302474
822
341
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original DEJFVU DJV D7 180W TC VW Variable Wattage Box Mod $72.99
Inspired by Rifle arms and weapon design, DEJFVU DJV D7 Mod is a cool and versatile touch screen TC Mod powered by dual 18650 batteries (NOT INCLUDED) with 180W maximum output. Equipped with advanced AsModus GX180 UTC touchscreen chip, the DJV D7 Mod supports Power, Temp, Curve, TCR and TFR working Modes for your selection. With the HD color touch screen, it will be much easier for operation. This item also has other color to choose. ![]() Original Sikary Vapor Tutu Disposable Sub Ohm Tank Clearomizer $3.99 The Sikary Vapor Tutu Sub Ohm Tank is a disposable clearomizer that comes with 2ml juice capacity and a 0.9ohm mesh coil for 12W to 15W output. The Tutu has adjustable bottom airflow for optimal flavor. The entire body of the Tutu is made of acrylic, except for the coil head and the gold-plated contact. This item also has other color to choose. ![]() Original OILAX Keto C4 400mAh Oil CBD Vaporizer Kit $10.99 The OILAX Keto C4 is a vaporizer kit designed for CBD oil. It is powered by built-in 400mAh battery. There are three shift pressure: 4.0V/3.8V/3.6V. It can be compatible with most 0.5ml / 1.0ml oil cartridges in the market. Inspired by the car key, the Keto C4 has a rotation shaft, which can rotate the cartridge by 180 degrees and hide it when not using it. ![]() Original Yocan STIX 320mAh CBD Vaporizer Pen Kit $7.99 Yocan STIX Vape Pen Kit is a pocket-sized starter kit designed for juice. It comes with an independent storage to store juice. With its leakproof design, you will enjoy satisfied vaping experience. The STIX kit utilizes ceramic coil which provides excellent vapor clouds and purer flavor. Three adjustable voltage level bring different vaping needs. Yocan STIX kit has 320mAh built-in battery and supports Micro USB charging. This item also has other color to choose. ![]() Original Yocan Stealth 650mAh 2-in-1 CBD Vaporizer Kit $24.99 Yocan Stealth 2-in-1 Vape Kit is multi-functional and portable kit designed for juice and concentrate. The atomizer can be concealed into the box mod when you don't use it. When you start vaping, just press the flip button on the top left side to take out atomizer. The juice atomizer adopts ceramic coil to achieve purer flavor, the concentrate atomizer adopts quartz coil to provide purest experience. The voltage can be adjusted for different occasions. This item also has other color to choose. ![]() Original Orchid Vapor Orchid 950mAh 30W TC VW Variable Wattage Pod System Starter Kit $36.99 The Orchid Pod System is an extremely versatile and innovative vape kit to be added to the Pod System lineup. The Orchid features a moderate 950mAh internal battery capacity and is capable of outputting from 5W to 30W of maximum power, being the first pod system to include a screen and full wattage, voltage, and temperature control firing modes. The Orchid maintains a 3ml E-Liquid Capacity and utilizes a 0.8ohm ohm mesh to produce fantastic flavor and cloud production when used with freebase, respectively. The extremely portable chassis of the Orchid allows it to be easily attached to a lanyard or pocketed with ease, making it a fantastic daily device for any type of vaper. This item also has other color to choose. ![]() Original Wotofo Profile Unity RTA Replacement 810 Drip Tip Original Price $4.99, Now Only $3.99 The mission for a drip tip is to supply vapor that generated from the atomizer. Most people choose drip tips on their personal preference for appearance. Of course appearance matters, however, drip tips do make a difference in flavor. The new profile unity RTA drip tip which is still made of resin kept the 810 connection standard for custom replacement if you prefer your own. It is nearly 2 times thicker than the one for the Profile RDA, but the center passage is smaller and has a gradual reduction in diameter downwards. The thickness is for consideration of heat dissipation and comfort, allowing the drip tip to snugly fit between your lips, while the center passage design facilitates flavor delivery. The passage size for the new profile unity RTA drip tip is tested to best balance air circulation and flavor enhancement. This item also has other color to choose. ![]() Vapeasy Replacement Tank Tube for Biatch RDTA $1.99 The replacement tank tube is made from PC. The tube is 22mm in diameter and with 1.5ml of juice capacity. This product is suitable for Original Biatch RDTA and Vapeasy Biatch RDTA Clone. ![]() SXK Replacement Long Mode Tank Kit for 22mm KF Lite 2019 RTA Clone $4.50 The replacement Long Mode section tank is made from PC and is suitable for SXK 22mm KF Lite 2019 RTA Clone. It has 4ml of juice capacity. This item also has other Version to choose. ![]() Original Orchid Vapor Orchid Replacement Pod Cartridge $8.99 The Orchid Replacement Pod Cartridge is designed to be used with the Orchid Pod System Kit. It has a 3ml e-liquid capacity alongside a 0.8ohm resistance to produce fantastic flavor and cloud production optimized for Nic Salt Vaping. This product comes with 2 PCS in 1 pack. This item also has other color to choose. ![]() Premium Leather Vape Tool Kit for DIY Coil Building $13.99 The Premium Leather Vape Tool Kit is a useful tool set for RDA / RTA DIY coil building. It contains multifunction screwdriver, ceramic tweezers, steel tip tweezers, coil jig, diagonal pliers, stainless steel scissors and cleaning brush.
342
Original Vapesoon VS24 RDA Rebuildable Dripping Atomizer with BF Pin $9.99
The Vapesoon VS24 RDA is a 24mm rebuildable dripping atomizer that features dual post build deck and adjustable side airflow. There are 10 airflow holes at each side, providing you with smooth airflow. The RDA comes with bottom feeding pin to be compatible with squonk mods. ![]() ShenRay Patibulum MTL RTA Rebuildable Tank Atomizer Clone Original Price $23.90, Now Only $21.99 ShenRay Patibulum RTA Clone is a 22mm rebuildable tank atomizer designed for mouth to lung vaping. It is made from 316 stainless steel and Ultem. It features disk type AFC system and juice tunnel which is ideal for straight wicking. This item also has other color to choose. ![]() Original Starss Bravo 1000mAh 14W Pod System Starter Kit $25.99 The Starss Bravo Pod system is an ultra portable newly designed pod device. It has a very large battery capacity of 1000mAh with a built-in rechargeable lithium ion battery, which allows the Starss Bravo Pod to last all day and supports the maximum output power of 8W. The Starss Bravo pod device uses the refillable Bravo Cartridge System, which allows you to utilize up to 2ml of your favorite regular e-liquids. The Bravo pod kit has three output modes (low, middle and high), indicated by red, green, and blue LEDs. The Starss Bravo utilizes an air-driven system for button-free and draw-activated firing. The cartridge resistance is 1.2ohm, utilizing the newest designed ceramic coil technology to ensure the purest flavor without the fear of burning coils. Located at the bottom of the cartridge is a flip-top silicone stopper for easy refill. This item also has other color to choose. ![]() Original Vapesoon Replacement Tank Tube + Drip Tip Kit for Uwell Crown 4 Tank $4.49 The Vapesoon Replacement Resin Tank Tube and drip tip are made from resin. The tank tube has 6ml of juice capacity and is suitable for Original Uwell Crown 4 Tank.
343
Original Yiloong Fogger 16 MTL RTA Rebuildable Tank Atomizer $19.99
Yiloong Fogger 16 MTL RTA is a rebuildable tank atomizer designed for mouth to lung vaping. Metal parts are made of stainless steel, chimney is made of peek to minimize the chance for shorts. The air inserts is interchangeable with 1.0mm and 2.0mm size. The tank has 2ml capacity and can suit all type Salt Nic liquid. It is a great MTL tank for the mouth to lung inhalers. ![]() Vapeasy Armor S RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99 The Vapeasy Armor S RDA Clone is a 22mm rebuildable dripping atomizer made from durable 316 stainless steel. It comes with a unique cap with many grooves on it. The deck is easy for coil building. The black Delrin drip tip will bring you comfortable experience. This RDA comes with bottom feeder pin. This item also has other color to choose. ![]() Original ShenRay Fossette 750mAh Pod System Starter Kit $13.99 The ShenRay Fossette Pod System Starter Kit is an ultra-portable pod vape kit with 2ml pod cartridge. When you turn it on, press and hold the button to vape. The longest vape time is 10 seconds each time. The red light means 3.3V output and the blue light means 3.5V output. It is easy to carry when you are on the go. ![]() YFTK Replacement Bell Tank for 22mm KF Lite 2019 RTA Clone $3.95 The replacement Bell section tank is made from PC and is suitable for YFTK KF Lite 2019 22mm RTA Clone. It has 2ml of juice capacity. ![]() Original Wotofo Vape Band Tank Protector Silicone Anti-slip Ring Original Price $4.99, Now Only $2.59 Wotofo Vape Band Tank Protector made from high quality and durable stretch silicon. They make gripping metal and glossy surfaces easy and slip proof, and also act as an effective bumper for vape device to prevent minor scratches. Wotofo Vape Band Tank Protector can help you to avoid your tanks falling down and breaking apart into a thousand pieces. Directly fit on your favorite RDA Tank Mechanical Mod and Atomizer. This product comes with 5 PCS in 1 pack. This item also has other color to choose. Original Wotofo 18650 Battery Case Protective Storage Box Original Price $3.99, Now Only $1.99 This is a carrying box for your 18650 batteries. This battery case can hold up to four 18650 batteries. It has a firm closure at the outside and battery separators at the inside to keep the batteries in place so they don't drop out accidentally. Keeping batteries in battery case can prevent unwanted discharging caused by coins or keys in your pocket. This Wotofo 18650 battery case is designed small enough to fit in your pocket and ensures battery safety while you are on-the-go. (BATTERIES NOT INCLUDED). This item also has other color to choose. ![]() Original Wotofo Disposable 510 Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer Original Price $4.99, Now Only $2.59 Wotofo Disposable Drip Tip is the best choice for sampling your E-Juice line. Wotofo Disposable Drip Tip uses environment-friendly grade silicone material and it is 100% safe, practical, hygienic and heat-resistant. Every silicone disposable drip tip comes sealed in plastic, so that it can prevent to be polluted secondly. It is so comfortable and testable that bite it without worries! This product comes with 5 PCS in 1 pack. This item also has other Version to choose. Original Wotofo Ni80 Alien Pre-built Coil Original Price $16.99, Now Only $9.39 Wotofo Ni80 Alien Prebuilt Coils are finely crafted coils twisted with machine-like precision for those that are looking to save time in rebuilding, available in a myriad of advanced configurations for immediate sophisticated RDA set-up. Using the highest grade of materials increases durability and reduced carbon deposit, Wotofo Ni80 Alien Prebuilt Coils will bring you the optimal clouds and flavor. It comes with 10pcs pre-built coils in one pack. This item also has other color to choose. ![]() Original Wotofo NI80 Competition Heating Resistance Wire Original Price $7.99, Now Only $4.99 Wotofo Ni80 Competition Wire is in 24 gauge. Low Resistance wire is perfect for rebuilding your beautiful atomizer and especially good for sub ohm coil builds. Wotofo Ni80 Competition Wire are designed to be small and portable and premium quality wires are annealed so they are easy to handle and cut. Featured with faster ramping up, easy to work and holding shapes, Wotofo Ni80 Competition Wire is really the best choice for the DIYers. This item also has other Version to choose. ![]() Original Wotofo Vape Carry Case Storage Bag for E-Cigarette $9.99 Wotofo Vape Carry Case is a specifically designed for safe and convenient storage and transportation of various vaping tools and kits. Wotofo Vape Carry Case has a simplistic design with a vivid "WOTOFO" emblem stitched onto the right corner of the case and a sturdy green WOTOFO emblem pull tab linked to the zipper to make unzipping easy. The Wotofo Carry Case opens wide displaying two sides, one with netting and the other with elastic straps to organize your vape gear as you see fit. It is 6.5 inch x 4.5 inch x 2.7 inch, which makes this carry case large enough to carry your mod, multiple bottles of e-juice, atomizers, extra batteries, or any other accessories. ![]() Original Wotofo Vape Scissors for DIY Cotton Cutting Original Price $9.99, Now Only $5.99 Wotofo Vape Scissors comes from Wotofo Tool Kit. Wotofo Vape Scissors in the kit are made with surgical scissors standard, very easy to clean. We choose super hard stainless steel for ongoing toughness, creating sharper edges. The scissors have blunt tips to be safer and finger rings are designed in bigger size for consideration of more comfortable hold. ![]() Original Wotofo Ceramic Tweezers for DIY Coil Building Original Price $9.99, Now Only $5.99 Wotofo Ceramic Tweezers are heat resistant up to 1300 Celsius degrees. Wotofo improved the ceramic pieces with compound materials to harden the tip, enhancing its heat and corrosion resistance, insulation, and anti-static & nonmagnetic properties. ![]() Original Wotofo Spring Loaded Flush Cutter Diagonal Pliers for DIY Coil Building Original Price $14.99, Now Only $9.39 Wotofo Spring Loaded Flush Cutter adopts tungsten steel inlay technology to have tungsten reinforcements along the cutting edges, making hardness of HRA-91 level. The hardness of this material allows for easier and smoother cuts and keeps the scissors sharp for longer life. Wotofo Spring Loaded Flush Cutter leaves a smoother and more even end on the wire. It can even cut your other cutters. We are not bluffing, just have a try if you don't mind ruining your old cutters. Tungsten steel has a series of excellent properties including high hardness, wear resistance, strength and toughness, heat resistance, and corrosion resistance. Its hardness remains unchanged even at a temperature of 500 Celsius degrees, and it still has a high hardness at 1000 Celsius degrees. Wotofo Spring Loaded Flush Cutter also features spring-loaded handles for fast use and comfortable grip with non-slip materials. ![]() Original Wotofo Ultrasonic Cleaner 50W 42KHz Cleaning Tool Original Price $69.99, Now Only $59.99 Wotofo Ultrasonic Cleaner is designed to eliminate all the hassles of manually cleaning and maintaining RTAs, RDAs, Sub-Ohm Tanks, and other metal, composite, or glass vaping equipment and tools, effectively cleaning each piece through the use of ultrasonic waves and tap water. Featuring an output of 50W and a frequency of 42 KHz, Wotofo Ultrasonic Cleaner is highly efficient at cleaning hard to reach places with a gentle yet powerful effect, using microscopic bubbles to lift debris and residue. With a large basin able that easily accommodates the vast majority of safe to clean items, users can simply fill the reservoir with tap water, place the desired items into the basin, and activate the cleaning operation. Users can also clean multiple items simultaneously, making maintenance quick and efficient. The integrated view window also allows for quick assessment as to the cleanliness and state of each operation. This product comes with US Plug. This item also has EU Plug to choose.
344
Original DEJAVU DJV Hybrid Mechanical Tube Mod Original Price $68.00, Now Only $54.49
The Original DEJAVU DJV Mech Mod, designed by the YouTube reviewer Adrian Lo Dejavu, is a high-end mech mod powered by single 18650 battery (NOT INCLUDED). The DJV Mech Mod can work efficiently with two types of button, the stainless steel or acrylics. DEJAVU DJV Mod also features the innovative hybrid system, which makes the 510 pin of atomizer contact the battery directly for better power transfer and a harder, faster hit. With the advanced canted coil inside the gold-plated contact pin, the DEJAVU DJV Mech MOD can provide maximum firing and reduce heat effectively. ![]() Original Oumier Bulk RTA Rebuildable Tank Atomizer Original Price $32.90, Now Only $23.59 Oumier Bulk RTA was collaboratively designed by Youtube reviewer VapnFagan, featuring a postless, dual coil build deck with 6.5ml of maximum juice capacity. The airflow can be adjusted by the bottom AFC ring, giving you optimal flavor. The RTA measures 28mm in diameter. This item also has other color to choose. ![]() Original Oumier Armadillo RDA Rebuildable Dripping Atomizer Original Price $27.90, Now Only $18.99 Oumier Armadillo RDA, jointly designed by Oumier and Dimi Crazy Damper, is a dual coil rebuildable dripping atomizer with 24mm diameter. It comes with a unique build deck for dual coils building, which can be compatible with different sizes of coils. The airflow can be adjusted by rotating the cap, bringing you optimal flavor. This item also has other color to choose. ![]() Original Joyetech Exceed Grip 1000mAh Pod System Starter Kit $29.39 Joyetech EXCEED Grip, a smart pod system based on the classic boxy style design, is compact with rich texture and colorful IML panels. Two kinds of cartridges available for your choice: one using changeable EX coil heads and the other using built-in coil system. New mesh coil, mesh cotton and Innovative DBP technology will bring you optimal vape experience. Combined the built-in 1000mAh battery with 3.5/4.5ml refillable cartridge, this device is perfect for both starter and advanced vapers. This item also has other color to choose. ![]() Original GeekVape Frenzy 950mAh Pod System Starter Kit Original Price $37.00, Now Only $27.99 Designed with pure elegance and beautifully crafted with zinc alloy and Resin making every single piece a unique masterpiece. Geekvape Frenzy is one of Geekvape's most advanced Pod system powered with the AS Micro Chipset and compatible with the replaceable NS coil system. This item also has other color to choose. ![]() Original GeekVape Replacement NS Mesh KA1 Coil for Frenzy Kit / Flint Tank / Flint Kit Original Price $10.90, Now Only $7.99 The GeekVape Replacement NS Mesh Coil is constructed from Kanthal A1 mesh heating material and food grade organic cotton, with 0.7ohm resistance. It will provide you with maximum flavor. It is suitable for GeekVape Frenzy Kit / Flint Tank / Flint Kit. This product comes with 5 PCS in 1 pack. This item also has other Version to choose.
345
Original SMOKTech SMOK Mag 225W TC VW Variable Wattage Mod Right-Handed Edition Original Price $51.99, Now Only $28.99
The Original SMOKTech SMOK Mag mod comes with innovative ergonomic design, which looks like a gun handle. By pressing the flower-shaped button, the battery case pops out for battery installation, you can even hear the pleasant sound that a real gun can offer you. Powered by dual 18650 batteries, Mag can deliver output up to 225W. There are three modes for you to choose from. Temp Mode can enhance consistency and taste of every puff. Watt Mode is perfect for cloud chasing. Memory Mode can be your intelligent partner. Powered by dual 18650 batteries (NOT INCLUDED). This item also has other color to choose. ![]() Original SMOKTech SMOK Procolor 225W TC VW Variable Wattage Box Mod Original Price $49.99, Now Only $25.99 The SMOK ProColor 225 wattage mod has the industrys leading design and new features. It has RGB backlights shaped like a shield and a super large OLED colorful screen of 1.3 inch with high definition. Besides, it owns a totally new designed software interface, a fire bar of ergonomic hand feel design. The max output power of ProColor can reach up to 225W, and provides two modes for you. Temp Mode can enhance consistency and taste of every puff. Watt Mode is perfect for cloud chasing. Powered by dual 18650 batteries (NOT INCLUDED). This item also has other color to choose. ![]() Original SMOKTech X Cube Mini 75W Bluetooth TC VW Variable Wattage Box Mod Original Price $47.99, Now Only $20.99 SMOK X CUBE MINI is the mini version of X CUBE II. As one of the most accurate temperature-control mods, X CUBE MINI features three new functions: Intelligent Coil Recognition, Adjustable Temperature Coefficient of Resistance and Adjustable Initial Resistance, which are designed to bring your vaping experience to the next level. It has 75W maximum outputBluetooth 4.0 technology, and a customizable LED that potentially illuminates in up to 16 million colors. And there many more functions are waiting for you to discover. Powered by single 18650 battery (NOT INCLUDED). ![]() Original SMOKTech SMOK Alien 220W TC VW Variable Wattage Box Mod Original Price $49.69, Now Only $26.99 The Alien is crafted of a Zinc alloy coated with a space age paint to bring humanity a durable, yet attractive finish. The SMOK Alien features curves and an aversion to hard angles which makes it feel very comfortable in the palm of your hand. Alien has a maximum power output of 220 watts, more than enough to handle almost any coil made here on earth. The Alien also has temperature mode. Whether you are a TC enthusiast who is chasing the purest flavor or a cloud chasing maniac, this mod will satisfy you. Powered by dual 18650 batteries (NOT INCLUDED). This item also has other color to choose. ![]() Original SMOKTech SMOK Koopor Mini 2 80W 2600mAh TC VW Variable Wattage Box Mod Original Price $29.99, Now Only $14.99 The SMOK KOOPOR MINI2 features 80W high power, Ttemperature Control and Variable Wattage function. In addition, the Micro-USB port supports firmware upgrading and charging; so you can update the device at any time. The KOOPOR MINI2 is made from Zinc Alloy, looks and feels good. Now it is time to get one Smok Koopor Mini, it will bring you wonderful vaping experience. This item also has other color to choose. This product is Chinese Version, which comes with manual in Chinese, but the UI menu is in English. ![]() Original SMOKTech SMOK T-PRIV 220W TC VW Variable Wattage Box Mod Original Price $53.99, Now Only $26.99 The SMOK T-PRIV mod has max output power up to 220W, and provides you two modes (temp mode / watt mode). It is powered by two 18650 batteries in series. The dual battery life indicator on the OLED screen is more accurate for you. Hollow out design of T-PRIV mod shows domineering, the big fire key kindles your desire, adjustable LED meets your various color demands, and 220W output is powered by 2 x 18650 batteries. This item also has other color to choose. ![]() Original SMOKTech SMOK R80 80W 4400mAh TC VW Variable Wattage Box Mod Original Price $43.99, Now Only $21.99 SMOK R80 TC box mod is upgraded version of SMOK M80, the new temp control box mod built-in 4000mAh battery, portable and compact size, and with fundamentally improvement in finish. The Smok R80 box mod support temperature control with stainless steel, Nickel 200 and titanium coil heads. Max. output 80 watts, with brand new internal battery monitoring technology, perfect battery system will be the guardian of your vaping safety. ![]() Hellfire V6 Hybrid Mechanical Tube Mod Clone $11.99 The Hellfire V6 Mechanical Mod Clone is a mini size 18350 mech mod with a diameter of 22mm. This mod is made from 316 stainless steel. It is very easy to carry and suits your palms perfectly. The mod is powered by single 18350 battery (NOT INCLUDED). ![]() Original SMOKTech SMOK Micro TFV4 Sub Ohm Tank Clearomizer Original Price $26.99, Now Only $13.39 SMOK Micro TFV4 is designed to offer three types of heating cores for different vaping needs: sub-ohm core (0.3 ohm Micro CLP2), standard resistance core (1.8 ohm Micro MTL) and rebuildable single Clapton core (Micro RCA). Along with two larger replacement glass tubes and two extension adapters, the original 2.5ml tank can be extended to 3.5ml and 5ml so that you can enjoy Micro TFV4 anywhere and anytime. Top refill design makes filling as easy as it gets. Constructed from superior-quality stainless steel and glass, Micro TFV4 will bring you unexpectedly excellent taste! Innovation keeps changing the vaping experience. This item also has other color to choose. ![]() Original Voopoo Drag Nano 750mAh Pod System Starter Kit Original Price $33.90, Now Only $24.99 Voopoo Drag Nano Pod System Kit is a brand new pod system kit of Drag series. It has elegant exterior and small size. It adopts brand-new GENE.Pod Chip to support the intelligent cold boot mode for better flavor. 750mAh built-in battery allows for 350 puffs. It comes with a smart LED indicator to display battery status. The pod cartridge can hold 1ml e-liquid and utilizes 1.8ohm coil head for intense flavor and smooth clouds. This item also has other color to choose. ![]() Original Voopoo Drag Baby Trio 25W 1500mAh TC VW Variable Wattage Mod Kit Original Price $44.90, Now Only $35.99 Voopoo Drag Baby Trio Kit consists of Voopoo Drag Baby Trio Mod and Voopoo Drag Baby Trio Tank. This item also has other color to choose. Mod: Voopoo Drag Baby Trio Mod is equipped with 1500mAh capacity built-in battery that can help you enjoy longer time and it only needs to charge it for 1.5 hours. The mod not only features advanced GENE chip which intelligently manipulate the power output, but also has Trio chip inside that will maintain the rich taste of flavor and quality. Tricolor LED battery indicator light makes sure that there is no burning as it will turn off automatically if it is low capacity when vaping it. Tank: Voopoo Drag Baby Trio Tank has 1.8ml E-juice capacity. The creative PnP coils makes it convenient to change coils in one second. It comes with top refill and middle adjustable airflow systems together to ensure the better flavor and safety as well. ![]() Original SMOKTech SMOK H-Priv 220W TC VW Box Mod + Micro TFV4 Kit Original Price $39.99, Now Only $19.99 The SMOK H-Priv, which max power can up to 220 watt; the Red Triangle design would help you forget the fire key from now on: holding it, vaping it. The fire key of H-Priv is based on the design of X CUBE; it combines the inconspicuous fire key with the mod box instead of the cool customizable LED. The SMOK Micro TFV4 Tank features 2.5 / 3ml capacity and 0.3 ohm resistance that can support 30~60W power output. The top refill design makes filling as easy as it gets. The SMOK H-Priv together with Micro TFV4 will bring you unexpectedly excellent taste! This item also has other color to choose. This product is Chinese Version, which comes with manual in Chinese, but the UI menu is in English. ![]() Original SMOKTech SMOK G150 150W TC VW Mod + Spirals Plus Tank Kit EU Edition Original Price $29.99, Now Only $14.99 SMOK G150 Mod and Spirals Plus tank is a good match for new experience. The G150 kit features with streamline arc design and innovative design. The 150W output power provides simplify operation and bottom adjustable airflow Spirals Plus tank offers good taste. All is only for better taste. Innovation keeps changing the vaping experience. This product is EU Edition. This item also has other color to choose. ![]() Original SMOKTech SMOK G80 80W TC VW Variable Wattage Mod + Spirals Tank Kit EU Edition Original Price $47.99, Now Only $23.99 G80 Mod has the characteristics of compact size and easy-to-read OLED screen. While the Spirals tank provides multi-level taste and e-juice saving as for its adjustable small airflow slots and precise wicking hole. Incomparable vaping time from G80 kit gives you complex flavor and long run time. This product is EU Edition. ![]() Original Uwell Juice Bank Refilling Dripping Bottle for E-juice Liquid $26.19 The Original Uwell Juice Bank is a refilling dripping bottle for e-liquid with a juice capacity of 15ml and the single refilling volume is about 0.1ml. Constructed from Stainless Steel and Quartz Glass, it has perfect protection from inside to outside. With the transparent windows on both sides of the bottle, you can check juice levels with a 15 ml scale. This item also has other color to choose. ![]() Original Voopoo Drag Nano Replacement Pod Cartridge Original Price $15.60, Now Only $9.59 The Voopoo Drag Nano Replacement Pod Cartridge has 1ml of juice capacity and 1.8ohm coil and is suitable for Voopoo Drag Nano Pod System Starter Kit. This product comes with 4 PCS in 1 pack. ![]() Original Voopoo Drag Baby Trio Replacement PnP-M2 Coil Heads Original Price $19.95, Now Only $12.39 The Voopoo Replacement PnP-M2 Coil Head features 0.6ohm resistance and is suitable for Voopoo Drag Baby Trio Kit. This product comes with 5 PCS in 1 pack.
346
Original Weepor Click 30W 400mAh CBD Battery Mod Vaporizer $13.99
Weepor Click CBD Battery Mod features compact U-shaped ergonomic design, which brings you sleek touch feeling. Three adjustable voltage levels can be adjusted. The Click mod comes with cartridge pop-up folded design that prevent dust contact mouthpiece. And it is compatible with all cartridges with a diameter of 11.5mm or less. This mod has 400mAh internal battery capacity and supports 30W output. It also comes with safe rapid charging system and intuitive safety systems. This item also has other color to choose. ![]() Original Vandy Vape Trident IP67 Waterproof Tube Mod Original Price $39.99, Now Only $28.99 Vandy Vape Trident Mod adopts silica gel surface to bring you a perfect handgrip. Extreme water, shock and dust protection makes the device safer and durable. The Trident Mod features an intelligent LED indicator to show the battery status. It is powered by single 18650 battery (NOT INCLUDED). This item also has other color to choose. ![]() Original Ldnliq FC 600mAh Pod System Starter Kit $8.99 Ldnliq FC Pod Kit is a refillable pod system vape kit with 600mAh built-in battery. It has soft touch rubber coating, which feels great in your hand. The pod cartridge has 2ml of juice capacity and 1.8ohm coil. It has Loose Draw and Tight Draw adjustable setting, bringing you different vaping experience. This item also has other color to choose. ![]() Original ShenRay Fossette X 750mAh 12W Pod System Starter Kit $13.99 The ShenRay Fossette X Pod System Starter Kit is an ultra-portable pod vape kit with 2ml pod cartridge and 1.5ohm coil. When you turn it on, just take a puff without pressing button. The button is for turn on/off and voltage function only. It has three levels of voltage for you to adjust. It is powered by built-in 750mAh battery with 12W maximum output. It is easy to carry when you are on the go. This item also has other color to choose. ![]() Original ShenRay Fossette C 650mAh 18W Pod System Starter Kit Original Price $15.99, Now Only $14.99 The ShenRay Fossette C Pod System Starter Kit is an ultra-portable pod vape kit with 1ml pod cartridge and 1.4ohm ceramic coil. The button is for turning on/off device, voltage setting and firing. It has three levels of voltage for you to adjust. It is powered by built-in 650mAh battery with 18W maximum output. It is easy to carry when you are on the go. This item also has other color to choose. ![]() Original Vandy Vape Trident IP67 Waterproof Starter Kit Original Price $52.99, Now Only $40.59 Vandy Vape Trident Kit consists of Vandy Vape Trident Mod and Vandy Vape Trident Tank. This item also has other color to choose. Mod: Vandy Vape Trident Mod adopts silica gel surface to bring you a perfect handgrip. Extreme water, shock and dust protection makes the device safer and durable. The Trident Mod features an intelligent LED indicator to show the battery status. It is powered by single 18650 battery (NOT INCLUDED). Tank: Vandy Vape Trident Sub Ohm tank utilizes integrated mesh coil to achieve massive clouds and pure taste. The Adjustable airflow system and top filling design are available. ![]() Original Vapeplus Meshwork Coil SS316L Kanthal A1 Heating Mesh $2.99 The Vapeplus Meshwork Coil comes with two types of mesh: SS316L (0.12~0.18ohm) and Kanthal A1 (0.13ohm). They are great for RDA / RTA that utilizes mesh coil. Each type of coil comes with 6 PCS, totally 12 PCS in the package. ![]() Original Uwell Crown 4 IV Replacement Glass Tank Tube $1.99 The Uwell Replacement Glass Tank Tube has 5ml of juice capacity and is suitable for authentic Uwell Crown 4 IV Tank. This item also has Other Capacity to choose. ![]() Original Vpdam Folding Vape Tool Kit for DIY Building $12.99 Vpdam Folding Tool Kit contains useful vape tools necessary for DIY vapers to build coils and adjust atomizers and other vaping devices. This tool bag can highly compatible with tough environment. This item also has other color to choose. ![]() Original Ldnliq FC Replacement Pod Cartridge $2.99 The Ldnliq FC Replacement Pod Cartridge has 2ml of juice capacity and 1.8ohm coil and is suitable for Ldnliq FC Pod System Starter Kit.1 PC per pack.
347
Original Vapor Storm S1 800mAh VV CBD Battery Mod Original Price $18.00, Now Only $16.95
The Vapor Storm S1 Mod is a portable device designed for CBD vaping. It has 3-level adjustable voltage, which is 3.4V, 3.7V and 4.2V. The mod is compatible with atomizer with diameter less than 11mm. Powered by built-in 800mAh battery, this mod also supports fast balance charging. Made from durable ABS material, this mod is very lightweight and easy to carry. This item also has other color to choose. ![]() FEV BF-1 RDA Rebuildable Dripping Atomizer Clone with BF Pin $12.99 The FEV BF1 Squonker RDA is constructed from 316 stainless steel and with 23mm diameter. The single coil RDA comes with bottom feeder pin for squonker mod. ![]() Kindbright VG V6 S V6S RTA Rebuildable Tank Atomizer Clone $23.59 The Kindbright VG V6S RTA Clone is a 23mm rebuildable tank atomizer with 5.5ml of juice capacity. It is constructed from 316 stainless steel with glass / PEI tank tube. The tank features infinitely adjustable bottom airflow, which is adjusted via 6 lockable holes in the deck. The tank can be refilled from the top. ![]() Original Lost Vape Orion Q 17W 950mAh Pod System Starter Kit Original Price $49.00, Now Only $33.63 The Original Lost Vape Orion Q (Orion Quest) is made without the DNA Go board, which makes it much more affordable while retaining Lost Vape's precise craftsmanship and most of the same great features as the Lost Vape Orion DNA GO. With the removal of the DNA board and power adjustment button, the Lost Vape Orion Q offers a much simpler vape experience with its one button design. Featuring the same safety protections and a 950mAh rechargeable LiPo battery as the original, the Lost Vape Orion Q utilizes a 2ml refillable pods that lock into the battery. In addition, the Orion Q retains the multi-colored LED battery life indicator to check the current battery level with a quick glance. This kit comes with a pod cartridge. This item also has other color to choose. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.49 The replacement 510 drip tip is made from resin and stainless steel. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose. ![]() Original Vapesoon 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.49 The Vapesoon replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.
348
ShenRay KF Lite 2019 RTA Rebuildable Tank Atomizer Clone $18.78
The ShenRay KF Lite 2019 Style RTA is a 22mm rebuildable tank atomizer with 2ml of juice capacity. It is made from 316 stainless steel and Ultem. It is designed for mouth to lung vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience. This item also has 24mm Version to choose. ![]() Vapeasy Patibulum MTL RTA Rebuildable Tank Atomizer Clone $12.99 Vapeasy Patibulum RTA Clone is a 22mm rebuildable tank atomizer designed for mouth to lung vaping. It is made from 316 stainless steel and Ultem. It features disk type AFC system and juice tunnel which is ideal for straight wicking. ![]() Kennedy Vindicator Less Ribbed Hybrid Mechanical Mod Clone + Kennedy 25 RDA Kit Clone $23.39 The Kennedy Vindicator Mech Kit Clone consists of Kennedy Vindicator Mechanical Mod Clone and Kennedy 25 RDA Clone. This item also has other color to choose. Mod: The Kennedy Vindicator Mechanical Mod Clone is a hybrid mech mod made from brass. It comes with 25mm hybrid connector. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED), it features 510 threading connection and spring-loaded fire button. The button and battery connector are made from brass. RDA: The Kennedy 25 RDA Clone is made from brass with 25mm diameter. The RDA comes with dual post build deck, bottom airflow and low profile PEI drip tip. It fits the Vindicator Style Mechanical Mod very well. This product comes with logo. This one is Less Ribbed Version. ![]() Kennedy Vindicator More Ribbed Hybrid Mechanical Mod Clone + Kennedy 25 RDA Kit Clone $23.39 The Kennedy Vindicator Mech Kit Clone consists of Kennedy Vindicator Mechanical Mod Clone and Kennedy 25 RDA Clone. This item also has other color to choose. Mod: The Kennedy Vindicator Mechanical Mod Clone is a hybrid mech mod made from brass. It comes with 25mm hybrid connector. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED), it features 510 threading connection and spring-loaded fire button. The button and battery connector are made from brass. RDA: The Kennedy 25 RDA Clone is made from brass with 25mm diameter. The RDA comes with dual post build deck, bottom airflow and low profile PEI drip tip. It fits the Vindicator Style Mechanical Mod very well. This product comes with logo. This one is More Ribbed Version. ![]() Original Eleaf iTap 30W 800mAh Pod System Starter Kit $19.74 Eleaf iTap Pod System Starter Kit is a new pod kit powered by built-in 800mAh battery with maximum 30W output. The pod cartridge has 2ml of juice capacity and is compatible with two types of coils: GS Air S 1.6ohm Head and GS Air 0.75ohm Head. With innovative dry-burn protection technology, this kit will bring you clean and pure flavor. This item also has other color to choose. ![]() Original Vapesoon 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.49 The Vapesoon replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This item also has other color to choose. ![]() Original Eleaf iTap Replacement SS316L GS Air S Coil Head $7.90 The GS Air S 1.6ohm Head adopts the SS316L material as its wire, it presents better MTL vaping and great flavor. It is also a new atomizer head with dry-burn protection. It is suitable for the Eleaf iTap Pod. This product comes with 5 PCS in 1 pack. ![]() Original Eleaf iTap Replacement Pod Cartridge $19.99 iTap pod is a newly designed pod that features a refined airflow system and an easy bottom-fill solution. Comes with new GS Air S (SS316L) 1.6ohm Head, it presents better MTL vaping and great flavor. It is suitable for Eleaf iTap Pod System Starter Kit. This product comes with 5 PCS in 1 pack.
349
Original Rincoe Mechman 228W TC VW Variable Wattage Box Mod Original Price $44.90, Now Only $33.79
Rincoe Mechman Mod is a versatile and durable regulated box mod that is powered by dual 18650 batteries (NOT INCLUDED) with 228W maximum output. The name of Mechman is inspired from the appearance of the mod. The unique and ergonomic design makes the whole device attractive and outstanding in the market. Mechman features the ability to change different panels and personalized stickers for much fun and fashion. The round angle and corner make the mod comfortable while holding. Mechman has different kinds of protection, including over-heating protection, low voltage protection, reverse battery protection, overload/short circuit protection and 10 second cut-off. This item also has other color to choose. ![]() Original Mechlyfe x AmbitionZ Vaper Arcless Hybrid Mechanical Tube Mod Original Price $69.00, Now Only $46.99 The Arcless Mech Mod, a collaboration between MECHLYFE and famous reviewer AmbitionZ Vaper, is a newly released portable and safe mech mod with 27mm diameter. The Arcless Mod is compatible with 18650, 20700 and 21700 batteries (NOT INCLUDED). It adopts Internal all-around insulation protection to bring a safe vaping experience. There wouldn't be any black arcing on the pole of your battery. ![]() SXK Biochip RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $17.90, Now Only $13.59 The SXK Biochip RDA Clone is a 22mm rebuildable dripping atomizer constructed from Teflon 510 drip tip, 316 stainless steel top lid and base, and PEI middle cap. It has a dual post build deck for easy single coil building. The top to side airflow system will bring you great flavor. This RDA comes with bottom feeder pin. ![]() Original Rincoe Mechman 228W TC VW Box Mod + Mechman Mesh Tank Kit Original Price $59.90, Now Only $44.59 Rincoe Mechman 228W Mesh Kit consists of Mechman 228W Mod and Mechman Mesh Tank. This item also has other color to choose. Mod: Rincoe Mechman Mod is a versatile and durable regulated box mod that is powered by dual 18650 batteries (NOT INCLUDED) with 228W maximum output. The name of Mechman is inspired from the appearance of the mod. The unique and ergonomic design makes the whole device attractive and outstanding in the market. Mechman features the ability to change different panels and personalized stickers for much fun and fashion. The round angle and corner make the mod comfortable while holding. Mechman has different kinds of protection, including over-heating protection, low voltage protection, reverse battery protection, overload/short circuit protection and 10 second cut-off. Tank: Mechman Mesh Tank is perfect with Mechman 228W Mod in size and the using experience. Wide 810 resin drip tip will bring you increased airflow and excellent appearance. Mechman Mesh Tank is dedicated for better flavor with single mesh coil and dual mesh coil for option. ![]() Original Marvec MV 10W 400mAh Pod System Starter Kit Original Price $39.00, Now Only $14.99 Marvec MV Pod Kit is a variable wattage pod system vape kit powered by built-in 400mAh battery with maximum 10W output. The pod cartridge has 2ml of juice capacity and 1.5ohm coil. The MV has two output mode, Auto and Manual. The output power can be set as 6W, 8W and 10W. Constructed from PC and ABS material, it is very lightweight and easy to carry. It has multiple protections to guarantee safe vaping. This item also has other color to choose. ![]() Replacement Bubble Glass Tank Tube for Wotofo Profile Unity RTA $1.99 The replacement bubble glass tank tube is sutiable for Original Wotofo Profile Unity RTA. ![]() YFTK Replacement Drip Tip for 22mm KF Lite 2019 RTA Clone $3.39 The replacement drip tip is made from Acrylic and is suitable for YFTK 22mm KF Lite 2019 RTA Clone. This item also has other Version to choose.
350
Vapeasy Dvarw MTL RTA Rebuildable Tank Atomizer Clone $10.99
The Vapeasy Dvarw MTL RTA Clone is a 22mm RTA made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. The RTA has 1mm bottom airflow hole. This RTA will bring you extreme MTL vaping experience. This item also has other color to choose. ![]() Vapeasy KF Lite 2019 RTA Rebuildable Tank Atomizer Clone $12.99 The Vapeasy KF Lite 2019 RTA Clone is a 24mm rebuildable tank atomizer with 2ml of juice capacity. It is made from 316 stainless steel and Ultem. It is designed for mouth to lung vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience. ![]() Original BugabooVape PVC Wrapper Skin Sticker for 18650 Battery $1.29 The wrapper sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. This product comes with 5 PCS in one pack. This item also has 21700 Version to choose. ![]() Original BugabooVape 810 Bioceramic Drip Tip for RDA / RTA / Sub Ohm Tank $3.39 The 810 Bioceramic drip tip is made from ceramic. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. ![]() Original BugabooVape Multi-functional Ceramic Tweezers for DIY Coil Building $3.39 The BugabooVape Multi-functional Tweezers is made from ceramic and is suitable for DIY coil building, coil adjusting and cotton wicking. This item also has other color to choose. ![]() Original BugabooVape Vaperface Decorative Sticker Accessory for 24mm Atomizer / Mechanical Mod $3.59 BugabooVape Vaperface is a decorative sticker accessory for vape products. It is made from Titanium steel. It adopts 3M double-sided tape, not magnet. It is suitable for 24mm atomizers and 24mm mechanical mod. This item also has A Series and B Series to choose. ![]() Original BugabooVape Vaperface Decorative Sticker Accessory for Box Mod $3.59 BugabooVape Vaperface is a decorative sticker accessory for vape products. It is made from Titanium steel. It adopts 3M double-sided tape, not magnet. It is suitable for box mods. This item also has A Series and B Series to choose. ![]() Coppervape Replacement MTL 510 Drip Tip for Spica Pro Helix Kit $1.28 Coppervape Replacement MTL 510 Drip Tip is made from POM and is suitable for Coppervape Spica Pro Helix Kit. (Helix Kit is a short tank set for Coppervape Spica Pro MTL RTA Clone). This item also has other color to choose. ![]() Coppervape Spica Pro Helix Kit Short Tank Set for Spica Pro MTL RTA Clone $12.95 Coppervape Spica Pro Helix Kit is a short tank set for Coppervape Spica Pro MTL RTA Clone. It is made from 316 stainless steel and Ultem PEI. The tank set has 2ml of juice capacity. ![]() SteamTuners Top Fill Tank Kit Clone + Clear Drip Tip for 22mm KF Lite 2019 RTA Clone $7.59 The SteamTuners Top Fill Tank Kit Clone is constructed from 316SS top lid / chimney and PEI tank tube. It is suitable for 22mm KF Lite 2019 RTA. Made at 1:1 scale.
351
Original Acrohm Fush LED Semi-Mechanical Tube Mod Original Price $77.99, Now Only $74.89
The Original Acrohm Fush Mod is an innovative semi-mechanical that features a LED color tube, which can be changed to different color with just a shake. It is safer to use than mechanical mod, and it can reach a firing speed less than 0.01S, and the minimum resistance is 0.07ohm. The mod is powered by single 18650 battery (NOT INCLUDED). It uses stainless steel and bulletproof PC material, together with 6 protections, it is a durable and safe mod for your choice. This item also has other color to choose. ![]() Original 5GVape Kool Disposable Tank Clearomizer $3.99 5GVape Kool Disposable Tank is made from PCTG and silicone. It is a 22mm tank with 1.8ml of juice capacity. The coil has 1.4ohm of resistance and works well at 8W to 10W. It has adjustable airflow system for optimal flavor. This item also has other color to choose. ![]() Original SMOKTech SMOK TFV8 Baby Sub Ohm Tank Atomizer Original Price $20.99, Now Only $5.99 TFV8 Baby, which size is 1/3 smaller than the Cloud Beast, TFV8. Meanwhile, its airflow system: the bottom pair air-slots, the air chamber, the drip tip, are re-designed after precise calculations and optimizations. All those efforts ensure that TFV8 Baby is another Cloud Beast, a Baby Beast. This item also has other color to choose. Please note: this TFV8 Baby Tank is EU edition, which comes with 2ml capacity. Please note: this TFV8 Baby Tank is separated from SMOK G150 Kit, coming without the original package box. ![]() Kampilan RDA Rebuildable Dripping Atomizer Clone $6.99 The Kampilan RDA Clone is constructed from PC and stainless steel with 24mm diameter. The deck features Velocity style design for easy dual coil builds. Working with the adjustable side airflow, it will bring you optimal flavor and massive cloud. This item also has other color to choose. ![]() YFTK FEV BF-1 RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.99 The YFTK FEV BF1 Squonker RDA is constructed from 316 stainless steel and with 23mm diameter. The single coil RDA comes with bottom feeder pin for squonker mod. ![]() Original CKS Dagger Junior 1000mAh CBD Vaporizer Starter Kit Original Price $32.00, Now Only $25.99 The CKS Dagger Junior is an all-in-one starter vape kit with a refillable vape system offering 3ml capacity pods that supports your favorite e-liquid. The compact but powerful unit offers a built in 1000mAh battery that charges up quickly in just over half an hour. Easy to use but slim and simple to quickly put away when you need to get back to it. The CKS Junior packs variable voltage settings (3.2V, 3.5V, and 3.8V) with multiple coil support for different viscosity levels. This item also has other color to choose. ![]() Original 5GVape Regal S 280mAh Pod System Starter Kit Original Price $28.00, Now Only $21.99 5GVape Regal S Pod System Starter Kit is a refillable pod vape kit that powered by 280mAh built-in battery. The pod cartridge has 1.2ml of juice capacity. There are two options for the coils, 1.5ohm cotton coil (INCLUDED) and 1.0ohm ceramic coil (NOT INCLUDED). Regal S Pod Kit is very portable and easy to use. This item also has other color to choose. ![]() Original 5GVape Regal 280mAh Pod System Starter Kit Original Price $26.00, Now Only $19.99 5GVape Regal Pod System Starter Kit is a refillable pod vape kit that powered by 280mAh built-in battery. The pod cartridge has 1.2ml of juice capacity. There are two options for the coils, 1.5ohm cotton coil (INCLUDED) and 1.0ohm ceramic coil (NOT INCLUDED). Regal Pod Kit is very portable and easy to use. This item also has other color to choose. ![]() Original 5GVape Regal / Regal S Replacement Cotton Coil Pod Cartridge $6.99 The replacement pod cartridge has 1.2ml of juice capacity and 1.5ohm cotton coil. It is suitable for Original 5GVape Regal / Regal S Pod System Starter Kit. This product comes with 3 PCS in 1 pack. This item also has Other Resistance to choose.
352
YFTK VW Hybrid Mechanical Tube Mod Clone $19.99
The YFTK VW Mech Mod Clone is made from 316 stainless steel. It measures 22mm in diameter. YFTK VW Style Mech Mod is power by single 18350 / 18650 battery (NOT INCLUDED). This item also has other color to choose. ![]() SXK Monarch 2 RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $17.90, Now Only $13.39 The SXK Monarch 2 RDA Clone is a 22mm rebuildable dripping atomizer constructed from 316 stainless steel. It features a clean single post build deck and an Ultem block for single side airflow. The top lid and decorative ring are made from Delrin. This RDA would be one of the best collections for single coil RDA lover. This RDA comes with bottom feeder pin. ![]() Original Sense Orbit 1100mAh Pod System Starter Kit $18.99 Sense Orbit Kit is a slim and portable pod system powered by built-in 1100mAh battery. It features three working modes, which is soft, normal and strong, to meet vapors' different needs and experience. Sense Orbit Pod Cartridge has 2.5ml of juice capacity, and is compatible with 1.1ohm regular Kanthal MTL coil and 0.6ohm mesh DL coil. This item also has other color to choose. ![]() Original Sense Orbit TF 1100mAh Pod System Starter Kit $19.99 Sense Orbit TF Pod System is the new innovation of Sense Orbit Pod System. Sense Orbit TF Pod System is a beautiful pattern and elegant design AIO device. Works with 1100 internal battery, the Orbit TF Pod kit supports soft, normal and strong working modes to meet vapors' different needs and experience. Sense Orbit TF Pod Cartridge has 3.0ml of juice capacity, and is compatible with 1.1ohm regular Kanthal MTL coil and 0.6ohm mesh DL coil. This item also has other color to choose. ![]() Original VO Tech Zeal 240mAh Pod System Starter Kit Original Price $24.99, Now Only $18.39 VO Tech Zeal Pod System, an ultra-portable device that utilizes proprietary interchangeable battery and the VO Micro Chipset. The Zeal is lightweight as it is made of anodized aluminum, allowing it to be a sleek and convenient device for on the go travel. The pod has 1ml of juice capacity and is refillable. Battery life indicator light can be activated by shaking the device twice in one direction whether it be left, right, up, or down. ![]() Original VO Tech Zeal 240mAh Pod System Starter Kit with Zeal+ 1350mAh Wireless Charging Box Original Price $59.99, Now Only $35.99 VO Tech Zeal Pod System, an ultra-portable device that utilizes proprietary interchangeable battery and the VO Micro Chipset. The Zeal is lightweight as it is made of anodized aluminum, allowing it to be a sleek and convenient device for on the go travel. The pod has 1ml of juice capacity and is refillable. Battery life indicator light can be activated by shaking the device twice in one direction whether it be left, right, up, or down. VO Zeal+ is a portable charging case for Zeal pod system. It has a built-in 1350mAh Lithium Polymer battery and supports 5W wireless charging. When you slide the Zeal+, there are two slots that can used to place your Zeal device and spare pod. This item also has other color to choose. ![]() Original Sense Orbit Replacement Pod Cartridge + 0.6ohm Mesh Coil + 1.1ohm Kanthal Coil $6.99 Sense Orbit Replacement Pod Cartridge has 2.5ml of juice capacity. It is compatible with 0.6ohm mesh coil for DTL vaping and 1.1ohm Kanthal coil for MTL vaping. It is suitable for Sense Orbit Pod System Starter Kit. ![]() Original Sense Orbit TF Replacement Pod Cartridge + 0.6ohm Mesh Coil + 1.1ohm Kanthal Coil $7.99 Sense Orbit TF Replacement Pod Cartridge has 3.0ml of juice capacity. It is compatible with 0.6ohm mesh coil for DTL vaping and 1.1ohm Kanthal coil for MTL vaping. It is suitable for Sense Orbit TF Pod System Starter Kit. ![]() Original Sense Orbit Replacement MTL Kanthal Coil $9.39 Sense Orbit Replacement Kanthal Coil features 1.1ohm resistance and works well at 10W to 12.5W. It is great for MTL vaping. It is suitable for Sense Orbit / Orbit TF Pod System Starter Kit. This item also has Other Resistance to choose. ![]() Original VO Tech Zeal Replacement Pod Cartridge $7.99 VO Tech Zeal Replacement Pod Cartridge has 1.0ml of juice capacity. It is suitable for VO Tech Zeal Pod System Starter Kit. This product comes with 4 PCS in 1 pack.
353
Kennedy Vindicator Less Ribbed Hybrid Mechanical Tube Mod Clone $14.99
The Kennedy Vindicator Mechanical Mod Clone is a hybrid mech mod made from brass. It comes with 25mm hybrid connector. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED), it features 510 threading connection and spring-loaded fire button. The button and battery connector are made from brass. This item also has More Ribbed Version to choose. ![]() ShenRay Firedrake MOSFET Semi-Mechanical Tube Mod Clone $23.39 ShenRay Firedrake Mechanical Mod Clone is a safe tube mod with a MOSFET chip to prevent short circuit from happening. It is constructed from stainless steel and has 25mm overall diameter. ![]() Original Vandy Vape Kylin M RTA Rebuildable Tank Atomizer Original Price $41.99, Now Only $30.19 Vandy Vape Kylin M RTA is a newly designed rebuildable tank atomizer of Kylin series. It has 24mm in diameter and holds 3ml of e-juice (4.5ml with bubble tank). Honeycomb intake airhole and trapezoidal airflow intake channel gather vapor and will make you experience the excellent flavor. The deck is quite easy to build with mesh coil. With long service life mesh coils, Kylin M RTA will bring you unprecedented vaping experience. This item also has other color to choose. ![]() Vapeasy Daywon RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.79 The Vapeasy Daywon RDA Clone is a 22mm rebuildable dripping atomizer. The design is good for pushing nice and simple coil clamps over to one side that are insulated with Ultem. Inner hourglass shaped walls perfectly house your wick leads and help condense the chamber to maximize flavor and vapor production. This RDA comes with bottom feeder pin. This item also has other color to choose. ![]() SXK Reload S RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $20.90, Now Only $18.89 The SXK Reload S RDA Clone measures 24mm in diameter with a build-friendly postless deck designed for single and dual coil configurations. Featuring a dual adjustable top airflow system, this RDA integrates internal honeycomb airflow holes which provides a satisfyingly smooth draw. In addition, the featured internal honeycomb airflow holes direct airflow to the side and bottom of the coil for optimal flavor and vapor production. This RDA comes with bottom feeder pin. This item also has other color to choose. ![]() Original Augvape Zoom 1000mAh Pod System Starter Kit Original Price $29.99, Now Only $20.99 Augvape Zoom Pod System Kit is first POD equipped with fast charging technology. It only takes 20 minutes to reach 80% power with 2A charging current. The Zoom is powered by its built-in 1000mAh battery. The zoom pod comes with 0.6ohm mech coil that will bring you excellent vaping experience by producing better flavor and having a longer lifespan. This item also has other color to choose. ![]() ShenRay Firedrake MOSFET Semi-Mechanical Tube Mod Clone + Wave RDA Kit Clone $28.99 ShenRay Firedrake Mechanical Mod Kit Clone consists of ShenRay Firedrake Mech Mod Clone and ShenRay Wave RDA Clone. This item also has other color to choose. Mod: ShenRay Firedrake Mechanical Mod Clone is a safe tube mod with a MOSFET chip to prevent short circuit from happening. It is constructed from stainless steel and has 25mm overall diameter. RDA: The ShenRay Typhoon BTD Wave RDA Clone is a 22mm rebuildable dripping atomizer which is constructed from 316 stainless steel. It features dual post build deck, single coil configuration and adjustable side airflow. ![]() Original OFRF Gear Replacement Bubble Glass Tank Tube $2.99 The replacement bubble glass tank tube has 3.5ml of juice capacity and is suitable for OFRF Gear RTA. ![]() Original Augvape Zoom Replacement Mesh Coil Head Original Price $9.99, Now Only $7.99 The Augvape Zoom replacement mesh coil head features 0.6ohm resistance and is suitable for Augvape Zoom Pod System Starter Kit. This product comes with 5 PCS in 1 pack.
354
The Hellfire V6 Mechanical Mod Clone is a mini size 18350 mech mod with a diameter of 22mm. This mod is made from 316 stainless steel. It is very easy to carry and suits your palms perfectly. The mod is powered by single 18350 battery (NOT INCLUDED). This item also has other color to choose. ![]() Original Ehpro Kelpie RTA Rebuildable Tank Atomizer Original Price $39.90, Now Only $26.59 The Ehpro Kelpie RTA, a collaboration between Ehpro and Vaping with Vic, is a well-made rebuildable tank atomizer with 2ml capacity and can be extended to 3.5ml larger juice storage with an extra bubble tube. With the honeycomb air slots and the airflow hits coil directly, the Kelpie will bring pure flavor for you. In addition, the Ehpro Kelpie RTA also adopts dual-post build deck for easy coil installation. This item also has other color to choose. ![]() Menelaus RTA Rebuildable Tank Atomizer Clone $14.99 Menelaus RTA Clone is a 22mm rebuildable tank atomizer with 4ml of juice capacity. It is constructed from 316 stainless steel and has both Acrylic and PEI tank. The deck comes with two air holes of 0.77mm below the coil, with the cotton fitted within two vertical axes placed on the deck, and AFC with three holes of 1.70mm and two of 1.00mm on each side. ![]() Original Ultroner Mini Stick Stabilized Wood Mechanical Mod + Ultroner RDA Kit Original Price $88.80, Now Only $65.99 The Ultroner Mini Stick Mod Kit consists of Ultroner Mini Stick Mech Mod and Ultroner RDA. This item also has other color to choose. Mod: The Ultroner Mini Stick Mod is a high end 18350 mechanical mod that constructed from stainless steel and beautiful stabilized wood. The mod is powered by single 18350 battery (NOT INCLUDED). The fire button is made from Ultem. The mod comes with a lanyard that makes it easy to be carried. RDA: The Ultroner RDA is perfectly suitable for the Ultroner Mini Stick Mod. It has a nice Ultem cap and is easy to build coil on its deck. Please note: the stabilized wood part will be in random color. More color than whats on the image. ![]() Original ThunderHead Creations THC 3-Core Fused Clapton Ni80 Resistance Wire $3.59 The Original ThunderHead Creations 3-Core Fused Clapton Heating Resistance Wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Nichrome 80. It features 28GA x 3 + 36GA gauge, which will be a good choice for DIY. This item also has other Version to choose. 5 Feet (1.5 Meters) per roll. ![]() Original ThunderHead Creations THC Tauren Tool Kit Elite V1 Original Price $36.00, Now Only $21.99 The Original THC Tauren Tool Kit Elite V1 is a multi-functional tool kit designed for vape. The kit includes many useful tools that can be used for coil building, wicking, adjusting. It will be a great helper for DIY lovers. This item also has Elite V2 Version to choose. ![]() Original Ehpro Kelpie Replacement Glass Tank Tube $1.30 The replacement glass tank tube has 2ml of juice capacity and is suitable for Ehpro Kelpie RTA. This item also has Other Capacity to choose.
355
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
SXK Integra Rebuildable Tank Atomizer Clone Original Price $24.90, Now Only $20.99
The SXK Integra RTA Clone is a 22mm rebuildable tank atomizer with 4.2ml of juice capacity. It is constructed from 316 stainless steel and PC. It features recessed build deck, reduced evaporation chamber, and various side airflow combinations from tight MTL to restricted DL with the stock AFC ring. ![]() Original Syiko SE 12W 650mAh Pod System Starter Kit $36.59 Syiko SE Pod System Kit is an AIO starter kit powered by 650mAh built-in battery with 12W maximum power. With 2.0 inch colorful touch screen, Syiko SE displays the details clearly and makes your operation convenient. The refillable pod has 2ml juice capacity and 1.5ohm coil, and it features easy bottom refilling design. This item also has other color to choose. ![]() Original OneVape Lambo II 12W 360mAh Pod System Starter Kit $24.49 The OneVape Lambo II Pod Kit is updated version of OneVape Lambo Pod kit. the Lambo II is a smarter pod system that comes with two innovative pod cartridges: One pod comes with 1.6ohm cotton coil for regular e-juice, while the other one adopts 1.0ohm ceramic coil which is optimized for CBD oil. Different Coils to meet your different vaping needs easily. What's more, the OneVape Lambo II features new airflow system with side intake, anti-dry, leakproof and airflow split design which effectively prevent fried liquid. Plus, the airflow switch with independent closed channel, the Lambo 2 kit is definitely an excellent device. Consisting of 360mAh built-in battery and 2ml cartridge, the Lambo II is definitely a great daily vape device for vapers. This item also has other color to choose. ![]() Original Ultroner Mini Stick Stabilized Wood Mechanical Mod + Ultroner RDA Kit Original Price $88.80, Now Only $65.99 The Ultroner Mini Stick Mod Kit consists of Ultroner Mini Stick Mech Mod and Ultroner RDA. This item also has other color to choose. Mod: The Ultroner Mini Stick Mod is a high end 18350 mechanical mod that constructed from stainless steel and beautiful stabilized wood. The mod is powered by single 18350 battery (NOT INCLUDED). The fire button is made from Ultem. The mod comes with a lanyard that makes it easy to be carried. RDA: The Ultroner RDA is perfectly suitable for the Ultroner Mini Stick Mod. It has a nice Ultem cap and is easy to build coil on its deck. Please note: the stabilized wood part may be a little color difference due to material. ![]() Original ThunderHead Creations THC Coil Jig Stick $2.59 ThunderHead Creations THC Coil Jig is a compact and handy device for vapers who prefer building their own coils. The coil tool is easy to use: using the numbered guide on the handle of the tool, simply select your preferred size from five different diameters and begin wrapping until you have achieved the desired number of wraps. There are 5 diameters users can choose: 1.5mm, 2.0mm, 2.5mm, 3.0mm, 3.5mm. ![]() Original ThunderHead Creations THC Mutilfunctional Screwdriver for RDA / RTA / RDTA Atomizer $2.99 ThunderHead Creations THC Pro Screwdriver comes with 8 different bits, which can satisfy your different needs on DIY coil building. ![]() Original ThunderHead Creations THC Folding Scissors for DIY Cutting Cotton $2.99 ThunderHead Creations THC folding scissors is used for cutting extra cotton when wicking. It can be folded when not being used. ![]() Original ThunderHead Creations THC Multifunctional Pliers V1 for DIY Coil Building $4.99 ThunderHead Creations THC Multifunctional Pliers V1 is made from stainless steel. It is a convenient tool for adjusting wires when you making your own coils. It also comes with different tools for daily using. ![]() Original ThunderHead Creations THC Multifunctional Pliers V2 for DIY Coil Building $4.99 ThunderHead Creations THC Multifunctional Pliers V2 is made from stainless steel. It is a convenient tool for adjusting wires when you making your own coils. It also comes with different tools for daily using. ![]() Original ThunderHead Creations THC Straight Ceramic Head Tweezers for RDA / RTA / RDTA $3.79 ThunderHead Creations THC Straight Ceramic Head Tweezer can withstand the high temperature when you dry fire your coil. Making coil building so much easier. It is a great and handle tool if you are into rebuildable atomizers. This item also has other Version to choose. ![]() Original ThunderHead Creations THC Diagonal Cutter Pliers for DIY Coil Building $4.99 ThunderHead Creations THC Diagonal Cutter Pliers is made from stainless steel. The handle is made from plastic for comfortable grip. It is a convenient tool for cutting leads of coils, and cutting wires when you making your own coils. ![]() Original ThunderHead Creations THC Pro Screwdriver for RDA / RTA / RDTA Atomizer $4.99 ThunderHead Creations THC Pro Screwdriver comes with 4 different bits, which are PH00, 2.5, H1.27 and H1.50. ![]() Original Syiko SE Replacement Pod Cartridge $9.99 The Syiko SE replacement pod cartridge has 2.0ml of juice capacity and 1.5ohm coil. It is suitable for Original Syiko SE Pod System Starter Kit. This product comes with 5 PCS in 1 pack. This item also has other color to choose.
356
The Hellfire V6 Mechanical Mod Clone is a mini size 18350 mech mod with a diameter of 22mm. This mod is made from 316 stainless steel. It is very easy to carry and suits your palms perfectly. The mod is powered by single 18350 battery (NOT INCLUDED). This item also has other color to choose. ![]() YFTK VWM Integra RTA Rebuildable Tank Atomizer Clone $18.99 The YFTK VWM Integra RTA Clone is a 22mm rebuildable tank atomizer with 4.2ml of juice capacity. It is constructed from 316 stainless steel and PC. It features recessed build deck, reduced evaporation chamber, and various side airflow combinations from tight MTL to restricted DL with the stock AFC ring. ![]() Original Syiko Alita 650mAh Pod System Starter Kit $27.99 Syiko Alita Pod System Starter Kit is powered by built-in 650mAh to support long-time vaping. Syiko Alita has a 0.96 inch TFT HD Screen to display vaping information clearly. Made of PC, Alita Pod comes with 2ml capacity and 1.5ohm resistance. Syiko Alita Pod adopts easy bottom filling design without leakage. This item also has other color to choose. ![]() Original OneVape Golden Ratio 25W 1100mAh Pod System Starter Kit $29.99 OneVape Golden Ratio Kit is a new lightweight and exquisite pod system. It adopts an ergonomic button design for comfortable holding and operating. Powered by built-in 1100mAh battery, the Golden Ratio has a wide output range of 10~25W to meet your different vaping needs. As for the pod, it features 2ml e-liquid capacity and convenient bottom-fill structure, and the side airflow adjustment design. Moreover, the pod features a lock button for pod fixation, which makes the pod cartridge connect with mod stably and safely. This item also has other color to choose. ![]() Original Aimo Mount 400mAh Pod System Starter Kit $20.19 AIMO Mount Pod System Kit features flat shape and ultra tiny size. With its tiny size, 400mAh built-in battery capacity will provide long lasting vaping. AIMO Mount pod kit features magnet connection design, simple and convenient to insert, and It has LED indicator displays battery status. AIMO Mount Pod Kit utilizes ceramic coil, has a stable heat conduction of ceramic coil which brings purer taste. Moreover, it has 1.8ml cartridge capacity and side filling design, which makes it easy to refill without leakage. This item also has other color to choose. ![]() Original Vladdin RE 12W 350mAh Pod System Starter Kit $24.99 The Vladdin Vapor RE is a brand new draw activated Ultra Portable System with 350mAh battery life and has a proprietary pod system with 1.5ml E-Liquid Capacity. The Vladdin has a 12W maximum wattage output and 3.5V output voltage. The ceramic pod systems have an atomizer range of 1.2 to 1.5 ohm. The pods have a removable silicone stopper for refilling located on top of the device covered by the removable tip. E-Liquid is poured on either left or right port; the middle port is the draw port. The 350mAh battery has a charging rate of 0.2 to 0.4V and can be charged through the micro USB port on the bottom of the device. This item also has other color to choose. ![]() Original Vladdin RE Replacement Pod Cartridge $12.99 The Vladdin RE Replacement Pod Cartridge has 1.5ml of juice capacity and 1.2~1.5ohm ceramic coil. It is used with Nicotine Salt E-Liquids. It is suitable for Vladdin RE Pod System Starter Kit. This product comes with 4 PCS in 1 pack.
357
The FEV BF1 Squonker RDA is constructed from 316 stainless steel and with 23mm diameter. The single coil RDA comes with bottom feeder pin for squonker mod. ![]() Original ZQ Vi 13W 650mAh Pod System Starter Kit $23.99 ZQ Vi Pod Kit with the CSA technology, the cellular spiral airflow system gives you smooth flavor and the coil won't easily get burnt. ZQ Vi Pod System Starter Kit represents portable design with built in 650mAh capacity lithium battery and 1.4ohm coil suits several e-juices including general juice for you option. Equipped with 2ml e-liquid capacity pod and gets you better leak-prevention. Included the airflow activation and manual key operation makes a perfect ZQ Vi Pod for you. There are two voltage-adjustable modes, the constant voltage mode can reach to 3.5V output and full power output mode fire up to 4.2V for different people are based on their juice. The ZQ Vi Pod Kit adopts intelligent smart chip protection system with multiple protection modes for vaping safety. Moreover, ZQ Vi Pod features two magnetic connector that is easy to take off and get replacement of pod. This item also has other color to choose. ![]() Original ZQ Assure 450mAh Pod System Starter Kit $30.99 ZQ Assure Pod System Kit is powered by built-in 450mAh battery and has beautiful and durable metallic finishes. This pod features an easy side-fill solution and is leakage-free. Offering great convenience and portability, ZQ Assure pod is a great option for vapers on the go or simply looking for an easy to use vape. This item also has other color to choose. ![]() Original OVNS W01 4.2W 280mAh Pod System Starter Kit $11.19 OVNS W01 Pod Vape Kit is powered by 280mAh built-in battery. It is of light weight and easy to be carried around. The OVNS W01 Pod Kit also features 4 protection functions: Overcharge, low voltage, weak current and short circuit. The pod has 0.7ml juice capacity and 1.8ohm coil. This item also has other color to choose. ![]() Original Coil Father POP 600mAh Pod System Starter Kit $11.55 Coil Father POP POD is a newly designed device with button-triggered pod system. It is fashionable and portable, with battery capacity as big as 600mAh battery. POP POD comes with a 2ml juice capacity and 1.6ohm coil, one of the most preferred coil for MTL users. It is easy to use, and friendly for beginners. This item also has other color to choose. ![]() Original ZQ Vi Replacement Pod Cartridge $3.99 The ZQ Vi Replacement Pod Cartridge can hold 2ml of juice capacity and comes with 1.4ohm coil. It is suitable for ZQ Vi Pod System Stater Kit. 1pc per pack. ![]() Original Coil Father POP Replacement Pod Cartridge $4.49 The Coil Father POP Replacement Pod Cartridge can hold 2ml of juice capacity and comes with 1.6ohm coil. It is suitable for Coil Father POP Pod System Stater Kit. This product comes with 3 PCS in 1 pack.
358
Overlord Hybrid Mechanical Tube Mod Clone $18.58
The Overlord Hybrid Mechanical Tube Mod Clone is constructed from brass. The battery contact is made from silver-plated copper. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED) ![]() TF Scarab Pro 23mm Mechanical Mod Clone $29.39 The TF Scarab Pro Mechanical Mod is constructed from Stainless Steel and powered by 1 x 18350 / 18650 battery (not included). The is with Electronic key lock for SHORT-TERM deactivation button. This item also has other color to choose. ![]() Original ThunderHead Creations THC Tauren Max Hybrid Mechanical Tube Mod Original Price $139.00, Now Only $53.99 The TAUREN MAX Mech Mod is a new and exciting addition to the TAUREN family from ThunderHead Creations (THC). It comes with unique 360-degree contact and lockable ball fire button which can provide safe and instant vaping experience. It can also work with single 20700/21700 and 18650 battery with an adaptor (BATTERY NOT INCLUDED). What's more, TAUREN MAX adopts advanced surface painting technology with ergonomic handshake design. Waterproof / Shockproof / Dustproof button design for maximum button service life. This item also has other color to choose. ![]() Original Kamry X 650mAh Pod System Starter Kit $22.29 The Kamry X pod starter kit comes with a fashionable and ergonomic car shape design which represent for youth. Constructed by aluminium alloy and intelligent board, the Kamry X is durable and safe with multiple safe protections. The Kamry X Pod is powered by 650mAh inbuilt battery, and the cartridge comes with 2ml capacity and 1.4ohm resistance. What's more, the Kamry features MTL and DTL vaping for your option. Mouth vaping is with silicone cover. And lung vaping is without the silicone cover. The portable X pod gives you huge vapor and good taste. This item also has other color to choose. ![]() Original Pomp Tetris 400mAh CBD Pod System Starter Kit $18.99 POMP Tetris Pod Kit is a safe and clean pod system device. It adopts the unique VPOCERA Zisha ceramic coil, which is designed for vape oil with customized heating wire and increased heating area. It also has customized features such as preheating and 3 optional output (Powerful/Normal/Soft) Modes. It is powered by 400mAh built-in battery for meeting the vaping needs of your whole day. The pod is designed with easy top filling. Plus the L-type oil-air separation structure design, it brings good taste and effectively solves the leakage problems. And it can be fully charged after being connected to the power supply for 40 minutes. There are 5-in-1 safety features ensuring your safety and avoiding any mishaps. This item also has other color to choose. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.59 The replacement 510 drip tip is made from PC. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.99 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This item also has other color to choose.
359
Original Yosta Ypod Mini 310mAh Pod System Starter Kit Original Price $18.99, Now Only $13.95
Yosta Ypod Mini Kit is the latest member of the Ypod family. It has a more exquisite appearance and slim body which just fits into your hand with comfortable hand feeling. Powered by a built-in 310mAh battery, it is free of any buttons or screens to extend the battery life while introducing a draw-activated firing mechanism. Located on the top is a "V" cut-out that acts as a juice view-port when the replaceable pod is implemented on. In the middle of the kit is an intelligent LED battery life indicator, which will show you the battery level clearly. The cartridge comes with a duck-billed mouthpiece, it can fit your mouth perfectly, giving you more convenience when vaping. And there is a 1.3ohm and 1.5ohm ceramic coil included in each set, so whether you like nicotine salt e-juice or CBD oil, the kit is always capable. This item also has other color to choose. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.99 The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose. ![]() Original Pomp Tetris CBD Replacement Pod Cartridge $3.99 The Pomp Tetris CBD Replacement Pod Cartridge can hold 0.5ml of juice capacity and comes with 1.5ohm coil. It is suitable for Pomp Tetris CBD Pod System Stater Kit. This product comes with 4 PCS in 1 pack. ![]() Original Vapmod Rock 710 650mAh CBD Battery Mod Vaporizer $12.99 Vapmod Rock 710 Battery Mod is made of PC and Leather. It is very comfort grip in hand and light weight. With a 510 connector, it is compatible with oil atomizer and wax atomizer. You will enjoy cool and different vaping experience. It is powered by 650mAh built-in battery and features adjustable 4-level voltage. What's more, the Rock 710 Battery also has smart preheating function. This item also has other color to choose. ![]() Original Yosta Ypod Mini Replacement Pod Cartridge Original Price $9.99, Now Only $7.25 The Yosta Ypod Mini Replacement Pod Cartridge can hold 1ml of juice capacity and comes with 1.3ohm ceramic coil. It is suitable for Yosta Ypod Mini Pod System Stater Kit. This product comes with 4 PCS in 1 pack. ![]() Original Vapor Storm V1 Tool Kit for E-Cigarettes DIY Coil Building $8.99 The Original Vapor Storm V1 Tool Kit is a multi-functional tool kit designed for vape. The kit includes many useful tools that can be used for coil building, wicking, adjusting. It will be a great helper for DIY lovers.
360
Original Ehpro M101 Sub Ohm Tank Clearomizer Original Price $28.10, Now Only $19.65
Ehpro M101 Sub Ohm Tank is a 25mm clearomizer with 2ml / 3ml of juice capacity. Designed by Ehpro, the M101 Tank utilizes the innovative EL1B-2 0.3ohm mesh coil to extend the lifespan of coil to a new level. The tank also features easy top refill and bottom airflow. This item also has other color to choose. ![]() Original Vandy Vape Jackaroo Replacement Glass Tank Tube $2.69 The replacement glass tank tube has 3.5ml of juice capacity and is suitable for Vandy Vape Jackaroo Tank. This item also has other Version to choose. ![]() Original Ehpro M101 Replacement Mesh Coil Head Original Price $13.10, Now Only $9.27 The Ehpro M101 Replacement Mesh Coil Head features 0.3ohm resistance and works well at 30~50W. It is suitable for Original Ehpro M101 Tank. This product comes with 4 PCS in 1 pack. ![]() Original Wotofo Xfiber Cotton for Profile RDA / Profile Unity RTA Original Price $6.99, Now Only $3.42 Wotofo's brand new organic cotton wick has come out now! The Wotofo Xfiber cotton series! Your next level of wicking experience starts here with the 6mm thick agleted cotton strips for Profile. The Xfiber Cotton for Profile is an upgraded version of Wotofo Agleted Cotton 6mm. It is electro-cleaned, being truly odorless by healthy purification process. Wotofo Xfiber Cotton for Profile provides you with fast cotton preparation for your rebuilding convenience. The cotton we selected are of long fibers so that it wicks smooth and its not easy to pull apart. To enhance the fiber strength, multi-fiber blends are adopted. There are 10 strips in one little box. Each cotton strip is ready-to-use with proper cotton amount especially for the Profile mesh RDA or RTA.
