Просмотров в теме 302440   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 13.07.2019, 11:23 Автор темы   401
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
AV Workman Hybrid Mechanical Mod Clone $10.99
The AV Workman Series Mechanical Mod Clone is with 24mm diameter at hybrid cap and 28mm outer diameter, made from aluminum and brass, powered by single 18650 battery (not included). It features hybrid connection. The fire button is activated by magnets and can be locked for your safety when not using it.
Origianl Eleaf iJust Mini 25W 1100mAh Battery Vape Pen + Atomizer Starter Kit $28.00
Eleaf iJust Mini Kit is very small in size, allowing you to carry it anywhere with ease. Powered with 1100mAh battery, the iJust mini can also last you a long time of vaping. The iJust mini battery features the adjustable power modes for your preference. Simply click the button three times to get the optimal vapor and flavor. For a child's security, Eleaf made an easy top solution with a lock system on the iJust mini atomizer. What's more, it automatically closes the e-liquid inlet when the coil is pulled out. You can replace the coil even when the tank is full. Moreover, utilizes two new GT coils which are thread-free. They are very easy to install.
Hussar Project X RTA Clone $27.59
The Coppervape Hussar Project X Style RTA is a 22mm rebuildable tank atomizer constructed from 316 stainless steel. It comes with 2ml juice capacity and Ultem PEI tank. It comes with adjustable bottom airflow and the airflow size is 3 x 1.5mm each side. The tank also has juice control function.
Original Eleaf Tance Max Replacement Pod Cartridge w/ GS Air M 0.6ohm Coil $5.39
This Pod Cartridge with GS Air M 0.6ohm Coil head is suitable for Eleaf Tance Max Pod System.
This newly-designed cartridge features a refined airflow system and an original rotary refilling system. And it comes with new GS Air M 0.6ohm Head to present great flavor and vapors.
3FVAPE вне форума   Вверх
Старый 15.07.2019, 13:16 Автор темы   402
3FVAPE
Vapeasy Venom-Tank RDTA Clone 12.99
The Vapeasy Venom-Tank RDTA Clone is made from 316L SS and PC in 22mm diameter. The Vapeasy Venom-Tank Style RDTA comes with 5 air plugs that allows you to combine them to get the right airflow needed.
Driptech-DS Mechanical Squonk Box Mod Clone + Goon 1.5 RDA Clone Kit 22.99
The Driptech-DS Goon Box Squonker Kit Clone consists of Driptech-DS Goon Box Style Squonk Box Mod and Goon 1.5 Style RDA.
Mod:
The Driptech-DS Goon Box Squonk Mod Clone features aluminum body with ergonomic design, which feels good in hands and is very lightweight. It comes with a 8ml silicone bottle for squonking. Powered by dual 18650 batteries (parallel, not included), this mod will provide raw power for massive clouds.
RDA:
The Goon 1.5 RDA Clone is constructed from aluminum cap with a stainless steel base. It measures 24mm in diameter. It features bridge clamp design for easy building and middle side adjustable air slots for airflow control. The RDA comes with an 810 wide bore drip tip.
Please Note: The mod is in parallel connection
The logo / texts on the mod is engraved.
Aftermath V2 Mechanical Mod Clone + Redemption RDA Clone Kit Clone 20.99
The Aftermath V2 Mech Kit Clone consists of Aftermath V2 Style Mechanical Mod and Redemption Style RDA.
Mod:
The Aftermath V2 Mechanical Mod Clone is constructed from Brass. It comes with stunning appearance, with carved grooves on it. There are totally 16 venting holes on the mod for battery safe. The fire button is activated by magnets.
RDA:
The Redemption RDA Clone is a 24mm rebuildable atomizer constructed from Brass + stainless steel. It features Rapture style posts and Apocalypse style airflow with single airflow option. The dual clamp posts forms a bridge over the shelf for extra space. Resin and POM drip tip are included.
Original VapeCige Nano 40W 950mAh Pod System Starter Kit 25.99
The VapeCige Nano kit is powered by 950mAh built-in battery. The max output wattage can be up to 40W. The pod cartridge features 2ml juice capacity.
Старый 16.07.2019, 13:46 Автор темы   403
3FVAPE
Original Oilax Alameda C1 650mAh CBD Vaporizer Battery Mod - C1-1 10.99
The Oilax Alameda C1 is a CBD Vaporizer that is powered by built-in 650mAh battery. The battery comes with LED indicator. The colorful cover makes the Alameda C1 more stylish.
Original JUSTFOG Q16 Pro 900mAh VV E-Cigarette Battery Mod 18.49
The JUSTFOG Q16 Pro Battery mod is built-in 900mAh inbuilt battery, the JUSTFOG Q16 Pro Battery mod provides an all-day-long vape to starters. The JUSTFOG Q16 Pro Battery mod has a 4-level voltage adjustment from 3.5V to 4.4V, meeting your different vaping needs. The constant voltage output of JUSTFOG Q16 Pro brings a stable performance to the users.
Original VOOPOO DRAG 2 Platinum 177W TC VW Variable Wattage Box Mod 52.09
The Platinum Edition of VOOPOO Drag 2 MOD is an upgraded version of the previous Drag 2. Equipped with non-fading and scratch-proof platinum frame, the Platinum Drag 2 looks much more attractive and durable. Still powered by external dual 18650 batteries (not included), it fires up to a powerful output of 177W. The Drag 2 Platinum MOD adopts the advanced GENE.FIT chip, which is secured by a V0 class fireproofing bridge to block the device from dust, liquid or burnout. And the Platinum Drag 2 has ergonomic design with curve surface and round corners for comfortable hand feeling.
Original JUSTFOG Q16 Pro 900mAh Battery VV E-Cigarette Mod + Atomizer Starter Kit 25.79
Justfog Q16 Pro Kit is an innovative version to the Q16 series, it comes with lightness and elegant body that is portable to be on the go. Powered by a built-in battery, it comes with multiple protections such as temperature control and short-circuit prevention, which will offer a comfortable and safe vaping experience. As for the tank, the adjustable airflow system can perfectly meet your different vapor needs. Finally, the top filling design will make it extremely convenient to refill the e-liquid.
Original asMODus Flow V1.5 500mAh Ultra-Portable Pod System Starter Kit Original price $29.99, now only $22.99
The asMODus FLOW is step further in the future of stealthy pod devices. After countless hours of designing and redesigning, the FLOW is packed with innovations and provides an impressively lightweight design while still easy to use!
The FLOW excels in many ways that other devices lack. The coil we installed in the FLOW Pods are a higher resistance to increase flavor production. High grade organic cotton ensures excellent e-liquid absorption and no break in period! Refilling of the pod comes with ease from the simple pull out cap system. Our fill hole is large enough for any dropper or nozzle of your choice. Fill up the pod with up to 2ml of your favorite e-liquid!
Due to the recent research of ceramic coils proving how ceramic coils can lead to death or internal injuries, we designed the FLOW Pods to be made with kanthal and not ceramic. While many companies have taken the route of ceramic coils for its longer lifespan, we were able to create a safer coil that performs just as well if not better than the rest!
We made the FLOW larger to help the user in two ways: To provide a better grip when using the device, and its enlarged size makes it much easier to find when misplaced. The large body also allowed us to equip the FLOW with a larger internal battery to make the device last much longer than any similar devices. In addition to the increased battery capacity, the battery cells have been increased in size to provide the FLOW larger battery cells to increase the lifespan of the device. Despite the size, the FLOW is made from premium aluminum alloy making it a deceptively lightweight mod. The FLOW charges via a micro USB port making it easy to charge it anywhere without carrying another unnecessary dedicated charger.
Старый 17.07.2019, 13:33 Автор темы   404
3FVAPE
I'M Infinity Piper Style Mechanical Mod Clone $12.99
The Infinity Mods Piper Style Mechanical Mod is construction from brass. The Piper mod is small as Ennequadro IMO350 with only 22mm diameter. The mod is powered by 1 x 18650 battery (not included)
The silver color is electroplating
Armageddon Squonk Mechanical Box Mod Clone+ Apocalypse RDA Kit Clone $14.99
The Armageddon Squonk Mod Kit Clone consists of Armageddon Squonk Box Mod Clone and Apocalypse RDA Clone.
Mod:
The Armageddon Squonk Box Mod Clone is constructed from ABS (chassis) and PC (back panel) with copper contact for better conductivity. The built-in bottle is made from super soft silicone and is capable of holding about 6ml e-juice. The front panel comes with magnets and is replaceable. This mod is powered by a single 18650 battery (not included).
The 510 pin is not adjustable.
RDA:
The Apocalypse RDA Clone is with clamp design and has a massive space in each clamp which provides space for mounting the most complex and insane coil builds. Coupled with the deep juice well, wide build deck, durable post clamps and extended post screws, the RDA is a builder's dream.
Original Kangvape TH-420 II Box CBD 650mAh Battery + 0.5ml Atomizer Kit $14.99
TH-420 II Box is R&D by kangvape technology, it has special design, can adjustable working voltage 3.4V-3.7V-4.0V, also different light display current battery power. Beautiful surface, very small and convenient. The atomizer is smartly inserted and locked in the box by a magnetic connector, it can use all 510 hemp CBD coil atomizer.
Original SMOKTech SMOK NOVO 2 25W 800mAh Pod System Starter Kit $21.99
The authentic SMOKTech Novo 2 Kit is the upgraded version of Novo, an advanced draw-activated device. The Novo 2 has been optimized from every detail which is a definitely mini and light device. Smaller than your palm, so it can be easily put into your pocket or bag. You can take it anywhere! Novo 2 follows the design style of its first generation, with a curved body, it allows you to grip comfortably. And whistle-shaped mouthpiece can perfectly fit your lips. It definitely is the representative product of the electronic cigarette industry. With built-in 800mAh battery, longer vaping time is assured. Newly added air-intake grooves on both sides can bring more air in, combining with specially designed pods, cloudy vapor and purer taste can be produced. Also, it has redesigned sensing element to make you enjoy every puff, improved LED indicator to clearly show you accurate devices condition.
Старый 18.07.2019, 12:41 Автор темы   405
3FVAPE
Original Wismec Reuleaux Tinker 2 200W TC VW Variable Wattage Waterproof Box Mod $50.52
The WISMEC Reuleaux Tinker2 MOD is powered by dual 18650 batteries (not included), the kit supports a max 200W power and 0.96-inch screen. Due to the self-developed avatar chip, you can fire in 0.001 seconds and make vaping safer and more reliable. Besides, it also provides waterproof, shockproof and dustproof for protection. The leather and metal combination frame make it sumptuous and durable.
Kindbright VCM Hybrid Mechanical Mod Clone Original price $25.99, now only $10.99
The Kindbright VCM Mechanical Mod Clone is constructed from copper tube and brass caps. There are air holes on the top cap and the tube to prevent the battery from overheating. It is powered by 1 x 18650 battery (not included).
Kindbright Bully Mechanical Box Mod Clone $29.99
The Kindbright Bully mechanical box mod Clone is constructed from Delrin and Copper. The Kindbright Bully style mechanical box mod is powered by 2 x 18650 batteries (not included). This mechanical mod comes with magnetic battery covers, easy to remove it. This Kindbright Bully style mechanical box mod is designed for cloud chasing enthusiasts!
Kindbright Aventador Mechanical Box Mod Clone $39.99
The Kindbright Aventador mechanical box mod Clone is constructed from Aluminum. The Kindbright Aventador style mechanical mod is powered by 2 parallel 18650 batteries (not included). With the cool body design and amazing design, the Kindbright Aventador style mechanical box mod will bring you a wonderful vaping experience!
Original Wismec Reuleaux Tinker 2 200W TC VW Waterproof Box Mod + Trough Tank Atomizer Kit $64.45
The Wismec waterproof kit consists of WISMEC Reuleaux Tinker2 MOD and 6.5ml Trough Tank. Powered by dual 18650 batteries (not included), the kit supports a max 200W power and 0.96-inch screen. Due to the self-developed avatar chip, you can fire in 0.001 seconds and make vaping safer and more reliable. Besides, it also provides waterproof, shockproof and dustproof for protection. The leather and metal combination frame make it sumptuous and durable.
The Trough Tank adopts quick sliding top filling and adjustable airflow control. Together with unique WT01 Single 0.35ohm Head and WT02 Dual 0.2ohm Head, the WISMEC Reuleaux Tinker2 Kit will bring you an excellent vaping experience!
SMOKTech SMOK Infinix 2 Pod System Replacement Pod Cartridge (3 PCS) $9.99
The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product.
The SMOK INFINIX 2 Pod Cartridge is designed for the SMOK INFINIX 2 Kit. Comes with 2ml e-juice capacity and 1.4ohm resistance, it brings you a smooth vaping flavor. It is easy to fill and convenient to insert on the battery. 3 PCS each pack.
Original Pioneer4You IPV-3 Mini 30W Pod System Replacement ELF ADA Pod (2 PCS) $9.99
The Pioneer4You iPV ELF ADA Replacement Refillable Pods are a set of proprietary squonking pods for the iPV V3 Mini Pod System, featuring a split juice reservoir, single coil layout, and is equipped with a 1.0ohm MTL coil.
2 PCS / Pack
Старый 23.07.2019, 09:53 Автор темы   406
3FVAPE
Kindbright Zeus Mechanical Mod Clone Original price $20.99, now only $10.99
The Kindbright Zeus mechanical mod Clone is constructed from Copper. The mod is with copper contact and spring fired button. It is powered by 1 x 18650 battery (not included).
Kindbright VG Mini V2.5 Stacked Mechanical Tube Mod Clone $26.99
The Kindbright VG Mini V2.5 mechanical tube mod Clone is constructed from 316 stainless steel which is powered by dual 18350 or single 18500 / 18650 batteries (Not Included). It comes with adjustable silver plated contacts, bottom vent holes and side mounted spring-loaded firing button (anti-clockwise twisty locking ring).
Kindbright Reactor Squonk Mechanical Box Mod Clone $43.43
The Kindbright Reactor Squonk Box Mod Clone has a stunning appearance, which has a aluminum alloy body with PEI fire button on top. The mod is powered by single 18650 battery (NOT INCLUDED). The squeeze bottle has 8ml of juice capacity. There is no overhang with 25mm atomziers. The mod comes with engraved logo and serial number.
Kindbright Speed Revolution RDA Clone with BF Pin $11.99
The Kindbright Speed Revolution RDA Clone is constructed from 316 stainless steel and in 18mm diameter. The deck feature dual post for single / dual coil configuration. The RDA is with bottom feeder pin for squonk ready. There is no replacement center pin for the RDA.
Kindbright Speed Revolution Mini RDA Clone with BF Pin $12.99
The Kindbright Speed Revolution Mini RDA Clone is constructed from 316 stainless steel in 14mm diameter. The deck is dual post design for single coil building. The cap has a single airhole for side airflow. The POM drip tip is heat resistant for protecting your mouth from heat.
Kindbright Speed Revolution EVO RDA Clone with BF Pin $11.99
The Kindbright Speed Revolution EVO RDA Clone is constructed from 316 stainless steel with 14mm diameter. The deck features dual post design for only single coil building. The airflow is adjustable with single airhole. A removable wide bore drip tip is included.
Kindbright Le Concorde RDA Clone with BF Pin $12.99
The Kindbright Le Concorde BF RDA Clone is constructed from 316 stainless steel in 22mm diameter. The RDA features side adjustable airflow and two posts build deck. The Le Concorde BF RDA supports either a horizontal single coil or a double micro coil. The RDA is compatible with 510 drip tip.
Kindbright Solo RDA Clone with BF Pin $12.99
The Kindbright Solo RDA Clone is constructed from 316 stainless steel in 22mm diameter. It features two post for single coil building and top-side adjustable airflow.
Kindbright Sherman RDA Clone with BF Pin $14.99
The Kindbright Sherman RDA Clone is constructed from 316 stainless steel in 25mm diameter. It comes with clamp style dual post build deck and redirected bottom airflow. The RDA is suitable for different types of fancy coils. The air accesses the tunnel via bottom airslots and travel up to the bottom of the coils, which provides smooth airflow and nice flavor.
Original KAEES Aladdin MTL RTA Rebuildable Tank Atomizer Original price $31.34, now only $25.99
The KAEES Aladdin MTL RTA Rebuildable Tank Atomizer is a new production from Aladdin series. The MTL Rebuildable Tank Atomizer is made of high-quality food-grade 304 stainless steel which is healthy and environment friendly. And it comes with marvelous dome look for outstanding you. Two paralleled tracks with one post each, on its build deck, can match any kind of heating wire. Support various 510 drip tips, and, still looks gorgeous, connected with them. Combined type airflow adjustment system is machined, resulting in multi or single airflow inlet for your choice. Featuring quick lock system and half-circle ON / OFF on its top cap, it will bring you super easy operation experience.
Across Vape Wormhole Dvarw MTL RTA Clone $13.99
The Dvarw MTL RTA Clone features 22mm diameter and 3.0ml juice capacity. The Dvarw MTL RTA Clone is contructed from 316 stainless steel and PEI.
YFTK Ataman V3 RTA Clone $22.99
The Ataman V3 RTA Clone Rebuildable Tank Atomizer is made of 316 stainless steel with juice capacity of 4ml. And it is compatible with 510 drip tip.
Original Dovpo D Salt 26W Pod Kit 1500mAh Pod System Starter Kit $29.90
The authentic Dovpo D Salt Pod Kit is powered by 1500mAh built-in battery. The D Salt Pod Kit is small enough for users to bring it everywhere. For the cartridge, it has 2ml juice capacity and matches mesh coils for 0.5ohm.
Original HorizonTech Magico Pod 1370mAh System Starter Kit $40.99
The HorizonTech Magico Pod Kit is with 1370mAh battery capacity, which is large enough for users to carry on for days. For tHorizonTech Magico Pod Kit comes with fancy appearance and powerful effect. Its battery capacity is 1370mAh, which is large enough for users to carry on for days. For the cartridge, it has 6.5ml liquid capacity. It supports E-liquid and nicotine oil that is portable and compatible. With constant power output, the flavor and clouds could be stayed nicely.
Старый 25.07.2019, 12:23 Автор темы   407
3FVAPE
Original Vandy Vape Berserker V2 MTL RDA Original price $32.99, now only $25.55
The Vandyvape BSKR V2 RDA is a rebuildable drip atomizer. It features Dome and smaller evaporation chamber for throwing you fantastic MTL experience. It has slim appearance and got a great airflow system which definitely upgrade the flavor and the degree of clouds.Innovative Dual-shell cap design, presents better temperature control and Isolation.
YFTK AIRLab RM (Remastered) RDA Clone w/ BF Pin
The YFTK AIRLab RM (Remastered) RDA Clone is constructed from 316 stainless steel in 22mm diameter. The AIRLab Remastered RDA Clone is with dual-pole design for single coil building. Comes with bottom feeder for squonker mod.
Original VEIIK Airo 360mAh Pod System Starter Kit $20.99
The VEIIK Airo Pod Kit is a portable and exquisite pod system starter kit with PU sticked panels. The VEIIK Airo comes with built-in 360mAh battery, which can bring you durable vaping experience if fully charged. With the LED indicator light, it will be very convenient to know the battery status. The Coil resistance is 1.2ohm and 2ml refillable VEIIK Airo Pod Cartridge adopts advanced bottom air driven system and organic cotton to bring you optimal flavor of nicotine. The VEIIK Airo features draw-activated switch, so you will vape it without any button.
Original Zeltu X 1000mAh Pod System Starter Kit $35.99
The Zeltu X is an easy to use pod system device that works perfectly with both traditional style nicotine and nicotine salt e-liquids. Powered by a built-in1000mAh battery, it outlasts most pod devices and can be easily charged by a 1 A power source and the micro USB port on the side. The etched logo in the side of the device provides a juice window that is also back lit as a battery life indicator. The discreet fire button is located on the side of the device and five quick clicks turns the device on and off. As for the refillable pods, they can hold up to 2ml of e-juice and come in a 1.2 and 1.6 Ohm resistance. Each pod is claimed to last up to 15 refills or around the 30ml mark using thinner 50/50 or nic salt e-juices but of course this will always be juice and use dependent. All up, the Zeltu X is a really lovely little kit worth the slightly higher price point. 3 colors to choose from.
Vapeasy Across Vape Wormhole Tank Tube Clone + Drip Tip + Chimney for 22mm Dvarw MTL RTA $10.99
The Vapeasy Across Vape Wormhole Replacement Tank Tube Clone set including Drip tip, Top ring, Tank tube,
Chimney, chimney base, across coin Clonefor juice control.
It is suitable for the 22mm Dvarw MTL RTA in 3FVape. We are not if this will be suitable for the authentic 22mm Dvarw MTL RTA (please let us know if you confirm).
The tank and the drip tip is made from PMMA, and the Chimney and chimney base are made from PEI.
Original VEIIK Airo Replacement Pod Cartridge(2 PCS) $4.99
The VEIIK Airo Pod Cartridge is designed for VEIIK Airo Pod Kit System, it features 2ml juice capacity and 1.2ohm coil. Best for Nic salts. 2 pieces each pack.
Original Zeltu X Pod System Kit Replacement Pod Cartridge - 1.6ohm, 2ml (3 PCS) $14.99
The ZELTU X Replacement Pods is designed for ZELTU X Pod Kit System.And it has a dynamic atomizer cartridge built for the ZELTU X, featuring a 2.0mL refillable capacity, integrated 1.6ohm coil and comes with a new drip tip with each pod.
Старый 26.07.2019, 12:56 Автор темы   408
3FVAPE
Original Wotofo Recurve 80W Squonk Mechanical Box Mod Original price $49.99, now only $25.99
The authentic Wotofo Recurve Squonk Mod, a collaboration between Wotofo and Mike Vapes, is an 80W mech mod level squonk mod, and an unregulated mod with full safety features. It is powered by a single 18650, 20650, 20700, or 21700 battery (BATTERY NOT INCLUDED) under working voltage of 3.2~4.2 volts. The mod combines the essence of beautiful curves and ergonomics seamlessly and delivers a fantastic smooth feel with special rubber coating.
Original Wotofo Serpent BF RDA Original price $25.99, now only $7.99
The Authentic Wotofo Serpent BF RDA is constructed from stainless steel in 22mm diameter. It comes with a wide bore trip dip and a BF pin. The Wotofo Serpent BF RDA features dual independent posts with four wire holes and adjustable airflow.
Original Wotofo Nudge RDA w/ BF Pin Original price $35.99, now only $9.69
The authentic Wotofo Nudge RDA 22mm is a compact atty and the build deck is different from Nudge RDA 24mm. It features a single coil deck, which allows you to build coil effortlessly. Coming with two top caps with different airslots for your option, the U type airflow will give you a clean and flavorful vaping experience.
Original Wotofo Warrior RDA w/ BF Pin Original price $34.99, now only $9.99
The authentic Wotofo Warrior RDA was designed by JMT Elite together with Wotofo. The 25mm dual coil RDA is the most coil-friendly RDA incorporated with the profound wisdom of coiling. The Warrior RDA features a domed top cap which has a great deal of structural strength and functions to compress air as to enhance flavor. There are two sets of beehive style air holes (3 lines a set with 8 holes for each line) symmetrically positioned on two sides of the Warrior RDA sleeve. There are two clamp posts with 4 screws on the top to fix the coils. The overall chamber is relatively short but the space is large enough for proper vaporization.
Original Wotofo Serpent SMM RTA Original price $34.99, now only $14.99
The Wotofo Serpent SMM 24mm RTA is designed by Wotofo and Suck My Mod. The Serpent SMM features a unique redirected airflow system which brings air in from a dual adjustable bottom airflow control ring, and redirects the air up into the posts of the build deck where it exits parallel with the coil. This airflow system helps reduce leakage in comparison with traditional bottom airflow and offers enhanced flavor production. The build deck on the Serpent SMM RTA is a two post design with two slotted terminals per post to allow coil mounting for both forward and reverse wrapped coils. The Serpent SMM also features a gold plated 510 contact, an ULTEM 510 drip tip, 4ml E-Juice capacity, and a threaded top fill system for easy filling.
Hussar Project X MTL RTA Clone $17.99
The Hussar Project X MTL RTA Clone features 22.5mm diameter and 31.2mm height. The Coppervape Hussar Project X MTL RTA Clone is constructed from 316 stainless steel. This MTL RTA is with Interchangeable airflow to easily change the shot even after having assembled the coil
Original Hippovape Papua 100W VW Variable Wattage Box Mod + RDA Kit $35.99
The Hippovape Papua kit is constructed from Zinc Alloy and the Papua mod is equipped with the advanced waterproof chipset, its output power range is from 3W to 100W and produces an outstanding power output accuracy by 21700 battery which fires extremely fast.The Resistance Range is from 0.1ohm to 3.0ohm and the atomizer size is 24mm.Included in the kit is the Papua Rda atomizer which is optimized by the ultimate airflow that providing large vapor production. With a Pom single coil adapter attached, it can be single coil Rda which bring you better flavor.
Original Suorin Air Plus Replacement Pod Cartridge - 3.5ml, 1.0ohm (1 PCS) $2.99
The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product.Suorin Air Plus Pod Cartridge can hold up to 3.5ml of e-juice and features easy bottom filling and oil baffle design, preventing leakage effectively while meeting your daily vaping needs with less refilling. Plus the unique 1.0ohm coil, the pod is perfect for nicotine salt or regular e-liquid, bringing you an amazing vaping experience.
Hussar Project X MTL RTA Replacement Tight Airflow Pins - 0.8mm (2 PCS) $2.59
The replacement airflow pins are constructed from PEEK. The replacement airflow pins feature 0.8mm airflow hole, which corresponds to a single 1.1mm hole. The replacement airflow pins is suitable for Hussar Project X MTL RTA. 2 PCS per pack.
Hussar Project X MTL RTA Replacement Tank Tube $2.99
The replacement tank features 9.8mm height and 22mm diameter. The replacement tank is made from PEI. The replacement tank is suitable for Hussar Project X MTL RTA.
Hussar Project X MTL RTA Replacement Drip Tip $1.99
The replacement drip tip features 9.2mm height and 12.8mm diameter. The replacement drip tip is made from 316 stainless steel and PEI. The replacement drip tip is suitable for Hussar Project X MTL RTA.
Старый 27.07.2019, 09:30 Автор темы   409
3FVAPE
Original Kangvape TH-420 V Box CBD 800mAh Battery VW Mod + 0.5ml Atomizer Kit $14.99
The Kangvape TH-420 V Box is made of zinc alloy. It has a 0.5ml atomizer capacity, and its resistance is 1.5ohm.The TH-420 V Box is suitable for 510 thread. With build-in 800mAh battery , its pre-heating time is only 15 seconds.
Original GeekVape Bident Pod System Starter Kit Original price $33.90, now only $24.99
The GeekVape Bident Pod Kit has a 950mAh build-in battery, and a 3.5ml juice capacity. Constructed from durable zinc-alloy, the exterior profile of the Bident is visually striking and protects the internal Micro AS Chipset which provides a 3 tiered power output. Featuring the advent of dual coil technology, the Bident can access a 0.8ohm and 1.2ohm DTL and MTL Coil, respectively.
Original Reewape RW-AS250WY 510 Drip Tip $1.29
The Reewape RW-AS250WY glowing-in-the-dark and temperature change Drip Tip is made of Resin and it is suitable for 510 thread atomzier.
Original Reewape AS246 Replacement Drip Tip for Smoant Pasito Kit $1.29
The Reewape AS246 Replacement Drip Tip is made of Resin and it is designed for Smoant Pasito Kit.
Original Reewape 5-in-1 Shortfill Cap Opener Tool for Juice / E-Liquid Bottle $1.99
The Reewape 5-in-1 Shortfill Cap Opener Tool is made of Zinc alloy, it is convenient to open juice cap of 10ml, 30ml , 50ml , 60ml, 120ml, and most 23~24mm caps can be opened by Reewape 5-in-1 shortfill..
Original SMOKTech SMOK Novo 2 Pod System Replacement DC Pod Cartridge w/ 1.4ohm MTL Coil(3 PCS) $8.99
The Authentic SMOKTech Replacement Pod Cartridge is suitable for Novo 2 Pod System kit. The pod is with 2ml capacity and comes with 1.4ohm MTL Coil.
Original GeekVape Bident Pod Stystem Replacement Pod Cartridge w/ 1.2ohm Ni80 MTL Coil(2 PCS) Original price $14.99, now only $8.99
The GeekVape Bident Replacement Pod Cartridge is designed for the Geekvape Bident Pod System Starter Kit, and it has 2ml refillable juice capacity.The 1.2ohm coil supports MTL vape.
Старый 29.07.2019, 11:35 Автор темы   410
3FVAPE
SXK AIRLab RM (Remastered) RDA Clone Original price $18.90, now only $14.99
The SXK AIRLab RM (Remastered) RDA Clone is constructed from 316 stainless steel in 22mm diameter. The AIRLab Remastered RDA Clone is with dual-pole design for single coil building. Comes with bottom feeder for squonker mod.
Original SMOKTech SMOK Vape Pen Nord 22 2000mAh Mod + TF Tank Starter Kit $21.45
The SMOKTech SMOK Vape Pen Nord 22 is upgraded versions of Vape Pen series, which has all-round improvements on both appearance and performance. The Vape Pen is constructed from Stainless Steel. The Vape Pen Nord 22 has a battery capacity of 2000mAh and a 3.6ml E-liquid capacity. The tank is redesigned that gives you a different look and feel, which is paired with two exclusive Nord coils, Nord Mesh 0.6ohm coil can bring you Sub-Ohm vaping experience and Nord Mesh-MTL 0.8ohm coil offering excellent MTL experience.
SXK 510 Connector + Button + Screen Plate + Button Plate Set for SXK BB 60W / 70W Box Mod Kit(4 PCS) $31.99
This SXK replacement accessories set is suitable for SXK BB 70W / DNA60 60W box mod kit. This set is including 510 Connector + fire button + screen plate + button plate.
Original Wotofo Easy Fill Drip Cap for RDA Original price $7.99, now only $5.99
The Wotofo Easy Fill Drip Cap is designed to make it a lot easier when dripping eliquid into your RDA (rebuildable dripping atomizer).It is suitable for 60ml gorilla bottle.With this drip cap, you can turn your gorilla-style bottles into a juice pump that saves the trouble to pull the top off your RDA when dripping, and it makes sure you drip the juice just right onto the coil and cotton. The drip cap can be fit onto any chubby gorilla standard juice bottles. It has a pump action tip that you put in your drip tip or chuff cap. With only a couple of pumps (normally, 2 pumps), you have the perfect amount of juice in your RDA.
Across Vape Wormhole Replacement Tank Tube Clone + Drip Tip for 22mm Dvarw MTL RTA $7.59
The Across Vape Wormhole Replacement Tank Tube set Clone includes drip tip chimney Drip tip, Top ring, Tank tude, Chimney, Chimney base, across style coin for juice control. It is suitable for the 22mm Dvarw MTL RTA Rebuildable Tank Atomizer in 3FVape. We are not if this will be suitable for the authentic 22mm Dvarw MTL RTA (please let us know if you
Original SMOKTech SMOK Novo Pod System Replacement Pod Cartridge with 1.5ohm Coil(3 PCS) $7.79
The Authentic SMOKTech SMOK Replacement Pod Cartridge is suitable for Novo Pod System kit. The pod is with 2ml capacity and comes with 1.5ohm Coil.
Original SMOKTech SMOK Novo Pod System Replacement Pod Cartridge with 0.8ohm Mesh Coil (3 PCS) $9.09
The Authentic SMOKTech SMOK Replacement Pod Cartridge is suitable for Novo Pod System kit. The pod is with 2ml capacity and comes with 0.8ohm Mesh Coil.
Original SMOKTech SMOK Novo Pod System Replacement Pod Cartridge with 1.4ohm Ceramic Coil (3 PCS) $9.69
The Authentic SMOKTech SMOK Replacement Pod Cartridge is suitable for Novo Pod System kit. The pod is with 2ml capacity and comes with 1.4ohm Ceramic Coil.
Старый 30.07.2019, 05:51 Автор темы   411
3FVAPE
Original GeekVape Zeus Sub Ohm Tank Atomizer $29.99
The Geekvape Zeus Sub ohm Tank is the new version of Zeus series. This new atomizer continues the structural design of the Zeus RTA and Zeus X RTA. Zeus Sub-Ohm Tank retains the structural design concept of the original Zeus series with an upgraded quick-change prebuilt coil system, easy to replace coils. Utilizing the latest technology of GV Mesh coil system to optimize flavor and vapor production. Geekvape Zeus comes with 26mm diameter and 5ml capacity. The Geekvape Zeus tank version features prebuilt mesh coils, direct top adjustable airflow, top-to-bottom airflow, quick push/pull coil replacements, an upgraded fill port to reduce juice spillage, a leak-proof structure.
Ataman V3 RTA Clone $14.99
The Ataman V3 RTA Rebuildable Tank Atomizer Clone is made of 316 stainless steel with juice capacity of 4ml. And it is compatible with 510 drip tip.
Millennium RTA Rebuildable Tank Atomizer Clone $17.99
The Millennium RTA Rebuidable Tank Atomizer has a 4ml of juice capacity, and the diameter is 22mm.
Original Marvec MV 10W 400mAh VW Pod System Starter Kit $18.99
Constructed from PC and ABS material, it is very lightweight and easy to carry. The pod cartridge has 2ml of juice capacity and 1.5ohm coil. The MV has two output mode: auto mode and manual mode. The output power can be set as 6W, 8W and 10W. It has multiple protections to guarantee safe vaping.
Original Vladdin Slide 12W 1000mAh Pod System Starter Kit Original price$34.90, now only$24.90
The Vladdin slide pod system with a sliding panel and replaceable mesh coil- Vladdin Slide Pod System Kit 1000mAh. Unique sliding slide panel can be used over 50000 times, which allows for a convenient and fast side fill. Vladdin Slide Kit is constructed from different resin colored panels, which comes with portable size and distinguishable look. Unlike the Vladdin Re, the Vladdin Slide does not take on the traditional pen shape. It takes on the shape of a general box mod but smaller, forming a different style and design, more unique and distinctive. The battery is now even more powerful, with a 1000mah battery, maximum output of 12W. In addition, the battery now has a three-light battery indicator. With three different voltage settings, the vaping experience is tailored to you. As for the pod, it adopts a powerful mesh coil and also supports coil replacement. The airflow of the device is designed to allow each user to change it according to their preference. If you like larger clouds, adjust to more restricted airflow, or a looser airflow for ease of vaping. Whatever the preference may be, Vladdin has you covered. There are available in four colors for your options.
Original Han Yan 300mAh Wireless Charger for Juul Pod System $20.99
The Authentic Han Yan Wireless Charger is designed for Juul pod system. It has a battery capacity of 300mAh. The set includes 1 x 2 in 1 lanyard + 1 x micro USB cable + 1 x protect shell + 1 x user manual.
Original GeekVape Zeus Z1 KA1 Mesh Coil Core Head for GeekVape Zeus Sub Ohm Tank Atomizer - 0.4 ohm(60~70W) (5 PCS) Original price$14.99, now only$10.99
The Geekvape Zeus Mesh Coil is specially designed for the Zeus Sub Ohm Tank Atomizer. The Zeus mesh coil is constructed from KA1 which is a longer lifespan and the resistance of it is 0.4 ohm. Output power is from 60 to 70W. Quick slide coil design allows for quick access coil replacement.
Original GeekVape Zeus Z2 KA1 Mesh Coil Core Head for GeekVape Zeus Sub Ohm Tank Atomizer - 0.2 ohm(70~80W) (5 PCS) Original price$14.99,now only$10.99
The Geekvape Zeus Mesh Coil is specially designed for the Zeus Sub Ohm Tank Atomizer. The Zeus mesh coil is constructed from KA1 which is a longer lifespan and the resistance of it is 0.2 ohm. Output power is from 70 to 80W. Quick slide coil design allows for quick access coil replacement.
Original Uwell Yearn 11W 370mAh Pod System (Body Only) $14.85
The Uwell Yearn Pod System is powered by 370mAh built-in battery. It is designed with smooth lines and simple classic appearance, which provides comfortable hand feelings. Adopting the UWELL patented isolated e-liquid chamber technology, it will offer you a convenient and fresh vaping experience. It features draw-activated mechanism for easy operation. The chip has multiple circuit protection functions to supply stable, safe and reliable performance. What's more, the unique Pro-FOCS flavor testing technology will provide you with the ultimate vaping experience by controlling the heating temperature and completely restoring the E-liquid flavor.
SXK Button + Screen Plate + Button Plate Set for SXK BB 60W / 70W Box Mod Kit Original price$31.99, now only$26.99
This SXK replacement accessories set are suitable for SXK BB 70W / DNA60 60W box mod kit. This set includes fire button + screen plate + button plate.
SXK 510 Connector + Button + Button Plate Set for SXK Bantam BB Mini Box Mod Kit Original price$31.99, now only$26.99
This SXK replacement accessories set are suitable for SXK BB Bantam BB Mini box mod kit. This set includes 510 Connector + fire Button + Button Plate.
Старый 31.07.2019, 05:43 Автор темы   412
3FVAPE
Original Wotofo Stentorian RAM Bottom Feeder Squonk Mechanical Box Mod original price$29.99, now only$14.99
The mod body of Authentic Wotofo Squonk Mechanical Box Mod is constructed from resin (Black + Blue + Yellow)+ which is one of the first affordable bottom feeder squonk mods in the market.It features an elegant design and comes with 7ml squonk bottle. The Squonk Mechanical Box Mod has a fire button with a safety lock on to prevent accidental discharge.
GeekVape Aegis Legend 200W TC VW APV Box Mod original price$74.00, now only$54.49
The Aegis legend is a stylish box mod designed to be water and shock resistant, the beast is now back and compatible with dual 18650 batteries powered by the new AS chipset that releases up to 200W output. This is a second to none choice for those who are looking for a durable box mod with extreme power and portability.Aegis Legend Limited Edition is constructed with new Magnesium Alloy material which is currently the world's strongest and lightest metal. While still maintaining the water, shock, and dust resistance feature of the standard version, the beast is back and is lighter than ever.
Hussar Project X MTL RTA Clone $19.99
Original GeekVape Aegis Legend 200W TC VW Box Mod + Zeus Sub-Ohm Tank Atomizer Kit Original price$95.00, now only$68.89
The Zeus Sub-Ohm Tank retains the structural design concept of the original Zeus series with an upgraded quick change prebuilt coil system. Utilizing the latest technology of GV Mesh coil system to optimize flavor and vapor production. The Zeus Sub-Ohm Tank is easily an unbeatable tank to date.Combination of both direct top airflow and the top-to-bottom airflow creates massive flavor and vapor boost while preserving its leakproof protection element.Quick slide coil design allows for quick access coil replacement. The Aegis legend is a stylish box mod designed to be water and shock resistant, the beast is now back and compatible with dual 18650 batteries powered by the new AS chipset that releases up to 200W output. This is a second to none choice for those who are looking for a durable box mod with extreme power and portability.Aegis Legend Limited Edition is constructed with new Magnesium Alloy material which is currently the world's strongest and lightest metal. While still maintaining the water, shock, and dust resistance feature of the standard version, the beast is back and is lighter than ever.
Hussar Project X MTL RTA Tight Airflow Pins Clone $1.99
The Tight airflow pins are constructed from PEEK and it features 0.8mm airflow hole, which corresponds to a single 1.1mm hole.The airflow pin is suitable for Hussar Project X MTL RTA Rebuildable Tank Atomizer.
Kindbright Replacement 510 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank $3.99
The Kindbright 510 Drip Tip is made of stainless steel (base) + PEI (mouthpiece) and it is suitable for 510 thread atomzier.
Original Aleader AS107C Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.59
The Aleader AS107C 810 Drip Tip is made of resin and It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Original Aleader AS107 Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.59
The Aleader AS107 810 Drip Tip is made of resin and It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Original Aleader AS108 Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.59
The Aleader AS108 810 Drip Tip is made of resin and It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Original Aleader AS107S Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.59
The Aleader AS107S 810 Drip Tip is made of resin and It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Replacement Drip Tip for Uwell Caliburn Pod System $1.99
The Replacement Drip Tip is made of Polypropylene material and it is suitable for Uwell caliburn pod system.
Replacement Pod Cartridge with 1.8ohm Ceramic Coil for Jbox Pod Kit / Juul - 0.5ml (4 PCS) $5.99
The Pod Cartridge with Ceramic Coil has a 0.5ml juice capacity and the resistance of the Ceramic Coil is 1.8ohm. The pod catridge is suitable for Jbox Pod Kit / Juul
Replacement Pod Cartridge with 1.8ohm Silica Wick Coil for Jbox Pod Kit / Juul - 0.7ml (4 PCS) $5.99
The Pod Cartridge with Ceramic Coil has a 0.7ml juice capacity and the resistance of the Silica Wick Coil is 1.8ohm. The pod catridge is suitable for Jbox Pod Kit / Juul
[Исправлено: 3FVAPE, 31.07.2019 в 06:05]
Старый 01.08.2019, 04:59 Автор темы   413
3FVAPE
Original Dovpo M VV II 280W VV Variable Voltage Box Mod $31.89
Dovpo M VV II Box Mod is made of PC + Zinc Alloy, and powered by dual 18650 batteries (Not Included) ,It features 1.0V to 8.0V voltage range,maximum 280W power wattage, and it has new aesthetic colorful look and a built-in USB Type-C port inside the box, battery reversal protection, a LED indicator that can show the life span of the battery.The thread type is 510 thread.
KF Lite Plus Five Pawns RTA Clone $10.99
The KF Lite Plus Five Pawns RTA Clone is constructed from 316 stainless steel with PC tank. It is 22mm in diameter and comes with 2.5ml capacity. With the special "Pawn" Clone drip tip, you can enjoy more denser flavor as well as a high volume of vapor.
Original Oukitel Bison Pod System Kit Replacement Pod Cartridge - Silver, 2ml (2 PCS) $5.99
The Oukitel Bison Pod System Replacement Pod Cartridge (Standard Version) features 2ml E-liquid / Juice capacity, which is available for your vaping longer. It is compatible with 1.2ohm ceramic coil (Not included) and 0.6ohm mesh steel coil(Not included). The Pod Cartridge is small and light, which is easy to reload in a minute. It is suitable for Oukitel Bison Pod System Kit.
Original Oukitel Bison Pod System Kit Replacement Mesh Coil Head - 0.6ohm (3 PCS) $6.99
The Oukitel Bison Mesh Coil Head is designed for Oukitel Bison Pod System Kit. The resistance of the Mesh Coil is 0.6ohm. It is durable and stable to create massive clouds and purer flavor. Each one is 3 pieces in a pack.
Original Oukitel Bison Pod System Kit Replacement Ceramic Coil Head - 1.2ohm (3 PCS) $6.99
The Oukitel Bison Ceramic Coil Head is designed for Oukitel Bison Pod System Kit. The resistance of the Ceramic Coil is 1.2ohm. It is durable and stable to create massive clouds and purer flavor. Each one is 3 pieces in a pack.
SXK Replacement Tank for BB Box Mod Kit / Bantam Box BB Mini Box Mod $7.99
The SXK BB Box Mod Style Replacement Tank is constructed from PC and glass. It is designed for SXK BB Box Mod Kit / Bantam Box BB Mini Box Mod.
Старый 02.08.2019, 05:58 Автор темы   414
3FVAPE
Kindbright Timekeeper Mechanical Mod Clone original price$25.99, now only$10.99
The Kindbright Timekeeper mechanical mod Clone is made from Brass and powered by 18650 battery (Not Included)The adjustable brass bottom-fire button with opposing earth magnet will be very easy for you to use. Hope this mod will bring you good vaping experience.
Kindbright Sentinel RDA Clone with BF Pin $12.99
The Kindbright Sentinel RDA Clone is constructed from 316 stainless steel in 22mm diameter. The deck features dual post design for single coil build. The airflow can be adjusted with the top airflow ring and angled airslots. A heat resistant POM drip tip is included for the RDA.
Kindbright NarCA RDA Clone with BF Pin $9.99
The Kindbright Narca RDA Clone is constructed from 316 stainless steel in 22mm diameter. The deck features dual post design for single coil building. The airflow is adjustable with the airslots on the cap. POM heat resistant drip tip is included.
Kindbright X1 RDA Clone original price$14.99, now only$5.99
Constructed from brass, the Kindbright X1 RDA Clone is a 24mm RDA with a quad post design, and adjustable bottom airflow. The X1 RDA Clone is adjustable bottom airflow design, allowing you to fine tune your airflow.
Kindbright KA V8 Nano RTA Clone $14.99
The Kindbright KA V8 Nano RTA Clone is a 22mm rebuildable tank atomizer with 2.8ml of juice capacity. It is made from 316 stainless steel. The RTA features dual post build deck, heat sink top cap and bottom adjustable airflow.
Kindbright KA V8 RTA Clone with Full Tank Kit $14.99
The Kindbright KA V8 RTA Clone is a 22mm rebuildable tank atomizer with 5ml of juice capacity. It is made from 316 stainless steel. The RTA features dual post build deck, heat sink top cap and bottom adjustable airflow.
Kindbright M-Atty RDA Clone with BF Pin $12.99
The Kindbright M-Atty RDA Clone is constructed from 316 stainless steel. This RDA supports single and dual coils building. And the deck of this RDA is designed around common vertical & horizontal builds.
Original FreeMax Gemm 80W 2900mAh VW Mod + Disposable Tank Kit $24.09
The Gemm Kit consists of Gemm 80W VW Mod and Gemm Disposable Tank. It is powered by 2900mAh built-in battery for whole day vaping. The Gemm Tank adopts eco-friendly PCTG material and easy top-filling system for provideing 360 degree e-liquid feeding. Gemm Tank adopts the new diamond mesh structure, which offers a surpassing balance of e-juice leading and intense flavor. And multiple built-in mesh coils are for your options. The output wattage of Freemax Gemm can be adjusted with 3 levels. With the intelligent LED indicator, you can get to know the battery level clearly. Multiple protections are applied to guarantee safe and stable vaping.
Original Curdo Viktor 400mAh Battery Mod CBD Kit $14.99
The Curdo Viktor CBD Kit is with delicate texture, metal paint appearance which is constructed from cuprum + pyrex glass tube. Curdo Viktor Kit is powered by built-in 400mAh battery to support vaping. Curdo Viktor adopts magnetic absorption and close-fit design, easy to operate.
Original SMOKTech SMOK Nord 15W 1100mAh Pod System Starter Kit $28.59
The SMOKTech SMOK Nord 15W 1100mAh Pod System Starter Kit is a newly designed button-triggered pod system device. It has 1100mAh battery capacity, extremely large among pod system devices, making it a definitely powerful one. It is equipped with two exclusive coils, Nord Mesh 0.6 coil and Nord regular 1.4 coil, one is perfect to get massive vapor; the other can offer excellent MTL experience. It also has a perfect size for you to hold in hand, a newly added button to start vaping and provide information about battery life, besides, there's an e-liquid window on the pod, all of which are for your convenience.Nord's mouthpiece continues the duck-billed design, but it also has a great improvement, with a lip curve on it, this mouthpiece could perfectly fit your mouth and offer better user experience.Nord has 3ml e-liquid capacity, pretty large for a pod system devices, you can choose your favorite e-liquid to drip in and enjoy long time vaping. There's a LED light on the button, press it twice then red, orange or green light will be on. Red light will on when battery power is lower than 30%; orange light will on when power is between 30% to 70%; and green light will on when power is between 70% to 100%. According to the different light colors you can clearly know the device's battery conditions.
Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $2.29
The 810 Drip Tip is made of stable wood and it is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Старый 05.08.2019, 05:53 Автор темы   415
3FVAPE
Original MECHLYFE x AmbitionZ Vaper Arcless Mechanical Mod original price$79.00, now only$52.99
The MECHLYFE Arcless is a new portable and durable mechanical mod cooperated between MECHLYFE and AmbitionZ Vaper. As a great cooperation between MECHLYFE and famous reviewer AmbitionZ Vaper, the MECHLYFE Arcless is a brand-new safer and portable tube mechanical mod with 27mm diameter and 91mm height of the original tube. Plus the extra stacked tube (sold separately), the height of MECHLYFE Arcless could be extended to 164mm. Moreover, the ARCLESS MOD is compatible with 20700, 21700 and 18650 batteries (18650 Battery is excluded).
Original FreeMax Neutron Star Sub-Ohm Tank Atomizer original price$20.99, now only$10.99
The Freemax Neutron Star Sub-Ohm Tank is a simplified Sub-Ohm system with user-friendly features, such as bottom airflow control and top-fill functionality with 2ml maximum juice capacity. Measuring 22mm in base diameter, the Neutron Star sub-ohm Tank presents beautiful colorways and patterns inspired from the FireLuke Tank, ranging from stainless steel finish to unique resin designs. The atomizer core implements dual vertical coils with a wattage range between 20 to 55W in two types of resistance: 0.25ohm and 0.5ohm.
Original Vapeston Maganus Cloud Blaster RTA original price$30.99, now only$20.99
The Vapeston Maganus Cloud Blaster is the next generation in sub ohm tanks, with top airflow and X3 Turbo coil. The Cloud Blaster supports 50~260W with performance equivalent to even the rebuildable atomizers. The unparalleled top airflow control system brings you both variety and quality to satisfy you preferences. In the meantime, the RTA coil is included so you can enjoy the diversification of the cloud blaster conveniently. And it is a 25mm tank with 5ml E-liquid capacity and comes with a velocity X3 RTA coil, 0.15ohm and 0.2ohm X3 Turbo coils for high wattage mods.
Original MECHLYFE x AmbitionZ Vaper Slatra Mesh RDA with BF Pin original price$32.90, now only$23.99
The MECHLYFE x AmbitionZ Slatra Mesh BF RDA comes with a triple clamp deck Clone for easy dual mesh coil installation. The Slatra Mesh RDA is also compatible with regular coils. The Slatra Mesh BF RDA adopts resin 810 drip tip for massive vapor production too. The Slatra Mesh BF RDA features bottom feeding pin, so you are capable of matching it with other squonker Mods. The regular 510 pin is also included. The honeycomb step down airflow of Slatra Mesh BF RDA will bring best air inlet to the coils.
Kindbright Speed 2019 RDA Clone with BF Pin $12.99
The Kindbright Speed 2019 RDA Clone Rebuildable Dripping Atomizer is constructed from 316 stainless steel in 18mm diameter. The RDA is with dual pole for single coil. The bottom feeder pin.
Kindbright Replacement Drip Tip for 900 BF RDA $3.59
The Kindbright Drip Tip is made of 316 stainless steel (base) + POM (mouthpiece) and it is suitable for 900 BF RDA Rebuidable Dripping Atomizera
Kindbright Replacement 510 Drip Tip for 900 BF RDA $4.89
The Kindbright 510 Drip Tip is made of 316 stainless steel (base) + POM (mouthpiece) and it is suitable for 900 BF RDA Rebuidable Dripping Atomizer
Kindbright 316 Stainless Steel Base Deck + Accessory Bag for 900 BF RDA (with Logo) $10.85
The Kindbright base is made of stainless steel and it is suitable for 900 BF RDA Rebuidable Dripping Atomizer. with logo
Kindbright 316 Stainless Steel Base Deck + Accessory Bag for 900 BF RDA (without Logo) $10.85
he Kindbright base is made of stainless steel and it is suitable for 900 BF RDA Rebuidable Dripping Atomizer Without Logo
Kindbright Repalcement Top Cap for 900 BF RDA Type A $6.09
The Kindbright top cap is made of 316 stainless steel, and it is suitable for 900 BF RDA Rebuidable Atomizer
Kindbright Repalcement Top Cap for 900 BF RDA Type B $6.09
Original MECHLYFE x AmbitionZ Slatra Ni80 Mesh Coil Sheet - 0.22ohm (30~50W) (10 PCS) $3.99
The MECHLYFE x AmbitionZ Slatra Mesh Coil is made of Ni80 material, the resistance of this mesh coil is 0.22ohm, and it is perfectly compatible with MECHLYFE x AmbitionZ Slatra Mesh RDA. And the Slatra Mesh Coil comes Get it for your RDA and enjoy a pure flavor and a amazing vaping.
Original MECHLYFE x AmbitionZ Slatra Kanthal A1 Mesh Coil Sheet - 0.13ohm (30~50W) (10 PCS) $3.99
Original MECHLYFE x AmbitionZ Slatra Kanthal A1 Mesh Coil Sheet - Silver, 0.13ohm (30~50W) (10 PCS) Model: 39272 Free Shipping for Most Countries When Orders > $15 Normal. Dispatches in 3 - 7 business days. $3.99 Add to Wishlist Add to Compare Qty: 1 Add to Cart The MECHLYFE x AmbitionZ Slatra Mesh Coil is made of Kanthal A1 material, the resistance of this mesh coil is 0.13ohm, and it is perfectly compatible with MECHLYFE x AmbitionZ Slatra Mesh RDA. And the Slatra Mesh Coil comes Get it for your RDA and enjoy a pure flavor and a amazing vaping.
Original MECHLYFE x AmbitionZ Slatra Kanthal A1 Mesh Coil Sheet - 0.26ohm (30~50W) (10 PCS) $3.99
The MECHLYFE x AmbitionZ Slatra Mesh Coil is made of Kanthal A1 material, the resistance of this mesh coil is 0.26ohm, and it is perfectly compatible with MECHLYFE x AmbitionZ Slatra Mesh RDA. And the Slatra Mesh Coil comes Get it for your RDA and enjoy a pure flavor and a amazing vaping.
Original FreeMax Neutron Star Sub-Ohm Tank Atomizer Replacement Coil - 0.25ohm (20~55W) (5 PCS) $6.99
The FreeMax Neutron Star Replacement Coil is designed for the FreeMax Neutron Star Sub-Ohm Tank Atomizer and it is made of kanthal material. The resistance of this coil is 0.25ohm.
Original FreeMax Neutron Star Sub-Ohm Tank Atomizer Replacement Coil - 0.5ohm (20~50W) (5 PCS) $6.99
The FreeMax Neutron Star Replacement Coil is designed for the FreeMax Neutron Star Sub-Ohm Tank Atomizer and it is made of kanthal material. The resistance of this coil is 0.5ohm.
Старый 06.08.2019, 05:32 Автор темы   416
3FVAPE
Whisper RDTA Clone $12.99
The Whisper RDTA Rebuildable Dripping Tank Atomizer Clone is made of stainless steel and PC with 22mm diameter and 2ml juice capacity. The RDTA is with dual-pole for single coil. This Whisper RDTA Clone supports MTL Vaping
Whisper RDA Clone $8.99
The Whisper RDA Rebuildable Dripping Atomizer Clone is made of stainless steel + PC with 22mm diameter. The RDA is with dual-pole and side airflow for single coil.
Original Yachtvape Meshlock RDA with BF Pin original price$35.99, now only$29.99
The Yachtvape Meshlock RDA Rebuildable Dripping Atomizer is made of Resin + Stainless Steel with 24mm Diameter which is a super innovative rebuildable atomizer. Specifically designed for mesh coils, this RDA features press-to-open terminals(no screw drivers) for extremely easy and fast coil installation. This RDA was designed with squonking in mind, utilizing three juice holes to ensure proper and full saturation of your wicks. Two of the holes direct to the juice wells on either side of the deck, and a third directs juice straight to the coil.
Vapor Giant VG V6M RTA Clone $24.99
The Vapor Giant VG V6M RTA Clone is made from stainless steel and glass tank with 7.5ml capacity. The V6M RTA Clone is with dual-pole and flexible airflow control for single coil building. The V6M RTA Clone is with top-filling system for improving leakage protection.
The Whisper RDA Rebuildable Dripping Atomizer Clone is made of stainless steel + PEI with 22mm diameter. The RDA is with dual-pole and side airflow for single coil.
MLM RTA Clone $17.99
The MLM RTA Rebuidable Tank Atomizer has a 4ml of juice capacity with 22mm diameter.
Vapor Giant VG V6M RTA Clone $23.99
Magnetic Clip Necklace Holder for Juul Pod System Starter Kit $3.99
The Magnetic Clip necklace Holder is made of stainless steel + ABS and it is suitable for Juul Pod System Starter Kit.
SXK Replacement Front + Back Cover Panel for BB Box Mod Clone original price$22.00, now only$14.99
The SXK Replacement Cover Panel is made of PC material, and is designed for SXK BB 70W / DNA60W Box Mod Clone. This cover panel comes with 2 pieces (front and back).
810 Replacement Anti Spit Back Drip Tip for Goon / Kennedy / Reload / Battle RDA $0.99
The replacement 810 drip tip is made of acrylic. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Старый 07.08.2019, 05:25 Автор темы   417
3FVAPE
350 Mechanical Mod Clone $12.99
650 Mechanical Mod Clone $14.99
The 650 Mechanical Mod Clone is constructed from brass and powered by 1 x 18650 battery (not included). The mechanical mod is with 22mm diameter and only 70mm height. The mod is side fire button.
Comp Lyfe Mini HK 24 Mechanical Mod Clone $13.99
The Comp Lyfe Mini HK 24 Mechanical Mod Clone is constructed from brass and powered by 1 x 18350 battery (not included). The mechanical mod is with 24mm diameter.
Original HorizonTech Falcon King Sub-Ohm Tank Atomizer $27.99
The Horizon Falcon King Sub Ohm Tank Atomizer is new version of HorizonTech Falcon series, which features large 6ml E-juice capacity can meet your daily vaping need. Horizon Falcon King Tank adopts durable Pyrex glass and high quality stainless steel material, plus resin drip tip. The refilling design of Falcon King tank is very special, click the button to open top cap. Falcon King Atomizer is compatible with new coils of M-Dual 0.38ohm mech coil and M1+ 0.16ohm mesh coil, which are made of bamboo fiber to bring you better flavor and longer lifespan. Furthermore, Falcon King Tank is able to compatible with all of falcon coils.The Horizon Falcon King Sub-Ohm Tank Atomizer is with massive dual adjustable airflow control and top-filling system for improving leakage protection.
Original Vaporesso PodStick 900mAh Pod System Starter Kit $20.99
The Vaporesso PodStick Pod System Starter Kit was newly launched by Vaporesso. It features its pen-style outlooking with aluminum housing and medical-grade PCTG material Pod, which is the perfect combination for excellent vaping life. Equipped with 900mAh built-in battery to provide you stable vaping life without charing the whole day. Besides, there are 3 levels of power for your selections, thus you enable to set your device to the favorite status if you like. Powered by OMNI Board Mini chipset, the performance of PodStick be outstanding. Adding a Pod to pen-style makes PodStick the most user-friendly device with the ability of sub-ohm and MTL vaping. PTF on top is taken to the next level with the sliding top cover, giving you the easiest, cleanest and safest filling system. With 0.6ohm meshed coil for MTL vaping, 1.3ohm ccell coil for Nic-salts. Having the option of Ccell and Meshed coil pod cartridge, you can choose to get that lung hit or for a smooth mouth to lung vape. The 5 level battery indicator keeps you in the know when its time to top up.What's more, multiple protections applied to ensure your device stable.
Vertex Mechanical Box Mod + RDA Kit Clone $14.99
The Vertex Mod Kit Clone consists of RDA atomizer (Stainless Steel) and mechanical Mod Kit (Aluminum Alloy + POM). Compatible with 18650 battery powered (Not included)
Original REEWAPE AS108 Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $1.59
Replacement 510 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank $2.99
The 510 Drip Tip is made of stainless steel and it is suitable for 510 thread atomzier.
Replacement 510 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank $1.99
The 510 Drip Tip is made of POM and it is suitable for 510 thread atomzier.
Original Vaporesso PodStick Pod System Kit Replacement Pod Cartridge with 1.3ohm Ccell Core Coil $6.99
This Replacement Pod Cartridge with Ccell core coil is designed for the Vaporesso PodStick Pod Kit, coming with 2ml E-juice capacity. With this pod cartridge, you can get that lung hit or for a smooth MTL vapeing. Optimized dimension of micro pore to fully realize flavors for nic-salts. Increased airflow to boost flavor and cloud production
Original Vaporesso PodStick Pod System Kit Replacement Pod Cartridge with 0.6ohm Mesh Coil $6.99
Original Horizon Falcon King Replacement Bubble Glass Tank Tube $2.99
The replacement 6ml bubble glass tank tube is suitable for authentic Horizon Falcon King Tank Atomizer
Original HorizonTech Falcon King Sub-Ohm Tank Atomizer Replacement M-Triple Mesh Coil Head - 0.15ohm (3 PCS) $14.99
The HorizonTech Falcon King Replacement M-Triple Mesh Coil is designed for the HorizonTech Falcon King Sub-Ohm Tank Atomizer and it consists of 30% wood pulp and 70% cotton material. The resistance of this coil is 0.15ohm, and the recommended wattage is from 80W to 85W.
Original HorizonTech Falcon King Sub-Ohm Tank Atomizer Replacement M1 Mesh Coil Head - 0.15ohm (3 PCS) $10.99
The HorizonTech Falcon King Replacement M1 Mesh Coil is designed for the HorizonTech Falcon King Sub-Ohm Tank Atomizer and it consists of 30% wood pulp and 70% cotton wicking material. The resistance of this coil is 0.15ohm, and the recommended wattage is from 60W to 80W.
Original HorizonTech Falcon King Sub Ohm Tank Atomizer Replacement M-Dual Mesh Coil Head - 0.38ohm (3 PCS) $14.99
The HorizonTech Falcon King Replacement M-Dual Mesh Coil is designed for the HorizonTech Falcon King Sub-Ohm Tank Atomizer and it consists of bamboo fiber and cotton blend wicking material. The resistance of this coil is 0.38ohm, and the recommended wattage is from 70W to 80W.
Original HorizonTech Falcon King Sub-Ohm Tank Atomizer Replacement M1+ Mesh Coil Head - 0.16ohm (3 PCS) $10.99
The HorizonTech Falcon King Replacement M1+ Mesh Coil is designed for the HorizonTech Falcon King Sub-Ohm Tank Atomizer and it consists of bamboo fiber and cotton blend wicking material. The resistance of this coil is 0.16ohm, and the recommended wattage is from 60W to 75W.
3FVAPE вне форума   Вверх
Старый 08.08.2019, 04:43 Автор темы   418
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Squid Industries Squad Replacement Refillable Metal Atomizer $14.99
The Squid Industries Squad Kit Replacement Refillable Metal Atomizer comes with 2ml e-juice capacity and powerful 0.6ohm mesh coil to bring you a great vaping with purer flavor. The Refillable Metal Atomizer is also compatible with Aspire General BVC Coils & Artery HP Coils.
Original Squid Industries Squad Replacement RTA $19.99
The Squid Industries Squad Kit Replacement RTA Atomizer comes with rebuildable build deck and pre-made single coil to bring you a huger cloud. You can enjoy the DIY fun with it.
FTL M25 RTA Clone $18.99
The FTL M25 RTA Clone is constructed from stainless steel in 25mm diameter, comes with 2 glass tanks (4ml / 5.5ml). The FTL M25 RTA Clone is with side terminal postless deck design supports Dual or single coil building. The RTA is with reduces airflow to increases flavor. The FTL M25 RTA Clone is with clip top cap for conveniently filling. It is very convenient to replace cotton or Coils without emptying your juice.
Original Squid Industries Squad Rebuildable VW Pod System Kit $59.99
The Squid Industries Squad Kit is a revolutionary multiple-functional VW pod system Kit which is compatible with three kinds of Atomizers: Refillable Metal Atomizer, Disposable Pod (not included) and RTA Atomizer (not included) to satisfy all your vaping needs. The 2ml Refillable Metal Atomizer comes with a replaceable and powerful 0.6ohm mesh coil to bring a purer flavor and long-time usage. Powered by 950mAh built-in battery with innovative chipset, the Squid Industries Squad Battery supports 5 to 30W output with advanced VW working modes. And with the OLED Screen, you can know the working conditions clearly.
Original GTRS Barton Pod System Starter Kit $23.45
The GTRS Barton Pod System Starter Kit is an all-in-one pod system vaporizer kit which has an excellent performance. Latest Original GTRS Barton Vape Pod equipped with built-in 700mAh battery and 2ml refillable pod cartridge which can supports your vaping all day long and bring you a pure vaping experience. It uses a honeycomb design to add texture. With the zinc alloy material and uses IML technology, it has high quality and will bring you a comfortable hand-feel. The working output is 3.6V which can support 1.0~3.0ohm resistance.
Original Squid Industries Squad Replacement Plastic Disposable Pod - 3 PCS $9.99
The Squid Industries Squad replacement Plastic Disposable Pod is designed for Squad Kit. The Squad Plastic Disposable Pod is a Disposable Pod comes with 2ml e-juice capacity and easy top filling design without leakage. And with the unique built-in coil, the Squad Plastic Disposable Pod will bring you an amazing vaping.
Original Squid Industries Squad Replacement Mesh Coil Core Head - 5 PCS $7.99
The Squid Industries Squad replacement mesh Coil comes with 0.6ohm (15~23W) for optimal flavor and best taste. Designed for Squid Industries Squad Kit, the Squid Industries Squad Coil is easy to replace.
Original GTRS Barton Replacement Pod Cartridge $4.39
The GTRS Barton Pod Cartridge is designed for GTRS Barton Pod Kit System, it features 2ml juice capacity and 1.3ohm coil. 2 pieces each pack.
Original Damn Vape Foxtail-M Agleted Organic Cotton for RBA / RDA / RTA / RDTA $2.99
The Damn Vape Foxtail-M Agleted Cotton is an agleted strip of cotton, ideal for usage in mesh coil rebuildable vapes, the Foxtail-M cotton features a plastic sleeve on one end to allow for easy installation into the coil structure, and can produce pure and excellent flavor. It is suitable for RBA / RDA / RTA / RDTA Atomizer. Comes in a pack of 10 PCS.
Original Damn Vape Doom RTA Replacement Kanthal A1 0.13ohm Mex-Mesh Strips + 0.11ohm Quad Mesh Strips Sheet - (45~70W) (10 PCS) original price$7.99, now noly$4.99
The Damn Vape Doom Mesh Coil Sheet is made of Kanthal A1 material, the set includes 0.11ohm Quad-mesh coil (5 PCS) and 0.13ohm Hex-mesh coil (5 PCS). These mesh is perfectly compatible with Damn Vape Doom Mesh RTA Rebuildable Tank Atomizer. And the Mesh Coil comes get it for your RTA and enjoy a pure flavor and a amazing vaping.
Original Aspire Cleito Shot Disposable Tank Clearomizer $16.90
The Aspire Cleito Shot Disposable Tank Clearomizer is constructed from 25mm diameter food-grade plastic PTGC constructed tank and stainless steel body with 4.3ml E-juice capacity. With the mesh coil of 0.3ohm resistance and super-efficient wicking (Linen Fiber and Organic Cotton), the disposable tank clearomizer can make an enormous vapor and flavor production to satisfy both MTL and DTL vapers. The new coil design also gives the Cleito the ability to handle higher power / wattage than its Aspire predecessors. It can easy to realize top-filling, but can not adjustable airflow.
Старый 09.08.2019, 05:02 Автор темы   419
3FVAPE
Original Augvape Merlin Nano MTL RTA Original price $34.99, now only $20.99
Augvape presents the Merlin Nano MTL RTA, a 18mm rebuildable tank atomizer with 2ml e-liquid capacity and a smooth mouth to lung draw. The Merlin Nano RTA's build deck features a dual post single terminal build deck and a non-adjustable airflow open located at the base of the RTA which siphons air up through the bottom of the build deck giving the perfect MTL draw every time. For added user customization, an added 3.5ml acrylic tank and 22mm beauty ring is included within the package. Internally, the Merlin Nano RTA features the a dual post single terminal build deck that features an adjustable airflow control system. The airflow can be manipulated via three interchangeable airhole inserts. Each insert measures 7mm by 4mm and has from 1mm to dual 1mm air holes. The terminal measures in at 4mm by 5mm and can accommodate a single coil build configuration. As an added feature, Philip screws are located at the top of each terminal for hassle free coil installations. A unique PEEK chamber encompasses the entire build deck to reduce heat effectively and keep flavor on point.
Original E-Bossvape Epod Pod System Starter Kit $12.99
The E-Bossvape Epod Pod System is compatible with Juul Pod Cartridge. The Epod Pod System is equipped with a 500mAh built-in battery and juice capacity of 0.5ml. ST smart chip applied provides 6 safrty protections. The output and power indicator can indicate the battery capacity of your Epod kit well. 1 hour charging time can provide your Epod kit full energy. The 1.4ohm ceramic coil can provide you a good vaping experience.The E-bossvape Epod Kit features ergonomic design, so you are capable of gripping it in hands. The device adopts pre-heat function, so you will fill the e-juice and enjoy an amazing vaping experience.
Original 510Vape SPAS-12 Pod System Starter Kit $24.99
The 510Vape SPAS-12 Pod System Starter Kit is constructed from resin (Middle part) and Aluminum Alloy (Body). The pod kit is equipped with a built-in 950mAh battery and 2ml refillable e-juice / E-liquid capacity which can provide you for all-day-long vape. The tie clip design make you clip easily in anywhere. The connector is applied PC material and magnet connection. It is with 0.4ohm mesh coil (16W Max) and 0.8ohm dual coil (13W) that you can choose from different vaping.
Original 510Vape SPAS-12 Pod System Starter Kit Replacement Regular Coil Head $10.99
The Original 510Vape SPAS-12 Pod System Replacement Regular Coil Head is designed for 510Vape SPAS-12 Pod System Starter Kit. The SPAS-12 coil head comes with 0.8ohm resistance for your vaping experience. Just get it as a spare part for your 510Vape SPAS-12 Pod Kit.
Original 510Vape SPAS-12 Pod System Starter Kit Replacement Mesh Coil Head $10.99
The Original 510Vape SPAS-12 Pod System Replacement Mesh Coil Head is designed for 510Vape SPAS-12 Pod System Starter Kit. The SPAS-12 coil head comes with 0.4ohm resistance for your vaping experience. Just get it as a spare part for your 510Vape SPAS-12 Pod Kit.
Original 510Vape SPAS-12 Pod System Starter Kit Replacement Ceramic Coil Head $10.99
The Original 510Vape SPAS-12 Pod System Replacement Ceramic Coil Head is designed for 510Vape SPAS-12 Pod System Starter Kit. The SPAS-12 coil head comes with 1.2ohm resistance for your vaping experience. Just get it as a spare part for your 510Vape SPAS-12 Pod Kit.
Original 510Vape SPAS-12 Pod System Replacement Pod Cartridge without Coil Head $4.99
The 510Vape SPAS-12 Pod System Replacement Pod Cartridge features 2ml E-liquid / Juice capacity, which is available for your vaping longer. It is compatible with 0.8ohm Regular Coil (Not included), 1.2ohm ceramic coil (Not included) and 0.4ohm mesh coil (Not included). The Pod Cartridge is small and light, which is easy to reload in a minute. It is suitable for 510Vape SPAS-12 Pod System Kit.
Original Vandy Vape Replacement 810 Drip Tip for 528 Goon / Kennedy / Battle / Mad Dog RDA $2.99
The Vandy Vape 810 Drip Tip is made of ultem and It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Original Vandy Vape Cotton Loops for RDA / RTA / RDTA DIY Coil Building $1.99
The Original Vandy Vape Cotton Loops is made out of 100% Japanese cotton. It is good to wick the coils and will bring you great vaping experience.
Original Vandy Vape Cotton for RDA / RTA / RDTA DIY Coil Building - 160 x 99mm (5 PCS) $2.59
The Original Vandy Vape Cotton is made out of 100% Japanese cotton. It is good to wick the coils and will bring you great vaping experience. The product comes with 5 PCS in 1 pack.
Original Vandy Vape Ni80 Heating Resistance Wire for RDA / RTA / RDTA - 24GA, 1.64 ohm / Ft $3.59
The Original Vandy Vape Pure Nickel Ni80 heating resistance wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Nickel Ni80. It features 24GA gauge and 1.64ohm resistance value per feet, which will be a good choice for DIY.
Original Vandy Vape Ni80 Heating Resistance Wire for RDA / RTA / RDTA Vape - 26GA, 2.64 ohm / Ft $3.59
The Original Vandy Vape Pure Nickel Ni80 heating resistance wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Nickel Ni80. It features 26GA gauge and 2.64ohm resistance value per feet, which will be a good choice for DIY.
Original Vandy Vape SS316L Heating Resistance Wire for RDA / RTA / RDTA - 26GA, 1.7 ohm / Ft $2.90
The Original Vandy Vape SS316L Wire heating resistance wire is perfect for RBA / RTA / RDA atomizers. The wire is made from 316L stainless steel. It features 26GA gauge and 1.7ohm resistance value per feet, which will be a good choice for DIY.
Original Vandy Vape Kanthal A1 Mesh Wire DIY Heating Wire for Mesh RDA / RTA / RDTA - 2.8 ohm / Ft $3.99
The Original Vandy Vape Mesh Wire is made from Kanthal A1 wires with 10mm by 40mm size. It is designed for Vandy Vape Mesh RDA and is super easy to build. The mesh wire comes with 2.8 ohm per feet, totally 5 feet in length. This product comes with 80 mesh wires in 1 pack.
PVC Wrapper Skin Sticker for 20700 / 21700 Battery - DC Comics (20 PCS) $1.99
The wrapper sticker is commonly used for 20700 and 21700 battery. This product comes with 20 PCS in 1 pack.
PVC Wrapper Skin Sticker for 20700 / 21700 Battery - Carpet (20 PCS) $1.99
PVC Wrapper Skin Sticker for 20700 / 21700 Battery - Dark Vader (20 PCS) $1.99
Старый 10.08.2019, 04:45 Автор темы   420
3FVAPE
Original Vapefly German 103 Brunhilde MTL RTA $54.99
The Vapefly Brunhilde MTL RTA is designed and created by a top coiler MTL RTA manufacturer German 103 and Vapefly.The Vapefly Brunhilde RTA is constructed from stainless steel with 5ml e-juice capacity that big capacity meets you all day vaping. The 6 levels airflow can meet your different airflow control needs and the bottom airflow and easy single coil building design will bring you fabulous flavour. The wire of this RTA is made of premium stainless steel wire from Germany which will convenient the e-juice transfer. The 3.2mm (outer diameter) refilling port matches perfectly with the Chubby Gorilla V3.
Original Dovpo Peaks Vape 15W 650mAh Pod System Starter Kit original price$37.99, now only$28.99
The Dovpo Peaks is a unique designed flip-cover pod system that is constructed from Zinc-Alloy and PCTG, which is aesthetically pleasing with the metal feel and fine print finish. The pod kit features built-in 650mAh battery and a Type-C USB port that charges in 5V~650mA. It will bring you a stable and lasting vaping experience. What's more, there are available in 2 types of power output for the Peaks, level 1 with 8 watts and level 2 with 15 watts to control which power you're comfortable with. The PCTG material top refillable pod has a 2ml E-liquid capacity that enables to last you a day and has a window to check your liquid level inside your pod. Besides, there are two types of coils for your selections, with 1.4ohm ceramic coil for MTL and 0.8ohm mesh coil for DTL type of vaping. Both of them are high performance with a longer life span before it has a burnt taste.
Original OneVape Golden Ratio Pod System Starter Kit Replacement Mesh Coil Core Head - 0.6ohm (27W) (5 PCS) $11.99
The OneVape Golden Ratio mesh coil core head is especially designed for OneVape Golden Ratio Pod System Kit. The resistance of the mesh coil is 0.6ohm, which fits for non-nicotine E-liquid. 5 PCS in a pack.
Original OneVape Golden Ratio Pod System Starter Kit Replacement Ceramic-MTL Coil Head - 1.2ohm (14W) (5 PCS) $11.99
The OneVape Golden Ratio ceramic-MTL coil core head is especially designed for OneVape Golden Ratio Pod System Kit. The resistance of the ceramic-MTL coil is 1.2ohm, which fits for non-nicotine E-liquid. 5 PCS in a pack.
Original Coil Master Stainless Steel + Ceramic Straight Tip Tweezers for E-Cigarettes / RDA / RTA / RDTA $4.99
The Coil Master Straight Tip Tweezer can withstand the high temperature when you dry fire your coil. Making coil building so much easier. It is a great and handle tool if you are into rebuildable atomizers.
Original Vapefly Brunhilde MTL RTA Replacement Short Drip Tip $2.99
The Vapefly Brunhilde Replacement Drip Tip is made of delrin and it is designed for Vapefly Brunhilde MTL RTA Rebuildable Tank Atomizer.
Original Vapefly Brunhilde MTL RTA Replacement Long Drip Tip $4.99
The Vapefly Brunhilde Replacement Drip Tip is made of resin and it is designed for Vapefly Brunhilde MTL RTA Rebuildable Tank Atomizer.
Original Vapefly Brunhilde MTL RTA Replacement Short Drip Tip + Long Drip Tip + Tank Tube $9.00
The Vapefly Brunhilde replacement drip tip and tank tube are made of PMMA and it is designed for Vapefly Brunhilde MTL RTA Rebuildable Tank Atomizer.
Original Vapefly Brunhilde MTL RTA Replacement Frame $12.99
The Vapefly Brunhilde replacement frame is made of stainless steel and is suitable for Vapefly Brunhilde MTL RTA Rebuildable Tank Atomizer.
Original Vapefly Brunhilde German Stainless Steel Heating Wire for Top Coiler RTA $6.49
The Vapefly Brunhilde Top Coiler RTA replacement heating wire is made of German stainless steel and is suitable for Vapefly Brunhilde Top Coiler MTL RTA.
Время генерации страницы 0.63316 секунды с 15 запросами
