302497
822
481
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Sigelei Sobra 198W TC VW Box Mod with Moonshot 120 Tank Starter Kit original price$59.99, now only$28.99
The Sigelei Sobra 198W TC Starter Kit consists of Sigelei Sobra 198W Box Mod and Moonshot 120 Tank Atomizer. The Sobra 198W Box Mod chassis is constructed from Zinc Alloy with lightweight construction and brass accents and is decorated with vibrant colorways and snakeskin patterns. Above the screen lies two LED illuminated eyes to create a visually striking impression. The Sobra Box Mod is powered by Dual High-Amp 18650 Batteries(Not included) sit safely within the device, enclosed by a hinged door located at the bottom, providing long-lasting capability. ![]() Original FreeMax Twister Replacement TX1 Mesh Coil Head for Fireluke 2 Tank(5 PCS) $13.99 The Freemax Twister TX1 Mesh Coil is specially designed for the Freemax Twister Kit / Fireluke 2 Tank Atomizer. It features 0.15ohm coil resistance and the power range of this coil is from 40W to 90W. The recommended range is 80W. 5PCS / Pack. ![]() Original FreeMax Twister Replacement TNX2 Mesh Coil Head for Fireluke 2 Tank(5 PCS) $14.99 The Freemax Twister TNX2 Mesh Coil is specially designed for the Freemax Twister Kit / Fireluke 2 Tank Atomizer. It features 0.5ohm coil resistance and the power range of this coil is from 20W to 50W. The recommended range is 40W. 5PCS / Pack. ![]() Original FreeMax Twister Replacement TX2 Mesh Coil Head for Fireluke 2 Tank(5 PCS) $14.99 The Freemax Twister TX2 Mesh Coil is specially designed for the Freemax Twister Kit / Fireluke 2 Tank Atomizer. It features 0.2ohm coil resistance and the power range of this coil is from 40W to 80W. The recommended range is 70W. 5PCS / Pack. ![]() Original FreeMax Twister Replacement TX3 Mesh Coil Head for Fireluke 2 Tank(5 PCS) $16.99 The Freemax Twister TX3 Mesh Coil is specially designed for the Freemax Twister Kit / Fireluke 2 Tank Atomizer. It features 0.15ohm coil resistance and the power range of this coil is from 50W to 90W. The recommended range is 80W. 5PCS / Pack. ![]() Original FreeMax Twister Replacement TX4 Mesh Coil Head for Fireluke 2 Tank(5 PCS) $20.99 The Freemax Twister TX4 Mesh Coil is specially designed for the Freemax Twister Kit / Fireluke 2 Tank Atomizer. It features 0.15ohm coil resistance and the power range of this coil is from 40W to 80W. The recommended range is 70W. 5PCS / Pack. ![]() Original Voopoo Replacement MT-M1 Single Coil Head for Maat Tank (5 PCS) $9.99 The Voopoo Replacement MT-M1 Coil is specially designed for the Maat Tank Atomizer. It features 0.13ohm coil resistance and the power range of this coil is from 60W to 85W. 5PCS / Pack. ![]() Original Voopoo Replacement MT-M2 Dual Coil Head for Maat Tank(5 PCS) $10.59 The Voopoo Replacement MT-M2 Coil is specially designed for the Maat Tank Atomizer. It features 0.2ohm coil resistance and the power range of this coil is from 55W to 80W. 5PCS / Pack. ![]() Original Voopoo Replacement MT-M3 Triple Coil Head for Maat Tank(5 PCS) $10.99 The Voopoo Replacement MT-M3 Coil is specially designed for the Maat Tank Atomizer. It features 0.17ohm coil resistance and the power range of this coil is from 65W to 85W. 5PCS / Pack. ![]() Original Voopoo Replacement Uforce U8 Octuple Coil for Uforce / T1 Tank / T2 Tank(5 PCS) $14.99 The Voopoo Replacement Uforce U8 Coil is specially designed for the Uforce Tank / Uforce T1 Tank / Uforce T2 Tank Atomizer. It features 0.15ohm coil resistance and the power range of this coil is from 70W to 130W. The best range is from 90W to 110W. 5PCS / Pack.
482
Original Ovns JC01 Pro 400mAh Box Mod AIO Pod System Starter Kit $8.99
The JC01 Pro Pod Kit is an ultra portable AIO starter Kit powered by 400mAh built-in battery. With LED power indicating system, you can check the power state clearly. It comes with 1.0ml Juice capacity and installed with 1.5ohm coil. This device is very easy to charge as it comes with the USB charging. It also has multiple protections to ensure your vaping safe. ![]() Original Wellon Beyond AIO 35W VW Box Mod Pod System Starter Kit original price$49.99, now only$31.99 The Wellon Beyond AIO VW Box Mod Pod Kit is constructed from Zinc Alloy and PCTG material, which is powered by Single 18650 battery (Not included). and comes with a 2ml juice capacity pod cartridge, featuring a 0.3ohm SS316 Mesh Coil to meet your all day long vaping experience. The Beyond AIO Pod Kit comes with a 0.96" inch TFT Color Screen that show you device's states like output wattage, puffs, firing time, battery level, coil resistance and working voltage. There are seven types of protections that provide you a safe vaping experience. ![]() Original Vaporesso Degree Meshed 30W 950mAh VW Box Mod Pod System Starter Kit original price$47.90, now only$29.99 The Vaporesso Degree Pod Kit adopts AXON Chip with dry hit protection and smart wattage output functions. The AXON also include pulse mode, giving your vapor extra power and flavor with every inhale. Degree Pod Kit is powered by built-in 950mAh battery and comes with a Meshed Pod with 0.6ohm coil (16~22W), a CCELL Pod with 1.3ohm Coil (7~12.5W), featuring 2ml refillable pod capacity. The adjustable output meets your different vape needs. The PTF on top system makes filling super simple, without taking the pod out of the tank. Plus the Low E-liquid screen reminder, the Vaporesso Degree Kit is definitely a wonderful daily vaping device with easy and safe operation. ![]() Original Sigelei Snowwolf Vfeng 120W TC VW Squonk Box Mod + BF RDA Kit original price$79.99, now only$59.99 The Snowwolf Vfeng Squonk BF Kit consists of Snowwolf Vfeng Squonk Mod and SnowWolf Vfeng Squonk BF RDA Atomizer. The Snowwolf Vfeng Squonk Box Mod is the first squonk mod from Sigelei Snowwolf. Vfeng Squonk Mod features dual bottom feeder bottle, each for 3ml capacity, totally 6ml; and is compatible with 18650 (need adapter) / 20700 / 21700 batteries (Not included), which allows this mod to provide maximum output to 120W. This mod allows you to build as low as 0.05ohm in temperature control mode and 0.1ohm in power mode. ![]() Original Vsticking VKsma Kit Replacement E-liquid Tank(3 PCS) $6.99 The Vsticking VKsma E-liquid Tank is designed for Vsticking VKsma Kit and it features 3ml E-juice capacity and will bring you smooth flavor and cloud. 3 PCS / Pack. ![]() Original OVNS JC01 Pro Pod Kit Replacement Pod Cartridge with 1.5ohm Ceramic Coil(3 PCS) $3.99 The OVNS JC01 Pro Pod Cartridge is specially designed for OVNS JC01 Pro Kit. It comes with 1.0ml e-juice capacity, and features 1.5ohm ceramic coils, reflect the purest of the flavor and better throat hit feeling. 3 PCS / Pack. ![]() Original OVNS JC01 Pro Pod Kit Replacement Pod Cartridge with 1.5ohm Ceramic Coil(4 PCS) $4.99 The OVNS JC01 Pro Pod Cartridge is specially designed for OVNS JC01 Pro Kit. It comes with 1.0ml e-juice capacity, and features 1.5ohm ceramic coils, reflect the purest of the flavor and better throat hit feeling. 4 PCS / Pack. ![]() Original Vaporesso Degree Pod Kit Replacement Pod Catridge with 1.3ohm CCELL Coil(2 PCS) $7.99 The Vaporesso Degree Pod Cartridge is designed for Vaporesso Degree Meshed Pod Kit, it comes with a 2ml e-juice capacity and a CCELL 1.3ohm coil. The optimal range is from 7W to 12.5W. The pod with CCELL 1.3ohm coil is 5 times bigger contact area, it can produce increased flavor, bigger clouds and increased airflow. 2 PCS / Pack. ![]() Original Vaporesso Degree Pod Kit Replacement Pod Catridge with 0.6ohm Meshed Coil(2 PCS) $7.99 The Vaporesso Degree Pod Cartridge is designed for Vaporesso Degree Meshed Pod Kit, it comes with a 2ml e-juice capacity and a Meshed 0.6ohm coil. The optimal range is from 16W to 22W. the pod with Meshed 0.6ohm coil has optimized dimension of micro pores to fully realize flavors improved distribution of heat and liquid. And it can produce tighter airflow. 2 PCS / Pack. ![]() Original Uwell Juice Bank Refilling Dripping Bottle for E-juice Liquid $12.99 The Uwell Juice Bank is a refilling dripping bottle for e-liquid with a juice capacity of 15ml and the single refilling volume is about 0.1ml. The Juice Bank is constructed from Stainless Steel and Quartz Glass material, it has perfect protection from inside to outside. With the transparent windows on both sides of the bottle, you can check juice levels with a 15 ml scale. ![]() Original Wellon Beyond AIO Pod Kit Replacement SS316L Mesh Coil Head(5 PCS) $14.99 The Wellon Replacement SS316L Regular Mesh Coil is designed for Wellon Beyond AIO Pod Kit and it features 0.3ohm mesh coil resistance. 5 PCS / Pack. ![]() SXK Smuggler Mechanical Mod 18350 Battery Adapter Tube Clone original price$6.90, now only$5.99 The SXK 18350 Battery Extension Adapter Tube is constructed from 316 Stainless Steel in 23mm diameter and 51mm height. It is suitable for Smuggler 18650 Mechanical Mod Clone. ![]() SXK 16mm Atomizer Adapter Ring for Smuggler 18650 Mechanical Mod Clone original price$6.90, now only$4.99 The SXK Atomizer Adapter Ring is constructed from 316 Stainless Steel in 23mm diameter and 23mm height. The Adapter Ring is used specially with 16mm inner diameter atomizer and it is suitable for Smuggler 18650 Mechanical Mod Clone. ![]() SXK 18mm Atomizer Adapter Ring for Smuggler 18650 Mechanical Mod Clone original price$6.90, now only$4.99 The SXK Atomizer Adapter Ring is constructed from 316 Stainless Steel in 23mm diameter and 6mm height. The Adapter Ring is used specially with 18mm inner diameter atomizer and it is suitable for Smuggler 18650 Mechanical Mod Clone.
483
Lucifer Mechanical Mod Clone $14.99
The Lucifer mechanical mod Clone is constructed from copper in 25mm diameter, which is powered by single 18650 battery (Not included). It features knurled top hat with 510 threading connection. It comes with adjustable center pin. ![]() Original Ultroner DJV Meche Hybrid Mechanical Mod original price$96.80, now only$72.99 The DEJAVU DJV Mech Mod, designed by the YouTube reviewer Adrian Lo Dejavu, is a high-end mech mod powered by single 18650 battery (Not included). The DJV Mech Mod can work efficiently with two types of button, the stainless steel or acrylics. DEJAVU DJV Mod also features the innovative hybrid system, which makes the 510 pin of atomizer contact the battery directly for better power transfer and a harder, faster hit. With the advanced canted coil inside the gold-plated contact pin, the DEJAVU DJV Mech MOD can provide maximum firing and reduce heat effectively. ![]() EL Thunder Hybrid Mechanical Mod Clone $14.99 The EL Thunder Mechanical Mod Clone is constructed from stainless steel in 26mm diameter, which is powered by single 18650 battery (Not included).There is a bevel in the middle of the body, giving it a very comfortable feel. The mod features 510 hybrid connection with beveled edge, on top of which the atomizer will look great. The mod has spring bottom fire button. ![]() EL Thunder V3 Hybrid Mechanical Mod Clone $14.99 The EL Thunder V3 Mechanical Mod Clone is constructed from Stainless Steel in 25mm diameter which is powered by single 18650 / 20700 battery (Not included). It comes with a spring-loaded fire button and is compatible with 510 threading connection. ![]() MDLR RDA Clone with BF Pin $6.99 The MDLR RDA Clone is constructed from stainless steel in 24mm diameter, it fits perfectly on most of Mechanical Mod and Mechanical Box. The MDLR Style RDA supports side airflow and bottom airflow control. This RDA comes with bottom feeder pin. ![]() Original Damn Vape Dread RDA with BF Pin $14.99 The DamnVape Dread RDA is a 12-sided shape flavor chasing atomizer. It features 24mm diameter and is constructed from stainless steel. The honey comb airflow hits full surface of the LOLLY coil, the trident-post deck is designed for LOLLY coil build and wick. You may also build it with standard coils, this kit comes with easy LOLLY coil tool. This RDA comes with bottom feeder pin. ![]() SXK Reload X RDA Clone with BF Pin original price$18.90, now only$17.99 The SXK Reload X RDA Clone is constructed from stainless steel in 24mm diameter. It features postless quad terminal build deck and supports anti-leakage dual adjustable top-down bottom airflow control. This RDA comes with bottom feeder pin. ![]() Original Ohm Vape AIO Pod Kit Replacement Empty Pod Cartridge $1.99 The Ohm Vape AIO Pod Kit Replacement Empty Pod Cartridge is designed for Ohm Vape AIO Pod System Kit, coil is not included in it. ![]() Original Ohm Vape AIO Pod Kit Replacement SS316L Mesh Coil Head(5 PCS) $9.99 The Ohm Vape AIO Pod Kit Replacement Coil Head is designed for Ohm Vape AIO Pod System Kit, it features 0.3ohm mesh coil resistance. 5 PCS / Pack. ![]() Original Ohm Vape AIO Pod Kit Replacement Ceramic Coil Head(5 PCS) $9.99 The Ohm Vape AIO Pod Kit Replacement Coil Head is designed for Ohm Vape AIO Pod System Kit, it features 1.5ohm ceramic coil resistance. 5 PCS / Pack.
484
Original Innokin MVP5 120W 5200mAh TC VW Box Mod $69.99
The Innokin MVP5 Box Mod is constructed from Zinc Alloy and powered by large 5200mAh internal battery that output power range from 6 to 120W. The MVP5 Box mod can withstand rugged usage and can easily deal with light to moderate falls or drops. In addition, the MVP5 Box mod can be used with a myriad of tanks and coils to provide satisfying DL vaping or can be used in flavor-oriented MTL vaping. It is compatible with the AJAX Sub-Ohm Tank or Z-Coil Tank (Not included), it will make MVP5 can automatically detect and match the resistance and output to the Z-Coil Tank or Ajax, dependent on vaping style. Featuring multiple output modes, the Innokin MVP5 Box Mod can be used in a wattage mode, temperature control, and TCR mode, lending a programmable and optimized vaping specifications to create large dense flavorful clouds of vapor. ![]() Original iOOi I007 117W TC VW Box Mod $36.99 The iOOi I007 117W TC VW box mod is power by single 18650 / 20700 / 21700 battery (Not included), it can reach the output power from 5W to 117W. The iOOi I007 117W box mod features 0.96 inch IPS high definition color screen, seven kinds of protections and the charging time is about 3 hours. The overall body design is ergonomically designed, with a comfortable grip and stronger sense of conquest. ![]() Original Timesvape Keen Hybrid Mechanical Mech Mod original price$59.99, now only$54.85 The Timesvape Keen Mechnical Mod is constructed from Copper in 30mm diameter and powered by single 18650 / 20700 / 21700 Battery (Not included), featuring an floating contact pin with ball head for hard fitting. The tube itself is 30mm at its widest point, tapering to 25mm or 27mm at the top. The contact pin is gold plated with a flat smooth button spring. ![]() Original Innokin GoMax Tube 80W 3000mAh Vape Pen Mod with GoMax Disposable Tank Kit $23.99 The Innokin GoMAX Tube 80W Mod Kit consists of the GoMAX Tube Vape Pen Battery Mod and the GoMAX Disposable Sub-Ohm Tank which is constructed from Stainless Steel and powered by 3000mAh built-in battery, featuring LED battery life indicator light, and a large 5.5ml juice capacity refillable sub-ohm tank with integrated 0.19ohm Plex3D-Matrix mesh coil that power range from 60W to 80W to provide rapid and even heating within the atomizer to produce the thickest, densest, and most flavorful clouds. Surrounding the button is a tri-color LED battery life indicator light, relaying the remaining battery life via specific colored LED lights. ![]() Original Innokin Zlide Tube 16W 3000mAh Vape Pen Mod with Zlide MTL Tank Starter Kit $33.99 The Innokin Zlide Tube Vape Pen MTL Tank Kit consists of Innokin Zlide Tube Vape Pen Battery Mod and Zlide Tube MTL Tank, which is constructed from Stainless Steel and powered by 3000mAh built-in battery, compatibility with the Innokin Z-Coil, meeting the needs of beginner and advanced vapers alike. The Zlide Tube Kit can utilize coils from the Z-Coil series to create deliciously flavored clouds of vapor. The Zlide MTL Tank features 4ml juice capacity and supports sliding top refilling system. ![]() Origianl IJOY Neptune AIO 650mAh Pod System Starter Kit original price$32.99, now only$22.99 The IJOY Neptune AIO Pod Kit is powered by 650mAh built-in single battery with a max 14W output and it features 1.8ml E-juice capacity and comes with a 1.0ohm coil that will provide you last and great vaping experience. With the intelligent LED indicator, three levels of voltage regulation, millisecond firing speed and delicate round fire button, you can enjoy convenient and excellent vaping. ![]() Original SMOKTech SMOK RPM40 Pod Kit Replacement MTL Mesh Coil Head(5 PCS) $14.99 The SMOK RPM40 Replacement MTL Mesh Coil is designed for SMOK RPM40 Pod Kit, it features 0.3ohm and fits for mouth to lung vaping experience. It can provide massive vapor and excellent flavor and has more power effient and longer life span. The max wattage of this mesh coil is 20W. 5 PCS / Pack. ![]() Original IJOY Neptune Pod Kit Replacement Pod Cartridge with 1.0ohm Coil(3 PCS) $7.99 The IJOY Replacement Pod Cartridge is designed for IJOY Neptune Pod Kit, it features a 1.8ml juice capacity and comes with a 1.0ohm coil. 3 PCS / Pack. ![]() 810 Replacement Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / CSMNT Cosmonaut / Reload RDA $1.49 The 810 Replacement drip tip is made of acrylic and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
485
Original Timesvape Keen Hybrid Mechanical Mech Mod original price$75.00, now only$49.99
The Timesvape Keen Mechnical Mod is constructed from Stainless Steel in 30mm diameter and powered by single 18650 / 20700 / 21700 Battery (Not included), featuring an floating contact pin with ball head for hard fitting. The tube itself is 30mm at its widest point, tapering to 25mm or 27mm at the top. The contact pin is gold plated with a flat smooth button spring. ![]() Original Curdo Hally 60W TC VW Box Mod original price$39.99, now only$29.99 The Curdo Hally TC VW Box Mod is powered by single 18650 battery (Not included) with 60W max wattage and convenient Micro-USB port, which will provide you great vapeing experience. There is a TC mode design for you to fit different kinds of tank and you can enjoy various vaping feelings. What's more, it is equipped with a 0.96 inch screen, which will remind you of vaping state and data. ![]() Original Vapelustion Hannia 230W TC VW Box Mod $52.99 The Vapelustion Hannia TC VW Box Mod can reach a maximum output power of 230W with dual 18650 batteries (Not included). The high-definition OLED screen will simplify the operation of the mod. Advanced ergonomic construction offers the user comfortable hand feel, and the aesthetic graffiti design makes the mod more unique. ![]() C2MNT V2 RDA Clone with BF Pin $7.99 The C2MNT V2 RDA Clone is constructed from Stainless Steel meaturing in 24mm diameter. The RDA features postless build deck and top cap heat sink design. It supports signature blade Airflow Control (AFC) and compatible with the Layer Cake deck. The RDA comes with bottom feeder pin for Squonk Ready. ![]() Vapeasy C2MNT V2 RDA Clone with BF Pin $9.99 The Vapeasy C2MNT V2 RDA Clone is constructed from 316 Stainless Steel meaturing in 24mm diameter. The RDA features postless build deck and top cap heat sink design. It supports signature blade Airflow Control (AFC) and compatible with the Layer Cake deck. The RDA comes with bottom feeder pin for Squonk Ready. ![]() Original Curdo Hally 60W TC VW Box Mod with Sub Ohm Tank Kit original price$46.99, now only$39.99 The Curdo Hally TC VW Box Mod Kit consists of Curdo Hally TC VW Box Mod and Curdo Hally Sub Ohm Tank Atomizer, which is powered by single 18650 battery (Not included) with convenient Micro-USB port and comes with 3ml juice capacity tank. And it supports two kinds of coil: 0.4ohm coil and 0.6ohm coil, which will cater to your different vaping needs. What's more, it is equipped with a 0.96 inch screen, which will remind you of vaping state and data. And it adopts bottom airflow and resin drip tip for better flavor experience. ![]() Original AVCT AV-D091 Interchangeable 810-510 Drip Tip for RDA / SMOK TFV8 Tank $1.99 The AVCT AV-D091 Interchangeable 810-510 drip tip is designed and manufactured by AVCT, which is made of POM (Body) and Resin (Middle Part, random color), it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. It is also compatible with all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. The 510 adapter connector is included. ![]() Original AVCT AV-D092 Interchangeable 810-510 Drip Tip for RDA / SMOK TFV8 Tank $1.99 The AVCT AV-D092 Interchangeable 810-510 drip tip is designed and manufactured by AVCT, which is made of POM (Body) and Resin (Middle Part, random color), it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. It is also compatible with all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. The 510 adapter connector is included. ![]() Original AVCT AV-D099W 12 in 1 Interchangeable 810-510 Drip Tip Set for RDA /SMOK TFV8 Tank $4.99 The AVCT AV-D099W Interchangeable 810-510 drip tip set is designed and manufactured by AVCT, which is made of POM (Body) and Resin (Middle Part, random color), it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. It is also compatible with all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. The 510 adapter connector is included. This drip tip can assemble 6 PCS 810 drip tip and 6 PCS 510 drip tip.
486
Original AVCT AV-D099B 12 in 1 Interchangeable 810-510 Drip Tip Set for RDA /SMOK TFV8 Tank $4.99
The AVCT AV-D099B Interchangeable 810-510 drip tip set is designed and manufactured by AVCT, which is made of POM (Body) and Resin (Middle Part, random color), it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. It is also compatible with all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. The 510 adapter connector is included. This drip tip can assemble 6 PCS 810 drip tip and 6 PCS 510 drip tip. ![]() Original AVCT AV-D100W 6 in 1 Interchangeable 810-510 Drip Tip Set for RDA / SMOK TFV8 Tank $3.99 The AVCT AV-D100W Interchangeable 810-510 drip tip set is designed and manufactured by AVCT, which is made of POM (Body) and Resin (Middle Part, random color), it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. It is also compatible with all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. The 510 adapter connector is included. This drip tip can assemble 3 PCS 810 drip tip and 3 PCS 510 drip tip. ![]() Original AVCT AV-D100B 6 in 1 Interchangeable 810-510 Drip Tip Set for RDA / SMOK TFV8 Tank $3.99 The AVCT AV-D100B Interchangeable 810-510 drip tip set is designed and manufactured by AVCT, which is made of POM (Body) and Resin (Middle Part, random color), it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. It is also compatible with all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. The 510 adapter connector is included. This drip tip can assemble 3 PCS 810 drip tip and 3 PCS 510 drip tip. ![]() Original AVCT AV-D065 810 Replacement Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Reload RDA $2.59 The AVCT AV-D065 810 Replacement drip tip is made of Resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original AVCT AV-D066 810 Snake Skin Replacement Drip Tip for SMOK TFV8 / TFV12 Tank / Reload RDA $2.59 The AVCT AV-D066 810 Snake Skin Replacement drip tip is made of Resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original Uwell Caliburn Pod Kit Replacement Pod Cartridge with 1.2ohm Coil(4 PCS) $9.99 The Uwell Caliburn Replacement Pod Cartridge is designed for Uwell Caliburn Pod Kit, it features a 1.2ohm resistance coil and 2ml juice capacity, supporting top filling system. Detach the drip tip to refill, reduces leakage. The magnetic connection design is easy to insert into the battery. 4 PCS / Pack. ![]() Original Coil Master Handle Adjustable Shoulder Strap Storage Vape Bag for Batteries / Mods / Atomizers / E-Cigarette $29.99 The Coi Master Storage Vape Bag is designed for vape gear carrying, which fits for all your vape stuffs including batteries, mods, atomizers, parts, tools and E-Liquid and so on. All items will be stored and protected discreetly. It comes with a handle and an adjustable shoulder strap. It's great for travelling. ![]() Original HippoVape VSS RBA Rebuildable Coil Kit V1 for Artery PAL 2 / PAL 2 Pro / IJOY Mercury $6.99 The HippoVape VSS RBA Rebuildable Coil Kit V1 is constructed from stainless steel, it is compatible with Artery PAL 2 / PAL 2 pro / Pal stick / IJOY Mercury / R3 Pod / CKS Junior / Aspire spryte / Hellvape grimm kit / Vladdy slide pod kit.
487
The Vapelustion Hannia TC VW Box Mod can reach a maximum output power of 230W with dual 18650 batteries (Not included). The high-definition OLED screen will simplify the operation of the mod. Advanced ergonomic construction offers the user comfortable hand feel, and the aesthetic graffiti design makes the mod more unique. The mod comes with 3 different sets of replaceable panels. ![]() C2MNT V2 RDA Clone with BF Pin $7.99 The C2MNT V2 RDA Clone is constructed from Stainless Steel meaturing in 24mm diameter. The RDA features postless build deck and top cap heat sink design. It supports signature blade Airflow Control (AFC) and compatible with the Layer Cake deck. The RDA comes with bottom feeder pin for Squonk Ready. ![]() Original OILAX Cito C2 Pro 2-in-1 400mAh Box Mod Battery with Oil / Wax Cartridge Starter Kit $18.99 The OILAX Cito Box Kit is powered by 400mAh built-in battery and equipped with a ceramic wickless 0.5ml (1.0ml) chamber that can be filled with E-liquid and juice. The Cito Mod Kit comes with a 10 seconds Pre-heating function (1.8~2.2V), and there are three levels of variable voltage (2.8V, 3.3V, 3.7V) to meet your different vaping needs. The Mod Kit is also equipped with a magnetic connection that can easily be applied to any 510 cartridge for quick removal and replacement. This kit comes with an advanced waxy cartridge that producing pure and flavorful vapor. ![]() Original GTRS Triad Plus AIO 750mAh Pod System Starter Kit $24.99 The GTRS Triad AIO Pod System Vape Kit is a lightweight and compact pod system, featuring the YiHi SX261 chip. The Triad AIO Pod Kit is powered by a built-in 750mAh battery with a max output wattage of 20 watts. The Triad AIO utilizes a refillable 3ml empty pod cartridge system with removable 0.6ohm mesh coil (DTL) and 1.0ohm dual coil (MTL) atomizer heads for pure flavor and vapor production. The Triad AIO also includes a RBA rebuildable atomizer head for DIY lovers. The Triad AIO also features an airflow control valve right underneath the coil that may be adjusted down to your personal preferences. The Triad AIO also may be charged via the bottom Micro-USB charging port. ![]() Original GTRS Triad Plus AIO 750mAh Pod System Starter Kit(DIY RBA Edition) $27.99 The GTRS Triad AIO Pod System Vape Kit is a lightweight and compact pod system, featuring the YiHi SX261 chip. The Triad AIO Pod Kit is powered by a built-in 750mAh battery with a max output wattage of 20 watts. The Triad AIO utilizes a refillable 3ml empty pod cartridge system with removable 0.6ohm mesh coil (DTL) and 1.0ohm dual coil (MTL) atomizer heads for pure flavor and vapor production. The Triad AIO also includes a RBA rebuildable atomizer head for DIY lovers. The Triad AIO also features an airflow control valve right underneath the coil that may be adjusted down to your personal preferences. The Triad AIO also may be charged via the bottom Micro-USB charging port. ![]() Original GTRS Triad AIO Pod Kit Replacement DTL Coil Head(5 PCS) $8.99 The GTRS Replacement DTL Coil is designed for GTRS Triad AIO Pod Kit, it features 0.6ohm DTL Coil resistance that provides you DTL Vaping experience. 5 PCS / Pack. ![]() Original GTRS Triad AIO Pod Kit Replacement MTL Dual Coil Head(5 PCS) $8.59 The GTRS Replacement DTL Coil is designed for GTRS Triad AIO Pod Kit, it features 1.0ohm MTL Dual Coil resistance that provides you MTL Vaping experience. 5 PCS / Pack. ![]() Original GTRS Triad AIO Pod Kit Replacement RBA Coil Head $7.99 The GTRS Replacement RBA Coil is designed for GTRS Triad AIO Pod Kit, it features 0.6ohm RBA Coil resistance that fits for DIY lover. ![]() Original Ohm Vape AIO Pod Kit Replacement Front Panel + Back Panel + Drip Tip $7.99 The Ohm Vape Replacement Parts consists of Resin Front Panel + Resin Back Panel + Resin Drip Tip. They are compatible with Ohm Vape AIO Pod Kit. ![]() Original Nitecore UM2 USB Charger for 10440, 14500, 14650, 16500, 1634(RCR123), 18350, 18490, 18500, 18650 Battery $18.99 The Nitecore UM2 Charger is an intelligent USB Quick Charger for IMR batteries with 2-slots and a 3000mA max output current. It charges 2 Li-ion batteries independently and is up to 1000mA in a single slot. It will automatically detect your battery's charge level and provide appropriate voltage and charging time to ensure the safety and longevity of battery life. Together with a LCD display and unique cooling fin design, the Nitecore UM2 is a necessity in making sure your rechargeable batteries last. Batteries are not included. ![]() Original Uwell Yearn Pod Kit Replacement Empty Pod Cartridge(4 PCS) $9.99 The Uwell Replacement Empty Pod Cartridge is designed for Uwell Yearn Pod Kit, it features a 1.5ml juice capacity and is compatible with 1.4ohm coil (Not included) for better flavor and smoother throat hit. The Pod supports nicotine salt and freebase, which could provide you with different vaping experience.
488
KayFun Lite 2019 RTA Clone $8.99
The KF Lite 2019 RTA Clone is a 22mm rebuildable tank atomizer with 2ml of juice capacity. It is made from stainless steel and Acrylic. It is designed for mouth to lung vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience. This RTA comes with 2 spare extension tank tubes (Acrylic). ![]() SXK LE Turbo MTL RDA Clone with BF Pin original price$19.90, now only$14.99 The SXK LE Turbo RDA Clone is constructed from 316 Stainless Steel measuring in 22mm diameter. The RDA has a special design in the vertical positioning of the coil, it allows you freely regulate the space of your coil and the position of your cotton. And then, there are multiple airflow positions associated with the external ring to find precision with your preferred pull and sublimates all your E-juice, which allows you to pass from aired inhaling to a restrained depending on your tastes and compositon of E-juice. The RDA supports MTL vaping experience and is compatible with most of boxes and mods equipped with 22mm diameter atomizers. The RDA comes with a bottom feeder pin. ![]() Original Myvapors Roak 1000mAh Box Mod Pod Kit $26.99 The Myvapors Roak Box Mod Pod System Kit features a sliding key design and hiding construction which makes atomizer more sanitary. Roak Box Mod Pod Kit is powered by a 1000mAh built-in battery with a durable power of capacity. Transportable and sleek, Roak box pod kit is designed to travel light. Adopting the principle of ergonomic design, it is equipped with a hanging chain that can be carried around. Roak Mod Kit comes with a 1.0ml juice capacity pod cartridge and the max output power of this mod kit is 8W. Multiple protections provide you a safe vaping experience. ![]() Original KDEST Armor 14500 Box Mod Pod Kit $18.99 The KDEST Armor Pod Kit is a simple and portable device for on-the-go vape, which is powered by Single 14500 battery (included), the KDEST Armor support 3-level power adjustment to meet your different vaping needs. Better than the built-in battery compartment system kit, there is no need to throw away the cassette kit when the battery is dead. There are 2 types of coils: 0.6ohm Coil (pre-installed) and 1.2ohm Coil (Spare). The KDEST Armor Pod also has 2ml refillable capacity. With the easy filling design, the Armor will prevent the leakage problem for you. ![]() Original Smoant Battlestar Baby Pod Kit Replacement Pod Cartridge w/o Coils $6.99 The Smoant Replacement Pod is made of PCTG, which is designed for Battlestar Baby Pod Kit, featuring 2ml juice capacity. It is compatible with two types of coils: 0.6ohm mesh coil and 1.2ohm Ni80 coil to meet your different vaping needs (Coils are not included).It also adopts side filling design to avoid leakage. ![]() Original Myvapors Roak Box Mod Pod Kit Replacement Pod Cartridge with 1.0ohm Coil(3 PCS) $10.99 The Myvapors Replacement Pod Cartridge is designed for Myvapors Roak Box Pod Kit, it features 1.0ml juice capacity and comes with a 1.0ohm resistance coil. 3 PCS / Pack. <br><b>The e-juice is not included</b> ![]() Original Nitecore UA55 5-Port QC Multiple Protections USB Desktop Adapter - AU Plug $34.99 The Nitecore UA55 5-Port QC USB Desktop Adapter (AU Plug) comes with five powerful output solts which can produce up to 2A current of each port. The powerful design can offers a dominant and stable output for max 5 devices simultaneously which saves a lot of space for you. It widely fits any mainstream device ranging from Android / iOS smartphones and tablets to other USB devices. It is important that it is made of durable and fire retardant PC material and features multiple protection functions, which will bring you a fastest and safer charging experience. ![]() Original Nitecore UA55 5-Port QC Multiple Protections USB Desktop Adapter - EU Plug $34.99 The Nitecore UA55 5-Port QC USB Desktop Adapter (EU Plug) comes with five powerful output solts which can produce up to 2A current of each port. The powerful design can offers a dominant and stable output for max 5 devices simultaneously which saves a lot of space for you. It widely fits any mainstream device ranging from Android / iOS smartphones and tablets to other USB devices. It is important that it is made of durable and fire retardant PC material and features multiple protection functions, which will bring you a fastest and safer charging experience. ![]() Original Nitecore UA55 5-Port QC Multiple Protections USB Desktop Adapter - US Plug $34.99 The Nitecore UA55 5-Port QC USB Desktop Adapter (US Plug) comes with five powerful output solts which can produce up to 2A current of each port. The powerful design can offers a dominant and stable output for max 5 devices simultaneously which saves a lot of space for you. It widely fits any mainstream device ranging from Android / iOS smartphones and tablets to other USB devices. It is important that it is made of durable and fire retardant PC material and features multiple protection functions, which will bring you a fastest and safer charging experience.
489
YFTK Hellfire Saber MTL / DL RDA Clone with BF Pin $19.99
The YFTK Hellfire Saber RDA Clone is constructed from 316 Stainless Steel measuring in 22mm diameter. The RDA is suitable for MTL vaping and slightly restricted DL vaping experience. Furthermore, it supports middle airflow control adjustable to meet your different vaping needs. ![]() Original Auguse MTL RTA with 2 Spare Tank Kit $31.99 The Auguse MTL RTA is constructed from stainless steel measuring in 22mm diameter, it features a 4ml juice capacity coming with three tank: a (SS + Acrylic) replacement tank, PEI tank (Pre-installed), and acrylic replacement tank. The RTA features a single coil build deck and supports bottom airflow control and side coil locking. ![]() Original Dovpo Blotto RTA original price$39.99, now only$32.99 The Dovpo Blotto RTA is constructed from stainless steel, which has 2ml E-liquid capacity and it includes two spare 6ml bubble tanks (Glass / Ultem). It is unique for the top refill design which is easy to fill on top. This rebuildable tank atomizer is compatible with dual or single coil. The 242 degrees of airflow direct to the coils will bring smooth flavor. By offering three types of glass tubes, this RTA is comfortable for users to operate. The adjustable airflow system creates milder and smoother flavor plus richer clouds, which brings users comfortable and safe vaping experience. ![]() Original Curdo M-One 400mAh Box Mod with M-One Atomizer Starter Kit $13.99 The Curdo M-One Vaporizer Kit is a small and exquisite kit which comes with 400mAh built-in battery. The appearance perfectly integrates streamline and sense of technology. With the magnetic absorption and close-fit design, which simple to operate. It provides four levels voltage (3.2V / 3.5V / 3.8V / 4V) to meet your different vaping needs. It adopts Zinc Alloy and advanced plastic materials which can balance product's weight. It is very small then you can carry it everywhere you want. There are also provides multiple protections for your safe vaping. ![]() Original OneVape Mace55 1500mAh Pod System Starter Kit $26.99 The OneVape Mace55 Mace 55 Pod Kit is a brand-new innovative pod system kit with simple yet exquisite design, which is powered by 1500mAh built-in battery with 3 levels adjustable voltage. It fires up to 55W and can be fully charged within 1.5 hours by USB Type-C port. It comes with two different mesh coils for regular or nicotine e-juice and a 3.5ml refillable Mace Pod. ![]() Original OneVape Mace70 2500mAh Pod System Starter Kit $30.99 The OneVape Mace70 Mace 70 Pod Kit is a brand-new innovative pod system kit with simple yet exquisite design, which is powered by 2500mAh built-in battery with 5 levels adjustable voltage. It fires up to 70W and can be fully charged within 2.5 hours by USB Type-C port. It comes with two different mesh coils for regular or nicotine e-juice and a 3.5ml refillable Mace Pod. ![]() [Ships from Battery Warehouse]Original Efest IMR 21700 3700mAh 35A Rechargeable Lithium Batteries(2 PCS) $21.99 The Efest IMR 21700 battery is a 3700mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 35A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 21700 batteies. ![]() Original OneVape Mace Pod Kit Replacement Empty Pod Cartridge $4.29 The OneVape Replacement Empty Pod Cartridge is designed for OneVape Mace Pod Kit, it features 3.5ml juice capacity. Coil is not included ![]() Original OILAX Cano 420mAh Vaporizer Box Mod Battery $10.99 The OILAX Cano is a convenient and easy-to-carry device for E-Liquids, which is powered by 420mAh built-in battery. Compatible with pre-filled and refillable cartridges, it is equipped with a magnetic adapter. The Cano has a variable voltage battery, offering you 3 optimized voltage settings and it is made perfect with its 15 seconds pre-heat function to ensure you have an ideal vaping experience. ![]() Original OILAX Cito C2 2-in-1 400mAh Vaporizer Box Mod Battery $12.99 The Oilax Cito C2 Box Mod is powered by 400mAh built-in battery that can be charged through the Micro-USB port. The Oilax Cito C2 Box Mod is designed with a single button operation: 2 clicks turn on the preheat mode for 15 seconds, 3 clicks switch the voltage between 3.4V / 3.6V / 3.8V / 4.0V. The LED lights at the front display the current voltage setting.
490
Original Kangvape 420-2IN1 650mAh APV VV Box Mod $7.18
The Kangvape 420 2in1 APV VV Box Mod is powered by 650mAh built-in battery and feayures from 1ohm to 3ohm resistance range, providing you various vaping experience. The Box Mod has Voltage adjustable function, you can press the button to adjustable the output voltage: 3.2V / 3.5V / 3.8V. The Box Mod comes with a window for you to see the cartridge's status. The LED indicator can also show you the voltage mode. What's more, the air can switch directly and the pod that fit for can use for Thick oil / E-liquid / Nic salt. The multiple protections of this box mod will provide you a safe vaping experience. ![]() Gata MTL / DLH RTA Clone with Spare 2ml Tank $14.99 The Gata RTA Clone is constructed from stainless steel (body) and glass (tank) in 24mm diameter. The Gata RTA Clone comes with postless build deck for single coil and supports bottom airflow control to meet MTL and DLH lover different vaping needs. ![]() Original SMOKTech SMOK Nord 1100mAh Pod System Starter Kit $25.68 The SMOKTech SMOK Nord, is a button-triggered pod system device. It is powered by a built-in 1100mAh battery, which making it a definitely powerful one among pod system devices. It is equipped with two exclusive coils (Nord Mesh 0.6ohm coil and Nord regular 1.4ohm coil), one is perfect to get massive vapor while the other can offer excellent MTL experience. Its size is very comfortable to hold in hand, and it has a newly added button to start vaping and provide information about battery life, besides, there's an e-liquid window on the pod, all of which are for your convenience. ![]() SXK Monarch R RDTA Clone Replacement 1 Hole Airflow Insert + 3 Holes Airflow Insert(2 PCS) $5.90 The SXK Monarch R RDTA Clone replacement parts consist of one airflow insert is with 1 Hole and another one is with 3 Holes. 2 PCS / Pack. ![]() SXK Monarch R RDTA Clone Replacement Drip Tip + Tube + Top Cap $7.90 The SXK Monarch R RDTA Clone replacement parts consist of one Drip Tip, one Top Cap, and one Tube. They are made of PC material. ![]() YFTK Replacement Diamond Top Cap Tank Tube + Chimney for Dvarw 22 MTL RTA $6.99 The YFTK Replacement Diamond Top Cap is made of PC material and it is compatible with Dvarw 22 MTL RTA Atomizer as a replacement part. The Top Cap comes with a 316 Stainless Steel Chimney. ![]() Original Istar Volcanee DIY Tool Kit - Plier + Ceramic Tweezer + Brush + Scissors + Pointed Tweezer + Coil Jig + Screwdriver $10.99 The Istar Volcanee DIY Tool Kit is a useful tool set for RDA / RTA DIY coil building. It contains multifunction screwdriver, ceramic tweezer, pointed tweezer, coil jig, plier, folding scissors and coil brush. Coil Jig1.5 / 2.0 / 2.5 / 3.0 / 3.5.
491
Original Hippovape Papua 100W VW Box Mod $29.95
The Hippovape Papua 100W Box Mod is powered by Single 18650 / 20700 / 21700 battery (Not included). It is a VW box mod constructed from Zinc Alloy. Equipped with the advanced waterproof chipset, it powers from 3W to 100W. It has 6 protections: low wattage protection, reverse polarity protection, overheating protection, short circuit protection, 10s cut off protection and low / high ohm protection. Its output voltage ranges from 1.0V to 8V and its resistance ranges from 0.1ohm to 3.0ohm. ![]() Original Hippopvape VIVA 245W VW Box Mod $35.99 The Hippovape VIVA Box Mod is a VW mod constructed from Zinc Alloy. Equipped with the advanced waterproof chipset, it powers from 10W to 245W and produces an outstanding power output accuracy by dual 18650 battery(Not included), which fires extremely fast. It has 6 protections: low wattage protection, reverse polarity protection, overheating protection, short circuit protection, 10s cut off protection and low / high ohm protection. Its output voltage ranges from 1.0V to 8.0V and its resistance ranges from 0.1ohm to 3.0ohm. ![]() Scar Mini Hybrid Mechanical Mod Clone $14.99 The Scar Mini Mechanical Mod Clone is constructed from Stainless Steel in 28mm diameter (largest) / 22mm diameter (top), which is powered by single 18350 battery (Not included). The magnet is height adjustable and allows the adjustment of the activation button movement. It is compatible with 510 threading connection. ![]() Coppervape BF-99 CUBE MTL RDTA Clone $19.99 The Coppervape BF-99 CUBE MTL RDTA Clone is constructed from 316 Stainless Steel (body) and PEI (tank) in 22mm diameter. The RDTA comes with a 2.5ml juice capacity PEI tank. The RDTA supports side airflow adjustable control and bottom refilling. The hole airflow provides a big vapor and great flavor. Two Air Plugs: "gold" 1 hole x 1.00mm, 0.79mm² (Pre-installed); "red" 2 holes x 1.00mm, 1.58mm². Drip tip: modular tip with 4mm or 6mm hole. The RDTA also supports Mouth to lung (MTL) vaping experience. ![]() Original Vandy Vape Mesh V2 RDA original price$34.99, now only$25.99 The Vandy Vape Mesh V2 RDA is constructed from stainless steel in 25mm diameter. The RDA comes with e-juice capacity. It adopts top airflow design for anti-leaking, which will bring you convenience. And with deeper indentation and wider M Wire, it will provide you with great flavor. Besides, it is compatible with 4 types of M Wire: 0.15ohm Dual M Coil, 0.15ohm Ni80 M Coil, 0.15ohm A1 M Coil and 0.12ohm SS316L M Coil, which will meet your different vaping needs.The Color of Drip Tip is random. This RDA comes with bottom feeder / BF / Squonk Pin ![]() Original Hippovape Papua 100W VW Box Mod + RDA Kit $37.99 The Hippovape Papua kit is constructed from Zinc Alloy and the Papua mod is equipped with the advanced waterproof chipset, its output power range is from 3W to 100W and produces an outstanding power output accuracy by 1 x 18650 / 20700 / 21700 battery (Not included) which fires extremely fast.The Resistance Range is from 0.1ohm to 3.0ohm and the atomizer size is 24mm. Included in the kit is the Papua RDA atomizer which is optimized by the ultimate airflow that providing large vapor production. With a POM single coil adapter attached, it can be single coil RDA which bring you better flavor. ![]() Original Goforvape Satisfy 50W 1300mAh VW Box Mod Pod System Starter Kit original price$45.00, now only$32.99 The Goforvape Satisfy VW box mod pod system starter kit is powered by a built-in 1300mAh battery that can be fully charged with the use of a USB Type-C port and 1A charging. The pod system kit is equipped with an OLED display screen for showing the detailed vaping data clearly. The Satisfy replacement pod features a top refilling 4ml E-liquid capacity with a removable drip tip and adjustable airflow located at the top of the pod. The multiple protections provide you a safer vaping experience. Goforvape Satisfy pod system kit is definitely a wonderful pod vape device to satisfy all your vaping needs and bring you an outstanding vaping experience, no matter for DTL and MTL vaping. ![]() Replacement Diamond Top Cap Tank Tube + Chimney for Flash e-Vapor V4 / V4.5 RTA Clone - Short Version $7.99 The replacement PEI Diamond Top Cap Tank Tube and Stainless Steel Chimney is suitable for Flash e-Vapor V4 / V4.5 RTA Clone. It comes with 3.5ml juice capacity. ![]() Replacement Diamond Top Cap Tank Tube + Chimney for Flash e-Vapor V4 / V4.5 RTA Clone $7.99 The replacement PEI Diamond Top Cap Tank Tube and Stainless Steel Chimney is suitable for Flash e-Vapor V4 / V4.5 RTA Clone. It comes with 5ml juice capacity. ![]() High End KS Kaser V2 SS Base + 3 Mouthpiece 510 Drip Tip + 6 Airflow Insert Set - Type A $5.99 High End KS V2 Replacement Set A consists of one Stainless Steel Base, three mouthpiece 510 drip tips (White: POM; Black: POM; Brown: PEI) and six airflow inserts (hole diameter: 1.5mm / 2.0mm / 2.5mm / 3.0mm / 3.5mm / 4.0mm). They are used as replacement parts. ![]() High End KS Kaser V2 SS Base + 3 Mouthpiece 510 Drip Tip + 6 Airflow Insert Set - Type B $5.99 High End KS V2 Replacement Set B consists of one Stainless Steel Base, three mouthpiece 510 drip tips (White: POM; Black: POM; Brown: PEI) and six airflow inserts (hole diameter: 1.5mm / 2.0mm / 2.5mm / 3.0mm / 3.5mm / 4.0mm). They are used as replacement parts. ![]() High End KS Kaser V2 SS Base + 3 Mouthpiece 510 Drip Tip + 6 Airflow Insert Set - Type C $5.99 High End KS V2 Replacement Set C consists of one Stainless Steel Base, three mouthpiece 510 drip tips (White: POM; Black: POM; Brown: PEI) and six airflow inserts (hole diameter: 1.5mm / 2.0mm / 2.5mm / 3.0mm / 3.5mm / 4.0mm). They are used as replacement parts. ![]() High End KS Kaser V2 SS Base + 3 Mouthpiece 510 Drip Tip + 6 Airflow Insert Set - Type D $5.99 High End KS V2 Replacement Set D consists of one Stainless Steel Base, three mouthpiece 510 drip tips (White: POM; Black: POM; Brown: PEI) and six airflow inserts (hole diameter: 1.5mm / 2.0mm / 2.5mm / 3.0mm / 3.5mm / 4.0mm). They are used as replacement parts.
492
High End KS Kaser V2 SS Base + 3 Mouthpiece 510 Drip Tip + 6 Airflow Insert Set - Type E $5.99
High End KS V2 Replacement Set E consists of one Stainless Steel Base, three mouthpiece 510 drip tips (White: POM; Black: POM; Brown: PEI) and six airflow inserts (hole diameter: 1.5mm / 2.0mm / 2.5mm / 3.0mm / 3.5mm / 4.0mm). They are used as replacement parts. ![]() Original Goforvape Satisfy Pod Kit Replacement GFV-EX1 Clapugatted Coil Head(5 PCS) original price$19.90, now only$12.99 The Goforvape Satisfy GFV-EX1 Clapugatted Coil is suitable for Goforvape Satisfy Pod Kit. The wattage range is from 30W to 60W and the resistance of this Coil is 0.35ohm. 5 PCS / Pack. ![]() Original Goforvape Satisfy Pod Kit Replacement GFV-EX2 Mesh Coil Head(5 PCS) original price$16.00, now only$7.99 The Goforvape Satisfy GFV-EX2 GFV EX2 Mesh Coil is suitable for Goforvape Satisfy Pod Kit. The wattage range is from 25W to 35W and the resistance of this Coil is 0.4ohm. 5 PCS / Pack. ![]() Original Goforvape Satisfy Pod Kit Replacement GFV-EX3 Mesh Coil Head(5 PCS) original price$16.00, now only$7.99 The Goforvape Satisfy GFV-EX3 GFV EX3 Mesh Coil is suitable for Goforvape Satisfy Pod Kit. The wattage range is from 16W to 25W and the resistance of this Coil is 0.6ohm. 5 PCS / Pack. ![]() Original Goforvape Satisfy Pod Kit Replacement GFV-EX4 Mesh Coil Head(5 PCS) original price$16.00, now only$7.99 The Goforvape Satisfy GFV-EX4 GFV EX4 Mesh Coil is suitable for Goforvape Satisfy Pod Kit. The wattage range is from 8W to 16W and the resistance of this Coil is 1.0ohm. 5 PCS / Pack. ![]() Original Goforvape Satisfy Pod Kit Replacement RBA Rebuildable Single Coil Head original price$12.00, now only$5.99 The Goforvape Satisfy RBA Rebuildable Single Coil is suitable for Goforvape Satisfy Pod Kit The RBA coil fits for DIY lover. ![]() Original Vandy Vape Mesh V2 RDA Replacement A1 M Coil Mesh Sheet(10 PCS) $3.99 The Vandy Vape A1 M Coil is suitable for Vandy Vape Mesh V2 RDA. The wattage range is from 50W to 65W and the resistance of this Coil is 0.15ohm. 10 PCS / Pack. ![]() Original Vandy Vape Mesh V2 RDA Replacement A1 Dual M Coil Mesh Sheet(10 PCS) $3.99 The Vandy Vape A1 Dual M Coil is suitable for Vandy Vape Mesh V2 RDA. The wattage range is from 45W to 70W and the resistance of this Coil is 0.15ohm. 10 PCS / Pack. ![]() Original Vandy Vape Mesh V2 RDA Replacement Ni80 M Coil Mesh Sheet(10 PCS) $3.99 The Vandy Vape Ni80 M Coil is suitable for Vandy Vape Mesh V2 RDA. The wattage range is from 55W to 70W and the resistance of this Coil is 0.15ohm. 10 PCS / Pack. ![]() Original Vandy Vape Mesh V2 RDA Replacement SS316L M Coil Mesh Sheet(10 PCS) $3.99 The Vandy Vape SS316L M Coil is suitable for Vandy Vape Mesh V2 RDA. The wattage range is from 50W to 70W and the resistance of this Coil is 0.12ohm. 10 PCS / Pack. ![]() ---------------------------- Coupon for Halloween Oct 28th 2019 00:00 - Nov 3rd 2019 23:59 (UTC-6 / Denver Time) Offer: site-wide 5% off Code: Halloween2019 Note: This offer is not stackable with other MAP discounts. |
493
Original CoolVapor Takit Mini V2 Semi-Mechanical Mod original price$39.90, now only$34.55
The CoolVapor Takit Mini V2 Semi-Mechanical Mod is constructed from stainless steel and powered by single 18350 / 18650 battery (Not included).The height of this mechanical mod is 78mm and is with a short-circuit protection chip board. ![]() Original Timesvape Saint Hybrid Mechanical Mech Mod $29.99 The Timesvape Saint Hybrid Mechanical Mod is constructed from brass with a diameter of 24mm and 94mm height. The mech mod is powered by single 18650 / 20700 / 21700 batteries. (Not included) ![]() YFTK Bastard MTL / DTL RTA Clone $19.99 The YFTK Bastard RTA Clone is constructed from 316 Stainless Steel in 22mm diameter. It features a single coil build deck. The RTA comes with a 3.5ml juice capacity tank tube and supports bottom modular airflow control and top filling system. The RTA can provide you MTL or DTL vaping experience. The RTA also can be converted to a RDA by conversion kit. (Not included) ![]() ShenRay Value Greek MTL RTA Clone $30.99 The ShenRay Value Greek MTL RTA Clone is constructed from 316 stainless steel (Body) and glass (Tank) in 22mm diameter. The RTA supports top refilling system and adjustable bottom airflow and it comes with a 4ml juice capacity tank. It can provide you mouth-to-lung (MTL) vaping experience. ![]() YFTK Bastard RTA Clone to RDA Replacement Conversion Kit with BF Pin $9.99 The YFTK Replacement Conversion Kit is constructed from 316 Stainless Steel in 22mm diameter. It can be used to convert your Bastard RTA Clone to RDA. ![]() Original Goforvape Ni80 Handmade Alien Heating Resistance Wire Pre-built Coil for RDA / RTA(2 PCS) $2.59 The Goforvape GFV-C2001 Ni80 Handmade Alien Heating Resistance Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features 28GA x 3 + 36GA gauge and 0.3ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Handmade Framed Staple Alien Wire Pre-built Coil for RTA(2 PCS) $3.99 The Goforvape GFV-C2002 Ni80 Handmade Framed Staple Alien Heating Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features (0.1 x 0.3) x 8 + 36GA gauge and 0.26ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Handmade Framed Staple Alien Heating Wire Pre-built Coil for RTA(2 PCS) $3.99 The Goforvape GFV-C2003 Ni80 Handmade Framed Staple Alien Heating Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features 28GA + Flat (0.1 x 0.3) x 4 + 28GA + 36GA gauge and 0.28ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Staggered Framed Staple Wire Pre-built Coil(2 PCS) $7.99 The Goforvape GFV-C2004 Ni80 Handmade Staggered Framed Staple Heating Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features 28GA x 2 + (0.1 x 0.4) x 6 + 38GA gauge and 0.25ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Triple Staggered Claptons Wire Pre-built Coil for RDA / RTA(2 PCS) $7.99 The Goforvape GFV-C2005 Ni80 Handmade Triple Staggered Claptons Heating Resistance Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features (26GA + 38GA) x 3 + 38GA gauge and 0.29ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Staple Aliens Wire Pre-built Coil for RTA(2 PCS) $7.99 The Goforvape GFV-C2006 Ni80 Handmade Staple Aliens Heating Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features 26GA x 2 + Flat (0.1 + 0.5) x 6 + 38GA gauge and 0.18ohm resistance value per feet, which will be a good choice for DIY.
494
Original Goforvape Ni80 Handmade Aliens Heating Wire Pre-built Coil for RDA / RTA(2 PCS) $6.59
The Goforvape GFV-C2007 Ni80 Handmade Aliens Heating Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features 28GA x 3 + 38GA gauge and 0.35ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Handmade Aliens Heating Wire Pre-built Coil for RDA / RTA(2 PCS) $6.59 The Goforvape GFV-C2008 Ni80 Handmade Aliens Heating Resistance Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features (27GA x 3) + 38GA gauge and 0.25ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Raging Fire Heating Wire Pre-built Coil for RDA / RTA(10 PCS) $6.29 The Goforvape GFV-C2009 Ni80 Raging Fire Heating Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features 28GA + 40GA x 48 gauge and 0.18ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 3 Core Fused Clapton Heating Wire Pre-built Coil for RDA / RTA(10 PCS) $2.59 The Goforvape GFV-C2010 Ni80 3 Core Fused Clapton Heating Resistance Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features 28GA x 3 + 38GA gauge and 0.25ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 4 Core Fused Clapton Heating Wire Pre-built Coil for RDA / RTA(10 PCS) $2.59 The Goforvape GFV-C2011 Ni80 4 Core Fused Clapton Heating Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features 28GA x 4 + 38GA gauge and 0.2ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Gatlin Heating Wire Pre-built Coil for RTA(10 PCS) $3.59 The Goforvape GFV-C2012 Ni80 Gatlin Heating Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features (0.1 + 0.4 + 0.5 x 2) + Flat (0.1 x 0.4) gauge and 0.15ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Staple Staggered Fused Clapton Wire for RTA(10 PCS) $6.59 The Goforvape GFV-C2013 Ni80 Staple Staggered Fused Clapton Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features Flat (0.1 x 0.3) x 2 + 28GA x 3 + 38GA + 28GA x 2 + 38GA gauge and 0.2ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Framed Staple Staggered Fused Clapton Wire Pre-built Coil(10 PCS) $3.99 The Goforvape GFV-C2014 Ni80 Framed Staple Staggered Fused Clapton Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features Flat (0.1 x 0.3) x 2 + 28GA x 3 + 38GA + 28GA x 2 + 38GA gauge and 0.27ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Ni80 Braided Fused Staple Clapton Wire Pre-built Coil for RDA / RTA(10 PCS) $3.99 The Goforvape GFV-C2015 Ni80 Braided Fused Staple Clapton Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Ni80 material. It features Flat (0.1 x 0.3) x 8 + 36GA + 38GA x 16 gauge and 0.26ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Goforvape Kanthal A1 Ant Clapception Heating Wire Pre-built Coil for RDA / RTA(10 PCS) $3.59 The Goforvape GFV-C2016 Kanthal A1 Ant Clapception Heating Wire is perfect for RDA / RTA / RDTA / RSA atomizers. The wire is made from Kanthal A1 material. It features Flat (0.1 x 0.3) x 8 + 36GA + 38GA x 16 gauge and 0.4ohm resistance value per feet, which will be a good choice for DIY. ![]() ---------------------------- Coupon for Halloween Oct 28th 2019 00:00 - Nov 3rd 2019 23:59 (UTC-6 / Denver Time) Offer: site-wide 5% off Code: Halloween2019 Note: This offer is not stackable with other MAP discounts. |
495
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Timesvape Dreamer Mechanical Mech Mod $27.99
The Dreamer Mechanical Mech Mod was designed in the USA by Stan at TenaciousTXVapes, manufactured by Timesvape. The Timesvape Dreamer Mech Mod is constructed from Aluminum material, it is a hard-hitting single tube mech which is powered by a single 18650, 20700 or 21700 battery(Not included), and has a unique multi-point contact pin for increased conductivity. The tube itself is 27mm at its widest point, tapering to 25mm at the top. The tube is reversible, so you can customize the grip to suit your preferences. The copper contact pin is also silver-plated for a perfect connection every time. ![]() Kindbright Katana 3D Print Semi-Mechanical Box Mod Stealth Clone $50.99 The Kindbright Katana Box Mod Stealth Clone is constructed from Nylon and Stainless Steel material, which is powered by single 18650 battery (Not included).You only switch on this box mod by press 5 times the button. The Box Mod Stealth fits for all lovers of MTL vaping and it is compatible with atomizers with a maximum diameter of 24mm. ![]() C2MNT V2 RDA Clone with BF Pin $6.99 The C2MNT V2 RDA Clone is constructed from stainless steel in 24mm diameter. The RDA comes with a postless deck and top cap heat sink design, which supports signature blade Airflow Control (AFC). It is compatible with the layer cake deck. This RDA comes with bottom feeder / BF / Squonk Pin. ![]() LE TBO MTL RDA Clone with BF Pin $12.59 The LE TBO RDA Clone is constructed from 316 Stainless Steel measuring in 22mm diameter. The RDA has a special design in the vertical positioning of the coil, it allows you freely regulate the space of your coil and the position of your cotton. And then, there are multiple airflow positions associated with the external ring to find precision with your preferred pull and sublimates all your E-juice, which allows you to pass from aired inhaling to a restrained depending on your tastes and compositon of E-juice. The RDA supports MTL vaping experience and is compatible with most of boxes and mods equipped with 22mm diameter atomizers. This RDA comes with bottom feeder / BF / Squonk Pin. ![]() Original Timesvape 1000mAh Wave Mini Salty Kit + Tank Atomizer with 1.2ohm Ceramic Coil $21.99 The Timesvape Wave Mini Salty Kit is a vape pen kit with a portable and ergonomic shape. The Wave mini battery is powered by a 1000mAh built-in battery with Micro-USB charging and can reach a voltage range from 3.4V to 4.4V that is conducive to produce optimal vaping with sufficient power and pure taste. The Wave Mini Tank comes with a 1.8ml straight tube (with a extra 2ml bubble tube) and a 1.2ohm ceramic coil (Best: 8~12W) for optimum taste. What's more, the Wave Mini tank comes with top filling design that prevent effectively from oil leakage. And it is compatible with the ceramic coil for stable and long-lasting foaming. The Timesvape Wave Mini Kit is also easy to install and replace the coil. The Timesvape Wave Mini Kit has also multiple protections for your safe vaping experience. ![]() Original Smoant Pasito 25W 1100mAh Mod Pod System Starter Kit $25.99 The Smoant Pasito Kit is made of CPR and aluminum alloy material, resulting in a more colorful and durable stunning finish. Powered by a built-in 1100mAh battery and assisted by the new ANT chip, it allows for 5 output levels within 10-25W and lasts a long vaping time. The battery is charged via the Type C USB port on the bottom of the device. And there are intelligent LED lights that will show the battery level clearly. As for the pod, it can store up to 3ml of e-juice and features an adjustable top airflow and refill system, which prevents leaking problems and guarantees the easy operation of the device. A 1.4ohm MTL Ni-80 Coil and a 0.6ohm DTL Mesh Coil are included with purchase, but you may also purchase a rebuildable coil separately. Anyway, the Pasito is worth a shot. ![]() Original DEJAVU Neon 80W TC VW Box Mod with Neon Atomizer Tank Kit $69.99 The DEJAVU Neon TC VW Box Mod Kit is designed in an original square shape with rounded edges, It is powered by a single 18650 battery (Not included) and the innovative RoninX RX-80 chipset, which can achieve a high output range from 5W to 80W. A variety of operating modes (such as power mode, TC Modes, voltage mode, curve mode) can meet your different e-cigarette needs. By the function of 5V / 2A input current, the Neon can easily be charged fast. The outer casing is made of polished ABS plastic, the DEJAVU Neon combines sturdy construction and lightweight texture in a compact unit. The control panel is also clean and neat. Not a small trigger button, the lower 0.96 inch IPS color display makes it easy to know the state of the battery, and even the lower three-button design brings great convenience to the operation. The accompanying DEJAVU Neon Tank is a 2-in-1 atomizer. It supports conventional 0.3ohm mesh coils and RBA coils. The electronic juice is filled from the top and there is a swirling airflow adjustment at the bottom. ![]() Original Dazzvape BOTO Concentrate Vaporizer Replacement Microporous Quartz Coil(2 PCS) $5.49 The BOTO Replacement Coil is designed for Dazzvape BOTO Concentrate Vaporizer Kit. It comes with 1.2ohm microporous quartz coil, which can prevents dry hits and has advanced thermal conductivity. With the extended coil design, it is much easier to dip concentrates and unique flat design enlarges concentrates contact area. What's more, the detachable design makes it easy to replace or clean. 2 PCS / Pack. ![]() Original Veeape Replacement Coil Head for V19 Tank Atomizer / Keybox Mod(3 PCS) $9.99 The Veeape Replacement Coil is designed for Veeape V19 Atomizer, it features a 1.5ohm coil resistance. 3 PCS / Pack. ![]() Original Veeape Vplus Pod Kit Replacement Pod Cartridge with 1.3ohm Ceramic Coil(3 PCS) $8.99 The Veeape Replacement Pod Cartridge Atomizer is designed for Veeape Vplus Pod Kit, it features a 1.2ml juice capacity and 1.3ohm ceramic coil. The Veeape Vplus Atomizer injects liquid through the top and pumps the 1.2ml tank 250 to 300 times per injection of liquid. 3 PCS / Pack. ![]() Original Veeape V19 Atomizer Replacement Pod Cartridge with 1.5ohm Coil for Ploomtech First Generation Mod / Keybox Mod $6.99 The Veeape V19 Atomizer Pod Cartridge is designed for the Ploomtech first generation mod and Veeape Keybox Mod. It comes with a 1.0ml E-liquid capacity and features the leak-proof function. The V19 Atomizer adopts 1.5ohm coil to provide for you with excellent vaping experience. What's more, the V19 Atomizer is suitable for regular juice to meet your different vaping needs. ![]() ---------------------------- Coupon for Halloween Oct 28th 2019 00:00 - Nov 3rd 2019 23:59 (UTC-6 / Denver Time) Offer: site-wide 5% off Code: Halloween2019 Note: This offer is not stackable with other MAP discounts. |
496
The Dreamer Mechanical Mech Mod was designed in the USA by Stan at TenaciousTXVapes, manufactured by Timesvape. The Timesvape Dreamer Mech Mod is constructed from Aluminum material, it is a hard-hitting single tube mech which is powered by a single 18650, 20700 or 21700 battery (Not included), and has a unique multi-point contact pin for increased conductivity. The tube itself is 27mm at its widest point, tapering to 25mm at the top. The tube is reversible, so you can customize the grip to suit your preferences. The copper contact pin is also silver-plated for a perfect connection every time. ![]() Original Eleaf iStick Amnis 2 23W 1100mAh Battery Box Mod $17.09 The iStick Amnis 2 Battery Mod is specially designed for iStick Amnis 2 Kit. It comes with 1100mAh built-in battery with 23W max output, which could provide you with a long time vaping experience. And there are 5 different working modes for your option: Bypass / Low power / Medium Power / High Power / Maximum Power. What' more, the box mod is equipped with easy to carry lanyard, it utilizes Type-C USB port for easy and safe operation. ![]() SXK Bastard MTL / DTL RTA Clone original price$19.90, now only$14.99 The SXK Bastd RTA Clone is constructed from 316 Stainless Steel in 22mm diameter. It features a single coil build deck. The RTA comes with a 3.5ml juice capacity tank tube and supports bottom modular airflow control and top filling system. The RTA can provide you MTL or DTL vaping experience. The RTA also can be converted to a RDA by conversion kit. (Not included) ![]() Original Vaporesso SWAG II 80W VW Box Mod with NRG PE Tank Atomizer Kit $47.99 The Vaporesso SWAG II Kit consists of 80W SWAG II Battery Box Mod and NRG PE MINI Tank atomizer. The SWAG II Mod Kit is powered by single 18650 battery. (Not included) By adopting a special formulated rubber coating, it is now even lighter and more durable, with a hand feel that will give you next level comfort. Equipped with AXON Chip, the SWAG II Kit brings you the incredible Pulse mode, giving you 5x more power in every inhalation. The upgraded GT4 Meshed coil brings dual meshed cores to increase contact area giving denser more flavorful clouds. ![]() Original Eleaf iStick Amnis 2 1100mAh Box Mod Battery with GTiO Tank Kit $35.13 The iStick Amnis 2 Kit consists of iStick Amnis 2 Box Mod Battery and Amnis 2 GTiO Tank Atomizer, which is powered by 1100mAh built-in battery with 23W max output and features 1.8ml / 3ml e-juice capacity. And it supports 0.6ohm GT M coil and 1.2ohm GT Coil for nicotine salt, which will bring you a better vaping experience. What's more, the Kit is equipped with easy to carry lanyard, it utilizes Type-C USB port for easy and safe operation. ![]() Original Eleaf iStick Amnis 2 1100mAh Box Mod Battery with GTiO Tank Kit(Basic Version) $33.97 The iStick Amnis 2 Kit consists of iStick Amnis 2 Box Mod Battery and Amnis 2 GTiO Tank Atomizer, which is powered by 1100mAh built-in battery with 23W max output and features 1.8ml / 3ml e-juice capacity. And it supports 0.6ohm GT M coil and 1.2ohm GT Coil for nicotine salt, which will bring you a better vaping experience. What's more, the Kit is equipped with easy to carry lanyard, it utilizes Type-C USB port for easy and safe operation. This is Basic Version ![]() Original Eleaf iStick Amnis 2 1100mAh Box Mod Battery with GS Drive Tank Kit $31.65 The iStick Amnis 2 Kit consists of iStick Amnis 2 Box Mod Battery and GS Drive Tank Atomizer. The Kit is powered by 1100mAh build-in battery with USB type-C charging. Also, it comes with 1.8ml e-juice capacity (can changeable to 3ml), which can provide you a last vaping experience. The childproof and lanyard design will create a safe and convenience vaping. Mesh Coil can provide you a better flavor feeling.
497
SXK Monarch R RDTA Repalcement Tank Tube Clone $1.49
The SXK Repalcement Tank Tube is made of glass, it is designed for SXK Monarch R RDTA as a replacement part. ![]() CG SS 510 Base Deck + 3 Mouthpiece Drip Tip + 6 Airflow Insert Set - Type A $5.99 CG Replacement Set A consists of one Stainless Steel Base Deck, three mouthpiece 510 drip tips (White: POM; Black: POM; Brown: PEI) and six airflow inserts (hole diameter: 1.5mm / 2.0mm / 2.5mm / 3.0mm / 3.5mm / 4.0mm). They are used as replacement parts. ![]() CG SS 510 Base Deck + 3 Mouthpiece Drip Tip + 6 Airflow Insert Set - Type B $5.99 CG Replacement Set B consists of one Stainless Steel Base Deck, three mouthpiece 510 drip tips (White: POM; Black: POM; Brown: PEI) and six airflow inserts (hole diameter: 1.5mm / 2.0mm / 2.5mm / 3.0mm / 3.5mm / 4.0mm). They are used as replacement parts. ![]() CG SS 510 Base Deck + 3 Mouthpiece Drip Tip + 6 Airflow Insert Set - Type C $5.99 CG Replacement Set C consists of one Stainless Steel Base Deck, three mouthpiece 510 drip tips (White: POM; Black: POM; Brown: PEI) and six airflow inserts (hole diameter: 1.5mm / 2.0mm / 2.5mm / 3.0mm / 3.5mm / 4.0mm). They are used as replacement parts. ![]() CG SS 510 Base Deck + 3 Mouthpiece Drip Tip + 6 Airflow Insert Set - Type D $5.99 CG Replacement Set D consists of one Stainless Steel Base Deck, three mouthpiece 510 drip tips (White: POM; Black: POM; Brown: PEI) and six airflow inserts (hole diameter: 1.5mm / 2.0mm / 2.5mm / 3.0mm / 3.5mm / 4.0mm). They are used as replacement parts. ![]() CG SS 510 Base Deck + 3 Mouthpiece Drip Tip + 6 Airflow Insert Set - Type E $5.99 CG Replacement Set E consists of one Stainless Steel Base Deck, three mouthpiece 510 drip tips (White: POM; Black: POM; Brown: PEI) and six airflow inserts (hole diameter: 1.5mm / 2.0mm / 2.5mm / 3.0mm / 3.5mm / 4.0mm). They are used as replacement parts. ![]() SXK Replacement Tank Tube for Bastard MTL / DTL RTA Clone original price$6.90, now only$4.99 The SXK Replacement Tank Tube is made of PEI, it comes with 3.5ml juice capacity. The Tank Tube is suitable for Bastard MTL / DTL RTA Clone. ![]() SXK Bastard RTA Clone to RDA Replacement Conversion Kit with BF Pin original price$12.90, now only$9.99 The SXK Replacement Conversion Kit is constructed from 316 Stainless Steel in 22mm diameter. It can be used to convert your Bastard RTA Clone to RDA. ![]() ---------------------------- Coupon for Halloween Oct 28th 2019 00:00 - Nov 3rd 2019 23:59 (UTC-6 / Denver Time) Offer: site-wide 5% off Code: Halloween2019 Note: This offer is not stackable with other MAP discounts. |
498
Original Timesvape Keen Hybrid Mechanical Mech Mod original price$75.35, now only$65.99
The Timesvape Keen Mechnical Mod is constructed from Stainless Steel in 30mm diameter and powered by single 18650 / 20700 / 21700 Battery (Not included), featuring an floating contact pin with ball head for hard fitting. The tube itself is 30mm at its widest point, tapering to 25mm or 27mm at the top. The contact pin is gold plated with a flat smooth button spring. ![]() Original Timesvape Keen Hybrid Mechanical Mech Mod original price$66.09, now only$56.99 The Timesvape Keen Mechnical Mod is constructed from Stainless Steel in 30mm diameter and powered by single 18650 / 20700 / 21700 Battery (Not included), featuring an floating contact pin with ball head for hard fitting. The tube itself is 30mm at its widest point, tapering to 25mm or 27mm at the top. The contact pin is gold plated with a flat smooth button spring. ![]() Original Hellvape MD MTL RTA original price$39.99, now only$29.99 The Hellvape MD RTA is constructed from stainless steel (body) and glass (tank tube) in 24mm diameter, it features 6 adjustable bottom airflow for two MTL modes and it comes with two insert slots and honeycomb airflow turntable to meet differenrt vaping needs. The e-juice capacity is 2ml (straight glass) or 4ml (bubble glass) with child-proof push style top-refilling system. Also, MD RTA comes with two kinds of 510 drip tip for you to choose. ![]() Original Hellvape GRIMM 30W 1200mAh VW Box Mod Pod System Starter Kit original price$59.99, now only$39.99 The Hellvape GRIMM VW Box Mod Pod System Starter Kit is the resulting efforts of collaboration between Hellvape, Grimm Green, and Ohm Boy. The Pod Kit is powered by 1200mAh built-in battery, power output range from 5 to 30W, and comes with a 3ml refillable pod with replaceable coils. Crafted from protective Zinc-alloy and PCTG materials, the GRIMM Pod System is moderately impact resistant, preventing unsightly markings from damaging the box mod. Firing in both a wattage and voltage output, the GRIMM Pod Kit can be tailored to the specific usage of a particular individual, reaching up to 4.6V and 30W, respectively. This allows the GRIMM 30W Pod Kit to be used with plastic food-grade pod, providing a large 3ml capacity, and can accept coils made for the GRIMM Pod Set, clocking in at either 0.7ohm Mesh or can use a 1.2ohm Regular Coil. Refilled in a sliding top fill system, the Hellvape GRIMM will definitely last through any future vape sessions. ![]() Original GeekVape Aegis Boost 40W 1500mAh VW Box Mod Pod System Starter Kit original price$49.99, now only$32.99 The Geekvape Aegis Boost VW Box Mod Pod System Starter Kit is Specially designed for Pod and RDTA, it also supports MTL and DTL vaping experience. The Pod Kit is powered by a built-in 1500mAh battery, it can support the usage of both Pod and RDTA up to 40W. Equipped with IP67, the pod mod is stain-resistant, corrosion-resistant and tear-resistant. It's definitely the lightest yet toughest pod mod. Featuring easy-to-fill design and easy airflow design, the Aegis Boost Pod Kit is highlighted by its easy access top filling and its easy access airflow valve. It can bring you a great visual enjoyment with elegant appearance and concise design and with extraordinary vaping experience. ![]() Original Innokin Endura T18II 1300mAh Battery with Prism T18 Sub-Ohm Tank Starter Kit $29.99 The Innokin Endura T18ii Starter Kit consists of Endura T18ii Vape Pen Battery and Prism T18 Tank. The Endura T18ii is powered by built-in 1300mAh battery and comes with 2.5ml juice capacity. The T18ii also features a re-designed firing / power button that gives this device a more modernized and distinct look. You can use this same button for easy wattage select from Cool at 10.5W, to Mid at 12W, to Warm at 13.5W. Three LED lights above the firing button will indicate which wattage mode you have selected. Equipped with all the necessary safety features, the Endura T18ii is charged through an industry standard Micro-USB port. Attached to the Ednura T18ii Mod by a threaded 510 connection is the Prism T18 Tank, composed of superior Stainless Steel and durable Pyrex glass. Near the base of the tank is a four air holes inside an adjustable airflow ring so you can get the draw you desire by closing one hole at a time. With a convenient top-filling method, this device has a threaded top cap for access to a 2.5ml e-liquid capacity glass reservoir. Inside this glass tube is a pre-installed 1.5 ohm coil with a 14W maximum output so you can get a smooth, flavorful, low wattage vape. For the drip tip of the Prism T18, Innokin has included a hygienic magnetic cap to keep it clean and free of debris. This pocket-friendly feature is also capable of sticking onto the bottom of your T18ii pen so you dont have to worry about loosing it during your sessions.
499
Original ThinkVape Replacement Mesh Coil for ZETA Kit / ZETA Pod(5 PCS) $9.99
The Think Vape Replacement Mesh Coil is designed for Think Vape ZETA Kit or Think Vape ZETA Pod. It features 0.5ohm coil resistance. 5 PCS / Pack. ![]() Original ThinkVape Replacement Mesh Coil for ZETA Kit / ZETA Pod(5 PCS) $9.99 The Think Vape Replacement Mesh Coil is designed for Think Vape ZETA Kit or Think Vape ZETA Pod. It features 0.2ohm coil resistance. 5 PCS / Pack. ![]() Original ThinkVape Replacement Regular DC Coil for ZETA Kit / ZETA Pod(5 PCS) $9.99 The Think Vape Replacement Regular DC Coil is designed for Think Vape ZETA Kit or Think Vape ZETA Pod. It features 1.0ohm coil resistance. 5 PCS / Pack. ![]() Original GeekVape Aegis Replacement Coil for Aegis Boost Kit / Pod(5 PCS) original price$14.99, now only$10.99 The GeekVape Aegis Replacement Coil is designed for Aegis Boost Kit / Aegis Boost Pod. It features 0.6ohm coil resistance. 5 PCS / Pack. ![]() Original GeekVape Aegis Replacement Coil for Aegis Boost Kit / Pod(5 PCS) original price$14.99, now only$10.99 The GeekVape Aegis Replacement Coil is designed for Aegis Boost Kit / Aegis Boost Pod. It features 0.4ohm coil resistance. 5 PCS / Pack. ![]() Original GeekVape Aegis Replacement Pod Cartridge for Aegis Boost Kit / Pod original price$14.99, now only$8.99 The GeekVape Aegis Replacement Pod Cartridge is designed for Aegis Boost Kit / Aegis Boost Pod. It comes with 3.7ml juice capacity and it is compatible with 0.4ohm or 0.6ohm coil. ![]() Original HorizonTech Replacement Bubble Tank Tube for Falcon II Tank $2.99 The HorizonTech Replacement Bubble Tank Tube is designed for Falcon II Sub Ohm Tank. It comes with 5.5ml juice capacity. ![]() Original Timesvape Keen Mechanical Mech Mod Extend Stacked Tube $26.99 The Timesvape Keen Mechanical Mech Mod Extend Stacked Tube is contructed from Copper and Extend Stacked Tube can extend the height of the Keen Mod and makes it can be powered by dual 18650 / 20700 / 21700 batteries. (Not included) ![]() Original Timesvape Keen Mechanical Mech Mod Extend Stacked Tube $27.99 The Timesvape Keen Mechanical Mech Mod Extend Stacked Tube is contructed from Copper and Extend Stacked Tube can extend the height of the Keen Mod and makes it can be powered by dual 18650 / 20700 / 21700 batteries. (Not included) ![]() ---------------------------- Coupon for Halloween Oct 28th 2019 00:00 - Nov 3rd 2019 23:59 (UTC-6 / Denver Time) Offer: site-wide 5% off Code: Halloween2019 Note: This offer is not stackable with other MAP discounts. |
500
Match Stick Hybrid Mechanical Mod Clone $20.99
The Match Stick Mechanical Mod Clone is constructed from brass in 24mm diameter. It is powered by Single 18650 battery (Not included). It features 510 hybrid top cap and spring fire button. ![]() Coppervape Hussar Single Coil RTA Clone with Mirco PEI Tank $18.99 The Coppervape Hussar Single Coil RTA Clone is constructed from 316 Stainless Steel (body) and PEI (tank tube) in 22mm diameter. The RTA comes with a 2.5ml juice capacity tank tube, which supports bottom adjustable airflow (2.5mm airflow post inside; 2.0mm airflow post in spare kit) and juice control. ![]() Caiman MTL RDTA Clone $18.99 The Caiman MTL RDTA Clone is constructed from stainless steel (body) and PC (tank) in 22mm diameter. The RDTA supports air feed adjustment, coming with a adjustable central connector screw and it is esay to E-liquid tank filling. Also, the RDTA can replaceable air pipes with different diameters. The inner surface of the atomizing chamber cap has a hemispherical shape which can hold some amount of liquid when the atomizer is turned over (similar to a no-spill cup). What's more, Milled stands is easy for coil clamping. ![]() Original Wismec PREVA 1050mAh Box Mod Battery Starter Kit with Pod Cartridge(Pod Version) $35.00 The Wismec PREVA Kit is a new intelligent Pod device. Powered by home-made advanced chip, this kit boasts its compact size and stylish appearance with fascinating glass panel and offering great portability and visual enjoyment. Featuring 1050mAh built-in battery, optional cartridges and various power modes, which will definitely provide incomparable vaping experience. Compatible with SS316 Dual 0.25 cartridge, absorbing e-liquid more fully and offering you more pure flavor. This is Pod Cartridge Version ![]() Original Wismec PREVA 1050mAh Box Mod Battery Starter Kit with Pod Cartridge(Standard Version) $36.50 The Wismec PREVA Kit is a new intelligent Pod device. Powered by home-made advanced chip, this kit boasts its compact size and stylish appearance with fascinating glass panel and offering great portability and visual enjoyment. Featuring 1050mAh built-in battery, optional cartridges and various power modes, which will definitely provide incomparable vaping experience. Compatible with standard cartridge. Standard cartridge uses Mesh 0.6ohm coil and mesh cotton, absorbing e-liquid more fully and offering you more pure flavor. This is Standard Cartridge Version ![]() Original Goforvape Monsterwix Organic Pre-loaded Cotton for RBA / RDA / RTA / RDTA Atomizer(30 PCS) $2.99 The Goforvape Monsterwix Cotton is premium organic cotton. It is compatible with all kinds of RBA / RDA / RTA / RDTA Atomizers. Best choice for DIY lovers. 30 PCS / Pack. ![]() Original Goforvape Flavorbeast Organic Cotton for RBA / RDA / RTA / RDTA Atomizer(10g) $2.99 The Goforvape Flavorbeast Cotton is premium organic cotton. It is compatible with all kinds of RBA / RDA / RTA / RDTA Atomizers. Best choice for DIY lovers. 0.36 Oz (10g) / Pack. ![]() Coppervape Replacement Diamond Top Cap Tank Tube + Chimney for Flash e-Vapor V4.5 RTA Clone - Short Version $7.99 The Coppervape replacement PC Diamond Top Cap Tank Tube and 316 Stainless Steel Chimney is suitable for Flash e-Vapor V4.5 RTA Clone. It comes with 3.4ml juice capacity. ![]() Coppervape Replacement Diamond Top Cap Tank Tube + Chimney for Flash e-Vapor V4.5 RTA Clone - Long Version $7.99 The Coppervape replacement PC Diamond Top Cap Tank Tube and 316 Stainless Steel Chimney is suitable for Flash e-Vapor V4.5 RTA Clone. It comes with 4.8ml juice capacity. ![]() YFTK Replacement Middle Top Cap for YFTK / SXK Haku Xeta Inside RBA Clone $4.99 The YFTK Replacement Middle Top Cap is made of PEI, which is suitable for YFTK / SXK Haku Xeta Inside RBA Clone as a replacement part. ![]() Original Ohm Vape AIO RBA Coil Head + Pod Cartridge for Ohm Vape AIO / Dotmod AIO Pod Kit $10.99 The Original Ohm Vape AIO Pod System Replacement Pod Cartridge with RBA Coil Head is compatible with Ohm Vape AIO Pod System Kit / Dotmod AIO Pod Kit. ![]() YFTK Haku Xeta Inside RBA Rebuildable Atomizer Clone for Billet Box Mod Kit $25.99 The YFTK Haku Xeta RBA Clone is constructed from Titanium Alloy and ultem. This RBA consists 510 chimney section, airdraw insert, elevating coil clamp system, airflow disk, wick channel controller pin, and air intake. It is suitable for BB Box Mod Kit. ![]() ---------------------------- Coupon for Halloween Oct 28th 2019 00:00 - Nov 3rd 2019 23:59 (UTC-6 / Denver Time) Offer: site-wide 5% off Code: Halloween2019 Note: This offer is not stackable with other MAP discounts. |
