302462
822
382
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original OBS Cube X 80W VW Variable Wattage Box Mod Original Price $41.99, Now Only $33.90
Inherited from OBS Cube family, the OBS Cube X Box MOD is a new cute yet powerful VW box mod with fashionable appearance and portable size. The OBS Cube X box mod is powered by external single 18650 battery (not included) and fires up to 80W max output with advanced VW mode and multiple protections. Plus the 0.96 inch LED screen and easy-operated buttons, you can easily operate it and know the working conditions clearly. The Cube X MOD is comfortable in hand, durable to use and also brings you a great visual enjoyment. Get one and have a try. It is definitely a great daily vaping device for starters or stagers. ![]() Original Vapefly Jester 1000mAh Pod System Starter Kit Meshed Pod Version Original Price $28.99, Now Only $22.99 Welcome the newest Vapefly Jester Pod Kit with 1000mAh built-in battery. There is a regular refillable cartridge with unique 0.5ohm mesh coil and adjustable bottom airflow to bring you purer flavor. The Jester regular mesh pod has 2ml refillable e-liquid capacity , then you can simply add your favorite e-juice from the top. Don not worry about oil leak. There are three output voltage, 3.3V / 3.8V / 4.8V, for your selection. And it has the unique pod release buttons for easy disassembly with child-lock design. You can have a safe and great flavor vaping. ![]() Original Suorin Air Plus 930mAh 22W Pod System Starter Kit Original Price $34.99, Now Only $24.99 Suorin Air Plus Kit is an updated version to the previous Suorin Air. Powered by a built-in 930mAh battery, the Suorin Air Plus Kit implements a maximum output power of 22W and longer vaping time than the 400mAh Air. The battery can be fully charged in 50 minutes via the USB C type charging port on the bottom of the kit. Along one side of the kit, there are five battery life indicator lights that will turn off one by one depends on the battery level, 5 lights for above 80%, 4 for 60~80%, 3 for 40~60%, 2 for 20~40%, and 1 means the battery level is below 20%. As for the pod, it can hold up to 3.5ml of e-juice. ![]() Original OBS Cube X 80W VW Box Mod + Tank Pod System Starter Kit Original Price $55.99, Now Only $44.99 Glad to introduce the latest OBS Cube X Kit from OBS Cube family. The Cube X is a new fashionable and portable 80W VW kit powered by external single 18650 battery (not included) with stable and high performance VW mode. With the ergonomic design and attractive resin colors, the OBS Cube X is comfortable in hand, durable to use and brings you a great visual enjoyment. Moreover, it comes with a brand-new Cube X tank which features 2ml / 4ml e-juice capacity, easy slide top filling design and powerful 0.2ohm and 0.15ohm mesh coils to offer the purer flavor with optimal cloud. Plus the easy operated buttons, convenient USB charging and firmware upgrade design, the OBS Cube X Kit is definitely a wonderful daily vaping device. ![]() Original CKS Mamba 75W TC VW Variable Wattage Box Mod kit Original Price $69.99, Now Only $39.99 The CKS Mamba 75W Mod Kit consists a VW box mod powered by VO 75 chip and an atomizer ![]() Original Vapefly Jester Meshed Pod Cartridge for Jester Meshed Pod Kit Original Price $4.99, Now Only $3.99 The Vapefly Jester meshed pod cartridge is coming with its innovative design. The Vapefly Jester meshed pod cartridge comes with a refillable mesh pod. The regular refillable cartridge adopts 0.5ohm mesh coil and adjustable bottom airflow to bring you purer flavor. Designed for Vapefly Jester Kit, the Vapefly Jester meshed pod cartridge is easy for replacement. ![]() Original Vapefly Jester Replacement Mesh Coil Head for Jester Pod Kit Original Price $9.99, Now Only $7.99 The Vapefly Jester Coil is perfectly compatible with Vapefly Jester Kit. The Jester Mesh Coil features 0.5ohm resistance for your choice. ![]() Original OBS Cube Replacement M3 Mesh Coil Head Core for OBS Cube X Kit Original Price $17.99, Now Only $12.99 OBS M3 Mesh Coil has a resistance of 0.15ohm and is rated at 50W to 70W (best at 55~65W). The OBS M3 Mesh Coil is perfectly compatible with the OBS Cube X Kit. The OBS M3 Mesh Coil is more durable and stable as well. Just get it as spare parts for your Cube X Kit. 5 PCS in each pack. ![]() Original Suorin Air Plus Replacement Pod Cartridge $2.99 Suorin Air Plus Pod Cartridge can hold up to 3.5ml of e-juice and features easy bottom filling and oil baffle design, preventing leakage effectively while meeting your daily vaping needs with less refilling. Plus the unique 0.7ohm and 1.0ohm coils, the pod is perfect for nicotine salt or regular e-liquid, bringing you an amazing vaping experience.
383
DDP Trio Mechanical Tube Mod Clone $25.99
The DDP Trio Mechanical mod Clone is powered by 1 x 18650 / 18500 / 18350 battery (not included) with ultra low stroke side switch and maximum conductivity. The DDP Trio Style Mechanical mod features solid silver contacts, magnets mechanics. ![]() Rockvape Titan Mechanical Tube Mod Clone $20.99 The Rockvape Titan mechanical tube Mod Clone is powered by 1 x 18650, 20700 and 21700 battery (not included). This Titan mechanical mod supports magnets and spring firing button. ![]() Original Eleaf Tance Max 15W 1100mAh Pod System Starter Kit $24.39 Eleaf Tance Max Kit is somewhat similar to the Tance Kit in appearance but adopts a fire button rather than a draw-activated mechanism. Powered by a built-in 1100mAh battery, the Eleaf Tance Max Kit can fire up to 15W and last a long vaping time. The battery is also charged via the Type-C USB port on the bottom. Differing from the Tance, the bar LED light of Tance Max is embedded in its fire button. As for the refillable pod, it can hold up to 4ml of e-liquid and utilizes innovative rotary-to-fill design. Heating elements included in the set is a GS Air M 0.6ohm Head and a GS Air S 1.6ohm Head in the set, they can easily handle your different vaping needs. Besides, the Eleaf Tance Max Kit is also compatible with other coil heads of GS Air series. At last, the Eleaf Tance Max Kit features an accurate bottom airflow system with which you can effortlessly adjust the airflow to your preference. ![]() Original Eleaf Tance 10W 580mAh Pod System Starter Kit $19.74 Eleaf Tance Kit with portable size has a tiny and light design which you can take along in pocket or bag and hide in your hand easily. Powered by an internal 580mAh battery, the Eleaf Tance pod kit adopts no fire button design, simple to operate, the type-c charging which can provide you a quick charge in a short time. As for the pod cartridge, it utilizes innovative rotary refilling and leak-proof design, which offer you better vaping experience. The unique two kinds of intake airflow design will bring you a pure flavor! ![]() Original Eleaf Tance Pod Cartridge for Tance Pod System Starter Kit $13.90 Eleaf Tance Pod Cartridge has 2ml e-juice capacity and features easy bottom filling design, preventing leakage effectively while meeting your daily vaping needs with less refilling. The two kinds of intake airflow design will bring you an amazing vaping experience. ![]() Original Hellvape Fused Clapton Pre-Built Coil HC02 Heating Resistance Wire $4.99 The Original Hellvape 28G Fused Clapton HC02 coil is 10 PCS / pack. The Authentic Hellvape 28G Fused Clapton HC02 coil is a great replacement for DIY. ![]() Original Hellvape Competition Wire HW02 25Ga Heating Wire for RBA Atomizer $2.99 The Hellvape HW02 25Ga heating wire is perfect for RBA / RDA / RTA atomizer, such as IJOY Limitless RDTA / Goon RDA / Kennedy 24 RDA and most of other RBA. The Hellvape HW02 25Ga heating wire will be a good vaping choice for DIY. The Hellvape HW02 25Ga heating wire is resilient and durable. It is easy to reload and makes the flavor great. ![]() 810 Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $1.29 The 810 drip tip is made from acrylic with 17.8mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
384
SXK Haku Riviera RDTA Rebuildable Dripping Tank Atomizer Clone Original Price $22.90, Now Only $21.09
Please log in to see the lower price.This SXK Haku Riviera RDTA Clone is made from 316 stainless steel with 22mm diameter. The rebuildable atomizer has large build deck with cut-outs for easy coil placement. The RDTA adopts bottom-feed pin for squonking use. ![]() SXK Taifun GTR MTL RTA Rebuildable Tank Atomizer Clone Original Price $21.90, Now Only $19.75 Please log in to see the lower price.The SXK Taifun GTR RTA Clone is made from 316 stainless steel and PC tank. The 23mm MTL RTA is in 23mm diameter and 4.0ml capacity. ![]() Original Vapefly Galaxies 1400mAh 30W Mod + MTL Tank Starter Kit Original Price $25.99, Now Only $22.99 Please log in to see the lower price.Vapefly Galaxies MTL Starter kit is for fantastic MTL vaping, which is a small and pretty starter kit for convenient daily vaping. Equipped with high battery capacity of 1400mAh, Vapefly Galaxies MTL Starter kit has long battery life and offer you durable vaping experience. Besides, there are three adjustable output modes for your selection to meet your vaping needs. With nine levels of adjustable airflow, the vaping experience is tailored to you specially. For the tank, it comes with 1.8ml capacity which can fullfill your daily use. Unique mesh coil head brings you outstanding flavor. Morever, it is simple to operate with easy refilling and coil replacment is especially designed for you. Multiple protections to ensure your security and avoid any mishaps. Galaxies MTL Kit is equipped with MTL technology, brings the long battery life of starter kit in the vape industry, giving you a convenient and enjoyable vaping experience! ![]() Original OVANTY Falcon 40W 950mAh VW Variable Wattage Pod System Starter Kit Original Price $44.99, Now Only $25.99 Please log in to see the lower price.OVANTY Falcon Kit is made from high-quality Tempered Glass and Zinc Alloy material, which makes it light yet very durable. Powered by a built-in 950mAh battery, the Falcon can fire from 5~40W and the battery can be fully charged in a short time via the Micro USB port on the bottom. Along the side, you have a fire button, a 0.69" OLED screen, and an adjustment button. As for the refillable pod, it can hold up to 1.8ml of e-juice and comes with two versions. With purchase, you will get a regular pod and a ceramic pod in the set. Inside the regular pod is a 0.5ohm metal coil while the ceramic pod houses a 1.1ohm ceramic coil, thus the Falcon can meet your different vaping needs easily. ![]() Original VapeCige Nano 40W 950mAh Pod System Starter Kit $25.99 The VapeCige Nano kit is powered by 950mAh built-in battery. The max output wattage can be up to 40W. The pod cartridge features 2ml juice capacity. ![]() Original G-Taste Preloaded Premium Organic Cotton Wick for RBA / RDA / RTA / RDTA $1.99 G-Taste preloaded cotton is to provide the most convenient, cleanest and easy to wick. We select premium organic cotton from Japan, free of impurities, natural oils and pesticides. By pre-loaded design, if you re-wick often or are in a hurry, G-Taste preloaded cotton is the way to go. ![]() Original Vapefly Replacement Mesh Coil Head for Galaxies MTL Starter Kit Original Price $9.99, Now Only $6.99 Please log in to see the lower price.Here comes the Vapefly Galaxies 0.5ohm Mesh Coil! Vapefly Galaxies 0.5ohm Mesh Coil is specially designed for Vapefly Galaxies MTL Starter Kit, of which the power range is from 16W to 23W for pure taste and excellent falvor. Five PCS in each pack. ![]() Original VapeCige Nano Kit Replacement Pod Cartridge with 0.25ohm Coil Head Original Price $10.99, Now Only $7.99 Please log in to see the lower price. The VapeCige Nano Pod Cartridge is specially designed for Nano Kit. The VapeCige Nano Pod Cartridge features 0.25ohm resistance and 2ml juice capacity.
385
Original Yocan Handy 500mAh Battery Box Mod $11.99
Just as its name, the Yocan Handy box mod is so handy! With its small and tiny size, you can take the Yocan Handy to anywhere as you like. The Yocan Handy mod is powered by 500mAh built-in battery. The Yocan Handy supports a 3-level voltage adjustment for different vape needs. The pack comes with a magnetic 510 thread adapter to fit the tanks of 9~11.5mm diameter. ![]() ShenRay Taifun GTR MTL RTA Rebuildable Tank Atomizer Clone $26.00 The ShenRay Taifun GTR RTA Clone is made from 316 stainless steel and PC tank. The 25mm MTL RTA is in 25mm diameter and 4.5ml capacity. ![]() FOUR ONE FIVE 415 RTA Clone $11.99 The FOUR ONE FIVE 415 RTA Clone is constructed from 316 stainless steel in 22mm diameter and 4.5ml capacity. The 415 style RTA is with top-refilling system and supports single coil design. ![]() Tripod RTA Rebuildable Tank Atomizer Clone $14.99 The Tripod RTA Clone is constructed from 316 stainless steel. The ULTON Tripod Style RTA features 22mm diameter and 2ml juice capacity. ![]() Original VXV RB 380mAh Pod System Starter Kit w/ Replacement Batteries + Charging Dock $27.99 VXV RB Kit is designed to solve the problem that most pod system kits in the market have, which is short battery life. It bothers customers who would like to take more puffs but need to wait for the charging. RB Kit includes a charging dock, which is also an expending dock, carrying two spare batteries and pod cartridges. This expanding dock is pretty nice and useful, and actually solve the battery life problem, providing you a comfortable vape experience. ![]() Original Vandy Vape Swell 188W VW Variable Wattage Box Mod + Tank Waterproof Kit $79.99 Vandy Vape Swell Kit comes with portable size and incredible light weight design. Vandy Vape Swell Kit is easy to operate when you hold it in the hand. The Vandy Vape Swell Kit is equipped with upgraded Vandy Chip which has 188w max output. With Waterproof PCBA, it so easy to clean and wash. Also, comes with the'find your device with retrieval' function, under blue tooth connection, the device can be easily detected bu using retrieval function on Vandyvape APP. Simply press retrieve button and the device will make sound itself. And the Swell Tank adopts newly mesh coils, easy to build and avoid leakage. ![]() Original Biologix Sterilized E-Liquid Dripper Transfer Pipet for E-Cigarette Vape $2.99 The Biologix 3ml Sterilized E-Liquid Dripper comes with secured packaging to guarantee maximum safety and sanitation. Easily Transfer your E-liquid solutions using this transparent Dripper. ![]() Original VXV RB Pod System Kit Replacement Pod Cartridges $6.99 The VXV RB Pod Cartridge is specifically designed for VXV RB Vape Kit. Constructed of food grade PCTG for more hygeian vaping life. Besides, the refillable and replaceable pod cartridge aims to deliver clean and pure flavor. Unique air-blast atomizer avoids leaking problems. The coil features 1.4ohm resistance. 3 PCS each pack. Just get it as a spare part for your VXV RB Kit. ![]() Replacement Drip Tip for Lost Vape Orion Pod $1.59 The replacement drip tip is made from acrylic and is suitable for authentic Lost Vape Orion Pod.
386
ShenRay Four One Five 415 RTA Clone $14.99
The ShenRay FOUR ONE FIVE 415 RTA Clone is constructed from 316 stainless steel in 22mm diameter and 4.5ml capacity. The 415 style RTA is with top-refilling system and supports single coil design. ![]() Original 5GVAPE Kool 1100mAh Battery Mod + Tank Atomizer Starter Kit w/ RGB Light $22.99 The 5GVAPE Kool kit is powered by 1100mAh built-in battery. The 5GVAPE Kool kit features 1.8ml juice capacity and 1.4ohm resistance. The atomzier is with PCTG tank and Ceremic Coil, and it is suitable for Salt-Nicotine and CBD Juice. The mod and the atomizer are with RGB light ![]() Original Pioneer4You IPV-3 Mini 30W 1400mAh Auto-Feeding Squonk TC Pod System $52.99 The Pioneer4You iPV V3-Mini is an intelligent, all-in-one, auto bottom-feeding device with temperature control. The Pioneer4You IPV-3 Mini pod adopts YIHI ESS (Electronic Spray Squonk) Driver Technology, which supports the auto bottom-feeding system on the basis of accurate YIHI chipset control. Powered by YiHi SX635J chipset, iPV V3-Mini can support Multiple Intelligent Control Systems. The small size and 1400mAh built-in battery make it easy to take to everywhere you go and support a whole day vaping. ![]() ShenRay Four One Five 415 RTA Replacement 510 Drip Tip $1.99 The 510 drip tip features 22mm height. The 510 drip tip is constructed from PEI and stainless steel. The 510 drip tip is specially designed for Four One Five 415 RTA. ![]() ShenRay Four One Five 415 RTA Short Tank + 510 Drip Tip Adapter Set $6.99 The short tank is constructed from PC and features 2ml juice capacity and 22mm diameter. The adapter is constructed from stainless steel. The short tank and 510 adapter set is specially designed for Four One Five 415 RTA.
388
Original Onetop Vape Pharaoh Mechanical Mod Original Price $199.00, Now Only $79.99
Please log in to see the lower price. The Onetop Vape Pharaoh Mechanical Mod, powered by single 18650 / 21700 battery (not included) , is constructed from polished brass material with exquisite workmanship and vivid expression, which makes it stylish and distinctive. ![]() Original Ultroner Mini Stick Tube Mechanical Mod Original Price $83.80, Now Only $55.89 Please log in to see the lower price. The Ultroner Mini Stick mechanical mod is powered by single 18350 battery (not included). The Ultroner Mini Stick mechanical mod is constructed from stainless steel and stabilized wood. ![]() Original Curdo Polaris 400mAh CBD Pod System Starter Kit $13.99 Curdo Polaris CBD Starter Kit comes with delicate texture, very exquisite. Curdo Polaris CBD is powered by built-in 400mAh battery and adopts the latest energy-saving technology to provide vapers stable power. And Polaris features adjustable voltage to meet different needs. Polaris kit utilizes LED indicator to display the power and voltage. ![]() Original Curdo Octantis 400mAh CBD Pod System Starter Kit $14.99 Curdo Octantis CBD Starter Kit come with delicate texture, very exquisite. Curdo Octantis CBD is powered by built-in 400mAh battery. And Octantis features adjustable voltage to meet different needs. Octantis CBD utilizes LED indicator to display the power and voltage. ![]() Original Lost Vape Regular Coil Head for Lyra Pod Kit $10.99 The Lost Vape regular coil features 1.2ohm resistance for MTL vaping. The Lost Vape regular coil is specially designed for Lyra Pod Kit. ![]() Original Lost Vape Lyra Replacement Pod Cartridge $6.99 Lyra Pod Cartridge by Lost Vape is specifically designed for Lost Vape Lyra Pod Kit. It features 2ml E-juice capacity. With a cleverly implemented top fill design, you can see the dual top fill ports hidden beneath the removable mouthpiece cover, helping to prevent any leakage. Each Lyra replacement pod comes with one of each Lyra replacement coil head: 0.6ohm mesh coil head and 1.2ohm regular coil. Get it for your Lost Vape Lyra Pod Kit. 1pc each pack. ![]() Original YouDe UD Mini Diagonal Pliers CVS Cutting Pliers Mini Electronic Cigarette DIY Tool $5.99 YouDe UD Mini Cutting Pliers CVS is a best DIY tool for cutting coils, which will make DIY easier.
389
Original Vladdin RE 12W 350mAh Pod System Starter Kit $22.89
The Vladdin Vapor RE is a brand new draw activated Ultra Portable System with 350mAh battery life and has a proprietary pod system with 1.5ml E-Liquid Capacity. The Vladdin has a 12W maximum wattage output and 3.5V output voltage. The ceramic pod systems are intended for use with Nicotine Salt E-Liquids and have an atomizer range of 1.2 to 1.5 ohm. The pods have a removable silicone stopper for refilling located on top of the device covered by the removable tip. E-Liquid is poured on either left or right port; the middle port is the draw port. The 350mAh battery has a charging rate of 0.2 to 0.4V and can be charged through the micro USB port on the bottom of the device. ![]() Vapeasy Stratum 303 MOSFET Squonk Box Mod Clone $46.99 The Vapeasy Stratum 303 Squonk Mod Clone is a safe mod with MOSFET which provides reverse polarity protection and short circuit protection. The squonk bottle can hold 8.5ml of e-juice. The mod is powered by single 18650 battery (NOT INCLUDED). The mod is ultra-compact and feels comfortable when holding in hand. ![]() Original Gas Mods HALA RDTA Rebuildable Dripping Tank Atomizer w/ BF Pin Original Price $24.99, Now Only $21.29 The Gas Mods Hala RDTA, with post-less build deck, is an RDTA of mini size and compatible with squonk mod when the bottom feeder pin is installed. The airslots will appear once you rotate the top cap clockwise and the airflow can be adjusted in this way. ![]() 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.29 The 810 drip tip is made from acrylic. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original Vladdin RE Pod System Replacement Pod Cartridge $10.99 The Vladdin RE Replacement Pod Cartridge has 1.5ml of juice capacity and 1.2~1.5ohm ceramic coil. It is used with Nicotine Salt E-Liquids. It is suitable for Vladdin RE Pod System Starter Kit. This product comes with 4 PCS in 1 pack.
390
ShenRay TF Taifun GTR MTL RTA Rebuildable Tank Atomizer Clone 26
The ShenRay Taifun GTR RTA Clone is made from 316 stainless steel and PEI tank. The 23mm MTL RTA is in 23mm diameter and 4.0ml capacity. ![]() Dvarw MTL RTA Rebuildable Tank Atomizer Clone $10.15 The Dvarw MTL RTA Clone features 22mm diameter and 3.0ml juice capacity. The Dvarw MTL Style RTA is contructed from 316 stainless steel and PMMA. ![]() 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.59 The 810 drip tip is made from glass. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.This item also has many color for you to choose. ![]() ShenRay TF Taifun GTR RTA Replacement Tank Tube $6.99 The ShenRay replacement tank features 25mm diameter and 24mm height. The replacement tank is constructed from PSU. The replacement tank is specially designed for ShenRay TF Taifun RTA.This product also has a 25mm Diameter version for you to choose. ![]() ShenRay TF Taifun GTR RTA Replacement DL Accessory Module $5.99 The ShenRay replacement accessory features 9.9mm diameter and 14.5mm height. The replacement accessory is constructed from 316 stainless steel. The replacement accessory is specially designed for ShenRay TF Taifun DL GTR RTA. ![]() ShenRay TF Taifun GTR RTA Replacement Tank Tube $6.20 The ShenRay replacement tank features 25mm diameter and 24mm height. The replacement tank is constructed from 316SS + PEI. The replacement tank is specially designed for ShenRay TF Taifun RTA.this has other diameters(23mm) to choose.
391
Original Kaees Alexander RDA Rebuildable Dripping Atomizer with BF Pin $22.99
The KAEES ALEXANDER RDA is a combination of advanced rebuildable atomizer features, incorporating a postless build deck, precision airflow control, and is equipped with a 6mm deep juice well that can be supplemented with the bottom feed squonk pin for a great vape that can conquer all. The KAEES Alexander RDA comes with a postless build deck in the shape of a lotus leaf, drawing inspiration from nature, lending 4 terminal openings at the base of the elevated build deck, side secured via hex screws. This allows for a single or dual coil installation, depending on the preference of the user or builder. In addition, the airflow inlet is located on the side of the mid cap, featuring four 5mm by 1.5mm airflow inlets, arranged in a square stacked pattern. These airflow inlets can be fully closed or opened to find an appropriate airflow preference. This allows airflow to enter and is then throttled through a second set of honeycomb style airflows that vent directly to the coil structures below in a top and side fashion. Equipped with a 6mm deep juice well, the Alexander RDA can go quite some time without dripping but can be connected to a squonker box mod to increase the length between refills and making dripping easy through the bottom fed squonking line. ![]() Original CKS Dagger Junior 1000mAh All-in-one Pod System Starter Kit $21.99 The CKS Dagger Junior pod system is powered by 1000mAh built-in battery. The CKS Dagger Junior pod cartridge features 3ml and supports an easy access side-fill port. The CKS Dagger Junior pod cartridge is compatible with all vape juices, along with cannabidiol CBD juices. ![]() 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $0.99 The 810 drip tip is made from acrylic. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() ShenRay TF Taifun GTR RTA Replacement 510 Drip Tip $2.99 The 510 drip tip is constructed from PC. The 510 drip tip is specially designed for ShenRay TF Taifun GTR RTA. ![]() Original Coil Father Vape DIY Tool Elastic Tweezers for RDA / RTA / RDTA Atomizer $2.99 The Coil Father elastic tweezer is made from ceramic. The Coil Father elastic tweezer features 133mm height. The Coil Father elastic tweezer is heat resistant and easy to use. ![]() Original CKS Dagger Junior Replacement Pod Cartridge $4.99 The CKS Dagger Junior pod cartridge has 3ml juice capacity. The CKS Dagger Junior pod cartridge is specially designed for CKS Dagger Junior pod system. The CKS Dagger Junior pod cartridge sports an easy access side-fill port. The CKS Dagger Junior pod cartridge is compatible with all vape juices, along with cannabidiol CBD juices. ![]() Original CKS Dagger Junior Mesh Kanthal Coil Head $7.99 The Mesh Kanthal coil features 0.6ohm resistance. The Mesh Kanthal coil is specially designed for CKS Dagger Junior pod system. The Mesh Kanthal coil is for use with 70VG and up vape juice. 4 PCS per pack. ![]() Original Vandy Vape Kylin M KA1 Dual Mesh Coil $3.99 The Vandy Vape Kylin M KA1 Dual Mesh Coil is a 0.15ohm kanthal strip with dual mesh designed specially for the Kylin M RTA. This dual mesh coil provides an astounding amount of flavor and vapor production as well as an extended lifespan.
392
Exile RDA Rebuildable Dripping Atomizer with BF Pin $8.99
The Exile RDA Clone, with 25mm diameter and 810 drip tip, comes with a bottom feeder pin, making it compatible with both regular box mods and squonk mods. In addition, the Exile style RDA supports both single / dual coils building. A simple rotation of the top-cap will allow to choose single or dual airflow. ![]() Original Freemax Replacement Kanthal Quad Mesh Coil Head for Mesh Pro Tank $10.55 The Freemax Replacement Kanthal Quad Mesh Coil Head head comes with 0.15ohm resistance for 80 to 120W wattage output. It is suitable for authentic Freemax Mesh Pro / Fireluke / Fireluke Pro Tank. This product comes with 3 PCS in 1 pack. ![]() Original Freemax Mesh Pro Sub-Ohm Tank Clearomizer $22.28 The FreeMax Mesh Pro Tank is the ultimate edition of the FireLuke series, introducing one of the first Dual and Triple mesh coil system with multiple compatibility, as well as 6mL maximum juice capacity and dual slotted bottom airflow. ![]() Original Freemax Replacement SS316L Single Mesh Coil Head for Mesh Pro Tank $7.65 The Freemax Replacement SS316L Single Mesh Coil Head head comes with 0.12ohm resistance for 400~550'F in TC mode. It is suitable for authentic Freemax Mesh Pro / Fireluke / Fireluke Pro Tank. This product comes with 3 PCS in 1 pack. ![]() Original Freemax Mesh Pro Replacement Tank Tube $2.39 The Freemax glass tank is designed for the Freemax Mesh Pro Tank. Made of advanced pyrex glass, the Mesh Pro glass tube is durable to use and easy to clean. ![]() YFTK TF Taifun GTR RTA Replacement Tank Tube $1.99 The YFTK replacement tank features 23mm diameter and 24mm height. The replacement tank is constructed from glass. The replacement tank is specially designed for YFTK TF Taifun GTR RTA.
393
Ennequadro Imo 650 Mechanical Mod Clone $14.99
The Ennequadro Imo 650 Mechanical Mod Clone is constructed from brass and powered by 1 x 18650 battery (not included). The mechanical mod is with 22mm diameter and only 70mm height. The mod is side fire button. ![]() Original Asmodus Viento Mesh Sub Ohm Tank Clearomizer $28.49 The Asmodus Viento Mesh Sub Ohm Tank features durable hinged top fill mechanism. The triple adjustable airflow slots at the tank bottom brings ample air inlet to the coils. The Asmodus Viento Mesh Sub Ohm Tank adopts powerful 0.18ohm mesh coil, prolonging the coil lifespan and bringing a better flavor. ![]() Original Ehpro Raptor Sub Ohm Tank Clearomizer Atomizer $27.99 Ehpro Raptor Sub Ohm Tank is the world's first sea grass fiber cotton tank which consists of sea grass fiber cotton coil and stainless steel body. Featuring 25mm in base diameter, it has a whopping capacity of 4ml. Featuring 360 degree airflow system, the airflow through the valve port that make it heated fully and brings a smooth vape experience! A pre-installed EL1B-3 single coil and EL2B-3 dual coil is served replacement. Moreover, the slide open style is easy to refill. ![]() SXK Invidia RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $19.90, Now Only $14.99 Please log in to see the lower price. The SXK Project Invidia style RDA is constructed from 316 stainless steel and in 22mm diameter. This RDA is with dual pole for single coil, comes with bottom feeder pin for squonk mod. ![]() Original Wellon Stan 650mAh Pod System Starter Kit $10.99 Wellon Stan pod system kit is powered by 650mAh built-in battery, which is large enough for users to carry on for days. For the cartridge, it has 1ml juice capacity and matches ceramic coils for 1.6ohm. Moreover, it supports E-liquid and salt nicotine oil that is portable and compatible. The magnetic connection between cartridge and battery absolutely presents the convenience and the speed of reloading. The 3-level voltage also proves safety and comfort when vaping. ![]() Original Artery Pal 2 1000mAh Pod System Starter Kit $27.99 The authentic Artery Pal 2 Kit, a Tony B project, is a upgraded version of Pal Kit. It features aluminum body, 1000mAh built-in battery and 2ml replaceable pod. The coil can be replaced and there are two types of coils, which are the 0.6ohm mesh coil and the 1.2ohm regular MTL coil. ![]() Original Artery PAL Stick AIO 750mAh Pod System Starter Kit $27.99 Artery PAL Stick Kit is a portable pen-style starter kit with lighter aluminum alloy construction and diamond embossing finish to bring great hand-feeling and visual pleasure. Powered by 750mAh built-in battery and 1.6ml atomizer with 3.5V / 3.3V / 3.0V variable voltages and powerful HP cores, the PAL Stick kit will bring you an awesome vaping experience with fantastic and long-lasting flavor. Moreover, it comes with a convenient magnet connection to make the installation easier. Plus the easy top filling, clear battery indicator, and convenient USB charging, the Artery PAL Stick is definitely a good daily vaping tool. ![]() Original Asvape Micro 1100mAh 30W VW Variable Wattage Pod System Starter Kit Original Price $59.99, Now Only $35.99 Please log in to see the lower price. Asvape Micro Pod System AIO starter kit supports E-juice and nicotine salt. It is refillable, which reduce the cost and meet the needs of different customers for vaping flavors. The Micro chip kit can automatically identify the coil resistance and match the best power. 5W to 30W Variable wattage meets all your needs of cloudy and flavors for a pod system. Micro employs a built-in 1100mAh battery to provide you durable vaping experience, and bring you massive cloud of vapor. ![]() Original Wellon Stan Replacement Pod Cartridge $5.99 The Wellon Stan Pod Cartridge adopts 1.0ml juice capacity and 1.6ohm ceramic coil which is compatible with nicotine salt e-juice and CBD oil. The Wellon Stan Pod cartridge is perfectly compatible with Wellon Stan Battery. The easy top refill design and magnetic connection of Wellon Stan Refillable Pod Cartridge will bring you amazing vaping experience! ![]() Original Ehpro Raptor Replacement Mesh Single Coil Head $14.99 The Ehpro Raptor Replacement mesh coil introduces a new material to making coil cotton - that is sea grass. Sea grass cotton is cheaper than common cotton, because of the shorter growing duration and lower planting cost. Besides, sea grass can bring a massive cloud and better flavor, and it also extends the working life fo the coil. The Ehpro Raptor Replacement mesh Coil has everything you love in the common coil, but cheaper, stronger and more durable. ![]() Original Ehpro Raptor Replacement Tank Tube $1.99 The Ehpro Raptor Replacement glass tube features 4ml juice capacity. The Ehpro Raptor Replacement glass tube is the special design for The Ehpro Raptor tank which provides optional capacity to meet your need. ![]() Original Asmodus Viento Replacement Mesh Coil Head $12.99 The Asmodus Viento mesh coil features 0.4ohm resistance. The Asmodus Viento Mesh Coil is best compatible with Asmodus Viento Mesh Tank. ![]() Original Asvape Micro Pod Kit Replacement Mesh DTL Coil Head Original Price $16.99, Now Only $13.99 Please log in to see the lower price. The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product. The Asvape Micro Mesh DTL coil features 0.5ohm resistance. The Asvape Micro Mesh DTL coil is specially designed for Asvape Micro Pod Kit.
394
Original Vapelustion Hannya Mini 80W TC VW Variable Wattage Box Mod $41.89
Vapelustion Hannya Mini Box Mod, maintaining 2 sets of replaceable art decoration panels, powered by single 18650 battery (not included) with 80W maximum output. The Hannya Mini is equipped with a 0.96 inch OLED screen to display the detail vaping information and it supports VW/ TC (Ni / Ti / SS) / Bypass modes to satisfy different vaping needs. ![]() Original Suorin Air V2 16W 400mAh Pod System Starter Kit $19.99 The Original Suorin Air V2 is designed with practicality and elegance in mind. This cutting-edge, minimalist device is everything you could want in a starter kit. The Authentic Suorin Air V2 is made with quality, durable aluminum. The modernized slender chassis is compact and lightweight. Unlike standard closed vaping systems this device is completely refillable. Featuring a built-in, Micro USB rechargeable battery, magnetic thread connection, and draw activation. Cartridge tank capacity of 2ml. Maximum power output of 16W. 400mAh built-in battery. Atomizer resistance of 1.2ohm. ![]() Original Asvape Micro Pod Kit Replacement Pod Cartridge Original Price $15.99, Now Only $12.99 The pod cartridge has 2ml juice capacity. The pod cartridge is suitable for Asvape Micro Pod Kit. ![]() Original OneVape Golden Ratio Kit Replacement Pod Cartridge $7.99 The OneVape Golden Ratio Replacement Pod Cartridge is an ideal alternative for OneVape Golden Ratio Kit. The OneVape Golden Ratio Replacement Pod Cartridge features 2ml juice capacity. The OneVape Golden Ratio Replacement Pod has two types for your selection. With 1.2ohm Mesh MTL Coil and 0.6ohm Mesh Coil, you will enjoy different flavor and taste. ![]() Original Suorin Air V2 Pod System Replacement Pod Cartridge $3.59 The replacement pod cartridge features 2ml juice capacity and 1.2ohm resistance. The replacement pod cartridge is suitable for Suorin Air V2 Pod System. ![]() 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.29 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Taifun TF GTR MTL RTA Replacement Drip Tip $2.99 The Taifun TF GTR MTL RTA replacement drip tip features 20.5mm height and 11mm diameter. The Taifun TF GTR MTL RTA replacement drip tip is constructed from Stainless Steel. The replacement drip tip is specially designed for Taifun TF GTR MTL RTA.
395
Original Uwell Amulet 10W 370mAh Pod System Starter Kit $33.99
The Uwell Amulet Kit is the world's first watch-style pod system kit powered by 370mAh built-in battery and 2ml refillable pod cartridge. It can be worn on your wrist to free your hand, just touch it, you can check the date and time at any time. And the direction of the screen can be adjusted according to your wearing habits. The included cartridge is compatible with e-liquids and nicotine salts. It also features no button design for easy operation. What's more, the unique Pro-FOCS flavor testing technology will provide you with the ultimate vaping experience by controlling the heating temperature and completely restoring the e-juice flavor. The anti-dust system effectively protects the core components and prolongs service life. Multiple protections are applied to guarantee safe vaping. ![]() Original Aspire AVP 12W 700mAh All-in-one Pod System Starter Kit $26.99 The Aspire AVP Pod System features a sleek and comfortable refillable pod / cartridge vape system that is easy to use and operate. The Aspire AVP Pod System features three wattage settings to choose from that is easily adjusted using the independent power button. The Aspire AVP Pod System is powered by a built-in 700mAh battery that can be charged via the bottom micro USB charging port. The Aspire AVP Pod System is automatically activated by inhaling for an easy and comfortable vaping experience. The AVP is designed to be portable and easily fits in the palm of your hand. The AVP utilizes a spring loaded leak resistant which locks into place when you are done refilling to help minimize leaks and messes. The Aspire AVP Pod System utilizes a refillable empty pod cartridge with a built-in coil inside which can be filled with your favorite vape juice. A lanyard is also included to help secure and carry your Aspire AVP pod system. This product is Chinese Version, which comes with manual / Package in Chinese, ![]() Original Justfog Minifit Ceramic Wick Replacement Pod Cartridge 3EA $6.89 Justfog Minifit Replacement Pod Cartridge,is perfectly used for Justfog Minifit Kit. Built-in coil design makes it a handy and ready component for vaping anytime and anywhere. Bottom filling design and airflow bring you simple but amazing vaping experience. ![]() Original Uwell Amulet Kit Replacement Pod Cartridge $8.99 The Uwell Amulet pod cartridge features 2ml juice capacity and 1.6ohm resistance. The max power output is 10W. ![]() Original Aspire AVP AIO Kit Replacement Pod Ceramic Coil Standard Version $7.99 The Aspire AVP Replacement Pods are a set of 2.0ml food-grade plastic pods, featuring a 1.3ohm integrated coil, and is refilled via bottom fill system, with two silicone stoppers to prevent any pesky leaks and spills. This product is Chinese Version, which comes with manual / Package in Chinese,
396
Underground MCM Hybrid Mechanical Mod Clone $26.95
The Underground MCM mechanical mod Clone features 25mm diameter. The Underground MCM Style mechanical mod is constructed from brass. The Underground MCM Style mechanical mod is powered by single 18650 / 20700/ 21700 battery (not included). ![]() Underground MCM Stackable Hybrid Mechanical Mod Clone $32.95 The Underground MCM mechanical mod Clone features 25mm diameter. The Underground MCM Style mechanical mod is constructed from brass. The Underground MCM Style Stackable Hybrid mechanical mod is powered by 1 / 2 x 18650 / 20700/ 21700 battery (not included). ![]() Original Ultroner Take It Go 80W VW Variable Wattage Box MOD Original Price $99.00, Now Only $62.99 Please log in to see the lower price. The ULTRONER Take It Go mod supports 5~80W output with a single 18650 battery (not included). The ULTRONER Take It Go 80W mod comes with two replacable panels. One is made of metal and the another is constructed from high end stabilized wood. ![]() Original asMODus x Ultroner Thor 2 II DNA 75 75W TC VW Box Mod Original Price $269.99, Now Only $249.99 Please log in to see the lower price. Ultroner ThorII DNA 75W TC Box mod is compatible with 21700 / 20700 / 18650 Li-ion battery (not included). The Ultroner ThorII DNA 75W TC Box mod delivers a maximum output of 75W. With aesthetics and ergonomics design, ThorII is very comfortable to be held for everyday vaping. Equipped with DNA 75C chip, ULTRONER Thor II's Window based program will allow you to change preheat functions and the look of the display as well as the operation of the device. ![]() Original Aleader Rocket RDA Rebuildable Dripping Atomizer $9.99 The Aleader Rocket RDA features 24mm diameter and 20mm height. The The Aleader Rocket RDA is constructed from resin and stainless steel. ![]() Original FreeMax Fireluke 2 Metal Sub Ohm Tank Clearomizer $22.99 The Freemax Metal Edition of Fireluke 2 is the update version of the original Fireluke M, with the TX1 / TX2 / TNX2 / TX3 / TX4 Mesh Coil, slide-to-open top fill design, 360 degree e-liquid feeding, patented 90% tea fiber cotton and 10% organic cotton formula, the Fireluke 2 offers a stylistic design and great flavor compared to all the other mesh coil sub ohm tanks in the market. ![]() Haku Riviera RDTA Rebuildable Dripping Tank Atomizer Clone with BF Pin $10.39 This Haku Riviera RDTA Clone is made from 316 stainless steel with 24mm diameter. The rebuildable atomizer has large build deck with cut-outs for easy coil placement. The RDTA adopts bottom-feed pin for squonking use. ![]() Original SMOKTech SMOK INFINIX 2 15W 450mAh Pod System Starter Kit $22.99 The Smok INFINIX 2 pod system starter Kit is an upgraded version of INFINIX. It follows the style of the first generation, slim and sleek, allowing you to bring it everywhere. Powered by built-in 450mAh battery, it can provide longer vaping time than INFINIX, whose battery capacity is 250mAh. This version also has a multiple-color LED indicator, you can clearly know the devices conditions by different colors. And there are two pods included in the kit, both of which have 2ml capacity, you can fill them with the e-liquid as you like. No fire key, no up and down buttons, just simply inhale you can feel the pleasure provided by infinix 2. ![]() Original Vladdin Eden Vape 350mAh All-in-one Pod System Starter Kit Original Price $26.90, Now Only $20.99 Please log in to see the lower price. The compact and portable design give Vladdin Eden pod system a good-looking appearance and better hand feeling. Plug the dust free design, it makes Vladdin Eden pod system outstanding. Powered by 350mAh built-in battery with constant output, it enables to fulfill your daily use. And the universal micro-usb charger provides you convenient daily charging. Besides, it is easy to install owing to the magnetic connection between pod and device. Unique patented ceramic coil delivers pure taste and excellent flavor. With easy top-?lling, leakage proof and childproof design, Vladdin Eden Kit brings you more simple and secure vaping life. What's more, the implementation of dry-burn prevention design also ensures your security and offer you stable vaping experience. ![]() Original SMOKTech SMOK INFINIX 2 15W 450mAh Pod System Starter Kit $22.99 The Smok INFINIX 2 pod system starter Kit is an upgraded version of INFINIX. It follows the style of the first generation, slim and sleek, allowing you to bring it everywhere. Powered by built-in 450mAh battery, it can provide longer vaping time than INFINIX, whose battery capacity is 250mAh. This version also has a multiple-color LED indicator, you can clearly know the devices conditions by different colors. And there are two pods included in the kit, both of which have 2ml capacity, you can fill them with the e-liquid as you like. No fire key, no up and down buttons, just simply inhale you can feel the pleasure provided by infinix 2. ![]() Original Nikola Antares Vape 1200mAh Pod System Starter Kit Original Price $35.99, Now Only $26.99 Please log in to see the lower price. Nikola Antares Vape Pod System Kit, constructed of zinc alloy material, which comes with the latest unique design with curvy shaping plus the in-mold extension technology. Powered by 1200mAh built-in battery with max output 3.5V can easily fulfill your daily use. What's more, you can have a quick charge in a short time. As for the pod with 2ml capacity, it adopts magnetic structure that can be easily pulled. The airflow of the device is designed to allow each user to change it to their preference, which perfectly switches between MTL and DL. ![]() Original Vapor Storm V2 DIY Tool Kit for RDA / RTA / RDTA $10.99 The Vapor Storm V2 DIY Tool Kit is specially designed for RDA / RTA / RDTA Vape Atomizer Coil building. ![]() Original Nikola Antares Kit Replacement Pod Cartridge Original Price $16.80, Now Only $9.99 Please log in to see the lower price. The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product.Nikola Antares Replacement Pod Cartridge features 2ml juice capacity to meet your daily consumption. It supports 0.6ohm mesh coil for pure taste. Besides, the long-lasting coil makes the property of Nikola Antares Kit Pod Cartridge outstanding. 2 PCS / Pack. The Replacement Pod Cartridge is suitable for your Nikola Antares Vape Pod Kit. ![]() Original Dovpo 7 In 1 Pre-Built Coils for DIY RBA / RDA / RTA / RDTA Atomizer $8.99 The Dovpo 7 In 1 Pre-Built Coils are constructed from Ni80. The Dovpo 7 In 1 Pre-Built Coils have many different resistances which can satisfy your DIY needs. ![]() Original Vapesoon DT231-G 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.69 The Original Vapesoon 810 drip tip is made from resin with 12.5mm diameter 810 connector. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
397
Rockvape Titan Mechanical Tube Mod Clone + Kennedy 24 Titan Style Cap $23.93
The Rockvape Titan mechanical tube Mod Clone is powered by 1 x 20700 and 21700 battery (not included). This Titan mechanical mod supports magnets and spring firing button. The mod comes with a cap for the Kennedy 24. The cap has a reduced evaporation chamber. This product has many colors for your choice. ![]() Rockvape Titan Mechanical Tube Mod Clone $20.59 The Rockvape Titan mechanical tube Mod Clone is powered by 1 x 20700 and 21700 battery (not included). This Titan mechanical mod supports magnets and spring firing button. The mod comes with a cap for the Kennedy 24. The cap has a reduced evaporation chamber. This product has many colors for your choice. ![]() Original Kumiho 510 Holder Stand for RDA / RTA / RDTA Vape Atomizer $1.49 The original Kumiho Atomizer Stand, made of aluminum, customized for 510 RDA / RTA / RDTA Vape atomizers fit with no suction. It can fit all 510 threaded tanks / Atomizers. ![]() Multifunctional Vape Tweezers Tool for RDA / RTA / RDTA Vape Atomizer $2.99 The Multifunction vaper Tweezers is your handy tool for rebuilding your coils. It's tip is made of ceramic, which is able to withstand the high temperature when you dry fire your coil. With this tool, you can tighten the wire, pull out the top cap, pull out the base & pull out the coils easily. Making coil building so much easier. It's a great and handle tool if you are into rebuildable atomizers. ![]() Original Efest H2 Updated Dual-Slot 18650 Plastic Battery Case $1.49 The Efest H2 dual-slot Battery Case is the safest and most convenient way to store your batteries. Small in size and sturdy in construction, the Efest H2 case can store up to two 18650 batteries and up to four 18350 batteries. No need to worry about your batteries shifting or falling out, the H2 case snaps tightly and secures your batteries when theyre not in use. The transparent case allows you to see your batteries without having to open the case and makes a great display container if youre a seller. The Efest battery case is a top-of-the-line product made to last a very long time with careful use. This product has many colors for your choice. ![]() Original OFRF nexMESH Coil SS316L Mesh Sheet for Wotofo Profile RDA / Wotofo Profile Unity RTA Original price $12.99, now only $4.99 The next generation of mesh coils comes a new SS316L nexMESH Mesh Coil. The nexMESH replacement mesh coil strips are made especially for the Profile series and deliver incredibly fast fire up and intense flavor production. Engineered by using a perforated SS316L material with 3 times the density of Wotofos standard mesh coils, the intricate micro weave netting of nexMESH delivers an increased den |
398
Original Wizman Puff Boy 200W Box Mod Original Price $69.90, Now Only $55.99
Please log in to see the lower price. The Wizman Puff Boy is a 200W box mod that is designed to provide extra style while vaping. This high-performance box mod features a body design in line with classic gaming devices. The Puff Boy offers users options between 12 presets and 3 distinct power modes, along with a full-color user interface that features 8-bit graphics. This device is powered by dual 18650 batteries (NOT INCLUDED) and features a maximum power output of 200W. ![]() Original Vapeonly Joya 9W 450mAh Pod System Starter Kit Original Price $29.90, Now Only $14.99 Please log in to see the lower price. The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product. The authentic VapeOnly Joya Kit is a premier combination of portability and easy to use. The resin appearance and tiny body is a perfect fit in the palm of your hand and easy to carry. With the elegant gemstone cutting and resin material veneer design, the Joya will bring you a feast of eyes when vaping. Powered by a built-in 450mAh battery, it can fire up to 9W max output to offer you stable and superior vaping. And the multi-color LED light indicator will show you the essential information clearly. What' more, the 2ml refillable pod, 1.2ohm ceramic coil optimized for nic-salt e-juice, the VapeOnly Joya is definitely an ideal device for vaping on the go! ![]() Original SMOKTech SMOK Stick 80W 2800mAh VW Mod + TF Sub-Ohm Tank Starter Kit $44.99 SMOK Stick 80W kit, as its name indicates, has a maximum output of 80 watts, which combines a built-in 2800mAh battery and the formidable TF tank providing the best flavor and cloud. The tank pairs with two new mesh coils that are designed for stick series. There is a dial on the bottom base where you can get the desired wattage by turning the scale value. As for the safety usage, there is a press button on the top cap to make the tank more leak-proof and childproof. Innovation keeps changing the vaping experience! ![]() Original VapeOnly Joya Replacement Pod Cartridge with 1.2ohm Ceramic Coil $7.99 The Vapeonly Joya Pod Cartridge is designed for the VapeOnly Joya Pod Kit. The Pod Cartridge is Equipped with the 1.2ohm ceramic coil to produce pure vaping flavor. It is highly compatible with nic-salts e-juice. And It also comes with refillable 2.0ml juice capacity. Get it as a spare part for your VapeOnly Joya Pod Starter Kit.
399
ShenRay Summon Mechanical Mod Clone $20.99
The ShenRay Summon Mechanical Mod Clone is made from stainless steel and powered by 1 x 18650 21700 battery (not included). ![]() Original DazzVape Fleap 400mAh Battery Mod for 510 thread Atomizers with Diameter Less Than 12mm $14.99 The Original Dazzvape Fleap Battery mod is constructed of smooth painted material finish and adopts a built-in draw activated system. Powered by a built-in 400mAh battery, it can offer you durable and easy vaping life. And there is an intelligent LED indicator to remind you of the battery status precisely. Moreover, Dazzvape Fleap Battery mod is suitable for any 510 threaded atomizers with a diameter of less than 12mm. Plus three protections to avoid potential risk, the Dazzvape Fleap Battery is certainly a cut above the rest. ![]() Original Tesla P226 220W TC VW Variable Wattage Box Mod Original Price $55.96, Now Only $42.99 Please log in to see the lower price. The Original Tesla P226 TC Box Mod comes with maximum power up to 220W which is supplied by two hi-rate 18650 batteries (not included) and high quality zinc alloy materials. The Tesla P226 Mod contains five output modes: KA / TC-SS316 / TC-Ni200 / TC-Ti / TCR; Four taste modes: Norm / Soft / Hard / User; And three memory modes: M1 / M2 / M3, which can meet your different needs and bring you various wonderful vaping experiences. the Temperature control function and clear 0.96 inch OLED screen, the Tesla P226 Mod is definitely one of the best vape device and will bring you an extraordinary perfect vaping experience. ![]() Bestia Animal 18650 Hybrid Mechanical Mod Clone $18.99 The Bestia Animal mod Clone is a hybrid mechanical mod powered by 1 x 18650 battery (not included), with a diameter of 24mm, it is equipped with a stylish side switch. This Mod is a beautiful side fire mod with a removable battery adjustable bottom and removable top with delrin insulator. The top insulator creates a barrier for your e-liquid spills so there is much less chance of your juice ending up in your tube. ![]() Bestia Animal 18650 Hybrid Mechanical Mod Clone $18.99 The Bestia Animal mod Clone is a hybrid mechanical mod powered by 1 x 18650 battery (not included), with a diameter of 24mm, it is equipped with a stylish side switch. This Mod is a beautiful side fire mod with a removable battery adjustable bottom and removable top with delrin insulator. The top insulator creates a barrier for your e-liquid spills so there is much less chance of your juice ending up in your tube. ![]() Original ThunderHead Creations THC Tauren One RTA Rebuildable Tank Atomizer Original Price $38.90, Now Only $22.99 Please log in to see the lower price. The Original Thunder HeadCreations (THC) TAUREN ONE RTA is an innovative single coil RTA. It comes with unique 3D honeycomb airflow system which can provide smoothest airflow and unique taste for vapers. Featuring the super easy single coil build deck and stylish appearance which always makes it attractive. It has a 2 ml tank capacity with 24mm diameter. You can change the RTA's capacity for 4.5ml by using a unbreakable PC bubble tube. Just get the TAUREN ONE RTA and enjoy excellent vaping. ![]() SXK WICK'T RDTA RSTA Rebuildable Dripping Tank Atomizer Clone with BF Pin Original Price $19.90, Now Only $18.99 Please log in to see the lower price. The SXK Wick'T RDTA is a dripper tank made of 316 stainless steel in 22mm diameter. The deck is with two flat screw posts, aligned and provided with horizontal slots allow easy installation of your resistance. The filling hole is at the back of the posts and is closed with a plug. There is a location for the installation of different airflow inserts. The air flow is regulated in two ways, by rotation of the top cap but also by means of different inserts to position on the deck. This RDTA comes with bottom feeder pin. ![]() Voltrove V2 Mini RTA Rebuildable Tank Atomizer Clone with Short Tank Kit $29.60 The Voltrove V2 Mini Style RTA is constructed from 316 stainless steel in 30mm diameter. The regular tank is with 10~11ml capacity and comes with short tank for 7~8ml capacity. The tank is with top refilling system and airflow adjustable control. ![]() Original Tesla P226 220W TC VW Variable Wattage Box Mod + Tind Tank Kit Original Price $66.41, Now Only $53.99 Please log in to see the lower price. The Original Tesla P226 Kit is a new production with military style from Tesla which consists of Tesla P226 TC Mod and Tesla Tind Tank. Powered by dual high-rate 18650 batteries (not included), the kit can fire up to max output of 220W and the battery can be recharged by USB Cable. The innovative TC mode, taste mode and memory mode with easy operation can give you an individual mode in conveniently. Besides, the sub-ohm tank with durable mesh coil and 4.5ml oil capacity can make denser clouds and various flavor to meet your need. And it supplies a 0.96" OLED display to show the mod condition. Just get it and enjoy a different vaping. ![]() SXK WICK'T RDTA RSTA Atomizer Clone Replacement Tank Tube $3.50 The SXK WICK'T RDTA RSTA Clone Replacement Tank Tube is made from PEI. ![]() SXK WICK'T RDTA RSTA Atomizer Clone Replacement Top Cap with 510 Drip Tip Adapter $3.99 The SXK WICK'T RDTA RSTA Clone replacement Top Cap is made from POM and comes with 510 Drip Tip Adapter. ![]() SXK WICK'T RDTA RSTA Clone Atomizer Replacement Airflow Insert $4.90 The SXK WICK'T RDTA RSTA Clone replacement airflow insert is with 4 Holes. The hold size is 1 x 1mm.
400
