Просмотров в теме 302440   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 16.10.2018, 04:41 Автор темы   221
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Tesla Mini Duo VV Variable Voltage 500mAh Box Mod $19.99
The Original Teslacigs Mini Duo Box Mod is powered by 500mAh built-in battery and comes with preheat function. With three level voltage adjustable, you can adjust it freely by your preference to enjoy great vaping taste. The unique magnetic connection is easy to connect the atomizer. The Mini Duo mod is compatible with CBD tank and Wax tank. This item also has other colors to choose.
YFTK L'Hypersonic RDTA Rebuildable Dripping Tank Atomizer Clone with BF Pin $18.99
The YFTK L'Hypersonic RDTA Clone is a 22mm rebuildable dripping tank atomizer made from 316 stainless steel. It features dual post deck for single coil build, adjustable side airflow, angled air hole design to avoid over-squonk or leak. It comes with Ultem chamber reducer, which is also heat resistant.
This RDTA comes with bottom feeder pin.
Ulton Typhoon BTD Wave RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.50
The Ulton Typhoon BTD Wave RDA Clone is a 22mm rebuildable dripping atomizer which is constructed from 316 stainless steel. It features dual post build deck, single coil configuration and adjustable side airflow. This RDA is made at 1:1 scale.
This RDA comes with bottom feeder pin.
Vapeasy L'Hypersonic RDTA Rebuildable Dripping Tank Atomizer Clone with BF Pin $14.99
The Vapeasy L'Hypersonic RDTA Clone is a 22mm rebuildable dripping tank atomizer made from 316 stainless steel. It features dual post deck for single coil build, adjustable side airflow, angled air hole design to avoid over-squonk or leak. It comes with Ultem chamber reducer, which is also heat resistant.
Original Tesla Mini Duo VV Variable Voltage 500mAh Box Mod + CBD Tank Kit $21.99
The Original Tesla Mini Duo Vape Kit is an ultimate lightweight kit for CBD oil. The kit combines Tesla Mini Duo mod with a vaporizer for CBD oil. The Tesla Mini Duo is powered by 500mAh built-in battery and comes with preheat function. Three level voltage adjustable, you can adjust it freely by your preference. The unique magnetic connection is easy to connect the atomizer. The CBD tank utilizes ceramic coil and ceramic mouthpiece to produce purer flavor and safe vaping experience.The Teslacigs Mini Duo Vape Kit will give you perfectly different vaping experience. This item also has other Version to choose.
Original HAVA One 350mAh Pod System Starter Kit Original Price $69.99, Now Only $29.99
The Original HAVA One Kit, which is constructed from high-density zinc alloy material, features a compact profile and comfortable texture. With 2.85mm intake width, ensures the optimal amount of air mixes with the e-liquid, allowing you to enjoy huge clouds, strong flavor and immediate vaping experience. Its refillable 2ml pod hidden in the magnetic front cover allows you to easily refill e-liquids or replace a pod. The HAVA One boasts 3 power output modes, you are not restricted to only one vapor taste. Easy to use and with dense clouds and natural taste, the HAVA One completely fulfills your vaping needs. This item also has other colors to choose.
Original HAVA Firefly 85W 2000mAh TC VW Mod + Vtank Kit Original Price $89.99, Now Only $59.99
The Original HAVA Firefly 85W Kit consists of HAVA Firefly 85W TC VW Mod and Vtank Clearomizer. This item also has other colors to choose.
Mod:
The HAVA Firefly 85W TC Mod is constructed from zinc alloy, it features sturdy body and comes with alight control button and two lighting modes, Flash and Breath modes, which can provide different vaping experience to you. It is powered by 2000mAh built-in battery and the maximum output can reach up to 85W. The intelligent controller chip has 6 safety features like high performance, long-lasting lifespan and safe charging. HAVA Firefly 85W mod adopts huge 0.96 inch OLED screen that display main information and keeps you informed of the current device status.
Tank:
The included VTANK, constructed from stainless steel, measuring 24mm in diameter with 5ml maximum juice capacity featuring top-fill method, dual slotted bottom airflow, and the utilization of mesh coil option. The coil is fully compatible with the highly appraised FreeMax FireLuke Mesh Coils.
Original HAVA Beetles 85W 2000mAh TC VW Mod + Vtank Kit Original Price $89.99, Now Only $59.99
The Original HAVA Beetles 85W Kit consists of HAVA Firefly 85W TC VW Mod and Vtank Sub Ohm Tank. This item also has other colors to choose.
Mod:
The Original Beetles 85W TC VW mod is creatively designed by HAVA. It includes a built-in 2000mAh battery and fires up to a maximum output of 85 W, covering your vaping needs for the entire day, allowing you to enjoy dense clouds, a pure flavor and smooth airflow. Stylish and compact, it can be taken along wherever you go and used anytime.
Tank:
Original HAVA Goliath Beetles 220W TC VW Mod + Vtank Kit Original Price $99.99, Now Only $61.99
The Original HAVA Goliath Beetles 220W Kit consists of HAVA Goliath Beetles 220W TC VW Mod and Vtank Sub Ohm Tank. This item also has other colors to choose.
Mod:
The HAVA Goliath Beetles mod is constructed from stainless steel and powered by dual 18650 batteries (NOT INCLUDED). The stylish device features a maximum output of 220 W and different vaping modes, ensuring a massive vapor volume and rich flavors for long-time use to meet your various vaping needs and allowing you to enjoy dense clouds, a pure flavor and smooth airflow.
Tank:
Original HAVA Replacement Pod Cartridge for One 350mAh Pod System Starter Kit Original Price $14.99, Now Only $8.99
The Original HAVA pod cartridge is for HAVA One 350mAh pod system. It has two kinds of coil, the ceramic coil and cotton coil. Its refillable 2ml pod allows you to easily refill e-liquids.
This product comes with 3 pcs in a pack.
Original HAVA Replacement Single Parallel Coil for Vtank Tank / Firefly Kit / Beetles Kit Original Price $19.95, Now Only $12.99
The Original HAVA Replacement Coil is a single parallel coil which features 0.5ohm resistance with an output power from 30W to 50W. It is compatible with HAVA Vtank sub ohm tank / HAVA Firefly Kit / HAVA Beetles Kit / HAVA Goliath Beetles Kit.
This product comes with 5 PCS in a pack. This item also has other Version to choose.
3FVAPE вне форума   Вверх
Старый 17.10.2018, 04:54 Автор темы   222
3FVAPE
Original Asmodus Plaque 150W TC VW Variable Wattage Box Mod Original Price $179.95, Now Only $126.69
The Original Asmodus Plaque features deep, high quality engravings through the body of the mod with an amazingly vibrant finish. The Plaque requires dual 18650 sized batteries (NOT INCLUDED) to power the device and has a maximum power output of 150 watts. It is powered by a GX-150-HF chip which grants the device power saving capabilities as well as a "flavor taste" boosting mode which enhances flavor. This item also has other colors to choose.
Original Think Vape Thor Pro 220W TC VW Variable Wattage Box Mod $45.90
The Original Thinkvape Thor Pro Mod, powered by dual 18650 batteries (NOT INCLUDED), is able to reach up to a maximum output power of 220W. The Thor Pro provides a stable and high performing VW / TC / Bypass modes with a 1.3" TFT screen. Meanwhile, with high-temperature and short-circuit protection, it is safe to use. Compared with the previous Thor, the Thor Pro comes with more attractively unique patterns and ergonomic design which is comfortable to have it on your hand. This item also has other colors to choose.
Citadel RDA Rebuildable Dripping Atomizer Clone with BF Pin $45.90
The Citadel RDA Clone is a rebuildable dripping atomizer which is constructed from stainless steel with a diameter of 22mm. It comes with PEEK insulators and black Delrin drip tip. The Citadel Style RDA has unique Ultem chamber reducer to enhance flavor and warmth, dual sided slotted post with large flathead securing set screws and Hadaly style airflow angled downward for minimizing leaks.
This RDA comes with BF pin. This item also has other colors to choose.
Original Vivismoke Magic Stick Coil Jig Coiling Rod Cotton Hook Vape Tool $3.59
The Original Vivismoke Magic Stick is a multifunctional vape tool that can be used to adjust the coils, tighten the screws, hook the cotton and build the coils. It is really useful for DIY.
Original Union Portable Carrying Storage Vape Bag for Pod System Kit $5.99
The Original Union Vape Bag is small sized carrying bag for pod system kits. Made of leather, it feels smooth and is very easy to carry.
Original Demon Killer Care Kit Replacement Screw Pack for RDA / RTA $3.99
The Original Demon Killer Care Kit is a replacement screw pack with three types of screws for all atomizers on the market. The kit comes with a soft brush for easy cleaning atomizer.
This kit comes with M2.5 x 3 Hex Socket Set Screw (10 PCS), M3.0 x 3 Hex Socket Set Screw (10 PCS) and M2.5 x 4 Round Head Cross Screw (10 PCS), totally 30 PCS.
Original Demon Killer Mini Staggered Clapton Ni80 Handcraft Coil for RDA / RTA / RDTA $4.99
The Original Demon Killer Mini Staggered Clapton Handcraft Coil Heating Wire is made from Nichrome 80 and features 0.3ohm resistance and (0.4 x 0.12) + 0.12 wires. This heating wire will be a good vaping choice for DIY.
This product comes with 2 PCS of Coils and 2 PCS of Cleaning Tools in 1 pack. This item also has other Version to choose.
Original Steam Crave Vape Building Mat for E-Cigarette $14.99
The Original Steam Crave Vape Building Mat is very useful for every vaper to build coils, cut cotton, all the DIY work about e-cigarette. It measures 345mm by 690mm by 3mm, providing enough space for you work.
Original Steam Crave Replacement Tank Tube for Aromamizer Plus RDTA $3.39
The Original Steam Crave replacement glass tank is suitable for Aromamizer Plus RDTA. It is made from glass with a 5ml juice capacity.
This product comes with 2 pcs in a pack. This item also has other Version to choose.
Original Steam Crave Replacement Postless Build Deck for Aromamizer Plus RDTA $9.59
The Original Steam Crave Replacement Postless Build Deck is made from stainless steel and is suitable for Aromamizer Plus RDTA.
Original Steam Crave Replacement Single Build Coil Deck for Aromamizer Supreme V2 RDTA $8.59
The Original Steam Crave Replacement Single Coil Build Deck is made from stainless steel and is suitable for Aromamizer Supreme V2 RDTA.
Старый 18.10.2018, 04:34 Автор темы   223
3FVAPE
Original Tesla XT Mini 220W TC VW Variable Wattage Box Mod $52.99
The Original Tesla XT TC VW Box Mod is constructed from zinc alloy, it also comes with unique RGB LED light effect, which brings you more vaping fun. Powered by dual 18650 batteries (NOT INCLUDED), the Teslacigs XT Mini mod can also fire up to the max output of 220W and supports KA / TC-SS316 / TC-Ni200 / TC-Ti / TCR mode. This item also has other colors to choose.
Original CoilART Mage Mech V2.0 Hybrid Mechanical Tube Mod Stacked Edition $79.99
The Original CoilART Mage Mech V2.0 mod is a hybrid mechanical tube mod constructed from brass, it is powered by 1 or 2 batteries and is compatible with 18650, 20700 and 21700 battery (NOT INCLUDED). This mechanical mod features electroplating frosted black body, internal insulation protection and self-adjusting battery contact.
Original Asmodus Bunker RDA Rebuildable Dripping Atomzier with BF Pin Original Price $39.95, Now Only $30.99
The Original Asmodus Bunker RDA is an ultimate single coil squonk-able RDA with 24.5mm diameter. The Bunker features a low profile style top cap, a locking airflow system, flavor boosting drip tip, and an incredible build quality all centered around a unique build deck. The airflow slots direct the incoming air through slots milled into the posts, creating a bottom airflow effect intended to help enhance the amazing flavor produced by single coil builds. It is compatible with any 810 drip tip of your choosing. This item also has other colors to choose.
Original SMOKTech SMOK R-Kiss 200W VW Box Mod + TFV-Mini V2 Tank Kit $71.39
The Original SMOKTech SMOK R-Kiss 200W Kit consists of the SMOK R-Kiss 200W VW box mod and TFV-Mini V2 sub ohm tank. This item also has other colors to choose.
Mod:
The SMOK R-Kiss mod is powered by dual 18650 batteries (NOT INCLUDED), which features cuboid design, two-color combination without extra decoration. The R-Kiss can fire up to 200W maximum output with the traditional lateral big fire key, which is ergonomically designed on the left side, you can press to set and vape. With a brand new user interface, on which you can see every part of vaping information is properly arranged, such as wattage, voltage, battery life and resistance.
Tank:
The included TFV-Mini V2 tank is a 25.4mm sub ohm tank, which has three wider airflow slots and supports top filling. Moreover, two new coils are available, the Mini V2 A1 and Mini V2 A2, all of which are perfect choices for max vapor.
Original SMOKTech SMOK Mag Grip 100W TC VW Mod + TFV8 Baby V2 Tank Kit $58.59
The Original SMOKTech SMOK Mag Grip 100W mod kit consists of the SMOK Mag Grip 100W TC VW mod and TFV8 Baby V2 sub ohm tank. This item also has other colors to choose.
Mod:
The SMOK Mag Grip mod features a handheld mod, exquisite fire key, and magazine release. It still has good hand feeling, its grooves on the upper part of the mod are optimized to maximize the practicability that makes the mod more comfortable to grip and hold. The Mag Grip also adopts the exquisite small fire key, like the trigger of a gun, and you can press the triggering button easily. But the display screen has been designed differently, a 0.66 inch OLED screen with high definition is close to the 510 plate, providing a more convenient viewing angle for the user, which is indeed an ergonomic handling. The Mag Grip mod is powered by single 21700 / 20700 and 18650 battery (NOT INCLUDED), when using the 20700 and 21700 battery, the Mag Grip mod can fire up to 100W maximum output (85W maximum with 18650 battery).
Tank:
The included TFV8 Baby V2 tank is a 30mm sub ohm tank with 5ml capacity. It has two new coils, 0.15ohm Baby V2 S1 single mesh coil (40~80W, best 60~70W) and 0.15ohm Baby V2 S2 quadruple kanthal coil (30~70W, best 45~60W), which are custom-made coils for Stick series battery with intense clouds and flavor.
Original Tesla XT Mini 220W TC VW Variable Wattage Mod + Tallica Mini Tank $70.09
The Original Tesla XT Mini Kit consists of Tesla XT Mini 220W Mod and Tallica Mini Tank. This item also has other colors to choose.
Mod:
Tank:
The Tesla Tallica Mini Tank is a 25mm sub ohm tank, which has 4ml / 6ml juice capacity and supports 110W max output. It has large airflow slots on the base, and the triangular airflow can easily adjusted to get different vaping experience. With slide refilling design, it is simple to fill e-liquid, and the plug-and-pull coil replacement design ensures easy coil installation.
Старый 19.10.2018, 06:50 Автор темы   224
3FVAPE
Original Dovpo Topside 90W TC VW Variable Wattage Squonk Box Mod Original Price $84.99, Now Only $65.99
The Original Dovpo Topside Mod is collaboratively designed by the Vapor Chronicles and Dovpo, which is constructed with food grade Stainless Steel, Zinc Alloy and Aluminum Alloy to make it moderately impact-resistant in an ergonomic shape and ensures safety to provide you healthy vaping experience. Powered by a single 18650 / 21700 battery (NOT INCLUDED), the Topside can fire up to 90W maximum output with switchable power, bypass, and temperature control modes. Besides, the mod also equips a 10ml silicone e-juice bottle which supports the top filling. This item also has other colors to choose.
Original Vandy Vape Pulse X 90W TC VW Variable Wattage Squonk Box Mod Original Price $58.90, Now Only $45.99
The Vandy Vape Pulse X 90W Mod is made from Zinc Alloy, it has a maximum power output of 90 watts with single 18650 / 20700 / 21700 battery (NOT INCLUDED). It is powered by Vandy Chip, which has excellent quality and highest stability. The replaceable panel comes with magnetic structure design. This item also has other colors to choose.
Citadel RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99
The Citadel RDA Clone is a rebuildable dripping atomizer which is constructed from stainless steel with a diameter of 24mm. It comes with PEEK insulators and black Delrin drip tip. The Citadel RDA Clone has unique Ultem chamber reducer to enhance flavor and warmth, dual sided slotted post with large flathead securing set screws and Hadaly style airflow angled downward for minimizing leaks.
Vapeasy Citadel RDA Rebuildable Dripping Atomizer Clone with BF Pin $12.99
The Vapeasy Citadel RDA Clone is a rebuildable dripping atomizer which is constructed from 316 stainless steel with a diameter of 22mm. It comes with PEEK insulators and black Delrin drip tip. The Citadel RDA Clone has unique Ultem chamber reducer to enhance flavor and warmth, dual sided slotted post with large flathead securing set screws and Hadaly style airflow angled downward for minimizing leaks. This RDA is made at 1:1 scale.
Original Eleaf iStick Nowos 80W 4400mAh Box Mod + ELLO Duro Tank Kit $73.54
The Original Eleaf iStick Nowos 80W Kit consists of the iStick Nowos 80W 4400mAh VW box mod and ELLO Duro sub ohm tank. This item also has other colors to choose.
Mod:
The Original Eleaf iStick NOWOS is leading the way with the innovative LED digital display and touch buttons, where aesthetic looking meets easy operation. It houses a mighty 4400mAh battery which can reach a maximum power of 80W and supports QC3.0 / PD3.0 protocol for faster charging than ever. Another revolution is the use of TYPE C. Unlike older USB cable, it doesnt matter which side is up with the TYPE C.
Tank:
The ELLO Duro sub ohm tank is a 28mm Clearomizer with a 6.5ml capacity, it comes with two new kinds of dual mesh coil: the HW-M Dual 0.2ohm coil and the HW-N Dual 0.25 ohm coil, bringing you the best vaping experience.
Original Vandy Vape Pulse X 90W TC VW Squonk Box Mod + Pulse X BF RDA Kit Original Price $69.90, Now Only $62.99
The Original Vandy Vape Pulse X 90W Kit consists of the Pulse X 90W TC VW squonk box mod and Pulse X BF RDA. This item also has other colors to choose.
Mod:
The Vandy Vape Pulse X Mod has maximum power output of 90 watts with single 18650 / 20700 / 21700 battery (NOT INCLUDED). It is powered by Vandy Chip, which has excellent quality and highest stability. The replaceable panel comes with magnetic structure design.
RDA:
The Pulse X RDA feeds the juice directly to the top of your coils, giving you the experience you would get with typical dripping atomizers, and saturating your wicks and coils from the top. This ensures that your coils are always wet and ready to go. When squonking, the one-way-valve design allows excess juice to return to the bottole at the bottom. It also allows you to drip right onto the center through the drip tip for non-squonk usage, and the liquid rolls off the top center of the post and onto your coils. The "X" design for the post can be used effectively for vertical and horizontal builds, and can accommodate large or small coils.
Original HAVA Replacement Cotton Pod Cartridge for One 350mAh Pod System Starter Kit Original Price $14.99, Now Only $8.99
The Original HAVA Replacement Cotton Pod cartridge is compatible for HAVA One 350mAh pod system. It comes with cotton coil. It has a resistance of 1.2ohm and 2ml capacity, it can provide different e-liquid flavors.
Старый 22.10.2018, 06:03 Автор темы   225
3FVAPE
Original iOOi I007 117W TC VW Variable Wattage Box Mod $54.99
The Original iOOi I007 117W TC VW box mod, power by single 18650 / 20700 / 21700 battery (NOT INCLUDED), it can reach the output power from 5W to 117W. The iOOi I007 117W mod features 0.96 inch IPS high definition color screen, seven kinds of protections and the charging time is about 3 hours. The overall body design is ergonomically designed, with a comfortable grip and stronger sense of conquest. This item also has other colors to choose.
Original VapeCige VTBOX250C 200W TC VW Variable Wattage Box Mod $119.95
The Original VapeCige VTBOX250C 200W is a TC VW box mode constructed from aluminum, power by dual 18650 batteries (NOT INCLUDED), it can reach the output power from 1W to 200W. It comes with Evolv DNA 250C chipset, 0.96 inch full color TFT screen, Spring-loaded firing button and Micro-USB charging port. This item also has other colors to choose.
Avid Lyfe Gyre Dimple Hybrid Mechanical Mod Clone $31.99
The Avid Lyfe Gyre Dimple Hybrid Mechanical Mod Clone is constructed from Cupronickel. The Twist mechanical mod Clone is powered by single 18650 battery (NOT INCLUDED). Comes with the unique twisted shape, this mod will bring an amazing vaping experience to your vaping life.
Original iOOi I007 Sub Ohm Tank Clearomizer $22.99
The Original iOOi I007 sub ohm tank is a 25mm Clearomizer, it features 6ml juice capacity and 0.3ohm resistance. It adopts bottom adjustable airflow design for huge vapor clouds and better vaping experience. The top side filling design makes refill easier and avoid leakage. This item also has other colors to choose.
Original Vandy Vape Kylin V2 RTA Rebuildable Tank Atomizer $39.90
The Original Vandy Vape Kylin V2 RTA is a 24mm rebuildable tank atomizer constructed from stainless steel and Pyrex glass, it features bottom beveled air intake and cambered surface air outlet for nice flavor and offers huge vapor production. The Kylin 2 RTA tank adopts an unique cambered deck, which is available for both single and dual coils. The internal airhole and beveled buttom air intake design creating a smooth vaping with excellent flavor for you. With nifty slide out top filling system for easy to refill e-juice, equip with bulb glass tube to hold 5ml maximum juice capacity, that will satisfy your daily vaping needs. Including the popular wide bore drip tip, makes the Kylin 2 RTA Tank more fashionable. This item also has other colors to choose.
Goon V1.5 Ti RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.99
The Goon 1.5 Ti RDA Clone is constructed from Titanium in 24mm diameter. It features bridge clamp design for easy building and middle side adjustable air slots for airflow control. The RDA supports single / dual coil build. The RDA comes with a Titanium 810 wide bore drip tip.
Original iOOi I007 117W TC VW Box Mod + Sub Ohm Tank Kit $65.99
The Original iOOi I007 117W mod kit consists of the iOOi I007 117W TC VW box mod and iOOi I007 sub ohm tank.This item also has other colors to choose.
Mod:
Tank:
Replacement Top Cap for Narda RDA Clone $4.49
The replacement top cap is made from PC with 22mm diameter. It is suitable for Narda RDA Clone.
Replacement Top Cap for Battle RDA Clone $5.39
The replacement top cap is made from Titanium with 24mm diameter. It is suitable for Battle RDA Clone.
Replacement X3-C2 Coil Head for I007 Sub Ohm Tank $10.39
The replacement coil head features 0.3ohm resistance and works well at 60 to 100W. It is suitable for Original iOOi I007 Tank.
This product comes with 3 PCS in 1 pack. This item also has other Version to choose.
Original Vivismoke Ultrasonic Cleaner for RDA / RTA / Sub Ohm Tank Atomizer $14.99
The Vivismoke Ultrasonic Cleaner utilizes practical and classic design and uses tap water for Ultrasonic cleaning. It can help you clean RTA, RDA, RBA, metal atomizer parts, screws, o-rings, glass tanks and drip tips. The Ultrasonic Cleaner has 150ml volume and 0.2W power.
Original Dovpo Replacement Squonk Bottle for Topside Squonk Box Mod $14.99
The replacement squonk bottle is made from stainless steel shell and silicone bottle. It has 10ml of juice capacity. It is suitable for Original Dovpo Topside squonk box mod.
Старый 23.10.2018, 04:28 Автор темы   226
3FVAPE
SOB Emperor Mechanical Box Mod Clone $12.99
The SOB Emperor Mechanical Mod Clone features POM chassis, brass 510 contact pin, Ultem fire button on the side and copper battery door. It has many cut-outs for heat dissipation. It is powered by dual 18650 batteries (NOT INCLUDED). This item also has other colors to choose.
Goon 25mm RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99
The Goon 25mm RDA Clone is constructed from 304 stainless steel and in 25mm diameter. The Goon 25mm RDA Clone is with unique dual post and bridge clamp posts coil clamping system for dual coil build. It comes with adjustable side airflow and 810 wide bore POM drip tip.
This RDA comes with bottom feeder pin. This item also has other colors to choose.
SXK Citadel RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $15.90, Now Only $12.99
The SXK Citadel RDA Clone is a rebuildable dripping atomizer which is constructed from 316 stainless steel with a diameter of 22mm. It comes with PEEK insulators and black Delrin drip tip. The Citadel RDA Clone has unique Ultem chamber reducer to enhance flavor and warmth, dual sided slotted post with large flathead securing set screws and Hadaly style airflow angled downward for minimizing leaks. This RDA is made at 1:1 scale.
SOB Emperor Mechanical Box Mod Clone + Outlaw RDA Kit Clone $18.99
The SOB Emperor Mech Kit Clone consists of SOB Emperor Mech mod Clone and Outlaw RDA Clone. This item also has other colors to choose.
Mod:
RDA:
The Outlaw RDA Clone is constructed from stainless steel with 24mm diameter. The deck features classic dual post style design and comes with a deep juice well. The airflow can be adjusted by dual airslots on each side.
Original Voopoo Drag 2 177W TC VW Box Mod + UForce T2 Tank Kit $65.99
The Original VOOPOO Drag 2 Kit consists of the Voopoo Drag 2 177W TC VW box mod and an UForce T2 sub ohm tank. This item also has other colors to choose.
Mod:
The Original Voopoo Drag 2 177W TC VW box mod is powered by dual 18650 batteries (NOT INCLUDED), it can fire up to a powerful output of 177W. As a new generation of drag, the Drag 2 is more lighter and functional. The Drag 2 mod adopts GENE.FIT chip, which is secured by a V0 class fireproofing bridge to block dust, liquid or burnout. It comes with innovative FIT mode to intelligently match and protect tanks from burnout.Tank:
The UFORCE T2 sub ohm tank is a 28mm innovative sub ohm tank. It can prevent the e-juice leakage by pushing the top cap. The tank utilizes U2 / N3 coil to achieve purer flavor and stronger clouds.
Original Voopoo Drag Mini 117W 4400mAh TC VW Mod + UForce T2 Tank Kit $66.79
The Original VOOPOO Drag Mini Kit consists of the Voopoo Drag Mini 117W TC VW box mod and an UForce T2 sub ohm tank. This item also has other colors to choose.
Mod:
The Original Voopoo Drag Mini 117W TC VW box mod, powered by built-in 4400mAh battery, it can fire up to 117W max output. As a new generation of drag, the DRAG mini features mini size and compact design, utilizes colorful resin panels to make your vaping life colorful. It also adopts GENE.FIT chip to ensures excellent taste and enjoyable vaping experience. The innovative FIT mode intelligent match and protect tanks. The mod equips with a crystal OLED display to show parameters of device such as mode, resistance, voltage and wattage.
Tank:
The UFORCE T2 sub ohm tank is a 28mm innovative sub ohm tank with a 5ml capacity. It can prevent the e-juice leakage by pushing the top cap. The tank utilizes U2 / N3 coil to achieve purer flavor and stronger clouds.
Старый 24.10.2018, 04:52 Автор темы   227
3FVAPE
Original Ovanty Vega 200W TC VW Variable Wattage Box Mod $57.99
The Original Ovanty Vega 200W mod is powered by dual 18650 batteries (NOT INCLUDED), it is able to reach up to a output power from 5W to 220W. It comes with Cambrian 200 chipset, built-in in balance charging chip and OTF update system, and also provides a stable and high performing with VW / TC / Bypass modes. This item also has other colors to choose.
Original Hatovape DF-Box 650mAh VV Battery Mod with UV Painting $9.99
Inspired by car key, the Original Hatovape DF-Box features compact design for griping. It can vary voltage from 3.2V, 3.7V and 4.2V. It uses simple, cool and clean design to create the best vaping experience. The mod is powered by inbuilt 650mAh battery. It is great for CBD vaping.
This product comes with UV painting finish. This item also has other Version to choose.
Original Blitz Versus Disposable Sub Ohm Tank Clearomizer Original Price $12.99, Now Only $10.89
The Original Blitz Versus is a 24mm sub ohm tank with 4ml capacity and 0.15ohm resistance. Constructed from food grade PCTG and stainless steel, this innovative tank features mesh coil installed with wood plup cotton and nature flax fiber, and it can bring super flavor and to a certain degree extend coil lifespan till its end. This Clearomizer is disposable with non-replaceable coil system.
This product comes with 2 pcs in a pack. This item also has other colors to choose.
Apocalypse Gen 4 RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.49
The Mechlyfe Apocalypse Gen 4 RDA Clone is a 24mm rebuildable dripping atomizer made from stainless steel. It comes with stainless steel cap and plastic internal cap. It features bridge clamp style dual post build deck and dual air slots on the cap. The RDA has resin drip tip in random color.
The manufacturer states that this product is Apocalypse Gen 4 RDA Clone. However, according to our research, the 4th generation of Apocalypse has not been released yet. We believe that it is more like an upgraded version of Mechlyfe style RDA.
Original ThunderHead Creations THC Tauren Honeycomb RTA Rebuildable Tank Atomizer Original Price $39.90, Now Only $22.99
The Original THC ThunderHead Creations Tauren Honeycomb RTA is a rebuildable atomizer with 2ml capacity and 24mm diameter which is constructed from stainless steel. It comes with extra PC tank tube to extend the capacity to 4.5ml. It features unique hexagonal honeycomb airflow system, convenient top filling system and AFC ring with innovative knurling design for easy airflow control. This item also has other colors to choose.
Original Gas Mods G.R.1 GR1 Pro RDA Rebuildable Dripping Atomizer with BF Pin $39.99
The Original GAS Mods GR1 Pro RDA is the upgraded version of GR1, featuring 24mm diameter, dual coil build deck, more fantastic airflow and squonk-ready. It will bring you more amazing vaping experience than GR1.
Original Carrys Ring 300mAh Pod System Starter Kit $11.69
The Original Carrys Ring 300mAh Pod Kit is very lightweight and comes with the innovative ring design, which is very convenient to carry. Powered by built-in 300mAh battery with the LED battery indicator light, the Carrys Ring can bring you great vaping experience. The device will also shut down without any operation in one hour. And the Carrys Ring Pod Cartridge comes with 1.0ml e-juice capacity, featuring the unique ceramic coil and side air intake design for huge clouds. This item also has other colors to choose.
Original Akattak Sneaker Cotton Pre-loaded Wick for RDA / RTA / RDTA $5.99
The Original Akattak Sneaker Cotton is made from 100% pure and natural cotton. It is hypoallergenic, medical grade. The impurity has been removed for pure flavor. It comes with shoelace edges, which makes it easy to be wicked.
This product comes with 20 PCS in 1 pack.
Original Carrys Replacement Pod Cartridge for Ring 300mAh Pod System Starter Kit $6.99
The Original Carrys Replacement Pod Cartridge comes with 1.6ohm of resistance and 1ml capacity. It is suitable for Carrys Ring 300mAh Pod System Kit.
This product comes with 4 PCS in a pack.
Старый 25.10.2018, 04:57 Автор темы   228
3FVAPE
Original Eleaf iStick Nowos 80W 4400mAh Battery TC VW Variable Wattage Mod $53.23
The Original Eleaf iStick NOWOS is leading the way with the innovative LED digital display and touch buttons, where aesthetic looking meets easy operation. It houses a mighty 4400mAh battery which can reach a maximum power of 80W and supports QC3.0 / PD3.0 protocol for faster charging than ever. Another revolution is the use of TYPE C. Unlike older USB cable, it doesnt matter which side is up with the TYPE C. This item also has other colors to choose.
Original Tesla One Disposable Sub Ohm Tank Clearomizer $11.99
The Original Teslacigs ONE Disposable Tank is a 23.5mm diameter sub ohm tank which is constructed by food-grade plastic, brings a safe vaping experience to vapers. It features 3ml e-juice capacity and 0.2ohm coil resistance. Moreover, the top filling is available on this tank. This Clearomizer is disposable with non-replaceable coil system.
This product comes with 3 pcs in a pack. This item also has other colors to choose.
Original Vapesoon Doraemon 510 Drip Tip with Cap for RDA / RTA / Sub Ohm Tank Atomizer $2.69
The replacement 510 drip tip is made from POM and the protective cap is made from silicone. It is suitable for all atomizers that fit 510 drip tip. This item also has other Version to choose.
Replacement Drip Tip + Top Cap for DEJAVU DJV RDTA $3.99
The replacement drip tip and top cap are made from POM and are suitable for Original DEJAVU DJV RDTA. This item also has other colors to choose.
Original Avidartisan DIY Tool Mini Kit for Coil Building $10.99
The Original Avidartisan DIY Tool Mini Kit comes with 5 useful DIY tools for coil building, including Diagonal pliers, Scissors, Elbow Tweezer T3, Ceramic Tweezer and Micro Coil Jig. It is good for RDA / RTA DIY coil building.
Original frieQuos Disassembly Tool for IQOS $13.99
The Original frieQuos Disassembly Tool consists of a ceramic tweezers, a main portion of disassembly tool, a positioning cylinder and a U-shape pin. You can use this tool to disassemble your IQOS for cleaning.
Старый 26.10.2018, 04:32 Автор темы   229
3FVAPE
20700 / 21700 Hybrid Mechanical Tube Mod $20.99
The mechanical tube mod is made from brass and features 25mm diameter, hybrid connection, lockable side firing button, and revolutionary firing mechanism. There is no spring nor magnet, just constant contact. It comes with two contact points for increased conductivity. Delrin insert is for heat dissipation. The mod is powered by single 20700 / 21700 battery (NOT INCLUDED). This item also has other colors to choose.
Original Yosta Livepor 230W TC VW Variable Wattage Box Mod $40.69
The Original Yosta Livepor 230W mod is powered by dual 18650 batteries (NOT INCLUDED), it is able to reach up to a output power from 5W to 230W, with only 0.01s fast firing speed. It comes with 1.33inch color IPS screen, comfortably big fire button and compact size with ergonomic designed for better touch feeling. This item also has other colors to choose.
Vindicator Hybrid Mechanical Tube Mod Clone $14.99
The Vindicator Mechanical Mod Clone is a hybrid mech mod made from 316 stainless steel. It comes with 25mm hybrid connector. The mod is powered by single 20700 / 21700 battery (NOT INCLUDED), it features 510 threading connection and spring-loaded fire button.
The manufacturer may change the battery contact part from copper to stainless steel. The final refers to the manufacturer's actual product. This item also has other colors to choose.
Kalasag V2 Mechanical Box Mod Clone $19.99
The Kalasag V2 Mechanical Box Mod Clone consists of PC chassis, brass main structure and stainless steel battery doors. The fire button is positioned at the top, which is made from Ultem PEI. The mod is powered by dual 18650 batteries in parallel (NOT INCLUDED). This item also has other colors to choose.
Original Gas Mods G.R.1 GR1 Pro RDA Rebuildable Dripping Atomizer with BF Pin Original Price $39.99, Now Only $34.99
The Original GAS Mods GR1 Pro RDA is the upgraded version of GR1, featuring 24mm diameter, single & dual coil build deck, more fantastic airflow and squonk-ready. GR1 Pro RDA comes with bottom airflow for dual coil build and 45-degree side airflow for single coil build. It will bring you more amazing vaping experience than GR1.
Original Wotofo Serpent Elevate RTA Rebuildable Tank Atomizer $34.99
The Original Wotofo Serpent Elevate RTA is a 24mm atomizer designed by Wotofo and Suck My Mod. It is a postless single coil RTA with 3.5ml capacity, top airflow design and the most advanced air distribution structure. Serpent Elevate is an RTA combining its past merits with current vape trends, it assures you exceptionally intense flavor. This item also has other colors to choose.
Chalice Retro RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.99
The Chalice Retro RDA Clone is made from stainless steel with sandblasting finish, making it feel smooth. It has a diameter of 14mm, which is very tiny. This RDA supports single coil build. It comes with bottom airflow. The squonk pin is silver plated for better conductivity. Standard pin is also included. This RDA is compatible with 510 drip tips.
Original Ambition Mods 810 to 510 Drip Tip Adapter for C-Roll BF RDA Rebuildable Atomizer $2.59
The Original Ambition Mods 810 to 510 Drip Tip Adapter is made from POM. With this adapter, you can use the standard 510 drip tip in the Ambition Mods C-Roll Rebuildable Dripping Atomizer.
Only one piece (1 PC) will be shipped.
Original GAS Mods Replacement Top Cap for G.R.1 GR1 Pro RDA Original Price $12.00, Now Only $8.99
The Original GAS Mods Replacement Top Cap is made from POM. The outer diameter is 24mm. It is suitable for Original GAS Mods G.R.1 GR1 Pro RDA. This item also has other colors to choose.
Original Wotofo Vape Tool Kit for Coil Building Original Price $32.99, Now Only $28.99
This Wotofo Vape Tool Kit provides a full coverage of your rebuilding needs. The kit contains a pair of medical standard scissors, a tungsten reinforced flush cutter, a pair of wire-friendly bent nose pliers, bent tip tweezers, hardened ceramic tweezers, 2 four-size coil jigs, and a 4-in-1 screwdriver. All the tools are organized in a bag constructed from tough, waterproof fabric with zipper closing.
Старый 29.10.2018, 09:32 Автор темы   230
3FVAPE
Original Artery Hive 200W TC VW Variable Wattage Box Mod Original Price $71.30, Now Only $48.99
The Original Artery Hive 200 200W TC VW box mod is a powerful and elegant mod inspired by hive with 1.3inch colorful TFT screen. Powered by dual 18650 batteries (NOT INCLUDED), with the most advanced AERO CHIP, the Hive 200 fires up to 200W max output with 0.01s instant fire speed and high performance VW / TC modes. What's more, the Artery Hive 200 supports the world's first "Flavor Mode" function which makes you can taste purer flavor from the e-juice, especial the mixed flavor e-juice. This item also has other colors to choose.
Original Vapjoy Hayabusa RDA Rebuildable Dripping Atomizer with BF Pin $20.99
The Original Hayabusa RDA is innovative designed by VAPJOY Team featured with 22mm 316F grade stainless steel for higher level vaping experience. It's single coil build atomizer comes with a high quality Ni90 26AWG 10R prebuilt coil as well as Jellyfish cotton. The Hayabusa RDA is easy to set up coil wires from 26AWG (0.4mm) with detailed design to higher level Flat Clapton wires for widely option. This item also has other colors to choose.
Original Ehpro True RTA Rebuildable Tank Atomizer Original Price $34.90, Now Only $23.29
The Original Ehpro True RTA, designed by Ehpro and NatureVape, is a unique and compact 22mm MTL RTA constructed from stainless steel with optional 2ml / 3ml e-juice capacity. It mainly features the innovative two ways for coil building, so you can install the coil under the clamp or under the screw, which brings you much more convenience. And the Ehpro True MTL RTA also comes with five air slots with different diameters for your selection. Plus the easy top refill design, the Ehpro True MTL RTA will bring you great vaping experience. This item also has other colors to choose.
Original Ehpro Lock RDA Rebuildable Dripping Atomizer with BF Pin Original Price $30.90, Now Only $23.89
The Original Ehpro Lock RDA is a 24mm rebuildable dripping atomizer constructed from stainless steel. It features nut style top cap, classic and industrial, easy to pull up yet, and side-up direct airflow system which brings effortless vapor and superb flavor.
YFTK Citadel RDA Rebuildable Dripping Atomizer Clone with BF Pin $19.99
The YFTK Citadel RDA Clone is a rebuildable dripping atomizer which is constructed from 316 stainless steel with a diameter of 22mm. It comes with PEEK insulators and black Delrin drip tip. The Citadel RDA Clone has unique Ultem chamber reducer to enhance flavor and warmth, dual sided slotted post with large flathead securing set screws and Hadaly style airflow angled downward for minimizing leaks. This RDA is made at 1:1 scale.
Original Hugsvape Surge 600mAh Pod System Kit Original Price $19.99, Now Only $14.99
The Original Hugsvape Surge Pod Kit is a convenient pod system device with 600mAh inbuilt battery. The pod comes with 6ml of juice capacity and 1.0ohm coil. There is no button for the decice. Surge pod will work immediately after detecting the draw pressure when you inhale from the mouth piece. The pod kit comes with LED light indicator. It can be easily charged via USB port. This item also has other colors to choose.
Original Artery Hive 200 200W TC VW Box Mod + Sub Ohm Tank Kit Original Price $82.00, Now Only $62.99
The Original Artery Hive 200W Kit consists of the Artery Hive 200W TC VW box mod and Hive sub ohm tank.This item also has other colors to choose.
Mod:
Tank:
The Original Artery Hive Tank is a brand-new 24mm sub ohm tank with 4ml capacity, it features outstanding mesh coil and easy top filling. It is a newly developed high wattage sub ohm tank, adopting the outstanding mesh coil, combines rich flavor, huge vapor and long lasting life.
Original Artery PAL Mini 1000mAh Pod System Starter Kit Original Price $29.90, Now Only $22.99
The Original Artery PAL Mini Pod System Kit inherits the appearance of its predecessor while shrinks the size to an extreme. Inspired by a cardcase, the PAL Mini is thin and portable in your hands. With 1.1ml juice capacity and a built-in 1000mAh battery, the starters will enjoy a simple vape for a long-lasting time. The Artery PAL Mini comes with two different pods: the 1.6ohm ceramic wicked pod is perfect for high nicotine e-juice, while the 1.0ohm organic cotton wicked pod is best for regular liquid. The innovative pull-out refilling system upgrades the juice filling to a new level. This item also has other colors to choose.
Original Hugsvape Replacement Squonk Bottle for Surge 80W Mod $1.59
The squonk bottle is made from stainless steel top lid and silicone bottle. It comes with 6ml of juice capacity. It is suitable for Original Hugsvape Surge 80W Squonk Mod.
Original Hugsvape Replacement Pod Cartridge for Surge Pod System Kit $3.50
The Original Hugsvape Replacement Pod Cartridge comes with 1.0ohm of resistance and 6ml capacity. It is suitable for Hugsvape Surge Pod Kit.
Original Artery Replacement Pod Cartridge for PAL Mini Pod System Original Price $14.90, Now Only $9.29
The replacement pod cartridge features 1.1ml of juice capacity and 1.0ohm cotton wick. It is suitable for Original Artery PAL Mini Pod System kit.
This product comes with 5 PCS in 1 pack. This item also has other Version to choose.
Original Ehpro Core Clapton Ni80 Pre-built Coil for True RTA Rebuildable Tank Atomizer $3.50
The Original Ehpro Core Clapton Pre-built Coil is made from Ni80 material. It features 1.0ohm resistance and 28 + 38GA wires. It is suitable for Ehpro True rebuildable tank atomizer.
Original Ehpro Replacement Tank Tube for True RTA Rebuildable Tank Atomizer $0.80
The replacement tank tube is made from glass with 2ml of juice capacity and is suitable for Ehpro True rebuildable tank atomizer. This item also has other Version to choose.
Original Ehpro Core for Lock BF RDA Rebuildable Dripping Atomizer $4.50
The Original Ehpro Core is made from 316 stainless steel. It features 0.2ohm resistence (30~50W) and is suitable for Ehpro Lock rebuildable dripping atomizer.
Старый 30.10.2018, 04:51 Автор темы   231
3FVAPE
Original Joyetech Riftcore Solo RTA Rebuildable Tank Atomizer $30.97
The Original Joyetech Riftcore RTA, featuring the innovative coil-less design, it brings a new concept for a rebuildable tank. The Riftcore Solo adopts RFC Heater with molecule heating technology, providing a long lifespan. It frees your hands from countless wires and sophisticated building. And the RFC heater passes the safety test from the independent US laboratory. The heating element in Riftcore Solo also has a self-cleaning function for easy cleaning. Just remove the cotton and dry burn the RFC heater at 30W for 3 seconds. Let it cool for 10 seconds. Repeat the dry burn and cooling cycle a few times until the heater is clean. This item also has other colors to choose.
Original Advken CP TF RTA Rebuildable Tank Atomizer Original Price $39.99, Now Only $28.19
The Original Advken CP TF RTA is an upgrade single coil RTA from Advken family, which features 3ml of e-juice with the standard glass tank and 4ml with the bubble glass tank. Constructed from 304 stainless steel, the Advken CP TF RTA also supports top slide filling design for convenient refilling liquid without leakage, and it adopts unique postless rebuild deck for easy single coil building. Plus the top airflow system, and the Ni80 coil with 0.3ohm resistance, it will bring wonderful flavor and astounding vaping experience. This item also has other colors to choose.
ShenRay Typhoon BTD Wave RDA Rebuildable Dripping Atomizer Clone with BF Pin + PC Cap $13.39
The ShenRay Typhoon BTD Wave RDA Clone is a 22mm rebuildable dripping atomizer which is constructed from 316 stainless steel. It features dual post build deck, single coil configuration and adjustable side airflow.
This RDA comes with bottom feeder pin and spare PC top cap. This item also has other colors to choose.
ShenRay Dome V3 RTA Rebuildable Tank Atomizer Clone $26.59
The ShenRay Dome V3 RTA Clone is a 24mm rebuildable tank atomizer made from 316 stainless steel and Ultem PEI. It has 3.5ml of juice capacity. It has single coil build deck and bottom airflow for optimal flavor. POM drip tip included.
Original Sigelei KAOS Vapsoon 208W TC VW Box Mod + KAOS 120 Tank Kit Original Price $64.79, Now Only $52.99
The Original Sigelei KAOS Vapsoon 208W mod kit consists of the Sigelei KAOS Vapsoon 208W TC VW box mod and KAOS 120 sub ohm tank. This item also has other colors to choose.
Mod:
The Original Sigelei KAOS Vapsoon TC VW mod is constructed by a combination of zinc alloy, it features a spin button to adjust the wattage and temperature, the distinguished leather sides and a 1.3inch OLED color screen, thus making it more attractive. It is free of adjustment buttons, instead, utilizing a rotating wheel to select the options similar to luxury car control knobs, this control system integrates the adjustment and fire button together. Powered by dual 18650 batteries (NOT INCLUDED), the KAOS Vapsoon 208W mod can fire up from 10W to 208W maximum output and supports Nickel, Titanium, and multiple stainless steel materials.
Tank:
The included KAOS 120 sub ohm tank is a 24mm tank with 5.5ml e-juice capacity, it features a threaded top filling system and dual bottom adjustable airflow, implementing a hybrid drip tip top cap, and access to the MS Coil Line.
Original Artery PAL 1200mAh AIO All-in-One Starter Kit Original Price $49.30, Now Only $35.49
The Original Artery PAL Starter Kit is thin and portable in your hands. With 3ml liquid capacity and a built-in 1200mAh battery which means you can vape for a really long time. What's more, the Artery PAL kit comes with a unique LQC coil to bring great flavor and decent vapor production, and a new 1.8ohm ceramic coil which is perfect for high nicotine and nicotine salt e-juice. The innovative slide refilling system upgrades the juice filling to a new level. The cover of the PAL is also changeable too (Not Inclueded). This item also has other colors to choose.
Original Perkey Lov Transformable 320mAh 10W Pod System Starter Kit $25.99
The Original Perkey Vapor LOV Transformable Vape Pod System Starter Kit is the first transformable device in the world, which can transform between pen style and loving heart. Powered by built-in 320mAh battery, it comes with a transform structure in the middle of it, you can screw to change the shape. Equipped with 1.6ml e-juice capacity Pod, it offers pure flavor and smooth taste. The V shape tank bottom makes e-liquid could be used up completely. The special air pathway and hidden top airflow can prevent leaking and produce bigger vapor. The Perkey Vapor LOV utilizes built-in constant-output chip and there are multi protections for you option. It may be charged via micro USB cable in a short time. In the bottom of the LOV Kit, there is a hole that can match any accessory you like, and you also can make it as a decoration.
Original Vivismoke Cotton Express Pre-loaded Cotton Wick for RDA / RTA / RDTA $4.99
The Original Vivismoke Cotton Express Pre-loaded Cotton is made of 100% pure cotton. It features tasteless, medical grade, super durable, less waste and peroxide free. It is easy to wick and suitable for all RDA, RTA and RDTA.
Original Artery Replacement LQC Coil for PAL 1200mAh Starter Kit Original Price $9.90, Now Only $6.99
The OriginalArtery LQC Coil is stainless steel coil which features 0.7ohm resistance with an output power from 15W to 25W. It is suitable for Artery PAL 1200mAh Starter Kit.
Original Perkey Replacement Pod Cartridge for Lov Transformable 320mAh Pod System $6.99
The Original Perkey Replacement Pod Cartridge comes with 1.6ohm of resistance and 1.6ml capacity. It is suitable for Perkey Lov transformable 320mAh pod system.
This product comes with 2 PCS in 1 pack.
ShenRay Replacement Top Cap + 510 Drip Tip for Wave BF RDA Clone $3.99
The replacement top cap and 510 drip tip are made from POM and is suitable for ShenRay Wave BF RDA Clone.
Старый 31.10.2018, 04:57 Автор темы   232
3FVAPE
Original Vsticking VK530 200W TC VW Variable Wattage Box Mod Original Price $76.99, Now Only $62.99
The Original Vsticking VK530 Mod is an ergonomic body mod with a visually striking graffiti print. There is a large TFT IPS display on the center that shows vape data in full color, and there has a car dashboard theme that features speedometer style wattage or temperature. Vape data on this display includes indicators for current temperature / power / resistance / voltage / battery indicator bars and more. You may also customize the background of the screen to your liking by uploading 5 to 10 wallpapers which is somewhat unique when it comes to mods. Powered by dual 18650 batteries (NOT INCLUDED) with the YiHi SX530 chip and the SXI-Q control system, the VK530 can fire up to 200W maximum output and supports SS316L, Ni200, Ti01, SX Pure, and Manual TCR Ni. The specification is in Chinese. This item also has other colors to choose.
ShenRay Skull HK Hybrid Mechanical Tube Mod Clone $28.99
The ShenRay Skull HK Mod Clonr is a mechanical tube mod with a diameter of 28.5mm which is constructed from brass. It is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). It comes with spring-loaded fire button.
Do It RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99
The Do It RDA Clone is a 24mm rebuildable dripping atomizer constructed from stainless steel. It has the best bottom air flow, comes with 45 degrees type bottom airflow and will make an unique vape sensation.
810 Replacement Drip Tip for Goon / Kennedy / Reload / Battle RDA $1.99
The replacement 810 drip tip is made from PEI. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Старый 01.11.2018, 04:59 Автор темы   233
3FVAPE
Original Wismec Active 2100mAh 80W TC VW Variable Wattage Box Mod $76.49
The Original Wismec Active can serve as an e-cig device and a speaker, adopting the innovative bluetooth technology. Moreover, the stylish box mod designed to be waterproof and shockproof, the masterpiece is now born and combines with built-in 2100mAh battery and 80W output power. Every detail is meticulously designed and elaborately crafted, whether from the design, the material or the workmanship, youll find it a desirable vaping device. This item also has other colors to choose.
Original GeekVape Aegis Legend 200W TC VW Variable Wattage Box Mod Limited Edition Original Price $75.00, Now Only $59.99
The Original GeekVape Aegis legend 200W TC VW box mod constructed with the new magnesium alloy material, which is currently the world's strongest and lightest metal. It now not only maintains its water, shock and dust resistance, but also lighter than ever. The Aegis legend 200W mod is compatible with dual 18650 batteries (Not Included) and powered by the new AS chipset, it releases up to 200W output. The Aegis Legend uses up to six different materials to achieve style and extreme durability, including stainless steel powder metallurgy, magnesium alloy, die-casting aluminum, 40hrc carbon steel, LSR silicone and leather. This item also has other colors to choose.
ShenRay Comp Lyfe Skull HK Hybrid Mechanical Tube Mod Clone $25.99
The ShenRay Skull HK Mod Clone is a mechanical tube mod with a diameter of 28.5mm which is constructed from brass. It is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). It comes with spring-loaded fire button. This item also has other colors to choose.
ShenRay Juggerknot Mini RTA Rebuildable Tank Atomizer Clone $29.99
The ShenRay Juggerknot Mini RTA is a 24mm rebuildable tank made from 316 Stainless Steel. It has 4.5ml of juice capacity and comes with 2ml glass tube for TPD compliant. It has a single coil deck with new design for more airflow and flavor. The triple channeled airflow hits the coil from top, side and bottom. It comes with random color 810 drip tip. This item also has other colors to choose.
Original VapeCige VTX200 200W TC VW Squonk Box Mod + RDA Kit $113.99
The Original VapeCige VTX200 mod kit consists of VTX200 200W TC VW squonk box mod and an RDA. Powered by DNA250C Chip for dual 18650 batteries (Not Included), it can fire up to a maximun wattage of 200W. It comes with a 7ml squeeze bottle. This item also has other colors to choose.
Original Artery Baton Semi-Mechanical Tube Mod + Hive S Tank Kit Original Price $49.60, Now Only $39.99
The Original Artery Baton kit consists of Baton semi-mechanical tube mod and Hive S sub ohm tank. This item also has other colors to choose.
Mod:
The Original Artery Baton a is a high-performance vape pen semi-mechanical tube mod. Constructed by brass and aluminum alloy, it is durable. Powered by single 18650 / 21700 / 20700 battery (Not Included) with an adaptor, the Artery Baton can bring you a stable vaping experience with several kinds of protections. It is also compatible with many other RDA / RTA.
Tank:
The included Artery Hive S is a 24.5mm sub ohm tank which features a 2ml / 3ml e-juice capacity and top filling design. With the unique mesh coil, it will bring you dense flavor and huge clouds.
Original Wismec Active 2100mAh 80W TC VW Variable Wattage Box Mod + Amor NSE Tank Kit $89.99
The Original Wismec Active 2100mAh 80W kit consists of the Active 2100mAh 80W TC VW box mod and Amor NSE sub ohm tank. This item also has other colors to choose.
Mod:
Tank:
The included Amor NSE is a 25mm sub ohm tank. It comes with 2ml e-liquid capacity (3ml with bubble tank), adjustable airflow and 510 threading connection.
Original GeekVape Aegis Legend 200W TC VW Mod + Alpha Tank kit Limited Edition Original Price $95.00, Now Only $75.99
The Original GeekVape Aegis legend 200W kit consists of the Aegis legend 200W TC VW box mod and Alpha sub ohm tank. This item also has other colors to choose.
Mod:
Tank:
The Original GeekVape Alpha Sub Ohm Tank is a clearomizer with 25mm diameter, 0.15ohm resistance and 4ml capacity. It is the flagship sub ohm tank fully developed by Geekvape Team, it presents unrivaled vaping experience to users with its meticulously made MeshMellow Coil System, which features the purest flavor from the very first inhale. Unlike any other coil of its kind, the MeshMellow coils uses the best cotton to ensure the perfect flavor.
Original Voopoo Replacement Pod Cartridge for VFL Pod System Kit $6.09
The Voopoo Replacement Pod Cartridge is refillable and has 0.8ml of juice capacity. The coil comes with 1.2ohm resistance. It is suitable for Original Voopoo VFL Pod System Kit.
Старый 02.11.2018, 04:49 Автор темы   234
3FVAPE
Original Ehpro Armor Prime Mechanical Tube Mod Original Price $29.90, Now Only $22.99
The Original Ehpro Armor Prime mechanical mod is constructed with high quality brass. It is compatible with single 20700, 18650, or external 21700 battery (Not Included). The Ehpro Armor supports a minimum coil resistance of 0.15ohm. The chipset in Armor Prime provides various protections for a safe vaping too. The LED indicator shows battery life clearly. The Ehpro Armor Prime mechanical mod is definitely an ideal choice for cloud chasers. This item also has other colors to choose.
Original Ehpro Mod 101 Pro 75W TC VW Variable Wattage Tube Mod Original Price $65.90, Now Only $44.79
The Original Ehpro Mod 101 Pro 75W TC VW tube mod is constructed from stainless steel. Powered by single 18650 / 21700 / 20700 battery (Not Included), it can fire up to an output wattage from 5W to 75W. The Ehpro Mod 101 Pro comes with a heat insulator to protect the top of the mod from getting scratched and helps keep the heat away from the atomizer. This item also has other colors to choose.
Original Uwell Crown 4 IV Sub Ohm Tank Clearomizer Original Price $39.99, Now Only $27.99
The Original Uwell Crown 4 IV Tank is constructed by Stainless Steel and Pyrex Glass, it looks durable and gorgeous. With a bubble pyrex glass tube in the package, the tank can hold a 6ml large capacity of e-juice (5ml in the normal tube). The biggest highlight of the Crown 4 is the advanced patented self-cleaning technology, the Uwell Crown 4 can absorb the e-juice in the condensation holder through regular usage and vaporize it. Moreover, the Dual SS904L coil and Double helix mesh coil is available on the tank, which will achieve heating evenly and produce excellent flavor. Besides, with the top filling design and bottom adjustable airflow system, you could enjoy easier refilling method and smooth airflow. This item also has other colors to choose.
Ulton Juggerknot Mini RTA Rebuildable Tank Atomizer Clone $29.90
The Ulton Juggerknot Mini RTA is a 24mm rebuildable tank made from 316 Stainless Steel. It has 4.5ml of juice capacity and comes with 2ml glass tube for TPD compliant. It has a single coil deck with new design for more airflow and flavor. The triple channeled airflow hits the coil from top, side and bottom. It comes with random color 810 drip tip. This item also has other colors to choose.
Original Hugsvape Magician Mesh Sub Ohm Tank Clearomizer Original Price $28.99, Now Only $24.99
The Original Hugsvape Magician Mesh sub ohm tank is constructed from stainless steel, it features 3ml juice capacity (5ml with bubble glass) and 24mm diameter. It adopts 0.15ohm dual mesh coil (65~95W) and 0.13ohm triple mesh coil (85~115W). This item also has other colors to choose.
Original Hugsvape Ring Lord RDA Rebuildable Dripping Atomizer with BF Pin Original Price $34.99, Now Only $24.99
The Original Hugsvape Ring Lord RDA is a 27mm rebuildable atomizer constructed from stainless steel and glass. It comes with single coil configuration, tornado style airflow system, spit-back proof design and adjustable airflow.
Ulton Strange RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.58
The Ulton Strange RDA Clone is a 22mm RDA made from 316 Stainless Steel. You can enjoy tight mouth-to-lung Nic salt vaping, or restricted lung hit vaping for higher VG e-liquid. Optimized for single vertical coil builds, the juice is squonked up through two positions, one above the coil at the top of the positive post, then another through the traditional lower 510 deck pin position. Double juice introduction provides fast and even distribution through your cotton wick.
This RDA comes with bottom feeder pin and 24mm beauty ring.
YFTK Typhoon BTD Wave RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.99
The YFTK Typhoon BTD Wave RDA Clone is a 22mm rebuildable dripping atomizer which is constructed from 316 stainless steel. It features dual post build deck, single coil configuration and adjustable side airflow. Decorative ring is included.
Original Ehpro Mod 101 Pro 75W TC VW Tube Mod + Lock RDA Kit Original Price $86.90, Now Only $56.99
The Original Ehpro Mod 101 Pro 75W kit consists of the Ehpro Mod 101 Pro 75W TC VW tube mod and Ehpro Lock RDA. This item also has other colors to choose.
Mod:
RDA:
This RDA comes with a bottom feeder pin.
Original Uwell Replacement Dual SS904L Coil for Crown 4 IV Sub Ohm Tank Clearomizer $10.99
The Original Uwell Crown 4 Replacement Dual SS904L Coil 0.2ohm features better flavor, longer life with the higher quality steel commonly used in luxury watches. It will bring you great flavor on your Uwell Crown IV Tank.
This product comes with 4 PCS in 1 pack. This item also has other Version to choose.
Старый 05.11.2018, 05:04 Автор темы   235
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Rincoe Manto S 228W TC VW Variable Wattage Box Mod $27.99
The Original Rincoe Manto S 228W is constructed from PC. Powered by dual 18650 batteries (Not Included), it can reach up to an output wattage from 1W to 228W output. Five multiple protections and 2A quick charging system bring you safe and wonderful experience. The Manto S supports 4 modes: Ni200 / Ti / SS and TCR. This item also has other colors to choose.
Original SMOKTech SMOK Mag Grip 100W TC VW Variable Wattage Mod $49.29
The SMOK Mag Grip mod features a handheld mod, exquisite fire key, and magazine release. It has a good hand feeling, its grooves on the upper part of the mod are optimized to maximize the practicability that makes the mod more comfortable to grip and hold. The Mag Grip also adopts the exquisite small fire key, like the trigger of a gun, and you can press the triggering button easily. But the display screen has been designed differently, a 0.66inch OLED screen with high definition is close to the 510 plate, providing a more convenient viewing angle for the user, which is indeed an ergonomic handling. The Mag Grip mod is powered by single 21700 / 20700 and 18650 battery (NOT INCLUDED), when using the 20700 and 21700 battery, the Mag Grip mod can fire up to 100W maximum output (85W max with 18650 battery). This item also has other colors to choose.
Kennedy Vindicator Hybrid Mechanical Tube Mod Clone $14.59
The Kennedy Vindicator Mechanical Mod Clone is a hybrid mech mod made from brass. It comes with 25mm hybrid connector. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED), it features 510 threading connection and spring-loaded fire button. The button and battery connector are made from copper. This item also has other colors to choose.
Vapeasy Bestia MiniB Mechanical Tube Mod Limited Edition Clone $25.99
The Vapeasy Bestia Mini B Mod Limited Edition Clone is the smallest 18650 mech mod. It is constructed from brass, with hybrid connection and side fire button. The mod is powered by only single 18650 battery (NOT INCLUDED). It features full engraved tube. This item also has other colors to choose.
Original Cthulhu Mjölnir Mjolnir RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.99, Now Only $27.59
The Original Cthulhu Mjolnir RDA is a very interesting 24mm diameter RDA. The unique double chamber system makes it dissipates heat and vape like a 20 mm RDA, and it has the innovative wide open, bottom airflow, from both sides, two asymmetrical side air flow optimize turbulence to get better flavor, which is made for DL vaping and restrictive DL vaping. The massive juice well (approximately 1.8ml) provides plenty of extra room for e-juice, so you don't have to drip very often. You can drip right down the middle onto the coil and the excess juice will pass through the airflow and into the juice well without leaking.
Original Ambition Mods Spiral MTL RDA Rebuildable Dripping Atomizer Original Price $30.99, Now Only $22.99
The Original Ambition Mods Spiral MTL RDA is a 18mm rebuildable dripping atomizer which is constructed from 316 stainless steel. It features dual post build deck, single coil configuration and adjustable bottom airflow. This item also has other colors to choose.
Kennedy Vindicator Hybrid Mechanical Mod Clone + Kennedy 25 RDA Kit Clone $22.99
The Kennedy Vindicator Mech Kit Clone consists of Kennedy Vindicator Mechanical Mod Clone and Kennedy 25 RDA Clone. This item also has other colors to choose.
Mod:
RDA:
The Kennedy 25 RDA Clone is made from brass with 25mm diameter. The RDA comes with dual post build deck, bottom airflow and low profile PEI drip tip. It fits the Vindicator Mechanical Mod Clone very well.
Original Vapethink Magic Shark 3M Wrapper Smart Skin Sticker for Juul $1.59
The Original Vapethink Magic Shark Smart Skin Sticker is used for Juul, made from 3M material. It is designed as 2.5D stereoscopic cover film, which looks more vivid, and you can feel concave-convex when touch it. This item also has other Version to choose.
Original Hugsvape Kanthal Single Ceramic Mesh Coil for Magician Sub Ohm Tank Original Price $11.99, Now Only $7.99
The Original replacement Kanthal Single Ceramic Mesh coil head features 0.3ohm resistance and works well at 50W to 80W. It is suitable for Hugsvape Magician sub ohm tank.
This product comes with 3 PCS in 1 pack. This item also has other colors to choose.
Старый 06.11.2018, 04:45 Автор темы   236
3FVAPE
Original Vandy Vape Berserker V1.5 MTL RTA Rebuildable Tank Atomizer Original Price $39.00, Now Only $28.39
The Original Vandy Vape Berserker V1.5 MTL RTA is a 24mm rebuildable tank atomizer with 2.5ml juice capacity. It comes with two appearances and two drip tips, top filling system and adjustable slot airflow. The 5 different sized holes (1.0 / 1.2 / 1.4 / 1.6 / 1. gives a simply possibility of a real cigarette tightening. This item also has other colors to choose.
YFTK Doggystyle V2 RTA Rebuildable Tank Atomizer Clone $20.59
The YFTK Doggystyle V2 RTA Clone is constructed from 316 stainless steel with pc tank tube and POM drip tip. It comes with single coil build deck, adjustable bottom airflow and 510 threading connection.
Original Vapesoon VSA 1000mAh Pod System Starter Kit Original Price $26.99, Now Only $19.99
The Original Vapesoon VSA 1000mAh pod system is constructed from silicone, stainless steel and plastic, it features 1.2ohm resistance and 2ml liquid capacity. Powered by a 1000mAh built-in battery, it comes with Air-driven system, multiple protections and ergonomically designed mouthpiece.
Original Vapethink Magic Shark 3M Wrapper Smart Skin Sticker for Juul $0.99
510 Heat Dissipation Insulator Heat Sink for RDA / RTA / Sub Ohm Tank Atomizer $1.99
This heat dissipation insulator is made from stainless steel with copper pin. It is installed between mod and atomizer to insulate heat between mod and atomizer, and it can be a decorative ring for your device.
Cannabis Marijuana Weed Tobacco Dry Herb Cigarette Roller Box $4.99
The Cigarette Roller Box is made from SPTE and can help you roll your own cigarette with Tobacco, Dry Herb or Weed easily. It is used with 70mm width cigarette paper. This tool is durable and convenient. This item also has other colors to choose.
3FVAPE вне форума   Вверх
Старый 07.11.2018, 04:52 Автор темы   237
3FVAPE
Original RFGVape 2+1 RDA Rebuildable Dripping Atomizer with BF Pin Flavor Puzzle Kit Original Price $63.50, Now Only $54.99
The Original RFGVape Flavor Puzzle Kit consists of RFGVape 2 + 1 RDA, Bottle Refill Cover, tools, coils and mesh and other useful accessories. The authentic RFGVape 2+1 RDA is a 24.8mm rebuildable dripping atomizer which is constructed from stainless steel and resin. The build deck is gold plated and comes with dual post design. It features 510 threading connection and adjustable airflow. Both stainless steel cap and resin cap are included.
Original RFGVape 2+1 RDA Rebuildable Dripping Atomizer with BF Pin Original Price $35.50, Now Only $26.99
The RFGVape 2+1 RDA is a 24.8mm rebuildable dripping atomizer which is constructed from stainless steel and resin. The build deck is gold plated and comes with dual post design. It features 510 threading connection and adjustable airflow. Both stainless steel cap and resin cap are included.
Original Lost Vape Orion DNA GO 40W 950mAh All-in-one Starter Kit Original Price $79.00, Now Only $64.99
The Lost Vape Orion DNA GO Kit is the first pod system to utilize a DNA board. The Orion DNA GO not only features safety protections, high efficiency, reliability and durability, but also has highly reputable and precise craftsmanship. The Orion DNA GO features three power output modes and adjustable airflow control to configure your settings for a satisfying mouth-to-lung or direct-lung vape. Once you've found your perfect setting, Replay mode can be activated by simply holding down the adjustment button until the LED indicator turns green. Replay mode is a groundbreaking feature that saves your settings and provides the same level of performance and consistency on all subsequent puffs while preventing dry hits for a truly remarkable vape experience. This item also has other colors to choose.
Старый 08.11.2018, 05:06 Автор темы   238
3FVAPE
Original Rincoe Manto X Mesh 228W TC VW Variable Wattage Box Mod $35.59
The Original Rincoe Manto X Mesh 228W TC VW mod is constructed from zinc alloy. Powered by dual 18650 batteries (Not Included), it can reach up to an output wattage from 1W to 228W. This item also has other colors to choose.
ShenRay TF Scarab Pro Max Mechanical Tube Mod Clone $39.99
The ShenRay TF Scarab Pro Max Mechanical Tube Mod Clone is constructed from stainless steel and powered by single 21700 battery (Not Included). It comes with Electronic key lock for short-term deactivation button, high-performance MosFet (power amplifier) with 0.001ohm switching resistance during operation, temperature sensor for MosFet that uses EXTREME current protection equipment during continuous operation.
Coppervape Hussar Project X RTA Rebuildable Tank Atomizer Clone $25.59
The Coppervape Hussar Project X RTA Clone is a 22mm rebuildable tank atomizer constructed from 316 stainless steel. It comes with 2ml juice capacity and Ultem PEI tank. It comes with adjustable bottom airflow and the airflow size is 3 x 1.5mm each side. The tank also has juice control function.
Original Rincoe Manto Mini 90W VW Box Mod + Metis RDA Kit $22.89
The Original Manto Mini 90W kit consists of the Rincoe Manto Mini 90W VW box mod and Metis RDA. This item also has other colors to choose.
Mod:
The Original Rincoe Manto Mini 90W VW box mod is constructed from PC material, which is more stable with the anti-shock function. Powered by single 18650 battery (Not Included), it can reach up to an output wattage from 1W to 90W, which is powerful enough to meet your various demands. Water transfer painting makes the device more classic and comfortable in hand.
RDA:
The Rincoe Metis RDA is a 24mm rebuildable dripping atomizer, it comes with a wide bore 810 drip tip and a simple deck which is easy to build and wick, brings dense flavor as well.
Original Rincoe Manto X Mesh 228W TC VW Box Mod + Metis Mix Tank Kit $44.99
The Rincoe Manto X Mesh 228W kit consists of the Original Rincoe Manto X Mesh 228W TC VW box mod and the Metis Mix sub ohm tank. This item also has other colors to choose.
Mod:
Tank:
The Original Rincoe Metis Mix sub ohm tank is a 25mm Clearomizer, it comes with 6ml juice capacity and four varieties of Metis Mix coils which is optimized for high nicotine satisfaction, bringing purer flavor and lasts longer.
Original Oukitel Nano 400mAh Pod System Starter Kit $25.89
The Original Oukitel Nano Pod kit is an abnormal beautiful pod system kit with a 3D mirror surface and gradient colors, whose application is very successful on the latest phone's battery cover, just like a cobblestone when you hold in hand. With the magnetic cartridges, you can switch the cartridge faster and easier, and of course, the cartridge is refillable, which has 2ml e-juice and 1.6ohm resistance. Powered by a built-in 400mAh battery, the Nano kit also features a colorful LED indicator to show the different lights according to the different working status. This item also has other colors to choose.
The Original Vapethink Magic Shark Smart Skin Sticker is used for Juul, made from 3M material. It is designed as 2.5D stereoscopic cover film, which looks more vivid, and you can feel concave-convex when touch it. This item also has other colors to choose.
Quick Charging Base Dock USB Charger for Juul $10.99
The quick charging dock is designed for Juul device. It has two rapid safety quick charge pin and light indicator to show the charging status. You can use it in your office or your car. This item also has other colors to choose.
Original Vapesoon Replacement Pod Cartridge for VSA Pod System Kit Original Price $8.99, Now Only $5.99
The Vapesoon VSA Replacement Pod Cartridge is refillable and has 2ml of juice capacity. The coil comes with 1.2ohm resistance. It is suitable for Original Vapesoon VSA Pod System Kit.
Original Vapefly Firebolt Mixed Edition Pre-loaded Cotton for E-cigarette Original Price $7.99, Now Only $4.49
The Original Vapefly Firebolt Cotton Mixed Edition utilizes pure organic cotton. The pre-loaded cotton is very easy to wick. This cotton provides more capacity and clean pure flavor. The Mixed Edition provides three types of cotton for 2.5mm / 3.0mm / 3.5mm coils.
This product comes with 21 x Pre-loaded cotton.
Original Oukitel Replacement Pod Cartridge for Nano 400mAh Pod System Starter Kit $9.99
The Original Oukitel pod cartridge is for Nano 400mAh pod system. It comes with a resistance of 1.6ohm and its refillable 2ml pod allows you to easily refill e-liquids.
Coppervape Replacement 510 Drip Tip for Hussar Project X RTA Clone $1.99
The Coppervape replacement 510 drip tip is made from PEI and 316 stainless steel, it is suitable for Hussar Project X RTA Clone and other atomizers that fit 510 drip tip.
Coppervape Replacement Tank Tube for Hussar Project X RTA Clone $2.99
The Coppervape replacement tank tube is made from PEI with 2ml juice capacity. It is suitable for Coppervape Hussar Project X RTA Clone.
Старый 09.11.2018, 05:11 Автор темы   239
3FVAPE
Kindbright VG Mini V2.5 Stacked Mechanical Tube Mod Clone $26.99
The Kindbright VG Mini V2.5 mechanical tube mod Clone is constructed from 316 stainless steel which is powered by dual 18350 or single 18650 batteries (Not Included). It comes with adjustable silver plated contacts, bottom vent holes and side mounted spring-loaded firing button (anti-clockwise twisty locking ring).
Original StageVape Armor RTA Rebuildable Tank Atomizer Original Price $32.99, Now Only $22.99
The Original Stage Vape Armor RTA is a 25mm rebuildable tank atomizer which is constructed from stainless steel. It comes with 3ml juice capacity, postless deck design for easy building and AFC redirect down to the cotton for better flavor. This item also has other colors to choose.
Original Vandy Vape Bonza V1.5 RDA Rebuildable Dripping Atomizer with BF Pin Original Price $31.99, Now Only $24.09
The Original Vandy Vape Bonza V1.5 RDA is a 24mm rebuildable dripping atomizer. It comes with 9mm deep juice well, 18mm Delrin drip tip, new dual AFC options, and top cap locking system.
SXK Doggystyle V2 2K18 RTA Rebuildable Tank Atomizer Clone Original Price $15.90, Now Only $12.99
The SXK Doggystyle 2K18 RTA Clone is a 22mm rebuildable tank atomizer constructed from 316 stainless steel with PC tank tube and POM drip tip. The tank has 3.5ml of juice capacity. It comes with single coil build deck, adjustable bottom airflow and 510 threading connection.
SOB OG Parallel Hybrid Mechanical Box Mod Clone + Outlaw RDA Kit Clone $20.99
The SOB OG Parallel Mech Kit Clone consists of SOB Parallel Mech mod Clone and Outlaw RDA Clone. This item also has other colors to choose.
Mod:
The SOB OG Parallel Mechanical box mod Clone is constructed from stainless steel and POM and is powered by dual 18650 batteries in parallel (NOT INCLUDED). The battery access door is easy to remove by hand. The venting holes are positioned at the access door. The logo and series number are on the mod.
RDA:
Original ECT Master 650mAh VV Vaporizer + CBD Atomizer Kit $13.49
The Original ECT Master CBD Kit consists of ECT Master 650mAh Vaporizer and ECT CBD Atomizer. This item also has other colors to choose.
Mod:
The Original ECT Master 650mAh Battery Vaporizer is a tiny device that designed for CBD Atomizer. It comes with three different voltage value for vaping, which are 3.3V, 3.6V and 3.6V.
CBD Atomizer:
The ECT CBD Atomizer comes with 0.5ml of juice capacity and a resistance of 1.5~2.0ohm. It is great for Cannabis / Marijuana / CBD oil vaping.
Original ECT Mico 350mAh VV Vaporizer + CBD Atomizer Kit $10.19
The Original ECT Mico CBD Kit consists of ECT Mico 350mAh Vaporizer and ECT CBD Atomizer. This item also has other colors to choose.
Mod:
The Original ECT Mico 350mAh Battery Vaporizer is a tiny device that designed for CBD Atomizer. It comes with three different voltage value for vaping, which are 3.3V, 3.6V and 3.6V.
CBD Atomizer:
Original Vandy Vape Bonza Hybrid Mechanical Tube Mod + V1.5 RDA Kit Original Price $73.99, Now Only $52.19
The Original Vandy Vape Bonza kit consists of the Vandy Vape Bonza hybrid mechanical tube mod and Vandy Vape Bonza V1.5 rebuildable dripping atomizer. This item also has other colors to choose.
Mod:
The Original Vandy Vape Bonza hybrid mechanical tube mod is powered by 1 x 18650 / 20700 / 21700 battery (Not Included), it comes with pure copper conducts electricity and Voltage drop contacts to reduce internal loss, interchangeable sleeve system for customization and logo alignment, and magnetic switch with spring option included.
Besides, each mech mod has an individually number.
RDA:
Original Lost Vape Replacement Pod Cartridge for Orion DNA GO Starter Kit $10.99
The Original Lost Vape Replacement Pod Cartridge comes with 0.5ohm of resistance and 2ml capacity. It is suitable for Lost Vape Orion DNA GO 40W 950mAh All-in-one Starter Kit.
Original ECT Master 650mAh VV CBD Vaporizer $10.89
The Original ECT Master 650mAh Battery Vaporizer is a tiny device that designed for CBD Atomizer. It comes with three different voltage value for vaping, which are 3.3V, 3.6V and 3.6V. It is great for Cannabis / Marijuana / CBD oil vaping. This item also has other colors to choose.
Original ECT Mico 350mAh VV CBD Vaporizer $8.89
The Original ECT Mico 350mAh Battery Vaporizer is a tiny device that designed for CBD Atomizer. It comes with three different voltage value for vaping, which are 3.3V, 3.6V and 3.6V. It is great for Cannabis / Marijuana / CBD oil vaping. This item also has other colors to choose.
Старый 12.11.2018, 04:44 Автор темы   240
3FVAPE
Original Squid Industries Double Barrel V3 VW Variable Wattage Box Mod Original Price $95.00, Now Only $70.99
The Original Squid Industries Double Barrel V3 is a new version of Double Barrel box mod. More detail is coming soon. This item also has other colors to choose.
Original CoilART MAGE RTA 2019 Rebuildable Tank Atomizer Original Price $39.99, Now Only $31.99
The Original CoilArt Mage Resin RTA 2019 is a 28mm rebuildable tank atomizer, it is constructed from resin stainless steel with glass tank, it features 4.5ml juice capacity and dual coil post-less build deck. The Mage Resin RTA 2019 has 20 pieces of the 1.4mm diameter honey comb air holes, which will bring you delicate flavor and intense throat hit. This item also has other colors to choose.
Coppervape Royal Atty DB RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $12.99, Now Only $9.99
The Coppervape Royal Atty DB RDA Clone is a 22mm rebuildable atomizer, it stands out from each other dual / single coil atomizers, increasing the aromatic yield of your favorite e-liquid. Taking of the chamber, the deck transforms itself in a real cloud deck, having the possibility to host more extreme builds. It comes with a PEEK insert for single coil build.
Original Innokin Cool Fire II VW Variable Wattage Mod Kit Original Price $36.99, Now Only $18.99
The Original Innokin Cool Fire II VW Mod Kit consists of the Cool Fire II variable wattage mod and the iClear 30s sub ohm tank. Scale display wattage improves intuitive control and provides more accurate performance. Adjusted with the rotational wheel to 7.0W, 8.0W, 8.5W, 9.0W, 9.5W, 10.5W, 11.0W, 12.0W, and 12.5W. It also comes with battery power indicator (green for fully power, yellow for medium power, red for low power). This item also has other colors to choose.
Original Starss ICON Vape 380mAh Pod System Starter Kit $23.39
The Original Starss ICON Vape Pod System Starter Kit is the brand new vape pod kit constructed from Zinc Alloy and food grade PC material, which has fully metallic screen with comfortable hand feeling. It is powered by large 380mAh built-in battery, and supports large 2ml e-juice capacity which satisfies your daily needed. The Starss ICON is designed as a motorcycle wheel while the drip tip is ergonomic offering you great vaping experience. To be different from other vape pods, the Starss ICON Pod System Starter Kit integrates DL (Direct to Lung) flavor and MTL (Month to Lung) flavor. This item also has other colors to choose.
Original Innokin iTaste SVD Variable Voltage / Wattage Starter Kit with 2 x iClear30 Atomizers Original Price $40.99, Now Only $20.99
The iTaste SVD (Superior Vaping Device) is a tube style, variable voltage, variable wattage advanced personal vaporizer ,which is made of Stainless Steel. The iTaste SVD is sleek, with easy to use functionality.
The Smart Skin Sticker is used for Juul, made from 3M material. It is designed as 2.5D stereoscopic cover film, which looks more vivid, and you can feel concave-convex when touch it. This item also has other colors to choose.
810 Drip Tip for 528 Goon / Kennedy / Reload RDA $1.99
The 810 drip tip is made from resin with 8.4mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA. This item also has other colors to choose.
Coppervape Replacement Top Cap for Royal Atty DB RDA Clone $2.99
The Coppervape Replacement Top Cap is made from POM. The outer diameter is 22mm. It is suitable for Coppervape Royal Atty DB RDA Clone.
This top cap is for single coil build. This item also has other colors to choose.
Original Ehpro ATL / SUB / DEL Adaptors Kit for Eciggity Morph Tank Atomizer Original Price $9.99, Now Only $4.99
The Original Ehpro ATL / SUB / DEL Adaptors Kit is used for Ehpro Eciggity Morph Tank. The Original Morph Tank is both an RTA and a Sub Ohm Tank, which was created through a collaboration with EHPRO and Eciggity. What makes the Morph different in the sub ohm tank market is its compatibility with many different types of sub ohm coils with the use of adaptors. You don't have to buy more sub ohm tanks, you can simply put an adaptor for the coil you want to use into the Morph Tank.
Время генерации страницы 0.62010 секунды с 15 запросами
