Просмотров в теме 302497   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 07.01.2020, 04:50 Автор темы   561
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Steel Vape Tailspin Hybrid Mechanical Mod + RDTA Vape Kit original price$35.99, now only$14.99
The original Steel Vape Tailspin Kit consists of Tailspin Mod and Tailspin RDTA. Mod: The Steel Vape Tailspin Mod is a high quality mech mod that features replaceable aluminum and resin sleeve, hidden fire button with spring design, copper battery contact and can support 0.05ohm minimum atomizer resistance. It is powered by single 18650 battery (not included). RDTA: The Steel Vape Tailspin RDTA is a 25mm atomizer which can be used as either RDA or RTA. The deck features dual post design with two post holes at each post, side filling port for easy refilling, 6mm deep juice well, AFC drip tip cap to adjust side airflow. Resin and POM drip tip are included.
Original Steel Vape ECG Bottom Feeder RDA with BF Pin original price$25.99, now only$4.99
The Steel Vape ECG Bottom Feeder RDA is constructed from Stainless Steel in 24mm diameter. The RDA comes with two clamp style posts in 45 degrees angle, easy build 1 or 2 coils. Circle PEI insulator around bottom, reduce power waste and cap temperature. Adjustable four cyclic admission airhole,smoother airflow control, atomizer working more comprehensive, meanwhile airflow cooling effect to bottom. 15 round holes inside the upper of the center cap, cluster effect function, filtration and reduction vape temperature, retention and condensation steam, making vape stronger and flavor better
Original VOZOL Ark 30W 1000mAh VW Mod Pod System Vape Starter Kit $29.99
The Vozol Ark VW Mod Pod System Vape Starter Kit has a streamline body and fashionable appearance, which features PVD acrylic panels of new aesthetic pattern. It is visually fancy and compact being powered by a 1000mAh built-in batter that supports 5~30W output wattage and comes with 3ml e-juice capacity cartridge. Furthermore, it comes with the independent coil design to provide two vaping choices: 0.6ohm Mesh DL and 1.4ohm Dual MTL vaping. And the Ark Kit features biggest side fire button design for smooth click and easy operating. In addition to this, it's 0.69" screen can show all specifications, including battery life, wattage, voltage, resistance etc. Top filling cap design for easy filling.
E-juice Injector / E-liquid Syringe Refilling Tool without Needle Tip(5 PCS) $1.29
The E-liquid Syringe is constructed with luer lock connector and soft silicon caps. High quality industrial grade luer lock connector, perfect for storage. It contains graduations / markings for volume measurement, which make it easier to accurately make your own e-liquid. It is a great transfer tool every DIYer should have in their kit! This one has 1ml capacity. 5 PCS / Pack.
E-juice Injector / E-liquid Syringe Refilling Tool without Needle Tip(5 PCS) $1.49
The E-liquid Syringe is constructed with luer lock connector and soft silicon caps. High quality industrial grade luer lock connector, perfect for storage. It contains graduations / markings for volume measurement, which make it easier to accurately make your own e-liquid. It is a great transfer tool every DIYer should have in their kit! This one has 5ml capacity. 5 PCS / Pack.
E-juice Injector / E-liquid Syringe Refilling Tool without Needle Tip(5 PCS) $1.99
The E-liquid Syringe is constructed with luer lock connector and soft silicon caps. High quality industrial grade luer lock connector, perfect for storage. It contains graduations / markings for volume measurement, which make it easier to accurately make your own e-liquid. It is a great transfer tool every DIYer should have in their kit! This one has 10ml capacity. 5 PCS / Pack.
3FVAPE вне форума   Вверх
Старый 07.01.2020, 04:56 Автор темы   562
3FVAPE
E-juice Injector / E-liquid Syringe Refilling Tool without Needle Tip(5 PCS) $4.99
The E-liquid Syringe is constructed with luer lock connector and soft silicon caps. High quality industrial grade luer lock connector, perfect for storage. It contains graduations / markings for volume measurement, which make it easier to accurately make your own e-liquid. It is a great transfer tool every DIYer should have in their kit! This one has 30ml capacity. 5 PCS / Pack.
Original Vivismoke Wire Mini Cutter Pliers for RDA / RTA / RDTA Vape Atomizers $3.49
The Vivismoke Wire Cutter Mini Diagonal Cutter Pliers is made from Chrome-Vanadium Steel. The handle is made from plastic for comfortable grip. It is a convenient tool for cutting leads of coils, and cutting wires when you making your own coils. It is suitable for RDA / RTA Rebuildable Atomizers or DIY Coil Building.
Original Vivismoke Coil Stick One DIY Coil Building Tool for RDA / RTA / RDTA Atomizers $4.98
The Vivismoke Coil Stick One is made of Avation Aluminum, it comes with 2.0 / 2.5 / 3.7 / 4.4 windding rod dimensions and it is suitable for RBA / RDA / RTA Rebuildable Atomizers or DIY Coil Building. Make your own coils easier.
Original Vivismoke 4 in 1 Screwdriver for RDA / RTA / RDTA Atomizers $2.99
The Vivismoke 4 in 1 Screwdriver comes with 4 different bits, which are PH00, Flat 2.5, Hex 1.5, Hex 1.27. It is suitable for RDA / RTA / RDTA Rebuildable Atomizers.
Original Vivismoke Handcrafted Staple Alien Ni80 Coil + Organic Wick for RDA / RTA / RDTA Atomizers(2 PCS) $4.79
The Vivismoke prebuilt handcrafted Staple Alien 0.13ohm Ni80 Coil are finely crafted coils twisted with machine-like precision for those that are looking to save time in rebuilding, available in a myriad of advanced configurations for immediate sophisticated set-up. 2 PCS / Pack.
Original Vivismoke 510 Display Base Stand for RDA / RTA / RDTA / Sub Ohm Tank Atomizer / Clearomizer $2.49
The Vivismoke 510 display base stand is made of Aluminum Alloy. It is used to display or place RDA / RTA / RDTA atomizers. It features 510 threading connection, which fits most standard atomizers. Use it for setting down for DIY user building coils, No more tanks falling on their sides and leaking every where. The base diameter is 34.5mm and the height is 20mm.
Original G-taste Transbost 510 Thread Adapter Connector for Geekvape Aegis Boost Vape Kit $3.99
The G-taste Transbost 510 Thread Adapter Connector is designed for Geekvape Aegis Boost Vape Kit, it can switch your Geekvape Aegis Boost Kit into a normal 510 thread box mod kit to use different atomizers.
Original VOZOL Ark Pod System Vape Kit / Cartridge Replacement MTL Dual Coil Head(5 PCS) $10.99
The VOZOL Ark Replacement MTL Dual Coil Head is designed for VOZOL Ark Pod System Vape Kit / Cartridge as a replacement part. It features 1.4ohm coil resistance. 5 PCS / Pack.
Original VOZOL Ark Pod System Vape Kit / Cartridge Replacement DL Mesh Coil Head(5 PCS) $10.99
The VOZOL Ark Replacement DL Mesh Coil Head is designed for VOZOL Ark Pod System Vape Kit / Cartridge as a replacement part. It features 0.6ohm coil resistance. 5 PCS / Pack.
Original VOZOL Ark Pod System Vape Kit Replacement Empty Cartridge $4.39
The VOZOL Ark Replacement Empty Cartridge is designed for VOZOL Ark Pod System Vape Kit as a replacement part. It features 3ml e-juice capacity.
Старый 08.01.2020, 04:38 Автор темы   563
3FVAPE
GET LOW MODS GLM V1 Hybrid Mechanical Vape Mod Clone $14.99
The GET LOW MODS GLM V1 Hybrid Mechanical Vape Mod Clone is another strong electric cigarette. Which the beautiful purple design should be used for this is a freshly fired electric cigarette. The Mechanical Mod is powered by single 18650 battery (Not included). The body is constructed from copper. It can be polished to give rise to phase. The press pin uses good conductivity copper material, guarantees fast running power. Packed in a beautiful wooden box, it is suitable for purchase as a collection beginners should not use it because there is no power cut because it is a live shot.
Original Sanvape Q8 Pro 40W 1620mAh MTL / DTL VW Mod Pod System Vape Starter Kit $27.99
The Sanvape Q8 Pro 40W VV VW Mod Pod System Vape Starter Kit is a sensational all-in-one Pod System kit, it has a compact box shape and unique design. With a premium zinc alloy frame and unique side panels. Powered by a built-in 1620mAh battery, it has a power range from 5W to 40W while implementing VW, VV modes and various protections. With a 0.69-inch display. Above the display is the remarkable point style - fire button and below it is the adjustment buttons. Directly located on the bottom of the device are the Type-C port, and 2A fast charging via the Type-C port. As for the refillable pod, it can hold up to 4.5ml of e-liquid and comes with two coil options. One is the 0.4ohm mesh coil for DTL, the other is the 1.2ohm regular coil for MTL, which can meet the needs of different vapers. It also adopts an adjustable airflow system and top filling design, and more importantly supports RBA coil replacement.
Original Reewape RUOK 510 Thread Adapter Connector for GeekVape Aegis Boost Pod System Vape Kit $3.99
The Reewape RUOK 510 Thread Adapter Connector is designed for Geekvape Aegis Boost Pod System Vape Kit, it can switch your Geekvape Aegis Boost Kit into a normal 510 thread box mod kit to use different atomizers.
Original Sanvape Q8 Pro Pod System Vape Kit / Cartridge Replacement Coil Head(5 PCS) $6.99
The Sanvape Q8 Pro Replacement Coil Head is designed for Sanvape Q8 Pro Pod System Vape Kit / Cartridge as a replacement part. It features 0.4ohm coil resistance that output power range from 25W to 40W. 5 PCS / Pack.
The Sanvape Q8 Pro Replacement Coil Head is designed for Sanvape Q8 Pro Pod System Vape Kit / Cartridge as a replacement part. It features 1.2ohm coil resistance that output power range from 8W to 13W. 5 PCS / Pack.
Replacement Top Cap for Gas Mods HALA RDTA $5.99
The Replacement Top Cap is designed for Gas Mods HALA RDTA Rebuildable Dripping Tank Atomizer as a replacement part, it is made of POM material.
Replacement Drip Tip for GeekVape Aegis Boost Pod System Vape Kit $1.99
The Replacement Drip Tip is designed for GeekVape Aegis Boost Pod System Vape Kit as a replacement part, it is made of resin material.
510 Thread Adapter Connector with Spring-Loaded Center Pin for GeekVape Aegis Boost Pod Vape Kit $3.59
The 510 Thread Adapter Connector is designed for Geekvape Aegis Boost Vape Kit, it is made of stainless steel (510 threading connector) and POM (outer housing), which can switch your Geekvape Aegis Boost Kit into a normal 510 thread box mod kit to use different atomizers. As for this 510 threading connector, it comes with a special Spring-Loaded 510 Center Pin design that can be fitted for 510 drip tip with different lengths.
Original Sanvape Q8 Pro Pod System Vape Kit / Cartridge Replacement RBA Rebuildable Coil Head $4.99
The Sanvape Q8 Pro Replacement RBA Rebuildable Coil Head is designed for Sanvape Q8 Pro Pod System Vape Kit / Cartridge as a replacement part. It fits for DIY vaping lovers.
Original Hellvape Grimm Pod System Vape Kit / Cartridge Replacement RBA Rebuildable Coil Head $5.99
The Hellvape Replacement RBA Rebuildable Coil Head is designed for Helllvape Grimm Pod System Vape Kit / Cartridge as a replacement part. It fits for DIY vaping lovers.
Старый 09.01.2020, 04:46 Автор темы   564
3FVAPE
Original DOVPO Topside Dual Carbon 200W YIHI Chip TC VW Squonk Box Vape Mod original price$179.99, now only$129.99
The DOVPO Topside Dual Carbon Squonk Mod is constructed from aluminum alloy, carbon fiber, zinc alloy and stainless steel material, which is the updated version of the innovative DOVPO Topside Squonk Mod that is wrapped by new carbon material to present you ingenious design with lightweight and the cozy sense of gripping. Most importantly, with external dual 18650 batteries (Not included) powered by new YIHI chip, the Topside Dual Carbon Squonk Mod can fire up to the 200W output power with VW / TC mode and throw you impeccable and accurate working. The Dual Carbon Squonk Mod also comes with 0.96 inch screen and 10ml large e-juice silicone bottle with easy top filling design, which brings you longer vaping and effective oil leakage resistance.
Original Coil Master ReBuild RBK Kit for Uwell Caliburn Pod System Vape Kit $4.99
The Coil Master ReBuild Kit is designed for Uwell Caliburn Pod System Vape Kit which includes 10 PCS 1.2ohm A1 Double Coils, 20 PCS Cotton, and 1 PCS Rod. It fits for DIY vaping lovers. Coil Master ReBuild Kit for Caliburn is made for pod vapers, which can rebuild their Pods quickly and easily. Save your money to rebuild the coil with this Coil Master ReBuild Kit in just 3 minutes. If you are still worried about running out of Caliburn pods to replace them with new ones, Coil Master ReBuild Kit will solve this problem.
Original Coil Master ReBuild Kit PnP-VM1 RBK for Voopoo VINCI / VINCI X Pod Vape Kit $5.99
The Coil Master ReBuild Kit (for PnP-VM1) is designed for Voopoo VINCI / VINCI X Pod System Vape Kit which includes 10 PCS 0.3ohm Ni80 Mesh Coils, 35 PCS Cotton, and 1 PCS Rod. It fits for DIY vaping lovers. Coil Master ReBuild Kit is made for pod vapers, which can rebuild their Pods quickly and easily. Save your money to rebuild the coil with this Coil Master ReBuild Kit. If you are still worried about running out of VINCI pods to replace them with new ones, Coil Master ReBuild Kit will solve this problem.
Pro V3 Noise Cancellation Bluetooth Earphone Clone with Spare Ear Tips + Wireless Charging Case for iPhone $39.99
The Pro V3 Bluetooth Earphone Clone is designed for your iPhone or other Apple devices. It can be used and connected with your iPhone or other Apple devices by Bluetooth. The Bluetooth Earphone supports Noise Cancellation or Transparency modes. It also supports charge wirelessly or charge using the Lightning Connector. Comes with spare changeable ear tips and Wireless Charging Case.
Original Ehpro Raptor Sub Ohm Tank Replacement Mesh Quad Coil Head(3 PCS) $11.99
The Ehpro Raptor Replacement Mesh Quad Coil Head is designed for Ehpro Raptor Sub Ohm Tank Clearomizer as a replacement part. It features 0.15 + / - 0.03ohm coil resistance that power range from 70W to 100W. The Ehpro Raptor Replacement mesh Coil has everything you love in the common coil, but cheaper, stronger and more durable. 3 PCS / Pack.
Original Coil Master ReBuild Kit PnP-R1 RBK for Voopoo VINCI / VINCI X Pod Vape Kit $5.99
The Coil Master ReBuild Kit (for PnP-R1) is designed for Voopoo VINCI / VINCI X Pod System Vape Kit which includes 10 PCS 1.0ohm Ni80 Double Coils, 40 PCS Cotton, and 1 PCS Rod. It fits for DIY vaping lovers. Coil Master ReBuild Kit is made for pod vapers, which can rebuild their Pods quickly and easily. Save your money to rebuild the coil with this Coil Master ReBuild Kit. If you are still worried about running out of VINCI pods to replace them with new ones, Coil Master ReBuild Kit will solve this problem.
Старый 10.01.2020, 04:46 Автор темы   565
3FVAPE
Original Voopoo VINCI AIR 30W 900mAh MTL / Half-DL VW Mod Pod System Vape Starter Kit $26.99
The Voopoo VINCI AIR, is not just a new version of VINCI. This is a versatile pod that combines exquisite and compact products with the fun of vaping. VINCI AIR has two air inlets, two ignition methods, and the size is two fingers. It is 20% lighter and 30% thinner than VINCI. Thin and thin, it remains one of the most feature-rich devices in a POD. Whether it's Manual or Auto mode, VINCI AIR can bring surging smoke in the first time. VINCI AIR retains the innovative Dual Airflow System. Try turning the atomizer 180 degrees and inserting it, you will get two completely different mouthfeel experiences. VINCI AIR has specially optimized the airway design, bringing unparalleled comfort to MTL and Half-DL. When you get used to using automatic mode, you even forget the key. It comes with a 4ml e-juice capacity pod and it is equipped with two dedicated coils.
Original Sanvape Q8 Pro 40W 1620mAh MTL / DTL VV VW Mod Pod System Vape Starter Kit $27.99
Original Reewape AS292 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle RDA $1.95
The Reewape AS292 810 Replacement drip tip is made of Carbon material, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS297F Replacement Anti Split 510 Drip Tip for RDA/RTA/RDTA/Sub-Ohm Tank Atomizer $1.55
The Reewape AS297F Replacement Anti Split 510 Drip Tip is made of resin and stainless steel, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
YFTK Replacement 510 Drip Tip for ParavozZ Ghost V2 RDTA / RDA / RTA / Sub Ohm Vape Tank Atomizer $6.99
The YFTK Replacement 510 Drip Tip is designed for YFTK ParavozZ Ghost V2 RDTA Vape Tank Atomizer as a replacement part, which is made of 316 Stainless Steel. It is also suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Fumytech Bdvape Precisio MTL RTA Replacement Top Cap Tank Tube $16.00
The Fumytech Replacement Top Cap Tank Tube is designed for Fumytech Bdvape Precisio MTL / Middle MDL RTA as a replacement part, which is made of PC material and it has a 2.7ml e-juice capacity.
Original Vivismoke Organic Cotton Express for RBA / RDA / RTA / RDTA Vape Atomizer(50 PCS) $4.99
The Vivismoke Cotton Express is a high quality cotton, which is made of organic cotton and it is tasteless, medical grade, super durable, less waste and peroxide free. It is suitable for RBA / RDA / RTA / RDTA Vape Atomizer as a replacement part. Moreover, it is also easy to carry, wick and absorb. 50 PCS / Pack.
Старый 11.01.2020, 04:47 Автор темы   566
3FVAPE
Original Sigelei Humvee 215W TC VW Box Vape Mod $42.99
The Sigelei Humvee 215W TC VW Box Mod, a visually striking dual battery vape device, implementing a durable zinc aluminium alloy chassis construction reinforced with resin, extensive temperature control suite, and it is equipped with a 0.66" OLED Display Screen to relay relevant vaping data back to the user. Featuring a dual battery layout, the Humvee Box Mod is powered by Dual 18650 Batteries (Not included) that wattage range from 5W to 215W. Incorporating extensive temperature control, the Sigelei Humvee can utilize nickel, titanium, and stainless steel wires to fine tune the vapor output and temperature to their personal liking. In addition to the rugged design, a 0.66" OLED Display screen, with two adjustment buttons below, graces the side of the Sigelei Humvee Box Mod displaying battery life, wattage, and other important information.
Original Steel Vape Sebone Hybrid Mechanical Mod + RDA Vape Kit Original price $40.99, now only $14.99
The Original Steel Vape Sebone mechanical mod kit consists of Sebone mech mod and Sebone RDA. Mod: The Steel Vape Sebone mechanical mod is a hybrid tube mod constructed from stainless steel. It features Chinese traditional dragon element on the tube, like the carving dragon scale and dragon totem. It comes with spring fire button and bottom venting holes. The mod is powered by single 18650 battery (Not included). RDA: The Steel Vape Sebone RDA is a 24mm dripper with silver plated copper 510 pin for great conductivity. The deck features dual post design with 3 x 4.5mm holes for various builds. The airflow is adjustable with dual side airslots. The RDA comes with one PEI and one resin drip tip to match two caps (included).
Original SMOKTech SMOK Nord 2 40W 1500mAh Pod System Vape Starter Kit $26.99
The SMOKTech SMOK Nord 2 Pod System Vape Kit, the upgrade version of the button-triggered pod system nord, has been fully improved. Based on nord's exceptional features, the nord 2 adds more highlights: it is equipped with a 0.69inch OLED screen, and powered by a large power capacity 1500mAh battery, charging display interface, adjustable wattage, and multiple protections. It comes with a nord 2 RPM pod (RPM Mech 0.4ohm Coil Pre-installed), a nord 2 nord pod (Nord DC 0.8ohm MTL Coil Pre-installed) and 4.5ml e-juice capacity to offer a larger capacity, more pod and coil options. nord 2 is a new innovator, and innovation keeps changing the vaping experience.
Original VOOPOO VINCI X 70W VW Box Mod Pod System Vape Kit with 5 PnP Coils $34.99
The VOOPOO VINCI X Kit is a powerful and perfect device of Voopoo's new "Mod Pod" type that pioneered a new era of MOD. Compared to Voopoo VINCI, the longer life of the Voopoo VINCI X Mod Pod Kit will give you a longer enjoyment. Voopoo VINCI X Mod Pod Kit is powered by a single 18650 battery (Not included) and supports 70W maximum power output. With max 70W power output, VINCI X enables you to make bigger clouds. Voopoo VINCI X becomes more lasting by a higher power
Original VOOPOO VINCI 40W 1500mAh VW Mod Pod System Vape Kit with 5 PnP Coils $31.99
The VOOPOO VINCI Mod Pod Kit consists of the 1500mAh built-in battery mod and visible pod cartridge which both comes with a unique appearance design. The VINCI mod is constructed from zinc alloy material which is decorated with various pattern panels to give you a different sense of vision. And the cuboid shape design will not make you feel any uncomfortable but suitable for gripping in hand on the contrary.
Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $1.59
The Replacement 510 Drip Tip is made of POM + Acrylic, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Voopoo VINCI AIR Pod System Vape Kit Replacement Empty Cartridge w/o Coils(2 PCS) $5.99
The Voopoo VINCI AIR Replacement Empty Pod Cartridge is made of plastic food-grade PCTG pods which is designed for Voopoo VINCI AIR Pod System Vape Kit as a replacement part. Fill up to your favorite 4ml nicotine salt or e-juice. Fill by opening the large silicone plug on the side. Very convenient and no need to worry about leaks. It is compatible with many types of coils of the Voopoo PnP series (PnP-VM3, PnP-VM4, PnP-RBA, PnP-R1, PnP-R2) (Coils are not included) to create tasty clouds of vapor. In addition, VINCI AIR comes with an innovative dual airflow system, try turning the VINCI AIR Pod 180 degrees and inserting it, you will get two completely different mouth feel experiences. The Voopoo VINCI AIR Pod Kit will secure the pod with strong magnets. A new upgraded magnetic suction tank provides the simplest and most sanitary way of filling oil. 2 PCS / Pack.
Original SMOKTech SMOK Nord 2 Pod System Vape Kit Replacement Empty Nord Pod Cartridge w/o Coils(3 PCS) $4.99
The SMOKTech SMOK Replacement Empty RPM Pod Cartridge is designed for SMOKTech SMOK Nord 2 Pod System Vape Kit as a replacement part. It features 4.5ml e-juice capacity and it is compatible with Nord Series Coils (Coil are not included). 3 PCS / Pack.
Original Geekvape Staggered Fused SS316L Clapton Coil for RBA / RDA / RTA /RDTA(2 PCS) $4.99
The Original Geekvape Staggered Fused Clapton Coil Heating Wire is made from SS316L Clapton wires and features coil resistance 0.25 + / - 0.05ohm, (26GA + 32GA) x 2 + 32GA (Size: 1.0mm x 1.4mm). It is suitable for RBA / RDA / RTA / RDTA Vape Atomizer. This heating wire will be a good vaping choice for DIY. 2 PCS / Pack.
Старый 13.01.2020, 04:25 Автор темы   567
3FVAPE
Original QUIZZ E-cigar Pod System Vape Kit Replacement Cartridge with 1.8ohm Cotton Coil(5 PCS) $11.99
The QUIZZ E-cigar Replacement Pod Cartridge is designed for QUIZZ E-cigar Pod System Vape Kit as a replacement part. It features 1.8ohm resistance coil and comes with 1.2ml e-juice capacity. 5 PCS / Pack.
Replacement Disposable 510 Drip Tip for RDA / RTA / RDTA / Clearomizer / Sub Ohm Tank Atomizer(5 PCS) $0.99
The Replacement Disposable 510 Drip Tip is made of Silicone. It is suitable for RDA / RTA / RDTA / Clearomizer Vape Atomizer and can fit most atomizers or cartomizers with 510 connectors. It is easy to be rinsed with water. 5 PCS / Pack.
Original Efest Zipper Battery Case Carrying Bag with Silver Hook for 18350/18450/18650 Li-ion Batteries $2.99
The Original Efest Battery Case Carrying Bag, which can hold up following types of batteries: 18350 / 18450 / 18650 Li-ion Batteries (Batteries are not included). It comes with a silver hook that convenient to carry out. The Battery Case size is 103 x 75 x 20mm.
Original Innokin I.O Pod System Vape Kit Drip Tip Adapter Compatible with Nib of Most E-juice / E-liquid Bottles $1.59
The Innokin Replacement Drip Tip Adapter is designed for refilling the Innokin I.O Pod System Vape Kit, the drip tip adaptor allows you to quickly refill the pods without leakage or waste. The adaptor fits over the nib of most e-liquid bottles and the metal nib of the adaptor slots into the pod cartridge.
Original Innokin Plexar Vape Starter Kit / Sub Ohm Tank Replacement Scion Plex3D KAL Coil(3 PCS) $8.99
The Innokin Replacement Scion Plex3D KAL Coil Head is designed for Innokin Plexar Vape Starter Kit / Innokin Plexar Sub Ohm Tank as a replacement part, which features 0.14ohm coil resistance that output power range from 60W to 100W. It adopts advanced Plex3D Coil Technology with "micro-grooves" uses less power for more puffs per charge and delivers maximum flavor and clouds. It is made with Eco-friendly Wood-pulp which wicks faster for enhanced flavors. 3 PCS / Pack.
Старый 14.01.2020, 04:43 Автор темы   568
3FVAPE
YFTK Replacement 510 Drip Tip for ParavozZ Ghost V2 RDTA / RDA / RTA / Sub Ohm Vape Tank Atomizer $10.99
The YFTK Replacement 510 Drip Tip is designed for YFTK ParavozZ Ghost V2 RDTA Vape Tank Atomizer as a replacement part, which is made of Titanium Alloy. It is also suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Старый 15.01.2020, 04:30 Автор темы   569
3FVAPE
Original Kumiho Vaping Magic Connector + Filter Tip with Flavor Core for Juul, GeekVape Aegis Boost, SEA, Puff, Hyde Kit $2.59
The Kumiho Vaping Magic Connector with Filter tip is design for Same Size Like Juul / GeekVape Aegis Boost / SEA / Puff / Hyde Pod System Vape Kit ect as a replacement part. The Filter Tip comes with flavor core inside.
Original Kumiho Vaping Magic Connector + Filter Tip with Flavor Core Inside for Uwell Caliburn / Caliburn KOKO Pod Kit $2.59
The Kumiho Vaping Magic Connector with Filter tip is design for Uwell Caliburn / Caliburn KOKO Pod System Vape Kit as a replacement part. The Filter Tip comes with flavor core inside.
YFTK In'Ax V5 DL RTA Replacement Top Cap + Tank Tube $10.99
The YFTK Replacement Top Cap + Tank Tube is designed for In'Ax V5 DL RTA Rebuildable Tank Vape Atomizer as a replacement part. It is made of PEI material and can hold up 3ml e-juice / E-liquid capacity.
Старый 03.03.2020, 04:33 Автор темы   570
3FVAPE
Original Suorin Shine 13W 700mAh Pod System Vape Starter Kit $25.99
The Original Suorin Shine 13W 700mAh Pod System Vape Starter Kit is a small discreet handheld vaping pod system, simple appearance, and easy to carry. The body of Suorin Shine Pod Kit has a single-button trigger button, built-in a 700mAh battery inside (Max Output Wattage: 13W), can work all day. Suorin Shine Pod Kit has a refillable pod cartridge of 2ml capacity that is used to contain favorite e-juice or E-liquid, vaporizing it within the integrated 1.0ohm coil. The inbuilt 1.0ohm coil of Suorin Shine Pod Kit is the best for high nic juice. The Suorin Shine Pod Kit can bring pure flavor and dense clouds to the vapers. In addition, Suorin Shine Pod Kit is firmly fixed to the pod system through a sturdy magnetized connection and can be easily released when pulled to facilitate replacement or refilling of the pod.
Original SMOKTech SMOK Pozz X 40W 1400mAh VW Pod System Vape Starter Kit $28.79
The Original SMOKTech SMOK Pozz X 40W 1400mAh VW Pod System Vape Starter Kit is an innovative pod system kit with significantly enhanced features and performance. The frame of the device adopts dual processes of electroplating and baking paint, which does not only ensure the metal texture but also enriches more color options. Besides, Pozz X's panel is made of composite material with a four-layer structure, which ensures that POZZ X is thinner, harder and shinier. SMOK Pozz X pod kit is powered by a 1400mAh built-in battery which can fire up to MAX 40W. In addition, the Pozz X main body frontal is equipped with a 0.96-inch screen that uses the enlarged font to display basic information more clearly, such as wattage, voltage, resistance, number of puffs and time of each puff. A one-button circular fire button at the top of the screen simplifies operations and provides convenience. The Pozz X kit includes a POZZ X RPM pod which allows adjustable airflow, and two RPM coils that are ideal for either MTL or DTL vaping style. (0.4ohm Coil Pre-installed). As for SMOK Pozz X Pod Cartridge, it has a large E-liquid or E-juice capacity of 4.5ml, ensuring a long and relaxing vaping. Open the silicone plug on the side for liquid refilling that is fast and easy. SMOK Pozz X Pod Kit is compatible with all RPM40 coils including the RPM RBA coil to maximize coil compatibility and meet the vaping needs of high-end users. Furthermore, the bottom of the POZZ X RPM pod is equipped with an adjustable airflow ring, which tightly surrounds the coil, forming the shortest path for the airflow to the coil, thereby maximizing flavor enjoyment and vapor production.
Original Suorin Shine Pod System Vape Kit Replacement Pod Cartridge with 1.0ohm Coil(2 PCS) $7.99
The Original Suorin Replacement Pod Cartridge is designed for Suorin Shine Pod System Vape Starter Kit, it comes with a 1.0ohm Coil and features 2ml E-liquid or nicotine salts capacity. 2 PCS / Pack.
Original SMOKTech SMOK Pozz X Pod System Vape Kit Replacement Empty Pod Cartridge(3 PCS) $4.99
The original SMOK Pozz X Empty Pod Cartridge is specially designed for SMOK Pozz X Pod System Vape Starter Kit, which has a 4.5ml e-juice capacity, ensuring a long and relaxing vaping. And SMOK Pozz X Pod features a translucent oil chamber that allows for more intuitive observation of e-liquids. Moreover, Pozz X Pod is made from PCTG, the most popular food-grade material, featuring safety, reliability, corrosion resistance and high light transmission. On the bottom of the Pozz X Pod is a knurled adjustable airflow ring so you can easily find the perfect draw. Pozz X cartridge has three enlarged air intake slots on both sides, which can generate huge airflow, which enhances the flavor and taste of your favorite salt nic or vape juice. It is compatible with all RPM40 mesh and RBA coils (Coils are not included) to maximize coil compatibility and meet the vaping needs of high-end users. 3 PCS / Pack.
Hi forest KN95 Protective Facial Mask Particles Respirator to Defend PM2.5 Dust / Bacteria / Virus - (10 PCS) Chinese Package $33.99
Hi-forest KN95 Protective Facial Mask is the high-quality facial Mask. It could effectively defend various particles in the air includes PM2.5 dust and bacteria/virus. It has a high-efficiency melt-blown layer which absorbs fine particles in the air, defend bacteria / virus. The facial mask is made by 3D defendable shaped cotton which is (Antibiosis, Antiviral is available), soft and comfortable, allaying shock.
Старый 04.03.2020, 05:07 Автор темы   571
3FVAPE
Original SMOKTech SMOK AL85 85W TC VW Box Vape Mod original price $35.99, now only $26.00
The original SMOKTech SMOK AL85 TC VW Box Vape Mod features a large intuitive OLED display screen, the mod's information is clear and easier to read than ever before. The micro compact design fits perfectly in the palm of your hand and the side firing button placement allow for an ergonomic and natural grip. The side fire button combined with the button placement allows for easy operation for the most efficient vaping with no hassle. The AL85 Mod is powered by one 18650 battery (Not included), which is installed through the top portion of the mod. Edgy carbon fiber inlays accent the unit to give it that aggressive feel while also making sense to finish off with a powerful, functional, and aesthetically pleasing device.
Original SMOKTech SMOK GX350 350W TC VW Box Vape Mod original price $57.99, now only $29.99
The SMOKTech SMOK GX350 TC VW Box Vape Mod max output power can up to 350W when powered by 4 x 18650 batteries or up to 220W when powered by 2 x 18650 batteries. (Batteries are not included). And the Micro-USB port supports firmware upgrade but not for charge. When matching with the cloud beast TFV8, you will enjoy fantastic clouds. The SMOKTech GX350 Mod was built around comfort and ergonomics, it's a compact design that fits nicely in the palm of your hand. Edgy carbon fiber inlays accent the unit to give it that aggressive feel while also making sense to finish off with a powerful, functional, and aesthetically pleasing device.
Original SMOKTech SMOK TFV8 Big Baby Light Edition Sub Ohm Tank Vape Atomizer original price $24.99, now only $14.99
SMOKTech introduces an advanced version of TFV8 Big Baby, the TFV8 Big Baby Light Edition tank. The new tank comes with LED lights at the base of the tank. When you fire the device to vape, the LED will light up and change its color along with the color of sealing ring. Besides, it can perfectly match with V8 Baby-X4, V8 Baby-T6, V8 Baby RBA, V8 Baby-Q2 and V8 Baby-T8 core. With bright light, hyper engines and 5ml large e-juice capacity, this baby will surprise you!
Original Uwell Rafale Sub Ohm Tank Vape Clearomizer original price $24.99, now only $14.99
The original Uwell Rafale Sub Ohm Vape Tank Clearomizer is made of Stainless Steel (body) and Quartz Glass (Tank Tube) in 22mm diameter. It features 5ml E-liquid / E-juice Capacity, and has a coil with 0.5ohm resistance.
Original SMOKTech SMOK Majesty 225W TC VW Box Vape Mod original price $57.99, now only $26.99
The SMOK Majesty from SMOKTech features 225W maximum output and comes with a newly upgraded user interface and a larger colorful OLED screen to give you an unprecedented interactive experience. The ergonomic design with durable material will give you comfortable hand-feel. The mod is powered by 2 x 18650 batteries (Not included).
Original SMOKTech SMOK GX350 350W TC VW Box Vape Mod with TFV8 Cloud Beast Tank Full Kit original price $74.99, now only $46.99
The original SMOKTech SMOK GX350 Kit comes with a GX350 Box Mod and TFV8 Tank. The GX350 MOD has the maximum output power in the global with a so much compact size. And GX350 mod max output power can up to 350W when powered by 4 x 18650 batteries or up to 220W when powered by 2 x 18650 batteries. (Batteries are not included). And the Micro-USB port supports firmware upgrade but not for charge. When matching with the cloud beast TFV8, you will enjoy fantastic clouds.
Original SMOKTech SMOK Mag 225W TC VW Mod + TFV12 Prince Tank Kit original price $64.99, now only $46.99
The Original SMOKTech SMOK Mag 225W TC VW Mod Kit consists of SMOK Mag 225W Mod and TFV12 Prince tank.
Original Vapor Storm Stalker 2 400mAh Pod System Vape Pen Starter Kit $10.99
The original Vapor Storm Stalker 2 Pod System Vape Pen Starter Kit is powered by 400mAh Built-in Battery, it comes with a 1.3ohm reistance mesh coil and 1.8ml E-liquid or E-juice capacity pod cartridge. The Anti-leaking Design will bring you a great vaping experience. Compared with Stalker 1, Stalker 2 has already been updated the Max. output power that can provide you a huge vapor experience. As for the pod cartridge. It features with an airway of stainless steel material and is equipped with advanced coil, which can meet your individual vapor need. The connection is magnetic design.
Original SMOKTech SMOK V12-X4 Coil Heads for SMOK TFV12 Cloud Beast King Tank(3 PCS) $9.99
The Original SMOKTech SMOK V12-X4 Coil Heads are designed for TFV12 Tank in 0.15 ohm resistance. The V12-TX4 Sextuple coils is rated for 60~220 watts and best for 100~170W.
Original Uwell Rafale Sub Ohm Vape Tank Replacement Coil Heads(4 PCS) original price $10.99, now only $5.99
The Original Uwell Rafale coil heads features a 0.1ohm resistance. It is made of Ni200. This coil is only suitable for Uwell Rafale Sub ohm tank. It uses 100% organic Japanese cotton, will offer delicious flavor. 4 PCS / Pack.
Original Vapor Storm Stalker 2 Pod System Kit Replacement Cartridge with 1.3ohm Mesh Coil(3 PCS) $5.99
The original Vapor Storm Replacement Pod Cartridge is designed for Vapor Storm Stalker 2 Pod System Vape Pen Starter Kit, it features 1.3ohm coil resistance (mesh coil) and comes with 1.8ml E-juice capacity. 3 PCS / Pack.
Dear customer,
Due to the Coronavirus effect, we're sorry that shipping time of some products will be delayed.
If you want quick shippment, please choose products with 24HRS tag which can be shipped in 24 hours after payment confirmed on business day.
Quantity limited, first order gets first! Using the filters to browse/locate products quickly.
Click the links below to enter "Ship in 24hrs" page:
3FVPAE - 24hrs >>>
Tips:
Include products in "Ship in 24hrs" zone in one separated order to get quick shipment. Otherwise your order may wait for other products not in this zone.
Старый 05.03.2020, 04:29 Автор темы   572
3FVAPE
Original ThunderHead Creations THC Tauren Max RDTA original price $29.99, now only $25.99
The Original ThunderHead Creations Tauren Max RDTA Rebuildable Dripping Tank Atomizer is an updated version of the original version Tauren RDTA, which is constructed from Stainless Steel, implemented the originality & unique Dual-Y-Shape build deck, advanced 3D cellular airflow system and dynamic modular design that will appease building enthusiasts. Compared with Tauren RDTA, Tauren Max RDTA is wider in diameter because it has a diameter of 25mm. The maximum juice storage capacity is increased to 4ml (Compatible with 2ml and 4.5ml capacities in one design), which can meet the needs of various popular electronic juices today. Air holes also increased to 32 holes, Tauren Max RDTA has triple sides with 32 holes honeycomb airflow to bring a strong throat hit. Plus dual AFC ring with multiple airflow options can provide the smoothest airflow and wonderful flavor for vapers. In addition, Tauren Max RDTA can be filled with e-liquid through the side and bottom, which not only facilitates daily operation but also solves the leakage problem.
Honeywell H1005591V H901V KN95 Facial Mask Particulate Respirator with Exhalation Valve Anti PM2.5 Dust / Bacteria / Virus - (1PC) $3.99
The Honeywell H1005591V H901V KN95 Facial Mask Particulate Respirator is with Exhalation Valve to Anti PM2.5 Dust / Bacteria / Virus. It could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus. It has a high-efficiency melt-blown layer which absorbs fine particles in the air, defend bacteria / virus. The facial mask is made by 3D defendable shaped cotton which is (Antibiosis, Antiviral is available), soft and comfortable, allaying shock.
ZhongTai Disposable 3-Ply Earloop Medical Surgical Facial Mask Particles Respirator Anti PM2.5 Dust / Bacteria / Virus - (50PCS) $42.99
The ZhongTai Disposable 3-Ply Earloop Medical Surgical Facial Mask Face Mouth Masks is made from 1 ply SPP non-woven + 1 ply melt blown non-woven + 1 ply SPP non-woven. It is with adjustable nose bar helps the mask close to face when wearing. The elastic ear-loops wears easily and comfortable.
Daruma Slit2 Long Hybrid 510 Drip Tip Set Clone for RDA / RTA / RDTA Atomizer $5.99
The Daruma Slit2 Long Hybrid 510 Drip Tip Kit Clone consists of 3 Mouthpiece Sleeves Caps (Black and White: POM; Brown: PEI) and 1 Stainless Steel Connector Base. This drip tip set will bring you up to 3 kinds of the combination effect.
Original Vapjoy DIY Rebuild Kit for Uwell Caliburn / KOKO Pod System Vape Kit - 1 Rod + 20 Cotton + 10 A1 Coils (1.2ohm) $2.59
The Original Vapjoy DIY Rebuild Kit consists of 1 x Rod, 20 x Cotton, and 10 x A1 Coils (1.2ohm), which is designed for Uwell Caliburn Pod System Kit and Uwell KOKO Pod System Kit, it can meet most of DIY lovers' demand, and it is very easy to build.
Original Steam Crave Rebuildable Mesh Deck with BF Pin for Aromamizer Plus / Plus V2 RDTA Vape Atomizer $11.85
The Steam Crave Mesh Deck is made of Stainless Steel, which is designed for Steam Crave Aromamizer Plus / Plus V2 RDTA vape atomizer, it can offers enough space and can easily be equipped with a mesh strip. The attachment is done by two big clamps, between which the mesh strip is clamped. The delivery includes a matching BF pin, so that the Aromamizer Plus RDTA can now be used on squonkable Mods.
Dear customer,
3FVPAE - 24hrs >>>
Tips:
Старый 06.03.2020, 04:47 Автор темы   573
3FVAPE
Original Augvape Air II 470mAh Pod System Vape Starter Kit original price $22.27, now only $18.99
The Original Augvape Air II Pod System Vape Starter Kit has a streamline body and fashionable appearance. With its ergonomic design and portable size, it is comfortable to hold in hand. It adopts intelligent board to ensure safe vaping. The Air II Kit is powered by a 470mAh internal battery, it has no button design, air switch for easy vaping. The pod cartridge features 1.7ml capacity, and comes with 1.3ohm organic cotton coil (OCC) brings you better flavor and huge vapor. What's more, it has multiple protections that provide you a safer vaping.
Original Coil Father N81 King Coils for RBA / RDA / RTA / RDTA(10 PCS) $1.99
The Original Coil Father N81 King Coils Prebuilt Wire is suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil is made of Ni80 material by 26GA x 2 + 38GA in 0.3 +/- 0.05ohm with 3mm inner diameter, totally in 5 wraps. 10 PCS / Pack.
Original Coil Father N82 King Coils for RBA / RDA / RTA / RDTA(10 PCS) $2.29
The Original Coil Father N82 King Coils Prebuilt Wire is suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil is made of Ni80 material by 26GA x 3 + 38GA in 0.2 +/- 0.05ohm with 3mm inner diameter, totally in 5 wraps. 10 PCS / Pack.
Original Coil Father N83 King Coils for RBA / RDA / RTA / RDTA(10 PCS) $2.39
The Original Coil Father N83 King Coils Prebuilt Wire is suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil is made of Ni80 material by 26GA x 4 + 38GA in 0.18 +/- 0.05ohm with 3mm inner diameter, totally in 5 wraps. 10 PCS / Pack.
Original Coil Father N84 King Coils for RBA / RDA / RTA / RDTA(10 PCS) $2.39
The Original Coil Father N84 King Coils Prebuilt Wire is suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil is made of Ni80 material by 28GA x 4 + 38GA in 0.22 +/- 0.05ohm with 3mm inner diameter, totally in 5 wraps. 10 PCS / Pack.
Original Coil Father N91 King Coils for RBA / RDA / RTA / RDTA(10 PCS) $2.29
The Original Coil Father N91 King Coils Prebuilt Wire is suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil is made of Ni90 material by 26GA x 2 + 36GA in 0.26 +/- 0.05ohm with 3mm inner diameter, totally in 6 wraps. 10 PCS / Pack.
Original Coil Father N92 King Coils for RBA / RDA / RTA / RDTA(10 PCS) $2.49
The Original Coil Father N92 King Coils Prebuilt Wire is suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil is made of Ni90 material by 26GA x 3 + 36GA in 0.2 +/- 0.05ohm with 3mm inner diameter, totally in 5 wraps. 10 PCS / Pack.
Original Coil Father Alien Clapton Coil for RBA / RDA / RTA / RDTA(2 PCS) $1.89
The Original Coil Father Alien Clapton Coils Prebuilt Wire is suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil is made of A1 material by 26GA x 3 + 32GA in 0.2 +/- 0.05ohm with 3mm inner diameter, totally in 5 wraps. 2 PCS / Pack.
Original Coil Father Coiling Kit V2 Vape Coil Jig $4.99
The Original Coil Father Coiling Kit V2 Vape Coil Jig is made of stainless steel in 17mm Diameter and 82mm Length, it supports Coil Size: 2.0mm, 2.5mm, 3.0mm, and 3.5mm. It can meet most of DIY vaping lovers' needs.
Original Coil Father Shortfill Cap Opener Tool for 60ml E-juice / E-liquid Bottle $1.99
The Original Coil Father Shortfill Cap Opener Tool is made of PC, it is convenient to open E-juice / E-liquid cap of 60ml. The size of it is 97 x 43mm.
Original Coil Father Anti Split 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy/Battle RDA $1.99
The Original Coil Father 810 Replacement Anti Split Drip Tip is made of Resin material, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Coil Father Bravo Organic Cotton Thread for RBA / RDA / RTA / RDTA Vape Atomizer(20 PCS) $2.59
The Original Coil Father Bravo Organic Cotton Threads are made of 100% organic cotton wick and are suitable for RBA / RTA / RDA / RDTA Vape Atomizer as a replacement part. They Support Coil Size: 2.5mm, 3.0mm, 3.5mm, 4.0mm. Each length is 108mm, and the effective length of each is 77mm. 20 PCS / Pack.
Original Augvape Air II Pod System Vape Kit Replacement Pod Cartridge with 1.3ohm OCC Coil(4 PCS) original price $13.36, now only $9.99
The Original Augvape Replacement Pod Cartridge is designed for Augvape Air II Pod System Vape Starter Kit, which features 1.3ohm OCC coil resistance and comes with 1.7ml E-juice / E-liquid Capacity. 4 PCS / Pack.
Original MECHLYFE Compact RBA Section Rebuildable Coil Head with 510 Thread for Geekvape Aegis Boost Pod System Kit $4.28
The Original Mechlyfe Compact RBA Rebuildable Bottom Airflow Section is compatible with Geekvape Aegis Boost Pod System Vape Kit, which is made of stainless steel. It comes with 510 thread connection design means that you can put it on your regulated mods for building purposes and pre-heating the coil. It supports bottom airflow control adjustable.
Honeywell H1005591V H901V KN95 Facial Mask Particulate Respirator with Exhalation Valve Anti PM2.5 Dust / Bacteria / Virus $3.99
Старый 07.03.2020, 04:49 Автор темы   574
3FVAPE
Original OBS Cube FP Fingerprint Unlock 80W VW Box Vape Mod original price $53.45, now only $49.99
The OBS Cube FP Fingerprint Unlock 80W VW Box Vape Mod is based on the Cube X Mod, it is powered by a removable 18650 battery (Not included), which features adjustable wattage output power that from 5W to 80W. The OBS Cube FP comes with a 3D curved tempered glass cover, importantly, it features fingerprint (FP) protection mode. There are six groups of fingerprints that provide you a convenivent fingerprint function, which can protect personal privacy and child-proof. There are also multiple protections that ensure your vaping safety. What' more, OBS Cube FP supports 1.6A charging current with Type-C Charging, the charging time will last 1.5 hours.
Original Dovpo Odin 200 200W TC VV VW Mod $94.99
The Original Dovpo Odin 200 200W TC VV VW Box Vape Mod is constructed from Aluminum Alloy and Zinc Alloy material. Equipped with Dovpo Chipset and powered by Dual 18650 / 20700 / 21700 Rechageable Batteries (Batteries are not included, 18650 adaptors are included), the power range of Odin 200 is from 5W to 200W (Max.) and the temperature range is from 100'C to 315'C / 200'F to 600'F. Dovpo Odin 200 Vape Mod comes with a gold-plated spring loaded 510 pin and a 0.96" OLED Screen that can provide you variety of data from this device. Moreover, the room of Odin 200 Vape Mod can be accommodated up to 30mm diameters without overhang.
Kindbright Katana Semi-Mechanical Box Mod Stealth Clone with Copper Spring Pin $49.99
The Kindbright Katana Box Mod Stealth Clone is constructed from Nylon and Stainless Steel material, which is powered by single 18650 battery (Not included) and comes with a copper spring pin. You just switch on this box mod by press 5 times the button. The Box Mod Stealth fits for all lovers of MTL vaping and it is compatible with atomizers with a maximum diameter of 24mm.
Original OBS Cube FP Fingerprint Unlock 80W VW Box Vape Mod Kit with Cube Tank original price $71.27, now only $56.99
The OBS Cube FP Fingerprint Unlock 80W VW Box Vape Mod Kit is based on the Cube X Mod, it is powered by a removable 18650 battery (Not included), which features adjustable wattage output power that from 5W to 80W. The OBS Cube FP comes with a 3D curved tempered glass cover, importantly, it features fingerprint (FP) protection mode. There are six groups of fingerprints that provide you a convenivent fingerprint function, which can protect personal privacy and child-proof. There are also multiple protections that ensure your vaping safety. What' more, OBS Cube FP supports 1.6A charging current with Type-C Charging, the charging time will last 1.5 hours.
Original Coil Father Premium Premade Twisted Clapton Coils for RBA / RDA /RTA/RDTA(10 PCS) $1.99
The Original Coil Father Premium Premade Twisted Clapton Coils are suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil features 28GA x 2 + 32GA in 0.45ohm, totally in 6 wraps. 10 PCS / Pack.
Original Coil Father Premium Premade Twisted Coils for RBA / RDA / RTA / RDTA Atomizer(10 PCS) $1.99
The Original Coil Father Premium Premade Twisted Coils are suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil features 26GA x 2 in 0.38ohm, totally in 4 wraps. 10 PCS / Pack.
Original Coil Father Premium Premade Tiger Coils for RBA / RDA /RTA/RDTA Atomizer(10 PCS) $1.99
The Original Coil Father Premium Premade Tiger Coils are suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil features 26GA + 0.2 x 0.8 in 0.36ohm, totally in 6 wraps. 10 PCS / Pack.
Original Coil Father Premium Premade Quad Coils for RBA / RDA / RTA / RDTA Vape Atomizer(10 PCS) $1.99
The Original Coil Father Premium Premade Quad Coils are suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil features 28GA x 4 in 0.36ohm, totally in 5 wraps. 10 PCS / Pack.
Original Coil Father Premium Premade Mixed Twisted Coil for RDA/RTA/RDTA Atomizer(10 PCS) $1.99
The Original Coil Father Premium Premade Mixed Twisted Coils are suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil features 0.2 x 0.8 + 26GA in 0.45ohm, totally in 7 wraps. 10 PCS / Pack.
Original Coil Father Premium Premade Hive Coil for RBA/RDA/RTA/RDTA Vape Atomizer(10 PCS) $1.99
The Original Coil Father Premium Premade Hive Coils are suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil features (30GA + 30GA) x 2 in 0.5ohm, totally in 5 wraps. 10 PCS / Pack.
Original Coil Father Premium Premade Fused Clapton Coil for RDA/RTA/RDTA Atomizer(10 PCS) $1.99
The Original Coil Father Premium Premade Fused Clapton Coils are suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil features 0.3 x 0.8 + 32GA in 0.45ohm, totally in 5 wraps. 10 PCS / Pack.
Original Coil Father Premium Premade Flat Twisted Coil for RBA/RDA/RTA/RDTA Atomizer(10 PCS) $1.99
The Original Coil Father Premium Premade Flat Twisted Coils are suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil features 0.2 x 0.8 x 2 in 0.36ohm, totally in 6 wraps. 10 PCS / Pack.
Original Coil Father Premium Premade Clapton Coils for RBA/RDA/RTA/RDTA Atomizer(10 PCS) $1.99
The Original Coil Father Premium Premade Clapton Coils are suitable for RBA / RDA / RTA / RDTA Vape Atomizer. The coil features 26GA + 32GA in 0.45~0.5ohm, totally in 6 wraps. 10 PCS / Pack.
Старый 09.03.2020, 04:44 Автор темы   575
3FVAPE
Original KIZOKU Limit MTL / DL RTA original price $34.99, now only $27.99
The Original KIZOKU Limit MTL / DL Rebuildable Tank Atomizer is a versatile single coil RTA, implementing a 3ml threaded top fill E-juice / E-liquid capacity, child proof locking system, and equipped with a dual slotted airflow control ring that delivers MTL and DL vaping options. The KIZOKU Limit MTL / DL RTA Tank is constructed from high grade stainless steel (body) and glass (tank tube) in 22mm Diameter. At the top is a threaded top fill system implemented in conjunction with a child proof locking system, preventing adolescents and children from refilling the system. At the base is a dual slotted airflow control ring, delivering airflow options for MTL or DL vaping. The build deck is simple, offering a two post design with an airflow outlet aimed directly at the bottom of the coil structure. Each post is equipped with an open terminal, allowing for larger coil configurations or exotic builds.
Original GeekVape Aegis 15W 800mAh Pod System Vape Starter Kit original price $39.99, now only $24.99
The Original Geekvape Aegis 15W 800mAh Pod System Vape Starter Kit is the toughest yet smallest device newly added to the Aegis Series. First IP-67 rated Type-C Charging Pod Vape in the industry,redefines skock proof technology with improved impact toughness, notch toughness and fracture toughness. It is small and convenient to be carried by vaporers everywhere. Matches with new modular G.Coil System, it assures future-proof cross compatibility with upcoming same level of products (5~20W) from Geekvape.The G.Coil Pod-Formula is made to chase the best flavor, designed to perfect leakproof tendency and capable of enhancing most types of salt nic juice. Moreover, it comes with a 3.5ml E-juice capacity pod cartridge that can meet your all day long vaping experience.
Original KIZOKU Chess Series Replacement 510 Drip Tip for RDA / RTA/ RDTA / Sub-Ohm Tank Atomizer(6 PCS) $14.99
Designed by famous Japanese designer, the KIZOKU Chess Series Drip Tip features the innovative chess figures design with different length, which can satisfy your various vaping needs, the Original KIZOKU Chess Series Replacement 510 Drip Tip is made of food grade material SS304L, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. 6 PCS / Pack.
Original KIZOKU Chess Series Replacement 510 Drip Tip for RDA / RTA/RDTA/Sub-Ohm Tank Atomizer(6 PCS) $14.99
Original KIZOKU Chess Series Replacement 510 Drip Tip for RDA / RTA/ RDTA /Sub-Ohm Tank Atomizer(6 PCS) $14.99
Original KIZOKU Chess Series Replacement 510 Drip Tip for RDA / RTA/ RDTA/Sub-Ohm Tank Atomizer(6 PCS) $14.99
Protective Washable Facial Mask Particles Respirator with Melt-blown Filter Layer Defend PM2.5 Dust/Bacteria/Virus(5 PCS) $8.99
Multi-functional Protective Washable Facial Mask is a high-quality facial Mask. It could effectively defend various particles in the air includes PM2.5 dust and bacteria / virus. It has a high-efficiency melt-blown filter layer which absorbs fine particles in the air, defend bacteria / virus. The facial mask is made by 3D defendable shaped polymer polyurethane sponge imported from Japan which is (Antibiosis, Antiviral is available), flexible, soft and comfortable, allaying shock. Moreover, it can be reused and washed over 8 times with water. It will not effect the use of this facial mask even if the mask is washed many times.
Старый 10.03.2020, 04:37 Автор темы   576
3FVAPE
Original OBS Cube X 80W VW Box Vape Mod $33.99
Inherited from OBS Cube family, the OBS Cube X Box MOD is a new cute yet powerful VW box mod with fashionable appearance and portable size. The OBS Cube X box mod is powered by external single 18650 battery (not included)and fires up to 80W max output with advanced VW mode and multiple protections. Plus the 0.96 inch LED screen and easy-operated buttons, you can easily operate it and know the working conditions clearly. The Cube X MOD is comfortable in hand, durable to use and also brings you a great visual enjoyment. Get one and have a try. It is definitely a great daily vaping device for starters or stagers.
Original CoilART Fancy 550mAh AIO Pod System Vape Starter Kit $12.90
The Origianl CoilART Fancy 550mAh Pod System Vape Starter Kit is a Slim All-in-one (AIO) pod kit, which is powered by 550mAh built-in Battery and comes with a 2ml pod cartridge with side filling system, and two types of coils for your options: 0.6ohm / 1.2ohm that meet your different needs.
510 Thread Adapter Connector for SMOKTech SMOK RPM80 / RPM80 Pro Pod System Vape Kit $2.99
The 510 Thread Adapter Connector is designed for SMOKTech SMOK RPM80 / RPM80 Pro Pod System Vape Kit as a 510 thread connection, it can switch your SMOK RPM80 / RPM80 Pro Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you.
Original ThinkVape 510 Thread Adapter Connector for SMOKTech SMOK RPM80 / RPM80 Pro Pod System Vape Kit $3.99
The Original ThinkVape 510 Thread Adapter Connector is is designed for SMOKTech SMOK RPM80 / RPM80 Pro Pod System Vape Kit as a 510 thread connection, it can switch your SMOK RPM80 / RPM80 Pro Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you.
Original CoilART Fancy Pod System Vape Kit Replacement Pod Cartridges(2 PCS) $3.99
The Original CoilART Pod Cartridges are designed for CoilART Fancy Pod System Vape Kit as a replacement part, and it features 2ml E-juice / E-liquid capacity. Moreover, the pod adopts side refilling system that convenient to refill E-juice / E-liquid. 2 PCS / Pack.
Старый 11.03.2020, 04:27 Автор темы   577
3FVAPE
ShenRay Taifun GT IV S DL RTA Clone $28.79
The ShenRay Taifun GT IV S DL RTA Clone is constructed from Stainless Steel in 23mm Diameter. The air duct system bring air flow via the poles in the chamber and adjustable AFC from the outside. It can offer a slightly restricted direct lung hit. Multiple wire mounts (6 connection points) allow for easy installation of the coil with versatility. Optimized for single coil builds, but can fit dual coils.
Vapeasy D.R.A.M III DRAM III MTL / DL RTA Clone $19.99
The Vapeasy D.R.A.M III DRAM III MTL / DL RTA Rebuildable Tank Vape Atomizer Clone is constructed from 316 Stainless Steel (body) and Glass (tank tube) in 22mm Diameter. The deck of this RTA is used as a single coil. It also offers an ultra-reduced atomization chamber to maximize the flavors as well as a rotary adjustment for the supply of E-liquid on cotton. The tank is made of Pyrex Glass and offers a capacity of 2ml in normal version and 4ml with extension. Moreover,the RTA has 3 reducers are available and an airflow ring allows it to be used in MTL or Restrictive DL, and comes with top filling system.
Original ThunderHead Creations THC Tauren Max RDTA Vape Atomizer Replacement Straight Tank Tube $1.99
The Original ThunderHead Creations THC Replacement Straight Tank Tube is designed for THC Tauren Max RDTA Vape Atomizer as a replacement part, which is made of Glass and features 4.5ml E-juice / E-liquid Capacity.
Original Nitecore UM10 Micro USB Charger for 18650, 18490, 18350, 17670, 17500, 16340 (RCR123), 14500, 10400 Batteries $10.99
The Original Nitecore UM10 is a USB powered one channel Li-ion battery charger, which is compatible with Li-ion / IMR: 18650, 18490, 18350, 17670, 17500, 16340 (RCR123), 14500, 10440 Batteries.
Replacement 810 Drip Tip with Airflow Hole for SMOK TFV8 / TFV12 Tank/Kennedy/Battle/Reload RDA $2.59
The Replacement 810 Drip Tip is made of Stainless Steel and Resin material, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Старый 12.03.2020, 04:45 Автор темы   578
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original SY Group Lucifer Mechanical Vape Mod original price $99.99, now only $79.99
The Original SY Group Lucifer mechanical mod is constructed from brass in 24mm diameter, which is powered by single 18650 battery (Not included). It features knurled top hat with 510 threading connection.
Original Hellvape Destiny RTA Tank Vape Atomizer Replacement Straight Tank Tube $1.68
The Original Hellvape Replacement Straight Tank Tube is made of glass material, which features 2ml E-juice / E-liquid capacity and is designed for Hellvape Destiny RTA Tank Vape Atomizer as a replacement part.
Original Hellvape Destiny RTA Tank Vape Atomizer Replacement Bubble Tank Tube $1.99
The Original Hellvape Replacement Bubble Tank Tube is made of glass material, which features 4ml E-juice / E-liquid capacity and is designed for Hellvape Destiny RTA Tank Vape Atomizer as a replacement part.
Original Hellvape Destiny RTA Tank Vape Atomizer Replacement 810 Drip Tip $2.49
The Original Hellvape Replacement 810 Drip Tip is made of PEI material, which is designed for Hellvape Destiny RTA Tank Vape Atomizer as a replacement part.
Original Hellvape Destiny RTA Tank Vape Atomizer Replacement 810 Drip Tip $2.43
The Original Hellvape Replacement 810 Drip Tip is made of PC material, which is designed for Hellvape Destiny RTA Tank Vape Atomizer as a replacement part.
Kindbright Power Mosget Kick Chip for Mechanical Vape Mod $4.99
The Power Mosget Kick Chip is suitable fo Mechanical Vape Mod. It will automatically pause every 10 seconds of working. There are 4 types of protections to ensure that provide a safe vaping for you. (Short-circuit Protection, Battery Reverse Protection, Over Discharge Protection, Low Battery Voltage Protection)
Старый 13.03.2020, 04:43 Автор темы   579
3FVAPE
Original Auguse Era MTL RTA $33.99
The Original Auguse Era RTA Rebuildable Tank Atomizer is constructed from Stainless Steel (Body) and Glass (Tank Tube) in 22mm Diameter. The tank can hold 3ml e-juice capacity. This RTA supports close the juice hole. Era RTA comes with 4 screws, 2 airflow inserts (0.8mm), 2 airflow inserts (1.0mm), 2 airflow inserts (1.2mm). The RTA can change between the side airflow and bottom airflow. There is no distincion between positive and negative when installing the wire coil.
Original Advken OWL Mechanical Vape Mod + Tank Starter Kit original price $49.99, now only $35.99
The Original Advken OWL Starter Kit consists of Advken OWL Mechanical Mod and OWL Mesh Tank, which is top sliding refill and top airflow control, which is powered by 1 x 18650 / 20700 / 21700 Batteries (Not inlcluded). It comes with an adapter sleeve to accommodate smaller diameter batteries. OWL Kit comes with two types of coils (0.16ohm mesh coil / 0.2ohm mesh coil)for you, and the Advken Mesh Coil will bring you a good flavor, curved shape give you the better hand feeling. And the top airflow system can avoid leakage and condensation.
Original Advken Artha 80W VW Box Mod Pod System Vape Starter Kit original price $49.99, now only $44.99
The Original Artha VW Box Mod Pod System Vape Starter Kit is a compact, portable and fashionable pod mod system kit. It adopts 4.5ml large pod cartridge and 80W powerful ouput, which is able to provide you with long-lasting vaping. With convenient side filling design, it also chooses comfortable 510 drip tip. In addition, compatible with 0.3ohm / 0.8ohm mesh coil, it supports bottom air-intake for smooth and pure flavor. Besides, it is equipped with 0.42-inch OLED screen to display you details. And there are multiple protections to ensure your safety, like Over-load / short circuit protection, Overcharge protection, Over-temperature protection, Over-time protection (10s), Low voltage protection, and Anti-Reverse connection protection.
Original Vandy Vape Mato RDTA Vape Atomizer Replacement Steel Wire Guide Wick(4 PCS) $2.99
The Original Vandy Vape Replacement Steel Wire Guide Wick is specially designed for Vandy Vape Mato RDTA Vape Atomizer, which is made of stainless steel and features 3mm in diameter. And 4 steel wire brings you insane juicy flow. 4 PCS / Pack.
Original Vandy Vape Mato RDTA Vape Atomizer Replacement Triple Fused Clapton Coil(5 PCS) $1.99
The Original Triple Fused Clapton Coil is compatible with Vandy Vape Mato RDTA and other RBA / RDA / RTA / RDTA atomizer. It is made of Ni80 material and features 0.26ohm coil resistance and 26GA x 3 + 36GA. 5 PCS / Pack.
Disposable 3-Ply Standard Earloop Medical Surgical Facial Mask Particles Respirator Anti PM2.5 Dust / Bacteria /Virus(50 PCS) $38.99
The Disposable Standard 3-Ply Earloop Medical Surgical Facial Mask Face Mouth Masks is made of 1 ply Polypropylene spun-bond non-woven fabric (effectively isolates saliva etc.) + 1 ply Meltblown non-woven (filter non-oily particles in the air) + 1 ply Polypropylene spun-bond non-woven fabric (absorbing hot air exhaled from the body, bring comfort). It is with adjustable nose bar helps the mask close to face when wearing. The elastic ear-loops wears easily and comfortable.
Across Intan Grip Base Clone + MTL / DL Drip Tip Kit for SXK BB / Billet Box Vape Mod Kit $5.99
The Instan Grip Drip tip Kit Clone includes 1 instan hand screw grip drip tip base, 1 drip tip for MTL (hole 3mm), 1 drip tip for DL (hole 5mm). The grip drip tip base is made of stainless steel and drip tip is made of POM. It is suitable for SXK BB / Billet Box Vape Mod Kit.
Disposable 3-Ply Single-use Type Face Mask Particles Respirator with Nose Wire Anti PM2.5 Dust / Bacteria / Virus(50 PCS) $42.99
The Disposable 3-Ply Single-use Type with Nose Wire Face Mask is made of 1 ply Polypropylene spun-bond non-woven fabric + 1 ply Meltblown non-woven + 1 ply Polypropylene spun-bond non-woven fabric. It is with adjustable nose bar helps the mask close to face when wearing. The elastic ear-loops wears easily and comfortable.
3FVAPE вне форума   Вверх
Старый 14.03.2020, 04:45 Автор темы   580
3FVAPE
Original Oumier Voocean 40 40W 1200mAh VW Box Mod Pod System Vape Starter Kit original price $38.00, now only $29.80
The Voocean 40 Kit is constructed from Zinc Alloy electroplating and TPU material. Powered by a built-in 1200mAh battery and comes with 3.5ml e-juice capacity, it will provide you long-term vaping. It looks marble-like with 2 of the colors having purple tints and one grey. Its ergonomic handle grip offers great and comfortable user experience. There is a circular activation button, two adjustment key and a USB port in the control panel, so it is easy to navigate screen.
Original Hellvape Destiny RTA Tank Vape Atomzier Replacement Straight Tank Tube $2.59
The Original Hellvape Replacement Straight Tank Tube is made of PEI material, which features 2ml E-juice / E-liquid capacity and is designed for Hellvape Destiny RTA Tank Vape Atomizer as a replacement part.
Original Hellvape Destiny RTA Tank Vape Atomzier Replacement Straight Tank Tube $2.99
The Original Hellvape Replacement Straight Tank Tube is made of PCTG material, which features 2ml E-juice / E-liquid capacity and is designed for Hellvape Destiny RTA Tank Vape Atomizer as a replacement part.
Original Wismec R80 Pod System Vape Kit / Cartridge Replacement Bottom Airflow Control RBA Coil Head $9.99
The Original Wismec R80 replacement bottom airflow control RBA Coil Head is specially designed for Wismec R80 pod system vape kit / cartridge, which devotes to offering you DIY enjoyment and large vapor clouds. It comes with an open build space, you can easily install the coil. The bottom airflow system facilitates to dissipate the heat, conducive to produce a perfect taste. The Wismec R80 RBA Coil brings a wide option for coil selection and dense cloud.
Original AWT C4 Intelligent USB 4-Slot Fast Charging Charger for Li-ion / Ni-MH / Ni-CD Batteries $14.99
The Original AWT C4 Intelligent USB 4-Slot Fast Charging Charger is compatible with 10440, 10670, 16340, 14500, 18350, 18490, 18500, 18650, 26650 etc. Li-ion / Ni-MH / Ni-CD Batteries (Not included), which makes charging your batteries simple! AWTs C4 Charger automatically detects your battery after inserting and supports 2A charging for blazing fast speeds.
Original Efest Slim K1 USB Intelligent Charger for 14500 / 16650 / 17650 / 17670 / 18350 / 18500 / 18650 / 20700 / 26500 /26650 $6.99
The Original Efest Slim K1 Charger is a high quality Intelligent Charger with a cost-efficient and portable design. The Efest Slim K1 Charger is a single slot charger with Micro USB input and charges at 1A. The LED indicates when your battery is charging and when the battery is fully charged. The Efest Slim K1 Charger features reverse polarity, short circuit, overcharge protection and many more safety features. The Efest Slim K1 Charger can charge different types of 3.6V / 3.7V lithium batteries commonly used in electronic cigarettes, flashlights, electric tools, and more. It is compatible with 10440, 14500, 14650, 16340, 16650, 17650, 17670, 18350, 18490, 18500, 18650, 20700, 26500, 26650 Batteries (Not included)
Original Vandy Vape Kanthal Wire for RBA / RDA / RTA / RDTA Vape Atomizer $2.59
Original Vandy Vape Kanthal Wire is suitable for RBA / RDA / RTA / RDTA Vape Atomizer, which features elasticity that you can build easily with twist and braid. It is made of Kanthal A1 material, 22GA, 1.52ohm/ft, totally 15ft.
[Ships from Battery Warehouse] Original Golisi S30 IMR 18650 3000mAh 3.7V 35A Flat Top Rechargeable Battery(2 PCS) $14.99
The Original Golisi S30 IMR 18650 Battery, featuring a diameter of 18mm and a length of 65mm, has a 3000mAh large battery capacity with 35A max continuous discharging current. Long storage life, light weight and high energy density. 2 PCS / Pack.
Micro Coil Jig 5-Size Coil Building Rods for RBA / RDA / RTA /RDTA Vape Atomizer $2.59
The Micro Coil Jig 5-Size Coil Building Rods is suitable for RDA / RBA / RTA Rebuildable Atomizer, which is made of stainless steel and in 100mm length. There are 5 diameters can choose: 1.5mm, 2.0mm, 2.5mm, 3.0mm, 3.5mm. This micro coil jig is a compact and handy device for vapers who prefer building their own coils. The coil tool is easy to use: using the numbered guide on the handle of the tool, simply select your preferred size from five different diameters and begin wrapping until you have achieved the desired number of wraps.
Время генерации страницы 0.48219 секунды с 15 запросами
