Просмотров в теме 302474   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 27.05.2020, 05:05 Автор темы   641
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Vaporesso GTX One VW Box Mod $24.99
The Vaporesso GTX One VW Box Mod is powered by large 2000mAh built-in battery with portable size and 2A fast charging Type-C Cable. GTX One Mod features Max 40W adjustable power supporting smart VW mode, it can offer impressive vaping experience throughout. Equipped with clear and concise 0.69-inch OLED screen, you can get the data of this device conveniently and fastly. Furthermore, Vaporesso GTX One Mod is perfect match the Vaporesso GTX 18 TANK. There are multiple protections that ensure your vaping safety.
Original Vaporesso GTX 18 MTL / DTL Sub Ohm Tank Clearomizer $13.99
The Vaporesso GTX Tank 18 is constructed from Stainless Steel and Glass in 22mm diameter, which comes with two types of GTX MESH Coil for options: GTX 0.8ohm MESH Coil (12~20W) and GTX 1.2ohm MESH Coil (7~11W). The Vaporesso GTX 18 Tank is designed for Vaporesso GTX One Kit, the GTX 18 tank has 3ml glass tube (Pre-installed) and a 2ml spare glass tube. With classic GTX coils, the Vaporesso GTX 18 Tank delivers amazing flavor and taste to the vapers. The GTX 18 Tank has easy coil installation system. Just pull and push, then you are capable of replacing the coils. With the bottom airflow, Vaporesso GTX 18 Tank supports MTL vaping experience and Restricted DTL vaping experience.
Original YDDZ T1 MTL RTA $22.99
The YDDZ T1 MTL RTA is constructed from Stainless Steel (body), PC Tube (Pre-installed), Glass Tube (Spare), and PC Drip Tip in 16mm Diameter. The tank tube features 2ml E-juice capacity. The YDDZ T1 MTL RTA comes with a Single Coil Build Deck with Dual Side Posts, which supports Top Refilling System and Dual Bottom Airflow Adjustments.
Original FreeMax Replacement Bubble Tank Tube for FreeMax Twister 80W VW Mod Kit $2.99
The Replacement Bubble Tank Tube is designed for Freemax Twister 80W VW Mod Tank Kit Standard Edition as a replacement part, which is made from Pyrex Glass and features 5ml E-juice capacity. It is easy to replace and clean.
Replacement Gorgeous Wide Bore Drip Tip for Aspire Cleito 120 Tank Atomizer $1.99
The Replacement Gorgeous Wide Bore Drip Tip is suitable for Aspire Cleito 120 Tank Atomizer. It is made from Delrin in 15.2mm height, 11mm inner diameter, and 25mm outer diameter.
Original Advken Replacement Bubble Tank Tube for Manta Mesh Tank Atomizer $2.99
The Replacement Bubble Tank Tube is designed for Advken Manta Mesh Tank Vape Atomizer as a replacement part, which is made from Glass and features 4.5ml E-juice capacity. With dazzling color, the Advken Glass Tube will be a perfect spare part for the Manta.
Original Advken Barra Tank Vape Atomizer Replacement Mesh Coil Head(5 PCS) $9.98
The Advken Replacement Mesh Coil Head is designed for Advken Barra Tank Vape Atomizer as a replacement part, which features 0.16ohm coil resistance and the output power range from 60W to 80W. 5 PCS / Pack.
The Advken Replacement Mesh Coil Head is designed for Advken Barra Tank Vape Atomizer as a replacement part, which features 0.2ohm coil resistance and the output power range from 50W to 70W. 5 PCS / Pack.
Original Augvape Intake Sub Ohm Tank Replacement Straight Tank Tube $2.59
The Augvape Replacement Straight Tank Tube is designed for Augvape Intake Sub Ohm Tank as a replacement part, which is made from Glass material and features 3.5ml E-juice capacity. It is easy to clean and replace.
Original Augvape Intake Sub Ohm Tank Replacement Bubble Tank Tube $2.59
The Augvape Replacement Bubble Tank Tube is designed for Augvape Intake Sub Ohm Tank as a replacement part, which is made from Glass material and features 5ml E-juice capacity. It is easy to clean and replace.
3FVAPE вне форума   Вверх
Старый 28.05.2020, 05:11 Автор темы   642
3FVAPE
Original Starss Blazer VW Box Mod $38.95
The Starss Blazer 75W TC VW Variable Wattage Vape Box Mod is powered by 1 x 18650 Battery (Not included) with 75W Max. Output Power. The Blazer Mod supports Working Mode: Power / TC (NI / TI / SS temperature control) / Bypass / TEMP POWER (Temperature Compensation). The temperature control range of this Mod Kit can from 100'C to 300'C / 200'F to 600'F. Moreover, it has multiple protections that ensure your vaping safety.
Original Suorin Elite Pod System Kit $39.99
The Suorin Elite 40W VW Mod Pod System Vape Starter Kit The Suorin Elite VW Pod Kit adopts Zinc Alloy with Resin bands material, and the whole device has no screw, giving an integrated and ingenious appearance. Suorin Elite VW Pod Kit is powered by a built-in 1100mAh battery which with 40W Max output power and comes with a 3.1ml Large Pod Cartridge to provide a long vaping. What's more, Suorin Elite VW Pod Kit possesses super clear LED screen, adjust the wattage as you like, the usage detail will be displayed in it. With the 1.0ohm coil, the Suorin Elite pod system will bring you fantastic flavor and rich clouds. The Suorin Elite device only takes 50 minutes to be fully charged with 1A fast charging.
Original Starss Blazer Mod Vape Starter Kit with Blazer Tank $48.95
The Starss Blazer 75W TC VW Mod Kit consists of Starss Blazer 75W TC VW Vape Box Mod and Starss Blazer Sub Ohm Tank Vape Atomizer. The Mod Kit is powered by 1 x 18650 Battery (Not included) with 75W Max. Output Power. The Blazer Mod Kit supports Working Mode: Power / TC (NI / TI / SS temperature control) / Bypass / TEMP POWER (Temperature Compensation). The temperature control range of this Mod Kit can from 100'C to 300'C / 200'F to 600'F. Moreover, it has multiple protections that ensure your vaping safety. As for the Blazer Tank, which comes with a 5.0ml large Glass Tube and V8 Dual Mesh Coil 0.5ohm to meet your all day long vaping. It is also compatible with other SMOK V8 Baby Coils.
Original Golisi Needle 1 One-Slot USB Charger for Li-ion 18650 / 26650 / 21700 / 20700 / 18500/ 18350 /Ni-mh/Ni-cd/AAA/AA, etc. $4.99
The Golisi Needle 1 One-Slot USB Charger is a portable and safe smart charger with one battery slot. It has a USB power port with DC 5V / 1A power input. What's more, it is compatible with almost ALL TYPES OF cylinder shape rechargeable batteries such as 18650, 20700, 21700, 26650 and 18350 batteries with 0.5A output current. Together with a LED light indicating the battery charging situation, light Short Circuit Protection, Over-Current Protection, Reverse Connection Protection and Over-Heat Protection, Needle 1 Charger will bring you a simple and safe charging experience.
Original Golisi I1 2A One-Slot Smart USB Charger with LCD Screen Compatible with Battery Length Ranging 32~70mm $11.99
The Golisi I1 is a compact mini smart charger. It has a USB power port with optional 0.5A, 1A and 2A output. And it is compatible with Batteries Length Range From 32mm to 70mm. Equipped with the LCD, it can displays all information of this charger in detail. It has 1 battery slot.
Original Golisi I2 2A Two-Slot Smart USB Charger with LCD Screen Compatible with Battery Length Ranging 32~70mm $19.99
The Golisi I2 is a compact mini smart charger. It has a USB power port with optional 0.5A, 1A and 2A output. And it is compatible with Batteries Length Range From 32mm to 70mm. Equipped with the LCD, it can displays all information of this charger in detail. It has 2 battery slots.
Original SMOKTech SMOK RPM160 Mod Pod Vape Kit Replacement Empty Pod Cartridge(3 PCS) $6.99
The SMOK RPM160 Replacement Empty Pod Cartridge is a set of refillable pod, which is designed for SMOK RPM160 Mod Pod Vape Kit as a replacement part. It features 7.5ml E-juice capacity. The unprecedented capacity of 7.5ml E-liquid, which is more than that of the previous pod, can simplify your daily refill without frequent filling of E-juice. Open the large rubber plug on the side of the pod to fill the juice, there is no leakage problem. Since the rubber plug is located at the top of the pod, it is convenient and easy to fill the e-liquid without removing the pod. The Pod Cartridge cooperates with the newly designed RPM160 Mesh Coil (Not included, Sold Separetely) bring the best flavor. SMOK RPM160 Empty Pod is also compatible with RPM and RGC Series Coils. (Not included, Sold Separetely) 3 PCS / Pack.
Original SMOKTech SMOK RPM160 Mod Pod Vape Kit / Cartridge Replacement Nichel-chrome Mesh Coil Head(5 PCS) $11.99
The SMOK RPM160Replacement Nichel-chrome Mesh Coil Head is designed for SMOKTech SMOK RPM160 Mod Pod Vape Kit / Pod Cartridge as a replacement part. The honeycomb-structed mesh coil is made of Nichel-chrome and comes with 0.15ohm coil resistance, it consists of multiple structurally stable hexagons that enables the mesh wire heating elements to heat more quickly and evenly. Every drop of the E-liquid can be fully heated through these small holes, obtaining high quality vapor and delivering best flavor. 5 PCS / Pack.
Original Joyetech EZ Pod Cartridge with 0.4ohm EZ Coil for Exceed Grip / Grip Pro / Exceed Grip Plus Vape Kit(5 PCS) $14.99
The Joyetech EZ Pod Cartridge adopts brand-new 0.4ohm EZ Coil for amazing vaping experience and it features 2.6ml E-juice capacity to meet your daily vaping. The innovative EZ coil brings rich flavor for you. The EZ Pod Cartridge is designed for Joyetech Exceed Grip series, which is compatible with Joyetech Exceed Grip Pro Kit / Joyetech Exceed Grip Kit / Joyetech Exceed Grip Plus Kit. The side airflow design of EZ cartridge ensures a leak-free vape.
Hulk 2W UV Disinfection Ray Sterilizer Box for Sterilizing Face Mask / Vape / Phone, etc. $21.99
The Hulk Sterilizer Box adopts ultraviolet light to remove bacteria from Face Mask / Vape / Phone, etc. The Ultraviolet Wavelength is UVC 270nm, UVA 395nm. The Max. Power is 2.0W. The Hulk Sterilizer Box is portable and small, it can inhibit the bacteria / virus / Coronavirus Disease 2019 (COVID-19) effectively.
Products with 24HRS tag can be shipped in 24hrs after payment confirmed on business day.
If you want to order 24HRS item directly,click on this link to purchase >>>
Старый 29.05.2020, 05:35 Автор темы   643
3FVAPE
YFTK NarDA RDA Clone with BF Pin $21.99
The YFTK NarDA RDA Clone is a rebuildable dripping atomizer with 22mm diameter. It is made from 316 Stainless Steel (top cap) and Copper (base deck). Coming with dual-post design, it is easy to build. This RDA comes with bottom feeder / BF / Squonk Pin.
Original Vaptio Sonar Max Pod Kit original price $52.99, now only $35.99
The Vaptio Sonar Max VW Mod Pod Kit is powered by single external 18650 battery (Not included) with Max. Output Power 75W. Sonar Max Kit comes with two types of coils for you options: 0.15ohm coil and 0.35ohm coil. Furthermore, the Sonar Max Kit features the world's first top-install coil design, it is convenient and no mess while you want to replace the coils. Sonar Max's 3D Holo Pattern Panel is made from composite material. The appearance of Sonar Max is breathtakingly beautiful, the iridescent shiny color under the light makes you stand apart in the crowd. The Sonar Max Kit comes with the dust-proof cap that can prevent the drip tip from dirt and dust. It can cover your device with the cap when your Sonar Max is not in use, and always keep your drip tip clean and fresh. Equipped with 0.96" TFT Color Screen, you can get detailed info of this device like battery capacity, wattage, and so on. What's more, Sonar Max Kit also comes with a large 4.5ml E-juice capacity Pod Cartridge with easy side filling design.
Original Pioneer4You iPV Aspect 750mAh Pod System Kit original price $21.99, now only $6.99
The Pioneer4You iPV Aspect Pod System, a button activated device powered by the YiHi SXK1 chipset and has two wattage output modes. The amazing aspect also has adjustable air flow built into its pod system and a robust 750mAh battery life. The iPV Aspect, powered by the YiHi SXK1 chip utilizes a single firing button that also allows the user to change between high and medium wattage modes. High wattage mode has a range of 7.8 to 13.7W and medium wattage mode has a range of 7.8 to 11.5W. The Aspect has a unique pod system with 2.0ml capacity, 1.0 atomizer resistance, and SS316 heating material. This pod system has adjustable side airflow covered by a silicone strip and is bottom filled. The iPV Aspect has a 30mm by 16mm viewing port. The robust battery has a 750mAh capacity that has 0.5A charging. Four LED indicators show four lights for 100 to 76%, three lights for 75 to 51%, two for 50 to 26%, and one for 25 to 0%. This set of indicator lights also show the first and fourth light to indicate high wattage mode, and the middle two lights for medium wattage mode.
Original Pioneer4You iPV-3 Mini Auto-Feeding Squonk TC Pod System Kit original price $52.99, now only $34.99
The Pioneer4You iPV V3-Mini is an intelligent, all-in-one, auto bottom-feeding device with temperature control. The Pioneer4You IPV-3 Mini pod adopts YIHI ESS (Electronic Spray Squonk) Driver Technology, which supports the auto bottom-feeding system on the basis of accurate YIHI chipset control. Powered by YiHi SX635J chipset, iPV V3-Mini can support Multiple Intelligent Control Systems. The small size and 1400mAh built-in battery make it easy to take to everywhere you go and support a whole day vaping.
Original Suorin Elite Pod Kit / Cartridge Replacement Wire Coil Head(3 PCS) $5.99
The Suorin Replacement Wire Coil is designed for Suorin Elite Mod Pod Vape Kit / Pod Cartridge as a replacement part, which features 1.0ohm coil resistance. It allows you to get pure flavor and dense cloud. 3 PCS / Pack.
Original Suorin Elite Pod Kit Replacement Empty Pod Cartridge - Black, 3.1ml (2 PCS) $3.99
The Suorin Replacement Empty Pod Cartridge is designed for Suorin Elite Mod Pod Vape Kit as a replacement part, which comes with 3.1ml E-juice capacity. It is compatible with Suorin Elite 1.0ohm Wire Coil and 0.4ohm Mesh Coil. (Coils are not included, sold separetely) 2 PCS / Pack.
Original Vaptio Sonar Max Pod Kit Replacement A2 Coil Head(5 PCS) $12.99
The Vaptio Sonar Max Replacement A2 Coil is designed for Vaptio Sonar Max Mod Pod Vape Kit / Pod Cartridge as a replacement part, which features 0.35ohm coil resistance and output power range from 35W to 40W. 5 PCS / Pack.
Старый 29.05.2020, 05:43 Автор темы   644
3FVAPE
Rubyvape Replacement 4-in-1 MTL 510 Drip Tip Clone for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $9.99
The Rubyvap Replacement 4-in-1 MTL 510 Drip Tip Clone is made of SS material. The 4-in-1 MTL 510 Drip Tip consists of one Stainless Steel Connector Base and Four Drip Tip Mouthpieces for you options. You can choose different mouthpieces to match the connector base as you like. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
[Ships from Battery Warehouse] Original Samsung INR18650 25R 2500mAh 35A Flat Top Li-ion Battery for Vape Mod / Mod Kit (1 PC) $5.99
The Samsung INR18650 battery is a 2500mAh high performance rechargeable flat top li-ion battery and made for high continuous discharge current (Max 35A) applications. It is compatible with any E-cig vape box mods / mod kit powered by 18650 batteies.
[Ships from Battery Warehouse]Original Samsung INR21700 30T 3000mAh 35A Flat Top Li-ion Battery for Vape Mod / Mod Kit (1 PC) $8.99
The Samsung INR21700 battery is a 3000mAh high performance rechargeable flat top li-ion battery and made for high continuous discharge current (Max 35A) applications. It is compatible with any E-cig vape box mods / mod kit powered by 21700 batteies.
[Ships from Battery Warehouse]Original Samsung INR18650 20S 2000mAh 30A Flat Top Li-ion Battery for Vape Mod / Mod Kit (1 PC) $7.99
The Samsung INR18650 battery is a 2000mAh high performance rechargeable flat top li-ion battery and made for high continuous discharge current (Max 30A) applications. It is compatible with any E-cig vape box mods / mod kit powered by 18650 batteies.
Original Pioneer4You iPV Aspect K1 Replacement Pod Cartridge(2 PCS) original price $6.99, now only $3.99
The Pioneer4You IPV Aspect K1 Replacement Pod is designed to work exclusively with the IPV Aspect Kit. The Aspect's refillable cartridge is equipped with a 2ml E-Juice capacity and a resistance of 1.0ohm. The Aspect K1's exclusive feature being the adjustable airflow control. Most pod systems not allowing you to adjust the air flow effectively limiting your vaping experience to what they want instead of what you want. The Aspect's pod is bottom filling and has 2 strong magnets on the bottom to keep it from popping off incase of a fall. 2 PCS / Pack.
Original Pioneer4You iPV-3 Mini Auto Squonking Pod System Kit Replacement E-Liquid Container(3 PCS) original price $6.99, now only $3.99
The Pioneer4You iPV V3-Mini Auto Squonking Pod System replacement E-Liquid Container is made from PCTG food-grade with 3.5ml capacity. The Container features a see-through construction to allow for the viewing of juice levels within the system, prompting refills to the marked MAX fill line. And with a silicone stoppered top, the iPV V3 Mini e-Liquid container silicone lid has a pass through to allow for the squonking nozzle to fit and draw from the capacious reservoir. 3 PCS / Pack.
Original Pioneer4You iPV-3 Mini Auto Squonking Pod System Vape Kit Replacement ELF ADA Pods(2 PCS) original price $9.99, now only $4.99
The Pioneer4You iPV ELF ADA Replacement Refillable Pods are a set of proprietary squonking pods for the iPV V3 Mini Pod System, featuring a split juice reservoir, single coil layout, and is equipped with a 1.0ohm MTL coil. 2 PCS / Pack.
3% OFF for No Tobacco Day
Time: 29th May 00:00 - 31st May 2020 23:59 (UTC-6 / Denver Time)
Coupon code:3FVAPE2020
Note: This offer is not stackable with other MAP discounts.
Старый 30.05.2020, 05:24 Автор темы   645
3FVAPE
SXK Avat MTL/DL RTA Clone with Spare 5.0ml Top Cap Tank Tube $23.99
The SXK Avat MTL/DL RTA Rebuildable Tank Vape Atomizer Clone is constructed from 316 Stainless Steel (body) and PEI (tank tube) in 22mm Diameter. The RTA comes with a 3.4ml E-juice capacity tank tube and a SS drip tip. And it supports MTL and DL vaping experience, bottom airflow control and top-filling system. The RTA comes with a spare 5.0ml E-juice capacity PEI top cap tank tube for a larger capacity.
YFTK ParavozZ Ghost V2 RDTA Clone $25.99
The YFTK ParavozZ Ghost V2 RDTA Clone is constructed from 316 stainless steel material in 22mm diameter. The RDTA comes with a PEI tank tube. The building deck supports single coil. Heat sinks in the top cap is good for better cooling.
YFTK ParavozZ Ghost V2 RDTA Clone - Titanium Alloy $50.99
The YFTK ParavozZ Ghost V2 RDTA Clone is constructed from Titanium Alloy material in 22mm diameter. The RDTA comes with a PEI tank tube. The building deck supports single coil. Heat sinks in the top cap is good for better cooling.
Original Yuoto K40W Pod System Kit $29.98
The Yuoto K40W VW Box Mod Pod System Vape Starter Kit is an ergonomically designed compact all-in-one Pod System Device. Comfortable hand feels pretty, and exquisite appearance. Yuoto K40W Mod Pod Kit is constructed from durable Zinc Alloy and safe and hygienic PCTG material, with various stickers to meet the individual needs of different vapers. It is equipped with a 0.96-inch LCD Screen with highlight square AXON chip and it is powered by a 1500mAh built-in battery with adjustable power up to 40W, better to fit well with your taste preference and re-charging via a micro USB port. If you are a fresh hand to mod or user unfamiliar with adjusting power, it is highly recommended for you to choose K40W Mod Pod Kit. K40W Mod Pod Kit comes with two types of coil for options: 0.8ohm Regular Coil and 0.3ohm Mesh Coil. Furthermore, it has a 3.5ml E-juice capacity pod with refilled from the bottom to meet your all day long vaping. The intelligent chip inside enables it to smartly recognize coils and automatically match the power, to a large extent avoiding coils being burned out. Smoothening your vaping with both automatic and manual dual start modes, multiple safety guarding, and intelligent power adaptation to the coil inserted. In addition, it is also compatible with VOOPOO PnP Coils (0.3ohm, 0.8ohm 1.2ohm coil) fully suitable for various needs of vapers. (VOOPOO PnP Coils are not included, Sold Separately).
Original FreeMax Autopod50 Pod System Kit $41.99
The Autopod50 VW Box Mod Pod System Vape Starter Kit is the World's First Double Mesh Coil Mod Pod Kit with everything you need for vaping between 15W to 50W. Autopod50 Mod Pod Kit utilizes quality material for comfortable hand feeling and durability. Autopod50 is powered by a 2000mAh built-in battery with Max Output 50W, it comes with a 4ml pod cartridge and two types of coils for options: 0.25ohm AX2 Mesh Coil (30~50W) and 0.5ohm AX2 Mesh Coil (15~35W), all of which can bring you long-lasting vaping experience. As it is famous for the lastest COILTECH 4.0 with military grade SS904L mesh and Tea Fiber Cotton formala, it is able to provide best vaping experience even better than the best sub ohm tanks in the market. According to multiple testing results, the AX2 Mesh Coil has an average life span of 30~40 refillings. What's more, with Type-C 2A fast charging function, it only takes 80 minutes to be fully charged. And it allows you to get vaping details via a screen.
Multifunctional Vape Tweezers Tool for RDA / RTA / RDTA Vape Atomizer $2.99
The Multifunction vaper Tweezers is your handy tool for rebuilding your coils. It's tip is made of ceramic, which is able to withstand the high temperature when you dry fire your coil. With this tool, you can tighten the wire, pull out the top cap, pull out the base & pull out the coils easily. Making coil building so much easier. It's a great and handle tool if you are into rebuildable atomizers.
Original Yuoto K40W Pod System Vape Kit Replacement Empty Pod Cartridge(3 PCS) $6.99
The Yuoto K40W Replacement Pod Cartridge is designed for Yuoto K40W Pod System Vape Kit as a replacement part, which is made of PCTG material and features 3.5ml E-juice refillable capacity and is refilled from the bottom, delivering the delicious flavor that will liven anyone's day. It is compatible with VOOPOO VINCI PnP Coils: 0.3ohm, 0.8ohm, and 1.2ohm. (Coils are not included, Sold Separetely), it will offer you more choices and richer taste experiences. Installed in a bottom plug ' n' play fashion. Easy to replace the coil. 3 PCS / Pack.
Original Yuoto K40W Pod System Vape Kit / Cartridge Replacement Mesh Coil Head(3 PCS) $8.99
The Yuoto K40W Replacement Mesh Coil Head is designed for Yuoto K40W Pod System Vape Kit as a replacement part, which features 0.3ohm coil resistance. With this mesh core, you've got more surface area and more metal to actually heat up your E-liquid. 3 PCS / Pack.
Original Yuoto K40W Pod System Vape Kit / Cartridge Replacement Regular Coil Head(3 PCS) $8.99
The Yuoto K40W Replacement Regular Coil Head is designed for Yuoto K40W Pod System Vape Kit as a replacement part, which features 0.8ohm coil resistance. With this mesh core, you've got more surface area and more metal to actually heat up your E-liquid. 3 PCS / Pack.
Original Yuoto K40W Pod System Vape Kit / Cartridge Replacement Coil Head(3 PCS) $8.99
The Yuoto K40W Replacement Coil Head is designed for Yuoto K40W Pod System Vape Kit as a replacement part, which features 1.2ohm coil resistance. With this mesh core, you've got more surface area and more metal to actually heat up your E-liquid. 3 PCS / Pack.
YFTK Replacement Tank Tube for ParavozZ Ghost V2 RDTA $2.99
The YFTK Replacement Tank Tube is designed for ParavozZ Ghost V2 RDTA as a replacement part. It is made of PC material.
Старый 01.06.2020, 05:18 Автор темы   646
3FVAPE
Original IJOY Captain 2 180W Box Mod $59.99
The IJOY Captain 2 Vape Box Mod continues the amazing design and performance of the Captain series of mods. IJOY Captain 2 Box Mod is constructed from durable and lightweight Aluminum Alloy with ergonomic dimensions. Captain 2 Mod is powered by dual 18650 batteries (Not included) and has a maximum wattage of 180 watts. It has ample power and a large number of functions to bring incredible experience. In addition, IJOY Captain 2 Mod is equipped with a new 0.96-inch full-color display, which can provide more detailed working data. On the control face, you can see an oversized fire button and an ergonomic grip underneath. The IJOY Captain 2 Mod is Dust and Shock Proof, durable. The various protection systems ensure a safe vaping environment. It can perfectly match the IJOY Captain V Tank. (Not included).
Original BP Mods Pioneer MTL / DL RTA $59.99
The BP Mods Pioneer RTA is constructed from Stainless Steel (body) and PC (tank tube) in 22mm Diameter. Pioneer RTA comes with innovative airflow design, it supports fantastic MTL vaping experience and Restricted DL vaping. (Extension Pack is Not included). The RTA also comes with a 3.7ml E-juice capacity PC tank tube for your daily vaping. Furthermore, there are two types of spare Drip Tips and Tank Tubes for options: 1 x Ultem Drip Tip, 1 x Clear Drip Tip; 1 x Ultem Tank Tube, and 1 x PCTG Tank Tube. You can choose different drip tip or tube for your RTA as you like. Moreover, there are three Airflow Control Pins that meet your different airflow adjustable needs.
Vapeasy Armor Engine RDA Clone with BF Pin - Black, 316 Stainless Steel, Without Logo $14.59
Vapeasy Armor Engine RDA Rebuildable Dripping Atomizer Clone is constructed from 316 stainless steel and with replaceable Delrin 510 drip tip. This RDA is with dual-pole for single coil building. The Vapeasy Armor Engine RDA Clone supports airflow adjustable control via the top cap. This RDA comes with bottom feeder / BF / Squonk Pin. This RDA without Logo.
Vapeasy Armor Engine RDA Clone with BF Pin - Silver, Titanium Alloy, Without Logo $14.99
Vapeasy Armor Engine RDA Rebuildable Dripping Atomizer Clone is constructed from Titanium Alloy and with replaceable Delrin 510 drip tip. This RDA is with dual-pole for single coil building. The Vapeasy Armor Engine RDA Clone supports airflow adjustable control via the top cap. This RDA comes with bottom feeder / BF / Squonk Pin. This RDA without Logo.
Original Hotcig Marvel AIO Mod Pod Kit $25.99
The Hotcig Marvel 40W VW Box Mod AIO Pod System Vape Starter Kit is the latest device from Hotcig. Marvel 40 Mod Pod Kit is powered by built-in 1200mAh battery with Max. output 40W. The Hotcig Marvel has adjustable airflow system, so you are capable of vaping juice up to 60VG. The Hotcig Marvel is compatible with both MTL and DL vape. Moreover, the meshed coil of Hotcig Marvel Kit provides pure taste to the users too. The Marvel 40 Kit comes with a 2ml E-juice capacity cartridge and 0.4ohm resistance coil for your daily vaping.
Original FreeMax Autopod50 Mod Pod Kit / Cartridge Replacement AX2 Mesh Coil Head(5 PCS) $14.99
The Autopod50 Mesh Coil is designed for Freemax Autopod50 Mod Pod Kit. Upgraded from world-known M Pro and Fireluke series, it is known as the lastest COILTECH 4.0 with military grade SS904L mesh and Tea Fiber Cotton formala that is able to provide best vaping experience even better than the best sub ohm tanks in the market. The Autopod50 AX2 Mesh Coil features 0.25ohm coil resistance and power output range from 30W to 50W. Moreover, based on testing results, the AX2 Mesh Coil has an average life span of 30~40 refillings. 5 PCS / Pack.
Старый 01.06.2020, 05:23 Автор темы   647
3FVAPE
The Autopod50 Mesh Coil is designed for Freemax Autopod50 Mod Pod Kit. Upgraded from world-known M Pro and Fireluke series, it is known as the lastest COILTECH 4.0 with military grade SS904L mesh and Tea Fiber Cotton formala that is able to provide best vaping experience even better than the best sub ohm tanks in the market. The Autopod50 AX2 Mesh Coil features 0.5ohm coil resistance and power output range from 15W to 35W. Moreover, based on testing results, the AX2 Mesh Coil has an average life span of 30~40 refillings. 5 PCS / Pack.
Original FreeMax Autopod50 Mod Pod Kit Replacement Pod Cartridge with 0.25ohm AX2 Mesh Coil Head(1 PC) $6.99
The Autopod50 Pod Cartridge is designed for Freemax Autopod50 Mod Pod Kit. And it comes with AX2 Mesh Coil 0.25ohm (30~50W). As it is famous for the lastest COILTECH 4.0 with military grade SS904L mesh and Tea Fiber Cotton formala, it is able to provide best vaping experience even better than the best sub ohm tanks in the market. And based on multiple testing results, the AX2 Mesh Coil has an average life span of 30~40 refillings. Moreover, it adopts 4ml large e-juice capacity design that will greatly reduce the refilling times.
Original FreeMax Autopod50 Mod Pod Kit Replacement Pod Cartridge with 0.5ohm AX2 Mesh Coil Head(1 PC) $6.99
The Autopod50 Pod Cartridge is designed for Freemax Autopod50 Mod Pod Kit. And it comes with AX2 Mesh Coil 0.5ohm (15~35W). As it is famous for the lastest COILTECH 4.0 with military grade SS904L mesh and Tea Fiber Cotton formala, it is able to provide best vaping experience even better than the best sub ohm tanks in the market. And based on multiple testing results, the AX2 Mesh Coil has an average life span of 30~40 refillings. Moreover, it adopts 4ml large e-juice capacity design that will greatly reduce the refilling times.
SXK Replacement Colorful Button Set Kit for BB 70W / DNA 60W Box Mod Kit Clone(16 PCS) original price $9.90, now only $7.99
The SXK Replacement Colorful Button Set Kit is suitable for SXK BB 70W / DNA 60W Box Mod Kit. They are used as replacement parts to make your BB box mod look nice. The Brown Color Button is made of PEI material, Transparent Color Button is made of PC material, the others (purple / green / blue / yellow / white / red) are made of ABS material.The Kit includes 16 PCS Colorful Buttons. 16 PCS / Pack.
Original Hellvape Dead Rabbit RTA Replacement Bubble Tank Tube $2.59
The Replacement Bubble Tank Tube is designed for Hellvape Dead Rabbit RTA as a replacement part, it is made of Glass material and comes with 4.5ml E-juice capacity.
Protective Case Sleeve for 18650 Battery $0.99
The protective sleeve is made from soft silicone to protect your 18650 battery.
Старый 02.06.2020, 05:03 Автор темы   648
3FVAPE
YFTK Across Vape Roulette MTL/DL RTA Clone $27.99
The YFTK Across Vape Roulette RTA Clone is constructed from 316 Stainless Steel in 22mm Diameter. The RTA supports MTL vaping and DL vaping, which comes with a 3.5ml E-juice capacity tank tube with top refilling and juice control by rotation of the drip tip base. What's more, the RTA also comes with two air roulettes. one for MTL and the other for DL. It is to change the air hole settings via rotating the air Roulette.
Original Steam Crave Aromamizer Titan RDTA Replacement Straight Tank Tube(2 PCS) $3.59
The Steam Crave Replacement Straight Tank Tube is designed for Steam Crave Aromamizer Titan RDTA as a replacement part, which is made of Glass and features 18ml E-juice capacity. 2 PCS / Pack.
Original Steam Crave Aromamizer Titan RDTA Replacement Straight Tank Tube(2 PCS) $3.69
The Steam Crave Replacement Straight Tank Tube is designed for Steam Crave Aromamizer Titan RDTA as a replacement part, which is made of Glass and features 28ml E-juice capacity. 2 PCS / Pack.
Original Steam Crave Aromamizer Titan RDTA Replacement Dual Series Mesh Deck(1 PC) $21.99
The Steam Crave Replacement Dual Series Mesh Deck is designed for Steam Crave Aromamizer Titan RDTA as a replacement to build dual mesh coils for smooth flavor.
Original Steam Crave Aromamizer Titan RDTA Replacement LEGO Deck(1 PC) $20.19
The Steam Crave Replacement LEGO Deck is designed for Steam Crave Aromamizer Titan RDTA as a replacement for great flavor.
Старый 03.06.2020, 05:11 Автор темы   649
3FVAPE
Taifun BT RTA Clone original price $20.99, now only $7.99
The Taifun BT RTA Clone is made from stainless steel and glass in 23mm diameter and holds 5ml capacity. The Taifun BT style RTA does not use traditional coils with wires but unbelievable durable stainless steel mesh with an extra-large surface for a brand new vaping experience, massive vapor clouds and flavor beyond words. The vapor and still the e-liquid and atomizer itself stay comfortably cool as the stainless steel mesh heatens very fast but cool down immediately, too. The top-filling system mesh cotton coil atomizer, an absolute premium class atomizer, is as expected build on highest quality standards in order to produce a high-satisfying device for an overwhelming vaping experience.Please Note: This RTA is without LOGO.
Original Advken Potento 560mAh Pod System Kit $25.99
The Advken Potento Pod System Vape Starter Kit is a new pod kit with a voltage adjustable knob, which is powered by a built-in 560mAh battery. Rotate the bottom potentiometer control knob to adjust voltage from 3.2V to 4.2V for most flawless flavor and effortless vapor. As for Advken Potento pod, it is made of PCTG material, comes with 1.2ohm resistance coil and 2.5ml E-juice capacity with side filling design.
Original Steam Crave Replacement Mesh Strips for Aromamizer Titan RDTA(10 PCS) $3.90
The Steam Crave Replacement Mesh Strips is suitable for Steam Crave Aromamizer Titan RDTA, which is made of Kanthal A1 material and features 0.15ohm resistance. (0.15 +/- 0.03ohm) 10 PCS / Pack.
The Steam Crave Replacement Mesh Strips is suitable for Steam Crave Aromamizer Titan RDTA, which is made of SS316L material and features 0.15ohm resistance. (0.15 +/- 0.03ohm) 10 PCS / Pack.
510 to eGo Threading Adapter Convertor for E-Cigarette / Vape Box Mod Kit $0.99
The 510 to eGo Threading Connector adapter is made of Copper material. With the adapter, you can change a 510 threading to an eGo threading or change an eGo threading to a 510 threading easily.
Original Advken Potento Pod System Vape Kit Replacement Cartridge with 1.2ohm Cotton Coil(3 PCS) $10.99
The Advken Potento Replacement Pod Cartridge is designed for Advken Potento Pod System Vape Starter Kit, which is made of PCTG material, comes with 1.2ohm cotton coil and 2.5ml E-juice capacity with side filling design.
SXK Fire Button + Screen Plate + Button Plate Set for SXK BB 60W / 70W Vape Box Mod Kit(3 PCS) original price $25.90, now only $22.99
This SXK replacement accessories set are made of 316 Stainless Steel, which are suitable for SXK BB Bantam BB 60W / 70W box mod kit. This set includes Fire SXK Button + Screen Plate + Button Plate Set. The Fire Button is 13mm diameter, Screen Plate is 37 x 28mm, and the Button Plate is 52 x 27mm.
Старый 04.06.2020, 05:19 Автор темы   650
3FVAPE
Original ThunderHead Creations THC Tauren Hybrid Semi-Mechanical Vape Mech Mod with X Chip $99.90
The THC Tauren Hybrid Semi-Mechanical Mod is constructed of Naval Standard Brass with 26mm diameter and tapers to 24mm. Equipped with the Proprietary-X-Chip (Removable), the Tauren Hybrid Mod is the first Smart Hybrid Mech Mod. There are multiple protections that ensure your vaping safety such as short-circuit protection, high-temperature protection, low-voltage protection, 10 seconds cut-off protection. The Tauren Hybrid Mod is powered by single 18650 / 20700 / 21700 battery (Battery is not included, the 18650 Adaptor is included). and it features a unique ball construction with constant contact design. Caution: Do not Use Extension Tube with X Chip (Not included, Sold Separately).
Original ThunderHead Creations THC Tauren Max Hybrid Semi-Mechanical Vape Mech Mod with X Chipest $142.00
The THC Tauren Max Hybrid Semi-Mechanical Mod is constructed of Naval Standard Brass with 26mm diameter and tapers to 24mm. Equipped with the Proprietary-X-Chip (Removable), the Tauren Max Hybrid Mod is the first Smart Hybrid Mech Mod. There are multiple protections that ensure your vaping safety such as short-circuit protection, high-temperature protection, low-voltage protection, 10 seconds cut-off protection. The Tauren Hybrid Mod is powered by single 18650 / 20700 / 21700 battery (Battery is not included, the 18650 Adaptor is included). and it features a unique ball construction with constant contact design. Caution: Do not Use Extension Tube with X Chip (Not included, Sold Separately).
Original Vape Master Hunter Pro 220W Box Mod original price $39.99, now only $14.99
The Vape Master Hunter Pro TC VW Box Mod is powered by 2 x 18650 batteries (Not included) with Max. Output 220W. The Box Mod supports SmartVW (H / N / S), CCW, CCT, VT (NI, TI, SS), T-CR (M1, M2), RCT, BYPASS Modes. The temperature control range from 100'C to 315'C / 200'F to 600'F. Equipped with a 0.96-inch OLED Screen, it can display the data of this device clearly.
Original Vape Master Aurora RTA original price $20.99, now only $6.99
The Vape Master Aurora RTA is constructed from Stainless Steel and Glass in 22mm diameter. The RTA comes with a dual post build deck design and supports top filling system and bottom airflow control.
Original OXVA Origin 40W AIO Pod System Kit $34.99
The Oxva Origin VW Mod Pod System Kit is powered by a single 18650 battery (Not included) with 40W Max. output, which is a sleek, compact kit with an unusual shape. The included UNI coils are designed to release the liquid's flavor to its maximum and you could enjoy the different vaping experiences through both the DTL sub-ohm mesh coil and MTL coils. Note: The airflow ring pre-installed in the kit is reusable. Please keep it for a new coil.
SXK Billet Box 70W All-in-One VW Box Mod Kit Clone with USB Port $75.00
The SXK BB Box Mod Kit Clone is constructed from aluminum with an all-in-one design. This mod comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor. The SXK Mission Style Replacement Switch + Back & Front Panel Kit can be used in the mod kit (Not included, Sold Separately). This BB Box comes with USB port for charging only. With Logo.
Original ThunderHead Creations THC Tauren Hybrid / Tauren Max Mech Mod Replacement Extension Tube $29.00
The ThunderHead Creations THC Tauren Extension Tube is designed for Tauren Mech Mod / Tauren Max Mech Mod as a replacement part to extent the battery tube, which is made of Brass material. Compatible with 18650 / 20700 / 21700 Batteries (with 18650 adapter, batteries not included)Caution: Do not Use Extension Tube with X Chip.
Original ThunderHead Creations THC Tauren X 2-in-1 Chip for Tauren Mech Mod / Tauren Max Mech Mod(1 PC) $26.00
The ThunderHead Creations THC Tauren X 2-in-1 Chip is the world's 2 in 1 and removable design chipset. It can control the power output based on the current battery state and supports mech mode and smart protection mode. The Tauren X Chip is compatible with Tauren Mod and Tauren Max Mod. Note: It cannot be used together with the THC Extension Tube.
Original OXVA Origin Pod System Kit Replacement Empty Pod Cartridge(2 PCS) $4.59
The OXVA Origin Replacement Empty Pod Cartridge is designed for OXVA Origin Pod System Vape Kit as a replacement part, which comes with 2ml E-juice capacity. 2 PCS / Pack.
Original OXVA X Pod System Kit Replacement Empty Pod Cartridge(2 PCS) $3.99
The OXVA X Replacement Empty Pod Cartridge is designed for OXVA X Pod System Vape Kit as a replacement part, which comes with 2ml E-juice capacity. 2 PCS / Pack.
Original OXVA UNI Replacement RBA Coil Head for OXVA Origin / OXVA X Pod System Kit(1 PC) $5.99
The OXVA UNI Replacement RBA Coil Head is compatible with OXVA X Pod System Vape Kit / OXVA Origin Pod System Vape Kit as a replacement part. The RBA Coil fits for DIY vaping lovers.
Original OXVA UNI Replacement Coil Head for OXVA Origin / OXVA X Pod System Kit(5 PCS) $10.99
The OXVA UNI Replacement Coil Head is compatible with OXVA X Pod System Vape Kit / OXVA Origin Pod System Vape Kit as a replacement part, which is made of Kanthal A1 material and features 1.0ohm coil resistance. 5 PCS / Pack.
Старый 05.06.2020, 05:34 Автор темы   651
3FVAPE
Original Cthulhu Hastur 88W Box Mod $85.00
The Cthulhu Hastur 88W TC VW Vape Box Mod with simple and elegant appearance is made of 304 food-grade steel bat tery tube and aviation aluminum with high quality cnc machining technology, which is powered by single 18650 battery with 88W Max. Output Power. (Battery is not included). The Cthulhu Hastur Mod is equipped with Atom chip inside which provides temperature control and adjustable power system. Featuring clear color OLED screen and easy side button design, the Cthulhu Hastur Mod will bring you a simple and powerful vaping.
Original League of Scoundrels CONSVR Mechanical Mod original price $139.99, now only $35.99
The Original League of Scoundrels CONSVR Mechanical Mod is constructed from Copper material, it is perfect for everyday use with a look that definitely catches the eye. The mod utilizes an adjustable top insulated floating pin whilst the bottom contact is insulated and adjustable to accommodate any 18650 variation.
Original asMODus Rose Finch Mechanical Mod original price $39.90, now only $25.99
The asMODus Rose Finch vape mechanical mod, is constructed from Brass material featuring 24.5mm diameter. The firing switch is powered by high quality Earth magnets. It is powered by a single 18650 battery (Not included). Moreover, the Rose Finch features floating top pin for easy accommodation and switching of atomizers.
Original Phevanda Memory MTL RTA $32.99
The Phevanda Memory MTL RTA is constructed from 316 Stainless Steel and PC material in 22mm diameter, which comes with a 3.5ml E-juice capacity and 510 pin to adjust airflow (1.0mm / 1.3mm / 1.6mm). The RTA supports bottom airflow control and top filling system. It is easy to separate the chimney and deck for building your coil. You can also turn the chimney to Close / Open the E-juice Flow (liquid control. The Phevanda Memory RTA supports MTL vaping experience.
Original Aspire Cloudflask 2000mAh DTL Pod System Kit $34.99
The Aspire Cloudflask is powered by 2000mAh built-in battery, it brings big cloud vaping performance in a compact and sleek sub-ohm replaceable coil pod system configuration. Designed to help new converts start their journey and experienced vapers travel easily, with fast access to big flavor and instant cloud action. Engineered from premium Stainless Steel, with a versatile range of microfiber leather cases in various colors, the Aspire Cloudflask provides a sleek and stylish look. The removable leather strap assists with easy carry. The Cloudflask is an easy to use Pod System, which is designed for those who enjoy restricted DTL (Direct To Lung) vaping experience. The ergonomic design makes it feel great in hand, and simple structure allows to operate very easily. The 0.25ohm Mesh Coil will provide extreme flavor similar to Aspire Atantis tank.
Original SMOKTech SMOK Nfix Pod System Kit(Standard Edition) $24.99
The SMOKTech SMOK Nfix VW Mod Pod System Vape Starter Kit is the perfect portable all-in-one pod vape, which is a good combination of simple design and superb technology. With the slim portable design and easy to carry to anywhere. Powered by a built-in 700mAh battery, Nfix can support a daily use for heavy users. Get rid of frequent charging and focus on your everyday vaping as you want. Nfix with Type-C interface for fast charging. Type-C charging can deliver reliable power and provide faster transfer speed, which makes recharging easier. It takes only 60 minutes to fully charge the battery, which is efficient and saves time to do more. Nfix Kit support max 25W output, it comes with two 3ml E-juice capacity pod and dual-coil 0.8ohm MTL Coil to meet your all day long vape, designed to deliver the best flavor for the MTL vaping mode. What's more, Nfix allows you to access all basic vaping data through a 0.69-inch OLED screen. It also has multiple protections to ensure vaping safety.
[Ships from Battery Warehouse] Original Listman IMR20700 4200mAh 30A Flat Top Li-ion Battery for Vape Mod / Mod Kit (2 PCS) $14.99
The Listman IMR20700 battery is a 4200mAh high performance rechargeable flat top li-ion battery and made for high continuous discharge current (Max 30A) applications. It is compatible with any E-cig vape box mods / mod kit powered by 20700 batteies. 2 PCS / Pack.
Original Listman X2 1A Dual-Slot Charger for 18650 / 17670 / 17500 / 17350 / 16340 (RCR123) / 10440 Batteries, etc. - AU Plug $8.99
The Listman X2 1A Charger is compatible with different kinds and sizes of most batteries like IMR / Li-ion: 26650, 22650, 18650, 17670, 18490, 17500, 17350, 116340(RCR123), 14500, 10440; Ni-MH(Ni-Cd): AA, AAA, AAAA, C. The Operation Temperature of X2 1A Charger are range from 0'C to 40'C. This is AU Plug
Original Listman X2 1A Dual-Slot Charger for 18650 / 17670 / 17500 / 17350 / 16340 (RCR123) / 10440 Batteries, etc. - Euro Plug $8.99
The Listman X2 1A Charger is compatible with different kinds and sizes of most batteries like IMR / Li-ion: 26650, 22650, 18650, 17670, 18490, 17500, 17350, 116340(RCR123), 14500, 10440; Ni-MH(Ni-Cd): AA, AAA, AAAA, C. The Operation Temperature of X2 1A Charger are range from 0'C to 40'C. This is Euro Plug
Original Listman X2 1A Dual-Slot Charger for 18650 / 17670 / 17500 / 17350 / 16340 (RCR123) / 10440 Batteries, etc. - UK Plug $8.99
The Listman X2 1A Charger is compatible with different kinds and sizes of most batteries like IMR / Li-ion: 26650, 22650, 18650, 17670, 18490, 17500, 17350, 116340(RCR123), 14500, 10440; Ni-MH(Ni-Cd): AA, AAA, AAAA, C. The Operation Temperature of X2 1A Charger are range from 0'C to 40'C. This is UK Plug
Original Listman X2 1A Dual-Slot Charger for 18650 / 17670 / 17500 / 17350 / 16340 (RCR123) / 10440 Batteries, etc. - US Plug $8.99
The Listman X2 1A Charger is compatible with different kinds and sizes of most batteries like IMR / Li-ion: 26650, 22650, 18650, 17670, 18490, 17500, 17350, 116340(RCR123), 14500, 10440; Ni-MH(Ni-Cd): AA, AAA, AAAA, C. The Operation Temperature of X2 1A Charger are range from 0'C to 40'C. This is US Plug
Original Listman F2 2A Dual-Slot Charger for 22650 / 18650 / 14500 / 18350 / 14650 / 18500 / 16340 / 17500/18700 - ABS, AU Plug $6.99
The Listman F2 2A Charger is compatible with Li-ion: 26650, 22650, 18650, 14500, 18350, 14650, 18500, 16340, 17500, 18700 Batteries. The Operation Temperature of F2 2A Charger are range from 0'C to 40'C. The LED indicator can show you if the batteries are full or not. This is AU Plug
Старый 05.06.2020, 05:45 Автор темы   652
3FVAPE
Original Listman F2 2A Dual-Slot Charger for 22650 / 18650 / 14500 / 18350 / 14650 / 18500 / 16340/17500/18700 - ABS, Euro Plug $6.99
The Listman F2 2A Charger is compatible with Li-ion: 26650, 22650, 18650, 14500, 18350, 14650, 18500, 16340, 17500, 18700 Batteries. The Operation Temperature of F2 2A Charger are range from 0'C to 40'C. The LED indicator can show you if the batteries are full or not. This is Euro Plug
Original Listman F2 2A Dual-Slot Charger for 22650 / 18650 / 14500 / 18350 / 14650 / 18500 / 16340 / 17500/18700 - ABS, UK Plug $6.99
The Listman F2 2A Charger is compatible with Li-ion: 26650, 22650, 18650, 14500, 18350, 14650, 18500, 16340, 17500, 18700 Batteries. The Operation Temperature of F2 2A Charger are range from 0'C to 40'C. The LED indicator can show you if the batteries are full or not. This is UK Plug
Original Listman F2 2A Dual-Slot Charger for 22650 / 18650 / 14500 / 18350 / 14650 / 18500 / 16340 / 17500/18700 - ABS, US Plug $6.99
The Listman F2 2A Charger is compatible with Li-ion: 26650, 22650, 18650, 14500, 18350, 14650, 18500, 16340, 17500, 18700 Batteries. The Operation Temperature of F2 2A Charger are range from 0'C to 40'C. The LED indicator can show you if the batteries are full or not. This is US Plug
Original Basen BC-2 Dual-Slot USB Charger for 18650 / 18700 / 20700 / 21700 / 22700 / 25500 / 26650 / 26700 Batteries, etc. $9.99
The Basen BC-2 USB Charger is made of Flame Retardant Material, which is wide adaptability to charge different size and types of batteries: 3.6V / 3.7V Li-ion Batteries: 10440, 14500, 14650, 16340, 16650, 17650, 17670, 18350, 18490, 18500, 18650, 18700, 22650, 20700, 21700, 22700, 25500, 26650, 26700.
Original Basen Ant1 One-Slot USB Charger for 18650 / 20700 / 21700 / 26650 Batteries $7.99
The Basen Ant1 USB Charger is compatible with 18650, 20700, 21700, 26650 batteries. The Ant1 USB Charger has multiple protection that ensure your charging safety like Auto detect charging function, Low voltage activation function, Short circuit protection, and Reverse polarity protection.
Original Basen BO4 Four-Slot USB Charger for 18650 / 18700 / 22650 / 20700 / 21700 / 26650 / 26700 Batteries, etc. $14.99
The BO4 Battery Charger has four independent charging channels, it can charge four lithium batteries at the same time. Users can choose different charging current to meet the needs of slow charge or fast charge. And the charger will display the status of each rechargeable battery when charging. It can charge for different types of DC 3.7V cylindrical lithium batteries 10440, 14500, 14650, 16340, 16650, 17650, 17670, 18350, 18490, 18500, 18650, 18700, 22650, 20700, 21700, 22700, 25500, 26650, 26700 and 1.2V Ni-MH / Ni-CD AA, AAA, A, C, SC, rechargeable batteries. Comes with special charge and discharge management circuit. With multiple security protection settings, the charger can effectively prevent reverse, short circuit, overcharge, over discharge, over-current damage to the battery, which makes users using the product without any safety concern.
Original ThinkVape Thor AIO Pod System Kit Replacement Pod Cartridge with 0.2ohm & 0.5ohm Mesh Coils(1 PC) $5.99
The Think Vape Thor AIO Pod Cartridge is compatible with ThinkVape Thor AIO Pod System Vape Kit as a replacement part, which comes with 3ml E-juice capacity and bottom adjustable airflow system. There are two types of coils for different vaping: 0.5ohm Mesh Coil and 0.2ohm Mesh Coil.
Original ThinkVape Thor AIO Pod System Kit Replacement RBA Coil Head(1 PC) $4.99
The Think Vape Thor AIO Replacement RBA Coil Head is designed for Think Vape Thor AIO Pod System Vape Kit as a replacement part. It fits for DIY vaping lovers.
Original SMOKTech SMOK Nfix Pod System Kit Replacement Cartridge with 0.8ohm Coil(3 PCS) (Standard Edition) $10.99
The SMOKTech SMOK Nfix Replacement Pod Cartridge is designed for SMOK Nfix Mod Pod System Vape Kit as a replacement part, which is made of PCTG material. It comes with 0.8ohm MTL DC Dual Coil amd 3ml E-juice capacity. With DC MTL 0.8ohm coil, the SMOK Nfix pod will bring you the wonderful MTL vaping. 3 PCS / Pack.
YFTK Roulette RTA Clone Replacement Top Cap Tank Tube $4.39
The YFTK Replacement Top Cap Tank Tube is suitable for YFTK Roulette RTA Clone as a replacement part, which is made of PC material and comes with 3.5ml E-juice capacity.
Original Flagbearer QSX-W001 USB Miniature Sodium Hypochlorite Disinfectant Generator $8.99
The Sodium hypochlorite generator is a kind of water treatment disinfection sterilization equipment. The equipment uses saline as raw material to produce sodium hypochlorite solution through electrolytic reaction. Sodium hypochlorite is a strong oxidant and disinfectant. It takes place from a wide range of inexpensive industrial salt or seawater dilute solution, and it occurs through electrolysis without diaphragm. To ensure that sodium hypochlorite is fresh in texture and has high activity. To ensure the disinfection effect, the device will add sodium hypochlorite while it is occurring. Compared with chlorine and chlorine compounds, it has the same oxidizing and disinfecting effect. Just add water, tap water and common salt to produce 84 disinfectant (also called sodium hypochlorite disinfectant), with a sterilization rate of up 99.99% can be used anywhere, family, dormitory, school, kindergarten, hotel, hospital, office, restaurant, etc.
Старый 08.06.2020, 04:59 Автор темы   653
3FVAPE
Original Vaporesso Gen Nano 80W 2000mAh Box Mod $42.99
The Vaporesso Gen Nano TC VV VW Box Mod is powered by a built-in 2000mAh battery with 2A fast charging design and Max. Output Power 80W. It adopts textured rubber coating material to bring you smooth grip, portable size, scratch resistance function and fingerprint resistance function. And driven by AXON chip, it supports 4 modes for your option: Pulse Mode, Power ECO, Smart TC and DIY. Moreover, it is equipped with a 0.91-inch OLED screen to display clear details and bring you a more convenient operation.
Original Vaporesso Gen S 220W VW Box Mod $42.99
The Vaporesso Gen S 220W VW Box Mod is equipped with the intelligent AXON chip, GEN S makes advanced devices more accessible to users. GEN S truly realizes the power isn't just for the pros.
Original Vaporesso NRG-S Sub Ohm Tank Vape Atomizer Clearomizer $20.99
The Vaporesso NRG-S Sub Ohm Tank is constructed from stainless steel and glass, which features large 8.0ml E-juice capacity. It is perfectly match the Vaporesso GEN S VW Box Mod to make a great vapor for you.
Original Vaporesso GTX 22 Sub Ohm Tank Vape Atomizer Clearomizer $14.99
The Vaporesso GTX Tank 22 is constructed from stainless steel and glass, which features 3.5ml E-juice capacity and two types of GTX MESH Coil: GTX 0.2ohm MESH Coil (Pre-installed) and GTX 0.6ohm MESH Coil (In box). The replaceable Vaporesso GTX Coil brings dense and rich flavor to the vapers. With easy top refill and bottom airflow, the GTX Tank 22 is friendly to starters and beginners. The optimized GTX coils and the new GTX TANK 22 work perfectly to deliver great flavor in an instant when you vape, bringing the ultra-smooth airflow and rich clouds to you.
Original Vaporesso Gen Nano 80W 2000mAh Mod Kit with GTX Tank 22 $54.99
The Vaporesso Gen Nano Kit consists of a 2000mAh Gen Nano TC VV VW Box Mod and a 3.5ml Large GTX Tank 22 Atomizer, both of which are large enough to provide you with long-lasting vape. It adopts textured rubber coating material to bring you smooth grip, portable size, scratch resistance function and fingerprint resistance function. With a GTX Tank 22 and GTX Coils, it delivers fresh flavor, dense cloud and smooth airflow to you. Furthermore, with 2000mAh mod and 2A fast charging design, it can fire up to 80W output power. And driven by AXON chip, it supports 4 modes for your option: Pulse Mode, Power ECO, Smart TC and DIY. Moreover, it is equipped with a 0.91-inch OLED screen to display clear details and bring you a more convenient operation.
Original Vaporesso Zero Care 650mAh Pod System Kit $14.99
The Vaporesso Zero Care is well-known as the pacemaker of the refillable Pod system kit, which is powered by built-in 650mAh battery. Coming with an extra mesh pod and four eye-catching colors make it more invincible now. You'll experience the perfect flavor delivery and throat hit with this new pod. Moreover, the unique CCELL pod is optimized for higher nicotine satisfaction. The innovative filling system - Press to Fill (PTF TM ) makes refilling as simple as it gets, significantly reducing leakage. What's more, it comes with a 2ml E-juice capacity and one Zero CCELL Pod (1.3ohm) and one Zero MESH Pod (1.0ohm) for options to meet your different vapor needs.
Original Vaporesso Gen S 220W Mod Kit with NRG-S Tank Atomizer $59.99
The Vaporesso Gen S Mod Kit consists of Gen S 220W VW Vape Box Mod and NRG-S Tank Atomizer, which is equipped with the intelligent AXON chip, GEN S makes advanced devices more accessible to users. The GEN S matches an upgraded NRG-S tank with the GT MESHED and GT4 MESHED coils included, keeping giving extra power for every flavor punch. GEN S truly realizes the power isn't just for the pros.
Original Snowwolf P40 Mini 40W 1100mAh Pod System Vape Starter Kit $31.18
The Snowwolf P40 Mini Kit is a small but powerful all-in-one (AIO) Pod System Vape Starter Kit. The shell is made from lightweight Aluminum Alloy, the outline is almost square, but the edges and corners are very rounded. The main body is equipped with a complete control panel. The traditional fire button, 0.42-inch monochrome display, and a pair of adjustment keys are standard. Snowwolf P40 Mini is powered by a built-in 1100mAh battery, with the help of the USB Type-C port on the bottom, you can achieve 2A and 10W fast charging. What's more, Snowwolf P40 Mini is equipped with IFV960 Smart Chip, which can use 5 watts to 40 watts of variable wattage, auto mode, and special intelligent power curve and RBA mode. Under Auto Mode, P40 Mini would automatically adjust the wattage based on the coil put in. Different from the previous product, P40 Mini has a special working mode: Smart Wattage Curve Output, which can be achieved the best balance between the power and the taste. Use Taze Series RBA Coil (Not included, Sold Separately) to achieve RBA Mode to help you DIY your vaping style. The P40 Mini Pod is made from PCTG and can hold up to 5ml of E-juice, filled juice through the side holes. Snowwolf P40 Mini uses the new New Pod Mesh Coil-Snowwolf TAZE Coil, there are three types, all with airflow adjustment. (0.6ohm Taze-Beta Coil is included, but 1.0ohm and 0.3ohm Coils are not included, Sold Separetely)
Original Snowwolf P50 50W 1250mAh Pod System Kit $35.63
The Snowwolf P50 Kit is constructed from durable zinc alloy, with a stylish and beautiful flip shell, the size is moderate. The intuitive fire button is on the side, the Type-C charge port is below the button, and the color display with a touch screen is installed on the wide side panel. Instead of using the traditional push-button "+" and "-" buttons to adjust the power output, the touch screen to adjust. Snowwolf P50 is powered by an built-in 1250mAh battery with fast charging through 5V / 2A. The Snowwolf P50 has a built-in smart IFV960 chipset. The chipset supports 5 watts to 50 watts of power, provides incredible response speed, and has a coil recognition function while outputting large clouds of delicious vapor. It also supports RBA mode by matching the RBA coil. (Not included, Sold Separately) At the top sits a 4.5ml refillable pod featuring side fill system, while the bottom accepts coils from the Snowwolf TAZE Coil Series, offering three different coils and an RBA option that caters to those that love building. The standard kit will only include two interchangeable options with a resistance of 0.6ohm. The other side has air intake, by the bottom of the Taze coils to rotate the ring for airflow adjustment.
Старый 09.06.2020, 04:37 Автор темы   654
3FVAPE
Original Exvape eXpromizer TCX DL RDTA $42.90
The Exvape eXpromizer TCX DL RDTA is the self-winding vaporizer from EXvape which is constructed from Stainless Steel (body), Glass (tank tube), and POM (drip tip) in 25mm Diameter, it is specially designed for direct lung vape. It features large 7.0ml e-liquid capacity with top filling way and top airflow system, the airflow will hit the coil directly to bring you the amazing flavor. The EXpromizer TCX is the first self-winding vaporizer from EXvape, which is designed for vaping for direct lung inhalation (DL). It is a top coiler vaporizer, whereby the liquid is directed from the lower tank to the cotton wool via the capillary action of stainless steel wicks. The winding deck has two clamping jaws, to which you can simply attach a screen coil or mesh coil by screwing. The air flow holes at an angle on both sides lead the air supply directly to the coil. The EXpromizer TCX is filled with Liuqid via a side fill system. By rotating the top cap, the airflow opening is positioned over the fill opening in order to fill the tank. The liquid tank can be filled with up to 7 ml of liquid. Due to the design of the evaporator and the installation of the air supply at the top, the EXpromizer TCX is a leak-proof system.
ShenRay Taifun GX MTL / DL RDTA Clone $26.00
The ShenRay Typhoon Taifun GX MTL / DL RDTA Clone is constructed from 316 Stainless Steel and Glass material in 23mm Diameter featuring a flavour-focused interchangeable air flow system, easy-build coil winding deck, and SS liquid feeder cables to quickly deliver liquid to the deck down to every last drop in your tank. It also features a modular structure that allows the build deck to be removed from the lower tank and airflow section to allow easy user access to the wicks and the changeable air disks. Moreover, the RDTA supports MTL vaping and DL vaping experience and comes with 4ml E-juice capacity glass tank tube.
YFTK Taifun GX MTL / DL RDTA Clone $27.99
The YFTK Typhoon Taifun GX MTL / DL RDTA Clone is constructed from 316 Stainless Steel and Glass material in 23mm Diameter featuring a flavour-focused interchangeable air flow system, easy-build coil winding deck, and SS liquid feeder cables to quickly deliver liquid to the deck down to every last drop in your tank. It also features a modular structure that allows the build deck to be removed from the lower tank and airflow section to allow easy user access to the wicks and the changeable air disks. Moreover, the RDTA supports MTL vaping and DL vaping experience and comes with 4ml E-juice capacity glass tank tube.
Original Asvape Hita Mech Mod RBA Pod System Kit original price $39.99, now only $32.99
The Original Asvape Hita Kit is a pod device based on a mechanical mod design. It combines pod and mechanical design. The retro appearance of the mechanical lever combines the high-quality flavor of the POD device, which is portable and safe to operate. Asvape Hita Mech Pod Kit is powered by a built-in 1000mAh battery with max 30W output, which can easily support your long term requirement. And use Type-C charging port for fast charging, faster and safer, 1h can be fully charged, extra-long battery life. In addition, the intelligence chipset Reekbox developed by Asvape, which can automatically identify different coil resistance and match the best output power. Create perfect fogging effects, whether you are just getting started or advanced players can quickly master. Asvape Hita Mech Pod Kit also features indicator light with the fire button always inform the user as to the current battery levels. Asvape Hita Mech Pod comes with 3ml capacity. Convenient filling of juice liquid by opening the side silicone plug. Equipped side air inlet adjustment. The set comes with two mesh coils for DTL and MTL vaping. Asvape Hita is also compatible with RBA coil for DIY vaping. (RBA Coil is not included).
810 to 510 Drip Tip Conversion Adapter Connector for SMOK TFV8 Tank(1 PC) $1.99
The 510 Drip Tip Adapter Connector is made of Acrylic material featuring 7mm height and 22mm diameter, it is suitable for SMOK TFV8 Tank as a replacement part. With this adapter, you can use the standard 510 drip tip in your TFV8 Tank.
Original Wotofo Profile Unity RTA Replacement 810 Drip Tip $4.99
The mission for a drip tip is to supply vapor that generated from the atomizer. Most people choose drip tips on their personal preference for appearance. Of course appearance matters, however, drip tips do make a difference in flavor. The new profile unity RTA drip tip which is still made of resin kept the 810 connection standard for custom replacement if you prefer your own. It is nearly 2 times thicker than the one for the Profile RDA, but the center passage is smaller and has a gradual reduction in diameter downwards. The thickness is for consideration of heat dissipation and comfort, allowing the drip tip to snugly fit between your lips, while the center passage design facilitates flavor delivery. The passage size for the new profile unity RTA drip tip is tested to best balance air circulation and flavor enhancement.
Старый 09.06.2020, 04:42 Автор темы   655
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Wellon Beyond AIO Pod System Vape Kit Replacement Empty Pod Cartridge(1 PC) $4.99
The Wellon Beyond AIO Pod Cartridge is specially designed for Wellon Beyond AIO Pod System Vape Starter Kit. With 2ml E-juice capacity, it adopts top filling design for easy operation. It is also compatible with 3 types of coil: RBA, SS316 Mesh coil 0.3ohm and SS316 Mesh coil 0.8ohm (RBA Coil and SS316 Mesh Coils are not included, sold separately). which will meet your individual demands better.
Original Wellon Beyond AIO Pod System Vape Kit Replacement RBA Coil Head(1 PC) $6.99
The Wellon Beyond AIO replacement RBA Coil Head is made of Stainless Steel material, and it is specially designed for Wellon Beyond AIO Pod System Vape Starter Kit / Pod Cartridge. It fits for DIY vaping lovers. It comes with Single coil design and adjustable airflow system.
Original Wellon Beyond AIO Pod System Vape Kit / Cartridge Replacement SS316L Mesh Coil Head(5 PCS) $7.99
The Wellon Beyond AIO replacement Mesh Coil Head is made of SS316L material, and it is specially designed for Wellon Beyond AIO Pod System Vape Starter Kit / Pod Cartridge. It features 0.3ohm coil resistance and output power range from 25W to 35W. And the coils will give you a fantastic vaping experience, like decent flavor, huge cloud and never burnt out. 5 PCS / Pack.
Original DOVPO Blotto Mini RTA Replacement Straight Tank Tube(1 PC) $2.59
The DOVPO Blotto Replacement Straight Tank Tube is designed for DOVPO Blotto Mini RTA as a replacement part, which is made of Glass material and features 2ml E-juice capacity.
Original DOVPO Blotto Mini RTA Replacement Bubble Tank Tube(1 PC) $3.09
The DOVPO Blotto Replacement Bubble Tank Tube is designed for DOVPO Blotto Mini RTA as a replacement part, which is made of Glass material and features 4ml E-juice capacity.
Original DOVPO Blotto Mini RTA Replacement Bubble Tank Tube(1 PC) $4.39
The DOVPO Blotto Replacement Bubble Tank Tube is designed for DOVPO Blotto Mini RTA as a replacement part, which is made of PEI material and features 4ml E-juice capacity.
3FVAPE вне форума   Вверх
Старый 10.06.2020, 04:38 Автор темы   656
3FVAPE
Original League of Scoundrels CONSVR Vape Mechanical Mod original price $139.99, now only $35.99
The Original League of Scoundrels CONSVR Mechanical Mod is constructed from Brass material, it is perfect for everyday use with a look that definitely catches the eye. The mod utilizes an adjustable top insulated floating pin whilst the bottom contact is insulated and adjustable to accommodate any 18650 variation.
Original Aspire x Taifun Nautilus GT Mini MTL Sub Ohm Tank Vape Atomizer Clearomizer $24.95
The combined forces of two legends has given birth to the ultimate mouth-to-lung tank. Aspire and Taifun present, the NAUTILUS GT Mini. Nautilus GT Mini is the mini version of Nautilus GT. With a diameter of just 22mm, the Nautilus GT Mini is handy and convenient while keeping the same airflow and BVC coils as the Nautilus GT Tank.The thick stainless steel of Nautilus GT tank will also cool down quickly, to avoid getting hot. The Nautilus GT Mini uses the famous Aspire Nautilus BVC coils, which provide a premium MTL experience and extreme flavor enjoyment. The Nautilus GT Mini tank comes with an elegant new metal sleeve. The tank is compatible with Nautilus BVC / Nautilus 2 / Nautilus 2S / Nautilus AIO Coils (Nautilus BVC and Nautilus 2S Coils are included, but Nautilus 2 Coils and Nautilus AIO Coils are not included and sold separately). And it has 5 airflow adjustments: 1mm, 1.5mm, 1.8mm, 2.5mm to meet your different airflow control needs.
SXK 415 FOUR ONE FIVE MTL RTA Clone original price $24.90, now only $21.99
The SXK 415 FOUR ONE FIVE MTL RTA Clone is constructed from 316 Stainless Steel in 22mm Diameter, and it has a 4.5ml E-juice capacity tank tube. The RTA comes with a Single Coil Build Deck and supports Top Filling System and Bottom Airflow Control Adjustment. The RTA also supports MTL (Mouth-to-lung) vaping experience.
Original Vaptio Real Touch Pod System Kit $25.99
The Vaptio Real Pod System Vape Starter Kit is the first pod system with accurate wattage and temperature setting, which is powered by 500mAh built battery with 13W Max. Output and temperature control range from 100'C to 315'C. Comes with 1.5ml refillable Vaptio Real pod cartridge with porous cotton technology to provide you a better flavor. The Vaptio Real kit possesses two output modes: Temperature Control Mode and Variable Wattage Mode. It has a smart touch control screen, so you can precisely control and freely adjust the temperature and wattage that suit you best.
Original Omaoo Toucan Pod System Kit $23.99
The Omaoo Toucan with exquisite appearance and stable performance, which is powered by a 900mAh built-in battery to meet a long time vaping, charging through the Micro USB port on the bottom of the device. There is a circular activation button on the control panel, which is responsible for starting the device and adjusting the voltage. There are bright and colorful LED indicators below the button for displaying the voltage level and battery capacity status. The kit comes with two empty pods, with a capacity of 2ml, which can be filled by unplugging the top cap and opening the silicone plug. What's more, Omaoo Toucan empty pod is compatible with RELX battery (Not included), and the Omaoo Toucan battery is also compatible with RELX pod (Not included), meaning that you can use RELX pre-filled pods with various flavors and different colors, and you can repeatedly fill Toucan empty pods. Omaoo Toucan's high compatibility brings diversification needs. The ceramic coil inside the pod provides you with the purest taste of E-liquid.
Original Innokin Ares 2 D24 MTL RTA Replacement Straight Tank Tube(1 PC) $2.59
The Innokin Ares 2 Replacement Straight Tank Tube is designed for Innokin Ares 2 D24 MTL RTA as a replacement part, which is made of glass material in 24mm diameter and features 4ml E-juice capacity.
Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer(1 PC) $2.29
The Replacement Short 510 Drip Tip is made of Epoxy Resin material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Vaptio Real Pod System Kit Replacement Cartridge with 0.8ohm SS316L Coil(3 PCS) $9.55
The Vaptio Real Replacement Pod Cartridge is designed for Vaptio Real Pod System Vape Starter Kit, which is made from PC and PCTG material, comes with 1.5ml refillable E-juice capacity and 0.8ohm SS316L Coil with porous cotton technology. Through the unique porous cotton technology and compression process, plus American organic cotton, Vaptio Real pod provides smoother and better flavor. Do not worry, easy to refill E-liquid and no oil leakage. 3 PCS / Pack.
Original Aspire Nautilus GT Mini Tank Replacement Straight Tank Tube(1 PC) $1.99
The Aspire Nautilus GT Mini Replacement Straight Tank Tube is designed for Aspire Nautilus GT Mini Tank as a replacement part, which is made of glass material and features 2.8ml E-juice capacity.
SXK Replacement Straight Tank Tube for SXK / YFTK Flash e-Vapor V4.5S+ RTA Vape Atomizer Clone $1.90
The SXK Replacement Straight Tank Tube is suitable for SXK Flash e-Vapor V4.5S+ RTA Clone / YFTK Flash e-Vapor V4.5S+ RTA Clone as a replacement part, it is made of PEI material.
SXK Replacement Straight Tank Tube for SXK / YFTK Flash e-Vapor V4.5S+ RTA Vape Atomizer Clone $3.90
The SXK Replacement Straight Tank Tube is suitable for SXK Flash e-Vapor V4.5S+ RTA Clone/ YFTK Flash e-Vapor V4.5S+ RTA Clone as a replacement part, it is made of Glass material.
SXK 316 Stainless Steel Wicks-DLC with O-rings for SXK / YFTK Flash e-Vapor V4.5S+ RTA(2 PCS) $2.60
The SXK Stainless Steel Wicks-DLC with O-rings is suitable for SXK Flash e-Vapor V4.5S+ RTA / YFTK Flash e-Vapor V4.5S+ RTA as a replacement part. It is made of 316 Stainless Steel and comes with two silicone O-rings. It can make a Good E-liquid flow for your RTA. 2 PCS / Pack.
Старый 11.06.2020, 05:22 Автор темы   657
3FVAPE
SXK Stickman SLGT V2 Gera GT 70W TC VW Box Mod Clone original price $108.80, now only $95.99
The SXK Stickman SLGT V2 Gera GT 70W Box Mod Clone is a TC Temperature Control and VW Variable Wattage Box Vape Mod, which is constructed from Stainless Steel and Carbon Fiber, it is powered by 1 x 21700 Battery (Not included) and comes with 18650 Adapter Ring. This product supports Temperature Control (TC) Mode and Variable Wattage (VW) Mode
SXK Doggystyle 2K16 Doggy RTA Clone $12.99
The SXK Doggystyle 2K16 RTA Clone is made from 316 stainless steel and PC tank with 3.5ml juice capacity. The RTA is adjustable airflow from the bottom, adjustable slot from totally closed to 2.5mm.
Original VOOPOO Drag Mini 117W 4400mAh VW Box Mod Kit with PnP Tank(Refresh Standard Edition) $34.99
The VOOPOO Drag Mini Refresh Edition Kit consists of a 4.5ml Voopoo PnP Pod Tank and a Voopoo Drag Mini VW Box Mod, which is an updated edition of Drag Mini Series. It comes with higher performance and longer endurance. The Drag Mini Kit is powered by a 4400mAh Built-in Battery with 117W Max. Output Power. Both of them are large enough to provide long-lasting and powerful vaping experience. The pod tank can flexibly switch between Pod and Tank, and it is also compatible with all PnP coils, which will satisfy your different vaping demands. And adopting convenient bottom filling design, it supports adjustable air 510 base to match almost all your devices. Furthermore, driven by innovative GENE.FIT Chip, it features adjustable power in the range from 5W to 117W, allowing you to make beast clouds at once. And it is equipped with a screen to display clear information, making operation easier. Moreover, there are multiple protections to ensure your vaping safety.
Original VOOPOO Drag 2 177W VW Mod Kit with PnP Tank(Refresh Standard Edition) $53.99
The VOOPOO Drag 2 Refresh Edition Kit consists of a 4.5ml VOOPOO PnP Pod Tank and VOOPOO Drag 2 Box Mod, which is the new version of Drag 2 that comes with and inherits the classic design of Drag 2. The Drag 2 Kit is powered by dual 18650 batteries with 177W Max. power (Batteries are not included). Featuring innovative GENE.FIT Chip, it will provide fast ignition and high burst and support intelligent identification of coil to preventing the coil from burning out. Furthermore, the FIT mode will bring you better vaping experience with its safety design and long battery life. The PnP Pod Tank can flexibly switch between Pod and Tank and is designed with powerful magnetic absorption that makes coil replacement and oil filling never so simple. The adjustable air 510 base matches almost all of your devices. Drag 2 Refresh Edition is equipped with PnP-VM5 0.2ohm Coil and PnP-VM6 0.15ohm Coil. Moreover, it is compatible with ALL PnP Coils.
Original Sigelei Snowwolf P50 Pod System Kit Replacement Cartridge with 0.3ohm & 0.6ohm Mesh Coil(2 PCS) $7.99
The Sigelei Snowwolf P50 Replacement Pod Cartridge is designed for Sigelei Snowwolf P50 Pod System Vape Starter Kit as a replacement part, which features 4.5ml E-juice capacity and comes with advanced Mesh Coils: Taze- Gamma 0.3ohm and Taze-Beta 0.6ohm for different taste demands. With adjustable airflow system, the Snowwolf P50 cartridge can offer excellent experience for you. 2 PCS / Pack.
Original Sigelei Snowwolf P40 Mini Pod System Kit Replacement Cartridge with 0.3ohm & 0.6ohm Mesh Coil(2 PCS) $7.99
The Sigelei Snowwolf P40 Mini Replacement Pod Cartridge is designed for Sigelei Snowwolf P40 Mini Pod System Vape Kit as a replacement part, which features 5ml E-juice capacity and comes with advanced Mesh Coils: Taze- Gamma 0.3ohm and Taze-Beta 0.6ohm for different taste demands. With adjustable airflow system, the Snowwolf P40 Mini cartridge can bring smooth and rich flavors for you. 2 PCS / Pack.
Original Sigelei Snowwolf Taze Epsilon Replacement RBA Coil Head for Snowwolf Taze Kit / P40 Mini Kit(1 PC) $5.99
The Sigelei Snowwolf Taze Epsilon Replacement RBA Coil Head is compatible with Snowwolf Taze Kit / Snowwolf P40mini Kit as a replacement part, it fits for DIY vaping lovers.
Original Sigelei Snowwolf Taze-Alpha Replacement Coil Head for Snowwolf P50 Kit / P40 Mini Kit(5 PCS) $12.99
The Sigelei Snowwolf Taze Alpha Replacement Coil Head is compatible with Snowwolf P50 Kit / Snowwolf P40 Mini Kit as a replacement part, it features 1.0ohm coil resistance. 5 PCS / Pack.
Original Sigelei Snowwolf Taze-Beta Replacement Mesh Coil Head for Snowwolf P50 Kit / P40 Mini Kit(5 PCS) $12.99
The Sigelei Snowwolf Taze Beta Replacement Mesh Coil Head is compatible with Snowwolf P50 Kit / Snowwolf P40 Mini Kit as a replacement part, it features 0.6ohm coil resistance. 5 PCS / Pack.
SXK 415 FOUR ONE FIVE MTL RTA Clone Replacement Short Tank Tube $4.90
The Replacement Short Tank Tube is suitable for SXK 415 FOUR ONE FIVE MTL RTA as a replacement part. It is made of PEI material.
SXK 415 FOUR ONE FIVE MTL RTA Clone Replacement Long Tank Tube + Short Tank Tube + Drip Tip Kit(3 PCS) original price $11.90, now only $9.00
The Replacement PC Tank Tube and Drip Tip Kit is suitable for SXK 415 FOUR ONE FIVE MTL RTA as a replacement part.
SXK 415 FOUR ONE FIVE MTL RTA Clone Replacement Airflow Inserts(3 PCS) original price $11.90, now only $9.00
The Replacement Airflow Inserts is suitable for SXK 415 FOUR ONE FIVE MTL RTA as a replacement part. There are three kinds of airflow inserts for options: 3 x 1.0mm (cross, Smooth DL air pin), 1.2mm (1 hole, MTL air pin), and 1.0mm (3 holes). You can choose different inserts to meet your individual needs.
Original Auguse Era MTL RTA Replacement Middle Decorative Ring $2.99
The Auguse Era Replacement Middle Decorative Ring is designed for Auguse Era RTA as a replacement part, which is made from stainless steel in 3.3mm height and 22mm diameter. With this middle decorative ring on your Era RTA, it will make it looks better.
Старый 12.06.2020, 05:07 Автор темы   658
3FVAPE
Original Aspire MIXX 60W VV VW Box Mod $57.91
The Aspire MIXX Vape Box Mod is constructed from Satin Anodized Aluminum and Surgical Grade Stainless Steel material and it is powered by 1 x 18350 or 18650 Battery (Battery is not included, sold separately) . The Maxium Output is up to 60W, and it supports 3 Modes: VV, VW, and Bypass Mode. Equipped with a 0.91" OLED Screen, it can display all data of this device for you.
Original SMOKTech SMOK SCAR-P3 80W 2000mAh VW Pod System Kit $37.99
The SMOKTech SMOK SCAR-P3 80W VW Box Mod Pod System Vape Starter Kit is powered by 2000mAh built-in battery with Max. 80W Output Power, which is compatible with the renowned SMOK RPM Coil Series. Constructed from durable Zinc Alloy material, the chassis of the SMOK SCAR-P3 Kit is impervious to light falls and drops. Delivering output in a 1~80W range, the SCAR-P3 Pod System works well with the SMOK RPM Coil Series, delivering delicious vapor in MTL or DTL fashion depending on the coil installed. Featuring intelligent atomizer detection, the SMOK SCAR-P3 can detect the installed coil type for better function. Moreover, SMOK SCAR-P3 Kit features waterproof, shockproof, dustproof and can be charged by the convenient type-C charge port.
Original SMOKTech SMOK SCAR-P5 80W VW Pod System Kit $36.99
The SMOKTech SMOK SCAR-P5 80W VW Mod Pod System Vape Starter Kit, is powered by a Single 18650 battery with Max. 80W Output Power and constructed from Zinc Alloy materil, which can deliver flavor from the proprietary pod using RPM Coils. Delivering power in 1~80W range, the SMOK SCAR-P5 can work with any of the coils from the renowned SMOK RPM Coil series, while granting the ability to refill the magnetically held pod at the top. Moreover, SMOK SCAR-P5 Kit features waterproof, shockproof, dustproof and the inventive new coils will bring you the great flavor.
Original SMOKTech SMOK SCAR-P18 230W VW Mod Kit with TFV9 Tank $64.99
The SMOKTech SMOK SCAR-P18 VW Box Mod Kit consists of SMOK SCAR-P18 VW Box Mod and TFV9 Sub Ohm Tank. SCAR-P18 Mod Kit is powered by Dual 18650 Batteries with 230W Max. output (Batteries are not included). With a high shock absorption alongside water and dust resistance this is a SMOK SCAR-P18 kit that's built to last. Perfect for those always on the go, people who work in labour or just the accident prone among us. As for the SMOK TFV9 Tank is phenomenal and versatile. With an easy and mess-free fill hole and a wide array of coil options this tank is built for maximum flavour and super dense vape clouds. It is primarily a medium power tank but is suited perfectly for Sub Ohm vapers and higher power vapers alike with the wide array of coil options and wattage control. There are multiple protections that ensure your vaping safety such as short circuit protection, over-heating protection, and so on.
Original GeekVape Aegis Boost Plus 40W TC VW Pod System Kit original price $50.99, now only $33.99
The Geekvape Aegis Boost Plus Kit, is the new and updated version of the highly sought after Aegis Boost. The all new Aegis Boost Plus is powered by a Single 18650 Battery with a 40W Max. output and 200~600'F Temperature Control Range (Battery is not included). It's equipped with a Geek Vape signature Military Grape IP67 Shockproof, Dustproof and Waterproof rating. Constructed from durable Zinc Alloy material, the Aegis Boost Plus Kit can withstand dust, drops, and water, preventing it from malfunctioning due to environmental and user errors. The new G.Coil Boost-Formula allows you to chase the best flavor, while being designed to prevent leaking and capable of bringing out the best flavor from most vape juice. The 0.08s firing speed make you enjoy a fast and convenient vaping experience.
Original ROCK G3 Retractable 3 in 1 3.6A Fast USB Charge & Sync Cable $8.99
The ROCK G3 Retractable 3 in 1 Charge & Sync Cable is made of ABS + TPE + Al-Alloy material in 1200mm Length, it can adjust the cable's length to meet your usage in different occasions, and it is suitable for your iPhone / Type-C / Vape, etc. It is equipped with 3 different types of magnetic cable heads: Micro / Lightning / Type-C Port. You can switch the cable head to charge your different devices.
Original GeekVape Aegis Boost Plus Mod Pod System Kit Replacement Empty Pod Cartridge(2 PCS) $7.99
The GeekVape Aegis Boost Plus Replacement Empty Pod Cartridge is designed for GeekVape Aegis Boost Plus Mod Pod System Vape Kit as a replacement part, which features 4.5ml E-juice capacity. 2 PCS / Pack.
Original GeekVape Aegis Boost Plus Mod Pod Kit Replacement Cartridge with 0.4ohm & 0.6ohm Coils(1 PC) original price $9.99, now only $8.99
The GeekVape Aegis Boost Plus Replacement Pod Cartridge is designed for GeekVape Aegis Boost Plus Mod Pod System Vape Kit as a replacement part, which features 4.5ml E-juice capacity and comes with two types of coils: 0.4ohm coil and 0.6ohm coil.
SXK Replacement Air Closed Screw Insert Plug for Flash e-Vapor V4.5 / V4.5S+ RTA(1 PC) $1.79
The SXK Replacement Closed Screw is suitable for Flash e-Vapor V4.5 / V4.5S+ Style RTA as a replacement part, which can help you close your RTA's airflow well. The Closed Screw is 3.3 x 3.8mm in size.
SXK Replacement Bohrung Airflow Insert Air Screw for Flash e-Vapor V4.5 /V4.5S+ RTA(1 PC) $1.79
The SXK Replacement Bohrung Airflow Insert Air Screw is suitable for Flash e-Vapor V4.5 / V4.5S+ RTA Clone as a replacement part, which can help you adjust your RTA's airflow well. The Bohrung Airflow Insert Air Screw has a 1.6mm Airhole (inner diameter) and 5.02 x 3.86mm in size.
Старый 13.06.2020, 04:24 Автор темы   659
3FVAPE
Original SMOKTech SMOK SCAR-P18 230W VW Box Mod $47.99
The SMOKTech SMOK SCAR-P18 VW Vape Box Mod is powered by Dual 18650 Batteries with 230W Max. output (Batteries are not included). With a high shock absorption alongside water and dust resistance this is a SMOK SCAR-P18 Box Mod that's built to last. Perfect for those always on the go, people who work in labour or just the accident prone among us. There are multiple protections that ensure your vaping safety such as short circuit protection, over-heating protection, and so on.
Vapeasy Warlock Project 60W TC VW Stealth Box Mod Clone original price $59.99, now only $49.99
The Vapeasy Warlock Project Elite Edition Style Vape Box Mod is constructed from POM and Stainless Steel material. The Box Mod is equipped with the XN-60W Chipset to support single 18350 or 18650 battery with 60W max output (Battery is not included, sold separately). The XN-60W Chipset is a high-power, high-efficiency e-cig control chip that supports system's version upgrades and 0.91-inch OLED screen to display the data of this device in detail. XN-60W Chip has a built-in ARM core 32-bit processor and built-in temperature and power precise control regulators, which can stably output up to 60W power and 200~600'F precise temperature control, even in the charging state, it can also output accurately and stably. XN-60W Chip supports three output modes: POWER (Adjustable Power) / TEMP (Adjustable Temperature Control) / BYPASS (Bypass Mode). In the POWER Mode, it can get ECO smooth energy saving, Sports adjustable mode, and Normal flavor output. Furthermore, it can meet many application scenarios, and has multiple protection mechanisms such as open circuit, short circuit, overcharge, overdischarge, and temperature, etc. What's more, it can also support Nickel chrome wire / Ni200 / Ti / SS316L mode. The Vapeasy Warlock Project Style Vape Box Mod is compatible with 25mm max atomizer diameter. (Not included, sold separately). Please Note: $49.99 is the lower price for pre-order. It will rise in price as product in 24HRS zone.
Genelocity Giant RTA Clone $29.99
The Genelocity Giant RTA Clone is absolutely a giant in the market. It is constructed from stainless steel in 32.5mm diameter. The glass tank features a huge capacity of 12ml. The large build deck, with two four-screw-hole posts in it, supports large clapton coils. The innovative adjustable top cap features two sets of air slots and holes. You can change it 180 degrees for another type of airflow at anytime. The RTA comes with removable wide bore drip tip and 510 drip tip adaptor to meet your different meets.
Original Vapor Storm V-PM 40 40W VW Pod System Kit $17.99
The Vapor Storm V-PM 40 Box Mod Pod System Vape Starter Kit is the lightest pod mod in the current market, which is powered by single 18650 battery (Not included) and it can provide 5W to 40W adjustable working voltage. The 0.96 inch colorful TFT screen will display the current battery level, resistance, and puff times for you. The pod is smartly inserted and locked in the box by a magnetic connector, it can use ALL 510 thread atomizer (pod connector is not included, sold separately) Moreover, V-PM 40 Mod Pod kit has also multiple protections to ensure your vaping safety.
Original Golisi Needle 1 One-Slot USB Charger for Li-ion 18650 / 26650 /21700/20700/18500/18350/Ni-mh/Ni-cd/AAA/AA, etc. $4.99
The Golisi Needle 1 One-Slot USB Charger is a portable and safe smart charger with one battery slot. It has a USB power port with DC 5V / 1A power input. What's more, it is compatible with almost ALL TYPES OF cylinder shape rechargeable batteries such as 18650, 20700, 21700, 26650 and 18350 batteries with 0.5A output current. Together with a LED light indicating the battery charging situation, light Short Circuit Protection, Over-Current Protection, Reverse Connection Protection and Over-Heat Protection, Needle 1 Charger will bring you a simple and safe charging experience.
Старый 15.06.2020, 04:40 Автор темы   660
3FVAPE
Original Vandy Vape Berserker BSKR V2 MTL RTA original price $39.99, now only $29.99
The Vandy Vape Berserker BSKR V2 RTA is constructed from stainless steel and glass (with spare PEI tube) in 24mm diameter. Berserker BSKR V2 RTA comes with two 3ml E-juice capacity tubes (Glass tube and PEI tube) and three drip tips for options. And it features a new comfortable design of refill cap to make it convenient and easy. The RTA supports bottom airflow control, and it supports variable setting of bottom airflow (0.8mm / 1.0mm / 1.4mm / 1.6mm / 2.0mm / D-1) to meet your different individual vaping needs.
Taifun GX MTL / DL RDTA Clone $20.99
The Taifun GX MTL / DL RDTA Clone is constructed from 316 Stainless Steel and Glass material in 23mm Diameter featuring a flavour-focused interchangeable air flow system, easy-build coil winding deck, and SS liquid feeder cables to quickly deliver liquid to the deck down to every last drop in your tank. It also features a modular structure that allows the build deck to be removed from the lower tank and airflow section to allow easy user access to the wicks and the changeable air disks. Moreover, the RDTA supports MTL vaping and DL vaping experience and comes with 4ml E-juice capacity glass tank tube.
Original IJOY Captain 1500 VW Pod System Kit $29.99
The IJOY Captain 1500 40W Box Mod Pod System Vape Kit is powered by a 1500mAh built-in battery with a maximum output of 40W. The IJOY Captain 1500 has large E-juice capacity of 5ml, bringing a spacious storage for juice filling. The IJOY Captain 1500 Pod uses new C15 series mesh coils, so it is compatible with regular e-juice and nic salts. The IJOY Captain 1500 can be easily refilled by pulling the silicone block out at the side. And it also supports RBA Coil (Not included, sold separately). The 0.96-inch TFT screen displays all vaping data clearly for you.
Original Sense Miosolo Pod System Kit $6.99
The Sense Miosolo Kit is the world's 1st rechargeable-refillable disposable pod system kit. Miosolo Kit is powered by a 480mAh built-in battery with USB charging and comes with a 2ml pod cartridge with top filling system. It features high cost-efficient like 5 times' refilling. Furthermore, it is user-friendly, such as easy to charge, easy to refill, mini size, fashion design, suitable for multiple options like E-liquid and flavors, and so on.
Original GeekVape Wenex Stylus Pod System Kit original price $18.99, now only $14.99
The GeekVape Wenex Stylus Pod System Vape Starter Kit is powered by a 1100mAh built-in battery with Maximum 16W Output. Wenex Stylus Pod Kit supports Auto Fire System (0.6ohm, 14W / 15W / 16W; 1.2ohm, 9W / 10W / 11W) and Button Fire System (0.6ohm, 1.6W; 1.2ohm, 11W). Wenex Stylus Pod Kit comes with a 2ml E-juice capacity pod, G Coil Pod Formula and unibody aluminium structure to provide you a great vaping experience. The Longlast Battery can meet your all day long vape.
Replacement Protective Silicone Sleeve Case for 28~30mm Diameter & 17~22mm Height Glass Bubble Tank Tube(1 PC) $0.99
The Replacement Protective Sleeve Case is made from silicone material and it is suitable for ALL glass bubble tank tube with height between 17mm and 22mm and diameter between 28mm and 30mm as a replacement part for protecting your glass tube.
Original GeekVape Wenex Stylus Pod System Kit Replacement Empty Pod Cartridges(3 PCS) original price $10.99, now only $4.99
The GeekVape Replacement Empty Pod Cartridge is designed for GeekVape Wenex Stylus Pod System Vape Kit as a replacement part, which features 2ml E-juice capacity. 3 PCS / Pack.
Original IJOY Captain 1500 Mod Pod System Kit / Cartridge Replacement C15D Coil Head(3 PCS) $8.99
The IJOY Replacement C15D Coil Head is suitable for IJOY Captain 1500 Mod Pod System Vape Kit as a replacement part, which features 0.7ohm coil resistance and output range from 15W to 25W. 3 PCS / Pack.
Original IJOY Captain 1500 Mod Pod System Kit / Cartridge Replacement C15 Mesh Coil Head(3 PCS) $8.99
The IJOY Replacement C15 Mesh Coil Head is suitable for IJOY Captain 1500 Mod Pod System Vape Kit as a replacement part, which features 0.3ohm coil resistance and output range from 30W to 40W. 3 PCS / Pack.
Original IJOY Captain 1500 Mod Pod System Kit Replacement Empty Pod Cartridge(1 PC) $6.99
The IJOY Captain 1500 Replacement Empty Pod Cartridge is designed for IJOY Captain 1500 Mod Pod System Vape Kit as a replacement part. It comes with 5ml E-juice capacity to bring you best flavor and vast clouds, and dual adjustable airflow system can bring smooth and rich flavors. It is compatible with C15 0.3ohm Mesh Coil / C15D 0.7ohm Coil and RBA Coil to meet your different vaping needs. (Coils are not included, sold separately)
510 Thread Adapter Connector for Voopoo Drag S / Drag X Pod System Vape Kit $2.99
The 510 Thread Adapter Connector is designed for Voopoo Drag S VW Mod Pod System Vape Kit / Drag X VW Mod Pod System Vape Kit, it is made of stainless steel (510 threading connector) and POM (outer housing), which can switch your Drag S or Drag X box mod kit into a normal 510 thread box mod kit to use different atomizers as you like.
Original Reewape 510 Thread Adapter Connector for Voopoo Drag S / Drag X Pod System Vape Kit $3.99
The Reewape 510 Thread Adapter Connector is designed for Voopoo Drag S VW Mod Pod System Vape Kit / Drag X VW Mod Pod System Vape Kit, it is made of stainless steel (510 threading connector) and POM (outer housing), which can switch your Drag S or Drag X box mod kit into a normal 510 thread box mod kit to use different atomizers as you like.
Время генерации страницы 0.78807 секунды с 15 запросами
