302418
822
21
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Vaporesso Switcher 220W TC VW Variable Wattage Box Mod $60.99
The Vaporesso Switcher is a multi-function device intended to let you vape with fun, which brings the interaction into vaping with its all-metal case fully replaceable, creating different looks that you like. It is powered by dual 18650 batteries (not included), the mod is capable of outputting up to 220W with up-to-date OMNI Board 2.6. The Switcher supports atomizer resistance low to 0.05ohm.This item also has many color to choose. ![]() Scepter Hybrid Mechanical Mod Clone $26.99 The Scepter mechanical mod Clone is constructed from copper with copper battery contact. The mod features twisted design and engraved millings and patterns. It comes with top venting holes and magnetic fire button. The mod is powered by single 18650 battery (not included). ![]() Original Hellvape Priest Cap for 24mm Dead Rabbit RDA Original Price $21.00,Now Only $12.99 Please log in to see the lower price.This item also has many color to choose. The Original Hellvape Priest Challenge Cap is constructed from T2 copper with 24mm diameter. It is compatible with 810 drip tip and fits all existing 24mm dead rabbit decks. This cap comes with either T2 copper drip tip or resin drip tip (random color). ![]() Original Hellvape Dead Rabbit SQ RDA Rebuildable Dripping Atomizer with BF Pin Original Price $36.99,Now Only $24.99 Please log in to see the lower price. The Original Hellvape Dead Rabbit SQ RDA is 22mm version of the Dead Rabbit and it is a single coil RDA. It comes with new features like a barrel lock, and the side airflow for Mouth to Lung Vaping. Its deck comes with dual post for single coil building, and the slide in top coil deck takes the guesswork out of pre-cutting your coil leads.This item also has many color to choose. This RDA comes with bottom feeder pin. ![]() Original Vaporesso Switcher 220W TC VW Variable Wattage Mod + NRG Tank Kit $88.90 The Vaporesso Switcher Kit consists of Vaporesso Switcher Mod and NRG Tank.This item also has many color to choose. Mod: The Vaporesso Switcher is a multi-function device intended to let you vape with fun, which brings the interaction into vaping with its all-metal case fully replaceable, creating different looks that you like. It is powered by dual 18650 batteries (not included), the mod is capable of outputting up to 220W with up-to-date OMNI Board 2.6. The Switcher supports atomizer resistance low to 0.05ohm. Tank: The NRG Tank by Vaporesso is a master piece of everyday vape and cloud chasing, featuring innovative GT Cores that comes in traditional and CCELL Ceramic coil. The Slide-n-Fill design makes refill easier than ever. The heating insulation layer on the bottom demonstrates how Vaporesso care for safer and relaxing vaping experience. Furthermore, the mesh drip tip with specially engineered structure will prevent any spit back. Enjoy the flavor and vapor out of the variety of GT cores available. ![]() Original Vandy Vape Replacement MAZE Coil for Maze Sub Ohm BF RDA $6.99 The Original Vandy Vape Maze Coils is so innovative that can compatible with the Regulated and Mechanical Mod, bringing better safety and compatibility. It comes with 0.2ohm resistance and works well at 50~100W, best for 70~80W. This product comes with 3 PCS in 1 pack.
22
Vulcan Squonk Mechanical Box Mod Clone $23.99
The Vulcan squonk box mod Clone is constructed from aluminum (body) and zinc alloy (top plate). The mod features triangular prism shape, side fire button, 8ml silicone bottle, full power output with dual 18650 batteries (not included).This item also has many color to choose. ![]() Original Coil Master Elfy RTA Rebuildable Tank Atomizer $24.99 The Original Coil Master Elfy RTA is a 22mm tank with 2.5ml e-juice capacity. Elfy features convenient top filling, dual post for single coil building, redirected bottom airflow, leaking-free design and gold plated 510 pin. The bottom airslots are adjustable via airflow control ring and can redirect the inflow to the coil, which prevents juice leakage.This item also has many color to choose. ![]() Original Vapefly Mesh Plus RDTA Rebuildable Dripping Tank Atomizer TPD Edition Original Price $28.50,Now Only $22.99 Please log in to see the lower price.The Original Vapefly Mesh Plus RDTA features stainless steel construction, 25mm diameter, 2ml e-juice capacity, easy side filling, and postless build deck for mesh wire, single coil or dual coil builds. There are 4 terminals with quad individual clamp, which make coil building much easier. The precise airflow system offers great flavor and eliminates leakage. 810 Delrin drip tip is included. This RDTA is TPD Edition with 2ml capacity. ![]() Vulcan RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Vulcan RDA Clone is a 24mm rebuildable atomizer constructed from stainless steel. The build deck features dual post design for single or dual coil building and supports various fancy coils. The airflow is adjustable via dual side airslots on the cap. Wide bore acrylic drip tip is included. This RDA comes with bottom feeder pin.This item also has many color to choose. ![]() Original Wismec Reuleaux RX2 230W TC VW Mod + GNOME Tank Kit $56.99 The Original Wismec Reuleaux RX2 21700 Kit consists of Reuleaux RX2 230W Mod and GNOME Tank.This item also has many color to choose. Mod: The Original Wismec Reuleaux RX2 21700 Mod is more updated as it can support 21700 battery, with which it is capable of outputting up to 230W; the mod is also compatible with 18650 battery (batteries not included). Tank: The Original Wismec GNOME Sub Ohm Tank feature 25mm diameter and 2ml e-juice capacity and comes with all-new WM coils for huge vapor and optimal flavor. ![]() Vulcan quonk Mechanical Box Mod Clone + BF RDA Kit $29.99 The Vulcan Squonk Clone Kit consists of Vulcan Squonk Mod Clone and Vulcan BF RDA Clone.This item also has many color to choose. Mod: The Vulcan squonk box mod Clone is constructed from aluminum (body) and zinc alloy (top plate). The mod features triangular prism shape, side fire button, 8ml silicone bottle, full power output with dual 18650 batteries (not included). RDA: The Vulcan RDA Clone is a 24mm rebuildable atomizer constructed from stainless steel. The build deck features dual post design for single or dual coil building and supports various fancy coils. The airflow is adjustable via dual side airslots on the cap. Wide bore acrylic drip tip is included. This RDA comes with bottom feeder pin. ![]() Original Vendetta Cotton for RDA / RTA / RDTA $2.99 The Original Vendetta cotton is 100% organic cotton, which has not been chemically treated, bleached or pigmented. The medical level facilities make sure all processing are carefully treated and 100 percent tasteless cotton for wicking. ![]() Replacement Tank Tube + Top Cap + Chimney Accessory Kit for Vandy Vape Berserker MTL RTA $9.99 The accessory kit comes with one PEI tube, glass tube, PEI chimney and spare screws and accessory. It is suitable for authentic Vandy Vape Berserker MTL RTA.
23
Никому не надо?!
24
Original Eleaf iStick Pico 21700 100W TC VW Variable Wattage Box Mod $29.99
The iStick Pico 21700, the newest addition to Eleaf iStick Pico family, is compatible with 21700 battery as well as 18650 battery (not included). The iStick Pico 21700 retains the compact and ergonomic shape of iStick Pico series, which is very comfortable for you to hold and carry. It is capable of running up to 100W and has a maximum of 2A charging for efficient recharging. With a new easy-to-go firmware, the iStick Pico 21700 is a must-have vaping mod.This item also has many color to choose. ![]() Original SMOKTech SMOK Majesty Luxe Edition 225W Mod + TFV12 Prince Standard Kit $75.99 The Original SMOKTech SMOK Majesty Luxe Edition Kit consists of SMOK Majesty Luxe Edition Mod and TFV12 Prince Tank.This item also has many color to choose. Mod: Majesty Luxe Edition Mod has ritzy, glossy appearance, every detail of the mod is telling you what exquisite means. It can reach a maximum output of 225W, with which you can enjoy massive vapor; and it has high-definition user interface, which can offer you comprehensive vaping data. Moreover, the ergonomically designed fire key can provide you with easy operations. The mod is powered by dual 18650 battery (not included). Tank: The Original SMOK TFV12 Prince Tank from SMOKTech is not only a powerful one but also an all-round sub ohm tank for daily use. The tank adopts 3 newest coils: V12 Prince Q4, V12 Prince X6 and V12 Prince T10, all of which have huge cloud and extremely dense flavor. It also has newly designed crown-style body and colorful Cobra resin drip tip. Besides, it uses convex glass tube, which effectively enlarged the capacity to 8ml. This kit is Standard Edition with 8ml capacity. ![]() Original Eleaf iStick Pico 21700 100W TC VW Box Mod + Ello Tank Kit $43.99 The Original Eleaf iStick Pico 21700 Kit consists of iStick Pico 21700 Mod and ELLO Tank.This item also has many color to choose. Mod: The iStick Pico 21700, the newest addition to Eleaf iStick Pico family, is compatible with 21700 battery as well as 18650 battery (not included). The iStick Pico 21700 retains the compact and ergonomic shape of iStick Pico series, which is very comfortable for you to hold and carry. It is capable of running up to 100W and has a maximum of 2A charging for efficient recharging. With a new easy-to-go firmware, the iStick Pico 21700 is a must-have vaping mod. Tank: The ELLO atomizer features its HW series coils, bringing you ultimate vaping experience with nice flavor. The retractable top fill system makes it really easy to fill the tank. You just need to slide the drip tip back and it reveals the fill port. The dual large air inlets allow optimal airflow for great vapor production. ELLO introduces a new HW1-C coil. Featuring a ceramic wrapped wick system for heat preservation, this HW1-C coil can provide a great and efficient vaping experience with enhanced taste.
25
Original Sigelei TOP 1 230W TC VW Variable Wattage Box Mod Original Price $99.99,Now Only $72.99
Please log in to see the lower price.The authentic Sigelei TOP 1 Box Mod features ergonomic design and stylish dashboard interface. Powered by dual 18650 batteries (not included), Top 1 is capable of delivering power up to 230W. The temperature mode supports SS316 / SS317 / NI200 / Ti1 / TCR. The atomizer resistance range is from 0.05 to 3.0ohm. ![]() Apocalypse GEN 2 RDTA Rebuildable Dripping Tank Atomizer Clone $10.99 The Apocalypse Gen 2 RDTA Clone is with clamp design and has a massive space in each clamp which provides space for mounting the most complex and insane coil builds. The RDTA is constructed from stainless steel (cap) and brass (base) with PEI drip tip. Coupled with the large build deck, durable post clamps, teardrop airflow design and more juice capacity, the Apocalypse Gen 2 Style RDTA is a builder's dream.This item also has many color to choose. ![]() Kindbright Culverin RDA Rebuildable Dripping Atomizer Clone $10.99 The Kindbright Culverin RDA Clone is a 25mm atty constructed from stainless steel. The deck features dual post with teardrop post hole design. The positive pin is copper made, while the negative is SS. The side airflow offers great flavor and massive vapor production.This item also has many color to choose. ![]() Original OBS Crius RDA Rebuildable Dripping Atomizer w/ BF Pin Original Price $35.90,Now Only $21.99 Please log in to see the lower price.The wild and gorgeous OBS Crius RDA, constructed from stainless steel, is a 24mm atomizer that features environmental-friendly DIY deck and 360 degrees cyclic airflow. The clamp was made from high tech Zirconia, which is the top high-temperature resistant materials worldwide, corrosion-resistant, anti-oxidant, high hardness, non-volatile and no pollution. The new airflow system allows Cyclic airflow to enter the chamber and hit the coils, which helps to improve the flavor.This item also has many color to choose. This RDA comes with bottom feeder pin. ![]() Original Cool Vapor Arthur RDA Rebuildable Dripping Atomizer w/ BF Pin Original Price $39.90,Now Only $23.99 Please log in to see the lower price. The authentic Cool Vape Arthur RDA is a 24mm atty that features innovative cross style adjustable bottom airflow, which offers smooth vapor and cools down the atomizer efficiently. The build deck is 24K gold plated with dual post for easy coil building. The inner side of the cap adopts dome design for intense flavor. PEI drip tip is included. Please note: This RDA comes with bottom feeder pin for squonker mods. ![]() Replacement Bottom Feeder Bottle for Driptech-DS Squonk Mod Clone $0.99 The replacement BF bottom feeder squonk bottle is made from PC and comes with 8ml capacity. It is suitable for Driptech DS Squonk Mod Clone. ![]() YFTK Dripping Dropper Bottle for BF Bottom Feeder Squonk Mod $7.69 This YFTK dripping dropper bottle is made from silicone with PC lid and has 15ml e-juice capacity. It is used for squonk bottom feeder mods which have built-in bottles. It can feed the built-in bottle with e-juice. Only for bottom feeder mods that come with built-in bottle. The black bottle comes with black lid.This item also has many color to choose. Original Vaporesso GTM2 Replacement Coil for Cascade Sub Ohm Tank $8.99 All new GTM Cores adapted EUC Core plug-n-pull coil change method for a fast, easy, mass free replacement process. Suited for cloud chaser who demands power vapor, smoother air flow, flavorful taste, durable coil at the same time. The GTM 2 features 0.4ohm resistance for 40~80W. The product comes with 3 PCS in 1 pack. ![]() YFTK Replacement Top Cap + Drip Tip Kit for Haku RDA Clone $36.99 The repalcement top cap and drip tip were made from Titanium and are suitable for YFTK Haku Phenom RDA Clone.This item also has many color to choose. The atomizer on the image is for reference only, not included. ![]() YFTK Replacement Top Cap + Drip Tip Kit for M-Atty RDA Clone $49.99 The repalcement top cap and drip tip were made from Titanium and are suitable for M-Atty RDA Clone.This item also has many color to choose. The atomizer on the image is for reference only, not included. ![]() Original Leesok E-Juice Liquid for E-Cigarette $14.99 The Leesok E-juice Liquid comes with the tobacco flavor. It comes with 60ml e-juice, 3mg/ml nicotine content, 70% VG and 30% PG.This item also has many flavor to choose. ![]() Original Martiani Ice Watermelon E-Juice Liquid for E-Cigarette $12.99 The Martiani Ice Watermelon E-juice Liquid comes with the icy watermelon flavor. It comes with 30ml e-juice, 3mg/ml nicotine content, 75% VG and 25% PG.This item also has many flavor to choose. ![]() Original Bluefogcige Cynthia E-Juice Liquid for E-Cigarette $12.99 The Bluefogcige Cynthia E-juice Liquid comes with the pitaya flavor. It comes with 30ml e-juice, 3mg/ml nicotine content, 80% VG and 20% PG.This item also has many flavor to choose. ![]() Original Bluefogcige Cherry Coke E-Juice Liquid for E-Cigarette $14.99 The Bluefogcige Cherry Coke E-juice Liquid comes with the icy cherry coke flavor. It comes with 60ml e-juice, 3mg/ml nicotine content, 70% VG and 30% PG.This item also has many flavor to choose.
26
Original Aspire Cygnet 80W VW Variable Wattage Box Mod $35.00
The Original Aspire Cygnet mod is a versatile device that supports three modes, Variable Wattage (1~80W), Variable Voltage (0.5~8V), and Bypass. The Cygnet will fire at resistances between 0.1 and 3.5ohms. It is powered by a single high amp 18650 battery (not included). Coming with 0.86 inch OLED screen, it is easy to read vaping informations. There is a micro USB port for convenient charging.This item also has many color to choose. ![]() Original Steel Vape Sanctuary Mechanical Box Mod $39.99 The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product.The Original Steel Vape Sanctuary Box Mod is an unregulated device with Mosfet chip to make it safe when vaping. It is powered by dual 18650 batteries (not included) in parallel. The mod supports resistance at between 0.1 and 3ohms. The 510 connetor is spring loaded and there is no overhang with even 26mm atomizer.This item also has many color to choose. ![]() Original Steel Vape Tailspin RDTA Rebuildable Dripping Tank Atomizer $22.99 The Steel Vape Tailspin RDTA is a 25mm atomizer which can be used as either RDA or RTA. The deck features dual post design with two post holes at each post, side filling port for easy refilling, 6mm deep juice well, AFC drip tip cap to adjust side airflow. Resin and POM drip tip are included.This item also has many color to choose. ![]() Apocalypse Mechlyfe RDTA Rebuildable Dripping Tank Atomizer Clone $10.99 The Apocalypse Mechlyfe RDTA Clone is constructed from stainless steel in 24mm diameter, coming with 3.5ml juice capacity. It features a large build deck for easy coil building, with dual post design and oversized bridge clamp. The RDTA also features dual air slots on the sleeve and teardrop shape slots on the inner side of top cap for adjustable airflow. 810 wide bore resin drip tip included.This item also has many color to choose. ![]() Original Vapefly Mesh Plus RDTA Rebuildable Dripping Tank Atomizer Original Price $35.50,Now Only $22.99 The Original Vapefly Mesh Plus RDTA features stainless steel construction, 25mm diameter, 3.5ml e-juice capacity, easy side filling, and postless build deck for mesh wire, single coil or dual coil builds. There are 4 terminals with quad individual clamp, which make coil building much easier. The precise airflow system offers great flavor and eliminates leakage. 810 Delrin drip tip is included.This item also has many color to choose. This RDTA is Standard Edition with 3.5ml capacity. ![]() Original Steel Vape Tailspin Hybrid Mechanical Mod + RDTA Kit $35.99 The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product.The authentic Steel Vape Tailspin Kit consists of Tailspin Mod and Tailspin RDTA.This item also has many color to choose. Mod: The Steel Vape Tailspin Mod is a high quality mech mod that features replaceable aluminum and resin sleeve, hidden fire button with spring design, copper battery contact and can support 0.05ohm minimum atomizer resistance. It is powered by single 18650 battery (not included). RDTA: The Steel Vape Tailspin RDTA is a 25mm atomizer which can be used as either RDA or RTA. The deck features dual post design with two post holes at each post, side filling port for easy refilling, 6mm deep juice well, AFC drip tip cap to adjust side airflow. Resin and POM drip tip are included. ![]() LK Ni80 Pre-built Coil Heating Wire for RDA / RTA / RDTA $3.59 The LK Coils is made from Nichrome 80 wires and features 0.18 ohm (single). This pre-coiled heating wire comes with 26GA x 4 / 38 coils. This heating wire will be a good vaping choice for DIY.This item also has many rated parameter versions to choose. This product comes with 8 PCS in 1 pack. ![]() Display Base Stand for 15mm Tube Mod $2.99 This display base stand is made out of aluminum. It is suitable for 15mm diameter tube mod.This item also has many color to choose. The top diameter is 22mm, inner diameter is 15mm. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99 The 810 drip tip is made from resin with 14mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.This item also has many color to choose. This drip tip will be shipped by random color (one piece). More options than what's on the image. ![]() 810 Anti-Spit Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99 The 810 drip tip is made from resin with 12mm height. The honeycomb design at the base can prevent e-juice spit back. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.This item also has many color to choose.
27
Original Hcigar VT Inbox V3 75W TC VW Varible Wattage Box Mod $79.99
The Original Hcigar VT Inbox V3 75W TC VW Box Mod is powered by Evolv DNA75 chip from USA, making it easy to operate and the maximum output can reach to 75W. Using single high-rate 18650 battery, it can be charged directly via USB or replacing the battery to achieve duration. The USB port is not only for charging, but also for connecting to computer to customize through Escribe software. VT Inbox is also squonk-friendly with inner 8ml bottom feeder bottle.This item also has many color to choose. ![]() Original Dovpo Trigger 168W TC VW Variable Wattage Box Mod $39.99 The Original Dovpo Trigger Box Mod features 168W max output with dual 18650 batteries (not included), full temperature control suite, 0.96in OLED display and four-button control interface with an S (Set) button to easily access a drop down menu. With the high power output and ergonomic shape, Trigger is a good choice for your daily vaping.This item also has many color to choose. ![]() Original Coppervape BF V2 Squonk Mechanical Box Mod $20.99 The Coppervape BF V2 Squonk Box Mod is made from ABS 94V0 plastic, which is a high temperature resistant plastic, with soft feel rubber paint on it. Coming with silver plated contacts, the voltage drop is close to zero. The BF V2 Squonk Box Mod is powered by single 18650 battery (not included) and has built-in 10ml PET bottle. With spring-loaded 510 pin, the mod can be compatible with all BF RDA in the market.This item also has many color to choose. ![]() Coppervape Skyline Drop Kit with Drip Tip + Tank for Skyline RTA Clone $9.99 The Coppervape Skyline Drop Kit / Skydrop Kit (Style C) can match coppervape skyline RTA Clone perfectly. It is a short kit for standard tank, with 1.8ml juice capacity.This item also has many color to choose. The kit comes with black PC drip tip, transparent PC tank, 316SS top cap and chimney. ![]() Original Demon Killer Tiny RDA Rebuildable Dripping Atomizer $10.99 The Demon Killer Tiny RDA is a 14mm atty constructed from durable PEI cap and stainless steel base. The build deck comes with dual post design for single coil building. The cap has dual airslots for side airflow, giving you massive vapor and pure flavor.This item also has many color to choose. ![]() Original Coppervape Hippo RDA Rebuildable Dripping Atomizer with BF Pin $12.99 The Original Coppervape Hippo RDA is a 24mm atty constructed from 316 stainless steel. The build deck comes with dual post and is wide for easy building. There is a M5 (5mm diameter) screw on each post. With the biggest lock screws, you can lock any size of wire very well. The airflow is adjustable via the top cap. PEI drip tip is included.This item also has many color to choose. This RDA comes with bottom feeder pin. ![]() Original Vzone Simply Squonk Mechanical Box Mod + BF RDA Kit $39.99 The Original Vzone Simply Squonk Kit consists of Simply Squonk Mod and Simply BF RDA.This item also has many color to choose. Mod: The Original Vzone Simply Squonk Box Mod is a compact squonker that can support 18650, 20700, 21700 batteries (not included). It is made out of PC material. The bottle is capable of holding 5.5ml e-juice. And it comes with power safety lock to avoid any risk of mis-firing. RDA: The Simply Squonk RDA is a 24.5mm atty constructed from PEI (drip tip cap) and stainless steel (base). The build deck features dual post and quad terminal design for easy building. The cap comes with dual side airslots for smooth airflow and nice flavor. ![]() Original Demon Killer Tiny 800mAh Mod + RDA Kit $30.99 The Original Demon Killer Tiny Kit consists of Demon Killer Tiny Mod and Tiny RDA.This item also has many color to choose. Mod: The Demon Killer Tiny mod is a tiny and compact mod that features friendly LED screen, round type power button and the textured tiny size body and built-in 800mAh. This mod is Resin version. There may be a little color difference. RDA: The Demon Killer Tiny RDA is a 14mm atty constructed from durable PEI cap and stainless steel base. The build deck comes with dual post design for single coil building. The cap has dual airslots for side airflow, giving you massive vapor and pure flavor. ![]() Coppervape Replacement Tank Tube for Skyline Drop Kit / Skydrop Kit $1.69 The replacement glass tank tube is suitable for Coppervape Skyline Drop Kit / Skydrop Kit.This item also has many color to choose. ![]() Coppervape Replacement Drip Tip for Skyline RTA Clone / Skyline Drop Kit / Skydrop Kit $1.69 The replacement PC drip tip is 13mm in height. It is suitable for Coppervape Skyline Style RTA / Skyline Drop Kit / Skydrop Kit.This item also has many color to choose. ![]() Coppervape Replacement Half Tank Tube for Skyline Drop Kit / Skydrop Kit $2.59 The replacement PEI half tank tube is suitable for Coppervape Skyline Drop Kit / Skydrop Kit (Style A).This item also has many color to choose.
28
Original Hugo Vapor Delux 220W TC VW Variable Wattage Box Mod $48.99
The Original Hugo Vapor Delux 220W Box Mod adopts a 1.33 inch full color IPS screen in round shape, which shows 9 different user interfaces for different needs. The mod is made out of precisely CNC aluminum and stainless steel. With dual 18650 batteries (not included), the output can reach up to 220W. The 3-button control face allows easy operation. The stylish and powerful mod is a must-have in 2018.This item also has many color to choose. ![]() Original SMOKTech SMOK TFV12 Baby Prince Sub Ohm Tank Standard Edition $23.99 The Original SMOK TFV12 Baby Prince from SMOKTech is the upgraded version of TFV8 baby beast tank. Its included V8 baby-Q4 ,V8 baby-T12 red light coil and V8 Baby Mesh coil are compatible with baby beast coils. The new coils can produce denser clouds and purer flavor at the same wattage, which is an awesome improvement. These coils are newly designed, the light coil will emit beautiful light when you are vaping and the mesh coil has larger heating area to speed up heating process. Besides, this tank employs bulb glass tube, which can enlarge the e-juice capacity to 4.5ml. Every detail of TFV12 Baby Prince is the best guarantee for high-quality vaping.This item also has many color to choose. This tank is Standard Edition with 4.5ml capacity. ![]() Original Wotofo Bravo RTA Rebuildable Tank Atomizer $23.99 The Original Wotofo Bravo RTA is a 25mm tank with 4.5ml / 6ml (with bubble glass) big capacity to support a more convenient vaping life. It is the first RTA that adopts clamp post design, which is more appropriate for flat wires. The floating deck makes coil building easier and provides more space for juice. The cap comes with less threading, making it quicker to refill. The banked airflow design helps concentrate the airflow, giving you better flavor. Resin drip tip is included (random color).This item also has many color to choose. ![]() Original Omeka MSM C8 30W 650mAh Starter Kit $34.99 The Original Omeka MSM&C8 is a cool device that features round shape and stylish appearance, which is like the car key of C8 Preliator Spyder. It is constructed from food grade 316 stainless steel, which is well-polished. The built-in atomizer comes with electroplated brass core and Ni80 0.5ohm coil. The internal bottle utilizes food grade PC plastic material. It is powered by 650mAh aluminum cell and the output is 30W. It is a tiny and portable starter kit for you to vape at anywhere and anytime.This item also has many color to choose. ![]() Original SMOKTech SMOK V8 Baby-Q4 Quadruple Coil for TFV12 Baby Prince Tank $12.99 The SMOK V8 Baby-Q4 coil head is suitable for SMOK TFV12 Baby Prince tank atomizer. The V8 Baby-Q4 core features 0.4 ohm resistance which supports 30~65W power output (best 50~60W). This coil head will bring you denser vapor and purer flavor. This product comes with 5 PCS in 1 pack. ![]() Original SMOKTech SMOK V8 Baby Mesh Coil for TFV12 Baby Prince Tank $12.99 The SMOK V8 Baby Mesh coil head is suitable for SMOK TFV12 Baby Prince tank atomizer. The V8 Baby-Mesh core features fast heating process and 0.15 ohm resistance which supports 40~80W power output (best 60~70W). This coil head will bring you massive vapor. This product comes with 5 PCS in 1 pack. ![]() Original SMOKTech SMOK V8 Baby-T12 Duodecuple Coil for TFV12 Baby Prince Tank $12.99 The SMOK V8 Baby-T12 coil head is suitable for SMOK TFV12 Baby Prince tank atomizer. The V8 Baby-T12 core features 0.15 ohm resistance which supports 50~90W power output (best 60~80W). This coil head will bring you massive vapor and purer flavor.This item also has many color to choose. This product comes with 5 PCS in 1 pack. ![]() Original Oumier Replacement Top Cap for Wasp Nano Mini RDA $3.59 The replacement top cap is made out of PC and is suitable for authentic Oumier Wasp Nano Mini RDA.This item also has many color to choose. ![]() Original Coil Father Liquid Dispenser for Squonk Mod / RDA / RTA $10.99 The Original Coil Father Liquid Dispenser is a versatile liquid dispenser that can be used to fill squonker mods or as a dripping / filling bottle for RDA / RTA. It is made out of aluminum and uses removable food grade PET internal bottle. The juice capacity is 30ml.This item also has many color to choose.
29
Original Sigelei Snowwolf Vfeng Squonk 120W TC VW Box Mod + BF RDA Kit $79.99
The Original SnowWolf Vfeng Squonk BF Kit consists of SnowWolf Vfeng Squonk Mod and SnowWolf Vfeng Squonk RDA. The SnowWolf Vfeng Squonk Box Mod is the first squonk mod from Sigelei Snowwolf. Vfeng Squonk Mod features dual bottom feeder bottle, each for 3ml capacity, totally 6ml; and is compatible with 18650 (need adapter) / 20700 / 21700 batteries (not included), which allows this mod to provide maximum output to 120W. This mod allows you to build as low as 0.05ohm in temperature control mode and 0.1ohm in power mode.This item also has many color to choose. ![]() Original VBS Iron Surface Squonk Mechanical Box Mod $26.99 The Original VBS Iron Surface squonk box mod is constructed from colorful resin. It comes with removable built-in silicone bottle for squonking, which holds about 7ml of e-juice. It is powered by a single 18650 or 20700 battery (not included). The mod has locking mechanism in the fire button to avoid mis-firing.This item also has many color to choose. ![]() Original Vandy Vape Kylin Mini RTA Rebuildable Tank Atomizer $39.99 The Original Vandy Vape Kylin Mini RTA is an updated version of Kylin RTA. It is a 24.4mm tank with innovative build deck that allows single coil building and simple stress free wicking. Kylin Mini RTA comes with condensed chamber section to concentrate vapor for pure flavor. The 180 degrees honey comb airflow design provides super smooth vapor.This item also has many color to choose.This item also has many color to choose. ![]() SXK Radius V2 RDA Rebuildable Dripping Atomizer Clone with BF Pin $16.90 The SXK Radius V2 Style RDA is constructed from 316 stainless steel. It features dual post single coil build deck, adjustable side airflow and squonk-ready. The RDA is tend to deliver pure flavor. ![]() Original VBS Iron Surface Squonk Mechanical Box Mod + Vivid RDA Kit $34.99 The VBS Iron Surface Squonk Kit consists of VBS Iron Surface Squonk Box Mod and VBS Vivid RDA.This item also has many color and patterns to choose. Mod: The Original VBS Iron Surface squonk box mod is constructed from high quality aviation aluminum alloy. It comes with removable built-in silicone bottle for squonking, which holds about 7ml of e-juice. It is powered by a single 18650 or 20700 battery (not included). The mod has locking mechanism in the fire button to avoid mis-firing. RDA: The Original VBS Vivid RDA is a 24mm rebuildable atty with squonk feature. It features smooth side airflow and colorful chuff cap. It perfectly matches the VBS Iron Surface squonk box mod.
30
Original HCigar Warwolf 80W TC VW Variable Wattage Box Mod $54.99
The Hcigar Warwolf 80W Box Mod is a compact and versatile device with ergonomic design and stylish appearance. It adopts XT80C chipset and is powered by single 18650 battery (not included), which allows it to output at between 5W and 80W. Warwolf also supports full temperature control suite, including Ni200, titanium and stainless steel. Coming with 4-button control face, which has a menu button, it is easier to operate. The micro USB port supports 2A charging and firmware upgrading.This item also has many color to choose. ![]() Original Sigelei Vcigo Moon Box 200W Box Mod $29.99 The brand new Sigelei Vcigo Moon Box mod is very stylish with artistic pattern on the body. The plastic body feels smooth and is wrapped with tinplate. The Moon box is powered by 2 x 18650 batteries (not included) and is capable of outputting 200W of raw power.This item also has many color to choose. ![]() KF 5.2 RTA Rebuildable Tank Atomizer Clone $18.99 The KF 5.2 RTA Clone is a 25mm tank constructed from 316 stainless steel. It features top filling design, maximum 7ml e-juice capacity, dual post deck for single coil building, e-liquid flow control function and adjustable bottom airflow. It will definitely bring you great vaping experience.This item also has many color to choose. ![]() Original Sigelei Vcigo Moon Box 200W Box Mod + Sig-S RDA Kit $32.99 The Original Sigelei Vcigo Moon Box mod kit consists of Vcigo Moon Box 200W mod and Sig-S RDA.This item also has many color to choose. Mod: The brand new Sigelei Vcigo Moon Box mod is very stylish with artistic pattern on the body. The plastic body feels smooth and is wrapped with tinplate. The Moon box is powered by 2 x 18650 batteries (not included) and is capable of outputting 200W of raw power. RDA: The Sigelei Sig S RDA is a 22mm atty with superior build and quality. The build deck comes with triple post design, leaving plenty of space for coils and wicks. The side airflow hitting directly on the coil provides smooth and massive vapor and nice fla ![]() Original Sigelei Vcigo A7 3000mAh Starter Kit $33.99 The Original Sigelei Vcigo A7 Kit is a convenient starter kit that is easy to use. With built-in 3000mAh battery, this kit provides full output for vaping and is safe enough due to its multiple protections. The tank comes with 2ml juice capacity. No matter what kind of vaper you are, professional or amateur, Vcigo A7 Kit is suitable for you.This item also has many color to choose. ![]() Original Demon Killer Raging Fire Coil D Ni80 Heating Wire $2.59 The Original Demon Killer Raging Fire Coil D is made from Ni80 wires and features 0.27 ohm. This pre-coiled heating wire comes with (0.1 x 0.3) x 6 x 0.1 + (0.1 x 10) coils. This heating wire will be a good vaping choice for DIY.This item also has many color to choose. This product comes with 4 PCS in 1 pack.
31
Original Uwell Nunchaku 80W TC VW Variable Wattage Mod $47.99
The Original Uwell Nunchaku Mod, equipped with Uwell's new self-developed control panel, is a versatile tube mod as safe box mod. It is ergonomically designed and pocket-size for easy carry. Powered by a single 18650 battery (not included), Nunchaku is capable of outputting at between 5W and 80W. The mod comes with multiple modes to choose: power mode, TC mode (NI, SS) and bypass mode. Nunchaku should satisfy you with its stylish look and high performance.This item also has many color to choose. ![]() Original Uwell Nunchaku Sub Ohm Tank Clearomizer $22.99 The Original Uwell Nunchaku Tank is a 25mm sub ohm tank with large juice capacity up to 5ml. It adopts the unique flavor testing technology from UWELL, which perfects the flavor profile. It features large clouds with low wattage, power-saving and juice efficient. The coil is plug-pull style, which is easy to replace. Nunchaku Tank is compatible with Claptonized A1 0.25ohm coil (40~50W ) and 0.4ohm coil (45~55W).This item also has many color to choose. ![]() Lost Art Goon 1.5 RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Lost Art Goon 1.5 RDA Clone is constructed from stainless steel in 24mm diameter. It features bridge clamp design for easy building and middle side adjustable air slots for airflow control.This item also has many color to choose. This RDA comes with bottom feeder pin. ![]() Original Godria Bolt RTA Rebuildable Tank Atomizer Original Price $39.99,Now Only $20.99 Godria innovatively utilized Goon style deck on a tank, the Godria Bolt RTA, which is a 24mm rebuildable tank with 2ml capacity. The whole deck and positive pin are gold plated and the screws are spring loaded, which means building coils is as easy as you can imagine. The precision airflow goes from the bottom to the coil directly. 510 resin drip tip is included.This item also has many color to choose. ![]() Original Uwell Nunchaku 80W TC VW Variable Wattage Mod + Tank Starter Kit $59.99 The Original Uwell Nunchaku Starter Kit consists of Uwell Nunchaku Mod and Nunchaku Tank.This item also has many color to choose. Mod: The Original Uwell Nunchaku Mod, equipped with Uwell's new self-developed control panel, is a versatile tube mod as safe box mod. It is ergonomically designed and pocket-size for easy carry. Powered by a single 18650 battery (not included), Nunchaku is capable of outputting at between 5W and 80W. The mod comes with multiple modes to choose: power mode, TC mode (NI, SS) and bypass mode. Nunchaku should satisfy you with its stylish look and high performance. Tank: The Original Uwell Nunchaku Tank is a 25mm sub ohm tank with large juice capacity up to 5ml. It adopts the unique flavor testing technology from UWELL, which perfects the flavor profile. It features large clouds with low wattage, power-saving and juice efficient. The coil is plug-pull style, which is easy to replace. Nunchaku Tank is compatible with Claptonized A1 0.25ohm coil (40~50W ) and 0.4ohm coil (45~55W). ![]() Original Uwell Replacement Claptonized A1 Coil for Nunchaku Sub Ohm Tank $12.99 The Original Uwell Claptonized A1 Coil features 0.25ohm resistance and work well at between 40W and 50W. It is suitable for authentic Uwell Nunchaku tank / Nunchaku Starter Kit.This item also has a 0.40ohm version to choose. This product comes with 4 PCS in 1 pack. ![]() Kindbright Nato Mechanical Mod Clone $22.99 The Kindbright Nato Mechanical Mod Clone is a 25mm tube mod with non-hybrid top cap. It is constructed from stainless steel. The fire button comes with unique design, which is solid marble that gives you great feedback. The switch is spring loaded. The mech mod is compatible with a single 18650 / 20650 / 20700 / 21700 battery (not included).This item also has many color to choose. ![]() YFTK FL RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.99 The YFTK FL RDA Clone is constructed from 316 stainless steel in 24mm diameter. It features dual post deck for single coil and middle side adjustable airflow. The deck has notches for easy installation of the coil. Insulation material helps this RDA to avoid any leaking of e-juice. The RDA comes with wide bore drip tip.This item also has many color to choose. This RDA comes with bottom feeder pin. Please note: the logo on the RDA is wiped. ![]() Original Hugo Vapor Squeezer BF Squonk Box Mod + N RDA Kit $32.79 The Original Hugo Vapor Squeezer BF Kit consists of Squeezer BF Squonk Mod and N RDA.This item also has many color to choose. Mod: The Original Hugo Squeezer BF Squonk Mod is a handy squonker that comes with 10ml built-in silicone bottle. The Squeezer consists of Nylonfibre shell, gold plated 510 connector and special copper contacts. It is convenient to use without refilling frequently. The mod is powered by a single 20700 / 18650 (18650 adapter needed, batteries not included). RDA: The N RDA is a BF RDA with 25mm diameter and adjustable side airflow. It can work well with not only the Hugo Squeezer BF Squonk Mod, but also other squonk mods on the market. The RDA comes with ultem wide bore drip tip. The RDA comes with bottom feeder pin.
32
Original Wismec Luxotic 100W Squonk Box Mod $37.99
The Wismec Luxotic BF Box Mod, designed by JayBo, features its reimagined squonk system and inbuilt refillable e-liquid bottle of 7.5ml capacity. Powered by single 18650 battery (not included), Luxotic can reach maximum output to 100W. The large capacity squonk bottle allows you to vape with ease without refilling frequently. The cover panel is replaceable, making it different whenever you like.This item also has many color to choose. ![]() Original Fumytech Rose MTL RTA Rebuildable Tank Atomizer $29.99 The Original Fumytech Rose MTL RTA, designed for mouth-to-lung vaping, is a 24mm tank with 3.5ml juice capacity. It features threaded top filling, dual post build deck, and fully adjustable bottom airflow, with totally 8 airholes for configuration. With the domed chamber and 3mm bore POM drip tip, this tank will bring you smooth vapor and pure flavor.This item also has many color to choose. ![]() Original GAS Mods ***** V1.0 RDTA Rebuildable Dripping Tank Atomizer w/ BF Pin Original Price $24.99,Now Only $20.99 Please log in to see the lower price. The Original GAS Mods ***** V1.0 RDTA is a mini size RDTA and features invisible airslots. The airslots will appear once you rotate the top cap clockwise and the airflow can be adjusted in this way. The deck features dual post for single coil build. The tank comes with 510 POM drip tip. The ***** V1.0 comes with smaller vapor amount than ***** V1.5. It will bring you mouth-to-lung vaping experience. Please Note: The RDTA supports airflow via screw up the top cap. And please be careful because the top cap is reverse threading. Please Note: The ***** V1.0 RDTA comes with BF pin (pre-installed).This item also has many color to choose. Series number is wiped on the image. [img]http://www.3fvape.com/185543-home_default/authentic-gas-mods-*****-v10-rdta-rebuildable-dripping-tank-atomizer-w-bf-pin-silver-stainless-steel-2ml-22mm-diameter.jpg[/img] Original Wismec Luxotic 100W Squonk Box Mod + Tobhino BF RDA Kit $47.99 The Original Wismec Luxotic BF Kit consists of Luxotic BF Box Mod and Tobhino BF RDA.This item also has many color to choose. Mod: The Wismec Luxotic BF Box Mod, designed by JayBo, features its reimagined squonk system and inbuilt refillable e-liquid bottle of 7.5ml capacity. Powered by single 18650 battery (not included), Luxotic can reach maximum output to 100W. The large capacity squonk bottle allows you to vape with ease without refilling frequently. The cover panel is replaceable, making it different whenever you like. RDA: The Wismec Tobhino BF RDA is a 22mm atty that features open build place and adjustable side airflow. You can even build a fancy coil in this tiny RDA. It comes with decorative ring for not only decoration, but also heat insulation. With optional top cap, Tobhino is compatible with both 510 and 810 drip tips. ![]() Original Bluefogcige Lychee Raspberry E-Juice Liquid for E-Cigarette $14.99 The Bluefogcige Lychee Raspberry E-juice Liquid comes with a flavor of mixture of lychee and raspberry. It comes with 60ml e-juice, 3mg/ml nicotine content, 70% VG and 30% PG.This item also has many flavor to choose.
33
Original GeekVape Athena Squonk Mechanical Box Mod $49.99
The Athena Squonk Box Mod features 6.5ml squonk bottle, 510 BF connection, oversized fire button and flip style magnetic battery cover. Athena Mod comes with a safety lock switch to prevent accidental firing, induction made out of high grade material for maximum power output. It is powered by 1 x 18650 battery (not included). Athena was designed to be compact, lightweight and powerful.This item also has many color to choose. The mod comes with 1 pre-installed squonk bottle and 1 spare squonk bottle. ![]() Lost Art Goon V1.5 RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.59 The Lost Art Goon V1.5 RDA Clone is constructed from aluminum (drip tip, cap) and stainless steel (base) in 24mm diameter. It features bridge clamp design for easy building and middle side adjustable air slots for airflow control.This item also has many color to choose. This RDA comes with bottom feeder pin. One piece will be shipped. Other colors on the image for reference only. ![]() Original OBS Crius II RTA Rebuildable Tank Atomizer Dual Coil Version $39.90 The Original OBS Crius II RTA Dual Coil Version is a 25mm tank with 4ml capacity, which has almost the same design as Crius II RTA, but it is different as dual coil can be built on this RTA now. The post is positioned in the middle of the deck, and still adopts high-tech Zirconia piece, which is the best heat resistant material. OBS Crius II RTA Dual Coil Version can provide you more intense flavor and massive vapor production.This item also has many color to choose. ![]() Original GeekVape Athena Squonk RDA Rebuildable Dripping Atomizer with BF Pin $29.99 The Original Athena Squonk RDA is a 24mm diameter atty that features gold plated postless deck for single or dual coil build, top angled airflow and bottom feeder pin for squonking. It is leakproof while producing outstanding flavor. The RDA is compatible with both 810 and 510 drip tips. This RDA comes with bottom feeder pin for squonking.This item also has many color to choose. ![]() Original Tesla CP Couples 220W TC VW Variable Wattage Box Mod + RDTA Kit $69.99 The Original Tesla CP Couples 220W Kit consists of CP Couples Mod and dual CP Couples RDTAs. The Tesla CP Couples 220W Kit is an updated version of Biturbo kit. It allows you to enjoy two kinds of flavor on one device at the same time, and the output wattage for dual RDTAs can be adjusted separately. Powered by dual 18650 batteries (not included), the mod can deliver power up to 110W (single RDTA) / 220W (dual RDTA). This kit will definitely gives great fun for cloud chasers.This item also has many color to choose. ![]() Original GeekVape Athena Squonk Mechanical Box Mod + BF RDA Squonker Kit $69.99 The Original Geekvape Athena Squonker Kit consists of Athena Squonk Box Mod and Athena BF RDA.This item also has many color to choose. Mod: The Athena Squonk Box Mod features 6.5ml squonk bottle, 510 BF connection, oversized fire button and flip style magnetic battery cover. Athena Mod comes with a safety lock switch to prevent accidental firing, induction made out of high grade material for maximum power output. It is powered by 1 x 18650 battery (not included). RDA: The Athena BF RDA is a 24mm diameter atty that features gold plated postless deck for single or dual coil build, top angled airflow and bottom feeder pin for squonking. It is leakproof while producing outstanding flavor. The RDA is compatible with both 810 and 510 drip tips. The mod comes with 1 pre-installed squonk bottle and 1 spare squonk bottle. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.59 The 810 drip tip is made from resin with 14mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This drip tip can glow in the dark. Please note: there may be a little color difference. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA - Random Color $2.99 The 810 drip tip is made from resin with 14mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This drip tip will be shipped by random color. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.59 The 810 drip tip is made from carbon fiber and POM with 22mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.This item also has many color to choose. One piece will be shipped. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank $2.99 The replacement 510 drip tip is made from Epoxy resin with 26mm height. It is suitable for all atomizers that fit 510 drip tip. Please note: there may be a little color difference due to Epoxy resin material.This item also has many color to choose. One piece will be shipped. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank $2.99 The replacement 510 drip tip is made from Epoxy resin with 22.7mm height. It is suitable for all atomizers that fit 510 drip tip. Please note: there may be a little color difference due to Epoxy resin material.This item also has many color to choose. One piece will be shipped.
34
Original Arctic Dolphin Crea RDA Rebuildable Dripping Atomizer with BF Pin $10.99
The Original Arctic Dolphin Crea BF RDA is a 22mm atty constructed from POM (cap) and stainless steel (base). The build deck features dual post design for single coil, deep juice well, and gold plated contact pin. The cap has two airslots on both sides for smooth vapor and pure flavor. This RDA comes with bottom feeder pin.This item also has many color to choose. ![]() Kindbright Le Supersonic RDA Rebuildable Dripping Atomizer Clone with BF Pin $12.99 The Kindbright Le Supersonic BF RDA Clone is constructed from 316 stainless steel in 24mm diameter. The build deck is wide and comes with dual post for single or dual coil building. The airflow is adjustable with the airslots on the cap, and there are three airholes on each side for your favorite configuration.This item also has many color to choose. This RDA comes with bottom feeder pin. ![]() Carnage RDA Rebuildable Dripping Atomizer Clone with BF Pin $10.59 The Carnage RDA Clone is constructed from 316 stainless steel in 25mm diameter. The build deck features dual post design, and the posts are not the same style. The negative post utilizes flathead grub screw, while the positive post adopts clamp design with dual flathead heads. The internal cap comes with single-hole airslot and triple-hole airslot, which allows you to adjust the configuration to your favorite one. This RDA comes with bottom feeder pin.This item also has many color to choose. Please note: other colors on the image for reference only. ![]() Original Innokin PocketBox 40W 1200mAh All-in-One Starter Kit $34.99 The Original Innokin PocketBox is an ultra compact and lightweight AIO vaporizer that easily fits in the palm of your hand. It features maximum 40W output, 0.02s super fast firing speed, grip-textured rubber diamond button, adjustable airflow and 2ml glass tank. Powered by 1200mAh inbuilt battery, the PockBox can be charged via micro USB port. Coming with DTL 0.35ohm and MTL 1.2ohm coils, PocketBox kit is great for both DTL and MTL vaping, bringing you amazing flavor and clouds.This item also has many color to choose. ![]() SXK Replacement Top Cap + Drip Tip Kit for Radius V2 RDA Clone $4.99 The replacement top cap and drip tip are made from PEI. They are suitable for SXK Radius V2 RDA Clone. One piece will be shipped.
35
Original Smoant Ranker 218W TC VW Variable Wattage Box Mod Original Price $67.60,Now Only $45.99
Please log in to see the lower price. The Original Smoant Ranker Mod utilizes the updated chip Ant218 V2 with a faster response when firing, which is in only 0.015 second. Powered by dual 18650 batteries (not included), Ranker can reach its maximum wattage to 218W. The minimum atomizer resistance allowed is 0.1ohm in VW mode and 0.05ohm in TC mode. Ranker also comes with curve mode for both VW and TC, which allows you to set the wattage or temperature at intervals for the first 10 seconds, bringing you a customized vaping experience.This item also has many color to choose. ![]() Original GeekVape Blade 235W TC VW Variable Wattage Box Mod Original Price $53.90,Now Only $38.99 Please log in to see the lower price. The GeekVape Blade Mod, which maximizes the use of dual 18650, 20700 and 21700 batteries (series, not included) and the maximum power can reach 235W, is a versatile device with high performance. Utilizing advanced aircraft grade material, it is very light and durable. ![]() AV Gyre Slow Twist Hybrid Mechanical Mod Clone $21.99 The AV Gyre Slow Twist Hybrid Mechanical Mod Clone is constructed from brass in 24mm diameter. The hybrid cap allows more aggressive raw power for massive clouds. The tube comes with Slow Twist style machined body, which is stylish and better to grip. The fire button is magnetic. Powered by single 18650 battery (not included).This item also has many color to choose. The logo is engraved. Other colors on the image for reference only. ![]() Dodge Ram Mechanical Box Mod Clone $20.99 The Dodge Ram Mechanical Box Mod Clone looks like a BF squonk mod but exactly not so. It is powered by dual 18650 batteries (not included) in parallel. The mod is constructed from brass and POM. Aesthetic elements can be found on this mod, like the Aries pattern, the emblems on both sides. The body is ergonomically designed for better hand feel. Coming with several venting slots, it is great for cooling down your batteries. Other colors on the image for reference only.This item also has many color to choose. ![]() Original GeekVape Blade 235W TC VW Variable Wattage Box Mod + Aero Tank Kit Original Price $67.90,Now Only $47.99 The Original GeekVape Blade Mod Kit consists of GeekVape Blade Mod and Aero Sub Ohm Tank. Mod: The GeekVape Blade Mod, which maximizes the use of dual 18650, 20700 and 21700 batteries (series, not included) and the maximum power can reach 235W, is a versatile device with high performance. Utilizing advanced aircraft grade material, it is very light and durable. Tank: The GeekVape Aero Sub Ohm Tank is a 25mm tank features convenient top filling and adjustable bottom airflow. It utilizes IM1 0.4ohm coil, which work well at between 40W and 60W, bringing you pure flavor and massive clouds.
36
Original Lost Vape Modefined Lyra 200W TC VW Variable Wattage Box Mod $59.00
The Original Lost Vape Modefined Lyra Mod, a compact and high-performance device, features 200W maximum output, full temperature control suite, 1.3inch large color screen, and ergonomic design. Modefined Lyra is powered by dual 18650 batteries (not included).This item also has many color to choose. ![]() Original GAS Mods G.R.1 GR1 RDA Rebuildable Dripping Atomizer with BF Pin $39.99 The Original GAS Mods GR1 RDA is a 22mm atty that features single coil build deck, replaceable airflow control accessories and squonk-ready. The airflow control accessories comes with two different sizes of airholes, one is 2mm by 2mm each side, the other is 2mm by 5mm each side. The most recommended angle is 45 degrees, giving you the best flavor. This RDA comes with bottom feeder pin. ![]() Original Sigelei TOP 1 230W TC VW Variable Wattage Box Mod Kit $89.99 The Original Sigelei TOP 1 Box Mod Kit features ergonomic design and stylish dashboard interface. Powered by dual 18650 batteries (not included), Top 1 is capable of delivering power up to 230W. The temperature mode supports SS316 / SS317 / NI200 / Ti1 / TCR. The atomizer resistance range is from 0.05 to 3.0ohm. Together with the atomizer, the Top 1 Kit will bring you excellent vaping experience.This item also has many color to choose. ![]() Original Sigelei Snowwolf Xfeng 230W TC VW Variable Wattage Box Mod Kit $79.99 The Original Sigelei Snowwolf Xfeng 230W Box Mod Kit features persistence of the vigorous design, representing the wolf temperament. The stylish front and back panel reflects the Zodiac constellation. Powered by dual 18650 batteries (not included), the Xfeng is capable of delivering power up to 230W. Temperature control mode supports SS / Ti1 / Ni200 / TCR modes. The mod supports atomizer resistance from 0.05 to 3.0ohm. Together with the atomizer, the Xfeng 230W Kit will bring you excellent vaping experience.This item also has many color to choose. ![]() Original Innokin EZ.WATT 35W 1500mAh Mod + Prism T20S Tank Kit $32.89 The Original Innokin EZ.WATT Starter Kit consists of EZ.WATT Mod and Prism T20S Tank.This item also has many color to choose. Mod: The Innokin EZ.WATT Mod is a premium quality device that features easy operation and compact size. The EZ.WATT is powered by built-in 1500mAh battery. There is LED indictor to show the current wattage level (13~14 / 15~18 / 30~35). With EZ.WATT Mod, you can enjoy both MTL and DTL vaping. Tank: The Innokin Prism T20S Tank is a 20mm atomizer with 2ml juice capacity. It features convenient top filling and bottom airflow. The tank utilizes Prism S coil for optimal flavor, one 0.8ohm coil pre-installed and one spare 1.5ohm coil. ![]() Original Innokin Prism S Replacement Coil for Prism T20S Tank $9.79 The replacement Prism S coil features 1.5ohm resistance and work well at between 13W and 14W. It is sutiable for authentic Innokin EZ.WATT Kit / Prism T20S tank atomizer. This product comes with 5 PCS in 1 pack. ![]() Original SMOKTech SMOK Replacement Bulb Pyrex Glass Tube $2.99 The replacement Bulb Pyrex Glass Tube #3 from SMOKTech is capable of holding 6ml of e-juice. It is suitable for SMOK TFV8 X-Baby Tank (standard edition only).This item also has a 5ml and 7ml version to choose. One piece will be shipped. ![]() Original Vapefly Replacement SS316 Mesh Coil for Mesh Plus RDA / Mesh Plus RDTA $5.99 The replacement SS316 mesh coil features 0.12~0.18ohm resistance and work well at between 50W and 70W. It is sutiable for authentic Vapefly Mesh Plus RDA / Mesh Plus RDTA. This product comes with 15 PCS in 1 pack.
37
Original Timesvape Dreamer Hybrid Mechanical Mod Original Price $90.00,Now Only $44.99
Please log in to see the lower price. Designed by Stan (USA), manufactured by Timesvape, the Original Timesvape Dreamer Mod is a fantastic mech mod that is compatible with single 18650 / 20700 / 21700 battery (not included). The innovative multipoint contact pin increases conductivity. It also features reversible tube for customizable grip, floating battery adjustment and hybrid 510 connection. Dreamer is a cloud chaser's dream mod.This item also has many color to choose. 18650 battery adapter included. ![]() Original GeekVape Aero Sub Ohm Tank Clearomizer Original Price $28.90,Now Only $17.99 Please log in to see the lower price. The GeekVape Aero Sub Ohm Tank is a 25mm tank features convenient top filling, 4ml juice capacity and adjustable bottom airflow. It utilizes IM1 0.4ohm coil, which work well at between 40W and 60W, bringing you pure flavor and massive clouds.This item also has many color to choose. ![]() Original Digiflavor Themis RTA Rebuildable Tank Atomizer Dual Coil Version Original Price $35.90,Now Only $23.99 Inspired by GeekVape Zeus, the Original Digiflavor Themis RTA is a leak-proof RTA with innovative airflow transferring from top to bottom providing outstanding flavor. Themis is available with two versions: Dual Coil Version and Mesh Version. The quick access top cap makes refilling easy. The tank is capable of holding 5ml e-juice.This item also has many color to choose. This one is Dual Coil Version, with build deck for single & dual coil. ![]() Original Joyetech eGo AIO ECO 650mAh Starter Kit $12.99 Stylish and discrete the eGo AIO ECO is a great all-in-one stealth e-cig not just for starters but for everyone. This new EGO AIO is incredibly simple and convenient to use and now with ECO technology. ECO Tech still provides the best vaping experience but allows the battery to have a very low output. this extends the battery life by almost double. The newly added BFHN 0.5ohm coil head is now optimized for use with high nicotine e-liquids. Considering it comes with an illuminated 7 color LED tank, multiple colorway options and a 1.2ml integrated tank, makes the eGo AIO ECO an ideal all-in-one kit for everyone.This item also has many color to choose. ![]() Original SMOKTech SMOK Replacement Bulb Pyrex Glass Tube $6.99 The replacement Bulb Pyrex Glass Tube #4 from SMOKTech is capable of holding 5ml of e-juice. It is suitable for TFV8 Baby Tank (standard edition only), TFV8 Baby Tank Carbon Fiber Edition (standard edition only), Brit Mini Flavor Tank.This item also has many a 6ml and 7ml version to choose. This product comes with 3 PCS in 1 pack. ![]() Coppervape Replacement Half Tank Tube for Skyline Drop Kit / Skydrop Kit $1.69 The replacement PC half tank tube is suitable for Coppervape Skyline Drop Kit / Skydrop Kit (Style A) and Skyline Drop kit Semi Tank (316SS + PC). ![]() Coppervape Replacement Semi Tank Tube for Skyline Drop Kit / Skydrop Kit $2.99 The replacement 316SS + PC Semi tank tube is suitable for Coppervape Skyline Drop Kit / Skydrop Kit (Style A / B / C).
38
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Uwell Ironfist 200W TC VW Variable Wattage Box Mod $42.99
The Original Uwell Ironfist Mod is a versatile device with high performance and ergonomic designs. Powered by dual 18650 batteries (not included), Ironfist is capable of outputting to 200W. The exclusive single switch design makes operation easier. There is no need to click the fire button for 5 times. Ergonomic design and wrapped in leather, makes it feel more comfortable in the hand. Ironfist provides multiple types of protection to safeguard against potential risk.This item also has many color to choose. ![]() Original Digiflavor Themis RTA Rebuildable Tank Atomizer Mesh Version Original Price $41.90,Now only $26.99 Inspired by GeekVape Zeus, the Original Digiflavor Themis RTA is a leak-proof RTA with innovative airflow transferring from top to bottom providing outstanding flavor. Themis is available with two versions: Dual Coil Version and Mesh Version. The quick access top cap makes refilling easy. The tank is capable of holding 5ml e-juice.This item also has many color to choose. This one is Mesh Version, with build deck for mesh wires. ![]() Original Dovpo Bushido Plus RDTA Rebuildable Dripping Tank Atomizer $6.99 The Original Dovpo Bushido Plus RDTA is a 24mm tank with 2ml e-juice capacity. The build deck features dual post design and oversized knurled thumb screws for dual coil builds. The airflow hits the coil via the redirected airslots at bottom. This RDTA comes with drip tip in random color. ![]() Original Uwell Fancier RTA / RDA Rebuildable Dripping Tank Atomizer $26.99 The Original Uwell Fancier RTA / RDA is a 24mm tank with 4ml capacity. Fancier allows you to enjoy the amazing experience of both RDA and RTA. When using it as RDA, the cross plate above the coil can be used as a safeguard to prevent spitback. Fancier allows you to observe the performance of your coils and cotton. Four adjustable bottom airflow holes to customize your vaping experience to your own preference.This item also has many color to choose. ![]() Original Hengling Qtank Sub Ohm Tank Clearomizer $29.99 The Original Hengling Qtank is an unique subohm tank that utilizes two coils and you can taste two different flavors at the same time. By a simple gyration, you can switch one flavor to the other one. With the optimal cooling system design on drip tip and sub-ohm coil, Hengling Qtank provides the purer taste and the huge vapor.This item also has many color to choose. ![]() Original Uwell Ironfist 200W TC VW Variable Wattage Box Mod + Crown III Tank Kit $60.99 The Original Uwell Ironfist Kit consists of Uwell Ironfist Mod and Crown 3 Tank.This item also has many color to choose. Mod: The Original Uwell Ironfist Mod is a versatile device with high performance and ergonomic designs. Powered by dual 18650 batteries (not included), Ironfist is capable of outputting to 200W. The exclusive single switch design makes operation easier. There is no need to click the fire button for 5 times. Ergonomic design and wrapped in leather, makes it feel more comfortable in the hand. Ironfist provides multiple types of protection to safeguard against potential risk. Tank: The Original Uwell Crown 3 III Sub Ohm Tank Clearomizer is the modernized rendition of the trendsetting Crown series, elevating the sub-ohm segment with top-tier chassis design featuring 5ml juice capacity, threaded top-fill, and introducing the innovative plug-pull Crown III replacement coils. An improvement in chimney and structural design greatly reduces the amount of e-juice condensation, which diminishes leakage potential. Following in trends with modern power delivery, the 0.25 ohm Crown III SUS316 parallel coil features a wattage range of 80 to 90W, with a 0.5 ohm rated for 70 to 80W. Airflow for the Crown III is arranged in dual air slots configuration around the base of the chassis, providing ample cooling properties throughout the structure. Heralding the newest generation of Crown atomizers, the Uwell Crown III Sub Ohm Tank heralds a class-leading flagship platform.
39
Original Coil Father Squonk Mini Mechanical Box Mod $9.99
The Original Coil Father Squonk Mini Mod is portable and made out of Nylon material. It features an 8ml silicone bottom feeder bottle for squonking. The mod comes with adjustable 510 pin, flip style battery access door and brass contact for better conductivity. The mod is powered by single 18650 battery (not included).This item also has many color to choose. ![]() Original DEJAVU RDA Rebuildable Dripping Atomizer with BF Pin $46.99 The Original DEJAVU RDA is a 25mm atty with innovative build deck for dual coil builds. The dual post with quad terminal design makes coil building much easier. The airflow system consists of adjustable side airflow and unique 4-tube bottom airflow. The juice well is deep enough to store more e-liquid.This item also has many color to choose. This RDA comes with bottom feeder pin. ![]() Original Sigelei Vcigo K3 150W TC VW Variable Wattage Box Mod + Tank Kit $56.99 The Original Sigelei Vcigo K3 Kit consists of Vcigo K3 Mod and Vcigo K3 Tank.This item also has many color to choose. Mod: The Original Sigelei Vcigo K3 Mod is a high-performance regulated device with sleek appearance. Powered by dual 18650 batteries (not included), Vcigo K3 is capable of outputting to maximum 150W. It also supports 2.5A quick charging. The atomizer resistance supported is from 0.05 to 3 ohm. Tank: The Vcigo K3 tank is a 24.5mm subohm tank with 2ml e-juice capacity. It features convenient top filling and adjustable bottom airflow. The tank supports these coils: SM2-H, SM2, SM4, SM6. With the Vcigo K3 Mod, it will bring you dense flavor and massive vapor.
40
Original Eleaf Tessera 150W 3400mAh TC VW Variable Wattage Box Mod $37.99
Designed with low-poly elements and high-performance experience in mind, the new TESSERA is elaborately engineered in every single detail to be not only visually appealing but versatile. It features a 1.45 inch TFT color display and an all new UI system, with the addition of 5 theme colors for your option. A beast behind the beauty, the TESSERA is capable of firing up to 150 watts and has a maximum of 2A charging for efficient recharging.This item also has many color to choose. ![]() Original Eleaf ELLO TS Sub Ohm Tank Clearomizer $16.99 The ELLO TS is a new member of Eleaf ELLO family with one significant difference, the all-new sleek appearance, which is full of elaboration to every detail. To fill the tank, you just need to slide the drip tip back to reveal the fill port. To provide you with the most optimal vaping experience, the ELLO TS is compatible with all HW coils and comes with two drip tips for your preference.This item also has many color to choose. ![]() Original Eleaf ELLO TS Sub Ohm Tank Clearomizer $16.99 The ELLO TS is a new member of Eleaf ELLO family with one significant difference, the all-new sleek appearance, which is full of elaboration to every detail. To fill the tank, you just need to slide the drip tip back to reveal the fill port. To provide you with the most optimal vaping experience, the ELLO TS is compatible with all HW coils and comes with two drip tips for your preference.This item also has many color to choose. ![]() Original GAS Mods Replacement Colour Caps for G.R.1 GR1 RDA Original Price $14.00,Now Only $11.00 Please log in to see the lower price. The replacement color caps is made from POM. The outer diameter is 24mm. It is suitable for Original GAS Mods G.R.1 RDA. This cap is only compatible with 810 drip tips. ![]() Replacement Hexagonal Bottom Feeder Center Pin for Goon RDA $1.59 Please Note: This bottom feeder pin is compatible with Goon Style RDA in 3FVape, we are not sure if it is compatible with other Goon RDA in other site. Because most of Goon LP Style RDA are not 1:1, this one is not compatible with Goon LP style RDA now. This 3FVape customized Bottom Feeder Center / Squonker Pin is made from brass with gold plated. It is suitable for 528 Goon (both 24mm and 22mm diameter). Comatible with the Goon RDA listing here: http://www.3fvape.com/searc... This bottom feeder pin is with hexagonal screw hole.
