Просмотров в теме 288772   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 04.11.2019, 05:06 Автор темы   501
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Vaporesso SWAG II 2 80W Variable Wattage Box Mod $32.99
The Vaporesso SWAG II 80W VW Box Mod is powered by Single 18650 battery (Not included), the maximum output can reach up to 80W and equipped with a high-quality 0.91-inch OLED screen. Furthermore, the AXON Chip inside brings you the incredible PULSE mode, giving you ultimate vaping experience and next-level comfort. In the pulse mode, AXON will continuously hit you throughout your puff (every 0.02s) - not just from the initial fire - bringing you more powerful, flavorful clouds with every puff.
Original Sikary Vapor OG Disposable Sub Ohm Tank Clearomizer(3 PCS) $10.99
The Sikary Vapor OG Sub Ohm Tank is a disposable clearomizer that comes with 3ml juice capacity and a 0.15ohm mesh coil for 40W to 70W output. The Sikary OG tank has a top fill system that uses a fully removable silicone plug. The OG has two 8mm by 3mm air slots that can be fully adjusted by rotating the outer barrel of the tank. The entire body of the OG is made of acrylic, except for the coil head and the gold-plated contact. 3 PCS / Pack.
Original Hcigar KRIS 650mAh Refillable Pod System Starter Kit $19.99
The Hcigar KRIS Refillable Pod Kit is powered by 650mAh built-in battery and adopts advanced condensate reflux technology to prevent inhaling e-juice and the exclusive patented pneumatic siphon technology can avoid airflow through harmful components carried by electronic products. The pod kit comes with 2.0ml juice capaciy pod and 1.8ohm resistance coil. Featuring four vibration reminders function: insert pod, 15 puffs, charging, inhale over 10s. The KRIS Refillable Pod Kit will bring you the most convenient vaping experience. What' more, the pod kit is equipped with 5 protections to provide a safer vaping experience for you.
Match Stick Hybrid Mechanical Mod Clone + Battle RDA Kit $27.99
The Match Stick Mechanical Mod Kit Clone consists of Match Stick Hybrid Mechanical Mod Clone and Battle RDA Atomizer, which are constructed from brass in 24mm diameter. It is powered by Single 18650 battery (Not included). It features 510 hybrid top cap and spring fire button.
Original Lost Vape Orion Q 950mAh AIO Pod System Starter Kit with KTR Orion Pod Cartridge $34.99
The Lost Vape Orion Q AIO Pod System Starter Kit features a proprietary chipset with 17W max output and is powered by 950mAh built-in battery, and coming with a 1.0ohm KTR Orion Pod and 2ml refillable pod cartridge. The Lost Vape Orion Q Edition retains all the intricate details of the Orion DNA GO, such as premium alloy shell and stunning carbon fiber or resin details to craft a high-end all-in-one (AIO) pod system. The key difference resides in the chipset, implementing a refined output presets with multiple output adjustments without customization functionality. The Orion Q AIO pod kit equippe with multiple protections will provide you with a safe vaping experience.
Original Vandy Vape Kylin M RTA Replacement Straight Tank Tube $2.59
The Vandy Vape Repalcement Straight Tank Tube is designed for Vandy Vape Kylin M RTA as a replacement part, which is made of glass and it comes with 3ml juice capacity.
Original Vandy Vape Kylin M RTA Replacement Bubble Tank Tube $2.99
The Vandy Vape Repalcement Bubble Tank Tube is designed for Vandy Vape Kylin M RTA as a replacement part, which is made of glass and it comes with 4.5ml juice capacity.
Original Lost Vape Orion DNA GO Replacement Pod Cartridge with 0.3ohm Mesh Coil(2 PCS) $8.99
The Lost Vape Repalcement Pod Cartridge is designed for Lost Vape Orion DNA GO Pod Kit as a replacement part, it comes with 2ml juice capacity and 0.3ohm coil resistance (mesh coil).
Original Lost Vape Orion Q Replacement Pod Cartridge with 0.8ohm Mesh Coil(2 PCS) $8.99
The Lost Vape Repalcement Pod Cartridge is designed for Lost Vape Orion Q Pod Kit as a replacement part, it comes with 2ml juice capacity and 0.8ohm coil resistance (mesh coil).
3FVAPE вне форума   Вверх
Старый 05.11.2019, 04:49 Автор темы   502
3FVAPE
Original asMODus Tribeaut 80W TC VW APV Box Mod original price$69.99, now only$48.99
The Tribeaut is an 80W Box Mod that features an ergonomic design and an easy-to-use operating system. The Tribeaut vape box mod can be comfortably picked up from any position. The Tribeaut is not biased to what the finger the vaper uses, whether it's the pointer or the thumb the mod will fit perfectly in their hand. The Tribeaut box mod is powered by single 18650 battery (Not included) and features asMODus 80H chipset, which has max output power up to 80W in the variable wattage option or in programmable curve mode. The Tribeaut box mod also features accurate temperature control mode presets such as NI200 nickel / titanium / SS316 / SS317 along with fully adjustable TFR and TCR. The screen has ten levels of adjustable brightness and a puff counter.
Original Dovpo Odin DNA250c 200W TC VW Box Mod original price$179.99, now only$149.99
The Dovpo Odin DNA250c TC VW Box Mod is compact and lightweight. Equipped with the worldwide known Evolve DNA250c Chip, it is a hard wearing and user-friendly chip that can connect to the computer for slight fine-turning and the theme modifications (Although a custom theme is already installed). The box mod is powered by dual 21700 batteries (Not included), which make the mod still maintains a small and ergonomic form. Furthermore, the box mod also provides various of safety functions: reverse polarity protection, atomizer protection, overheat protection.
Terk V2 RDA Clone + 1 Spare 25mm Diameter Top Cap with BF Pin $12.99
The TERK V2 24mm Squonk RDA Clone creatively crafted for building enthusiasts, implementing a large two-post clamp configuration with AFC constructed onto the build deck and comes with two top cap options: 24mm and 25mm. The TERK V2 style RDA supports dual coil configuration on the expansive space of the build deck, calling on the clamping systems, top secured, to affix performance coils within the appropriate terminals. The dual slotted airflow system can be found on the mid cap, sending airflow from the side of the tank to the side of the coil, creating dense flavorful clouds. The additional support of two top cap options allows for user-customization and preference with squonk 510 pin to match best squonk mods.
Original Aspire Tigon 1300mAh AIO Pod System Starter Kit $29.99
The Aspire Tigon AIO Pod Kit is powered by a 1300mAh built-in battery and comes with two types of coils: 0.4ohm coil (23~28W) and 0.7ohm mesh coil (20~25W) and a 4.6ml juice capacity pod cartridge. The Tigon AIO Pod Kit supports Adjustable airflow control that can meet different vaping needs.
Original WISMEC Replacement WR01 Mesh Coil Head for Preva Pod Cartridge / Kit $2.99
The WISMEC Replacement Mesh Coil Head is designed for WISMEC Preva Pod Cartridge / Preva Kit, it features 0.6ohm coil resistance (Mesh).
Original WISMEC Preva Kit Replacement Pod Cartridge with 0.25ohm SS316 Dual Coil - Childproof Version $5.99
The WISMEC Preva Replacement Pod Cartridge is designed for WISMEC PREVA Kit. It's a 3ml atomizer with SS316 Dual 0.25ohm Coil. It will satisfy both DL lovers and MTL pursuers. What' more, it adopts adjustable top-airflow system to prevent e-juice leakage effectively and makes the vaping experience incomparable. This is Childproof Version.
Original WISMEC Preva Kit Replacement Pod Cartridge with 0.6ohm WR01 Mesh Coil - Childproof Version $5.99
The WISMEC Preva Replacement Pod Cartridge is designed for WISMEC PREVA Kit. It's a 3ml atomizer with WR01 0.6ohm Mesh Coil. It will satisfy both DL lovers and MTL pursuers. What' more, it adopts adjustable top-airflow system to prevent e-juice leakage effectively and makes the vaping experience incomparable. This is Childproof Version.
Original WISMEC Preva Kit Replacement Pod Cartridge with KTR 0.5ohm Coil - Childproof Version $5.99
The WISMEC Preva Replacement Pod Cartridge is designed for WISMEC PREVA Kit. It's a 3ml atomizer with KTR 0.5ohm Coil. It will satisfy both DL lovers and MTL pursuers. What' more, it adopts adjustable top-airflow system to prevent e-juice leakage effectively and makes the vaping experience incomparable. This is Childproof Version.
Original WISMEC Preva Kit Replacement Pod Cartridge with 0.25ohm SS316 Dual Coil $5.99
Original WISMEC Preva Kit Replacement Pod Cartridge with 0.6ohm WR01 Mesh Coil $5.99
Original WISMEC Preva Kit Replacement Pod Cartridge with KTR 0.5ohm Coil $5.99
Original Vaporesso Sky Solo Plus Tank / Kit Replacement Bubble Tank Tube $1.99
The Vaporesso Replacement Bubble Tank Tube is designed for Sky Solo Plus Kit. It comes with a large 8ml juice capacity.
Старый 06.11.2019, 04:43 Автор темы   503
3FVAPE
Original Vaporesso GEN 220W TC VW Box Mod $45.99
The Vaporesso GEN Mod comes with an innovative casing which features 4 layers of coating, giving it soft rubber-like feel, yet still making it smooth to the touch. The final coating makes it scratch-proof and flame retardant. Powered by dual 18650 batteries and assisted by the advanced AXON chipset, the mod can fire from 5W to 220W whilst it implements the pulse mode and the power ECO mode. In the pulse mode, AXON will continuously give you a hit throughout your puff (every 0.02s) - not just from the initial fire - bringing you more powerful, flavorful clouds with every puff. When the power ECO mode is on, it can optimize your device's settings to give you that extra vaping time you need. At last, there is a 0.91" OLED screen to show the essential vaping data clearly.
Original FreeMax Mesh Pro Sub Ohm Tank Clearomizer $22.99
The Freemax Mesh Pro is constructed from stainless steel (body) + pyrex glass (tank tube) in 25mm diameter, the Sub Ohm Tank is compatible with the 0.12ohm SS316L Single Mesh Coil (400~550'F), 0.15ohm Kanthal Single Mech Coil (40~70W), 0.2ohm Kanthal Double Mesh Coil (60~90W), 0.15ohm Kanthal Triple Mesh Coil (80~110W). Also, it supports slide-to-open top fill design, 360 degree e-liquid feeding, the Freemax Mesh Pro offers a stylistic design and great flavor compared to all the other mesh coil sub ohm tanks in the market.
YFTK Caiman MTL RDTA Clone $23.99
The YFTK Caiman MTL RDTA Clone is constructed from 316 stainless steel (body) and PC (tank) in 22mm diameter. The RDTA supports air feed adjustment, coming with a adjustable central connector screw and it is esay to E-liquid tank filling. Also, the RDTA can replaceable air pipes with different diameters. The inner surface of the atomizing chamber cap has a hemispherical shape which can hold some amount of liquid when the atomizer is turned over (similar to a no-spill cup). What's more, Milled stands is easy for coil clamping.
ShenRay Vapor Giant VG Kronos 2S DL / MTL RTA Clone(23mm) $29.90
The ShenRay Vapor Giant VG Kronos 2S RTA Clone is constructed from 316 Stainless Steel (Body) and PC (Tank Tube) in 23mm Diameter. The RTA comes with a 4ml juice capacity PC tank tube and 360 degrees Logo Shield. Also, the RTA supports bottom adjustable airflow and MTL (MTL opening: 2 x 0.8mm) or restrictive DL (DL opening: 4 x 1.8mm) vaping experience. What's more, it comes with a childproof topcap and leakproof design, too.
ShenRay Vapor Giant VG Kronos 2S DL / MTL RTA Clone(25mm) $33.90
The ShenRay Vapor Giant VG Kronos 2S RTA Clone is constructed from 316 Stainless Steel (Body) and PC (Tank Tube) in 25mm Diameter. The RTA comes with a 4.5ml juice capacity PC tank tube and 360 degrees Logo Shield. Also, the RTA supports bottom adjustable airflow and MTL (MTL opening: 2 x 0.8mm) or restrictive DL (DL opening: 4 x 1.8mm) vaping experience. What's more, it comes with a childproof topcap and leakproof design, too.
Original SMOKTech SMOK RPM40 40W 1500mAh VW Mod Pod System Starter Kit $31.99
The SMOKTech SMOK RPM40 Pod Mod Kit is an ultra-portable pod mod that shapes like a cuboid and is covered with glossy finish and characteristic material, making the whole device look fancy and stylish. It is small in size but has a battery capacity of 1500mAh which can ensure enough running time and help you avoid frequent charging, and a power range from 1W to 40W for you to adjust, and you can press the UP / DOWN button to get your preferred power. The internal IQ-R chip is a new one, which can shorten the firing time to 0.001S, and charging time to two hours. Different from normal tiny and slim pod devices, RPM40 is designed with a 0.96 inches screen, with which, detailed vaping data is clearly presented, like the wattage, resistance, voltage, screen color, puff number, and battery level. Besides, the newly designed RPM Mesh 0.4ohm Coil and Nord DC 0.6ohm Coil are designed for the best flavor and excellent vapor production.
Original Vaporesso GEN 220W TC VW Box Mod with SKRR-S Tank Kit $58.99
The Vaporesso GEN 220W Vape Mod and SKRR-S Mesh Sub-Ohm Tank Starter Kit is a high power device designed to be used by newbies and pros alike. GEN presents a sleek and light weight design, paired with the new AXON chip for easy operation. The new AXON chip from Vaporesso is an intuitive chipset with a simple user interface and several power modes to please every user. Vaporesso has paired the GEN with the SKRR-S tank for the ultimate vape starter kit.The Vaporesso GEN mod is constructed from durable aluminum and features a soft touch finish made from four layers of coating. This allows the vape device to have a soft rubber-like feel, while offering extreme durability.
[Ships from Battery Warehouse]Original AWT IRM 1200mAh 18A 18500 High Drain Rechargeable Battery for Mod / Mod Kit(2 PCS) $4.99
The AWT IRM 18500 Battery is a 1200mAh high performance High Drain Rechargeable Battery and made for high continuous discharge current (max 18A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18500 batteries. 2 PCS / Pack.
Original Auguse MTL RTA Replacement Top Cap Tank Tube $7.99
The Auguse Replacement Top Cap Tank Tube is designed for Auguse MTL RTA Atomizer, it is made of PC material and comes with 4ml juice capacity.
Старый 07.11.2019, 09:42 Автор темы   504
3FVAPE
Scar Mini Hybrid Mechanical Mod Clone $14.99
The Scar Mini Mechanical Mod Clone is constructed from Brass in 28mm diameter (largest) / 22mm diameter (top), which is powered by single 18350 battery (Not included). The magnet is height adjustable and allows the adjustment of the activation button movement. It is compatible with 510 threading connection.
YFTK FL EVO 22 RDA Clone with BF Pin $19.99
The YFTK FL EVO 22 RDA Clone is constructed from 316 Stainless Steel in 22mm Diameter. The RDA comes with a single coil build deck design and 4 holes on the top cap that is adjustable on two different positions: 4 holes for a airy draw and 2 holes for a tighter draw. This RDA is without Logo, comes with bottom feeder / BF / Squonk Pin.
The YFTK FL EVO 22 RDA Clone is constructed from 316 Stainless Steel in 22mm Diameter. The RDA comes with a single coil build deck design and 4 holes on the top cap that is adjustable on two different positions: 4 holes for a airy draw and 2 holes for a tighter draw. This RDA comes with bottom feeder / BF / Squonk Pin and Logo.
SXK Kennedy Trickster 24 Dual-pole RDA Clone original price$14.99, now only$8.99
The SXK Kennedy Trickster 24 RDA Clone is constructed from copper. The SXK Kennedy 24 RDA comes with dual-post design, which will offer you more build room. The new version sleeve design is for adjustable airflow control via the sleeve.
Gata MTL / DLH RTA Clone $19.99
The Gata RTA Clone is constructed from 316 stainless steel (body) and glass (tank) in 24mm diameter. The Gata Style RTA comes with postless build deck for single coil and supports bottom airflow control to meet MTL and DLH lover different vaping needs.
SXK Bastd MTL / DTL RTA Clone original price$19.90, now only$14.99
The SXK Bastd RTA Clone is constructed from 316 Stainless Steel in 22mm diameter. It features a single coil build deck. The RTA comes with a 3.5ml juice capacity tank tube and supports bottom modular airflow control and top filling system. The RTA can provide you MTL or DTL vaping experience. The RTA also can be converted to a RDA by conversion kit. (Not included)
Original Uwoo Y1 3200mAh Dry Herb Vaporizer Heating Starter Kit Compatible with IQOS $42.99
The Uwoo Y1 Dry Herb Vaporizer E-cigarette Vape Head Heating Starter Kit is a heating device Compatible with HEETS / IQOS, which is powered by 3200mAh Built-in High Performance Lithium Battery that can support 1 to 2 days vaping and 2 hours quick charging. The heating kit is equal to about 40 sticks when the device is full charged. Uwoo Y1 Heating Kit is constructed from Aluminum and High Temperature Resistant Plastic material, which is quipped with multiple protections to ensure your vaping safety.
SXK Billet Box 70W All-in-One Box Mod Kit Clone with USB Port original price$75.00, now only$65.29
The SXK Billet Box Mod Kit Clone is constructed from aluminum with an all-in-one design. This mod comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor. This BB Box comes with USB port for charging only.
Original Lost Vape Orion Q-Pro Q Pro Pod Kit Replacement Cartridge with 1.0ohm Regular Coil $7.99
The Lost Vape Replacement Pod Cartridge is designed for Lost Vape Orion Q-Pro Pod Kit, which comes with a 1.0ohm Regular coil (Pre-stalled) and 2ml juice capacity. Furthermore, it is compatible with all types of Orion Series interchangeable coils, which is easy to replace. What' more, it adopts top adjustable airflow design for mouth-to-lung (MTL) and direct-to-lung (DTL) vaping.
YFTK Replacement Drip Tip + Top Cap for FL EVO 22 RDA Clone $7.99
The YFTK Replacement Drip Tip and Top Cap are suitable for YFTK FL EVO 22 RDA Atomizer Clone as a replacement part. They are made of PEI material.
YFTK Haku Xeta Inside RBA Rebuildable Atomizer Clone with PEI Black Middle Top Cap for Billet Box Mod Kit $20.99
The YFTK Haku Xeta RBA Clone is constructed from 316 stainless steel and ultem. This RBA consists 510 chimney section (SS), airdraw insert, elevating coil clamp system, airflow disk, wick channel controller pin, and air intake. It is suitable for BB Box Mod Kit.
Старый 08.11.2019, 04:45 Автор темы   505
3FVAPE
Original Zoor 500mAh Portable Pod System Device original price$29.99, now only$8.00
The Original ZOOR Ultra-Portable Pod System Device delivers the modern progression of today's travel-friendly pod systems, beautifully designed with an integrated 500mAh lithium battery and a tasty collection of pre-filled pods (not included). The ZOOR features a robust pen-style design and optimized for portability with soft curvature all-around and a comfortable grip section. Staying true to its closed-system core, the ZOOR is enabled by a draw-activated mechanism with a built-in 500mAh lithium rechargeable battery and LED indicators. A proprietary magnetic pod is implemented onto the device for easy-to-use set-up, housing a wide range of replacement pods infused with Ceramic Coil Technology. Each pod is pre-filled with 2mL of nic salts e-liquid with 5mg nicotine strengths in a lot of flavor options such as Apple, Cake, and Mint ICE. This product comes with battery device only, pod cartridges not included.
Original Hellvape Dead Rabbit V2 RDA with BF Pin original price$36.99, now only$25.99
The Hellvape Dead Rabbit V2 RDA is constructed from Stainless Steel in 24mm diameter, which is an update to the original featuring a few tweaks to the airflow inlets and build deck. The airflow inlets of V2 RDA have slot or honeycomb options. Simply rotate the barrel to select which you prefer. Also the airflow is angled down towards the deck to allow the inlets to be set higher to reduce the chance of leaks. The barrel has a locking feature to ensure that the airflow inlets are always aligned with your coils and you turn the top cap to adjust. Moving on to the deck-this still features the rabbit ear posts which are nice and easy to build on.
Original Joyetech Exceed Edge AIO 650mAh Starter Kit $11.99
Being a pod system while you can still change the coil heads as you like, the Joyetech EXCEED Edge is ergonomically designed, inspired by the sports car. It is meant to offer you a delectable and pure flavor using with the fine EX 1.2ohm head for mouth-to-lung enthusiasts. Meanwhile, it is compatible with high nicotine and nicotine salts. The EXCEED Edge is such a tiny and sleek device that fits you perfectly not just for starters but also advanced vapers.
Original YiHi SXmini SX Auto DTL / MTL 1400mAh TC VW Box Mod Pod Kit with SX-ADA Atomizer $95.89
The YiHi SXmini SX Auto Pod Kit consists of a SX Auto Device and SX-ADA Atomzier (0.4ohm SS316 for DTL / 0.8ohm SS316 for MTL), featuring an auto-squonking system (electronic squonk motor) and the reservoir comes with 3.5ml e-juice capacity with a 100% sealed chamber to limit any leakage. Powered by internal 1400mAh battery and the advanced SX685J chipset, SXmini SX Auto Pod Kit will automatically detect the SX ADA atomizer, but you may also set the mod to the DIY mode for use with the rebuildable version of the SX ADA (Not included).
Original YiHi SXmini 680 Vape 900mAh TC Box Mod Pod System Starter Kit $105.99
The YiHi SXmini 680 vape pod system TC starter kit is creative in separating the coil from the tank tube, efficient to avoid splashing while vaping and leaking when stored in the pocket. The matched ADA pod is intelligent in transmitting a drop of oil to the heated coil, strongly guaranteeing a fresh taste each time you inhale. YiHi SXmini 680 vape pod system TC starter kit is powered by 900mAh Built-in Battery and has 3 modes of power are adjustable and the chosen one will be reflected on the display, along with the battery life and temperature, recording the real-time operating data and reminding you of developing a relatively healthy vaping habit.
Original TrustFire TR 001 LED Charger for 18650, 18500, 18350, 17670, 16340, 14650, 14500, 14430 $10.99
The TrustFire TR 001 2 Slots LED Battery Charger allows you to charge 2 kinds of different size batteries at once and LED charge indicator light for each battery. When the battery is fully charged, the LED turns from red to green to warn you. Also, the battery charger allows you to use the charger on the car with universal car charging adapter. It is compatible with most IMR and Li-ion batteries. The batteries are not included
Старый 11.11.2019, 04:43 Автор темы   506
3FVAPE
Original Innokin Proton Mini Ajax 120W 3400mAh TC VW Box Mod $50.99
The Innokin Proton Mini Ajax TC VW Box Mod comes with a 1.45 inches colorful TFT screen and easy to operate via the joystick and intuitive and full-featured menu system, it can also shows you the vaping data clearly. Furthermore, the Innokin Proton Mini comes with the advanced chipset heats coils nearly instantaneously, the max output wattage can up to 120W, working wattage adjustable can from 6W to 120W, you can adjust the working modes easily for your favorite vaping demands. What's more, the Proton Mini mod supports temperature control, custom TCR, custom wattage curve, bypass mode and 3 coil memory slots. It is powered by 3400mAh built-in battery that can be charged fast with 2A quick charge system and equipped with safety protections to ensure the charging and vaping reliable.
Original Timesvape Dreamer Hybrid Mechanical Mod original price$75.00, now only$46.99
The Mechanical Mod is designed by Stan (USA), manufactured by Timesvape, the original Timesvape Dreamer Mod is a fantastic mech mod, which is constructed from Brass and is compatible with single 18650 / 20700 / 21700 battery(Not included). The innovative multipoint contact pin increases conductivity. It also features reversible tube for customizable grip, floating battery adjustment and hybrid 510 connection. Dreamer is a cloud chaser's dream mod. 18650 battery adapter is included.
Squape S MTL / DL RDA Clone with BF Pin $14.99
The Squape S BF RDA Clone is constructed from 316 stainless steel in 22mm diameter and 20mm height (without drip tip). The RDA is made by hand in small batches in Switzerland and it is compatible with many mods equipped with 510 threading connector. With the single coil build deck, it can provide stable smoke and good taste. The Squape S Style BF RDA supports mouth to lung (MTL) and direct lung (DL) vaping experience by a simple adjustment to swap from one to the other style. Furthermore, you can turn the cap to infinitely adjust how much airflow you would like. The MTL is two 1mm inlets and the DL is two 4mm inlets. It's important that the RDA supports temperature control and VV / VW modes as well. This RDA comes with bottom feeder / BF / Squonk Pin.
Original Innokin Proton Mini Ajax 120W 3400mAh TC VW Box Mod + Ajax Tank Atomizer Kit $60.99
The Innokin Proton Mini Ajax TC VW Box Mod Kit consists of TC VW Box Mod and Ajax Tank Atomizer, it is the mini version of Innokin Proton Kits, with the small ergonomically design and comfortable to grip. The Proton Mini Kit comes with one 1.45 inches colorful TFT screen and easy to operate via the joystick and intuitive and full-featured menu system, it can also shows you the vaping data clearly. Furthermore, the Innokin Proton Mini comes with the advanced chipset heats coils nearly instantaneously, the max output wattage can up to 120W, working wattage adjustable can from 6W to 120W, you can adjust the working modes easily for your favorite vaping demands. What's more, the Proton Mini Kit supports temperature control, custom TCR, custom wattage curve, bypass mode and 3 coil memory slots. It is powered by 3400mAh built-in battery that can be charged fast with 2A quick charge system and equipped with safety protections to ensure the charging and vaping reliable. On the other hand, the Innokin Ajax Tank can hold 5ml e-juice, with convenient top e-juice refill design and bottom airflow adjustable slots, compatible with Ajax Coils and Plex3D Matrix Coils. the Plex3D Matrix Coils with the mesh wire inside and covered with organic cotton and the large heating area, which will heat the e-liquid fastly and evenly, delivering the incredible bursts of flavor and cloud of vapor.
SXK Billet Box 60W All-in-One Box Mod Kit Clone with USB Port original price$129.00, now only$104.89
The SXK Billet Box Mod Clone is constructed from aluminum with an all-in-one design. It is powered by 1 x 18650 battery (Not included) and maximum power output is 60W. The box mod is powered by Evolv DNA 60 chip. This BB Box comes with USB port for firmware upgrading, setting modification and user customization via software.
Original Artery Nugget AIO 40W 1500mAh VW Box Mod Pod System Starter Kit original price$49.99, now only$28.99
The Artery Nugget AIO Pod System Kit is powered by 1500mAh internal battery and has a maximum output of 40W. The Nugget AIO Pod Kit supports Type-C charging with 1.5A fast charging current, charging current will provide full charge in one hour. The bright and clear LED display shows you all the vaping and the battery status that you want. It features 2ml juice capacity tank and convenient top-fill structure, and the bottom airflow adjustment design. The Artery Nugget AIO pod kit provides a simple magnetic connection between the 2ml juice tank and the battery, and a large electronic juice window for easy viewing of the liquid juice level.
SXK LE TB MTL RDA Clone with BF Pin $14.99
The SXK LE TB RDA Clone is constructed from 316 Stainless Steel measuring in 22mm diameter. The RDA has a special design in the vertical positioning of the coil, it allows you freely regulate the space of your coil and the position of your cotton. And then, there are multiple airflow positions associated with the external ring to find precision with your preferred pull and sublimates all your E-juice, which allows you to pass from aired inhaling to a restrained depending on your tastes and compositon of E-juice. The RDA supports MTL vaping experience and is compatible with most of boxes and mods equipped with 22mm diameter atomizers. The RDA comes with a bottom feeder pin.
YFTK LE TB MTL RDA Clone with BF Pin $17.99
The YFTK LE TB RDA Clone is constructed from 316 Stainless Steel measuring in 22mm diameter. The RDA has a special design in the vertical positioning of the coil, it allows you freely regulate the space of your coil and the position of your cotton. And then, there are multiple airflow positions associated with the external ring to find precision with your preferred pull and sublimates all your E-juice, which allows you to pass from aired inhaling to a restrained depending on your tastes and compositon of E-juice. The RDA supports MTL vaping experience and is compatible with most of boxes and mods equipped with 22mm diameter atomizers. The RDA comes with a bottom feeder pin.
Original Hippovape Replacement Squonk Bottom Feeder Bottle for Kudos 80W Box Mod $2.59
The Hippovape Replacement Squonk Bottom Feeder BF Bottle is specially designed for Kudos 80W Box Mod, it features 7ml capacity and 30mm height.
Старый 11.11.2019, 04:43 Автор темы   507
3FVAPE
Старый 11.11.2019, 04:50 Автор темы   508
3FVAPE
Старый 11.11.2019, 13:10 Автор темы   509
3FVAPE
Original WISMEC AI Alexa 200W TC VW Box Mod with Bluetooth $59.99
The Wismec AI Alexa Box Mod, an amazing intelligent vape device, is powered by dual 18650 batteries (Not included) with 200W max output. Adopting 510 thread, it can handle a wide range of tanks up to 30mm in diameter without overhang. And there are two types of mode for your option: TC mode (0.05~1.5ohm) and VW mode (0.05~3.5ohm). What's more, it utilizes bluetooth technology and you can get any information by downloading the Amazon Alexa app, just like navigation and so on. Furthermore, it is engineered with a built-in quality speaker, and you can listen to music via Bluetooth when vaping.
Lucifer Mechanical Mod Clone $14.99
The Lucifer mechanical mod Clone is constructed from brass in 25mm diameter, which is powered by single 18650 battery (Not included). It features knurled top hat with 510 threading connection. It comes with adjustable center pin.
Ruby RTA Clone $14.99
The Ruby RTA Clone is contructed from 316 Stainless Steel in 22mm diameter. The RTA comes with a 2ml juice capacity tank tube and supports bottom airflow control system.
Original Vaporesso NRG PE Sub Ohm Tank Clearomizer $16.99
The Vaporesso NRG PE Tank Atomizer is perfectly compatible with the new Vaporesso Swag II Box Mod 80W with 25mm diameter and 3.5ml e-juice capacity. It is widely compatible with GT series coils and works with two of them at a time, the key to the stronger flavor and denser vapor. The Vaporesso NRG PE Tank adopts the latest GT4 meshed coil with dual-coil structure and tea fiber material, and 0.5ohm GT CCELL Coil (25~35W). The upgraded GT4 Meshed coil brings dual meshed cores to increase contact area giving denser more flavorful clouds. The bottom airflow system will also help enhance the flavor for you.
Haku Venna RDA Clone with BF Pin $14.99
The Haku Venna RDA Clone is a low profile 22mm RDA with dual post design for single coil building. The RDA is constructed from stainless steel material. The air enters the chamber via two different sizes of airholes on both side of the cap, hitting the coil directly. delrin drip tip is included. This RDA comes with bottom feeder / BF / Squonk Pin.
Original Rincoe Manto 80W VW Box Mod AIO Pod System Starter Kit original price$49.99, now only$30.99
The Rincoe Manto VW Box Mod AIO Kit, a compact and stunning pod system kit, comes with 3ml e-juice capacity with easy side filling design. And there are two types of 510 drip tips for MTL / DTL vapers. Powered by Single 18650 Battery (Not included) with 80W max output, it is charged via Type-C USB port for faster, safer and more convenient operation. And it is powered by the chip that could recognize coils and automatically match power after the cartridge inserted into the device. What's more, it is equipped with 0.49 inch OLED screen to show you clear data.
Original Hugo Vapor Planet Pod Kit Replacement DIY RBA Coil Head(5 PCS) $11.99
The Hugo Vapor Planet Replacement RBA Coil is designed for Hugo Vapor Planet Pod Kit, it is suitable for DIY vaping lovers. 5 PCS / Pack.
Original MECHLYFE Ratel Rebuildable Tank with RBA Deck for Ratel Pod Kit $11.89
The MECHLYFE Ratel Rebuildable Tank with RBA Deck is designed for Mechlyfe Ratel Pod System Kit, which comes with 4ml juice capacity. Through MECHLYFE Ratel pod, ratel can be used to build coils that you like.
Replacement Bell Cap for Gata MTL RTA $3.99
The Replacement Bell Cap is made from PMMA for Gata MTL RTA Clone. The bell cap has a 2ml juice capacity.
Original Reewape AS278 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $2.25
The AS278 510 drip tip is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS278S 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $2.65
The AS278S 510 drip tip is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Vaporesso Replacement GT4 Mesh Coil for SWAG II Kit(3 PCS) $9.99
The Vaporesso Replacement GT4 Mesh Coil is specially designed for Vaporesso SWAG II Kit. It features 0.15ohm coil resistance and range of output power is from 50W to 75W. 3 PCS / Pack.
Старый 13.11.2019, 04:48 Автор темы   510
3FVAPE
Original Fumytech Bdvape Precisio MTL / Middle MDL RTA $54.00
The Fumytech Bdvape Precisio RTA is constructed from stainless steel (body) and Ultem (tank tube) in 22mm diameter. The RTA comes with a 2.7ml juice capacity tank tube and supports bottom airflow control system and MTL and Middle MDL vaping experience. Also, it is easy to build and filling.
Original Ohm Vape AIO 42W Box Mod Pod System Starter Kit original price$52.99, now only$44.99
The Ohm Vape AIO Pod System Box Mod Kit is a portable vaping pod system, which is powered by single 18650 rechangeable battery (Not included). This device is configured to stop firing if the chipset recognizes: short circuit, reverse battery connection, low voltage, battery overcharge, battery discharge or dry burn. The device has three types of charging indicator to indicate the battery capacity: Green (61%~100% Charge), Blue (21%~60% Charge), and Red (1%~20% Charge). While charging, the battery light will pulse. Once the device is fully charged, the battery light will stop pulsing and turn off after ten minutes. This device has four different power levels. Click the fire button once and then the power level button to start navigation through the four settings. Each click will change to the next setting. After three seconds, the Ohm Vape AIO will set the power to the mode selected and the light indicator will blink twice for confirmation. Compatible with Aspire Nautilus coil.
Original Vladdin Boqpod 400mAh Pod System Starter Kit original price$29.90, now only$20.99
The Vladdin boqpod is Vladdin Global Ltd. and boqpod tech's first-ever co-branded product, which is powered by 400mAh built-in Battery and comes with 1.0ml juice capacity pod and 1.1ohm Microporous Ceramic Coil. The pod system features a convenient and fully responsive auto-activated airflow switch. And the unique leak-proof pod design allows for optimal use and preservation of the devices' main structure. Multiple camouflage design options with Double-sided magnetic panels make the Boqpod more than just stylish. The 2-in-1 airflow structure keeps liquid and air separated, which along with the storage tank for leaked liquid, improves the product lifecycle. In addition, the unique spit back-proof airflow design provides you with a better vaping experience. More importantly, the Vladdin boqpod kit applying the world's first inlaid mesh coil. The AX ceramic coil combines the advantages of ceramic and metal mesh technologies, ensuring a more pure and flavorful vape experience. Multiple protections applied to provide you a stable and secure vaping experience.
Original Gas Mods Mars 15W 750mAh Pod System Starter Kit original price$24.99, now only$22.99
The Gas Mods Mars is a power adjustable designed starter kit with built-in 750mAh battery and 2.0ml refillable cartridge. The special tiny chip in the device provides constant output voltage which make it powerful with a small sized body. There are two kinds of cartridges: 1.5ohm SS316L / 1.8ohm Ni80 can be chosen to match different E-liquid. The Gas Mods Mars Pod will bring you not only great flavor but also safe and simple vaping experience.
Original Reewape Replacement Drip Tip for Uwell Caliburn Pod Kit $1.49
The Reewape Replacement Drip Tip is designed for Uwell Caliburn Pod Kit, which is made of resin material.
Original Reewape AS272 Changeable 810-510 Drip Tip with Anti Spit SS Mesh Sheet for RDA / SMOK TFV8 $1.89
The Reewape AS272 Replacement drip tip is made of resin, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. Also, it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. The drip tip is changeable between 510 connector and 810 connector each other, and it is a kind of anti spit drip tip with Anti Spit SS Mesh Sheet.
Original Reewape AS274 Replacement 810 Drip Tip for 528 Goon / Reload / Battle RDA $1.49
The Reewape AS274 810 drip tip is made from resin with 11mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Старый 13.11.2019, 04:53 Автор темы   511
3FVAPE
Original Reewape Replacement Cobra Tube + Drip Tip Set for Uwell Crown IV Tank / Mod Kit $4.99
The Reewape Replacement Cobra Tube + Drip Tip Set is made of resin and it is designed for Uwell Crown IV Tank / Crown IV Mod Kit.
Original Efest H2 Updated Dual-Slot 18650 Plastic Battery Case $1.49
The Efest H2 dual-slot Battery Case is the safest and most convenient way to store your batteries. Small in size and sturdy in construction, the Efest H2 case can store up to two 18650 batteries and up to four 18350 batteries. No need to worry about your batteries shifting or falling out, the H2 case snaps tightly and secures your batteries when theyre not in use. The transparent case allows you to see your batteries without having to open the case and makes a great display container if youre a seller. The Efest battery case is a top-of-the-line product made to last a very long time with careful use.
Disposable Replacement 510 Drip Tip for for RDA / RTA / RDTA / Clearomizer / Sub Ohm Tank Atomizer $0.39
The Disposable Replacement 510 Drip Tip is made of Silicone. It is suitable for RDA / RTA / RDTA / Clearomizer Vape Atomizer and can fit most atomizers or cartomizers with 510 connectors. It is easy to be rinsed with water.
Original Voopoo Replacement PnP-VM4 DL Single Mesh Coil for VINCI / VINCI R / VINCI X Pod Kit(5 PCS) $13.99
The Voopoo Replacement PnP-VM4 Coil is specially designed for VINCI Kit, VINCI X Kit, VINCI R Kit. And it features 0.6ohm signle mesh coil, which is suitable for 20~28W power range and will bring you MTL / half-DL vaping experience. 5 PCS / Pack.
Original GeekVape Aegis Boost Pod Kit Replacement Empty Pod Cartridge(2 PCS) $7.99
The Aegis Boost Empty Pod Cartridge is designed for Geekvape Aegis Boost Pod Mod Kit. It has 3.7ml e-juice capacity. With easy top refill design and great airflow control, which make the vaping more convenient. Just get it for your Geekvape Aegis Boost Pod Mod Kit. 2 PCS / Pack.
Original Vladdin Boqpod Pod Kit Replacement Cartridge with 1.1ohm Ceramic Coil(2 PCS) $5.99
The Vladdin Replacement Pod Cartridge is designed for Vladdin Boqpod Pod Kit. It has 1.0ml e-juice capacity and comes with a 1.1ohm ceramic coil. 2 PCS / Pack.
Original Gas Mods MARS Pod Kit Replacement Cartridge(3 PCS) $6.00
The Gas Mods Replacement Pod Cartridge is designed for Gas Mods MARS Pod Kit. It has 2.0ml e-juice capacity. 3 PCS / Pack.
Original Reewape RUOK RBA Coil Head for SMOK Nord / SMOK RPM Nord Pod / Blitz Realm Kit / Hotcig Marvel / Dovpo Peaks $5.99
The Reewape RUOK RBA Coil is perfectly compatible with the hot-selling pod: SMOK Nord pod / SMOK RPM nord pod / SMOK Fetch mini Nord pod / Volta AIO kit / Blitz realm kit / SMOK vape pen / SMOK trinity pod / Hotcig marvel pod / Oukitel mate / Oukitel bison / Dovpo peaks / Lusty nevoks / Nikola antares as a replacement RBA coil. It fits for most of DIY vaping lovers. You can enjoy the DIY pleasure and it brings you massive vapor and purer flavor.
Старый 14.11.2019, 05:04 Автор темы   512
3FVAPE
Original Pioneer4You IPV Revo YIHI Chip 200W TC VW Box Mod $97.99
The Pioneer4You IPV Revo YIHI Chip 200W TC VW Box Mod is powered by dual 18650 batteries (Not included), it reaches a maximum output of 200W. The IPV Revo mod adopted the YIHI high-performance intelligent control system with YiHi SX605E Chipset. Morever, the IPV Revo supports the automatic liquid-filling system. The ESS (Electronic Spay Squonk) technology makes refill so easy than before. The IPV Revo is also adjustable in temperature. Compatible with IPV Finder BF RDA, it is designed for the vapers who is seeking for purer taste and personalized vaping experience. The anti dry burn system ensures a safe vape, too.
Orignal Pioneer4You IPV Finder RDA with BF Pin $20.99
The Pioneer4You IPV Finder BF RDA is constructed from stainless steel in 24mm diameter. The RDA is Dual Bottom-Feeding RDA for perfect flavor and adopt fused clapton wire as heating coil material. The RDA is perfectly compatible with Pioneer4You IPV Revo YIHI Chip TC 200W Mod. This RDA comes with bottom feeder / BF / Squonk Pin.
Original asMODus ANANI MTL RTA $25.00
The asMODus ANANI MTL RTA is constructed from stainless steel in 24mm diameter, which comes with 5.3mm deep juice and gold plated grub screws, gold plated squonk. With top airflow design and two post build deck, this RTA can offers excellent flavor. What's more, it can be used as a squonker RTA for bottom feeding devices.
Original Wotofo Profile 1.5 RDA with BF Pin original price$34.99, now only$25.99
The Wotofo Profile1.5 RDA is a upgraded version of profile RDA, which is constructed from stainless steel in 24mm diameter. It comes with three different coils for option, including nexMESH CHILL A1 0.15ohm, nexMESH TURBO A1 0.13ohm and nexMESH EXTREME A1 0.16ohm. The RDA features max air supply, lower air supply and flexible air supply, which support single mesh coil and provides fast heating and flavor strengthening. It is compatible with Squonk style mod and regular mod. The RDA can provide you with great flavor and cloud vapor. This RDA comes with bottom feeder / BF / Squonk Pin.
Original Shanlaan Laan Lite 10.5W 320mAh Pod System Starter Kit original price$29.99, now only$8.99
The Shanlaan Laan Lite Pod Kit is operated with a draw activated firing mechanism and has a maximum output of 10.5W. Shanlaan Laan has a refillable pod with an atomizer resistance of 1.3ohm and a maximum capacity of 1.4ml. A 320mAh built in battery supplies power for the device and an LED battery life indicator indicates its battery life. The Laan can be charged via the proprietary magnetic charging cable.
Original SMOKTech SMOK SLM 16W 250mAh Pod System Starter Kit original price$20.99, now only$8.99
The SMOKTech SMOK SLM Pod System Kit is an ultra-portable vape kit. It is powered by built-in 250mAh battery. The pod cartridge has 0.8ml of juice capacity and 1.8ohm coil. It is an air-activated pod device, you can enjoy the puffs without any fire button. Equipped with an intelligent LED indicator, it can show the battery status clearly.
Original SMOKTech SMOK Mico 26W 700mAh Pod System Starter Kit original price$20.99, now only$11.99
In the palm of your hand, MICO is coming for you. It adopts a classic resin design on the device where the unique multicolored fluid lines look like abstract oil paintings, possessing a stylish and elegant high-gloss finish. Powered by a built-in 700mAh lithium battery, MICO is sufficient for you to enjoy vaping all day along. There are two pods included in this kit, one pod with 0.8ohm mesh coil and one pod with 1.0ohm regular coil which can offer superb MTL vaping experience; both of them have 1.7ml capacity, and you can drip your favorite e-liquid into them. Besides, one lanyard is attached in the kit for both decorative purpose and portability.
Original IJOY Stick VPC 15W 1100mAh Mod + VPC 1.6 Pod System Starter Kit original price$20.99, now only$7.99
The IJOY STICK VPC KIT consists of the authentic IJOY Stick VPC 1100mAh mod and VPC 1.6 Pod. The IJOY Stick VPC 1100mAh mod is a well-made pen-shaped vaping device with elegant and exquisite appearance and pocket friendly size, powered by 1100mAh rechargeable battery. It carries IWEPAL control chip internally to guarantee stable output The all-in-one metal button and indicator light not only give your hands generous feeling, but also illustrate the battery storage. The Stick VPC 1.6 Pod is equipped with a 2ml e-juice capacity VPC UNIPOD with an innovative side filling system for your easy operation. Built-in ceramic coil performs better than standard coils, giving you the tastier and purer flavor.
Original KangerTech Ripple Kit 200W TC VV Box Mod with Sub Ohm Tank original price$49.99, now only$33.99
The Kanger Ripple Box Mod Kit consists of Kanger Ripple 200W TC VV Box Mod and Kanger Ripple Sub-Ohm Tank Atomizer, which is the newest vaping powerhouse from Kanger, utilizing a high-amp dual 18650 battery layout, an extensive temperature control suite, and is paired with the advanced Ripple Sub-Ohm Tank. Within the Kanger Ripple Starter Kit, is an advanced proprietary chipset, amounting to an instantaneous firing speed and provides access to an extensive temperature control suite with nickel, titanium, and stainless steel compatibility. The Kanger Ripple is powered by dual high-amp 18650 batteries (Not included) and can accept coils of 0.05~3.0ohm resistance while providing extensive temperature control options. In addition, the Kanger Ripple utilizes a slew of safety protections like over-temperature protection, over-time protection, overcharging protection, short-circuit, and low voltage protection. Furthermore, the kit comes with the Ripple Tank, featuring a 25mm Sub-Ohm chassis with 3.5ml maximum capacity, dual bottom airflow, and a mesh Kanger NR Coil System.
Старый 14.11.2019, 05:09 Автор темы   513
3FVAPE
Original Innokin CoolFire Mini 40W 1300mAh VV VW Box Mod with Zenith D22 Tank Atomizer Kit original price$49.99, now only$33.99
The Innokin Coolfire Mini 40W Kit consists of Innokin Coolfire Mini 40W Box Mod and Zenith D22 Tank Atomizer, which is a compact device from Innokin, featuring an integrated 1300mAh rechargeable battery, variable wattage and voltage modes, and can fire at up to 40W. The Coolfire Mini Box Mod implements an internal 1300mAh battery for long-lasting experience, easily charge via Micro-USB charging port situated beneath the adjustment buttons. The Coolfire Mini 40W has a variable voltage and wattage modes that can utilize features off of other tanks to dial in the optimal power adjustments. The maximum wattage the Innokin can achieve is 40W, perfect for those looking for a more discreet vape, perfectly balance for the compact size. Each kit is paired with the Innokin Zenith D22 Tank, featuring a top fill system, 2.0ml E-liquid capacity, and dual bottom adjustable airflow control ring. Airflow enters the Zenith D22 MTL Tank through four adjustable airslots located at the base, each measuring a different diameter for precision fine-tuning for desired airflow pull. The central atomizer chamber accommodates the new Zenith Plexus Z Coil Technology, headlined by a 1.6ohm Plexus Z Coil rated for cooler vape with a wattage range of 10 to 14W and 0.8ohm coil rated for a warmer vape with a wattage range of 15 to 18W.
Original Wotofo nexMESH Extreme A1 Prebuilt Wire Mesh Sheet for Profile 1.5 RDA / Profile Unity RTA(10 PCS) original price$9.90, now only$4.99
The Wotofo nexMESH Prebuilt Wire Mesh Sheet features fast heating process and 0.16ohm resistance, it will bring you massive vapor. It is suitable for Wotofo Profile RDA / Profile Unity RTA and other RDAs that use mesh wire. The nexMESH Extreme is to mesh as complex Clapton is to single-strand coil, it offers larger coiling surface area, in a micro way, than normal mesh strips, thus increases vapor production and enhance flavor production. 10 PCS / Pack.
Original KangerTech CLOCC TC Ni200 Coil Atomizer Head for Kanger CLTANK 2.0 / CLTANK 4.0 / CUPTI 2(5 PCS) $6.99
The KangerTech CLOCC TC Nickel Ni200 Atomizer Head features 0.15ohm coil resistance, which is compatible with Kanger CLTANK 2.0 / CLTANK 4.0 / CUPTI / CUPTI 2, butthe Ni200 Atomizer Head is not compatible with the EVOD PRO or the TOGO Series.5 PCS / Pack.
Original KangerTech NR Replacement Mesh Kanthal Coil Head for XLUM Sub Ohm Tank(3 PCS) $7.99
The KangerTech NR Mesh Kanthal Coil Head features 0.18ohm coil resistance and power range from 40W to 60W, which is designed for XLUM Sub Ohm Tank. 3 PCS / Pack.
Original Shanlaan Laan Lite Replacement Pod Cartridge with 1.3ohm Ceramic Coil(4 PCS) $7.99
The Shanlaan Laan Lite Replacement Pod Cartridge comes with 1.3ohm of resistance and 1.4ml capacity. It is suitable for Shanlaan Laan Lite Pod System Kit.
Original SMOKTech SMOK Mico Pod Kit Replacement Cartridge with 1.4ohm Ceramic Coil(3 PCS) $6.99
The SMOKTech SMOK Mico Replacement Pod Cartridge can hold 1.7ml of juice capacity and comes with 1.4ohm ceramic coil. It is suitable for SMOKTech SMOK Mico Pod Kit.
Original SMOKTech SMOK Mico Pod Kit Replacement Cartridge with 1.0ohm Regular Coil(3 PCS) $6.99
The SMOKTech SMOK Mico Replacement Pod Cartridge can hold 1.7ml of juice capacity and comes with 1.0ohm Regular Coil. It is suitable for SMOKTech SMOK Mico Pod Kit.
Original SMOKTech SMOK Mico Pod Kit Replacement Cartridge with 0.8ohm Mesh Coil(3 PCS) $6.99
The SMOKTech SMOK Mico Replacement Pod Cartridge can hold 1.7ml of juice capacity and comes with 0.8ohm Mesh Coil. It is suitable for SMOKTech SMOK Mico Pod Kit.
Original Artery Nugget AIO Pod Kit Replacement Cartridge for HP 0.4ohm Mesh Coil original price$12.90, now only$7.99
The Artery Nugget AIO Replacement Pod Cartridge is perfectly designed for the Nugget AIO Pod Kit. The pod comes with 2ml juice capacity, which is compatible with 0.4ohm mesh coil (Not included). It will bring great flavor and decent vapor production when you vape with Artery Nugget Kit. The innovative refilling system upgrades the juice filling to a new level.
Original Artery Nugget AIO Pod Kit Replacement Cartridge for 1.4ohm Regular Coil original price$12.90, now only$7.99
The Artery Nugget AIO Replacement Pod Cartridge is perfectly designed for the Nugget AIO Pod Kit. The pod comes with 2ml juice capacity, which is compatible with 1.4ohm regular coil (Not included). It will bring great flavor and decent vapor production when you vape with Artery Nugget Kit. The innovative refilling system upgrades the juice filling to a new level.
Original Artery Nugget Replacement HP Regular Coil Head for AIO Pod Kit / Pod Cartridge(5 PCS) original price$14.90, now only$7.99
The Artery Nugget Replacement HP Regular Coil Head is designed for Artery Nugget AIO Pod Kit / Pod Cartridge. It features 1.4ohm coil resistance and power range from 7W to 11W. 5 PCS / Pack. Compatible with Pal 2 / Pal 2 Pro
Original Artery Nugget Replacement HP Mesh Coil Head for AIO Pod Kit / Pod Cartridge(5 PCS) original price$16.90, now only$7.99
The Artery Nugget Replacement HP Mesh Coil Head is designed for Artery Nugget AIO Pod Kit / Pod Cartridge. It features 0.4ohm coil resistance and power range from 20W to 28W. 5 PCS / Pack.
Original Artery Nugget Replacement DIY RBA Coil Head for AIO Pod Kit / Pod Cartridge original price$12.90, now only$7.99
The Artery Nugget Replacement RBA Coil Head is designed for Artery Nugget AIO Pod Kit / Pod Cartridge. It fits for DIY vaping lovers.
Старый 15.11.2019, 05:05 Автор темы   514
3FVAPE
Original Pioneer4You IPV V-IT 200W TC VW Box Mod with YIHI SX540 Chip $34.99
The Pioneer4You IPV V-IT 200W TC VW Box Mod is powered by dual 21700 batteies (Not included) enough to reach up to 200W output for your longer vaping, equipping with YiHi SX540 chipset. There are three working modes are allowed to utilize, including bypass mode for mechanical vaping, novice mode for simpler operation and the taste mode for customized flavor. What's more, the IPV V-IT TC box mod adopts YiHi SXI-Q control system with 1.3 inches TFT screen and 510 thread, which will escalate the vaping experience to a new level.
Original Nikola Delorean 12.67W 350mAh Refillable Pod System Starter Kit original price$25.99, now only$14.99
The Nikola Delorean 350mAh Pod System is constructed from Zinc Alloy. Powered by a built-in 350mAh battery, it comes with three LED indicators, four changeable voltage levels. The 2ml pod with 1.2ohm ceramic coil utilizes the usage of nicotine salt e-liquids beautifully.
Original Oukitel Ravo 40W VW Box Mod Pod System Starter Kit $30.99
The Oukitel Ravo can support 3000mAh 18650 batteries while bringing you massive vapor. You can use single 18650 battery (Not included) to help you enjoy massive vaping all the time. Small and easy to carry. The power range of RAVO can from 10 watts and 40 watts. You can switch to your desired power output mode by pressing the wattage adjustable button. RAVO has excellent grip feeling and multiple functions, it can be used for NIC SALT mode, power mode. It also only takes 0.03s to start vape. There is a high-definition LED screen on the battery body to indicate the battery capacity clearly. The atomizer capacity is 3.5ml, which can also airflow adjustable. It is equipped with two replaceable coils: 0.3ohm mesh coil and 1.4ohm dual wire coil. You can use 1.4ohn coil for nic salt mod or 0.3ohm coil for free base mode. More importantly, RAVO also offers a variety of protections to ensure your vaping safety.
Original Nevoks Angus 60W 1700mAh Mesh RDA Starter Kit $27.99
The Nevoks Angus Kit, a delicate and portable RDA Starter kit, is powered by 1700mAh built-in battery with 60W max output. Applying special square RDA for new and better vape experience, it adopts slide design for stability and playability. What's more, it comes with 0.18ohm mesh coil for intense flavor and massive cloud, 0.5ohm Ni80 coil for evenly heating and long lifespan. With the RDA kit, you are allowed to DIY coils that could add more DIY enjoyment. Furthermore, just needing 0.01s ignition time, it chooses adjustable wattage to meet your individual demands better. And it provides multiple protections to ensure your vaping safety.
Original Suorin Trio 16W 850mAh Pod System Starter Kit original price$33.99, now only$27.99
The Suorin Trio Pod Systme Starter Kit is a thin and portable vape, which is powered by built-in 850mAh rechargeable battery (Output Power: Max 16W) to support long-time vaping. It is equipped with an LED power indicator for showing the detailed vaping data clearly. The pod kit is made of Aluminium Alloy with light weight, making this vape can be brought around in the pocket, backpack, or purse. Suorin Trio Pod features a child-safe locking system and side filling design to prevent usage by children and those that are not supposed to be using the device. Suorin Trio cartridges maintain one 3ml single cartridge and two 1ml dual cartridges that can bring vapers 2 flavors in 1 Pod, allowing the user to bring around two of their favorite flavors without needing to change the pod to change flavors.
Original Gas Mods Mars Pod Kit Replacement Cartridge with 1.8ohm Coil(3 PCS) $6.00
The Gas Mods Replacement Pod Cartridge is designed for Gas Mods MARS Pod Kit. It has 2.0ml e-juice capacity and comes with 1.8ohm coil. 3 PCS / Pack.
Original Wotofo nexMESH Turbo A1 Prebuilt Wire Mesh Sheet for Profile 1.5 RDA(10 PCS) original price$9.90, now only$4.99
The Wotofo nexMESH Prebuilt Wire Mesh Sheet features fast heating process and 0.13ohm resistance, it will bring you massive vapor. It is suitable for Wotofo Profile 1.5 RDA. The nexMESH Turbo is the high-density perforated mesh strip similar to nexMESH Chill. It offers a faster ramp up time and provides large contact surface to the e-liquid. More vapor with more possibilities to taste more notes in e-liquids within lesser time. 10 PCS / Pack.
Original Wotofo nexMESH Chill A1 Prebuilt Wire Mesh Sheet for Profile 1.5 RDA(10 PCS) original price$9.90, now only$4.99
The Wotofo nexMESH Prebuilt Wire Mesh Sheet features fast heating process and 0.15ohm resistance, it will bring you massive vapor. The nexMESH Chill is the strip of vape metal with properly punched holes in it to form a mesh-like structure. It offers even heat distribution and fast heating speed. With precise control on meshing, nexMESH Chill is able to break down the flavor profile in the e-liquid and allow more definite taste sensation. 10 PCS / Pack.
SXK Boxer Replacement Bottom Feeder Squonk Bottle $2.59
The replacement bottom feeder squonk bottle is made from super soft silicone and comes with 7ml capacity. It is suitable for SXK Box 200W VV VW Variable Wattage Squonk Box Mod Clone.
Original Hippovape Replacement Silicone Bottom Feeder Squonk Bottle + SS Connector for Kudos 80W Box Mod $11.99
The Hippovape replacement bottom feeder squonk bottle is made of silicone (bottle)and stainless steel (connector), it comes with 7ml capacity. The Stainless Steel Connector can be opened or closed the squonk bottle by uplock or lock the knob. It is suitable for Hippovape Kudos 80W VW Variable Wattage Squonk Box Mod.
Original Suorin Trio Pod System Kit Replacement Single Cartridge $6.99
The Suorin TRIO replacement pod is designed specifically for the Suorin Trio Pod System Kit, which has 3ml juica capacity and supports side filling system, coming with a magnetic pod connection.
Original Suorin Trio Pod System Kit Replacement Dual Cartridge $6.99
The Suorin TRIO replacement pod is designed specifically for the Suorin Trio Pod System Kit, which has 1ml juice capacity and can bring vapers 2 flavors in 1 Pod. The Pod supports side filling system and comes with a magnetic pod connection.
Original Uwell Replacement Neutral Bubble Tank Tube for Nunchaku 2 Tank / Kit $2.99
The Uwell Replacement Glass Bubble Tank Tube has 5ml juice capacity, which is designed for Uwell Nunchaku 2 Kit and Nunchaku 2 Tank as a replacement part.
Старый 15.11.2019, 05:11 Автор темы   515
3FVAPE
Original Oukitel Ravo Pod System Kit Replacement Empty Cartridge(2 PCS) $8.59
The Oukitel Ravo replacement pod is designed specifically for the Oukitel Ravo Pod System Kit, which has 3.5ml juice capacity. 2 PCS / Pack.
Original Oukitel Ravo Pod System Kit Replacement Coil Head(3 PCS) $8.89
The Oukitel Ravo replacement coil head is designed specifically for the Oukitel Ravo Pod System Kit, which features 1.4ohm coil resistance. 3 PCS / Pack.
The Oukitel Ravo replacement coil head is designed specifically for the Oukitel Ravo Pod System Kit, which features 0.3ohm coil resistance. 3 PCS / Pack.
Original Nikola Replacement Refillable Pod Cartridge with 1.2ohm Coil for Delorean Pod System Kit(3 PCS) original price$9.99, now only$5.99
The Nikola Delorean Replacement Refillable Pod features 2ml of juice capacity and 1.2ohm coil resistance. It is suitable for authentic Nikola Delorean Pod System Kit. 3 PCS / Pack.
Старый 16.11.2019, 04:39 Автор темы   516
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original VGME Mask Bottom Feeder Squonk Mechanical Box Mod original price$29.99, now only$14.99
The VGME Mask BF squonk mod is a high end squonker device constructed from durable ABS material, which is powered by a single 18650 / 20700 / 21700 battery (Not included). The built-in bottom feeder bottle is capable of holding 8ml e-juice. The mod adopts brass contact for better conductivity. The fire button can be locked to avoid risk of mis-firing.
Triple ABS Mechanical Box Mod Clone original price$29.99, now only$14.99
The Triple ABS Mechanical Box Mod Clone is constructed from Acrylic and it is powered by triple 18650 batteries. (Not included)
Violence Box 280W Mechanical Mod Clone original price$29.99, now only$14.99
The Violence Box 280W Mechanical Mod Clone is constructed from Aluminum and it is powered by dual 18650 batteries.(Not included)The Mod comes with Spring loaded fire button and the maximum wattage can up to 280W.
Original Puff Rectangle Replacement Organic Cotton Wick for RDA / RTA / RBA Atomizer $9.29
The Puff Rectangle Organic Cotton Wick is suitable for RDA / RTA / RBA / rebuildable atomizer. It comes with 6 x 8mm, L size.
Original Demon Killer Food Grade Rosin Press Paper(50 PCS) $2.99
The Demon Killer Food Grade Rosin Press Paper is suitable for Rosin Press Machine KP-1, KP-2 as replacement rosin press paper. It comes with 100 x 150mm size. 50 PCS / Pack.
Original Demon Killer Food Grade Rosin Press Paper(50 PCS) $3.59
The Demon Killer Food Grade Rosin Press Paper is suitable for Rosin Press Machine KP-1, KP-2 as replacement rosin press paper. It comes with 150 x 200mm size. 50 PCS / Pack.
Original Demon Killer Food Grade Rosin Press Paper(50 PCS) $4.99
The Demon Killer Food Grade Rosin Press Paper is suitable for Rosin Press Machine KP-1, KP-2 as replacement rosin press paper. It comes with 200 x 300mm size. 50 PCS / Pack.
Original Demon Killer Terp Done Tool Kit - Beaker + Syringe + Syringe Needle + Dropper + Muddler + Brush + Silicone Mat & Box original price$39.00, now only$14.99
The Demon Killer Terp Done Tool Kit is a professional kit for the adjustment of THC oil. It has a small size and comes with complete tools, which will satisfy your needs of DIY vaping. The unique soft brush is easy to clean.
Original Timesvape Dreamer Mechanical Mech Mod Extend Stacked Tube $20.99
The Timesvape Dreamer Mechanical Mech Mod Extend Stacked Tube is contructed from Stainless Steel and the Extend Stacked Tube can extend the height of the Dreamer Mod and makes it can be powered by single 18650 / 20700 / 21700 batteries. (Not included)
Original VGME 521 Tab V3 Battery Capacity Tester / Ohm Meter Reader / Coil Rebuilding Deck original price$29.99, now only$14.99
The Original VGME 521 Tab V3 3 in 1 Tool is a collection of battery capacity tester, ohm meter and coil building function. The resistance measuring range is from 0.01ohm to 3ohm. The ohm meter reader utilizes single high amp 18650 battery (Not included). It is one of the best DIY tools for vapers.
Старый 18.11.2019, 04:50 Автор темы   517
3FVAPE
Original OVNS Saber 2 II 600mAh Pod System Starter Kit $14.99
The OVNS Saber II Pod System Starter Kit is the sequel generation of the renowned Saber pod system, which is powered by 600mAh built-in battery. The Pod Kit comes with a 1.4ohm coil and 1.5ml juice capacity pod to meet your all day long vaping. This Saber 2 kit inherit the special and ergonomic design. Moreover, the refillable pod adopts a unique dual ON-S cotton coil structure, which means it can produce more vapor and gives you the original flavor taste. You can have a box mod vaping experience with this small pod kit.
Original Reewape AS282 Replacement 810-510 Drip Tip Conversion Adapter $1.29
The Reewape AS282 Replacement 810-510 Drip Tip Conversion Adapter is constructed from stainless steel. The Height of Conversion Adapter is 7mm and the Connector Diameter is 17mm (Max) and 12.5mm. The Conversion Adapter can be used to convert 510 drip tip connector to 810 drip tip connector.
Original Reewape AS281TS 810 Replacement Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy /Battle/Reload RDA $1.79
The Reewape AS281TS 810 Replacement drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS263CS 810 Replacement Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy /Battle/Reload RDA $1.59
The Reewape AS263CS 810 Replacement drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS265 810 Replacement Drip Tip for SMOK TFV8 /TFV12 Tank/Kennedy/Battle/Reload RDA $1.49
The Reewape AS265 810 Replacement drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS267 810 Replacement Drip Tip for SMOK TFV8 /TFV12 Tank/Kennedy/Battle/Reload RDA $1.49
The Reewape AS267 810 Replacement drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS268 810 Replacement Drip Tip for SMOK TFV8/TFV12 Tank/Kennedy/Battle/Reload RDA $1.49
The Reewape AS268 810 Replacement drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS270 810 Replacement Drip Tip for SMOK TFV8/TFV12 Tank/Kennedy/Reload RDA $1.69
The Reewape AS270 810 Replacement drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
3FVAPE вне форума   Вверх
Старый 18.11.2019, 04:54 Автор темы   518
3FVAPE
Original Reewape AS271 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.69
The Reewape AS271 510 drip tip is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS279 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.69
The Reewape AS279 510 drip tip is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS280 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.69
The Reewape AS280 510 drip tip is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS281 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.59
The Reewape AS281 510 drip tip is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS281S 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.69
The Reewape AS281S 510 drip tip is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Voopoo PnP-VM3 Mesh Coil Head for VINCI Series Mod Pod Kit / Drag Baby Trio Kit(5 PCS) $12.99
The Voopoo Replacement PnP-VM3 Mesh Coil Head features 0.45ohm coil resistance and the recommended wattage is from 25 to 35W, which is designed for VINCI / VINCI R / VINCI X Mod Pod Kit / Drag Baby Trio Pod Kit.
Original Fumytech 2.7ml to 5ml Replacement Lengthen Tank Tube for BDvape Precisio MTL RTA $7.80
The Fumytech Replacement Lengthen Tank Tube is constructed from stainless steel and it is designed for BDvape Precisio MTL RTA Atomizer as a replacement part to lengthen the length of tank tube from 2.7ml juice capacity to 5ml juice capacity. The images for reference only, the real color is Carbon Black
Original Fumytech Replacement Bottom Feeder Juice Bottle 1.5 for BDvape Pure BF Squonk Box Mod $9.99
The Fumytech Replacement Juice Bottle 1.5 is designed for BDvape Pure BF Squonk Mechanical Box Mod as a replacement part to refilling the juice.
Original OVNS Saber II Pod Kit Replacement Cartridge with 1.4ohm Coil(4 PCS) $8.39
The OVNS Replacement Cartridge is designed for Saber II Pod Kit as a replacement part, which features 1.4ohm coil resistance and comes with 1.5ml juice capacity. 4 PCS / Pack.
Original HippoVape VSS RBA Rebuildable Coil Kit V2 for SMOK RPM Nord Pod / Hotcig Marvel /Dovpo Peaks $6.99
The HippoVape VSS RBA Rebuildable Coil Kit V2 is constructed from stainless steel, it is compatible with Volta AIO Kit / Blitz Realm Kit / SMOK Nord Pod Kit / SMOK RPM Nord Pod Kit / SMOK Fetch Mini Nord Pod Kit / SMOK Vape Pen Kit / SMOK Trinity / Hotcig Marvel / Oukitel Mate / Oukitel Bison / Dovpo Peaks.
Старый 19.11.2019, 04:34 Автор темы   519
3FVAPE
BF-99 BF99 MTL RDTA Clone $14.99
The BF-99 BF99 MTL RDTA Clone is constructed from 316 Stainless Steel (body) and PC (tank) in 22mm diameter. The RDTA comes with a 2.5ml juice capacity PC tank. The RDTA supports side airflow adjustable control and bottom refilling. The hole airflow provides a big vapor and great flavor. It also supports Mouth to lung (MTL) vaping experience.
Bastard MTL / DTL RTA Clone $14.99
The Bastard RTA Clone is constructed from 316 Stainless Steel in 22mm diameter. It features a single coil build deck. The RTA comes with a 3.5ml juice capacity tank tube and supports bottom modular airflow control and top filling system. The RTA can provide you MTL or DTL vaping experience. The RTA also can be converted to a RDA by conversion kit. (Not included)
Original Rincoe Mechman Nano 90W Box Mod with Metis RDA Kit $19.99
The Rincoe Mechman Nano 90W RDA Kit consists of Mechman Nano 90W Box Mod and Metis RDA Atomizer, which is powered by single 18650 battery (Not included) and delivers a maximum output of 90W. Constructed from PC and Leather, Mechman Nano kit has a fine appearance, good hand feeling and lightweight. As for the Metis RDA, it is constructed from stainless steel and aluminum in 24mm diameter and comes with gold plated 510 contact pin. And it also features dual airflow slots and top adjustable airflow top cap.
Clear Battery Protected Case for 18650 / 18500 / 18350 / 16340 / CR123A Li-ion Batteries $0.99
This is a Portable Plastic Clear Case, which can hold up 2 x 18650 Li-ion Batteries or 4 x 16340 / CR123A Batteries or 18350 Batteries.
eGo 420mA Fast USB Charger for Kanger EVOD / Kumiho eGo-C Manual Battery $2.99
The eGo Fast USB charger can charge for eGo Batteries. Normally it takes 2 hours to charge a 650mAh Battery completely. The LED on charger is red when charging, when the battery is fully charged, LED turns green. The Charger can also charge Kanger EVOD Manual Battery (3.7V,650mAh), Kumiho eGo-C 1300mAh Manual Battery (Constant Voltage: 3.7V).
eGo 450mA Fast USB Charger with Cord for eGo K / Kumiho eGo-C / Vision eGo Spinner Battery $2.99
The universal USB charger for most eGo 1100mAh / 1300mAh batteries. Normally, it takes 2 hours to charge a 1100mAh / 1300mAh battery completely. The LED is red when charging,when the battery is fully charged,LED turns green. It can match with eGo K 1100mAh battery, Kumiho eGo-C 1300mAh Manual Battery (Constant Voltage:3.7V), Vision eGo Spinner 1100mAh Variable Volt Battery and so forth. NOTE: As the output of this charger is larger than 420mA eGo Fast USB charger, it is NOT recommended for battery whose capacity is less than 1100mAh, such as Vision eGo Spinner 400mAh Variable Volt Battery, Kumiho eGo-C 900mAh Manual battery.
Original Uwell Valyrian 2 Tank Replacement Bubble Tank Tube $2.99
The Uwell Replacement Bubble Glass Tank Tube is designed for Valyrian 2 tank. It features 6ml tank capacity.
Original OneVape Mace M Replacement MTL Single Mesh Coil Head for Mace Pod Kit / Cartridge(4 PCS) $10.99
The OneVape Mace M Replacement MTL Single Mesh Coil Head is designed for OneVape Mace Pod Kit / Pod Cartridge as a replacement part, which features 0.6ohm Coil Resistance (Best: 23W).
Original OneVape Mace DM Replacement DTL Dual Mesh Coil Head for Mace Pod Kit / Cartridge(4 PCS) $10.99
The OneVape Mace DM Replacement DTL Dual Mesh Coil Head is designed for OneVape Mace Pod Kit / Pod Cartridge as a replacement part, which features 0.3ohm Coil Resistance (Best: 45W).
Original OneVape Mace TM Replacement DTL Triple Mesh Coil Head for Mace Pod Kit /Cartridge(4 PCS) $10.99
The OneVape Mace TM Replacement DTL Triple Mesh Coil Head is designed for OneVape Mace Pod Kit / Pod Cartridge as a replacement part, which features 0.2ohm Coil Resistance (Best: 70W).
Original OneVape Mace Relacement MTL RBA Coil Head for OneVape Mace Pod Kit / Cartridge $6.99
The OneVape Mace Relacement MTL RBA Coil Head is designed for OneVape Mace Pod Kit / Pod Cartridge as a replacement part, which supports power range from 0.2ohm to 2.5ohm.
KS Replacement Stainless Steel Base Deck + 3 Mouthpiece Drip Tip Set for SXK BB Billet Mod Box $5.99
The KS Replacement Drip Tip Set consists of one Stainless Steel Base Deck and three mouthpiece drip tips. They are suitable for SXK Billet BB Box Mod kit as replacement parts.
Старый 20.11.2019, 04:49 Автор темы   520
3FVAPE
SXK HOLY Patibulum MTL RTA Clone original price$22.90, now only$18.99
The SXK HOLY Patibulum MTL RTA Clone is a 22mm rebuildable tank atomizer designed for mouth to lung vaping, which comes with 3.5ml tank capacity. It is constructed from 316 stainless steel and PEI. It features disk type AFC system and juice tunnel which is ideal for straight wicking.
Original Innokin Podin Mini 800mAh Pod System Starter Kit $26.99
The Innokin Podin Mini Pod Systme Starter Kit is powered by 800mAh built-in battery, coupled with a sturdy yet lightweight construction the Podin is Innokins latest venture into the burgeoning interchangeable coil pod kit market. With an adjustable airflow function and a range of safety functions, the Podin employs the proprietary 2ml refillable Podin pods. Furthermore, the Podin Mini Pods are reusable. The pod can replace the coils easily and reduce plastic pod waste. The long lasting 800mAh battery is micro USB charged and the Podin features a full range of integrated safety protections. The Tri-LED Battery level indicator clearly shows remaining battery capacity.
Original Innokin Podin Mini 800mAh Pod System Starter Kit with Adapter Installed $27.99
The Innokin Podin Mini Pod Systme Starter Kit (with Adapter Installed) is powered by 800mAh built-in battery, coupled with a sturdy yet lightweight construction the Podin is Innokins latest venture into the burgeoning interchangeable coil pod kit market. With an adjustable airflow function and a range of safety functions, the Podin employs the proprietary 2ml refillable Podin pods. Furthermore, the Podin Mini Pods are reusable. The pod can replace the coils easily and reduce plastic pod waste. The long lasting 800mAh battery is micro USB charged and the Podin features a full range of integrated safety protections. The Tri-LED Battery level indicator clearly shows remaining battery capacity.
Original AVCT Avictor Orbit AIO 30W 1300mAh Pod System Starter Kit $20.99
The AVCT Avictor Tech Orbit AIO Pod Kit is an aesthetically gorgeous device with an epoxy resin chassis construction. The Orbit has an integrated 1300mAh rechargeable battery that can put out up to 30W. Sturdy brass and epoxy resin go into the construction of the Orbit pod kit so it is able to withstand unplanned falls and drops. A soft-touch rubberized coating and ergonomic design will keep it from slipping out of the hand. The 0.6ohm and 1.0ohm coils are designed for vaping clouds and flavor, respectively. An oversize firing button is featured along with a top mounted pilot light that doubles as an LED battery indicator light to estimate the charge status of the remaining battery's charge. Removing the 4mm bore resin drip tip allows for changing of the coil and accessing the threaded top fill system, marked with a fill line to prevent over filling and leaks.
Original Innokin Podin Mini Pod Kit Replacement Cartridge with 1.3ohm Coil $5.99
This Innokin Replacement Pod Cartridge is designed for Innokin Podin Mini Pod Kit, which has 2ml e-juice capacity and comes with 1.3ohm coil resistance, it supports airflow control, easy side filling and can replaceable coil.
Original Innokin Replacement Kanthal Coil Head for Podin Mini Pod Kit / Cartridge(5 PCS) $6.99
This Innokin Replacement Kanthal Coil Head is compatible with Innokin Podin Mini Pod Kit or Innokin Podin Mini Pod Cartridge, which features 1.3ohm coil resistance. 5 PCS / Pack.
Replacement Decorative Beauty Ring for Dvarw MTL RTA $4.99
The Dvarw Replacement Decorative Beauty Ring is designed for Dvarw MTL RTA Atomizer as a replacement part, which is made of PEI and has 22mm inner diameter and 24mm outer diameter.
SXK Replacement Middle Top Cap for SXK Haku Xeta Inside RBA Clone $3.90
The SXK Replacement Middle Top Cap is made of PC, which is suitable for SXK Haku Xeta Inside RBA Clone as a replacement part.
SXK Replacement Top Cap Tank Tube for HOLY Patibulum RTA $3.90
The SXK Replacement Top Cap Tank Tube is made of PC in 22mm diameter, which is suitable for HOLY Patibulum RTA Atomizer as a replacement part.
SXK Replacement Drip Tip for HOLY Patibulum RTA $2.90
The SXK Replacement Drip Tip is made of PC, which is suitable for HOLY Patibulum RTA Atomizer as a replacement part.
SXK Replacement Top Cap for HOLY Patibulum RTA - Type A $6.90
The SXK Replacement Top Cap is made of 316 Stainless Steel, which is suitable for HOLY Patibulum RTA Atomizer as a replacement part.
SXK Replacement Top Cap for HOLY Patibulum RTA - Type B $6.90
SXK Replacement Top Cap for HOLY Patibulum RTA - Type C $6.90
Original Uwell Replacement UN2 Meshed Coil Head for Nunchaku / Nunchaku 2 Tank(4 PCS) $9.99
The Uwell UN2 Meshed Coil Head features 0.2ohm coil resistance and work well between 50W and 60W. It is suitable for Original Uwell Nunchaku tank / Nunchaku 2 tank. 4 PCS / Pack.
Время генерации страницы 0.58444 секунды с 15 запросами
