Просмотров в теме 302474   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 10.04.2020, 04:41 Автор темы   601
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original SUNVAPE Sunpipe H2O DH Water Pipe Vaporizer Vape Starter Kit $22.99
The Original Sunpipe H20 Vaporizer Vape Starter Kit is a compact and portable water pipe vaporizer Kit. The internal water tank can filter and reduce the temperature of the smoke and give you a cooler, smoother and better tasting hit. The heating chamber and slider are made of Stainless Steel material. The design of spring loaded slider makes the chamber capacity changeable, you can use 0.1~0.5 gram as you like. With a mini size and magnet connection of water tank and heating chamber design, Sunpipe H20 is easy to clean, take them apart, put them in resin cleaning solution or 91+ alcohol around 30 minutes, then you can get a fresh device. Unlike water tank made of glass, the Sunpipe H20 water pipe won't break when dropped on floor.
Original Acrohm Fush Nano Mesh 15W 550mAh AIO Pod System Vape Starter Kit(Limited Edition) original price $39.99, now only $25.99
The Original Acrohm Fush Nano Limited Edition Pod Kit has been upgraded based on Acrohm Fush Nano Pod Kit. The new Limited Edition Fush Nano Pod Kit, specially designed for flavor enthusiasts. It has an improved design. A fresh new look and more color options. The aluminum mouthpiece is designed ergonomically, perfectly fit your mouth and provides real MTL experience. It maintains the original function of changing colors by shaking the body. It is powered by an internal 550mAh battery. Capable of reaching max 15W constant power output to strive for the best performance. It uses dual-boot mode, enjoys both vaping via button pressing and inhalation activation, switches between MTL and DTL. Draw Activation - Direct vape with 13W output of air pressure sensor, savoring the smooth and elegant flavor. Bottom Firing - The bottom-firing pod system, still vaping like a mech. With the 15W button output, it can deliver rich vapor and intense flavor. What's more, it is also compatible with the fush nano pod for great flavor.
Replacement Top Cap Tank Tube + Drip Tip for 22mm Hussar RTA / Hussar The End RTA Vape Atomizer $6.99
The Replacement Top Cap Tank Tube + Drip Tip is suitable for Hussar RTA / Hussar The End RTA Vape Atomizer as a replacement part, which is made of PEI material (tank tube & drip tip) and features 3.5ml E-juice capacity.
Replacement Top Cap Tank Tube + Drip Tip for 22mm Hussar RTA / Hussar The End RTA Vape Atomizer $5.99
The Replacement Top Cap Tank Tube + Drip Tip is suitable for Hussar RTA / Hussar The End RTA Vape Atomizer as a replacement part, which is made of PC material (tank tube & drip tip) and features 3.5ml E-juice capacity.
The Replacement Top Cap Tank Tube + Drip Tip is suitable for Hussar RTA / Hussar The End RTA Vape Atomizer as a replacement part, which is made of PC (top cap tank tube) and Stainless Steel (drip tip) material and features 3.5ml E-juice capacity.
SXK The Syclla MTL RTA Replacement Straight Tank Tube Clone $2.90
The SXK Replacement Straight Tank Tube is suitable for SXK The Syclla MTL RTA Rebuildable Tank Vape Atomizer Clone as a replacement part, which is made of PC material and features 4.0ml E-juice capacity.
Original Reewape AS302 Replacement 810 Drip Tip for 528 Goon / Reload / Kennedy /Wotofo Profile/Battle RDA $1.95
The Reewape AS302 Replacement 810 drip tip is made of resin. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.
Original Reewape AS307 Replacement 810 Drip Tip for 528 Goon / Reload / Kennedy / Wotofo Profile/Battle RDA $1.95
The Reewape AS307 Replacement 810 drip tip is made of resin. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.
Original Reewape AS306 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle /Reload RDA $1.95
The Reewape AS306 Replacement 810 drip tip is made of resin, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original SUNVAPE Sunpipe H2O Water Pipe Vaporizer Vape Kit Replacement Bubbler Tank(1 PC) $3.55
The Original Sunpipe H20 Bubbler tank is an internal water tank and fits for dry herb. It can filter and reduce the temperature of the smoke which offer your a cooler, smoother and better tasting hit.. Moreover, this water tank is less ash, less tar. It is designed for SUNVAPE Sunpipe H20 Water Pipe Vaporizer Vape Kit as a replacement part.
3FVape 2020 Easter Sale Information
Time: 00:00:00 April 10th 2020 - 23:59:59 April 12th 2020 (MDT)
Offer: Site-wide 5% OFF + Extra Gift
Coupon code: Easter2020
Tips For Self-Protection From Covid-19 >>>
Hygiene products for anti Covid-19 >>>
3FVAPE вне форума   Вверх
Старый 13.04.2020, 04:55 Автор темы   602
3FVAPE
Original Hellvape Dead Rabbit SE RDA with BF Pin original price $18.99, now only $13.99
The Original Hellvape Dead Rabbit SE RDA is an update to the original featuring a few tweaks to the airflow inlets and build deck, which is constructed from PCTG (body) and Stainless Steel (deck) in 24mm Diameter. The airflow inlets have slot or honeycomb options. Simply rotate the barrel to select which you prefer. Also the airflow is angled down towards the deck to allow the inlets to be set higher to reduce the chance of leaks. The barrel has a locking feature to ensure that the airflow inlets are always aligned with your coils and you turn the top cap to adjust. Moving on to the deck-this still features the rabbit ear posts which are nice and easy to build on.
Original Hellvape Dead Rabbit SE RDA Kit with BF Pin - Blue + Black + Red + Clear original price $21.99, now only $17.99
The Original Hellvape Dead Rabbit SE RDA Kit is an update to the original featuring a few tweaks to the airflow inlets and build deck, which is constructed from PCTG (body) and Stainless Steel (deck) in 24mm Diameter. The kit includes one RDA with clear cap plus one black cap, one red cap and one blue cap. The airflow inlets have slot or honeycomb options. Simply rotate the barrel to select which you prefer. Also the airflow is angled down towards the deck to allow the inlets to be set higher to reduce the chance of leaks. The barrel has a locking feature to ensure that the airflow inlets are always aligned with your coils and you turn the top cap to adjust. Moving on to the deck-this still features the rabbit ear posts which are nice and easy to build on.
Vapeasy Roulette MTL/DL RTA Clone $23.99
The Vapeasy Roulette RTA Clone supports MTL / DL vaping. This Vapeasy Roulette RTA Clone is with top refilling and juice control by rotation of the drip tip base. The RTA comes with two air roulette. one for MTL and the other for DL. It is to change the air hole settings via rotating the air Roulette.
Original VEIIK Airo Pro 20W 1200mAh Pod System Vape Starter Kit $23.99
The Original VEIIK Airo Pro 1200mAh Pod System Vape Starter Kit is the advanced version of VEIIK Airo Kit. The VEIIK Airo Pro Pod Kit is powered bu a 1200mAh built-in battery (Max. Output: 20W), providing a powerful and long vaping experience for you. The VEIIK Airo Pro Pod Cartridge adopts 2ml E-juice capacity and comes with replaceable coils of 1.2ohm (BVC Coil) / 0.6ohm (DTL Mesh Coil). The side refill system of VEIIK Airo Pro Pod make filling easier too.
Original Ultroner Theia 30W VW Pod System Vape Mod Starter Kit original price $89.90, now only $68.99
The Original Ultroner Theia Pod system is the latest stabwood pod system from Ultroner. The pod cartridge is with 2ml capacity and with mesh coils with 0.6ohm and 1.2ohm resistance. The Ultroner Theia Pod system is with adjustable wattage from 5W to 30W, and this pod is powered by Ultroner's efficient Sevo Chipset. The Ultroner Theia Pod system accommodates a replaceable Li-Po battery and includes a charging dock to charge the battery externally while also supplying a spare battery.
Steam Tuners Replacement Bell Cap + Chimney Clone for Flash e-Vapor E-Vapor V4.5 RTA Clone $7.99
The Steam Tuners Replacement Bell Cap Clone is made of PEI (bell cap) and SS (chimney), which is suitable for YFTK Flash e-Vapor E-Vapor V4.5 RTA Rebuildable Tank Vape Atomizer Clone. The cap is 23mm diameter. The bell cap has a 3.8ml E-juice capacity.
Steam Tuners Bell Cap + Chimney Clone for Flash e-Vapor E-Vapor V4.5 RTA Clone $6.99
The Steam Tuners Replacement Bell Cap Clone is made of PC (bell cap) and SS (chimney), which is suitable for YFTK Flash e-Vapor E-Vapor V4.5 RTA Rebuildable Tank Vape Atomizer Clone. The cap is 23mm diameter. The bell cap has a 3.8ml E-juice capacity.
Original VEIIK Airo Pro Pod System Vape Kit / Cartridge Replacement BVC Coil Head(5 PCS) $8.99
The VEIIK Replacement BVC Coil Head is designed for VEIIK Airo Pro Pod System Vape Kit / Pod Cartridge as a replacement part. It features 1.2ohm coil resistance. 5 PCS / Pack.
Original VEIIK Airo Pro Pod System Vape Kit / Cartridge Replacement DTL Mesh Coil Head(5 PCS) $8.99
The VEIIK Replacement DTL Mesh Coil Head is designed for VEIIK Airo Pro Pod System Vape Kit / Pod Cartridge as a replacement part. It features 0.6ohm coil resistance. 5 PCS / Pack.
Original Ultroner Theia Pod System Vape Mod Replacement Coil Head(3 PCS) $11.99
The Original Ultroner 1.2ohm Coil Head is suitable for Theia Pod System Vape Mod Kit. The coil comes in 3 PCS / Pack. The image will be updated soon.
Original Ultroner Theia Pod System Vape Mod Replacement Mesh Coil Head(3 PCS) $11.99
The Original Ultroner mesh 0.6ohm Coil Head is suitable for Theia Pod System Vape Mod Kit. The coil comes in 3 PCS / Pack. The image will be updated soon.
Старый 14.04.2020, 05:02 Автор темы   603
3FVAPE
Avatar RTA Clone $14.99
The Avatar RTA Rebuildable Tank Vape Atomizer Clone is constructed from stainless steel (body) and comes with a PEI Tank, an Acrylic Tank, and an Acrylic Drip Tip. The RTA supports bottom airflow adjustable control.
Original dotMod dotAIO SE Ultra MTL / DTL Portable AIO Pod System Vape Starter Kit $59.99
The dotMod dotAIO SE Ultra Portable Pod Kit is made of zinc alloy and a stainless steel finish, it is powered by 1 x 18650 Battery. (Not included) Using the exact same technology as our standard dotAIO, the SE spares no exceptions. Vape freebase nicotine or nicotine salts. Dial-in the perfect airflow and power. Vape MTL or DTL. With the dotAIO SE easy to remove 2.0ml tank, changing coils has never been easier. The ergonomic spring-loaded contact located under the tank section allows for easy tank removal. The dotAIO offers four power settings based on coil resistance (very soft, soft, medium, strong), designed to fit your preferences and deliver the best performance. Featuring dry burn protection that cuts the current when the E-juice level is low, extending the life of your coils. Use 0.3ohm coils for sub-ohm vaping or 0.7ohm coil for higher nicotine levels. Are you a fan of Aspire Nautilus coils. (Not included) You can use them too with the adapter we included. Prefer a mouth-to-lung experience.
Original dotMod dotAIO 35W Ultra MTL / DTL Portable AIO Pod System Vape Starter Kit $89.99
The dotMod dotAIO Ultra Portable AIO Pod Kit features a hybrid style pod with replaceable coils, four preset power output levels, and is powered by a single 18650 battery (Not included). The dotAIO includes both a 0.3ohm mesh coil and a 1.6ohm MTL coil, and is also compatible with Aspire Nautilus BVC coils (BVC coils are not included) when used with the included adapter. The dotAIO has a proprietary chipset inside that is highly intuitive with some unique features. The chipset uses a two button control interface and a four LED indicator light ring around the firing button. Featuring the classic dotMod button logo, the firing button is ergonomically positioned and controls the firing of the device and the power on / off. Below the firing button, hidden under the battery access panel, is the adjustment button. This button allows the user to select between the four power outputs, and also controls the Dry Burn Protection feature. The Dry Burn Protection features is designed to work SS316 coils and will indicate when the juice levels are low via a flashing purple light.
SXK VapeSnail Replacement Chimeny Inner D Clone for SXK BB / Billet Box Mod Kit original price $5.90, now only $4.99
The SXK VapeSnail Replacement Chimeny Inner D Clone is of 316 stainless steel, it is suitable for SXK BB / Billet Box Mod Kit as a replacement part.
SXK VapeSnail Replacement 4 AFC Tubes + 4 MTL Pins Clone for SXK BB / Billet Box Mod Kit original price $12.90, now only $8.99
The SXK VapeSnail Replacement AFC Tubes Clone are made of 316 stainless steel, the replacement parts includes 4 AFC Tubes (hole sizes: 2mm / 2.5mm / 3mm / 3.5mm; Diameter: 8mm; Height: 11mm) plus 4 MTL Pins (hole sizes: 1mm / 1.2mm / 1.5mm / 1.8mm pinned; Diameter: 5mm; Height: 5mm). They are suitable for SXK BB / Billet Box Mod Kit as replacement parts.
SXK VapeSnail Replacement Tank RBA Clone + Chimney + Base Deck with 4.0mm AFC for SXK BB / Billet Box Mod Kit orignal price $23.90, now only $21.99
The SXK VapeSnail Replacement Tank Clone includes a 316SS Chimney and a 316SS Base Deck, and a PCTG Replacement Tank. They are suitable for SXK BB / Billet Box Mod Kit as replacement parts. Comes with 4.0mm AFC tube
Original Reewape AS310 Replacement Anti-Spit 510 Drip Tip for RDA / RTA / RDTA /Sub-Ohm Tank Vape Atomizer $1.99
The Reewape AS310 Replacement 510 Drip Tip is made of resin material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Старый 14.04.2020, 05:05 Автор темы   604
3FVAPE
Original Reewape AS311 Anti-Spit 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / Reload RDA $1.99
The Reewape AS311 Replacement 810 drip tip is made of resin, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS312 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / Reload RDA $1.99
The Reewape AS312 Replacement 810 drip tip is made of resin, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original dotMod dotAIO Pod System Vape Kit Replacement Single Mesh Coil Head(5 PCS) $14.99
The dotMod dotAIO replacement Coils are designed for dotMod dotAIO Portable Pod System Vape Kit. It is designed to improve E-liquid flavor, giving users a smooth and long lasting vaping experience. With the use of brass construction and multiple configurations users may enjoy a steady vape with very little power drop off. The Single Mesh Coil features 0.3ohm coil resistance that power output range from 20W to 35W.
Original dotMod dotAIO Pod System Vape Kit Replacement SS316L Stainless Coil Head(5 PCS) $14.99
The dotMod dotAIO replacement Coils are designed for dotMod dotAIO Portable Pod System Vape Kit. It is designed to improve E-liquid flavor, giving users a smooth and long lasting vaping experience. With the use of brass construction and multiple configurations users may enjoy a steady vape with very little power drop off. The SS316L Stainless Coil features 0.7ohm coil resistance that power output range from 14W to 20W.
Original dotMod dotAIO Pod System Vape Kit Replacement Ceramic Coil Head(5 PCS) $14.99
The dotMod dotAIO replacement Coils are designed for dotMod dotAIO Portable Pod System Vape Kit. It is designed to improve E-liquid flavor, giving users a smooth and long lasting vaping experience. With the use of brass construction and multiple configurations users may enjoy a steady vape with very little power drop off. The Ceramic Coil features 1.6ohm coil resistance that power output range from 8W to 14W.
Original dotMod dotAIO Pod System Vape Kit Replacement Empty Tank with Coil Adapter $21.99
The dotMod dotAIO replacement tank is designed for the dotMod dotAIO Portable Pod System Vape Kit. It feature a 2ml e-juice capacity, single 6mm by 4mm fill port and comes with coil adapter for Aspire Nautilus BVC Coils. (BVC Coils are Not included) Without the use of the coil adapter users may enjoy a flavorful vaping experience with the DotAIO Replacement Coils. (Not included) With the gold plated accents on this replacement tank completely match the visually stunning aesthetic of DotMod Devices.
Original dotMod dotAIO Pod System Vape Kit Replacement RBA Coil with RBA Build Deck & Tank & 510 Adapter $33.99
The dotMod dotAIO RBA Coil is designed for dotMod dotAIO Portable Pod System Vape Kit. The RBA kit comes with a tank with a 2ml e-juice capacity, single 6mm by 4mm fill port and RBA build deck. With the included coil adapter, you can connect your RBA deck to a regulated mod for an easy readout of their atomizer resistance. Utilizing gold plated accents on this replacement tank completely match the visually stunning aesthetic of DotMod Devices as well as increase conductivity on the contact located at the base of the RBA build deck.
Original Fumytech 2.7ml to 6.1ml Replacement DLC Lengthen Tank Tube for BDvape Precisio MTL RTA $9.99
The Fumytech DLC Replacement Lengthen Tank Tube is constructed from stainless steel and it is designed for BDvape Precisio MTL RTA Atomizer as a replacement part to lengthen the length of tank tube from 2.7ml juice capacity to 6.1ml juice capacity.
SXK VapeSnail Replacement Tank RBA Clone + Chimney + Base Deck with 4 AFC Tubes + 4 MTL Pins for SXK BB / Billet Box Mod Kit $30.98
Старый 15.04.2020, 05:24 Автор темы   605
3FVAPE
SXK Avat MTL / DL RTA Clone original price $23.90, now only $19.99
The SXK Avat MTL / DL RTA Rebuildable Tank Vape Atomizer Clone is constructed from 316 Stainless Steel (body) and PEI (tank tube) in 22mm Diameter. The RTA comes with a 3.4ml E-juice capacity tank tube and a SS drip tip. And it supports MTL and DL vaping experience, bottom airflow control and top-filling system.
Original Teslacigs Dailee 21W 700mAh Mod Pod System Vape Starter Kit orignal price $29.99, now only $24.99
The Teslacigs Dailee 700mAh Mod Pod System Vape Kit is a compact Pod system device, features whistle-like design, small and chic. The smooth case was harmoniously supplemented with a translucent cartridge with an ergonomic flattened mouthpiece. The mouthpiece design fits the lips comfortably, and the lips naturally wrap the mouthpiece. Teslacigs Dailee is powered by a 700mAh built-in battery which is charged using a standard micro-USB connector located on the bottom of the device, a full charge cycle with a current of 0.8A can be carried out in less than an hour, lasting endurance while charge once, enjoy all day. Supported resistance range from 0.6 to 3.0 ohms. A small LED located on the side panel indicates the operation of the device and the battery charge level. The mod itself has no buttons, air activation. Teslacigs Dailee Pod with a pod of 2ml E-juice capacity. The cartridge is held in the battery blocks by means of magnets. Plug and play. Only one type of vaporizer is available for the Teslacigs Dailee Mod Pod Kit - with a conventional 1.2ohm nichrome coil, each drop of e-juice is fully atomized, tastes more natural and pure.
Original GeekVape HBC-S03 Handbuild Staggered Fused Clapton Single Coil for Eagle Clearomizer(2 PCS) $1.99
The GeekVape HBC-S03 coil head is a 0.2ohm Staggered Fused Clapton Single Coil Head is constructed from 316 Stainless Steel. This HBC-S03 coil head is suitable for Eagle Clearomizer. The GeekVape HBC-S03 coil head can support 40~70W power output. 2 PCS / Pack.
Original Aspire Nautilus X Tank Vape Atomizer Replacement Straight Tank Tube $1.99
This Aspire replacement Frosted Pyrex Glass tube is designed for Aspire Nautilus X Tank Vape Atomizer as a replacement part. It features 2ml E-juice capacity and it is very convenient to replace and easy to clean.
Original Footoon Aqua Mini 2W UV Sanitizer Light for Sterilizing Face Mask /Vape/Phone, etc. $25.99
The Footoon Aqua Mini UV Sterilizer is easy to carry and use, suitable for home, office, travel, business trip etc. The UV Sterilizer is powered by 4 x AAA batteries.(Not included)And the Sterilizer adopts ultraviolet light to remove bacteria from Face Mask / Vape / Phone, etc. So it effectively kills bacteria to keep cleanliness of room, closet and household items. What's more, the Aqua Mini UV Sterilizer has automatic safety switch design, simply turn the UV light tube up side and the light will auto go off, which will ensure a safe operation.
Original Reewape AS309 Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99
The Reewape AS309 Replacement 510 Drip Tip is made of resin and SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
ULTON DOTSHELL Replacement Tank RBA Clone with 3 MTL Pin for dotAIO Portable AIO Pod System Vape Kit $28.95
The ULTON DOTSHELL Rebuildable Replacement Tank Clone includes a PCTG Replacement Tank, and 3 MTL Pins (Hole Sizes: 1.0mm, 1.2mm, 1.5mm + / - 0.1mm tolerance). They are suitable for dotAIO Portable AIO Pod System Vape Kit as replacement parts.
SXK Avat RTA Vape Atomizer Clone Replacement Drip Tip orignal price $6.90, now only $3.99
The SXK Replacement Drip Tip is suitable for SXK Avat RTA Rebuildable Tank Vape Atomizer as a replacement part, which is made of SS material in 17.5mm height, 14mm diameter.
SXK Avat RTA Vape Atomizer Clone Replacement Top Cap Tank Tube orignal price $6.90, now only $4.99
The SXK Replacement Top Cap Tank Tube is suitable for SXK Avat RTA Rebuildable Tank Vape Atomizer as a replacement part, which is made of PEI material in 22mm height, 22mm diameter. The Tank Tube features 5.0ml E-juice capacity.
SXK VapeSnail Tank RBA Clone + Base Deck + 4 AFC Tubes + 4 MTL Pins + 2.5mm Chimney Inner C & C Reducer $35.97
The SXK VapeSnail Replacement Tank Clone includes a 316SS 4.0mm Chimney and a 316SS Base Deck, and a PCTG Replacement Tank. They are suitable for SXK BB / Billet Box Mod Kit as replacement parts. The SXK VapeSnail Replacement 2.5mm Chimney Inner C & C reducer Clone is of 316 stainless steel, it is suitable for SXK BB / Billet Box Mod Kit as a replacement part. With this 2.5mm Chimney Inner C & C reducer, your SXK VapeSnail RBA will be with MTL vaping experience. The SXK VapeSnail Replacement AFC Tubes Clone are made of 316 stainless steel, the replacement part includes 4 AFC Tubes (hole sizes: 2mm / 2.5mm / 3mm / 3.5mm; Diameter: 8mm; Height: 11mm) plus 4 MTL Pins (hole sizes: 1mm / 1.2mm / 1.5mm / 1.8mm pinned; Diameter: 5mm; Height: 5mm). They are suitable for SXK BB / Billet Box Mod Kit as replacement parts.
Старый 16.04.2020, 04:30 Автор темы   606
3FVAPE
Original Uwell Zumwalt 13W 520mAh Pod System Vape Starter Kit $24.99
The Uwell Zumwalt Pod System Vape Starter Kit is an elegant pod kit, which is powered by a built-in 520mAh battery. Combined with a quick charge function using a micro USB cable, the installation of all relevant protective circuits, a very well-functioning automatic train and the compact format, the Zumwalt Kit is a perfect daily companion, which can be stowed anywhere without any problems. A small three-color LED keeps the you up to date with the remaining battery capacity. Due to the simple operation, the kit is also perfect for beginners / transitioners in the steamer world. The battery carrier outputs its power depending on the resistance of the winding used with up to a maximum of 13 watts. The small pods hold 1.6ml of E-juice and can easily be filled from above by pulling off the drip tip. Inside there is a 1.2ohm parallel winding, which offers a great taste development. This is accompanied by a very pleasant amount of steam and a smoother throat hit. The pulling behavior is similar to that of an ordinary cigarette, so that the Zumwalt Kit is perfectly geared for a classic MTL / baking steam train.
Original Artery Pal SE V2 20W 700mAh Pod System Vape Starter Kit original price $39.99, now only $25.99
The Artery Pal SE V2 Pod System Vape Kit is a New Version Artery Pal SE pod kit, it comes with new pod design with more comfortable mouth piece and much better flavor. Artery Pal SE V2 Pod kit is powered by a 700mAh built-in battery with max 20W output power. Artery Pal SE V2 kit features Tri-color LED indicator to show battery life. Artery Pal SE V2 cartridge can hold 2ml E-juice capacity with bottom refill design and comes with 1.2ohm KA1 coil for great flavor.
510 Thread Connector Adapter with Copper Gold Plated for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit $1.99
The 510 Thread Adapter is designed for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit, it can switch your Voopoo VINCI Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you. It is made of ABS, and comes with a copper gold plated.
Original Vandy Vape Fused Clapton Heating Wire Coil for RBA / RDA/RTA/RDTA Vape Atomizer(10 PCS) $5.99
The Vandy Vape Fused Clapton Coil is made of A1 (26GA x 2) and Ni80 (36GA) material. It could bring you better flavor. Just get it for your RDA / RTA / RDTA and enjoy DIY fun. 10 PCS / Bottle.
Original Vandy Vape Superfine MTL Fused Clapton Wire Coil for RBA / RDA/RTA/RDTA Vape Atomizer(10 PCS) $6.59
The Vandy Vape Superfine MTL Fused Clapton Wire Coil is made of Ni80 material. It features 30GA x 2 + 38GA, and could bring you better flavor. Just get it for your RBA / RDA / RTA / RDTA and enjoy DIY fun. 10 PCS / Bottle.
Старый 17.04.2020, 04:42 Автор темы   607
3FVAPE
Vapeasy Armor Engine RDA Clone with BF Pin $16.99
The Vapeasy Armor Engine RDA Rebuildable Dripping Atomizer Clone is constructed from 316 stainless steel and with replaceable Delrin 510 drip tip. This RDA is with dual-pole for single coil building. The RDA supports airflow adjustable control via the top cap. This RDA comes with bottom feeder / BF / Squonk Pin. Only one batch, limited quantity.
Original Vaporesso TARGET PM30 1200mAh MTL Box Mod Pod System Vape Starter Kit original price $29.90, now only $24.99
The Vaporesso TARGET PM30 based on the latest GTX coil platform, bringing you even more convenience as well as a huge leap in flavor production. Target PM30 is powered by a built-in 1200mAh battery gives all day long usage time, plus adding Type-C charging cable makes recharging easier. It comes with a 3.5ml E-juice capacity Pod Cartridge and two GTX Coils for you options: GTX 0.6ohm Mesh Coil and GTX 1.2ohm Regular Coil. It also is compatible with 0.8ohm Mesh Coil (Sold Separately). Supported by the latest GTX coil platform, it brings fresh flavors, smooth airflow and dense clouds. By keeping the patented slide and PTF system on top, refilling will be both mess-free and simple.
Original Vaporesso TARGET PM80 SE 80W VW Box Mod Pod System Vape Starter Kit original price $39.90, now only $31.99
The Vaporesso TARGET PM80 SE VW Box Mod Pod System Vape Kit is powered by single 18650 battery (Not included) that output power range can from 5W to 80W. The 0.91-inch OLED display brings a clear operation interface to users. The TARGET PM80 SE Pod Cartridge comes with large 4ml E-juice capacity to meet your all day vape, the GTX series coils / GTX RBA coil is compatible with TARGET PM80 Kit. (GTX RBA coil sold separately) The 2A quick charge of TARGET PM80 SE Kit provides a fast charge. With adjustable airflow system, the TARGET PM80 SE supports a DL and restricted DL vape.
Original Vaporesso Target PM80 SE Mod Pod System Vape Kit Replacement Empty Pod Cartridge(2 PCS) $5.29
The Vaporesso Replacement Empty Pod Cartridge is designed for Vaporesso Target PM80 SE Box Mod Pod System Vape Kit as a replacement part, which comes with 4.0ml E-juice capacity. 2 PCS / Pack.
Original Vaporesso Target PM80 Mod Pod Vape Kit / Catridge GTX FeCrAl Restricted DTL Mesh Coil Head(5 PCS) $10.99
The Vaporesso Replacement GTX FeCrAl Restricted DTL Mesh Coil Head is designed for Vaporesso Target PM80 Mod Pod System Vape Kit / Vaporesso Target PM80 Empty Pod Catridge as a replacement part. It features 0.6ohm coil resistance and power range from 20W to 30W (Best: 28W). 5 PCS / Pack.
Original Vaporesso Target PM80 Mod Pod Vape Kit / Catridge GTX FeCrAl Dual-wire MTL Regular Coil Head(5 PCS) $10.99
The Vaporesso Replacement GTX FeCrAl Dual-wire MTL Regular Coil Head is designed for Vaporesso Target PM80 Mod Pod System Vape Kit / Vaporesso Target PM80 Empty Pod Catridge as a replacement part. It features 1.2ohm coil resistance and power range from 8W to 12W (Best: 11W). 5 PCS / Pack.
Replacement Drip Tip for Kayfun KF Lite 2019 RTA Clone $2.99
The replacement drip tip is made from Stainless Steel and is suitable for SXK Kayfun KF Lite 2019 RTA Clone.
Slam Replacement Cap Clone + Beauty Ring + 510 Drip Tip for Narda RDA Clone $7.99
The Slam Replacement Cap Clone, Beauty Ring and 510 Drip Tip are made of PMMA and is suitable for Narda RDA Clone.
Старый 20.04.2020, 04:40 Автор темы   608
3FVAPE
Original Aspire Glint 75W VW Box Vape Mod $34.99
The Aspire Glint VW Box Vape Mod is powered by single 18650 battery (Not included), Glintmo 75W Max output and can be quickly charged via Type-C port. Equipped with the advance Aspire ASP Chip, there are six multiple protections for your safety vaping. Glint Mod is constructed from Aluminum, Zinc Alloy, and Plastic with a stealthy and refined look, the unique slide open / close battery door is also very convenient to use. Moreover, it comes with a 0.91 inches OLED Screen that provide you this device's data in detail.
Original Coil Father PUMP V2 Liquid Dispenser for Squonk Mod / BF RDA / RDTA Vape Atomizer $7.99
The Original Coil Father Liquid Dispenser is a versatile liquid dispenser that can be used to fill squonker mods or as a dripping / filling bottle for bottom feeder RDA / RDTA, Squonk Mod. It comes with stainless steel caps, soft-touch finishing with food grade silicon bottle inside. The E-juice capacity is 30ml.
Original XTAR PB2S Portable Power Bank Dual-role Fast Charger for 3.6V /3.7V Li-ion/IMR/INR/ICR/18650/18700/20700/21700 $24.99
The XTAR PB2S Portable Power Bank Charger is not an intelligent Li-ion battery charger, but also a portable power bank, charges your mobile devices anywhere and anytime in outdoors. Support the most popular QC3.0 + PD3.0 dual-protocol fast charging, compatible with most phones' fast-charging adapters on the market, easy for match and use. Apply to 3.6V / 3.7V Li-ion / IMR / INR / ICR: Unprotected 18650 / 18700 / 20700 / 21700 and protected 18650 batteries. Shows real-time charging / discharging current and voltage, and battery capacity percentage, and supports a one-handed button to check each battery' s charging voltage and current. Type-C and USB-A ports can both be used for output and charge two external devices at the same time, more convenient for outdoor usage. You can DIY the capacity of the power bank up to 10000mAh+. If there are enough batteries, PB2S is your outdoor charging station. The negative pole of PB2S applies high-quality metal material. Compared with the previous generation, it has a stronger conductivity and smaller impedance. PB2S comes with a magnetic cover, which can prevent dust and other things from falling in the slots, and prevent the batteries from dropping out of the slots. There are multiple protections that ensure your safety.
Старый 21.04.2020, 04:47 Автор темы   609
3FVAPE
Vapeasy Vauban V1.5 BF RDA Clone with 7 Air Duct Insert $14.99
The Vapeasy Vauban V1.5 RDA Rebuildable Dripping Vape Atomizer Clone is constructed from 316 stainless steel and PEI / Ultem air duct inserts. The RDA comes with bottom feeder / BF Pin for squonk mods. The tiny RDA is in 22mm diameter and with middle airflow adjustable. The Vauban RDA Clone is with single coil design and easy to mount coil. The air ducts allow optimal cooling of the coil and are interchangeable. Choosing the appropriate air duct, matched to the coil mount and heating power to get precise and unaltered flavors. Fine adjustment of the air flow is further possible by rotating the top cap. The Vauban atomizer Clone offers interchangeable PEI air duct inserts, supports efficient in Mouth to Lung (MTL) as in DTL draw, you have the choice between savoring your e-liquid in the mouth or producing a consistent cloud of vape. This V1.5 is based on customer feedback, Vapeasy upgraded the new version as Vapeasy Vauban V1.5.
Original Vaptio AirGo 700mAh PCC Kit + 80mAh Pod System Vape Starter Kit $43.99
The Vaptio AirGo PCC Kit is a super portable device with convenient operations. The charging box has 700mAh capacity, which can charge the mod (80mAh) for 7 times, the AirGo mod can be fully charged within only 5 minutes, then it can be vaped for 40~50 puffs (Depends on personal vaping habits), do not worries about running out of battery for a whole day. In addition, the charging box uses a unique flip-type design, which makes it delicate and user-friendly, cause it can keep the pods clean and fresh, and perfectly prevents the pods from dust and dirt. The AirGo pod kit also features automatic system so you don't need to press any button while vaping.
Original ESUN S 6W 350mAh Pod System Vape Starter Kit $26.99
The ESUN S Pod System Vape Starter Kit is a slim and delicate vape device that is stable and temperature resistant, safe and easy to deliver the e-liquid, and bring you softer puffs and leakage-free experience. There is a warning light on the ESUN S device front, the two sides of the device are made of frosted material, and the middle decorative strip is baked paint to keep a good feel in your hands. ESUN S is powered by a built-in 350mAh high-rate polymer battery. Half an hour fully charging for long as 48 hours vaping time. There is a card slot on the side of the top, which is firmly connected to the cartridge and is not easy to fall off. ESUN S Cartridge has a capacity of 1.6ml. It adopts oil core separation technology to separate the smoke oil from the air to achieve the effect of no oil leakage. ESUN S Cartridge integrated honeycomb ceramic coil provides a constant output power of 6W. The honeycomb hole design on the ceramic coil can heat each drop of e-liquid adequately, so the vapor is much softer. One Pod is approximately equal to 3 PACKS of REAL Cigarettes. The Kit Package comes with 3 Flavors Pods (Classic Tobacco Pod 50mg, Ice Peppermint Pod 50mg, Chuan Bei Pi Pa Gao Pod 0mg). The bottom of each pod has a corresponding color.
Original Uwell Zumwalt Pod System Vape Kit Replacement Pod Cartridge(2 PCS) $6.99
The Uwell Zumwalt Replacement Pod Cartridge is designed for Uwell Zumwalt Pod System Vape Kit as a replacement part, which features 1.6ml E-juice capacity. 2 PCS / Pack.
Original Vaporesso Target PM30 Pod System Vape Kit Replacement Empty Pod Cartridge(2 PCS) $5.99
The Vaporesso Target PM30 Replacement Pod Cartridge is designed for Vaporesso Target PM30 Pod System Vape Kit as a replacement part, which features 3.5ml E-juice capacity. 2 PCS / Pack.
Original Kamry Kecig1.0 Vape Kit Replacement 510 Drip Tip $2.99
The Kamry Kecig1.0 Replacement 510 Drip Tip is compatible with Kamry Kecig1.0 Vape Kit as a replacement part, which is made of Stainless Steel. It is also suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Vaptio AirGo PCC Pod System Vape Kit Replacement Pod Cartridge(3 PCS) $8.90
The Vaptio AirGo Replacement Pod Cartridge is designed for Vaptio AirGo 700mAh PCC Pod System Vape Kit as a replacement part, which features 1.5ml E-juice capacity. 3 PCS / Pack.
Original XTAR VC8 8 Bay Eight-Slot 3A Smart Li-ion Battery Charger for 18650 / 26650 / 20700 / 21700 Batteries etc. $29.99
The XTAR VC8 8 Bay Smart Li-ion Battery Charger, can charge max 8 PCS 21700 Batteries simultaneously at the same time. It is compatible with 18650, 20700, 21700, 26650 batteries and more. This charger supports QC3.0 fast charging and has a max 3A current for each slot. This can be changed manually to either 3A, 2A, 1A, 0.5A allowing you to adjust the currents to the demands of batteries. The XTAR VC8 utilizes a USB-C input current for faster charging of all the batteries. Another great bonus to this battery charger is that integrated LCD screen that provides real-time information including voltage, capacity, internal resistance, and battery type. The VC8 has two user modes: Grade and Storage. Storage mode makes it easier to charge or discharge batteries to its rated voltage to maximize the lifespan of your batteries especially when they're in transport. Grade mode tests the true capacity of your batteries so you'll know what they're truly capable of.
SXK Replacement Tank for SXK BB Vapesnail Tank RBA original price $7.90, now only $5.99
The SXK Replacement Tank is made of PCTG material. It is suitable for SXK Vapesnail Series Tank RBA as a replacement part. Please Note: This tank is without LOGO.
Старый 22.04.2020, 05:59 Автор темы   610
3FVAPE
Original Lost Vape Centaurus DNA 250C 200W TC VW Box Vape Mod original price $189.00, now only $139.99
The Lost Vape Centaurus DNA 250C TC VW Box Vape Mod features the high-end Evolv DNA 250C chipset with high accuracy and super-fast response time. It is powered by dual 18650 batteries (Not included), delivers a maximum power of 200W and supports VW / TC (Ni80, Ni90, Ti, SS316, TCR), Custom Curve modes. The device has a handy 0.91 inch TFT display screen to easily read out the essential parameters. Centaurus Mod can be charged via the USB port and includes an adapter that is compatible with the power bank.
Original IJOY Neptune X 14W 650mAh Mod Pod System Starter Kit $28.99
The IJOY Neptune X Pod System Vape Kit is optimized and updated on IJOY Neptune Kit, has a stylish and simple appearance and adopts a newly designed square size. IJOY Neptune X is made of Zinc Alloy, supplemented by new composite material side inserts panel with rounded edges that makes Neptune X more elegant and light-weight. IJOY Neptune X is powered by a built-in 650mAh battery for fast charging through the Type-C port at the bottom. The output power of IJOY Neptune X Pod Kit is about 14W, build-in 3 Switchable Voltage (3.5V / 3.6V / 3.7V) Levels, meet your different electronic cigarette needs. You can know which available options are currently active through the three-color indicator above the fire button. It comes with two 1.8ml E-juice capacity pods. Simply remove the top cover and fill it directly. No more worry about leakage. Also, it has a 1.0ohm coil and 14W max output to strive to give you the best flavor. The device has holes in the upper right corner to support lanyard. The Neptune X designed with a chain necklace follows you to go everywhere.
Original Advken Oasis 360mAh Pod System Vape Starter Kit original price $19.95, now only $14.99
The Advken Oasis Pod System Vape Starter Kit, a compact and portable pod system kit, comes with 2ml E-juice capacity with side filling design. Due to its double anti-leaking structure, it will give you convenient and comfortable vaping experience. Oasis Pod Kit is powered by 360mAh built-in battery with USB Type-C port, it can be quickly charged around 40 minutes. And it supports 1.2ohm A1 cotton coil, which will bring you pure flavor. Moreover, it utilizes bottom airflow control to meet your individual demands better.
Original Hotcig Sniper Pod System Vape Kit / Cartridge Replacement Mesh Coil Head(5 PCS) $11.99
The Hotcig Replacement Mesh Coil Head is designed for Hotcig Sniper Pod System Vape Kit / Pod Cartridge as a replacement part, which features 0.4ohm coil resistance and recommended power output is 26W for rich clouds and pure flavor. 5 PCS / Pack.
The Hotcig Replacement Mesh Coil Head is designed for Hotcig Sniper Pod System Vape Kit / Pod Cartridge as a replacement part, which features 0.17ohm coil resistance and recommended power output is 50W for rich clouds and pure flavor. 5 PCS / Pack.
Original Hotcig AFA Replacement RBA Rebuildable Coil Head for SMOK RPM40 / RPM80 / Nord 2 /Pro Fetch/Marvel 40 Pod Kit $7.99
The Hotcig AFA Rebuildable RBA Coil is suitable for SMOK RPM40 / RPM80 / Nord 2 / Pro Fetch / Marvel 40 Pod System Vape Kit as a replacement part. It features 0.8ohm built-in coil resistance. The Hotcig AFA RBA Coil can bring a wide option for coil selection and dense cloud.
Original Hotcig Sniper Pod System Vape Kit Replacement Empty Pod Cartridge(2 PCS) $8.99
The Hotcig Sniper Replacement Empty Pod Cartridge is designed for Hotcig Sniper Pod System Vape Kit as a replacement part, which features 3.2ml E-juice capacity, and is compatible with 0.17ohm mesh coil / 0.4ohm mesh coil (Coils are sold separately). 2 PCS / Pack.
SXK Hussar GR Tip Straight Clone + MTL DT R + DT Long 510 Drip Tip Set for RDA / RTA / RDTA / Sub-Ohm Tank(3 PCS) original price $15.90, now only $10.99
The SXK Hussar 13mm GR Tip Straight Clone + 18.3mm MTL DT R + 32mm DT Long 510 Drip Tip Set are made of POM and 316SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. 3 PCS / Pack.
Original IJOY Neptune X Pod System Vape Kit Replacement Pod Cartridge(3 PCS) $8.99
The IJOY Neptune X Replacement Pod Cartridge is designed for IJOY Neptune X Pod System Vape Kit as a replacement part, which features 1.8ml E-juice capacity. 3 PCS / Pack.
Original Advken Oasis Pod System Vape Kit Replacement Pod Cartridge with 1.2ohm A1 Coil Head(3 PCS) $8.99
The Advken Oasis Replacement Pod Cartridge is designed for Advken Oasis Pod System Vape Kit as a replacement part, which features 2ml E-juice capacity, it comes with a 1.2ohm A1 wire and organic cotton that can make the taste more purely. 3 PCS / Pack.
SXK Replacement Tank + Base Deck + Chimney + Aspire Atlantis Coil Kit for SXK BB Bantam Revision Mod Kit original price $15.90, now only $10.99
The SXK Replacement Kit consists of a 5ml Replacement PCTG Tank, a 316SS Base Deck, a 316SS Chimney, and a 1.8ohm Aspire Atlantis Coil Head. They are suitable for SXK Bantam Revision 30W VW Box Vape Mod Kit as replacement parts.
The SXK Hussar 13mm GR Tip Straight Clone + 18.3mm MTL DT R + 32mm DT Long 510 Drip Tip Set are made of PEI and 316SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. 3 PCS / Pack.
Vapeasy Armor Engine RDA Clone Replacement Airflow Inserts(2 PCS) $11.99
The Replacement Airflow Inserts are compatible with Vapeasy Armor Engine RDA Clone and the original Armor Engine RDA as replacement parts. Two inserts are included in the package: one is 1.2 x 1.2mm, and the other one is 1.8 x 2.2mm. 2 PCS / Pack.
SXK Replacement Tank for SXK BB Bantam Revision 30W Mod Kit original price $6.90, not only $4.99
The SXK Replacement Tank is suitable for SXK Bantam Revision 30W VW Box Vape Mod Kit as a replacement part. It features 5ml E-juice capaciy and is made of PCTG material.
Старый 23.04.2020, 05:55 Автор темы   611
3FVAPE
Alpha RTA Clone $24.99
The Alpha RTA Atomizer Clone is constructed from 316 Stainless Steel in 22mm diameter. The RTA features single coil build deck, it supports bottom airflow adjustable control and E-liquid adjustable control, comes with a 2.8ml E-juice capacity PEI tank.
Replacement Bell Cap Tank Tube for Bastard / Bastd RTA Clone $2.59
The Bell Cap Tank Tube is suitable for Bastard / Bastd RTA Clone as a replacement part. It is made of Acrylic material and features 3.5ml E-juice capacity.
SXK Replacement Mission Switch + Panel Mission Switch Kits for SXK BB / Billet DNA60 60W Mod Kit Clone original price $39.90, now only $33.99
The SXK Replacement Mission Switch + Panel Mission Switch Kits are suitable for SXK BB / BB DNA60 60W Mod Kit Clone. It is made of G10 material.
Hussar GR Tip Straight Clone + MTL DT R + DT Long 510 Drip Tip Set for RDA/RTA/RDTA/Sub-Ohm Tank(3 PCS) $7.99
The Hussar 13mm GR Tip Straight Clone + 18.3mm MTL DT R + 32mm DT Long 510 Drip Tip Set are made of PEI and SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original FreeMax Replacement Silicone Case for Fireluke Mesh / Twister Kit / All Tank Vape Atomizer with 24mm Dia. - Little 1PM $2.99
The FreeMax Replacement Silicone Case Decorative Ring is specially designed for the FreeMax Fireluke Mesh / Twister Kit and all atomizers with 24mm diameter. The Silicone Case is made of silicone gel material, it is durable and can protect your atomizers well.
Original FreeMax Replacement Silicone Case for Fireluke Mesh / Twister Kit / All Tank Vape Atomizer with 24mm Dia. - Black Tire $2.99
MAYDAY Vape Sale Information
Time: 00:00:00 April 29th 2020 - 23:59:59 May 2nd 2020 (UTC - 7/Denver Time)
Coupon code: Laborday2020
Старый 24.04.2020, 05:20 Автор темы   612
3FVAPE
The Lost Vape Centaurus DNA 250C TC VW Box Vape Mod features the high-end Evolv DNA 250C chipset with high accuracy and super-fast response time. The body materail of Centaurus DNA 250C is made from Stainless Steel. It is powered by dual 18650 batteries (Not included), delivers a maximum power of 200W and supports VW / TC (Nickel, Ni80, Ni90, Titanium, SS316, KA1), Custom Curve modes. The device has a handy 0.90 inch TFT color display screen to easily read out the essential parameters. Centaurus Mod can be charged via the USB port and includes an adapter that is compatible with the power bank.
FEV VS MTL RTA Clone $14.99
The FEV VS MTL RTA Rebuildable Tank Atomizer Clone is constructed from Stainless Steel in 17mm diameter tank designed for mouth-to-lung vaping. The RDA comes with dual post design for easy coil building. Comes with a 3.0ml Acrylic Tank Tube.
Taifun GT4 S GT 4 S IV S DL RTA Clone $17.99
The Taifun GT4 S DL RTA Rebuildable Tank Atomzier Clone is constructed from Stainless Steel (Body) and PSU (Tank Tube) in 23mm diameter. The RTA comes with a 3.5ml e-juice capacity tank. The air duct system bringing air flow via the poles in the chamber and adjustable AFC from the outside. And it can offer a slightly restricted direct lung hit. Multiple wire mounts allow for easy installation of the coil with versatility. Optimized for single coil builds, but can fit dual coils
YFTK ParavozZ k5k RDTA Clone $44.99
The YFTK ParavozZ k5k RDTA Clone is constructed from Titanium Alloy material in 22mm diameter. The RDTA comes with a PEI tank tube. The building deck supports single coil. Heat sinks in the top cap is good for better cooling.
YFTK ParavozZ k5k RDTA Clone $22.99
The YFTK ParavozZ k5k RDTA Clone is constructed from 316 Stainless Steel material in 22mm diameter. The RDTA comes with a PEI tank tube. The building deck supports single coil. Heat sinks in the top cap is good for better cooling.
9 Holes Airflow 510 Drip Tip for RDA / RTA / RDTA /Sub-Ohm Tank Vape Atomizer $2.99
The 9 Holes Airflow Replacement 510 Drip Tip is a drip tip in new style with airflow control system. There are 9 holes on the bottom of the stainless steel part, with the holes, the airflow can be adjusted. It's safe and easy to be rinsed with water. It is made of Stainless Steel and Delrin, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Coil Master B4 Battery Carrier Protective Box for Four 18650 Battery Cells $1.99
The Coil Master B4 battery carrier is a protective boxes for 18650 sized batteries. Each carrier features a snap lock ensuring your batteries remain secure while you're on the move. The B4 battery carrier is made of high quality polypropylene plastic, the battery carriers will prevent accidental discharge and damage to the batteries while inside. These carriers are a convenient and safe solution to carrying your batteries.
Replacement Anti Slip Silicone Band for Tube Vape Mod/RDA/RTA/RDTA Vape Atomizer(5 PCS) $1.99
The Anti Slip Band is made of Silicone material in 20mm inner diameter and 23mm outer diameter, it is suitable for most of E-Cigarette / Pod Vape Kit / Vape Mod Kit and designed for 20mm diameter glass tank, RBA or RTA, RDA and Tube Mod. The vape band is a necessary accessory for any and ALL vapers, especially glass tank users. Not only does it keep your device stylish and looking awesome, they also serve a purpose. The bands can help protect glass tanks from breaking in case of a fall. They are also wonderful for when those darn threads just don't want to come loose. Pop a band on there and loosen it with ease. 5 PCS / Pack.
Original Aspire Degerm 400mAh UV Disinfection Ray Sterilizer for Sterilizing Vape / Drip Tip / Phone, etc. $13.99
The Aspire Degerm sterilizer is powered by 400mAh built-in battery, it adopts very high-level UV disinfection rays, which is used to sterilize 360-degree orientation with UV light. Any bacteria which is present on the drip tip will be wiped out in 30 seconds. Aspire Degerm adopts ultraviolet light to remove bacteria from Face Mask / Vape / Phone, etc. The Degerm sterilizer is super-portable and small. The protection cap is provided to avoid dust integration when being carried. Operate the Degerm with only 1 button, super easy to use. Just put the drip tip into the Degerm, click button for 3 times after turning on the device, it will start working. The LED lights will indicate the working status. After finishing sterilizing, the device will stop automatically.
Старый 25.04.2020, 06:02 Автор темы   613
3FVAPE
Original SMOKTech SMOK RPM Lite 40W 1250mAh VW Box Mod Pod System Vape Starter Kit $24.99
The SMOKTech SMOK RPM Lite Kit is equivalent to the reduced version of RPM40, the appearance is more simplified and concise, single color side panel, no multiple color collocation. It's lighter and smaller, you can feel its compactness by holding it in your hand. The RPM Lite Kit is powered by a built-in 1250mAh battery, which can ensure enough running time and help you avoid frequent charging. It features micro USB charging port by 5V / 1.2A fast charging. RPM Lite's power range is 1W to 40W, which guarantees cloudy vapor, and you can press UP / DOWN Button to adjust the power you preferred. Moreover, SMOK RPM Lite is equipped with the same IQ-R chipset to accommodate the popular RPM Coil Series. The RPM Lite owns a 0.96 inch screen, presenting detailed vaping data, such as the wattage, resistance, voltage, screen color, puff number, and battery level. The SMOK RPM Lite Pod is a refillable 3.2ml pod, enough for vaping needs, easy to side filling of your favorite E-liquid, easily enjoy a carefree vaping. The kit includes two RPM coils: RPM Mesh 0.4ohm Coil and RPM DC 0.8ohm MTL Coil, which are made for pure taste. The SMOK RPM Lite pod mod kit maintains the traditional intuitive button layout and a slew of safeties and protections, making this an ideal vape for beginners or advanced vaporers.
Original SMPO OS 650mAh Pod System Vape Starter Kit $24.99
The SMPO OS Pod System Starter Kit is the another SMPO vape pod system, unlike SMPO Kit, SMPO OS is the open pod system with the 1.8ml empty pod to get you perfectly refill your own favorite E-juice, which is powered by 650mAh built-in battery with 40 minutes USB Quick Charging Cable. SMPO OS features ultra compact design to fit your palm and allows you to vape on the go without time and space limitation.
SXK Replacement Kanger Subtank OCC Coil Adapter for SXK BB / Billet Box Mod Kit Clone original price $5.50, now only$3.99
The SXK Replacement Kanger Subtank OCC Coil Adapter is suitable for SXK BB / Billet 70W / DNS 60 60W Style Box Mod Kit as a replacement part, it is made of 316 Stainless Steel in 23mm Height, 12mm Diameter.
Original SMPO OS Pod System Vape Kit Replacement Pod Cartridge(2 PCS) $8.99
The SMPO OS Replacement Pod Cartridge is designed for SMPO OS Pod System Vape Kit as a replacement part. A pair of strong neodymium magnets secure each cartridge to the SMPO OS device. It features 1.8ml E-juice capacity. 2 PCS / Pack.
Original SMOKTech SMOK RPM Lite Pod System Vape Kit Replacement Empty RPM Pod Cartridge(3 PCS) $5.99
The SMOK RPM Lite Replacement Empty RPM Pod Cartridge is designed for SMOK RPM Lite Mod Pod System Vape Kit as a replacement part. It features 3.2ml E-juice capacity. 3 PCS / Pack.
SXK Replacement Aspire Nautilus Coil Adapter for SXK BB / Billet Box Mod Kit Clone original price $5.50, now only $3.99
The SXK Replacement Aspire Nautilus Coil Adapter is suitable for SXK BB / Billet 70W / DNS 60 60W Box Mod Kit Clone as a replacement part, it is made of 316 Stainless Steel in 29mm Height, 10mm Diameter.
Original VAPJOY DIY Rebuild Kit for GeekVape Aegis Boost Pod Vape Kit $3.99
The Original VAPJOY DIY Rebuild Kit is suitable for GeekVape Aegis Boost Mod Pod Vape Kit. The Vapjoy DIY Rebuild Kit consists of Opening Tool Kit, Cottons and Ni80 Mesh Coils (0.4ohm). It is designed to replace coil economical, pod vapers would easy rebuild their Pods quickly. Enjoy fun to Rebuild. It can meet most of DIY lovers' demand.
Старый 27.04.2020, 05:29 Автор темы   614
3FVAPE
Original Vape Master Fury 220W TC VW Box Vape Mod original price $49.99, now only $14.99
The Vape Master Fury TC VW Box Vape Mod is a temperature control 220W Box Mod, which is powered by 2 x 18650 Batteries (Not included) with power range from 5W to 220W. The Box Mod can temperature control range from 200'F to 650'F / 90'C to 343'C. The Box Mod is equipped with a Display Screen that can show you related data about this device. There are seven protections that ensure your safety during vaping.
Original Artery Nugget GT 200W VW Box Mod Pod System Vape Starter Kit original price $49.99, now only $39.99
The Artery Nugget GT Kit is powered by dual 18650 battery (Not included), which is constructed from Zinc Alloy and PCTG material. Equipped with the innovative Aero chip, Nugget GT can release 200W constant wattage output, it has multiple protections and intelligently avoid dry burn accidentally wattage setting system for the nice vape experience. The Nugget GT cartridge utilizes the brand new XP coil series and bottom airflow system. It comes with a large 8.0ml E-juice capacity pod cartridge. Moreover, you can also install the 510 adapter (510 Adapter is sold separately) for Nugget GT Mod to match the 510 thread atomizers. Nugget GT Kit is equipped with a 0.96 inch color screen that show you data about this device in detail. Anyway, Artery Nugget GT Dual 18650 Pod Mod 200W Kit makes its mark as one of the sleekest designs Artery has released and is a perfect device for you on the go.
Original Artery PAL SE V2 Pod System Vape Kit Replacement Pod Cartridge with 1.2ohm KA1 Coil(3 PCS) $9.99
The Artery PAL SE V2 Replacement Pod Cartridge is designed for Artery PAL SE V2 Pod System Vape Kit as a replacement part. It features 2.0ml E-juice capacity and comes with a 1.2ohm KA1 Coil. 3 PCS / Pack.
AU Plug Charger Cable for Trustfire TR 001 / TR 003 Battery Charger & Nitecore I2 / I4 / D2 / D4 Charger $3.99
This is a charger cable, which can be used on following chargers: TrustFire TR-001 Lithium ion Battery 2 Channel Charger / TrustFire TR-003 Lithium ion Battery 4 Channel Charger / Nitecore Intellicharge i2 / Nitecore Intellicharge i4 / Nitecore Digicharger D2 / Nitecore Digicharger D4 Note: This cable can only be used in countries where AU Plug are accepted.
Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $2.59
The Type Replacement 510 Drip Tip is made of Plastic material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Replacement 810 Wide Bore Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / Reload RDA $2.99
The Replacement 810 Wide Bore Drip Tip is made of PEI, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Replacement 810 Wide Bore Drip Tip for SMOK TFV8 / TFV12 Tank /Kennedy/Battle/Reload RDA $2.59
The Replacement 810 Wide Bore Drip Tip is made of Delrin and Stainless Steel, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
The Type Replacement 510 Drip Tip is made of SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
SXK Replacement Silicone O-Ring Kit for SXK BB VapeSnail Tank RBA Clone(3 PCS) $1.99
The SXK Replacement Silicone O-ring Kit is suitable for SXK BB VapeSnail Tank RBA Clone as replacement parts. The Size of this Kit: 22 x 14 x 3mm, 9mm Diameter, and 10mm Diameter.
3FVape.com is scheduled to be on holiday of International MAY DAY on May 1st, 2020 HKT (GMT+. May 1st, May 2nd, May 3rd, there will be 3 days off in total. All service will resume on Monday, May 4th, 2020 (GMT+.
Старый 28.04.2020, 05:40 Автор темы   615
3FVAPE
Stratum V5.1 VW Box Vape Mod Clone $229.99
The Stratum V5.1 VW Variable Wattage Box Vape Mod Clone is constructed from High Quality Stabilized Wood from Ukraine, which is powered by 1 x 18650 battery (Battery is not included) and is equipped with Evolv DNA 60 Chip set. Color as image shows (47 Color). And this product may vary due to Stabilized Wood properties.
SXK 5A's Basic V2 RDA Clone with BF Pin & 4.0 x 2.0mm Airflow Insert original price $19.90, now only $14.99
The SXK 5A's Basic V2 RDA Rebuildable Dripping Vape Atomizer Clone is constructed from 316 Stainless Steel in 22mm Diameter. The RDA features top airflow from both sides and supports 4 Airflow Chambers: 2 x 1mm Airflow Restricted Direct Lung (not included) / 4 x 1mm Semi Restricted Direct Lung (not included) / 4 x 2mm Regular Basic Air Flow (included) 2 x 3mm Cloud Chasers Dream (not included)
Tall Hat Flat Replacement 510 Drip Tip Clone for RDA / RTA /RDTA/Sub-Ohm Tank Vape Atomizer $0.99
The Tall Hat Flat Replacement 510 Drip Tip Clone is made of Plastic material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Acrylic Shorty Replacement Wide Bore 510 Drip Tip for RDA / RTA / RDTA/Sub-Ohm Tank Vape Atomizer $1.89
The Acrylic Shorty Replacement Wide Bore 510 Drip Tip is made of Acrylic material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original FreeMax Replacement Silicone O-ring Set for FreeMax Mesh Pro Tank Vape Atomizer $0.99
The FreeMax Replacement Silicone O-ring is designed for FreeMax Mesh Pro Tank Vape Atomizer as a replacement part.
18650 Battery PVC Wrappers Skin Sticker for LG MH1 /LG HB6/Samsung ICR18650-26F/Samsung INR18650, etc.(5 PCS) $0.99
The PVC Wrappers Skin Sticker is designed for 18650 Batteries like LG MH1 / LG HB6 / Samsung ICR18650-26F / Samsung INR18650 Batteries, etc. as a replacement part. 5 PCS / Pack.
SXK Mission Tips Integrated Whistle Drip Tip Mouthpiece + Base Clone for SXK BB Box Mod original price $14.90, now only $11.99
SXK Mission Tips Integrated Whistle Drip Tip Clone is suitable for SXK BB Box Vape Mod Kit Clone as a replacement. The Drip Tip Set consists of 3 x Drip Tip Mouthpiece and 1 x Mouth Base. They are made of POM material. The Diameter of Plugs are: 1.5mm / 2.5mm / 3.5mm / 4.5mm.
Original SXK Stunt RBA Rebuildable Atomizer for SXK Bantam Revision Box Vape Mod Kit original price $13.90, now only $11.99
The SXK Stunt RBA Rebuildable Atomizer is designed for SXK BB Bantam Revision Box Vape Mod Kit Clone as a replacement part. It is made of 316 Stainless Steel in 16.5mm Height and 10mm Diameter. Please Note: The RBA is suitable for SXK BB Bantam Revision 30W VW Mini Box Mod Kit Clone and Replacement Tank & Tank + Base Deck + Chimney + Coil Kit as follows ONLY.
SXK Replacement Basic 2.0 Airflow Inserts Clone for SXK 5A's Basic V2 RDA Clone(3 PCS) original price $15.90, now only $11.99
The SXK Replacement Basic 2.0 Airflow Inserts Clone is designed for 5A's Basic V2 RDA Clone as a replacement part. It is made of 316 Stainless Steel in 12mm Height and 19.5mm Diameter.
SXK Replacement Top Cap with Drip Tip Clone for 5A's Basic V2 RDA Clone original price $6.90, now only $5.99
The SXK Replacement Top Cap with Drip Tip Clone is designed for SXK 5A's Basic V2 Style RDA as a replacement part. The Top Cap is 18 x 22mm and the drip tip is 9 x 11mm. They are made of POM material.
Старый 29.04.2020, 05:48 Автор темы   616
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
YFTK Flash e-Vapor V4.5S+ RTA Clone $22.99
The YFTK Flash e-Vapor V4.5S+ RTA Rebuildable Tank Vape Atomizer Clone is constructed from 316 Stainless Steel in 23mm Diameter. The RTA comes with a 4.5ml E-juice capacity glass tank tube, 1 x air screw mounted seald, 1 x 1.2mm airflow insert, 1 x 1.4mm airflow insert, and 2 x 2.1mm airflow inserts. The RTA features dual post build deck and adjustable airflow for MTL vaping. Compared with the YFTK Flash e-Vapor V4.5S and YFTK Flash e-Vapor V4.5, V4.5S+ comes with a stainless steel wick to make a good liquid flow for you.
SXK Alpha RTA Clone original price $27.90, now only $22.99
The SXK Alpha RTA Atomizer Clone is constructed from 316 Stainless Steel in 22mm diameter. The RTA features single coil build deck, it supports bottom airflow adjustable control and E-liquid adjustable control, comes with a 2.8ml E-juice capacity PEI tank.
SXK Kayfun 5² Square SE RTA Clone(Special Edition) original price $32.90, now only $28.99
The SXK Kayfun 5² Square SE RTA Rebuildable Tank Vape Atomizer Clone is constructed from 316 Stainless Steel (body) and PSU (tank tube) in 25mm Diameter. The RTA comes with a 7.0ml E-juice capacity tank tube. It features single coil build deck, which support DL vaping experience, liquid flow control and top filling system.
Original OneVape AirMOD 60 60W 1500mAh VW Mod Pod System Vape Starter Kit(Standard Version) $29.99
The OneVape AirMOD 60 VW Box Mod Pod System VaPE Kit is so small that it is portable to carry. The AirMOD 60 Mod is powered by built-in 1500mAh huge capacity battery with unique Quick Charge (Fully charge within 1 hour) via USB Type C, and support strong power up to 60W. Moreover, it features 6ml pod capacity and compatible with all Air series coils, including Dual Mesh Coil 0.2ohm (Included), Quadruple Coil 0.5ohm (Included), Quadruple Coil 0.8ohm (Not included). Air sensor system ensures you can vape directly without button.
Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer(1 PC) $2.59
The Replacement 510 Drip Tip is made of Resin material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
PVC Wrappers Skin Sticker for 20700 / 21700 Battery(5 PCS) $0.99
The PVC Wrappers Skin Sticker is designed for 20700 / 21700 Batteries. 5 PCS / Pack.
Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / Reload RDA(1 PC) $1.99
The Replacement 810 Drip Tip is made of Resin, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer(1 PC) $1.99
Original OneVape AirMOD 60 Pod System Vape Kit / Cartridge Replacement DTL Dual Mesh DM Coil Head(4 PCS) $10.99
The OneVape Replacement DTL Dual Mesh DM Coil Head is designed for OneVape AirMOD 60 Pod System Vape Kit / Pod Cartridge as a replacement part. It features 0.2ohm coil resistance that power range from 5W to 60W. 4 PCS / Pack.
Original OneVape AirMOD 60 Pod System Vape Kit / Pod Cartridge Replacement MTL Quadruple DQ Coil Head(4 PCS) $10.99
The OneVape Replacement MTL Quadruple DQ Coil Head is designed for OneVape AirMOD 60 Pod System Vape Kit / Pod Cartridge as a replacement part. It features 0.8ohm coil resistance that power range from 5W to 20W. 4 PCS / Pack.
Original OneVape AirMOD 60 Pod System Vape Kit Replacement Empty Pod Cartridge(1 PC) $3.99
The OneVape Replacement Empty Pod Cartridge is designed for OneVape AirMOD 60 Pod System Vape Kit as a replacement part, which features 6ml E-juice capacity, it is compatible with 0.2ohm DTL Dual Mesh DM Coil Head / 0.5ohm Light DTL Quadruple DQ Coil / 0.8ohm MTL Quadruple DQ Coil (Coils are sold separately).
YFTK 316 Stainless Steel Wicks with O-rings for Flash e-Vapor V4.5S+ RTA(2 PCS) $2.59
The Stainless Steel WicksC with O-rings is suitable for YFTK Flash e-Vapor V4.5S+ RTA as a replacement part. It is made of 316 Stainless Steel and comes with two silicone O-rings. It can make a Good E-liquid flow for your RTA. 2 PCS / Pack.
YFTK 316 Stainless Steel Wicks-DLC with O-rings for Flash e-Vapor V4.5S+ RTA(2 PCS) $2.59
The Stainless Steel Wicks-DLC with O-rings is suitable for YFTK Flash e-Vapor V4.5S+ RTA as a replacement part. It is made of 316 Stainless Steel and comes with two silicone O-rings. It can make a Good E-liquid flow for your RTA. 2 PCS / Pack.
Mission Tips Integrated Whistle Drip Tip Mouthpiece + Base Clone for SXK BB Box Mod $8.99
The Mission Tips Integrated Whistle Drip Tip Clone is suitable for SXK BB Box Vape Mod Kit Clone as a replacement. The Drip Tip Set consists of 3 x Drip Tip Mouthpiece and 1 x Mouth Base and 4 x Plugs. They are made of POM material. The Diameter of Plugs are: 1.5mm / 2.5mm / 3.5mm / 4.5mm.
Offer: Site-wide 5% OFF
3FVAPE вне форума   Вверх
Старый 30.04.2020, 05:34 Автор темы   617
3FVAPE
Original Itsuwa Liberty V9 NS Tank Vape Atomizer Vaporizer Catridge with 1.8ohm Ceramic Coil for THC Oil $3.99
The Itsuwa Liberty V9 NS Tank Vape Atomizer is constructed from SS and Glass. It is compatible with EGO type battery threads easily and Vaporizer Kit, which has a glass tank of 0.5ml and a ceramic heating element perfect for THC oils.
YFTK M-Atty RDA Clone with BF Pin(Limited Edition) $37.99
The YFTK M-Atty RDA Clone is constructed from 316 stainless steel. This RDA supports single and dual coils building. And the deck of this RDA is designed around common vertical & horizontal builds. This RDA comes with bottom feeder / BF / Squonk Pin. This RDA is Limited Edition.
Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.89
The Replacement 510 Drip Tip is made of PC material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
ULPS 2-in-1 Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.89
The ULPS 2-in-1 Replacement 510 Drip Tip is made of Resin material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This 510 Drip Tip can be not only disassembled into two Drip Tips to use on your atomizers, but also assembled into one Drip Tip to be used. It is 2 in 1 510 Drip Tip.
ULPS 2-in-1 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / Reload RDA $1.89
The ULPS 2-in-1 Replacement 810 Drip Tip is made of Resin, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This 810 Drip Tip can be not only disassembled into two Drip Tips to use on your atomizers, but also assembled into one Drip Tip to be used. It is 2 in 1 810 Drip Tip.
Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / Reload RDA $1.69
The Replacement 810 Drip Tip is made of PC, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Replacement Anti-Splash 810 Drip Tip for SMOK TFV8/TFV12/Kennedy/Battle/Reload RDA(1 PC) $2.99
The Replacement Anti-Splash 810 Drip Tip is made of Resin + SS, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Joyetech Cubis Tank Vape Atomizer Replacement Colorful Tank Tube $2.99
The Joyetech Cubis Replacement Colorful Tank Tube is designed for Joyetech Cubis Tank Vape Atomizer as a replacement part. The Colorful Tank Tube is made from transparent glass window and integrated stainless steel structure. The Cubis Tubes adopt the new leak resistant cup design. It features 3.5ml E-juice capacity and in 22mm Diameter.
Старый 30.04.2020, 05:49 Автор темы   618
3FVAPE
Time: 00:00:00 April 29th 2020 - 23:59:59 May 3rd 2020 (UTC - 6/Denver Time)
Старый 04.05.2020, 05:11 Автор темы   619
3FVAPE
Original Hugo Vapor Z ONE 11W 520mAh AIO Pod System Vape Starter Kit $9.99
The Hugo Vapor Z ONE Pod System Vape Starter Kit is an all in one pod system kit. Powered by a built-in 520mAh battery, Z ONE is constructed from Aluminum alloy, PP, PC, ABS material. It is also compatible with Uwell Caliburn device and pod, it features colorful LED indicate lights to display the battery level and convenient visible E-juice capacity function, comes with both air switch and manual fire button system. The Z ONE cartridge can hold 1.5ml E-juice with the top filling system, you will not worry about the leakage.
SXK Billet Box 70W VW All-in-One Box Mod Kit Clone with USB Port original price $75.00, now only $64.99
The SXK BB Box Mod Kit Clone is constructed from aluminum with an all-in-one design. This mod comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor. This BB Box comes with USB port for charging only. This mod with 2019 LOGO.
Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / Reload RDA(1 PC) $2.99
The Replacement 810 Drip Tip is made of Resin + SS, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Wellon Pandora 1000mAh PCC Portable Charger for Juul Pod Vape Kit $14.99
The Wellon Pandora is a world's first smart JUUL portable charging case with fingerprint locker. Your finger is the key to open the case. Its powerful memory storage capacity allows you to collect 40 sets of fingerprint for multi-user function. Any unauthorized users cannot open your Pandora case. Meanwhile, it holds a Juul battery and 4 Juul pods with 1000mAh battery in a pocket size, charge your Juul fully in 45 minutes. Additionally, it will keep your Juul away from dust, vape healthily. However, Zinc Alloy & ABS material makes its form feeling high-end. Just get it to your Wellon Pandora JULL PCC Kit. Wellon Pandora will be your best choice for Juul.
Original GeekVape Zeus X Mesh RTA Replacement Micromesh KA1 Mesh Sheet $2.99
The GeekVape Zeus X Replacement Micromesh KA1 Mesh Sheet is designed for GeekVape Zeus X 2 RTA as a replacement part. The package consists of 2 x 0.2ohm KA1 Mesh Sheet and 2 x Cotton. The Size of Mesh Sheet is 18 x 6.2 x 0.1mm.
Original GeekVape Zeus X Mesh RTA Replacement Micromesh Ni80 Mesh Sheet $2.99
The GeekVape Zeus X Replacement Micromesh Ni80 Mesh Sheet is designed for GeekVape Zeus X 2 RTA as a replacement part. The package consists of 2 x 0.17ohm Ni80 Mesh Sheet and 2 x Cotton. The Size of Mesh Sheet is 18 x 6.2 x 0.1mm.
Original GeekVape Zeus X Mesh RTA Replacement Single-Mesh Coil Build Deck $14.99
The GeekVape Zeus X Mesh Replacement Build Deck is constructed from Stainless Steel material, which is desinged for single-mesh coil use. And it is compatible with GeekVape Zeus X Mesh RTA. This mesh build deck is compatible with Zeus X RTA, which allows you enjoy superior flavor with Zeus X RTA as well.
Старый 05.05.2020, 05:29 Автор темы   620
3FVAPE
Original Arctic Dolphin Elux Petrel 30W VW 1100mAh Pod System Vape Starter Kit $21.99
The Original Arctic Dolphin Elux Petrel 30W Pod System vape starter kit is a compact and lightweight. Arctic Dolphin Elux Petrel pod kit maintains built-in 1100mAh battery with max 30W output. Arctic Dolphin Elux Petrel adopts Type C cable and lanyard 2 in 1 design. Arctic Dolphin Elux Petrel cartridge comes with 2ml capacity, 0.5ohm mesh coil and 1.2ohm regular coil.
Replacement Bubble Glass Tank Tube for Vaporesso Skrr Tank Vape Atomizer $1.99
The Replacement Bubble Glass Tank Tube is with 8ml capacity and it is suitable for Vaporesso Skrr Tank Vape Atomizer.
Replacement Glass Tank Tube for Vaporesso Veco Plus Vape Atomizer $1.99
The Replacement Glass Tank Tube is with 4ml capacity and it is suitable for Vaporesso Veco Plus Vape Atomizer.
Replacement Glass Tank Tube for Vaporesso Sky Solo Vape Atomizer $1.99
The Replacement Glass Tank Tube is with 3ml capacity and it is suitable for Vaporesso Sky Solo Vape Atomizer.
Replacement Glass Tank Tube for Vaporesso Drizzle Vaping AIO Vape Atomizer $1.99
The Replacement Glass Tank Tube is with 1.8ml capacity and it is suitable for Vaporesso Drizzle Vaping AIO Tank Atomizer.
Replacement Glass Tank Tube for Vaporesso Cascade Baby SE Vape Atomizer $1.99
The Replacement Glass Tank Tube is with 6.5ml capacity and it is suitable for Vaporesso Cascade Baby SE Tank Vape Atomizer.
Replacement Glass Tank Tube for Vaporesso Revenger & NRG Vape Atomizer $1.99
The Replacement Glass Tank Tube is with 5ml capacity and it is suitable for Vaporesso Revenger & NRG Vape Atomizer.
Replacement Glass Tank Tube for Vaporesso Orca Solo Vape Atomizer $1.99
The Replacement Glass Tank Tube is with 1.5ml capacity and it is suitable for Vaporesso Orca Solo Vape Atomizer.
Replacement Glass Tank Tube for Vaporesso Cascade & Cascade SE Vape Atomizer $1.99
The Replacement Glass Tank Tube is with 7.5ml capacity and it is suitable for Vaporesso Cascade & Cascade SE Vape Atomizer.
Replacement Glass Tank Tube for Vaporesso Uforce T2 Vape Atomizer $1.99
The Replacement Glass Tank Tube is with 8ml capacity and it is suitable for Vaporesso Uforce T2 Vape Atomizer.
PVC Heat Shrinkable Tube Wrap Sleeve for 18650 Battery(20 PCS) $1.99
The sleeve is universal for 18650 batteries, such as: Sony VTC5, LGHE4, Samsung 25R, LGHG2 and more.
Original Artery Nugget GT 200W VW Box Mod Pod System Replacement 510 Adapter $4.99
The Artery Nugget GT 510 Adapter is designed for Artery Nugget GT 200W VW Box Mod Pod System to be a dual 18650 box mod. With this adapter, you can use 510 thread atomizers (Sub ohm tank / RTA / RDA / RDTA) on Artery Nugget GT.
Original Artery Nugget GT 200W VW Box Mod Pod System Replacement Empty Pod Cartridge(1 PC) $4.99
The Artery Nugget GT Replacement Empty pod Cartridge is suitable for Artery Nugget GT Dual 18650 Pod Mod Kit. Artery Nugget GT pod Cartridge comes with 8.0ml large capacity with bottom filling design.
Original Artery Nugget GT 200W VW Box Mod Pod System Replacement RBA Coil Head(1 PC) $7.99
The Original Artery Nugget GT Replacement RBA Coil is designed for Artery Nugget GT Dual 18650 Pod Mod Kit to provide DIY vaping.
Original Artery Nugget GT 200W VW Box Mod Pod System Replacement XP Coil Head(60~80W) (1 PC) $9.99
The Original Artery Nugget GT Replacement 0.15ohm XP coil head is suitable for Artery Nugget GT Dual 18650 Pod Mod Kit / Empty Pod Cartridge. 0.15ohm resistance is suitable for 60~80W.
Original Artery Nugget GT 200W VW Box Mod Pod System Replacement XP Coil Head (20~35W) (1 PC) $9.99
The Original Artery Nugget GT Replacement 0.15ohm XP coil head is suitable for Artery Nugget GT Dual 18650 Pod Mod Kit / Empty Pod Cartridge. 0.4ohm resistance is suitable for 20~35W.
SXK BB Gen BBGen MTL Rebuildable RBA Clone for SXK BB 60W / 70W Vape Box Mod Kit original price $25.90, now only $20.99
The SXK BB Gen BBGen Rebuildable RBA Clone is suitable for SXK BB 60W / 70W Vape Box Mod Kit. The BBGen is with adjustable top airflow control and designed for mouth to lung (MTL) and restricted lung hits.
Время генерации страницы 0.72195 секунды с 15 запросами
