2ohm coil and 0.8ohm coil for long-lasting life and amazing flavor. And the Innokin Zlide Tube Tank is easy to refill without mess. Just get the Innokin Coolfire Z50 device and enjoy the fantastic vaping. ![]() Replacement 810 Drip Tip for RDA / RTA / RDTA $2.59 The 810 Drip Tip is made from resin (mouthpiece) and stainless steel (connector base) and suitable for RDA / RTA / RDTA Vape Atomizer. ![]() Replacement 810 Drip Tip for SMOK TFV8 & TFV12 / RDA / RTA / RDTA $2.99 The 810 Drip Tip is made from resin and suitable for RDA / RTA / RDTA Vape Atomizer. ![]() Replacement 810 Drip Tip for RDA / RTA / RDTA $3.59 The 810 Drip Tip is made from resin (mouthpiece) and stainless steel (connector base) and suitable for RDA / RTA / RDTA Vape Atomizer. ![]() Replacement 510 Drip Tip for RDA / RTA / RDTA Vape Atomizer(10 PCS) $7.99 The 510 Drip Tip is made from Random resin and is suitable for RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack ![]() Replacement 810 Drip Tip for RDA / RTA / RDTA Vape Atomizer(10 PCS) $7.99 The 810 Drip Tip is made from Random resin and is suitable for RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack ![]() Replacement 810 Drip Tip for SMOK TFV8 & TFV12 / RDA / RTA / RDTA Vape Atomizer(10 PCS) $14.99 The 810 Drip Tip is made from Random resin and is suitable for SMOK TFV8 & TFV12 / RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack ![]() Original VOOPOO Replacement PnP-TM1 Mesh Coil Head for VOOPOO VINCI R/VINCI/DRAG S/DRAG X Vape Kit(5 PCS) $13.85 The VOOPOO Replacement PnP-TM1 Mesh Coil Heads is suitable for VOOPOO DRAG X VW Mod Pod Vape Kit as replacement parts. The PnP-VM6 Mesh Coil features 0.6ohm coil resistance that power range from 20W to 25W, and the suggested E-liquid Nicotine < = 35mg. 5 PCS / Pack. ![]() Original Yachtvape Pandora MTL RTA Replacement Stainless Steel Screws + Silicone O-Rings $0.99 he stainless steel and silicone O-Rings are Suitable for Yachtvape Pandora 30 Plus Airflow Combinations MTL RTA Rebuildable Tank Vape Atomizer. |
686
Original Vape Master Aurora 200W VW Box Mod original price $49.99, now only $24.99
The Original Vape Master Aurora 200W Box Mod is crafted by Wotofo in collaboration with Rig Mod, presenting a high-performance set-up with a powerful three-mode output device with instant firing speed and 200W of maximum power. Creatively designed by Rig Mod combined with the manufacturing capability of Wotofo, the Vape Master Aurora 200W Box Mod presents a fully streamline designed device with stealth firing bar and adjustment button. At the centerpiece of the device lies a 1.3" Full-Color OLED Display, combined with a 7-Color LED Light-Up functionality for a3 futuristic impression. The internal chipset features maximum 200W of power, combined with ultra fast ramp up speed and three output modes - Standard, Powerful, and Powerful+. ![]() Original Augvape VX217 217W TC VV VW Box Mod original price $49.90, now only $38.99 The Augvape VX217 Mod Kit consists of VX217 TC VV VW Box Mod is constructed from durable and sturdy Zinc Alloy material, which is impact resistant and withstands a certain degree of collision. The VX217 is powered by Dual 21700 Batteries and it is also compatible with 20700 and 18650 batteries. (18650 / 20700 / 21700 Batteries are not included). It's upgraded from VX200. With all relevant circuit protection, it also supports 1.2A current fast charging through Type-C port. In terms of output, the maximum output power of VX217 is 217W. Similarly, the VX217 mod will reach 12V and can emit 0.05~3ohm. It's safe to say this is the first mod that can reach 12V. So when you use high ohm coil in a big rebuildable atomizer, you can get the fast and powerful output as well. There are several Modes: Variable Wattage, Variable Voltage, Temperature Control, and Bypass user modes you can choose from. VX217 is equipped with a 1.3-inch color screen with 240 x 240RGB resolution and offers hundreds of color options. The UI simulates the car dashboard which is cool and beautiful. You can read vape time, mode, wattage, voltage, resistance, batteries life. VX217 Kit uses a minimalist design, canceling plus and minus buttons, can using spin button matches with the UI of the screen. ![]() Dvarw MTL FL Facelift RTA Clone with 11 x Air Inserts + 2 x Spare Tanks $22.99 Dvarw MTL FL Facelift RTA atomizer Clone is constructed from stainless steel in 22mm diameter and 5ml capacity. The Dvarw FL RTA contains an improved base, which now allows easy attachment of Clapton spirals. The single coil base itself allows you to experiment with an inexhaustible number of different builds and tune the taste expression exactly according to you. Dvarw MTL FL Facelift 5.0ml RTA Clone has a diameter of 22mm and is supplied airflow insert 1.2mm for classic style puff-mouth lungs. The Airflow AFC Inserts comes with 11 PCS and size in 1 x 0.8mm, 1 x 1.0mm, 1 x 1.2mm (pre-installed), 1 x 1.5mm, 1 x 2.0mm, 2 x 0.8mm, 2 x 1.2mm, 2 x 1.5mm, 2 x 2.0mm, 3 x 0.6mm, 3 x 0.8mm, 3 x 1.0mm. ![]() Dvarw MTL FL Facelift RTA Clone with 11 x Air Inserts $14.99 Dvarw MTL FL Facelift RTA atomizer Clone is constructed from stainless steel in 22mm diameter and 5ml capacity. The Dvarw FL RTA contains an improved base, which now allows easy attachment of Clapton spirals. The single coil base itself allows you to experiment with an inexhaustible number of different builds and tune the taste expression exactly according to you. Dvarw MTL FL Facelift 5.0ml RTA Clone has a diameter of 22mm and is supplied airflow insert 1.2mm for classic style puff-mouth lungs. The Airflow AFC Inserts comes with 11 PCS and size in 1 x 0.8mm, 1 x 1.0mm, 1 x 1.2mm (pre-installed), 1 x 1.5mm, 1 x 2.0mm, 2 x 0.8mm, 2 x 1.2mm, 2 x 1.5mm, 2 x 2.0mm, 3 x 0.6mm, 3 x 0.8mm, 3 x 1.0mm. ![]() Original Footoon Aqua Master V2 RTA original price $29.99, now only $14.99 Footoon Aqua Master V2 RTA is a step up to the previous Aqua Master. Measuring 24mm in diameter, it can hold up to 4.5ml of e-juice. Thanks to its innovative build deck, you can build the coil without any pain. In addition, the Aqua Master V2 features a revolutionary new airflow design, the Interchangeable Flow System, which will bring you smoother vaping experience and enhance flavors. This RTA is compatible with Aqua Reboot and Aqua Master Tank section. ![]() Original Footoon Aqua Master RTA original price $29.99, now only $14.99 The Original Footoon Aqua Master RTA is a 24mm diameter RTA with beautiful stylish designs, which also comes with a standard 2.6ml glass tube and 4.4ml bubble tube. Besides, it can compatible with Footoon Aqua Reboot juice tank section. With the big 24mm build deck, it has enough space that easy to build coils. The revolutionary new airflow design of Aqua Master RTA is piston flow system that provide smoothest airflow and best taste for users. ![]() Original Civanpor Atena RDA with BF Pin original price $29.99, now only $13.99 The Original Civanpor Atena RDA is a 24mm rebuildable squonking atomizer constructed from POM (cap) and 316 stainless steel (base). It features dual post build deck and has quad terminals for easy building. The RDA comes with side airflow for great flavor and massive clouds. ![]() Original SMOKTech SMOK RPM 2 80W 2000mAh VW Pod System Kit $33.99 The SMOKTech SMOK RPM 2 80W 2000mAh VW Variable Wattage Pod System Vape Mod Kit strikes a good balance in the RPM series, presenting full-fledged technology with excellent visual sensation. It's powered by a built-in 2000mAh battery and can reach a maximum output of 80W. The RPM 2 uses two mesh coils designed for both DL and MTL vaping styles. Its unprecedented 7.0ml e-liquid capacity makes RPM 2 stand out from all pod mods. With a firing speed of 0.001s and a stable USB-C, RPM 2 brings vape to a new and high level. Innovation keeps changing the vaping experience! ![]() Original Vapefly TGO 70W 2300mAh VW Pod System Kit $59.99 The Original Vapefly TGO 70W Pod System Vape Mod Kit is built-in 2300mAh Battery and supports variable wattage from 5W to 70W. The TGO mod is with fingerprint technology to ensure the privacy of the mod, others cannot use it without your permission. The Pod cartridge is with top refilling system for easier use and leakproof. Comes with 0.3ohm and 0.6ohm mesh coil. The TGO mod will automatically match the best wattage for different coils. There are 3 directions adjustable airflow to provide excellent flavor. ![]() Original Vapefly TGO Pod System Mod Replacement Mesh Coil Head - 0.3ohm(5 PCS) $12.99 The Original Vapefly TGO Pod System Mod Replacement Mesh Coil Head comes with 5 PCS / Pack in 0.3ohm. The TGO mod will automatically match the best wattage for different coils. 3 directions adjustable airflow provide excellent flavor.
687
Original Vapefly TGO Pod System Mod Replacement Mesh Coil Head - 0.6ohm(5 PCS) $12.99
The Original Vapefly TGO Pod System Mod Replacement Mesh Coil Head comes with 5 PCS / Pack in 0.6ohm. The TGO mod will automatically match the best wattage for different coils. 3 directions adjustable airflow provide excellent flavor. ![]() Original Vapefly TGO Pod System Mod Replacement Pod Cartridge(1 PC) $3.99 The Original Vapefly TGO Pod System Mod Replacement Pod Cartridge holds 4.5ml capacity. The pod cartridge is with top refilling system for easily use and leakproof, with child lock design for safe use. ![]() Original SMOKTech SMOK RPM 2 Empty Pod Cartridge for RPM 2 80W Pod Mod Kit(3 PCS) $7.99 The Original SMOKTech RPM 2 Empty Pod Cartridge is suitable for RPM 2 80W Pod System Vape Mod Kit with 7.0ml capacity and side refilling system. ![]() Replacement 510 Drip Tip for Dvarw MTL FL Facelift RTA $1.99 The Replacement 510 Drip Tip is made from POM and is suitable for Dvarw MTL FL Facelift RTA Vape Atomizer and other 510 compatible atomizers.
688
Original Damn Vape Wotan Mesh Sub Ohm Tank Vape Atomizer original price $30.99, now only $23.99
The Original Damn Vape Wotan Mesh sub ohm Tank is a DIY featured sub ohm tank, and provide variable airflow setting to bring DIY pleasure (honeycomb airflow / Restricted airflow / full airflow). Honeycomb airflow creates outstanding flavor. Innovative series Clapton mesh coil (single mesh 0.3ohm and Clapton mesh 0.3ohm) for new level vaping experience, Comes with dual glass tank (5.5ml / 2ml). ![]() Original Wotofo Profile RDTA/RDA with BF Pin original price $39.99, now only $32.99 Wotofo x Mrjustright1, THE PROFILE! Yes, we are now introducing to you our new Profile member, the Profile RDTA! Being the RDTA version of the popular Profile RDA, the Profile RDTA is sure to live up to you flavor chasers' expectations. It improves RDTA juice transfer from bottom to top by using 4 stainless steel wicks, and it can be used with single wire coil setup, dual wire coil setup and mesh coil of course. ![]() SXK Nibiru MTL/RDL RTA Clone(Replica) original price $27.90, now only $26.50 The SXK Nibiru RTA Rebuildable Tank Vape Atomizer Clone is constructed from 316 stainless steel and frosted glass tank with 2.7 / 3.1ml capacity. The SXK Nibiru RTA Clone is with single coil building deck and airflow adjustable from 0.8mm to 1.8mm, supports MTL / RDL vaping. Comes with 3 different chimneys ![]() Original Reewape AS315 810 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $1.59 The Original Reewape AS315 810 Drip Tip is made from stainless steel and carbon, and it is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer. ![]() Original Reewape AS316 510 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $1.59 The Original Reewape AS316 510 Drip Tip is made from stainless steel and carbon, and it is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer. ![]() Original Damn Vape Wotan Vape Atomizer Replacement Straight Glass Tank Tube $1.89 The Straight Glass Tank Tube is suitable for Authentic Damn Vape Wotan Sub Ohm Tank Vape Atomizer, it holds 2.0ml capacity. ![]() Original Damn Vape Wotan Vape Atomizer Replacement Bubble Glass Tank Tube $1.99 The Bubble Glass Tank Tube is suitable for Authentic Damn Vape Wotan Sub Ohm Tank Vape Atomizer, it holds 5.5ml capacity. ![]() Original Damn Vape Wotan Vape Atomizer Replacement Clapton Mesh Coil Head - 0.3ohm(3 PCS) $9.39 The Original Damn Vape Wotan Replacement 0.3ohm Clapton Mesh Coil is Innovative series Clapton mesh coil for new level vaping experience. Comes in 0.3ohm for 75~85W. Comes with 3 PCS / Pack. ![]() Original Damn Vape Wotan Vape Atomizer Replacement Single Mesh Coil Head - 0.3ohm(3 PCS) $8.59 The Original Damn Vape Wotan Replacement 0.3ohm Single Mesh Coil in 0.3ohm for 75~85W. Comes with 3 PCS / Pack. ![]() Original VOOPOO RTA Pod Cartridge for Drag X & Drag S Pod System Vape Mod Kit $17.99 The Original VOOPOO RTA Pod Cartridge is the rebuildable tank atomizer version of the PnP Pod Tank. The difference with the latter is that VOOPOO RTA Pod does not have a 510 base, but there is a build deck of regular RTA inside. The VOOPOO RTA Pod has a diameter of 26mm and a capacity of 2.0ml. The RTA pod cartridge is with bottom refilling system. The adopted RBA deck of VOOPOO RTA Pod is a dual-post building deck for single coil, mounting the coil leads within the open terminals. You can install the RTA Pod on the VOOPOO PnP Pod Tank Base and switch it to a 510 thread RTA Tank. The VOOPOO RTA Pod is suitable for the VOOPOO Drag X / Drag S Pod System Vape Mod Kit. Through the pod's internal dual air intake and infinite airflow system, the airflow is ventilated around the internal single coil structure to produce a dense and delicious vapor cloud. ![]() Original BMI Replacement Mesh DTL Coil Head for Asvape Micro Pod Kit - 0.5ohm(5 PCS) $14.99 The BMI Mesh DTL coil features 0.5ohm resistance. The BMI Micro Mesh DTL coil is specially designed for Asvape Micro Pod Kit. ![]() Original Reewape RUOK RBA Coil Head for SMOK Nord / SMOK RPM Nord Pod / Blitz Realm / SMOK Fetch Mini / Dovpo Peaks $5.99 The Reewape RUOK RBA Coil is perfectly compatible with the hot-selling pod: SMOK Nord pod / SMOK RPM Nord pod (RPM40) / SMOK Fetch mini Nord pod / Volta AIO kit / Blitz Realm kit / SMOK Vape Pen / SMOK Trinity pod / Hotcig Marvel pod / Oukitel Mate / Oukitel Bison / Dovpo Peaks / Lusty Nevoks / Nikola Antares as a replacement RBA coil. It fits for most of DIY vaping lovers. You can enjoy the DIY pleasure and it brings you massive vapor and purer flavor. ![]() Original Reewape RUOK Replacement RBA Coil Head with 510 Connector Adapter for Voopoo VINCI / VINCI X Pod System Kit $4.99 The Reewape Ruok RBA Coil is specially designed for DIY lovers, it comes with two-post build deck and single coil building design. It is perfectly compatible with the Voopoo VINCI and VINCI X Mod Pod System Vape Kit.
689
Original Steam Crave Aromamizer Ragnar RDTA Advanced Kit original price $82.99, now only $61.13
The Steam Crave Aromamizer Ragnar RDTA Advanced Kit includes Ragnar basic kit, 25ml glass tube with extension chimney, mesh deck kit and velocity deck. Steam Crave Aromamizer Ragnar RDTA, is a self-winding tank atomizer with 35mm diameter and 18ml large capacity. Aromamizer Ragnar RDTA is compatible with Steam Crave Aromamizer plus decks(mesh deck and velocity deck included) for different DIY fun due to chamber reducer. Steam Crave Aromamizer Ragnar features adjustable smooth bottom and side airflow for medium or high power vaping (80% side airflow and 20% bottom airflow). Aromamizer Ragnar adopts postless deck with bottom honeycomb air holes. The Steam Crave Aromamizer Ragnar RDTA is constructed from Stainless Steel (body) and Glass (tank tube) in 35mm Diameter. The RDTA comes with a postless deck with bottom honeycomb air holes. The smooth airflow system can provide you a medium and high power vaping, which supports 80% side airflow and 20% bottom airflow. As for the chamber reducer, it is actually a deck adaptor, with this adaptor, you can use mesh deck of Aromamizer Plus, and you can also use other decks of Aromamizer Plus like Postless Deck, Series Deck, Velocity Deck, and Single Coil Deck.(Not included) But, we recommend that you choose MESH DECK to get a good vaping experience! The RDTA comes with 22mm wide bore 810 drip tip and a large E-liquid tube of 18ml Capacity. ![]() Original Steam Crave Aromamizer Ragnar RDTA Replacement Glass Tank Tube(2 PCS) $4.22 The Original Steam Crave Aromamizer Ragnar RDTA Vape Atomizer Replacement Glass Tank Tube holds 25ml capacity and comes with 2 PCS / Pack. ![]() Original Steam Crave Aromamizer Ragnar RDTA Replacement 25ml Glass Tank tube + Chimney Conversion Kit(2 PCS) $5.87 The Original Steam Crave Aromamizer Ragnar RDTA Conversion Kit includes 2 PCS 25ml capacity glass tank tube and 1 chimney. ![]() Original Wotofo NexMESH Clapton Mesh Sheet Coil Wire for Mesh RDA / RTA / RDTA Vape Atomizer(5 PCS) original price $9.99, now only $4.99 The Original nexMESH Clapton NI80 + KA1 in 0.20ohm. The Claptonized mesh or the mesh-style Clapton you could say. Creative meshing with quality wire, more contact surface for e-liquid, and mixed Clapton heating features, all of these just make the nexMESH Clapton a unique bad boy for huge vapor and amazing flavor. ![]() Original SMOKTech SMOK RPM160 RDTA Pod Cartridge for SMOK RPM160 Pod System Vape Kit $12.99 The Original SMOK RPM160 RDTA Pod is SMOK's first rebuildable dripping tank atomizer style pod cartridge, with a 5.5ml capacity, easy to fill, just open the large silicone plug on the front of the pod cartridge, and do not need to worry about leakage. Compared with RPM160 Pod, there is still sufficient capacity to accommodate your favorite electronic juice for long-term vaping. But the main difference is that it now can uses rebuildable coils as opposed to other disposable coils. At the top, it comes equipped with a wide bore 510 drip tip that's pretty much geared to direct lung vaping. RPM160 RDTA Pod cartridge has a two-post build deck inside, which can be used for dual-coil building. Easy to build. Furthermore, it has two air inlets that allow the air to pass from the bottom of the coil to the top, maximizing the performance of vapor and flavor. Use SMOK RPM160 RDTA Pod cartridge to build your own coil, enjoy your vaping!
690
Original Innokin LiftBox Bastion System Vape Box Mod original price $49.99, now only $20.99
The Innokin Bastion LIFT Box Mod Siphon System is the first vaporizer upgraded with the LIFT Siphon system. Designed for style and convenience, the LIFTBOX has an 8.0ml integrated glass tank and the LIFT Siphon system that automatically saturates coils with every puff. Convenient and clean vaping. Simply fill the internal tank, attach an RDA with a bottom feed pin, prime the coils, squeeze the side-firing button, vape & enjoy. Featuring a replaceable side panel and durable carbon fiber side finish, the LIFTBOX is crafted with premium quality materials and only available in limited numbers. Power up your coils with the LIFTBOXs unregulated output and enjoy the freedom to create unique vaping experiences from 0.1ohm and above builds. The LIFTBOX is powered by a replaceable 18650 battery (not included) that can be charged via micro USB, or with an external charger, and the LED indicates the remaining power level. Safe vaping is a priority and the LIFTBOX incorporates battery safety protections including short circuit, low voltage, reverse polarity and a 0.08ohm cutoff. ![]() Original Blitz Lung RTA original price $26.99, now only $18.99 The Original Blitz Lung RTA has the transparent atomizer cap for seeing the working conditions of the heating plate, wire and cotton conveniently. Multiple airflow adjustment mode: the inner central airflow whose size can be adjusted in the range of 3.0mm / 2.0mm / 1.5mm / 1.0mm; and the external bottom airflow which has 4 sizes for option. ![]() Haar RTA Clone(Replica) $17.69 The Haar RTA Clone is a 22mm rebuildable tank atomizer, which supports Single coil building, it is compatible with MTL and DL styles and can contain up to 4.0ml of e-liquid with top filling. The airflow is versatile and has a spectrum from slightly restrictive DL (direct lung) to a slightly open MTL (mouth to lung). ![]() Original Vaporesso Barr 13W 350mAh Pod System Kit $20.99 VAPORESSO BARR Pod System Kit, Having the modern design and well-developed MESH pod in its slim body, it surprises you with the outlook and taste, with the entry-level vaping experience required only to master it. Also, the innovative airflow system allows you to adjust the amount of vapor in a simple, secure, and mess-free way. With VAPORESSO BARR, making your daily vaping more than the satisfaction of taste, but a smart way to express your stylish status. ![]() Original TRX Xyrus X3 Mechanical Mod + RDA Atomizer Vape Kit original price $74.99, now only $29.99 The Original TRX Xyrus X3 Mech Mod kit contains a Mechanical Mod and RDA Vape Atomizer. The Mechanical Mod is constructed from stainless steel and copper with side fire button. The fire button is with lock function for safety use. The RDA is in 24mm diameter and dual-pole deck for single coil building. With airflow adjustable from the middle. ![]() Original Listman F2 2A Dual-Slot Charger for 22650/ 18650 / 14500 / 18350 / 14650 / 18500 / 16340 / 17500/18700 $6.99 The Listman F2 2A Charger is compatible with Li-ion: 26650, 22650, 18650, 14500, 18350, 14650, 18500, 16340, 17500, 18700 Batteries. The Operation Temperature of F2 2A Charger are range from 0'C to 40'C. The LED indicator can show you if the batteries are full or not. This is USB Plug.
691
Original Aspire Nautilus Prime Pod System Replacement RBA Coil Build Deck $10.99
The Original Aspire Nautilus Prime RBA Coil is designed for Aspire Nautilus Prime vape Kit. It features a simple structure, which will provide easy building and amazing performance. More flexibility can be obtained with it. ![]() [Ships from Battery Warehouse]Original Listman IMR 18650 3000mAh 40A Flat Top Li-ion Rechargeable Battery for Mod(2 PCS) $11.99 The Original Listman IMR 18650 3000mAh 40A Flat Top Li-ion Rechargeable Battery is suitable for Vape Box Mod / Mechanical Mod. comes with 2 PCS / Pack. ![]() [Ships from Battery Warehouse] Original Listman IMR 20700 3400mAh 40A Flat Top Li-ion Rechargeable Battery for Mod(2 PCS) $14.99 The Original Listman 20700 3400mAh 40A Flat Top Li-ion Rechargeable Battery is suitable for Vape Box Mod / Mechanical Mod. comes with 2 PCS / Pack. ![]() [Ships from Battery Warehouse]Original Listman IMR 21700 3800mAh 40A Flat Top Li-ion Rechargeable Battery for Mod(2 PCS) $14.99 The Original Listman IMR 21700 3800mAh 40A Flat Top Li-ion Rechargeable Battery is suitable for Vape Box Mod / Mechanical Mod. comes with 2 PCS / Pack. ![]() Original Listman L1 2A USB Charger for 14650, 16340, 16650, 17650, 17670, 18350, 18500, 18650, 20700, 21700, 22700 battery $7.99 The Original Listman L1 2A Battery Charger is with USB port for USB charging. It is compatible 10440 / 14500 / 14650 / 16340 / 16650 / 17650 / 17670 / 18350 / 18490 / 18500 / 18650 / 20700 / 21700 / 22700 / 26650 / 26700 battery type AA / AAA / A / C / SC / F6 Ni-MH / Ni-Cd battery. ![]() Original Listman L2 2A USB Charger for 14650, 16340, 16650, 17650, 17670, 18350, 18500, 18650, 20700, 21700, 22700 battery $8.99 The Original Listman L2 2A USB Charger is with dual slot for dual batteries charge at the same time and convenient to use with USB port. It is compatible 10440 / 14500 / 14650 / 16340 / 16650 / 17650 / 17670 / 18350 / 18490 / 18500 / 18650 / 20700 / 21700 / 22700 / 26650 / 26700 battery type AA / AAA / A / C / SC / F6 Ni-MH / Ni-Cd battery. ![]() Original Listman L4 2A USB Charger for 14650, 16340, 16650, 17650, 17670, 18350, 18500, 18650, 20700, 21700, 22700 battery $12.99 The Original Listman L4 2A USB Charger is with Quad-slot for 4 batteries charge at the same time and convenient to use with USB port. It is compatible 10440 / 14500 / 14650 / 16340 / 16650 / 17650 / 17670 / 18350 / 18490 / 18500 / 18650 / 20700 / 21700 / 22700 / 26650 / 26700 battery type AA / AAA / A / C / SC / F6 Ni-MH / Ni-Cd battery.
692
Original Lost Vape Ultra Boost X MTL / DL Sub Ohm Tank Vape Atomizer Clearomizer $29.99
The Original Lost Vape Ultra Boost X Tank is an innovative sub ohm tank. Featuring the innovative design of 4.0ml large capacity and high nic-salt e-liquid compatibility, it delivers a much more satisfying and bold experience for MTL vapers. This revolutionary Ultra Boost X tank features a top refilling system and leak proof design, bringing as much convenience as possible. In addition, Ultra Boost X Tank comes with innovative airflow intake on the bottom, supporting intake-adjustable airflow for both DL and MTL vaping. By turning the AFC ring all the way to the right, the two MTL AF intake hole will appear and then just enjoy the MTL vaping to your preference. It is also compatible with Ultra Boost Series Coils and suitable for high nic-salt e-liquid. At the top of the tank is the replaceable 510 drip tip, and two types of drip tips are available including 510 DL Drip Tip and 510 MTL Drip Tip. Optional coils plus airflow adjustment will create perfect DL vaping and MTL vaping. ![]() SXK Big Blind MTL RTA Clone(Replica) original price $25.90, now only $23.90 The SXK Big Blind MTL RTA Rebuildable Tank Vape Atomizer Clone is constructed from 316 stainless steel and PEI tank. The SXK Big Blind MTL RTA Clone with dual-pole from single coil building. The SXK Big Blind MTL RTA Clone is with 4 fixed air holes to give the airflow to the center quickly. ![]() YFTK Nextiny RDA Clone(Replica) $23.99 The YFTK Nextiny RDA Clone is a rebuildable dripping vape atomizer with 22mm diameter. It is made from 316 Stainless Steel. Hope this RDA will bring you good vaping experience. ![]() Original Lost Vape BTB 100W Box Mod + Ultra Boost X Tank Vape Starter kit $59.99 The Original Lost Vape BTB 100W Starter Kit, Powered by a single 18650 battery (not included) and the Quest chipset, the portable and durable BTB (Back to Basic) is capable of instantly firing up to 100W and supporting SS / TI / NI in Temperature Control Mode. The compact design is paired with the large 4.0mL capacity UBX Sub-Ohm Tank, coming with MTL Airflow intake-adjustable airflow for DL and MTL. It is also compatible with Ultra Boost Series Coils and Suitable for high Nic-Salt E-liquid MTL. ![]() Original Joyetech eGo 1000mAh Pod System Kit $13.70 The Original Joyetech eGo Pod Kit redefines the simplified way of vaping: comfortable, easy to operate, and portable. Joyetech eGo Pod Kit is the smallest and lightest starter kit that is user-friendly to new vapers, only 47g weight and only 98mm height. When you put it in your pocket, you will not feel its existence at all. With a durable stainless steel body, Joyetech eGo Pod Kit is powered by a 1000mAh built-in battery and charged via the side micro USB port. Just directly inhale to activate the device without clicking a button, its ready for vaping anytime. The lightweight body internal is equipped with Avatar IC 1.0 chip, creatively integrating the input and output into one circuit. It brings more consistent constant voltage, lower power consumption, and more reliable performance. Meanwhile, the eGo Pod, a worry-free use of equipment, provides a variety of safety protections. Joyetech eGo Pod Cartridge has a 2.0ml capacity with a childproof filling system, you can finish the liquid replenishment from the bottom quickly. Integrated with 1.2ohm coil, consistent flavor through 7 x 2ml coil's lifespan can be got successfully. Whats more, Joyetech eGo Pod kit comes with a 12ml e-liquid bottle this time. And the eGo Pod can be used with Freebase, Nicotine, or Nic Salt perfectly. ![]() Steam Tuner Bell Cap Tank Tube Clone for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer - 2.0ml $5.99 The Steam Tuner Bell Cap Tank Tube Clone is suitable for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer. The bell cap is made from PMMA and holds 2.0ml capacity. ![]() Steam Tuner Bell Cap Tank Tube Clone for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer - 3.5ml $5.99 The Steam Tuner Bell Cap Tank Tube Clone is suitable for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer. The bell cap is made from PMMA and holds 3.5ml capacity. ![]() Steam Tuner Bell Cap Tank Tube Clone for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer - 3.5ml $5.99 The Steam Tuner Bell Cap Tank Tube Clone is suitable for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer. The bell cap is made from PMMA and holds 5.0ml capacity. ![]() SXK Bell Cap Tank Tube for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer - 2.0ml $5.70 The SXK Bell Cap Tank Tube is suitable for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer. The bell cap is made from PC and holds 2.0ml capacity. ![]() SXK Bell Cap Tank Tube for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer - 3.5ml $5.70 The SXK Bell Cap Tank Tube is suitable for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer. The bell cap is made from PC and holds 3.5ml capacity. ![]() SXK Bell Cap Tank Tube for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer - 5.0ml $5.70 The SXK Bell Cap Tank Tube is suitable for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer. The bell cap is made from PC and holds 5.0ml capacity.
693
Original asMODus Anani V2 MTL RTA original price $30.99, now only $23.99
The Original asMODus ANANI V2 MTL RTA, a single coil rebuildable tank vape atomizer geared for nicotine salt, it comes with 2.0ml e-juice capacity PEI tank, top filling system design and threaded airflow diffuser. Made of stainless steel, this MTL tank is more impact-resistant. the Anani V2 RTA is an MTL tank made take full advantage of your regulated devices that have been shelved. Under the build deck is a large juice reservoir that allows the juice to flow effortlessly to the 2 bored out holes on the build deck. Forged of stainless steel alongside with ultem, the Anani V2 MTL RTA has more impact-resistant build for us clumsy vapors. ![]() Original YDDZ T1 MTL RTA $22.99 The YDDZ T1 MTL RTA is constructed from Stainless Steel (body), PC Tube (Pre-installed), Glass Tube (Spare), and PC Drip Tip in 16mm Diameter. The tank tube features 2ml E-juice capacity. The YDDZ T1 MTL RTA comes with a Single Coil Build Deck with Dual Side Posts, which supports Top Refilling System and Dual Bottom Airflow Adjustments. ![]() Original Joyetech eGo Pod Kit Replacement Pod Cartridge with 1.2ohm Coil(5 PCS) $12.20 The Original Joyetech eGo Pod Cartridge is specially designed for Joyetech eGo Pod vape Kit. It has a capacity of 2.0ml and adopts an anti-leakage TFTA structure and childproof filling system. It is safer to use, without worrying about liquid leakage and children's misoperation. You can finish the liquid replenishment from the bottom quickly. Built-in 1.2ohm coil, plus wide-caliber cigarette holder, bring a comfortable MTL vaping experience. And the Joyetech eGo Pod can be used with Freebase, Nicotine, or Nic Salt perfectly. ![]() Original Vaporesso Barr Pod System Kit Replacement Pod Cartridge with 1.2ohm Mesh Coil(2 PCS) $6.99 The Original Vaporesso Barr Pod Cartridge is specially designed for Vaporesso Barr Pod Vape Kit. It comes with 1.2ml e-juice capacity. Fill the liquid by opening the side silicone plug. The pods are integrated with a 1.2ohm mesh coil, which can provide an ideal flavor. The really pleasant moment is to adjust the airflow by rotating around the axis of the Barr Pod, with four airflow level controls, from tight to looser airflow, to define personal vape mode according to your own needs. 2 PCS / Pack. ![]() Original Uwell Crown IV 4 Sub Ohm Tank Vape Atomizer Replacement Drip Tip $3.99 The Original Uwell Crown IV 4 Drip Tip is made from high grade and heat resistant resin. Designed for long term use, the durable material is impact resistant and designed to keep your vaping experience as pain-free as possible. this drip tip is good for the Uwell Crown 4 IV tank vape atomizer. ![]() SXK Nibiru MTL/RDL RTA Vape Atomizer Clone Replacement Glass Tank Tube $1.90 The Replacement Glass Tank Tube is suitable for SXK Nibiru MTL/RDL RTA Vape Atomizer Clone. ![]() SXK Tank Tube + Top Cap + Drip Tip Opped Kit for Holy Atty Patibulum Unleashed MTL RTA Clone original price $9.90, now only $8.90 The SXK 3-in-1 Kit includes PC Tank Tube, Stainless Steel Top Cap and PC Drip Tip. It is suitable for SXK Holy Atty Patibulum Unleashed MTL RTA Clone.
694
Vapeasy Stealth Project Elite 70W TC VW Box Mod Clone(Replica) $59.99
The Vapeasy Stealth Project Elite Vape Box Mod Clone is constructed from POM and Stainless Steel material. The Vapeasy Stealth Project Elite Vape Box Mod Clone is compatible with 25mm max atomizer diameter. (Not included, sold separately). The mod is built-in 70W chipset and supports wattage adjustable from 5W to 70W, temperature control (200~600'F / 100~300'C). Only one batch, limited quantity. ![]() Original FreeMax Fireluke 22 Sub Ohm Tank Vape Atomizer Clearomizer $29.99 The Original Fireluke 22 Tank utilizes FreeMax COILTECH 4.0 with SS904L Mesh and Tea Fiber Cotton formula. With 0.5ohm DTL Mesh Coil and 1.0ohm & 1.5ohm MTL Mesh Coil, its compatible with both freebase as well as salt nicotine e-liquids for both DTL and MTL vaping needs. The child-proof top fill design and leak-proof mechanism is also added to the tank for convenience and safety. The FreeMax Fireluke 22 Tank is 22mm in diameter. The FreeMax Fireluke 22 Tank comes with bulb 3.5ml capacity and straight 2ml juice storage for selection. The FreeMax Fireluke 22 Tank adopts child-proof top fill design for easy refill. The leak-proof mechanism ensures a convenient vape too. ![]() Original Suorin AIR UL 16W 400mAh Pod System Kit $24.99 The Original Suorin AIR UL Pod system vape Kit is a new all-in-one device with a modern mode. It comes with a 400mAh battery and 2.0ml cartridge. The Suorin AIR UL features on-off switch, indicator light and refilling design. It is a good choice for you to carry anywhere and everywhere. ![]() Original FreeMax Twister 30W 1400mAh VW Mod + Fireluke 22 Tank Vape Starter Kit $53.45 The FreeMax Twister 30W VW Kit is a stylish vape pen kit. Powered by 1400mAh inbuilt battery, the FreeMax Twister 30W VW Kit can provide 30W max output. And the Twister 30W VW mod possesses twist style wattage adjustment system from 7.5W to 30W, 2.5W per click. With the 1.5A fast charging, the FreeMax Twister 30W VW mod can offer an all day going power and 80 minutes charging time for maximum. What is more, the Fireluke 22 Tank utilizes FreeMax COILTECH 4.0 with SS904L Mesh and Tea Fiber Cotton formula. And the Fireluke 22 Tank is equipped with 0.5ohm DTL Mesh Coil and 1.5ohm MTL Mesh Coil that is compatible with both freebase as well as salt nicotine e-liquids for both DTL and MTL vaping needs. Plus the child-proof top fill design with leak-proof mechanism, the Fireluke 22 Tank will easy to refill juice without mess. Just get the FreeMax Twister 30W VW Kit with Fireluke 22 Tank and enjoy the wonderful flavor. ![]() Original FreeMax Single DTL Mesh Coil for Fireluke 22 Tank/Twister 30W Mod Vape Kit(5 PCS) $13.99 The FreeMax Fireluke 22 Tank utilizes Freemax COILTECH 4.0 with SS904L Mesh and Tea Fiber Cotton formula. With 0.5ohm DTL Mesh Coil, its compatible with both freebase as well as salt, nicotine e-liquids. This coil is compatible with FreeMax Fireluke 22 Tank and FreeMax Twister 30W Mod Kit. ![]() Original FreeMax Single MTL Mesh Coil for Fireluke 22 Tank/Twister 30W Mod Vape Kit(5 PCS) $13.99 The FreeMax Fireluke 22 Tank utilizes Freemax COILTECH 4.0 with SS904L Mesh and Tea Fiber Cotton formula. With 1.0ohm MTL Mesh Coil, its compatible with both freebase as well as salt, nicotine e-liquids. This coil is compatible with FreeMax Fireluke 22 Tank and FreeMax Twister 30W Mod Kit. ![]() Original FreeMax Single MTL Mesh Coil for Fireluke 22 Tank/Twister 30W Mod Vape Kit(5 PCS) $13.99 The FreeMax Fireluke 22 Tank utilizes Freemax COILTECH 4.0 with SS904L Mesh and Tea Fiber Cotton formula. With 1.5ohm MTL Mesh Coil, its compatible with both freebase as well as salt, nicotine e-liquids. This coil is compatible with FreeMax Fireluke 22 Tank and FreeMax Twister 30W Mod Kit. ![]() Original Vapefly TGO Pod System Mod Kit Replacement RBA Deck Coil(1 PC) $7.99 The Original Vapefly TGO RBA Coil is compatible with Vapefly TGO Pod Vape Mod Kit. It is designed to meet your different needs of vaping and provide more DIY enjoyment. Just get it to enjoy DIY fun.
695
El Thunder MTLite Mechanical Mod Clone(Replica) $14.99
The El Thunder MTLite Vape Mechanical Mod Clone is constructed from brass and powered by 1 x 18350 / 18650 battery (not included). The Electric pole is made from brass with silver-plating. ![]() Original DOVPO Odin 100 100W TC VW Box Mod $79.99 The Odin 100 VW Vape box Mod is a new members of Odin series, it's also collaboration with Vaping Bogan, Vaperz Cloud and Dovpo. This Odin 100 is equipped with the advanced Dovpo Chip to bring you better battery life, an intelligent interface and up to 100w of power. Supported by USB Type-C makes your Odin 100 charging easier and faster. Compact Design and compatible with single 18650 / 20700 / 21700 battery (not included), supporting your whole-day using and portable carrying to anywhere for the Odin 100. ![]() Original Hcigar VT INPOD 40W 1500mAh VW Pod System Kit original price $36.99, now only $24.99 The Original Hcigar VT INPOD 40W Pod Vape Kit is constructed of Zinc alloy & PCTG with line design and smooth appearance for good hand feeling. Hcigar VT INPOD Pod Kit is powered by 1500mAh built-in polymer battery. Hcigar VT INPOD features Towis chipset of Hcigar and adjustable output wattage of 5~40W. Hcigar VT INPOD pod cartridge maintains 0.3ohm Honeycomb mesh heating coil and 4.5ml capacity with top filling design to prevent leakage. Hcigar VT INPOD pod adopts bottom intake for more soft and delicate vaping. ![]() Original Artery Pal GX 25W 1000mAh Pod System Kit original price $39.99, now only $25.99 The Original Artery Pal GX Pod System Vape Kit comes with portable size and 1000mAh built-in battery. Artery Pal GX Pod kit features LED light indicator for battery levels and three voltage output levels (Green high, Blue medium, Red low) to meet your needs. Artery Pal GX adopts Pal SE Pod (new version) with 2.0ml capacity and 1.3ohm Kanthal A1 Parallel wire ![]() Original Innokin Zenith Pro Vape Atomizer Replacement Glass Tank Tube $2.59 The Original Innokin Zenith Pro Replacement Glass Tank Tube is suitable for for Innokin Zenith Pro tank. It features 5.5ml capacity. ![]() Original Vapefly TGO 10 PCS KA1 0.6ohm Heating Wire + 2 PCS Cotton for TGO Pod Mod Kit / TGO RBA Coil $1.99 The Original Vapefly KA1 0.6ohm Heating Wire + Cotton is designed Vapefly Pod Mod Kit / TGO RBA Coil. It contains 10 PCS heating wires and 2 PCS cottons. ![]() Original BP MODS Pioneer RTA Vape Atomizer Replacement Air Pin Insert Set - 0.9mm, 1.0mm, 1.1mm, 1.3mm, 1.4mm (5 PCS) $6.99 The Original BP MODS Pioneer RTA vape atomizer Air Pin Insert Set is suitable for your BP MODS Pioneer RTA. The BP MODS Pioneer RTA Air Pin Insert Set comes with five different diameter (0.9mm, 1.0mm, 1.1mm, 1.3mm, 1.4mm) in each pack for meeting your daily needs. ![]() Original VOOPOO RTA Pod Cartridge for Drag X & Drag S Pod System Vape Mod Kit $18.99 The Original VOOPOO RTA Pod Cartridge is the rebuildable tank atomizer version of the PnP Pod Tank. The difference with the latter is that VOOPOO RTA Pod does not have a 510 base, but there is a build deck of regular RTA inside. The VOOPOO RTA Pod has a diameter of 26mm and a capacity of 2.0ml. The RTA pod cartridge is with bottom refilling system. The adopted RBA deck of VOOPOO RTA Pod is a dual-post building deck for single coil, mounting the coil leads within the open terminals. You can install the RTA Pod on the VOOPOO PnP Pod Tank Base and switch it to a 510 thread RTA Tank. The VOOPOO RTA Pod is suitable for the VOOPOO Drag X / Drag S Pod System Vape Mod Kit. Through the pod's internal dual air intake and infinite airflow system, the airflow is ventilated around the internal single coil structure to produce a dense and delicious vapor cloud. ![]() Original Hcigar VT INPOD 40W Pod Vape Kit Replacement Honeycomb Mesh Coil Head(5 PCS) $8.99 The Original Hcigar VT INPOD VC-M1 0.3ohm Mesh Coil is suitable for Hcigar VT INPOD 40W Pod Vape Kit. The Hcigar VT INPOD replacement mesh coil is 0.3ohm Honeycomb mesh heating coil. 5 PCS / Pack. ![]() Original BP MODS Pioneer RTA Vape Atomizer Replacement DL Extension Pack $16.99 The Original BP MODS Pioneer RTA DL Extension Pack is designed for BP MODS Pioneer MTL RTA. The BP MODS Pioneer RTA Extension Pack will switch MTL Pioneer RTA to DL which includes specific chimney and drip tip and two air pins under holes of 2.0mm and 2.9mm. The chimney brings much space for vapor production and air inlet. The Ultem drip tip has larger hole than normal. With the two air pins with different holes, the BP MODS Pioneer RTA Extension Pack brings direct-to-lung vape to you.
696
Original Hugo Vapor Rader ECO 200W VV VW Box Mod $25.99
The Hugo Vapor Rader Eco Mod, powered by dual 18650 batteries (Not included) with 200W max output, is the newly designed box mod from Hugo Vapor. The Rader Eco supports Variable Voltage, Variable Wattage, Bypass and Curve Heating output Mode. Equipped with the 0.96inch OLED screen, the Hugo Vapor Rader Eco Mod will bring you great vaping experience. ![]() Original VEIIK Dynam 1100mAh Pod System Kit $20.29 The Original VEIIK Dynam Pod System Vape Starter Kit is built-in 1100mAh. The pod cartridge is with 2.0ml capacity and 1.2ohm coil. ![]() Original VEIIK Dynam Pod System kit Replacement Pod Cartridge(2 PCS) $5.08 The Original VEIIK Dynam Pod System Vape kit Replacement Pod Cartridge holds 2.0ml capacity. Comes with 2 PCS / Pack ![]() Original Coilology Ni80 Clapton Spool Wire for RDA / RTA / RDTA Vape RBA Atomizer(3m) $3.99 The Original Coilology Clapton spool wires available in Ni80 (3 wire Configurations) And SS316L (1 wire configuration). To create it by using a thinner gauge wire tightly wrapped around a thicker gauge core. Clapton wires have a slower ramp up time than round wire builds, but are considered more flavorful due to their increased texture and surface area. It is with 10 feet (3 meters) length and 22GA / 36GA. ![]() Original Coilology Ni80 Chain Link Spool Wire for RDA / RTA / RDTA Vape RBA Atomizer(3m) $3.59 The Original Coilology Ni80 Chain Link Spool Wire is suitable for RDA / RTA / RDTA Vape RBA Atomizer. With 4-28GA and 10FT (3m) length ![]() Original Coilology Ni80 Twisted Clapton Spool Wire for RDA / RTA / RDTA Vape RBA Atomizer(3m) $4.59 Original Coilology Ni80 Twisted Clapton Spool Wire is suitable for RDA / RTA / RDTA Vape RBA Atomizer. With 3-28 GA / 36GA and 2.17ohm / feet. The twisted Clapton coils is a 3 ply 28 GA wire wrapped in a 36 GA wire. ![]() Original Coilology Ni80 Juggernaut Spool Wire for RDA / RTA / RDTA Vape RBA(3m) $4.99 Original Coilology Ni80 Juggernaut Spool Wire is suitable for for RDA / RTA / RDTA Vape RBA Atomizer. With 2-28 GA / 0.1 x 0.3 / 2-36 GA and 2.6ohm / Feet.
697
Original Vapeasy dotEasy MTL RBA Coil Deck with Tank + 4 Air Pin Inserts for dotMod dotAIO Pod System original price $30.99, now only $24.99
The Original Vapeasy dotEasy MTL RBA Coil Deck is made from stainless steel with bottom airflow adjustable for MTL Vaping. This MTL RBA is with dual-side airflow control, each side with 4 air holes: 1.5mm / 1.5mm / 1.2mm / 0.9mm. Combining with 4 Air Pin Inserts: 1.8mm / 1.5mm / 1.3mm / 0.9mm, you will get excellent MTL vaping experience. The Authentic Vapeasy dotEasy MTL RBA Coil Deck is with single coil building deck, dual-pole design for very easy coil building. The airflow will reach the coil directly from the bottom. What's more, the RBA deck is very convenient to take out for building, without taking out the top cap and chimney. Just take out the RBA deck, build the coil, plug the deck back, Very convenient. The deck is with 510 threading connection, take off the airflow ring, and then you can install the deck on resistance tester or mod to test the resistance of the coil. The Vapeasy dotEasy MTL RBA Coil Deck is perfect to match your dotMod dotAIO Pod System to get MTL Vaping experience. ![]() Original Vapeasy dotEasy Replacement Pod Tank for dotMod dotAIO Pod System - Transparent $5.99 The Original Vapeasy dotEasy Replacement Pod Tank is made from acrylic with 2.0ml and it is suitable for dotMod dotAIO Pod System. ![]() Original Vapeasy dotEasy Replacement Pod Tank for dotMod dotAIO Pod System - Translucent Red $5.99 The Original Vapeasy dotEasy Replacement Pod Tank is made from acrylic with 2.0ml and it is suitable for dotMod dotAIO Pod System. ![]() Original Vapeasy dotEasy Replacement Pod Tank for dotMod dotAIO Pod System - Translucent Blue $5.99 The Original Vapeasy dotEasy Replacement Pod Tank is made from acrylic with 2.0ml and it is suitable for dotMod dotAIO Pod System. ![]() original Vapeasy dotEasy Replacement Pod Tank for dotMod dotAIO Pod System - Translucent Green $5.99 The Original Vapeasy dotEasy Replacement Pod Tank is made from acrylic with 2.0ml and it is suitable for dotMod dotAIO Pod System.
698
Original Innokin Sceptre 1400mAh Pod System Kit $26.99
The Original Innokin Sceptre pod system vape starter kit is a 1400mAh built in battery device suited for new vapers looking for a small yet compact device. With two coils to choose from, a 1.2ohm for MTL Vaping and a 0.5ohm RDL Coil for high wattages, the Sceptre can easily identify between the two and automatically adjust your settings for the ultimate vaping experience. With an auto draw and button operation the Sceptre also features Boost Mode which can create more heat and vapor. Rechargeable via the micro USB port the also Secptre features a 3.0ml refillable pods that are easily replaceable with Innokin's latest Sceptre coils. Simply twist the bottom of the pod to remove and replace the coils. ![]() Original Artery NUGGET+ 70W 2000mAh VW Pod System Kit original price $53.90, now only $31.99 The Original Artery NUGGET+ 70W VW Pod System Vape Mod Kit is made of PC and PCTG with super light and pocket size. Artery NUGGET+ Pod Mod Kit is built-in 2000mAh battery with max 70W output. Artery NUGGET+ Pod Mod 70W Kit features AERO chip with constant wattage and 0.96 inch color screen to show vaping data clearly. Artery NUGGET+ cartridge comes with 5.0ml capacity with top filling design and Brand new XP core series: 0.15ohm coil, 0.4ohm coil and RBA coil (not included). Artery HP pod is compatible with HP cores series. Artery NUGGET+ can adjust airflow by airflow reduction silicon part and turn to a box mod by 510 adapter (not included). ![]() Original Artery NUGGET+ Pod System Replacement HP Pod Cartridge(1 PC) $5.99 The Original Artery NUGGET+ Replacement HP Pod is suitable for Artery NUGGET+ 70W Pod system Mod vape Kit. Artery NUGGET+ HP Empty Pod maintains 5.0ml capacity with top filling design. Artery NUGGET+ HP cartridge is compatible with HP coil series: 0.17ohm coil (not included). ![]() Original Artery NUGGET+ Pod System Replacement XP Pod Cartridge(1 PC) $5.99 The Original Artery NUGGET+ Replacement XP Pod is suitable for Artery NUGGET+ 70W Pod System Mod Vape Kit. Artery NUGGET+ XP Empty Pod maintains 5.0ml capacity. Artery NUGGET+ XP cartridge features top filling design and is compatible with brand new XP coil series: 0.15ohm coil, 0.4ohm coil and RBA coil (coils not included). ![]() Original Artery NUGGET+ Pod System Replacement RBA Coil Deck(1 PC) $9.99 The Original Artery NUGGET+ XP RBA Coil is suitable for Artery NUGGET+ 70W 2000mAh POD System Vape MOD KIT. The XP RBA coil is for your DIY fun, and improve more powerful and flavorful vaping experience. ![]() SXK Big Blind RTA Replacement PC + PEI Tank Tube + Extension Connector for Small Blind RTA Clone original price $12.90, now only $11.50 The SXK Long Oil bunker Kit includes long PC tank tube + long PEI Tank Tube + Extension Connector. The Long Oil bunker Kit will switch your Small Blind RTA to Big Blind RTA. The long tank tube is around 4.5ml capacity.
699
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Timesvape Dreamer V1.5 Hybrid Mechanical Mech Vape Mod original price $74.99, now only $56.99
The Timesvape Dreamer V1.5 Mechanical Mod is constructed from stainless steel material. Dreamer V1.5 is powered by 1 x 18650 / 20700 / 21700 Batteries (Not included). The tube itself is 27mm at its widest point, tapering to 25mm at the top. The tube is reversible, so you can customize the grip to suit your preferences. The copper contact pin is also silver-plated for a perfect connection every time. ![]() El Thunder MTLite Mechanical Mod Clone $14.99 The El Thunder MTLite Mechanical Mod Clone is constructed from brass and powered by 1 x 18350 / 18650 battery (not included). The Electric pole is made from brass with silver-plating. ![]() Original Artery NUGGET+ Pod System Replacement HP Pod Cartridge(1 PC) $5.99 The Original Artery NUGGET+ Replacement HP Pod is suitable for Artery NUGGET+ 70W Pod system Mod vape Kit. Artery NUGGET+ HP Empty Pod maintains 5.0ml capacity with top filling design. Artery NUGGET+ HP cartridge is compatible with HP coil series: 0.17ohm coil (not included). ![]() Original Artery NUGGET+ Pod System Replacement XP Pod Cartridge(1 PC) $5.99 The Original Artery NUGGET+ Replacement XP Pod is suitable for Artery NUGGET+ 70W Pod System Mod Vape Kit. Artery NUGGET+ XP Empty Pod maintains 5.0ml capacity. Artery NUGGET+ XP cartridge features top filling design and is compatible with brand new XP coil series: 0.15ohm coil, 0.4ohm coil and RBA coil (coils not included). ![]() Original Artery NUGGET+ Pod System / HP Pod Cartridge Replacement HP Mesh Coils Heads(5 PCS) $7.99 The Original Artery NUGGET+ Replacement HP Mesh Coil is suitable for Artery NUGGET+ 70W Pod System Mod Vape Kit. The Artery NUGGET+ 0.7ohm HP Mesh coil is compatible with Artery NUGGET+ HP Pod Cartridge to boost flavor. ![]() Original Artery Nugget+ 70W Pod System Replacement RUOK 510 Adapter Connector $6.99 Switch the Artery NUGGET+ Pod Mod into a box mod to install 510 vape atomizers ![]() SXK Replacement Tank for 70W / DNA 60W BB Billet Box / SXK Bantam Revision 30W Mod Vape Kit original price $8.90, now only $6.99 The SXK BB Box Mod Style Replacement Tank is constructed from acrylic and glass. It is designed for SXK BB Box Mod Kit / SXK Bantam Revision 30W Box Mod Vape Kit.
700
Original Crested Ibis MODS Vape Semi-Mech Mechanical Mod with MOSFET $89.00
The Original Crested Ibis MODS Mod is made from Delrin and Stainless Steel. The mod is built-in MOSFET with low / high resistance, overheating, short circuit, reverse polarity protection. The Mod supports 22mm diameter atomizer. ![]() Original Augvape DRUGA 2 BF RDA $29.99 The Original Augvape DRUGA 2 24mm RDA, featuring revised Clamp Snag System build deck bundled in a visually striking aesthetic. Constructed from superior 304 Stainless steel, the chassis is well constructed and visually striking. Implemented within the build deck is an upgraded clamp snag system to maintain ease of building, accommodating a single or dual coil configuration. In addition, the top cap features a dual sided airflow control, offering control over airflow intake. At the bottom is a threaded 510 connection to facilitate connectivity through a swappable gold plated pin or bottom feeder squonk pin, allowing e-Juice to travel through the bottom from your favorite squonk mod ![]() Original Vapor Storm FLAME 25W 1100mAh Pod System Kit $12.99 The Original Vapor Storm FLAME 25W Pod System Vape Starter Kit is built-in 1100mAh battery, and constructed from aluminum alloy and PCTG, lightweight to easily carry, Comes with two kinds coil, 0.6ohm and 1.2ohm mesh coil, one of Flame kit advantage is that you can freely switch from DTL TO MTL. ![]() Original OBS Naze 80W VW Pod System Kit original price $50.99, now only $42.99 The Original OBS Naze Mod Pod System Vape Kit is triggered by the fashionable, efficient and safe fingerprint identification technology, which provides a better and more sensitive system for child-proof and vaping privacy. Powered by a single 18650 battery (not included), it is designed with adjustable power range from 5 to 80W. And it also adopts 1.5-hour type-c fast charging port and a screen for convenient and easy operation. Besides, there are two pod cartridges for your options: one is 3.0ml juice capacity with 0.4ohm OM NA Mesh Coil for Restricted DTL vape, and the other is 2.5ml liquid capacity with 0.2ohm OM ZE Mesh Coil for DTL vape. ![]() Original Vaporesso XIRON 50W 1500mAh VW Pod System Kit $31.99 The Original Vaporesso XIRON Pod System Vape Starter Kit embodies the combination of high-quality craftsmanship and vaping technology. It is made of highly durable zinc alloy and has a tough appearance that provides a stable and reliable user experience. The Vaporesso XIRON is powered by a built-in 1500mAh battery with a maximum output power of 50W, which allows your vaping experience to be completely immersed in dense vapor. The device integrates a chipset to provide ultra-fast firing time and circuit protection. On the complete control surface, there is an intuitive and easy-to-operate raised fire button, a 0.69" OLED Screen, two control buttons, and the bottom Type-C port. Vaporesso XIRON Pod can hold 5.5ml of e-juice. It can be filled easily and leakage-free with the help of the large filling port on the top. The transparent top cover allows you to know at a glance how much e-juice is left. The pod has an airflow adjustment valve on the side, just release the perfect amount of vapor by spinning the dial, easy, and smoothly. Vaporesso XIRON is compatible with GTX Mesh coils and comes with GTX 0.3ohm Mesh Coil and GTX 0.8ohmm Mesh Coil for the bigger cloud and smooth flavor, you will get the strong throat hit. ![]() Original Vapor Storm FLAME 25W Pod System Replacement Mesh Coil Head - 0.6ohm (5 PCS) $8.59 The Original Vapor Storm FLAME 25W Pod System Vape Kit Replacement Mesh Coil is in 0.6ohm resistance and comes with 5 PCS / Pack. ![]() Original Vapor Storm FLAME 25W Pod System Replacement Mesh Coil Head - 1.2ohm (5 PCS) $8.59 The Original Vapor Storm FLAME 25W Pod System Vape Kit Replacement Mesh Coil is in 1.2ohm resistance and comes with 5 PCS / Pack. ![]() Original Vapor Storm FLAME 25W Pod System Replacement Empty Pod Cartridge(2 PCS) $3.29 The Original Vapor Storm FLAME 25W pod system vape kit Replacement Empty Pod cartridge holds 2.5ml capacity and with side filling design and adjustable airflow can make you freely switch from DTL TO MTL. ![]() Original Vaporesso XIRON 50W Pod System Replacement Empty Pod Cartridge(2 PCS) $5.99 The Vaporesso XIRON Pod Cartridge is suitable for Vaporesso XIRON Kit. It is designed with 5.5ml e-juice capacity, which is large enough for a longer vaping experience after one filling. And it adopts replaceable 810 drip tip, leakage-free top filling design and convenient visible oil window. In addition, it is compatible with GTX MESH coils (coils not included) for excellent flavor. And with adjustable airflow dial, it allows you to choose the vapor you like. ![]() Original Innokin Zlide Replacement Glass Tank Tube $2.59 The replacement glass tank tube has 4.0ml of juice capacity and is suitable for Innokin Zlide 4ml Sub ohm tank vape atomizer. ![]() Original Auguse Draw RTA Pod Cartridge for Voopoo Drag S / X Vape Pod System $12.99 The Original Auguse Draw RTA Pod Cartridge is suitable for Voopoo Drag S / X Vape Pod System Vape Mod Kit. The RTA Pod is constructed from stainless steel and acrylic tank holds 4.5ml capacity. This Pod cartridge is with Draw RTA style single coil building deck and airflow control adjustable from the bottom.
