Просмотров в теме 302474   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 12.08.2019, 05:01 Автор темы   421
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Vapefly German 103 Brunhilde MTL RTA $54.99
The Vapefly Brunhilde MTL RTA is designed and created by a top coiler MTL RTA manufacturer German 103 and Vapefly.The Vapefly Brunhilde RTA is constructed from stainless steel with 5ml e-juice capacity that big capacity meets you all day vaping. The 6 levels airflow can meet your different airflow control needs and the bottom airflow and easy single coil building design will bring you fabulous flavour. The wire of this RTA is made of premium stainless steel wire from Germany which will convenient the e-juice transfer. The 3.2mm (outer diameter) refilling port matches perfectly with the Chubby Gorilla V3.
KF lite MTL RTA Clon with PC Top Cap Tank $12.99
The KF lite RTA Clone is a 22mm diameter rebuildable tank atomizer with 2ml of juice capacity. It is made of 316 stainless steel and PEI material. It is designed for MTL vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience.
Original Dovpo Peaks Vape Pod System Starter Kit original price$37.99, now only$28.99
The Dovpo Peaks is a unique designed flip-cover pod system that is constructed from Zinc-Alloy and PCTG, which is aesthetically pleasing with the metal feel and fine print finish. The pod kit features built-in 650mAh battery and a Type-C USB port that charges in 5V~650mA. It will bring you a stable and lasting vaping experience. What's more, there are available in 2 types of power output for the Peaks, level 1 with 8 watts and level 2 with 15 watts to control which power you're comfortable with. The PCTG material top refillable pod has a 2ml E-liquid capacity that enables to last you a day and has a window to check your liquid level inside your pod. Besides, there are two types of coils for your selections, with 1.4ohm ceramic coil for MTL and 0.8ohm mesh coil for DTL type of vaping. Both of them are high performance with a longer life span before it has a burnt taste.
Original SMOK RPM40 VW Mod Pod System Starter Kit $25.99
The SMOK RPM40 Pod Mod Kit is an ultra-portable pod mod that shapes like a cuboid and is covered with glossy finish and characteristic material, making the whole device look fancy and stylish. It is small in size but has a battery capacity of 1500mAh which can ensure enough running time and help you avoid frequent charging, and a power range from 1W to 40W for you to adjust, and you can press the UP/DOWN button to get your preferred power. The internal IQ-R chip is a new one, which can shorten the firing time to 0.001S, and charging time to two hours. Different from normal tiny and slim pod devices, RPM40 is designed with a 0.96 inches screen, with which, detailed vaping data is clearly presented, like the wattage, resistance, voltage, screen color, puff number, and battery level. Besides, the newly designed RPM Mesh 0.4ohm Coil and Nord DC 0.6ohm Coil are designed for the best flavor and excellent vapor production.
Original Acacia Q-Watch Pod System Starter Kit $28.99
The Acacia Vape Q-Watch Pod Kit, a watch-style pod system with compact design and simple operation, is a fashionable wearable electronic vaping devices. The pod kit is made of zinc alloy and PC material and equipped with a built-in 270mAh battery. The cartridge adopts 1.5ohm ceramic material with 1.1ml juice capacity for durability and stability with better flavor. Furthermore, the intelligent airflow sensing inside brings the highly true smoke feeling. It is equipped with small but clear LED screen to show you the fundamental conditions, with just one glance and a simple tap, you can check the time, puff count, and battery level.
Kindbright Nine-Hundred BF RDA Clone with Squonker Pin $22.99
The Kindbright Nine-Hundred RDA Clone is made of 316 stainless steel and features 18mm diameter. The Kindbright Nine-Hundred RDA Clone comes with a bottom feeder pin. Equipped with dual-pole for single coil and bottom adjustable airflow control.
Original Aspire Nautilus 2S Replacement Mesh Coil Core Head $8.99
This Aspire Nautilus 2S mesh coil is suitable for Aspire K1 Plus / Aspire Nautilus / Aspire Nautilus 2 / Aspire Nautilus 2S / Aspire Zelos 2.0 / Aspire Nautilus AIO Tank Atomizer. The 0.7 ohm works with from 20W to 25W.
Original Yachtvape Meshlock Replacement Mesh Coil Sheet - 0.2ohm (50~70W) (10 PCS) $3.59
The Yachtvape Meshlock mesh coil is made of Kanthal A1 material and is suitable for Yachtvape Meshlock Mesh RDA Atomizer and other mesh RDA / RTA / RDTA.
Original Yachtvape Meshlock Replacement Mesh Coil Sheet - 0.13ohm (60~80W) (10 PCS) $3.59
Original Acacia Q-Watch Pod Kit Replacement Pod Cartridge with 1.5ohm Cotton Coil $4.99
The Acacia Q-Watch Pod Cartridge is designed for the Acacia Q-Watch Pod Kit. The Pod Cartridge is Equipped with the 1.5ohm cotton coil to produce pure vaping flavor. And it also comes with refillable 1.1ml juice capacity. Get it as a spare part for your Acacia Q-Watch Pod Kit.
Original Acacia Q-Watch Pod Kit Replacement Pod Cartridge with 1.5ohm Ceramic Coil $4.99
The Acacia Q-Watch Pod Cartridge is designed for the Acacia Q-Watch Pod Kit. The Pod Cartridge is Equipped with the 1.5ohm ceramic coil to produce pure vaping flavor. And it also comes with refillable 1.1ml juice capacity. Get it as a spare part for your Acacia Q-Watch Pod Kit.
3FVAPE вне форума   Вверх
Старый 13.08.2019, 04:58 Автор темы   422
3FVAPE
Kindbright Nine-Hundred Mechanical Mod Clone $14.99
The Kindbright Nine-Hundred Mechanical Mod Clone is constructed from 316 Stainless Steel and powered by 1 x 16500 / 16650 battery (not included). The mechanical mod is with 80.5mm height.
Original Dovpo Blotto RTA original price$39.99, now only$30.99
The Dovpo Blotto RTA has 2ml E-liquid capacity and it includes two spare 6ml bubble tanks (Glass / Ultem). It is unique for the top refill design which is easy to fill on top. This rebuildable tank atomizer is compatible with dual or single coil. The 242 degrees of airflow direct to the coils will bring smooth flavor. By offering three types of glass tubes, this RTA is comfortable for users to operate. The adjustable airflow system creates milder and smoother flavor plus richer clouds, which brings users comfortable and safe vaping experience.
Original Rincoe Tix Pod System Starter Kit $37.99
The Original Rincoe Tix Kit is powered by a massive 1000mAh battery with a type-c charge that enables you to enjoy vaping the whole day. The Rincoe Tix Kit supports three modes to meet different vaping experience, which is corresponding to 3.3V, 3.65V, and full-battery output. Press the mode button and switch to any power output mode you like. And the pod system kit utilizing the adjustable airflow system to satisfy both MTL and DTL vapers, you just twist the airflow ring to adjust airflow and enjoy the excellent vaping experience. The kit comes with 0.8 ohm mesh coil and 1.0 ohm regular coil.
Original Syiko Galax Pod System Starter Kit $22.99
The Syiko Galax Pod Kit is powered by 1200mAh built-in battery with 25W max output power. It comes with 2ml refillable pod cartridge. There are 2 coil options: 0.6ohm Mesh Coil for DTL vaping and a 1.2ohm Coil for MTL vaping. It has three power modes for options: Low, Middle and High. It is designed with compact and portable size, which is convenient and easy to use. The air control ring is under the cartridge for easy operation. It also comes with the LED indicaror for displaying the battery level clearly.
SXK AIRLab RM RDA Replacement Decorative Ring Adapter Clone $2.99
The SXK AIRLab RM decorative ring adapter Clone is suitable for 22mm diameter SXK AIRLab RM RDA. The outer diameter is 24mm and the inner diameter is 22mm.
SXK AIRLab RM RDA Replacement AFC Airflow Control Ring Clone $2.99
The SXK AIRLab RM airflow AFC Clone ring adapter is suitable for 22mm diameter SXK AIRLab RM RDA.
SXK AIRLab RM RDA 510 Drip Tip Adapter Clone $2.59
The SXK AIRLab RM RDA 510 drip tip adapter Clone is suitable for 22mm diameter SXK AIRLab RM RDA. The outer diameter is 16mm and the height is 6mm.
SXK AIRLab RM RDA Replacement Airflow Control Insert Clone $3.99
The SXK AIRLab RM airflow control insert Clone is suitable for 22mm diameter SXK AIRLab RM RDA.
Original Syiko Galax Pod System Replacement Pod Cartridge $7.99
The Pod Cartridge is suitable for Syiko Galax Pod System Starter Kit and it has a 2ml juice capacity. 2 PCS / Pack.
Original Syiko Galax Pod System Replacement MTL Regular Coil Head $8.99
The MTL Regular Coil Head is suitable for Syiko Galax Pod System Starter Kit with a 1.2ohm coil resistance. 5 PCS / Pack.
Original Syiko Galax Pod System Replacement DTL Mesh Coil Head $8.99
The Mesh Coil Head is suitable for Syiko Galax Pod System Starter Kit. Two types of coil resistance options: the 0.6ohm mesh coil for DTL vaping. 5 PCS / Pack.
Original Rincoe Tix Pod System Replacement Regular Coil $8.99
The Regular Coil is suitable for Rincoe Tix Pod System Starter Kit and the coil resistance is 1.0ohm. 5 PCS / Pack.
Original Rincoe Tix Pod System Replacement Mesh Coil $8.99
The Regular Coil is suitable for Rincoe Tix Pod System Starter Kit and the coil resistance is 0.8ohm. 5 PCS / Pack.
Original Rincoe Tix Pod System Replacement Pod Cartridge $7.99
The Pod Cartridge is suitable for Rincoe Tix Pod System Starter Kit and it has 2ml juice capacity. 2 PCS / Pack.
Старый 14.08.2019, 04:43 Автор темы   423
3FVAPE
Original MECHLYFE Arcless Competition Mechanical Mod + Slatra RDA Kit original price$79.00, now only$59.99
The MECHLYFE Competition Mechanical Mod Kit consists of an Arcless Mechanical Mod and a Slatra Mesh RDA. The Arcless Mod is compatible with 18650, 20700 and 21700 batteries (a 18650 adapter included, but batteries not included). With attractive resin pattern, the arcless mechanical mod will be your best vaping pal. The Slatra mesh RDA comes with a triple clamp style deck for easy dual mesh coil installation. The Slatra mesh RDA is also compatible with regular coils. The resin 810 drip tip helps you acquire massive vapor production too. The Slatra RDA features bottom feeding pin and regular 510 pin.
Original Oukitel MATE Pod System Vape Kit $22.99
The Oukitel MATE Pod System Vape Kit boasts the compact design and elegant appearance and its big vapor and 1200mAh built-in battery will support you long time of vaping. Besides, it comes with a 2ml juice capacity pod cartridge (Not include E-liquid). Also, the kit is equipped with two replaceable coils: 0.6ohm mesh coil and 1.2ohm ceramic coil (Not include Coil), which provide you more vaping choice and satisfy your multiple vaping needs. Coming with the lanyard, you can wear it around your neck and have your vaping more conveniently. This capable kit will bring you wonderful vaping experience without doubt.
Original Artery PAL II 2 Pro Pod System VW Mod Kit original price$34.90, now only$28.99
The Artery PAL II Pro Pod System VW Mod Kit is the upgraded version of Artery Pal II Mod Kit that escalates multiple functions for great vaping experience, featuring a built-in 1000mAh battery power. On one hand, it is still compatible with Pal II pods and Pal series of coils. However, it adopts new HP coils and enhances the PAL II Pro pod with better airflow inlet, which is definitely conducive for the rich flavor and massive clouds via the big oil refilling hole. On the other hand, it is equipped with the LED display, variable wattage system (Max output power: 22W) and oil window as well. In this way, you can have a comfortable vaping in details. Two coils for MTL and DL vaping with 1.0ohm and 0.6ohm, which can meet your special requirements. Surprisingly, it also boasts the memory mode which means it is able to retrieve your wattage record automatically and you can still enjoy the same wattage next time. The PAL II Pro have a side filled 3ml E-liquid capacity with an attached silicone plug. The body of the PAL II Pro has two parallel 4.5mm by 1.5mm air slots along the side.Artery PAL II Pro kit is really exquisite in appearance while possesses powerful function at the same time.
Original DEJAVU DJV Mod Replacement Stable Wood Sleeve + Resin Drip Tip original price$46.99, now only$35.99
The replacement sleeve and drip tip are designed specially for the DEJAVU DJV Mechanical Tube Mod. The sleeve is made of stable wood and the drip tip is made of resin.
Original Oukitel MATE Pod System Replacement Mesh Coil Head $7.99
The replacement mesh coil head is suitable for Oukitel MATE Pod System Starter Kit and the resistance of this coil head is 0.6ohm. 3 PCS / Pack.
Original Oukitel MATE Pod System Replacement Ceramic Coil Head $7.99
The replacement ceramic coil head is suitable for Oukitel MATE Pod System Starter Kit and the resistance of this coil head is 1.2ohm. 3 PCS / Pack.
Original Oukitel MATE Pod System Replacement Pod Cartridge $6.99
The replacement pod cartridge is suitable for Oukitel MATE Pod System Starter Kit and the juice capacity is 2ml. 2 PCS / Pack.
Original Artery PAL II Pro Pod System Replacement Empty Pod Cartridge - TPD Edition original price$8.90, now only$5.99
The replacement pod cartridge is suitable for Artery PAL II Pro Pod System Starter Kit and the juice capacity is 2ml.
Original Artery PAL II Pro Pod System Replacement Empty Pod Cartridge - Standard Edition original price$8.90, now only$5.99
The replacement pod cartridge is suitable for Artery PAL II Pro Pod System Starter Kit and the juice capacity is 3ml.
Старый 15.08.2019, 04:41 Автор темы   424
3FVAPE
Original Augvape VTEC1.8 200W VV Box Mod original price$40.00, now only$35.99
The Augvape VTEC1.8 200W VV Box Mod implements an ergonomic design with a modern touch. It features a hidden firing mechanism integrated onto the 0.96 inch OLED display as well as a rotating adjustment button with the analog trigger for setting adjustments. The internal chipset is intelligent with three different output modes: Auto Mode, Bypass Mode, VV Mode, and V Mode. Updated software with variable voltage mode included which allows you to have more variety of vaping experience. With reinforced battery door, the device is strong, durable, and easy to be slided to open and close. Decorated with finest leather strip to make it feel more comfortable in hand. VTEC1.8 Box Mod is made of zinc alloy material and is powerd by two 18650 batteries (Not included) in series. The dual battery life indicator on the OLED screen shows you the accurate conditions of both batteries.
SXK Stealth 60W VW Box Mod Clone original price$56.90, now only$40.99
The SXK Stealth Box Mod Clone is powered by 1 x 18650 battery (Not included) and maximum power output is 60W. The SXK Stealth Box Mod Kit Clone is with a 0.91 inch OLED screen.
Original Augvape Occula RDA with BF Pin original price$39.99, now only$23.99
The Occula 24mm RDA by Augvape is a collaboration between Augvape and Twisted Messes, this is a project you will not want to miss. Featuring an innovative Dual Post captive clamp system to fit any size build with ease. Each post has 5.5mm width by 2.6mm in height, leaving space for even the beefiest coils. Utilizing two massive hex-shaped screws that work with flat-head and Philips screwdrivers, as well as pliers if needed. Clamps raise automatically with screws. The adjustable airflow system helps a lot in escalating the taste as well.
Original Vandy Vape Swell Replacement Single Mesh Coil Head $11.99
The single mesh coil head features 0.15ohm resistance. The single mesh coil head is suitable for Vandy Vape Swell mod kit. 4 PCS / Pack.
SXK MTL RBA Replacement Modular AFC + Screws + Airflow Insert Parts $8.99
The replacement parts include modular AFC, screws ,and airflow insert parts, which are made of PC and ABS material. Sizes of these insert parts (White: 0.8 x 0.8mm, Red: 0.8mm, Blue: 1mm, Yellow: 1.2mm, Orange: 1.5mm). These replacement parts are suitable for SXK MTL RBA.
SXK MTL RBA for BB Box Mod Clone $14.99
The SXK MTL RBA is made from 316 stainless steel. It is suitable for SXK BB Box Mod Clone. It supports single coil builds.
SXK Insider RBA Clone for BB Box Mod $13.99
The SXK Insider RBA Clone is constructed from stainless steel and in 14mm diameter. This RBA features dual-post design, huge juice channels and bottom airflow design. It is designed for SXK BB Box Mod Kit. Without LOGO.
Старый 16.08.2019, 04:29 Автор темы   425
3FVAPE
Original Vapor Storm Eco 90W Mechanical Box Mod original price$18.00, now only$14.99
The Vapor Storm Eco is a newly designed powerful and portable mod with attractive graffiti series body and great hand feeling. It mades of high quality ABS plastic material which makes it quite lightweight. With single 18650 battery (Not included), the Vapor Storm mod can fires up to 90W (Maximum Power) with 10 seconds continuous vapeing time. It is definitely an excellent vape device for vapers. Best match with the Vapor Storm Tank.
Original DEJAVU DJV Hybrid Mechanical Tube Mod original price$68.00, now only$54.49
The Original DEJAVU DJV Mech Mod, designed by the YouTube reviewer Adrian Lo Dejavu, is a high-end mech mod powered by single 18650 battery (NOT INCLUDED). The DJV Mech Mod can work efficiently with two types of button, the stainless steel or acrylics. DEJAVU DJV Mod also features the innovative hybrid system, which makes the 510 pin of atomizer contact the battery directly for better power transfer and a harder, faster hit. With the advanced canted coil inside the gold-plated contact pin, the DEJAVU DJV Mech MOD can provide maximum firing and reduce heat effectively.
Comp Lyfe Mini HK 24 Mechanical Mod Clone + Battle RDA $21.99
The Complyfe Battle Clone RDA is constructed from stainless steel build deck, brass top cap and stainless steel drip tip and powered by 1 x 18350 battery (not included). The mechanical mod is with 24mm diameter. With the large post holes and flathead screws, the triple post deck is easy for coil building. The cap has dual large airslots for side airflow.
SXK Box 200W VV VW Squonk Box Mod Clone $26.99
The SXK Box Box Mod Clone is a durable regulated mod made from ABS. The wattage can be varied from 5 to 200 watts with dual 18650 / 20700 batteries (NOT INCLUDED). It comes with three modes: power mode, voltage regulation mode, and mechanical mode. The squonk bottle has 7ml of juice capacity.
Original Vapor Storm Eco 90W Mod + D11 Disposable Tank Starter Kit original price$21.50, now only$17.99
The Vapor Storm Eco Starter Kit with a stylish interface and compact size was designed by Vapor Storm. The Eco mod is constructed by ABS plastic, which is lightweight and modern, and the 22mm diameter D11 disposable tank is made of PC and Metal which features 2ml E-juice capacity. Powered by single 18650 battery (not included), it can reach up to max 90W output power. Bottom airflow control, and retractable top fill system make it really easy to refill the tank. Besides, the airflow can easily be adjusted by turning the control ring with knurled design.
SXK Replacement Tank for Billet Box Mod Kit / Bantam Box BB Mini Box Mod $14.99
The SXK BB Box Mod Replacement Tank Clone is constructed from PEI. It is designed for SXK BB Box Mod Kit / Bantam Box BB Mini Box Mod.
Старый 19.08.2019, 04:41 Автор темы   426
3FVAPE
Original YiHi SXmini X Class 200W TC VW Box Mod $399.99
The YiHi SXmini X Class 200W TC VW Box Mod is a dual battery Auto-Squonk system, incorporating a myriad of output variations, exquisite visual detailing, and features the advanced YiHi SXmini X Class reservoir with innovative ESS Technology. This high class box mod brings a new chipset to the table, the brand new Yihi SX650J has control over more functions than earlier options. This device is the first Auto Squonker mod to join Yihi's lineup, the e-liquid is fed to the atomoizer with an electronic spray atomizer control technology. This not only prevents dry hits but removes manual dripping yourself. The X Class box mod is a dual 18650 battery powered device (Not included) with an 0.69 inch TFT Color display and Bluetooth or WiFi connection. Manufactured from a beautiful zinc-stainless steel alloy chassis with carbon fiber accents, the X Class Box Mod carries an aura of the highest luxury. The SXmini X Class features a separated e-liquid reservoir found at the base of the device that keeps e-liquid fresh and away from the heating element, this keeps heat away from your e-liquid that could degrade the flavor. The SX Mini X Class is for those looking to up their vaping experience.
Haku Venna RDA Clone with BF Pin $6.99
The Haku Venna RDA Clone is a low profile 22mm RDA with dual post design for single coil building. Constructed from stainless steel, the RDA adopts sandblasting technology to make it feel smooth on the surface. The air enters the chamber via two different sizes of airholes on both side of the cap, hitting the coil directly. POM drip tip is included. This RDA comes with bottom feeder pin.
Original Smoant Pasito 25W 1100mAh Mod Pod System Starter Kit original price$35.00, now only$25.79
Smoant Pasito Kit is made of CPR and aluminum alloy material, resulting in a more colorful and durable stunning finish. Powered by a built-in 1100mAh battery and assisted by the new ANT chip, it allows for 5 output levels within 10-25W and lasts a long vaping time. The battery is charged via the Type C USB port on the bottom of the device. And there are intelligent LED lights that will show the battery level clearly. As for the pod, it can store up to 3ml of e-juice and features an adjustable top airflow and refill system, which prevents leaking problems and guarantees the easy operation of the device. A 1.4ohm MTL Ni-80 Coil and a 0.6ohm DTL Mesh Coil are included with purchase, but you may also purchase a rebuildable coil separately. Anyway, the Pasito is worth a shot.
Original SMOKTech SMOK RPM40 Pod Kit Replacement Mesh Coil Head $13.99
The SMOK RPM40 Coil Head is specially designed for SMOK RPM40 Pod Kit and SMOK RPM40 Pod Cartridge. Get it as spare parts for your SMOK RPM40 Pod Kit. 5 PCS / Pack.
Original SMOKTech SMOK RPM40 Pod Kit Replacement Triple Coil Head $13.99
Original SMOKTech SMOK RPM40 Pod Kit Replacement Quartz Coil Head $14.99
Original SMOKTech SMOK RPM40 Pod Kit Replacement SC Coil Head $12.99
Original SMOKTech SMOK RPM40 Pod Kit Replacement Nord Pod Cartridge $5.39
The SMOK RPM40 Pod Cartridge is compatible with SMOK RPM40 pod kit, the Nord Pod Cartridge has a juice capacity of 4.5ml for the SMOK Nord Coil (coil not included). 3 PCS / Pack.
Старый 20.08.2019, 04:40 Автор темы   427
3FVAPE
LieFeng Kayfun Mini V3 RTA Clone with Replacement Tank $9.99
The LieFeng KF Mini V3 RTA Clone Rebuildable Tank Atomizer is constructed from 316 Stainless Steel and Pyrex Glass. This RTA is 19mm diameter and holds 2ml capacity. This RDA is adjustable airflow control with AFC ring on the bottom.
Original VEIIK MOOS 1100mAh Pod System Vape Starter Kit $22.99
The VEIIK MOOS Pod System Vape Kit features compact and exquisite size which enable you can carry it to anywhere at anytime. With built-in 1100mAh large battery capacity, this device can definitely satisfy your whole day vaping. Besides, it adopts PCTG material, making it easy to operate and bring you better hand feeling. At the same time, the zinc alloy material and gloss metallic paint promise you wear-proof and anti corrosion function. Moreover, the kit utilizes 1.2ohm ceramic coil and 2ml juice capacity pod cartridge, which will bring you rich mouth-feel as well as rich and dense clouds.
Original Reewape K3 5-in-1 Shortfill Cap Opener Tool for Juice / E-Liquid Bottle $1.99
The Reewape K3 5-in-1 Shortfill Cap Opener Tool is made of Zinc alloy, it is convenient to open juice cap of 10ml, 30ml , 50ml , 60ml, 120ml, and most 23~24mm caps can be opened by K3 Reewape 5-in-1 shortfill.
Original Reewape AS116C Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.49
The Reewape AS116C 810 Drip Tip is made of resin and It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Original Reewape AS137C Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.49
The Reewape AS137C 810 Drip Tip is made of resin and It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Original Reewape AS137E Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.49
The Reewape AS137E 810 Drip Tip is made of resin and It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Original Reewape AS144 Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.99
The Reewape AS144 810 Drip Tip is made of resin and It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Original VEIIK MOOS Pod System Replacement Pod Cartridge with 1.2ohm Ceramic Coil $6.99
The VEIIK MOOS Pod Cartridge is designed especially for the VEIIK MOOS pod system vape kit. The Pod Cartridge is Equipped with the 1.2ohm ceramic coil to produce pure vaping flavor. And it also comes with refillable 2ml juice capacity. Get it as a spare part for your VEIIK MOOS vape kit. 2 PCS / Pack.
Старый 21.08.2019, 04:32 Автор темы   428
3FVAPE
Stratum Zero Semi-Mechanical Mod Clone $11.99
The Stratum Zero Style Semi-Mechanical Mod is constructed from 304 stainless steel and powered by single 21350 / 18350 battery (Not included).The height of this mechanical mod is 46mm and is with a short-circuit protection chip board.
Original Joyetech Teros One 13W 650mAh VW Pod System Starter Kit $23.36
The Joyetech Teros One Kit is a VW Variable Wattage Pod Kit. Inherited from Joyetech Teros series, the Teros One Kit is an updated pod system vape AIO kit with 650mAh larger built-in battery and exquisite design. Moreover, it comes with 3 adjustable power levels (High / Medium / Low). You can change the power easily by pressing the power / mode button and get the optimal flavor. Plus the 2ml refillable pod cartridge with easy bottom filling hole, childproof design and 0.5ohm mesh coil, the Joyetech Teros One Pod kit will bring you a simple awesome vaping. A 12ml E-liquid Bottle and a Lanyard included.
Original SMOKTech SMOK Nord 15W 1100mAh Pod System Starter Kit $27.99
The original SMOKTech SMOK Nord, is a button-triggered pod system device. It is powered by a built-in 1100mAh battery, which making it a definitely powerful one among pod system devices. It is equipped with two exclusive coils (Nord Mesh 0.6ohm coil and Nord regular 1.4ohm coil), one is perfect to get massive vapor while the other can offer excellent MTL experience. Its size is very comfortable to hold in hand, and it has a newly added button to start vaping and provide information about battery life, besides, there's an e-liquid window on the pod, all of which are for your convenience.
Original Reewape AS146 Replacement 810 Drip Tip for 528 Goon RDA $1.99
The Reewape AS146 810 Drip Tip features change color under heating and is made of resin and It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA. Reewape is the new brand of Aleader, the same product.
Original Reewape AS147 Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.99
The Reewape AS147 810 Drip Tip is made of resin and It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA. Reewape is the new brand of Aleader, the same product.
Original Reewape AS150 Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.49
The Reewape AS150 810 Drip Tip is made of resin and It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA. Reewape is the new brand of Aleader, the same product.
Original Joyetech Teros One Pod System Replacement Pod Cartridge with 0.5ohm Mesh Coil $5.62
The Joyetech Teros One Pod Cartridge is specially designed for Joyetech Teros One Pod System Starter Kit with 2ml juice capacity and 0.5ohm mesh coil to provide pure flavor. Together with the easy to fill design, the Teros One Pod will bring you a wonderful vaping. Just get the pod cartridge for your kit and enjoy great flavor and big clouds. 2 PCS / Pack.
Старый 22.08.2019, 04:38 Автор темы   429
3FVAPE
Original 5GVape DIVO 10W 650mAh Pod System Starter Kit $22.99
The 5GVape DIVO Pod System Starter Kit is with durable exquisite design and double leakproof top secure. The DIVO pod kit is constructed from aviation aluminum alloy (battery), PCTG and ABS (pod cartridge). Powered with 650mAh built-in battery and is with a 1.8ml juice capacity and 1.0ohm coil pod catridge. The output wattage is from 8 to 10 watts.
Original VOOPOO Find S Trio 23W 1200mAh Pod System Starter Kit $20.99
The VOOPOO Find S Trio Pod System is a GENE. Trio-powered portable pod kit, utilizing the new VOOPOO PnP Coil Technology. Contained with the durable zinc-aluminium alloy chassis, sits the advanced GENE. Trio Chipset, integrating various safety protections and a 3.7V constant output for consistent output. The Voopoo Find S Trio is powered by a 1200mAh rechargeable battery, equipped with LED lights for convenient battery life indicator. The refillable Find S Trio Pod has a long-lasting 3ml juice capacity, utilizing the new coil system with a 0.8ohm PnP-R1 Coil and a 1.2ohm Pnp-C1 Ceramic Coil option for flavor-enhanced experience.
Original Reewape AS151 Replacement 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.89
The Reewape AS151 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS154 Replacement 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.49
The Reewape AS154 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS156 Replacement 810 Drip Tip 528 Goon / Reload / Battle RDA $1.49
The Reewape AS156 810 drip tip is made from resin with 11mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS157 Replacement 810 Drip Tip for 528 Goon / Reload / Battle RDA $1.49
The Reewape AS157 810 drip tip is made from resin with 13mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS158 Replacement 810 Drip Tip for 528 Goon / Kennedy / Reload RDA $1.59
The Reewape AS158 810 drip tip is made from resin with 13mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS159S Replacement 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.55
The Reewape AS159S 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS160 Replacement 810 Drip Tip for 528 Goon / Reload / Battle RDA $1.49
The Reewape AS160 810 drip tip is made from resin with 14mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original 5GVape DIVO Pod System Replacement Pod Cartridge $8.99
The 5GVape DIVO Pod Cartridge is designed for the 5GVape DIVO Pod System Starter Kit, which is made from PCTG and ABS material with 1.8ml juice capacity and the resistance of this coil is 1.0ohm. 3 PCS / Pack.
Original VOOPOO PnP-C1 Replacement MTL Ceramic Coil Head $10.99
The VOOPOO PnP MTL Ceramic Coil Head has a 1.2ohm resistance and features organic cotton wicking material. The PnP coil also features anti-leaking and anti-spitback technologies.The coil are to be used with various Voopoo products including Finic P18 Aio, Drag Baby Trio, Find S Trio. They may not be compatible with other Voopoo or non-Voopoo tanks. 5 PCS / Pack.
Original VOOPOO PnP-R1 Replacement Half DL Coil Head $10.99
The VOOPOO PnP Half DL Coil Head has a 0.8ohm resistance and features organic cotton wicking material. The PnP coil also features anti-leaking and anti-spitback technologies.The coil are to be used with various Voopoo products including Caliber P22 AIO, Finic P18 AIO, Drag Baby Trio, Find S Trio. They may not be compatible with other Voopoo or non-Voopoo tanks. 5 PCS / Pack.
Старый 23.08.2019, 04:45 Автор темы   430
3FVAPE
Modegan Sun Classic Mechanical Mod Clone $22.99
The Modegan Sun Classic Mechanical Mod Clone is made from brass material with 25mm diameter. It is compatible for 24mm diameter RDA atomizer and single 18650 battery (Not included).
Original Lost Vape Orion Plus DNA 22W 950mAh VW Pod System Starter Kit $69.99
The Lost Vape Orion Plus DNA 22W Pod Starter Kit, integrating the updated Evolv DNA GO with 5-Level Power Outputs, Temperature Limiting Technology, REPLAY Functionality, 950mAh Li-Po Battery, and ergonomic replaceable coil mechanism. Fully constructed with high-quality metal construction along with the introduction of Stabwood panels alongside the iconic resin and carbon fiber designs, the Lost Vape Orion Plus epitomizes a true high-end vape device. The updated Evolv DNA GO Chip features a 5-Level Power Outputs, Patent-Pending Temperature Limiting Technology, and capability that allow user to automatically regulate power and temperature. The Orion Plus retains the beloved REPLAY Functionality with the capability of Boost (40W peak power) and Auto-Detect of coil resistances. In terms of cartridge, the drip tip implements a dual slotted airflow control ring, allowing for proper adjustment of airflow pathing catering to Mouth-to-Lung (MTL) or Direct-Lung (DL) vaping. The new Orion Plus Pod Cartridge introduces the highly anticipated replaceable coil mechanism, along with showcasing the 0.25ohm Mesh Coil and 0.5ohm Regular OCC Pod Coil for optimal flavor and vapor production to create a complete pod system. The Lost Vape Orion Plus Kit will be fully compatible with the original Orion DNA Go Pod.
Original Reewape AS116SY Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Goon RDA $1.99
The Reewape AS116SY glowing-in-the-dark drip tip is made of Resin and it is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS161 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.99
The Reewape AS161 drip tip is made of Resin and it is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS162 Replacement 810 Drip Tip for SMOK TFV8/TFV12 Tank/Goon/Kennedy RDA $1.69
The Reewape AS162 drip tip is made of Resin and it is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS164 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank /Goon/Kennedy/Reload RDA $1.99
The Reewape AS164 drip tip is made of Resin and it is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS165 Replacement 810 Drip Tip for 528 Goon / Reload / Battle RDA $1.59
The Reewape AS165 810 drip tip is made from resin with 6mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS166 Replacement 810 Drip Tip for 528 Goon / Reload / Battle RDA $1.59
The Reewape AS166 810 drip tip is made from resin with 6mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Vapeasy 5-in-1 Shortfill Cap Opener Tool Clone for Juice / E-Liquid Bottle $2.99
The Vapeasy Style 5-in-1 Shortfill Cap Opener Tool is made of Zinc alloy, it is convenient to open juice cap of 10ml, 60ml, 120ml, and most 23~24mm caps can be opened by Reewape 5-in-1 shortfill.
Original Lost Vape Orion Plus Pod System Replacement Regular OCC Coil Head - 0.5ohm (5 PCS) $19.95
The Lost Vape Orion Plus Regular OCC Coil is designed for Lost Vape Orion Plus Pod System and the resistance of this mesh OCC coil is 0.5ohm. 5 PCS / Pack.
Original Lost Vape Orion Plus Pod System Replacement Mesh OCC Coil Head - 0.25ohm (5 PCS) $19.95
The Lost Vape Orion Plus Mesh OCC Coil is designed for Lost Vape Orion Plus Pod System and the resistance of this mesh OCC coil is 0.25ohm. 5 PCS / Pack.
Original Lost Vape Orion Plus Pod System Replacement Pod Cartridge $16.95
The Orion Plus Pod Cartridge is designed for Lost Vape Orion Plus Pod System and it is an empty 2ml plastic pod, consisting of a threaded top fill system, various threaded coil options, and a selectable dual airflow control system that offers a MTL or DTL style draw.
Puncher + Drill Bit + Plastic Stopper Set for Pod Cartridge $2.99
The Pod Cartridge Puncher set consists Puncher, Drill Bit and Plastic Stopper, and it is used especially for punching on the pod Cartridge.
Старый 24.08.2019, 04:32 Автор темы   431
3FVAPE
FTL M25 RTA Clone $18.99
The FTL M25 RTA Clone is constructed from stainless steel in 25mm diameter, comes with two glass tanks (4ml / 5.5ml). The FTL M25 RTA Clone is with side terminal postless deck design supports Dual or single coil building. The RTA is with reduces airflow to increases flavor. The FTL M25 RTA Clone is with clip top cap for conveniently filling (No thread). It is very convenient to replace cotton or Coils without emptying your juice and twist to close juice ports on filling for no leaking.
Original Mechlyfe Ratel 80W Rebuildable TC VW Mod Pod Kit original price$75.00, now only$50.99
manufacturer's actual product. The Mechlyfe Ratel Rebuildable TC VW Pod Kit, with single coil configuration, and the pod kit supports single 18650 battery (Not included). With 80W max output, the Ratel features 6 working modes: Power / Voltage / Bypass / Ni / Ti and Temperature control. Not only is the Ratel features portable and palm-friendly design, it also has rechangeable panels on both side. Moreover, the Mechlyfe Ratel is compatible with both MTL vape and DTL vape.
Original VOOPOO VINCI R 1500mAh VV Mod Pod System Starter Kit $34.19
The VOOPOO VINCI R Pod Kit from VOOPOO is a Mod Pod Kit with a new generation of GENE.AI chip and it is powered by 1500mAh built-in battery and comes with 5.5ml large e-juice capacity. The VOOPOO VINCI R Mod Pod Kit has variable voltage function of 3.8 / 3.5 / 3.2V to meet your whole day vaping demand, and utilizes a new 0.3ohm PnP-MV1 Mesh Coil from the Voopoo PnP coil line that can deliver satisfying clouds of delectable vapor, designed for DTL vaping as it effectively vaporizes the eJuice with ease. The intelligent coil provides multiple protections like dry burn protection to safeguard your vaping and can match the coils by intelligently adjustable power. The VOOPOO VINCI R Kit adopts manual and auto modes to meet your different vape needs.
Original VOOPOO VINCI 40W 1500mAh VW Mod Pod System Starter Kit $44.64
The VOOPOO VINCI Mod Pod Kit consists of the 1500mAh built-in battery mod and visible pod cartridge which both comes with a unique appearance design. The VINCI mod is constructed from zinc alloy material which is decorated with various pattern panels to give you a different sense of vision. And the cuboid shape design will not make you feel any uncomfortable but suitable for gripping in hand on the contrary. Moreover, the common buttons and 0.96" inch TFT colorful screen are both equipped to provide you more information you want. With the up / down button, you can adjust the output wattage from 5W to 40W; with the fire button, you can select the mode suits you the best between Manual mode and Auto mode. Furthermore, the brand-new GENE.AI chipset also makes its debut which aims to provide you more secure and more comfortable user experience like automatically adjust the most suitable wattage for you when a new coil installed.
Original Blitz Realm 1100mAh Pod System Starter Kit $24.99
The Blitz Realm Pod System Starter Kit is designed and branded in Los Angeles, USA, which is powered by 1100mAh built-in battery that 1.5A quick charge fully charged in 30 minutes and equipped the advanced Taiwan imported chipset with temperature limiting anti-dry hit protection, which can keep a constant output. The facet polymer technology panel brings you a fashion and cool vision. The buck-boost & const-output technology brings you great flavor even with low battery. The pod kit is compatible with SMOK Nord mesh coils for better flavor and longer lifespan. The Blitz Realm pod kit has multiple protection for your safe vaping, and it has 2ml or 3.5ml pod capacity that you can choose.
Original VOOPOO VINCI Mod Pod Replacement Empty Pod Cartridge $9.48
The VOOPOO VINCI Pod Cartridge is an empty pod (without built-in coils)designed for VOOPOO VINCI Mod Pod VW Kit and VINCI R Mod Pod Kit with the e-juice capacity of 5.5ml. The resistance ranges from 0.1ohm to 3.0ohm that is also compatible with PnP series coils, which is extremely convenient and feasible to meet your different requirement. 2 PCS / Pack.
Старый 26.08.2019, 04:41 Автор темы   432
3FVAPE
Original Marstech La One RDA with BF Pin $9.49
The Marstech La One RDA Rebuildable Dripping Atomizer is made from POM material in 23mm diameter and 32mm height. It is designed especially for Marstech La One Kit. The La One RDA is with dual-pole and side airflow for single coil.
SXK SiChro RDA Clone with BF Pin original price$17.90, now only$14.99
The SXK SiChro RDA is constructed from 316 Stainless steel (Base Deck), POM (Top Cap), Ultem (Inner Chamber)and PEEK (Insulator). It is with 45-degree angle posts and 3 air holes on each side (2mm in the middle and 1.5mm on the outside). It is suitable for any type of vape you want from RDL to DL. The deck includes dual gold plated brass positive post and a positive pin.
Original Hotcig Marvel 30W 1200mAh VW Mod Pod System Starter Kit $36.99
The Hotcig Marvel Pod Kit is a refillable pod system which is constructed from zinc alloy and food grade PC material.Equipped with HM 30W 0.96 inch screen chipset, it has three ouput modes: POWER Mode, BYPASS Mode, and CUSTOM DIY Mode. The Pod is powered with 1200mAh built-in battery and with 2ml juice capacity. There are 2 types of 0.6ohm mesh coil and 1.2ohm regular coil for you choose different vaping experience. The refilling system is convenient to fill the juice and avoid to spill out. The Pod's power output is 1~30w, and supports the USB 1A charge.
Original Steam Crave Glaz V2 RTA Replacement Dual Coil Base Deck $10.29
The Steam Crave Glaz Dual Coil Base Deck is made of stainless steel and supports dual coil building. It is suitable for Steam Crave Glaz V2 RTA Rebuidable Tank Atomizer.
Original Vaporesso Traditional EUC Clapton Coil Head for Estoc Tank Mega / Estoc Tank $7.99
The Vaporesso Traditional EUC (ECO Universal coil) Clapton with sleeve is designed to deliver cloud-size vapor with the purest flavor. The EUC will allow you to replace only the core of your atomizer which is called EUC by dropping it in and out of its casing, leaving the metal sleeve. It can fit for Estoc Tank Mega / Estoc Tank / Doubloon Tank / Target Pro / ORC / Gemini Tank / Atlantis Tank / Eleaf Pico / Eleaf iJust. 5 PCS / Pack.
Original Vaporesso Ceramic EUC 316L Coil Head for Estoc Tank Mega / Estoc Tank / Doubloon Tank $8.99
The Vaporesso Ceramic EUC (ECO Universal coil) is designed to deliver cloud-size vapor with the purest flavor. The EUC will allow you to replace only the core of your atomizer which is called EUC by dropping it in and out of its casing, leaving the metal sleeve. It can fit for Estoc Tank Mega / Estoc Tank / Doubloon Tank. Also can fit for Target Pro / ORC / Gemini Tank / Atlantis Tank / Eleaf Pico / Eleaf iJust (need an extra sleeve). More affordable & ECO-friendly. 5 PCS / Pack.
Original Vaporesso VECO ONE Traditional EUC Kanthal Coil Head $7.99
The Vaporesso VECO ONE Traditional EUC Kanthal Coil is designed for VECO ONE with resistance 0.3ohm and wattage range from 35W to 40W. The EUC coils reinvents traditional atomizers allowing a faster and easier than ever system to replace the coil and wick after use that just need to replace the core. 5 PCS / Pack.
Original Vaporesso EUC Replacement Mesh Coil Head $9.99
The Vaporesso Traditional EUC Mesh Coil is designed for Vaporesso Traditional EUC with resistance 0.6ohm and wattage range from 16W to 22W. 5 PCS / Pack.
Original Vaporesso EUC Replacement CCELL Coil Head $9.99
The Vaporesso Traditional EUC CCELL Coil is designed for Vaporesso Traditional EUC with resistance 1.0ohm and wattage range from 10W to 14W. 5 PCS / Pack.
Original Vaporesso Orca Solo CCELL Coil Head with Organic Cotton $9.99
The Vaporesso Orca Solo CCELL coil head is 1.3ohm, which is equipped with organic cotton. And it is suitable for Vaporesso Orca Solo AIO Kit. 5 PCS / Pack.
Старый 27.08.2019, 04:42 Автор темы   433
3FVAPE
Original Vaporesso GEN 220W TC VW Box Mod with SKRR $56.79
The Vaporesso GEN 220W Vape Mod and SKRR-S Mesh Sub-Ohm Tank Starter Kit is a high power device designed to be used by newbies and pros alike. GEN presents a sleek and light weight design, paired with the new AXON chip for easy operation. The new AXON chip from Vaporesso is an intuitive chipset with a simple user interface and several power modes to please every user. Vaporesso has paired the GEN with the SKRR-S tank for the ultimate vape starter kit.The Vaporesso GEN mod is constructed from durable aluminum and features a soft touch finish made from four layers of coating. This allows the vape device to have a soft rubber-like feel, while offering extreme durability. The GEN utilizes dual 18650 vape batteries (Not included), which are accessible via a dual magnetic battery access panel.
Original asMODus Tribeaut 80W TC VW Box Mod original price$69.99, now only$49.99
The Tribeaut is simplicity re-imagined. The Tribeaut is an 80W box mod and powered by single 18650 battery (Not included)that features an ergonomic design and an easy-to-use operating system. The Tribeaut vape box mod can be comfortably picked up from any position. The Tribeaut is not biased to what the finger the vaper uses, whether it's the pointer or the thumb the mod will fit perfectly in their hand. The Tribeaut features our asMODus 80H chipset, and has the potential to output up to 80W in the variable wattage option or in our programmable curve mode. The Tribeaut also features accurate temperature control mode presets such as NI200 nickel, titanium, SS316, and SS317 along with fully adjustable TFR and TCR. The screen has ten levels of adjustable brightness and a puff counter.
Original Vaporesso VM 18 Sub-Ohm Tank Atomizer $19.69
The Vaporesso VM 18 Sub-ohm Tank features a threaded top fill system, utilizing the Vaporesso EUC Coil Series. Dependent on size, the VM tank can hold anywhere 2ml of juice without any complications or issues. The 18mm diameter VM Tank can hold 2ml of juice within the glass capacity but does not come with the protective metal sleeve. At the top of the VM Tank is a leak-proof threaded top fill system, accepting needle nose and unicorn style e-juice bottles for the refill system. In addition, the VM Sub-ohm tank can utillize coils from the Vaporesso EUC Coil Series, introducing wires made from ceramic, mesh coil, and delivers a fix of nicotine reliably when needed.
Original Vaporesso VM 22 Sub-Ohm Tank Atomizer $23.99
The Vaporesso VM 22 Sub-ohm Tank features a threaded top fill system, utilizing the Vaporesso EUC Coil Series. Dependent on size, the VM tank can hold anywhere 2ml of juice without any complications or issues. The 22mm diameter VM Tank can hold 2ml of juice within the glass capacity and come with the protective metal sleeve. At the top of the VM Tank is a leak-proof threaded top fill system, accepting needle nose and unicorn style e-juice bottles for the refill system. In addition, the VM Sub-ohm tank can utillize coils from the Vaporesso EUC Coil Series, introducing wires made from ceramic, mesh coil, and delivers a fix of nicotine reliably when needed.
Original Vaporesso VM 25 Sub-Ohm Tank Atomizer $24.99
The Vaporesso VM 25 Sub-ohm Tank features a threaded top fill system, utilizing the Vaporesso EUC Coil Series. Dependent on size, the VM tank can hold anywhere 3ml of juice without any complications or issues. The 25mm diameter VM Tank can hold 3ml of juice within the glass capacity and come with the protective metal sleeve. At the top of the VM Tank is a leak-proof threaded top fill system, accepting needle nose and unicorn style e-juice bottles for the refill system. In addition, the VM Sub-ohm tank can utillize coils from the Vaporesso EUC Coil Series, introducing wires made from ceramic, mesh coil, and delivers a fix of nicotine reliably when needed.
Original Vaporesso SKRR-S Sub-Ohm Tank Atomizer $29.99
The Vaporesso SKRR-S Tank is an updated version to the SKRR Tank with 30mm diameter (26mm diameter with 5ml tank). The tank is constructed from stainless steel (Body)and pyrex glass (tank) and it can hold up to 8ml of E-liquid whilst adopting top fill structure. Along the base are trapezoid-shaped, quad-adjustable airflow slots that allows for personalized airflow intake. This unique airflow system draws air directly into the coil head through a unique design that eliminates spit back and cold air intake while minimizing leakage. To further assist with this system are the QF coil heads that have a bullet shaped inner structure to manipulate airflow. Two coil heads can be chosen for you in the set. One is the pre-installed 0.15ohm QF strip coil, the other is the 0.2ohm QF meshed coil. Both of them are rated between 55~85W but is best between 60~90W. The SKRR-S is an decent choice if you'd like to blow bigger and denser clouds with smooth flavor.
Original Vandy Vape Berserker S 25W 1100mAh All in One AIO Starter Kit original price$69.99, now only$27.99
The Vandy Vape Berserker S Kit is a compact and portable AIO starter kit. It is powered by large 1100mAh built-in battery for long time vaping. It comes with 2ml e-juice capacity. There are two types of coil for you to choose: 0.7ohm and 1.5ohm to serve your different demands. It is made of Food-grade PSU material with high durability. It is compatible with nic, salt nic, which will bring you different vaping experience. It is an affordable beginner kit with high performance. Featuring the LED button mode switching, you can get to know the working condition and battery levels clearly and easily. It is designed with detachable structure for easy cleaning.
510 Anti-Spit Replacement Drip Tip for RDA / RTA / Sub-ohm Tank Atomizer $1.99
The replacement 510 drip tip is made from stainless steel mouthpiece and PC base. It is suitable for all atomizers that fit 510 drip tip. The inner air path comes with honeycomb design for smooth vapor and anti-spit.
Original Vandy Vape Berserker S Replacement MTL Coil Head - 1.5ohm (7~15W) $9.69
The Vandy Vape Berserker S Coil Head is specially designed for Vandy Vape Berserker S Kit. The coil resistance is 1.5ohm, and the wattage range from 7~15W. It is compatible with both e-liquid and nicotine salt, bringing smooth taste and optimal flavor. The MTL coil is also fit for Vandy Vape AP Kit. 5 PCS / Pack.
Original Vandy Vape Berserker S Replacement MTL Coil Head - 1.8ohm (7~13W) $9.69
The Vandy Vape Berserker S Coil Head is specially designed for Vandy Vape Berserker S Kit. The coil resistance is 1.8ohm, and the wattage range from 7~13W. It is compatible with both e-liquid and nicotine salt, bringing smooth taste and optimal flavor. The MTL coil is also fit for Vandy Vape AP Kit. 5 PCS / Pack.
Original Vandy Vape Berserker S Replacement Mesh Coil Head - 0.7ohm (5~25W) $12.59
The Vandy Vape Berserker S Coil Head is specially designed for Vandy Vape Berserker S Kit. The coil resistance is 0.7ohm, and the wattage range from 5~25W. It is compatible with both e-liquid and nicotine salt, bringing smooth taste and optimal flavor. 5 PCS / Pack.
Старый 28.08.2019, 04:37 Автор темы   434
3FVAPE
Original Vaporesso SKRR-S Mini Sub-Ohm Tank Atomizer $20.99
The SKRR-S Mini 23mm Sub-Ohm Tank is the latest sub-ohm tank from Vaporesso, providing a threaded top-fill, upgraded dual bottom airflow ring, and the utilization of the QF Coil System. Formed from durable stainless steel, the SKRR-S Mini tank has pyrex glass reinforcement to prevent breaking during light and moderate falls. The SKRR-S Mini Tank adopts the newly introduced Quadflow (QF) Air Distribution System, in which airflow channels into the atomizer core and spreads internally in four directions. The Vaporesso QF Coil System utilizes the combination of cotton and flax materials for a long-lasting yet flavor-enhanced performance with the following coil options: 0.2ohm QF Meshed and 0.15ohm QF Strip. At the top of the Vaporesso SKRR-S Mini Sub-Ohm Tank is a threaded top fill system, designed for fast and easy refills by removing the top cap to reveal a generously large fill port that allows the tank to hold up to 3.5ml of juice within the pyrex glass.
Original Vaporesso VECO Sub-Ohm Tank Atomizer $14.99
The VECO Sub-Ohm 22mm Sub-Ohm Tank is the latest sub-ohm tank from Vaporesso, providing a threaded top-fill, top adjustable air flow, and the utilization of the EUC Coil System. Formed from durable stainless steel, the VECO Sub-Ohm tank has glass to prevent breaking during light and moderate falls. The coil resistance is 0.3ohm. At the top of the Vaporesso VECO Sub-Ohm Tank is a threaded top fill system, designed for fast and easy refills by removing the top cap to reveal a generously large fill port that allows the tank to hold up to 2ml of juice within the glass.
Original Vaporesso VECO Plus Sub-Ohm Tank Atomizer $18.95
The VECO Plus 24.5mm Sub-Ohm Tank is the latest sub-ohm tank from Vaporesso which is constructed from 316 stainless steel and glass material, providing a easy top-fill, the utilization of the EUC Coil system and top adjustable air flow. Formed from durable stainless steel, the VECO Plus Sub-Ohm tank has glass to prevent breaking during light and moderate falls. There are two types of coil for you to choose: 0.2ohm coil and 0.6ohm coil to meet your different vaping demands. At the top of the Vaporesso VECO Plus Sub-Ohm Tank is a threaded top fill system, designed for fast and easy refills by removing the top cap to reveal a generously large fill port that allows the tank to hold up to large 4ml of juice within the glass.
ShenRay FEV V5 RTA Clone $29.99
The ShenRay FEV V5 RTA Clone is constructed from 316 stainless steel in 23mm diameter. The FEV V5 RTA has a 6ml juice capacity PC tank, it supports dual AFC and single AFC control. The FEV V5 RTA has a 2 posts simple design and it can provide MTL and DL vaping options to meet your different demands.
Original Vaporesso VM SOLO 22 2000mAh Vape Pen with VM 22 Sub-Ohm Tank Starter Kit $26.25
The Vaporesso VM Solo 22 Starter Kit is an exemplary vaping system, encapsulating an integrated 2000mAh rechargeable battery, direct voltage based output, and is paired with the Vaporesso VM 22 Sub-Ohm Tank. Initially, the Vaporesso VM Solo Kit features an integrated 2000mAh rechargeable battery within the durable housing to protect the heart of the VM Solo. When pressing the single button to fire, the VM Solo outputs voltage based on the remaining battery life, firing the 0.6ohm and 1.0ohm EUC coils with ease to vaporize e-juice. Paired with the Vaporesso VM 22 Tank, the Vaporesso VM Solo Kit can utilize coils from EUC Coil Series, but comes with the mesh and ceramic coil options above, tailoring the starter kit to those that prefer cloud chasing or those that are more flavor oriented. Furthermore, the VM 22 Sub-Ohm Tank features a threaded top fill system that works in conjunction with multi-hole bottom airflow control ring, metering the desired amount of airflow through the internal coil structure.
Original Vaporesso VM Stick 18 1200mAh Starter Kit with VM 18 Sub-Ohm Tank $24.65
The Vaporesso VM Stick 18 Starter Kit is a pairing of two latest quality vape pens from Vaporesso, combining the 1200mAh rechargeable battery and direct voltage based output with the versatility of the VM Tank 18, capturing the finer details like compatibility with the EUC Coil Series, threaded top fill system, and an adjustable MTL Clone bottom airflow control ring. Constructed from durable zinc alloy, the chassis of the VM Stick 18 is coated in a shiny metallic finish to lend an air of luxury to the vape system. Featuring a voltage based output, the capacious 1200mAh battery can be recharged in little to no time, providing vaporized nicotine at the press of a button. Paired with the VM Tank, this starter kit can utilize coils from the Vaporesso EUC Coil Series, but is already equipped with the ceramic and meshed heating element and tea fiber wicking material options. Furthermore, the VM Tank, possesses a top fill port hidden by a threaded top cap, allowing for quick and easy refills. At the base is an adjustable bottom airflow control ring, offering a 5-hole MTL Clone airflow to guide airflow through the internal coil structure.
Original Vaporesso VECO Solo 1500mAh AIO Starter Kit with Sub-Ohm Tank $23.89
The Vaporesso VECO SOLO Starter Kit as the latest All-in-One (AIO) vaping device which is constructed from zinc alloy, stainless steel and pyrex glass material. It is an attractive and compact starter kit with 2ml VECO Solo Tank and built-in 1500mAh VECO Solo Li-ion battery (20400CX Battery Chip). With ECO Universal Coil preinstalled and the adjustable top airflow, it will offer you a great vaping experience. The VECO Solo Kit is a great option for advanced vapers.
Original Vaporesso VECO Solo 3300mAh AIO Starter Kit with Sub-Ohm Tank $27.49
The VECO Plus Solo Kit is a new pen Clone vaping device from Vaporesso, which is constructed from zinc alloy, stainless steel, and pyrex glass, including large built-in 3300mAh battery and 4ml e-juice capacity tank. The kit has a compact and leak free design, adjustable top airflow system, and easy top fill. The included ECO Universal Coil will deliver the most original flavor of your e-liquid. You will enjoy a great vaping with the VECO Plus Solo Kit.
510 Snake Skin Drip Tip for RDA / RTA / RDTA / Clearomizer / Sub Ohm Tank Vape Atomizer $1.89
The 510 Drip Tip is suitable for RDA / RTA / RDTA / Clearomizer Vape Atomizer. The 510 drip tip is made from resin (Mouthpiece) and acrylic (base).
510 MTL Drip Tip for RDA / RTA / RDTA / Clearomizer / Sub-Ohm Tank Vape Atomizer $1.89
Старый 29.08.2019, 04:39 Автор темы   435
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Myuz Hadar RDA with BF pin $24.99
The Hadar RDA is an intricate vaping system developed by Myuz in 25mm diameter and 41mm height. It is compatible with two heating modes and a 0.15ohm and a 0.3ohm mesh coil. Compatible with top filling and bottom feeding. L shaped air inlet for compact smooth airflow. It is recommended that you adjust between 35 and 50W, you will get an unprecedented vaping experience with excellent flavor taste.
Original OBS Land 10W 750mAh VW Mod Pod System Starter Kit original price$39.99, now only$29.99
The OBS Land 10W Pod System is a retractable vaping pod system, integrating a significant 750mAh rechargeable battery, retractable pod lever, and can hold up to 1.5ml while firing with the 1.4ohm integrating coil within the refillable pod. Constructed from durable zinc-alloy, the chassis of the OBS Land is protective while maintaining a striking visual presentation with the variety of panel designs. On the side of the OBS Land Pod System is a sliding pod lever, retracting and raising the installed pod for immediate vaping. The OBS Land Replacement Pods are side filled and are refillable, removing a silicone plug to facilitate refills.
Original Reewape AS142 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank/Goon/Kennedy/Reload RDA $1.99
The Reewape AS142 drip tip is made of Resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS168 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank /Goon/Kennedy/Reload RDA $1.99
Original Reewape AS168 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank /Goon/Kennedy/Reload RDA - Black + Gold, Resin, 14mm Model: 39848 Free Shipping for Most Countries When Orders > $15 Normal. Dispatches in 3 - 7 business days. $1.99 Click to See Wholesale Price Add to Wishlist Add to Compare Qty: 1 Add to Cart The Reewape AS168 drip tip is made of Resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS170 Replacement 810 Drip Tip for 528 Goon / Reload / Battle RDA $1.69
The Reewape AS170 810 drip tip is made from resin with 13mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS171 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy $1.79
The Reewape AS171 drip tip is made of Resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS172 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy $1.79
The Reewape AS172 drip tip is made of Resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
3FVAPE вне форума   Вверх
Старый 30.08.2019, 04:52 Автор темы   436
3FVAPE
Original Vapor Storm Trip Sub-Ohm Tank Atomizer original price$23.00, now only$18.99
The Vapor Storm Trip Tank is constructed from Stainless Steel and Glass with 0.2ohm mesh coil for massive cloud and excellent flavor. The tank supports Vapor Storm Replacement Hawk Coil. It have been installed a 2ml glass tube and also supplies a 6ml glass tube in package to meet your need. The tank has everything you loved in normal atomizer, but lighter and more delicacy.
GLM V3 Hybrid Mechanical Tube Mod Clone + RDA Kit $14.99
The GLM V3 Mech Kit Clone consists of GLM V3 Mechanical Mod Clone and GLM V3 RDA Clone. Mod: The GLM V3 Mechanical Mod Clone is constructed from Copper. It has hybrid connection and spring fire button. The mod is powered by single 18650 battery (NOT INCLUDED). RDA: The GLM V3 RDA Clone is a nice rebuildable dripping atomizer made from stainless steel. It features dual post build deck and adjustable side airflow. It will bring you great amount of cloud and dense flavor.
Original Reewape AS103 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.79
The Reewape AS103 510 drip tip is made from stainless steel (base) and resin (mouthpiece). It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS103S 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.89
The Reewape AS103S 510 drip tip is made from stainless steel (base) and resin (mouthpiece). It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS104 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.79
The Reewape AS104 510 drip tip is made from stainless steel (base) and resin (mouthpiece). It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS104S 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.89
The Reewape AS104S 510 drip tip is made from stainless steel (base) and resin (mouthpiece). It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS106 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.79
The Reewape AS106 510 drip tip is made from stainless steel (base) and resin (mouthpiece). It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS116D Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy $1.89
The Reewape AS116D drip tip is made of resin, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS133 Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle $1.99
The Reewape AS133 810 Drip Tip is made of resin (mouthpiece) and stainless steel (base). It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Hussar Project X MTL RTA Replacement Drip Tip $1.99
The replacement drip tip features 9.2mm height and 12.8mm diameter. The replacement drip tip is made from POM and PEI. The replacement drip tip is suitable for Hussar Project X MTL RTA.
Original Vapor Storm Replacement Tank Tube for Trip / Hawk Sub Ohm Tank $1.99
The Vapor Storm Glass Tube is suitable for Vapor Storm Trip / Hawk Sub Ohm Tank.
Original Vapor Storm Replacement Bubble Tank Tube for Trip / Hawk Sub Ohm Tank $2.59
The Vapor Storm Bulb Glass Tube is suitable for Trip / Hawk Sub Ohm Tank.
Original Vapor Storm Replacement Mesh Coil Head for Trip / Hawk Sub Ohm Tank original price$9.00, now only$6.99
The Vapor Storm Replacement Coil has a 0.2ohm resistance and unique structure. The Hawk Coil is not only fit for Vapor Storm Hawk Tank and Trip Tank. It is best used with the wattage of 40~60W. 3 PCS / Pack.
Старый 02.09.2019, 04:55 Автор темы   437
3FVAPE
Original Reewape AS141 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.59
The Reewape AS141 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS143 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99
The Reewape AS143 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS145 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99
The Reewape AS145 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS152 510 Drip Tip for RDA / RTA / RDTA $1.99
The Reewape AS152 Temperature Change Drip Tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS155 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.59
The Reewape AS155 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS163 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.99
The Reewape AS163 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS179 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy $1.69
The Reewape AS179 drip tip is made of Resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA
Original Reewape AS181 Replacement 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy $1.59
The Reewape AS181 drip tip is made of Resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Steam Tuners Wave Tank Tube Clone + Drip Tip for Kayfun Prime RTA Clone $6.99
The Hayfun Prime wave tank Clone is made of PMMA material in 22mm diameter and with a 2.5ml juice capacity. It is suitable for Steam Tuners Hayfun Prime RTA Clone.
Original Sbody MYPOD Pod System Replacement Mesh Coil Head original price$14.99, now only$7.99
The Sbody MYPOD Replacement 0.8ohm Mesh Coil is designed especially for Sbody MYPOD pod system starter kit. 5 PCS / Pack.
Original HorizonTech Magico Pod System Replacement Mesh Coil Head $6.99
The Horizon Magico 0.12ohm mesh coil is compatible with Nic-salt and regular juice. The flavor would be purer and fresher. It fits for HorizonTech Magico Tank. 3 PCS / Pack.
Original HorizonTech Magico Pod System Replacement Standard Coil Head $6.59
The Horizon Magico 1.8ohm standard coil is compatible with Nic-salt and regular juice. The flavor would be purer and fresher. It fits for HorizonTech Magico Tank. 3 PCS / Pack.
Original HorizonTech Falcon 80W VW Mod + Falcon King Sub Ohm Tank Starter Kit $69.99
The Horizon Falcon Starter Kit is a performance vape pen system, delivering a max power of 80 watts by single 18650 battery (Not included). The Falcon Kit is paired with the HorizonTech Falcon King Tank in 25.4mm diameter, maintaining high-level of craftsmanship with durable stainless steel material with a visually striking contrasting resin drip tip. Each set comes with a bulb glass that can handle 6ml of maximum juice capacity, integrating a high-quality stainless steel material and a new rotary hinge top-fill with a lock button design. The Falcon King Tank implements the same Falcon Coil System as the previous Falcon series, equipped with a new 0.38ohm M-Dual Mesh Coil and 0.16ohm M1+ Mesh Coil with bamboo fibers and organic cotton. Airflow enters the apparatus through two large airslots, producing sensational cloud production with maintaining high-level of flavor recreation for a balanced vape experience.
Старый 03.09.2019, 04:58 Автор темы   438
3FVAPE
ShenRay Bestia Animal 18650 Hybrid Mechanical Mod Clone $14.99
The ShenRay Animal mod Clone is a hybrid mechanical mod which is constructed from copper and is powered by 1 x 18650 / 20700 / 21700 battery (not included), with a diameter of 27mm, it is equipped with a stylish side switch. This Mod is a beautiful side fire mod with a removable battery adjustable bottom and removable top with delrin insulator. The top insulator creates a barrier for your e-liquid spills so there is much less chance of your juice ending up in your tube. This mod is with B logo
SXK Insider V2 MTL RBA Clone for Billet Box Mod / SXK Bantam Box 30W original price$29.90, now only$14.99
The SXK Insider V2 RBA Clone is constructed from 316 stainless steel and in 14mm diameter. This RBA features dual-post design, huge juice channels and bottom airflow design. It is designed for SXK BB Box Mod Kit and SXK Bantam Box 30W. This RDA supports MTL vaping, comes with 3 airflow modules: 1 hole x 1.0mm, 2 holes x 1.2mm, 3 holes x 1.2mm, and extra chimney with 2.0mm diameter hole. Without LOGO.
ION V2 MTL RTA Clone $19.99
The ION V2 MTL RTA Clone is constructed from 316 stainless steel in 23mm diameter. The ION V2 MTL RTA Clone has a 4ml juice capacity PC tank, it supports liquid adjustable and has 4 different airflow holes. The ION V2 MTL RTA Clone has a 2 posts simple design and it can provide MTL and DL vaping options to meet your different demands.This is not made by Ulton, but with the same or better quality.
Original Sbody MYPOD 25W 900mAh Pod Kit original price$33.60, now only$19.99
The Sbody MYPOD Pod System Starter Kit is equipped with a built-in 900mAh battery. It comes with a 2.8ml juice capacity tank and two 0.8ohm mesh coils for your daily vaping experience. The indicator light can provide the power capacity when you use Sbody MYPOD pod kit. The pod has a side refilling hole for you to filling e-juice conveniently.
Original SMOKTech SMOK MAG P3 230W TC VW Box Mod with TFV16 Tank Kit $75.99
The SMOKTech SMOK MAG P3 Kit is the newest rendition of the Mag Series of box mods from SMOK. Featuring a familiar pistol grip form factor, the new P3 kit forgoes the use of the magazine-style battery compartment in favor of a new hinged door to accommodate the new waterproof design. MAG P3 continues the classic MAG series, adding more stunning features, such as waterproof, dustproof and shockproof. It includes a robust MAG P3 mod and a remarkable 9ml TFV16 tank, preinstalled with a new TFV16 Conical Mesh 0.2ohm coil powered by nexMesh Technology. Driven by external dual 18650 batteries(Not included) and a smart IQ-M Chipset, MAG P3 can fire up to the max output of 230W with 0.001s flash firing speed. It owns a super responsive 1.9" HD touch screen to offer useful data information for easier operation. In addition, it comes with an input keyboard that provides password protection to unlock the device. 230W maximum output power, and a full temperature control suite. This is MAG P3, catering to all your needs.
Original Reewape AS219 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy $1.79
The Reewape AS219 drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS225 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy $1.49
The Reewape AS225 drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS208 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy $1.59
The Reewape AS208 drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Старый 03.09.2019, 04:59 Автор темы   439
3FVAPE
Original Reewape AS198 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy $1.59
The Reewape AS198 drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Reewape AS181 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy $1.59
The Reewape AS181 drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
510 Replacement 360 Degree Rotatable Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.39
The replacement 510 drip tip is made from Stainless steel and it comes with a 360 degree rotatable mouthpiece. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original HorizonTech Falcon King Replacement Bubble Glass Tank Tube + M1+ 0.16ohm Single Mesh Coil Head $5.99
The Bubble Tank Tube is made of glass material with 6ml juice capacity, and the M1+ Single Mesh Coil Head has 0.16ohm coil resistance. They are designed especially for HorizonTech Falcon King Sub Ohm Tank Atomizer.
Original Benctech Protective Storage Case Vape Bag E-cig Pouch for E-Cigarette $5.99
A vapor case from Benctech. It comes with great space yet small and easy carrying. You can put one set of your E-cig products in it. A good setup will be: E-cig devices, some DIY tool / accessories, batteries, and pod cartridges.
Steam Tuners Replacement Bell Cap Clone for Dvarw MTL RTA - 2ml $4.99
The Steam Tuners Replacement Bell Cap Clone is made from PMMA for Steam Tuners Dvarw MTL RTA Clone. The cap is 22mm diameter and the height of this cap is 21mm. The bell cap has a 2ml juice capacity.
Steam Tuners Replacement Bell Cap Clone for Dvarw MTL RTA - 3.5ml $4.99
The Steam Tuners Replacement Bell Cap Clone is made from PMMA for Steam Tuners Dvarw MTL RTA Clone. The cap is 22mm diameter and the height of this cap is 25mm. The bell cap has a 3.5ml juice capacity.
Kaser 510 Replacement Drip Tip Clone Set with MTL Mouthpiece $5.99
The Kaser 510 Replacement Drip Tip Set Clone with 2 PCS drip tip base, silver stainless steel, black POM. Comes with 3 PCS normal mouthpiece (Black POM / Translucent PMMA / Brown PEI) and 5 PCS MTL mouthpiece (Black POM / Translucent PMMA / Brown PEI / White POM / Silver stainless steel).
Старый 04.09.2019, 04:51 Автор темы   440
3FVAPE
Original Fumytech Precisio MTL Pure RTA for BD Vape $34.99
The Fumytech Precisio MTL RTA is constructed from stainless steel (Body) and Polish Ultem (Tank). The 22mm diameter RTA has a 2.7ml juice capacity tank. The airflow control can be used from MTL to middle DL. Double airflow hole inside provides more power and blow to the coil directly.
SiChro RDA Clone with BF Pin $13.99
The SiChro RDA is constructed from 316 Stainless steel (Base Deck), POM (Top Cap), Ultem (Inner Chamber)and PEEK (Insulator). It is with 45-degree angle posts and 3 air holes on each side (2mm in the middle and 1.5mm on the outside). It is suitable for any type of vape you want from RDL to DL. The deck includes dual gold plated brass positive post and a positive pin. Comes with bottom feeder pin.
YFTK Haku Xeta Inside RBA Clone for Billet Box Mod Kit $21.99
The YFTK Haku Xeta RBA Clone is constructed from 316 stainless steel and ultem. This RBA consists 510 chimney section (SS), airdraw insert, middle top cap (SS and Ultem), elevating coil clamp system, airflow disk, wick channel controller pin, and air intake. It is suitable for BB Box Mod Kit.
Original Demon Killer Puck 400mAh Pod System Starter Kit $14.99
The Demon Killer Puck Pod Kit is a new product from Demon Killer with a smooth and sleek design, nice texture and portable to have it anywhere. Demon Killer Puck Kit coming with Zinc Alloy material, the surface of the fuselage is shiny and durable. It is visually fancy and compact being equipped with a battery of 400mAh and a 0.7ml juice capacity pod (with 1.6ohm cotton coil)to meet everyday use. The most important is Puck mod compatible with Jull / Jbox Pod Cartridge.
Original Starss Romeo 25W 1200mAh VW Mod Pod System Starter Kit original price$36.90, now only$24.99
The Starss Romeo Kit is the latest ultra pod system device with a curved surface. It is powered by 1200mAh Lithium-ion Battery, which supports the device for a whole week normal use. It adapts top intake system ensures sealing of the cartridge bottom and avoids leaking. Adjustable airflow enables users to adjust the airflow as needed. With a maximum output of 25W, it also supports 3 adjustable output, which indicated by 4 RGB indicators. The Starss Romeo Pod Kit features 2.0ml e-juice capacity, 1.4ohm Regular Cotton Coil and 0.6ohm Mesh Coil for massive clouds.
810 Replacement Drip Tip for 528 Goon /Reload /Battle /CSMNT Cosmonaut /Unholy /Apocalypse GEN 2 /Reload RDA original price$1.99, now only$0.00
The 810 drip tip is made from PC. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Aspire Breeze NXT Pod System Replacemnt Coil Head $9.99
The Aspire Breeze NXT Coil Head is designed especially for Breeze NXT Pod System. The coil has a 0.8ohm coil resistance, and the power range of this coil is from 15W to 20W. 3 PCS / Pack.
Original Aspire Breeze NXT Pod System Replacemnt Single Mesh Coil Head $9.99
original Starss Romeo Pod System Replacement MTL Regular Coil Head original price$16.50, now only$9.99
Starss Romeo MTL Regular Coil Head is designed especially for Starss Romeo Pod System. The coil has a 1.4ohm coil resistance. 5 PCS / Pack.
Original Starss Romeo Pod System Replacement Mesh Coil Head original price$16.50, now only$9.99
The Starss Romeo Mesh Coil Head is designed especially for Starss Romeo Pod System. The coil has a 0.6ohm coil resistance. 5 PCS / Pack.
Original Starss Romeo Pod System Replacement Pod Cartridge w/o Coil Head $4.29
The Starss Romeo Pod is made of PCTG and is suitable for Starss Romeo Pod System. The pod has a 2ml juice capacity.
Original Starss Romeo Pod System Replacement Pod Cartridge w/ Coil Head original price$11.28, now only$8.99
The Starss Romeo Pod is made of PCTG and is suitable for Starss Romeo Pod System. The pod has a 2ml juice capacity. The set consists two types of coil: 0.6ohm Mesh Coil / 1.4ohm MTL Regular Coil to meet your different vapeing demands.
Время генерации страницы 1.05170 секунды с 15 запросами
