288772
822
521
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Steam Crave Hadron 220W TC VW Vape Box Mod $96.99
The Steam Crave Hadron 220 Mod, adopted the innovative YiHi SX480 chipset, is powered by Dual 18650 / 21700 batteries (Not included) with a maximum output power of 220W. The large OLED screen displays pertinent vaping data, including power output, battery life, puff, flavor mode, etc. Detailed and simple user interface. The Hadron 220 Mod is perfect match with Aromamizer Plus, Glaz V2 and other atomizers with diameter from 25mm to 35mm. ![]() Original Dovpo The Ohmage Sub Ohm Tank Vape Atomizer with 4 Spare Coils $39.99 The Dovpo Ohmage Sub Ohm Tank Atomizer is a collaboration by Mr.JustRight1 and Dovpo, which is constructed from stainless steel (body) and quartz glass (tank tube) in 26.5mm diameter. The Ohmage Industrys First Dual Stacked mesh coil Adjustable flavor controller (aka airflow) Multiple resistance coils Balanced vapor / flavor production. The Sub Ohm Tank comes with 4 replacement coils: 2 x 0.2ohm Coil (40~55W) and 2 x 0.16ohm Coil (30~45W) for you to choose and 5.5ml juice capacity to meet your all day long vaping experience. ![]() Original Innokin Zenith Pro RDL / MTL Sub Ohm Tank Vape Atomizer $28.99 The Innokin Zenith Pro Sub Ohm Tank Atomizer is constructed from stainless steel (body) and glass (tank tube) in 24mm diameter, which is able to replace the coil without liquid draining whether the tank is upside down OR rightside up. The Zenith Pro comes with 5.5ml juice capacity, two replacement coils: 1.2ohm coil (10~14W) and 1.0ohm coil (20~25W). A new dual tone look with additional color beauty rings that can be purchased separatelyto customize the look of your tank. A higher wattage Z-Coil with more airflow for a restricted direct lung (RDL) vape. All this while maintaining the great mouth to lung (MTL) vape, the Zenith has become known for and completely compatible with the entire exiting Z-Coil line. ![]() Original Sense Herakles 40W 1500mAh VW Pod Mod Hybrid AIO System Vape Starter Kit $28.99 The Sense Herakles VW Pod Mod Kit, a hybrid AIO system kit, consists of a compact pod device and a powerful box mod. With 6ml e-juice capacity, it is powered by 1500mAh built-in battery with 40W max output. It comes with 0.4ohm mesh coil and anti-bacterial cotton for better flavor and healthier vaping. What's more, it is equipped with LED lights and screen to show you data clearly. The Pod Mod Kit is also compatible with the SMOK RPM40 Standard 0.4ohm Coil. ![]() Original HorizoTech Adamats 930mAh Pod System Vape Starter Kit $32.99 The Horizon Adamats Pod System Starter Kit is a super portable, compact vape kit. It features a well-built metal housing, glossy paint finish and an angular appearance. The large ignition button is located in the center of the front panel, and the bottom is the LED battery level indicator. The Horizon Adamats Pod System Kit is powered by a 930mAh built-in battery and is charged via the USB port on the bottom. The LED on the Adamats kit will always inform the vapers as to the current battery levels. The Adamats Pod Kit comes with juice capacity of 3.5ml / 2ml and two coils: 0.6ohm Mesh Coil and 1.0ohm Round Wire to meet different your different vaping needs. ![]() Original Hellvape MD MTL RTA Vape Replacement Straight Tank Tube $2.59 The Hellvape Replacement Glass Tank Tube is specifically designed for Hellvape MD MTL RTA. It features a 2ml juice capacity. It is very easy to clean and replace. ![]() Original Hellvape MD MTL RTA Vape Replacement Bubble Tank Tube $2.59 The Hellvape Replacement Glass Bubble Tank Tube is specifically designed for Hellvape MD MTL RTA. It features a 4ml juice capacity. It is very easy to clean and replace. ![]() Original Sense Replacement Mesh Coil Head for Herakles Pod Mod Kit / SMOK RPM Pod Vape Kit(5 PCS) $9.99 The Sense Replacement Mesh Coil is specifically designed for Sense Herakles Pod Mod Kit and also compatible with SMOK RPM Pod System Kit. The coil resistance is 0.4ohm and wattage Range is from 15W to 30W. 5 PCS / Pack. ![]() Original Sense Replacement Pod Cartridge with 0.4ohm Coils for Herakles Pod Mod /SMOK RPM Pod Vape Kit $7.99 The Sense Replacement Pod Cartridge is specifically designed for Sense Herakles Pod Mod Kit and also compatible with SMOK RPM Pod System Kit. The pod cartridge comes with two 0.4ohm mesh coils and 6ml juice capacity. ![]() Original HorizonTech Adamats Pod Vape Kit Replacement Cartridge with 0.6ohm Mesh Coil(2 PCS) $8.99 The HorizonTech Replacement Pod Cartridge is specifically designed for HorizonTech Adamats Pod Kit. The pod cartridge comes with 0.6ohm mesh coil (21.5~17.1W) and 3.5ml juice capacity. ![]() Original HorizonTech Adamats Pod Vape Kit Replacement Cartridge with 1.0ohm NS Round Wire(2 PCS) $8.99 The HorizonTech Replacement Pod Cartridge is specifically designed for HorizonTech Adamats Pod Kit. The pod cartridge comes with 1.0ohm NS Round Wire (10.2~15.2W) and 3.5ml juice capacity.
522
Original Teslacigs T40W 2000mAh VW Vape Box Mod $35.55
The Teslacigs T40W VW Box Mod is powered by 2000mAh built-in large battery with 40W maximum output power to provide you durable vaping experience, and full charge in just 2 hours at 5V / 1A, no need to wait for a long time. The Box Mod comes with a 0.49 inch OLED intelligent display screen to show you the device's date. There are multiple protections to ensure your vaping safety. ![]() ShenRay TF Taifun GTR MTL RTA Rebuildable Vape Tank Atomizer Clone $18.99 The ShenRay Taifun GTR RTA Clone is constructed from 316 stainless steel (body) and PC (tank tube) in 25mm diameter. The RTA comes with a 4.5ml tank capacity and supports bottom airflow control. ![]() ShenRay TF Taifun GTR MTL RTA Rebuildable Vape Tank Atomizer Clone $17.99 The ShenRay Taifun GTR RTA Clone is constructed from 316 stainless steel (body) and PC (tank tube) in 23mm diameter. The RTA comes with a 4.0ml tank capacity and supports bottom airflow control. ![]() MLNM RTA Rebuildable Vape Tank Atomizer Clone with 2 316SS Spare Chimney $21.99 The MLMM RTA Rebuildable Vape Tank Atomizer Clone is PEI in 22mm diameter, it comes with a 4ml juice capacity glass tank. The RTA supports top refilling and bottom airflow control. ![]() Original Vandy Vape Widowmaker RTA Rebuildable Vape Tank Atomizer original price$59.99, now only$44.99 The Widowmaker RTA Rebuildable Tank Atomizer is constructed from stainless steel in 25mm diameter. The RTA comes with a 6ml juice capacity tank and supports bottom and side airflow control. Adopting dual airflow regulation and side airflow adjustment, it utilizes 3 replaceable air rings to match various airflow adjustment. And it uses dual juice regulation for your option. What's more, it comes with dual coil configuring port, which will bring you great convenience and entertainment. ![]() Original Dovpo Cat God C&G 360mAh Pod System Vape Starter Kit w/o E-liquid original price$23.52, now only$20.99 The Dovpo Cat God CG Pod System Starter Kit, compact and portable, is powered by 360mAh built-in battery with 45~60 minutes for a full charge, and comes with 2ml pod cartridge (Not include e-juice / E-liquid). It adopts magnetic connection between the pod and battery. What's more, it supports 9 flavors for your option (Not included), it is compatible with high-quality nicotine salts. ![]() Original Teslacigs T40W 2000mAh VW Vape Box Mod with Arktos Atomizer Kit $46.24 The Teslacigs T40W VW Box Mod Kit consists of T40W VW Box Mod and Arktos Atomizer, which is powered by 2000mAh built-in large battery with 40W maximum output power to provide you durable vaping experience, and full charge in just 2 hours at 5V / 1A, no need to wait for a long time. What's more, T40W VW Box Mod Kit comes with new different coils: T-A3 (Pre-installed) and T-A4 (1.2ohm), which is suitable for Nicotine salts and Regular e-liquid. With the adjustable airflow system, precise structural design to ensure intake balanced and smooth. What' s more, it features the cross-shaped e-liquid injection hole, easy to fill e-iquid and refused leakage. There are multiple protections to ensure your vaping safety. ![]() Original Blitz Realm 30W 1100mAh VW Box Mod Pod System AIO Vape Starter Kit original price$34.99, now only$27.99 The Blitz Realm VW Vape Box Mod Pod System Starter Kit is designed and branded in Los Angeles, USA, which is powered by 1100mAh built-in battery with output wattage from 5W to 30W that 1.5A quick charge fully charged in 30 minutes and equipped the advanced Taiwan imported chipset with temperature limiting anti-dry hit protection, which can keep a constant output. The facet polymer technology panel brings you a fashion and cool vision. The buck-boost & const-output technology brings you great flavor even with low battery. The pod kit is compatible with SMOK Nord mesh coils for better flavor and longer lifespan. The Blitz Realm pod kit has multiple protection for your safe vaping, and it has 2ml or 3.5ml pod capacity that you can choose. ![]() ShenRay Ontech Ro BF Squonk Mechanical Box Mod Clone with Typhoon BTD Wave BF Vape RDA Clone $14.99 The Ontech Ro Mod with Wave RDA consists of Ontech Ro Box Mod Clone and a 22mm diameter ShenRay Typhoon BTD Wave RDA Atomizer Clone with BF Pin. The Ontech Ro Box Mod Kit Clone is constructed from Aluminum (Box Mod) and 316 Stainless Steel (Atomizer) material, which is powered by Single 18650 Battery (Not included). The BF Squonk Mechanical Box Mod comes with a fire button with safe lock and one peek with 510 adapter to prevent the top of mod overheating. Furthermore, the 510 spring contact pin can support all atomizers. ![]() ---------------------------- Black Friday & Cyber Monday sale informoation Time: 1.Black Friday Discount - All items 10%off 10% OFF : 28th Nov 2019 00:00 - 29th Nov 2019 23:59 (UTC-6 / Denver Time) 2.Cyber Moday Discount - All items 8% off 8% OFF : 30th Nov 2019 00:00 - 2nd Dec 2019 23:59 (UTC-6 / Denver Time) Coupon Code: 2019BlackFriday Note: Site-wide extra 8%-10% off, also valid on discounted products. Shipping fee excluded |
523
Original SMOKTech SMOK G-Priv 3 230W TC VW Vape Box Mod $59.99
The SMOKTech SMOK G PRIV 3 230W TC VW Box Mod, the modern box mod powered by the newest IQ-G chipset, which is powered by dual 18650 batteries (Not included) that allows the max output up to 230W and firing time low to 0.001s. the back panels adopt an acrylic shell pattern panel with a mellow and smooth texture. the vibrant colors make the whole SMOK Mod look more trendy and modern. The Box Mod fits perfectly on the palm for a comfortable grip, it comes with one 2.4 inches large touch screen, which is quite responsive, most of the operations can be finished with a simple touch and the newly upgraded UI provides you the more clear and detailed vaping information, such as the working modes, vaping effect, voltage, battery life. The SMOK Touch Screen Mod with the innovative passcode setting, which helps protect your vaping data and also prevent others from using your device. The G-PRIV 3 with the secondary key to lock and unlock the touch screen, with the independent button you can lock / uplock the screen easily. The Battery cover adopts the large-area strong magnetic adsorption, convenient to install and replace the batteries. with the USB type-C fast-charging system supports 2A super fast charge, the batteries will be fully charged in a short time. ![]() Original Dovpo x Brian Topside Lite 90W TC VW Squonk Box Vape Mod $59.99 The Dovpo x Brian Topside Lite TC VW Box Mod is constructed from Polycarbonate and PCTG material, and powered by Single 20700 / 21700 Batteries (Not included) with 90W max output and the large 0.96-inch OLED screen will available to remind you of the battery status and provide you the vaping data clearly. The Topside Lite Mod is 2 in 1 squonk mod, either used as a regular mod or a squonk mod. ![]() Original Reewape RUOK Ghost 21700 Hybrid Mechanical Vape Mech Mod original price$95.00, now only$76.99 The Reewape RUOK Ghost 21700 Mechanical Mech Mod is a full high-end pure copper mech mod of RUOK, which is constructed from copper material with PVD coating and powered by 1 x 18650 / 20700 / 21700 battery (Not included). The Mech Mod uses unique Innovative Three-Piece clutch connected button. Importantly, it is compatible with 22mm, 24mm, 25mm, 26mm RDA and RTA Atomizer. ![]() Original SMOKTech SMOK TFV16 Lite Mesh Sub Ohm Tank Vape Atomizer $25.99 The TFV16 Lite Sub Ohm Vape Tank Atomizer, the lightweight version of the TFV16 Tank, is constructed from stainless steel (body) and glass (tank tube) in 28mm diameter, it has the same outstanding performance as the TFV16. The sub ohm tank comes with two new mesh coils: Conical Mesh Coil powered by nexMesh Technology and Dual Mesh Coil. The TFV16 Lite Tank comes with a 5ml capacity bulb tank tube, an 810 resin drip tip, an upgraded airflow system, and the reliable locking mechanism, all of which make your ideal vaping partner. ![]() Original Dovpo Variant RDA with BF Pin $27.99 The Dovpo Variant RDA Rebuildable Dripping Atomizer is a versatile 24mm Atomizer built for ease and convenience, which is constructed from stainless steel. The RDA supports side airflow control and comes with Quad posts for dual coil building. The post terminals are drop-in style, similar to the Digiflavor Drop RDA. With a multitude of different air-flow configurations, from a tight draw to a loose cloud chucker, this RDA is designed for any build you can throw at it. This RDA comes with bottom feeder / BF / Squonk Pin. ![]() Original Teslacigs Punk 620mAh Pod System Starter Vape Kit $26.99 The Teslacigs Punk Kit is a new portable pod system with delicate punk design and 1.2ml pod cartridge which features simple fill design. And the Punk Kit is powered by 620mAh battery to provide all day vaping, convenient and quick to charge with a charging cable B. The Punk Kit comes with a 1.4ohm cotton coil, you will obtain great steam and excellent flavor. In addition, the Teslacigs Punk Kit contains a lanyard, you can hang it around your neck and carry it anywhere. ![]() Original Vandy Vape Widowmaker RTA Vape Replacement Straight Tank Tube $1.99 The Vandy Vape Replacement Straight Tank Tube is made of glass, it has a 5ml juice capacity. The Tank Tube is designed for Vandy Vape Widowmaker RTA Vape Atomizer as a replacement part. ![]() Original Vandy Vape Widowmaker RTA Vape Replacement Bubble Tank Tube $1.99 The Vandy Vape Replacement Bubble Tank Tube is made of glass, it has a 6ml juice capacity. The Tank Tube is designed for Vandy Vape Widowmaker RTA Vape Atomizer as a replacement part. ![]() OriginalTeslacigs Punk Pod Vape Kit Replacement Cartridge with 1.4ohm Cotton Coil(3 PCS) $6.99 The Teslacigs Replacement Pod Cartridge is designed for Teslacigs Punk Pod Kit, it comes with a 1.4ohm cotton coil and 1.2ml juice capacity. 3 PCS / Pack. ![]() Original SMOKTech SMOK Conical Mesh Coil Head for TFV16 Lite Vape Tank(3 PCS) $11.99 The SMOKTech Replacement Conical Mesh Coil Head is designed for TFV16 Lite Vape Tank Atomzier (only), it features a 0.2ohm coil resistance with output power range from 60W to 85W. 3 PCS / Pack. ![]() Original SMOKTech SMOK Dual Mesh Coil Head for TFV16 Lite Vape Tank(3 PCS) $11.99 The SMOKTech Replacement Dual Mesh Coil Head is designed for TFV16 Lite Vape Tank Atomzier (only), it features a 0.15ohm coil resistance with output power range from 60W to 90W. 3 PCS / Pack. ![]() ---------------------------- Black Friday & Cyber Monday sale informoation Coupon Code: 2019BlackFriday Time: 1.Black Friday Discount - All items 10%off 10% OFF : 28th Nov 2019 00:00 - 29th Nov 2019 23:59 (UTC-6 / Denver Time) 2.Cyber Moday Discount - All items 8% off 8% OFF : 30th Nov 2019 00:00 - 2nd Dec 2019 23:59 (UTC-6 / Denver Time) Note: Site-wide extra 8%-10% off, also valid on discounted products. Shipping fee excluded |
524
Original USV VIA240 CKS VIA 240 240W TC VW Box Vape Mod original price$69.99, now only$39.99
The USV VIA240 Mod is one of the most impressive vaping devices that we've seen in a long time. From its absolutely striking look to its uniquely advanced technology, this vaping kit won't let you down. Plus, being a dual battery unit coupled with the VO CHIPSET is also what's boosting its popularity amongst the vaping community. The USV VIA240 TC VW Box Vape Mod is powered by dual 18650 batteries (Not included) with wattage rang from 5W to 240W, the VIA240 boasts incredibly high output capabilities, guaranteeing enormous clouds that are thick and satisfying. The Box Mod comes with a 0.91" OLED Display Screen to show you all data of this device. The Box Mod has multiple protections that ensure your vaping safety. It's compatible with any atomizer on the marketing, allowing you customize each hit. This device comes with a flip cover that keeps it safe while providing it with a stunning appearance. ![]() Original Vaporesso Renova Zero 650mAh AIO Pod System Vape Starter Kit original price$29.99, now only$18.99 The Vaporesso Zero 650mAh AIO Pod System Vape Starter Kit is the new pacemaker for all refillable POD systems. It comes with 2ml capacity tank which adopts a new innovative filling system - press to fill which allows easy filling and improved leak prevention. Unique CCELL coil is optimized for high nicotine satisfaction. The Omini Board Mini integrates auto temperature control and multiple protections. The massive 650mAh battery is built in and can be quickly charged to full within 45 minutes. All of these are the perfect mix to give you an easy vaping life. ![]() Original Voopoo Find 12W 420mAh Pod System Vape Starter Kit original price$29.99, now only$10.99 As a smart pod system kit from VOOPOO FIND family, the VOOPOO FIND Pod Kit is a brand-new innovative pod vape device with intelligent GENE. Pod chip supports constant voltage output and brings strong hitting flavors even with nicotine salt. With the concise and delicate design, the FIND Pod Kit is a fashionable device with eye-catching colors to make you a trendsetter anytime and anywhere. What's more, it is powered by a internal 420mAh battery with tri-color indicator light for about 220 puffs available. Plus the 1.8ml refillable pod with easy side filling design and 1.2ohm coil, the VOOPOO FIND Pod Kit will bring you an extremely simple yet amazing vaping. ![]() YDDZ 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer - Type A $2.29 The YDDZ 510 Replacement Drip Tip is made of PC material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() YDDZ 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer - Type B $2.59 The YDDZ 510 Replacement Drip Tip is made of PC material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() YDDZ 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer - Type C $2.29 The YDDZ 510 Replacement Drip Tip is made of PC material, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Voopoo Find Pod Vape Kit Replacement Cartridge with 1.2ohm Coil(4 PCS) $4.99 The VOOPOO Peplacement Pod Cartridge is made of PCTG material, which is designed for VOOPOO Find Pod System Starter Kit as a replacement. It comes with 1.8ml e-liquid capacity and the 1.2ohm coil. The Find Pod Cartridge adopts the side fill design which allows you to fill it quickly and easily. ![]() Original Voopoo VFL Pod Vape Kit Replacement Cartridge with 1.2ohm Ceramic Coil(4 PCS) $3.99 The VOOPOO Peplacement Pod Cartridge is made of PCTG material, which is designed for VOOPOO VFL Pod System Starter Kit as a replacement. It is a refillable pod cartridge with 0.8ml e-juice capacity. It comes with 1.2ohm ceramic coil and u-shape airflow system, which can bring you the original taste and optimal flavor. Plus the two airflow holes with different pore sizes, the VOOPOO VFL Pod can be placed accordingly to connect either airflow on both sides. ![]() Original Voopoo Rota Pod Vape Kit Replacement Cartridge with 1.5ohm Coil(4 PCS) $4.99 The VOOPOO Peplacement Pod Cartridge is made of PCTG material, which is designed for VOOPOO Rota Pod System Starter Kit as a replacement. It is a refillable pod cartridge with 1.5ml e-juice capacity and comes with 1.5ohm coil. ![]() ---------------------------- Black Friday & Cyber Monday sale informoation Coupon Code: 2019BlackFriday Time: 1.Black Friday Discount - All items 10%off 10% OFF : 28th Nov 2019 00:00 - 29th Nov 2019 23:59 (UTC-6 / Denver Time) 2.Cyber Moday Discount - All items 8% off 8% OFF : 30th Nov 2019 00:00 - 2nd Dec 2019 23:59 (UTC-6 / Denver Time) Note: Site-wide extra 8%-10% off, also valid on discounted products. Shipping fee excluded |
525
SXK Hussar V2.0 RDA 2.0 Clone $17.90
The SXK Hussar V2.0 RDA Clone is constructed from 316 Stainless Steel in 22mm diameter. The RDA features dual post build deck design and Anti-Spin Lock Mechanism. It can interchangeable top piece (X / MTL X / Legacy / RDTA + Compatible). The RDA has a 4 holes (1.5mm each) milled at an angle for best flavour and to prevent and supports side airflow adjustable control. ![]() Original Talent Vape ECO 40W 1100mAh VW Mod Pod System Vape Starter Kit $29.99 The Talent Vape ECO Pod System Vape Starter Kit is an ultra-compact pod system device. The ECO Pod Kit is constructed from Zinc Alloy and PCTG material, the surface gloss looks very refined and shaped in the size of a palm, you would find it burdenless when holding in hands. The dreamlike pattern adds the aesthetics to a monotonous vaping device, standing you out of the vaping crowd. It is powered by a built-in 1100mAh battery and comes with a 4.5ml pod cartridge to meet your all day long vaping. What's more, it adopts the adjustable working mode and side airflow system design to meet your individual demands better. Two types of coils are included: 0.6ohm Mesh Coil (15~25W) for DTL vapers and 1.2ohm Ceramic Coil (8~15W) for MTL vapers. ![]() Original Reewape AS237 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.68 The Reewape AS237 510 drip tip is made of resin material and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Reewape AS238 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.58 The Reewape AS238 510 drip tip is made of resin material and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Reewape AS239 510 Replacement Drip Tip for RDA / RTA/RDTA/Sub-Ohm Tank Vape Atomizer $1.48 The Reewape AS239 510 drip tip is made of resin material and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Reewape AS243 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.65 The Reewape AS243 510 drip tip is made of resin material and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Reewape AS262 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.48 The Reewape AS262 510 drip tip is made of resin material and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Reewape AS266 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.48 The Reewape AS266 510 drip tip is made of resin material and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() SXK Replacement Drip Tip for SXK NOI RTA Vape Atomizer Clone $11.90 The SXK Replacement Drip Tip is made of POM and 316 Stainless Steel material in 23mm height and 12.5mm outer diameter. It is suitable for SXK NOI RTA Vape Atomizer Clone. ![]() SXK Fire Button + Screen Plate + Button Plate Set for SXK BB 60W / 70W Box Mod Kit(3 PCS) $25.90 This SXK replacement accessories set are suitable for SXK BB Bantam BB 60W / 70W box mod kit. This set includes Fire SXK Button + Screen Plate + Button Plate Set..The Panel Set adopts sandblasting technology. ![]() Original Talent Vape Replacement RBA Coil Head for ECO Pod Vape Kit / Cartridge $5.50 The Talent Vape ECO Replacement RBA Coil Head is designed for Talent Vape ECO Pod Kit / Pod Cartridge as a replacement part. It fits for DIY vaping lovers. ![]() Original Talent Vape Replacement DTL Mesh Coil Head for ECO Pod Vape Kit / Cartridge(5 PCS) $8.99 The Talent Vape ECO Replacement DTL Mesh Coil Head is designed for Talent Vape ECO Pod Kit / Pod Cartridge as a replacement part. It features 0.6ohm coil resistance and power range is from 15W to 25W. 5 PCS / Pack. ![]() Original Talent Vape Replacement MTL Ceramic Coil Head for ECO Pod Vape Kit / Cartridge(5 PCS) $8.99 The Talent Vape ECO Replacement MTL Ceramic Coil Head is designed for Talent Vape ECO Pod Kit / Pod Cartridge as a replacement part. It features 1.2ohm coil resistance and power range is from 8W to 15W. 5 PCS / Pack. ![]() Original Talent Vape ECO Pod Vape Kit Replacement Cartridge w/o Coil(2 PCS) $8.99 The Talent Vape ECO Replacement Pod Cartridge is designed for Talent Vape ECO Pod Kit and comes with 4.5ml juice capaciy. It is compatible with three kinds of coil: DTL Mesh Coil 0.6ohm, Ceramic MTL Coil 1.2ohm and RBA Coil, which will fit your demands for vaping. (Not included). 2 PCS / Pack. ![]() ---------------------------- Black Friday & Cyber Monday sale informoation Coupon Code: 2019BlackFriday Time: 1.Black Friday Discount - All items 10%off 10% OFF : 28th Nov 2019 00:00 - 29th Nov 2019 23:59 (UTC-6 / Denver Time) 2.Cyber Moday Discount - All items 8% off 8% OFF : 30th Nov 2019 00:00 - 2nd Dec 2019 23:59 (UTC-6 / Denver Time) Note: Site-wide extra 8%-10% off, also valid on discounted products. Shipping fee excluded |
526
Original Oumier PLIP 550mAh 2 IN 1 Vaporizer Vape Mod Battery for 510 Atomizer & 13.8 x 5.6mm Cartridge original price$21.90, now only$14.99
The Oumier PLIP 2 IN 1 Vaporizer Vape Mod Battery comes with 550mAh built-in battery, which will provide you with long vaping session. It works with all 510 oil cartridge and most 13.8 x 5.6mm pods. What's more, it adopts flexible gold-plated electrode to ensure the stable and reliable performance. Furthermore, featuring 10 seconds pre-heat function, it utilizes one key operation with intelligent air switch for easy operation. ![]() Kindbright Vapor Giant VG Kronos 2S DL / MTL RTA Clone $22.99 The Kindbright Vapor Giant VG Kronos 2S RTA Clone is constructed from 316 stainless steel (body) and PC (tank tube) in 23mm diameter. The RTA has a 4ml juice capacity tank tube and comes with dual post build desk design, it supports top filling, bottom airflow adjustable control and DL / MTL vaping experience. What's more, it comes with a childproof topcap and leakproof design, too. ![]() Original ROUCI Swand 15W 450mAh Pod System Vape Starter Kit $11.99 The POUCI Swand Pod System Starter Kit, a compact and portable open pod system kit, which is constructed from Aluminum material, and comes with 2ml easy top filling cartridge. Powered by 450mAh built-in battery with 15W max output, it adopts magnetic connection for easy operation. And it utilizes micro USB port for easy and quick charging. What's more, it supports 1.1ohm cotton coil to create big vapor and perfect taste. Furthermore, it provides multiple protections to ensure your vaping safety. ![]() Original Tesla AIO 70W TC VW Box Mod Vape Starter Kit original price$43.99, now only$22.99 The Tesla AIO 70W all-in-one TC VW Box Mod Starter Kit features a built-in internal tank inside a powerful single 18650 battery (Not included) mod. The Tesla AIO 70W supports temperature control with stainless steel, nickel and titanium coils and can fire up to 70 watts. The Tesla AIO 70W features a comfortable top fire button along with hidden bottom adjustment buttons. The built-in glass tank has a 4.5ml e-Liquid capacity and features a leak resistant top-filling cup design for easy refills. The Tesla AIO 70W utilizes unique rewickable Tesla EOCC atomizer heads which are easily rewicked. ![]() Original SMOKTech SMOK Fetch Mini 40W 1200mAh VW Box Mod Pod System Vape Starter Kit $36.99 The SMOKTech SMOK Fetch Mini Pod Kit, powered by an built-in 1200mAh battery, is constructed from eco-friendly PCTG material body and featured with Acrylic panel. The Pod Kit comes with a 3.7ml pod cartridge to meet your daily vaping experience. Paired with convenient magnetic installation system, the Fetch Mini chamber also supports waterproof and dust proof functions. Fetch Mini Pod Kit is supported by advanced technology, allowing you to adjust wattage from 5W to 40W freely. Plus the 0.96" TFT Screen can display pertinent vaping data for you. The pod kit includes two sets of pods and coils -- RPM pod and RPM Mesh 0.4ohm Coil, Nord pod and Nord Regular DC 0.6ohm Coil, which are one-to-one correspondence. And Fetch Mini RPM Pod and Nord Pod are compatible with RPM coils and Nord coils respectively, you can choose the pod and coil according to your preference. ![]() Original ROUCI Swand Pod Vape Kit Replacement Cartridge with 1.1ohm Cotton Coil $8.99 The ROUCI Replacement Pod Cartridge is designed for ROUCI Swand Pod System Vape Starter Kit, it is made of PCTG, which comes with 2ml juice capacity and a 1.1ohm food grade cotton coil. 5 PCS / Pack. ![]() Replacement RBA Coil Head + 510 Connector Adapter with Airflow Adjustable for SMOK RPM40 40W Pod / SMOK Fetch Mini 40W $5.99 The SMOK RPM RBA Airflow Adjustable Rebuildable Coil Head is made of stainless steel. It features Airflow Adjustable function and comes with a 510 Connector Adapter. The RBA is Suitable for SMOK RPM40 40W Pod / SMOK Fetch Mini 40W Pod System. ![]() ---------------------------- Black Friday & Cyber Monday sale informoation Coupon Code: 2019BlackFriday Time: 1.Black Friday Discount - All items 10%off 10% OFF : 28th Nov 2019 00:00 - 29th Nov 2019 23:59 (UTC-6 / Denver Time) 2.Cyber Moday Discount - All items 8% off 8% OFF : 30th Nov 2019 00:00 - 2nd Dec 2019 23:59 (UTC-6 / Denver Time) Note: Site-wide extra 8%-10% off, also valid on discounted products. Shipping fee excluded |
527
Original Wismec Sinuous P80 80W TC VW Box Vape Mod original price$33.99, now only$21.99
The SINUOUS P80, a new flagship e-cig mod designed by sinuous designs, impresses us with its centered 510 connector and side OLED display. Powered by single 18650 cell (Not included), it reaches a mighty 80W output along with a sequence of other unique features including 2A quick charge, preheat and LED light with changeable colors. ![]() Original Nikola Lapetus Sub Ohm Tank Vape Atomizer original price$28.95, now only$7.99 The Nikola Lapetus is constructed from Stainless Steel, Aluminum Alloy (body) and Glass (tank tube) in 25mm diameter, it is compatible with most mod devices. It makes E-juice filling easy and convenient by its top-fill design. The Lapetus Tank comes with a 4.5ml Normal Tank Tube (Pre-installed), a spare 6ml Bubble Glass Tank Tube and a 0.18ohm Mesh coil that power range from 60W to 110W (Best: 70~90W), a perfect vapor experience brought to vapors. Changing coils is easy with its Plug-N-Pull design. ![]() Original SMOKTech SMOK TFV12 Prince Sub Ohm Tank Vape Atomizer original price$39.99, now only$24.99 The SMOKTech SMOK TFV12 Prince Tank is not only a powerful one but also an all-round sub ohm tank for daily use. The tank adopts 3 newest coils: V12 Prince Q4, V12 Prince X6 and V12 Prince T10, all of which have huge cloud and extremely dense flavor. It also has newly designed crown-style body and colorful Cobra resin drip tip. Besides, it uses convex glass tube, which effectively enlarged the capacity to 8ml. ![]() Original SMOKTech SMOK TFV8 X-Baby Sub Ohm Tank Vape Atomizer original price$23.99, now only$14.99 Among TFV8 series with stylish bottom airflow system, it is TFV8 X-Baby with top airflow that we are making the attempt to provide an entirely different tank for clouds chasers. And our engineers make innovation on both the structure and coil's design. So it brings massive clouds, rich flavor, smooth airflow and pleasant atomization sound after repeated test and improvement. Besides, large 4.0ml capacity and classical swivel top cap design makes refilling and leak-proof easier. Finally, as the baby beast brother, TFV8 X-Baby will be a surprise member of TFV8 family. Innovation keeps changing the vaping experience. ![]() Vapor Giant VG Kronos 2S DL / MTL RTA Clone $21.99 The Vapor Giant VG Kronos 2S RTA Clone is constructed from 316 stainless steel (body) and PC (tank tube) in 23mm diameter. The RTA has a 4ml juice capacity tank tube and comes with dual post build desk design, it supports top filling, bottom airflow adjustable control and DL / MTL vaping experience. What's more, it comes with a childproof topcap and leakproof design, too. ![]() Original Voopoo Drag Nano 750mAh Pod System Vape Starter Kit original price$33.90, now only$11.99 The Voopoo Drag Nano Pod System Kit is a brand new pod system kit of Drag series. It has elegant exterior and small size. It adopts brand-new GENE.Pod Chip to support the intelligent cold boot mode for better flavor. 750mAh built-in battery allows for 350 puffs. It comes with a smart LED indicator to display battery status. The pod cartridge can hold 1ml e-liquid and utilizes 1.8ohm coil head for intense flavor and smooth clouds. ![]() Original Eleaf iStick Pico 25 85W TC VW Mod + Ello Tank Vape Starter Kit original price$45.99, now only$39.99 The iStick Pico 25 ingeniously packs a big 0.91" screen that offers a concise and clear interface, 2A quick charge capability and upgradeable firmware with preheat function in a compact, stylish yet powerful package. Powered by a single 18650 battery, the iStick Pico 25 is capable of outputting a maximum power of 85W and can handle various tanks up to 25mm diameter. With a compact size, you can hold it in the palm, much more convenient for usage and portability. The ELLO atomizer features its all-new HW series coils, bringing you ultimate vaping experience with nice flavor. The retractable top fill system makes it really easy to fill the tank. You just need to slide the drip tip back and it reveals the fill port. The dual large air inlets allow optimal airflow for great vapor production. Not only does the ELLO come in various colors for your choice, it also provides you with two drip tips, one with a tapered elegant shape and the other with a wider bore for more airflow and flavorful taste. ![]() Original Kanger SUBOX Mini-C 50W VW Box Mod + Subtank Mini-C Tank Vape Starter Kit original price$39.99, now only$24.99 The Kangertech SUBOX Mini-C Starter Kit includes the KBOX Mini-C 50W Mod and the Subtank Mini-C Tank. The SUBOX Mini-C Starter Kit is designed for beginners or vapers looking for a simple yet effective setup. The SUBOX Mini-C Starter Kit is the perfect starter kit for vapers looking for a sub-ohm and cloud producing experience without destroying the wallet. The KBOX Mini-C 50W Mod can fire up to 50 watts and has a minimum resistance of 0.3 ohm. The KBOX Mini-C 50W Mod requires (1) high amp 18650 battery (not included) and has a magnetized battery cover for easy and convenient access. The device may also be recharged via the micro USB charging port. The Subtank Mini-C Tank features many new quality of life improvements based on the design of the past Subtank / Toptank models. The Subtank Mini-C now offers a top-fill option for easy e-liquid refills which can be accessed by unscrewing the top cap. The Subtank Mini-C features a leak resistant glass tank cup design which has a 3.0mL e-Liquid capacity. The tank also features an adjustable e-Liquid channel and symmetric airflow slots. The Subtank Mini-C Tank also now supports the popular SSOCC atomizer heads which allows for more airflow, vapor, and flavor. ![]() Original Eleaf iStick Pico 75W TC VW Mod + MELO III Tank Vape Starter Kit original price$45.99, now only$35.99 The Eleaf iStick Pico, just like its name, is preferable, innovative, compact and outstanding (PICO). With a compact size can fit perfect in your palm, much more convenient for usage and portability. Powered by 1 x 18650 battery (Not included), the iStick Pico also provides you with 75W maximum power output and switchable VW / Bypass / TC-Ni / TC-Ti / TCR modes. The ventilation holes at the bottom are for better heat dissipation and the adjustment buttons are located at the bottom as well. Eleaf iStick Pico also retains stainless steel spring loaded 510 connector for strong wear resistance and high adaptability. With top e-liquid filling design, hidden airflow control and detachable structure, the MELO III is the best match for the iStick Pico. ![]() Steam Tuners T11 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $2.99 The Steam Tuners T11 510 Replacement Drip Tip is made of POM and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
528
Original Eleaf iStick Rim C 80W TC VW Box Vape Mod $31.17
The iStick Rim C TC VW Vape Mod, an ergonomic and suitable size box mod, is compatible with iStick Rim C Kit with MELO 5 Tank (Not included). Powered by replaceable single 18650 battery (Not included) with 80W max output, it adopts USB type-c port for convenient and quick charging. And it chooses 3 kinds of mode for your option: TC mode, VW mode and Bypass Mode. What's more, it is equipped with a screen to show you clear vaping data. And to ensure your safety, it provides you with Short Circuit Protection and Low Voltage Protection. ![]() Hellfire Cobra Squonk Mechanical Box Mod Clone original price$46.89, now only$14.99 The Hellfire Cobra mod Clone is a squonk mechanical box mod. It is powered by single 18650 battery (NOT INCLUDED). The internal squeeze bottle is made from silicone with 7ml of juice capacity. ![]() Sine MTL RTA Clone $10.99 The Sine Dvarw Atty MTL RTA Clone is designed and built in the USA. It is constructed from 316 Stainless Steel (Body) and Polycarbonate (Tank) in 22 mm diameter, it comes with a tank of 4.2ml juice capacity. The MTL RTA supports bottom adjustable internal airflow control and easy top filling system. ![]() Nipple RDA Clone original price$9.99, now only$5.99 The Nipple RDA Clone is constructed from food grade stainless steel in 22mm diameter. The RDA is extra small chamber extreme taste. The Nipple RDA Clone supports single coil, dual coils, vertical and horizontal coil configuration. This RDA is perfect choice for both flavor and cloud chasers. ![]() DDP ONE RTA Clone original price$22.99, now only$5.99 The DDP One RTA Clone is constructed from 316 stainless steel and PC tank, in 22mm diameter and 2.0ml capacity. The DDP One RTA Clone is easy liquid refilling design. Just remove the top cap, and fill liquid into a hole located in the side of the reducer. The chamber shroud directs air flow from the top of the cap to the lowest sides to hit vertical coils directly. This ensures proper air flow while maximizing flavor production and minimizing leakage even further. This shroud is a huge improvement over the traditional Genesis setup. ![]() Goon RDA Clone with Wide Bore Drip Tip original price$12.99, now only$5.99 The Goon RDA Clone is a 24mm RDA that uses an innovative "bridge clamp" design unrivaled by any other design in the industry. Installing massive and intricate builds or the simplest coils have never been easier with the bridge clamp design of the Goon. This Goon RDA Clone features a quad-pole and with the adjustable air holes, it supports dual and single coil build. The Goon RDA comes with 1/2" wide bore drip tip. ![]() Split R Atty RDTA Clone original price$18.99, now only$5.99 The Split R Atty RDTA Clone is a rebuildable tank atomizer features 22mm diameter and 1.3ml e-juice capacity. The Split RTA Clone is constructed from 316 Stainless Steel and Acrylic. Comes with dual post deck, big build room, this Split RTA Clone will bring you a good vaping experience! ![]() DNV Scar Atty RDTA Clone with BF Pin original price$19.99, now only$5.99 The DNV Scar Atty RDTA Clone is constructed from 316 stainless steel in 22mm diameter. The deck features dual post design for single or dual coil building. The side airflow is adjustable for smooth vapor. Removable POM wide bore drip tip is included. ![]() Hobo 4.0 Customs Drifter RDA Clone original price$10.99, now only$5.99 This Hobo Customs Drifter RDA Clone rebuildable atomizer is made from Stainless Steel in 22mm diameter. It's unique airflow comes up under the coil at an angle will bring you the good vaping experience. ![]() Karma RDA Clone with BF Pin original price$17.99, now only$5.99 The Karma RDA Clone is constructed from 316 stainless steel in 18mm diameter. The build deck has dual post for single coil build. The air accesses the chamber via bottom airhole and travels up to the bottom of the coil. The top cap is made of Delrin.
529
NoLegal RDA Clone with BF Pin original price$18.99, now only$5.99
The NoLegal RDA Clone is constructed from 316 stainless steel with bottom feeder pin and comes with Tank Cloud Cap. The RDA is delivered with pre-assembled Bottom Feeder Pin and is ideally equipped for use as a squonker. But also as a traditional dripper, the RDA makes no compromises and delivers pure taste. A separate center pin for the regular operation as dripper is included. The 316 stainless steel construction is of high quality. The poles on the side of the small atomizer chamber allow for easy mounting and positioning of the coils, with the proven system. This RDA comes with bottom feeder / BF / Squonk Pin. ![]() IAI V2 BF 2.0 RDA Clone with BF Pin original price$11.99, now only$5.99 The IAI V2 RDA Clone is constructed from 316 stainless steel and in 22mm diameter. The 3FVape RDA comes with bottom feeder center pin. SXK Version IAI V2 RDA Clone. This RDA comes with bottom feeder / BF / Squonk Pin. ![]() Hurricane V2 RTA Clone original price$23.99, now only$10.99 The Hurricane V2 RTA Clone is constructed from stainless steel and glass in 22.5mm diameter and holds 2ml capacity. The RTA is with 3 different airflow types for wide-direct lung inhale, medium lung inhale and MTL (mouth to long inhale). ![]() SQX Squape X Dream RTA Clone original price$31.99, now only$10.99 Comparison between 2 SQuape X [Dream] RTA Clone From 3FVAPE The SQX X Dream style RTA is a rebuildable tank atomizer with 22mm diameter. It features 4ml juice capacity. The SQX X Dream RTA Clone is top filling with stepless airflow control. ![]() Original Eleaf iStick Rim C 80W TC VW Box Vape Mod Kit with Melo 5 Tank Atomizer $51.68 The Eleaf iStick Rim C TC VW Box Vape Mod Kit consists of Rim C TC VW Box Vape Mod and Melo 5 Tank Atomizer. The Eleaf iStick Rim C is powered by single 18650 battery (Not included) with maximum output of 80W . The IML technology makes the Eleaf iStick Rim C mod so outstanding in appearance. The anti-dry-burn mechanism of Eleaf iStick Rim C will ensure a safe vape too. The innovative Type-C quick charge system makes the Eleaf iStick Rim C Mod a real advanced device with short charging time. The Melo 5 Tank adopts 2ml / 4ml juice capacity for your selection. The new EC SS316L Mesh coil brings huge cloud and flavorful taste. The top childproof system and bottom liquid lock design provides dual protection for the Melo 5 ![]() Noi 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $6.99 The Noi 510 Replacement Drip Tip is made of POM and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Dovpo Blotto RTA Vape Atomizer Replacement Straight Tank Tube $2.85 The Dovpo Replacement Straight Tank Tube is made of Glass, which is designed for Blotto RTA Vape Atomizer. It comes with a 2ml juice capacity. ![]() Original Dovpo Blotto RTA Vape Atomizer Replacement Bubble Tank Tube $3.33 The Dovpo Replacement Bubble Tank Tube is made of Glass, which is designed for Blotto RTA Vape Atomizer. It comes with a 6ml juice capacity. ![]() Original Dovpo Replacement Bottom Feeder Juice Bottle for Topside Lite 90W Squonk Box Vape Mod $10.69 The Dovpo Replacement Squonk Bottle is made of silicone, which is designed for the Dovpo Topside Lite 90W TC VW Squonk Box Mod, it comes with 10ml juice capacity. ---------------------------- Black Friday & Cyber Monday sale informoation Coupon Code: 2019BlackFriday Time: 1.Black Friday Discount - All items 10%off 10% OFF : 28th Nov 2019 00:00 - 29th Nov 2019 23:59 (UTC-6 / Denver Time) 2.Cyber Moday Discount - All items 8% off 8% OFF : 30th Nov 2019 00:00 - 2nd Dec 2019 23:59 (UTC-6 / Denver Time) Note: Site-wide extra 8%-10% off, also valid on discounted products. Shipping fee excluded |
530
Original asMODus ANANI MTL RTA original price$29.99, now only$23.99
The asMODus ANANI MTL RTA is constructed from stainless steel in 24mm diameter, which comes with 5.3mm deep juice and gold plated grub screws, gold plated squonk. With top airflow design and two post build deck, this RTA can offers excellent flavor. What's more, it can be used as a squonker RTA for bottom feeding devices. ![]() Original Uwell Crown 25W 1250mAh Pod System Vape Starter Kit $25.99 The Uwell Crown pod system vape kit is a stylish and powerful pod device. The sleek body with the Gothic pattern and the Crown fire button provides an elegant look and comfortable grip. The pattern is clear and detailed, the hand feels delicate. Uwell Crown Pod System kit supports two working modes. In the unlocked state, you can choose to use direct suction or button ignition, which is convenient and simple. The Uwell Crown is powered by a built-in 1250 mAh battery, providing stable output for longer battery life, and supports three different LED battery level indicator display status. You can easily know the working condition and battery levels with indicator light. Uwell Crown has a maximum transmit power of 25W, a built-in BEIN chip in the fuselage, and multiple circuit protection functions. The performance is stable and the use is more assured. As for the Crown Pod cartridge, it is an open-type cartridge with a capacity of 3ml, the top-fill design reduces leakage, you can repeatedly filling your favorite e-liquid and nicotine salt e-liquid. ![]() Original SXK Bantam Revision 30W VW Box Vape Mod Kit w/o 18350 Battery original price$75.00, now only$62.99 The SXK Bantam Revision 30W VW Variable Wattage Mini Box Vape Mod Kit is powered by 1 x 18350 battery (Not included) with output power of maximum 30W. Compact but fully functional variable power device that integrates various pre-built and reconflgurable coil units with a variety of adapters. SXK Bantam Revision is equipped with new updated SEVO-30 Chipset that provide you a new experience. It comes with new MTL pod unit and EUC Coil to provide you MTL vaping experience and great vapor enjoyment. The mod kit is compatible with Aspire Nautilus Coils that meet your different vaping needs. What's more, Bantam Revision has a AFC airflow control function that makes airflow control conveniently and fastly. ![]() [Ships from Battery Warehouse] Original SXK Bantam Revision 30W VW Box Vape Mod Kit with 18350 Battery original price$75.00, now only$64.99 The SXK Bantam Revision 30W VW Variable Wattage Mini Box Vape Mod Kit is powered by 1 x 18350 battery (Included) with output power of maximum 30W. Compact but fully functional variable power device that integrates various pre-built and reconflgurable coil units with a variety of adapters. SXK Bantam Revision is equipped with new updated SEVO-30 Chipset that provide you a new experience. It comes with new MTL pod unit and EUC Coil to provide you MTL vaping experience and great vapor enjoyment. The mod kit is compatible with Aspire Nautilus Coils that meet your different vaping needs. What's more, Bantam Revision has a AFC airflow control function that makes airflow control conveniently and fastly. ![]() Original Uwell MarsuPod PCC 1000mAh Pod System Vape Starter Kit $27.99 The Uwell Marsupod PCC Kit consists of a 150mAh rechargeable Pod System Device and a 1000mAh Rechargeable Case. Uwell Marsupod PCC Kit is constructed from durable plastic, lightweight and easy to carry. The PCC Pod Kit combines a pod system with a carrying case, providing enough power for approximately six full charges. The design of this pod system and a charging carrying case is convenient for a long and sustained to enjoy vaping without worrying about the insufficient battery. Uwell Marsupod PCC's pod system section has 1.3ml refillable and replaceable pod cartridge. View the e-liquid capacity in the cartridge through the juice window. And refilled with a side filling system (plugged by a silicone plug). Generate delicious steam from your favorite e-juice with the integrated 1.2ohm resistance coil. What's more, when putting pod system equipment into a rechargeable carrying case, a lever system pulls the pod system within, the sliding cigarette holder cover will hide the top of the pod to prevent debris from entering the cigarette holder, which is very humane. ![]() Original Ohm Vape AIO Pod Vape Kit Replacement Empty Pod Cartridge $1.99 The Ohm Vape AIO Pod Kit Replacement 3ml Empty Pod Cartridge is designed for Ohm Vape AIO Pod System Kit, but coil is not included in it. ![]() Original Uwell MarsuPod PCC Pod System Vape Kit Replacement Refillable Pod Cartridge with 1.2ohm Coil $9.99 The Uwell Replacement Refillable Pod Cartridge is designed for Uwell MarsuPod PCC Pod System Kit, which comes with a 1.2ohm coil and features 1.3ml juice capacity. 4 PCS / Pack. ![]() Original Uwell Crown Pod System Vape Kit Replacement Refillable Pod Cartridge with 1.0ohm MTL Coil(2 PCS) $7.99 The Uwell Crown Pod cartridge, it is an open-type cartridge with a capacity of 3ml, the top-fill design reduces leakage, you can repeatedly filling your favorite e-liquid and nicotine salt e-liquid. Compatible with 1.0ohm coil for MTL, using classic double heating wire design, excellent atomization effect, strong flavor release. The Uwell Replacement Refillable Pod Cartridge is designed for Uwell Crown Pod System Kit. 2 PCS / Pack. ![]() Original Uwell Crown Pod System Vape Kit Replacement Refillable Pod Cartridge with 0.6ohm DTL Coil(2 PCS) $7.99 The Uwell Crown Pod cartridge, it is an open-type cartridge with a capacity of 3ml, the top-fill design reduces leakage, you can repeatedly filling your favorite e-liquid and nicotine salt e-liquid. Compatible with 0.6ohm coil for Restricted DTL, using classic double heating wire design, excellent atomization effect, strong flavor release. The Uwell Replacement Refillable Pod Cartridge is designed for Uwell Crown Pod System Kit. 2 PCS / Pack. ![]() YFTK Haku Xeta Inside RBA Rebuildable Atomizer Clone for BB Box Mod Kit $33.99 The YFTK Haku Xeta RBA Clone is constructed from Titanium Alloy and ultem. This RBA consists 510 chimney section, airdraw insert, elevating coil clamp system, airflow disk, wick channel controller pin, and air intake. It is suitable for BB Box Mod Kit.
531
The YFTK Haku Xeta RBA Clone is constructed from Titanium Alloy and ultem. This RBA consists 510 chimney section, airdraw insert, elevating coil clamp system, airflow disk, wick channel controller pin, and air intake. It is suitable for BB Box Mod Kit. ![]() Original Snowwolf Kfeng 80W 2500mAh VW Box Vape Mod + Mark Tank Atomizer Kit $49.99 The Snowwolf K-feng different from the traditional box mod, it has a slim body which gives you a better hand feeling and the novel appearance. Kfeng Kit continues to use the classic element- 3D Snowwolf logo design, which provides the most unique ID for you. Supporting 0.008s Insta-fire, Kfeng can also provide you the most sensational taste of every puff and large vapor clouds experience. It is powered by 2500mAh built-in battery, which support 5~80W wattage range. And with the real fast charge, Kfeng offers you the amazing charging speed. What's more,it comes with 0.3ohm Mark-X coil, which will provide long-lasting performance and great taste for you. ![]() Original Yuoto ACME 1200mAh Pod System Vape Starter Kit with 6 Changing Light $21.99 The Yuoto ACME Pod System Vape Starter Kit is distinguished in the glaring LED light and smart auto-adjusting power function, the former responsible for standing you out of the crowd by shaking the device to change the light in 6 colors and the latter contributing to obtaining a vaping with optimized taste. It is powered by a 1200mAh built-in battery, the YUOTO ACME pod system starter kit affords to a lasting vaping with full power. The pod kit comes with a 4ml pod cartridge and a 0.7ohm coil that meet your all day long vaping and allows you to immerse into a pleasant vaping without worrying about lacking juice. ![]() Original Cybervape CyberX 30W 800mAh TC VV VW Box Mod AIO Pod System Vape Starter Kit $29.99 The Cybervape CyberX TC VV VW Box Mod Pod System Starter Kit is a compact device designed with a Cyberpunk theme. It's a futuristic-looking little thing with sharps lines a sleek, futuristic feel. It's rubber-coated surface and light in the hand. There are two sides to the CyberX, one with a removable, triangular door, where the Artery Pal styled Pod slides in and the other where the fire button, adjustments buttons, and a small screen is placed. CyberX may look and feel like a pod system, but the screen (along with various modes) put it solidly into the AIO category. The CyberX Kit is powered by a built-in 800mAh battery and can be quickly charged via USB Type-C. It will be fully charged in about 1 hour when completely discharged. The inclusion of a 4-bar battery indicator on the screen. CyberX offers three modes, variable power (5~30W), variable voltage (1~6V) and temperature control (200~600'F). As for CyberX Pod Cartridge, it has a 3ml e-juice capacity. It will be refueled from the side, with no leak issues. There are 2 types of coils: 0.5ohm mesh coil and 1.2ohm coil to meet your different vaping needs. ![]() Original Snowwolf Mark-X Replacement Mesh Coil Head for Kfeng Box Vape Mod Kit / Mark Tank(5 PCS) $10.99 The Snowwolf Mark-X Replacement Mesh Coil Head is designed for Snowwolf Kfeng Box Kit or Snowwolf Mark Tank, it features 0.3ohm coil resistance with output power range from 25W to 35W. 5 PCS / Pack. ![]() Original Yuoto ACME Pod Vape Kit Replacement Cartridge with 0.7ohm Coil $4.99 The Yuoto ACME Replacement Pod Cartridge is made of PCTG material, it comes with a coil of 0.7ohm resistance and 4ml juice capacity. It is designed for Yuoto ACME Pod System Vape Kit. ![]() Original Timesvape Keen Replacement Button Housing + Internal Pin + Spring for Keen Mech Mod original price$9.99, now only$3.99 The Timesvape button housing is made of copper, it is designed for Timesvape Keen Mechannical Mech Mod, which can increase the conductivity of your mod and avoid heating the button. ![]() Original Mechlyfe RBA Section Rebuildable Coil Head with 510 Thread for Voopoo VINCI / VINCI X Pod System $5.99 The Mechlyfe Replacement RBA Section is designed for Voopoo VINCI / VINCI X Pod System Kit, which is made of stainless steel. It comes with 510 thread connection design means that you can put it on your regulated mods for building purposes and pre-heating the coil. It supports bottom airflow control adjustable and easy build Kayfun Style Deck. ![]() ---------------------------- Cyber Monday sale informoation Coupon Code: 2019BlackFriday Offer: All items 8% off Time: 30th Nov 2019 00:00 - 2nd Dec 2019 23:59 (UTC-6 / Denver Time) Note: Site-wide extra 8%off, also valid on discounted products. Shipping fee excluded |
532
Original Acevape Arjuna Hybrid Mechanical Mech Mod Vape Kit + Pasopati RDA Atomizer $67.99
The Acevape Arjuna Mech Mod Kit is a standard mechanical device. Acevape Arjuna mech mod kit workable with several unlimited battery types, it is powered by 1 x 18650 / 20700 / 21700 Batteries. (Not included) The Mech Mod comes with Pasopati RDA Atomizer, it is made of copper and fits for other atomizer of 510 thread connection, too. ![]() LE 86 BF RDA Clone with BF Pin original price$12.59, now only$5.99 The LE 86 BF RDA Clone is in 24mm and with bottom feeding pin for squonking. The bottom feeder pin capable RDA is made of 316 Stainless Steel, with Peek drip tip, large building deck for dual or single coils with derlin chamber reducer. ![]() In'Ax MKIIr RDA Clone original price$20.99, now only$5.99 The In'Ax MKIIr RDA Clone is constructed from 316 stainless steel in 22mm diameter and 47.5mm height. The RDA supports top airflow adjustable, it features a revised airflow control, with a second airflow hole, a tighter airflow control with reference for, tighter PTFE insulator preventing the positive post spinning during coiling. ![]() Original Acevape Pasopati RDA $20.29 The Acevape Pasopati RDA is constructed from stainless steel in 25mm diameter and 28.8mm height. The RDA is compatible with 810 PC drip tip, also function with wraparound Evaporation System with high smoke efficiency. It comes with 4 post build deck and supports side airflow adjustable control. ![]() Original Damn Vape Intense DL / MTL RDA w/ith BF Pin original price$29.99, now only$20.99 The Intense MESH MTL RDA is constructed from stainless steel in 24mm diameter. Easy to build on and wick. It features worlds first CTC system (Cotton Tightness Control). With this system, you can adjust the tightness of the cotton to get the best flavor experience. What's more, you can also vape at restrictive direct lung (DL) mode by taking off the MTL AFC adapter. The kit also comes with extra frosted PC top cap and extra hollow pin for squonking. ![]() Original Teslacigs Miniwo 12.6W 400mAh Pod System Vape Starter Kit $24.99 The Teslacigs Miniwo Pod System Starter Kit has a novel appearance, and the whole body is full of Iron Man Shape. It is an ultra-portable pod system device. Stylish and ultra-thin mod, lightweight and portable, you can enjoy the vaping anytime, anywhere. Teslacigs Miniwo Pod Kit body has an excellent cut surface design, no button except fire switch, fit the palm of your hand, the hold is enjoyment. Powered by a built-in 400mAh battery, it features a power range from 9W to 12.6W and can be charged via the USB port on the bottom with 5V / 500mA fast charging, fully charged in 0.8 hours, and compatible with a variety of charging devices. As for Teslacigs Miniwo Pod, is a PCTG food-grade material cartridge which has a 2ml refillable capacity, with the Magnetic suction function, you can easily pull it out. Open two rubber plugs from the bottom at the same time, and pour your favorite electronic juice into the filling hole. In addition, it comes with 1.4ohm high-quality cotton coil that bring soft taste for you. ![]() 510 Replacement Drip Tip for Doggystyle 2K16 RTA Vape Atomizer Clone original price$2.99, now only$0.99 The S44 510 Replacement PEI Drip Tip will fits the Doggystyle 2K16 RTA Clone perfectly. Because the unique design of the Doggystyle 2K16 RTA, the drip tip connector is shorter and smaller than universal 510 connector. The 510 drip tip with silicone O-ring will fit the Doggystyle 2K16 well, but some may be longer ![]() Replacement Top Cap Tank Tube Sleeve for Pico V2 RTA Vape Atomizer Clone original price$2.99, now only$0.99 The Replacement Top Cap Tank Tube Sleeve is made of PC in 22mm diameter and 25mm height. It is suitable for YFTK Pico V2 RTA Vape Atomizer Clone. ![]() Original Dovpo Replacement Coil Head for The Ohmage Sub Ohm Tank(4 PCS) $11.99 The Dovpo Replacement Coil Head is designed for Dovpo The Ohmage Sub Ohm Tank Vape Atomizer, it features a 0.2ohm coil resistance with output power range from 40W to 55W. 4 PCS / Pack. ![]() Original Dovpo Replacement Coil Head for The Ohmage Sub Ohm Tank(4 PCS) $11.99 The Dovpo Replacement Coil Head is designed for Dovpo The Ohmage Sub Ohm Tank Vape Atomizer, it features a 0.16ohm coil resistance with output power range from 30W to 45W. 4 PCS / Pack. ![]() Original Damn Vape MESH MTL A1 Wire Mesh Sheet for Intense DL / MTL RDA(10 PCS) original price$7.99, now only$5.99 The Damn Vape Replacement MESH MTL A1 Wire Mesh Sheet is designed for Intense RDA Vape Atomizer. The size of this mesh sheet is 16 x 3.5mm, it features 0.8ohm coil resistance with power range from 15W to 30W. 10 PCS / Pack. ![]() YFTK Haku Xeta Inside RBA Rebuildable Atomizer Clone for Billet Box Mod Kit $33.99 The YFTK Haku Xeta RBA Clone is constructed from Titanium Alloy and ultem. This RBA consists 510 chimney section, airdraw insert, elevating coil clamp system, airflow disk, wick channel controller pin, and air intake. It is suitable for BB Box Mod Kit.
533
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
SXK Hussar RTA V1.5 Clone original price$23.90, now only$21.99
The SXK Hussar RTA V1.5 Clone is constructed from 316 Stainless Steel in 22mm diameter. The RTA comes with 2 post build deck design, it supports bottom airflow adjustable control and top filling system. ![]() SXK Krma GEN DL / MTL RDTA Clone with BF Pin original price$19.90, now only$17.99 The SXK Krma GEN DL / MTL RDTA Clone is constructed from 316 Stainless Steel in 22mm diameter, which comes with 1.0ml juice capacity. The RDTA comes with tunnel airflow and customisable design. It features an easy to build deck, small chamber. Side airflow intakes travels directly under your coils for maximum flavor and smooth vapor production. The versatile airflow meet your different vaping needs. ![]() Replacement Top Bell Cap Tank Tube for Pico V2 RTA Clone original price$2.99, now only$0.99 The Replacement Top Bell Cap Tank Tube is made of PC, it is suitable for Pico V2 RTA Atomizer Clone as a replacement part. ![]() Replacement Top Bell Cap Tank Tube for Rose V3 RTA Clone original price$2.99, now only$0.99 The Replacement Top Bell Cap Tank Tube is made of PC, it is suitable for Rose V3 RTA Atomizer Clone as a replacement part. ![]() Replacement Top Bell Cap Tank Tube for Rose V2-S RTA Clone original price$2.99, now only$0.99 The Replacement Top Bell Cap Tank Tube is made of PC, it is suitable for Rose V2-S RTA Atomizer Clone as a replacement part. ![]() Replacement Acrylic Drip Tip + SS Base + Forest Tank Accessories Kit for Split / Split R Atty RDTA Clone original price$2.99, now only$0.99 The Replacement Accessories is suitable for Split / Split R RDTA. It includes one metal base with a tank and one acrylic drip tip. ![]() Replacement Top Bell Cap Tank Tube for Hurricane V2 RTA Clone original price$2.99, now only$0.99 The Replacement Top Bell Cap Tank Tube is made of PC, it is suitable for Hurricane V2 RTA Atomizer Clone as a replacement part. ![]() Replacement Decorative Beauty Ring original price$2.99, now only$0.99 The Replacement Decorative Beauty Ring is made of 316 Stainless Steel and has 22mm inner diameter and 25mm outer diameter, which is suitable for most of atomizers with 22mm diameter. ![]() 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer original price$2.99, now only$0.99 The 510 Replacement Drip Tip is made of PC and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() SXK Krma Gen DL / MTL RDTA Clone Replacement Air Inlet Fittings original price$6.90, now only$5.99 The Replacement Air Inlet Fittings are made of 316 Stainless Steel, it is suitable for Krma Gen DL / MTL RDTA Tank Vape Atomizer Clone as a replacement part with air inlet hole size: 1.0mm / 1.5mm / 2.0mm / 2.5mm. 4 PCS / Pack. ![]() SXK Krma Gen DL / MTL RDTA Replacement Extension Tank Tube Clone original price$7.90, not only$6.59 The Replacement Extension Tank Tube is made of PC, which comes with 2ml juice capacity. It is suitable for Krma Gen DL / MTL RDTA Tank Vape Atomizer Clone as a replacement part. ![]() SXK Hussar V1.5 RTA Replacement Extension Tank Tube Clone original price$11.90, now only$8.99 The Replacement Extension Tank Tube are suitable for Hussar V1.5 RTA Tank Vape Atomizer Clone as replacement parts. ![]() Original Mechlyfe Replacement RPM RBA Coil Head for SMOK RPM40 / Fetch Mini Pod System Kit $4.93 The Mechlyfe Replacement RPM RBA Coil Head is compatible with SMOK RPM40 / Fetch Mini Pod System Kit as a replacement part. It fits for DIY vaping lovers. ![]() Original Yachtvape Replacement RBA Coil Head for Voopoo VINCI / VINCI R / VINCI X Pod System Kit $4.99 The Yachtvape Replacement RBA Coil Head is compatible with Voopoo VINCI / / VINCI R / VINCI X Pod System Kit as a replacement part. It fits for DIY vaping lovers.
534
Hussar 2.0 II RDA Clone $10.99
The SXK Hussar 2.0 II RDA Clone is constructed from Stainless Steel in 22mm diameter. The RDA features dual post build deck design and Anti-Spin Lock Mechanism. It can interchangeable top piece (X / MTL X / Legacy / RDTA + Compatible). The RDA supports side airflow adjustable control. ![]() Original Vsticking SMA ADA Auto Dripping Atomizer for VKsma Mod Vape Kit(2 PCS) $6.99 The Vsticking VKsma Dripping Atomizers (ADA) are designed for Vsticking VKsma Auto Filling Yihi Chip TC Vape Kit. The ADA Atomizer is constructed from 316 Stainless Steel and PP material, It not only can work by auto mode but also the DIY mode with 1.0ohm Coil to bring you fun and great flavor. ![]() Vapor Giant VG Kronos 2S DL / MTL RTA Clone $22.99 The Vapor Giant VG Kronos 2S RTA Clone is constructed from 316 stainless steel (body) and PC (tank tube) in 23mm diameter. The RTA has a 4ml juice capacity tank tube and comes with dual post build desk design, it supports top filling, bottom airflow adjustable control and DL / MTL vaping experience. What's more, it comes with a childproof topcap and leakproof design, too. ![]() Original Aspire AVP Pro 16W 1200mAh Pod System Vape Starter Kit $30.99 Refined and improved to advance the world-class styling and performance of the original AVP, with sleek and eye-catching looks, teamed with precision technical improvements. Easily utilized through an auto-draw firing system, which simply requires you to inhale to experience smooth and flavor-rich vapor production, the AVP Pro also benefits from a simple single-button variable wattage interface, for true custom vaping enjoyment. ![]() Original Aspire AVP Pro Pod Vape Kit / Cartridge Replacement Standard Coil Head(5 PCS) $9.99 The Aspire Replacement Standard Coil Head is designed for Aspire AVP Pro Pod Vape Kit / Cartridge as a replacement part. It features 1.15ohm coil resistance with wattage range from 10W to 16W. 5 PCS / Pack. ![]() Original Aspire AVP Pro Pod Vape Kit / Cartridge Replacement Mesh Coil Head(5 PCS) $9.99 The Aspire Replacement Mesh Coil Head is designed for Aspire AVP Pro Pod Vape Kit / Cartridge as a replacement part. It features 0.65ohm coil resistance. 5 PCS / Pack. ![]() Original Aspire AVP Pro Replacement Empty Pod Cartridge w/o Coil $4.99 The Aspire Replacement Empty Pod Cartridge is designed for Aspire AVP Pro Pod Vape Kit as a replacement part. It is compatible with Aspire AVP Pro Replacement 1.15ohm Standard Coil or 0.65ohm Mesh Coil (Not included). ![]() Replacement Top Cap Sleeve for Noname Plug-In RDA Clone $0.99 The Replacement top cap sleeve is made from PEI in 20mm diameter, which is suitable for Noname Plug-In RDA Clone. ![]() Replacement Diamond Tank Tube Top Cap + Chimney for Dvarw 22 MTL RTA $6.99 The Replacement Top Cap is made of PC, it comes with a 316 Stainless Steel chimney. The Top Cap features 22mm diameter and 4.5ml juice capacity. They are used for Dvarw 22 MTL RTA as replacement parts. ![]() Original Rincoe Manto AIO 80W Pod System Vape Kit Replacement Regular Coil Head(3 PCS) $5.75 The Rincoe Replacement Regular Coil Head is designed for Rincoe Manto AIO 80W Pod Vape Kit as a replacement part, it features 1.2ohm coil resistance. 3 PCS / Pack. ![]() Original Rincoe Manto AIO 80W Pod System Vape Kit Replacement Mesh Coil Head(3 PCS) $5.75 The Rincoe Replacement Mesh Coil Head is designed for Rincoe Manto AIO 80W Pod Vape Kit as a replacement part, it features 0.3ohm coil resistance. 3 PCS / Pack. ![]() Original Rincoe Manto AIO 80W Pod System Vape Kit Replacement RBA Coil Head $5.99 The Rincoe Replacement RBA Coil Head is designed for Rincoe Manto AIO 80W Pod Vape Kit as a replacement part. It fits for DIY vaping lovers. ![]() ------------------- 3FVAPE 12-12 Great Sale information Offer: Site-wide 5% off Coupon code: 20191212 5% OFF: 11th Dec 2019 00:00 - 15th Dec 2019 23:59 (UTC-6 / Denver Time) Note: This offer is not stackable with other Vouchers discounts. |
535
Original Suorin Reno 13W 800mAh Pod System Vape Starter Kit $20.59
The Suorin Reno Pod System Vape Starter Kit is powered by built-in 800mAh battery and comes with a 3ml refillable pod cartridge featuring 1.0ohm mesh coil and 100% import organic cotton, the Reno Pod System Kit will bring natural and pure flavor for you. And the Suorin adopts shape straight airway design which provides the strong throat hit for you. What's more, Suorin Reno Pod Kit possess three-level LED battery indicator to display remaining charge. And it possesses child-proof safety lock and 5-protection system, you can enjoy a safe and wonderful vaping. ![]() Original Damn Vape Fresia 8W 450mAh MTL Refillable Pod System Vape Starter Kit original price$24.99, now only$12.99 The Damn Vape Fresia Refillable Pod System Vape Starter Kit is a super compact and elegant device for MTL lovers. It is powered by 450mAh built-in battery and comes with 2ml Fresia pod cartridge. By adopting the side oil filling design, you can refill oil conveniently without dirty hands. What's more, it only takes about 30 minutes to 45 minutes for a full charge. The magnetic connection makes the cartridge reloading easier in efficiency. You are also allowed to tell the battery status from the indicator in the middle of the battery. With the aluminum material and micro USB port, you will definitely have an amazing vaping with protections. ![]() [Ships from Battery Warehouse] Original SXK Bantam Revision 30W VW Box Vape Mod Kit with 18350 original price$75.00, now only$69.99 The SXK Bantam Revision 30W VW Variable Wattage Mini Box Vape Mod Kit is powered by 1 x 18350 battery (Included) with output power of maximum 30W. Compact but fully functional variable power device that integrates various pre-built and reconflgurable coil units with a variety of adapters. SXK Bantam Revision is equipped with new updated SEVO-30 Chipset that provide you a new experience. It comes with new MTL pod unit and EUC Coil to provide you MTL vaping experience and great vapor enjoyment. The mod kit is compatible with Aspire Nautilus Coils that meet your different vaping needs. What's more, Bantam Revision has a AFC airflow control function that makes airflow control conveniently and fastly. ![]() Original Suorin Reno Pod System Vape Kit Replacement Cartridge with 1.0ohm Mesh Coil(2 PCS) $3.69 The Suorin Reno Replacement Pod Cartridge is designed for Suorin Reno Pod System Vape Kit, it comes with 3ml juice capacity and 1.0ohm mesh coil. Featured the duck-bill design mouthpiece and childproof function, the Reno Pod provides safer and more comfortable vaping and meet you daily vaping needs with less refilling. 2 PCS / Pack. ![]() Original Damn Vape Fresia Pod System Vape Kit Replacement Cartridge with 1.4ohm Coil(3 PCS) original price$9.99, now only$5.99 The Damn Vape Fresia Replacement Pod Cartridge is designed for Damn Vape Fresia Pod System Vape Kit, it comes with 2ml juice capacity and 1.4ohm coil. 3 PCS / Pack. ![]() Original Damn Vape DR-1 RBA Rebuildable Coil Head with 510 Thread Adapter for Joyetech Exceed Grip / Pod Cartridge original price$6.99, now only$4.99 The Damn Vape Replacement DR-1 RBA Rebuildable Coil Head is suitable for Joyetech Exceed Grip Kit and Exceed Grip Cartridge, and recommanded to be used with coil (28GA, Coil ID: 2.0mm). The RBA comes with a 510 thread adapter and it is easy to build on. ![]() Original Damn Vape Foxtail-M Organic Cotton for Mesh RBA / RDA / RTA / RDTA Vape Atomizer(10 PCS) $2.99 The Damn Vape Foxtail-M Organic Cotton is made from 100% Organic Cotton, features a great wicking capacity and the proper pre-measured amount for ready-to-use. It is suitable for RBA / RDA / RTA / RDTA Atomizer, especially for Mesh atomizers. 10 PCS / Pack. ![]() Original Damn Vape Base Pro Replacement Leak-proof Atty Base Stand for RTA / RDTA / Sub Ohm Tank origianl price$3.99, now only$2.99 The Damn Vape Base Pro Replacement Leak-proof Atty Base Stand is made of Stainless Steel, the Base features special leak-proof design, it can hold 3ml E-juice if your tank leaks E-juice / E-liquid. You will never mess up your desk even if the tank leaks. ![]() Origianl Vapeasy 510 Thread Adapter for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit $4.99 The Vapeasy 510 Thread Adapter is designed for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit, it can switch your Voopoo VINCI Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you. ![]() ------------------- 3FVAPE 12-12 Great Sale information Offer: Site-wide 5% off Coupon code: 20191212 5% OFF: 11th Dec 2019 00:00 - 15th Dec 2019 23:59 (UTC-6 / Denver Time) Note: This offer is not stackable with other Vouchers discounts. |
536
Original Vfolk Pro 6.2W 350mAh Built-in Battery Vape Mod $20.99
The Vfolk Pro Built-in Battery Vape Mod is a slim and elegant vape device that is compatible with a disposable pre-filled 1.2ml pod (not included (Not included). Located on the top is a semi-oval cut-out that acts as a juice view-port when the replaceable pod is implemented on. In the middle of the Mod, there is an intelligent "V" shaped LED battery life indicator to let you know when to charge. Powered by a built-in 350mAh battery, the Built-in Battery Mod supports about 500 puffs with the battery fully charged. And it is free of any buttons or screens to extend the battery life while adopting a draw-activated firing mechanism. It is compatible with the ceramic coil (Not included) that rated from 0.8 to 1.4ohm, the Vfolk Pro is really an ideal choice for MTL vaping. ![]() Original Airistech Mystica R 450mAh Vaporizer Built-in Battery Vape Mod with 12mm Diameter Hole for 510 Thread Cartridge $8.99 The Vfolk Pro Built-in Battery Vape Mod is a slim and elegant vape device that is compatible with a disposable pre-filled 1.2ml pod (Not included). Located on the top is a semi-oval cut-out that acts as a juice view-port when the replaceable pod is implemented on. In the middle of the Mod, there is an intelligent "V" shaped LED battery life indicator to let you know when to charge. Powered by a built-in 350mAh battery, the Built-in Battery Mod supports about 500 puffs with the battery fully charged. And it is free of any buttons or screens to extend the battery life while adopting a draw-activated firing mechanism. Compatible with the ceramic coil (Not included) that rated from 0.8 to 1.4ohm, the Vfolk Pro is really an ideal choice for MTL vaping. ![]() Original Airistech Turboo 450mAh Vaporizer Built-in Battery Vape Mod with 12mm Diameter Hole for 510 Thread Cartridge $10.99 The Airistech Turboo Vaporizer Built-in Battery Vape Mod is a premium discreet oil vaporizer. The fancy lanyard attached makes it more convenient to carry. The mod features fast heating function, providing you ultimate vaping experience. With the diameter 12mm hole and universal 510 thread, it is fit for most of the 510 cartridges on the market. The vaporizer is powered by 450mAh built-in battery and has 3 voltage settings designed for your different preferences. In addition, the universal micro USB charging port is designed for your convenience of charging. ![]() Original Airistech Diamond 280mAh Vaporizer Kit Battery Box Vape Mod with G2 Thick Oil Cartridge $8.99 The Airistech Diamond Vaporizer Kit consists of Diamond Vaporizer Battery Box Vape Mod and G2 Thick Oil Cartridge is powered by a 280mAh built-in Lithium Polymer battery. The Diamond Vaporizer Kit is as easy to use as they come. There are no buttons, it is breath activated. Just make sure that the unit is charged, screw one of the 510 thread magnetic connector rings onto your bottom airflow cartridge, and drop it in and inhale. The Diamond is one of the easiest to use and its compact design make it very discreet. ![]() Replacement Glowing-in-the-Dark Mouthpiece Hybrid Drip Tip with Silicone Sleeve for E-Hookah / Shisha $2.99 The Replacement Glowing Hookah Mouthpiece Drip Tip is made of resin and it is suitable for Hookah and Shisha as a replacement part. The drip tip comes with a Silicone sleeve and features Glowing-in-the-Dark. Original Suorin Reno Pod System Vape Kit / Cartridge Replacement Mesh Coil Head(5 PCS) $9.99 The Suorin Replacement Mesh Coil Head is designed for Suorin Reno Pod System Vape Kit / Suorin Reno Pod Cartridge as a replacement part, it features 1.0ohm coil resistance. 5 PCS / Pack. ![]() Original Voopoo Half-DL / MTL PnP-RBA Prebuilt Heating Wire Coil for Voopoo VINCI / VINCI X /VINCI R Vape Kit(10 PCS) $1.99 The Voopoo Replacement PnP-RBA Prebuilt Wire Coil is designed for Voopoo VINCI / VINCI X / VINCI R Pod System Vape Kit. It features 0.6ohm coil resistance and supports Half-DL & MTL vaping experience. 10 PCS / Pack. ![]() Original Voopoo Replacement PnP-RBA Coil Head DIY Kit for Voopoo VINCI / VINCI X / VINCI R Pod System Vape Kit $5.45 The Voopoo Replacement PnP-RBA Coil Head DIY Kit is designed for VINCI / VINCI X / VINCI R Pod System Vape Kit. It comes with 0.6ohm coil resistance heat wire that power range from 20W to 28W and supports Half-DL & MTL vaping experience. ![]() ------------------- 3FVAPE 12-12 Great Sale information Offer: Site-wide 5% off Coupon code: 20191212 5% OFF: 11th Dec 2019 00:00 - 15th Dec 2019 23:59 (UTC-6 / Denver Time) Note: This offer is not stackable with other Vouchers discounts. |
537
SXK SB E8 Moonraker 70W Sliding VW Box Vape Mod Clone Compatible with 22mm Diameter Atomizer original price$69.90, now only$63.99
The SXK SB E8 Moonraker Adjustable-Height Sliding VW Box Vape Mod Clone is powered by single 18650 battery (Not included) with a maximum output wattage of 70W. The SXK SB E8 Mnraker Box Mod Clone is constructed from Aluminum and quiepped with SEVO 70W large screen that provides your device's data. It is compatible with most of 22mm Diameter Atomizer. (Not included) ![]() Original IJOY Saturn 16W 1100mAh Pod System Vape Starter Kit original price$34.99, now only$24.99 The IJOY Saturn Pod System Vape Starter Kit, a compact and portable pod system kit features award striking futuristic design and advanced curved glass technology. With ground-breaking craftsmanship, it utilizes a delicate round fire button to integrate with the overall design. IJOY Saturn Pod Kit is powered by 1100mAh built-in battery with 16W max output. What's more, it comes with 3ml juice capacity with top filling design for easy operation. Furthermore, it supports two types of coil: S1 0.6ohm mesh coil for intensive clouds and S2 1.0ohm mesh coil for nic salts. ![]() Original Mechlyfe Ratel XS 80W TC VW DL / MTL Rebuildable AIO Pod System Vape Kit original price$75.00, now only$52.99 The Mechlyfe Ratel XS AIO 80W TC VV VW Rebuildable Pod System Vape Starter Kit is powered by a single external 18650 battery with a maximum output of 80W. The MECHLYFE Ratel XS Kit comes with a build deck for single coil building, the elegant resin panels makes the device so unique in hands. The airflow valve at the base brings you two ways of DL / MTL AFC. The 510 drip tip of MECHLYFE Ratel XS has a high compatibility with other mouthpieces. ![]() Original Hellvape GRIMM Pod System Vape Kit Repalcement Pod Cartridge w/o Coil original price$6.99, now only$4.99 The Hellvape Repalcement Pod Cartridge is designed for Hellvape GRIMM Pod System Vape Kit as a replacement part, which is made of PCTG material and it comes with 3ml juice capacity. The pod is compatible with 0.7ohm H3-01 Mesh Coil and H3-02 Regular Coil. (Not included) ![]() Original Mechlyfe Ratel XS Mod Pod Vape Kit Replacement Empty Pod Cartridge w/o RBA Deck original price$10.00, now only$6.99 The MECHLYFE Ratel XS Replacement Pod Cartridge is designed for MECHLYFE Ratel XS TC VW Mod Pod Vape Kit, it has a huge 5.5ml juice capacity for large liquid storage. ![]() Original Mechlyfe Ratel XS Mod Pod Vape Kit Replacement Pod Cartridge w/ Dual Coil RBA Deck original price$29.00, now only$19.99 The MECHLYFE Ratel XS Replacement Pod Cartridge is designed for MECHLYFE Ratel XS TC VW Mod Pod Vape Kit, it has a huge 5.5ml juice capacity for large liquid storage and comes with RBA deck. Different from the MECHLYFE Ratel XS Kit, the RBA deck of MECHLYFE Ratel XS Replacement Cartridge supports dual-coil building and wicking. ![]() Original IJOY Saturn Pod System Vape Kit Replacement Cartridge with 0.6ohm Mesh Coil $5.99 The IJOY Saturn Replacement Pod Cartridge is designed for IJOY Saturn Pod System Vape Kit, it has a 3ml juice capacity and comes with 0.6ohm S1 mesh coil that power range from 12W to 16W. ![]() Original IJOY Saturn Pod System Vape Kit / Cartridge Replacement S2 Mesh Coil Head(3 PCS) $6.59 The IJOY Saturn Replacement S2 Mesh Coil Head is designed for IJOY Saturn Pod System Vape Kit / Cartridge, it features 1.0ohm coil resistance that power range from 6W to 10W and is optimized for nic salts. It can also produce top-notch flavor from the first to the last puff. 3 PCS / Pack. ![]() Original IJOY Saturn Pod System Vape Kit / Cartridge Replacement S1 Mesh Coil Head(3 PCS) $5.99 The IJOY Saturn Replacement S1 Mesh Coil Head is designed for IJOY Saturn Pod System Vape Kit / Cartridge, it features 0.6ohm coil resistance that power range from 12W to 16W and can create intensive clouds and is perfect for clouds chasers. It can also produce top-notch flavor from the first to the last puff. 3 PCS / Pack. ![]() Original Voopoo PnP-R2 Replacement MTL Regular Coil Head for Voopoo DRAG Baby/FIND Trio/VINCI(5 PCS) $11.99 The Voopoo PnP-R2 Replacement MTL Regular Coil Head is designed for Voopoo DRAG Baby Pod Kit / FIND Trio Pod Kit / VINCI Pod Kit / VINCI R Pod Kit / VINCI X Pod Kit / Caliber P22 Pod Kit as a replacement part. It features 1.0ohm regular coil resistance that power range from 10W to 15W. 5 PCS / Pack. ![]() Original GeekVape Aegis Boost Mod Pod Vape Kit Replacement Adjustable Airflow RBA Rebuildable Pod Cartridge original price$16.99, now only$12.99 The Geekvape Aegis Boost Replacement RBA Pod comes with 2.0ml e-juice capacity with a leak-proof top filling system. It features two posts easy build deck and adjustable airflow. It is designed for Geekvape Aegis Boost Box Mod Pod System Vape Kit. ![]() ------------------- 3FVAPE 12-12 Great Sale information Offer: Site-wide 5% off Coupon code: 20191212 5% OFF: 11th Dec 2019 00:00 - 15th Dec 2019 23:59 (UTC-6 / Denver Time) Note: This offer is not stackable with other Vouchers discounts. |
538
Original Timesvape Keen Hybrid Mechanical Vape Mech Mod original price$75.00, now only$50.99
The Timesvape Keen Mechnical Mod is constructed from Brass in 30mm diameter and powered by single 18650 / 20700 / 21700 Battery (Not included), featuring an floating contact pin with ball head for hard fitting. The tube itself is 30mm at its widest point, tapering to 25mm or 27mm at the top. The contact pin is gold plated with a flat smooth button spring. ![]() Original Hcigar KRIS 650mAh Refillable Pod System Vape Starter Kit original price$26.99, now only$17.39 The Hcigar KRIS Refillable Pod System Vape Starter Kit is powered by 650mAh built-in battery and adopts advanced condensate reflux technology to prevent inhaling e-juice and the exclusive patented pneumatic siphon technology can avoid airflow through harmful components carried by electronic products. The pod kit comes with 2.0ml juice capaciy pod and 1.8ohm resistance coil. Featuring four vibration reminders function: insert pod, 15 puffs, charging, inhale over 10s. The KRIS Refillable Pod Kit will bring you the most convenient vaping experience. What' more, the pod kit is equipped with 5 protections to provide a safe vaping experience for you. ![]() Original IJOY Luna 11W 350mAh AIO Pod System Vape Starter Kit original price$29.90, now only$20.99 The IJOY LUNA Pod System Vape Starter Kit is definitely a revolutionary pod system vape AIO kit which is the world's first e-cig utilizing the double-sided advanced hot bending glass to bring you a great visual enjoyment with elegant appearance and concise design. Powered by 350mAh built-in battery and comes with 1.4ml refillable pod, the LUNA Pod Kit supports 11W max output with draw-activated design for instant response and long enjoyment. Equipped with the intelligent LED indicator to show the current working conditions, 1.1ohm coil optimized for high nicotine e-liquid or nic salts, and easy side filling system, the IJOY LUNA Kit is definitely a smart and excellent daily vaping device. ![]() Original IJOY MIPO 10.5W 200mAh Pod System Vape Starter Kit with 1000mAh Charging Bank Case original price$46.99, now only$35.99 The IJOY MIPO Pod System Vape Starter Kit is one of the world's smallest pod system vape device with innovative magnetic wireless charging case. The 1000mAh charging case can recharge the MIPO vape kit up to 5 times. The Pod Kit is powered by 200mAh built-in battery, the MIPO battery supports the max 9W output, and the multiple protection functions make the pod system safe to use. What's more, the MIPO Pod cartridge features 1.4ml e-juice capacity with side refilling design. And it comes with 1.4ohm KA1 coil for massive clouds and optimal flavor. ![]() [Ships from Battery Warehouse] IMR 18350 1100mAh 3.7V 10A High Drain Rechargeable Battery for Vape Mod / Mod Kit $3.99 The IMR 18350 Battery is a 1100mAh high performance High Drain Rechargeable Battery. It is compatible with any E-cig vaping mods / mod kit powered by 18350 batteries. ![]() Original Hellvape Dead Rabbit V2 RDA Vape Atomizer Replacement Ag+ Anti-bacterial 810 Drip Tip $3.19 The Hellvape Replacement 810 Drip Tip is designed for Hellvape Dead Rabbit V2 RDA Vape Atomizer as a replacement part. It features Ag+ and Anti-bacterial. ![]() Original HCigar KRIS Pod System Vape Kit Replacement Double Filling-Hole Cartridge with 1.8ohm Coil(2 PCS) $4.65 The Hcigar Replacement Pod Cartridge is designed for Hcigar KRIS Pod System Vape Starter Kit, it features 2ml e-juice capacity and double filling-hole design, coming with 1.8ohm coil. 2 PCS / Pack. ![]() Original IJOY LUNA Pod System Vape Kit Replacement Cartridge with 1.1ohm Ni80 Coil(3 PCS) $5.99 The IJOY Replacement Pod Cartridge is designed for IJOY LUNA Pod System Vape Starter Kit, it features 1.4ml e-juice capacity and comes with 1.1ohm Ni80 coil. 3 PCS / Pack. ![]() Original IJOY MIPO Pod System Vape Kit Replacement Cartridge with 1.4ohm KA1 Coil(3 PCS) $5.99 The IJOY Replacement Pod Cartridge is designed for IJOY MIPO Pod System Vape Starter Kit, it features 1.4ml e-juice capacity and comes with 1.4ohm KA1 coil. 3 PCS / Pack. ![]() Original HippoVape VSS RBA Rebuildable Coil Kit V3 for SMOK RPM Pod / SMOK RPM40 /Fetch Mini Vape Kit $5.99 The HippoVape VSS RBA Rebuildable Coil Kit V3 is constructed from stainless steel, it is compatible with SMOKTech SMOK RPM Pod / SMOK RPM40 40W / SMOK Fetch Mini Pod Vape Kit. ![]() ------------------- 3FVAPE 12-12 Great Sale information Offer: Site-wide 5% off Coupon code: 20191212 5% OFF: 11th Dec 2019 00:00 - 15th Dec 2019 23:59 (UTC-6 / Denver Time) Note: This offer is not stackable with other Vouchers discounts. |
539
Original Joyetech eGrip Mini 13W 420mAh Box Mod Vape Starter Kit(Dual Pods Version) $20.90
The Joyetech eGrip Mini Vape Starter Kit, a new version of eGrip Series, is fashionable in appearance and portable in size. eGrip Mini Kit comes with two types of coil: 1.2ohm Ni-Cr Coil and 0.5ohm Mesh Coil, and 1.3ml e-juice capacity which will meet your different needs. What's more, it is powered by 420mAh (Output Power: 13W Max) built-in battery with Type-C port for fast charging. Furthermore, it is equipped with unique 3D display design, which will bring you fantastic vape experience. This is Dual Pod Cartridges Version. ![]() Original Vaporesso Target PM80 80W 2000mAh Sub Ohm DTL VW Mod Pod System Vape Starter Kit $39.99 The Vaporesso Target PM80 Kit is a power-focused Sub-Ohm pod mod kit, it is built with quality and design for its small size and big capability. Target PM80 features an ergonomic and compact design, which makes it more portable. Powered by an 2000mAh built-in battery that supports 2.0A fast charging, it can be fully charged quickly in one hour. The Target PM80 kit has a complete control panel, convenient large fire button, and is equipped with a 0.96" TFT display screen. What's more, the Target PM80 kit can fire up to 80W, and equipped with 0.001's insta-fire AXON chip. The chipset has a variable mode, powerful performance is designed to meet all vaper needs, and supports pulse mode to bring more powerful and delicious clouds. Target PM80 kit comes with a pod cartridge of 4ml e-juice capacity and the latest GTX coil: GTX 0.2ohm Mesh Coil (45~60W) and GTX 0.3ohm Mesh Coil (32~15W), which can produce more turbidity and huge flavor. The Vaporesso Target PM80 is a mod kit that can meet all your real Sub-Ohm Direct-to-lung (DTL) vape. ![]() Original OBS Cube 850mAh Pod System Vape Starter Kit original price$33.90, now only$23.99 The OBS Cube Pod System Vape Starter Kit has a portable and compact appearance. Cube Pod is constructed from Zinc Alloy and powered by 850mAh built-in battery, it also comes with large 4ml e-juice capacity pod and a 1.4ohm resistance coil, it is sufficient to meet vapers' all day long vaping needs. What's more, it is equipped with multiple protections to provide a more safer vaping for you. With smooth airflow design, OBS Cube Pod will provide best flavor for you. ![]() Original asMODus Microkin 1100mAh Box Mod Ultra Portable Vape Starter Kit original price$29.99, now only$19.99 The asMODus Microkin Ultra Portable Kit is constructed from Plastic material, with light weight and in tiny size. Microkin Ultra Portable Kit is powered by an built-in 1100mAh battery with three output levels. Equipped with the RGB LED lights, the Ultra Portable Kit will indicate the battery level for you. What's more, the Microkin pod features 2.0ml e-juice capacity and comes with two coils for your option: 1.0ohm Dual Coil and 1.2ohm Ceramic Coil. ![]() Original Mechlyfe XS 80W Rebuildable AIO Pod Vape Kit Replacement 510 MTL Drip Tip $2.09 The Mechlyfe Replacement 510 MTL Drip Tip is made of resin material which is specially designed for Mechlyfe Ratel XS 80W TC VW DL / MTL Rebuildable AIO Pod System Vape Kit as a replacement part. The 510 Replacement Drip Tip is also suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Mechlyfe XS 80W Rebuildable AIO Pod Vape Kit Replacement 510 DTL Drip Tip $2.09 The Mechlyfe Replacement 510 DTL Drip Tip is made of resin material which is specially designed for Mechlyfe Ratel XS 80W TC VW DL / MTL Rebuildable AIO Pod System Vape Kit as a replacement part. The 510 Replacement Drip Tip is also suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original asMODus Microkin Ultra Portable Vape Kit Replacement Cartridge with 1.0ohm Coil & 1.2ohm Coil(3 PCS) $9.99 The asMODus Microkin Replacement Pod Cartridge is designed for asMODus Microkin Ultra Portable Vape Kit, it features 2.0ml E-juice Capacity with Side Filling System and comes with two coils for your option: 1.0ohm Dual Coil and 1.2ohm Ceramic Coil. 3 PCS / Pack. ![]() Original OBS Cube Pod System Vape Kit Replacement Pod Cartridge with 1.4ohm Coil(2 PCS) $7.99 The OBS Replacement Pod Cartridge is specially designed for the OBS Cube Pod System Vape Kit, it features 4ml e-juice capacity and comes with 1.4ohm resistance Coil. 2 PCS / Pack. ![]() Original Joyetech eGrip Mini Pod System Vape Kit Replacement Cartridge with 1.2ohm Ni-Cr Coil(5 PCS) $9.90 The Joyetech Replacement Pod Cartridge is specially designed for Joyetech eGrip Mini Pod System Vape Kit, it features 1.3ml e-juice capacity and comes with 1.2ohm Ni-Cr Coil. 5 PCS / Pack. ![]() Original Joyetech eGrip Mini Pod System Vape Kit Replacement Cartridge with 0.5ohm Mesh Coil(5 PCS) $9.90 The Joyetech Replacement Pod Cartridge is specially designed for Joyetech eGrip Mini Box Mod Vape Kit, it features 1.3ml e-juice capacity and comes with 0.5ohm Mesh Coil. 5 PCS / Pack. ![]() ------------------- 3FVAPE 12-12 Great Sale information Offer: Site-wide 5% off Coupon code: 20191212 5% OFF: 11th Dec 2019 00:00 - 15th Dec 2019 23:59 (UTC-6 / Denver Time) Note: This offer is not stackable with other Vouchers discounts. |
540
Aftermath Mechanical Mod Clone + Apocalypse GEN 2 RDA Vape Kit Clone original price$20.99, now only$7.99
The Aftermath Style Mod is a mechanical mod powered by 1 x 18650 battery (Not included). It has long button threads for maximum conductivity. The Apocalypse Gen 2 Style RDA is with clamp design and has a massive 13mm space in each clamp which provides space for mounting the most complex & insane coil builds. Coupled with the 4mm deep juice well, 21mm build deck, durable post clamps and extended post screws, the Apocalypse is a builders dream. ![]() Original Dovpo Odin DNA250c 200W TC VW Box Vape Mod $179.99 The Dovpo Odin DNA250c TC VW Box Mod is compact and lightweight. Equipped with the worldwide known Evolve DNA250c Chip, it is a hard wearing and user-friendly chip that can connect to the computer for slight fine-turning and the theme modifications (Although a custom theme is already installed). The box mod is powered by dual 21700 batteries (Not included), which make the mod still maintains a small and ergonomic form. Furthermore, the box mod also provides various of safety functions: reverse polarity protection, atomizer protection, overheat protection. ![]() Recoil Rebel RDA Clone with BF Pin + A Spare SS Dual Hole Top Cap original price$9.99, now only$4.99 The Recoil Rebel RDA Clone is constructed from stainless steel in 25mm diameter. This deck features stair style dual post and has a lot of open space for building. The cap has two options (one dual hole cap, one quad hole cap) that allow for several airflow configurations. A removable knurled wide bore drip tip is included. This RDA comes with bottom feeder / BF / Squonk Pin. ![]() Original Justfog J-Easy 3 4.2V 900mAh VV Box Mod Battery Vape Starter Kit with P16A Clearomizer $14.99 The Justfog P16A VV Box Mod Vape Starter Kit is a revised version of Q16 Kit, which consists of a built-in 900mAh J-Easy 3 Battery Mod and a P16A Clearomizer that comes with 1.9ml e-juice capacity and 1.6ohm coil. With an easy bottom airflow control, bottom filling design, 3 various voltage function levels and an easy one button operation, the P16A kit provides a safe and easy vaping experience. ![]() Original SMOKTech SMOK RPM80 80W VW Mod Pod System Vape Starter Kit with IQ-80 Chip $30.99 The SMOKTech SMOK RPM80 Kit has been upgraded based on RPM40. The RPM80 pod mod Kit is powered by 1 x 18650 Battery (Not included), which is more convenient for daily use. And RPM80 can support the transmission of power output up to 80W, more powerful. It has Variable Wattage / Variable Voltage modes to choose from. Fast charging through the type-c port to keep vape for a long time. What's more, RPM80 Pod is compatible with two types of cartridges, it is also compatible with all RPM40 coils and RPM80 RGC Pod which have innovative RGC RPM Mesh 0.4ohm coil (pre-installed) and RGC conical mesh 0.17ohm coil, providing a more powerful cloud and flavor. And RPM80 is larger than RPM40 in all dimensions but slightly lighter than it. Furthermore, SMOK RPM80 Pod Kit is equipped with a 0.96" color display screen that can provide you all information of this device and features newly developed IQ-80 chipset, which makes it more outstanding. Product may vary due to stabilized wood properties. ![]() Original Aspire AVP 12W 700mAh All-in-one Pod System Vape Starter Kit original price$26.99, now only$20.99 The Aspire AVP Pod System Vape Kit features a sleek and comfortable refillable pod / cartridge vape system that is easy to use and operate. The Aspire AVP Pod System features three wattage settings to choose from that is easily adjusted using the independent power button. The Aspire AVP Pod System is powered by a built-in 700mAh battery that can be charged via the bottom micro USB charging port. The Aspire AVP Pod System is automatically activated by inhaling for an easy and comfortable vaping experience. The AVP is designed to be portable and easily fits in the palm of your hand. The AVP utilizes a spring loaded leak resistant which locks into place when you are done refilling to help minimize leaks and messes. The Aspire AVP Pod System utilizes a refillable empty pod cartridge with a built-in coil inside which can be filled with your favorite vape juice. A lanyard is also included to help secure and carry your Aspire AVP pod system. ![]() Original Vivismoke Gentle Organic Cotton Wick Long Fiber $1.99 The Vivismoke Gentle Organic Cotton Wick Long Fiber is made of Pharma Grade 100% tasteless cotton wick and it is suitable for RBA / RTA / RDA / RDTA Vape Atomizer as a replacement part. ![]() Original Vivismoke Vape Mini Tool Kit - Mini Cutter + Screwdriver + Tweezer + Scissor + Coil Brush + Tweezer + Coil Builder $7.99 The Vivismoke Vape Mini Tool Kit fits for DIY lovers. The Multifunctional Coil builder is used to build the coils with four heads (2 / 2.5 / 3 / 3.5) and the screwdriver each head designed with various Integrated tips (PH00 / 2.5 / H1.5 / H1.27). ![]() ------------------- 3FVAPE 12-12 Great Sale information Offer: Site-wide 5% off Coupon code: 20191212 5% OFF: 11th Dec 2019 00:00 - 15th Dec 2019 23:59 (UTC-6 / Denver Time) Note: This offer is not stackable with other Vouchers discounts. |
