Просмотров в теме 298172   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 15.02.2019, 04:39 Автор темы   301
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Cthulhu Tube Dual MOSFET Mod $33.99
The Original Cthulhu Tube is one of the safest tube mods on the market. It comes with Insulators and dual MOSFET chip to support 0.1ohm and max 40A current. The battery will not short circuit even if the wraps are broken. Two vent holes are close to battery positive side. The chip will stop working when atomizer short. It also has reverse battery protection. There is a lever on the bottom that acts as a safety lock. Unscrewing it a little can lock the mod. The mod supports single 18650 and 18350 battery (NOT INCLUDED). It supports 22mm and 24mm atomizer. This item also has other color to choose.
Original GeekVape Zeus X RTA Rebuildable Tank Atomizer Original Price $36.99, Now Only $26.58
The Original Geekvape Zeus X RTA is an upgraded dual coil version of the original Zeus RTA and Zeus dual RTA. It features the innovative leak-proof top airflow system, airflow transferring from the top to the bottom to maintain great flavor. It comes with dual coils build deck and Bubble Glass. And it's compatible with both 810 and 510 drip tips. This item also has other color to choose.
Original Rofvape Warlock Peas 10W 400mAh Pod System Vape Pen Starter Kit $12.99
The Original Rofvape Warlock Peas Vape Pen is the newest Starter Kit released by Rofvape. It is light and small, and can be easily vaped at anytime and anywhere. With air flow switch it will start vaporizing as long as you vape. The Rofvape Warlock Peas Vape Pen comes with 1.5ml pod cartridge which has a 1.8ohm coil. This item also has other color to choose.
Original Innokin Redefined EQ 800mAh Pod System Starter Kit $25.99
Vape the EQ ultra-compact refillable pod system with Plexus coils and experience more flavor and longer lasting pods! Plexus coil technology heats-up and cools-down faster than traditional coils to greatly extend coil life. Activate EQ Boost Mode for even more flavor from your favorite eliquids! The large Plexus coil surface area delivers unsurpassed flavor with every puff. EQ pods are easy to twist to refill and a cap keeps the mouthpiece clean and debris-free. Featuring a 800mah capacity battery with safety protections and micro-USB charge, the EQ packs more power into a compact Pod system. Stand out from the crowd with this beautiful and durable line of EQ Electroplated finishes. This item also has other color to choose.
SXK Replacement Glass for Boxxer RDTA Clone $1.99
The replacement glass is suitable for SXK Boxxer RDTA Clone.
Original Justfog Replacement Pod Cartridge for C601 Pod System Kit $7.99
The Justfog C601 Replacement Pod Cartridge can hold 1.7ml of juice capacity and comes with 1.6ohm coil. It is suitable for Justfog C601 Pod System Stater Kit.
Original Innokin Replacement Pod Cartridge for EQ Pod System Kit $4.68
The Innokin EQ Replacement Pod Cartridge can hold 2ml of juice capacity and comes with 0.5ohm coil. It is suitable for Innokin EQ Pod System Stater Kit.
3FVAPE вне форума   Вверх
Старый 16.02.2019, 04:39 Автор темы   302
3FVAPE
Original Augvape VX200 200W TC VV VW Variable Wattage Box Mod Original Price $35.90, Now Only $30.99
The Augvape VX200 Mod, powered by dual 18650 batteries (NOT INCLUDED) with 200W max output, is a well-constructed TC mod that features a side mounted firing bar. The VX200 is constructed from durable ABS and PC plastic chassis construction to remain moderately resistant to falls and drops. The chipset within opens up an extensive temperature control suite reaching ohms as low as 0.05 or as high as 3.0 while allowing for four separate firing modes to meet any vaping desires for any particular set up. This item also has other color to choose.
Original Hugo Vapor Rader ECO 200W VV VW Variable Wattage Box Mod Original Price $34.99, Now Only $26.39
The Original Hugo Vapor Rader Eco Mod, powered by dual 18650 batteries (NOT INCLUDED) with 200W max output, is the newly designed box mod from Hugo Vapor. The Rader Eco supports Variable Voltage, Variable Wattage, Bypass and Curve Heating output Mode. Equipped with the 0.96inch OLED screen, the Hugo Vapor Rader Eco Mod will bring you great vaping experience. This item also has other color to choose.
Original Augvape VX200 200W TC VV VW Box Mod + Jewel Disposable Mesh Tank Kit Original Price $38.90, Now Only $34.99
The Augvape VX200 Kit consists of Augvape VX200 200W Mod and Jewel Disposable Mesh Tank. This item also has other color to choose.
Mod:
Tank:
As for the Jewel Disposable Mesh Sub Ohm Tank, it's a polycarbonate 3.0ml plastic tank featuring an integrated 0.15ohm mesh coil rated for 50~70W. A dual slotted bottom airflow control ring is situated at the base and can alter the flow of air into the tank system at the simplest twist for adjustment.
Original Suorin Edge 10W 230mAh Pod System Device Original Price $29.99, Now Only $24.99
The Suorin Edge is a sleek shaped vape device. Simple to use, lightweight and slim, you'll be sure to love the latest addition to the Suorin family of products. This item also has other color to choose.
Original Suorin Replacement Pod Cartridge for Edge Pod System Device $3.48
The Suorin Edge Replacement Pod Cartridge can hold 1.5ml of juice capacity and comes with 1.4ohm coil. It is suitable for Suorin Edge Pod System. It can be used with Nic-Salt e-liquids, Freebase e-liquids,60/40 VG/PG ratio e-liquids and 70/30 VG/PG ratio e-liquids.
Старый 18.02.2019, 05:17 Автор темы   303
3FVAPE
Vapeasy Stratum 303 MOSFET Squonk Box Mod Clone $46.99
The Vapeasy Stratum 303 Squonk Mod Clone is a safe mod with MOSFET which provides reverse polarity protection and short circuit protection. The squonk bottle can hold 8.5ml of e-juice. The mod is powered by single 18650 battery (NOT INCLUDED). The mod is ultra-compact and feels comfortable when holding in hand. This item also has other color to choose.
Original Oumier Wasp Nano RTA Rebuildable Tank Atomizer Original Price $37.50, Now Only $20.99
The Original Oumier Wasp Nano RTA is a new launch from Oumier. Oumier Wasp Nano RTA features 23mm diameter and 2ml of juice capacity. The drip tip is made from PCTG. This tank adopts easy top filling system, dual post build deck for single coil build, and dual side airflow for optimal flavor. This item also has other color to choose.
Vapeasy EVL Reaper V3 RTA Rebuildable Tank Atomizer Clone $20.99
The Vapeasy EVL Reaper V3 RTA Clone is a 22mm mouth-to-lung rebuildable tank atomizer made from 316 stainless steel. It comes with a 2ml and a 5ml ultem tank. The RTA features dual post build deck and adjustable bottom airflow. The bottom airhole of the installed deck is about 2.6mm, and the size of spare MTL deck is 1.6mm.
Original Flowermate Swift Pro 1000mAh Dry Herb Vaporizer Aroma Therapy Device $89.99
The Flowermate SWIFT PRO Vaporizer is ONLY designed for legal dry herb as an aroma therapy device. It is powered by built-in 1000mAh battery and has 1ml capacity for dry herb. The temperature range is from 140 to 446 Fahrenheit degree (60 to 230 Celsius degree). This item also has other colors to choose.
Vapeasy Replacement Squonk Bottle for Stratum 303 MOSFET BF Box Mod Clone $2.99
The Vapeasy Replacement Squonk Bottle is made of food grade silicone and holds 8.5ml of e-juice. It is suitable for Vapeasy Stratum 303 MOSFET Squonk Box Mod Clone.
Старый 19.02.2019, 05:09 Автор темы   304
3FVAPE
YFTK KF Prime Nite DLC RTA Rebuildable Tank Atomizer Clone $21.99
The YFTK KF Prime Nite DLC RTA Clone is a 22mm rebuildable tank atomizer with 2ml of juice capacity. It is made from 316 stainless steel with DLC coating. The tank features top fill design, fully adjustable liquid control, 6 step external adjustable airflow from 1mm to 2mm and small chamber size for the best possible flavor.
YFTK KA V8 RTA Rebuildable Tank Atomizer Clone $21.99
The YFTK KA V8 RTA Clone is a 22mm rebuildable tank atomizer with 5ml of juice capacity. It is made from 316 stainless steel. The RTA features dual post build deck, heat sink top cap and bottom adjustable airflow.
Original Green Sound GS Navigator 800mAh VV All-in-One Starter Kit $23.99
The Green Sound GS Navigator Starter Kit is an elegant vape kit features sail curve design. It is powered by a single 18350 battery (INCLUDED). The mod has 5 levels variable voltage setting, which can work at 3.4V, 3.7V, 4.1V, 4.4V, 4.8V. As for the built-in tank clearomizer, it has a 2ml capacity and 0.4ohm vertical coil, bringing you bigger vapor and better taste. The air enters the chamber from the top and travels to bottom then go straight to the top. The great mod kit will bring you excellent vaping experience. This item also has other color to choose.
Original Vaporesso Sky Solo Plus 3000mAh Starter Kit $26.55
The Original Vaporesso Sky Solo Plus Kit is powered by built-in 3000mAh battery. Equipped with the advanced OMNI Board Mini chip, it provides excellent performance and safe features. The tank comes with 8ml e-juice capacity. The GT Meshed Coil maximizes the interaction with cotton and enlarges the heating area, providing turbo heating performance that produces denser and more flavorful clouds. This item also has other color to choose.
Original Asmodus Flow 500mAh Pod System Starter Kit Original Price $29.99, Now Only $24.99
The asMODus FLOW is step further in the future of stealthy pod devices. The FLOW excels in many ways that other devices lack. The coil installed in the FLOW Pods are a higher resistance to increase flavor production. asMODus made the FLOW larger to help the user in two ways: To provide a better grip when using the device, and its enlarged size makes it much easier to find when misplaced. The large body also allowed the FLOW to be equipped with a larger internal battery to make the device last much longer than any similar devices. Despite the size, the FLOW is made from premium aluminum alloy, making it a deceptively lightweight mod. The FLOW charges via a micro USB port making it easy to charge it anywhere without carrying another unnecessary dedicated charger. This item also has other color to choose.
Original Asmodus Replacement Pod Cartridge for Flow Pod System Device Original Price $10.99, Now Only $6.99
The Asmodus Flow Replacement Pod Cartridge can hold 2ml of juice capacity and comes with 2.5ohm coil. It is suitable for Asmodus Flow Pod System.
This product comes with 2 PCS in 1 pack.
Старый 20.02.2019, 05:04 Автор темы   305
3FVAPE
YFTK Stratum Zero Stratum 0 MOSFET Tube Mod Clone $27.99
The YFTK Stratum Zero Mod Clone is made from 316 stainless steel. It features an ergonomically designed body and a Mosfet that provides maximum protection on all the aspects for vapers, like protection from reverse polarity, short circuit protection. The mod is powered by single 18650 / 21700 battery (NOT INCLUDED).
Original Sikary Vapor Nunu Disposable Sub Ohm Tank Clearomizer $10.99
The Sikary Vapor Nunu Sub Ohm Tank is a disposable clearomizer that comes with 3ml juice capacity and a 0.15ohm mesh coil for 40W to 70W output. The Sikary Nunu tank has a top fill system that uses a fully removable silicone plug. The Nunu has two 8mm by 3mm air slots that can be fully adjusted by rotating the outer barrel of the tank. The entire body of the Nunu is made of acrylic, except for the coil head and the gold-plated contact.
This product comes with 3 PCS in 1 pack. This item also has other color to choose.
Original ThunderHead Creations THC Tauren Solo RDA Rebuildable Dripping Atomizer with BF Pin Original Price $34.90, Now Only $21.99
The ThunderHead Creations THC TAUREN SOLO RDA is an innovative single coil RDA. It comes with unique triple sides with 31-micro air holes which can provide smoothest airflow and intense flavor for vapers. Featuring the stylish appearance which always makes it attractive and eye-catching. It is compatible to Tauren MOD. Just get the TAUREN SOLO RDA and enjoy excellent vaping.
This RDA comes with bottom feeder pin. This item also has other color to choose.
SXK Replacement Tank Tube for Doggystyle V2 2K18 RTA Clone $1.99
This replacement tank tube is made from PC and is suitable for SXK Doggystyle V2 2K18 RTA Clone. It features 22mm diameter and 3.5ml capacity.
Старый 21.02.2019, 05:11 Автор темы   306
3FVAPE
Original Vandy Vape Jackaroo 100W TC VW Variable Wattage Box Mod Original Price $73.99, Now Only $54.09
The Vandy Vape Jackaroo Mod is a single 21700 battery box mod featuring IP67 waterproof, shockproof and dustproof. The G10 and Resin panels are durable and replaceable. Powered by an upgraded Vandy chip, the mod can reach its maximum output to 100W. Ergonomic design provides you comfortable holding and it is no need to worry for rains or dropping by accident. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). This item also has other color to choose.
Original Yosta Livepor 100W TC VW Box Mod + IGVI M2 Tank Kit $37.99
The Yosta Livepor 100W Kit consists of Yosta Livepor 100W Mod and IGVI M2 Tank.This item also has other color to choose.
Mod:
The Original Yosta Livepor 100W Mod is a versatile regulated box mod with compact size and ergonomic design. Powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED), the mod can reach its maximum output to 100W. The mod supports various modes like POWER, Ti, Ni200, SS316, BYPASS. It comes with a 0.96-inch colorful display screen to show necessary vaping data.
Tank:
The Yosta IGVI M2 Tank is a 25mm sub ohm tank with 6ml of juice capacity. It features top refill design, adjustable bottom airflow and 0.15ohm mesh coil for great flavor.
Original Vandy Vape Replacement Mesh Coil Head for Jackaroo Tank / Jackaroo Kit $10.75
The Vandy Vape Jackaroo Replacement Mesh Coil Head comes with 0.3ohm resistance rated for 40~60W. It is suitable for Vandy Vape Jackaroo Tank / Jackaroo Kit.
This product comes with 4 PCS in 1 pack. This item also has other Version to choose.
Старый 22.02.2019, 05:12 Автор темы   307
3FVAPE
Original Vsticking VK530 200W TC VW Variable Wattage Box Mod Original Price $76.99, Now Only $52.84
The Original Vsticking VK530 Mod is an ergonomic body mod with a visually striking graffiti print. There is a large TFT IPS display on the center that shows vape data in full color, and there has a car dashboard theme that features speedometer style wattage or temperature. Vape data on this display includes indicators for current temperature / power / resistance / voltage / battery indicator bars and more. You may also customize the background of the screen to your liking by uploading 5 to 10 wallpapers which is somewhat unique when it comes to mods. Powered by dual 18650 batteries (NOT INCLUDED) with the YiHi SX530 chip and the SXI-Q control system, the VK530 can fire up to 200W maximum output and supports SS316L, Ni200, Ti01, SX Pure, and Manual TCR Ni. The specification is in Chinese. This item also has other color to choose.
Original Yosta Livepor 100W TC VW Variable Wattage Box Mod Original Price $35.99, Now Only $32.15
The Original Yosta Livepor 100W Mod is a versatile regulated box mod with compact size and ergonomic design. Powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED), the mod can reach its maximum output to 100W. The mod supports various modes like POWER, Ti, Ni200, SS316, BYPASS. It comes with a 0.96-inch colorful display screen to show necessary vaping data. This item also has other color to choose.
Original Asmodus Moni 16W 450mAh Stabilized Wood Pod System Starter Kit $79.99
The Asmodus Moni, an ultra-portable device that has a compact form factor while not sacrificing juice and battery capacity and vapor production. The Moni is a pocket friendly and powerful device. Within the Moni is a built-in 450mAh rechargeable battery that allows maximum performance, giving a satisfying experience. A LED indicator directly in the center of the mod will flash fifteen times when your battery's voltage goes below 3.3V. The Moni has a low wattage output of 10~16W for vapers who want to focus on flavor rather than producing massive clouds. The Moni pod has a 2mL reservoir to ensure the vaper is filling less. The Moni is elegantly encased with a Stabilized wood to bring class to any casual vaper.
Original Asmodus Oni Ignition 12W 500mAh CBD Pod System Starter Kit $29.99
Made to be stealthy and very much resembles a car key, Asmodus Oni Ignition is compact and produces a lot of vapor. The pod system is ceramic based and works well with CBD oil. This kit comes with 2 pods and a keychain. For best performance the pod was designed to only be used once. Fill the pod with any flavor you like but once you have capped the pod, it locks into place to create a secure, leak resistant seal. This item also has other color to choose.
Original Asmodus Replacement Pod Cartridge for Moni Pod System Device $11.95
The Asmodus Moni Replacement Pod Cartridge can hold 2ml of juice capacity and comes with 1.5ohm coil. It is suitable for Asmodus Moni Pod System.
Original Asmodus Replacement Pod Cartridge for Oni Ignition Pod System Device $12.99
The Asmodus Oni Ignition Replacement Pod Cartridge can hold 1.8ml of juice capacity and comes with 1.5ohm coil. It is suitable for Asmodus Oni Ignition Pod System.
Старый 26.02.2019, 05:46 Автор темы   308
3FVAPE
Original Uwell Caliburn 11W 520mAh Pod System Kit $23.99
The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product.
Uwell Caliburn Pod System Kit is a first pod vape kit from Uwell. It has elegant appearance and ultra thin body. It is powered by 520mAh built-in battery. With air switch design, you can direct vape by inhaling. In addition, if the draw-activated mechanism fails, the system will automatically disable the draw-activated working mode. You can press the fire button to vape. The pod cartridge has 2ml capacity and comes with top filling system which can reduce leakage. This pod vape kit is perfect suit for beginners. This item also has other color to choose.
Original Vaporesso Aurora Play Replacement Pod Cartridge $7.99
The Vaporesso Aurora Play Zippo Pod System Kit replacement Pod Cartridge is with 2.0ml e-juice capacity. The 1.3ohm pod is best for nic-salts e-juice. Plus the Press-To-Fill design, you can fill the Vaporesso Aurora Play pod with the e-juice filling bottle easily. No mess, no leak and no worries! Just get them as spare parts for your Vaporesso Aurora Play kit.
Original Justfog Minifit Mini Fit Replacement Pod Cartridges $6.89
Justfog Minifit Pod, designed for all vapors who aspire for simple vaping, is perfectly used with Justfog Minifit Kit. It is a 1.5ml refillable cartridge with 1.6ohm coil resistance and Japanese organic cotton coil, which delivers the purest flavor.
Original Uwell Caliburn Replacement Pod Cartridges $9.99
Uwell Caliburn Replacement Pod Cartridge has 2ml capacity and comes with top filling system. Detach the drip tip to refill, reduces leakage. The magnetic connection design is easy to insert into the battery. 4 PCS in a pack.
Старый 27.02.2019, 05:25 Автор темы   309
3FVAPE
Original Uwell Blocks 90W Juice Pump Squonk Box Mod 40.55
The Uwell Blocks Squonk 90W Mod is a new squonk mod that features a patented juice pump on the top of the mod. Powered by single 18650 battery (NOT INCLUDED), Uwell Blocks supports 90W maximum output. It has a built-in juice bottle with 15ml of capacity. By pressing the top button, the juice will be pumped up to the RDA. The mod also features a juice window for easy checking the juice level. The mod has 0.008s fast firing speed. The leak-proof 510 connector prevents the juice leaking into the mod. This item also has other color to choose.
Original Voopoo X217 217W TC VW Variable Wattage Box Mod Original Price $79.00, Now Only $49.99
The Voopoo X217 Mod is compatible with dual 18650 / 20700 / 21700 batteries (NOT INCLUDED) and can reach maximum output to 217W. Made of zinc alloy and resin material to provide better grip feeling and metallic texture with polished rounded corners. Moreover, leather material applied on the both sides also ensures you great hand feeling with its crafted workmanship. What's more, 1.3inch TFT IPS color screen displays the essential information you want to know and V-shape interactive LED breathing light also make vaping become interesting. With safer and more stable GENE.FAN chip inside, you can enjoy safe and powerful vaping. This item also has other color to choose.
YFTK VW Mechanical Tube Mod Clone $21.89
The YFTK VW Mech Mod Clone is made from 316 stainless steel. It measures 22mm in diameter. YFTK VW Mech Mod Clone is power by single 18350 / 18650 battery (NOT INCLUDED).
Kayfun Prime Nite DLC RTA Rebuildable Tank Atomizer Clone $14.65
The Kayfun Prime Nite DLC RTA Clone is a 22mm rebuildable tank atomizer with 2ml of juice capacity. It is made from 316 stainless steel with DLC coating. The tank features top fill design, fully adjustable liquid control, 6 step external adjustable airflow from 1mm to 2mm and small chamber size for the best possible flavor. This item also has other color to choose.
SXK WICK'D WICKD RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $19.90, Now Only $18.99
The SXK WICK'D RDA Clone is made from 316 stainless steel with 22mm diameter. It is a single coil RDA that will be able to accommodate various coil sizes and styles. When the top cap is installed, the chamber is reduced giving the user great flavor. The juice well's depth is also sufficient to hold a great amount of liquid. It is able to remove the airflow block and change it according to your airflow preference. It allows vaper to experience different vaping from loose DL, restricted DL up to MTL.
Original Uwell Blocks 90W Squonk Box Mod + Nunchaku RDA Kit $58.99
The Uwell Blocks 90W Squonk Kit consists of Uwell Blocks Mod and Uwell Nunchaku RDA. This item also has other color to choose.
Mod:
RDA:
The Uwell Nunchaku RDA is a 24mm rebuildable dripping atomizer that comes with a simple build deck for single or dual coils easy building. It has dual airflow for optimal flavor. By using a squonk pin, it is also compatible with Squonk mod.
Original Ambition Mods Polymer Multi-Tool Kit Coil Jigs for DIY Coil Building $24.99
The Ambition Mods Polymer Multi-Tool Kit consists of coil jigs set, mid cap and Trox insert bit set. With this Tool Kit, it is easy to make your own coils and build them on your favorite rebuildable atomizers with ease.
Replacement Tank Tube + 510 Drip Tip Kit for Kayfun Prime Nite DLC RTA Clone $4.99
The replacement tank tube is made from 316 Stainless Steel and PEI. The 510 drip tip is made from PEI. They are suitable for Kayfun Prime Nite DLC RTA Clone. This item also has other color to choose.
Старый 28.02.2019, 05:01 Автор темы   310
3FVAPE
Vicious A Phenom Mechanical Tube Mod Clone $14.99
The Vicious A Phenom Mechanical Mod Clone is a 18350 mech mod with a diameter of 22mm. Made from stainless steel, this mod comes with an engraved line all over the whole mod. The mod is powered by single 18350 battery (NOT INCLUDED). This item also has other color to choose.
YFTK Corinne Hybrid Mechanical Tube Mod Clone $14.99
The YFTK Corinne Mechanical Mod Clone is a mini size 18350 mech mod with a diameter of 22mm. This mod is made from 316 stainless steel. It is very easy to carry and suits your palms perfectly. The mod is powered by single 18350 / 18650 battery (NOT INCLUDED).
KF Lite 2019 RTA Rebuildable Tank Atomizer Clone $14.99
The KF Lite 2019 RTA Clone is a 22mm rebuildable tank atomizer with 2ml of juice capacity. It is made from 316 stainless steel and Ultem. It is designed for mouth to lung vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience. This item also has other color to choose.
Ulton Replacement Long Mode Tank Kit for KF Lite 2019 22mm RTA Clone $3.49
The replacement tank kit has 4ml of juice capacity and is suitable for Ulton KF Lite 2019 22mm RTA Clone . This item also has other Version to choose.
Ulton Replacement Dome Tank Kit for KF Lite 2019 22mm RTA Clone $4.89
The replacement tank kit is suitable for Ulton KF Lite 2019 22mm RTA Clone. This item also has other Version to choose.
Ulton Replacement Bell Tank for KF Lite 2019 22mm RTA Clone $3.39
The replacement tank has 2ml of juice capacity and is suitable for Ulton KF Lite 2019 22mm RTA Clone. This item also has other Version to choose.
Старый 01.03.2019, 04:57 Автор темы   311
3FVAPE
Original Wotofo Profile Unity RTA Rebuildable Tank Atomizer $34.99
The new Profile Unity RTA does not only retain all the advantages of the Profile RDA, but also has the advantages of an RTA's eliquid reservoir. The Profile Unity RTA focuses on providing phenomenal flavor production. All of the flavors of your eliquid locked in the tank awaits you to vape. This is not just any RTA. This is the Profile Unity mesh RTA. Conversations about leakage are going to stop thanks to the groove top cap and perfected eliquid delivery system. The design of the drip tip is going to be different also. It'll make you rethink how drips tips matter.
KF Lite 2019 RTA Rebuildable Tank Atomizer Clone $13.39
The KF Lite 2019 RTA Clone is a 24mm rebuildable tank atomizer with 2ml of juice capacity. It is made from 316 stainless steel and Ultem. It is designed for mouth to lung vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience. This item also has other color to choose.
Original IJOY Katana RDA Rebuildable Dripping Atomizer with BF Pin $19.39
The IJOY KATANA RDA is a new flavor chasing rebuildable dripping atomizer and features the flat clamp design for easy single coil or dual coils rebuilding. The air intake at the bottom is direct to the heating coil so that the clouds are more intensive than normal. It also comes with the gold plated BF (Bottom Feeder) pin and 810 PEI drip tip, The KATANA RDA not only shows your noble taste, but also meets the demanding needs of DIY lovers for deeper vaping experience. This item also has other color to choose.
Reload S RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.79
The Reload S RDA Clone measures 24mm in diameter with a build-friendly postless deck designed for single and dual coil configurations. Featuring a dual adjustable top airflow system, this RDA integrates internal honeycomb airflow holes which provides a satisfyingly smooth draw. In addition, the featured internal honeycomb airflow holes direct airflow to the side and bottom of the coil for optimal flavor and vapor production.
Original Smokjoy VEIIK Airo 360mAh Pod System Starter Kit $22.49
Smokjoy VEIIK Airo Pod System Kit comes with exquisite PU sticked panels which makes it luxury and elegant. It has 360mAh built-in battery and 2ml refillable pod cartridge. The pod cartridge adopts advanced bottom air driven system and organic cotton to bring you optimal flavor. It also features LED indicator on the bottom for displaying battery status. Air switch design makes it simple to use. This item also has other color to choose.
Original Coil Master Vape Cleaning Brush Coil Jig $3.66
The Coil Master Vape Cleaning Brush is a convenient vape tool for coil cleaning and coil building. It has 0.1mm 304 Stainless Steel Bristles. The rod is used as a coil jig, with jig sizes of 2.0mm, 2.5mm, 3.0mm, 3.5mm and 4.0mm.
Original Smokjoy Replacement Pod Cartridge for VEIIK Airo Pod System Kit $2.24
The Smokjoy VEIIK Airo Replacement Pod Cartridge can hold 2ml of juice capacity and comes with 1.2ohm coil. It is suitable for Smokjoy VEIIK Airo Pod System Kit.
Старый 02.03.2019, 05:34 Автор темы   312
3FVAPE
Original Hotcig G100 100W TC VW Variable Wattage Box Mod Original Price $45.99, Now Only $34.49
The Hotcig G100 TC Box Mod is a versatile regulated box mod which uses single 18650, 20700 or 21700 batteries (NOT INCLUDED), and the maximum output is 100W. The front of the mod features a 0.9inch display screen and there are Variable Wattage, Temperature Control and Bypass modes. The battery access door adopts magnetic design. This item also has other color to choose.
Original Joyetech Cuboid 200 200W TC VW Variable Wattage Box Mod Original Price $39.99, Now Only $25.99
Having the glossy zinc alloy shell with its premium finish, the original Joyetech CUBOID 200 provides durability and reliability in its one of a kind style. Featuring 3 replaceable high-rate 18650 batteries (NOT INCLUDED), it can be powered to 200W. The CUBOID 200 has a 0.96-inch OLED display, supporting VT / VW / TCR modes as well as real-time-clock, preheat and custom logo functions. Meanwhile, it is designed with upgradeable firmware with which you can keep the CUBOID 200 up-to-date. This item also has other color to choose.
YFTK KA V8 RTA Rebuildable Tank Atomizer Clone with Full Tank Kit $28.99
The YFTK KA V8 RTA Clone is a 22mm rebuildable tank atomizer with 2.8ml / 5ml of juice capacity. It is made from 316 stainless steel. The RTA features dual post build deck, heat sink top cap and bottom adjustable airflow.
This full kit comes with a Nano Tank kit (2.8ml) and a Long Tank Kit (5ml).
Original Vandy Vape AP MTL Sub Ohm Tank Clearomizer Original Price $19.99, Now Only $18.88
The Vandy Vape AP MTL Sub Tank is a 22mm clearomizer with 2ml of juice capacity. It features Multi-directional air holes with wide range adjustment from 0.6mm to 2.5mm. Together with the BSKR MTL coils (1.5ohm / 1.8ohm), this tank will bring you optimal flavor and great MTL experience.
Original Joyetech Ornate Sub Ohm Tank Clearomizer Original Price $18.99, Now Only $9.99
The Original Joyetech ORNATE atomizer, detailed with the stylings of Neo-Georgian architecture, brings forth such bold characteristics as the MGS triple coil head with three distinct airflow channels. Each air channel correlates with the featured triple airflow inlets for an ultra-low resistance draw. The ORNATE sits prominently on any mod embellished by an ultra-comfortable wide bore drip tip. Its 25mm diameter cleverly disguises a full 6ml. e-liquid capacity. In short, this atomizer looks smart but means business. This item also has other color to choose.
Original Wismec Orma Sub Ohm Tank Clearomizer Original Price $14.99, Now Only $7.59
The Wismec Orma Sub Ohm Tank is a 22mm clearomizer that features 3.5ml juice reservoir, convenient detachable structure, Wismec's DS Coil Technology, and an innovative side-fill that simultaneously serves as the adjustable airflow system. The 0.25ohm DS NC Notch Coil provides ample vapor production as well as excellent vapor production. In addition, it includes an innovative 0.25ohm DS Dual Coil, consisting of Stainless Steel coils placed vertically in parallel arrangements, with wattage range of 25 to 60W. This item also has other color to choose.
YFTK Replacement Drip Tip for 22mm KF Lite 2019 RTA Clone $2.99
The replacement drip tip is made from PC and is suitable for YFTK 22mm KF Lite 2019 RTA Clone. This item also has other color to choose.
YFTK Replacement Bell Tank for 22mm KF Lite 2019 RTA Clone $4.29
The replacement Bell section tank is made from PC and is suitable for YFTK 22mm KF Lite 2019 RTA Clone. It has 2ml of juice capacity. This item also has other color to choose.
YFTK Replacement Long Mode Tank Kit for 22mm KF Lite 2019 RTA Clone $6.39
The replacement Long Mode section tank is made from PEI and is suitable for YFTK 22mm KF Lite 2019 RTA Clone. It has 4ml of juice capacity. This item also has other color to choose.
YFTK Replacement Dome Extension Tank Kit for 22mm KF Lite 2019 RTA Clone $4.99
The replacement Dome Extension Kit is made from PC and is suitable for YFTK 22mm KF Lite 2019 RTA Clone. It has 4ml of juice capacity. This item also has other color to choose.
YFTK Replacement Extension Tank Kit for KA V8 RTA Clone $7.59
The replacement extension tank kit is made from PC and is suitable for YFTK KA V8 RTA Clone. It has 5ml of juice capacity.
Original Vandy Vape Replacement Coil Head for AP MTL Sub Tank / AP Kit / BSKR Kit $7.99
The replacement coil head features 1.5ohm resistance and work well at 7~13W. It is suitable for Original Vandy Vape AP MTL Sub Tank / Vandy Vape AP Kit / Vandy Vape Berserker MTL Kit.
This product come with 5 PCS in 1 pack. This item also has other Version to choose.
Старый 04.03.2019, 04:40 Автор темы   313
3FVAPE
Dvarw MTL RTA Rebuildable Tank Atomizer Clone $10.99
The Dvarw MTL RTA Clone is a 16mm RTA made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. The kit comes with 4 spare airflow inserts to adjust airflow. This RTA will bring you extreme MTL vaping experience.
The airflow insert come with 1 x 0.3mm / 2 x 0.3mm / 3 x 0.3mm / 2 x 0.5mm airhole size. This item also has other color to choose.
Original Eleaf iJust 21700 80W Mod + ELLO Duro Tank Kit $40.85
The iJust 21700 with ELLO Duro (5.5ml version) is the updated version of Eleaf iJust series, delivering a max power of 80 watts by single 21700 / 18650 battery (NOT INCLUDED). It is not just a beautiful tube-style kit though as it introduces the latest HW-M2 and HW-N2 coils that boast an innovative Leakage-Proof & Self-Cleaning (LPSC) technology. These two coils also allow a more uniform airflow and utilize porous cotton as its wicking material for fully and quickly absorbing e-liquid, providing you with an unprecedented vaping experience. The iJust 21700 implements a single button firing mechanism, in which battery life can easily be noticed by a simple glance at the LED light behind the button. In a word, Eleaf iJust 21700 with ELLO Duro is an innovative, practical and essential vape kit for all sorts of vapers. This item also has other color to choose.
810 Replacement Drip Tip for Goon / Kennedy / Reload / Battle RDA $1.49
The replacement 810 drip tip is made from PC. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This item also has other color to choose.
SteamTuners T9 510 Drip Tip Clone for RDA / RTA / Sub Ohm Tank $1.99
The SteamTuners T9 510 Drip Tip Clone is made from stainless steel. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose.
810 Rock Drip Tip Clone for Goon / Kennedy / Reload / Battle RDA $3.59
The replacement 810 drip tip is made from resin. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This item also has other color to choose.
810 Beauty Drip Tip Clone for Goon / Kennedy / Reload / Battle RDA $3.59
Старый 05.03.2019, 04:48 Автор темы   314
3FVAPE
Original Serisvape Viking Mechanical Tube Mod Original Price $119.90, Now Only $57.99
Designed by Arkham Mods in Sweden, manufactured by Serisvape, the Serisvape Viking Mech Mod, is a 24mm mechanical mod constructed from T2 Copper. The mod is a hard hitting mod with excellent conductivity, low resistance and high output. Viking is powered by single 18650 battery (NOT INCLUDED). This item also has other color to choose.
SXK Atto Mechanical Tube Mod Clone + Dvarw V2 MTL RTA Kit Clone $26.99
The mod kit consists of SXK Atto Mod Clone and Dvarw V2 MTL Top Refill RTA Clone.
Mod:
The SXK Atto mechanical mod Clone is made from Stainless Steel. It is powered by a single 18650 / 18350 battery (NOT INCLUDED). The mod is equipped with a MOSFET.
RTA:
The Dvarw V2 MTL RTA Clone is a 22mm RTA made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. The RTA has 1mm bottom and 7mm by 1.9mm side airflow hole. This RTA will bring you extreme MTL vaping experience. The RTA comes with 2ml SteamTuners Style Top Refill Tank.
Please note: this RTA is not from SXK.
Original Vapefly Replacement Glass Tank Tube for Brunhilde Top Coiler RTA $3.00
The Vapefly Brunhilde Top Coiler RTA Replacement Glass Tank Tube has 8ml of juice capacity and is suitable for Vapefly Brunhilde Top Coiler RTA.
Original Vapefly Replacement Frame for Brunhilde Top Coiler RTA $12.99
The Vapefly Brunhilde Top Coiler RTA Replacement Frame is made from stainless steel and is suitable for Vapefly Brunhilde Top Coiler RTA.
Original Vapefly German Stainless Steel Heating Wire for Brunhilde Top Coiler RTA $6.49
Original Vapefly Replacement Drip Tip for Brunhilde Top Coiler RTA $1.99
The Vapefly Brunhilde Top Coiler RTA Replacement Drip Tip is made from resin and is suitable for Vapefly Brunhilde Top Coiler RTA.
YFTK Replacement MOSFET Chip for Stratum Zero Semi-Mechanical Mod Clone $5.19
The Replacement MOSFET Chip is suitable for YFTK Stratum Zero Semi-Mechanical Mod CLone.
Старый 06.03.2019, 06:03 Автор темы   315
3FVAPE
Original Wotofo Profile Unity RTA Rebuildable Tank Atomizer Original Price $39.99, Now Only $25.99
The new Profile Unity RTA does not only retain all the advantages of the Profile RDA, but also has the advantages of an RTA's eliquid reservoir. The Profile Unity RTA focuses on providing phenomenal flavor production. All of the flavors of your eliquid locked in the tank awaits you to vape. This is not just any RTA. This is the Profile Unity mesh RTA. Conversations about leakage are going to stop thanks to the groove top cap and perfected eliquid delivery system. The design of the drip tip is going to be different also. It'll make you rethink how drips tips matter. This item also has other color to choose.
SXK KF Lite 2019 RTA Rebuildable Tank Atomizer Clone Original Price $21.99, Now Only $18.68
The SXK KF Lite 2019 RTA Clone is a 24mm rebuildable tank atomizer with 2ml of juice capacity. It is made from 316 stainless steel and Ultem. It is designed for mouth to lung vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience. This item also has other Version to choose.
Original Sikary Amand 100W VW Variable Wattage Mod + Nunu Tank Kit $28.59
The Sikary Amand mod kit consists of Sikary Amand Mod and Sikary Vapor Nunu Disposable Tank. This item also has other color to choose.
Mod:
Sikary Amand mod is ergonomically designed with concave-convex body, feeling quite nice when holding it. The mod is powered by single 18650, 20700, or 21700 battery (NOT INCLUDED). With 7~100W adjustable wattage output, it satisfies different people's needs at cloud and flavor. Whats more, this device has LED lights, which will light up and change its color along with you vaping.
Tank:
Original Sikary OG 1800mAh Mod + Nunu Disposable Tank Kit $23.59
The Sikary OG Starter Kit consists of Sikary OG Mod and Sikary Vapor Nunu Disposable Tank. This item also has other color to choose.
Mod:
Sikary OG mod is a stick vape mod which has exquisite design and pocket size. 1800mAh built-in battery capacity is enough for your daily vaping needs. One button for easy operation. Moreover, the kit has LED lights at the tank base, which will light up and change its color along with you vaping.
Tank:
Original Hotcig Kubi 550mAh Pod System Starter Kit $14.99
The Hotcig Kubi Pod kit is an ultra-portable Pod System Starter Kit with portable design and anti-leak system. It has a draw-activated switch so it is easy to operate without button. Kubi is powered by a built-in 550mAh battery for long vaping time. The pod cartridge has 1.7ml of juice capacity and 1.8ohm ceramic coil for optimized flavor. This item also has other color to choose.
SXK BBillet Box 70W All-in-One Mod Kit Clone with USB Port Original Price $75.00, Now Only $69.99
The SXK Billet Box Mod Kit Clone is constructed from aluminum with an all-in-one design. This mod comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor.
This Billet Box comes with USB port for charging only. This item also has other Version to choose.
Original Hotcig Replacement Pod Cartridge for Kubi Pod System Starter Kit $12.99
The Hotcig Kubi Replacement Pod Cartridge can hold 1.7ml of juice capacity and comes with 1.8ohm coil. It is suitable for Hotcig Kubi Pod System Kit.
SXK Decorative Ring Chain Lanyard $10.99
The SXK Decorative Ring Chain Lanyard is made from iron with nickel plating (chain) and stainless steel (ring). You can wear it with your favorite mod kit. The decorative ring is suitable for 22mm atomizers. This item also has other size to choose.
Старый 07.03.2019, 04:42 Автор темы   316
3FVAPE
YFTK KF Lite 2019 RTA Rebuildable Tank Atomizer Clone $19.78
The YFTK KF Lite 2019 RTA Clone is a 24mm rebuildable tank atomizer with 2ml of juice capacity. It is made from 316 stainless steel and Ultem. It is designed for mouth to lung vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience.
Original Kamry GXG I2 1900mAh Heat Not Burn Device Vaporizer $29.99
The Kamry GXG I2 Heating Kit is a new generation of dry cigarette vaporizer / heat-not-burn device. Powered by built-in 1900mAh battery, the Kamry GXG I2 can support 25 to 30 with various safe protections. The bottom rotate switch can adjust the temperature among High, Middle and Low. The detachable heating bar guarantees low maintenance cost and easiness in cleaning. As the levels of harmful chemicals are hugely reduced, the Kamry GXG I2 will make your vape be healthier than before. This item also has other color to choose.
Hellfire Apollo 510 Drip Tip Clone for RDA / RTA / Sub Ohm Tank Atomizer $2.99
The replacement 510 drip tip is made from stainless steel. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose.
810 Color Changing Drip Tip for 528 Goon / Kennedy / Reload RDA $2.79
This drip tip will change its original color when being heated and will return to original color after cooling down. For the color changing effect, please check the image. This item also has other color to choose.
Original Vpdam Staggered Kanthal A1 Wire Prebuilt Coil $3.99
The Original Vpdam Staggered Kanthal A1 Pre-built Coils Heating Wire is made from Kanthal A1 wires and features 0.45ohm resistance and (24GA + 24GA) x 32GA wires. This heating wire will be a good vaping choice for DIY.
This product comes with 10 PCS in 1 pack.
Original Coilology Fused Clapton Ni80 Wire Prebuilt Coil $3.39
The Original Coilology Fused Clapton Pre-built Coils Heating Wire is made from Nichrome 80 wires and features 0.34ohm resistance and 26GA x 2 + 36GA wires. This heating wire will be a good vaping choice for DIY.
This product comes with 10 PCS in 1 pack. This item also has other Version to choose.
Старый 08.03.2019, 05:54 Автор темы   317
3FVAPE
Reload S RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.68
YFTK KF Lite 2019 RTA Rebuildable Tank Atomizer Clone $20.59
The YFTK KF Lite 2019 RTA Clone is a 24mm rebuildable tank atomizer with 2ml of juice capacity. It is made from 316 stainless steel and Ultem. It is designed for mouth to lung vaping. The deck is suitable for single coil build. With the adjustable bottom airflow, the RTA will bring you great vaping experience. This item also has other Version to choose.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.99
The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose.
810 Replacement Drip Tip for Goon / Kennedy / Reload RDA $2.59
Fujicco 510 Drip Tip Clone for RDA / RTA / Sub Ohm Tank Atomizer $2.99
The Fujicco 510 drip tip Clone is made from PC. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose.
Старый 09.03.2019, 05:25 Автор темы   318
3FVAPE
Original Vapemons Hunter Pro 220W TC VW Variable Wattage Box Mod $30.99
The Vapemons Hunter Pro box mod adopts VM86 chip and applied on IML panel material, durable and environmental protection. Atomizer at the top of the slide design, easy oil effortlessly. The four hot frying oil atomizing core. At the bottom of the annular heat insulation coating, easy and safe enjoy the pleasure of vapor. Supports Ni / Ti / SS coil with temperature control function.
Original Vapemons X2 Stick Vape Pen 80W 3000mAh Battery Mod Starter Kit Original Price $59.99, Now Only $29.99
Vapemons X2 Stick Starter Kit vape pen, a powerful combination of 3000mAh battery and X2 tank, is born to be a legend. It is newly designed, with a special perforated power button and a carefully carved battery base you can feel how exquisite it is. Vapemons X2 Stick Starter Kit vape pen's large battery capacity is the best guarantee for long time vaping and LED indicator on its body can tell you the specific conditions of itself. The X2 tank is compatible with TFV8 baby coil has the 5.5ml capacity and hyper engines, which can bring you massive vapor. Besides, the tank's patented locking mechanism can effectively solve the leakage problem. This item also has other color to choose.
Original Vpdam Stainless Steel Elbow Tweezers for E-Cigarettes / RTA / RDA / RDTA Coil Building $1.85
Original Vpdam Stainless Steel Elbow Tweezers can withstand the high temperature when you dry fire your coil. Making coil building so much easier. It is a great and handle tool if you are into rebuildable atomizers.
Original Vpdam Stainless Steel + Ceramic Tip Tweezers for E-Cigarettes / RDA / RTA / RDTA Vape Atomizer Coil Building $2.75
The Vpdam Elbow Tweezers can withstand the high temperature when you dry fire your coil. Making coil building so much easier. It is a great and handle tool if you are into rebuildable atomizers.
Original Vpdam Stainless Steel + Ceramic Straight Tip Tweezers for E-Cigarettes / RDA / RTA / RDTA Vape Atomizer $2.75
The Vpdam Straight Tip Tweezer can withstand the high temperature when you dry fire your coil. Making coil building so much easier. It is a great and handle tool if you are into rebuildable atomizers.
Original Wotofo Profile Unity RTA Replacement Glass Tube Tank $2.59
The glass tube tank is suitable for Wotofo Profile Unity RTA atomizer. The glass tank is with 3.5ml capacity. This item also has 5ml Capacity to choose.
Original Coil Master 521 Mini V2 Tab Resistance Tester Ohm Meter Coil Rebuilding Deck $14.99
The Coil Master 521 Tab Mini V2 delivers a modern update to the original multi-functional building accessory, retaining the features of ohm meter reader, voltage drop checker, rebuild deck, and test fire station. It is equipped with a 510 spring-loaded connector for attys of all size and intuitive OLED screen with pipe symbol for test-fire setting and measurement readouts. While your RDA is attached and juiced up with today's top e-liquids, you can read the current ohm status and test fire it. Overall, this is a game-changer, one of the most fascinating device engineered for advanced vapers and DIY cloud chasing enthusiasts in a carrying-size device.
Micro Coil Jig Plus with Screwdriver $3.99
This upgraded version of micro coil jig, it is a compact and handy device for vapers who prefer building their own coils.
The coil tool is easy to use: using the numbered guide on the handle of the tool, simply select your preferred size from five different diameters and begin wrapping until you have achieved the desired number of wraps.
There are 5 diameters users can choose: 1.5mm, 2.0mm, 2.5mm, 3.0mm, 3.5mm.
The biggest difference of this jig is, a screwdriver head is built, so user don't have to buy a screwdriver separately.
Старый 12.03.2019, 05:23 Автор темы   319
3FVAPE
Original Vapelustion Hannia 230W TC VW Variable Wattage Box Mod $48.89
The Vapelustion Hannia Box Mod can reach a maximum output power of 230W with dual 18650 batteries (NOT INCLUDED). The high-definition OLED screen will simplify the operation of the mod. Advanced ergonomic construction offers the user comfortable hand feel, and the aesthetic graffiti design makes the mod more unique.
The mod comes with 3 different sets of replaceable panels.
Original Ovanty KOOP 10W 380mAh Pod System Starter Kit $14.99
The Original Ovanty Koop Kit is a slim and lightweight pod device which has air-driven system without fire button. Koop Kit is comfortable to hold in hand, and it has ergonomic mouthpiece, it can fit your mouth perfectly, giving you a great vaping experience. The kit is powered by 380mAh built-in battery. This item also has other color to choose.
Original Ovanty KOOB 10W 1000mAh Pod System Starter Kit $19.99
The Original Ovanty Koob Kit is an intelligent pod device which has air-driven system without fire button. Koob Kit is comfortable to hold in hand, and it has ergonomic mouthpiece, it can fit your mouth perfectly, giving you a great vaping experience. The kit is powered by 1000mAh built-in battery. This item also has other color to choose.
Original Aspire Replacement Coil Head for Cleito Pro Tank $14.99
The Original Aspire Replacement Coil features 0.5ohm resistance and works well at 60~80W. It is suitable for original Aspire Cleito Pro Tank.
This product comes with 5 PCS in 1 pack.
Original Aspire Replacement Coil Head for Revvo Tank $6.29
The Original Aspire Replacement Coil features 0.1~0.16ohm resistance and works well at 50~100W (best 80~85W). It is suitable for original Aspire Revvo Tank.
Original Aspire Replacement Coil Head for Breeze Starter Kit $8.28
The Original Aspire Replacement Coil features 0.6ohm resistance and works well at 60~100W. It is suitable for original Aspire Breeze Starter Kit.
This product comes with 5 PCS in 1 pack. This item also has other Version to choose.
Original Aspire Replacement BVC Bottom Vertical Coil Head for Nautilus Tank $7.99
The Original Aspire Replacement Coil features 0.7ohm resistance and works well at 18~23W. It is suitable for original Aspire Nautilus Tank.
Original Aspire Replacement Coil Head for PockeX Starter Kit $10.99
The Original Aspire Replacement Coil features 0.6ohm resistance and works well at 18~23W. It is suitable for original Aspire PockeX Starter Kit.
Original Ovanty Replacement Pod Cartridge for KOOP / KOOB Pod System Kit $8.99
The Ovanty KOOP/KOOB Replacement Pod Cartridge can hold 1.5ml of juice capacity and comes with 1.5ohm coil. It is suitable for Ovanty KOOP/KOOB Pod System Kit.
Original Aspire Atlantis EVO Coil Head for Triton 2 / Atlantis / Atlantis V2 / Atlantis Mega Tank $11.58
The Original Aspire Replacement Coil features 0.4ohm resistance and works well at 40~50W. It is suitable for original Aspire Triton 2 / Atlantis / Atlantis V2 / Atlantis Mega Tank.
This product comes with 5 PCS in 1 pack. This item also haso ther Version to choose.
Старый 13.03.2019, 05:13 Автор темы   320
3FVAPE
Original Vapmod Vmod 900mAh CBD Mod $12.99
Vapmod Vmod has a tiny size and 900mAh large capacity. It is designed with a large circle button to operate conveniently. It comes with 15s preheating function, you will enjoy pure and nice taste. It also has 3 adjustable voltages that can satisfy your different vaping needs. ST smart chip ensure safe vaping. This item also has other color to choose.
Original Tesla Citrine 24 Sub Ohm Tank Clearomizer Atomizer $6.99
The Original Tesla Citrine 24 Sub Ohm Tank is an inexpensive 24mm sub-ohm tank. Despite being mainly made of PC material, the tank actually has an internal metal structure, making it extremely durable and one of the most cost-effective non-disposable tanks on the market. Both the top cap and base of the tank have a texture for grip. The base section additionally has dual and fully adjustable airflow slots as well as a gold-plated 510 pin with Stainless Steel threading. The included and pre-installed coil is a T-X4 Mesh with a 0.17ohm resistance, rated between 40~60W. This item also has other color to choose.
Original Vandy Vape Berserker BSKR V1.5 Mini MTL RTA Rebuildable Tank Atomizer Original Price $32.49, Now Only $24.99
The Vandy Vape Berserker BSKR V1.5 Mini RTA is an innovative MTL RTA. Berserker V1.5 Mini simplified top fill design and improved liquid flow. It features convenient airflow ring, five sizes airflow slots can be adjusted by your preference. This new RTA will offer you real MTL vaping experience. As the berserker featuring, it also has two appearances and two drip dips. Get this new Berserker V1.5 Mini MTL RTA to enjoy excellent MTL vaping experience. This item also has other color to choose.
YFTK TROYA MV2 MTL RTA Rebuildable Tank Atomizer Clone $23.99
The YFTK TROYA MV2 MTL RTA Clone is constructed from 316 stainless steel and PEI tank. The MTL RTA is with 22mm diameter and 3.7ml capacity. The single coil RTA is a perfect MTL RTA. This item also has other color to choose.
Original Pioneer4You iPV Aspect 750mAh Pod System Starter Kit $21.38
iPV presents the Aspect Pod System, a button activated device powered by the YiHi SXK1 chipset and has two wattage output modes. The amazing aspect also has adjustable air flow built into its pod system and a robust 750mAh.
The iPV Aspect, powered by the YiHi SXK1 chip utilizes a single firing button that also allows the user to change between high and medium wattage modes. High wattage mode has a range of 7.8 to 13.7W and medium wattage mode has a range of 7.8 to 11.5W. The Aspect has a unique pod system with 2.0ml capacity, 1.0 atomizer resistance, and SS316 heating material. This pod system has adjustable side airflow covered by a silicone strip and is bottom filled. The iPV Aspect has a 30mm by 16mm viewing port. The robust has a 750mAh capacity that has 0.5A charging. Four LED indicators show four lights for 100 to 76%, three lights for 75 to 51%, two for 50 to 26%, and one for 25 to 0%. This set of indicator lights also show the first and fourth light to indicate high wattage mode, and the middle two lights for medium wattage mode. This item also has other color to choose.
Original FreeMax Twister 316L Stainless Steel X1 Mesh Coil Head $13.39
The Freemax Twister Coil is specially designed for the Freemax Twister Kit. The SS316L X1 0.12ohm coil supports 400'F to 550'F, which will bring you various vaping experience. 5 PCS each pack. Get it as a spare part for your Freemax Twister Kit. This item also has other Version to choose.
Original Vpdam 170 PVC + Steel Diagonal Pliers for RDA / RTA / RDTA Vape Atomizer $2.89
Vpdam 170 PVC + Steel Diagonal Cut Pliers is a bigger pliers that is very effective when you try to cut bigger and thicker wires when building coils. It is very sharp and effective. Besides, the light weight makes it easy to carry it anywhere! A must-have for DIY vapers.
Original Vpdam Stainless Steel + Ceramic Straight Tip Tweezers for RDA / RTA / RDTA Vape Atomizer $2.75
The Vpdam Straight Tip Tweezer can withstand the high temperature when you dry fire your coil. Making coil building so much easier. It is a great and handle tool if you are into rebuildable atomizers. This item also has other Version to choose.
Original Pioneer4You IPV Aspect K1 Replacement Pod Cartridge $6.99
The Pioneer4You IPV Aspect K1 Replacement Pod is designed to work exclusively with the IPV Aspect Kit. The Aspect's refillable cartridge is equipped with a 2ml E-Juice capacity and a resistance of 1.0ohm. The Aspect K1's exclusive feature being the adjustable airflow control. Most pod systems not allowing you to adjust the air flow effectively limiting your vaping experience to what they want instead of what you want. The Aspect's pod is bottom filling and has 2 strong magnets on the bottom to keep it from popping off incase of a fall.
Время генерации страницы 0.45362 секунды с 15 запросами
