302474
822
581
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Armor Mech V2 BF Bottom Feeder Squonk Mechanical Box Vape Mod Clone original price $65.00, now only $55.00
The Armor Mech V2 Mechanical Box Vape Mod Clone is a BF Squonk Mechanical Mod, which comes with side fire button, and custom bottle system. A 24mm inset catch cup surrounds the 510 connector, and an included matching 22mm insert ring allows users to seat either a 22mm or 24mm diameter atomizer into the top plate, or flip the ring for a completely flush mounting surface for larger diameter atomizers and beauty rings. ![]() YFTK Taifun GT4 S DL RTA Clone $24.99 The YFTK Taifun GT4 S DL RTA Rebuildable Tank Atomzier Clone is constructed from 316 Stainless Steel (Body) and PSU (Tank Tube) in 23mm diameter. The RTA comes with a 3.5ml e-juice capacity tank. The air duct system bringing air flow via the poles in the chamber and adjustable AFC from the outside. And it can offer a slightly restricted direct lung hit. Multiple wire mounts allow for easy installation of the coil with versatility. Optimized for single coil builds, but can fit dual coils. ![]() Disposable Earloop Folding Dust Mask Particulate Respirator with Breathing Valve Anti PM2.5 Dust / Bacteria / Virus(2 PCS) $7.99 The Disposable Earloop Folding Dust Mask Particulate Respirator is a disposable dust Mask. It could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus. The elastic ear-loops wears easily and comfortable. It comes with adjustable nose bar helps the mask close to face when wearing. 2 PCS / Pack. ![]() YQ95 Disposable Earloop Folding Facial Mask Particulate Respirator Anti PM2.5 Dust / Bacteria / Virus(10 PCS) $29.99 The YQ95 Disposable Earloop Folding Facial Mask Particulate Respirator is a disposable facial mask. It could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus. The elastic ear-loops wears easily and comfortable. It comes with adjustable nose bar helps the mask close to face when wearing. 10 PCS / Pack. ![]() Disposable Earloop Non-woven Facial Masks Particulate Respirator Anti PM2.5 Dust / Bacteria / Virus(50 PCS) $38.99 The Disposable Non-woven Masks are been manufcture from pure virign double Beam Non Woven Fabrics. It could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus. The elastic ear-loops wears easily and comfortable. It comes with adjustable nose bar helps the mask close to face when wearing. The side with filter touches your face. Place the mask to your nose level and put ear loops around your ears. ![]() Original Advken Artha 80W Pod System Vape Kit Replacement Coil Head - 0.8ohm (5 PCS) $10.99 The Advken Replacement Coil Head is designed for Advken Artha 80W VW Box Mod Pod System Vape Starter Kit as a replacement part, which features 0.8ohm coil resistance. 5 PCS / Pack. ![]() Original Advken Artha 80W Pod System Vape Kit Replacement Coil Head - 0.3ohm (Best: 30W) (5 PCS) $10.99 The Advken Replacement Coil Head is designed for Advken Artha 80W VW Box Mod Pod System Vape Starter Kit as a replacement part, which features 0.3ohm coil resistance (Best: 30W). 5 PCS / Pack. ![]() Original Oumier Voocean 40 Pod System Vape Kit / Cartridge Replacemet Coil Head - 0.8ohm (10~15W) (1 PC) $2.88 The Oumier Replacement Coil is designed for Oumier Voocean 40 Pod System Vape Kit / Cartridge, which features 0.8ohm coil resistance and power range from 10W to 15W. ![]() Original Oumier Voocean 40 Pod System Vape Kit / Cartridge Replacemet Coil Head - 0.3ohm (35~40W) (1 PC) $2.88 The Oumier Replacement Coil is designed for Oumier Voocean 40 Pod System Vape Kit / Cartridge, which features 0.3ohm coil resistance and power range from 35W to 40W. ![]() Original Oumier Voocean 40 Pod System Vape Kit Replacemet Pod Cartridge w/o Coils $2.88 The Oumier Replacement Pod Cartridge is designed for Oumier Voocean 40 Pod System Vape Kit, which features 3.5ml e-juice capacity. And with top filling design, it brings you convenience and avoids leakage. In addition, it supports 2 types of coil: 0.3ohm and 0.8ohm. (Coils are not included) ![]() Original Nitecore Intellicharge Upgraded NEW I2 Dual-Slot Li-ion Battery Charger $14.99 The Original Nitecore Intellicharge Upgraded NEW I2 Li-ion Battery Charger is compatible with following Li-ion batteries: 10340, 10350, 10440, 10500, 12340, 12500, 12650, 13450, 13500, 13650, 14350, 14430, 14500, 14650, 16500, 16340(RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490, 18500,18650,18700, 20700, 21700, 22500, 22650, 25500, 26500, 26650,Ni-MH(NiCd): AA, AAA, AAAA, C, D. And the Max output is 1000mA. ![]() Original Nitecore Intellicharger I4 New Version Universal Smart Charger $23.99 The Nitecore Intellicharger I4 NEW Version Charger is a universal, automatic smart-charger compatible with almost all types of rechargeable batteries thus eliminating the need to own several chargers. The i4 is able to automatically identify Li-ion, Ni-MH and Ni-Cd rechargeable batteries and apply an appropriate charging mode (Constant Charge Current (CC), Constant Charge Voltage (CV) and Trickle Charge). Each of the i4's four microcomputer-controlled charging slots is capable of monitoring and charging batteries independently. Additionally, yellow and blue power / charging status indicator lights could visibly indicate battery status and charging process. i4: The all-new highly advanced smart charger. It's as simple as insert, detect, and charge. This is AU Plug Version.
582
Original Steam Crave Aromamizer Plus V2 DL RDTA Advanced Kit original price $62.99, now only $50.99
The Original Steam Crave Aromamizer Plus V2 DL RDTA is a great-looking, high-quality self-winding device that can be used both as an RTA and as an RDTA. The Aromamizer Plus V2 has a diameter of 30mm, it can hold 8ml of e-liquid and also get an 8ml extension set up. Enlarging the tank is possible so that a filling volume of up to an incredible 16 ml is achieved. A juice flow control system is also included to adjust the e-liquid to suit the mixture / temperature. As to the deck arrangement C the deck is a single coil postless deck and also get a mesh build deck included. Regardless of which expansion height is filled from above, the pillarless deck is carefully designed without causing any confusion. The grid platform is also simple and well-designed, so you can also perform operations here successfully. Following on from the Steam Crave tradition of plenty of accessories you can also get a single coil deck, a series deck, and a velocity style deck to customize your Plus V2 even further (these decks are not including in the kit, sold separately). Airflow control has also been revised and optimized, especially for lower output steam. It is even more adjustable and has many options that have been significantly expanded, especially in more restrictive areas. The airflow is adjustable via the ring on the side which has honeycomb inlets. In addition, the ring has the option of 1, 2 or 3 slots and you can also turn the ring upside down to adjust this further. With Steam Crave's unique tank design, you will enjoy the incredible flavor and amazing cloud production. ![]() Original Steam Crave Aromamizer Plus V2 DL RDTA Basic Kit original price $42.99, now only $37.99 The Original Steam Crave Aromamizer Plus V2 DL RDTA is a great-looking, high-quality self-winding device that can be used both as an RTA and as an RDTA. The Aromamizer Plus V2 has a diameter of 30mm and can hold 8ml of e-liquid. A juice flow control system is also included to adjust the e-liquid to suit the mixture / temperature. As to the deck arrangement C the deck is a single coil postless deck. The grid platform is also simple and well-designed, so you can also perform operations here successfully. Following on from the Steam Crave tradition of plenty of accessories you can also get a single coil deck, a series deck, and a velocity style deck to customize your Plus V2 even further (these decks are not including in the kit, sold separately). Airflow control has also been revised and optimized, especially for lower output steam. It is even more adjustable and has many options that have been significantly expanded, especially in more restrictive areas. The airflow is adjustable via the ring on the side which has honeycomb inlets. In addition, the ring has the option of 1, 2 or 3 slots and you can also turn the ring upside down to adjust this further. With Steam Crave's unique tank design, you will enjoy the incredible flavor and amazing cloud production. ![]() Original Hotcig Sniper 18650 80W VW Box Mod Pod System Vape Starter Kit $37.99 The Original Hotcig Sniper 18650 Pod Kit is a tight combination of compact but effective vaping technology, adopt traditional box mod style and new pod usage, provide more comprehensive performance. It is powered by a 18650 external battery (not included), with sufficient power and longer lifespan. Sniper 18650 Pod Kit also uses a feature-rich, stable output HM-80W chip, strong performance. In addition, the Sniper panels are covered in visually striking artistic finish, facilitating easy removal while leaving cut-outs for a juice level viewing window, and a 0.96 inches color screen to relay critical vaping information. As for the Sniper Pod cartridge with a capacity of 3.2ml, it is filled by opening the side silicone plug and easy to pull out. It features a bottom coil installation point, accepting either a 0.4ohm Mesh Coil or 0.17ohm Mesh Coil in a plug 'n' play method. Hotcig Sniper 18650 Pod Kit dedicated mesh coils satisfy you massive clouds and flavors. ![]() Hi forest KN95 Protective Facial Mask Particles Respirator to Defend PM2.5 Dust / Bacteria / Virus(1 PC) $3.99 Hi-forest KN95 Protective Facial Mask is the high-quality facial Mask. It could effectively defend various particles in the air includes PM2.5 dust and bacteria/virus. It has a high-efficiency melt-blown layer which absorbs fine particles in the air, defend bacteria / virus. The facial mask is made by 3D defendable shaped cotton which is (Antibiosis, Antiviral is available), soft and comfortable, allaying shock. ![]() 3-Layer Soft Toilet Paper Tissue Bathroom Living Room Decor Toilet Tissue(1 Roll) $2.99 Will you buy this Toilet Paper Tissue from oversea? Maybe your ass has already get clean when you receive the paper. Maybe you will need it from China if it is stockout in the local supermarket. It will be a good choice to get it from oversea in some case.
583
Original Auguse V1.5 MTL RTA with 5 Airflow Inserts $25.85
The Original Auguse V1.5 MTL RTA rebuildable tank atomizer is constructed from stainless steel in 22mm diameter and features 5 airflow inserts option for your different flavors (2.0mm, 1.5mm, 1.2mm, 1.0mm, 0.8mm). The Auguse V1.5 MTL RTA can be loaded 4.0ml e-juice through the bottom fill port. The build deck is oriented to accept a single coil configuration with two posts with a single large open terminal on each (coil is not included), affixed from the side via flathead screws. It is very easy to build. ![]() Original Steam Crave Aromamizer Plus V2 RDTA Vape Atomizer Replacement Straight Tank Tube(2 PCS) $7.98 The Original Steam Crave Replacement Straight Tank Tube is designed for Steam Crave Aromamizer Plus V2 RDTA Vape Atomizer as a replacement part, it is made of glass and features 8ml e-juice capacity. 2 PCS / Pack. ![]() Original Steam Crave Aromamizer Plus V2 RDTA Replacement Extension Tank Tube(1 PC) $4.39 The Original Steam Crave Replacement Extension Tank Tube is designed for Steam Crave Aromamizer Plus V2 RDTA Vape Atomizer as a replacement part ![]() Original Steam Crave Aromamizer Plus V2 RDTA Replacement 6mm Chimney Reducer(1 PC) $2.59 The Original Steam Crave Replacement 6mm Chimney Reducer is designed for Steam Crave Aromamizer Plus V2 RDTA Vape Atomizer as a replacement part. It is recommended for single coil deck and mesh deck. ![]() Original Steam Crave Replacement Single Coil Deck for Aromamizer Plus V1 / V2 RDTA(1 PC) $7.29 The Original Steam Crave Replacement Single Coil Deck is made of stainless steel and it is compatible with Steam Crave Aromamizer Plus V1 / V2 RDTA Vape Atomizer as a replacement part. ![]() Original Steam Crave Replacement Series Deck for Aromamizer Plus V1 / V2 RDTA(1 PC) $7.29 The Original Steam Crave Replacement Series Deck is made of stainless steel and it is compatible with Steam Crave Aromamizer Plus V1 / V2 RDTA Vape Atomizer as a replacement part. ![]() Original Steam Crave Replacement Velocity Deck for Aromamizer Plus V1 / V2 RDTA(1 PC) $7.59 The Original Steam Crave Replacement Velocity Deck is made of stainless steel and it is compatible with Steam Crave Aromamizer Plus V1 / V2 RDTA Vape Atomizer as a replacement part. ![]() Firebird Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $3.99 The Firebird 510 Replacement Drip Tip is made of Stainless Steel and POM and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. Without Logo. ![]() Disposable 3-Ply Facial Masks Particulate Respirator Anti PM2.5 Dust / Bacteria / Virus / COVID-19 (30 PCS) (Children Version) $20.99 The Disposable 3-Ply Earloop Non-woven Facial Masks Particulate Respirator is made from 1 ply SPP non-woven + 1 ply melt blown non-woven + 1 ply SPP non-woven. It is with adjustable nose bar helps the mask close to face when wearing. The elastic ear-loops wears easily and comfortable. It could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. It comes with adjustable nose bar helps the mask close to face when wearing. The side with filter touches your face. Place the mask to your nose level and put ear loops around your ears. This is children version and it is fit well for children's face shape. ![]() Disposable 3-Ply Earloop Non-woven Protective Masks Particulate Respirator Anti PM2.5 Dust / Bacteria / Virus /COVID-19 (10 PCS) $8.99 The Disposable 3-Ply Earloop Non-woven Protective Masks Particulate Respirator with CE & FDA Certification is made from 1 ply SPP non-woven + 1 ply melt blown non-woven + 1 ply SPP non-woven. It is with adjustable nose bar helps the mask close to face when wearing. The elastic ear-loops wears easily and comfortable. It could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. It comes with adjustable nose bar helps the mask close to face when wearing. The side with filter touches your face. Place the mask to your nose level and put ear loops around your ears. Blue or white will be shipped randomly. ![]() KN95 3D Respirator Protective Mask Anti PM2.5 Dust / Bacteria / Virus / COVID-19 - 1 PC (Children Version) $3.99 The KN95 3D Earloop Folding Particulate Respirator Protective Mask with a Breathing Valve could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. There are 4-ply protection for you to defend varous dust and virus. This is children's version. ![]() KN95 3D Earloop Particulate Respirator Protective Mask with Breathing Valve Anti Bacteria/Virus/COVID-19 - 1 PC (Children Version) $3.99 The KN95 3D Earloop Folding Particulate Respirator Protective Mask could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. There are 4-ply protections for you to defend varous dust and virus. This is children's version. ![]() KN95 3D Earloop Folding Particulate Respirator Protective Mask Anti PM2.5 Dust / Bacteria / Virus / COVID-19(2 PCS) $6.99 The KN95 3D Earloop Folding Particulate Respirator Protective Mask with CE Certification could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. It comes with adjustable nose bar helps the mask close to face when wearing. There are 4-ply protections for you to defend varous dust and virus. 2 PCS / Pack.
584
Original KIZOKU Kirin Semi-Mech Mechanical Tube Vape Mod $29.99
The Original KIZOKU Kirin Tube Mod comes in thousands of anticipation with high-end elegant Kirin theme graphic design. The shell of Kirin Tube Mod is made of all stainless steel material, possesses the perfect combination of super hardness and beautiful appearance. And the KIZOKU Kirin mod is widely compatible with 18650 / 18350 battery (Batteries are not included) to meet your different needs. Plus the innovative one-in-one key structure and a hand-held compact size, you will receive the excellent flavor and rich clouds. Just get the mod for your KIZOKU Kirin Kit / KIZOKU Kirin Tube now and wander in the beautiful vaping world. ![]() Original Auguse V1.5 MTL RTA with 5 Airflow Inserts $25.85 The Original Auguse V1.5 MTL RTA rebuildable tank atomizer is constructed from stainless steel in 22mm diameter and features 5 airflow inserts option for your different flavors (2.0mm, 1.5mm, 1.2mm, 1.0mm, 0.8mm). The Auguse V1.5 MTL RTA can be loaded 4.0ml e-juice through the bottom fill port. The build deck is oriented to accept a single coil configuration with two posts with a single large open terminal on each (coil is not included), affixed from the side via flathead screws. It is very easy to build. ![]() Original KIZOKU Kirin Semi-Mech Mechanical Tube Mod + Disposable Tank Vape Kit $39.99 The Original KIZOKU Kirin Mech Mod Kit consists of Semi-Mech Mechanical Tube Mod and Disposable Tank, which is optimized for the use with MTL atomizers. Adopting the stainless steel material and Kirin theme graphic design, it will bring you durable use and comfortable gripping. The atomizer comes with 2ml e-juice capacity and 0.5ohm coil for restricted DL vaping. You can also make it to MTL vaping by choosing the advanced tank with 1.2ohm coil. The oil can be refilled quickly with the bottom silicone plug filling design. Moreover, the Kirin mod is compatible with 18350 battery and it can be extended to 18650 battery with the 18650 extended tube (18350 and 18650 Batteries are not inclueded), which meets your different needs. In general, the Kirin mech kit is compact yet functional, you will acquire a quite amazing vaping experience. ![]() Original KIZOKU Kirin Semi-Mech Tube Mod Replacement Disposable Tube Tank with 1.2ohm Coil(3 PCS) $6.99 The Original KIZOKU Replacement Disposable Tank Tube is designed for KIZOKU Kirin Semi-Mech Tube Vape Mod as a replacement part, which is made of PCTG. It comes with 2ml e-juice capacity and a 1.2ohm resistance coil. 3 PCS / Pack. ![]() Original KIZOKU Kirin Semi-Mech Tube Mod Replacement Disposable Tube Tank with 0.5ohm Coil(3 PCS) $6.99 The Original KIZOKU Replacement Disposable Tank Tube is designed for KIZOKU Kirin Semi-Mech Tube Vape Mod as a replacement part, which is made of PCTG. It comes with 2ml e-juice capacity and a 1.2ohm resistance coil. 3 PCS / Pack. ![]() Original KIZOKU Kirin Semi-Mech Tube Vape Mod Replacement MTL / DL 2ml Disposable Tube Tank with Drip Tip & Base + 0.5ohm Coil $8.99 The Original KIZOKU Replacement MTL / DL Disposable Tank Tube is designed for KIZOKU Kirin Semi-Mech Tube Vape Mod as a replacement part, which is made of PCTG. It comes with 2ml e-juice capacity and a 0.5ohm resistance high quality cotton coil inside for excellent taste. Featuring accurate airflow control system and bottom silicone plug filling design, you can enjoy the great flavor with easy operation. What is more, it supports MTL vaping and restricted DL vaping. Moreover, Drip Tip and a SS Base are included. ![]() Steam Tuners Replacement Bell Cap Clone for Dvarw MTL RTA $5.99 The Steam Tuners Replacement Bell Cap Clone is made from PMMA for Steam Tuners Dvarw MTL RTA Clone. The cap is 22mm diameter and the height of this cap is 21mm. The bell cap has a 2ml juice capacity. ![]() Original Vandy Vape Mato RDTA Vape Atomizer Replacement 810 Drip Tip $2.59 The Original Vandy Vape Replacement 810 drip tip is made of resin. It is designed for Vandy Vape Mato RDTA Vape Atomizer and it is also suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. ![]() Original ALiCN R1D1 Forehead Non-contact Infrared Digital Body Clinical Thermometer $75.99 The Original ALiCN R1D1 Clinical Thermometer is a Forehead Non-contact Infrared Digital Body Clinical Thermometer, which comes with pracitical patent design that infrared induction is faster and more comprehensive. Also, the Clinical Thermometer is equipped with a HD LED large screen that provide you the data of device. Furthermore, there are multiple functions like automatic shutdown, high temperature warning, accurate measurement, and 32 sets of memory which make you use it more conveniently. What's more, it can provide One key One second non contact measurement that makes mesurement more safer. ![]() Original ALiCN R1A3 Ear & Forehead Non-contact Infrared Digital Body Clinical Thermometer $79.99 The Original ALiCN R1A3 Clinical Thermometer is a Ear & Forehead Non-contact Infrared Digital Body Clinical Thermometer, which comes with infrared induction is faster and more comprehensive. Also, the Clinical Thermometer is equipped with a LED large screen that provide you the data of device. Furthermore, there are multiple functions like automatic shutdown, high temperature warning, accurate measurement, and forehead & Ear double use which make you use it more conveniently.
585
Original Aspire Nautilus XS Sub Ohm Tank Vape Atomzier $21.99
The Aspire Nautilus XS tank is constructed from stainless steel (body) and glass (tube) in 22mm diameter, which represents the latest exciting development, advancing the original Nautilus X format further, presented a sleek and versatile replaceable U-Tech coil,designed to exceed your expectations. Precision engineered for ultra-smooth and consistent airflow operation, the Nautilus XS is equipped with two large airflow holes, which feed air into the coil chamber from above the refillable tank section. These holes are adjusted easily, to allow fast tuning for a wide variety of airflow styles. The XS tank supports top filling system that convenient to refill. The Nautilus XS tank system uses the Nautilus X coil with enhanced features such as top airflow adjustment from MTL to restricted DTL, easy to use filling system, and cooling fins next to the mouth tip to reduce heat build up. ![]() Original Aspire Rover 2 NX40 40W 2200mAh VV VW Box Mod Starter Kit with Nautilus XS Tank $51.99 The Original Aspire Rover 2 NX40 40W 2200mAh VV VW Box Mod Vape Starter Kit consists of NX40 Mod and Nautilus XS Tank, it takes compact vaping to a new level with it's fit in your hand size and legendary Nautilus vaping performance. The Rover 2 uses the new exciting NX40 mod, which is powered by 2200mAh built-in battery that delivers up to 40 watts of power. To complete the new Rover 2, Aspire took the legendary Nautilus XS and matched its performance to the NX40 mod. The new Nautilus XS tank system uses the Nautilus X coil with enhanced features such as top airflow adjustment from MTL to restricted DTL, easy to use filling system, and cooling fins next to the mouth tip to reduce heat build up. The Rover 2 is a small, compact design that fits in the palm of your hand, but has the performance of mods twice its size. ![]() Original Nitecore UM20 2-Channels Li-ion Battery USB Charger for 18650 / 18490 / 18350 / 17670/17500/16340 (RCR123)/14500/10440 $14.99 The Nitecore UM20 is a USB powered two channels Li-ion battery charger, which is compatible with Li-ion / IMR: 18650, 18490, 18350, 17670, 17500, 16340(RCR123), 14500, 10440 sized batteries. (Batteries are not included) ![]() Original Aspire Nautilus XS Sub Ohm Tank Replacement Mesh Coil Head(5 PCS) $14.99 The Original Aspire Nautilus XS Replacement Mesh Coil Head is desigend for Aspire Nautilus XS Sub Ohm Tank Vape Atomizer as a replacement part. It features 0.7ohm coil resistance and power range from 18W to 22W. 5 PCS / Pack ![]() Original VAPJOY DIY Rebuild Kit for SMOK RPM80/ RPM80 Pro - Opening Tool Kit + Cottons + RPM-Triple Ni80 Triple Coils (0.6ohm) $2.99 The Original VAPJOY DIY Rebuild Kit is suitable for SMOK RPM80/ RPM80 Pro Pod System. The authentic Vapjoy DIY Rebuild Kit consists of 1 x Opening Tool Kit, 40 x Cottons and 10 x RPM-Triple Ni80 Triple Coils (0.6ohm). It is designed to replace coil head economical, RPM pod vapers would easy rebuild their Pods quickly. Enjoy fun to Rebuild. It can meet most of DIY lovers' demand. ![]() Original VAPJOY DIY Rebuild Kit for SMOK RPM80/ RPM80 Pro - Opening Tool Kit + Cottons + RPM-VM1 Ni80 Mesh Coils (0.4ohm) $3.59 The Original VAPJOY DIY Rebuild Kit is suitable for SMOK RPM80/ RPM80 Pro Pod System. The authentic Vapjoy DIY Rebuild Kit consists of 1 x Opening Tool Kit, 40 x Cottons and 10 x RPM-VM1 Ni80 Mesh Coils (0.4ohm). It is designed to replace coil head economical, RPM pod vapers would easy rebuild their Pods quickly. Enjoy fun to Rebuild. It can meet most of DIY lovers' demand. ![]() Original VAPJOY DIY Rebuild Kit for Voopoo Vinci / Vinci X / Vinci Air Kit - Rod + Cottons + VINCI-VM1 Ni80 Mesh Coils (0.3ohm) $3.59 The Original VAPJOY DIY Rebuild Kit is suitable for for Voopoo Vinci / Vinci X / Vinci Air Kit. The authentic Vapjoy DIY Rebuild Kit consists of 1 x Rod, 35 x Cottons and 10 x VINCI-VM1 Ni80 Mesh Coils (0.3ohm) rated for 32~40W (DTL). It is designed to replace coil head economical, VINCI pod vapers would easy rebuild their Pods quickly. Enjoy fun to Rebuild. It can meet most of DIY lovers' demand. ![]() Original VAPJOY DIY Rebuild Kit for Voopoo Vinci / Vinci X / Vinci Air Kit - Rod + Cottons + VINCI-R1 Ni80 Coils (1.0ohm) $2.59 The Original VAPJOY DIY Rebuild Kit is suitable for for Voopoo Vinci / Vinci X / Vinci Air Kit. The authentic Vapjoy DIY Rebuild Kit consists of 1 x Rod, 40 x Cottons and 10 x VINCI-R1 Ni80 Coils (1.0ohm) rated for 12~18W (MTL). It is designed to replace coil head economical, VINCI pod vapers would easy rebuild their Pods quickly. Enjoy fun to Rebuild. It can meet most of DIY lovers' demand.
586
Original ATNNK Portable Non-washing Sanitizer Anti-Bacterial Instant Hand Sanitizer inhibit Bacteria / Virus / COVID-19 - 100ml $4.99
The Instant Hand Sanitizer is easy to use, it can inhibit 99.99% of bacteria. It features natural ingredients can inhibit Bacteria / Virus / COVID-19 effectively. The cream shape makes it convenient to use, which will keep your hands refresh, no sticky, no greasy. Air dries within seconds. Use without water and add moisturisers. ![]() Original ATNNK Protective Wash Hands Alcohol Instant Hand Sanitizer inhibit Bacteria /Virus/COVID-19 - 100ml (Children Version) $4.99 The Protective Wash Hands Alcohol Instant Hand Sanitizer is easy to use, it can inhibit 99.99% of bacteria. It features natural ingredients, the content of alcohol is 75% which can inhibit Bacteria / Virus / COVID-19 effectively. The cream shape makes it convenient to use, which will keep your hands refresh, no sticky, no greasy. Air dries within seconds. Use without water and add moisturisers. ![]() Original Vinda Non-alcoholic Adult Sterilization Wipes inhibit Bacteria / Virus / COVID-19(80 PCS) $7.99 The Vinda Adult Wet Wipes is easy to use, it can inhibit 99.99% of bacteria. It features natural ingredients, and consists of pure water, benzyl ammonium chloride, non-woven. It is no alcohol which can inhibit Bacteria / Virus / COVID-19 well. 80 PCS / Pack ![]() Orginal Vinda Non-alcoholic Adult Sterilization Wipes inhibit Bacteria / Virus / COVID-19(10 PCS) $2.99 The Vinda Adult Wet Wipes is easy to use, it can inhibit 99.99% of bacteria. It features natural ingredients, and consists of pure water, benzyl ammonium chloride, non-woven. It is no alcohol which can inhibit Bacteria / Virus / COVID-19 well. 10 PCS / Pack ![]() Original 3M 1621AF Chemical Goggle Glasses for Anti-Impact / Anti Chemical Splash / Anti-Fog / Anti-Bacteria / Virus / COVID-19 $9.99 The original 3M 1621AF Chemical Goggle Glasses is made of Polycarbonate material in 150 x 80 x 70mm size. It is suitable for Anti-Impact / Anti Chemical Splash / Anti-Fog / Lens Eye Protection / Anti-Bacteria / Virus / COVID-19. ![]() Original Coil Master ReBuild Kit for GeekVape Boost Kit - 1 Opening Pry Tool Kit + 40 Cottons + 10 Ni80 Mesh Coils (0.4ohm) $6.99 The Original Coil Master ReBuild Kit is suitable for GeekVape Boost Kit. It consists of 1 x Opening Pry Tool Kit, 40 x Cottons and 10 x Ni80 Mesh Coils (0.4ohm). It can meet most of DIY lovers' demand. It can rebuild the pod coil quickly & easily. ![]() Original Coil Master ReBuild Kit for SMOKTech SMOK RPM Kit - 1 Opening Pry Tool Kit + 40 Cotton + 10 Ni80 Triple Coils (0.6ohm) $6.99 The Original Coil Master ReBuild Kit is suitable for SMOKTech SMOK RPM40 / RPM 80 / RPM 80 Pro Kit. It consists of 1 x Opening Pry Tool Kit, 40 x Cottons and 10 x Ni80 Triple Coils (0.6ohm). It can meet most of DIY lovers' demand. It can rebuild the pod coil quickly & easily. ![]() Original Coil Master ReBuild Kit for SMOKTech SMOK RPM Kit - 1 Opening Pry Tool Kit + 40 Cottons + 10 Ni80 Mesh Coils (0.4ohm) $6.99 The Original Coil Master ReBuild Kit is suitable for SMOKTech SMOK RPM40 / RPM 80 / RPM 80 Pro Kit. It consists of 1 x Opening Pry Tool Kit, 40 x Cottons and 10 x Ni80 Mesh Coils (0.4ohm). It can meet most of DIY lovers' demand. It can rebuild the pod coil quickly & easily.
587
Original Reewape AS300 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / Reload RDA $1.69
The Reewape AS300 810 Replacement drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer original price $1.99, now only $0.59 The Replacement 510 Drip Tip is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Replacement 810 Drip Tip for Goon / Kennedy / Battle / Reload RDA orignal price $1.99, now only $0.59 The Replacement 810 drip tip is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Replacement 810 Drip Tip for Goon Kennedy / Battle / Reload RDA original price $2.99, now only $0.79 The Replacement 810 drip tip is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Replacement Drip Tip for SMOKTech SMOK TFV16 Sub Ohm Tank $1.99 The Replacement Drip Tip is designed for SMOKTech SMOK TFV16 Sub Ohm Tank as a replacement part. It is made of epoxy resin material. ![]() Original Coil Master Pro Cotton for RBA / RDA / RTA / RDTA Vape Atomizer(10 PCS) $3.99 The Original Coil Master Pro cotton is high-quality cotton dedicated for vaping. No colorant, or chemical treatment. It is made of 100% Indonesian Organic Cotton which will bring you a purer and cleaner taste and vape. It is suitable for DIY vaping lovers well. 10 PCS / Pack. ![]() SXK Replacement Airflow Inserts for Bridg'D Kit(4 PCS) original price $9.90, now only $8.59 The SXK Replacement Airflow Inserts is suitable for SXK Bridg'D Kit as a replacement part. The airflow inserts hole size includes: 1.5mm / 2mm / 3mm / 3.5mm, and the airflow insert size is 12 x 6mm. 4 PCS / Pack. ![]() SXK Replacement Top Cap Chimney for SXK Bridg`D Kit original price $9.90, now only $8.59 The SXK Replacement Top Cap Chimney is suitable for SXK Bridg'D Kit as a replacement part. The Top Cap Chimney size is 22 x 17mm and it is made of 316 Stainless Steel. ![]() SXK Bridg'D Bridg D MTL / DL RBA Rebuildable Atomizer Clone with 2.5mm Airflow Insert for SXK BB / Billet Box Mod Kit original price $21.90, now only $19.99 The SXK Bridg'D RBA Rebuildable Atomizer Clone is constructed from 316 Stainless Steel, which is suitable for SXK BB / Billet Box Vape Mod Kit as a replacement RBA part. The RBA is easy to build and wick. It supports MTL / DL vaping experience, zero dry hits, dialing airflow is very easy, and fitments are flawless. The RBA comes with a 2.5mm airflow insert, a full RBA Deck, 2 Cap / Chimneys, a bridg'd key, a 510 adapter tool, panda button, integral tip, and spare bag (o-rings and screws).
588
Original Aspire Nautilus GT MTL Sub Ohm Tank Vape Atomizer $29.99
The Original Aspire Nautilus GT MTL Sub Ohm Tank Vape Atomizer is constructed from stainless steel (body) and pyrex glass (tank tube) in 24mm diameter. The Nautilus GT Tank comes with a 0.7ohm Mesh Coil (20~25W), a 1.6ohm BVC Coil (7~11W) to meet your different needs, a 3ml E-juice capacity tank tube, top-fill design, and supports adjustable airflow system. The Nautilus GT Tank can be adjusted easily, with 5 precision setting airflow holes (1.0mm / 1.2mm / 1.5mm / 1.8mm / 2.5mm). Just rotate the airflow ring to adjust. The Nautilus GT incorporates a thickened base hardware material, matching with the oblate air channel, which allows air to enter the tank directly, without any unwanted air loss. This ensures richer and thicker flavor. The thick stainless steel of Nautilus GT tank will also cool down quickly, to avoid getting hot. The Nautilus GT features easy and convenient top filling, just unscrew the top hardware to fill. The large diameter filling holes will match all kinds of E-liquid bottles. ![]() Original Aspire Nautilus GT 75W VW Box Mod Vape Starter Kit $64.99 The Original Aspire Nautilus GT Kit consists of Aspire Glint Mod and Nautilus GT Tank. The GT Kit is powered by a single 18650 battery (Battery is not included) and comes with a 3ml e-juice capacity glass tank tube. The Glint Mod of Nautilus GT Kit can fire up to 75W, press the fire button together with "+" and "-" buttons to adjust, easy to operate. Furthermore, it is equipped with a 0.91" OLED Screen which can provide you details of device's data such as wattage, battery capacity, etc. The Nautilus GT features easy and convenient top filling, just unscrew the top hardware to fill. The large diameter filling holes will match all kinds of E-liquid bottles, and it comes with adjustable airflow system to meet your different needs. The Stainless Steel Hollowed Sleeve makes Nautilus GT tough and rugged. This helps to protect the glass from breaking if dropped. Moreover, it supports MTL and DTL vaping, and compatible with high VG and high PG E-juices.
589
Stratum v5.1 VW Squonk Mechanical Box Mod Clone $229.99
The Stratum v5.1 VW Variable Wattage Squonk Mechanical Box Vape Mod Clone is constructed from High Quality Stabilised Wood from Ukraine, which is powered by 1 x 18650 battery (Battery is not included) and is equipped with Evolv DNA 60 Chip set. ![]() Original Eleaf iJust 23W 1500mAh AIO Mod Pod System Vape Starter Kit $18.00 The Original Eleaf iJust AIO Kit is known as a pod system vape starter kit, which comes with compact and portable size, fashionable appearance and sleek hand feeling. The iJust AIO Kit is powered by a 1500mAh built-in battery with 23W Max output. Equipped with 3-color LED indicator light, it will show you battery level clearly. In addition, it adopts adjustable power output to meet your individual needs better. As for its pod cartridge, it chooses 2ml E-juice capacity with convenient refilling method. And utilizing visible transparent window, it will display you liquid level directly. Moreover, it supports 0.6ohm GT M Coil for pure and smooth flavor. Furthermore, iJust AIO provides 3 power levels(Low, Medium, and High) for you to choose the one that you like. Multiple protections are available for iJust AIO to ensure the safety: Over-charge protection, Over-discharge protection, Over 10s protection, Short circuit protection. ![]() Original EGQ B011 1000mAh VW Box Mod Pod System Vape Starter Kit $17.99 The Original EGQ B011 VW Box Mod Pod System Vape Starter Kit is powered by a 1000mAh built-in battery and comes with 1.6ml capacity cartridge to meet your all day long vape. The LED screen will display the battery, puff, voltage, load resistance, which is very convenient. Furthermore, there are multiple protecetions that provide you safer vaping experience: Over-temperature Protection, Short Circuit Protection and Charging Protection. ![]() Disposable PVC Gloves Withanti-static / Anti-oil / Anti-infiltration / Anti-bacterial / Virus / COVID-19(100 PCS) $10.99 The Disposable PVC Gloves does not contain allergens, non-toxic, noimpurities, regardless of left and right hand, easy to wear comfortable, withanti-static properties, anti-oil, anti-infiltration, anti-bacterial, Coronavirus Disease 2019 (COVID-19). 100 PCS / Pack. ![]() Uncoated Protective Goggle Glasses for Anti-Impact / Anti Chemical Splash / Anti-Fog /Anti-Bacteria/Virus/COVID-19 $6.99 The Uncoated Protective Safety Goggle Glasses is flexible, durable, lightweight, and comfortable to wear, it is suitable for Anti-Impact / Anti Chemical Splash / Anti-Fog / Anti-Bacteria / Virus / Coronavirus Disease 2019 (COVID-19). ![]() KN95 3D Earloop Folding Protective Mask Particulate Respirator Anti PM2.5 Dust / Bacteria / Virus / COVID-19(50 PCS) $75.99 The KN95 3D Earloop Folding Protective Mask Particulate Respirator with CE Certification could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. It comes with adjustable nose bar helps the mask close to face when wearing. The KN95 Protective Mask adopts national protection level, can effectively protect the external dust and bacteria. Filtration efficiency for non-oily particles is at least 95%. 50 PCS / Pack. ![]() Wormhole Top Cap Tank Tube Clone + Drip Tip + Top Ring + Chimney & Chimney Base + Coin + Beauty Ring for Dvarw DL 24mm Tank $14.99 The Wormhole set Clone includes dual tank (PMMA tank & PC tank), across special driptip (pure black PMMA), top ring (pure black PMMA), chimney (black PEEK), chimney base (black PEEK), beauty ring with air hole (pure black PMMA), across coin (SS) for juice control. PMMA tank polished finished, and juice with Citric and mint not recommended. PC tank frosted finished, suitable for all kind of juice. They are suitable for Dvarw DL 24mm Tank Atomizer. ![]() Wormhole Top Cap Tank Tube Clone + Drip Tip + Top Ring + Chimney & Chimney Base + Coin + Beauty Ring for Dvarw MTL 22mm Tank $13.99 The Wormhole set Clone includes dual tank (PMMA tank & PC tank), across special driptip (pure black PMMA), top ring (pure black PMMA), chimney (black PEEK), chimney base (black PEEK), beauty ring with air hole (pure black PMMA), across coin (SS) for juice control. PMMA tank polished finished, and juice with Citric and mint not recommended. PC tank frosted finished, suitable for all kind of juice. They are suitable for Dvarw MTL 22mm Tank Atomizer.
590
Original Wotofo COG MTL RTA original price $35.99, now only $31.99
The Original Wotofo COG MTL RTA is the world's first gear mechanism powered atomizer, which is constructed from stainless steel (body) and PCTG (tank tube) in 22mm diameter. Not only does this RTA give you an exceptional MTL (Mouth-To-Lung) Experience, but it also has everything for every flavor. Of course, a good tank has good airflow, Wotofo COG MTL RTA innovative airflow design with 5 airflow options leads air to hit right at the coil to deliver the most favorable MTL vaping experience. ![]() Original Teslacigs Invader GT 50W 1200mAh VW Box Mod Pod System Vape Starter Kit $36.99 The Original Teslacigs Invader GT Kit uses the old-style common to the Invader series, mainly made of aluminum alloy. There are three buttons on the side control panel. From top to bottom are fire buttons, wattage adjustable knob, mode button. The output wattage could be reached to 50W, which provides a bigger and more exciting vaping experience. The Invader GT is powered by a 1200mAh built-in battery, more stable, more durable. You can charge this fully in 1.4 hours at a 1A charging rate via the mainstream Type-C charging interface. The RGB LED light at the bevel above the control panel, intelligent indicator, battery power at a glance. The power adjustment range is 7~50W, no screen, adjust the amount of smoke as needed through dial with 5 settings on. ![]() Original Smoant Knight 80 80W TC VW Box Mod RBA Pod System Vape Starter Kit $29.99 The Original Smoant Knight 80 RBA TC VW Box Mod Pod System Vape Starter Kit is a new RBA pod mod from Smoant and powered by a 18650 battery (Battery is not included), which is compatible with six types of coils, including two new sub-ohm mesh coil, one new RBA coil, and three Pasito coils (RBA coils and Pasito coils are not included). Equipped with the advanced AI smart ANT-chip and buck boost chip, Knight 80 supports atomizer memory function which will adjust to the best output automatically. Knight 80 comes with the minimalism 0.96 inch OLED screen, independent air-flow control system, new child lock system, and multiple protections. ![]() Original 59S S1 13W UVC LED Ultraviolet Ray Sterilizing Box for Sterilizing Face Mask / Vape / Phone, etc. - 260~280nm, EU Plug $79.99 Mobile Phones are Vectors for Viruses and the virus is sensitive to ultraviolet light. S1 only takes 180 seconds to kill 99.9% of bacteria and germ block the spread of the virus. The Choice of Healthier Lives: 59S specializes in UV LED sterilizers based on the daily needs.It mainly to make disinfection faster and easier, everyone to live a healthy sterile life. Suitable for Small Accessories: S1 disinfecting case is not just for smartphone,its also compatible with face masks, glasses, keys, beauty tools and daily necessities. It can inhibit the bacteria / virus / Coronavirus Disease 2019 (COVID-19) effectively. Keep the items sterile and reduce the infection of the disease. This is EU Plug Version. ![]() Original 59S S1 13W UVC LED Ultraviolet Ray Sterilizing Box for Sterilizing Face Mask / Vape / Phone, etc. - 260~280nm, US Plug $79.99 Mobile Phones are Vectors for Viruses and the virus is sensitive to ultraviolet light. S1 only takes 180 seconds to kill 99.9% of bacteria and germ block the spread of the virus. The Choice of Healthier Lives: 59S specializes in UV LED sterilizers based on the daily needs.It mainly to make disinfection faster and easier, everyone to live a healthy sterile life. Suitable for Small Accessories: S1 disinfecting case is not just for smartphone,its also compatible with face masks, glasses, keys, beauty tools and daily necessities. It can inhibit the bacteria / virus / Coronavirus Disease 2019 (COVID-19) effectively. Keep the items sterile and reduce the infection of the disease. This is US Plug Version. ![]() Original 59S S2 8W UVC LED Ultraviolet Ray Sterilizing Box for Sterilizing Face Mask / Vape / Phone, etc. - 260~280nm, BS Plug $79.99 This salon quality sterilizing box can be used for face masks, nails as well as baby pacifiers, small toys, keys, glasses, mobile devices, hearing aids and personal items. It can inhibit the bacteria / virus / Coronavirus Disease 2019 (COVID-19) effectively. ADVANCED UV-C LIGHT: Offering wide wavelength coverage at 260~280nm, this UV sterilization box with reflective glass provides 360 degrees protection for universal support. SIMPLE, PORTABLE DESIGN: Small enough to use in the bathroom, kitchen or nursery room these sterilizing boxes are easy to use, work quickly, and shut off automatically. PROMOTE HEALTHIER LIFESTYLES: Using the 59S UV-C light storage box to help sterilize tools and accessories can help reduce the spread of germs, bacteria and impurities. This is BS Plug Version. ![]() Original 59S S2 8W UVC LED Ultraviolet Ray Sterilizing Box for Sterilizing Face Mask / Vape / Phone, etc. - 260~280nm, EU Plug $79.99 This salon quality sterilizing box can be used for face masks, nails as well as baby pacifiers, small toys, keys, glasses, mobile devices, hearing aids and personal items. It can inhibit the bacteria / virus / Coronavirus Disease 2019 (COVID-19) effectively. ADVANCED UV-C LIGHT: Offering wide wavelength coverage at 260~280nm, this UV sterilization box with reflective glass provides 360 degrees protection for universal support. SIMPLE, PORTABLE DESIGN: Small enough to use in the bathroom, kitchen or nursery room these sterilizing boxes are easy to use, work quickly, and shut off automatically. PROMOTE HEALTHIER LIFESTYLES: Using the 59S UV-C light storage box to help sterilize tools and accessories can help reduce the spread of germs, bacteria and impurities. This is EU Plug Version. ![]() Original 59S S2 8W UVC LED Ultraviolet Ray Sterilizing Box for Sterilizing Face Mask / Vape / Phone, etc. - 260~280nm, US Plug $79.99 This salon quality sterilizing box can be used for face masks, nails as well as baby pacifiers, small toys, keys, glasses, mobile devices, hearing aids and personal items. It can inhibit the bacteria / virus / Coronavirus Disease 2019 (COVID-19) effectively. ADVANCED UV-C LIGHT: Offering wide wavelength coverage at 260~280nm, this UV sterilization box with reflective glass provides 360 degrees protection for universal support. SIMPLE, PORTABLE DESIGN: Small enough to use in the bathroom, kitchen or nursery room these sterilizing boxes are easy to use, work quickly, and shut off automatically. PROMOTE HEALTHIER LIFESTYLES: Using the 59S UV-C light storage box to help sterilize tools and accessories can help reduce the spread of germs, bacteria and impurities. This is US Plug Version.
591
Original Smoant Ladon 225W TC VW Variable Wattage Box Vape Mod Original price $35.99, now only $33.99
The Original Smoant Ladon Ladon 225W TC VW Box Vape Mod is compact, ergonomically sized, comfortable to hold and has many powerful features in one. It is constructed from high-quality Zinc Alloy and PMMA material. Wear-resistant leather, smooth and fingerprint-free body, comfortable control, excellent feel. Ladon Mod is powered by dual 18650 batteries (Batteries are not included) and delivers 225W max output, with 2A fast charging via Type-C USB port. In addition, Smoant Ladon Mod is equipped with the advanced AI smart ANT-chip and buck-boost chip which will adjust to the best output automatically. It absolutely will bring you the best vaping experience. Moreover, the Smoant Ladon Mod is also featured with multiple protections to guarantee a safe vaping environment. ![]() Original Smoant Ladon AIO 2in1 Sub Ohm Tank + RBA Vape Atomizer $25.99 The Original Smoant Ladon AIO 2in1 Sub Ohm Tank Vape Atomizer is the world's first 2in1 AIO Sub Ohm Tank which is not only compatible with Sub-ohm coil, but also can be used with RBA coil, and for the RBA head, you can build the mesh coil and the regular coil. The Ladon AIO 2in1 Sub Ohm Tank is constructed from Stainless Steel (body) and Quartz Glass (tank tube) in 28mm Diameter. The tank capacity of Ladon AIO 2in1 Tank is 4.0ml / 6.0ml, it comes with easy top filling. Furthermore the bottom adjustable airflow will bring you the best vaping experience. ![]() Original Smoant Ladon 225W TC VW Box Vape Mod + AIO 2in1 Tank Vape Kit original price $59.99, now only $49.99 The Original Smoant Ladon AIO 2in1 Box Kit consists of Ladon 225W TC VW Box Vape Mod and Ladon AIO Sub Ohm Tank Atomizer. Smoant Ladon AIO Kit is compact, ergonomically sized, comfortable to hold and has many powerful features in one. For Ladon 225W Mod, it is constructed from high-quality Zinc Alloy and PMMA material. Wear-resistant leather, smooth and fingerprint-free body, comfortable control, excellent feel. Ladon Mod is powered by dual 18650 batteries (Batteries are not included) and delivers 225W max output, with 2A fast charging via Type-C USB port. In addition, Smoant Ladon Mod is equipped with the advanced AI smart ANT-chip and buck-boost chip which will adjust to the best output automatically. It absolutely will bring you the best vaping experience. As for Ladon AIO Tank, it is the world's first 2in1 AIO Sub Ohm Tank with 4ml / 6ml capacity. Compatible with Sub-ohm coil and RBA coil, and for the RBA head, you can build not only the mesh coil but also the regular coil. (RBA Coil is not included) Moreover, the Smoant Ladon Kit is also featured with multiple protections to guarantee a safe vaping environment.
592
Rogue Hybrid Mechanical Vape Mod Clone $20.99
The Rogue Mechanical Vape Mod Clone is constructed from brass in 24mm diameter. It is powered by 1 x 18650 battery (Not included). It features 510 hybrid top cap and spring fire button. ![]() Original Kangvape Anarchist 60W 1500mAh MTL / DTL VW Box Mod Pod System Vape Starter Kit $2.88 The Original Kangvape Anarchist 60W VW Box Mod Pod System Vape Startet Kit is a compact and grip comfortable pod system device, which is powered by an integrated 1500mAh battery for a long time vape without worrying about running out of battery. Moreover, outputting up to 60W, the Kangvape Anarchist 60W Kit can be used with the included two type coils, and offer rapid and even heating to vaporize the e-juice or nicotine salts with ease. Kangvape Anarchist 60W Kit is constructed from durable and lightweight aluminum alloy, which can easily withstand to a certain extent drops. There is an intuitive oval ignition button on the control panel for easy operation. Below the button is a clear HD OLED display screen, relaying critical vape data back to the user. Anarchist 60W Kit also maintain a slew of protections for your safe vaping. On the other hand, Kangvape Anarchist 60W Pod has a maximum capacity of 4ml that can accept any formulation of e-liquid, refilling the modest capacity through the convenient side fill system. In addition, Anarchist 60W also includes 0.4ohm and 1.2ohm coil to cater to those that prefer DTL or MTL. Equipped convenient plug 'n' play coil installation. Kangvape Anarchist 60W Kit is also compatible market 510 thread tank. ![]() InnJoo Wash Free Alcohol Instant Hand Sanitizer inhibit Bacteria / Virus / COVID-19 $4.99 The InnJoo Wash Free Alcohol Instant Hand Sanitizer is easy to use, it can inhibit 99.99% of bacteria. It features natural ingredients, the content of alcohol is 75% which can inhibit Bacteria / Virus / COVID-19 effectively. The hand sanitizer that strengthens the skin's natural defense. Cleaning and protection without rinsing. ![]() Original Kangvape Anarchist VW Box Mod Pod System Vape Kit Replacement Mesh Coil Head(5 PCS) $6.99 The Original Kangvape Replacement Mesh Coil Head is designed for Kangvape Anarchist VW Box Mod Pod System Vape Kit as a replacement part. It features 1.2ohm coil resistance. 5 PCS / Pack. ![]() Original Kangvape Anarchist VW Box Mod Pod System Vape Kit Replacement Mesh Coil Head(5 PCS) $6.99 The Original Kangvape Replacement Mesh Coil Head is designed for Kangvape Anarchist VW Box Mod Pod System Vape Kit as a replacement part. It features 0.4ohm coil resistance. ![]() Original Teslacigs Invader GT VW Box Mod Pod System Vape Kit Replacement T-P1 Mesh Coil Head(5 PCS) $10.99 The Original Teslacigs Replacement T-P1 Mesh Coil Head is designed for Teslacigs Invader GT VW Box Mod Pod System Vape Kit as a replacement part. It features 0.2ohm coil resistance and power range from 30W to 50W. ![]() Original Teslacigs Invader GT VW Mod Pod System Vape Kit Replacement T-P2 Regular Coil Head(5 PCS) $10.99 The Original Teslacigs Replacement T-P2 Regular Coil Head is designed for Teslacigs Invader GT VW Box Mod Pod System Vape Kit as a replacement part. It features 0.6ohm coil resistance and power range from 13W to 23W. ![]() Original Teslacigs Invader GT VW Box Mod Pod System Vape Kit Replacement T-P3 Mesh Coil Head(5 PCS) $10.99 The Original Teslacigs Replacement T-P3 Mesh Coil Head is designed for Teslacigs Invader GT VW Box Mod Pod System Vape Kit as a replacement part. It features 0.8ohm coil resistance and power range from 10W to 15W. ![]() Original Teslacigs Invader GT VW Box Mod Pod System Vape Kit Replacement T-P4 Mesh Coil Head(5 PCS) $10.99 The Original Teslacigs Replacement T-P4 Mesh Coil Head is designed for Teslacigs Invader GT VW Box Mod Pod System Vape Kit as a replacement part. It features 0.3ohm coil resistance and power range from 20W to 35W. ![]() Original Smoant Pasito Mod Pod System Vape Kit Replacement Coil Connector Adapter(1 PC) $2.58 The Original Smoant Replacement Coil Connector Adapter is designed for Smoant Pasito 25W 1100mAh Mod Pod System Vape Kit as a replacement part.
593
Original Smoant Knight 80 TC VW Mod RBA Pod Kit / Cartridge Replacement Single Mesh Coil Head(3 PCS) $5.69
The Original Smoant Replacement Single Mesh Coil Head is designed for Smoant Knight 80 TC VW Mod RBA Pod System Vape Kit / Pod Cartridge as a replacement part. It features 0.3ohm coil resistance and power range from 50W to 65W. ![]() Original Smoant Knight 80 TC VW Mod RBA Pod Kit / Cartridge Replacement Dual Mesh Coil Head(3 PCS) $5.69 The Original Smoant Replacement Dual Mesh Coil Head is designed for Smoant Knight 80 TC VW Mod RBA Pod System Vape Kit / Pod Cartridge as a replacement part. It features 0.4ohm coil resistance and power range from 30W to 50W. ![]() Original Smoant Knight 80 TC VW Mod RBA Pod System Vape Kit / Cartridge Replacement RBA Coil Head $7.89 The Original Smoant Replacement RBA Coil Head is designed for Smoant Knight 80 TC VW Mod RBA Pod System Vape Kit / Pod Cartridge as a replacement part. It features 0.3~2.0ohm coil resistance. ![]() Original Smoant Knight 80 TC VW Mod RBA Pod System Kit Replacement Pod Cartridge with 0.3ohm & 0.4ohm Mesh Coils $11.38 The Original Smoant Replacement Pod Cartridge is designed for Smoant Knight 80 TC VW Mod RBA Pod System Vape Kit as a replacement part. It comes with a 0.3ohm mesh coil (50~65W) and a 0.4ohm dual mesh coil (30~50W) for you to choose. ![]() Original Smoant Ladon AIO 2in1 Tank Replacement Dual Mesh Coil Head(3 PCS) $8.88 The Original Smoant Replacement Dual Mesh Coil Head is designed for Smoant Ladon AIO 2in1 Tank as a replacement part. It features 0.15ohm coil resistance and power range from 70W to 80W. ![]() Original Smoant Ladon AIO 2in1 Tank Replacement Single Mesh Coil Head(3 PCS) $6.99 The Original Smoant Replacement Single Mesh Coil Head is designed for Smoant Ladon AIO 2in1 Tank as a replacement part. It features 0.16ohm coil resistance and power range from 65W to 80W. ![]() Original Smoant Ladon AIO 2in1 Tank Replacement RBA Coil Head $10.59 The Original Smoant Replacement RBA Coil Head is designed for Smoant Ladon AIO 2in1 Tank as a replacement part. It features two posts build deck for mesh coil or single regular coil build. ![]() Original Smoant Ladon AIO 2in1 Tank Replacement Straight Tank Tube $1.99 The Original Smoant Replacement Straight Tank Tube is designed for Smoant Ladon AIO 2in1 Tank as a replacement part. It features 4ml E-juice capacity and is made of glass. ![]() Original Smoant Ladon AIO 2in1 Tank Replacement Bubble Tank Tube $2.59 The Original Smoant Replacement Bubble Tank Tube is designed for Smoant Ladon AIO 2in1 Tank as a replacement part. It features 6ml E-juice capacity and is made of glass.
594
Vapeasy Armor Mech V2 BF Bottom Feeder Squonk Mechanical Box Vape Mod Clone $99,999.99
This Vapeasy Armor Mech V2 BF Bottom Feeder Squonk Mechanical Box Vape Mod Clone is made from Pure Gold. The pure gold Vapeasy Armor Mech V2 is luxurious and exclusive. It will make you be the super star and attracts all the people around you. Haha, This is April Fool's Day Prank of 2020! ![]() Taifun GT4 S DL RTA Clone $20.99 The Taifun GT4 S DL RTA Clone is constructed from 316 Stainless Steel (Body) and PSU (Tank Tube) in 23mm diameter. The RTA comes with a 3.5ml e-juice capacity tank. The air duct system bringing air flow via the poles in the chamber and adjustable AFC from the outside. And it can offer a slightly restricted direct lung hit. Multiple wire mounts allow for easy installation of the coil with versatility. Optimized for single coil builds, but can fit dual coils. ![]() Original Asvape Hita 30W 1000mAh Mech Mod RBA Pod System Vape Starter Kit $39.99 The Original Asvape Hita Kit is a pod device based on a mechanical mod design. It combines pod and mechanical design. The retro appearance of the mechanical lever combines the high-quality flavor of the POD device, which is portable and safe to operate. Asvape Hita Mech Pod Kit is powered by a built-in 1000mAh battery with max 30W output, which can easily support your long term requirement. And use Type-C charging port for fast charging, faster and safer, 1h can be fully charged, extra-long battery life. In addition, the intelligence chipset Reekbox developed by Asvape, which can automatically identify different coil resistance and match the best output power. Create perfect fogging effects, whether you are just getting started or advanced players can quickly master. Asvape Hita Mech Pod Kit also features indicator light with the fire button always inform the user as to the current battery levels. Asvape Hita Mech Pod comes with 3ml capacity. Convenient filling of juice liquid by opening the side silicone plug. Equipped side air inlet adjustment. The set comes with two mesh coils for DTL and MTL vaping. Asvape Hita is also compatible with RBA coil for DIY vaping. (RBA Coil is not included). ![]() Replacement Bottom Feeder Squonk Bottle for Armor Mech V2 Mechanical Box Vape Mod $1.99 The Replacement Bottom Feeder Squonk Bottle is designed for Armor Mech V2 Mechanical Box Vape Mod as a replacement part, it is made of silicone and comes with 4.5ml E-juice capacity. Replacement Bottom Feeder Squonk Bottle Kit for Armor Mech V2 Mechanical Box Vape Mod $13.99 The Replacement Bottom Feeder Squonk Bottle Kit is designed for Armor Mech V2 Mechanical Box Vape Mod as a replacement part, it is made of silicone (bottle) and stainless steel, POM, which comes with 4.5ml E-juice capacity. Replacement Top Cap Tank Tube + 510 Drip Tip Wave Set for Kayfun Prime 22mm Tank $7.98 The Replacement Top Cap Tank Tube + 510 Drip Tip Wave Set is designed for Kayfun Prime 22mm Tank as a replacement part,they are made of PEI and comes with a 2ml E-juice capacity. ![]() Original Coil Father King A11 Wire Spool for RDA / RTA /RDTA $3.78 The Original Coil Father King A11 Wire Spool is suitable for RBA / RDA / RTA / RDTA Vape Atomizer, it is made of Kanthal A1 and features 0.4 x 2 + 0.1 (26GA x 2 + 38GA), 5.6ohm/ft (5m/15ft). ![]() Original Coil Father King N81 Wire Spool for RBA / RDA / RTA /RDTA $4.38 The Original Coil Father King N81 Wire Spool is suitable for RBA / RDA / RTA / RDTA Vape Atomizer, it is made of Ni80 and features 0.4 x 2 + 0.1 (26GA x 2 + 38GA), 4.5ohm/ft (5m/15ft). ![]() Original Coil Father King N82 Wire Spool for RBA / RDA / RTA /RDTA $4.78 The Original Coil Father King N82 Wire Spool is suitable for RBA / RDA / RTA / RDTA Vape Atomizer, it is made of Ni80 and features 0.4 x 3 + 0.1 (26GA x 3 + 38GA), 3.0ohm/ft (5m/15ft). ![]() Original Coil Father King N84 Wire Spool for RBA / RDA / RTA /RDTA $4.99 The Original Coil Father King N84 Wire Spool is suitable for RBA / RDA / RTA / RDTA Vape Atomizer, it is made of Ni80 and features 0.3 x 4 + 0.1 (28GA x 4 + 38GA), 3.9ohm/ft (5m/15ft).
595
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Coil Father King N85 Wire Spool for RBA / RDA / RTA /RDTA $4.78
The Original Coil Father King N85 Wire Spool is suitable for RBA / RDA / RTA / RDTA Vape Atomizer, it is made of Ni80 and features 0.3 x 3 + 0.1 (28GA x 3 + 38GA), 5.3ohm/ft (5m/15ft). ![]() Original Coil Father King SS1 Wire Spool for RBA / RDA / RTA/RDTA $3.98 The Original Coil Father King SS1 Wire Spool is suitable for RBA / RDA / RTA / RDTA Vape Atomizer, it is made of 316SS and features 0.4 x 2 + 0.1 (26GA x 2 + 38GA), 3.2ohm/ft (5m/15ft). ![]() Original Coil Father King SS2 Wire Spool for RBA / RDA / RTA/RDTA $3.98 The Original Coil Father King SS2 Wire Spool is suitable for RBA / RDA / RTA / RDTA Vape Atomizer, it is made of 316SS and features 0.4 x 3 + 0.1 (26GA x 3 + 38GA), 2.1ohm/ft (5m/15ft). ![]() Original Coil Father King SS3 Wire Spool for RBA / RDA / RTA/RDTA $4.18 The Original Coil Father King SS3 Wire Spool is suitable for RBA / RDA / RTA / RDTA Vape Atomizer, it is made of 316SS and features 0.4 x 4 + 0.1 (26GA x 4 + 38GA), 1.6ohm/ft (5m/15ft). ![]() Original Coil Father King SS4 Wire Spool for RBA / RDA / RTA/RDTA $4.18 The Original Coil Father King SS4 Wire Spool is suitable for RBA / RDA / RTA / RDTA Vape Atomizer, it is made of 316SS and features 0.3 x 4 + 0.1 (28GA x 4 + 38GA), 2.9ohm/ft (5m/15ft). ![]() Original Augvape Narada Pro VW Mod Vape Kit / Cartridge Replacement MTL Coil Head(5 PCS) $9.82 The Original Augvape Replacement MTL Coil Head is designed for Augvape Narada Pro VW Mod Vape Kit as a replacement part, it features 1.0ohm coil resistance. ![]() Original Augvape Narada Pro VW Mod Vape Kit / Cartridge Replacement Mesh Coil Head(5 PCS) $9.82 The Original Augvape Replacement Mesh Coil Head is designed for Augvape Narada Pro VW Mod Vape Kit as a replacement part, it features 0.4ohm coil resistance. ![]() Original Augvape Narada Pro VW Mod Vape Kit / Cartridge Replacement RBA Single Coil Kit $7.55 The Original Augvape Replacement RBA Single Coil Kit is designed for Augvape Narada Pro VW Mod Vape Kit as a replacement part, it comes with 1.3 x 2.2mm air hole and single coil build deck. It fits for DIY vaping lovers. ![]() Original Augvape Narada Pro VW Mod Vape Kit Replacement Pod Cartridge with Airflow Adaptor & Gasket Seal $2.47 The Original Augvape Replacement Pod Cartridge is designed for Augvape Narada Pro VW Mod Vape Kit as a replacement part, it is made of PCTG, which features 3.7ml e-juice capacity, comes with airflow adaptor and gasket seal that convenient to adjust airflow and refill. ![]() Original ZhengDe KN90 Disposable 3-layer Earloop Face Mask Particulate Respirator Anti Bacteria / Virus / COVID-19(50 PCS) $34.99 The Original ZhengDe KN90 High-Quality Disposable 3-layer Earloop Face Mask Particulate Respirator can effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable.
596
Vapeasy Flash e-Vapor V4.5 MTL RTA Clone $19.99
The Vapeasy Flash e-Vapor V4.5 RTA Clone is a 23mm rebuildable tank constructed from stainless steel, and comes with a 6ml E-juice capacity PC tank tube. The RTA features dual post build deck and adjustable airflow for MTL vaping. This tank will provide fantastic mouth-to-lung vaping experience. ![]() Original Augvape Druga Narada 1100mAh Box Mod Pod System Vape Starter Kit original price $37.00, now only $25.58 The Augvape Druga Narada Box Mod Pod Systam Vape Starter Kit is a minimalist designed vaping pod system, which is powered by an 1100mAh rechargeable battery, comes with 2.8ml refillable juice pod capacity, and features a uniquely designed airflow control option. The Augvape Druga Narada presents a sleek and sharp design free of any screens, adjustment buttons, or airflow control rings viewable from the outside. Combined with an incredibly powerful integrated battery clocking in at 1100mAh, the Druga Narada Pod Kit can last throughout prolonged vaping sessions with ease as the Druga Druga Narada is free of features like screens or auxiliary buttons. Airflow for the Druga Narada is inlet via a slotted multihole airflow option but can be restricted by installing airflow inserts directly onto the pod based airflow control system. In addition, the Druga NARADA Pod Kit can hold up to 2.8ml of eJuice or nicotine salts within the confines of the refillable pod. Refills are facilitated by a side fill system stoppered by a silicone plug. ![]() OYT KN95 Disposable 4-layer Protective Masks Particulate Respirator Anti Bacteria / Virus / COVID-19(10 PCS) $22.99 Highly Effective Protection: KN95 4-layer masks with CE certification, universal fit for men and women. High Effectiveness: Made of water-repellent material, still offers high air permeability, ensures an ideal filter effect and a strong barrier against all kinds of dangerous bacteria. Applications: Protection against bacteria, smog, air pollution and dust. It can effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). For on the go, at home, hospitals, industry, hygiene area, etc. Skin-friendly: Naturally free of pollutants, thus also hypoallergenic. Particularly comfortable to wear even with sensitive skin. Offer perfect protection for you. ![]() Original Augvape Narada Pro VW Mod Vape Kit Replacement RBA Empty Pod Cartridge with Airflow Adaptor original price $14.78, now only $7.55 The Original Narada Pro RBA Pod Cartridge is designed for Narada Pro VW Mod Vape Kit as a replacement part. It utilizes 3.7ml large pod cartridge, which will reduce the refilling times. With an airflow adapter, it allows you to get an excellent vape experience you like. And it supports RBA coil with single coil design and a deck for easy operation. ![]() Original Augvape Druga Narada Box Mod Pod Vape Kit Replacement Mesh Coil Head(5 PCS) original price $15.00, now only $8.69 The Original Narada Replacement Mesh Coil Heads is designed for Druga Narada Box Mod Pod Vape Kit as a replacement part. It features 0.6ohm coil resistance and made of Kanthal material. 5 PCS / Pack. ![]() Original Augvape Druga Narada Box Mod Pod Vape Kit Replacement Coil Head - 316SS(5 PCS) original price $15.00, now only $8.69 The Original Narada Replacement Mesh Coil is designed for Druga Narada Box Mod Pod Vape Kit as a replacement part. It features 0.5ohm coil resistance and made of 316SS material. 5 PCS / Pack. ![]() Original Augvape Druga Narada Mod Pod Vape Kit Replacement RBA Rebuildable Kanthal Coils with Cartridge & 510 Adapter & RBA Deck original price $15.00, now only $8.99 The Original Narada RBA comes with a set of 20 prebuilt 1.0ohm kanthal coils, features a single coil configuration and post build deck design, which is designed for Augvape Druga Narada Mod Pod Vape Kit. It is perfect for extracting flavor and developing large satisfying clouds. Made of durable zinc-alloy, make the build deck moderately impact resistant. In addition, the rebuildable deck comes with an included 510 threaded adapter, you can measure the ohms or resistance. All of these make the Narada RBA easy to use and build.
597
SXK Integra MTL/DL RTA Clone original price $24.90, now only $11.99
The SXK Integra MTL / DL RTA Clone is a 22mm rebuildable tank atomizer with 4.2ml of juice capacity. It is constructed from 316 stainless steel (body) and PC (tank tube). It features recessed build deck, reduced evaporation chamber, and various side airflow combinations from tight MTL to restricted DL with the stock AFC ring. Without Logo. ![]() Original Yocan Hit 1400mAh Convection Heating Dry Herb Vaporizer Vape Starter Kit $29.99 The Original Yocan Hit Vaporizer Vape Kit is a portable combustion-free dry herb vaporizer. Designed for use with dry material. Yocan Hit Vaporizer is outfitted with advanced vaping technology and kept small and compact body, allowing you to enjoy the ideal balance of utility and portability. The Yocan Hit Vaporizer is powered by a built-in 1400mAh battery, provides sufficient power for the equipment, which ensures that you have the latest and fastest in data and power transfer with its USB-C charging capabilities. The Yocan Hit Vaporizer has a large and clear OLED screen that keeps you updated on all of the necessary info like temperature and battery level. However, it has an intelligent vibration function as well, so you don't need to look at the screen to know when it has reached the selected temperature. This makes for a convenient means of consuming herbs whilst you're on-the-go. ![]() Original Yocan Regen 25W 1100mAh Wax Vaporizer Vape Pen Starter Kit with QTC & QDC Coils $19.99 The Original Yocan Regen Wax Vape Kit is a compact and discreet vaporizer wax pen, sleek in design. Yocan Regen is powered by a built-in 1100mAh battery that ramps up fast with a 15-second continuous heat. The 10-second cut-off feature protects the battery from overheating and conserves the power. It is made for discreet sessions on the move with an easy to use one-button operation. You can click the single power button 5 times rapidly to turn the device on or to lock it for while it is not in use. The Regen battery has a variable voltage which allows you to pick a heat level that is right for the material you are loading. There are 3 different preset voltage settings at 3.0V, 3.5V, and 4.2V. There are 3 lights above the button that quickly tell you what setting you are on. ![]() Original Reewape AS303 Replacement 810 Drip Tip for 528 Goon / Reload /Kennedy /Wotofo Profile /Battle RDA $1.99 The Reewape AS303 Replacement 810 drip tip is made of resin. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. ![]() Original Reewape AS294 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / Reload RDA $2.39 The Reewape AS294 Replacement 810 drip tip is made of Glass and SS material, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original Reewape AS295 Replacement 510 Drip Tip for RDA/RTA/RDTA/Sub-Ohm Tank Atomizer $2.39 The Reewape AS295 Replacement 510 Drip Tip is made of Glass and SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Reewape AS296 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / Reload RDA $2.39 The Reewape AS296 Replacement 810 drip tip is made of Glass and SS material, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original Reewape AS298F Anti Split 810 Drip Tip for SMOK TFV8 / TFV12 Tank /Kennedy/Battle/Reload RDA $2.39 The Reewape AS298F Replacement Anti Split 810 drip tip is made of Resin and Stainless Steel, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original Reewape AS299 Replacement 360 Degree Rotatable 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank $2.39 The Reewape AS299 Replacement 360 Degree Rotatable 510 Drip Tip is made of SS material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Reewape AS301 Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $2.39 The Reewape AS301 Replacement 510 Drip Tip is made of Resin material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Yocan Regen Wax Vaporizer Vape Kit Replacement QTC Quartz Triple Coil Head(5 PCS) $10.99 The Yocan Regen Replacement QTC Coil is the perfect replacement coil for Yocan Regen Vaporizer Kit. It allows for more substantial cloud production while still maintaining a low power requirement for longer vaping sessions in between charges. Providing variable voltage settings, It allows you to maximize every ounce of power the battery has to offer. With this coil, you can enjoy powerful vapor production with decent flavor retention. What's more, Regen Quartz Triple Coil boasts a threaded design that makes it compatible with other Yocan products. It completes the series of quarts heating elements from the iconic quartz dual coils(QDC) to the ultra-powerful quad coils. 5 PCS / Pack.
598
Original Starss Alpha Mesh RDA original price $29.99, now only $24.99
The Original Starss Alpha Mesh RDA is constructed from Stainless Steel in 24mm Diameter and comes with perfect adjustable airflow designed. The Starss Alpha Mesh RDA adopts two 0.15ohm Mesh Coils and high-quality organic cotton for rich clouds and excellent taste. And Starss Alpha Mesh RDA possesses side intake honeycomb structure design. Other Color: ![]() Original Acrohm Fush Nano Mesh 15W 550mAh AIO Pod System Vape Starter Kit original price $39.99, now only $25.99 The Original Acrohm Fush Nano Mesh Pod System Vape Starter Kit is the upgrade of Fush Nano Pod Kit which maintains the color-changeable body, has added the new mesh coil and 510 adapter to match 510 thread tanks. With the innovative ACE chip, Fush Nano Mesh Kit is powered by 550mAh built-in battery and comes with a 1.8ml E-juice capacity cartridge, 1.0ohm resistance coil to meet your all day long vape. Furthermore, it features intelligently recognize and auto-adjust to the suitable power function that can prevent coils from burning out too soon. What's more, it is also compatible with the fush nano pod for great flavor. ![]() Original Asvape Hita Mech Mod RBA Pod Vape Kit Replacement Empty Pod Cartridge $5.68 The Original Asvape Hita Replacement Empty Pod Cartridge is designed for Asvape Hita Mech Mod RBA Pod Vape Kit as a replacement part. The Cartridge comes with 3.0ml E-juice capacity and features leak-proof side refill system. (Coils are not included). ![]() Original Asvape Hita Mech Mod RBA Pod Vape Kit Replacement DTL Mesh Coil Head(5 PCS) $14.99 The Original Asvape Hita Replacement DTL Mesh Coil Head is designed for Asvape Hita Mech Mod RBA Pod Vape Kit as a replacement part. It features 0.5ohm coil resistance. 5 PCS / Pack. ![]() Original Asvape Hita Mech Mod RBA Pod Vape Kit Replacement MTL Mesh Coil Head(5 PCS) $14.99 The Original Asvape Hita Replacement MTL Mesh Coil Head is designed for Asvape Hita Mech Mod RBA Pod Vape Kit as a replacement part. It features 1.0ohm coil resistance. 5 PCS / Pack. ![]() Original Asvape Hita Mech Mod RBA Pod Vape Kit Replacement RBA Coil Head $9.99 The Original Asvape Hita Replacement RBA Coil Head is designed for Asvape Hita Mech Mod RBA Pod Vape Kit as a replacement part. It fits for DIY vaping lovers, it supports single coil build on the two posts build deck. ![]() YFTK Taifun GT4 S GT 4 S IV S RTA Replacement Straight Tank Tube $1.99 The YFTK Replacement Straight Tank Tube is designed for Taifun GT4 S GT 4 S IV S RTA as a replacement part. Tha tank tube is made of glass and comes with 3.5ml E-juice capacity. ![]() [Ships from Battery Warehouse]Original Ampking AK4030 21700 3000mAh 35A High Drain Lithium Battery for Mod / Mod Kit(1 PC) $8.99 As the new professional energy supplier who focus on vaping industry, Ampking only use the A level cell 100% from the international certificated factory. Not merely the performance but also the safety under the vaping condition is what we are concerned more when our client using Ampking instrument. The Amazing AK4030 is our new product which using 21700 cell. With new technology AK4030 achieves typical capacity of 3000mAh and furthermore, a new Rapid Charging Mode which can charge with 4A leading to shortcut almost 50% charging time. Compare to the cell of 18650, the standard of Heating Test is from 80'C up to 130'C, AK4030 do with no explosion and no fire over 30 minutes. According to the data of overcharging test in Lab it do no fire and no explosion when charging with 20V and 18A, with 7 hours duration. More incredible, refer to short-circuit test it stand in no fire and no explosion with the resistance load of 100mW. ![]() Original Canuxi Disposable Surgical Medical Face Mask Respirator Anti Bacteria / Virus / COVID-19 - FDA Certification (50 PCS) $29.99 The Canuxi Disposable Surgical Medical Face Mask Particulate Respirator can effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. It is with adjustable nose bar helps the mask close to face when wearing. This product is made of non-woven fabrics through tabletting, heat sealing and packaging. It is suitable for covering the user' mouth, nose and jaw, and is used for wearing and blocking the exhalation or ejection of pollutants in the oral and nasal cavity in the general medical environment. This product is sterilized by ethylene oxide and has a service life of two years. See production date, expiration date or service life for details. It is recommended to replace it every 3 to 5 hours. With FDA Certification ![]() Original Dr. Mfyan KN95 3D Protective Face Mask Particulate Respirator Anti Bacteria /Virus/COVID-19 - FDA Certification (1 PC) $3.99 The Dr. Mfyan KN95 Three-Dimensional Protective Mask Particulate Respirator can effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. It is with adjustable nose bar helps the mask close to face when wearing. The Respirator is made of electrostatic meltblown cloth, pp spunbond non-woven cloth, electrostatic filter cotton. Adopting KN95 grade anti- particulate matter filtering technology and antibacterial environmental protection fabric, effectively filtering and protecting from PM2.5 air particulate matter and bacteria. It is suitable for protection against harmful particles such as dust, PM2.5 haze particles, influenza bacteria, droplets and so on. With CE & FDA Certification
599
The Rogue Mechanical Vape Mod Clone is constructed from brass in 24mm diameter. It is powered by 1 x 18650 battery (Not included). It features 510 hybrid top cap and spring fire button. Please Note: This mod is without anti-oxidation process, please don't touch it with hands directly. ![]() Original VapeOnly Space 60W VW Mod Pod System Vape Starter Kit original price $39.90, now only $29.99 The Original VapeOnly Space VW Box Mod Pod System Vape Kit is super portable with compact size to be carry-on. The VapeOnly Space kit is powered by an external single 18650 battery (Battery is not included) and can fire up to max 60W. The Space Mod Pod comes with a pod of 3.5ml E-liquid capacity and you can have DIY fun with the RBA base. (RBA Base is not included) Moreover, the VapeOnly Space kit features easy and precise airflow adjustment for MTL and restricted DL vaping. And the Space battery is able to intelligently adjust power to match coils, which you can enjoy the excellent vaping. The 0.69 inch screen and function buttons will make it easier and effective to work. ![]() Original Oumier Voocean 40 40W 1200mAh VW Box Mod Pod System Vape Starter Kit original price $38.00, now only $19.99 The Original Voocean 40 Kit is constructed from Zinc Alloy electroplating and TPU material. Powered by a built-in 1200mAh battery and comes with 3.5ml e-juice capacity, it will provide you long-term vaping. It looks marble-like with 2 of the colors having purple tints and one grey. Its ergonomic handle grip offers great and comfortable user experience. There is a circular activation button, two adjustment key and a USB port in the control panel, so it is easy to navigate screen. It comes with two coils: 0.3ohm Mesh Coil (35~40W) and 0.8ohm Mesh (10~15W) that can meet your different vaping needs. ![]() SXK BB 60W All-in-One Box Mod Kit Clone with USB Port original price $129.00, now only $104.89 The SXK Billet Box mod Clone is constructed from aluminum with an all-in-one design. It is powered by 1 x 18650 battery (not included) and maximum power output is 60W. The box mod is powered by Evolv DNA 60 chip. Without Logo. ![]() Original Nitecore D2 Dual-Slot Digicharger for 18650 / 17500 / 18350 / 16340 (RCR123) / 14500 / 10440 Ni-MH / Ni-Cd - AU Plug $23.79 The Original Nitecore D2 Dual-Slot Digicharger is a universal smart charger compatible with almost all cylindrical rechargeable batteries, thus eliminating the need to own several chargers. It is compatible with Li-ion / IMR / LiFePO4: 26650, 22650, 18650, 17670, 18490, 17500, 18350, 16340 (RCR123), 14500, 10440 Ni-MH / Ni-Cd: AA, AAA, AAAA, C. ![]() Original Nitecore D4 Four-Slot Digicharger for 18650 / 17500 / 18350 / 16340 (RCR123) / 14500 / 10440 Ni-MH / Ni-Cd - AU Plug $31.99 The Original Nitecore D4 Four-Slot Digicharger is a universal smart charger compatible with almost all cylindrical rechargeable batteries, thus eliminating the need to own several chargers. It is compatible with Li-ion / IMR / LiFePO4: 26650, 22650, 18650, 17670, 18490, 17500, 18350, 16340 (RCR123), 14500, 10440 Ni-MH / Ni-Cd: AA, AAA, AAAA, C. ![]() Original Nitecore SC2 3A Dual-Slot Quick Charge Intelligent Battery Charger for 18650 / 20700 / 21700 / 26500 / 26650 - AU Plug $35.99 The Original Nitecore SC2 battery charger is a universal, smart-charger compatible with almost all types of rechargeable batteries. It can charge a battery at up to 3A current in single slot. With all the protection, SC2 make charging faster and safer. It is compatible with Li-ion / IMR / LiFePO4:10340, 10350, 10440, 10500, 12340, 12500, 12650, 13450, 13500, 13650, 14350, 14430, 14500, 14650, 16500, 16340(RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490, 18500, 18650, 18700, 20700, 21700, 22500, 22650, 25500, 26500, 26650 / Ni-MH(NiCd): AA, AAA, AAAA, C, D. ![]() Original Nitecore SC4 6A Fout-Slot Quick Charge Intelligent Battery Charger for 18650 / 20700 / 21700 / 26500 / 26650 - AU Plug $49.99 The Original Nitecore SC4 is the next generation of SC2 charger with 4-slot and LCD screen. The charging current of SC4 Superb Charger is up to 6A in total and maximum charging current up to 3A in s single slot. Together by using LCD screen with MVA technology, it can display real-time information of charging status. More safer and easier to use. Moreover, with intelligent charging mode, Nitecore SC4 can automatically detect battery type and capacity, then select the appropriate charging current. In a word, the SC4 Superb Charger will give you a faster and safer charging experience. It is compatible with IMR / Li-ion / LiFePO4: 10440, 10500, 12340, 12500, 12650,13450, 13500, 13650, 14350, 14430, 14500, 14650,16500, 16340(RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490, 18500, 18650, 22500, 22650, 25500, 26500, 26650 / Ni-MH(NiCd): AA, AAA, AAAA, C, D. ![]() 510 to eGo Threading Connector Adapter for MVP / IPV Mini / eGrip Box Vape Mods $1.99 The 510 to eGo Threading Connector adapter is made of Stainless Steel, which allows the use of eGo threaded atomizers on your 510 Batteries or Box Vape Mods like MVP / IPV Mini / eGrip.
600
Original Ehpro Armor COD 21700 Semi-Mech Mechanical Vape Mod original price $39.99, now only $30.99
The Original Ehpro 21700 Mechanical Mod is a Semi-Mech Tube Mod, which succeeds in combining the clean lines of mechanics and the safety of electronics. Armor COD Semi-Mech Mod combines the timeless beauty of a mechanical mod. Its slim and delicate body hides a variety of protections, allowing you to safely vaping. The Ehpro Armor COD mod is powered by 1 x 18650 / 20700 / 21700 battery (Batteries are not included, with an included adapter). The Armor COD mod is semi-electro and therefore does not offer any adjustment, but it still has a switch. Good size, it allows you to turn off and on the mod with 5 presses. This switch also triggers the heating of the resistance. The Ehpro Armor COD mod supports a minimum coil resistance of 0.1ohm. But the most interesting thing is the light indicator present in this single button. The three small integrated LEDs accurately indicate the remaining autonomy in the battery! Thanks to Ehpro Armor COD Mod, you can have the charm of mechanical modification without facing potential risks. ![]() Stratum V5.1 VW Box Vape Mod Clone $259.99 The Stratum v5.1 VW Variable Wattage Box Vape Mod Clone is constructed from Imitation Ivory, which is powered by 1 x 18650 battery (Battery is not included) and is equipped with Evolv DNA 60 Chip set. Color as image shows, 44# Color. only one made, 1 of 1 ![]() SXK The Syclla MTL RTA Clone $19.90 The SXK The Scylla MTL RTA Clone is constructed from 316 Stainless Steel in 22mm Diameter. Showcasing a wide selection of airflow options, a removable reservoir that allows disassembly without spills, and an easy-to-build deck, the Scylla is truly a force to be reckoned with. The RTA supports MTL vaping experience. ![]() Original GeekVape Aegis 15W 800mAh Pod System Vape Starter Kit original price $29.90, now only $24.99 The Original Geekvape Aegis 15W Pod System Vape Starter Kit is the first IP-67 rated Type-C charging pod vape kit, it redefines shockproof technology with improved impact toughness, notch toughness, and fracture toughness. It is constructed from zinc alloy, leather, and rubber, and is powered by an internal 800mAh battery and is charged by a convenient USB Type-C port. Furthermore, the Geekvape Aegis Pod kit comes with a pod cartridge of 3.5ml E-juice capacity and two 0.6ohm mesh coils to meet your all day long vaping experience. ![]() SXK Billet Box 60W All-in-One VW Box Mod Vape Kit Clone with USB Port original price $129.00, now only $104.89 The SXK Billet Box mod Clone is constructed from aluminum with an all-in-one design. It is powered by 1 x 18650 battery (not included) and maximum power output is 60W. The box mod is powered by Evolv DNA 60 chip. This BB Box comes with USB port for firmware upgrading, setting modification and user customization via software. This BB Box with Logo. ![]() Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.69 The Replacement 510 Drip Tip is made of Resin material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original GeekVape Aegis Pod System Vape Kit / Cartridge Replacement G Coil Head(5 PCS) original price $11.90, now only $8.99 The GeekVape Replacement G Coil is designed for GeekVape Aegis 800mAh Pod System Vape Starter Kit / Pod Cartridge as a replacement part, which features 0.6ohm coil resistance. 5 PCS / Pack. ![]() Original GeekVape Aegis Pod System Vape Kit Replacement Empty Pod Cartridge(2 PCS) $3.90 The package and accessories may be various from batch to batch. The GeekVape Replacement Pod Cartridge is designed for GeekVape Aegis 800mAh Pod System Vape Starter Kit as a replacement part, which comes with 3.5ml E-juice capacity. Coils are not included. 2 PCS / Pack. ![]() Disposable 4-Layer Children Face Mask Particulate Respirator Anti Bacteria / Virus / COVID-19(1 PC) $2.99 The Disposable 4-Layer Children Face Mask Particulate Respirator Protective Mask could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. There are 4-ply protections for you to defend varous dust and virus. This is children Version. ![]() Disposable 4-Layer Adult Face Mask Particulate Respirator Anti Bacteria / Virus / COVID-19(1 PC) $2.99 The Disposable 4-Layer Adult Face Mask Particulate Respirator Protective Mask could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. There are 4-ply protections for you to defend varous dust and virus. This is Adult Version.
