Просмотров в теме 66641   Ответов в теме 210   Подписчиков на тему 1   Добавили в закладки 0
Старый 02.02.2021, 05:17 Автор темы   21
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update. Part 2.
KF Lite Plus Clone 2021 RTA Rebuildable Tank Atomizer w/ Spare PC Tank Tube Kit 22mm Diameter $14.99
KF Lite Plus Clone 2021 RTA Rebuildable Tank Atomizer Kit consists of a KF Lite Plus Clone 2021 RTA, a spare PC Tank Tube and a Drip tip. Constructed from stainless steel, KF Lite Plus Clone 2021 RTA Rebuildable Tank Atomizer holds a 4.0ml e-juice capacity with bottom filling system. It features infinitely adjustable AEROKON airflow control, bringing you an amazing vaping experience.
3FVAPE вне форума   Вверх
Старый 03.02.2021, 04:52 Автор темы   22
3FVAPE
Original SMOKTech SMOK Nord 0.6ohm Mesh Coil for Priv N19 Kit /Nord AIO 19 Kit /Alike Kit /Nord Kit /Fetch Mini Kit $9.99
Original SMOKTech SMOK Nord 0.6ohm Mesh Coil is suitable for Priv N19 Kit / Vape Pen Nord 19 kit / Vape Pen Nord 22 Kit / Nord AIO 19 Kit / Nord AIO 22 Kit / Alike Kit / Nord 2 Kit / Fetch Mini Kit / RPM40 Kit / Nord Kit. 5 PCS / Pack
Original Fucig EXvape eXpromizer V5 MTL RTA Replacement Tank Tube 2.0ml $2.49
Original Fucig EXvape eXpromizer V5 Tank Tube holds 2.0ml capacity, especially designed for Fucig EXvape eXpromizer V5 MTL RTA Rebuildable Tank Vape Atomizer. Two types for your choice: Glass / PEI. 1 PC / Pack
Original Fucig EXvape eXpromizer V5 MTL RTA Replacement PEI Tank Tube + Drip Tip Kit $4.19
Original Fucig EXvape eXpromizer V5 MTL RTA Replacement 2.0ml PEI Tank Tube + Drip Tip Kit is especially designed for Fucig EXvape eXpromizer V5 MTL RTA Rebuildable Tank Vape Atomizer.
Старый 04.02.2021, 06:11 Автор темы   23
3FVAPE
Original OBS Oner 80W VW Pod System Vape Side by Side Kit $49.99
Original OBS Oner 80W VW Pod System Vape Kit includes an OBS Oner 80W VW Pod System Mod and a 5.0ml OBS Oner Pod Cartridge. OBS Oner 80W VW Pod System Mod, the latest side by side Mod, is powered by 1 x 18650 battery (Not included), with Type-C 5V / 1.4A charging, providing a maximum output power of 80W (5~80W) in watt mode. OBS Oner Pod System Mod is not a standard box mod, because there is no 510 connector, replaced the 510 connection with a pod connection. Constructed from Zinc Alloy and Leather, it adopts a wide range airflow system, allowing more precisely airflow from MTL to DL vaping experience. OBS Oner Pod Cartridge holds 5.0ml capacity with top slide filling system, made of PCTG. With easy coil replacement design, it is compatible with all OM series coils, like OM YE 0.4ohm Mesh Coil for RDL vaping and OM 0.2ohm Mesh Coil for DL are included, meeting your different demands.
Original OBS Oner 80W Pod System Vape Kit Replacement Pod Cartridge 5.0ml $8.99
Original OBS Oner Pod Cartridge holds 5.0ml capacity with top side filling system, especially designed for OBS Oner 80W Pod System Vape Kit. Made of PCTG, it is compatible with all OM series coils (Not included) with easy coil replacement design. 2 PCS / Pack
Original Damn Vape Mongrel RDA Atomizer Replacement Spare Parts Bag $1.99
Original Damn Vape Mongrel Spare Parts Bag includes O-rings, 4 x Screws, 1 x Screwdriver and 1 x BF Pin, especially designed for Damn Vape Mongrel RDA Rebuildable Dripping Vape Atomizer.
Старый 05.02.2021, 04:39 Автор темы   24
3FVAPE
Original Eleaf iSolo R 30W 1800mAh Pod System Vape Starter Kit $29.99
Original Eleaf iSolo R 30W 1800mAh Pod System Starter Kit consists of an Eleaf iSolo R 30W 1800mAh Pod Mod and a 4.5ml Eleaf GTL Pod Cartridge. Eleaf iSolo R Pod System Mod is powered by a 1800mAh built-in battery, enough to fire up to 30W (1~30W), bringing you a long lasting vaping experience. With 510 threading connection, it is widely compatible with any atomizer you like. In addition, it comes with only an intuitive fire button, which is easy for you to operate. Eleaf GTL Pod Cartridge holds 4.5ml e-juice capacity with bottom filling system. With a powerful magnetic connection, it is convenient for you to refill oil or clean GTL pod cartridge without damage to the Mod. It is compatible with all GTL Coils, only GTL 0.4ohm Coil (suggested wattage: 20~30W) and GTL 0.8ohm Coil (12~18W) included, delivering you a DL or MTL vaping experience. Available in four colors: Red, Blue, Light brown, Dark brown
Старый 06.02.2021, 05:52 Автор темы   25
3FVAPE
VG Extreme V2 Clone RTA Rebuildable Tank Vape Atomizer w/ Spare Tank Tube 23mm Diameter $20.99
The VG Extreme V2 Clone RTA Rebuildable Tank Vape Atomizer holds 6.5ml capacity in 23mm diameter. VG Extreme V2 Clone RTA comes with adjustable airflow control via Air Pins, and winding is supplied air from three sides (frontal, bottom, diagonal top). The VG Extreme V2 Clone RTA supports dual / single coil building and DL / RDL / MTL Vape.
Старый 23.02.2021, 07:07 Автор темы   26
3FVAPE
Original SMOKTech SMOK ACRO 25W 1000mAh Pod System Vape Kit $27.99
Original SMOKTech SMOK ACRO 25W 1000mAh Pod System Vape Kit - 2.0ml SMOK ACRO Pod Cartridge. SMOKTech SMOK ACRO 25W Pod System Mod is powered by a 1000mAh built-in battery, enough to provide a maximum power output of 25W (5~25W). The Mod has a round fire button on the front, an air inlet on the back, a 0.69-inch OLED screen on the narrow side, and two adjustment buttons. In addition, ACRO also has an intelligent detection function to help better understand the status of the device. The SMOK ACRO Mod adopts auto-draw and button-activated draw functions. With adjustable airflow design, SMOK ACRO Battery Mod allows you to adjust intake volume and immerse in every inhalation. SMOKTech SMOK ACRO Pod Cartridge holds 2.0ml capacity whether it is freebase or nicotine salt with side filling system. ACRO Pod Cartridge comes with 0.8ohm built-in meshed coil (suggested wattage: 12~15W), brings an excellent flavor and dense vapor. Seven colors in total for your choice.
Original Nevoks Feelin 22W 1000mAh Pod System Starter Kit $24.99
Original Nevoks Feelin 22W 1000mAh Pod System Starter Kit - 2.8ml Feelin Empty Pod Cartridge. Nevoks Feelin 22W Pod System Battery Mod is powered by a 1000mAh built-in battery with 3 levels variable voltage (3.1V / 3.4V / 3.7V), enough to fire up to 22W (10~22W). Equipped with quick charge bottom Type-C USB port, it could be fully charged around 50 minutes. It adopts double way airflow adjustment design to accommodate either nicotine salts or freebase e-juice, meeting your different airflow demand with every inhalation, no matter for MTL or half DL. In addition, it supports firing button or draw-activated firing. Nevoks Feelin Pod Cartridge holds 2.8ml capacity, made of TPE. It comes with SPL-10 Mesh Coil 0.6ohm (Suggested wattage: 18~25W) and SPL-10 Mesh Coil 1.0ohm (10~13W) in the package, giving you a real inhalation experience in the flavor about what you need from Nic-Salts and clouds. Four colors for your choice: Black, Red, Blue, Silver
Original SMOKTech SMOK ACRO 25W Pod System Replacement Pod Cartridge w/ 0.8ohm Meshed Coil 2.0ml $8.99
SMOKTech SMOK ACRO Replacement Meshed 0.8ohm Pod Cartridge holds 2.0ml capacity with side filling system (Suggested wattage: 12~15W). It is designed for SMOKTech SMOK ACRO 25W 1000mAh Pod System Vape Kit. 3 PCS / Pack
Original Nevoks Feelin 22W 1000mAh Pod System Starter Kit Replacement Pod Cartridge 2.8ml $7.99
Original Nevoks Feelin Pod Cartridge holds 2.8ml capacity, especially designed for Nevoks Feelin 22W 1000mAh Pod System Starter Kit. 2 PCS / Pack
Original Nevoks Feelin 22W 1000mAh Pod System Kit / Pod Cartridge Replacement SPL-10 Mesh Coil $11.99
Original Nevoks Feelin SPL-10 Mesh Coil is with 0.6ohm resistance (suggested wattage: 18~25W), designed for Nevoks Feelin 22W 1000mAh Pod System Kit and Nevoks Feelin Pod Cartridge. Nevoks Feelin SPL-10 Mesh Coil 1.0ohm is also available. 5 PCS / Pack
Старый 24.02.2021, 05:00 Автор темы   27
3FVAPE
Original Innokin Sensis 40W 3000mAh Next-Gen Pod System Vape Mod Kit $37.99
Original Innokin Sensis 40W 3000mAh Next-Gen Pod System Vape Mod Kit includes a Sensis 40W 3000mAh Next-Gen Pod System Mod and a Sensis 3.1ml Pod Cartridge. Innokin Sensis 40W Next-Gen Pod System Mod is integrated with a 3000mAh built-in battery enough to fire up to 40W (6~40W). With Find F Function, it can create and harness a new form of thermodynamic heating and extend coil longevity and deliver more flavors over time. It features the Coil + Mode, which automatically primes the coil at the end of each puff by drawing in more liquid and reducing carbon. In addition, refresh is it's another highlight point that allows you to manually refresh the coil between hits to provide better wicking, bringing in flavor to extend the coils life. Made of glass, Innokin Sensis Pod Cartridge with 3.1ml capacity is compatible with Sceptre Coil and Sceptre S Coil (Only Sceptre S Coil 0.25ohm (25~35W) and Sceptre Coil 0.65ohm (9~12W) included), delivering a RDL or MTL vaping experience. Five optional colors in total
Original Gas Mods Cyber RTA Rebuildable Tank Vape Atomizer Original Price $41.99, Now Only $36.99.
Original Gas Mods Cyber RTA Rebuildable Tank Vape Atomizer in 24mm diameter adopts bottom filling system, easy to refill oil. It features 2 kinds of air inlet, bottom and side inlet and the side airflow can be closed by screw. It adopts dual terminal postless style build deck and 6 inner adjustable airflows, easy for you to build and wick. Three colors for your choice: Rainbow, Black, Silver
Original Koguovape Lamo MTL RTA Rebuildable Tank Vape Atomizer 2.0ml Original Price $39.99, Now Only $28.99.
Original Koguovape Lamo MTL RTA Rebuildable Tank Vape Atomizer, made of SS316 (Body) and Glass (Tube), holds 2.0ml capacity with convenient top filling system in 22mm diameter. It adopts snap-in design chamber, easy to replace the cotton and coil. Koguovape Lamo MTL RTA comes with air disc (4mm x 1.2mm, 3 x 1.0mm, 2 x 1.0mm, 1 x 1.0mm) on the RTA, which is easy to replace and to carry and use. With 510 threading connection, it can be applied in most of your favorite Mods. The deck has a side by side post system for easy coil installation and a removable peak insert to intensify the flavor, creating a MTL or DL vaping experience. Two Color: Black, Silver
Original Innokin Sensis Next-Gen Replacement Pod Cartridge w/ 0.25ohm Coil 3.1ml $8.99
Original Innokin Sensis Pod Cartridge holds 3.1ml capacity with bottom filling system, especially designed for Innokin Sensis 40W 3000mAh Next-Gen Pod System Vape Kit. Innokin Sensis Pod Cartridge comes with Sceptre S Coil 0.25ohm (Prebuilt) (suggested wattage: 25~35W) and Sceptre Coil 0.65ohm (9~12W), brings a RDL or MTL vaping experience. Compared to other conventional plastic pod cartridges, this Glass Pod Cartridge improves flavor and prevents corrosion from within the pod when using certain e-liquids. 1 PC / Pack
Старый 25.02.2021, 04:45 Автор темы   28
3FVAPE
Original Lost Vape Grus 100W VW Box Mod + 5.0ml UB Pro Pod Tank Kit $39.99
Original Lost Vape Grus 100W VW Box Mod Kit consists of a Lost Vape Grus 100W VW Box Mod and a 5.0ml UB Pro Pod Tank. Lost Vape Grus 100W VW Box Mod is powered by 1 x 21700 / 20700 / 18650 (Battery not included), with a maximum power output of 100W (5~100W). Lost Vape Grus 100W Mod adopts fully upgraded quest 2.0 chip, which can provide five vape modes VW / TC / SS / TI / NI Mode, three boost levels and 3 user records. Equipped with 0.96 inch TFT display screen, it has accurate temperature adjustment so you can set what wattage you want to. With the 510 threading connection, Grus 100W Mod can accommodate atomizers up to 30mm diameter. UB Pro Pod Tank Atomizer holds 5.0ml capacity with easy side filling system. It is compatible with UB Pro Coils, like UB Pro P1 Coil 0.15ohm (70~90W) and UB Pro P3 Coil 0.3ohm (60~70W) included in the package, bringing you an excellent DL vaping experience. Made of stainless steel and PCTG, UB Pro Pod Tank features fully adjustable airflow system and triple airflow channels, delivering the most balanced and flavorful clouds. It comes with a base with a bottom AFC and standard 510 threading connection. Nine colors in total for your choice.
Original Innokin Sensis 40W Pod Kit / Pod Cartridge Replacement Sceptre S Coil 0.25ohm $5.99
Original Innokin Sceptre S Coil is with 0.25ohm resistance (suggested wattage: 25~35W). It is perfectly compatible with Innokin Sensis 40W Kit and Innokin Sensis Next-Gen Pod Cartridge. 5 PCS / Pack
Старый 26.02.2021, 04:46 Автор темы   29
3FVAPE
Original Auguse MTL / DTL V2 RTA Rebuildable Tank Vape Atomizer 3.0ml Original Price $35, Now Only $28.99.
Original Auguse MTL / DTL V2 RTA Rebuildable Tank Vape Atomizer holds 3.0ml capacity with convenient top filling system. It adopts oil switch system, single coil configuration, design of inclined inlet with 30 degree angle and three kinds of independently adjustment precise air flow, delivering you a MTL or DL optional vaping experience. It features 30 degree angle oblique bellowing method, which combined with 3 independent precise air intake adjustments on the bottom, so you can customize your own vaping experience. With 510 threading connection, it can accommodate most of your favorite mods. Two colors: Black / Silver
Original ULTRONER Alieno 70W TC VW Variable Wattage Vape Box Mod SEVO 70 Chipset Original Price $139, Now Only $129.
Original ULTRONER Alieno 70W TC VW Vape Box Mod is powered by SEVO-70 chipset enough to fire up to max. 70W output, made from Stabilized Wood and Stainless Steel. The Ergonomic design makes it more convenient to use and supports replacement battery tube (not included). The redesigned top cap adapts to 24mm atomizer. Please Note: Product may vary due to stabilized wood properties. Two kinds of appearance material: ABS / Stabilized Wood
SXK BB Clone 60W All-in-One VW Box Mod Vape Kit w/ USB Port Evolv DNA 60 (2021 Logo) Original Price $119, Now Only $114.8.
The SXK BB Clone mod, constructed from aluminum features an all-in-one design. It is powered by 1 x 18650 battery (Not Included), enough to fire up to maximum power output 60W. The box mod is powered by Evolv DNA 60 chip. This BB Box comes with USB port for firmware upgrading, setting modification and user customization via software. Please note: This BB Box with 2021 Logo
510 to 510 Stainless Steel Heat Sink for Atomizer with 510 Threading Connection 22mm $3.99
510 to 510 Stainless Steel Heat Sink is designed for most of atomizer with 510 threading connection. It is quite useful for heat insulation when vaping. With different diameters, it can be easily compatible with your atomizers. 1 PC / Pack
Original Wotofo OFRF NexMESH Pro Tank Atomizer Replacement H18 Triple Mesh Coil Head 0.15ohm $7.99
Original Wotofo NexMESH H18 Triple Mesh Coil 0.15ohm is designed for Wotofo NexMESH Pro Sub Ohm Tank Atomizer. It features triple mesh coil structure, forming a triangle mesh heating network inside, producing thicker vapor while keeping amazing flavor. Power range is 65~95W while suggested range 80~90W. Wotofo OFRF NexMESH Pro Tank Atomizer Replacement H19 Wire & Mesh Quad 0.15ohm Coil Head is also available. 3PCS / Pack
Старый 27.02.2021, 04:42 Автор темы   30
3FVAPE
Original Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit Dovpo Chipset $134.99
Original Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit included a Dovpo X Suicide Mods Abyss 60W Mod and a Dovpo X Suicide Mods Abyss Refillable Tank Atomizer. Dovpo X Suicide Mods Abyss 60W VW Mod is powered by 1 x 18650 / 21700 battery (not included), with a maximum power output of 60W (5~60W). The OLED Display screen is located on the base of the device as not to spoil the overall sleek look with additional screens and buttons. Constructed from Aluminum Alloy and Stainless Steel and equipped with Dovpo Chipset, Dovpo X Suicide Mods Abyss Mod comes with the Nautilus Coil adaptor bridge. In addition, it is also compatible with additional bridges for the Caliburn G, EUC, PnP / GTX, Nord Coils and ETHER RBA Bridge (Both not included), allowing you to turn AIO kit into a Side by Side device. Dovpo X Suicide Mods Abyss Refillable Tank Atomizer adopts side filling system, brings you an amazing vaping experience.
Apocalypse GEN 2 Clone Mechanical Mod + RDA Rebuildable Dripping Atomizer Kit 24.5m $20.99
Apocalypse Mod Kit included mechanical mod and Apocalypse Gen 2 Clone RDA. Apocalypse GEN 2 Clone Mechanical Mod is powered by 1 x 18650 battery (Not included). constructed from Brass, It is with 510 threading connection. Apocalypse Gen 2 Clone RDA Rebuildable Dripping Vape Atomizer in 24.5mm diameter features clamp design and has a massive 13mm space in each clamp which provides space for mounting the most complex & insane coil builds. Coupled with the 4mm deep juice well, 21mm build deck, durable post clamps and extended post screws, the Apocalypse is a great choice for those who like DIY.
Старый 01.03.2021, 05:03 Автор темы   31
3FVAPE
Original Hellvape Trishul V2 Semi-Mech Vape Mechanical Mod Original Price $76.5, Now Only $50.99.
Original Hellvape Trishul V2 Semi-Mechanical Mod with 510 threading connection is powered by 1 x 1 x 18650 / 20700 / 21700 (Battery not included, 18650 Battery Adapter included). Hellvape Trishul V2 Semi-Mech Mod can switch from mechanical to semi-mechanical by simple operation. It is equipped with powerful N52 NdFeB Black Magnet, offering stable and strong magnetism. With a silicon gasket, it is compatible with different batteries automatically. In addition, it comes with large copper contact with mirror polishing craft, which can transfer the arc to protect users and the device. Three colors for your choice: Brass, Copper, Copper Black
Original Innokin Ares 2 D22 MTL RTA Rebuildable Tank Vape Atomizer Cross Air Flow Control $24.99
Original Innokin Ares 2 D22 MTL RTA Rebuildable Tank Vape Atomizer features the new Cross Air Flow Control (CAFC) located under the coil, allowing you to change airflow from a tiny hole to a larger slot running the length of the coils. Innokin Ares 2 D22 MTL RTA holds 4.0ml capacity with top filling system in 22mm diameter. It upgrades the top cap and seals to prevent liquid and air seepage. Moreover, it also improves the bottom seals and adds a 0.8mm airhole, delivering an excellent MTL vaping experience.
Original Gas Mods Cyber RTA Replacement Glass Tank Tube $1.29
Original Gas Mods Cyber Replacement Glass Tank Tube is especially designed for Gas Mods Cyber RTA Rebuildable Tank Vape Atomizer. Two optional capacities: 3.5ml / 6.0ml. 1 PC / Pack
Старый 02.03.2021, 04:47 Автор темы   32
3FVAPE
Original Elf Bar RF350 350mAh Pod System Vape Starter Kit $7.99
Original Elf Bar RF350 350mAh Pod System Vape Starter Kit consists of an Elf Bar RF350 350mAh Pod System Mod and a 1.6ml Elf Bar RF350 Pod Cartridge. Elf Bar RF350 Pod System Mod, a compact and ergonomic mod, is powered by a 350mAh built-in battery with type-C charging system for a long lasting vaping experience. Elf Bar RF350 Refillable Pod Cartridge with 1.6ml capacity is made of PCTG. With 1.2ohm resistance, it absolutely delivers you an amazing vaping experience. Optional colors: Dark Green, Green, Orange, Blue, Red, Yellow, White, Black
Original Elf Bar RF350 Pod System Kit Replacement Pod Cartridge w/ 1.2ohm Coil $6.99
Original Elf Bar RF350 Pod Cartridge with 1.2ohm resistance is especially designed for Elf Bar RF350 350mAh Pod System Starter Kit. It holds 1.6ml capacity, made of PCTG. 4 PCS / Pack
Replacement Nano Bell Cap + Chimney for Flash e-Vapor V4.5S Clone RTA Tank $9.99
Replacement Nano Bell Cap + Chimney Kit is constructed from Stainless Steel, especially designed for Flash e-Vapor V4.5S Clone RTA Rebuildable Tank Vape Atomizer. 1 PC / Pack
Kontrl Clone Front + Back Door Panel Plates w/ Black Button for dotMod dotAIO Vape Pod System Acrylic $40.99
The Replacement Front and Back Door Panel Plates is made from Acrylic and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included). It comes with a black button for easy operation. Totally seven colors for your choice.
Старый 03.03.2021, 04:55 Автор темы   33
3FVAPE
Original Vandy Vape Jackaroo 70W VW Pod System Mod Kit 2000mAh Original Price $49.99, Now Only $30.99.
Original Vandy Vape Jackaroo 70W Pod System Mod Kit consists of a Vandy Vape Jackaroo 70W VW Pod System Mod and a 4.5ml Vandy Vape Jackaroo Mesh Coil Pod Cartridge. Vandy Vape Jackaroo 70W Pod System Mod is integrated with a 2000mAh built-in battery with waterproof USB charging design, enough to provide a maximum power output of 70W (5~70W). Jackaroo 70W Pod Mod is equipped with an upgraded VANDY Chip. Moreover, Jackaroo Pod Mod is also compatible with a rebuildable coil's DIY pod (not included) for DIY fun and cost-saving. Vandy Vape Jackaroo Mesh Coil Pod Cartridge holds 4.5ml capacity with easy top filling system. It comes with top honeycomb airflow system, which can avoid e-juice leaking. It is compatible with VVC Mesh Coil Series (2 x VVC Coil included), supporting a MTL or DL vaping experience. Totally 8 colors for your choice
Original Coil Father King RTA Rebuildable Tank Vape Atomizer Dual Coil Configuration 24mm $10.99
Original Coil Father King RTA Rebuildable Tank Vape Atomizer holds 3.5ml refillable capacity by removing the threaded knurled top cap in 24mm diameter. It features dual coil configuration with an effective airflow design, which directs airflow to both the bottom and side of each coil simultaneously, absolutely bringing an impeccable flavor and great vaping experience. Constructed of stainless steel, it comes with a postless midsection build deck. It is compatible with most mods with 510 threading connection. 3 colors for your choice: Silver, Black, Gold
Original Vandy Vape Jackaroo Pod Kit Replacement Mesh Coil Pod Cartridge 4.5ml $8.99
Original Vandy Vape Jackaroo Mesh Coil Pod Cartridge holds 4.5ml capacity with top filling system, designed for Vandy Vape Jackaroo 70W VW 2000mAh Pod System Mod Kit. It features top honeycomb airflow system, which can avoid e-juice leaking. In addition, Jackaroo Pod Cartridge is compatible with VVC Mesh Coil Series (Not included). Vandy Vape Jackaroo DIY RBA Pod Cartridge is also available. 1 PC / Pack
Original Vandy Vape Jackaroo Pod Kit / Pod Cartridge Replacement VVC-15 Mesh Coil Head $8.99
Original Vandy Vape Jackaroo VVC-15 Mesh Coil Head is designed for Vandy Vape Jackaroo Pod Mod Kit and Vandy Vape Jackaroo Pod Cartridge. It is suitable for fruit flavored e-liquid (not included), delivering a DL vaping experience in warmer smoke. Vandy Vape Jackaroo VVC-30 0.3ohm / VVC-60 0.6ohm / VVC-90 0.9ohm / VVC-120 1.2ohm are also available. 4 PCS / Pack
Старый 04.03.2021, 05:02 Автор темы   34
3FVAPE
Original BP Mods Bushido Squonk Vape Mechanical Box Mod For 22mm BF RDA $59.99
Original BP Mods Bushido Squonk Mod, a portable mech squonk mechanical mod, is powered by 1 x 18650 battery (not included). With durable Aluminum Alloy construction, it is compatible with 22mm BF RDAs. Bushido Mod is easily operated by users only by turning the mod over and unscrewing the cap to refill the squonk bottle. Four colors for your choice: Space Grey, Grape, Tangerine, Green
Original Artery PAL 3 25W Pod System Vape Starter Kit Original Price $39.99, Now Only $26.99.
Original Artery PAL 3 25W Pod System Vape Starter Kit includes an Artery PAL 3 Pod System Mod and a 3.0ml Artery PAL 3 Pod Cartridge. Artery PAL 3 Pod System Mod is powered by a 1000mAh built-in battery, enough fire up to 25W (5~25W) with Type-C charging port. Compared to Artery PAL 2, Artery PAL 3 is 20% smaller in volume. Artery PAL 3 Pod Cartridge holds 3.0ml capacity with easy bottom filling system. PAL 3 pod cartridge features a Finely Tuned Airflow System for perfectly RDL and MTL. It adopts ergonomic mouth piece design for a better inhale feeling. PAL 3 Pod Cartridge is compatible with the upgraded HP coils (HP 0.7ohm Coil and HP 1.2ohm Coil included), delivering better flavor and longer lasting vaping experience. Totally six colors for your choice.
Original BP Mods Futon Ohm Tab Luxury Edition $44.99
Original BP Mods Futon Ohm Tab is powered by 1 x 18650 battery (not included), designed for RTA / RDA / RDTA Rebuildable Vape Atomizer. It is a V / W adjustable coil tab with many bright spot functions, which brings you a brand new experience. Construed from aluminum alloy with four 3M rubber pads on the bottom, the Futon Ohm Tab comes with a side fire button which is pleasing to press with your left hand index finger. In addition, it has Mode select button, + / - buttons, screen and 510 port are on the top. And there is a type-C USB interface which supports 1A current input on the Futon Ohm Tab so it can plays an emergency charger for your 18650 battery (Not included). Two colors: Everglade Green / Space Grey
Original Vandy Vape Jackaroo Pod Kit / Pod Cartridge Replacement DL Drip Tip $1.99
Original Vandy Vape Jackaroo Replacement DL Drip Tip is especially designed for Vandy Vape Jackaroo 70W VW Pod System Mod Kit and Vandy Vape Jackaroo Pod Cartridge. Vandy Vape Jackaroo MTL Drip Tip is also available. 1 PC / Pack
Original Artery PAL 3 Pod System Kit Replacement Empty Pod Cartridge $3.59
Original Artery PAL 3 Empty Pod Cartridge holds 3.0ml capacity with easy bottom filling system, especially designed for Artery PAL 3 25W Pod System Kit. It comes with ergonomic mouth piece design, brings you better inhale feeling. PAL 3 Pod Cartridge is compatible with the upgraded HP coils (Not included). 1 PC / Pack
Original BP Mods Bushido V3 RDA Replacement Air Pin Kit $4.99
Original BP Mods Air Pin Kit is designed for Bushido V3 RDA Rebuildable Dripping Vape Atomizer. This Air Pin Kit aims at controlling the desired airflow rate, including 2 x 0.7mm Airflow Pin, 1x Airflow Blocking Pin, 1 x Pin Pusher.
Original BP Mods Pioneer RTA Replacement Build Deck w/ 1.2mm + 1.5mm Air Pins $18.99
Original BP Mods Pioneer Build Deck is made of Stainless Steel, especially designed for Pioneer RTA Rebuilable Tank Vape Atomizer. The deck is pre-installed 0.8mm air pin and comes with 1.2mm and 1.5mm air pins. 1 PC / Pack
Старый 05.03.2021, 05:04 Автор темы   35
3FVAPE
SXK Scud TT Clone TC 70W VW Vape Box Mod SEVO 70 Chipset Original Price $126.8, Now Only $115.9.
The SXK Scud TT Clone TC VW Box Mod is powered by SEVO 70 Chipset, constructed from POM. SXK Scud TT box Mod is powered by 1 x 18650 battery (not included), with the range of output power of 1~70W and accommodates 22mm diameter atomizer. Please note: The USB port is only for charging, does not supports upgrading.
SXK Scud TT Clone TC 60W VW Vape Box Mod Evolv DNA 60 Chipset Original Price $179.9, Now Only $165.9.
The SXK Scud TT Clone TC VW Box Mod is powered by Evolv DNA 60 Chipset, constructed from Aluminum Alloy. Powered by 1 x 18650 battery (not included), the SXK Scud TT box Mod is compatible with 22mm diameter atomizer. SXK Scud TT Clone Box Mod Stabilized Wood is also available. Please note: The USB port is only for charging, does not supports upgrading.
Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Bell Cap + Chimney + Drip Tip Kit $13.99
Original Ambition Mods and The Vaping Gentlemen Club Bishop Bell Cap Kit holds 4.0ml capacity, designed for Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA 2.0ml / 4.0ml Rebuildable Tank Vape Atomizer. This bell cap kit is made of PEI, including 1 x Bell Cap, 1 x Chimney, 1 x Drip Tip. Three colors for your choice: Brown, Black, Transparent.
Original BP Mods Pioneer MTL / DL RTA Replacement Short Clear Tank Kit $14.99
Original BP Mods Short Clear Tank Kit is designed for BP Mods Pioneer MTL / DL RTA Rebuildable Tank Vape Atomizer. BP Mods Short Clear Tank Kit includes 1 x Whole Short Clear Tank Kit, 1 x Spare Chimney, 2 x Air Pins, 1 x Set of Screws / O-rings. Two optional capacities for your choice: Short 2.8ml / Long 4.4ml in respectively three colors: Amber, Eclipse, Clear
Original BP Mods Pioneer MTL / DL RTA Replacement Damascus Top Cap $74.99
Original BP Mods Damascus Top Cap is designed for Pioneer MTL / DL RTA Rebuildable Tank Vape Atomizer. BP Mods Damascus Blade Top Cap is also available. 1 PC / Pack
Original BP Mods Pioneer MTL / DL RTA Replacement Damascus AFC Airflow Ring $64.99
Original BP Mods Damascus AFC Airflow Ring is designed for Pioneer MTL / DL RTA Rebuildable Tank Vape Atomizer. 1 PC / Pack
Старый 06.03.2021, 04:32 Автор темы   36
3FVAPE
Original Vaporesso Luxe Q 1000mAh Pod System Vape Kit SSS Leak Resistance Technology $26.99
Original Vaporesso Luxe Q Pod System Vape Starter Kit includes a Luxe Q 1000mAh Pod System Mod and a 2.0ml Luxe Q Pod Cartridge. Luxe Q Pod System Mod is integrated with a 1000mAh built-in battery with type-C charging. It adopts SSS Leak Resistance Technology which builds comprehensive anti-leakage liquid effect. Luxe Q Pod System Mod supports draw activated system. Luxe Q Pod Visible Cartridge holds 2.0ml capacity with top filling system. By simply switching the installing direction of the cartridge, Luxe Q Pod System Vape Starter Kit can change the airflow. Two pod cartridges are included in the package, one pod cartridge with 0.8ohm resistance and another with 1.2ohm, absolutely delivering a pure flavor and excellent experience. Seven colors: Black / White / Blue / Red / Pink / Green / Bown
Старый 08.03.2021, 04:48 Автор темы   37
3FVAPE
Original IJOY Captain Link 100W VW Box Mod + 5.0ml Captain Pod Tank Kit Univ S 2.0 Chipset Original Price $69.99, Now Only $43.99.
Original IJOY Captain Link Pod Kit consists of an IJOY Captain Link 100W VW Pod Mod and a 5.0ml Captain Pod Tank. IJOY Captain Link 100W Pod Mod is powered by 1 x 18650 / 21700 battery (battery not included, 18650 battery adaptor included) with Type-C charging, enough to fire up to 100W (5~100W). Equipped with newly-upgraded Univ S 2.0 chipset inside, IJOY Captain Link Pod Mod is more powerful, intelligent and safety and supports POWER / TEMP / TCR mode. With 510 threading connection, it is compatible with most atomizers. In addition, vaping date can be easily checked by 0.96 inch TFT screen. IJOY Captain Pod Tank holds 5.0ml capacity with bottom filling system. It comes with dual slotted bottom airflow, which enables to bring ample air inlet to the coils too. In this kit, there are a L15 Clapton Mesh Coil 0.15ohm (Pre-installed, 60~80W) and a L5 Mesh Coil 0.5ohm (30~50W), bringing a longer lifespan than other devices. Five optional colors: Green, Red, Black, Blue, SS
Original IJOY Captain Link 100W VW Box Mod Univ S 2.0 Chipset Original Price $49.99, Now Only $31.99.
Original IJOY Captain Link 100W Box Mod is equipped with newly-upgraded Univ S 2.0 chipset inside, which makes more powerful, intelligent and safety and supports POWER / TEMP / TCR mode. IJOY Captain Link Pod Mod is powered by 1 x 18650 / 21700 battery (battery not included, 18650 battery adapter included) with Type-C charging and 0.96 inch TFT screen, enough to provide a maximum output power of 100W (5~100W). With 510 threading connection, it can accommodate most of atomizers. Five optional colors: Green, Red, Black, Blue, SS
Original IJOY Captain Link Pod Kit Replacement Pod Tank $9.99
Original IJOY Captain Pod Tank holds 5.0ml capacity with bottom filling system. It has dual slotted bottom airflow, which enables to bring ample air inlet to the coils too. Captain Pod Tank comes with a L5 Mesh Coil 0.5ohm (Suggested wattage: 30~50W) and a L15 Clapton Mesh Coil 0.15ohm (Pre-installed, 60~80W), brings a longer lifespan than other devices. With 510 threading connection, it is compatible with most of your favorite mods.
Original IJOY Captain Link Pod Kit / Pod Cartridge Replacement L5 Mesh Coil Head $8.99
Original IJOY Captain Link Mesh Coil Head is designed for IJOY Captain Link 100W Pod Mod Kit and IJOY Captain Link Pod Cartridge. Two optional resistances: 0.5ohm / 0.15ohm. 3 PCS / Pack
Старый 09.03.2021, 04:43 Автор темы   38
3FVAPE
Original Lost Vape UB Lite 30W Pod System Starter Kit $18.99
Original Lost Vape UB Lite 30W Pod System Vape Starter Kit is a Draw / Button Activation pod kit, including a Lost Vape UB Lite 30W Pod Mod and a 2.0ml UB Lite Pod Cartridge. Lost Vape UB Lite Pod Mod is combined with a 1000mAh built-in battery with Type-C fasting charging, enough to provide a maximum output power of 30W (7~30W). With Smart Coil Detection, Lost Vape UB Pod Mod can automatically detect the coil resistance and provide the recommended power output. It features airflow control slider, allowing you to customize your phenomenal MTL / RDL draw. UB Lite Pod Cartridge holds 2.0ml capacity with side refilling design. It is compatible with new UB Lite Series Coils, UB Lite L1 0.4ohm Coil (20~30W) and UB Lite L5 1.4ohm Coil (8~10W) included, bringing you a DL / MTL vaping experience.
Original Lost Vape UB Lite Pod Kit Replacement Empty Pod Cartridge $3.99
Original Lost Vape UB Lite Empty Pod Cartridge is designed for Lost Vape UB Lite 30W Pod System Starter Kit. It holds 2.0ml capacity with side refilling design. It is compatible with new UB Lite Series Coils (Coils not included), absolutely delivering you a DL / MTL vaping experience. 1 PC / Pack
Original Lost Vape UB Lite Pod Kit / Pod Cartridge Replacement UB Lite L1 Coil Head $9.99
Original Lost Vape UB Lite L1 Coil Head is designed for Lost Vape UB Lite 30W Pod System Starter Kit and Lost Vape UB Lite Pod Cartridge. Three options: UB Lite L1 Coil Head 0.4ohm (20~30W, DL), UB Lite L3 Coil Head 0.8ohm (12~17W, DL), UB Lite L5 Coil Head 1.4ohm (8~10W, MTL). 5 PCS / Pack
Старый 10.03.2021, 05:05 Автор темы   39
3FVAPE
Original Ambition Mods and R. S. S.Mods Hera 60W VW Box Mod $69.99
Original Ambition Mods and R. S. S.Mods Hera 60W Box Mod is powered by 1 x 18650 battery (not included) with the output power range of 1~60W. Constructed from SS316 and PC, Hera Box Mod accommodates atomizer tanks up to 24mm in diameter. Equipped with 0.91 inch OLED screen, it supports NI / SS / TI / VW modes by pressing up button or down button twice continuously. 13 colors for your choice.
Original Wotofo The Troll X RTA Rebuildable Tank Vape Atomizer 24mm Original Price $37.99, Now Only $28.99.
Original Wotofo The Troll X RTA Rebuildable Tank Vape Atomizer holds 3.0ml / 4.4ml capacity with top filling system in 24mm diameter. The Troll X RTA features a postless build deck, so it can accommodate dual coils while still leaving large space for easy building inside its compact chamber. It has a flexible air control with Triangular Air Balancing System for smooth and high quality air supply. To make the inflow air travel in a more intended way in the vaporizing chamber, Wotofo The Troll X RTA adopts an airflow insert that diffuses the air through its specially designed slots and surrounds the coils with streamed airflow evenly to enhance the flavor production. In addition, it comes with two airflow inserts by simply switch operation, honeycomb dot and slim groove, delivering soft smooth and vigorous chunky airflow respectively. Six colors: Black, Rainbow, SS, Gold, Blue, Blue Metal
Original Asvape Hita Ink 40W Pod System Vape Mod Kit 1500mAh Original Price $36, Now Only $30.99.
Original Asvape Hita Ink Pod System Vape Mod Kit inherits the classic style of Asvape strider, including an Asvape Hita Ink 40W Pod System Mod and a 3.0ml Asvape Hita Ink Pod Cartridge. Asvape Hita Ink Pod Kit is powered by built-in 1500mAh battery with adjustable output power of 5~40W. Asvape Hita Ink features self-developed ReekBox chip to identify the coil resistance and match the power automatically and OLED screen to display vaping data. Asvape Hita Ink Pod cartridge with 3.0ml capacity comes with a 0.3ohm mesh coil and a 1.0ohm for a DTL / MTL vaping experience. 10 colors for your choice
Original Vaporesso Swag PX80 80W VW Variable Wattage Box Mod $29.99
Original Vaporesso Swag PX80 Box Mod is powered by 1 x 18650 battery (not included) with Type-C 2A fast charging, enough to fire up to 80W (5~80W). Monitored by the AXON Chip, Swag PX80 Mod can be fired in 0.001s. In addition, as an ergonomic box mod, Swag PX80 Mod has a 0.96 inch embedded IML screen, easier for you to carry out and check the vaping data. Vaporesso Swag PX80 Kit is also available. Five colors in total: Emerald Green, Imperial Red, Leather Brown, Gunmetal Grey, Brick Black
Старый 11.03.2021, 04:42 Автор темы   40
3FVAPE
Original SMOKTech SMOK NOVO 4 25W Pod System Vape Starter Kit 800mAh $27.99
Original SMOKTech SMOK NOVO 4 Pod System Vape Starter Kit, a one-to-all Pod Kit, consists of a NOVO 4 25W Pod System Mod and a 2.0ml SMOK NOVO 4 Pod Cartridge. NOVO 4 Pod System Mod is powered by an 800mAh built-in battery with the output power range of 5~25W. Equipped with 0.49 inch OLED display and constructed from zinc alloy, NOVO 4 Pod Mod comes with fast and fun adjustable airflow, satisfying your demand for tightness / thickness of the vapor. NOVO 4 Pod Cartridge holds 2.0ml capacity with side filling system. It is compatible with LP1 Coils, only LP1 Meshed 0.8ohm Coil (12~15W) included in the package for a softer flavor. With 3 silicone rings, it can realize No leakage anymore to a great extent. 10 colors in total for your choice
Original Wotofo The Troll X RTA Replacement 810 Drip Tip $2.99
Original Wotofo The Troll X RTA Replacement 810 Drip Tip is especially designed for Wotofo The Troll X RTA Rebuildable Tank Vape Atomizer, bringing an excellent vaping experience for cloud chasers. 5 colors: Rainbow, Red, Blue, Gold, Black. 1 PC / Pack
Original Wotofo The Troll X RTA Replacement Straight Tank Tube $2.59
Original Wotofo The Troll X Glass Tank Tube is especially designed for Wotofo The Troll X RTA Rebuildable Tank Vape Atomizer. 2 optional capacities: 3.0ml / 4.4ml. 1 PC / Pack
Время генерации страницы 0.27023 секунды с 15 запросами
