302440
822
621
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original FreeMax Maxpod 11W 550mAh Pod System Vape Starter Kit $24.99
The FreeMax Maxpod Kit, it's a portable, powerful yet durable draw-activated open pod system. With FreeMax patented NS Mesh Coil technology inspired from world-known Fireluke and M Pro product line, it's customized to preserve the original flavor while increasing the throat hit for both salt nicotine and freebase e-liquids. Powered by 550mAh built-in battery and 3.3V constant output, the FreeMax Maxpod offers you strong and stable performance from the first to the last vape. ![]() Original FreeMax Maxpod Pod System Replacement Pod Cartridge(1 PC) $3.99 The Original FreeMax Maxpod Pod System Replacement Pod Cartridge is with 2.0ml capacity. It is Compatible with NS Mesh coil 1.0ohm / 1.5ohm (not included) ![]() Original FreeMax Maxpod Pod System Replacement NS Mesh Coil Head(5 PCS) $9.99 The Original FreeMax Maxpod Pod System Replacement NS Mesh Coil Head is with 1.0ohm resistance in 5 PCS / pack. The coil is made from 66.66% Flax Cotton and 33.34% Organic Cotton. The 1.0ohm NS Mesh Coil Head supports Nic Salt (Best 20~30mg) and Freebase E-liquid (Best 3~12mg) ![]() Original FreeMax Maxpod Pod System Replacement NS Mesh Coil Head(5 PCS) $9.99 The Original FreeMax Maxpod Pod System Replacement NS Mesh Coil Head is with 1.5ohm resistance in 5 PCS / pack. The coil is made from 44.44% Flax Cotton and 55.56% Organic Cotton. The 1.0ohm NS Mesh Coil Head supports Nic Salt (Best 30~50mg) and Freebase E-liquid (Best 12~24mg) ![]() Steam Tuners Steel Tank Clone + Chimney for Flash e-Vapor E-Vapor V4.5 RTA $8.99 The Steam Tuners Steel Tank Clone is made from stainless steel and PC. It is suitable for Flash e-Vapor E-Vapor V4.5 RTA. The stainless steel will be in Black and the PC tank is Translucent Black, the real image will be upgraded soon. ![]() Vapeasy Grizzly Rebuildable RBA Bridge Clone with 1.1mm + 1.4mm + 1.9mm AFC for SXK BB 60W / 70W / Billet Box Mod Kit $14.99 The Vapeasy Grizzly Rebuildable RBA Bridge Clone is made from stainless steel and is suitable for SXK BB DNA 60W / 70 / Billet Box Mod Kit. It comes with genesis building deck Clone. ![]() Original Alchemy Disposable Surgical Medical Face Mask Respirator Anti Bacteria / Virus / COVID-19 - FDA Certification (50 PCS) $26.99 The Alchemy disposable face mask is strictly implemented in accordance with the medical device production standard (YY/T 0969-2013).The relevant license is expected to pass the approval in early April. The package is not in the form of "medical" before the certificate is issued. BFE95/PFE95 filter layer: Effectively filter dust particles and bacteria larger than 2.5um in diameter, prevent most virus infection sources, and protect the respiratory system. ![]() Original Alchemy KN95 FFP2 Protective Face Mask Particulate Respirator Anti Bacteria/Virus/COVID-19 - FDA Certification (10 PC) $27.99 Alchemy KN95 FFP2 Anti Bacterial Respirator Face Mask means that it can filter 95% of the air Oil-free particles, prevent Coronavirus and pm2.5 air pollution, suitable for home and professional use, making your indoor and outdoor breathing easier. KN95 mask is a great alternative to the N95 mask. And it's also better than the disposable mask if you have to go to where the crowds gather. 4-Layer filtering method for maximum protection. Alchemy KN95 masks are comfortable, soft on the skin, non-toxic and non-irritating. Reduce the viral infection in crowd Light and Non-bulky, fabric-based. Comfort wear, elastic fasteners with latch-on clip. When worn correctly, you will benefit from comprehensive protection. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
622
Replacement 810 Snake Skin Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy/Battle/Reload RDA Vape Atomizer $1.89
The Replacement 810 Snake Skin Drip Tip is made of Resin, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Shorty Wide Bore Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.29 The Shorty Wide Bore Replacement 510 Drip Tip is made of Delrin material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Replacement 510 Wide Bore Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99 The Replacement 510 Drip Tip is made of Carbon Fiber and SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
623
Original Vape Master X80T 80W 2500mAh TC VW Box Vape Mod original price $30.99, now only $13.99
The Vape Master X80T 80W TC VW Box Vape Mod is powered by 2500mAh Built-in Battery. The X80T Mod supports Temperature Control and Variable Wattage Adjustable. The output power range can from 7W to 80W, and the range of temperature ranger can from 200'F to 600'F / from 100'C to 315'C. ![]() Kindbright Alpha RTA Clone $18.99 The Kindbright Alpha RTA Atomizer Clone is constructed from 316 Stainless Steel in 22mm diameter. The RTA features single coil build deck, it supports bottom airflow adjustable control and E-liquid adjustable control, comes with a 2.8ml E-juice capacity PEI tank. ![]() Original Aspire Minican 350mAh Pod System Vape Starter Kit(Standard Version) $10.99 The Aspire Minican is an ultra-small and stealthy vape pod with very fashionable look and compact structure, you will get super good vapor and flavor performance at a low cost from it. The Aspire minican adopts the top-grade rubber paint, which gives the holder a perfect grip while providing a delicate and comfortable feel. This paint material is also anti-dust. The minican pod is held in place into the main body with strong magnets for stable connection and output. The installed and non-replaceable 1.2ohm Mesh Coil will output powerfully to provide massive vapor and richer flavor. The minican has an auto-draw system, simply vape without pressing any buttons. It outputs in Bypass mode for either optimal flavor and vapor performance, or durable coil life. Aspire minican has a refillable pod and is very convenient to fill. Simply pull out the pod from the battery section and lift the silicon seal to supply it with your perferred E-liquid. A leak-proof silicone design set inside the filling port complies with TPD leak-free standards. The minican has a 350mAh battery capacity, charging via Micro USB charging port. Equipped with Aspire ASP Chipset, there are multiple protections that ensure your vaping safety. ![]() Original VOOPOO DRAG S 60W 2500mAh VW Mod Pod System Vape Starter Kit $37.99 The VOOPOO DRAG S VW Mod Pod Kit is a compact and ergonomic pod mod system kit that consists of a 4.5ml pod cartridge and a 2500mAh built-in battery. The pod cartridge adopts a bottom refilling design and innovative infinite airflow system for the most comfortable experience. The Kit comes with a PnP-VM1 0.3ohm Coil and a PnP-VM5 0.2ohm Coil, it is also compatible with the other PnP coils, which can bring you DL and MTL vaping experience. As for the mod, it features adjustable power in the range of 5W to 60W. Monitored by GENE.TT chip, it can ignite within 0.001s, and also provides intelligent functions such as PUFF recording, SCORE ranking, SMART switching start mode, and so on. Moreover, there are 7 safety protections to ensure your vaping safety. The RBA Coil is not included. ![]() Original VOOPOO DRAG X 80W VW Mod Pod System Vape Starter Kit $39.99 The VOOPOO DRAG X Pod Kit is made of metal and leather, so Drag X is not only soft, but also has advantages of anti scratch, anti perspiration and anti fingerprint. It is powered by Single 18650 battery (Not included). Equipped with the new GENE.TT Chip, Drag X features fast ignition (only takes 0.001s) and high burst. GENE.TT Chip also offers intelligent functions such as PUSS and SCORE ranking mode. In addition, the SCORE ranking mode helps you continuously unlock the new level from "IRON" to "KING" according to the cloud size of each suction. It comes with power range from 5W to 80W to fit your needs and the 80W max power will enable you to make bigger flavorful clouds. Drag X is designed with the innovative infinite airflow system that supports the regulation of any size of airway. Most importantly, you can enjoy the most comfortable experience through this system no matter which kind of coil or different parameters are set! As for the pod, it can hold 4.5ml E-juice capacity and adopt a wide range of coils, including RBA (RBA Coil is sold separately). The 510 adapters and other new technologies are also be added to this pod. Drag X is equipped with 0.15ohm and 0.3ohm PnP coil and it is compatible with all PnP coils. Moreover, there are 7 safety protections to ensure your vaping safety. ![]() Replacement Tall 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer(1 PC) $1.99 The Replacement Tall 510 Drip Tip is made of Resin material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Replacement Short 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer(1 PC) $2.29 The Replacement Short 510 Drip Tip is made of Resin material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
624
Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer(1 PC) $2.39
The Replacement 510 Drip Tip is made of Resin material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Acrohm Fush Nano Pod System Vape Kit Replacement Pod Cartridge with 1.0ohm Mesh Coil(2 PCS) $6.99 The Acrohm Fush Nano Replacement Pod Cartridge is designed for Acrohm Fush Nano Pod System Vape Kit as a replacement part. It features 1.8ml E-juice capacity and comes with 1.0ohm Mesh Coil. The capacity is increased from Acrohm Fush Nano Pod Cartridge 1.5ml to 1.8ml, and the pod is able to be refilled up to 10 times, much more than its kind with more stable flavor maintenance. Integrated 1.0ohm mesh coil in 1.8ml cartridge, 1.0 ohm mesh coil with strong and uniform heating capacity, matched with nature organic cotton owning high oil conductivity, it will deliver the extremely delicious and rich flavor. 2 PCS / Pack. ![]() Original Auguse Era MTL RTA Replacement Top-Filling Top Cap Tank Tube - Type A $7.99 The Auguse Replacement Top Cap Tank Tube with top refilling system is designed for Auguse Era MTL RTA as a replacement part. It is made of Stainless Steel and Glass, which features 3ml E-juice Capacity. ![]() Original Auguse Era MTL RTA Replacement Top-Filling Top Cap Tank Tube - Type B $7.99 The Auguse Replacement Top Cap Tank Tube with top refilling system is designed for Auguse Era MTL RTA as a replacement part. It is made of Stainless Steel and Glass, which features 3ml E-juice Capacity. It features Heat Sink Effect. ![]() Original Auguse Era MTL RTA Replacement Top-Filling Top Cap Tank Tube - Type A $6.99 The Auguse Replacement Top Cap Tank Tube with top refilling system is designed for Auguse Era MTL RTA as a replacement part. It is made of Stainless Steel and Glass, which features 3ml E-juice Capacity. ![]() Original Aspire Minican Pod System Vape Kit Replacement Pod Cartridge with 1.2ohm Mesh Coil(2 PCS) Standard Version $7.12 The Aspire Minican Replacement Pod Cartridge is designed for Aspire Minican Pod System Vape Kit as a replacement part. It features 2ml E-juice Capacity and comes with 1.2ohm Mesh Coil. 2 PCS / Pack. ![]() Original Auguse Era MTL RTA Replacement Top-Filling Top Cap Tank Tube - Type B $6.99 The Auguse Replacement Top Cap Tank Tube with top refilling system is designed for Auguse Era MTL RTA as a replacement part. It is made of Stainless Steel and Glass, which features 3ml E-juice Capacity. It features Heat Sink Effect. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
625
Original Dovpo Odin Mini DNA75C 75W TC VW Box Vape Mod $149.99
The Dovpo Odin Mini DNA75C TC VW Box Mod is the smallest member of the Odin series, it is the collaboration created by Dovpo, Vaperz Cloud, and Vaping Bogan. This slim, single 21700 device is the follow up to its bigger brothers The Odin DNA250C and Odin 200. The Odin Mini is more lightweight and the ergonomic feel of the device is comfortable in the palm of your hand. The outer shell is made of high-quality aluminum alloy material. It is particularly prominent visually and is very suitable for carrying around. The Odin Mini Mod is powered by a single 21700 battery (Not included) and with 5V / 1A charging system for the fast charging. The battery can be inserted and removed through the foldable battery compartment cover for external charging. The front-panel with 3 adjustment buttons and the large firing button with Vaping Bogan Logo, easy to use and operate, the 0.96-inch large colorful display will show you the vaping data clearly. Like the large Odin, Odin Mini also uses one of Evolv's most popular DNA chipsets-DNA75C for operation, which brings you better battery efficiency, you may maximize vape times. It has unmatched responsiveness and can provide up to 75 watts of power. Odin Mini also supports the various heating elements, such as Nickel, Titanium, and Stainless Steel, or you can adjust the resistance setting via the TCR Mode, only recommended if you are an experienced vaper. DNA chips are one of the safest chipsets in the market, and various protection circuits ensure safe use. Combined with EScribe software and PC with an Internet connection, you can make full use of the full potential of the DNA75C chip. The smaller shape and design are perfect for on the go use and you can feel comfortable knowing that it can accommodate any atomizer, flush, up to 26mm. ![]() Original Dovpo x Vaping Bogan Blotto Mini RTA $26.90 The Dovpo Blotto Mini RTA is the mini version of Blotto RTA which is lighter and smaller, a collaboration between Vaping Bogan and Dovpo. It's an aesthetically pleasing RTA that delivers a restricted lung hit with lots of flavors. The Blotto Mini RTA has a diameter of 23.4mm and comes with a capacity of 2ml straight glass tube and a 4ml bubble glass tube. Taking design influence from an old-fashioned bottle cap, the knurling on the Blotto Mini RTA allows for easy removal of the threaded top cap to reveal the dual fill ports, and the top filling method will not worry about the leakage. For cleaning and maintenance, the RTA may be completely disassembled into the drip tip, top cap, chimney, glass tube, and the build deck. Blotto Mini RTA continues the 242 degrees airflow system and dual or single coil build deck. It's bottom-fed airflow with honeycomb-style holes, where the air comes through the bottom of the deck and around the sides, giving you 242 degrees of airflow hitting your coils. The airflow system with internal air inlet makes its best flavor production stand out. ![]() Original SMOK RPM160 160W VW Mod Pod System Vape Starter Kit $38.99 The SMOKTech SMOK RPM160 VW Mod Pod Kit is the upgraded version of the extremely popular SMOK RPM80. The RPM 160 features the ability to use dual 18650 batteries (Not included) and is offered in a multitude of gorgeous carbon fiber colors. Equipped with the newest Smok IQ-160 chipset, offering a variety of intelligent features and functional protections that allows the device to fire up to 160W. In addition the fast charging system allows the battery to be fully charged in a short time. The RPM160 has the option of using two different pods: the RPM Pod and RGC Pod. Both of them hold 5ml of E-juice, the RPM Pod is compatible with all RPM Coils. The RGC Pod is Smok's first pod with an adjustable airflow design. This is the ultimate ultra portable high wattage box mod / pod system all in one. ![]() Original Ohm Vape MP60 60W 1300mAh VW Box Mod Pod System Vape Starter Kit $24.99 The Ohm Vape MP60 VW Mod Pod Kit is a versatile pod that combines exquisite and compact products with the powerful vaping experience. It is small in size but has a battery capacity of 1300mAh, enough to meet long-time vape needs, and a power range from 5W to 60W for you to adjust. In addition, Ohm Vape MP60 integrates innovative chipset inside, shortening the firing time to 0.001s, and charging time to two hours. Ohm Vape MP60 offers you stable and superior vaping. As for Ohm Vape MP60 Pod, it is a refillable empty pod, with 3.7ml E-juice capacity, pull out the rubber plug on the side slot and inject E-liquid through the slot. The MP60 Kit comes with two pod types (MP Standard Pod and MP Pod), respectively pre-installed with newly designed MP mesh 0.4ohm coil and 0.7ohm coil. The newly designed MP mesh 0.4ohm Coil is designed for the best flavor and excellent vapor production. Small and powerful MP60, innovation brings a new vaping experience! ![]() Original Hugo Vapor Z ONE Pod System Vape Kit Replacement Pod Cartridge with 0.14ohm Coil(4 PCS) $8.99 The Hugo Vapor Z ONE Replacement Pod Cartridge features 1.5ml E-liquid Capacity and comes with 0.14ohm resistance coil. It is not only designed for Hugo Vapor Z ONE Pod Vape Kit, but also compatible with Uwell Caliburn device and pod. 4 PCS / Pack. ![]() Original Ohm Vape MP60 Pod System Vape Kit Replacement MP Pod Cartridge with 0.7ohm Coil(2 PCS) $11.99 The Ohm Vape MP60 Replacement MP Pod Cartridge is designed for Ohm Vape MP60 Pod System Vape Kit as a replacement part. It features 3.7ml E-juice capacity and comes with 0.7ohm Coil. 2 PCS / Pack. ![]() Original Ohm Vape MP60 Pod System Vape Kit Replacement Standard MP Pod Cartridge with 0.4ohm Mesh Coil(2 PCS) $11.99 The Ohm Vape MP60 Replacement Standard MP Pod Cartridge is designed for Ohm Vape MP60 Pod System Vape Kit as a replacement part. It features 3.7ml E-juice capacity and comes with 0.4ohm Mesh Coil. 2 PCS / Pack. ![]() Original Ohm Vape MP60 Pod System Vape Kit / Cartridge Replacement MP Coil Head - 0.7ohm(5 PCS) $8.99 The Ohm Vape MP60 Replacement Coil Head is designed for Ohm Vape MP60 Pod System Vape Kit as a replacement part. It features 0.7ohm coil resistance. 5 PCS / Pack. ![]() Original Ohm Vape MP60 Pod System Vape Kit / Cartridge Replacement MP Mesh Coil Head - 0.4ohm(5 PCS) $8.99 The Ohm Vape MP60 Replacement Coil Head is designed for Ohm Vape MP60 Pod System Vape Kit as a replacement part. It features 0.4ohm mesh coil resistance. 5 PCS / Pack. ![]() ------------------- Happy Mother's Day!! Offer: All Products 5% OFF Time: 8th May 00:00 - 10 May 2020 23:59 (UTC-6 / Denver Time) Code: MothersDay2020 Note: This offer is not stackable with other MAP discounts. |
626
KF 5² Square SE RTA Clone $21.99
The KF 5² Square SE RTA Rebuildable Tank Vape Atomizer Clone is constructed from Stainless Steel (body) and PSU (tank tube) in 25mm Diameter. The RTA comes with a 7.0ml E-juice capacity tank tube. It features single coil build deck, which support DL vaping experience, liquid flow control and top filling system. ![]() Original Auguse 2 in 1 Slotted & Phillips Screwdriver $2.99 The Auguse 2 in 1 Screwdriver can be used as a Slotted Screwdriver or a Phillips Screwdriver. It is made of Stainless Steel in 62mm Length, 5.2mm Diameter. ![]() Noi Replacement MTL 510 Drip Tip Clone for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $3.99 The Noi Replacement MTL 510 Drip Tip Clone is made of POM material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Auguse Diamond Replacement MTL 510 Drip Tip for RDA / RTA/RDTA/Sub-Ohm Tank Vape Atomizer $3.99 The Auguse Diamond Replacement MTL 510 Drip Tip is made of POM and Acrylic material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Auguse 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99 The Auguse Replacement 510 Drip Tip is made of POM and PEI, SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Auguse Replacement MTL 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99 The Auguse Replacement MTL 510 Drip Tip is made of POM material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Auguse Replacement MTL 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99 The Auguse Replacement MTL 510 Drip Tip is made of POM material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Auguse Replacement MTL 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99 The Auguse Replacement MTL 510 Drip Tip is made of POM material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
627
The Auguse Replacement MTL 510 Drip Tip is made of POM material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Auguse Replacement MTL 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99 The Auguse Replacement MTL 510 Drip Tip is made of POM material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Auguse Replacement MTL 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99 The Auguse Replacement MTL 510 Drip Tip is made of POM material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Auguse Replacement Top Cap Tank Tube for Auguse V1.5 MTL RTA $8.99 The Auguse Replacement Top Cap Tank Tube is designed for Auguse V1.5 MTL RTA Vape Atomizer as a replacement part. It features 4.0ml E-juice capacity and is made of PEI material. ![]() Original Auguse Replacement Top Cap Tank Tube with Top Refilling System for Auguse V1.5 MTL RTA $7.99 The Auguse Replacement Top Cap Tank Tube w/ Top Refilling System is designed for Auguse V1.5 MTL RTA Vape Atomizer as a replacement part. It features 4.0ml E-juice capacity and is made of Stainless Steel and PC material. ![]() Replacement Long 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99 The Replacement 510 Drip Tip is made of SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Replacement Short 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99 The Replacement 510 Drip Tip is made of SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Replacement Top Cap Tank Tube Nano Kit for Taifun GT4 S GT 4 S IV S DL RTA Clone $7.99 The Taifun Replacement Top Cap Tank Tube Nano Kit is designed for Taifun GT4 S GT 4 S IV S DL RTA Vape Atomizer Clone as a replacement part. It is made of Stainless Steel and PC material, and features 2.9ml E-juice capacity. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
628
SXK Stickman SLGT V2 Gera GT 60W VW Vape Box Mod Clone $129.90
The SXK Stickman SLGT V2 Gera GT Box Mod Clone is a VW Variable Wattage Box Vape Mod, which is constructed from Stainless Steel and Carbon Fiber, it is powered by 1 x 21700 Battery (Not included) and comes with 18650 Adapter Ring. The Stickman SLGT V2 is equipped with Evolv DNA 60 Chip. The DNA 60 is a power regulated digital switch-mode DC-DC converter for personal vaporizers. It features Evolv's patented Wattage Control, Temperature Protection, Preheat, OLED Screen, Reverse Polarity Protection, and waterproof onboard buttons. The DNA 60 runs from a single lithium polymer or lithium-ion battery, and features battery monitoring. ![]() Original Asmodus Galatek RDA with BF Pin original price $29.99, now only $9.99 The Asmodus Galatek RDA is a low profile RDA with unique graveyard deck, which is constuctred from Stainless Steel in 24mm Diameter, it allows enough space for easy coil building in such low profile atomizer. The metal cage that sits between the drip tip and top cap can absorb and dissipate the excess heat. ![]() Original IJOY Captain 2 180W TC VV VW Mod Vape Starter Kit with Captain V Tank $59.99 The IJOY Captain 2 Kit consists of IJOY Captain 2 180W TC VV VW Box Mod and Captain V Tank Atomizer. Captain 2 continues the amazing design and performance of the Captain series of mods. IJOY Captain 2 Box Mod is constructed from durable and lightweight Aluminum Alloy with ergonomic dimensions. Captain 2 Mod is powered by dual 18650 batteries (Not included) and has a maximum wattage of 180 watts. It has ample power and a large number of functions to bring incredible experience. In addition, IJOY Captain 2 Mod is equipped with a new 0.96-inch full-color display, which can provide more detailed working data. On the control face, you can see an oversized fire button and an ergonomic grip underneath. The IJOY Captain 2 Mod is Dust and Shock Proof, durable. The various protection systems ensure a safe vaping environment. Paired with the IJOY Captain V Tank, the Captain 2 Starter Kit can utilize coils from the IJOY Captain X3 Series, offering a myriad of options to be used to vaporize the contents of the 5ml refillable E-juice capacity. What stands out is that you will get a total of 8 coils: four 0.15ohm X3 mesh coils and four X3-C1 coils that have a 0.4ohm heating element. Featuring a threaded top fill system, the Captain V Tank is also equipped with a dual slotted bottom airflow control ring that can diffuse air entering the atomizer and are fully adjustable to your liking. It can be used with the included X3 mesh coil to produce a satisfying large vapor cloud. ![]() Original Hangsen IQ Touch 450mAh Pod System Vape Starter Kit original price $24.99, now only $14.99 The Hangsen IQ Touch Pod System Kit is a portable pod kit with portable and slim design. IQ Touch Pod Kit is powered by built-in 450mAh battery to provide vaping. IQ Touch Pod Kit adopts touch button to check power and adjustable three-level voltages. IQ Touch cartridge maintains 2ml capacity with top filling design and 1.2ohm resistance coil. IQ Touch features intelligent breathing light and draw-activated system without switch. ![]() Original SMOKTech SMOK & OFRF nexMesh 30W 1200mAh VW Box Mod Pod System Vape Starter Kit $26.89 The SMOKTech SMOK & OFRF nexMesh VW Box Mod Pod Kit is designed by SMOKTech and OFRF Tech. The Pod Kit is constructed from lightweight and durable Aluminum Alloy material comes with a compact size that allows you to take it to everywhere you want. Powered by an internal 1200mAh battery, nexMesh Pod kit can up to 30W max output and sports the lithium battery protection function. The nexMesh pod cartridge adopts a waterproof design that prevents condensation from entering the interior, and it is compatible with conical nexMesh coil to bring you the rich vapor and excellent flavor. ![]() Original Vandy Vape Kylin M AIO 70W TC VV VW Box Mod RBA Pod System Vape Starter Kit original price $74.99, now only $49.99 The Vandy Vape Kylin M AIO Kit is a real rebuildable AIO Pod System Device, which brings richer flavors and rebuildable head only. Kylin M AIO has a compact size, with a beautiful pattern's side panel, eye-catching appearance. The exterior construction is well-engineered, presenting a waterproofed PCBA to prevent short circuits or water from damaging the vaping systems. Powered by an external 18650 battery (Not included), this powerful pod system is capable of providing a power output range from 5W to 70W and supports VV Mode, VW Mode, and TCSS Mode. The various options allow for a great deal of versatility with vaping. Behind the magnetic panel, the Kylin M AIO is capable of holding up to 2.5ml / 5ml of E-juice within its pod. The capacity change depends on whether the matching is a rebuildable atomizer or a pre-built coil. Up to 5ml E-juice capacity designed for rebuildable atomizer and 2.5ml for the pre-built coil. Hassle-free filling of juice by opening the side silicone plug. The top cap of Kylin M AIO Pod has a pillarless build deck inside for DIY rebuildable and pre-built coil building, single-coil configuration. The Kit comes with various types of the pre-built coil to provide DIY fun. Kylin M AIO Pod complete with single mesh coil on the bottom that is accepted in a plug 'n' play installation method. Moreover, the Vandy Vape Kylin M AIO is also featured with multiple protections to guarantee a safe vaping environment. ![]() YFTK Replacement Tank Tube for YFTK ParavozZ k5k RDTA Clone $2.99 The YFTK Replacement Tank Tube is designed for YFTK ParavozZ k5k RDTA Clone as a replacement part. It is made of PC material. ![]() Replacement Drip Tip for SMOKTech SMOK Fetech Pro Pod Vape Kit $1.99 The Replacement Drip Tip is designed for SMOKTech SMOK Fetech Pro Pod Vape Kit as a replacement part. It is made of resin material. ![]() Original Hangsen IQ Touch Pod System Vape Kit Replacement Pod Cartridge with 1.2ohm Coil(3 PCS) $9.99 The Hangsen IQ Touch Replacement Pod Cartridge is designed for Hangsen IQ Touch Pod System Vape Kit as a replacement part. It features 2ml E-juice capacity, supports top refilling and easy to use, and comes with a 1.2ohm Coil. 3 PCS / Pack. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
629
[QUOTE=3FVAPE;1276992]SXK Stickman SLGT V2 Gera GT 60W VW Vape Box Mod Clone original price $139.90, now only $129.90
630
Original SMOKTech SMOK & OFRF nexMESH VW Mod Pod System Vape Kit Replacement Empty Pod Cartridge(1 PC) $3.99
The SMOK & OFRF nexMESH Pod Cartridge is specially designed for SMOK & OFRF nexMESH VW Mod Pod System Vape Kit. It can hold up to 2ml E-liquid and adopts waterproof design. Besides, it is compatible with 2 types of coil, 0.4ohm SS316 nexMESH Coil and 0.4ohm A1 nexMESH Coil (Coils are sold separately, not included), which is suitable for both MTL and DTL vaping. ![]() Original Vandy Vape Kylin M AIO Mod RBA Pod System Vape Kit Replacement DIY Pod Cartridge with 5 Steel Wires(1 PC) original price $23.99, now only $18.99 The Vandy Vape Kylin M AIO Replacement DIY Pod Cartridge is designed for Vandy Vape Kylin M AIO Mod RBA Pod System Vape Kit as a replacement part. It is created for DIY fun and rebuildable atomizer, which will provide you richer flavor and satisfy your different demands. ![]() Original SMOKTech SMOK & OFRF nexMESH VW Mod Pod System Vape Kit / Cartridge Replacement SS316 Coil(5 PCS) $10.99 The SMOK & OFRF nexMESH replacement SS316 Coil is specially designed for SMOK & OFRF nexMESH VW Mod Pod System Vape Kit as a replacement part. It features 0.4ohm coil resistance and power output range from 15W to 20W. 5 PCS / Pack. ![]() Original SMOKTech SMOK & OFRF nexMESH VW Mod Pod System Vape Kit / Cartridge Replacement A1 Coil Head(5 PCS) $11.99 The SMOK & OFRF nexMESH replacement A1 Coil is specially designed for SMOK & OFRF nexMESH VW Mod Pod System Vape Kit as a replacement part. It features 0.4ohm coil resistance and power output range from 13W to 18W. 5 PCS / Pack. ![]() Original Vandy Vape Kylin M AIO Mod RBA Pod System Vape Kit / Cartridge Replacement Single Mesh Coil(4 PCS) original price $12.99, now only $10.99 The Vandy Vape Kylin M AIO Replacement Single Mesh M Coil that features 0.3ohm resistance. It is designed for Vandy Vape Kylin M AIO Kit and Vandy Vape Kylin M AIO Pre-built Pod Cartridge. The best adapted power is 35~45W. 4 PCS / Pack. ![]() Replacement Top Cap for Gas Mods G.R.1 GR1 S RDA Vape Atomizer $4.99 The Replacement Top Cap is designed for Gas Mods G.R.1 GR1 S RDA Rebuildable Dripping Atomizer as a replacement part, it is made of PEI material. Compatible with 510 drip tip. ![]() SXK Mag Replacement MTL / DL 510 Drip Tip Clone for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer(2 PCS) original price $12.90, now only $8.99 The SXK Mag Replacement MTL / DL 510 Drip Tip Clone are made of PEEK material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. The drip tip with 3 holes for DL vaping, and the drip tip with 1 hole for MTL vaping ![]() SXK Diamond 510 Thread Adapter & Decorative Ring for SXK Stickman SLGT V2 Gera GT VW Box Mod Clone(2 PCS) original price $15.90, now only $13.79 The SXK Replacement Superleggera Diamond 510 Thread Adapter & Decorative Ring are suitable for SXK Stickman SLGT V2 Gera GT VW Vape Box Mod Clone as replacement parts. The 510 thread adapter is 30 x 8mm, and the Decorative Ring is 30 x 6mm. The product features Diamond face. ![]() SXK Mirror 510 Thread Adapter & Decorative Ring for SXK Stickman SLGT V2 Gera GT VW Box Mod Clone(2 PCS) original price $11.90, now only $9.69 The SXK Replacement Superleggera Diamond 510 Thread Adapter & Decorative Ring are suitable for SXK Stickman SLGT V2 Gera GT VW Vape Box Mod Clone as replacement parts. The 510 thread adapter is 30 x 8mm, and the Decorative Ring is 30 x 6mm. The product features Mirror face. ![]() PVC Wrapper Skin Sticker for 18650 Battery(20 PCS) $1.99 The PVC Wrapper Skin Sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. 20 PCS / Pack. ![]() Original Vandy Vape Kylin M AIO Mod RBA Pod System Vape Kit Replacement Empty Pod Cartridge(1 PC) $7.99 The Vandy Vape Kylin M AIO Replacement Pod Cartridge is designed for Vandy Vape Kylin M AIO Mod RBA Pod System Vape Kit as a replacement part. It features 2.5ml E-juice capacity, and it is compatible with 0.3ohm Single Mesh Coil (Coils are sold separately) ![]() Original VOOPOO PNP Tank for VOOPOO Drag X & Drag S VW Mod Pod Vape Kit $9.99 The VOOPOO PNP Tank is a new concept created. With 510 base at the bottom of the Drag X & Drag S Pod that fit for Drag X and Drag S kit. The tank can hold up to 4.5ml of your favorite E-juice, and refill the juice from the bottom of the Pod by twisting 510 base. Removed with just one hand, and you'll experience a simpler and cleaner way of filling oil. It comes in two forms: on its own, it's the perfect partner for Drag X and Drag S. With 510 base, it's perfect for any devices you want. PNP Tank can flexibly switch between POD and TANK. It matches perhaps the most abundant and excellent PnP coils. The adjustable air 510 base matches almost all of your devices. Installing to the POD or 510 base, or replacing the coils is easier than ever because of the new powerful magnets. PnP Tank is compatible with all PnP coils, just pull and push, you can enjoy different vaping experience. ![]() Replacement Top Cap Tank Tube Nano Kit with Drip Tip for Taifun GT4 S GT 4 S IV S DL RTA Clone $7.99 The Replacement Top Cap Tank Tube Nano Kit is designed for Taifun GT4 S GT 4 S IV S DL RTA Vape Atomizer Clone as a replacement part. It is made of Stainless Steel and PC material, and features 2.9ml E-juice capacity. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
631
Original LTQ T-FLASK 650mAh CD Vape Box Mod Compatible with ALL 510 CD Atomizers original price $19.99, now only $10.99
The LTQ T-FLASK CD Mod comes with small and tiny size, you can take the T-FLASK to anywhere as you like. T-FLASK CD Mod is powered by 650mAh built-in battery and compatible with ALL 510 CD Atomizers. The magnetic connection absolutely sheds light on the convenience and the speed of reloading. It is constructed form aluminum alloy material which is durable and create perfect hand feeling. ![]() Original Wotofo Atty3 Cubed RDA original price $19.99, now only $4.99 The Original Wotofo Atty Cubed RDA / Atty3 RDA is the essential box mod specific RDA, combining a very strong feature set, high quality machining, and a box mod centric form factor. The Atty Cubed features a split positive center post and deck-milled negatives, with each post hole measuring 2mm in diameter. Coupled with a 6mm deep juice well, the Atty Cubed can accommodate a wide variety of build configurations. Airflow is designed as dual staggered air slots, each measuring 7mm by 2mm, allowing absolutely tremendous airflow. ![]() Original Wotofo Serpent RDA with BF Pin original price $25.99, now only $6.99 The Original Wotofo Serpent BF RDA is constructed from aluminum and 316 Stainless Steel in 22mm diameter. It comes with a wide bore trip dip and a BF pin. The Wotofo Serpent BF RDA features dual independent posts with four wire holes and adjustable airflow. This RDA comes with bottom feeder / BF / Squonk Pin. ![]() Original Exvape eXpromizer TCM DL RDTA $39.99 The Exvape eXpromizer TCM DL RDTA is the self-winding vaporizer from EXvape which is constructed from Stainless Steel (body), Glass (tank tube), and POM (drip tip) in 25mm Diameter, it is specially designed for direct lung vape. It features large 7.0ml e-liquid capacity with top filling way and top airflow system, the airflow will hit the coil directly to bring you the amazing flavor. The EXpromizer TCM is the first self-winding vaporizer from EXvape, which is designed for vaping for direct lung inhalation (DL). It is a top coiler vaporizer, whereby the liquid is directed from the lower tank to the cotton wool via the capillary action of stainless steel wicks. The winding deck has two clamping jaws, to which you can simply attach a screen coil or mesh coil by screwing. The air flow holes at an angle on both sides lead the air supply directly to the coil. The EXpromizer TCM is filled with Liuqid via a side fill system. By rotating the top cap, the airflow opening is positioned over the fill opening in order to fill the tank. The liquid tank can be filled with up to 7 ml of liquid. Due to the design of the evaporator and the installation of the air supply at the top, the EXpromizer TCM is a leak-proof system. ![]() Kindbright Reborn RDTA Clone $20.99 The Kindbright Reborn RDTA Clone is constructed from 316 Stainless Steel in 22mm Diameter. The RDTA comes with single coil build deck, which is perfect with any density of E-liquid. ![]() Original XTAR VC2 Charger for 3.6V / 3.7V Li-ion / IMR/INR/ICR: 18350, 18490, 18500, 18650, 18700, 20700, 21700 Batteries, etc. $14.99 The XTAR VC2 Charger is compatible with different kinds and sizes of most batteries like 3.6V / 3.7V Li-ion/IMR/ INR /ICR: 10440, 14500, 14650, 16340, 17335, 17500, 17670, 18350, 18490, 18500, 18650, 18700, 20700, 21700, 22650, 25500, 26650. Note: VC2 cannot charge protected 20700 / 21700 batteries. VC2 Charger is equipped with an innovative Tachometer-style Display, the screen displays information from top to bottom: Charging Current, Battery Voltage, Battery Charged Capacity. It is compatible with ALL 5V USB power, including USB wall adaptors, cell phone chargers, solar panel, PC USB, power banks, etc. Recommend 5V / 2.1A power source or above to maximize efficiency. ![]() Original XTAR VC4 Charger for 3.6V / 3.7V Li-ion / IMR/INR/ICR: 18350, 18490, 18500, 18650, 18700, 20700, 21700 Batteries, etc. $29.99 The XTAR VC4 Charger is compatible with different kinds and sizes of most batteries like 3.6V / 3.7V Li-ion/ IMR / INR / ICR: 10440, 14500, 14650, 16340, 17335, 17500, 17670, 18350, 18490, 18500, 18650, 18700, 20700, 21700, 22650, 25500, 32650, and Ni-MH / Ni-CD: AAAA, AAA, AA, A, SC, C, D. It can maximally charge two 32650 cells (CH1 & CH4) & two 18650 cells (CH2 & CH3) simultaneously. Ni-MH symbol will flick max 10 minutes when charging Ni-MH battery due to 0V activation. Note: VC4 Charger cannot charge protected 20700 / 21700 batteries. VC4 Charger is equipped with an innovative Tachometer-style Display, the screen displays information from top to bottom: Battery Voltage, Battery Charged Capacity, Battery Types and Channels. It is compatible with ALL 5V USB power, including USB wall adaptors, cell phone chargers, solar panel, PC USB, power banks, etc. Recommend 5V / 2.1A power source or above to maximize efficiency. ![]() Original XTAR VP2 Charger for 3.0V / 3.2V / 3.7V, 3.8V Li-ion/IMR/INR/ICR/LiFe-PO4: 18650, 18700, 20700, 21700, Batteries, etc. $37.99 The XTAR VP2 Charger is compatible with different kinds and sizes of most batteries like 3.0V / 3.2V / 3.7V, 3.8V Li-ion / IMR / INR / ICR / LiFe-PO4: 10440, 14500, 14650, 16340, 17335, 17500, 17670, 18350, 18490, 18500, 18650, 18700, 20700, 21700, 22650, 25500, 32650. Note: VP2 Charger cannot charge protected 20700 / 21700 batteries. VP2 Charger has a selectable charging current, it can choose a charge current best suited for your battery. Lower currents maximize battery life. VP2 Charger is able to see the screen clearly at any angle. Display battery voltage and charging status accurately. Press button for 1.5s to turn off the LCD backlight. ![]() Original XTAR VP4 Charger for 3.0V / 3.2V / 3.7V, 3.8V Li-ion/IMR/INR/ICR/LiFe-PO4: 18650, 18700, 20700, 21700, Batteries, etc. $45.99 The XTAR VP4 Charger is compatible with different kinds and sizes of most batteries like 3.0V / 3.2V / 3.7V, 3.8V Li-ion / IMR / INR / ICR / LiFe-PO4: 10440, 14500, 14650, 16340, 17335, 17500, 17670, 18350, 18490, 18500, 18650, 18700, 20700, 21700, 22650, 25500, 32650. Note: VP4 Charger cannot charge protected 20700 / 21700 batteries. VP4 Charger has a selectable charging current, it can choose a charge current best suited for your battery. Lower currents maximize battery life. VP4 Charger is able to see the screen clearly at any angle. Display battery voltage and charging status accurately. It can maximally charge two 32650 cells (CH1 & CH4) & two 18650 cells (CH2 & CH3) simultaneously. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
632
Original ThinkVape Thor AIO 80W VW Box Mod Pod System Vape Starter Kit original price $26.90, now only $20.09
The Think Vape Thor AIO Kit is a pod mod system kit that comes with ergonomic design, proper volume and compact size. It comes with a 3ml pod cartridge that is large enough to provide you with long-lasting vaping experience. And adopting adjustable airflow, it also supports 0.2ohm mesh coil and 0.5ohm mesh coil (0.2ohm and 0.5ohm Coils are included, but RBA Coils are not included), both of which will satisfy your vaping demands. Powered by a single 18650 battery (Not included), it features adjustable power in the range from 5W to 80W. Equipped with a screen, it will display you the vaping details. What's more, there are multiple protections to ensure your safety like Intelligent Atomizer Recognition, Puff Monitoring System, Over-temperature Protection, 10 Seconds Cut-off, Short Circuit Protection, Low-Battery Warning, and so on. Last but not least, Think Vape ZETA Pod Cartridge and ZETA Coils are compatible with Thor AIO Kit. ![]() Original XTAR ROCKET SV2 Charger for 3.6V / 3.7V Li-ion/IMR/INR/18350, 18490, 18500, 18650, 18700, 20700, 21700 Batteries, etc. $38.99 The XTAR ROCKET SV2 Charger is compatible with different kinds and sizes of most batteries like 3.6V / 3.7V Li-ion/ IMR / INR / ICR: 10440, 14500, 14650, 16340, 17335, 17500, 17670, 18350, 18490, 18500, 18650, 18700, 20700, 21700, 22650, 25500, 26650, 32650, and Ni-MH / Ni-CD: AAAA, AAA, AA, A, SC, C, D. Note: VC4 Charger cannot charge protected 20700 / 21700 batteries. The XTAR SV2 Charger can save your precious time, it is a fast and efficient charger that FULLY CHARGE 2 x 2500mAh 18650 just takes about 1.5HRS. ![]() Original XTAR DRAGON VP4 Plus Charger for 3.6V / 3.7V Li-ion /IMR/INR/18350, 18500, 18650, 18700, 20700, 21700 Batteries, etc. $99.99 The XTAR DRAGON VP4 Plus Charger is compatible with different kinds and sizes of most batteries like 3.6V / 3.7V Li-ion/ IMR / INR / ICR: 10440, 14500, 14650, 16340, 17335, 17500, 17670, 18350, 18490, 18500, 18650, 20700, 21700, 22650, 25500, 26650, 32650, and Ni-MH / Ni-CD: AAAA, AAA, AA, A, SC, C, D. The battery pack is 11.1V / 3S battery pack. The Ni-MH symbol will flick max 10 minutes when charging, Ni-MH battery due to 0V activation.Note: VC4 Charger cannot charge protected 20700 / 21700 batteries. The XTAR DRAGON VP4 Plus Charger can charge your 11.1V battery pack evenly and fully. With 11.1V / 3s port, DRAGON can charge your 11.1V / 3S battery pack with 1.0A current in a balance way to make sure that all batteries of your battery pack can be fully charged. Charging battery pack should have wall adapter conecting to the power. ![]() Original YDDZ A1 510 Thread Adapter Connector for dotMod dotAIO Pod System Vape Kit $8.99 The YDDZ A1 510 Thread Adapter Connector is designed for dotMod dotAIO Pod System Vape Kit as a replacement part, which is made from POM (Black Part) and Stainless Steel (Silver Part). With this 510 adapter, you can use 510 atomizer (RTA / RDA / RDTA / Tank) on your dotMod dotAIO Pod System. ![]() PVC Wrapper Skin Sticker for 18650 Battery(20 PCS) $1.99 The PVC Wrapper Skin Sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. 20 PCS / Pack. ![]() Original Kumiho K1 3 in 1 Magnetic 3A Fast Charge Sync USB Cable with 3 Types of Cable Heads for iPhone /Type-C/Android $8.99 The Kumiho K1 3 in 1 Magnetic 3A Braided Fast Charge Sync USB Cable is made of Al-alloy + Nylon Braided material in 1000mm Length, it is suitable for your iPhone / Type-C / Android Devices. It is equipped with 3 different types of magnetic cable heads contains USB Type C, Android, iPhone / iPad Cable Heads. You can switch the cable head to charge your different devices. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
633
Original Augvape Intake Sub Ohm Tank Vape Atomizer original price $43.99, now only $28.99
The Augvape Intake Sub Ohm Tank is constructed from Stainless Steel (body) and Glass (tank tube) in 25mm Diameter. The Intake Sub Ohm Tank can hold between 3.5ml and 5ml of E-juice. A 3.5ml straight glass tube can be replaced with an extended version with volume of 5ml. Refilled using a top fill system, the Augvape Intake Sub Ohm Tank reveals two large fill ports to accommodate any nozzle size from E-juice bottles. The massive top was decorated in a familiar mode and crowned with a faceted twisting lid with a wide 810 drip tip. Air intake holes and a rotating ring were placed directly under the top cap, reliably protecting the Tank from accidental leaks. You can adjust the airflow by turning the air ring on the top. Within the tank, installed in a plug 'n' play manner resides a mesh coil: advanced 0.2ohm Clapton Mesh Coil, focusing and throttling the flavor and clouds directly to the taste buds via the 810 wide bore drip tip. Moreover, a 0.15ohm Coil is included to help divulge the complex flavors from your favorite E-liquid, delivering large clouds of vapor. ![]() SXK Haku Venna RDA Clone with BF Pin original price $17.90, now only $14.99 The SXK Haku Venna RDA Clone is a low profile 22mm RDA with dual post design for single coil building. Constructed from 316 stainless steel, the RDA adopts sandblasting technology to make it feel smooth on the surface. The air enters the chamber via two different sizes of airholes on both side of the cap, hitting the coil directly. POM drip tip is included. This RDA comes with bottom feeder / BF / Squonk Pin. ![]() Original YDDZ V1 22mm RTA $21.99 The Original YDDZ V1 RTA Rebuildable Tank Vape Atomizer is constructed from stainless steel (body) and glass (tank tube) in 22mm diameter with 4ml capacity. The YDDZ V1 RTA is with top filling system and adjustable juice control via the ring in the middle. The YDDZ V1 RTA is with adjustable side airflow with 4 sizes: 1.2mm, 1.6mm, 2.0mm, + / - 0.1 tolerance. ![]() Original Augvape VX217 217W TC VV VW Mod Vape Starter Kit with Intake Sub Ohm Tank original price $75.99, now only $67.99 The Augvape VX217 Mod Kit consists of VX217 TC VV VW Box Mod and the latest Intake Sub Ohm Tank Vape Atomizer. It is the perfect combination of regulated battery modules and atomizer. Augvape VX217 is constructed from durable and sturdy Zinc Alloy material, which is impact resistant and withstands a certain degree of collision. The VX217 is powered by Dual 21700 Batteries and it is also compatible with 20700 and 18650 batteries. (18650 / 20700 / 21700 Batteries are not included). It's upgraded from VX200. With all relevant circuit protection, it also supports 1.2A current fast charging through Type-C port. In terms of output, the maximum output power of VX217 is 217W. Similarly, the VX217 mod will reach 12V and can emit 0.05~3ohm. It's safe to say this is the first mod that can reach 12V. So when you use high ohm coil in a big rebuildable atomizer, you can get the fast and powerful output as well. There are several Modes: Variable Wattage, Variable Voltage, Temperature Control, and Bypass user modes you can choose from. VX217 is equipped with a 1.3-inch color screen with 240 x 240RGB resolution and offers hundreds of color options. The UI simulates the car dashboard which is cool and beautiful. You can read vape time, mode, wattage, voltage, resistance, batteries life. VX217 Kit uses a minimalist design, canceling plus and minus buttons, can using spin button matches with the UI of the screen. Intake Sub Ohm Tank can hold up to 5ml of E-liquid, you can easily fill from above, cleaning or replacing the coil head will not cause any trouble. The prefabricated Coil head is a new mesh coil made of Clapton wire, which can further improve the taste and form huge clouds. Better flavor and a longer lifespan than regular mesh coil. ![]() Original Justfog Minifit Max 7W 650mAh Pod System Vape Starter Kit $16.99 The Justfog Minifit Max Pod Kit is a compact and portable pod system kit. It is known as an upgraded version of Justfog Minifit Kit. Compared with 370mAh Minifit Kit, Minifit Max Kit is powered by a 650mAh internal battery, but both of them adopt the same pod cartridge that holds 1.5ml E-juice and supports 1.6ohm Japanese organic cotton coil. As it utilizes safe and healthy cotton coil, you can experience the pure and smooth flavor. Moreover, there are multiple protections to ensure your vaping safety. ![]() Universal Desktop USB Charging Station with 6 USB Ports Compatible with ALL Kinds of USB Enabled Devices $39.99 he Universal Desktop USB Charging Station with 5V / 10A that can charge 6 devices at the same time, such as ipad, iphone or other smart phones. There is a removable cable 1500mm making it easier for taking and charging. 7 PCS Clear Dividers on each charger to keep your desk uncluttered. The USB Charging Station is made from ABS fireproof material, it can input range from 100V to 220V, 50 / 60Hz. ![]() Original XTAR X2 Charger for 3.6V / 3.7V Li-ion / IMR / INR / 18350 / 18500 / 18650/18700/20700/21700 Batteries, etc. - US Plug $28.99 The XTAR X2 Quick Charger is a new high current intelligent charger with simple and convenient operation. It has great compatibility, which can work with different batteries. It also features two battery slots with LCD display that you can see the charging situation clearly. The X2 regulates the voltage and current delivered to the batteries in three automatic stages, ensuring batteries receive optimum charging with minimal wear and tear. It also has the great soft start function, which can increase the output current slowly to protect the batteries. The XTAR X2 Charger is compatible with different kinds and sizes of most batteries like 3.6V / 3.7V Li-ion/ IMR / INR / ICR: 14500 / 14650 / 16340 / 17335 / 17500 / 17670 / 18350 / 18490 / 18500 / 18650 / 18700 / 20700 / 21700 / 22650 / 25500 / 26650, and 1.2V Ni-MH / Ni-CD: AAAA / AAA / AA / A / SC / C. Note: The XTAR X2 Charger cannot charge protected 20700 / 21700 batteries.
634
Original XTAR X4 Charger for 3.6V / 3.7V Li-ion / IMR / INR / 18350 / 18500 / 18650/18700/20700/21700 Batteries, etc. - US Plug $41.99
The XTAR X4 Quick Charger is a new high current intelligent charger with simple and convenient operation. It has great compatibility, which can work with different batteries. It also features four battery slots with LCD display that you can see the charging situation clearly. The X4 regulates the voltage and current delivered to the batteries in three automatic stages, ensuring batteries receive optimum charging with minimal wear and tear. It also has the great soft start function, which can increase the output current slowly to protect the batteries. The XTAR X4 Charger is compatible with different kinds and sizes of most batteries like 3.6V / 3.7V Li-ion/ IMR / INR / ICR: 14500 / 14650 / 16340 / 17335 / 17500 / 17670 / 18350 / 18490 / 18500 / 18650 / 18700 / 20700 / 21700 / 22650 / 25500 / 26650, and 1.2V Ni-MH / Ni-CD: AAAA / AAA / AA / A / SC / C. Note: The XTAR X4 Charger cannot charge protected 20700 / 21700 batteries. ![]() Original Augvape Intake Sub Ohm Tank Replacement Clapton Mesh Coil Heads(5 PCS) $10.99 The Augvape Intake Replacement Clapton Mesh Coil Heads are designed for Augvape Intake Sub Ohm Tank Vape Atomizer as replacement parts. The Clapton Mesh Coil is made from Kanthal and Nichrome material, which features 0.2ohm coil resistance and output range from 60W to 75W. 5 PCS / Pack. ![]() Original Augvape Intake Sub Ohm Tank Replacement Mesh Coil Heads(5 PCS) $10.99 The Augvape Intake Replacement Mesh Coil Heads are designed for Augvape Intake Sub Ohm Tank Vape Atomizer as replacement parts. The Mesh Coil is made from Kanthal material, which features 0.15ohm coil resistance and output range from 60W to 75W. 5 PCS / Pack. ![]() Original VOOPOO PNP Tank for VOOPOO Drag X & Drag S VW Mod Pod Vape Kit(1 PC) $10.99 The VOOPOO PNP Tank is a new concept created. With 510 base at the bottom of the Drag X & Drag S Pod that fit for Drag X and Drag S kit. The tank can hold up to 4.5ml of your favorite E-juice, and refill the juice from the bottom of the Pod by twisting 510 base. Removed with just one hand, and you'll experience a simpler and cleaner way of filling oil. It comes in two forms: on its own, it's the perfect partner for Drag X and Drag S. With 510 base, it's perfect for any devices you want. PNP Tank can flexibly switch between POD and TANK. It matches perhaps the most abundant and excellent PnP coils. The adjustable air 510 base matches almost all of your devices. Installing to the POD or 510 base, or replacing the coils is easier than ever because of the new powerful magnets. PnP Tank is compatible with all PnP coils, just pull and push, you can enjoy different vaping experience. ![]() SXK Mission Tips Integrated Whistle Drip Tip Mouthpiece Clone + Base for SXK BB Box Mod original price $16.90, now only $12.99 SXK Mission Tips Integrated Whistle Drip Tip Clone is suitable for SXK BB Box Vape Mod Kit Clone as a replacement. The Drip Tip Set consists of 3 x Drip Tip Mouthpiece and 1 x Mouth Base and 4 x Plugs. They are made of PEI material. The Diameter of Plugs are: 1.5mm / 2.5mm / 3.5mm / 4.5mm. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
635
Original Dovpo Odin DNA250c 200W TC VW Vape Box Mod $179.99
The Dovpo Odin DNA250c TC VW Vape Box Mod is compact and lightweight. Equipped with the worldwide known Evolve DNA250c Chip, it is a hard wearing and user-friendly chip that can connect to the computer for slight fine-turning and the theme modifications (Although a custom theme is already installed). The box mod is powered by dual 21700 / 20700 / 18650 batteries (Not included), which make the mod still maintains a small and ergonomic form. Furthermore, the box mod also provides various of safety functions: reverse polarity protection, atomizer protection, overheat protection. ![]() Original Steam Crave Aromamizer Ragnar RDTA original price $62.99, now only $50.99 The Steam Crave Aromamizer Ragnar RDTA is constructed from Stainless Steel (body) and Glass (tank tube) in 35mm Diameter. The RDTA comes with a postless deck with bottom honeycomb air holes. The smooth airflow system can provide you a medium and high power vaping, which supports 80% side airflow and 20% bottom airflow. As for the chamber reducer, it is actually a deck adaptor, with this adaptor, you can use mesh deck of Aromamizer Plus, and you can also use other decks of Aromamizer Plus like Postless Deck, Series Deck, Velocity Deck, and Single Coil Deck.(Not included) But, we recommend that you choose MESH DECK to get a good vaping experience! The RDTA comes with 22mm wide bore 810 drip tip and a large E-liquid tube of 18ml Capacity. It is worthy to say that Ragnar RDTA is perfect match with HADRON 220 MOD. ![]() Original VOOPOO Replacement PnP-VM5 Mesh Coil Heads for VOOPOO DRAG S / DRAG X VW Mod Pod Vape Kit(5 PCS) $12.99 The VOOPOO Replacement PnP-VM5 Mesh Coil Heads is suitable for VOOPOO DRAG S VW Mod Pod Vape Kit / VOOPOO DRAG X VW Mod Pod Vape Kit as replacement parts. The PnP-VM5 Mesh Coil features 0.2ohm coil resistance that power range from 40W to 60W, and the suggested E-liquid Nicotine < = 10mg. 5 PCS / Pack. ![]() Original VOOPOO Replacement PnP-VM6 Mesh Coil Heads for VOOPOO DRAG X VW Mod Pod Vape Kit(5 PCS) $12.99 The VOOPOO Replacement PnP-VM6 Mesh Coil Heads is suitable for VOOPOO DRAG X VW Mod Pod Vape Kit as replacement parts. The PnP-VM6 Mesh Coil features 0.15ohm coil resistance that power range from 60W to 80W, and the suggested E-liquid Nicotine < = 10mg. 5 PCS / Pack. ![]() Original Steam Crave Hadron 220W TC VW Box Mod Replacement Squonk Backpack $24.99 The Steam Crave Hadron Replacement Squonk Backpack is designed for Steam Crave Hadron 220W TC VW Box Mod, which is used to add on your Steam Crave Hadron Box Mod that can transform into a regulated squonk beast. ![]() Original Steam Crave Replacement Dual Mesh Strips for Aromamizer Plus / Ragnar RDTA(10 PCS) $3.99 The Steam Crave Replacement Dual Mesh Strips is suitable for Steam Crave Aromamizer Plus RDTA / Steam Crave Ragnar RDTA, which is made of Kanthal A1 material and features 0.15ohm resistance. (0.15 +/- 0.03ohm) 10 PCS / Pack. ![]() Original Steam Crave Replacement Mesh Strips for Aromamizer Plus / Ragnar RDTA(10 PCS) $3.99 The Steam Crave Replacement Mesh Strips is suitable for Steam Crave Aromamizer Plus RDTA / Steam Crave Ragnar RDTA, which is made of Kanthal A1 material and features 0.15ohm resistance. (0.15 +/- 0.03ohm) 10 PCS / Pack. ![]() Original Steam Crave Replacement Mesh Strips for Aromamizer Plus / Ragnar RDTA(10 PCS) $3.99 The Steam Crave Replacement Mesh Strips is suitable for Steam Crave Aromamizer Plus RDTA / Steam Crave Ragnar RDTA, which is made of Ni60 material and features 0.14ohm resistance. (0.14 +/- 0.03ohm) 10 PCS / Pack. ![]() Original Steam Crave Replacement Mesh Strips for Aromamizer Plus / Ragnar RDTA(10 PCS) $3.99 The Steam Crave Replacement Mesh Strips is suitable for Steam Crave Aromamizer Plus RDTA / Steam Crave Ragnar RDTA, which is made of SS316L material and features 0.14ohm resistance. (0.14 +/- 0.03ohm) 10 PCS / Pack. ![]() Original Steam Crave Replacement Mesh Strip Shoelace Cotton for Mesh Deck / RBA / RDA / RTA / RDTA Vape Atomizer(10 PCS) $3.99 The Steam Crave Replacement Mesh Strip Shoelace Cotton are suitable for Mesh Deck / RBA / RTA / RDA / RDTA Vape Atomizer as a replacement part. 10 PCS / Pack. ![]() Mission Tips Integrated Whistle Drip Tip Mouthpiece Clone + Base for SXK BB Box Mod $9.99 The Mission Tips Integrated Whistle Drip Tip Clone is suitable for SXK BB Box Vape Mod Kit Clone as a replacement. The Drip Tip Set consists of 3 x Drip Tip Mouthpiece and 1 x Mouth Base and 4 x Plugs. They are made of PEI material. The Diameter of Plugs are: 1.5mm / 2.5mm / 3.5mm / 4.5mm. ![]() Mission Tips Integrated Whistle Drip Tip Mouthpiece Clone + Base for SXK BB Box Mod $8.99 The Mission Tips Integrated Whistle Drip Tip Clone is suitable for SXK BB Box Vape Mod Kit Clone as a replacement. The Drip Tip Set consists of 3 x Drip Tip Mouthpiece and 1 x Mouth Base and 4 x Plugs. They are made of Acrylic material. The Diameter of Plugs are: 1.5mm / 2.5mm / 3.5mm / 4.5mm. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
636
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Vaptio Capt'n 220W Box Mod original price $67.99, now only $14.99
The Vaptio Capt'n 220W Mod is an innovative TC VW Vape Box Mod, which perfectly compatible with Vaptio Paragon Tank (Not included). Capt'n 220W Mod is powered by Dual 18650 batteries (Not included) with output wattage range from 10W to 220W, and comes with Zinc-alloy frame and IML panel body. Capt'n Mod supports stable and high performance VW / TC modes with 0.005s fire speed. Equipped with 1.3-inch TFT color screen, firmware upgradeable, the Vaptio Capt'n Mod will bring you a good vaping experience. ![]() Original Vaptio C-II VW Mod Kit with C-II Sub Ohm Tank original price $29.99, now only $19.99 The Vaptio C-II VW Box Mod Vape Starter Kit consists of Vaptio C-II VW Box Mod and Vaptio C-II Sub Ohm Tank, which is powered by a large 3000mAh Built-in Battery with range from 30W to 100W output. The mod kit comes with a 4.0ml glass tank tube and two 0.25ohm clapton coils, it is also compatible with other different kinds of coils like PW41129A 50W Max. 0.25ohm Kanthal Coil, KW41128A 100W Max. 0.15ohm Kanthal Coil and so on. (Coils are not included). The mod kit has one button design with a compact size, which is easy to use and convenient to carry during travel. The tank features in bottom adjustable airflow, which can give you a smooth vaping experience. ![]() Original Vaptio Wall Crawler TC VW Mod Kit with Frogman C Tank original price $55.90, now only $20.99 The Wall Crawler TC VW Mod Vape Starter Kit consists of Wall Crawler Mod and Frogman C Tank. The mod kit is powered by single 18650 battery (Not included) with Max. 80W output, it adopts supercharger technology, and fire it up to the max throttle only takes 0.005 second. Under bypass mode, the resistance go as low as 0.05ohm. On top of Vaptio's existing SMOOTH TECH flavor optimization technology, it offers you instant big cloud and optimal flavor. Moreover, the 1.3-inch full color high-definition TFT screen brings you more convenience, and the user interface supports multiple languages and demonstrates all vaping details. The mod kit supports VW / TC / Smart / CCW / CCT / Bypass Modes to meet your different needs. ![]() Original Vaptio SLEEK Pod System Kit original price $39.99, now only $10.99 The Vaptio SLEEK Kit is a pod system vape kit, which is the first original pod system with magnetic all-metal shell that can automatically adjust airflow based on the air volume the user inhales. The SLEEK Kit is powered by a built-in 400mAh battery with Max. 13W Output, and comes with a 1.5ml E-juice capacity pod. A perfect size as small as a lighter enables you to take along with whenever you want and wherever you go. A built-in detachable tank with generation 4 diatomite ceramic atomizer gives you outstanding performance of strong absorbability, good e-liquid lock and excellent heat conductivity for faster firing and better taste. There are multiple protections that provide you a safe vaping experience like over-vaping protection, over charging protection, etc. ![]() Original Vaptio FRAGG 60 VV VW Mod Kit with Casto Sub Ohm Tank original price $63.99, now only $28.99 The Vaptio FRAGG 60 Mod Vape Starter Kit consists of Vaptio FRAGG 60 VV VW Mod and Casto Sub Ohm Tank. The mod kit is constructed from Zinc Alloy, Plastic, and Leather material, which is powered by a 2000mAh built-in battery with Max. 60W Output for extraordinary direct-to-lung (DTL) vaping, and comes with a 2ml E-juice capacity tank tube, two 0.25ohm mesh coils to meet your all day long vaping. FRAGG 60 has a compact stylish shape, it is equipped with a 0.69-inch OLED display with various modes for better vaping experience and plug-type mesh coil for more handy operation. ![]() Original Vaptio X-HUBBLE 220W VW Mod Kit with APOLO Sub Ohm Tank original price $96.10, now only $44.99 The Vaptio X-HUBBLE 220W VW Mod Vape Starter Kit consists of X-HUBBLE VW Mod and APOLO Sub Ohm Tank. The mod kit is powered by 2 x 18650 Batteries (Not included) with Max. 220W Output. The mod kit comes with a 5ml E-juice capacity tank and two APOLO Coils: APOLO A1 Single Mesh Coil 0.17ohm, 50~70W and APOLO A3 Triple Mesh Coil 0.15ohm, 60~90W to meet your all day long vaping. Equipped with a 2.0-inch TFT Color Screen, the mod kit supports VW / VT / CCW / CCR Bypass Modes. ![]() Original Vaptio AirGo 11W 700mAh Pod System Kit original price $54.99, now only $30.99 The Vaptio AirGo is the world's smallest and lightest open pod system, it is small but powerful. The unique box of AirGo keeps the pods clean and fresh, and perfectly prevents the pods from dust and dirt. The AirGo mod is powered by a 700mAh capacity battery and comes with a 1.5ml E-juice capacity pod, which can charge the mod for 7 times. It can provide 400 puffs with full power, no more worries about running out of battery for a wholr day. The AirGo mod can be fully charged within 5 minutes, it can be vaped for 40~50 puffs (Depends on personal vaping habits). The charging box uses a unique flip-type design, it is delicate and user-friendly. The shaft is stainless steel, and manufactured by Apple's supplier, which can endure up to 100,000 openings and closings. What's more, it can satisfy you with another flavor you like in the spare pod inside charging box. ![]() Replacement Tank Tube for GAS Mods Kree RTA $4.99 The Replacement Tank Tube is designed for GAS Mods Kree RTA as a replacement part, which is made of PCTG material and comes with 2.0ml E-juice capacity. The Tank Tube features high temperature resistance, corrosion resistance, non-toxic, durable, good gloss and transparent like glass. ![]() ------------------- Tips For Self-Protection From Covid-19 >>> Hygiene products for anti Covid-19 >>> |
637
Original Vaptio Capt'n 220W TC VW Box Mod original price $67.99, now only $14.99
The Vaptio Capt'n 220W Mod is an innovative TC VW Vape Box Mod, which perfectly compatible with Vaptio Paragon Tank (Not included). Capt'n 220W Mod is powered by Dual 18650 batteries (Not included) with output wattage range from 10W to 220W, and comes with Zinc-alloy frame and IML panel body. Capt'n Mod supports stable and high performance VW / TC modes with 0.005s fire speed. Equipped with 1.3-inch TFT color screen, firmware upgradeable, the Vaptio Capt'n Mod will bring you a good vaping experience. ![]() SXK Flash e-Vapor V4.5S+ RTA Clone original price $24.90, now only $22.99 The SXK Flash e-Vapor V4.5S+ RTA Clone is constructed from 316 Stainless Steel in 23mm Diameter. The RTA comes with a 4.5ml E-juice capacity glass tank tube, 1 x air screw mounted seald, 1 x 1.2mm airflow insert, 1 x 1.4mm airflow insert, and 2 x 2.1mm airflow inserts (pre-installed). The RTA features dual post build deck and adjustable airflow for MTL vaping. The SXK Flash e-Vapor V4.5S+ comes with 2 x 316 stainless steel wicks to make a Good Liquid Flow. ![]() Original Vaptio Wall Crawler TC VW Mod Kit with Frogman Sub Ohm Tank original price $56.99, now only $27.99 The Vaptio Wall Crawler 80W TC VW Starter Kit consists of Vaptio Wall Crawler TC VW Box Mod and Frogman Sub Ohm Tank. The mod kit provides a highly advanced, compact vape system with 80W of maximum power and full temperature control suite to pair with the ergonomic Throne Sub Ohm Tank. The Wall Crawler 80W Box Mod is creatively crafted with spider-inspired designs, it is powered by Single 18650 (Not included) with Max. 80W Output, it comes with a full color 1.3" OLED Display and stealth firing button. The internal chipset provides rapid firing time, equipped with temperature control settings ranging from TCR adjustments and normal smart vaping modes. The Frogman Tank holds up to 5ml of your favorite e-juice, Maintaining performance capability, the throne implements the Vaptio's new Hotswap Technology, which makes the coil installation more convenient. Easy top refill and adjustable bottom airflow design, funneling upwards to create an effective passage to optimal flavor. ![]() Original Vaptio ET AUTO Pod System Kit original price $29.99, now only $9.99 The Vaptio ET AUTO Mod Pod Kit, with cool ET head design, is born to durably create pure stable flavors and prevent dry hits. Magnetic pull of the pod base ensures the pod snuggly connecting to the mod and avoids malfunction. ET AUTO Kit is powered by 550mAh built-in battery with Max. 12W Output. It comes with a 1.5ml E-juice capacity pod and a 1.5ohm honeycomb ceramic coil to meet your all day long vape. ET AUTO frees you from any confusing buttons, making vaping as simple as breathing, just to inhale, and exhale. Its quick charger doubles charging efficiency, taking a half less time than before. Innovative LED Tail lights flash to indicate the power level, as your escort in the vaping journey. ![]() YFTK Replacement Airflow Insert for Flash e-Vapor V4.5 / V4.5S / V4.5S+ RTA & YFTK Flash e-Vapor V4.5S+ RTA Clone - 0.8mm (1 PC) $1.55 The YFTK Replacement Airflow Insert is compatible with YFTK Flash e-Vapor V4.5S+ RTA Clone and it is also compatible with Original Flash e-Vapor V4.5 / V4.5S / V4.5S+ RTA, but it cannot be used in the YFTK Flash e-Vapor V4.5 RTA Clone. The airhole of this Airflow Insert is 0.8mm diameter. ![]() YFTK Replacement Airflow Insert for Flash e-Vapor V4.5 / V4.5S / V4.5S+ RTA & YFTK Flash e-Vapor V4.5S+ RTA Clone - 0.9mm (1 PC) $1.55 The YFTK Replacement Airflow Insert is compatible with YFTK Flash e-Vapor V4.5S+ RTA Clone and it is also compatible with Original Flash e-Vapor V4.5 / V4.5S / V4.5S+ RTA, but it cannot be used in the YFTK Flash e-Vapor V4.5 RTA Clone. The airhole of this Airflow Insert is 0.9mm diameter. ![]() YFTK Replacement Airflow Insert for Flash e-Vapor V4.5 / V4.5S / V4.5S+ RTA & YFTK Flash e-Vapor V4.5S+ RTA Clone - 1.0mm (1 PC) $1.55 The YFTK Replacement Airflow Insert is compatible with YFTK Flash e-Vapor V4.5S+ RTA Clone and it is also compatible with Original Flash e-Vapor V4.5 / V4.5S / V4.5S+ RTA, but it cannot be used in the YFTK Flash e-Vapor V4.5 RTA Clone. The airhole of this Airflow Insert is 1.0mm diameter. ![]() Original Steam Crave Aromamizer Ragnar RDTA Replacement Straight Tank Tube(2 PCS) $4.99 The Steam Crave Aromamizer Ragnar Replacement Straight Tank Tube is designed for Steam Crave Aromamizer Ragnar RDTA as a replacement part. It is made from glass material, and features 18ml E-juice capacity. 2 PCS / Pack.
638
Original Yachtvape Pandora 30 Plus Airflow Combinations MTL RTA $29.99
The Yachtvape Pandora 30 Plus Airflow Combinations MTL RTA is constructed from Stainless Steel (body) and Ultem (tank tube) in 22mm diameter. There are FIVE rotatable adjustable internal air holes (Holes Sizes: 1.0mm / 1.2mm / 1.4mm / 1.6mm / 1.8mm) to meet your different needs. Also, it comes with an extension tube that can freely increase capacity (2ml / 3.5ml) and length for your RTA. Moreover, the RTA supports Ture Pure MTL and DTL (Lite) Vaping experience. ![]() SXK Flash e-Vapor V4.5S+ RTA Clone original price $28.90, now only $24.99 The SXK Flash e-Vapor V4.5S+ RTA Clone is constructed from 316 Stainless Steel in 23mm Diameter. The RTA comes with a 4.5ml E-juice capacity glass tank tube, 1 x air screw mounted seald, 1 x 1.2mm airflow insert, 1 x 1.4mm airflow insert, and 2 x 2.1mm airflow inserts (pre-installed). The RTA features dual post build deck and adjustable airflow for MTL vaping. The SXK Flash e-Vapor V4.5S+ comes with 2 x 316 stainless steel wicks to make a Good Liquid Flow. ![]() Original Vaptio Wall Crawler TC VW Mod Kit with Frogman Sub Ohm Tank original price $56.99, now only $27.99 The Vaptio Wall Crawler 80W TC VW Starter Kit consists of Vaptio Wall Crawler TC VW Box Mod and Frogman Sub Ohm Tank. The mod kit provides a highly advanced, compact vape system with 80W of maximum power and full temperature control suite to pair with the ergonomic Throne Sub Ohm Tank. The Wall Crawler 80W Box Mod is creatively crafted with spider-inspired designs, it is powered by Single 18650 (Not included) with Max. 80W Output, it comes with a full color 1.3" OLED Display and stealth firing button. The internal chipset provides rapid firing time, equipped with temperature control settings ranging from TCR adjustments and normal smart vaping modes. The Frogman Tank holds up to 5ml of your favorite e-juice, Maintaining performance capability, the throne implements the Vaptio's new Hotswap Technology, which makes the coil installation more convenient. Easy top refill and adjustable bottom airflow design, funneling upwards to create an effective passage to optimal flavor. ![]() Original Steam Crave Hardon 220W TC VW Mod Kit with Squonk Backpack + Glaz V2 RTA original price $119.00, now only $109.99 The Steam Crave Hadron 220 TC VW Vape Box Mod Kit consists of Hadron 220 TC VW Vape Box Mod, Squonk Backpack, and Steam Crave Glaz V2 RTA, it adopted the innovative YiHi SX480 chipset, is powered by Dual 18650 / 21700 batteries (Not included) with a maximum output power of 220W. The large OLED screen displays pertinent vaping data, including power output, battery life, puff, flavor mode, etc. Detailed and simple user interface. The Steam Crave Hadron Mod Kit comes with a Squonk Backpack that can transform your Hadron 220 Mod into a regulated squonk beast. As for the Steam Crave Glaz V2 RTA, it is constructed from stainless steel and comes with 10ml bubble glass tank. The RTA is solid metal cage design for glass protection and comes with wider coil heating and bigger airflow and improved juice flow. What's more, Hadron 220 Mod is also compatible with Aromamizer Plus and other atomizers with diameter from 25mm to 35mm. ![]() Replacement Top Filling Tank + Drip Tip Kit for 24mm KF Lite 2019 RTA $4.69 The Replacement Top Filling Tank + Drip Tip Kit is suitable for 24mm KF Lite 2019 RTA. It is made from PC material in 26mm Height and 24mm Outer Diameter. ![]() SXK Replacement Colorful Screw Set Kit for SXK BB 70W / DNA 60W Style Box Mod Kit(9 PCS) original price $6.90, now only $4.99 The SXK Replacement Colorful Screw Set Kit is suitable for SXK BB 70W / DNA 60W Box Mod Kit. They are used as replacement parts to fix your BB box mod and make your BB box mod look nice, which is made from stainless steel material.The Kit includes 9 x Colorful Screws. 9 PCS / Pack. ![]() Replacement Top Filling Tank + Drip Tip Kit $4.69 The Replacement Top Filling Tank + Drip Tip Kit is suitable for 22mm KF Lite 2019 RTA. It is made from PC material in 22mm Outer Diameter.
639
Original FamoVape Magma Mate 200W TC VW Box Mod $28.99
The FamoVape Magma Mate 200W TC VW Box Mod is powered by Dual 18650 Batteries (Not included) with 200W Max. output. The Magma Mate Box Mod features multiple working modes with many heat elements, intelligent atomizer detection function, 10s cut-off, and many protections. What's more, it is equipped with a 0.96-inch TFT Color Screen that can display the data of battery, resistance, voltage, wattage and puff counter clearly. ![]() Original Joyetech eVic Primo 200W TC VW Box Mod with UNIMAX 25 Atomizer original price $49.99, now only $20.99 The Joyetech eVic Primo 200W TC VW Box Mod Kit consists of Joyetech eVic Primo TC VW Box Mod and UNIMAX 25 Atomizer. Powered by dual replaceable 18650 cells (Not included), the eVic Primo provides durability and reliability with 200W maximum output. Featuring the new equalizing charge system, it supports 1.5A quick charge capability. The UNIMAX 25 atomizer adopts the exclusive TFTA system where airflow control and e-liquid filling can be easily achieved by rotating or removing the top cap. The eVic Primo also comes with upgradeable firmware, as well as multiple fashionable features including the real-time clock, custom logo and preheat. With the help of the RC (reverse charging) adapter, you can even use it as a power bank to charge your electronic products. ![]() Original Joyetech Cuboid 200 200W TC VW Box Mod original price $39.99, now only $14.99 Having the glossy zinc alloy shell with its premium finish, the authentic Joyetech CUBOID 200 provides durability and reliability in its one of a kind style. Featuring 3 replaceable high-rate 18650 batteries (NOT INCLUDED), it can be powered to 200W. The CUBOID 200 has a 0.96-inch OLED display, supporting VT / VW / TCR modes as well as real-time-clock, preheat and custom logo functions. Meanwhile, it is designed with upgradeable firmware with which you can keep the CUBOID 200 up-to-date. ![]() YFTK Flash e-Vapor V4.5S+ RTA Clone $24.99 The YFTK Flash e-Vapor V4.5S+ RTA Rebuildable Tank Vape Atomizer Clone is constructed from 316 Stainless Steel in 23mm Diameter. The RTA comes with a 4.5ml E-juice capacity glass tank tube, 1 x air screw mounted seald, 1 x 1.2mm airflow insert, 1 x 1.4mm airflow insert, and 2 x 2.1mm airflow inserts (pre-installed). The RTA features dual post build deck and adjustable airflow for MTL vaping. Compared with the YFTK Flash e-Vapor V4.5 RTA Clone, V4.5S+ comes with 2 x 316 stainless steel wicks to make a Good Liquid Flow. ![]() Kindbright Vega DL/MTL RDA Clone with BF Pin $21.99 The Kindbright Vega DL/MTL RDA Clone is constructed from 316 Stainless Steel material in 22mm Diameter. The Vega RDA comes with a single coil build deck, which is very easy to build that has enough space for building the coil. With the Vega RDA , you can invert V-shaped side airflow directs air to the base and no worry about the E-liquid leakage problem. Moreover, Vega RDA supports DL and MTL vaping experience, and supports Side airflow system. And the RDA comes with different pins and drip tips to meet your different vaping needs. This RDA comes with bottom feeder / BF / Squonk Pin. ![]() SXK Billet Box 70W All-in-One Mod Kit Clone with USB Port original price $75.00, now only $64.99 The SXK BB Box Mod Kit Clone is constructed from aluminum with an all-in-one design. This mod comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor. This BB Box comes with USB port for charging only. Without LOGO. ![]() SXK Replacement Ultem Drip Tip for SXK Alpha / Kindbright Alpha / Alpha RTA Clone original price $3.90, now only $2.99 The SXK Replacement Drip Tip is suitable for Alpha RTA Clone/ SXK Alpha RTA / Kindbright Alpha RTA Clone as a replacement part. It is made from PEI material in 15mm Height and 14mm Diameter. ![]() SXK Replacement Clear Top Cap Tank Tube + Drip Tip Set Kit for SXK Alpha / Alpha RTA Clone original price $5.90, now only $4.99 The SXK Replacement Top Cap Tank Tube + Drip Tip Kit is suitable for Alpha RTA Clone/ SXK Alpha RTA / Kindbright Alpha RTA Clone as replacement parts. They are made from PC material. The tank tube is 18mm Height, 22mm Diameter, and the Drip Tip is 15mm Height, 14mm Diameter. The E-juice capacity of this tank tube is 2.8ml. ![]() SXK Replacement Ultem Top Cap Tank Tube for SXK Alpha / Alpha RTA Clone original price $5.90, now only $4.59 The SXK Replacement Ultem Top Cap Tank Tube is suitable for Alpha RTA Clone/ SXK Alpha RTA / Kindbright Alpha RTA Clone as a replacement part. It is made from PEI material. The tank tube is 18mm Height, 22mm Diameter. The E-juice capacity of this tank tube is 2.8ml. ![]() SXK Internal Hexagonal Wrench Allen Wrench Tool Kit for SXK BB 70W / DNA 60W Mod Kit Clone(5 PCS) $2.90 The SXK Hexagon Screwdriver Tool Kit is suitable for SXK BB 70W / DNA 60W Mod Kit Clone, they are made from stainless steel. 5 PCS / Pack.
640
Original GeekVape Aegis Max 100W Box Mod original price $48.00, now only $41.99
The Geekvape Aegis Max 100W TC VW Variable Wattage Vape Box Mod is powered by single 21700 / 18650 battery (Not included) and has Power(VW) / VPC / TC / TCR / Bypass five working modes for options. Equipped with AS 100 chipset and constructed from durable Zinc-Aluminum Alloy, Aegis Max Mod features IP67 Waterproof / Shockproof / Dustproof. What's more, there are multiple protections that ensure your vaping safety. ![]() Original Advken Barra Mesh Sub Ohm Tank Clearomizer $9.99 The Advken Barra Mesh Tank is made from Food-grade PCTG Plastic and Stainless Steel in 24mm Diameter. It has a detachable sub-ohm mesh coil and offers a variety of color and coil options. The Advken Barra Mesh Tank Base is a regular-sized tank that can hold 4ml of E-juice. Barra Mesh Tank is half-transparent to indicate the level of remaining juice within the 4ml tank. Furthermore, the Advken Barra is top filled, stoppered by a silicone plug, revealing a single fill hole. Within the Barra Mesh Tank is the replaceable atomizer core constructed from mesh wires in a single fashion, utilizing organic cotton as a wicking medium. The mesh coil has a larger heating area to speed the healing process brings you a fantastic vaping experience. Outfitted with a dual slotted bottom airflow control ring, the Advken Barra Mesh Tank can meter the amount of airflow rushing into the coil's internal structure by adjusting the size of the open airflows. ![]() Dripper Nio RDA / RSA Master Kit Clone with 5 Spare Colorful Top Caps & 510 Drip Tips & Beauty Rings $14.99 The Dripper Nio RDA / RSA Master Kit Clone comes with a single coil postless build deck and supports top airflow intake to reduce leaking. The RDA / RSA Kit comes with 1 x SS Base Deck + 7 x Acrylic Top Caps (Black Top Cap, Clear Top Cap, Blue Top Cap, Green Top Cap, Red Top Cap, Purple Top Cap, and Ultem Top Cap) + Acrylic 510 Drip Tip + Acrylic Beauty Ring. There are so many colors for you to choose according to your favors. ![]() Original Joyetech Exceed Grip Pro Pod System $35.86 The Exceed Grip Pro VW Mod Pod System Vape Starter Kit is a brand new one of EXCEED Grip Series. Exceed Grip Pro Kit is powered by a 1000mAh built-in battery with Max. 40W Power. The battery mod is designed with many creative functions. Equipped with 0.69 inch OLED screen, it can show you the details of battery and wattage. Smart mode can automatically detect the coil you inserted to offer you the optimum wattage output. Moreover, there is the amazing charging display to tell you the charging state of battery. As to the pod cartridge and coil, Exceed Grip Pro Kit is compatible with NEW EZ cartridge and EZ coils. The pod cartridge holds 2.6ml E-juice capacity and features side airflow which will prevent leakage. And the EZ cartridge is compatible with all the EXCEED Grip line. The EZ Coils will provide you improved flavor. (The EZ RBA Coil is not included and sold separetely). The Exceed Grip Pro Kit also comes with multiple safety protections. ![]() Original Joyetech Exceed Grip Plus Pod System $40.59 The Exceed Grip Plus VW Box Mod Pod System Vape Starter Kit is an updated version of Joyetech Exceed Grip Series. Exceed Grip Plus Kit comes with a special appearance, portable size, and comfortable hand feeling design that will catch your eyes. It comes with a new EZ cartridge that has applied the latest patent technology. As for the pod cartridge, holding 2.6ml E-juice capacity, it also adopts side airflow and side refilling design to prevent leakage. It comes with new EZ coils, EZ 0.4ohm coil for fast heating process, EZ 1.2ohm coil for MTL vape and even EZ RBA coil for DIY entertainment. (EZ RBA Coil is not included, sold separetely). Exceed Grip Plus Kit is powered by a Single 18650 battery (Not included) with adjustable output power in the range from 1W to 80W. And it is charged via a type-C port in one hour and a half. Moreover, the concise and informative user interface will bring you easy operations like changing the theme color and display details, like the mode and the battery life. What's more, there are multiple protections to prevent potential risks. ![]() Original GeekVape Aegis Max 100W Mod Kit with Zeus Tank original price $68.00, now only $59.99 The Geekvape Aegis Max 100W TC VW Box Mod Vape Starter Kit consists of Geekvape Aegis Max TC VW Box Mod and Zeus Sub Ohm Tank Atomizer. Equipped with AS 100 chipset and constructed from durable Zinc-Aluminum Alloy, Aegis Max Kit features IP67 Waterproof / Shockproof / Dustproof, Aegis Max is powered by single 21700 / 18650 battery (Not included), and has Power(VW) / VPC / TC / TCR / Bypass five working modes for options. As for the Zeus Sub Ohm Tank, which utilizes the technology of GV Mesh Coil System (Mesh Z1 Coil, 0.4ohm, 60~70W / Mesh Z2 Coil, 0.2ohm, 70~80W, Pre-installed) to optimize flavor and vapor production, the Geekvape Aegis Max Starter Kit will be a perfect device for vapers on the go. ![]() Original Joyetech Replacement EZ Empty Cartridge for Exceed Grip / Exceed Grip Plus / Pro Pod System Vape Kit(5 PCS) $9.99 The Joyetech EZ Cartridge is a 2ml refillable pod cartridge, using the latest patented technology of breakthrough Joyetech, which will prevent leakage by side airflow design. Refillable via side-fill system stoppered by a silicone plug. The EZ Cartridge supports adjustable airflow. The air enters from the black airflow valve on the side of the cartridge and can be opened or closed at will according to your needs. In addition, EZ Cartridge uses the newly designed EZ Coil to bring you pure flavor and dense steam.(Coils are not included, sold separately). Joyetech EZ Replacement Cartridge is compatible with All EXCEED GRIP Series Products, including Exceed Grip Plus, Exceed Grip Pro, Exceed Grip. 5 PCS / Pack. ![]() Original Joyetech Replacement EZ Coil Head for Exceed Grip Plus / Pro Pod System Vape Kit(5 PCS) $13.00 The Joyetech Replacement EZ Coil Head is compatible with Joyetech Exceed Grip Plus / Joyetech Exceed Grip Pro Pod System Vape Kit. The EZ Coil can make you get a pure flavor. The resistance of this coil is 1.2ohm and the power range from 7W to 13W. 5 PCS / Pack. ![]() Original Joyetech Replacement EZ RBA Coil Head for Exceed Grip Plus / Pro Pod System Vape Kit(1 PC) $8.60 The Joyetech Replacement EZ RBA Coil Head is compatible with Joyetech Exceed Grip Plus / Joyetech Exceed Grip Pro Pod System Vape Kit. The EZ RBA Coil fits for DIY lovers.
