66639
210
201
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Vandy Vape SS316L Superfine MTL Fused Clapton Heating Resistance Wire Original Price $6.99, Now Only $4.99.
The Original Vandy Vape Superfine MTL Fused Clapton Wire heating resistance wire is perfect for RBA / RTA / RDA atomizers. The wire is made from SS316L stainless steel. It features 32GA x 2 + 38GA gauge and 3.88ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Aspire Kumo RDTA Rebuildable Dripping Tank Vape Atomizer Original Price $59.99, Now Only $49.99. Original Aspire Kumo RDTA is jointly created by Aspire and Steampipes, dedicated to exploring groundbreaking high-end RDTA technology. Kumo RDTA is supplying the ultimate vaping experience to DTL users. Featuring the Capillary System E-liquid Conduction Technology patented by Steampipes and the imaginative design by Aspire, the Kumo is the first RDTA atomizer of the Aspire Brand. It is another founder Aspire that provides a unique appearance design, precision machining technology and sandblasting craft make Kumo RDTA upscale and fashionable. Kumo RDTA has four adjustable air inlets, 3.5/2ml capacity, and uses a side filling method to add E-juice. All in all, according to its patented process and aesthetically pleasing appearance, this Kumo RDTA has both beauty and practicality. ![]() Original Aspire Boxx AIO VW Vape Box Mod Kit Original Price $129.99, Now Only $104.99. Original Aspire BOXX Vape Mod Kit has been partner designed alongside Sunbox and Atmizoo. It features the design language of the famous MIXX mod design, such as rich metallic and CNC processed. BOXX is powered by a replaceable single 18650 battery (not included) with 1~60W wattage range, supports VW / VV / Bypass mode. You will enjoy MTL / RDTL / DTL vaping style with various coil options.The ASP chipset comes with the overall protection to ensure safe use.
202
Original BP Mods Futon Ohm Tab Basic Edition Original Price $39.99, Now Only $29.99.
The Futon Ohm Tab is a V/W adjustable coil tab which may bring you a brand new experience that you've never found on any other coil tabs. The Futon Ohm Tab has a side fire button which is pleasing to press with your left index finger. Mode select button, +/- buttons, screen and 510 port are on the top and an 1A current input type-C USB interface is on one side. The back trunk is also available on this basic edition, so same as the luxury edition, it's not just a coil tab, but also a tool kit and an 18650 charger. ![]() Original Aspire Favostix Pod System Vape Kit Original Price $39.99, Now Only $27.99. Original Aspire Favostix Pod System Vape Kit is constructed of aluminum alloy oxidation and combines elegant and slender designs with innovative brand-new coil technology. It comes out to offer a superior flavor and a comfortable throat hit, and aims to let you experience the colorful, flavorful and powerful vaping. Powered by 1000mAh built-in battery, it features adjustable power from 1W to 30W and Type-C fast charging port. And you can obtain clear details via a 0.42-inch OLED screen. Plus, it can be activated by auto draw and fire button. ![]() Original Aspire Cloudflask S Pod System Vape Mod Kit Original Price $49.99, Now Only $38.99. The Original Aspire Cloudflask S Pod System Vape Kit comes with incredible value, massive cloud actions and is ready for HUGE performance. It is ergonomic and ruggedly durable with premium grade aluminum material. Cloudflask S not only adopts a 0.25ohm Cloudflask mesh coil for DTL vaping, but also supports an all-new 0.6ohm mesh coil for restricted DTL. You can enjoy amazing vaping experience when the unique double-side air inlets work with Bypass output. The Standard Version is not contains leather case. Cloudflask Pod cartridge is a bottom-filling pod cartridge of 5.5ml. Cloudflask S is built with 2000mAh battery and 2A type-c quick charging port. ![]() Original Aspire Cloudflask S Replacement Empty Pod Cartridge Original Price $7.99, Now Only $4.99. The Cloudflask S Pod Cartridge is designed for Aspire Cloudflask S Pod Sysetm Vape Kit. It is an empty pod of 5.5ml e-juice capacity. It is compatible with Cloudflask mesh coil 0.25ohm / 0.6ohm (not included). Bottom filling design makes refilling easy and convenient.
203
Luca creations 4C Tank MTL RTA Clone Rebuildable Vape Atomizer Original Price $22.99, Now Only $14.99.
The Luca creation 4C Tank Clone MTL RTA Rebuildable Vape Atomizer is made from stainless steel in 22mm diameter and PEI tank tube holds 3ml capacity. The 4C Tank Clone MTL RTA is with bottom airflow (1mm / 1,2mm / 1,7mm). ![]() Original Auguse Era Billet Adapter for Billet Box Mod - Style B Original Price $15.98, Now Only $13.99. The Original Auguse Era Billet Adapter is made from stainless steel and suitable for Billet Box Mod. With the Auguse Era Billet Adapter, you can use the DotMod AIO RBA Tank on Billet Box Mod. The adapter frame only. The DotMod AIO RBA Tank and Billet Box Mod is not included. ![]() Original Auguse Era Billet Adapter for Billet Box Mod - Style A Original Price $15.98, Now Only $13.99. The Original Auguse Era Billet Adapter is made from stainless steel and suitable for Billet Box Mod. With the Auguse Era Billet Adapter, you can use the DotMod AIO RBA Tank on Billet Box Mod.The adapter frame only. The DotMod AIO RBA Tank and Billet Box Mod is not included.
204
Original Voopoo Drag X PnP-X Kit 80W 1 x 18650 Mod Kit Original Price $59.99, Now Only $38.99.
Original Voopoo Drag X PnP-X Kit must be soared in popularity to be a salute to the knight. Meticulously engineered, it holds a 5ml magnetic suction pod couple with two PnP coils of 0.15ohm and 0.3ohm inside. It inspires to vape for infinite airflow to vaporize to the luscious clouds that it has to offer. Drag X Pnp-X is also furnished with a special knob-filling on the top, press the semi-hidden button and rotate to the left, and then put out the silicone plug to fill, this design can stem the e-liquid and have a clean hand when vaping. ![]() Original Voopoo Drag S PNP-X Pod Tank Kit 60W 2500mAh Mod Kit Original Price $59.99, Now Only $39.99. Original Voopoo Drag S PNP-X Kit has both an Original and heroic spirit, which likes a knight with a sword in his hand, ready to fight for glory and his girl, taking you back in Arthurian Europe, as a knight of the Round Table. With its leather and metal material, the knight product perfectly fits the curvature of your fingers. The PnP-X pod can cater to 5ml vape juice, it is equipped with a semi-hidden button with a special knob-filling on the top, press the semi-hidden button and rotate to the left, and then put out the silicone plug to fill. Customizing your cloud via its infinite airflow valve and based on its 0.1~3.0ohm PnP coils, the sought-after flavor upgrades to a high level. ![]() 4.0ml Replacement Top Filling Tank Tube Kit for Typhoon Taifun GT One RTA Clone Original Price $9.99, Now Only $6.99. The Replacement Top Filling Tank Tube Kit included tank tube and chimney and is suitable for Typhoon Taifun GT One Clone RTA. The tank tube holds 4.0ml capacity. ![]() 2.0ml Replacement Top Filling Tank Tube Kit for Typhoon Taifun GT One RTA Clone Original Price $9.99, Now Only $6.99. The Replacement Top Filling Tank Tube Kit included tank tube and chimney and is suitable for Typhoon Taifun GT One Clone RTA. The tank tube holds 2.0ml capacity.
205
ULTON DOTSHELL Replacement Tank RBA Clone w/ 3 MTL Pin for dotAIO Original Price $39.99, Now Only $28.95.
The ULTON DOTSHELL clone Rebuildable Replacement Tank includes a PCTG Replacement Tank, and 3 MTL Pins (Hole Sizes: 1.0mm, 1.2mm, 1.5mm + / - 0.1mm tolerance). They are suitable for dotAIO Portable AIO Pod System Vape Kit as replacement parts. ![]() Original GeekVape Obelisk 65 FC Pod System Vape Mod Kit Original Price $63.99, Now Only $51.99. The original GeekVape Obelisk 65 FC Pod System Vape Mod Kit is the first pod mod with fast charging, it can be fully charged within 18 mins. GeekVape Obelisk 65 FC Kit features TUV-tested battery: 2 x 1100mAh built-in battery with max 65W output. Obelisk 65 FC supports Chip-triggered Smart / Power / TC-SS / TCR / VPC / Bypass / OTG modes to meet different needs. GeekVape Obelisk 65 FC is paired with 4.5ml clear pod, easy to top filling design and top airflow adjustment.
206
Original GeekVape Obelisk 65 Pod Kit Original Price $49.99, Now Only $39.99.
Original GeekVape Obelisk 65 Pod System Vape Mod Kit, palm-fit tech-chic, is powered by 2500mAh built-in battery to support 2-day-use and can fire up to 65W output. Obelisk 65 supports Chip-triggered Smart / Power / TC-SS / TC-TCR / VPC/ Bypass modes to meet different needs. GeekVape Obelisk 65 is paired with 4.5ml clear pod cartridge, easy to top filling design and top airflow adjustment. ![]() Original Vapefly Manners II Pod Kit Original Price $19.9, Now Only $14.99. Original Vapefly Manners 2 Pod System Vape Kit is a minimalist button-free pod system kit with 3 power levels (12W / 10W / 8W). It is built with 850mAh battery capacity and type-c fast charging port to provide a long lasting vaping. The pod cartridge of 2ml e-juice capacity is designed with ergonomic mouthpiece to make it more comfortable and natural when vaping. In addition, Vapefly Manners II Pod Kit adopts FreeCore J-1 1.0ohm coil and FreeCore J-2 1.4ohm coil that feature high-quality organic cotton, optimized mesh micro-honeycomb structure. And the FreeCore J-2 1.4ohm Coil will provide you great MTL vaping experience. ![]() Original Vapefly Manners II Pod Replacement FreeCore Coil Original Price $14.99, Now Only $8.99. Original Vapefly Manners 2 J-2 1.4ohm Coil & Vapefly Manners 2 J-1 1.0ohm Coil are designed for Vapefly Manners 2 Kit and Pod Cartridge. It also features high-quality organic cotton and optimized mesh micro-honeycomb structure.5 PCS / each pack. ![]() Original Vapefly Manners II Replacement Pod Cartridge Original Price $4.99, Now Only $2.99. Original Vapefly Manners II 2 Replacement Pod Cartridge is created for Vapefly Manners II 2 Pod Kit. It can be filled with 2ml e-juice. Compatible with FreeCore J-1 1.0ohm coil and FreeCore J-2 1.4ohm coil (coil not included), it will bring you great vaping.
207
Original GAS Mods Kree V2 RTA 22mm Rebuildable Tank Atomizer Original Price $35, Now Only $29.99.
The Original GAS Mods Kree V2 RTA Rebuildable Tank Vape Atomizer is in 22mm diameter. Compared to the old version, some features has been undated on Kree V2 RTA. The oil hole can be closed when you refill to prevent leaking. And there is no need to empty the juice before replace the coil. ![]() Original Vandyvape Pulse 80W AIO Kit - 5~80W, 1 x 18650 / 20700 / 21700 Original Price $89.99, Now Only $69.99. The Original Vandyvape Pulse 80W VW AIO Kit supports wattage adjustable from 5W to 80W and is powered by 1 x 18650 / 20700 / 21700 battery (not included). The Vandyvape Pulse 80W VW AIO Kit comes with dual pod cartridge: 3.7ml RBA Pod cartridge and 5ml Pod Cartridge. The Boro is compatible and tanks work in most Boro style mods. ![]() Original Augvape Druga S RDA Single Coil 22mm BF Rebuildable Dripping Atomizer Original Price $29.99, Now Only $20.99. The Original Augvape Druga S RDA Rebuildable Dripping Vape Atomizer is constructed from stainless steel in 22mm diameter. The Augvape Druga S RDA is low profile RDA comes with BF Pin. The Augvape Druga S RDA is with single coil deck and adjustable airflow. ![]() Original Steam Crave Aromamizer Classic MTL RTA 23mm Original Price $36.9, Now Only $29.99. Original Steam Crave Aromamizer Classic MTL RTA Vape atomizer comes with 23mm diameter and 3.5ml capacity with top filling design. Steam Crave Aromamizer Classic RTA features adjustable side airflow with customizable air pins to offer optimized MTL or RDL vaping which is a Full flavor engine and delivers excellent flavor, especially for MTL and RDL vapors.3.5ml rebuildable tank with single coil deck, very simple to build on. Top refilling makes it easy to refill the e-liquid. Side airflow is adjustable with customizable air pins. Various choices of airflow makes it amazing for both Mouth-to-Lung and Restricted Direct to Lung vaping. Aromamizer Classic RTA adopts single coil deck, easy to build. Steam Crave Aromamizer Classic matches with Mini Robot tube, Hadron Lite mod and Hadron mini mod perfectly. ![]() Original Uwell Caliburn G2 Pod Kit 750mAh Original Price $44.99, Now Only $29.99. Original Uwell Caliburn G2 Pod System Vape Kit is a continuation and upgrade of the generation, and gains a well-known reputation from Caliburn G Kit. Here is it and must satisfy all you pod system kit enthusiasts better than ever. First and foremost, it adopts Pro-FOCS technology to focus on its ultimate taste for the rich vapor, sustaining the last drop of the e-liquid. It is available for 2ml vape juice and is convenient to fill your e-juice via a top filling system, which decreases the leakproofness and saves your time. Caliburn G2 is also equipped with a liquid check window to remind you of filling your e-liquid when it is running out. ![]() Original Steam Crave Hadron Lite 100W SBS Box Mod 1 x 18650 / 20700 / 21700 Original Price $59.9, Now Only $45.99. Original Steam Crave Hadron Lite SBS Mod is powered by single 18650 / 20700 / 21700 battery (not included) with adjustable wattage of 5~100W. Equipped with 0.69 inch OLED screen, Hadron Lite MOD can show vaping data clearly. Steam Crave Hadron Lite is compatible with tanks of up to 25mm diameters. made of Zinc alloy, is a side-by-side mod with elegant and ergonomic design. Steam Crave Hadron Lite Mod offers the steamer a VW and bypass mode, as well as TC mode for Ni, Ti and SS. Lt is high-performance chipset ensures top performance and efficient power management and has extensive security features on board. The great mod can accommodate vaporizers up to a diameter of 25mm on its 510 connection. ![]() Original Steam Crave Hadron Lite Advanced Combo Kit with Hadron Lite SBS Box Mod + Aromamizer Supreme V3 RDTA Original Price $109.9, Now Only $79.99. Original Steam Crave Hadron Lite Advanced Combo Kit consisting of Hadron Lite Mod and Aromamizer Supreme V3 Advanced RDTA.Mod with space-saving and ergonomic side-by-side construction. Vaporizer with lots of accessories and additional deck. The Hadron Lite Mod by Steam Crave immediately catches the eye due to its unusual construction as well as its elegant appearance. The engineers at Steam Crave have revived the side-by-side concept and created a modern battery mod that takes advantage of this space-saving and compact design. Inside, either a 21700 or an 18650 battery (not included) ensures good performance. In classic power mode, the mod provides a variable output power from 5 to 100watts. Alternatively, you can control the kit by volt or temperature selection. The Steam Crave Aromamizer Supreme V3 Advanced RDTA provides plenty of steam. This dripper-tank combination is extremely versatile and brings first-class DL enjoyment. Thanks to the modular structure, the user can choose how he would like to enjoy his Aromamizer. Using a replacement chimney and a bubble glass, the filling volume can easily be expanded from 5ml to 7ml.
208
Replacement Screw Set Kit for Billet / SXK BB 70W / DNA 60W Style Box Mod Kit Original Price $10.99, Now Only $7.99.
The Replacement Screw Set Kit is suitable for Billet / SXK BB 70W / DNA 60W Box Mod Kit. They are used as replacement parts to fix your BB box mod and make your BB box mod look nice, which is made from stainless steel material. The Kit includes 9 PCS Screws ![]() Original Vandy Vape Pulse Vessel Kit RBA Tank + Pre-Built Tank Original Price $49.99, Now Only $32.99. The Original Vandy Vape Vandyvape Pulse Vessel Kits consist of the Vessel Tanks that go inside the Mod. You can DIY it with the Vessel RBA Tank or you can use the VVC Pre-Built Coils. This DIY RBA has Curved Airflow which allows for Large & Small Coils. It is suitable for Vandy Vape Pulse AIO vape Kit / Boro / Billet box.. ![]() Original Vandy Vape Pulse AIO Replacement Vessel Pre-Built Tank Cartridge Original Price $5.99, Now Only $4.99. The Original Vandy Vape Pulse AIO Replacement Vessel Pre-Built Tank Cartridge holds 5mL capacity and is compatible with VVC-Coils (not included). It is suitable for Vandy Vape Pulse AIO vape Kit / Boro / Billet box.. ![]() Original Steam Crave Aromamizer Classic MTL RTA Replacement Build Deck Original Price $14.99, Now Only $9.99. The Original Steam Crave Aromamizer Classic MTL RTA Replacement Build Deck is made from stainless steel and PEEK ![]() Original Steam Crave Aromamizer Classic MTL RTA Replacement Drip Tip Original Price $3.99, Now Only $2.89. The Original Steam Crave Aromamizer Classic MTL RTA Replacement Drip Tip is made from Delrin and comes with 1 PC / Pack ![]() Original Steam Crave Aromamizer Classic MTL RTA Replacement Straight Glass Tank Tube Original Price $4.99, Now Only $3.59. The Original Steam Crave Aromamizer Classic MTL RTA Replacement Straight Glass Tank Tube holds 3.5ml capacity and comes with 2 PCS / Pack ![]() Original Uwell Caliburn G2 Replacement Empty Pod Cartridge Original Price $8.99, Now Only $5.99. The Original Uwell Caliburn G2 Empty Pod Cartridge is suitable for Uwell Caliburn G2 Pod System Kit. Available for 2ml vape juice and featuring an e-juice check window to fill your vape juice in time, which is beneficial to avoid a dry hit. Based on its pre-installed meshed-H 1.2ohm coil for heating up evenly, it is designed for both MTL vape and restricted DTL vape by 1.2ohm and 0.8ohm separately (coils not included). It adopts Pro-FOCS technology for high taste restoration and superb flavor. Ideal for refilling on the road and can shorten your filling time through its top filling system, from its adjustable airflow, the coil must warm every drop of e-liquid.
209
original ZQ Trio RTA 22.3mm Rebuildable Tank Vape Atomizer Original Price $29.99, Now Only $12.99.
original ZQ Trio RTA Rebuildable Tank Vape Atomizer holds 2.0ml e-juice capacity with top filling system in 22.38mm diameter. It features three independently adjustable airflow control rings, which enables you to customize your personal MTL or DTL vaping experience. In addition, with 13 airflow holes, it provides 143 airflow combinations to choose, bringing you an excellent vaping experience. It comes with single coil, a wide and excellent deck design making rebuilding a painless process. In 22mm diameter, original ZQ Trio RTA is compatible with both larger and smaller Mods without any overhanging. ![]() Typhoon Taifun GT One clone RTA Rebuildable Tank Vape Atomizer Original Price $19.99, Now Only $14.99. The Typhoon Taifun GT One clone RTA Rebuildable Tank Vape Atomizer Improved Version Kit is in 23mm diameter and holds 4.3ml capacity. The Taifun GT One clone RTA Vape Atomizer comes with 4 PCS Air Inserts: 0.8mm, 1.0mm, 1.2mm, 1.5mm, 1.8mm. ![]() YFTK Replacement Negative Contact for SXK BB 60W / 70W / Billet Box Mod - Brass Original Price $9.99, Now Only $6.99. he YFTK Replacement Negative Contact is made from brass and is suitable for SXK BB 60W / 70W / Billet Box Mod.
210
original Vandy Vape Pulse AIO Kit Replacement Metal Button Ring Set Original Price $18.99, Now Only $8.99.
This original Vandy Vape Pulse AIO Kit replacement Metal Button Set comes with 4 Button Rings. One of each color; Black, Gold, Rainbow, SS.Please Note: This product will be shipped around December 30, 2021 (ETA, not guaranteed). The final shipping date depends on the manufacturer. ![]() original Vandy Vape Replacement Ni80 24GA 0.4ohm Coil for Pulse AIO Kit / Pulse Vessel Kit Original Price $8.99, Now Only $3.99. The original Vandy Vape Pulse AIO Ni80 24GA coil is in 0.4ohm resistance and is suitable for Vandy Vape Pulse AIO Kit / Vandy Vape Pulse Vessel Kit Please Note: This product will be shipped around December 30, 2021 (ETA, not guaranteed). The final shipping date depends on the manufacturer. ![]() original Smoant Charon Baby Plus Pod System Vape Kit Original Price $29.99, Now Only $25.99. original Smoant Charon Baby Plus Pod System Vape Kit, This new pod system features magnetic replaceable 3D panels, puff-activated firing, built-in 1000mAh battery, all vape styles, adjustable airflow control, fast charging, 3.5ml pod cartridge, new mesh coils that last longer, and multiple protections. the replaceable panels that are held in place by way of strong magnets. This means you can swap them out at any time for a brand new appearance that is sure to turn heads thanks to a wide range of graffiti-like prints. All the Charon Baby Plus panels use brand new UV 3D prints with 2-layered protective UV films to ensure longevity, fingerprint resistance, and bright colors. ![]() original Timesvape Dreamer V1.5 Hybrid Mechanical Mech Vape Mod 1 x 18650 / 20700 / 21700 Original Price $75.99, Now Only $58.99. The Timesvape Dreamer V1.5 Mechanical Mod is constructed from copper material. Dreamer V1.5 is powered by 1 x 18650 / 20700 / 21700 Batteries (Not included). The tube itself is 27mm at its widest point, tapering to 25mm at the top. The tube is reversible, so you can customize the grip to suit your preferences. The copper contact pin is also silver-plated for a perfect connection every time.
211
original Vapefly Nicolas II MTL Tank Vape Atomizer Original Price $29.99, Now Only $24.99.
original Vapefly Nicolas II MTL Tank S Version is firm tank that is dedicated to giving you ultimate MTL vape experience. With very restrictive airflow, MTL vapers can get a strong throat hit from the Nicolas ll Tank. Nicolas II MTL Tank adopts top refilling system and Pull & plug coil replacement. And FreeCore N series coils will produce excellent flavor. ![]() original Vapefly Nicolas II MTL Tank Vape Atomizer Original Price $29.99, Now Only $24.99. original Vapefly Nicolas II MTL Tank G Version is firm tank that is dedicated to giving you ultimate MTL vape experience. With very restrictive airflow, MTL vapers can get a strong throat hit from the Nicolas ll Tank. Nicolas II MTL Tank adopts top refilling system and Pull & plug coil replacement. And FreeCore N series coils will produce excellent flavor. ![]() original Vapefly Nicolas II MTL Tank 1.2ohm Replacement Coil Original Price $12.99, Now Only $9.99. original Vapefly Nicolas II Coil Head belongs to FreeCore N series coils. It adopts Pull & plug coil replacement design and is fit for Nicolas II MTL Tank G / S Version to produce excellent flavor..5 PCS / Pack ![]() original Vapefly Nicolas II MTL Tank 0.8ohm Replacement Coil Original Price $12.99, Now Only $9.99. original Vapefly Nicolas II Coil Head belongs to FreeCore N series coils. It adopts Pull & plug coil replacement design and is fit for Nicolas II MTL Tank G / S Version to produce excellent flavor..5 PCS / Pack ![]() original Vapefly Nicolas II MTL Tank G / S Version 2ml Replacement Glass Tube Original Price $3.99, Now Only $2.99. The original Vapefly Nicolas II MTL Tank G / S Version Replacement Glass Tube holds 2.0ml capacity. ![]() original Smoant Charon Baby Plus Pod System Replacement Panels Original Price $5.99, Now Only $3.99. The original Smoant Charon Baby Plus Pod System Replacement Panels comes with 2 PCS / Pack, including front + back panels. The Smoant Charon Baby Plus Panel uses new UV 3D print and 2-layer protective UV films technology to provide bright color and high wear resistance but no finger print. ![]() original Smoant Charon Baby Plus 3.5ml Replacement Pod Cartridge Original Price $5.99, Now Only $3.99. The original Smoant Charon Baby Plus Replacement Pod Cartridge adopts side-filling system and is equipped with ingenious "U" type and dual independent airflow system for DL / RDL / MTL vaping.1 PC / Pack, coil not included ![]() original Lost Vape Centaurus Quest 100W BF Box Mod Original Price $117.99, Now Only $75.99. original Lost Vape Centaurus Quest BF Vape Box Mod stands out from its Squonk & storage bottle for its super-large vape juice capacity. When you get in touch with its 9.5ml capacity, it is bigger than the most and saves your time of frequently supply your capacity, used as an alternative to the e-juice bottle, especially fit for people who have a large demand for vaping. The combination of squonk & Storage bottle is separated designed for BF RDA vaping and any other atomizers. Its right up there with its creative connection mechanism to achieve valve linkage & automatic reset. The valve of the bottle will automatically react to the linkage when you replace your atomizer. Then reset itself to reach the liquid sealing structure if you remove your atomizers, helping to store and do its best to enhance the possibility of high taste restoration. Hold the device and slide down the Squonk or storage bottle, and then align to match the side of the bottle, push and lock into your mode. It is powered by a single 18650/20700/21700 battery (not included) couple with 100W max output, supported by the brand new Centaurus Solo RDA, theres no denying that you will achieve the fluffy cloud by its powerful basic. The costly and the leather pattern displays the sense of low-key luxury, as a sleeping giant dragon, wait for your awakening, come and challenge it at once. ![]() original Lost Vape Centaurus Quest 100W BF Box Mod Kit with Centaurus Solo RDA Original Price $142.99, Now Only $92.99. original Lost Vape Centaurus Quest BF Vape Box Mod Kit can show you its versatility and incomparable charm from its exciting leak-proof squonk and storage design. In order to save the trouble of carrying an e-liquid bottle and suit for two options for free combination, Centaurus Quest BF Box Mod represents a large portion of vaping, the combination of squonk & storage bottle is separately engineered for BF RDA vaping and any other atomizers, both of them boast its gigantic 9.5ml capacity, definitely surpassed most on the market. It is worth mentioning that it sets an extraordinary leak-proof connection mechanism. Once it senses that your atomizer is connected, the valve of the squonk / storage bottle will open to realize the linkage the first time. On the contrary, the spring inside the valve will reset automatically to store your e-liquid. ![]() original Lost Vape Centaurus 24mm Diameter Solo RDA Rebuildable Dripping Vape Atomizer Original Price $32.99, Now Only $27.99. original Lost Vape Centaurus Solo RDA is the first RDA of the Lost Vape brand, designing the dual airflow channel for a smooth flavor. This RDA can be realized by the valve of the Squonk / storage bottle when it is connected, and then feed the e-liquid through the 510-connection. This design works its best to take advantage of every drop, never waste your-e-liquid, as well as keep the purity. The premium wick can reach the desired result when it is fully saturated, once you install your wick for the first time, wait for minutes to saturate. The hallmark 510 threaded base connector lets you have no hassle to lose and drop when in use on the Lost Vape Centaurus Quest BF Kit. ![]() Monarchy clone Drip Tip Billet Thread Set for Billet Box Original Price $12.99, Now Only $8.99. The Monarchy clone Drip Tip Billet Thread comes with 1 x Drip tip base and 4 x Mouthpiece (POM / PC / PEEK / PEI) ![]() original Ambition Mods and Sun box 2.0 60W AIO Box Mod Original Price $129.99, Now Only $97.99. original Ambition Mods and Sun box 2.0 60W AIO Box Mod, designed by SUNBOX and produced by Ambition Mods, consists of 2.0 mod, Ambition Mods 2.0 Box Mod is powered by single 18650 battery (not included) with adjustable wattage of 1~60W output. Ambition Mods 2.0 Mod is equipped with 0.91 inch OLED display on the side. ![]() original Ambition Mods and Sun box 2.0 60W Box Mod AIO Vape Kit Original Price $149.99, Now Only $119.99. original Ambition Mods 2.0 AIO Box Mod Starter Kit with Molen Bridge and Boro Tank, designed by SUNBOX and produced by Ambition Mods, consists of 2.0 mod, Molen Bridge RBA Kit and Boro Tank to offer MTL and DL / RDL vaping. Ambition Mods 2.0 Box Mod is powered by single 18650 battery (not included) with adjustable wattage of 1~60W output. Ambition Mods 2.0 Mod is equipped with 0.91 inch OLED display on the side. Molen Bridge RBA Kit adopts 2-post single coil deck, easy to build and wire.
