302418
822
41
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Lost Art Goon V1.5 RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99
The Lost Art Goon V1.5 RDA Clone is constructed from aluminum (drip tip, cap) and stainless steel (base) in 24mm diameter. It features bridge clamp design for easy building and middle side adjustable air slots for airflow control.This item also has mmany color to choose. This RDA comes with bottom feeder pin. ![]() Speed Revolution Mini RDA Clone Rebuildable Dripping Atomizer with BF Pin $7.99 The Speed Revolution Mini RDA Clone is constructed from 316 stainless steel in 14mm diameter. The deck is dual post design for single coil building. The cap has a single airhole for side airflow. The POM drip tip is heat resistant for protecting your mouth from heat. This RDA comes with bottom feeder pin. ![]() Soul S RDA Clone Rebuildable Dripping Atomizer with BF Pin $9.59 The Soul S RDA Clone is constructed from stainless steel in 22mm diameter. It feature dual post build deck for single coil building, and dual air slots on the cap for smooth airflow. This RDA comes with bottom feeder pin.
42
Original Vapefly 8 in 1 Pre-built Coil Heating Wire Kit $3.99
The Original Vapefly 8 in 1 Coil Kit comes with 6 x Pre-built Mix Twisted Coil (0.45ohm), 6 x Pre-built Clapton Coil (0.85ohm), 6 x Pre-built Quad Coil (0.36ohm), 6 x Pre-built Alien Clapton Coil (0.45ohm), 6 x Pre-built Fused Clapton Coil (0.45ohm), 6 x Pre-built Tiger Coil (0.36ohm), 6 x Pre-built Hive Coil (0.50ohm), 6 x Pre-built Flat Twisted Coil (0.36ohm). These heating wires will be a good vaping choice for DIY. This product comes with 8 types of coils, totally 48 PCS in 1 pack. ![]() Original Coil Father 8 in 1 SS316 Coil Heating Wire Kit $5.49 The Original Coil Father 8 in 1 SS316 Coil Heating Wire Kit is made from SS316 wires and comes with 4 x Pre-built Staggered Coil (0.3ohm), 4 x Pre-built Clapton Coil (0.32ohm), 4 x Pre-built Quad Coil (0.2ohm), 4 x Pre-built Alien Clapton Coil (0.28ohm), 4 x Pre-built Fused Clapton Coil (0.3ohm), 4 x Pre-built Tiger Coil (0.26ohm), 4 x Pre-built Hive Coil (0.55ohm), 4 x Pre-built Super Clapton Coil (0.7ohm). These heating wires will be a good vaping choice for DIY. This product comes with 8 types of coils, totally 32 PCS in 1 pack.
43
Original Timesvape Dreamer Hybrid Mechanical Mod Original Price $95.00,Now Only $54.99
Limited quantity before the CNY holiday. Designed by Stan (USA), manufactured by Timesvape, the authentic Timesvape Dreamer Mod is a fantastic mech mod that is compatible with single 18650 / 20700 / 21700 battery (not included). The innovative multipoint contact pin increases conductivity. It also features reversible tube for customizable grip, floating battery adjustment and hybrid 510 connection. Dreamer is a cloud chaser's dream mod.This item also has many color to choose. 18650 battery adapter included.
44
Original ShenRay Aquarius Sub Ohm Tank Clearomizer $11.99
The Original ShenRay Aquarius Sub Ohm Tank is a 22mm tank with 4.5ml capacity. The tank adopts 0.4ohm coil which works well at 20 to 50W. The airflow is top-down style, which allows air get in via top airslots and travel down to the bottom of the coil. The PCC drip tip can protect your mouth from heat.This item also has many color to choose. ![]() Original Coil Father Q Subohm Tank Atomizer Standard Edition $6.49 The Original Coil Father Q Subohm Tank is a 22mm tank with leak-proof design. Inside the glass tank, there are two thick silicone o-rings to prevent e-liquid leaking. The tank adopts 0.5ohm coil head which work well at 30 to 100W. The POM drip tip can protect your mouth from heat.
45
Original Sigelei Vcigo K3 150W TC VW Variable Wattage Box Mod $35.99
The Original Sigelei Vcigo K3 Mod is a high-performance regulated device with sleek appearance. Powered by dual 18650 batteries (not included), Vcigo K3 is capable of outputting to maximum 150W. It also supports 2.5A quick charging. The atomizer resistance supported is from 0.05 to 3 ohm.This item also has many color to choose. ![]() Original Vandy Vape Pulse BF 80W TC VW Variable Wattage Squonk Box Mod $45.00 The Original Vandy Vape Pulse BF 80W Squonk Box Mod is a collaboration by VandyVape and Tony B. The new Pulse BF Mod is no longer a mechanical mod, but a regulated mod with built-in Gene chip, which is also used in Voopoo Drag and Alpha One. With 80W maximum output and 7ml bottom feeder bottle, Pulse BF 80W Mod will bring you better squonking experience. The mod is powered by a single 18650 (adapter included) or 20700 battery (battery not included).This item also has many color to choose. ![]() Original GeekVape Blade 235W TC VW Variable Wattage Box Mod Original Price $53.00,Now Only $38.99 The GeekVape Blade Mod, which maximizes the use of dual 18650, 20700 and 21700 batteries (series, not included) and the maximum power can reach 235W, is a versatile device with high performance. Utilizing advanced aircraft grade material, it is very light and durable. ![]() Original Vandy Vape Berserker MTL RDA Rebuildable Dripping Atomizer $35.90 The Original VandyVape Vandy Vape Berserker MTL RDA is an affordable high-end MTL RDA. It is 18mm in diameter. The deck comes with dual post for single coil build. The amazing thing is that Berserker MTL RDA has 6 different types of airflow accessories, which are replaceable and will bring you different flavor. The air enters from the side slots and finally blows the bottom of coil. What's more, the cap has 6 sizes of airholes, meaning there are lots of airflow configurations. Berserker MTL RDA comes with a 22mm and a 24mm beauty ring to fit different mods.This item also has many color to choose. This RDA comes with bottom feeder pin. ![]() Original GeekVape Blade 235W TC VW Variable Wattage Box Mod + Aero Tank Kit Original Price $67.90,Now Only $47.99 The Original GeekVape Blade Mod Kit consists of GeekVape Blade Mod and Aero Sub Ohm Tank. Mod: The GeekVape Blade Mod, which maximizes the use of dual 18650, 20700 and 21700 batteries (series, not included) and the maximum power can reach 235W, is a versatile device with high performance. Utilizing advanced aircraft grade material, it is very light and durable. Tank: The GeekVape Aero Sub Ohm Tank is a 25mm tank features convenient top filling and adjustable bottom airflow. It utilizes IM1 0.4ohm coil, which work well at between 40W and 60W, bringing you pure flavor and massive clouds. ![]() 810 Replacement Drip Tip for TFV12 Prince Tank / 528 Goon / Kennedy / Reload RDA $2.59 The 810 drip tip is made from resin with 15.6mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.This item also has many color to choose. ![]() Original Vapefly Ni80 Fused Clapton Coil for Galaxies MTL RDA $3.99 The Original Vapefly Fused Clapton Coil is made from Ni80 wires and features 0.5 ohm. This pre-coiled heating wire comes with 28GA + 44GA x 2 x 16 coils. This heating wire will be a good vaping choice for DIY. This product comes with 2 PCS in 1 pack. ![]() Original Vapefly Replacement Top Cap for Galaxies MTL RDA $4.99 The replacement top cap is made from PMMA with 24mm diameter. It is suitable for Original Vapefly Galaxies MTL RDA.This item also has many color to choose.
46
Goon Squonker Squonk Mechanical Box Mod Clone $13.99
The Goon Squonker Box Mod Clone is constructed from ABS, which is very lightweight. It adopts stainless steel 510 connector and contact, and 8ml food grade silicone bottle for squonking. The mod is powered by single 18650 battery (not included).This item also has many color to choose. ![]() Original IJOY Avenger Sub Ohm Tank Clearomizer $22.90 The Original IJOY Avenger Sub Ohm Tank is a 25mm tank with normally 3.2ml capacity and can be extended to 4.7ml with extra glass tube. The Avenger can be compatible with various coils and Mesh pre-made coil, which will bring you pure flavor and vapor production.This item also has many color to choose. ![]() Goon 1.5 RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99 The Goon 1.5 RDA Clone is constructed from aluminum (top cap) + stainless steel (base) in 22mm diameter. It features bridge clamp design for easy building and middle side adjustable airslots for airflow control.This item also has many color to choose. This RDA comes with bottom feeder pin. ![]() Goon Squonker Squonk Mechanical Box Mod Clone + Goon 1.5 RDA Clone Kit $18.99 The Goon Squonker Clone kit consists of Goon Squonker Box Mod Clone and Goon 1.5 RDA Clone.This item also has many color to choose. Mod: The Goon Squonker Box Mod Clone is constructed from ABS, which is very lightweight. It adopts stainless steel 510 connector and contact, and 8ml food grade silicone bottle for squonking. The mod is powered by single 18650 battery (not included). RDA: The Goon 1.5 RDA Clone is constructed from aluminum (top cap) + stainless steel (base) in 22mm diameter. It features bridge clamp design for easy building and middle side adjustable airslots for airflow control. The RDA comes with bottom feeder pin.
47
Original SMOKTech SMOK Mag Baby 1600mAh TC VW Variable Wattage Box Mod $67.00
The SMOK Mag Baby, the next generation of Mag, shaped like a handle of mini gun, is more smart and flexible. Every angle shows the exquisite aesthetics and real texture. The whole mod is ergonomically designed and you can hold it in a comfortable way. For this mod shaped like a gun-handle, you can feel a strong sense of conquering. The mod comes with built-in 1600mAh battery and the maximum output can reach 50W.This item also has many color to choose. ![]() Original Hellvape Anglo RDA Rebuildable Dripping Atomizer $35.99 The Original Hellvape Anglo RDA is a dual post deck dripper that has great flavor with its airflow system. It comes with 2 AFC rings. 24mm and 29 mm beauty ring. Monoblock one piece top cap all made from SS316 for solid best bold flavor! ![]() Original SMOKTech SMOK Resa Stick 2000mAh Mod + Resa Baby Tank Kit $62.00 The Original SMOKTech SMOK Resa Stick Kit consists of Resa Stick Mod and Resa Baby Tank.This item also has many color to choose. Mod: The SMOK Resa Stick is a newly designed pen style mod with built-in battery capacity of 2000mAh, whether from its usage or appearance or tactility, can provide you superior user experiences. The whole body of cobra resin design fully displays the beauty of the wild, filled with vitality and strength. Tank: The Resa Baby Tank is a 28mm tank (25mm at bottom), which is equipped with powerful V8 Baby cores and can bring you massive vapor. Besides, this tank employs bulb glass tube, which can enlarge the e-liquid to super large 7.5ml. ![]() Original SMOKTech SMOK Mag Baby 1600mAh TC VW Mod + TFV12 Baby Prince Tank Kit $85.00 The Original SMOKTech SMOK Mag Baby Kit consists of Mag Baby Mod and TFV12 Baby Prince Tank.This item also has many color to choose. Mod: The SMOK Mag Baby, the next generation of Mag, shaped like a handle of mini gun, is more smart and flexible. Every angle shows the exquisite aesthetics and real texture. The whole mod is ergonomically designed and you can hold it in a comfortable way. For this mod shaped like a gun-handle, you can feel a strong sense of conquering. The mod comes with built-in 1600mAh battery and the maximum output can reach 50W. Tank: The authentic SMOK TFV12 Baby Prince from SMOKTech is the upgraded version of TFV8 baby beast tank. Its included V8 baby-Q4 ,V8 baby-T12 red light coil and V8 Baby Mesh coil are compatible with baby beast coils. The new coils can produce denser clouds and purer flavor at the same wattage, which is an awesome improvement. These coils are newly designed, the light coil will emit beautiful light when you are vaping and the mesh coil has larger heating area to speed up heating process. Besides, this tank employs bulb glass tube, which can enlarge the e-juice capacity to 4.5ml. Every detail of TFV12 Baby Prince is the best guarantee for high-quality vaping. This tank is Standard Edition with 4.5ml capacity.
48
Kindbright Nato Mechanical Mod Clone $24.18
The Kindbright Nato Mechanical Mod Clone is a 25mm tube mod with non-hybrid top cap. It is constructed from stainless steel. The fire button comes with unique design, which is solid marble that gives you great feedback. The switch is spring loaded. The mech mod is compatible with a single 18650 / 20650 / 20700 / 21700 battery (not included). ![]() Original Tesla Punk Mini 85W TC VW Variable Wattage Box Mod $44.99 The Original Tesla Punk Mini is the slim version of Punk 220W mod, which is powered by single 18650 battery (not included) and the maximum output is 85W. It is constructed from zinc alloy, ABS and PC, and it still comes with the same steampunk style PCB, which you can see through the transparent PC panel. The portable size and retro looking will catch everyone's eyes when you show off this to your friends. ![]() Original Hellvape Dead Rabbit SQ RDA Rebuildable Dripping Atomizer with BF Pin Original Price $36.99,Now Only $24.69 The Original Hellvape Dead Rabbit SQ RDA is 22mm version of the Dead Rabbit and it is a single coil RDA. It comes with new features like a barrel lock, and the side airflow for Mouth to Lung Vaping. Its deck comes with dual post for single coil building, and the slide in top coil deck takes the guesswork out of pre-cutting your coil leads. This RDA comes with bottom feeder pin. Please note: the drip tip included is random color. ![]() Original SMOKTech SMOK Mag 225W TC VW Mod + TFV12 Prince Tank Kit Right-Handed Edition $62.89 The Original SMOKTech SMOK Mag 225W TC VW Mod Kit consists of SMOK Mag 225W Mod and TFV12 Prince tank. Mod: The SMOK Mag mod comes with innovative ergonomic design, which looks like a gun handle. By pressing the flower-shaped button, the battery case pops out for battery installation, you can even hear the pleasant sound that a real gun can offer you. Powered by dual 18650 batteries, Mag can deliver output up to 225W. There are three modes for you to choose from. Temp Mode can enhance consistency and taste of every puff. Watt Mode is perfect for cloud chasing. Memory Mode can be your intelligent partner. This Mag Mod is right-handed edition. Tank: The authentic SMOK TFV12 Prince Tank from SMOKTech is not only a powerful one but also an all-round sub ohm tank for daily use. The tank adopts 3 newest coils: V12 Prince Q4, V12 Prince X6 and V12 Prince T10, all of which have huge cloud and extremely dense flavor. It also has newly designed crown-style body and colorful Cobra resin drip tip. Besides, it uses convex glass tube, which effectively enlarged the capacity to 8ml. ![]() Original GAS Mods Decorative Ring for 22mm Diameter RDA / RTA / Sub Ohm Tank $7.99 The Original GAS Mods decorative vape ring is suitable for 22mm diameter atomizers. The inner diameter is 22mm. This product comes with 3 PCS as 1 set. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank $2.59 The replacement 510 drip tip is made from resin with 12.6mm height. It is suitable for all atomizers that fit 510 drip tip.
49
The Original Tesla Punk Mini is the slim version of Punk 220W mod, which is powered by single 18650 battery (not included) and the maximum output is 85W. It is constructed from zinc alloy, ABS and PC, and it still comes with the same steampunk style PCB, which you can see through the transparent PC panel. The portable size and retro looking will catch everyone's eyes when you show off this to your friends. ![]() Kindbright Nato Mechanical Mod Clone $24.18 The Kindbright Nato Mechanical Mod Clone is a 25mm tube mod with non-hybrid top cap. It is constructed from stainless steel. The fire button comes with unique design, which is solid marble that gives you great feedback. The switch is spring loaded. The mech mod is compatible with a single 18650 / 20650 / 20700 / 21700 battery (not included). ![]() Rogue Purity Hybrid Mechanical Mod Clone $21.99 The Rogue Purity Mechanical Mod Clone is constructed from stainless steel in 24mm diameter. It is powered by 1 x 18650 battery (not included). It features 510 hybrid top cap and spring fire button. ![]() Original Hellvape Dead Rabbit SQ RDA Rebuildable Dripping Atomizer w/ BF Pin Original Price $36.99,Now Only $24.69 Please log in to see the lower price. The Original Hellvape Dead Rabbit SQ RDA is 22mm version of the Dead Rabbit and it is a single coil RDA. It comes with new features like a barrel lock, and the side airflow for Mouth to Lung Vaping. Its deck comes with dual post for single coil building, and the slide in top coil deck takes the guesswork out of pre-cutting your coil leads. This RDA comes with bottom feeder pin. Please note: the drip tip included is random color. ![]() Kindbright Nato Mechanical Mod Clone + Culverin RDA Clone Kit $29.99 The Kindbright Nato Mech Clone Kit consists of Kindbright Nato Mechanical Mod Clone and Kindbright Culverin RDA Clone. Mod: The Kindbright Nato Mechanical Mod Clone is a 25mm tube mod with non-hybrid top cap. It is constructed from stainless steel. The fire button comes with unique design, which is solid marble that gives you great feedback. The switch is spring loaded. The mech mod is compatible with a single 18650 / 20650 / 20700 / 21700 battery (not included). RDA: The Kindbright Culverin RDA Clone is a 25mm atty constructed from stainless steel. The deck features dual post with teardrop post hole design. The positive pin is copper made, while the negative is SS. The side airflow offers great flavor and massive vapor production.
50
Original RiP Trippers and Digiflavor Pharaoh Dripper Tank RDA Atomizer Original Price $30.99,Now Only $13.99
The Pharaoh Dripper Tank is made in conjunction with the legendary RiP Trippers and Digiflavor, combining a cleverly designed 2ml tank reservoir, a dual post shelf style build deck, tremendous overall airflow, and a flavor and vapor intensive chamber. This unique dripper tank features a Clamp Style Build deck to support a variety of different coils. The airflow control is precise as it "clicks" into each airflow hole. ![]() Original Augvape Templar RDA Rebuildable Dripping Atomizer with BF Pin Original Price $27.90,Now Only $22.99 The Original Augvape Templar RDA is a 24mm low profile flavor chasing RDA that comes with many impressive features. The build deck adopts innovative Velocity Clamp System, which makes building very easy like Velocity deck but without needing to bend the coil. There is only a big titanium screw on top of the post, and the insulator is made of Zirconium dioxide, which is the top high-temperature resistant materials worldwide, corrosion-resistant, anti-oxidant, high hardness, non-volatile and no pollution. The whole deck is 24K gold plated for great conductivity. There are 6 airslots on both sides of top cap and you can get 3 layers of airflow by adjusting the internal cap. A frosted bullet shaped top cap is included, which can bring smooth side airflow (non-adjustable). The Templar RDA has an 810 Delrin drip tip and comes with 510 drip tip adapter. This RDA comes with bottom feeder pin. ![]() Original NCR 256W TC VW Variable Wattage Box Mod + RDA Kit with Super Cooker $48.99 The Original NCR Mod Kit consists of Nicotine Reinforcer 256W Mod and Nicotine Reinforcer RDA. The kit also includes a Super Cooker which is compliant with NCR RDA base. Mod: The Original NCR Mod is a sleek and ergonomically designed mod, which can reach 256W with triple 18650 batteries (not included). The NCR 256W Mod comes with multiple output modes, including NCR mode, VW, Ni-200, Ti-01, SS-316, Bypass and PTC (curve) mode. This versatile mod will definitely give you fantastic experience. RDA: The Original NCR RDA is a revolutionary atty that you do not need to build any coil on it. It is 24mm in diameter, constructed from food grade PC cap and stainless steel base. In the center of the deck, there is a 600,000 times cycle-use ceramic WAFER heater, featuring 0.4~0.5ohm resistance and is capable of self-cleaning within a short-time dry burning in 30~40W. About the Super Cooker: it is compatible with NCR RDA base. The cooker can used for dry herb / Sisha / wet leaf / weed / wax vaping. ![]() Original ThinkVape Thunder 200W TC VW Variable Wattage Box Mod $37.99 The Original ThinkVape Thunder Mod is versatile variable wattage mod that adopts ST 200C chip, which allows it to reach 200W with dual 18650 batteries (not included). Thunder comes with multiple output modes to meet different vapers' need. It supports VW, VT (NI, TI, SS), TCR, and BYPASS mode. The resistance range is from 0.1 to 3 ohm and the lowest one in TC mode is 0.15ohm.This item also has many color to choose. ![]() Original RiP Trippers and Digiflavor Pharaoh Dripper Tank RDA Atomizer Original Price $30.99,Now Only $13.99 The Pharaoh Dripper Tank is made in conjunction with the legendary RiP Trippers and Digiflavor, combining a cleverly designed 2ml tank reservoir, a dual post shelf style build deck, tremendous overall airflow, and a flavor and vapor intensive chamber. This unique dripper tank features a Clamp Style Build deck to support a variety of different coils. The airflow control is precise as it "clicks" into each airflow hole. ![]() Original Digiflavor Themis RTA Rebuildable Tank Atomizer Dual Coil TPD Version Original Price $35.90,Now Only $24.99 Inspired by GeekVape Zeus, the Original Digiflavor Themis RTA is a leak-proof RTA with innovative airflow transferring from top to bottom providing outstanding flavor. Themis is available with two versions: Dual Coil Version and Mesh Version. The quick access top cap makes refilling easy. The tank is capable of holding 2ml (TPD) e-juice.This item also has many color to choose. This one is Dual Coil Version, with build deck for single & dual coil. ![]() Original Digiflavor Themis RTA Rebuildable Tank Atomizer Mesh TPD Version Original Price $41.90,Now Only $27.99 Inspired by GeekVape Zeus, the Original Digiflavor Themis RTA is a leak-proof RTA with innovative airflow transferring from top to bottom providing outstanding flavor. Themis is available with two versions: Dual Coil Version and Mesh Version. The quick access top cap makes refilling easy. The tank is capable of holding 2ml (TPD) e-juice.This item also has many color to choose. This one is Mesh Version, with build deck for mesh wires.
51
Original Vandy Vape Pulse BF 80W TC VW Squonk Box Mod Original Price $65.00,Now Only $46.99
The Original Vandy Vape Pulse BF 80W Squonk Box Mod is a collaboration by VandyVape and Tony B. The new Pulse BF Mod is no longer a mechanical mod, but a regulated mod with built-in Gene chip, which is also used in Voopoo Drag and Alpha One. With 80W maximum output and 8ml bottom feeder bottle, Pulse BF 80W Mod will bring you better squonking experience. The mod is powered by a single 18650 (adapter included) or 20700 battery (battery not included). ![]() Original Vandy Vape Pulse BF 80W TC VW Squonk Box Mod with 30ml Refill Bottle Original Price $70.00,Now Only $50.99 The Original Vandy Vape Pulse BF 80W Squonk Box Mod is a collaboration by VandyVape and Tony B. The new Pulse BF Mod is no longer a mechanical mod, but a regulated mod with built-in Gene chip, which is also used in Voopoo Drag and Alpha One. With 80W maximum output and 8ml bottom feeder bottle, Pulse BF 80W Mod will bring you better squonking experience. The mod is powered by a single 18650 (adapter included) or 20700 battery (battery not included). This mod comes with a 30ml refilling bottle. The color of the bottle is to be confirmed. ![]() Original SXmini G Class 200W TC VW Variable Wattage Box Mod Limited Edition $219.99 The Original SXMini G Class Box Mod adopts the YiHi SX550J chip set which provides maximum power to 200W, along with accuracy, and sophistication combined with an ergonomic chassis, unique joystick control, beautiful and robust display technology, and an expertly machined chassis. The box mod is powered by 2 x 18650 batteries (not included). Firing in variable wattage and temperature control mode, this 200 watt vape MOD was crafted to accommodate up to 31mm tanks and RDAs with flawless execution.
52
Original Dovpo VEE VV Variable Voltage Box Mod $59.99
The Original DOVPO VEE Mod is a collaboration by 1vp.me and Dovpo, which is a variable voltage box mod powered by dual 18650 batteries (not included). VEE allows you to regulate voltage from 1 to 8V, and the voltage value can be clearly seen on the display screen. VEE has been added safety features and regulation capabilities and cut the bells and whistles from a regulated device.This item also has many tom choose. ![]() YFTK Chanupa Stacked Hybrid Mechanical Mod Clone $39.99 The YFTK Chanupa Mechanical Mod Clone is constructed from stainless steel and brass. The tube mod has many carved patterns on it. It is able to be stacked with extra extension tube, which allows it to use dual 18650 batteries; When it is not stacked, single 18650 battery can make this mod work (batteries not included).This item also has many tom choose. ![]() Original Vapor Storm Puma 200W TC VW Variable Wattage Box Mod $33.99 The Original Vapor Storm Puma Mod has sleek appearance and is versatile with its multiple output modes. Powered by dual high rate 18650 batteries (not included), it is able to reach 200W in wattage mode. In temperature control mode, Puma supports Ni, Ti, SS316 and TCR. In bypass mode, the output can even be higher than 200W and the maximum is 230W. Puma will definitely provide you with different vaping experience.This item also has many tom choose. ![]() Tower Mods Desolator Z Hybrid Mechanical Mod Clone + Axis RDA Clone Kit $18.99 The mod kit consists of Tower Mods Desolator Z Mechanical Mod Clone and Axis RDA Clone.This item also has many tom choose. Mod: The Tower Mods Desolator Z Mechanical Mod Clone is constructed from brass with hybrid connection. The mod features artistic patterns almost on the whole tube, brass connection for better conductivity and magnetic fire button. The mod is powered by single 18650 battery (not included). RDA: The Axis RDA Clone is constructed from brass (cap) and stainless steel (base) in 24mm diameter. The build deck features triple post design, T shaped center post for easy building and 8mm deep juice well for juice storage. The airflow can be adjusted with multiple airflow configuration, from zero to maximum (5 holes open). Heat resistant Ultem wide bore drip tip is included. ![]() Original SMOKTech SMOK Replacement Bulb Pyrex Glass Tube 2 $2.99 The replacement Bulb Pyrex Glass Tube #2 from SMOKTech is capable of holding 8ml of e-juice. It is suitable for SMOK TFV12 Prince Tank.
53
Original GeekVape Blade 235W TC VW Variable Wattage Box Mod Original Price $53.90,Now Only $38.99
The GeekVape Blade Mod, which maximizes the use of dual 18650, 20700 and 21700 batteries (series, not included) and the maximum power can reach 235W, is a versatile device with high performance. Utilizing advanced aircraft grade material, it is very light and durable. ![]() Original SXmini MX Class 75W TC VW Variable Wattage Box Mod $149.99 The Original SXmini MX Class Mod is powered by the YiHi SX480J-BT chipset and has stable performance at between 5 and 75W with single 18650 battery (not included). MX Class provides several modes to satisfy different vapers' need and you can also DIY your favorite curve to get the best flavor. Instead of using two buttons to adjust the setting, MX Class uses a joystick, which makes the operation much easier. With the compact size and outstanding performance, MX Class is a good device to vape. ![]() Original Vapefly Horus RTA Rebuildable Tank Atomzier Original Price $35.99,Now Only $24.99 The Original Vapefly Horus RTA is a 25mm tank with 4ml capacity. It features a unique "b" airflow system that makes airflow surrounding the coil to product best flavor. It can be easily refilled from the top and with top airflow there is no leakage. The deck is 24K gold plated and designed for single coil build. The tank is compatible with both 810 and 510 drip tip. The resin drip tip included is random color. ![]() Original SMOKTech SMOK V-Fin 160W 8000mAh TC VW Mod + TFV12 Big Baby Prince Tank kit $60.99 The Original SMOKTech SMOK V-Fin Kit consists of V-Fin Mod and TFV12 Big Baby Prince Tank. Mod: The Original SMOK V-Fin Mod has built-in battery with amazing capacity of 8000mAh, which can provide you with long time vaping experience. It can fire from 6 to 160W in wattage mode, and also support temperature mode. With the ergonomically designed fire key and high-definition OLED screen, it will be comfortable to use V-Fin Mod. Tank: The Original SMOK TFV12 Big Baby Prince Tank is a 28mm tank with 6ml capacity. The newly designed top cap has a patented locking mechanism, simpley press this button then you can open the cap. Besides, this design can effectively avoid accidently opening of top cap and leaking of e-juice. TFV12 Big Baby Prince is combined with innovative V8 Baby cores, which will bring you denser cloud and purer flavor. ![]() Original SMOKTech SMOK Devilkin 225W TC VW Mod + TFV12 Prince Tank kit $60.99 The Original SMOKTech SMOK Devilkin Kit consists of Devilkin Mod and TFV12 Prince Tank. Mod: The Original SMOK Devilkin Mod can reach maximum 225W output with dual 18650 batteries (not included). It has upgraded user interface and 1.3 inch screen with high-definition that displays more specific data. Snake pattern on the back side is in harmony with the cobra drip tip, fully presenting your unique personal taste and charm. Tank: The Original SMOK TFV12 Prince Tank from SMOKTech is not only a powerful one but also an all-round sub ohm tank for daily use. The tank adopts 2 newest coils: V12 Prince Q4 and V12 Prince T10, all of which have huge cloud and extremely dense flavor. It also has newly designed crown-style body and colorful Cobra resin drip tip. Besides, it uses convex glass tube, which effectively enlarged the capacity to 8ml. ![]() Original GeekVape Blade 235W TC VW Variable Wattage Box Mod + Aero Tank Kit Original Price $67.90,Now Only $47.99 The Original GeekVape Blade Mod Kit consists of GeekVape Blade Mod and Aero Sub Ohm Tank. Mod: The GeekVape Blade Mod, which maximizes the use of dual 18650, 20700 and 21700 batteries (series, not included) and the maximum power can reach 235W, is a versatile device with high performance. Utilizing advanced aircraft grade material, it is very light and durable. Tank: The GeekVape Aero Sub Ohm Tank is a 25mm tank features convenient top filling and adjustable bottom airflow. It utilizes IM1 0.4ohm coil, which work well at between 40W and 60W, bringing you pure flavor and massive clouds.
54
Original SXmini G Class 200W TC VW Variable Wattage Box Mod Limited Edition $299.99
The Original SXMini G Class Box Mod adopts the YiHi SX550J chip set which provides maximum power to 200W, along with accuracy, and sophistication combined with an ergonomic chassis, unique joystick control, beautiful and robust display technology, and an expertly machined chassis. The box mod is powered by 2 x 18650 batteries (not included). Firing in variable wattage and temperature control mode, this 200 watt vape MOD was crafted to accommodate up to 31mm tanks and RDAs with flawless execution. ![]() Original Sigelei Snowwolf Xfeng 230W TC VW Variable Wattage Box Mod Original Price $69.90,Now Only $57.99 The Original Sigelei Snowwolf Xfeng 230W Box Mod features persistence of the vigorous design, representing the wolf temperament. The stylish front and back panel reflects the Zodiac constellation. Powered by dual 18650 batteries (not included), the Xfeng is capable of delivering power up to 230W. Temperature control mode supports SS / Ti1 / Ni200 / TCR modes. The mod supports atomizer resistance from 0.05 to 3.0ohm.This item also has many color to choose. ![]() Original Vaptio Wall Crawler 80W TC VW Variable Wattage Box Mod $44.99 The Original Vaptio Wall Crawler Mod features the newest supercharger technology from Vaptio, which is a rapid heating system that will give you instant respond when you press the fire button. It fires in 0.005s every time the button is pressed. Powered by single 18650 battery (not included), it can be regulated from 7 to 80W. Coming with multiple modes to vape, Wall Crawler will provide much fun of vaping. ![]() Original Vaptio Super Bat 220W TC VW Variable Wattage Box Mod $64.99 The Original Vaptio Super Bat Mod is a versatile regulated mod that can be varied from 1 to 220W with dual 18650 batteries (not included). The chassis utilizes Batman-theme design, which is cool and stylish. It also comes other cool features, like the LED lighting system, 1.3inch HD screen with fingertip control, which makes operation much easier. ![]() Original Joyetech ESPION Solo 80W TC VW Variable Wattage Box Mod $44.99 The Joyetech ESPION Solo Mod Features a particularly responsive touch screen, which is very convenient for you to operate. It is the first box mod that compatible with 21700 battery, but still works with 18650 battery as well (battery not included). ESPION Solo is capable of outputting up to 80W, providing you with huge vapor production. ![]() Original Vapefly Horus RTA Rebuildable Tank Atomzier $38.99 The Original Vapefly Horus RTA is a 25mm tank with 4ml capacity. It features a unique "b" airflow system that makes airflow surrounding the coil to product best flavor. It can be easily refilled from the top and with top airflow there is no leakage. The deck is 24K gold plated and designed for single coil build. The tank is compatible with both 810 and 510 drip tip.This item also has many color to choose. The resin drip tip included is random color. ![]() YFTK Karma RDA Rebuildable Dripping Atomizer Clone with BF Pin $17.99 The YFTK Karma RDA Clone is constructed from 316 stainless steel in 25mm diameter. The build deck has dual post for single coil build. The air accesses the chamber via bottom airhole and travels up to the bottom of the coil. The top cap is made of Delrin. The RDA comes with bottom feeder pin and decorative ring. ![]() Original Suorin Vagon 12W 340mAh Starter Kit $39.99 The Original Suorin Vagon Kit is a portable ergonomically designed starter kit with pod vaporizer system. It utilizes a 340mAh built-in battery and 2.5ml refillable Vagon pods. With the draw-to-activate design, you can just take a puff without any fire button. The pod can be filled with Nic salt or regular e-liquid. ![]() Original Sense Linkedvape Arrow 230W TC VW Variable Wattage Box Mod + Herakles 3 Tank Kit $99.99 The Original Sense Linkedvape Arrow Kit consists of Sense Linkedvape Arrow Mod and Herakles 3 Tank. Mod: The Sense Linkedvape Arrow Box Mod is equipped with Cortex M4 chipset and the wattage can be varied from 7 to 230W with dual 18650 batteries (not included). There are 6 LED lights sitting on top of the mod, which shine brightly when pressing the button to vape. You can find 5 buttons on the mod, which are the fire button, LED light trigger button, up and down button, and a menu button. The full-color TFT LCD screen displays necessary information like the wattage, temperature, atomizer resistance, individual battery life display, and also has a Real Time Clock (RTC) display. Tank: The Original Sense Herakles III Sub Ohm Tank is a 24mm tank with 4.5ml juice capacity. It is the upgraded version of legendary Herakles tank. The Herakles 3 features flip hinged top fill system and adjustable bottom airflow. It is compatible with V-Jet coils, with 0.2ohm, 0.4ohm and 0.6ohm resistance for your option. ![]() Original Vaptio Wall Crawler 80W TC VW Variable Wattage Box Mod + Throne Tank Kit $63.99 The Original Vaptio Wall Crawler Kit consists of Wall Crawler Mod and Throne Tank. Mod: The Original Vaptio Wall Crawler Mod features the newest supercharger technology from Vaptio, which is a rapid heating system that will give you instant respond when you press the fire button. It fires in 0.005s every time the button is pressed. Powered by single 18650 battery (not included), it can be regulated from 7 to 80W. Coming with multiple modes to vape, Wall Crawler will provide much fun of vaping. Tank: The Vaptio Throne Tank is a 23.5mm sub ohm tank with 2ml juice capacity. It features Hotswap technology for easy coil-installation, convenient top filling and adjustable bottom airflow. The tank adopts 0.25ohm D1 coil and 1.2ohm D2 coil for pure flavor and smooth vapor. ![]() Original Vaptio Super Bat 220W TC VW Variable Wattage Box Mod + Frogman Tank Kit $69.99 The Originalc Vaptio Super Bat Kit consists of Super Bat Mod and Frogman Tank. Mod: The Original Vaptio Super Bat Mod is a versatile regulated mod that can be varied from 1 to 220W with dual 18650 batteries (not included). The chassis utilizes Batman-theme design, which is cool and stylish. It also comes other cool features, like the LED lighting system, 1.3inch HD screen with fingertip control, which makes operation much easier. Tank: The Original Vaptio Frogman Tank is a 26.5mm tank with 5ml juice capacity. It features convenient top filling and bottom airflow. The tank adopts 0.15ohm Frogman-W8 Coil and 0.4ohm Frogman-W2 Coil for massive clouds and distinct flavor. ![]() Original Joyetech ESPION Solo 80W TC VW Variable Wattage Mod + ProCore Air Tank Kit $63.99 The Original Joyetech ESPION Solo Kit consists of Joyetech ESPION Solo Mod and ProCore Air Tank. Mod: The Joyetech ESPION Solo Mod Features a particularly responsive touch screen, which is very convenient for you to operate. It is the first box mod that compatible with 21700 battery, but still works with 18650 battery as well (battery not included). ESPION Solo is capable of outputting up to 80W, providing you with huge vapor production. Tank: The Joyetech ProCore Air Tank Features the innovative push-to-open top filling system, which allows user to fill the e-liquid with great convenience. Having a plenty of options for you to choose, the ProC series heads are all capable: from direct lung or mouth to lung, from massive vapor production to optimal flavor. Meanwhile, it is totally detachable and easy to clean. ![]() Original SMOKTech SMOK Mag 225W TC VW Mod + TFV12 Prince Tank Kit Right-Handed Edition $64.99 The Original SMOKTech SMOK Mag 225W TC VW Mod Kit consists of SMOK Mag 225W Mod and TFV12 Prince tank. Mod: The SMOK Mag mod comes with innovative ergonomic design, which looks like a gun handle. By pressing the flower-shaped button, the battery case pops out for battery installation, you can even hear the pleasant sound that a real gun can offer you. Powered by dual 18650 batteries, Mag can deliver output up to 225W. There are three modes for you to choose from. Temp Mode can enhance consistency and taste of every puff. Watt Mode is perfect for cloud chasing. Memory Mode can be your intelligent partner. This Mag Mod is right-handed edition. Tank: The Original SMOK TFV12 Prince Tank from SMOKTech is not only a powerful one but also an all-round sub ohm tank for daily use. The tank adopts 3 newest coils: V12 Prince Q4, V12 Prince X6 and V12 Prince T10, all of which have huge cloud and extremely dense flavor. It also has newly designed crown-style body and colorful Cobra resin drip tip. Besides, it uses convex glass tube, which effectively enlarged the capacity to 8ml. ![]() Ni90 Clapton Pre-built Coil Heating Resistance Wire $2.99 The pre-built coil is made from Nichrome 90 wires and comes with 0.4 x 2 + 36 gauge. This heating wire will be a good vaping choice for DIY. This product comes with 6 PCS in 1 pack.
55
Это ж надо столько гумна наворотить?!
56
Original SMOKTech SMOK V-Fin 160W 8000mAh TC VW Variable Wattage Box Mod $48.99
The Original SMOK V-Fin Mod has built-in battery with amazing capacity of 8000mAh, which can provide you with long time vaping experience. It can fire from 6 to 160W in wattage mode, and also support temperature mode. With the ergonomically designed fire key and high-definition OLED screen, it will be comfortable to use V-Fin Mod.This item also has many color to choose. ![]() Original SMOKTech SMOK Devilkin 225W TC VW Variable Wattage Box Mod $47.99 The Original SMOK Devilkin Mod can reach maximum 225W output with dual 18650 batteries (not included). It has upgraded user interface and 1.3 inch screen with high-definition that displays more specific data. Snake pattern on the back side is in harmony with the cobra drip tip, fully presenting your unique personal taste and charm.This item also has many color to choose. ![]() Original FreeMax Fireluke Mesh Sub Ohm Tank Atomizer Resin Version $26.99 The Original FreeMax Fireluke Mesh Sub Ohm Tank features 24mm diameter, 3ml juice capacity, convenient top fill design, adjustable bottom airflow, and most importantly the new mesh coil. The new mesh coil comes with 0.15ohm, supporting 40W to 90W power. It has wide contact surface between organic cotton and coil, which allows it to burn evenly and absorb e-juice effectively, giving you more intensive flavor and vapor production.This item also has many color to choose. ![]() Original FreeMax Fireluke Mesh Sub Ohm Tank Atomizer Carbon Fiber Version $27.99 The Original FreeMax Fireluke Mesh Sub Ohm Tank features 24mm diameter, 3ml juice capacity, convenient top fill design, adjustable bottom airflow, and most importantly the new mesh coil. The new mesh coil comes with 0.15ohm, supporting 40W to 90W power. It has wide contact surface between organic cotton and coil, which allows it to burn evenly and absorb e-juice effectively, giving you more intensive flavor and vapor production.This item also has many color to choose. ![]() Original 528 Custom Lost Art Goon V1.5 RDA Rebuildable Dripping Atomizer with BF Pin Original Price $79.99,Now Only $49.99 The Original 528 Custom Lost Art Goon 1.5 Style RDA is a classic 24mm dripper for cloud-chasing. It features bridge clamp design for easy building and middle side adjustable air slots for airflow control. Lost Art x 528 Custom Logos is engraved on drip tip, sleeve, base, deck. This RDA comes with bottom feeder pin and a special bag with Lost Art x 528 logos.This item also has many color to choose. ![]() Replacement Top Cap for Hadaly RDA Atomizer Clone $2.99 The replacement top cap sleeve is made from PMMA and is suitable for the Hadaly RDA Clone.This item also has many color to choose.
57
Original Soomook Hato K-One 238W TC VW Variable Wattage Box Mod $47.99
The Original Soomook Hato K-One Mod is a high end regulated device that is powered by ST chipset. With dual 18650 batteries (not included), the wattage can be varied from 5 to 238W. Hato K-One supports various modes, like power mode, temperature control mode, memory mode and bypass mode. The resistance range is 0.1 to 5ohm (VW), 0.06 to 1.3ohm (TC). The 510 connector is spring-loaded to match most atomizers in the market. ![]() Kindbright FL RTA Rebuildable Tank Atomizer Clone with BF Pin $14.99 The Kindbright FL RTA Clone is constructed from 316 stainless steel in 24mm diameter. It features dual post deck for single coil and middle side adjustable airflow. The deck has notches for easy installation of the coil. The tank is large and allows to take about 30 puffs per drip. This RTA comes with bottom feeder pin. ![]() Kindbright Sherman RDA Rebuildable Dripping Atomizer Clone with BF Pin $17.99 The Kindbright Sherman RDA Clone is constructed from 316 stainless steel in 25mm diameter. It comes with clamp style dual post build deck and redirected bottom airflow. The RDA is suitable for different types of fancy coils. The air accesses the tunnel via bottom airslots and travel up to the bottom of the coils, which provides smooth airflow and nice flavor.This item also has many color to choose. ![]() Original Hellvape Aequitas RDA Rebuildable Dripping Atomizer with BF Pin Original Price $37.00,Now Only $24.69 The Original Hellvape Aequitas RDA is a 24mm RDA with gold plated postless raised style deck. The post hole is 2.5mm by 2.5mm and can be compatible with any build. Aequitas comes with both top and bottom airflow, you can flip barrel upside down to make your choice. The RDA has an 810 resin drip tip and 810 Delrin drip tip, 510 drip tip adapter is also included. This RDA comes with bottom feeder pin. ![]() Original Smokjoy Knights 2200mAh Starter Kit $28.99 The Original Smokjoy Knights Kit is an unregulated device with built-in 2200mAh battery. It adopts top push-style to fill the atomizer and bottom power button. Press the Power Button the LED will light gradually and different color means different battery status. The tank utilizes 0.16ohm and 0.3ohm coil head for great flavor and massive cloud.This item also has many color to choose. The SMOK TFV8 Baby Coil Heads are compatible with Smokjoy Knights Kit. ![]() Original Coil Father Pbag Vape Bag for E-cigarette Mod / Atomizer / Accessory $3.99 The Original Coil Father Pbag is a vaper pocket bag with great space yet small and easy carrying. You can put one set of your vape products in it. A good setup will be: a box mod, an atomizer, some DIY tool / accessories, battery, and a bottle of 30ml liquid.This item also has many color to choose. ![]() Original Coil Father Pre-made Coil F Ni80 Heating Wire for DIY $6.99 The Original Coil Father Pre-made Coil F Ni80 Coil comes with 3mm bore and 4 wraps. This heating wire will be a good vaping choice for DIY. This product comes with 10 PCS in 1 pack.This item also has many versions to choose. ![]() Original Coil Father Lazy Cotton for RDA / RTA / RDTA $5.59 The Lazy Cotton is designed to give you an amazingly tasty vaping experience. It is 100% organic cotton, which has been treated with a thorough purification process to remove impurities and natural oil. There is no chemically treated, bleached, or pigmented cotton used. It is precut and easy to use. This product comes with 20 PCS cotton in 1 pack. ![]() Original Smokjoy Replacement Coil Head for Knights Kit / SMOK TFV8 Baby Tank $10.99 The Original Smokjoy Replacement Coil Head features 0.3ohm resistance for 3.7V direct output. It is suitable for authentic Smokjoy Knights Kit and SMOK TFV8 BabyTank.This item also has a 0.16ohm version to choose. This product comes with 5 PCS in 1 pack.
58
The Kindbright Sherman RDA Clone is constructed from 316 stainless steel in 25mm diameter. It comes with clamp style dual post build deck and redirected bottom airflow. The RDA is suitable for different types of fancy coils. The air accesses the tunnel via bottom airslots and travel up to the bottom of the coils, which provides smooth airflow and nice flavor.This item also has many color to choose. ![]() YFTK Flash e-Vapor V4.5 RTA Rebuildable Tank Atomizer Clone $22.99 The YFTK Flash e-Vapor V4.5 RTA Clone is a 23mm rebuildable tank constructed from 316 stainless steel. The RTA features dual post build deck and adjustable airflow for MTL vaping. This tank will provide fantastic mouth-to-lung vaping experience. ![]() YFTK Warhead RDA Rebuildable Dripping Atomizer Clone with BF Pin $21.99 The YFTK Warhead RDA Clone has a beast size of 30mm and is constructed from 316 stainless steel. The build deck comes with triple post design for dual coil building. The top cap has a wide airslot and five airholes on both sides for multiple airflow configuration. The beveled Delrin drip tip can prevent the juice spitting out. This RDA comes with bottom feeder pin. ![]() Original Freemax Replacement Coil Head for Fireluke Mesh Sub Ohm Tank $13.99 The replacement coil head features 0.15ohm resistance, which works well at between 40 and 90W. It is suitable for Original Freemax Fireluke Mesh Sub Ohm Tank. It has wide contact surface between organic cotton and coil, which allows it to burn evenly and absorb e-juice effectively, giving you more intensive flavor and vapor production. This product comes with 5PCS in 1 pack. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $1.99 The 810 drip tip is made from resin with 16mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.This item also has many versions to choose. One piece will be shipped. ![]() Original Coil Father Pre-made Coil Super Alien Heating Wire for DIY - 2 PCS $2.59 The Original Coil Father Pre-made Coil Super Alien Coil comes with 2.5mm bore and 4 wraps. This heating wire will be a good vaping choice for DIY. This product comes with 2 PCS in 1 pack.This item also has many versions to choose. ![]() Original Coil Father Pre-made Coil Kanthal A1 Heating Wire for DIY - 22GA (30 PCS) $3.99 The Original Coil Father Pre-made Coil Coil is made of Kanthal A1 and comes with 22GA, 3mm bore and 4 wraps. This heating wire will be a good vaping choice for DIY.This item also has many versions to choose. This product comes with 30 PCS in 1 pack.
59
Original Wismec Luxotic 100W Squonk Box Mod $36.99
The Wismec Luxotic BF Box Mod, designed by JayBo, features its reimagined squonk system and inbuilt refillable e-liquid bottle of 7.5ml capacity. Powered by single 18650 battery (not included), Luxotic can reach maximum output to 100W. The large capacity squonk bottle allows you to vape with ease without refilling frequently. The cover panel is replaceable, making it different whenever you like. ![]() Original GeekVape Loop RDA Rebuildable Dripping Atomizer with BF Pin Original Price $28.90,Now Only $19.99 The Original GeekVape Loop RDA is the first leak-proof RDA with surround bottom airflow system. The innovative W style postless build deck is raised and provide more space for the juice well. Whats more, it will not cause juice leaking when refilling because of the deck and beveled airslots. The air accesses the internal via side airslots and hit the bottom of coils. The structure of the deck can surround the coils well and enhance the flavor. This RDA comes with bottom feeder pin. ![]() SXK Armor 2.0 RDA Rebuildable Dripping Atomizer Clone Original Price $17.90,Now Only $13.39 The SXK Armor 2.0 RDA Clone is constructed from 316 stainless steel and in 22mm diameter. It features dual-pole design and adjustable airflow. The RDA supports single and dual coil build with the insulated blocker. POM drip tip included. This RDA comes with bottom feeder pin. ![]() Original Wismec Luxotic 100W Squonk Box Mod + Tobhino BF RDA Kit $51.99 The Original Wismec Luxotic BF Kit consists of Luxotic BF Box Mod and Tobhino BF RDA. Mod: The Wismec Luxotic BF Box Mod, designed by JayBo, features its reimagined squonk system and inbuilt refillable e-liquid bottle of 7.5ml capacity. Powered by single 18650 battery (not included), Luxotic can reach maximum output to 100W. The large capacity squonk bottle allows you to vape with ease without refilling frequently. The cover panel is replaceable, making it different whenever you like. RDA: The Wismec Tobhino BF RDA is a 22mm atty that features open build place and adjustable side airflow. You can even build a fancy coil in this tiny RDA. It comes with decorative ring for not only decoration, but also heat insulation. With optional top cap, Tobhino is compatible with both 510 and 810 drip tips. ![]() Original Amphisbaena 8 in 1 Kanthal A1 Pre-made Coils Kit for RDA / RTA / RDTA $2.99 The Original Amphisbaena 8 in 1 Pre-made Coils Kit comes with 2 x Kanthal A1 22GA Coils, 2 x Kanthal A1 24GA Coils, 2 x Kanthal A1 26GA Coils, 2 x Kanthal A1 28GA Coils, 2 x Kanthal A1 Fused Clapton Coils, 2 x Kanthal A1 Tiger Coils, 2 x Kanthal A1 Quad Coils, 2 x Kanthal A1 Twisted Clapton Coils. These pre-made coils are great for RDA / RTA / RDTA building. This kit contains 8 types of coils, 2 PCS for each type, totally 16 PCS. ![]() Original Vapjoy 810 Replacement Drip Tip Kit for 528 Goon / Kennedy / Reload RDA $6.99 The Original Vapjoy 810 drip tip is made from PEI with 13mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This kit comes with 5 PCS in 1 pack. ![]() Original Vapjoy 510 Replacement Drip Tip Kit for TFV8 Baby / Uwell Crown 3 Tank $8.99 The Original Vapjoy replacement 510 drip tip is made from resin with 18mm height. It is suitable for all atomizers that fit 510 drip tip, like SMOK TFV8 Baby and Uwell Crown 3 Tank. ![]() Original Vapjoy 810 Replacement Drip Tip Kit for 528 Goon / Goon LP / Reload RDA $9.99 The Original Vapjoy 810 drip tip is made from resin with 11.6mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This kit comes with 5 PCS in 1 pack. The drip tips are in random color. More options than what's on the image. ![]() Original Vapjoy 810 Replacement Drip Tip Kit for TFV8 / TFV 12 Tank $11.99 The Original Vapjoy 810 drip tip is made from resin and stainless steel with 15mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This kit comes with 5 PCS in 1 pack. The drip tips are in random color. More options than what's on the image. ![]() Original Vapjoy 510 Replacement Drip Tip Kit for TFV8 Baby / Crown 3 Tank $11.59 The Original Vapjoy replacement 510 drip tip is made from resin and stainless steel with 15mm height. It is suitable for all atomizers that fit 510 drip tip, like SMOK TFV8 Baby and Uwell Crown 3 Tank. ![]() Original Vapjoy Cubweb Coil 8 in 1 Pre-made Coils Kit for RDA / RTA / RDTA $16.99 The authentic Vapjoy Cobweb 8 in 1 Coil Kit carries 8 different kinds of advanced pre-made coils which are made from premium quality coil wires. The coils are Fused Clapton coil 0.3ohm, Tortuosity coil 0.22ohm, Clapton Parallel coil 0.3ohm, Interlock Clapton coil 0.3ohm, Fused Clapton (Twist) coil 0.45ohm, Flat Clapton 0.45ohm, Clapton coil 0.6ohm, and Super Tiger coil 0.6ohm. This kit contains 8 types of coils, 6 PCS for each type, totally 48 PCS. ![]() Original Blitz Subohmcell Hellcat Replacement Coil Heads for Hellcat RDTA / Sub Ohm Tank $8.99 The Original Blitz Subohmcell Hellcat Replacement Coil Head features 0.2ohm resistance and can work at between 60 and 200W (80~130W recommended). It is suitable for Blitz Subohmcell Hellcat RDTA / Sub Ohm Tank. This product comes with 5 PCS in 1 pack. ![]() YFTK Replacement Top Cap for Karma RDA Clone $6.99 The replacement top cap is made out of PEI and is suitable for YFTK Karma RDA Clone. One piece will be shipped.
60
Original Sigelei Fuchai R7 230W TC VW Variable Wattage Box Mod $44.99
The Sigelei Fuchai R7 Mod has sleek transformer style appearance with oversized fire button. It is powered by dual 18650 batteries (not included) and the wattage can be varied from 10 to 230W. The temperature suite contains Nickel chrome, stainless steel (316 / 317 / 304), Titanium wire, Nickel 200, and TCR. The resistance range is from 0.05 to 3ohm.This item also has many color to choose. ![]() Rogue Purity Hybrid Mechanical Mod Clone $20.99 The Rogue Purity Mechanical Mod Clone is constructed from aluminum in 24mm diameter. It is powered by 1 x 18650 battery (not included). It features 510 hybrid top cap and spring fire button.This item also has many color to choose. ![]() Phenomenon Pmma Lite RTA Rebuildable Tank Atomizer Clone $13.89 The Phenomenon Pmma Lite Style RTA Clone is constructed from 316 stainless steel in 22mm diameter. The tank can hold about 4ml of e-juice. The RTA comes with adjustable bottom airflow for smooth airflow and nice flavor. ![]() Ulton Adler Mikro DA Rebuildable Dripping Atomizer Clone with BF Pin $13.59 The Ulton Adler Mikro RDA Clone is constructed from 316 stainless steel in 22mm diameter. The deck looks very neat as the post structure is simple. The RDA comes with top airflow system. This RDA comes with bottom feeder pin. ![]() Original Ulton Fev V5 RTA Rebuildbale Tank Atomizer $21.99 The Ulton Fev V5 RTA is a 25mm tank with 7~8ml juice capacity. The deck comes with dual psot design. The tank features dual AFC (DL) and single AFC (MTL) control, which is exchanged by a solid screw. The kit has 3 pairs of AFC screws for various airflow configurations. ![]() Original Eleaf iStick Pico Baby 25W 1050mAh Mod + GS Baby Tank Kit $35.99 The Original Eleaf iStick Pico Baby Kit contains iStick Pico Baby Mod and GS Baby Tank.This item also has many color to choose. Mod: The Eleaf iStick Pico Baby Mod is a compact device with 1050mAh built-in battery and the wattage output is 25W. It is mini in size so you can take it everywhere and enjoy your vaping journey. Tank: The GS Baby Tank is a 16.5mm atomizer that features 2ml juice capacity, refined airflow system and adopts 0.75ohm GS air coils for great flavor. ![]() Original Sigelei Fuchai R7 230W TC VW Variable Wattage Box Mod + T4 Tank Kit $54.69 The Original Sigelei Fuchai R7 Kit consists of Fuchai R7 Mod and T4 Tank.This item also has many color to choose. Mod: The Sigelei Fuchai R7 Mod has sleek transformer style appearance with oversized fire button. It is powered by dual 18650 batteries (not included) and the wattage can be varied from 10 to 230W. The temperature suite contains Nickel chrome, stainless steel (316 / 317 / 304), Titanium wire, Nickel 200, and TCR. The resistance range is from 0.05 to 3ohm. Tank: The T4 Tank is a 24mm atomizer with 2.5ml juice capacity. It features convenient top filling and adjustable bottom airflow. The tank supports SM2-H / SM2 / SM4 / SM6 coils. ![]() Original SJMY Replacement Panels for Toy Brick Squonk Box Mod $29.99 The replacement panel is made out of G10 fiberglass and is suitable for Original SJMY Toy Brick Squonk Box Mod. This product comes with 6 PCS of panels for each side of SJMY Toy Brick Squonk Box Mod.
