302474
822
261
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Vapeasy Mini B MiniB Mechanical Tube Mod Limited Edition Clone $27.99
The Vapeasy Mini Bestia Mini B Mod Limited Edition Clone is the smallest 18650 mech mod. It is constructed from brass, with hybrid connection and side fire button. The mod is powered by only single 18650 battery (NOT INCLUDED). It features full engraved tube with anti-oxidation feature. This mod comes with insulated insert and protruding battery contact (about 0.3mm), so the battery can be put in any direction. This atomizer should have a protruding pin with length more than 4.5mm to ensure safety and better contact. This item also has other colors to choose. ![]() Dvarw MTL RTA Rebuildable Tank Atomizer Clone $12.99 The Dvarw MTL RTA Clone is a 16mm RTA made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. The kit comes with 4 spare airflow inserts to adjust airflow. This RTA will bring you extreme MTL vaping experience. The airflow insert come with 0.8mm / 2 x 0.8mm / 3 x 0.8mm / 2 x 1mm / 2 x 1.2mm airhole size. ![]() Original Vaporesso Sky Solo 1500mAh Starter Kit $39.90 The Original Vaporesso Sky Solo Kit is powered by built-in 1500mAh battery. Equipped with the advanced OMNI Board Mini chip, it provides excellent performance and safe features. The tank comes with 3.5ml e-juice capacity. The GT Meshed Coil maximizes the interaction with cotton and enlarges the heating area, providing turbo heating performance that produces denser and more flavorful clouds. This item also has other colors to choose. ![]() Original Vaporesso Luxe Nano 80W 2500mAh TC VW Box Mod + SKRR-S Mini Tank Kit Original Price $89.90, Now Only $59.99 The Original Vaporesso Luxe Nano Kit consists of Vaporesso Luxe Nano Mod and Vaporesso SKRR-S Mini Tank. This item also has other colors to choose. Mod: The Vaporesso Luxe Nano combines the same beastly power as its predecessor in its compact design. Equipped with sleek edge-to-edge 1.3inch TFT screen, the mod fits comfortably in your palm. Holding it in hand, the vibration-enabled buttons provide tactile feedback you expect from high-tech devices. The integrated OMNI Board 4.0 chip achieves the most rapid, stable yet safe firing rate of 0.001s, bringing you rich flavor and denser clouds within the very first puff. The resistance range, from 0.03 to 5 ohm, is adaptive to all mainstream tanks. Tank: The Vaporesso SKRR-S Mini Tank has 3.5ml of juice capacity. The innovative 0.15ohm QF Strip coil provides rapid, even heating, longest-lasting. Combining the use of airflow and an internal, it has minimized leaking. ![]() Original IJOY Replacement Pod Cartridge for Stick VPC Pod Kit / VPC 1.6 Pod $9.99 The replacement pod cartridge features 1.6ml of juice capacity and 1.6ohm resistance coil. It is suitable for Original IJOY Stick VPC Pod System Kit / VPC 1.6 Pod. This product comes with 3 PCS in 1 pack. ![]() Original IJOY Replacement Pod Cartridge for AI Pod System Kit $7.99 The replacement pod cartridge features 2ml of juice capacity and 1.6ohm resistance coil. It is suitable for Original IJOY AI Pod System Kit. This product comes with 3 PCS in 1 pack. ![]() Original IJOY Replacement Pod Cartridge for IVPC Pod System Kit $7.99 The replacement pod cartridge features 2ml of juice capacity and 1.6ohm resistance coil. It is suitable for Original IJOY IVPC Pod System Kit. This product comes with 3 PCS in 1 pack.
262
Original Ehpro SPD A8 80W 4000mAh TC VW Variable Wattage Box Mod Original Price $30.99, Now Only $18.99
The Original Ehpro SPD A8 Mod is a regulated mod that is powered by built-in 4000mAh battery. It can work at between 5 and 80 watts in VW mode, 0.5 and 8 volts in VV mode. The resistance range is from 0.3 to 3 ohm. It comes with a spring-loaded brass center pin and Micro USB charging port. This item also has other colors to choose. ![]() Get Low Mods GLM V3 Hybrid Mechanical Tube Mod Clone $13.99 The Get Low Mods GLM V3 Mechanical Mod Clone is constructed from copper. It has hybrid connection and spring fire button. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original Artery Pal 2 1000mAh Pod System Starter Kit Original Price $34.90, Now Only $29.99 The Original Artery Pal 2 Kit, a Tony B project, is a upgraded version of Pal Kit. It features aluminum body, 1000mAh built-in battery and 2ml replaceable pod. The coil can be replaced and there are two types of coils, which are the 0.6ohm mesh coil and the 1.2ohm regular MTL coil. This item also has other colors to choose. ![]() Original Artery Lady Q 1000mAh All in One Starter Kit Original Price $29.89, Now Only $18.99 The Artery Lady Q is a discreet and unique vaporizer designed with women in mind. With a lipstick style design, the Lady Q is perfect to keep in purse or handbag. The Lady Q offers the reliable and consistent performance among with portability and convenience. Available in three vibrant colors, the Lady Q is an expressive vaping device with a classy appearance that doesn't sacrifice quality. The Lady Q is a modern vaporizer for the modern woman. This item also has other colors to choose. ![]() Original Ehpro 2-in-1 Fusion 150W TC VW Mod + Fusion RDTA Kit Original Price $61.99, Now Only $43.99 The Ehpro 2-In-1 Fusion mod kit consists of Fusion box mod and Fusion RDTA. This item also has other colors to choose. Mod: The Fusion mod is powered by dual 18650 batteries (NOT INCLUDED) and the max output is 150 watts. The mod has two separate chips in and can be used to power the coils independently, each max capable of 100 watts when used in dual way. If used in single way, the max output will be 150 watts. The front panel of Fusion mod built-in 0.96inch OLED screen, which displays the vaping data clearly. The side indicator light will notice you how much power left. Tank: The Fusion RDTA features dual coil deck, two separate chambers for different flavors, and each chamber can hold 2ml of e-juice. The side airflow adjustable design allows vapers to adjust the airflow easily. ![]() SOB S3 Mechanical Box Mod Clone + Outlaw RDA Kit Clone $20.99 The SOB S3 Mech Kit Clone consists of SOB S3 Mech mod Clone and Outlaw RDA Clone. This item also has other colors to choose. Mod: The SOB S3 Mechanical box mod Clone is constructed from Brass and POM and is powered by dual 18650 batteries in parallel (NOT INCLUDED). The battery access door is easy to remove by hand. RDA: The Outlaw RDA Clone is constructed from PC (cap) and stainless steel (base) with 24mm diameter. The deck features classic dual post style design and comes with a deep juice well. The airflow can be adjusted by dual airslots on each side. ![]() Knight Mechanical Box Mod Clone + Fuel RDA Kit Clone $25.59 The Knight Mech Kit Clone consists of Knight Mech mod Clone and Fuel RDA Clone. This item also has other colors to choose. Mod: The Knight Mechanical box mod Clone is constructed from Brass and POM and is powered by Quad 18650 batteries in parallel / Series (NOT INCLUDED). The mod will bring you more vapor production than dual battery mods. RDA: The Fuel RDA Clone is constructed from PEI and stainless steel. The deck features dual post style design and comes with a deep juice well. The airflow can be adjusted by the top cap. ![]() Original Artery Uno 1500mah All in One Starter Kit Original Price $40.99, Now Only $20.99 The Artery Uno Kit is an ultra-compact starter kit made from Aluminum and Zinc Alloy. It is powered by 1500mah built-in battery. The atomizer has 3.5ml of juice capacity and supports adjustable airflow. It is a great device for all starters. ![]() Original Artery Replacement Regular Coil for Pal 2 Kit $5.99 The replacement coil features 1.2ohm resistance and works well at 7~12W. It is suitable for Artery Pal 2 Kit / Artery Pal 2 Replacement Pod. This product comes with 5 PCS in 1 pack. ![]() Original Artery Replacement Mesh Coil for Pal 2 Kit $7.59 The replacement coil features 0.6ohm resistance and works well at 15~23W. It is suitable for Artery Pal 2 Kit / Artery Pal 2 Replacement Pod. This product comes with 5 PCS in 1 pack. ![]() Original Artery Replacement Pod Cartridge for Pal 2 Kit $5.90 The replacement pod cartridge comes with 2ml of juice capacity and is suitable for Artery Pal 2 Kit. This item also has other Version to choose. This product does not contain any coil, which need to be purchased separately.
263
Hellboy RDA Rebuildable Dripping Atomizer Clone Original Price $9.99, Now Only $4.99
The Hellboy RDA Clone features unique cube shape and it measures 22.5mm by 22.5mm. The RDA is made from stainless steel. The build deck comes with triple post design and the side airflow is adjustable with the top cap and the airflow can match both single and dual coil builds. This item also has other colors to choose. ![]() Original Ehpro Mr.Owl RDA Rebuildable Dripping Atomizer Original Price $11.99, Now Only $5.99 The Original Ehpro Mr. Owl RDA is a 22mm uniquely designed RDA with fins on the bottom and top. It comes with a chuff drip tip and a spare wide bore one. The RDA has a triple post build deck and side airflow for great vaping experience. This item also has other colors to choose. ![]() Ulton Knight LowRider RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.59 The Ulton Knight LowRider RDA Clone is a super low-profile BF RDA with 22mm diameter. It is made from 316 stainless steel. The deck is very wide for single coil build. Coming with side airflow, this RDA will bring different vaping experience. This RDA comes with bottom feeder pin. ![]() Original Ehpro Iguana RDA Rebuildable Dripping Atomizer with BF Pin Original Price $13.99, Now Only $6.99 The Original Ehpro Iguana RDA is a 24.5mm BF RDA that features dual post build deck, which has quad terminals for dual coil builds. There are two squonk holes just right below the wicks. The bottom airflow will bring great flavor. 810 Ultem drip tip is included. ![]() Original LIO Device 400mAh Pod System Starter Kit $14.99 With compact and portable design, the Original LIO Device Kit is a great all-in-one pod starter kit. Working with built-in 400mAh battery, LED battery level indicator light, and 0.7ml LIO pod cartridge, the LIO Device MOD will bring you a convenient vaping experience. This item also has other colors to choose. ![]() Original Smoant Karat 370mAh Pod System Starter Kit Original Price $29.90, Now Only $16.99 The Original Smoant Karat Pod System Starter Kit features innovative Quartz coil, diamond cut one-piece design, dual filling slots and steady output. It is powered by built-in 370mAh battery and comes with 2ml pod cartridge, which has a 1.3ohm coil. The Quartz coil features shorter priming time, stable heating and better flavor. The bottom comes with a lanyard hole for easy carry. This item also has other colors to choose. ![]() Original LIO Device Replacement Pod Cartridge for LIO Pod System Starter Kit $6.99 The replacement pod cartridge features 0.7ml of juice capacity and 1.6ohm resistance coil. It is suitable for Original LIO Device Pod System Kit. This product comes with 4 PCS in 1 pack. ![]() Original Smoant Replacement Pod Cartridge for Karat Pod System Starter Kit $2.89 The replacement pod cartridge features 2ml of juice capacity and 1.3ohm resistance coil. It is suitable for Original Smoant Karat Pod System Kit.
264
1:1 Hammerhand Hybrid Mechanical Tube Mod Clone $14.89
The Hammerhand Mechanical Mod Clone is made from brass with hybrid connection. It is powered by single 18650 battery (NOT INCLUDED). The mod comes with spring fire button and it can be locked to avoid mis-firing. This mod is made at 1:1 scale. This item also has other colors to choose. ![]() Original Wotofo Elder Dragon RDA RYUJIN RDA Rebuildable Dripping Atomizer with BF Pin Original Price $34.99, Now Only $24.59 The Original Wotofo Elder Dragon RDA, as a projection of the mighty dragons in the story, is competent to fulfill any tasks in breathing clouds and controlling your e-liquid for perfect flavor. It is designed by Wotofo and the Japanese YouTube reviewer Ryusei Sakaue, and is named Ryujin (the dragon god) for Japan Edition. It features compact pagoda shape, 22mm postless build deck allowing different coil directions, focused air supply guaranteeing perfect flavor production and deep juice well for longer vape. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Ehpro Revel RDTA Rebuildable Dripping Tank Atomizer Original Price $18.99, Now Only $7.99 The Original Ehpro Revel RDTA is a 22mm rebuildable dripping tank atomizer. It has a pyrex glass tank with 3ml of juice capacity. Coming with a triple post build deck, it is easy to build dual coils. The airflow enters the chamber via the bottom air holes and will bring you great flavor. This item also has other colors to choose. ![]() Original Ehpro Billow V2 Nano RTA Rebuildable Tank Atomizer Original Price $18.99, Now Only $7.99 The Billow v2 Nano RTA is a 23mm RTA with glass tank that holds 3.2ml of e-liquid. The glass section still tapers out measuring 23mm in diameter and the base and the top cap of the Billow v2 Nano RTA are still 22mm in diameter allowing it to still sit flush on all of your 22mm mods. The RTA also features triple post build deck and adjustable bottom airflow. This item also has other colors to choose. ![]() Coppervape Ka V6 Long Tank MTL RTA Rebuildable Tank Atomizer Clone $19.99 The Coppervape Ka V6 MTL RTA Clone is a 22mm mouth-to-lung RTA with 5.6ml long tank. It is made from 316 stainless steel. It comes with 1.2mm airhole deck for single coil build and will bring you pure flavor with bottom airflow. This item also has other color to choose. ![]() Original Mulwin Q20 Spinner 300mAh Pod System Starter Kit $23.99 The Original Mulwin Q20 is an ultra compact pod system kit that features spinner design, which means you can play it as a finger spinner. It comes with a 2ml refillable pod with 1.2ohm coil. The Q20 pod automatically activate when you inhale. With 2-color power indicator and a micro-USB port, it is very convenient to use and charge. This item also has other colors to choose. ![]() Original ATVS Ghost 350mAh Pod System Starter Kit $9.99 The Original ATVS Ghost is super portable and comfortable to fit your palm. The Ghost comes with a 1.8ml pod with 1.4ohm coil, which will bring you smooth flavor. Powered by built-in 350mAh battery, it also comes with multiple protections to guarantee safe vaping. This item also has other colors to choose. ![]() Original ATVS Replacement Pod Cartridge for Ghost Pod System Starter Kit $5.99 The replacement pod cartridge features 1.8ml of juice capacity and 1.4ohm resistance coil. It is suitable for Original ATVS Ghost Pod System Kit. This product comes with 3 PCS in 1 pack. ![]() Coppervape Replacement 2.4mm Airhole Deck for Ka V6 RTA Clone $2.99 The replacement airflow deck is made from 316 Stainless Steel and Teflon and comes with 2.4mm airhole. It is suitable for Coppervape Ka V6 RTA Clone. ![]() Coppervape Replacement Dripper 510 Drip Tip Adapter for Ka V6 RTA Clone $2.29 The replacement dripper 510 drip tip adapter is made from 316 Stainless Steel and is compatible with 510 drip tip. It is suitable for Coppervape Ka V6 RTA Clone. ![]() Coppervape Replacement Long Tank Tube for Ka V6 RTA Clone $1.99 The replacement long tank tube (5.6ml) is made from PC and is suitable for Coppervape Ka V6 RTA Clone.
265
Original Maskking TODOO Heat Not Burn Device with Dual Battery Charger $43.99
The Original Maskking TODOO is a Heat Not Burn Device that is powered by single 18650 battery (NOT INCLUDED). It is compatible with various of heat sticks in the market. It can work for 20 puffs or 5 minutes. And it comes with a double battery charger to charge 18650 battery. This item also has other colors to choose. ![]() Original Acrohm Fush LED Semi-Mechanical Tube Mod $74.99 The Original Acrohm Fush Mod is an innovative semi-mechanical that features a LED color tube, which can be changed to different color with just a shake. It is safer to use than mechanical mod, and it can reach a firing speed less than 0.01S, and the minimum resistance is 0.07ohm. The mod is powered by single 18650 battery (NOT INCLUDED). It uses stainless steel and bulletproof PC material, together with 6 protections, it is a durable and safe mod for your choice. ![]() EVL Reaper V3 MTL RTA Rebuildable Tank Atomizer Clone $20.99 The EVL Reaper V3 MTL RTA Clone is a 22mm mouth-to-lung rebuildable tank atomizer made from 316 stainless steel. It comes with a 2ml ultem tank. The RTA features dual post build deck and adjustable bottom airflow. The internal airhole size is 1.8mm and the MTL airflow ring sizes are 1.8mm, 1.6mm, 1.4mm, 1.2mm, 1.0mm and 0.8mm. This RTA comes without drip tip. ![]() Original Maskking Nightingale 1100mAh Starter Kit $19.99 The Original Maskking Nightingale Kit is a simple but powerful starter kit, with 1100mAh built-in battery, 2ml tank which has Ceramic core to keep the flavor more delicate and better, Magnetic dust-Proof cap to make the mouthpiece cleaner and more hygienic, and buttom LED ring light to make it more fashionable and beautiful, also display battery power. This item also has other colors to choose. ![]() Original Maskking Mini Tank 16W 1800mAh Battery Mod Starter Kit $32.99 The Original Maskking Mini Tank Starter Kit is powered by built-in 1800mAh battery. It comes with a 2ml atomizer with 1.0/1.5ohm resistance. It has a dust-Proof cap on the drip tip. The kit provides you a safe vaping with six protections: overvoltage protection, overcharge protection, over discharge protection, power protection, short-circuit protection, and overload protection. This item also has other colors to choose. ![]() Original Maskking Trek 80W 2800mAh Mod + Piston RDA Starter Kit $43.99 The Original Maskking Trek Starter Kit is powered by built-in 2800mAh battery and can reach maximum output to 80W. The kit includes Piston RDA, which is constructed from 316 stainless steel and PEI. The Maskking Trek Kit will bring you dense flavor and massive clouds. The image is for reference only, the actual product will come with a Piston RDA. This item also has other colors to choose. ![]() Original Maskking Guardian 1000mAh Starter Kit $36.99 The Original Maskking Guardian Starter Kit is powered by built-in 1000mAh battery. It comes with a 2ml atomizer. Equipped with a smart chip, it provides 4.8V constant voltage output, which does not affect the taste no matter the battery is full or low. The unique stainless dust-proof cap keeps drip tip clean. Small body gives you big vapor. This item also has other colors to choose. ![]() Original Maskking T-More 2800mAh 100W TC VW Variable Wattage Box Mod + Piston RDA Kit $66.69 The Original Maskking T-More Starter Kit is powered by built-in 2800mAh battery and can reach maximum output to 100W. The mod utilizes double electric balanced technology, with 0.015s speed ignition, 5 working modes and 6 protections. The kit includes Piston RDA, which is constructed from 316 stainless steel and PEI. The Maskking Trek Kit will bring you dense flavor and massive clouds. The image is for reference only, the actual product will come with a Piston RDA. This item also has other colors to choose. ![]() Original Suorin iShare Single 9W 130mAh Pod System Starter Kit $13.89 The Original Suorin iShare Single Pod System Kit is an ultra-portable device with 130mAh battery and a refillable 0.9ml cartridge. The refillable pod is suitable for Nic salt e-liquid and has a 2.0 ohm atomizer resistance. With draw activated firing design, you can just take a puff without any switch. This item also has other colors to choose. ![]() Replacement Tank Tube for Vandy Vape Kylin V2 RTA $1.79 The replacement glass tank tube has 3ml of juice capacity and is suitable for Original Vandy Vape Kylin V2 RTA. ![]() Replacement Bubble Tank Tube for Vandy Vape Kylin V2 RTA $1.99 The replacement glass tank tube has 5ml of juice capacity and is suitable for Original Vandy Vape Kylin V2 RTA. ![]() Original Suorin Replacement Pod Cartridge for iShare / iShare Single Pod System Kit $6.99 The replacement pod cartridge features 0.9ml of juice capacity and 2.0ohm resistance coil. It is suitable for Original Suorin iShare / Suorin iShare Single Pod System Kit. This product comes with 3 PCS in 1 pack.
266
Original Demon Killer JBOX 420mAh Pod System Mod $10.89
The Original Demon Killer JBOX Mod comes with a compact size and stylish demon pattern. The panels adopt the mirror finish, which feels very smooth and comfortable when holding it in hand. Powered by a 420mAh built-in battery, it perfectly meets your daily vaping need. Because of the light weight and mini size, you can easily hang it on the neck or put into the pocket. This item also has other colors to choose. ![]() Original Vapor Storm ECO Pro 80W TC VW Variable Wattage Box Mod Original Price $25.50, Now Only $23.99 The Vapor Storm ECO Pro Box Mod is constructed from ABS, with unique graffiti patterns and attractive colors, the mod is lightweight and convenient to carry around. Powered by single 18650 battery (NOT INCLUDED), the ECO Pro Mod is able to reach up to a maximum output power of 80W. This item also has other colors to choose. ![]() Original Wotofo Profile RDA Rebuildable Dripping Atomizer with BF Pin Original Price $34.99, Now Only $23.49 Designed by Wotofo and Mrjustright1, this RDA aims to free every single flavor in you juice to your taste sensation. It is the flavor profile interpreter for your juice. The Original Wotofo Profile RDA is an innovative BF RDA that features unique clamp style dual post build deck, which is easy to switch between mesh and wire coils. The RDA has a 24mm sleeve with multiple airholes for accurate airflow. It supports up to 30 puffs at 75W before needing to re-saturate the wick when using pancake wicking method. What's more, this RDA supports both top refilling and bottom feeding. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() SXK Boxxer RDTA Rebuildable Dripping Tank Atomizer Clone for Billet Box Mod Clone Original Price $32.90, Now Only $30.99 The SXK Boxxer RDTA Clone is made from 316 stainless steel. It features a dual post build deck and a silicone gasket sealed tank with about 5ml of juice capacity. It is suitable for SXK Billet Box Mod Cllone. Image for reference only, the box mod is not included. This item also has other color to choose. ![]() Original Vapor Storm ECO Pro 80W TC VW Box Mod + Hawk Tank Kit Original Price $36.00, Now Only $34.99 The Vapor Storm ECO Pro Hawk Kit consists of Vapor Storm ECO Pro Box Mod and Vapor Storm Hawk Tank. This item also has other colors to choose. Mod: The Vapor Storm ECO Pro Box Mod is constructed from ABS, with unique graffiti patterns and attractive colors, the mod is lightweight and convenient to carry around. Powered by single 18650 battery (NOT INCLUDED), the ECO Pro Mod is able to reach up to a maximum output power of 80W. Tank: The Original Vapor Storm Hawk Tank is a 24mm sub ohm tank with 6ml of juice capacity. It comes with a 0.2ohm mesh coil head and adjustable bottom airflow control for pure and optimal flavor. ![]() Original Vapor Storm ECO Pro 80W TC VW Box Mod + Lion RDA Kit Original Price $34.00, Now Only $32.99 The Vapor Storm ECO Pro RDA Kit consists of Vapor Storm ECO Pro Box Mod and Vapor Storm Lion RDA. This item also has other colors to choose. Mod: The Vapor Storm ECO Pro Box Mod is constructed from ABS, with unique graffiti patterns and attractive colors, the mod is lightweight and convenient to carry around. Powered by single 18650 battery (NOT INCLUDED), the ECO Pro Mod is able to reach up to a maximum output power of 80W. RDA: The Original Vapor Storm Lion RDA made of stainless steel, it comes with 24mm diameter and dual post deck. And the Lion RDA features easy top fill design and adjustable bottom airflow control system for optimal flavor and huge cloud. It can support dual coils. ![]() Original Demon Killer Replacement Pod Cartridge for JBOX Mod $5.89 The replacement pod cartridge features 0.7ml of juice capacity and 1.5ohm resistance coil. It is suitable for Original Demon Killer JBOX Mod. This product comes with 4 PCS in 1 pack. ![]() Original Vapor Storm Replacement Mesh Coil Head for Hawk Tank Original Price $9.00, Now Only $6.99 The replacement mesh coil features 0.2ohm resistance and works well at 20 to 80W, best at 40 to 60W. It is suitable for Original Vapor Storm Hawk Tank / Vapor Storm Eco Pro Hawk Tank Kit. This product comes with 3 PCS in 1 pack.
267
Original Advken Manta RTA Rebuildable Tank Atomizer Resin Edition Original Price $25.99, Now Only $24.49
Advken Manta RTA Resin Edition is coming! The Original Advken Manta RTA is a 24mm diameter tank with 4.5ml capacity. The special two-post design can be compatible with different types of wires. It also features convenient top filling, gold plated posts, and bottom adjustable airflow. Manta RTA comes with a beautiful resin 810 wide bore drip tip. This item also has other colors to choose. ![]() Coil Father King RDA Rebuildable Dripping Atomizer Clone $6.99 The Coil Father King RDA is a 22mm rebuildable dripping atomizer constructed from aluminum cap and stainless steel deck. The build deck features postless design for single coil build. With dual side airflow, this RDA will bring you smooth vaping experience. ![]() Tower Mods Battle Master V2 Mechanical Mod Clone + Evil Clown RDA Kit Clone $22.99 The Battle Master V2 Mod Kit Clone consists of Battle Master V2 Mechanical Mod Clone and Evil Clown RDA Clone. This item also has other colors to choose. Mod: The Battle Master V2 Mechanical box mod Clone is constructed from Brass and POM and is powered by single 18650 battery (NOT INCLUDED). It can also use dual 18650 batteries with external tube in series. The battery access door is easy to remove by hand. RDA: The Evil Clown RDA Clone is constructed from stainless steel with 25mm diameter. The deck features triple post style design for easy dual coil builds. Working with the side airflow, it will bring you dense flavor and massive cloud. ![]() Kalasag V2 Mechanical Mod Clone + Kampilan RDA Kit Clone $25.99 The Kalasag V2 Mod Kit Clone consists of Kalasag V2 Mechanical Mod Clone and Kampilan RDA Clone. This item also has other colors to choose. Mod: The Kalasag V2 Mechanical box mod Clone is constructed from Brass and POM and is powered by quad 18650 batteries in parallel / series (NOT INCLUDED). The battery access door is easy to remove by hand. RDA: The Kampilan RDA Clone is constructed from PC and stainless steel with 24mm diameter. The deck features dual post style design for easy dual coil builds. Working with the adjustable side airflow, it will bring you optimal flavor and massive cloud. ![]() Viper Mechanical Mod Clone + Kampilan RDA Kit Clone $24.99 The Viper Mod Kit Clone consists of Viper Mechanical Mod Clone and Kampilan RDA Clone. This item also has other colors to choose. Mod: The Viper Mechanical box mod Clone is constructed from Brass and POM and is powered by dual / triple / quad 18650 batteries (NOT INCLUDED). The battery access door is easy to remove by hand. Dual 18650 battery external tubes are included. RDA: The Kampilan RDA Clone is constructed from PC and stainless steel with 24mm diameter. The deck features dual post style design for easy dual coil builds. Working with the adjustable side airflow, it will bring you optimal flavor and massive cloud. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA Original Price $1.99, Now Only $0.89 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This drip tip will be shipped with random color (1 piece). More option than what's on the image. This item also has other Version to choose. ![]() ShenRay Vapor Giant 510 Drip Tip Clone with Logo for RDA / RTA / Sub Ohm Tank Atomizer $4.99 The ShenRay Vapor Giant 510 drip tip is made from stainless steel. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other Version to choose. This drip tip comes with logo. One piece will be shipped only. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.59 The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This drip tip glows in the dark. This item also has other colors to choose.
268
ShenRay Nduro N[Duro] DL RTA Rebuildable Tank Atomzier Clone without Logo Original Price $28.50, Now Only $26.99
The ShenRay Nduro N[Duro] DL RTA Clone is a 24mm rebuildable tank atomizer with 5ml of juice capacity. It is constructed from 316 stainless steel and aluminum alloy. The RTA features postless build deck for single coil and direct lung designed structure for DL vaping. This RTA comes without logo. This item also has other Version to choose. ![]() ShenRay Nduro N[Duro] MTL RTA Rebuildable Tank Atomzier Clone without Logo Original Price $28.50, Now Only $26.99 The ShenRay Nduro N[Duro] MTL RTA Clone is a 24mm rebuildable tank atomizer with 5ml of juice capacity. It is constructed from 316 stainless steel and aluminum alloy. The RTA features postless build deck for single coil and mouth to lung designed structure for MTL vaping. This RTA comes without logo. This item also has other Version to choose. ![]() YFTK Boxxer RDTA Rebuildable Dripping Tank Atomizer Clone for Billet Box Mod Clone $29.99 The YFTK Boxxer RDTA Clone is made from 316 stainless steel. It features a dual post build deck and a silicone gasket sealed tank with about 5ml of juice capacity. It is suitable for YFTK Billet Box Mod Clone. This item also has other colors to choose. Image for reference only, the box mod is not included. ![]() Original Vandy Vape Bonza Hybrid Mechanical Mod + V1.5 RDA Kit Original Price $89.99, Now Only $62.99 The Original Vandy Vape Bonza kit consists of the Vandy Vape Bonza hybrid mechanical tube mod and Vandy Vape Bonza V1.5 rebuildable dripping atomizer. This item also has other colors to choose. Mod: The Original Vandy Vape Bonza hybrid mechanical tube mod is powered by 1 x 18650 / 20700 / 21700 battery (Not Included), it comes with pure copper conducts electricity and Voltage drop contacts to reduce internal loss, interchangeable sleeve system for customization and logo alignment, and magnetic switch with spring option included. Besides, each mech mod has an individually number. RDA: The Original Vandy Vape Bonza V1.5 RDA is a 24mm rebuildable dripping atomizer. It comes with 9mm deep juice well, 18mm Delrin drip tip, new dual AFC options, and top cap locking system. This RDA comes with bottom feeder pin. ![]() Original OBS Cube 80W 3000mAh VW Mod + Engine MTL RTA Kit Original Price $59.99, Now Only $45.89 The Original OBS Cube Starter Kit consists of OBS Cube Mod and OBS Engine MTL RTA. This item also has other colors to choose. Mod: The Original OBS Cube Mod is constructed from zinc alloy, it is powered by a built-in 3000mAh 23600 A+ high rate battery, with the fire speed of 10 milliseconds, it is very safe and durable. It features 0.96-inch LED screen, high- tech appearance, ergonomic design, comfort grip and exquisite buttons. The 1.5A charge current makes it safe and efficient to charge within 2~3 hours. RTA: The Original OBS Engine MTL RTA is constructed from stainless steel, it has a 24mm diameter with a tank capacity of 2ml. The rebuild deck and base are isolated, reduces the contact area greatly, reduces the heating delivery to chamber and the base from the coil, makes full tank not too hot when it works at high wattage. Temperature controlled excellently, the temperature reduced 30% under the same wattage. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.59 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This drip tip glows in the dark. This item also has other colors to choose. ![]() Original Advken Replacement Tank Tube for OWL Tank Atomizer $1.69 The replacement tank tube is made from glass with 3.5ml of juice capacity and is suitable for Advken OWL tank atomizer. This item also has other Version to choose. ![]() ShenRay Replacement Tank Tube for Nduro N[Duro] RTA Clone $1.29 The replacement tank tube is made from glass with 5ml of juice capacity and is suitable for ShenRay Nduro N[Duro] RTA Clone.
269
Doggystyle 2K18 V2 RTA Rebuildable Tank Atomizer Clone $9.99
The Doggystyle 2K18 RTA Clone is a 22mm rebuildable tank atomizer constructed from 316 stainless steel with PC tank tube and POM drip tip. The tank has 3.5ml of juice capacity. It comes with single coil build deck, adjustable bottom airflow and 510 threading connection. This item also has other colors to choose. ![]() Goon 25 RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99 The Goon 25 RDA Clone is constructed from stainless steel and in 24mm diameter. The Goon 25 RDA Clone is with unique dual post and bridge clamp posts coil clamping system for dual coil build. It comes with adjustable side airflow and 810 wide bore POM drip tip. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() YFTK Ka V7 RTA Rebuildable Tank Atomizer Clone with Nano Tank Tube $26.99 The YFTK Ka V7 RTA Clone is a 23mm rebuildable tank atomizer made from 316 stainless steel and PC. The PC tank has 3ml of juice capacity. The deck features dual post design for single coil and replaceable airflow insert. The pre-installed insert has 1.4mm size hole, and a 1.7mm and 2.3mm inserts are included. With the adjustable bottom airflow and replaceable airflow inserts, this tank will bring you optimal flavor. Spare Nano tank is included. This item also has Full Kit to choose. ![]() YFTK Ka V7 RTA Rebuildable Tank Atomizer Clone with Nano Tank + Extension Kit $37.99 The YFTK Ka V7 RTA Clone is a 23mm rebuildable tank atomizer made from 316 stainless steel and PC. The PC tank has 3ml of juice capacity. The deck features dual post design for single coil and replaceable airflow insert. The pre-installed insert has 1.4mm size hole, and a 1.7mm and 2.3mm inserts are included. With the adjustable bottom airflow and replaceable airflow inserts, this tank will bring you optimal flavor. Spare Nano tank and extension kit (2 tanks + 1 chimney) are included. This item also has Nano Kit to choose. ![]() Never Normal 510 Drip Tip Clone + Decorative Ring for 22mm Atomizer $3.99 The Never Normal 510 Drip Tip Clone and Decorative Ring are made from PMMA. The drip tip is suitable for all atomizers that fit 510 drip tip. The decorative ring is suitable for 22mm atomizers only. This item also has other colors to choose. ![]() Never Normal 810 Drip Tip Clone for Pulse X / Drop Dead / Profile RDA $2.39 The replacement 810 drip tip is made from POM. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This item also has other colors to choose. ![]() SteamTuners T7 Drip Tip Clone for RDA / RTA / Sub Ohm Tank Atomizer $1.99 The SteamTuners T7 510 drip tip Clone is made from POM. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other colors to choose. ![]() SXK Replacement Button for Billet Box Mod Clone Original Price $9.80, Now Only $5.99 The replacement button is made from stainless steel with polished finish. It is suitable for SXK Billet Box Mod Clone. This item also has other colors to choose. Image for reference only, the box mod is not included. ![]() YFTK Replacement Tank Tube Extension Kit for Ka V7 RTA Clone $12.99 The YFTK Ka V7 Extension Kit consists of two different tanks and a chimney. One tank is made from PC and the other is made from 316 stainless steel and PC. This kit is suitable for YFTK Ka V7 RTA Clone.
270
Original VapeCige Creator IM 250W VV Variable Voltage Box Mod $33.99
The Original VapeCige Creator IM250 Mod is a versatile regulated box mod powered by dual 18650 batteries (NOT INCLUDED). It can fire up to 250W with 0.008s firing speed. The potentiometer comes with 5 selections from 5W to 250W. The mod has multiple protections, like PCB temperature protection, low voltage protection, short circuit protection, overtime protection. This item also has other colors to choose. ![]() Hussar Project X RTA Rebuildable Tank Atomizer Clone $16.79 The Hussar Project X RTA Clone is a 22.5mm rebuildable tank atomizer constructed from 316 stainless steel. It comes with 2ml juice capacity and Ultem PEI tank. It comes with adjustable bottom airflow and the airflow size is 3 x 1.5mm each side. The tank also has juice control function. This item also has other colors to choose. ![]() Layercake CSMNT V2 RDA Rebuildable Dripping Atomizer Clone with BF Pin $11.59 The LC1 LayerCake RDA Clone is an innovative rebuildable atomizer utilizing a dual-layer center clamp post in the build deck. Its post provides ample room for unabated exploratory coil building. Installed coils are kept to be cool by the signature dual skinny slots, bringing in plenty of airflow. The LayerCake CSMNT V2 RDA Clone also includes an 810 drip tip that can be interchanged for any other of your favorite 810 tips. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() KA V8 RTA Rebuildable Tank Atomizer Clone $17.48 The KA V8 RTA Clone is a 22mm rebuildable tank atomizer with 5ml of juice capacity. It is made from 316 stainless steel. The RTA features dual post build deck, heat sink top cap and bottom adjustable airflow. This item also has other Version to choose. ![]() Ulton Nduro N[Duro] DL RTA Rebuildable Tank Atomzier Clone $28.50 The Ulton Nduro N[Duro] DL RTA Clone is a 24mm rebuildable tank atomizer with 5ml of juice capacity. It is constructed from 316 stainless steel and aluminum alloy. The RTA features postless build deck for single coil and direct lung designed structure for DL vaping. This item also has other Version to choose. ![]() Original SMOKTech SMOK Nord AIO 22 60W 2000mAh All in One Starter Kit Standard Edition $27.79 The Original SMOK Nord AIO Kit is an all-in-one pen-style kit equipped with top rotary cap and built-in glass tank. Nord AIO 22, powered by a built-in 2000mAh battery, is capable of firing up to 60 watts. It uses Nord Mesh 0.6ohm coil which is the best fit for sub ohm vaping to bring you massive vapor, and Nord Regular 1.4ohm coil that can offer excellent MTL experience. This item also has other colors to choose. ![]() Original SMOKTech SMOK Nord AIO 19 25W 1300mAh All in One Starter Kit Standard Edition $27.29 The Original SMOK Nord AIO Kit is an all-in-one pen-style kit equipped with top rotary cap and built-in glass tank. Nord AIO 19 has an internal 1300mAh battery, which is capable of firing up to 15~25 watts. It uses Nord Mesh 0.6ohm coil which is the best fit for sub ohm vaping to bring you massive vapor, and Nord Regular 1.4ohm coil that can offer excellent MTL experience. This item also has other colors to choose. ![]() Original Vandy Vape AP Apollo 20W 900mAh VV Box Mod + MTL Sub Tank Kit Original Price $49.90, Now Only $39.79 The Original Vandy Vape AP Kit, also called Vandy Vape Apollo Kit, is a waterproof starter kit with variable voltage function. The kit utilizes TPE material and features IP66 waterproof, which can provide extreme water, shock and dust protections. Powered by built-in 900mAh battery, the mod can work from 3.2 to 4.0 voltages. The MTL sub tank uses vandyvape MTL coil, with 1.5ohm and 1.8ohm resistance, which works well at 7~13W. The tank has multi-directional air holes and wide range adjustment (0.6/0.8/1.0/1.5/2.0/2.5). The whole kit will give you extreme vaping experience. This item also has other colors to choose.
271
Original Vaporesso Luxe Nano 80W 2500mAh TC VW Variable Wattage Box Mod Original Price $59.90, Now Only $51.56
The Vaporesso Luxe Nano combines the same beastly power as its predecessor in its compact design. Equipped with sleek edge-to-edge 1.3inch TFT screen, the mod fits comfortably in your palm. Holding it in hand, the vibration-enabled buttons provide tactile feedback you expect from high-tech devices. The integrated OMNI Board 4.0 chip achieves the most rapid, stable yet safe firing rate of 0.001s, bringing you rich flavor and denser clouds within the very first puff. The resistance range, from 0.03 to 5 ohm, is adaptive to all mainstream tanks. This item also has other colors to choose. ![]() Original Vapefly Brunhilde Top Coiler RTA Rebuildable Tank Atomizer $54.99 The Vapefly Brunhilde Top Coiler RTA, designed by German 103 team, is a high end top coiler that features fantastic appearance, easy fast refilling, easy dual coil building, 8ml big capacity, surrounding airflow system, and continuous automatic e juice replenishment system. This item also has other colors to choose. ![]() Original Dotmod DotRDA Single Coil RDA Rebuildable Dripping Atomizer with BF Pin Original Price $60.00, Now Only $51.99 The Original Dotmod DotRDA Single Coil RDA is a 22mm rebuildable dripping atomizer that features dual-termianl, postless style build deck with ample space to utilize greatest performing coils. The RDA is constructed from hard-anodized aluminum cap and 24K gold palted solid brass base. Besides, the DotRDA comes with an extra frosted PC cap, Ultem 510 drip tip and Ultem beauty ring to ensure flush fit on any 24mm device. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for Goon / Pulse V2 / Drop Dead / Profile RDA $1.29 The replacement 810 drip tip is made from resin. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This item also has other colors to choose. ![]() Replacement Tank Tube for Hurricane Junior RTA Clone $3.99 The replacement tank tube is made from PC. It is suitable for Hurricane Junior RTA Clone. ![]() Original Vaporesso Replacement Pod Cartridge for Renova Zero Pod System Kit $6.25 The replacement pod cartridge features 2.0ml of juice capacity and 1.0ohm resistance coil. It is suitable for Original Vaporesso Renova Zero Mod. This product comes with 2 PCS in 1 pack. ![]() EDC Every Day Carry High Output 350lm 5-Mode LED Flashlight Torch $89.99 This EDC LED Flashlight Torch is made from copper and is powered by single 18350 battery (NOT INCLUDED). The light output is over 350 lumens. You can continuously use it for about 1 hour. It is suitable for outdoors activities at night, like camping, cycling. The product is without anti-oxidation process This item also has other colors to choose.
272
Original Dotmod Dotbox Dual Mech Mechanical Box Mod Original Price $120.00, Now Only $99.99
The Original Dotmod Dotbox Dual Mech is a dual battery mechanical box mod device designed for the advanced vaper. Utilizing either a series or parallel battery orientation, dictated by the switch underneath the magnetic removable side panel, the Dotbox Dual Mech allows for vapers to choose between a long-lasting parallel setup, or a super powerful series setup. The mod is powered by dual 18650 batteries (NOT INCLUDED). The full anodized aluminum body holds a sleek and minimalist exterior, showcasing the staple reflective Dotmod logo on one side, and the gold-plated and engraved firing button and gold plated 510 connection. The Dotbox Dual Mech is a fantastic box mod for the advanced vaper looking for a beautifully crafted masterpiece of design work as their next device. This item also has other colors to choose. ![]() Original CoilART LUX Sub Ohm Tank Clearomizer Original Price $34.99, Now Only $25.85 The Original CoilART LUX Tank is a 24mm sub ohm tank with 5.5ml of juice capacity. It utilizes a M1 single mesh coil, which has 0.15ohm resistance and works well at 50~90W, best at 60~80W. The M4 quad mesh coil is also included, with 0.15ohm resistance and wattage range 80~150W, best 100~120W. This item also has other colors to choose. ![]() Coppervape Hussar Project X RTA Rebuildable Tank Atomizer Clone $22.99 The Coppervape Hussar Project X RTA Clone is a 22mm rebuildable tank atomizer constructed from 316 stainless steel. It comes with 2ml juice capacity and Ultem PEI tank. It comes with adjustable bottom airflow and the airflow size is 3 x 1.5mm each side. The tank also has juice control function. This item also has other colors to choose. ![]() Original CoilART LUX 200W TC VW Variable Wattage Box Mod + LUX Mesh Tank Kit Original Price $89.99, Now Only $66.99 The Original CoilART LUX Kit consists of CoilART LUX 200W Mod and CoilART LUX Tank. This item also has other colors to choose. Mod: The Original CoilART LUX Mod is a dual 18650 battery (NOT INCLUDED) mod with maximum output power to 200W. It features reinforced glass panel with UV printing, which looks like marble texture. Equipped with Eagle chip, LUX will bring you great and stable performance. Tank: The Original CoilART LUX Tank is a 24mm sub ohm tank with 5.5ml of juice capacity. It utilizes a M1 single mesh coil, which has 0.15ohm resistance and works well at 50~90W, best at 60~80W. The M4 quad mesh coil is also included, with 0.15ohm resistance and wattage range 80~150W, best 100~120W. ![]() Original CoilART Mino 13W 320mAh Pod System Starter Kit Original Price $29.99, Now Only $25.25 The Original CoilART Mino Pod System Kit is an ultra compact pod kit powered by built-in 320mAh battery and comes with 2ml refillable Mino pod. The coil resistance is 1.8ohm. The Mino utilizes draw activated firing system, just take a puff without any button, easy to start vaping. This item also has other colors to choose. ![]() Skull Shape Replacement Mount Clip for Flashlight Torch $23.99 The replacement flashlight clip is made from brass (skull) and stainless steel (clip). It is easy to be installed on your flashlight and will give it a fantastic look. ![]() Coppervape Replacement 510 Drip Tip for Hussar Project X RTA Clone $1.99 The Coppervape replacement 510 drip tip is made from PEI and 316 stainless steel, it is suitable for Hussar Project X RTA Clone and other atomizers that fit 510 drip tip. ![]() Coppervape Replacement Extended Tank Tube for Hussar Project X RTA Clone $3.59 The Coppervape replacement extended tank tube is made from PEI with 4ml juice capacity. It is suitable for Coppervape Hussar Project X RTA Clone Extended Kit. ![]() Coppervape Replacement Extended Tank Tube Kit for Hussar Project X RTA Clone $7.99 The Coppervape replacement extended kit is made from 316 stainless steel and PEI with 4ml juice capacity. It is suitable for Coppervape Hussar Project X RTA Clone. This item also has other colors to choose. ![]() Original CoilART Replacement M1 Single Mesh Coil for LUX Sub Ohm Tank Original Price $12.99, Now Only $12.43 The CoilART LUX Tank Replacement M1 Mesh Coil features 0.15ohm resistance and works well at 50~90W (best 60~80W). It is suitable for Original CoilART LUX Tank / CoilART LUX Kit. This product comes with 3 PCS in 1 pack. This item also has other Version to choose. ![]() Original CoilART Replacement Pod Cartridge for Mino Pod System Kit $8.99 The CoilART Mino Replacement Pod Cartridge features 1.8ohm resistance and 2ml of juice capacity. It is suitable for Original CoilART Mino Pod System Kit. This product comes with 2 PCS in 1 pack. This item also has other colors to choose.
273
Kindbright Reactor Squonk Mechanical Box Mod Clone $43.94
The Kindbright Reactor Squonk Box Mod Clone has a stunning appearance, which has a aluminum alloy body with PEI fire button on top. The mod is powered by single 18650 battery (NOT INCLUDED). The squeeze bottle has 8ml of juice capacity. There is no overhang with 25mm atomziers. The mod comes with engraved logo and serial number. This item also has other colors to choose. ![]() YFTK EVL Reaper V3 MTL RTA Rebuildable Tank Atomizer Clone $21.44 The YFTK EVL Reaper V3 MTL RTA Clone is a 22mm mouth-to-lung rebuildable tank atomizer made from 316 stainless steel. It comes with a 2ml ultem tank. The RTA features dual post build deck and adjustable bottom airflow. The internal airhole size is 1.8mm and the MTL airflow ring sizes are 1.8mm, 1.6mm, 1.4mm, 1.2mm, 1.0mm and 0.8mm (specs to be confirmed). This RTA comes without drip tip. ![]() YFTK Dvarw MTL RTA Rebuildable Tank Atomizer Clone $17.99 The YFTK Dvarw MTL RTA Clone is a 16mm RTA made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. The kit comes with 4 spare airflow inserts to adjust airflow. This RTA will bring you extreme MTL vaping experience. This RTA is made at 1:1 scale. The airflow insert come with 0.8mm / 2 x 0.8mm / 3 x 0.8mm / 2 x 1mm / 2 x 1.2mm airhole size. ![]() Original Hugsvape FMCC Frozen 2500mAh SDL Pod System Starter Kit Original Price $34.99, Now Only $28.35 The Hugsvape FMCC Frozen starter kit is a brand new pod device that gives you SDL vaping experience, which is a new concept between DL and MTL, yet they're different. When it comes to DL, you inhale vapor hard straight into your lung. While with SDL, you inhale vapor gently and let it linger a short moment in your mouth before sucking it down to the mouth. SDL is a combination of flavor and vapor production. The FMCC Frozen is powered by built-in 2500mAh battery and comes with 5ml refillable cartridge. This item also has other colors to choose. ![]() YFTK Replacement 510 Drip Tip + Top Cap for Haku Venna RDA Rebuildable Dripping Atomizer Clone $6.59 The replacement top cap is made from PC and is suitable for YFTK Haku Venna RDA Clone. This item also has other colors to choose. ![]() YFTK Replacement 510 Drip Tip + Top Cap for Citadel RDA Rebuildable Dripping Atomizer Clone $6.59 The replacement top cap is made from PC and is suitable for YFTK Citadel RDA Clone. This item also has other colors to choose. ![]() YFTK Replacement MTL Airflow Insert for EVL Reaper V3 RTA Clone $3.98 The Replacement MTL Airflow Insert is made from 316 stainless steel and is suitable for YFTK EVL Reaper V3 RTA Clone. More information will be provided soon. ![]() YFTK Replacement Extension Tank Tube + Chimney Kit for EVL Reaper V3 RTA Clone $9.88 The Replacement Extension Tank Tube Kit is constructed from PEI and 316 stainless steel and is suitable for YFTK EVL Reaper V3 RTA Clone. It can extend the capacity to 5ml. ![]() Original Hugsvape Replacement X1 Mesh Coil for FMCC Frozen Stater Kit Original Price $10.60, Now Only $8.36 The Hugsvape FMCC Frozen Replacement X1 Mesh Coil features 0.9ohm resistance and works well at 12~19W, which is great for SDL vaping. It is suitable for Hugsvape FMCC Frozen Stater Kit. This product comes with 5 PCS in 1 pack. ![]() Original Hugsvape Replacement Pod Cartridge without Coil for FMCC Frozen Stater Kit $3.99 The Hugsvape FMCC Frozen Replacement Pod Cartridge can hold 5ml of juice capacity and comes with curve shaped mouthpiece. It is suitable for Hugsvape FMCC Frozen Stater Kit. This product comes without coil.
274
Original Vapor Storm Puma Baby 80W TC VW Variable Wattage Box Mod Original Price $24.50, Now Only $22.57
The Vapor Storm Puma Baby Box Mod is constructed from ABS, with unique graffiti patterns and attractive colors, the mod is lightweight and convenient to carry around. Powered by single 18650 battery (NOT INCLUDED), the Puma Baby Mod is able to reach up to a maximum output power of 80W. This item also has other colors to choose. ![]() Original Arctic Dolphin Orion 250W TC VW Variable Wattage Box Mod $158.99 The Original Arctic Dolphin Orion 250W Box Mod is a beautiful Stabilized Wood mod with 250W max output when using dual 18650 batteries (NOT INCLUDED). It is quite like an artwork and you will not realize it is a vape mod until you find it comes with a 0.96" OLED and a 3-button control panel. Please note: the product will be shipped with random color. More options than what's on the image. ![]() Original Lcovape 98K RDA Rebuildable Dripping Atomizer with BF Pin Original Price $31.99, Now Only $18.72 The Original Lcovape 98K RDA is a 24.5mm RDA constructed from Aluminum and 316 stainless steel. The gold plated build deck features single large post design and postless negative terminal, which allows you to build horizontal or vertical coils. The spring loaded clamp design makes building easier. The air enters the dual side airslots and hit the coils directly. 810 SS drip tip is included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Ulton Shift Batch 2 RDA Rebuildable Dripping Atomizer Clone with BF Pin + Extra Cap $16.97 The Ulton Shift Batch 2 RDA Clone is a 22mm rebuildable squonking atomizer with a special deck that allows users to build single horizontal coil, single vertical coil, or dual vertical coils. The adjustable airflow will provide a restricted lung hit. Extra transparent cap is included. This RDA comes with bottom feeder pin. ![]() Original One Vape Nano 11W 430mAh Pod System Starter Kit $18.99 The Original OneVape Nano Pod System Kit is an ultra compact pod kit powered by built-in 430mAh battery and comes with 2ml refillable pod. The coil resistance is 1.5~1.6ohm. The Nano utilizes draw activated firing system, just take a puff without any button, easy to start vaping. This item also has other colors to choose. ![]() Original Vapor Storm Puma Baby 80W TC VW Box Mod + Hawk Tank Kit Original Price $35.00, Now Only $33.96 The Vapor Storm Puma Baby Hawk Kit consists of Vapor Storm Puma Baby Box Mod and Vapor Storm Hawk Tank. This item also has other colors to choose. Mod: The Vapor Storm Puma Baby Box Mod is constructed from ABS, with unique graffiti patterns and attractive colors, the mod is lightweight and convenient to carry around. Powered by single 18650 battery (NOT INCLUDED), the Puma Baby Mod is able to reach up to a maximum output power of 80W. Tank: The Original Vapor Storm Hawk Tank is a 24mm sub ohm tank with 6ml of juice capacity. It comes with a 0.2ohm mesh coil head and adjustable bottom airflow control for pure and optimal flavor. ![]() Original Vapor Storm Puma Baby 80W TC VW Box Mod + Lion RDA Kit Original Price $33.00, Now Only $31.31 The Vapor Storm Puma Baby RDA Kit consists of Vapor Storm Puma Baby Box Mod and Vapor Storm Lion RDA. This item also has other colors to choose. Mod: The Vapor Storm Puma Baby Box Mod is constructed from ABS, with unique graffiti patterns and attractive colors, the mod is lightweight and convenient to carry around. Powered by single 18650 battery (NOT INCLUDED), the Puma Baby Mod is able to reach up to a maximum output power of 80W. RDA: The Original Vapor Storm Lion RDA made of stainless steel, it comes with 24mm diameter and dual post deck. And the Lion RDA features easy top fill design and adjustable bottom airflow control system for optimal flavor and huge cloud. It can support dual coils. ![]() SXK Billet Box 70W All-in-One Box Mod Kit CLone with USB Port Original Price $75.00, Now Only $65.19 The SXK Billet Box Mod Kit Clone is constructed from aluminum with an all-in-one design. This mod comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor. This Billet Box comes with USB port for charging only. This item also has other Version to choose. ![]() Original One Vape Replacement Pod Cartridge for Nano Pod System Starter Kit $6.70 The One Vape Nano Replacement Pod Cartridge features 1.5~1.6ohm resistance and 2ml of juice capacity. It is suitable for Original One Vape Nano Pod System Kit. This product comes with 2 PCS in 1 pack.
275
Original Tesla Teslacigs Punk 86W VW Variable Wattage Tube Mod Original Price $56.90, Now Only $46.52
Teslacigs Punk 86W Mod has exquisite carving punk-style appearance. It is made of Brass and Stainless Steel, giving you great metal texture. The Punk 86W mod is powered by single 18650 battery (NOT INCLUDED) and is capable of 86W output. It is equipped with 0.49" OLED screen, which displays the data clearly. This item also has other colors to choose. ![]() Original Tesla Teslacigs Poker 218W TC VW Variable Wattage Box Mod Original Price $63.90, Now Only $48.94 The Teslacigs Poker mod is made of Zinc Alloy and comes with classic poker element designed in appearance. It is powered by dual 18650 batteries (NOT INCLUDED) and it can be fired up to 218W maximum output. With big fire button design, it is simple to operate. The mod also supports various modes to achieve different vaping experience. The OLED screen displays data clearly. ![]() Vapeasy Mini B MiniB Mechanical Tube Mod Clone $21.99 The Vapeasy Mini Bestia Mini B Mod Clone is the smallest 18650 mech mod. It is constructed from brass, with hybrid connection and side fire button. The mod is powered by only single 18650 battery (NOT INCLUDED). This item also has other colors to choose. This mod comes with sandblasting finish, which is anti-fingerprint. This mod comes with insulated insert and protruding battery contact (about 0.3mm), so the battery can be put in any direction. This atomizer should have a protruding pin with length more than 4.5mm to ensure safety and better contact. ![]() Original Advken Owl Sub Ohm Tank Clearomizer Original Price $29.99, Now Only $24.99 The Original Advken Owl tank is a 25mm diameter sub ohm tank which comes with a bullet-shaped appearance with exquisite carving and high-quality stainless steel and Pyrex glass construction. It is compatible with two types of coil, the 0.16ohm and the 0.2ohm mesh coil, which could bring great flavor and huge clouds. In addition, the top airflow system avoid leakage and condensation and top slide filling design makes refill easier. Plus the 810 heat-resistant PEI drip tip, you can form your own mini weather system each time you vape. This item also has other colors to choose. ![]() Coppervape Dvarw MTL RTA Rebuildable Tank Atomizer Clone $17.29 The Coppervape Dvarw MTL RTA Clone is a 16mm RTA made out of 316 stainless steel and Ultem. The build deck comes with dual post design and bottom airflow system. The kit comes with 4 spare airflow inserts to adjust airflow. This RTA will bring you extreme MTL vaping experience. This RTA is made at 1:1 scale. The airflow insert come with 0.8mm / 2 x 0.8mm / 3 x 0.8mm / 2 x 1mm / 2 x 1.2mm airhole size. This item also has other colors to choose. ![]() Original Tesla Teslacigs Poker 218W TC VW Box Mod + Resin Tank Kit Original Price $73.90, Now Only $59.84 The Original Teslacigs Poker 218W Resin Kit consists of Teslacigs Poker 218W Mod and Teslacigs Resin Tank. This item also has other colors to choose. Mod: The Teslacigs Poker mod is made of Zinc Alloy and comes with classic poker element designed in appearance. It is powered by dual 18650 batteries (NOT INCLUDED) and it can be fired up to 218W maximum output. With big fire button design, it is simple to operate. The mod also supports various modes to achieve different vaping experience. The OLED screen displays data clearly. Tank: The Resin Tank is a 6ml innovative atomizer, features a 4ml capacity for standard and 6ml in bulb tube for you to choose. With the top-filling system and adjustable airflow, it will provide you a convenient vape experience with great flavor and big cloud. What's more, the Resin Tank utilizes the latest TS-XX coil (0.18ohm, 60~100W) and TS-120X coil (0.15ohm, 70~120W). ![]() Original Tesla Teslacigs Poker 218W TC VW Box Mod + Tallica Mini Tank Kit Original Price $74.90, Now Only $60.69 The Original Teslacigs Poker 218W Resin Kit consists of Teslacigs Poker 218W Mod and Teslacigs Tallica Mini Tank. This item also has other colors to choose. Mod: The Teslacigs Poker mod is made of Zinc Alloy and comes with classic poker element designed in appearance. It is powered by dual 18650 batteries (NOT INCLUDED) and it can be fired up to 218W maximum output. With big fire button design, it is simple to operate. The mod also supports various modes to achieve different vaping experience. The OLED screen displays data clearly. Tank: The Teslacigs Tallica Mini Tank is a 25mm sub ohm tank, which has 4ml / 6ml juice capacity and supports 110W max output. It has large airflow slots on the base, and the triangular airflow can easily adjusted to get different vaping experience. With slide refilling design, it is simple to fill e-liquid, and the plug-and-pull coil replacement design ensures easy coil installation. ![]() Original Steam Crave Titan PWM 300W VV Variable Voltage Box Mod + Aromamizer Titan RDTA Kit Original Price $124.99, Now Only $110.29 The Original Steam Crave Titan PWM Kit consists of Steam Crave Titan PWM Mod and Steam Crave Aromamizer Titan RDTA. This item also has other colors to choose. Mod: The Original Steam Crave Titan PWM Mod is a quad 18650 variable voltage box mod. Powered by quad 18650 batteries (NOT INCLUDED) in parallel / series, this mod can provide maximum output to 300W, which is very powerful. By Rotating the fire button you can adjust the voltage, and it comes with lock function. Besides, the mod has multiple protections to give you a safe vaping experience. Tank: The Original Steam Crave Aromamizer Titan RDTA is so amazing as it has 41mm diameter and maximum 28ml capacity! The Innovative Lego modular build deck allows you to build coils on postless, Velocity, or Series style deck, which offers vapers a great change to build various configurations. The tank can be switched from 28ml to 18ml, or you can use it as RDA, which has a 4.5ml juice well. Titan will bring you great fun for endless coil building and fantastic vaping experience. ![]() Coppervape Replacement Tank Tube for Dvarw 16 RTA Clone $2.29 The replacement tank tube is made from PEI and is suitable for Coppervape Dvarw 16 RTA Clone. It has 2ml of juice capacity.
276
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Get Low Mods GLM V3 Hybrid Mechanical Tube Mod Clone $13.59
The Get Low Mods GLM V3 Mechanical Mod Clone is constructed from brass. It has hybrid connection and spring fire button. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original Vapor Storm Subverter 2 200W TC VW Variable Wattage Box Mod Original Price $39.99, Now Only $37.56 The Original Vapor Storm Subverter 2 Box Mod, powered by dual 18650 batteries (NOT INCLUDED), can reach maximum wattage to 200W. The side panels has many geometrical cut-outs and graffiti pattern, which is very aesthetic. The mod comes with a 0.96 inch colorful display and big fire button. The resistance allowed is from 0.05 to 3ohm (VW), 0.05 to 1ohm (TC). This item also has other colors to choose. ![]() Kindbright Speed RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99 The Kindbright Speed RDA Clone is a 14mm rebuildable dripping atomizer constructed from 316 stainless steel. It has a dual post build deck for single coil build. The RDA comes with two Delrin drip tips and one decorative ring. This RDA comes with bottom feeder pin. ![]() Original Xuan Feng Lou Desire Hybrid Mechanical Mod + Xuan Feng Lou 24mm RDA Ki Original Price $33.99, Now Only $14.99 Mod: The Original Desire Xuan Feng Lou Mechanical Mod is constructed from brass. It comes with 510 hybrid connection, 3 vent holes on the side, spring-loaded bottom firing button. Xuan Feng Lou mod has a unique design body for easy grib. Powered by 1 x 18650 battery (not included). RDA: The Original Desire Xuan Feng Lou RDA is constructed from brass in 24mm diameter. It features two posts design deck for easy coil building. It comes with flexible airflow control design with 6 air holes on the sleeve and 9-hole design on the top cap. This item also has other colors to choose. ![]() Get Low Mods GLM V3 Hybrid Mechanical Tube Mod Clone + RDA Kit $20.59 The GLM V3 Mech Kit Clone consists of GLM V3 Mechanical Mod Clone and GLM V3 RDA Clone. This item also has other colors to choose. Mod: The Get Low Mods GLM V3 Mechanical Mod Clone is constructed from brass. It has hybrid connection and spring fire button. The mod is powered by single 18650 battery (NOT INCLUDED). RDA: The GLM V3 RDA Clone is a nice rebuildable dripping atomizer made from stainless steel. It features dual post build deck and adjustable side airflow. It will bring you great amount of cloud and dense flavor. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.99 The replacement 510 drip tip is made from POM. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other colors to choose. ![]() Replacement Conversion Deck + Airflow Ring for Reaper V3 MTL RTA Clone $3.59 The 2.7mm deck comes with positive post fitted. Airflow ring offers 6 airflow options: 1.0, 1.2, 1.5, 2.0, 2.5, and 2.7mm. Both of them are made from 316 stainless steel and suitable for Reaper V3 MTL RTA Clone. ![]() Original SMOKTech SMOK Replacement Pod Cartridge for Nord Pod System Kit $7.98 The SMOK Nord Replacement Pod Cartridge features 3ml of juice capacity. It comes with two coils (0.6ohm / 1.4ohm) for replacement. It is suitable for Original SMOKTech SMOK Nord Pod System Kit. ![]() Original SMOKTech SMOK Replacement Regular Coil Head for Nord Pod System Kit $13.40 The SMOK Nord Replacement regular coil head features 1.4ohm resistance. It is suitable for Original SMOKTech SMOK Nord Pod System Kit. This product comes with 5 PCS in 1 pack.This item also has other Version to choose.
277
ASAP Bottom Feeder Squonk Mechanical Box Mod Clone Original Price $25.99, Now Only $12.88
The ASAP box mod Clone is a 3D printed mod with ABS material. Coming with inner bottom feeder bottle for squonking, the mod features magnetic battery door, rechangeable decorative rings made from 316 stainless steel and super light weight. It is very convenient to use and is powered by single 18650 battery (NOT INCLUDED). ![]() Original One Top Onetopvape Gemini RDTA Rebuildable Dripping Tank Atomizer Original Price $34.99, Now Only $25.99 The Original One Top Onetopvape Gemini RDTA is a 26.5mm diameter RDTA which is especially two sizes cap designed you've never seen in vape market. Constructed by 304 Stainless Steel and PC, it is well-built and durable. With the dual post build deck and quad terminals, it is very easy to build. Together with the Quad terminal and side airflow system, Gemini RDTA will bring an excellent vaping experience for you. This item also has other colors to choose. ![]() 1:1 Get Low Mods GLM V3 Hybrid Mechanical Tube Mod Clone + RDA Kit $20.64 The Get Low Mods GLM V3 Mech Kit Clone consists of GLM V3 Mech mod Clone and GLM V3 RDA Clone. This item also has Copper Version to choose. Mod: The Get Low Mods GLM V3 Mechanical Mod Clone is constructed from brass and made at 1:1 scale. It has hybrid connection and spring fire button. The mod is powered by single 18650 battery (NOT INCLUDED). RDA: The GLM V3 RDA Clone is a nice rebuildable dripping atomizer made from stainless steel. It features dual post build deck and adjustable side airflow. It will bring you great amount of cloud and dense flavor. ![]() YFTK 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $3.98 The replacement 510 drip tip is made from PEI. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() ShenRay Replacement Squonk Bottle for Armor BF Squonk Box Mod Clone $9.89 The ShenRay Replacement Squonk Bottle is made of food grade silicone, SS and POM materials. It is suitable for ShenRay Armor BF Squonk Box Mod Clone. Bottle capacity is 8ml. Original Advken Replacement Mesh Coil for Owl / Manta Sub Ohm Tank Original Price $14.99, Now Only $12.99 The Advken Owl / Manta Replacement Mesh Coil features 0.2ohm resistance and works well at 50~70W. It is suitable for Advken Owl / Manta Sub Ohm Tank. This product comes with 5 PCS in 1 pack. This item also has other Version to choose.
278
Avid Lyfe Medieval Gyre Mace Hybrid Mechanical Tube Mod Clone $26.79
The Avid Lyfe Medieval Gyre Mace Mechanical Mod Clone is constructed from brass. It features mace style machined body, hybrid connection and adjustable magnetic bottom firing button. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original Arctic Dolphin Kurve 220W TC VW Variable Wattage Box Mod Original Price $70.70, Now Only $44.72 The Original Arctic Dolphin Kurve mod is a TC VW box mod powered by dual 18650 batteries (NOT INCLUDED), is able to reach up to an output power from 5W to 220W. It has a 0.96inch OLED white screen, the screen display will inform you essential parameters you need. It also can be quickly charged via USB port. This item also has other colors to choose. ![]() Original VapeCige VTX 100W TC VW Variable Wattage Box Mod $24.10 The Original battery (NOT INCLUDED), Vapecige VTX100 Mod can reach its max output to 100W, and supports VW, Ni, Ti, SS, Bypass modes. It has a 0.91-inch OLED screen to display vape data. With spring-loaded 510 connection, it can be compatible with most atomizers in the market. This item also has other colors to choose. ![]() Original Ystar Hell Demons RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.99, Now Only $21.96 The Original Ystar Hell Demons is a 20mm BF RDA that features single coil deck with innovative invisible airflow system. The airflow transfers from the bottom to the top for great flavor. The package comes with Ystar 316L coil which is recommended to be used at 20~40W. It is suitable for nic salt juice at low wattage. The RDA comes with a delicate 810 agate drip tip. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original OBS Cheetah 3 III RDA Rebuildable Dripping Atomizer with BF Pin Original Price $24.99, Now Only $18.99 The OBS Cheetah 3 RDA is an updated dual coils RDA atomizer with 25mm diameter and is constructed from durable stainless steel. OBS Cheetah 3 features a super big build deck with much space for easy dual coils building. The juice well is deep and thus can hold large amount of e-juice. With the adjustable middle airflow, Cheetah III RDA is definitely a vapor beast for cloud chaser. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Hugo Vapor Kobra 500mAh Pod System Starter Kit Original Price $29.99, Now Only $14.56 Inspired by "King Cobra", Hugo Vapor released a unique pod system kit, the Hugo Vapor Kobra. The Kobra features 500mAh built-in battery, battery life LED indicator, draw-activate design for simple operation. The pod cartridge has 1.8ml of juice capacity and a 1.5ohm ceramic coil. This item also has other colors to choose. ![]() Original Arctic Dolphin Kurve 220W TC VW Box Mod + Sub Ohm Tank Kit Original Price $86.60, Now Only $56.34 The Arctic Dolphin Kurve Kit consists of Arctic Dolphin Kurve Mod and Arctic Dolphin Kurve Tank. This item also has other colors to choose. Mod: The Original Arctic Dolphin Kurve mod is a TC VW box mod powered by dual 18650 batteries (NOT INCLUDED), is able to reach up to an output power from 5W to 220W. It has a 0.96inch OLED white screen, the screen display will inform you essential parameters you need. It also can be quickly charged via USB port. Tank: The Arctic Dolphin Kurve Sub Ohm Tank is a 2ml clearomizer that features adjustable bottom airflow and top filling design. With a 0.2ohm coil, you can taste the pure flavor from this tank.
279
Original Vandy Vape Pulse X 90W TC VW Squonk Box Mod + Pulse X BF RDA Kit $69.90
The Original Vandy Vape Pulse X 90W Kit consists of the Pulse X 90W TC VW squonk box mod and Pulse X BF RDA. This item also has other colors to choose. Mod: The Vandy Vape Pulse X Mod has maximum power output of 90 watts with single 18650 / 20700 / 21700 battery (NOT INCLUDED). It is powered by Vandy Chip, which has excellent quality and highest stability. The replaceable panel comes with magnetic structure design. RDA: The Pulse X RDA feeds the juice directly to the top of your coils, giving you the experience you would get with typical dripping atomizers, and saturating your wicks and coils from the top. This ensures that your coils are always wet and ready to go. When squonking, the one-way-valve design allows excess juice to return to the bottole at the bottom. It also allows you to drip right onto the center through the drip tip for non-squonk usage, and the liquid rolls off the top center of the post and onto your coils. The "X" design for the post can be used effectively for vertical and horizontal builds, and can accommodate large or small coils. ![]() Original Cozyvape Mouse 13W 380mAh Pod System Starter Kit $14.99 The Original Cozyvape Mouse is a designed refillable pod system, which is quite simple to use for its no-button design. When you inhale, it automatically initiates. The cartridge is compatible with eliquid and nicotine sale, and has excellent taste. The screen will show the puffs after you inhale. It comes with a 380mAh inbuilt battery. This item also has other colors to choose. ![]() Original Hugo Vapor Replacement Pod Cartridge for Kobra Pod System Kit $5.97 The Hugo Vapor Kobra Replacement Pod Cartridge features 1.5ohm resistance and 1.8ml of juice capacity. It is suitable for Original Hugo Vapor Kobra Pod System Kit. This product comes with 4 PCS in 1 pack. ![]() 810 Replacement Drip Tip for Goon / Kennedy / Reload / Battle RDA $1.99 The replacement 810 drip tip is made from resin. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This drip tip will be shipped with random color (1 piece). More option than what's on the image. ![]() Coppervape Replacement Extended Tank Tube Kit for Hussar Project X RTA Clone $7.99 The Coppervape replacement extended kit is made from 316 stainless steel and PEI with 4ml juice capacity. It is suitable for Coppervape Hussar Project X RTA Clone. ![]() Replacement Tank Tube for Vandy Vape Berserker V1.5 MTL RTA $1.59 The replacement glass tank tube has 2.5ml of juice capacity and is suitable for Original Vandy Vape Berserker V1.5 MTL RTA. ![]() Replacement Bubble Tank Tube for Vandy Vape Berserker V1.5 MTL RTA $1.59 The replacement glass tank tube has 2.5ml of juice capacity and is suitable for Original Vandy Vape Berserker V1.5 MTL RTA. ![]() Original Cozyvape Replacement Pod Cartridge for Mouse Pod System Kit $4.99 The Cozyvape Mouse Replacement Pod Cartridge features 1.4ohm resistance and 2ml of juice capacity. It is suitable for Original Cozyvape Mouse Pod System Kit. This product comes with 3 PCS in 1 pack.
280
Original Asmodus Ohmsmium II Ohmsmium 2 Box Mod $349.95
The Asmodus Ohmsium II Mod is crafted from the sought after stabilized wood to make a beautiful masterpiece. The making of the Ohmsmium II is handled with much love and care, from the custom molding process of the body, to the gold plated stainless steel. The featured chipset on the Ohmsmium II is the GX-80-UL! This chipset allows for an unregulated experience, that also has a plethora of protection features. The Ohmsmium II is operated by a single oversized firing button that provides tactile feedback to replicate a mechanical keyboard to please the user with its distinct click. This mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original Vandy Vape Widowmaker RDA Rebuildable Dripping Atomizer with BF Pin $37.99 The Original VandyVape Widowmaker RDA is a 24mm rebuildable dripping atomizer with three different airflow caps and two different drip tips, which can be mixed in 6 different ways. The build deck comes with dual posts and quad terminals for single and dual coil builds. The airflow can be adjusted by the side aiflow holes for optimal flavor. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Vivismoke Mesh Coil for Wotofo Profile RDA / Vandy Vape Lit RDA $3.35 The Vivismoke Mesh Coil features 0.13ohm resistance and works well at 40~70W. It is suitable for RDA's that use mesh wire, such as Wotofo Profile RDA, Vandy Vape Mesh RDA, Vandy Vape Mesh 24 RTA, Vandy Vape Lit RDA, Digiflavor Mesh Pro RDA, Digiflavor Themis RTA (Mesh Version), Vapefly Mesh Plus RDA, Cthulhu Iris Mesh RDA, etc. This product comes with 12PCS in 1 pack. ![]() Original Hellvape Replacement H1 Mesh Coil for Hellbeast Sub Ohm Tank Clearomizer $19.99 The Hellvape Hellbeast Replacement H1 Mesh Coil head features 0.13ohm resistance and work well at 30~90W (best 60~80W). It is suitable for Original Hellvape Hellbeast Tank. This product comes with 5 PCS in 1 pack. ![]() Original Vapesoon Replacement Bubble Glass Tank Tube for SMOK TFV8 Baby V2 Tank $1.99 The Vapesoon Replacement Glass Tank Tube has 5ml of juice capacity and is suitable for Original SMOKTech SMOK TFV8 Baby V2 Tank. This item also has other Version to choose. ![]() Original Vapesoon Replacement Bubble Glass Tank Tube for Hellvape Dead Rabbit RTA $1.89 The Vapesoon Replacement Glass Tank Tube has 4.5ml of juice capacity and is suitable for Original Hellvape Dead Rabbit RTA. This item also has other colors to choose.
