Просмотров в теме 302474   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 05.09.2019, 05:20 Автор темы   441
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Vapor Storm Trip 200W Suitcase TC VW Box Mod original price$44.47, now only$39.99
The Vapor Storm Trip 200W Box Mod is a suitcase inspired vaping box mod, introducing an aerometal and PC material chassis construction, dual 18650 battery (Not included) configuration, and comes with an extensive temperature control suite to help dial in the perfect preferred vape settings. Fashioned from lightweight aero metal, the Vapor Storm Trip Box Mod is constructed from CNC machining processes, perfecting the dimensions of the vape with less imperfections due to other older manufacturing processes. Hidden behind an anodized metal body panel, the Vapor Storm TRIP Box Mod utilizes a pair of high-amp 18650 batteries that must be purchased separately. Working in conjunction with the proprietary chipset inside, the Vapor Storm Trip 200W Box Mod offers an extensive temperature control suite, implementing compatibility with nickel, titanium, and stainless steel wire compositions in TCR Mode. Furthermore, in wattage mode, the highest wattage available is 200W, but in BYPASS mode, a new ceiling of 230W can be achieved.
Original Innokin GoMax Plex-3D Multi-Use Disposable Sub Ohm Tank Clearomizer $3.99
The advanced grid design of Plex-3D Matrix distributes power evenly and heats ultra-fast for more intense flavors and clouds. The GoMax DTL tank has a 24mm diameter with a large 5.5ml capacity that features a slide to fill top and silicone seal. Turn the bottom adjustable airflow ring to focus on flavors, clouds or a great mix of both. The GoMax standard 510 connection works great with any (60~80W) adjustable wattage vaporizer. The GoMax Multi-use DTL tank is made with food grade PCTG plastic and available in four great colors. The Innokin GoMax multi-use disposable tank is the affordable choice for those who love flavorful and convenient DTL vaping.
Original Innokin iSub-B Sub Ohm Tank Clearomizer $14.99
The Innokin iSub B Sub-Ohm Tank is a well constructed tank, featuring a 3ml standard juice capacity, threaded top fill system with protections, and utilizes the new Innokin iSub B Plex 3D Mesh Coils. Constructed from sturdy stainless steel, the iSub B Tank features Pyrex glass reinforcement to protect the rainbow tinted standard 3ml juice capacity or the expanded 4ml juice capacity. At the top sits a threaded top fill system with automatic flood protection to prevent unwanted leaking during refills. In addition, at the base is a set of bored airflow channels behind an adjustable airflow ring to change the airflow restriction for each hit. Within the tank, is the Innokin iSub B Mesh Coil Family with extensive microgrooves on the mesh heating element to expand the surface area and create a better flow of juice via capilliary effect. With wood pulp and organic cotton as the wicking material, the Innokin iSub B Sub-Ohm Tank is sure to function well when used in conjunction with the Innokin iSub B Plex 3D Mesh Coil Family.
Original E-bossvape GT 400mAh Pod System Starter Kit $14.99
The Ebossvape GT Vape Kit includes 400mAh built-in battery and 1.2ml pod cartridge. The cartridge comes with ceramic coils that fits for, which drives smooth airflow and puerer flavor. Furthermore, the innovative charging design ease users and is time-saving. It is compact and light yet the powerful protection is covered in this vape kit.
Original Innokin Endura T20 MTL 13W 1500mAh Mod Pod System Starter Kit $21.99
The Innokin Endura T20 is the latest version of the super popular Innokin Endura series. The Innokin Endura T20 follows the same philosophy of an easy and convenient to use device with a simple one button design built in a compact and portable design. The Endura T20 features a more smooth and open draw compared to the original Endura T18. The Endura T20 features a slim 20.5mm diameter with a built-in 1500mAh battery that may be charged with the included micro-USB cable. The Prism T20 tank features a 2ml E-Liquid capacity with a simple top fill design with a twist off cap. The Endura Prism T20 atomizer heads are designed to bring out the flavor of your favorite e-Liquid and is compatible with high VG based e-Liquids. A protective drip tip cap is included as well.
Original Vapor Storm Trip 200W Suitcase TC VW Box Mod + Trip Tank Kit original price$59.00, now only$49.99
The Vapor Storm Trip Kit consists of Vapor Storm Trip 200W Box Mod and Trip Tank Kit. The Vapor Storm Trip Kit adopts suitcase design, making it so unique and elegant in palms. The Vapor Storm Trip MOD is powered by two 18650 batteries (Not included), firing up to a 200W output. The lateral 0.91-inch OLED display shows wattage data and device status clearly too. The Vapor Storm Trip Sub Ohm Tank adopts 6ml large capacity. The pack comes with a 2ml tube for easy replacement. The Vapor Storm Trip Tank adopts 0.2ohm Hawk coil, bringing best flavor to vapers.
Original SMOKTech SMOK TF-RTA G4 Pre-made Dual Deck Wire $1.39
The SMOK TF-RTA G4 Pre-made Dual Wire is made of Clapton Kanthal & Nichrome wire. It has a 0.54ohm coil resistance and high quality to bring you purer flavor. The deck wire fits for SMOK TF-RTA Tank. Just get it as your spare part. 12 PCS / Pack.
Original SMOKTech SMOK TF-RDTA S2 DECK Coil Head $1.39
The SMOKTech TF-RDTA S2 DECK is suitable for SMOKTech TF-RDTA atomizer. You can rebuild the coil head with different wires.
Original Aspire Cleito Kanthal AF Pre-Built Clapton Coil for Cleito RTA $1.99
The Original Aspire Pre-built Coil Heating Wire is made from Kanthal AF wires and features 0.8~0.9 ohm. This pre-coiled heating wire comes with 26GA (core) + 35GA (wrapped) coils. This heating wire will be a good vaping choice for DIY. The coil fits for Aspire Cleito RTA
3FVAPE вне форума   Вверх
Старый 05.09.2019, 05:25 Автор темы   442
3FVAPE
Original HorizonTech Arctic Turbo Replacement Bottom Sextuplet Coil Head $3.99
The Arctic Turbo Coil Head is constructed from 100% Organic Cotton and Stainless Steel with 0.6ohm coil resistance. The wattage range is from 40W to 120W. 5 PCS / Pack.
Original Innokin iSub Replacement Ti Coil Head $7.99
The Innokin iSub Coil Head is constructed from Japanese Organic Cotton and Titanium with 0.4ohm coil resistance. The recommended temperature is from 180'C to 240'C. The coil is compatible with iSub, iSub Apex tank. 5 PCS / Pack.
Original Freemax Starre Pro Replacement Ni200 Coil Head for Pro Tank $6.99
The FreeMax Starre PRO Ni200 replacement coil is specially for the newly released Pro tank. It is designed with popular temperature control function and with 0.15ohm resistance. 5 PCS / Pack.
Original FreeMax Scylla RTA Replacement Coil Head $6.99
The FreeMax Scylla Clapton replacement coil head with 0.5ohm resistance can work under from 20W to 50W. This clapton coil will produce cloud vapor and pure taste on the Scylla RTA atomizer. 5 PCS / Pack.
Original Innokin Zenith Plex3D Replacement Coil Head for Platform Zlide Tank $8.99
The Innokin Zenith Plex3D Replacement Coil Head fits for Platform Zlide Tank, which is made of Kanthal material with 0.48ohm resistance. This coil is good for the medium and high power settings. 5 PCS / Pack.
Original Innokin iSub Plex3D Mesh Coil Head for iSub-B Tank $8.59
The iSub Plex3D Mesh Coil is perfectly compatible with Innokin iSub-B Tank, which has a 0.35ohm coil resistance. The wattage range is from 30W to 55W. 5 PCS / Pack.
Original Innokin Jem Replacement MTL Ceramic Coil Head for Jem / Goby Pen Kit $7.99
The Innokin Jem replacement Coil is compatible with the Innokin Jem Pen AIO Starter Kit / Goby Pen AIO Starter Kit. Each coil features either a ceramic element or a kanthal coil which are designed to produce a pure and smooth e-liquid flavor, giving users long lasting vaping experience. With a solid stainless steel construction. Designed to perfection for accurate MTL vaping. 5 PCS / Pack.
Original Innokin Jem Replacement MTL Kanthal Regular Coil Head for Jem / Goby Vape Pen Kit $7.99
Original E-bossvape GT Pod System Replacement Pod Cartridge with 1.4ohm Ceramic Coil $7.99
The Ebossvape GT Vape Pod Cartridge is specially designed for E-bossvape GT pod system kit. The ceramic coil drives the flavor better and massive clouds. The resistance is 1.4ohm. 4 PCS / Pack.
Старый 06.09.2019, 05:02 Автор темы   443
3FVAPE
SXK Stratum Zero Mini Semi-Mechanical Mod Clone original price$19.90, now only$17.99
The SXK Stratum Zero Mini Semi-Mechanical Mod Clone is constructed from stainless steel and powered by single 18350 battery (Not included). The height of this semi-mechanical mod is 46mm and is with a short-circuit protection chip board.
Original Vzone Preco MTL Disposable Sub Ohm Tank Clearomizer $3.99
The Vzone Preco MTL Disposable Tank is a 24mm diameter food grade plastic constructed tank atomizer, featuring a TPD-compliant 2ml juice capacity. Within the food grade plastic construction is an integrated 0.9ohm that can effectively vaporize the e-liquid with little to no effort. Feeding the coil is an 2ml juice capacity refilled via top fill system, silicone stoppered by a plug. In addition, the coil fires at wattages between 10~25W, working optimally at wattages between 10~25W. At the base of the atomizer is an airflow control ring with three drilled air holes to inlet airflow to the coil within. With the disposable tank, it can simply be tossed out and thrown away when the coil within no longer transfers the true taste of the juice properly.
Original ShenRay Value Greek MTL RTA $30.50
The ShenRay Value Greek MTL RTA Clone is constructed from 316 stainless steel in 22mm diameter. The RTA supports top refilling system and adjustable bottom airflow. It can provide you mouth to lung (MTL) vaping experience.
Original Vzone Vowl Vlit 40W 1600mAh Box Mod + Preco MTL Disposable Sub-Ohm Tank Kit $18.99
The Vzone Vowl Vlit 40W MTL Mod Kit is a truly ergonomic vape system, featuring an integrated 1600mAh rechargeable battery, an intuitive firing button, and is paired with the Vzone Preco Disposable Sub-Ohm Tank. The integrated 1600mAh rechargeable battery can be charged via Micro-USB port and allows the Vzone Vowl to last the entire day between charges. The integrated battery and proprietary chipset within allow for resistances as low as 0.3ohms and can achieve a max wattage output of 40W. The oversized firing button can be found on the user interface and is intuitive at a glance. Beneath that is a set of LED indicator lights that relay the power mode setting that is selected and relays the remaining battery charge within the Vowl battery. Furthermore, the Vowl is paired with the Vzone Preco Disposable Sub-Ohm Tank, relying on the top fill system stoppered by a silicone plug to fill the 2.0ml juice capacity to fire within the integrated 0.9ohm coil. A dual slotted bottom airflow control ring possesses three bored holes to inlet airflow to the coils.
Original Bohr Flask 20W 1150mAh VW Mod Pod System Starter Kit original price$35.00, now only$28.99
The Bohr Flask Pod Kit comes with a large 1150mAh built-in battery and 2ml refillable pod cartridge. It is the first intelligent vape pod system from Bohr, which is based on the SAGA Player Chip. It features super stable performance and great taste experience. Adopting a high definition OLED screen, you can control the real-time output by pressing the adjustment button. With VW / VV / Play Modes, it supports intelligent vape control and you can find the best flavor or yourself by switching the modes. It is compatible with 0.4ohm Mesh Coil and 1.2ohm Ceramic Coil for the optimal taste and massive clouds. It is also designed with portable size for easy carrying. Multiple protections are applied for safe and stable vaping.
Original Reewape AS122 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.49
The Reewape AS122 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS131 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.59
The Reewape AS131 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS177 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.55
The Reewape AS177 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Bohr Flask Pod System Replacement Pod Cartridge original price$7.19, now only$4.99
The Bohr Flask Pod Cartridge is especially designed for the Bohr Flask Pod Kit with 2ml e-juice capacity. It adopts 0.4ohm mesh coil and 1.2ohm ceramic coil for both MTL and DL vaping (coils are not included). Get it as a spare part for your Bohr Flask Pod Kit.
Original Bohr Flask Pod System Replacement DL Mesh Coil Head original price$14.50, now only$9.99
The Bohr Flask Coil is especially designed for the Bohr Flask Pod Kit. The Mesh coil has a longer life span. It has 0.4ohm resistance and best for DL vaping. Get it as a spare part for your Bohr Flask Pod Kit. 5 PCS / Pack.
original Bohr Flask Pod System Replacement MTL Ceramic Coil Head original price$14.50, now only$9.99
The Bohr Flask Coil is especially designed for the Bohr Flask Pod Kit. The Ceramic coil has a longer life span. It has 1.2ohm resistance and best for MTL vaping. Get it as a spare part for your Bohr Flask Pod Kit. 5 PCS / Pack.
SXK 21700 / 18650 Battery Extension Adapter Tube for Stratum Zero 18350 Semi-Mechanical Mod Clone $9.99
The SXK Battery Adapter Tube set consists a stainless steel adapter tube (Height: 41mm; Diameter: 26mm), a translucent PC adapter tube (Height: 70mm; Diameter: 22mm), and an electrical pole (Height: 5mm; Diameter: 18mm). The set is suitable for SXK Stratum Zero Mechanical Mod Clone.
Original Demon Killer PUCK 400mAh Pod System Mod Battery $12.99
The Demon Killer Puck Pod System Mod Battery is a new product from Demon Killer with a smooth and sleek design, nice texture and portable to have it anywhere. Demon Killer Puck Mod Battery coming with Zinc alloy material, the surface of the fuselage is shiny and durable. It is visually fancy and compact being equipped with a battery of 400mAh to meet everyday use. The pod Mod Battery is compatible with 0.7ml pod capacity and 1.6ohm resistance (Cotton Coil) (pod cartridge not included). The most important is Puck mod compatible with Jull / Jbox cartridge.
Старый 07.09.2019, 04:45 Автор темы   444
3FVAPE
Original Damn Vape Diamond MTL RTA original price$30.99, now only$22.99
The Damn Vape Diamond MTL RTA is designed by Damn Vape and JAY DESIGN company. The RTA is constructed from Stainless Steel (Body) and Glass (Straight / Bubble Tank) in 22mm diameter. The tank features cone-shape small chamber and none diffusion single hole adjustable airflow. With 1.5mm center airflow hitting coil, traveling through compact cone-shape chamber and small chimney, you'll get outstanding flavor and perfect throat hit. Two post build desk for MTL builds, you can use flat / phillips screwdriver to tighten up screws. PEEK insulator around positive post. 1.5mm airflow hole in the center, and 2 wicking holes on two sides. Improved Kayfun Lite Style airflow. Adjust airflow from the side (you don't have to unscrew the stty to adjust airflow). No airflow-ring, no diffusion, no worries about changing your favorite setting by accident. Diamond has small build deck, so the chamber diameter is small as well. Meanwhile, it features cone-shape bell. It has one of the smallest room inside for vaporizing.
Haku Riviera RDA Clone with BF Pin $7.59
The Haku Riviera RDA Clone is constructed from Stainless Steel in 22mm diameter. It comes with bottom feeder pin, dual post design and single coil configuration. It also supports side airflow control. Comes with bottom feeder pin.
Original Cthulhu Mulan MTL RDTA with BF Pin original price$34.90, now only$24.99
The Cthulhu Mulan MTL RDTA is from the Chinese ancient poem pf a brave girl, which is constructed from 304 food grade stainless steel in 22mm diameter and 33mm height (without drip tip). The Cthulhu Mulan has a lim and long 510 drip tip and restricted lateral airflow hole for MTL vaping experience. The 2ml juice capacity provides an ample liquid storage too. The Cthulhu Mulan RDTA has a changeable airflow insert, so you ae capable of experiencing different air inlet without rebuilding coil. The Cthulhu Mulan's coil is near to drip tip, bringing outstanding flavor to vapers. The Cthulhu Mulan also comes with a BF pin to fit most squonker MODs.
Original JUSTFOG QPod 900mAh Pod System Starter Kit $26.48
The JUSTFOG QPod Kit is a new innovative and elegant pod system kit that has a slim, compact body and pocket size. Made of PC and Anodized-AI / Brass, the JUSTFOG QPOD Pod System Kit will definitely bring you a comfortable feeling. The Qpod kit is powered by a built-in 900mAh battery and comes with a 1.9ml cartridge for superior stability and vape. The size of the pocket will make it easier for our e-cigarette users to carry and vape wherever they are. In addition, the adjustable airflow on the control unit guarantees a perfect taste. The JUSTFOG QPod Pod cartridge adopts the side fill design which there is no leak, the battery indicator will notify you when it is empty. The JUSTFOG QPOD battery has a boost mode and operates from 3.5V to 4.2V to meet your taste needs. JUSTFOG QPOD is equipped with a 1.6 ohm OCC bottom coil for a good vaping experience.
Original Aspire K Lite 900mAh Mod with K Lite Tank Starter Kit original price$34.99, now only$25.99
The Aspire K Lite Kit consists the K Lite Mod and the new K Lite Tank. The long standing, reliable, compact and ergonomic K Lite Mod, with the K Lite Tank. The K Lite Kit is very portable with sleek minimalist design, it fits as easily in the purse as it does in the hand. The 900 mAh built-in battery can meet your demand of one-day vaping. The K Lite tank comes in 2ml, with 1.8ohm and 1.6ohm coils, which are also compatible with aspire original BVC coils and Spryte coils. Refilling the childproof K Lite Tank is simplicity itself and mess free. Unscrew the top cap and remove it from the tank; Add your preferred e-liquid by pushing the tip of your filling bottle through the filling slot; Once filled, put the top cap back on top of the tank then screw to secure it. The Micro USB charging port is at the bottom of the K Lite mod. Once charging, the LED light will be on to indicate the charging status.
SXK Replacement O-Ring Seals for Billet Box 60W / 70W Box Mod Kit $2.28
The SXK Replacement O-Ring Seals is suitable for SXK Billet Box 60W / 70W Box Mod Kit. The O-Ring Seal are made of Silicone, which include one big O-Ring Seal and two small O-Ring Seals. 3 PCS / Pack.
Original Voopoo MT-M2 Replacement Dual Mesh Coil Head for Maat Tank Atomizer $8.99
The VOOPOO MT Replacement Coil Head is specially designed for the VOOPOO Maat Sub-ohm Tank. It comes with the MT-M2 0.2ohm Dual Mesh Coil. The wattage range of this coil is from 55W to 80W, which will bring you great vaping experience. 5 PCS / Pack.
Original Voopoo MT-M3 Replacement Triple Mesh Coil Head for Maat Tank Atomizer $9.99
The VOOPOO MT Replacement Coil Head is specially designed for the VOOPOO Maat Sub-ohm Tank. It comes with the MT-M3 0.17ohm Triple Mesh Coil. The wattage range of this coil is from 65W to 85W, which will bring you great vaping experience. 5 PCS / Pack.
Original Voopoo MT-M1 Replacement Single Mesh Coil Head for Maat Tank Atomizer $8.59
The VOOPOO MT Replacement Coil Head is specially designed for the VOOPOO Maat Sub-ohm Tank. It comes with the MT-M1 0.13ohm Single Mesh Coil. The wattage range of this coil is from 60W to 85W, which will bring you great vaping experience. 5 PCS / Pack.
Original HorizonTech Magico Pod Kit Replacement Pod Cartridge $8.99
The HorizonTech Magico Replacement Pod can hold 6.5ml e-juice, with convenient top e-juice refill design, easy to refill your favorite e-juice. the coil base with dual airflow adjustable slots, only rotating the ring to adjust the intake air freely. there are two coil heads available, the 1.8ohm regular coil and 0.12ohm mesh coil (Coil is not included). both of them covered with bamboo fiber material will deliver a decent flavor or large cloud or vapor. The HorizonTech Magico Replacement Pod Cartridge is specially designed for Horizon Magico Pod Kit.
Original JUSTFOG QPod Pod System Replacement Pod Cartridge Clearomizer $3.99
The JUSTFOG QPod Pod Cartridge Clearomizer is an exquisite atomizer, which is specially designed for JUSTFOG QPod Kit and JUSTFOG QPod Battery. And the JUSTFOG QPod Clearomizer possesses the OCC Bottom 1.6ohm coil which will provide the extreme flavor and 1.9ohm juice capacity with easy to side refill design.
Старый 09.09.2019, 05:11 Автор темы   445
3FVAPE
Original Ultroner GAEA 200W VW Box Mod $239.90
The Ultroner GAEA VW Box Mod is constructed from Stainless Steel and Stabwood material, which is powered by dual 18650 rechangeable batteries (Not included). The VW Box Mod is equipped with Sevo-200C Chipset, and it supports power range from 5W to 200W
Original SMOKTech Mag P3 230W Touch Screen TC VW Box Mod $59.99
The SMOKTech SMOK Mag P3 230W Touch Screen TC Box MOD features the gun-handle shape, beautiful carbon fiber panel and big fire button, the Mag P3 mod is an excellent 230W TC Box Mod powered by external dual 18650 batteries (Not included). Adopting a smart IQ-M Chipset, it supports high performance VW / TC modes, Puff Setting and 0.001s flash fire speed. Moreover, plus the super responsive 1.9 inch HD touch screen, the Mag P3 has an upgraded user interface to make the operation easier and more accurate. Just like a phone, it also supports passcode setting and slide-to-unlock function. What's more, SMOK Mag P3 adopts waterproof (IP67), dustproof and shockproof design to make it durable and outstanding. Perfectly match the TFV16 Tank and TFV16 Series Coils.
Original Augvape Druga Foxy 150W VV VW APV Box Mod $47.99
The Augvape Druga Foxy Mod is constructed from high quality Zinc Alloy and equipped with Switchable IML panels. You can use different panels to match your atomizer. It is powered by dual 18650 batteries (Not included) and can reach up to 150W. The OLED screen will show you the accurate conditions of both batteries. It adopts advanced Quick Release button, which makes it easy to install atomizer. It supports two different working modes: VV Mode, VW Mode, which can satisfy different vaping demands. It features the compact outlooking with aesthetics design, which is the perfect combination for excellent vaping life.
Original GeekVape Aegis X 200W TC VW Box with Cerberus Tank Kit original price$96.50, now only$76.99
The Geekvape Aegis X TC VW Mod Kit is powered by dual 18650 batteries (Not included) with upgraded AS 2.0 chipset to bring 200W max output power and provide fast and accurate VW / TC / VPC modes. Moreover, it is equipped with a 2.4 inch OLED screen for vivid display. You can know the working conditions clearly and operated the mod easily with the comfortable buttons. What's more, it still features IP67 water & dust resistance and high shock resistance for comfortable hand feeling and durable use. And the innovative Cerberus Sub-Ohm Tank features 5.5ml e-juice capacity and easy top filling. Plus the awesome super mesh X1 0.2ohm coil which maximizes heating contact surface area and provides more vaping flavor and clouds with the large adjustable airflow, you can enjoy a super wonderful vaping experience.
Original GeekVape Aegis X 200W TC VW Box original price$73.90, now only$59.99
The Geekvape Aegis X 200W TC VW Box Mod is powered by dual 18650 batteries with innovative AS 2.0 chipset to strongly fire up 200W max output. The several feasible modes including VW / TC / VPC modes will bring you the excitement of high speed and accurate operation. Furthermore, it adopts 2.4 inch OLED display for easily checking out the fundamental conditions plus the the three-proof function including waterproof, dustproof and shockproof to ensure you a durable vaping. The Aegis X TC VW mod is just right for the Geekvape Aegis X 200W TC Kit.
Старый 09.09.2019, 05:16 Автор темы   446
3FVAPE
Original Augvape Intake Dual RTA original price$31.99, now only$23.99
The Mike Vapes and Augvape proudly present to you the Intake Dual 26mm RTA. With the huge success of the single coil Intake and the demand for a dual coil version, Mike and Augvape decided to make that happen. The intake dual has top fill, top airflow, and a postless style deck with side airflow. Capacity of tank with straight glass is 4.2ml and with bubble glass 5.8ml. It's a leak proof RTA, too. In order to get more airflow while keep the diameter 26mm, the airflow is from the top and get through the chimney, then blow the coil from side and bottom. Intake Dual uses postless deck and offer a coil tool for customers to cut the coil lead so that these dual coils in the deck will be in the perfect position to produce flavorful and condense vapor.
Original Vandy Vape Pyro V3 RDTA with BF Pin original price$39.99, now only$29.69
The Pyro V3 RDTA is constructed from stainless steel in 24mm diameter. It comes with advanced airflow intake system to provide you excellent flavor taste. The enhanced bottom airflow design and optimized filling structure make airflow control and refilling conveniently.
YFTK Phenomenon Zest 2.2 URS RTA Clone $23.99
The YFTK Phenomenon Zest 2.2 URS RTA Clone is constructed from 316 Stainless Steel (Body) and PC (Tank) in 22mm diameter. It comes with a 4ml juice capacity tank. The RTA comes with AFC ring turn and close liquids to supports bottom airflow control and top refilling.
Старый 10.09.2019, 05:29 Автор темы   447
3FVAPE
Original Kangvape D-pod V2 400mAh Pod System Starter Kit $12.99
The Kangvape D-pod V2 Kit is an ultimate lightweight Kit. It has adjustable voltage and battery power indicator light features.The three different voltage options for your choice and the rapid preheating can heat your oil to bring you a nice and pure taste. It comes with 400mAh built-in battery and 0.7ml Pods capacity.It is small and exquisite which easy to carry. It has multiple protections to ensure your safe use.
Original Medo 500mAh Pod System Starter Kit $19.99
The Medo is a sleek and compact Pod kit, its thin aluminum-alloy body is finely polished with multiple colors. The 500mAh battery is manufactured by GOLISI, a 45-minutes charging can support one whole day vape. The leak-proof Nicotine-salt cartridge is designed by then engineer who designed DROP, and was lavished with Japanese organic cotton and S316 medical-level stainless steel coil.
Original G-taste Mimo 450mAh Pod System Starter Kit $14.99
The G-taste Mimo is a super-portable pod system kit with innovative leakfree design. It is powered by 450mAh built-in battery, which provides long stable vapor output and is charged by the bottom micro USB. With 1.3ml visible e-juice capacity, it ships with two 1.8ohm pods, bringing you smooth flavor and cloud. And BTS Bottom to Side RDA Style Airflow Structure creates an outstanding flavor and vapor production while maintaining its leak-proof condition. Adopting food grade PCTG materials and anti-bacterial copper base for safety, it also chooses one button for all operations design to avoid the risk of automatically working
Original Bohr Hunter 12W 360mAh Pod System Starter Kit $24.99
The Bohr Hunter Pod Kit is made of Zinc alloy and plastic with tiny size, which is portable to use. It comes with built-in 360mAh battery and 2ml refillable pod. Replaceable covers are available for you, you can change the color of the Hunter as you want. Two kinds of cartridges are included: one is made with cotton for flavorful e-juice, another is made with ceramic for nicotine. The Hunter Pod is designed with a convenient filling system. And it adopts the LED light indicator to show the battery life when vaping. Multiple protections are applied to guarantee safe and stable vaping.
Original DOVPO Peaks Vape 15W 650mAh Pod System Starter Kit original price$37.99, now only$28.99
The DOVPO Peaks Vape is a unique designed flip-cover pod system that is constructed from Zinc-Alloy and PCTG, which is aesthetically pleasing with the metal feel and fine print finish. The pod kit features built-in 650mAh battery and a Type-C USB port that charges in 5V~650mA. It will bring you a stable and lasting vaping experience. What's more, there are available in 2 types of power output for the Peaks, level 1 with 8 watts and level 2 with 15 watts to control which power you're comfortable with. The PCTG material top refillable pod has a 2ml E-liquid capacity that enables to last you a day and has a window to check your liquid level inside your pod. Besides, there are two types of coils for your selections, with 1.4ohm ceramic coil for MTL and 0.8ohm mesh coil for DTL type of vaping. Both of them are high performance with a longer life span before it has a burnt taste.
Original Efest Slim K2 Intelligent Micro USB Charger for 17650, 17670, 18350, 18490, 18500, 18650, 20700, 26500, 26650 $8.99
The Efest Slim K2 Intelligent Charger is a high quality with a cost-efficient and portable design. The Efest Slim K2 Charger is a dual slot charger with Micro USB input and charges at 1A. Each slot is monitored independently to provide the most efficient charge. The LED indicates when your battery is charging and when the battery is fully charged. The Efest Slim K2 Charger features reverse polarity, short circuit, overcharge protection and many more safety features. The Efest Slim K2 Charger can charge different types of 3.6V / 3.7V lithium batteries commonly used in electronic cigarettes, flashlights, electric tools, and more. Batteries not included.
Original Efest LUC Mini Intelligent Micro USB Charger for 17650, 17670, 18350, 18490, 18500, 18650, 22650, 26500, 26650 $10.99
The Efest LUC Mini Charger is a smart charger with single battery slot. With a LCD display, it displays the battery voltage level clearly. The LUC Mini will give you a faster and safer charging experience. Batteries not included.
Original DOVPO Peaks Pod System Replacement MTL Ceramic Coil Head original price$11.89, now only$9.99
The DOVPO Peaks Replacement Coil Head is specially designed for DOVPO Peaks Pod Kit. With the high quality, the coil has a Longer Life Span and has no burnt taste. They will bring you various vaping experience. Just get it as spare parts for your DOVPO Peaks Pod Kit. 5 PCS / Pack.
Original DOVPO Peaks Pod System Replacement DTL Mesh Coil Head original price$10.39, now only$8.99
Original G-taste Mimo Pod System Replacement Pod Cartridge $5.60
The G-taste Mimo Pod Cartridge is compatible with Mimo Pod Kit. It features 1.3ml E-juice capacity. With 1.8ohm coil, it brings you smooth flavor and cloud. It adopts BTS Bottom to Side RDA Style Airflow Structure, which creates an outstanding flavor and vapor production while maintaining its leak-proof condition. It also utilizes food grade PCTG materials to provide you safe vaping experience. 3 PCS / Pack.
Original Kangvape D-Pod Pod System Replacement Pod Cartridge $5.39
The Kangvape D-Pod Cartridge is specially designed for Kangvape D-POD V1 / V2 Kit. It features 0.7ml E-juice capacity. Use with the ceramic coil (not included), it will bring you a pure vaping experience. It can use for THC / E-liquid / Nic salt. 5 PCS / Pack.
Original Medo Pod System Replacement Pod Cartridge $5.80
The Medo Pod Cartridge is specially designed for the Medo Pod Kit. It comes with 2ml e-juice capacity. Get it as a spare part for your Medo Pod Kit. 2 PCS / Pack.
Original Vapor Storm Cotton King Premium Wicking Vape Cotton for RBA / RDA Atomizer $1.99
The Vapor Storm Cotton King is a premium wicking vape cotton, suitable for heating coil of any size. No chemically treated, bleached, or pigmented. Best choice for DIY lovers. 10 PCS / Pack.
Старый 11.09.2019, 04:41 Автор темы   448
3FVAPE
Original DOVPO Topside 90W TC VW Squonk Box Mod original price$84.99, now only$63.85
The DOVPO Topside Mod is collaboratively designed by the Vapor Chronicles and Dovpo, which is constructed with food grade Stainless Steel, Zinc Alloy and Aluminum Alloy to make it moderately impact-resistant in an ergonomic shape and ensures safety to provide you healthy vaping experience. Powered by a single 18650 or 21700 battery (Not included), the Topside can fire up to 90W maximum output with switchable power, bypass, and temperature control modes. Besides, the mod also equips a 10ml silicone e-juice bottle which supports the top filling.
Original DOVPO Topside Dual 200W TC VW Squonk Box Mod original price$89.99, now only$74.59
The DOVPO Topside Dual is the newest version of the innovative Topside Squonk mod that is created by Brian from The Vapor Chronicles YouTube channel. This game changing squonk mod has all the innovation from the original single battery TOPSIDE but now offers more power and extended battery life. This hard hitting device offers 200W of regulated power and uses dual 18650 batteries (Not included). The Topside Dual offers a large 10ml squonk bottle e-liquid capacity (backward compatible with original topside bottle and sled), simple top filling and an easy to use interface which makes this the perfect addition to those who want more power and extended battery life. Powerful and Simple squonking has arrived with the Topside Dual.
Original Steam Crave Glaz Mini MTL RTA $34.99
The Steam Crave Glaz Mini MTL RTA, with 23mm diameter, is the newest rebuildable tank atomizer that features with standard 2.0ml e-juice capacity and 5.0ml extension option. The Glaz Mini adopts the glass chamber which will enhance the flavor taste. Plus the easy top refilling, adjustable bottom airflow, and single coil build deck, Steam Crave Glaz Mini RTA will bring you a new MTL vaping experience.
Original Timesvape Diesel RTA original price$34.90, now only$23.99
The Timesvape Diesel RTA is a 25mm diameter RTA with a 2ml juice capacity glass tank. The RTA supports leak-proof top airflow system.
Sichro RDA Clone with BF Pin $12.99
The SiChro RDA is constructed from 316 Stainless steel (Base Deck), POM (Top Cap), Ultem (Inner Chamber)and PEEK (Insulator). It is with 45-degree angle posts and 3 air holes on each side (2mm in the middle and 1.5mm on the outside). It is suitable for any type of vape you want from RDL to DL. The deck includes dual gold plated brass positive post and a positive pin. Comes with bottom feeder pin.
Reload MTL RTA Clone $9.79
The Reload MTL RTA Clone is constructed from stainless steel (Body) and glass (Tank) in 22mm diameter. It has a 2ml juice capacity tank. The RTA supports top filling system and Bottom adjustable airflow.
Original VOOPOO ALPHA Zip 180W TC VW APV Box Mod + Maat Tank Kit $69.99
The VOOPOO ALPHA Zip Kit consists of the ALPHA Zip Box Mod and a Maat Sub Ohm Tank. It is powered by dual 18650 batteries (Not included) with 180W max output. Equipped with a brand new GENE. Chip, it becomes more powerful and more stable with 0.01s fire speed. The included Maat Tank adopts middle adjustable triple holes airflow design for smoother flavors. Plus the PNP design on coil, it is very simple and convenient to reload the coils. It is compatible with MT-M1, MT-M2 and MT-M3 coils for intensive and enhanced flavors. And the top filling design makes refilling much easier. What's more, multiple protections are applied for safe and stable vaping.
Kindbright 5-in-1 Shortfill Cap Opener Tool for Juice / E-Liquid Bottle $2.99
The Kindbright 5-in-1 Shortfill Cap Opener Tool Clone is made of Zinc alloy, it is convenient to open juice cap of 10ml, 60ml, 120ml, and most 23~24mm caps can be opened by Reewape 5-in-1 shortfill.
Original VOOPOO Find Trio Pod System Replacement Pod Cartridge $8.09
The VOOPOO Find Trio Pod Cartridge is designed especially for VOOPOO Find Trio Pod Kit. It has a 3ml juice capacity (Coil is not included). 4 PCS / Pack.
Original Aspire Nautilus Replacement Coil Head for Nautilus Mini/ Nautilus / Nautilus 2 / Nautilus 2S $7.99
The direct Aspire Nautilus 2S Replacement Coil Head is direct lung (DL) vaping sub-Ohm coil and it comes with the Aspire Nautilus Mini / Nautilus / Nautilus 2 / Nautilus 2S tank. 5 PCS / Pack.
Старый 12.09.2019, 04:53 Автор темы   449
3FVAPE
Original Aspire Odan Mini Sub Ohm Tank Vape Atomizer $29.99
The Aspire Odan Mini is a stylish sub-ohm vape tank, stylish design and diamond cutting technology make it look beautiful and refined. A unique Diamond Cut glass on the Odan Mini Tank is combined with a resolute Stainless Steel construction as well as an 810 Honeycomb Resin drip tip, provides stylish and durable style. The heat resistant construction of the resin material offers you a comfortable vaping experience. The polished stainless steel brings Odan Mini a strong metal texture and brightness as well as strong build quality. The machined design of the hardware ensures long use with smooth airflow adjustment. The tank a refined feel whilst the slide open top fill mechanism enables an easy refill which greatly reduces the chance of leakage. The self-sealing coil housing In the Odan Mini Tank means the user won't experience spit backs due to e-liquid being contained in the tank without interference from the chimney. The Odan Mini has a consistent extraction of flavor and is compatible with two separate coil types: a 0.2ohm mesh coil which heats a larger surface area resulting in clear taste and large clouds or a 0.3ohm mesh coil. All these colors consist of Stainless Steel with a toughened Pyrex Glass Tube. This vape tank is compatible with the large majority of mods due to its 510 connection point.
Original Aspire Odan Sub Ohm Tank Vape Atomizer $29.99
The Aspire Odan is a stylish sub-ohm vape tank, stylish design and diamond cutting technology make it look beautiful and refined. A unique Diamond Cut glass on the Odan Tank is combined with a resolute Stainless Steel construction as well as an 810 Honeycomb Resin drip tip, provides stylish and durable style. The heat resistant construction of the resin material offers you a comfortable vaping experience. The polished stainless steel brings Odan a strong metal texture and brightness as well as strong build quality. The machined design of the hardware ensures long use with smooth airflow adjustment. The tank a refined feel whilst the slide open top fill mechanism enables an easy refill which greatly reduces the chance of leakage. The self-sealing coil housing In the Odan Tank means the user won't experience spit backs due to e-liquid being contained in the tank without interference from the chimney. The Odan has a consistent extraction of flavor and is compatible with two separate coil types: a 0.2ohm mesh coil which heats a larger surface area resulting in clear taste and large clouds or a 0.3ohm mesh coil. All these colors consist of Stainless Steel with a toughened Pyrex Glass Tube. This vape tank is compatible with the large majority of mods due to its 510 connection point.
Original Nevoks Lusty 25W 1000mAh Pod System Starter Kit original price$34.90, now only$19.99
The Lusty Pod Kit is a compact and portable pod system kit. It is powered by 1000mAh built-in battery, which can meet the vaping needs of your whole day. With the advanced chipset, the Nevoks Lusty can automatically recognize the resistance and adjust the wattage to bring you optimal vaping. It features 3.3ml E-juice capacity, it will bring you a pure and smooth vaping flavor. It supports 12~25W output power with stable and high performance. With the adjustable airflow design, it can could provide you a better vaping experience.
Benctech Protective Storage Case Vape Bag E-cig Pouch Clone for E-Cigarette $5.99
The vapor case comes with great space yet small and easy carrying. You can put one set of your E-cig products in it. A good setup will be: E-cig devices, some DIY tool / accessories, batteries, and pod cartridges.
SXK 415 Replacement Drip Tip Clone original price$11.99, now only$8.99
The SXK 415 Replacement Drip Tip Clone is made of PEI and Stainless Steel. The outer diameter is 11mm and 17mm height.
Replacement 510 Drip Tip + Top Cap + Decorative Ring Kit for Haku Venna RDA Clone 6.99
This Top Cap Set are made of POM and suitable for Haku Venna RDA Clone. Tank Only, Atomizer not included.
Kaser KS High-End Replacement 510 Drip Tip Clone for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $4.59
The Kaser KS High-End 510 Drip Tip Clone is made of Stainless Steel and POM. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original SMOKTech SMOK RPM40 Pod Kit Replacement RBA Coil Head + Drip Tip Set $4.99
The SMOK RPM40 RBA 0.6ohm Replacement Coil is designed for the Smok RPM40 pod kit and the SMOK RPM RBA pod cartridge. In addition to all available coil options, the SMOK RPM RBA coil is replaceable, which means you don't have to discard the pod when the coil is near the end of its life. With the RPM40 RBA coil, you can enjoy DIY entertainment to the fullest. For example, a 0.6ohm coil can give you a lot of steam and a purer taste. You can also make high resistances of 1.0 ohms and 1.4 ohms by yourself, which can support coils with a minimum resistance of 0.25 ohms. In short, the special features of DIY meet the vaping needs of different users.
Original DOVPO Peaks Pod System Replacement Pod Cartridge with 1.4ohm Ceramic MTL Coil + 0.8ohm Mesh Coil original price$12.00, now only$8.99
The DOVPO Peaks Replacement Pod Cartridge is specially designed for DOVPO Peaks Kit. It comes 2ml E-juice capacity. It has a 2 types of coil a 1.4ohm Ceramic Coil for MTL and 0.8ohm Mesh Coil for DTL type of vaping. With the high quality, the coil has a Longer Life Span and has no burnt taste. They will bring you various vaping experience.
Старый 12.09.2019, 04:57 Автор темы   450
3FVAPE
Original Nevoks Lusty Pod System Replacement Pod Cartridge with 0.6ohm Mesh Coil + 1.4ohm Regular Coil original price$9.90, now only$4.99
The Nevoks Lusty Pod Cartridge is specially designed for Nevoks Lusty Pod Kit. Lusty Pod Cartridge is equipped with 3.3ml large e-juice capacity with side refill design. Lusty Pod Cartridge contains two kinds of coil: a 0.6ohm mesh coil and a 1.4ohm regular coil for your choice.
Original Nevoks Lusty Pod System Replacement Mesh Coil Head - 0.8ohm original price$16.90, now only$7.99
The Lusty Replacement Coil is specially designed for Nevoks Lusty AIO Pod Kit. They will bring you an excellent vaping experience. 5 PCS / Pack.
Original Nevoks Lusty Pod System Replacement Mesh Coil Head - 0.6ohm original price$16.90, now only$7.99
The Lusty Replacement Coil is specially designed for Nevoks Lusty AIO Pod Kit. The 0.6ohm Mesh Coil is fit for Sub-Ohm Vape. They will bring you an excellent vaping experience. 5 PCS / Pack.
Original Nevoks Lusty Pod System Replacement MTL Regular Coil Head original price$16.90, now only$7.99
The Lusty Replacement Coil is specially designed for Nevoks Lusty AIO Pod Kit. The Coil is compatible with MTL vaping. They will bring you an excellent vaping experience. 5 PCS / Pack.
Original Nevoks Lusty Pod System Replacement Ceramic Coil Head original price$19.90, now only$8.99
Старый 16.09.2019, 04:43 Автор темы   451
3FVAPE
Original Fumytech BDvape Pure BF Squonk Mechanical Box Mod $110.00
The BDvape Pure BF Squonk White Delrin Mod is powered by Single 18650 Battery(Not included). It is a mechanical mod whose tube for battery is equipped with small handle that makes you replace in convenience. Furthermore, the material of Pure Mod adopts original white Delrin and the T6 sandblasted aluminum which ensure its cozy gripping and lightweight. You can simply refill the oil via the top refilling system to avoid oil leakage. With the 510 connector plus an o-ring, it is compatible with 25mm BF atomizer perfectly.
Original Fumytech BDvape Pure MTL RDA $35.00
As a high-end division of Fumytech brand, the BDvape Pure MTL RDA is an innovative rebuildable tank with DIY coil. Moreover, the BDvape MTL Pure RDA comes with a new airflow design - Adjustable Airflow Flow System to bring smoother airflow and increased taste, and the airflow can be adjusted to your preference by rotating the atomizer tube. Plus the convenient filling system on the top, the BDvape MTL Pure RDA perfectly combines the MTL function together to meet your most vaping need. Compatible with BDvape Pure BF White Delrin MOD and BDvape Pure BF PEI version MOD.
Sine MTL RTA Clone $14.99
The Sine Dvarw Atty MTL RTA Clone is designed and built in the USA. It is constructed from 316 Stainless Steel (Body) and Polycarbonate (Tank) and with 4.2ml juice capacity. The MTL RTA supports bottom adjustable internal airflow control and easy top filling system.
Original SMOKTech SMOK NOVO 2 25W 800mAh Pod System Starter Kit $23.59
The Original SMOKTech Novo 2 Kit is the upgraded version of Novo, an advanced draw-activated device. The Novo 2 has been optimized from every detail which is a definitely mini and light device. Smaller than your palm, so it can be easily put into your pocket or bag.
Original OBS Land Pod System Replacement Pod Cartridge $8.79
The OBS Land Pod Cartridge is designed especially for OBS Land Pod Kit, coming with 1.5ml e-juice capacity. 3 PCS / Pack.
Original Hellvape A1 MTL Fused Clapton Heating Resistance Wire - 30GA + 38GA $4.99
The Hellvape A1 MTL Fused Clapton Heating Resistance Wire is perfect for RBA / RTA / RDA atomizers. The wire is made from A1 material. It features 30GA + 38GA gauge and 1.8ohm (Single) / 0.9ohm (Dual) resistance value per feet, which will be a good choice for DIY.
Original Hellvape Ni80 Dual Core Fused Clapton Heating Resistance Wire - 26GA x 2 + 36GA 3.99
The Hellvape Ni80 Dual Core Fused Clapton Heating Resistance Wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Ni80 material. It features 26GA x 2 + 36GA gauge and 0.36ohm (Single) / 0.18ohm (Dual) resistance value per feet, which will be a good choice for DIY.
Original Hellvape Ni80 Triple Core Fused Clapton Heating Resistance Wire - 28GA x 3 + 36GA $4.59
The Hellvape Ni80 Triple Core Fused Clapton Heating Resistance Wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Ni80 material. It features 28GA x 3 + 36GA gauge and 0.37ohm (Single) / 0.17ohm (Dual) resistance value per feet, which will be a good choice for DIY.
Original Hellvape Ni80 Quad Core Fused Clapton Heating Resistance Wire - 28GA x 4 + 36GA $4.99
The Hellvape Ni80 Triple Core Fused Clapton Heating Resistance Wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Ni80 material. It features 28GA x 4 + 36GA gauge and 0.28ohm (Single) / 0.14ohm (Dual) resistance value per feet, which will be a good choice for DIY.
Original Hellvape Ni80 MTL Dual Core Fused Clapton Heating Resistance Wire - 32GA x 2 + 38GA $3.99
The Hellvape Ni80 MTL Dual Core Fused Clapton Heating Resistance Wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Ni80 material. It features 32GA x 2 + 38GA gauge and 1.0ohm (Single) / 0.5ohm (Dual) resistance value per feet, which will be a good choice for DIY.
SXK Fire Button + Button Plate Set for SXK Bantam BB Mini Box Mod Kit original price$23.90, now only$18.99
This SXK replacement accessories set are suitable for SXK BB Bantam BB Mini box mod kit. This set includes Fire Button + Button Plate. Made from Stainless steel with silver plating
SXK Fire Button + Screen Plate + Button Plate Set for SXK BB 60W / 70W Box Mod Kit original price$23.90, now only$19.99
This SXK replacement accessories set are suitable for SXK BB Bantam BB 60W / 70W box mod kit. This set includes Fire SXK Button + Screen Plate + Button Plate Set. Made from Stainless steel with silver plating
Original Aspire Odan Mesh Coil for Aspire Odan / Odan Mini Sub Ohm Tank - 0.2ohm $10.99
The Aspire Odan 0.2ohm Mesh Coil is perfectly compatible with Aspire Odan and Odan Mini Sub Ohm Tank. 3 PCS / Pack.
Original Aspire Odan Mesh Coil for Aspire Odan / Odan Mini Sub Ohm Tank - 0.3ohm $10.99
Старый 17.09.2019, 04:41 Автор темы   452
3FVAPE
Original GeekVape AEGIS 100W TC VW Variable Wattage Squonk Box Mod $72.00
The GeekVape Aegis Squonk Box Mod is equipped with advanced AS-100 Chipset and features with rapid and responsive firing times, allowing the use of atomizers with a resistance as low as 0.05ohm and identifying any attached atomizers accurately. The mod is powered by single 18650 battery (Not included). The mod has 5 types of modes: Power / VPC / TC / TCR / Bypass to meet your different demands. The mod is constructed from plastic, silicone, stainless steel, and zinc alloy material. Comes with protective silicone and rubberized corners, the Aegis Squonker maintains IP67 shockproof, waterproof and dustproof features.
SXK Haku Xeta Inside RBA Rebuildable Atomizer Clone for Billet Box Mod Kit $23.90
he SXK Haku Xeta X eta RBA Clone is constructed from 316 stainless steel and ultem. This RBA consists 510 chimney section (SS), airdraw insert, middle top cap (SS and Ultem), elevating coil clamp system, airflow disk, wick channel controller pin, and air intake. It is suitable for BB Box Mod Kit.
Original Vzone Scado 500mAh Pod System Starter Kit $36.90
The Vzone Scado is a compact pod device which is made from zinc alloy with food grade PC material. It consists of Scado Battery and Scado Pod. It is powered by a built-in 500mAh battery. It has 3ml e-juice capacity. It features 4 optional power levels to satisfy your different vaping needs. The large 0.91 inch OLED display shows the parameters of the device clearly. And it comes with 1.2ohm long-lasting ceramic coil for massive clouds and purer taste. Compatible with high nicotine and nicotine salt e-juice, it is a perfect choice for nicotine salts e-juice lovers.
Original Hellvape GRIMM 30W 1200mAh VW Mod Pod System Starter Kit $56.99
The Hellvape GRIMM Pod Kit is a collaboration between Hellvape and Grimm Green and Ohm Boy. The Hellvape Grimm 30W Pod System is powered by an internal 1200mAh rechargeable battery. It is equipped with a bright OLED display screen for showing the detailed vaping data clearly and bringing you convenient operation. Made from zinc-alloy and PCTG materials, the GRIMM Pod System is moderately impact-resistant, preventing scratch from damaging the box mod. With the refillable 2ml Pod and GRIMM Coil Series, 0.7ohm Mesh coil and 1.2ohm regular coil.
Original Ultroner Oner 12W 380mAh Pod System Starter Kit $89.90
The Ultroner Oner 12W 380mAh Pod Kit is constructed from Stainless Steel and Stabilized Wood, which comes with a 2ml juice capacity refillable pod and a 1.5ohm ceramic coil to meet your daily vaping demand. The pod kit is powered by a built-in 380mAh battery. The wattage range is from 5W to 12W.
Original Efest iMate R4 Intelligent QC Charger for 17650, 17670, 18350, 18490, 18500, 18650, 20700, 26500 Battery $24.99
The Efest iMate R4 Intelligent QC Charger is an affordable and accurate battery charger that can charge up to four batteries simultaneously, safely and securely. Formed from durable and flame retardent PC materials, the Efest iMate R4 Intelligent QC Charger is designed to deliver a consistent charge at a rapid pace to batteries within the bays. Auto-detecting the type of battery, the iMate Battery Charger will regulate and control the amount and speed the battery can charge, preventing overcharging with the auto-cut off feature, further maintaining the life of the battery cell. Able to accept a myriad of battery cells of differing sizes, the iMate will intelligently auto detect the type of battery and size and relay the estimated charging time on the display screen. Batteries are not included
Original Efest iMate R2 Intelligent QC Charger for 17650, 17670, 18350, 18490, 18500, 18650, 20700, 26500 Battery $17.99
The Efest iMate R2 Intelligent QC Charger is a durable flame retardant dual bay battery charger, incorporating nifty features like intelligent charging and monitoring, accurate display and consistent charging, and comes with a slew of protections and safeties to charge with a peace of mind. Batteries are not included
Старый 17.09.2019, 04:45 Автор темы   453
3FVAPE
Original Efest Lush Q2 Intelligent LED Charger for 17650, 17670, 18350, 18490, 18500, 18650, 20700 Battery - EU Plug 17.99
The Efest Lush Q2 Intelligent LED Charger offers a quick way to recharge your batteries. Utilizing the smart shut off function, when your batteries reach 4.2 volts they will not exceed. This charger has two independently monitored channels, ensuring the most fulfilled lifespan for your batteries. Batteries are not included
Original Efest Lush Q2 Intelligent LED Charger for 17650, 17670, 18350, 18490, 18500, 18650, 20700 Battery - US Plug $17.99
Original Golisi Needle 2 Smart USB Charger for Li-ion 18650 / 21700 / 26650 / Ni-Mh / Ni-Cd / AAA / AA Battery $7.85
The Golisi Needle 2 USB Charger is a compact charger with 2 slots. It has a USB power port for 1A charging. And it's compatible with almost all types of cylinder-shaped rechargeable batteries. You can charge two batteries at the same time. Batteries are not included
Original Nitecore UMS2 USB Charger for 10440, 14500, 14650, 16500, 1634(RCR123), 18350, 18490, 18500, 18650 Battery $23.99
The Nitecore UMS2 is an intelligent USB 2-slot superb battery charger. Nitecore UMS2 has QC input function which enables a total max output of 4000mAh and a single slot max output of 3000mAh. And Nitecore UMS2 is widely compatible with almost all IMR / Li-ion / LiFePO4 batteries. Equipped with the great LCD display, the Nitecore UMS2 provides real-time charging information for better charging process. According to the battery type and capacity, UMS2 will automatically select between three charging modes (CC, CV and -dV / dt). Batteries are not included
Original Nitecore UMS4 USB Charger for 10440, 14500, 14650, 16500, 1634(RCR123), 18350, 18490, 18500, 18650 Battery $33.99
The Nitecore UMS4 is the newly designed smart charger with 4 battery slots. With the innovative LCD screen display, the Nitecore UMS4 can provide real-time charging information for better charing process. Nitecore UMS4 features QC input function which enables a total max output of 4000mAh and a single slot max output of 3000mAh. And the Nitecore UMS4 charger is not just compatible with 20700, 26650, 18650 Li-ion batteries but nearly all cylinder shaped rechargeable batteries, even charging different batteries at the same time. Batteries are not included
Original Vandy Vape Superfine Ni80 MTL Fused Clapton Heating Wire Coil for RDA / RTA / RDTA $3.09
The Vandy Vape Superfine MTL Fused Clapton Coil is made of Ni80 material. Coil jig is included. It could bring you better flavor. Just get it for your RDA / RTA / RDTA and enjoy DIY fun. 10 PCS / Bottle.
Original Ultroner Oner Pod System Replacement Pod Cartridge $11.90
The Ultroner Oner Pod Cartridge is designed especially for Oner Pod Kit, coming with 2ml e-juice capacity. 3 PCS / Pack.
Original Vzone Scado Pod System Replacement Pod Cartridge $10.79
The Vzone Scado Replacement Pod Cartridge is designed for Vzone Scado pod kit. It comes with 3ml capacity and is perfectly compatible with nicotine salts. 3 PCS / Pack.
Старый 18.09.2019, 04:38 Автор темы   454
3FVAPE
Original Yocan UNI Pro 650mAh VV Box Mod $14.99
The Yocan UNI Pro Box Mod is the upgraded version of Yocan UNI that features universal compatibility with all oil atomizers at all length and size. The Yocan UNI Pro Mod is incredibly the world's first Mod that is universal for any type of oil cartridge. The Patented universal width and height-adjustable Box Mod that will work with all kinds of oil atomizers. fully bring customization and personalization to the next level. The UNI Pro built-in with height slide matching all styles of oil atomizers, don't have to worry the atomizer is too tall or too short, the UNI Pro will let you adjust the height to any oil atomizers. The UNI Pro Mod is powered by an internal 650mAh battery and an OLED display for a stable vaping experience. UNI Pro also built-in various working voltage adjustable from 2.0V to 4.2V, simply press the " right " or " left " button to achieve your desired voltage accurate to 0.1V difference. The 10s warm-up feature warms up your oils before first use.
SXK Le S-Tank RDL RTA Clone $17.90
The SXK Le S-Tank RDL RTA Clone, a single coil RTA, which is constructed form 316 Stainless Steel in 22mm Diameter, coming with a 3.5ml juice capacity tank. The RTA is equipped with single coil building, supports bottom airflow control and top refilling system, it can provide you a very smooth draw and a perfect RDL vape.
SXK Lord MTL RTA Clone $21.90
The SXK Lord MTL RTA Clone is constructed from Stainless Steel material in 22mm Diameter. The RTA supports mouth to lung (MTL) vape. The lateral airflow and interal chamber in peek for a single coil flavor, and excellent aromatic airflow as for any RDA but with tank comfort. The Simple and intuitive post-less deck, external airflow control that allows you to find your favorite airflow simply by choosing one of the multiple combinations of holes. The AFC removable without disassembling the RTA, this allows to customize it at any time.
Original Sikary Epipa 900mAh Vape Pipe Pod System Starter Kit $25.99
The Sikary Epipa vape pod system is shaped in a tobacco pipe, making your vaping in a nostalgic way. The vape pod kit is powered by 900mAh built-in battery and 2ml juice capacity free you from the low power a while vaping. A spare pod is included in the package, allowing you to replace a new one after a period of use.
Original Innokin I.O 310mAh Pod System AIO Starter Kit $11.99
The Innokin I.O. Pod System is a small discreet handheld vaping pod system, implementing an integrated 310mAh rechargeable battery, stainless steel chassis construction, and is equipped with a refillable 0.8ml pod geared for nicotine salts or freebase E-Juice, and a Ceramic 1.4ohm coil, Kanthal 1.4ohm coil for your daily vaping experience. Consisting of superior stainless steel, the Innokin I.O. Pod System sports a luxurious and compact silhouette that fits in the palm of the hand. Outputting with a draw-activated firing mechanism, the Innokin I.O. Pod System is free of buttons, keeping the exterior sleek and freely preserved. Furthermore, the chassis of the Innokin I.O. Pod System is lightweight and durable, protecting the prorpietary chipset inside.
Original Sikary Epipa Pod System Replacement Pod Cartridge with 1.5ohm Coil $4.99
The Sikary Epipa Replacement Pod is designed for Sikary Epipa Pod System Kit. The pod comes with 1.7ml juice capacity and 1.5ohm coil resistance. 2 PCS / Pack.
Original Innokin I.O Pod System Replacement Pod Cartridge with 1.4ohm KAL Coil $5.59
The I.O Pod Cartridge is designed especially for the Innokin I.O Pod Kit, coming with 0.8ml e-juice capacity and 1.4ohm KAL coil resistance. 3 PCS / Pack.
Original Innokin I.O Pod System Replacement Pod Cartridge with 1.4ohm Ceramic Coil 5.99
The I.O Pod Cartridge is designed especially for the Innokin I.O Pod Kit, coming with 0.8ml e-juice capacity and 1.4ohm Ceramic coil resistance. 3 PCS / Pack.
Original Voopoo PnP-M1 DL Single Mesh Coil for Finic P18 Aio, Drag Baby Trio, Find S Trio $12.99
The Voopoo PnP-M1 DL Single Mesh Coil Head is designed for Finic P18 Aio, Drag Baby Trio, Find S Trio. It has 0.45ohm resistance, and the wattage range from 28W to 35W. 5 PCS / Pack.
Original Voopoo PnP-VM1 DL Single Mesh Coil Head for VINCI Mod Pod $12.99
The Voopoo PnP-VM1 DL Single Mesh Coil Head is designed for VINCI, It has 0.3ohm resistance, and the wattage range from 32W to 40W. 5 PCS / Pack.
Старый 19.09.2019, 05:01 Автор темы   455
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Ambition Mods Purity MTL RTA $42.99
The Ambition Mods presents the Purity Rebuildable Tank Atomizer, a compact single coil mouth to lung (MTL) RTA. The Purity RTA is constructed from 316 Stainless Steel (Body) and Glass (Tank), it features a dual post single terminal build deck and dual adjustable airflow slots located at the bottom of the RTA which siphons air up through the bottom of the build deck. With a stainless steel finish, users can match their mods perfectly. For user customization, an added juice flow control ring is provided which helps create the perfect vaping experience.
Original IJOY Mipo Pod System 7.5W 190mAh Starter Kit original price$34.99, now only$25.99
The IJOY Mipo Pod System Starter Kit is powered by 190mAh built-in battery. The Mipo Pod Kit comes with a new charging box to charge your device. The 1000mAh charging box can charge the Mipo Pod Kit about five times, which is very portable and user-friendly. The pod kit includes three cassettes with different coil resistances, and an innovative air-activated pod system to meet different atomization requirements. You can also place 3 extra boxes in the charging case if you want to switch flavors or just as a backup.
Original Augvape Narada Vape Pod System 1100mAh Box Mod Starter Kit original price$50.99, now only$35.99
The Augvape Narada Pod System Box Mod Starter Kit is constructed from zinc alloy materials and compact design which has durable quality and portable features. It inherits the aesthetics of minimalist from druga foxy mod. No screen, no airflow control ring on the main body and no other buttons except fire button. Powered by a massive 1100mAh battery with long life span which can vape 4.3ml e-juice. Implementing most advanced 2.4A quick charging technology, it only takes 25mins to reach 80% power. Besides, the innovative USB-C lanyard enable to work as a USB-C cable as well. Moreover, the big fire button design has the same shapes as the main body which makes it ultra-comfortable to hold in hand and perfect position to fire. There are two types of pods for your selections, with 0.5ohm 316 SS coil head and 0.6ohm Kanthal mesh coil. And the optional RBA deck for MTL vapers. Thus it is also possible to attach your own windings, and to achieve an MTL vaping experience. Portable, Strong power, Quick-charging, Better flavor, Augvape Narada will meet your diverse vaping demands.
Original asMODus Pavinno Wing 20W 720mAh TC Pod System Starter Kit original price$34.99, now only$29.99
The Pavinno Wing pod system kit, the palms, and pockets are comfortably fitted in soft faux leather with a herringbone LED battery status indicator, allowing users to easily determine when Pavinno Wing needs to be recharged.
Original Uwell Caliburn KOKO 11W 520mAh Pod System Box Mod Starter Kit $23.99
The Caliburn KOKO Pod Kit is a compact and portable system kit which is the sister series of Uwell Caliburn. It comes with 520mAh built-in battery and 2ml top-fill pod cartridge. It is made of Aluminum Alloy and PCTG, compact and durable, the look looks refined. It uses the attached chain to release your hands and pockets to suit your daily travel or good vaping in different situations. The appearance of the product adopts exposure and development technology, which better reflects the metal texture of the product. The coil inside the pod has a resistance of 1.4ohm and the parallel coil design can fully atomize the e-liquid which will bring you better flavor. It is also compatible with the caliburn pod Cartridge. What's more, it optimizes the chip and circuit design, and strengthens the protection of testing and electrical components.
Original Acrohm Fush Nano 10W 550mAh Pod System Starter Kit original price$39.99, now only$29.99
The Acrohm Fush Nano Pod System Kit maintains airflow control 7W for throat hit and button switch 10W for bigger vapor. The Acrohm Fush Nano Pod Kit adopts shaking to change its colors. It is powered by built-in 550mAh battery to support MTL to DTL vaping and comes with 1.5ml capacity and 1.4ohm coil resistance. And Acrohm Fush Nano pod cartridge features top filling design without leakage and Rotate 180 degrees left or righy to looser or tighter draw.
Original asMODus Pavinno Wing Pod System Replacement Pod Cartridge with 1.2ohm Ceramic Coil $9.99
The Pavinno Wing Pod System Replacement Pod Cartridge is designed especially for use with the Pavinno Wing Pod Kit. It can provide an amazing taste and have a longer life than traditional pod system replacement cartridges. Pavinno Wing Pods are tailored for a comfortable fit during use with a tapered mouthpiece to bring maximized comfort. In addition to extending the overall life of the pod, this relatively high resistance also makes the Pavinno Wing pod system the perfect choice for anyone looking for a compact vape for thick oil fluids. Each pod offers a gold plated magnetic connection for enhanced conductivity and quality. Each pod holds approximately 2.5ml of e-liquid. 2 PCS / Pack.
Старый 19.09.2019, 05:11 Автор темы   456
3FVAPE
Original asMODus Pavinno Wing Pod System Replacement Pod Cartridge with Mesh Coil $9.99
Original Uwell Caliburn KOKO Pod System Replacement Pod Cartridge with 1.4ohm Coil 9.99
The Caliburn KOKO Pod Cartridge is designed for Uwell Caliburn KOKO Pod Kit. It has 2ml e-juice capacity. With the top filling system, it is easy to refill the pod. The coil inside the pod has a resistance of 1.4ohm and the parallel coil design can fully atomize the e-liquid which will bring you better flavor. 4 PCS / Pack.
Original Ambition Mods Multi-function MTL PC Drip Tip Mouthpiece + Stainless Steel 510 Base(No Polished) $15.99
The Multi-function MTL Drip Tip (No Polished) is made of PC (Mouthpiece) and Stainless Steel (510 Base). The set includes two short type mouthpieces (Height: 13mm; Outer Diameter: 8.5mm; Inner Diameter: 3.5mm), two long type mouthpieces (Height: 23mm; Outer Diameter: 8.5mm; Inner Diameter: 3mm) and a 510 Base (Height: 6.5mm; Outer Diameter: 11mm).
Original Ambition Mods Multi-function MTL PC Drip Tip Mouthpiece + Stainless Steel 510 Base(Polished) $19.99
The Multi-function MTL Drip Tip (Polished) is made of PC (Mouthpiece) and Stainless Steel (510 Base). The set includes two short type mouthpieces (Height: 13mm; Outer Diameter: 8.5mm; Inner Diameter: 3.5mm), two long type mouthpieces (Height: 23mm; Outer Diameter: 8.5mm; Inner Diameter: 3mm) and a 510 Base (Height: 6.5mm; Outer Diameter: 11mm).
Original Ambition Mods Purity MTL RTA Replacement Tank Tube $3.99
The Ambition Mods Purity MTL RTA Replacement Glass Tank Tube features 2ml juice capacity. The glass tank tube is the especially designed for The Ambition Mods Purity MTL RTA.
3FVAPE вне форума   Вверх
Старый 20.09.2019, 04:40 Автор темы   457
3FVAPE
Original ThinkVape Thor 200W TC VW APV Box Mod original price$34.99, now only$24.99
The ThinkVape Thor 200W TC VW APV Box Mod is constructed from ABS material and is powered by dual 18650 batteries (Not included). The APV Box Mod is equipped with ST200 Chip, it supports 200W maxium wattage, and it supports temperature control function to meet your different vaping experience. There are four working modes: VW / VT (Ni / Ti / SS) / TCR / Bypass to meet your different demands. With 0.96 inch OLED for easy operation, you can see clearly the state of your box mod.
Original Hellvape Fat Rabbit Sub Ohm Tank Clearomizer original price$33.99, now only$27.50
The Hellvape Fat Rabbit Sub Ohm Tank is constructed from stainless steel (body) and glass (tank), presenting a myriad of specialized Mesh and Quad OCC Coils, with 5ml maximum juice capacity tank, and it supports top refilling and bottom airflow control system.
Original Wotofo STNG MTL RDA original price$34.99, now only$24.99
The Wotofo STNG MTL RDA is constructed from stainless steel material in 22mm diameter.The STNG MTL RDA features a droplet shaped air control design on its top cap. This amazing and classic design allows users to set their favorite airflow as freely as possible. The droplet air inlet resides on only one side of the top cap, so do put that side onto the deck side with air hole on. The spring-loaded post clamps are T-shaped to give convenient mounting for different coil directions. No need to remove the screws when installing coil, just loosening the screws a little will do. The coil is secured by top mounted Phillip screws on two sides, positioned right above the air supply holes. On entering the single-sided air inlet, the air is pulled into the center of the deck bottom and redirected into two air channels that are right underneath the coil spot, supplying double airflows right onto the coil. Such air splitting system provides soft and optimal vaporization. The narrow looking drip tiappears pretty nice with the overall design of this rebuildable dripping atomizer. The drip tip features 510 connection to meet the market standard. It fits into your mouth perfectly when doing mouth-to-lung (MTL) inhales. It's made to let you enjoy your thick and rich draws of nicotine hitsmouth to lung.
Original ThinkVape ZETA AIO 60W VW Box Mod Pod System Starter Kit original price$59.90, now only$49.90
The ThinkVape ZETA replacement pod Cartridge is constructed from Food Grade PCTG material. The ThinkVape ZETA Pod Kit is powered by single 18650 batteries (No included), it delivers a maximum output of 60W, along with three modes available to choose, including Power / Bypass / NI / SS. The pod cartridge of ZETA Pod Kit comes with 3ml e-liquid capacity and multiple coils for your different demand. And it also supports RBA coil for DIY lovers. (RBA Coil not included)
Original Ambition Mods Purity MTL RTA Replacement Drip Tip $5.59
The Ambition Mods Purity MTL RTA Replacement Drip Tip is made of PC and it is suitable for Purity MTL RTA.
Original GeekVape Replacement Skeleton Panel for GeekVape Aegis Squonker Mod / Squonker Kit original price$8.40, now only$6.99
The GeekVape Replacement Skeleton Panel is made of Zinc Alloy, Plastic, and Silicone material. It is designed especially for GeekVape Aegis Squonker Box Mod and Squonker Mod Kit, The GeekVape Replacement Skeleton is a spar part to change your Aegis Squonker Mod to a regular Mod. The Aegis Squonker Skeleton is easy to install and replace.
Original Hellvape H7-02 Replacement Single Mesh Coil Head for Fat Rabbit Sub-Ohm Tank Atomizer original price$14.95, now only$9.99
The Hellvape H7-02 Replacement Single Mesh Coil Head is designed especially for Fat Rabbit Sub-Ohm Tank Atomizer and the resistance of this coil is 0.2ohm. 3 PCS / Pack.
Original Hellvape H7-03 Replacement Quad OCC Coil Head for Fat Rabbit Sub-Ohm Tank Atomizer original price$14.95, now only$9.99
The Hellvape H7-03 Replacement Quad OCC Coil Head is designed especially for Fat Rabbit Sub-Ohm Tank Atomizer and the resistance of this coil is 0.15ohm. 3 PCS / Pack.
Original ThinkVape ZETA AIO Pod Kit Pod Cartridge original price$14.90, now only$7.99
The ThinkVape ZETA AIO Pod Cartridge is made of food grade PCTG. It comes with 3ml juice capacity, a 0.5ohm pre-filled Mesh Coil and a 1.0ohm Regular DC Coil. The Pod is designed for the Think Vape ZETA AIO 60W Pod Kit, and is equipped with bottom airflow adjustable system which is bound to meet the needs of customers and to bring a stunning vaping experience.
Original ThinkVape ZETA AIO Pod Kit Replacement RBA Single Coil Head original price$13.90, now only$6.99
The ThinkVape ZETA AIO RBA Coil comes with the simple post deck. Plus the easy and safe rebuildable design, the ZETA AIO RBA Coil will be the best choice of DIY fans. It is designed for Think Vape ZETA AIO Kit and Think Vape ZETA AIO Pod.
Старый 20.09.2019, 12:19   458
Сколько труда и материалов истрачено на эту дрянь!
Tankist_20 вне форума   Вверх
Старый 21.09.2019, 04:41 Автор темы   459
3FVAPE
Original Eleaf iStick T80 80W 3000mAh VW Battery Box Mod $28.90
The Eleaf iStick T80 Mod is compact mod, stylish and simple appearance, small size and easy to carry in every occasion. The Eleaf iStick T80 Mod features a large 3000mAh built-in battery which is available for your Eleaf iStick T80 kit(with Pesso / with MELO 4 D25). There are several VW Modes to adjust to meet different vaping demands (Ni, Ti, SS, TCR-M1 / M2 / M3 Mode). And charging via the Type-C port for a stable and long-lasting vaping experience. The Eleaf iStick T80 Mod has a 2A charging current, and plugging into the USB Type-c port results in a larger charging current, which means less charging time. In addition, the Eleaf iStick T80 can transmit up to 80W of power and various working modes while supporting short circuit protection and low voltage protection to provide you with safe vaping.
Original Eleaf Pesso Sub Ohm Tank Atomizer Clearomizer $20.90
The Pesso Tank is constructed from stainless steel (body)and glass (tank), it comes with 2ml / 5ml large E-juice capacity. It is designed with smart child-lock design for childs security. With the easy top filling design and adjustable bottom airflow system, it will bring you larger cloud of vapor. It compatible with both e-liquid and nicotine salt, bringing smooth taste and optimal flavor. With the EF-M 0.6ohm Coil and the EF 0.3ohm Coil, it will provide you different and intense vaping experience.
Original Footoon Aqua Pro RTA $8.99
The Footoon Aqua Pro RTA is made from stainless steel (body) and pc (tank tube). It comes with 22mm diameter and 2ml or 4ml juice capacity. The RTA supports dual coil and single coil use, bottom airflow control system, bottom spin lock system, and juice boost system. Also, it is equipped with water proof juice tank.
Origianl Eleaf iStick T80 80W 3000mAh VW Battery Box Mod with MELO 4 D25 Tank Kit $42.40
The Eleaf iStick T80 Box Mod Tank Kit consists of the iStick T80 Battery and MELO 4 D25 Tank. It is powered by 3000mAh built-in battery with 80W max output and supports long time vaping. And it supports charging via an easy-to-access USB Type-C port. Multiple protections are also applied to guarantee a safe and stable vaping experience. The MELO 4 D25 Tank comes with 4.5ml large e-juice capacity. The retractable top fill system makes it really easy to fill the tank. The dual large air inlets allow optimal airflow for great vapor production.
Original Eleaf iStick T80 80W 3000mAh VW Battery Box Mod with Pesso Tank Kit $44.71
The Eleaf iStick T80 Vape Kit consists of the iStick T80 Battery and a Pesso atomizer. It is powered by built-in 3000mAh battery, which can fire up to the max output of 80W. With the oversized fire button on the side, which is easy to operate. It also has large an intelligent screen to display the vaping data clearly. The include Pesso atomizer features 5ml and 2ml e-juice capacity for your options. It adopts easy top filling design and adjustable bottom airflow system to bring you larger cloud of vapor. It compatible with both E-liquid and nicotine salt, bringing smooth taste and optimal flavor. It adopts the all-new EF coils for huge clouds and intense flavor. With multiple protections.
Original Vapefly Brunhilde MTL RTA Replacement Short 510 Drip Tip $3.99
The Vapefly Brunhilde Replacement Drip Tip is made of delrin and stainless steel, it is designed for Vapefly Brunhilde MTL RTA Rebuildable Tank Atomizer.
Original Vapefly Brunhilde MTL RTA Replacement Short 510 Drip Tip with Cooling Fin $3.99
Original Vapefly Brunhilde MTL RTA Replacement Long 510 Drip Tip with Cooling Fin 5.99
The Vapefly Brunhilde Replacement Drip Tip is made of resin and stainless steel, it is designed for Vapefly Brunhilde MTL RTA Rebuildable Tank Atomizer.
Original Vapefly Brunhilde MTL RTA Replacement Short Drip Tip + Long Drip Tip + Tank Tube $9.99
The Vapefly Brunhilde replacement drip tip is made of PMMA and Stainless Steel, and tank tube is made of PMMA. It is designed for Vapefly Brunhilde MTL RTA Rebuildable Tank Atomizer.
Original Myuz Hadar Organic Cotton for RBA / RDA / RTA / RDTA Atomizer(3 PCS) $0.99
The Myuz Hadar Cotton is designed for the Myuz Hadar RDA and it is also suitable for other RBA / RDA / RTA / RDTA Atomizer. 3 PCS / Pack.
Original Myuz Hadar Kanthal Clapton Heating Resistance Wire Coil for Hadar RDA(2 PCS) $1.99
The Myuz Hadar Wire Coil is especially designed for the Myuz Hadar RDA. The resistance of this coil is 0.3ohm. 2 PCS / Pack.
Original Vandy Vape SS316L Twisted Clapton Heating Resistance Wire for RBA / RTA $4.99
The Vandy Vape SS316L Twisted Clapton Heating Resistance Wire is perfect for RBA / RTA / RDA atomizers. The wire is made of 316L stainless steel. It features 28GA x 2 + 30GA gauge and 1.7ohm resistance value per feet, which will be a good choice for DIY.
Original YouDe UD SS316L Clapton Heating Resistance Wire for RBA / RTA / RDA $3.89
The YouDe UD SS316L Clapton Heating Resistance Wire is perfect for RBA / RTA / RDA atomizers. The wire is made of 316L stainless steel. It features 26GA + 30GA gauge, which will be a good choice for DIY.
Original Eleaf EF Replacement Coil Head for Eleaf Pesso Tank(3 PCS) $6.74
The Eleaf EF Coil is designed for Eleaf Pesso Tank. The resistance of this coil is 0.3ohm power ratings range from 30 to 60W. 3 PCS / Pack.
Original Eleaf EF-M Replacement Coil Head for Eleaf Pesso Tank(3 PCS) $5.99
The Eleaf EF Coil is designed for Eleaf Pesso Tank. The resistance of this coil is 0.6ohm power ratings range from 18 to 35W. 3 PCS / Pack.
Старый 24.09.2019, 04:44 Автор темы   460
3FVAPE
Original DOVPO Topside Dual Carbon 200W YIHI Chip TC VW Squonk Box Mod original price$169.99, now only$149.89
The DOVPO Topside Dual Carbon Squonk Mod is constructed from aluminum alloy, carbon fiber, zinc alloy and stainless steel material, which is the updated version of the innovative DOVPO Topside Squonk Mod that is wrapped by new carbon material to present you ingenious design with lightweight and the cozy sense of gripping. Most importantly, with external dual 18650 batteries (Not included) powered by new YIHI chip, the Topside Dual Carbon Squonk Mod can fire up to the 200W output power with VW / TC mode and throw you impeccable and accurate working. The Dual Carbon Squonk Mod also comes with 0.96 inch screen and 10ml large e-juice silicone bottle with easy top filling design, which brings you longer vaping and effective oil leakage resistance.
Original Footoon Aqua Master RDA original price$33.99, now only$25.99
The Aqua Master RDA is constructed from stainless steel in 24mm diameter. The Aqua Master RDA supports adjustable airflow system that drives the flavor richer and better and creates massive clouds as well. Besides, it comes with innovative building deck and compatible with both Mesh and Kanthal coil to provides outstanding flavor.
Fatality M25 RTA Clone $17.99
The Fatality M25 RTA Clone is constructed from stainless steel in 25mm diameter, comes with 2 glass tanks (4ml / 5.5ml). The Fatality M25 RTA Clone is with side terminal postless deck design supports Dual or single coil building. The RTA is with reduces airflow to increases flavor. The FTL M25 style RTA is with clip top cap for conveniently filling. It is very convenient to replace cotton or Coils without emptying your juice.
Original Goforvape Eternal RDA $23.99
The Goforvape Eternal RDA is constructed from stainless steel in 25mm diameter. The RDA features four different airflow patterns to suit everyone's vaping needs. If the RDA is fully adjustable airflow, it will produce a more flavorful vaping experience. The RDA features vertical coil installation with unique U shaped deck for easy to building and the best flavor. What's more, the RDA is designed for dripping and squonking with a bottom juice return.
Original Hugo Vapor Kylin 30W VW Box Mod Pod Kit original price$49.95, now only$40.99
The Hugo Vapor Kylin 30W Pod System Box Mod Kit is a portable vaping pod system implementing a large 1000mAh rechargeable battery, magnetized chassis panels, and uses a 0.6ohm or 1.2ohm specialized refillable pod with nonreplaceable coil. The Kylin 30W Pod System Box Mod Kit is constructed from durable aluminium alloy, offering a strong and dependable chassis making it lightweight and portable as well. In addition, the magnetized panels are made of lightweight PC materials and are covered in visually striking artistic finish, facilitating easy removal while leaving cut outs for a juice level viewing window, nonadjustable airflow slotting, and a 0.49" OLED Display screen to relay critical vaping information such as ohms, voltage, or output levels.
Original SMOKTech SMOK NOVO 2 25W 800mAh Pod Kit $23.59
The Original SMOKTech Novo 2 Kit is the upgraded version of Novo, an advanced draw-activated device. The Novo 2 has been optimized from every detail which is a definitely mini and light device. Smaller than your palm, so it can be easily put into your pocket or bag. You can take it anywhere! Novo 2 follows the design style of its first generation, with a curved body, it allows you to grip comfortably. And whistle-shaped mouthpiece can perfectly fit your lips. It definitely is the representative product of the electronic cigarette industry. With built-in 800mAh battery, longer vaping time is assured. Newly added air-intake grooves on both sides can bring more air in, combining with specially designed pods, cloudy vapor and purer taste can be produced. Also, it has redesigned sensing element to make you enjoy every puff, improved LED indicator to clearly show you accurate devices condition.
Original THC Thunderhead Creations Tauren X 25W 1000mAh Mesh Pod System VW Box Mod Kit original price$49.00, now only$39.99
The Tauren X Pod Kit is constructed from Aluminium Alloy (Box Mod) and PCTG (Pod Cartridge), which is powered by an internal 1000mAh battery. The Tauren X Pod Kit supports 25W max output power for long lasting vaping. It comes with a 2ml juice capacity pod cartridge and two mesh coils: 0.6ohm mesh coil and 1.0ohm mesh coil. Vaping data details is visible through the 0.42 inch OLED screen.
Original THC Thunderhead Creations Tauren X 25W 1000mAh RBA Pod System VW Box Mod Kit original price$59.00, now only$46.99
The Tauren X Pod Kit is constructed from Aluminium Alloy (Box Mod) and PCTG (Pod Cartridge), which is powered by an internal 1000mAh battery. The Tauren X Pod Kit supports 25W max output power for long lasting vaping. It comes with a 2ml juice capacity pod cartridge. Vaping data details is visible through the 0.42 inch OLED screen. The build deck of RBA is very easy for building and adjustable airflow will bring you purer flavor.
Время генерации страницы 0.75890 секунды с 15 запросами
