Просмотров в теме 298099   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 14.03.2019, 05:31 Автор темы   321
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
SXK Billet Box 70W All-in-One Box Mod Kit Clone with USB Port Original Price $75.00, Now Only $69.99
The SXK Billet Box Mod Kit Clone is constructed from aluminum with an all-in-one design. This mod comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor.
This Billet Box comes with USB port for charging only. This item also has other color to choose.
Original Yocan Hive 2.0 650mAh CBD Vaporizer Starter Kit $18.99
The Yocan Hive 2.0 is a special device box mod kit that fits for juice and concentrate with concentrate atomizer and juice atomizer included. The concentrate atomizer is with the quartz coil, which provide with the purest experience and guarantee a crystal clean essence. The juice atomizer is a top fill unit with No-leakage design. Provide premium method for vaporizing your favorite juice. This item also has other color to choose.
Original Yocan Evolve Plus XL 1400mAh Quad Coil All-in-One Starter Kit $25.99
The Yocan Evolve Plus XL Kit is a compact and portable starter kit that features a unique Quad Coil technology using a 4 quartz rod coil, which is designed for cloud chaser. The adjustable airflow valve allows you to control the amount of vapor being inhaled to optimize the experience for any advanced vaper or beginner. The kit is powered by 1400mAh built-in battery. It can be easily carried with a lanyard. This item also has other color to choose.
Kingtons Black Widow 2200mAh TC Vaporizer Clone $37.99
The Kingtons Black Widow Vaporizer is a temperature control vaporizer for dry herb or wax. It is powered by built-in 2200mAh battery and can work for 1 hour. The temperature can be set from 356 to 428 Fahrenheit degrees. It features fast heating time and ceramic chamber to bring great flavor. This item also has other color to choose.
Kingtons Black Mamba 1600mAh TC Vaporizer Clone $33.99
3FVAPE вне форума   Вверх
Старый 15.03.2019, 04:52 Автор темы   322
3FVAPE
ShenRay TF Scarab Pro 25mm Mechanical Mod Clone $38.00
The ShenRay TF Scarab Pro Mechanical Mod Clone is constructed from Stainless Steel and powered by 1 x 18350 / 18650 / 20700 / 21700 battery (not included). The is with Electronic key lock for SHORT-TERM deactivation button. This item also has other color to choose.
Original YouDe UD Rosary Tank Clearomizer Original Price $20.99, Now Only $7.99
The YouDe UD Rosary Tank Clearomizer Atomizer is constructed from stainless steel with 22mm diameter. The glass tank is with 3ml capacity. This item also has other color to choose.
Original Youde UD Anzu RDA Rebuildable Dripping Atomizer Original Price $20.99, Now Only $6.99
The Youde Anzu RDA is a rebuildable dripping atomizer with 22mm diameter. It is made from Stainless Steel. Comes with dual-post deck, top and bottom airflow holes, the Anzu RDA Clone will bring you a wonderful vaping experience. This item also has other color to choose.
Original YouDe UD Simba RTA Rebuildable Tank Atomizer Original Price $20.99, Now Only $7.99
The YouDe UD Simba RTA Tank features a ceramic coil without cotton, double protection of preventing condensation, juice flow control ring, top and bottom AFC. Simba brings the best flavor and great cloud to you. With RBA head, you can DIY your own coils with different materials.
ShenRay FEV BF-1 RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99
The FEV BF1 Squonker RDA is constructed from 316 stainless steel and with 23mm diameter. The single coil RDA comes with bottom feeder pin for squonker mod.
Original SMOKTech SMOK MORPH 219W TC VW Box Mod Kit + TF2019 Tank Standard Edition $63.99
The SMOK Morph 219 kit, an outstanding example of top-notch craftsmanship and advanced technologies. It is the world's first mod designed with input keyboard, which is a revolutionary change for mod operation! It also improved the inner chip, shortening firing time to 0.001S! As for screen, its 1.9" touch screen can offer you convenient operations. Its max output power is 219W, easily to satisfy the cloud chasers. TF2019 tank is included in this kit, with 6ml e-liquid capacity and two powerful coils, it would provide best flavor and cloud. Innovation keeps changing the vaping experience! This item also has other color to choose.
Original SMOKTech SMOK Trinity Alpha Resin 1000mAh Pod Starter Kit Standard Edition $30.99
Trinity Alpha, the new open pod system by SMOK, is in the shape of square box featuring one 1000mAh internal battery and two Nord Mesh coils, boasting many novel features to deliver diversified vaping pleasures. The colorful flowing resin streaks on both sides add a touch of radiance to the device which shows its meticulous attention to detail and a fine combination of vape and art. The device has implemented an ingenious output preference function-ality offering three power modes. As for its pod, it adopts an ingenious slide-to-open type design on its filling cap to ensure everyday long-lasting vaping with a maximum e-liquid capacity of 2.8ml. Innovation keeps changing the vaping experience! This item also has other color to choose.
Original SMOKTech SMOK Replacement Ceramic Coil Head for Nord Pod System Kit / Trinity Alpha Kit $13.99
The SMOK Nord Replacement Ceramic Coil head features 1.4ohm resistance. It is suitable for Original SMOKTech SMOK Nord Pod System Kit and Trinity Alpha Kit. This item also has other Version to choose.
Original SMOKTech SMOK Trinity Alpha Kit Replacement Pod Cartridge + Nord MTL 0.8ohm Coil + Mesh 0.6 Coil Ki $13.99
Original SMOKTech SMOK Replacement BF-Mesh Coil for MORPH 219 Kit / TF2019 Sub Ohm Tank $8.99
The SMOK BF-Mesh Coil is with 0.25 ohm resistance and suitable for MORPH 219 Kit / TF2019 Sub Ohm Tank.
Please Note: This is the standard version. This item also has other Version to choose.
Старый 18.03.2019, 04:53 Автор темы   323
3FVAPE
1:1 Hammerhand Hybrid Mechanical Tube Mod Clone $14.29
The Hammerhand Mechanical Mod Clone is made from brass with hybrid connection. It is powered by single 18650 battery (NOT INCLUDED). The mod comes with spring fire button and it can be locked to avoid mis-firing. This mod is made at 1:1 scale.
TF Scarab Pro 25mm Mechanical Mod Clone $33.99
The TF Scarab Pro Mechanical Mod is constructed from Stainless Steel and powered by 1 x 18350 / 18650 / 20700 / 21700 battery (not included). The is with Electronic key lock for SHORT-TERM deactivation button. This item also has other color to choose.
Original Steam Crave Aromamizer Lite RTA 23mm Rebuildable Tank Atomizer $33.39
The Steam Crave Aromamizer Lite RTA atomizer is constructed from stainless steel and with 23mm diameter. The RTA comes with 3.5ml glass tank and 4.5ml bubble glass tank. The RTA is with flavor Chasing Single Coil deck for Restricted DL & MTL vaping. This item also has other color to choose.
Kindbright Caiman MTL RDA Rebuildable Dripping Atomizer Clone with BF Pin $20.99
The Kindbright Caiman RDA Clone is a 22mm RDA designed for MTL vaping. Constructed from 316 stainless steel, it comes with dual posts for easy coil building. The RDA has 5 airholes at both sides for adjustable bottom airflow. Besides, the airflow control set can be replaced with different one for different experience.
This RDA comes with bottom feeder pin.
KF Lite 2019 RTA Rebuildable Tank Atomizer Clone $9.79
The KF Lite 2019 RTA Clone is a 22mm rebuildable tank atomizer with 2ml of juice capacity. It is made from stainless steel and PC. It is designed for mouth to lung vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience.
This RTA comes with 2 spare extension tank tube (PC). This item also has other color to choose.
Original Henrui Alameda C1 650mAh CBD Vaporizer Starter Kit $12.99
The Henrui Alameda C1 is a CBD Vaporizer that is powered by built-in 650mAh battery. The atomizer is 10mm diameter and with 0.5ml of juice capacity. It is compatible with CBD oil. The battery comes with LED indicator. The colorful cover makes the Alameda C1 more stylish. This item also has other color to choose.
Replacement Long Mode Tank Kit for 22mm KF Lite 2019 RTA Clone $2.99
The replacement Long Mode Tank Kit is made from PC and is suitable for 22mm KF Lite 2019 RTA Clone. It has 4ml of juice capacity. This item also has other Version to choose.
Replacement Dome Extension Tank Kit for 24mm KF Lite 2019 RTA Clone $4.49
The replacement Dome Extension Tank Kit is made from PEI and is suitable for 24mm KF Lite 2019 RTA Clone. It has 5ml of juice capacity.
Original Steam Crave Glaz RDSA V1.1 Replacement Glass Top Cap $5.99
The replacement Glass Top Cap is suitable for Original Steam Crave Glaz RDSA V1.1.
This product comes with 2 PCS in 1 pack.
Original Steam Crave Glaz RDSA V1.1 Replacement Metal Top Cap $9.39
The replacement Metal Tpp Cap is suitable for Original Steam Crave Glaz RDSA V1.1.
Original Steam Crave Glaz RDSA V1.1 Replacement Silicone Mouth Tip Cap $0.99
The replacement Silicone Mouth Tip Cap is suitable for Original Steam Crave Glaz RDSA V1.1.
Original Steam Crave Glaz RTA V2 Replacement Glass Tank Tube $2.99
The replacement 7ml glass tank tube is suitable for Original Steam Crave Glaz RTA V2.
This product comes with 2 PCS in 1 pack. This item also has other Version to choose.
Original Steam Crave Glaz RTA V1 / V2 Replacement Dual Coil Deck $9.39
The replacement dual coil deck is suitable for Original Steam Crave Glaz RTA V1 / V2.
Original Steam Crave Aromamizer Lite Replacement Single Coil Deck $7.89
The replacement single coil deck is suitable for Original Steam Crave Aromamizer Lite RTA.
Старый 19.03.2019, 05:10 Автор темы   324
3FVAPE
Overlord Hybrid Mechanical Tube Mod Clone $24.89
The Overlord Hybrid Mechanical Tube Mod Clone is constructed from copper. The battery contact is made from silver-plated copper. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). The mod was made at 1:1 scale. This item also has other color to choose.
YFTK Noname Oldboy Hybrid Mechanical Tube Mod Clone $30.49
The YFTK Noname Oldboy Hybrid Mechanical Tube Mod Clone is constructed from 316 stainless steel and brass. The mod is powered by single 18650 battery (NOT INCLUDED). It is compatible with 24mm atomizers.
Dvarw MTL RTA Rebuildable Tank Atomizer Clone $10.99
The Dvarw MTL RTA Clone is a 16mm RTA made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. The kit comes with 4 spare airflow inserts to adjust airflow. This RTA will bring you extreme MTL vaping experience.
The airflow insert come with 1 x 0.3mm / 2 x 0.3mm / 3 x 0.3mm / 2 x 0.5mm airhole size. This item also has other color to choose.
Ulton FEV BF-1 RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99
The Ulton FEV BF1 Squonker RDA Clone is constructed from 316 stainless steel and with 23mm diameter. The single coil RDA comes with bottom feeder pin for squonker mod.
Ulton Daywon RDA Rebuildable Dripping Atomizer Clone with BF Pin + 24mm Beauty Ring $12.99
The Ulton Daywon RDA Clone is a 22mm rebuildable dripping atomizer. The design is good for pushing nice and simple coil clamps over to one side that are insulated with a nice colourful hit of Ultem. Inner hourglass shaped walls perfectly house your wick leads and help condense the chamber to maximize flavor and vapor production.
Original Kamry X2 320mAh CBD Pod System Starter Kit $13.99
The Kamry X2 is a compact vape kit designed for CBD oil. It is powered by built-in 320mAh battery and has a 1.5ml pod with 1.6ohm ceramic coil. This kit will bring you great vaping experience. This item also has other color to choose.
Original Henrui Cito C2 400mAh 2-in-1 CBD Wax Vaporizer Starter Kit $20.99
The Henrui Cito C2 is a 2-in-1 Vaporizer Kit designed for both CBD oil and wax. It is powered by built-in 400mAh battery. There are four shift pressure: 4.0V/3.8V/3.6V/3.4V. It can be compatible with atomizer from 9.2mm to 12.5mm. The oil cartridge comes with ceramic coil, while the wax cartridge comes with Quartz coil. This item also has other color to choose.
Original Henrui Liky C3 400mAh 2-in-1 CBD Wax Vaporizer Starter Kit $14.99
The Henrui Liky C3 is a 2-in-1 Vaporizer Kit designed for both CBD oil and wax. It is powered by built-in 400mAh battery. There are four shift pressure: 4.0V/3.8V/3.6V/3.4V. It can be compatible with atomizer from 9.2mm to 12.5mm. The oil cartridge comes with ceramic coil, while the wax cartridge comes with Quartz coil (wax cartridge NOT INCLUDED). This item also has other color to choose.
Original Kamry Replacement Heat Blade for GXG I2 Vaporizer $4.99
The replacement heat blade is suitable for Kamry GXG I2 Heat Not Burn Device Vaporizer.
Original Magic Shark Soul Eater Hand Spinner Fidget Toy EDC $10.99
The Original Magic Shark Soul Eater Hand Spinner is constructed from stainless steel. The spinner is a small spinning device designed to keep your hands busy and your mind focused. It is pocket sized and can be spun in one hand by using the other hand to rapidly spin it from small continuous strikes. Great for people with Fidgety hands, ADHD, Anxiety & OCD sufferers. The bearing is R188 and made from stainless steel, with size of 12.6 x 4.7mm (diameter x height).
810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $10.99
The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.
This product comes with 8 PCS in 1 pack.
Original Vapesoon VSC Dual Open HEETS Heatsticks Cartridge Case $9.79
The Vapesoon VSC Cartridge Case is designed to carry HEETS, Heatsticks. It can carry 20 PCS. It features dual open design, mini size and hard box.
SXK Replacement Chip with MOSFET for Atto Mechanical Mod Clone $4.99
The replacement chip is suitable for SXK Atto Mechanical Mod Clone. It comes with MOSFET.
Старый 20.03.2019, 05:28 Автор темы   325
3FVAPE
Original Vapemons Magic Mod 228W TC VW Variable Wattage Box Mod Original Price $49.00, Now Only $34.99
Vapemons Magic Mod is compatible with dual 18650 battery (NOT INCLUDED). When using the 18650 battery, its max wattage can reach up to 228W. Vapemons Magic Mod features 0.005s fire speed, multiple modes (VW/TC/CCW/Smart/Bypass/CCT). Made of Zinc alloy, this mod is compact and lightweight. The mod comes with 0.96inch HD OLED display and fast 2A quick charge function. This item also has other color to choose.
Original Wismec Luxotic Surface 80W TC VW Squonk Box Mod $42.29
Wismec Luxotic Surface, the smallest squonk box with 0.49inch OLED screen, is compact and ergonomic enough to lead the vaping industry. Powered by single replaceable 18650 cell (NOT INCLUDED), Wismec Luxotic Surface is capable of firing up to 80W, offering you more powerful output than ever. This item also has other color to choose.
Noname Oldboy Hybrid Mechanical Tube Mod Clone $23.99
The Noname Oldboy Hybrid Mechanical Tube Mod Clone is constructed from stainless steel and brass. The mod is powered by single 18650 battery (NOT INCLUDED). It is compatible with 24mm atomizers.
SXK Corinne Hybrid Mechanical Tube Mod Clone $14.99
The SXK CorinneMechanical Mod Clone is a mini size 18350 mech mod with a diameter of 22mm. This mod is made from 316 stainless steel. It is very easy to carry and suits your palms perfectly. The mod is powered by single 18350 battery (NOT INCLUDED).
Original Vapemons X2 Mesh Sub Ohm Tank Clearomizer $14.99
The Vapemons X2 tank is compatible with TFV8 baby coil has the 5ml capacity and hyper engines, which can bring you massive vapor. Besides, the tank's patented locking mechanism can effectively solve the leakage problem. This item also has other color to choose.
Original Wismec Kestrel RDTA Rebuildable Dripping Tank Atomizer $26.29
Wismec Kestrel, an innovative RDTA, features its brand-new mesh heater design with larger heating area for optimal flavor and vapor cloud. It has 4ml of juice capacity. This item also has other color to choose.
Original Advken Dark Mesh Sub Ohm Tank Clearomizer Original Price $39.99, Now Only $26.19
Advken Dark Mesh Sub Ohm Tank adopts 0.15ohm Triple Mesh Coil (80~110W) and 0.15ohm Single Mesh Coil (50~80W), together with adjustable bottom airflow, bringing excellent vaping experience for you. It also features top slide filling design, easy to refill and prevent leakage. The tank comes with different juice capacity which is up to the coil you used, Triple Mesh Coil is for 5ml, while Single Mesh Coil is for 6ml. This item also has other color to choose.
Original Wismec Luxotic Surface 80W TC VW Squonk Mod + Kestrel RDTA Kit $61.29
The Wismec Luxotic Surface Kit consists of Wismec Luxotic Surface Mod and Kestrel RDTA. This item also has other color to choose.
Mod:
Tank:
With WISMEC LUXOTIC SURFACE Kit in hand, squonking has never been so simple.
Original Vapemons X2 Replacement Mesh Coil Head $9.99
The Replacement Mesh Coil Head features 0.15ohm resistance and works well at 40~90W. It is suitable for Original Vapemons X2 Mesh Tank.
This product comes with 5 PCS in 1 pack.
Original Advken Dark Mesh Replacement Single Mesh Coil Head $12.50
The Replacement Single Mesh Coil Head features 0.15ohm resistance and works well at 50~80W. It is suitable for Original Advken Dark Mesh Tank.
This product comes with 3 PCS in 1 pack.
Original Advken Dark Mesh Replacement Triple Mesh Coil Head $14.99
The Replacement Triple Mesh Coil Head features 0.15ohm resistance and works well at 80~110W. It is suitable for Original Advken Dark Mesh Tank.
Старый 21.03.2019, 06:08 Автор темы   326
3FVAPE
Original Dovpo Nickel 230W TC VW Variable Wattage Box Mod $42.19
The Dovpo Nickel 230W box mod has multiple features for different vaping experience and taste. Vapers can easily adjust the settings according to their taste and enjoy the vaping experience with the Nickel. The mod has full Zinc alloy body with PC material on both sides. The inner structure is made from plastic and the mod have ventilation on side and bottom, so Nickel stays cool all the time while vaping. It has wattage mode, Titanium, Nickel, Stainless Steel and TCR in Temperature Control Mode, apart from that it offers some more key features like you can choose normal, soft, hard and user preheat options on top of the variable features. This item also has other color to choose.
Vapeasy Gem Light Mini Gem LM RTA Rebuildable Tank Atomizer Clone $18.99
The Vapeasy Gem Light Mini RTA Clone is made from 316 stainless steel and glass. It features 2ml capacity, dual post build deck for single coil build and bottom airflow for great flavor. It has the possibility to adjust the air flow between 0mm and 2.5mm, the AFC system is unique and has a very reduced vapor chamber. The tank has two top fill holes, in order to make it easier for the user to fill it. This RTA was made at 1:1 scale.
SXK FLVR RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $15.90, Now Only $12.99
The SXK FLVR RDA Clone is made from 316 stainless steel with 22mm diameter. It is a single coil RDA that will be able to accommodate various coil sizes. The deck has 3 air holes at both sides to allow the airflow to hit the coil directly. The juice well is deep enough to hold some amount of e-juice. The RDA comes with bottom feeder pin. This item also has other color to choose.
Original Innokin DV 500mAh 15W Pod System Starter Kit $26.75
The Innokin D.V. is an ultra-light and compact refillable pod system vaporizer with PLEX3D 3D Mesh Coils that is designed to deliver a superior Daily-Vape experience. Perfect for on-the-go vaping, the stealthy and sleek DV is comfortable to hold and features a distinct cutting-edge design. Enjoy automatic Puff to vape activation with DV Auto-draw or push the power button to vape great! Stylish and beautiful, the LED at the base lights up with every delicious puff. This item also has other color to choose.
Original Voopoo Finic Fish 350mAh 12W Pod System Starter Kit $20.29
Voopoo Finic Fish Pod Kit is an ultra-portable pod system kit with fish shaped design. It adopts GENE Pod Chip to control voltage output intelligently. The pod cartridge features open juice refill system, easy to operate in one step. It is also perfectly compatible with Nic-salts e-juice with unique 1.6ohm coil. This item also has other color to choose.
Original OBS Cube Mini Resin 1500mAh Starter Kit Original Price $54.90, Now Only $35.89
The OBS Cube Mini Kit consists of OBS Cube Mini Mod and OBS Cube Mini Tank. This item also has other color to choose.
Mod:
The OBS Cube Mini, aimed for MTL vape with low power output, features a 1500mAh built-in battery for long life-span. The big and responsive round button on the Cube Mini Mod makes operation easier than ever. The 3 color LED light below the button tells you the status of battery too.
Tank:
As for the Cube Mini Tank, it comes with 3.0ml juice capacity to meet you own vaping needs. The innovative cores of Cube Mini Tank will fit juices of different strength. The tank adopts top filling system and bottom airflow via three tiny holes.
Original SMOKTech SMOK Trinity Alpha Kit Replacement Pod Cartridge $5.14
SMOK Trinity Alpha Pod Cartridge is designed for SMOK Trinity Alpha Pod Kit. It comes with 2.8ml juice capacity. The pod cartridge is locked by a lock button. Enjoy portability, simplicity, and your liquid of choice with this awesome Trinity Alpha Pod Cartridge from Smok today! 1 piece each pack. This item also has other color to choose.
Original Innokin DV Replacement Pod Cartridge $13.39
The Innokin DV Replacement Pod Cartridge can hold 2.8ml of juice capacity and comes with 0.5ohm coil. It is suitable for Innokin DV Pod System Stater Kit.
This product comes with 5 Packs, each pack comes with 1 pod cartridge.
Original Voopoo Finic Fish Replacement Pod Cartridge $10.59
The Voopoo Finic Fish Replacement Pod Cartridge can hold 1.7ml of juice capacity and comes with 1.6ohm coil. It is suitable for Voopoo Finic Fish Pod System Stater Kit.
This product comes with 4 PCS in 1 pack.
Original OBS Cube Mini Replacement S1 Mesh Coil Head Original Price $15.00, Now Only $9.99
The OBS Cube Mini Replacement S1 Mesh Coil Head features 0.6ohm resistance. It is suitable for Original OBS Cube Mini Resin Kit / OBS Cube Mini Tank.
This product comes with 5 PCS in 1 pack. This item also has other Version to choose.
Старый 22.03.2019, 05:42 Автор темы   327
3FVAPE
Original IJOY Captain Resin 200W TC VW Variable Wattage Box Mod Original Price $69.99, Now Only $42.55
Powered by dual 18650 / 20700 batteries (NOT INCLUDED), the IJOY Captain Resin Mod can reach a max 200W power. Captain Resin Mod features an ergonomic chassis with large 0.96 inch OLED Screen and beautiful resin panel in the back for an overall stunning looking. This item also has other color to choose.
Original Tesla Teslacigs Invader 4X 280W VV Variable Voltage Box Mod Original Price $43.90, Now Only $35.99
Teslacigs Invader 4X Mod was adopted with lightweight material to made it portable. It has a novel appearance with 5 sharp claws on the panel. Powered by dual 18650 batteries (NOT INCLUDED), this mod can reach a maximum output power to 280W. The potentiometer becomes larger for easy voltage regulation, and it has 5 levels to be adjusted. This item also has other color to choose.
Reload S RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.68
The Reload S RDA Clone measures 24mm in diameter with a build-friendly postless deck designed for single and dual coil configurations. Featuring a dual adjustable top airflow system, this RDA integrates internal honeycomb airflow holes which provides a satisfyingly smooth draw. In addition, the featured internal honeycomb airflow holes direct airflow to the side and bottom of the coil for optimal flavor and vapor production.
This RDA comes with bottom feeder pin. This item also has other color to choose.
ShenRay FEV BF-1 RDA Rebuildable Dripping Atomizer Clone with BF Pin $16.99
Original Voopoo Finic 16 12W AIO Starter Kit $19.59
Voopoo Finic 16 Kit is an all-in-one starter kit with portable size and exquisite appearance which gives you great vaping experience. Powered by built-in 850mAh battery, the max output can reach up to 12W. Ergonomic design on drip tip to give you smoother vaping experience. Adopted YC-R2 regular coil and YC-C ceramic coil inside, not only ensure long life span, but also give you rich flavor to experience. Moreover, the kit is equipped with GENE chip and adopted with patented child safety lock to offer you stable and safe vaping. This item also has other color to choose.
Original Voopoo Finic 20 22W AIO Starter Kit $26.59
Voopoo Finic 20 Kit is an all-in-one starter kit with portable size and exquisite appearance which gives you great vaping experience. Powered by built-in 1500mAh battery, the max output can reach up to 22W. Ergonomic design on drip tip to give you smoother vaping experience. Adopted YC-R1 and YC-R2 coil inside with multiple cellular air intake design, not only ensure long life span, but also give you rich flavor to experience. Moreover, the kit is equipped with GENE chip and adopted with patented child safety lock to offer you stable and safe vaping. This item also has other color to choose.
Original IJOY Captain Resin 200W TC VW Box Mod + Captain Resin Tank Kit Original Price $79.99, Now Only $54.19
IJOY Captain Resin Kit consists of Captain Resin 200W Box Mod and Captain Resin Sub Ohm Tank. This item also has other color to choose.
Mod:
Tank:
The Captain Resin Tank, comes with newly Mesh series coil, and it is also compatible with IJOY Katana / Diamond / Captain X3 Replacement Coil. Equipped with large 6ml e-juice capacity, retractable top filling system and adjustable bottom airflow, you will acquire a superior vaping experience.
Original Teslacigs Invader 4X 280W VV Variable Voltage Box Mod + Invader 4X RDA Kit Original Price $53.90, Now Only $43.59
The Teslacigs Invader 4X Kit consists of Invader 4X Mod and Invader 4X RDA. This item also has other color to choose.
Mod:
RDA:
Teslacigs Invader 4X RDA is a 25mm rebuildable dripping atomizer that features an easy-to-build deck for dual coil configurations. The adjustable airflow provides you with optimal flavor. With resin wide bore drip tip, this RDA looks more attractive.
YFTK Replacement 510 Drip Tip for TROYA MV2 MTL RTA Clone $4.15
The replacement 510 drip tip is made from PC. It is suitable for YFTK TROYA MV2 MTL RTA Clone and all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose.
YFTK Replacement 510 Drip Tip + Tank Tube for TROYA MV2 MTL RTA Clone $7.95
The replacement tank tube is made from PC and is suitable for YFTK TROYA MV2 MTL RTA Clone.
YFTK Replacement Tank Tube for 22mm KF Lite 2019 RTA Clone $5.59
The replacement tank tube is made from PC and is suitable for 22mm YFTK KF Lite 2019 RTA Clone.
Original Voopoo Finic Replacement YC-C Ceramic Coil Head $10.59
The Voopoo Finic Replacement YC-C Ceramic Coil Head features 1.6ohm resistance. It is suitable for Original Voopoo Finic 16/20 starter kit.
Старый 23.03.2019, 04:56 Автор темы   328
3FVAPE
Evade Hydro RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99
The Evade Hydro RDA Clone is a 22mm rebuildable dripping atomizer that comes with a single coil deck and side airflow right at the middle, which hits the coil directly, bringing you great flavor. The knurled base helps you to take the top cap out easily.
Original 528 Customs Goon RDA Rebuildable Dripping Atomizer with BF Pin Original Price $52.00, Now Only $28.99
The 528 Customs Goon 25mm RDA is constructed from stainless steel in 25mm diameter. The Goon 25mm RDA comes with Larger build space vertically and horizontally than the Goon V1 and V1.5. The RDA also features original V1 style airflow, Ultem inner sleeve to help cut down on heat to the drip tip, and domed interior top cap for better flavor. This RDA comes with bottom feeder squonk pin.
This product comes with serial number. This item also has other color to choose.
Original Vapor Storm M1 800mAh VV CBD Starter Kit Original Price $12.50, Now Only $11.59
The Vapor Storm M1 Kit consists of Vapor Storm M1 Mod and M1 CBD Atomizer. This item also has other color to choose.
Mod:
The Vapor Storm M1 Mod is a portable device designed for CBD vaping. It has 3-level adjustable voltage, which is 3.4V, 3.7V and 4.2V. The mod is compatible with atomizer with diameter less than 12mm. Powered by built-in 800mAh battery, this mod also supports fast balance charging. Made from durable ABS material, this mod is very lightweight and easy to carry.
Tank:
The Vapor Storm M1 Tank is a CBD atomizer that is suitable for CBD oil. It has 0.5ml of juice capacity and a coil with 1.8ohm resistance.
Original VapeCige VTX 480mAh VV Pod System Starter Kit $19.25
VapeCige VTX Pod System Starter Kit is a variable voltage pod kit made from durable PETG and zinc alloy. The kit is powered by built-in 480mAh battery. The pod cartridge has 2.5ml of juice capacity and a ceramic coil. VapeCige VTX Pod Kit can be adjusted from 3.2V to 4.2V and come with LED light indicator. Moreover, it has multiple protections to offer you a safe vaping. This item also has other color to choose.
Replacement Window Section + 510 Drip Tip Kit for KF Lite 2019 24mm RTA Clone $2.99
The Replacement Window Section & 510 Drip Tip Kit is made from PC and is suitable for KF Lite 2019 24mm RTA Clone. This item also has other color to choose.
Original VapeCige VTX Replacement Pod Cartridge $6.54
The VapeCige VTX Replacement Pod Cartridge has 2.5ml of juice capacity and is suitable for VapeCige VTX Pod System Starter Kit.
Старый 25.03.2019, 05:44 Автор темы   329
3FVAPE
Original Vapmod Magic 710 380mAh CBD Battery Mod $11.99
Vapmod Magic 710 CBD Battery Mod is a discreet battery for 510 threaded CBD cartridges. It features an M7 magnetic adapter, 380mAh battery, and a constant 3.5V output. The Magic 710 utilizes a button free, draw-activated system with a magnetic adapter connection that fits up to 11mm diameter cartridges. This item also has other color to choose.
Original Vapmod Xtube 710 900mAh CBD Battery Mod $14.99
Vapmod Xtube 710 is a compact and portable vaporizer kit specially designed for use with very thick oils and wax due to its unique Pre-Heating Chamber and the smart Pre-Heat function. The Vapmod Xtube 710 features a sleek design with an only 19mm diameter, the rubberized soft-touch finish, the simple one-button operation and the full set of safety protection. The Xtube 710 pre-heating chamber and the smart 90-second 4-stages Pre-Heat Mode will allow you to evenly heat up your material. The Vapmod Xtube 710 features four voltage outputs 2.5V/3.0V/3.5V/4.0V that will light up with white/blue/green/red LED light accordingly. The powerful built-in 900mAh battery can be quickly recharged with an included micro USB cable in only 2 hours. The Vapmod Xtube is compatible with most 510-thread mini atomizers with up to 11mm diameter and will be a perfect match for your oil/wax with very thick consistency like the one from Alpine Vapor. This item also has other color to choose.
Original Vapmod Pipe 710 900mAh CBD Battery Mod $13.99
Vapmod Pipe 710 is powered by built-in 900mAh battery and features 15s rapid preheating, 4 variable voltage and unique folding pipe design. Vapmod Pipe 710 is compact enough to disappear in your hand. Its design allows you to use it in a number of ways using your thumb or index finger to fire it. You can adjust the angle of your cartridge, or keep it vertical when it's not in use. The device utilizes a magnetic 510 adapter that screws on to the tank. It's pretty convenient for popping your cartridge in and out quickly. It is compatible with 11mm (or less than 11mm) cartridges. This item also has other color to choose.
Original Aleader Mamba Semi-Mechanical Mod Kit Original Price $39.80, Now Only $28.79
The Aleader Mamba Kit consists of Aleader Mamba Mod and Mamba Tank. The mod is not regulated with 4.2V maximum voltage output. The Mamba mod can support resistance as low as 0.1ohm. It has 3-color battery indicator and Micro-USB charging port. As for the Mamba Tank, it has 2ml of juice capacity and is adopted with 0.4ohm coil. A spare 0.15ohm coil is included. The airflow can be adjustable from the bottom. This mod kit will bring you great vaping experience. This item also has other color to choose.
Replacement Drip Tip for Lost Vape Orion Pod $2.59
The replacement drip tip is made from resin and is suitable for Original Lost Vape Orion Pod. This item also has other color to choose.
Старый 26.03.2019, 04:37 Автор темы   330
3FVAPE
Original Justfog Compact 14 12W 1500mAh Battery Mod $19.09
Justfog Compact 14 Mod is powered by built-in 1500mAh rechargeable battery with 3.6V constant voltage output. The greatest advantage of the Justfog Compact 14 Battery is that it can work more than two days because of the 1500mAh battery and 3.5V constant output voltage. Justfog Compact 14 also comes with LED battery indicator light and various smart battery protection functions, which can make vaping safer. This item also has other color to choose.
ShenRay Armor BF Squonk Mechanical Box Mod Updated Version Clone with Chip $63.00
The ShenRay Armor BF Squonk Mod Clone is constructed from black Delrin body, black stainless steel top / bottom and brass battery tube. This mod is powered by single 18650 battery (NOT INCLUDED). This mod comes with gold plated brass contact.
This product is updated version with a chip that provides short circuit protection. This item also has other color to choose.
Original MyVapors Myuz SS5 220W TC VW Variable Wattage Box Mod Kit $59.99
MyVapors Myuz SS5 Kit features colorful double-sided resin panels which performance like gas planet-Jupiter (No.5 in the solar system). Powered by dual 18650 batteries (NOT INCLUDED), its output can reach 220W max. Comes with large HD color screen that displays specific data. The Magnetic Battery Door provides a brilliant and great visual effect, it also makes battery replacement easier. As for the Myuz SS5 tank, it has a 6.5ml large capacity and super convenient top filling design. Together with new revolutionary SS5-N Coil and SS5-M Coil design, Myuz SS5 Kit will bring you a convenient vape experience and smoother flavor. This item also has other color to choose.
Original Justfog Compact 14 12W 1500mAh Starter Kit $24.09
Justfog Compact 14 Kit consists of Justfog Compact 14 Mod and Justfog Q14 Clearomizer. Justfog Compact 14 Mod is powered by built-in 1500mAh rechargeable battery with 3.6V constant voltage output. The greatest advantage of the Justfog Compact 14 Battery is that it can work more than two days because of the 1500mAh battery and 3.5V constant output voltage. Justfog Compact 14 also comes with LED battery indicator light and various smart battery protection functions, which can make vaping safer. Together with the 14mm Q14 atomizer featuring the adjustable bottom airflow control and the coil short protection function, the JUSTFOG Compact 14 Kit can bring you simple yet amazing vape with long working time. This item also has other color to choose.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.59
The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.29
The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This item also has other Version to choose.
Original Wotofo Serpent Elevate Replacement Tank Tube $2.59
The replacement tank tube is made from glass with 3.5ml of juice capacity and is suitable for Wotofo Serpent Elevate RTA. This item also has other Version to choose.
Original MyVapors Myuz SS5 Replacement S5-M Kanthal Coil Head $11.99
The MyVapors Myuz SS5 Replacement S5-M Kanthal Coil Head features 0.15ohm resistance. It is suitable for Original MyVapors Myuz SS5 Kit / MyVapors Myuz SS5 Tank.
Старый 27.03.2019, 04:25 Автор темы   331
3FVAPE
Original ATVS Blade 228W TC VW Variable Wattage Box Mod $29.25
The ATVS Blade can reach its maximum output to 228W, providing you with huge vapor production. The 0.96-inch intuitive display presents you with everything you need. The mod can vary the wattage from 6W to 228W. This item also has other color to choose.
Original ATVS Castle 225W TC VW Variable Wattage Box Mod $25.19
The ATVS Castle can reach its maximum output to 225W, providing you with huge vapor production. The 0.96-inch intuitive display presents you with everything you need. The mod can vary the wattage from 6W to 225W. This item also has other color to choose.
SXK PyroGeyser RDTA Rebuildable Dripping Tank Atomizer Clone Original Price $28.80, Now Only $20.99
The SXK PyroGeyser RDTA Clone is a 22mm rebuildable dripping tank atomizer made from 316 stainless steel and PEI. The tank comes with both PEI tank tube and PC tank tube. The drip tip and the black insulated ring are made from medical grade PEI. The unique deck allows user to build vertical coils. The airflow will hit the coils from the side airholes. This RDTA will bring you great vaping experience.
Original ATVS Blade 228W TC VW Variable Wattage Box Mod + SR-11 Tank Kit $37.59
ATVS BLADE 228W Kit consists of ATVS BLADE 228W Mod and SR-11 Tank Atomizer. This item also has other color to choose.
Mod:
Powered by dual 18650 batteries (NOT INCLUDED), The ATVS Blade can reach its maximum output to 228W, providing you with huge vapor production. The 0.96-inch intuitive display presents you with everything you need. The mod can vary the wattage from 6W to 228W.
Tank:
The SR-11 atomizer adopts the push-to-open top filling design. Simply push the top cap to reveal the filling hole. The coil pre-installed has 0.15ohm resistance. The tank also features top filling system and adjustable bottom airflow control.
Original ATVS Castle 225W TC VW Variable Wattage Box Mod + SR-11 Mini Tank Kit $33.59
ATVS Castle 225W Kit consists of ATVS Castle 225W Mod and SR-11 Mini Tank Atomizer. This item also has other color to choose.
Mod:
Powered by dual 18650 batteries (NOT INCLUDED), The ATVS Castle can reach its maximum output to 225W, providing you with huge vapor production. The 0.96-inch intuitive display presents you with everything you need. The mod can vary the wattage from 6W to 225W.
Tank:
The SR-11 Mini atomizer adopts the push-to-open top filling design. Simply push the top cap to reveal the filling hole. The coil pre-installed has 0.15ohm resistance. The tank also features top filling system and adjustable bottom airflow control.
Original Vivismoke Leather Vape Pocket Case for Juul / Myle / e8 / Drop Pod System Kit $4.99
The Vivismoke Vape Pocket Case is made from leather and is suitable for slim pod system kits, like Juul, Myle, e8, Drop Kit. It features creative stretch-pulling design, which is easy to use. The case can organize and store up to 1 pod device and 2 extra pods. There is an extra slot for cash, card, pod or charger. The magnetic closure keeps pod device safely in place. Just take your pod and go. This item also has other color to choose.
Старый 28.03.2019, 04:35 Автор темы   332
3FVAPE
Vapeasy Armor S RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99
The Vapeasy Armor S RDA Clone is a 22mm rebuildable dripping atomizer made from durable 316 stainless steel. It comes with a unique cap with many grooves on it. The deck is easy for coil building. The black Delrin drip tip will bring you comfortable experience.
Original Innokin Zlide Sub Ohm Tank Clearomizer $19.75
The Innokin Zlide Tank is not designed to replace the Zenith, but rather to offer a more cost-effective solution while addressing some requests from Zenith users. The tank is compatible with the entire Z-coil line and maintains the same easy and clean coil replacement system you've come to love from the Zenith. To save cost for you, this tank does not feature a liquid shut off as found on the Zenith which is why it will only come in a 2ml, 22mm format allowing you to take advantage of the easy slide filling top cap without the risk of flooding the coil. The top cap also features a child-proof design. Removing the mouthpiece first allows the top cap to slide open. With the mouth piece in place, the cap is locked closed. This item also has other colors to choose.
Original Innokin Platform Z-Biip 1500mAh Pod System Starter Kit $39.29
The Innokin Platform Z-Biip can be considered as a replaceable coil pod system, an all-in-one system and a n excellent starter kit. However, the most important things it should be considered are easy to use and satisfying. Although the Biip works perfectly with salt nic, it also has the power to be fully satisfying using standard e-liquids. The Biip is compatible with the entire Z-Coil line making it desirable for vapers who have come to love the Zenith tank and vendors who want to carry more products but less coils. The audible system is unique on this product allowing the user to not only see status information, but also hear it, making it desirable to those whos eyesight may not be as good as it once was. This item also has other colors to choose.
Original Innokin EQs 800mAh Pod System Starter Kit $22.99
The Innokin EQs. EQs delivers great vaping with every puff. The EQS is compatible with Innokin EQ Plex3D pods; EQ pods are easy to twist to refill and the protective cap keeps the mouthpiece clean and debris-free. The Innokin EQs is powered by advanced Plex3D mesh coils with 'micro-grooves', increasing the total coil surface area for more intense flavors. Plex3D coils heat-up and cool-down faster than traditional coils, extending coil life and maximizing vape satisfaction. This item also has other colors to choose.
Original Tesla Teslacigs Innovator 1100mAh Battery Mod + Citrine 19 Tank Kit Original Price $26.90, Now Only $22.99
The Teslacigs Innovator kit consists of Innovator Mod and Citrine 19 Tank.
The Innovator kit with 0.6ohm resistance but also satisfied with standard e-liquids. It features replaceable coil system and utilizes mesh coil. It is like a combination of big vapor production and pure original flavor. The kit is very easy to refill and there is no leakage. 1100mAh large capacity battery makes sure long time vaping. This item also has other colors to choose.
Original Oumier Wasp Nano RTA Replacement Bubble Tank Tube $1.99
The replacement bubble tank tube is made from glass with 3ml of juice capacity and is suitable for Oumier Wasp Nano RTA.
SXK Replacement Drip Tip for KF Lite 2019 RTA Clone $3.59
The replacement drip tip is made from PEI and is suitable for SXK KF Lite 2019 RTA Clone.
SXK Replacement Window Section for KF Lite 2019 22mm RTA Clone $3.59
The replacement window section is made from PEI and is suitable for SXK KF Lite 2019 22mm RTA Clone. This item also has other Version to choose.
SXK Replacement Bell Tank for 24mm KF Lite 2019 RTA Clone $5.59
The replacement Bell section tank is made from PEI and is suitable for SXK KF Lite 2019 Style 24mm RTA. It has 2ml of juice capacity. This item also has other Version to choose.
Original Innokin Platform Z-Biip Replacement Pod Cartridge $4.69
The Innokin Platform Z-Biip Replacement Pod Cartridge has 2ml of juice capacity and 0.48ohm coil and is suitable for Innokin Platform Z-Biip Pod System Starter Kit.
Original Innokin EQs Replacement Pod Cartridge $18.99
The Innokin EQs Replacement Pod Cartridge has 2ml of juice capacity and 0.48ohm coil and is suitable for Innokin EQs Pod System Starter Kit.
Старый 29.03.2019, 04:39 Автор темы   333
3FVAPE
Original Digiflavor Lunar Box Mod Original Price $26.99, Now Only $19.99
Digiflavor Lunar is a dual 18650 Mod powered by the AS chipset and compatible with coils as low as 0.1 Ohm. Built with high grade ultra-lightweight ABS material which increases impact and heat resistance. Three power output modes are available to match your personal preference. This item also has other color to choose.
Original Smoant Taggerz 200W TC VW Variable Wattage Box Mod Original Price $34.90, Now Only $27.99
Smoant Taggerz 200W Box Mod has ergonomic and compact design. It is very light and portable. The Taggerz mod requires dual 18650 batteries (NOT INCLUDED) and supports 200W maximum output. It is also equipped with large 0.96" OLED screen. It supports VW/DVW/Ni/Ti/SS316/TCR mode to bring different vaping experience. Big button easy to operate. Moreover, it comes with balanced charging safety, give you safe vaping experience. This item also has other color to choose.
ShenRay VG V6 S V6S RTA Rebuildable Tank Atomizer Clone $32.99
The ShenRay VG V6S RTA Clone is a 23mm rebuildable tank atomizer with 5.5ml of juice capacity. It is constructed from 316 stainless steel with glass / PEI tank tube. The tank features infinitely adjustable bottom airflow, which is adjusted via 6 lockable holes in the deck. The tank can be refilled from the top. This item also has other color to choose.
Original Digiflavor Lunar Box Mod + GeekVape Lumi Tank Starter Kit Original Price $33.99, Now Only $25.99
Digiflavor Lunar Kit consists of Digiflavor Lunar Mod and GeekVape Lumi Tank. This item also has other color to choose.
Mod:
Tank:
The Lumi is a 24mm pre-coiled sub ohm tank that is powered with Geekvape supermesh coil system (non-replaceable) to produce the best flavor and outstanding vapor production. The tank is built with FDA certified medical grade Polycarbonate which can withstand extremely high temperature and Stainless Steel and only weighs 16g. With the Supermesh coil system, Lumi can produce outstanding flavor and vapor production.
This tank is disposable.
Original Smoant Taggerz 200W TC VW Variable Wattage Box Mod + Disposable Tank Kit Original Price $37.90, Now Only $30.99
Smoant Taggerz Kit consists of Smoant Taggerz Mod and Smoant Taggerz Disposable Tank. This item also has other color to choose.
Mod:
Tank:
Smoant Taggerz Disposable Tank features 2ml capacity, top filling design makes it easy to refill and avoid leaking effectively. This tank adopts translucent material which makes it looked nice and easy to check e-juice level.
SXK Replacement Top Refill Tank + Drip Tip Kit for 22mm KF Lite 2019 RTA Clone Original Price $10.99, Now Only $7.99
The replacement Top Refill tank is made from 316SS and PEI. The drip tip is made from POM. They are suitable for SXK KF Lite 2019 22mm RTA Clone. This item also has other Version to choose.
Старый 01.04.2019, 04:41 Автор темы   334
3FVAPE
Original Aleader Orbit 100W TC VW Variable Wattage Box Mod $31.49
The Aleader Orbit 100W Box Mod features ergonomic design structure, solid Zinc alloy chassis construction, intuitive OLED Display Screen, and intelligent chipset to power today's top tanks and rebuildables. Powered by single 18650 / 21700 / 20700 battery (NOT INCLUDED), this mod can reach its maximum output to 100W. Besides, it supports both VW and TC modes and comes with multiple protections. This item also has other color to choose.
Original Eleaf iStick Mix 160W TC VW Variable Wattage Box Mod $43.55
iStick Mix, "Art Mix Tech", is a very personalized product. From the appearance, iStick Mix shows an artistic double-sided design-IML and Resin, which Eleaf has never used and is also one of the connotations of "mixed life". At the same time, iStick Mix combines with TYPE-C and balanced charging technology, charging is more efficient and safer than ever. Powered by dual 18650 batteries (NOT INCLUDED), iStick Mix can fire up to 160 watts. In a short, iStick Mix is a unique, artistic and technical product that brings you a brand-new feeling. This item also has other color to choose.
Original ThunderHead Creations THC Tauren RDA Rebuildable Dripping Atomizer with BF Pin Original Price $46.80, Now Only $20.29
The Original ThunderHead Creations THC Tauren RDA is a 24mm RDA that features 45-degree angled dual post and 28 micro airholes on each post for delicate and fullest flavor. The RDA has gold-plated 510 pin for great conductivity and also comes with BF pin for squonking. PEI drip tip is included.
Original Hugsvape Ring Lord Mesh RTA Rebuildable Tank Atomizer $31.39
Hugsvape Ring Lord Mesh 26mm RTA is made of high quality Stainless Steel and glass, features easy top filling design and adjustable bottom airflow. The unique deck is very easy to build mesh coil. This item also has other color to choose.
Vapeasy Armor S RDA Rebuildable Dripping Atomizer Clone with BF Pin $23.99
The Vapeasy Armor S RDA Clone is a 22mm rebuildable dripping atomizer made from durable Titanium Alloy. It comes with a unique cap with many grooves on it. The deck is easy for coil building. The black Delrin drip tip will bring you comfortable experience.
This RDA comes with bottom feeder pin. This item also has 316SS Version to choose.
Original Aleader Orbit 100W TC VW Variable Wattage Box Mod + Clearomizer Kit $36.29
Aleader Orbit Kit consists of Aleader Orbit Mod and Aleader Orbit Tank. This item also has other color to choose.
As for the clearomizer, it is a 24mm sub ohm tank with 2ml of juice capacity. It is constructed from stainless steel and resin. Adopted with 0.15/0.4 ohm coil heads, this tank will bring you great vaping experience.
Original Eleaf iStick Mix 160W TC VW Variable Wattage Box Mod + ELLO POP Tank Kit $60.97
Eleaf iStick Mix Kit consists of Eleaf iStick Mix Mod and Eleaf ELLO POP Tank. This item also has other color to choose.
Mod:
Tank:
ELLO POP, a new member of Eleaf ELLO series tanks, features new HW-M2 and HW-N2 coils which boasts the LPSC technology and new wicking of the porous cotton. With the smartly designed childproof structure, refilling on ELLO POP becomes high security and great convenience.
SXK Replacement Drip Tip for KF Lite 2019 RTA Clone $2.99
The replacement drip tip is made from PC and is suitable for SXK KF Lite 2019 RTA Clone.
SXK Replacement Window Section for KF Lite 2019 22mm RTA Clone $2.99
The replacement window section is made from PC and is suitable for SXK KF Lite 2019 22mm RTA Clone. This item also has other Version to choose.
SXK Replacement Bell Tank for 22mm KF Lite 2019 RTA Clone $4.50
The replacement Bell section tank is made from PC and is suitable for SXK KF Lite 2019 22mm RTA Clone. It has 2ml of juice capacity. This item also has other Version to choose.
SXK Replacement Top Refill Tank + Drip Tip Kit for 22mm KF Lite 2019 RTA Clone Original Price $9.50, Now Only $6.99
The replacement Top Refill tank is made from 316SS and PC. The drip tip is made from POM. They are suitable for SXK KF Lite 2019 22mm RTA Clone. This item also has other Version to choose.
Старый 02.04.2019, 05:16 Автор темы   335
3FVAPE
Overlord Hybrid Mechanical Tube Mod Clone $21.95
The Overlord Hybrid Mechanical Tube Mod Clone is constructed from brass. The battery contact is made from silver-plated copper. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). The fire button is activated by spring. This item also has other color to choose.
Original Smoant Taggerz Disposable Sub Ohm Tank Clearomizer $9.09
Smoant Taggerz Disposable Tank features 2ml capacity, top filling design makes it easy to refill and avoid leaking effectively. This tank adopts translucent material which makes it looked nice and easy to check e-juice level. It has a 0.2ohm coil that works well at between 40W and 45W.
This product comes with 3 PCS in 1 pack. This item also has other color to choose.
Original Vapefly Holic MTL RDA Rebuildable Dripping Atomizer with BF Pin $27.99
Vapefly and HORICK TV, an experienced Japanese vape reviewer, together represent a great mouth-to-lung RDA, Vapefly Holic MTL RDA. In pursuit of fashion and excellent flavor, Vapefly combined these two features, made some improvements on the Galaxies series, and finally Vapefly came up with Vapefly Holic MTL RDA, which will rise the tide of a new vape trend. It features six levels airflow control and unique unlimited AFC system with airflow control set, aiming to give you optimal flavor. It supports both dripping and squonking. This item also has other color to choose.
Original Vapethink Silicone Anti-slip Ring Vape Band Original Price $1.99, Now Only $0.00
The Original Vapethink Anti-slip Ring Vape Band is made from high quality silicone and with high-resolution pattern printed. The vape band is in 22mm diameter, 12mm height and 2mm thickness.
This product will be shipped with random color and random pattern.
1 PC / Pack
Original Evolv DNA 401 Smart Chip for Electronic Cigarette Mod $59.99
The DNA 401 is a power regulated digital switch-mode DC-DC converter for personal vaporizers. It features Evolvs patented Wattage Control, Temperature Protection, Preheat, OLED Screen, and waterproof onboard buttons. The USB port and Evolvs EScribe software can be used to customize or monitor the user experience. The DNA 401 runs from a 4 cell lithium polymer battery, and features cellby-cell battery monitoring and integrated 2.5A balance charger.
Старый 03.04.2019, 04:45 Автор темы   336
3FVAPE
Overlord Hybrid Mechanical Tube Mod Clone $18.98
The Overlord Hybrid Mechanical Tube Mod Clone is constructed from brass. The battery contact is made from silver-plated copper. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). This item also has other color to choose.
KF Lite 2019 RTA Rebuildable Tank Atomizer Clone $10.39
The KF Lite 2019 RTA Clone is a 22mm rebuildable tank atomizer with 2ml of juice capacity. It is made from stainless steel and Ultem. It is designed for mouth to lung vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience. This item also has other color to choose.
Original Voopoo Drag 2 177W TC VW Box Mod + UForce T2 Tank Kit $73.25
The authentic VOOPOO Drag 2 Platinum Kit consists of the Voopoo Drag 2 Platinum 177W TC VW box mod and an UForce T2 sub ohm tank. This item also has other color to choose.
Mod:
The authentic Voopoo Drag 2 Platinum 177W TC VW box mod is powered by dual 18650 batteries (NOT INCLUDED), it can fire up to a powerful output of 177W. As a new generation of drag, the Drag 2 is more lighter and functional. The Drag 2 Platinum mod adopts GENE.FIT chip, which is secured by a V0 class fireproofing bridge to block dust, liquid or burnout. It comes with innovative FIT mode to intelligently match and protect tanks from burnout.
Tank:
The UFORCE T2 sub ohm tank is a 28mm innovative sub ohm tank. It can prevent the e-juice leakage by pushing the top cap. The tank utilizes U2 (0.4ohm) / N3 (0.2ohm) coil to achieve purer flavor and stronger clouds.
Original Voopoo Drag Mini 117W 4400mAh TC VW Box Mod + UForce T2 Tank Kit $73.90
The Original VOOPOO Drag Mini Platinum Kit consists of the Voopoo Drag Mini Platinum 117W TC VW box mod and an UForce T2 sub ohm tank.This item also has other color to choose.
Mod:
The Original Voopoo Drag Mini Platinum 117W TC VW box mod, powered by built-in 4400mAh battery, it can fire up to 117W max output. As a new generation of drag, the DRAG Mini Platinum features mini size and compact design, utilizes colorful resin panels to make your vaping life colorful. It also adopts GENE.FIT chip to ensures excellent taste and enjoyable vaping experience. The innovative FIT mode intelligent match and protect tanks. The mod equips with a crystal OLED display to show parameters of device such as mode, resistance, voltage and wattage.
Tank:
The UFORCE T2 sub ohm tank is a 28mm innovative sub ohm tank with a 5ml capacity. It can prevent the e-juice leakage by pushing the top cap. The tank utilizes P2 (0.6ohm) / N1 (0.13ohm) coil to achieve purer flavor and stronger clouds.
Original Marstech M101 350mAh Pod System Starter Kit $11.95
The Marstech M101 Pod System Starter Kit is a very compact and mini sized vape kit that compatible with Juul Pod. It is powered by built-in 350mAh battery. The ceramic heating pod has 0.6ml of juice capacity and 1.9ohm ceramic coil. It can also be used on Juul battery.
Старый 04.04.2019, 04:55 Автор темы   337
3FVAPE
Original GeekVape Aegis Solo 100W TC VW Variable Wattage Box Mod Original Price $44.00, Now Only $37.39
The Aegis Solo is a compact version of the original Aegis, it is smaller, lighter and more durable. Powered with the Latest AS-100 Chipset that has incredible accuracy and stable power output, the Aegis Solo is able to produce up to 100W power with a single 18650 battery (NOT INCLUDED). This item also has other color to choose.
Original GeekVape Tengu RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.90, Now Only $20.39
The GeekVape Tengu RDA which features an easy-to-build innovative deck, Honeycomb airflow system, concealed airflow adjustment system and two ways of refilling (dripping and squonking). Delrin drip tip and PMMA drip tip are included. The 24mm Tengu RDA will bring you smooth and even controllable airflow with its honeycomb side airflow inlets design. This item also has other color to choose.
Original Justfog J-Easy 9 900mAh Mod + Q16C Clearomizer Starter Kit $23.39
The Original Justfog Q16C Starter Kit consists of J-Easy 9 Battery and Q16C Clearomizer. It is a convenient starter kit with built-in 900mAh battery, 1.9ml of tank capacity and 1.6ohm coil head (6~12W). The battery works with constant output voltage. The recommended resistance is from 1.0 to 3.0ohm. This item also has other color to choose.
Original Justfog FOG1 1500mAh All-in-One Starter Kit $22.25
Justfog FOG1 Kit is a handy kit with a 1500mAh battery and 2ml capacity. It is the epitome of security with its childproof opening system and anti-spit protection shield. Featuring top filling, replaceable liquid tank tube, and metal-coated appearance, this kit is right here for you. It is simple and convenient to use, making the device so popular and unique. This item also has other color to choose.
Original Justfog P14A Compact 900mAh All-in-One Starter Kit $17.89
Being one of the JUSTFOG 14 series, the JUSTFOG P14A Compact Kit comes with the atomizer of 14mm diameter as well. With the built-in, strong and long-lasting grade A 900mAh battery, the compact battery is able to provide accurate constant voltage. It does not only come with multiple safety circuit protection including short circuit protection, overheat protection, over-discharge protection and overcharge protection, but also with child-proof opening system. This item also has other color to choose.
Original Vapesoon V16 240mAh Pod System Starter Kit $13.65
The Vapesoon V16 Pod System Starter Kit is a slim pod kit powered by built-in 240mAh battery. The pod cartridge has 0.7ml of juice capacity and 1.5ohm coil. It can be activated by the air-driven system, without any button. The battery can be easily charged by the Micro-USB charging port. This item also has other color to choose.
Original GeekVape Aegis Solo 100W TC VW Variable Wattage Mod + Cerberus Tank Kit Original Price $64.00, Now Only $49.99
The GeekVape Aegis Solo Kit consists of GeekVape Aegis Solo Mod and Cerberus Sub Ohm Tank. This item also has other color to choose.
Included in the kit is the Cerberus sub ohm tank which is optimized by the ultimate Super Mesh coil that maximizes heating contact surface area in order to provide maximum flavor and large vapor production. Super Mesh Coils are compatible with Aero Mesh tank and Cerberus tank.
Original GeekVape Aegis Solo 100W TC VW Variable Wattage Mod + Tengu RDA Kit Original Price $63.00, Now Only $49.49
The GeekVape Aegis Solo Kit consists of GeekVape Aegis Solo Mod and Tengu RDA. This item also has other color to choose.
Included in the kit is the GeekVape Tengu RDA which features an easy-to-build innovative deck, Honeycomb airflow system, concealed airflow adjustment system and two ways of refilling (dripping and squonking). Delrin drip tip and PMMA drip tip are included. The 24mm Tengu RDA will bring you smooth and even controllable airflow with its honeycomb side airflow inlets design.
Fujicco 510 Drip Tip Clone for RDA / RTA / Sub Ohm Tank Atomizer $3.15
The Fujicco 510 drip tip Clone is made from stainless steel. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose.
YFTK Replacement Bell Tank for 22mm KF Lite 2019 RTA Clone $3.95
The replacement Bell section tank is made from PC and is suitable for YFTK KF Lite 2019 22mm RTA Clone. It has 2ml of juice capacity. This item also has other color to choose.
Original Vapesoon V16 Replacement Pod Cartridge $2.39
The Vapesoon V16 Replacement Pod Cartridge has 0.7ml of juice capacity and 1.5ohm coil and is suitable for Vapesoon V16 Pod System Starter Kit.
1 PC per pack
3FVAPE вне форума   Вверх
Старый 07.04.2019, 04:51 Автор темы   338
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Vapor Storm M1 800mAh VV CBD Battery Mod $10.50
The Vapor Storm M1 Mod is a portable device designed for CBD vaping. It has 3-level adjustable voltage, which is 3.4V, 3.7V and 4.2V. The mod is compatible with atomizer with diameter less than 12mm. Powered by built-in 800mAh battery, this mod also supports fast balance charging. Made from durable ABS material, this mod is very lightweight and easy to carry. This item also has other color to choose.
Original LTQ Vapor Mini Globefish Wax Tank CBD Atomizer Original Price $8.00, Now Only $3.99
LTQ Vapor Mini Globefish Wax Tank is designed especially for LTQ Vapor Mini Globefish Kit. You will find it easy to clean the glass tank. LTQ Vapor Mini Globefish Tank comes with 2.2ohm ceramic coil, hence producing the original flavor and amazing clouds for your vaping.
Original LTQ Vapor Lock CBD Atomizer Original Price $5.00, Now Only $3.39
LTQ Vapor Lock CBD Atomizer comes with 1ml e-juice capacity. You can find an oil hole on the tube. It adopts Q1 oil-lock design for you to easy operate the device. 1.2ohm ceramic coil will produce the purest flavor and biggest cloud for you. Moreover, by the bottom air flow system, it will enhance the flavor for your taste. It is compatible with most 510 thread MODs and Batteries.
SXK NarEA RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $15.90, Now Only $12.99
The SXK NarEA RDA Clone is a rebuildable dripping atomizer with 22mm diameter. It is made out of 316 stainless steel. Coming with dual-post design, it is easy to build. SXK NarEA style RDA is a nice single coil RDA that will provide intense flavor and massive cloud. 510 POM drip tip is included.
Original LTQ Vapor Mini Globefish 280mAh Wax CBD Vape Pen Kit Original Price $20.00, Now Only $9.99
LTQ Vapor Mini Globefish Kit, equipped with 2.2ohm coil, is designed innovatively as a pen shape. Powered by 280mAh built-in battery though, it can support your ordinary vaping time, with adjustable output voltage from 2.0V to 4.0V. LTQ Vapor Mini Globefish Kit comes with 2.2ohm resistance and is made of stainless steel. No doubt that it will be durable enough. The ceramic coil it adopts will bring the original flavor for your taste and amazing clouds.
PVC Wrapper Skin Sticker for 18650 Battery $1.59
The wrapper sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc.
This product comes with 10 PCS in 1 pack. This item also has other color to choose.
Original LTQ Vapor Stainless Steel Dab Tool for Vaporizer Original Price $9.00, Now Only $3.39
Perfectly designed for vaporizer, the LTQ Vapor Stainless Steel Dab Tool is a durable and useful dab tool. Made of high quality Stainless Steel, the LTQ Vapor Dab Tool is durable to use and easy to clean. Get it for your vape device. This item also has other Version to choose.
Original LTQ Vapor Silicone Mat Original Price $12.00, Now Only $7.99
The LTQ Vapor Silicone Mat is comprised of advanced silica with high temperature resistance, pressure resistance, tension and flexibility. It is used to handle the stickiest concentrates with ZERO waste or mess, and make the sticky tools stay clean of debris. The Silicone Mat is easy to clean with soap and water. Environmentally friendly and completely reusable.
Original LTQ Vapor IE-Nail TC Vaporizer Original Price $149.00, Now Only $63.99
The LTQ Vapor IE-Nail, a delicate device. It has two nails for your different preference. The operation part is used to control the temperature. The fast heating time of 15s will bring you an amazing vaping experience.
Original Wotofo Agleted Organic Cotton for Coil Wicking $3.99
Wotofo Agleted Organic Cotton is inspired by the ever increasing needs of fast cotton preparation for your rebuilding convenience. The cotton we selected are of long fibers so that it wicks smooth and its not easy to pull apart. However, thats not the best part, the best part is that we put a sheath on one end of the cotton strip so as to function like the aglet on your shoelace, then its much easier to thread the cotton through the coils. Each cotton strip is ready-to-use with proper cotton amount thats tested to best fit for dominant 3mm I.D. coils on the market. The cotton features great absorption capability and better retention ability, freshly packaged to deliver the purest flavor. There are 30 pieces of agleted cotton strips in one little box, convenient to carry around and stored in a clean way.
This product comes with 30PCS in 1 pack.
Старый 08.04.2019, 04:49 Автор темы   339
3FVAPE
Original Justfog P14A Tank Clearomizer $5.55
Justfog P14A Clearomizer is a 14mm tank atomizer with 1.9ml e-juice capacity. It features a childproof opening system, easy body-spinning airflow control and anti-spit back protection. The P14A is pre-installed with 1.6ohm coil, it is also compatible with 1.2ohm coil (NOT INCLUDED). This item also has other Version to choose.
Original Justfog Q16 Tank Clearomizer $6.25
Justfog Q16 Clearomizer is an exquisite atomizer with 1.9ml of juice capacity and 1.6ohm coil. It features anti-leakage Star-shield system, smooth stainless air ring system, grade-one nichrome wire coil and easy bottom airflow control. Q16 Clearomizer will bring you a huge cloud with nice flavor.
Original OBS KFB2 KFB 2 1500mAh All-in-One Starter Kit Original Price $49.90, Now Only $27.99
OBS KFB2 AIO Starter Kit has exquisite appearance and ergonomic design. It is powered by 1500mAh built-in battery, brings you long time vaping. It is equipped with one big button for easy operating. The intelligent protections ensure safe vaping. KFB2 atomizer features 2ml capacity and top filling design. With bottom airflow system, it can offer MTL and DL vaping experience for you. It is compatible with S1 mesh coil (0.6ohm) and N1 coil (1.2ohm), which are best for flavor. This item also has other color to choose.
Original Desire More Pro 1000mAh Pod System Starter Kit $14.99
Desire More Pro Pod System Kit has aluminum external shell that provides wear-proof and corrosion-resistant functions. It comes with the 1000mAh battery that brings you long time vaping without worrying about charging. The pod cartridge has 2ml of juice capacity and 1.2ohm coil. This item also has other color to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.99
This drip tip glows in the dark.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.99
Original Desire More Pro Replacement Pod Cartridge $9.99
The Desire More Pro Replacement Pod Cartridge has 2ml of juice capacity and 1.2ohm coil and is suitable for Desire More Pro Pod System Starter Kit.
Старый 09.04.2019, 05:16 Автор темы   340
3FVAPE
Original Dazzvape GT800 800mAh 20W VV VW CBD Vaporizer Battery Mod $27.99
Dazzvape GT800 Battery Mod is an excellently designed and dependable vaporizing device. It comes with a three-button interface, internal 800mAh battery and 0.69 inches OLED screen. It is compatible with most of standard 510 cartridges. Temperature control capabilities and variable wattage/voltage makes the perfect choice for your need. Ergonomically designed with smooth lines and rounded edges for a comfortable feel when in use. This item also has other color to choose.
Original Dazzvape U-Key 400mAh VV Oil CBD Vaporizer Battery Mod $14.99
Dazzvape U-Key Oil Vaporizer is a super portable concentrate vaporizer device with 10 second preheating function. Built-in 350mAh battery and direct voltage output. The U-Key Mod supports 4 level of adjustable voltage marked at 4.0V, 3.6V, 3.2V and 2.8V. The finish consists of ABS material, Zinc Alloy and litchi grain leather which gives your better hand feeling. It features single button which makes the mod easier to operate and is compatible with 510 thread connection. This item also has other color to choose.
YFTK Auco RDA Rebuildable Dripping Atomizer Clone with BF Pin $20.99
The YFTK Auco BF RDA Clone is a 22mm rebuildable dripping atomizer made from 316 stainless steel. It has a dual post build deck, which is wide enough for easy coil building. The airflow can be adjusted by the side airflow control system, providing you with precise airflow and optimal flavor. The RDA comes with bottom feeder pin to be compatible with squonk mods. This item also has other color to choose.
Original SMOKTech SMOK Nord Cube 1800mAh 30W Pod System Starter Kit $30.25
SMOKTech SMOK Nord Cube is a masterpiece combines excellent design and powerful functions. It has streamlined profile and elegant curves, which can perfectly fit your hand and offer comfortable hand-feel. It also designed with a user-friendly fire key, allowing convenient operations. For power source, it has built-in 1800mAh battery, combining with specially designed Nord Mesh 0.6ohm coil and Nord Mesh-MTL 0.8ohm coil, you can get two different vaping experience, and both of them would meet your vaping demands. Besides, it has 4.5ml e-liquid capacity. This item also has other color to choose.
Original Dazzvape Acus 350mAh Wax Pen CBD Vaporizer Kit $21.99
Dazzvape Acus Wax Vaporizer is a pen style kit suitable for wax. Just one button design with 350mAh built-in battery. It features two kinds of coils: Dip or Dab your concentrates. One of it called quartz dab coil which stores concentrates (wax) in a chamber with a knurled cap. The other called quartz dip coil which allow the tip to contact with concentrates (wax) directly. On each side, there is a mouthpiece. One for dab coil usage and another for dip coil usage. Take this compact Acus on the go and enjoy the flavor. This item also has other color to choose.
Original Innokin Zenith Replacement MTL Coil Head $9.35
The Innokin Zenith Replacement Coil Head features 0.8ohm resistance and works well at 15~18W. It is suitable for Original Innokin Zenith MTL Tank / Innokin Zlide Tank.
Original Innokin Zenith Plexus Z Replacement MTL Mesh Coil Head $10.39
The Innokin Zenith Plexus Z Replacement MTL Mesh Coil Head features 0.5ohm resistance and works well at 14~19W. It is suitable for Original Innokin Zenith MTL Tank / Innokin Zlide Tank.
Original Innokin Zenith Plex3D Replacement MTL Mesh Coil Head $10.39
The Innokin Zenith Plex3D Replacement MTL Mesh Coil Head features 0.48ohm resistance and works well at 13~16W. It is suitable for Original Innokin Zenith MTL Tank / Innokin Zlide Tank.
Original Vapesoon Replacement Glass Tank Tube for GeekVape Zeus X RTA $1.26
The Vapesoon Replacement Glass Tank Tube has 3.5ml of juice capacity and is suitable for Original GeekVape Zeus X RTA.
Original SMOKTech SMOK Nord Cube Replacement Pod Cartridge + 0.8ohm Coil + 0.6ohm Coil $7.99
SMOKTech SMOK Nord Cube Pod Cartridge has 4.5ml of capacity. It is compatible with Nord Mesh 0.6ohm coil and Nord Mesh-MTL 0.8ohm coil. The Mesh 0.6ohm coil is specially designed for sub ohm vaping, it has a large mesh inside, with which you can get the faster heating process and massive vapor clouds. The Mesh-MTL 0.8ohm coil is designed for MTL vaping, you can enjoy throat hit with it. This pod is designed for the SMOK Nord Cube Kit. 1 PC each pack.
Original Cthulhu Tube Dual MOSFET Mod Replacement Chip Original Price $5.00, Now Only $4.44
The replacement chip is suitable for Original Cthulhu Tube Dual MOSFET Mod.
Время генерации страницы 0.57834 секунды с 15 запросами
