302418
822
201
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Smoant Naboo 225W TC VW Variable Wattage Box Mod Original Price $58.50, Now Only $48.99
The Smoant Naboo Mod is a versatile regulated box mod with a lot of functional modes and protections. It is powered by dual 18650 batteries (NOT INCLUDED) and can be fire up to 225W. The Naboo Mod has a 2.4 inch TFT color screen and comes with 2 + 1 UI options. With the touch button, which provides tactile feedback and make you enjoy the fun of vaping. This item also has other colors to choose. ![]() Original Eleaf iJust ECM 40W 3000mAh Built-in Battery Mod Original Price $35.00, Now Only $21.19 The Eleaf iJust ECM comes in a fashionable looking and each color has its own unique pattern, making the iJust ECM stand out from other tube mods. Fitted up with an internal 3000mAh battery, the iJust ECM is long sustainable, while its multiple circuit protections will keep you vaping safe. The LED light on the button is not only gorgeous but will cycle through three colors to let you know at a glance how much battery life is remaining. Efficient, simple and sustainable, it's the Eleaf iJust ECM. This item also has other colors to choose. ![]() Original Vapor Storm Subverter 200W TC VW Variable Wattage Box Mod Original Price $45.00, Now Only $41.99 The Original Vapor Storm Subverter Box Mod, powered by dual 18650 batteries (NOT INCLUDED), can reach maximum wattage to 200W. The side panels are made from beautiful resin and become aesthetic pattern. The mod comes with a 0.96 inch colorful display and big fire button. The resistance allowed is from 0.05 to 3ohm for power mode, 0.05 to 1ohm for temperature control mode. This item also has other colors to choose. ![]() Original Smoant Campbel 80W Vaping Soft Drinks Starter Kit Original Price $87.90, Now Only $70.99 The Original Smoant Campbel Kit consists of Smoant Campbel Mod, Campbel Filter and Campbel Tank. This item also has other colors to choose. Mod: The Original Smoant Campbel Mod is a single 18650 vaping device with 80W full battery output. The resistance range is from 0.08 to 3.0 ohm. The mod is powered by single 18650 battery (NOT INCLUDED). Filter and Tank: The Original Smoant Campbel Filter and Campbel Tank integrate innovatively as one piece, which allows vapers to vape with a mixture of e-liquid and soft drinks. The Filter comes with 3ml of capacity for soft drink, while the tank comes with 2ml of capacity for e-juice. The tank adopts Ni80 0.2ohm coil, which works well at 30 to 60 Watts. ![]() Original Smoant Naboo 225W TC VW Variable Wattage Box Mod + Naboo Mesh Tank Kit Original Price $73.00, Now Only $60.99 The Smoant Naboo Kit consists of Smoant Naboo Mod and Naboo Mesh Tank. This item also has other colors to choose. Mod: The Smoant Naboo Mod is a versatile regulated box mod with a lot of functional modes and protections. It is powered by dual 18650 batteries (NOT INCLUDED) and can be fire up to 225W. The Naboo Mod has a 2.4 inch TFT color screen and comes with 2 + 1 UI options. With the touch button, which provides tactile feedback and make you enjoy the fun of vaping. Tank: The Smoant Naboo Mesh Tank is a 25mm sub ohm tank with 4ml of juice capacity. It supports two kinds of mesh coils, the Mesh 0.18ohm coil for 40~80W power and the Mesh 0.17ohm coil for 60~100W power. The tank comes with adjustable airflow control system for optimal flavor. ![]() Original Wismec SINUOUS Solo 40W 2300mAh Battery Mod + Amor NS Pro Tank Starter Kit Original Price $59.80, Now Only $41.89 The Original Wismec SINUOUS Solo Starter Kit is a compact and sleek vape pen kit with a fascinating appearance. It consists of the Wismec SINUOUS Solo 2300mAh mod and Amor NS Pro tank. This item also has other colors to choose. Mod: The Wismec SINUOUS Solo mod is powered by an internal 2300mAh battery, it can fire up to 40W and supports direct output and constant power output with multiple circuit protections. Besides, the indicator light will stay lit or flash slowly when the battery quantity is high. On the contrary, the indicator light will flash in frequency. Tank: The included Amor NS Pro tank has a diameter of 22mm, it features new 0.27ohm WS-M (Mesh) coil and 2ml capacity, with the retractable top filling solution and refined airflow control system, it will provide you a convenient vape experience with big cloud and great flavor. ![]() Original SMPO OS 650mAh TC Pod System Starter Kit Original Price $32.50, Now Only $19.39 The SMPO OS kit is a perfectly compact and portable pod that utilizes a simple draw activated system along with one button control. The advanced chipset features Auto temperature control and low e-liquid level detection, which eliminates e-liquid burning and gives optimal vape flavor delivery. The SMPO kit features short circuit, no load, low power, overtime, and overcharge protection which makes the SMPO OS Kit a safe device for all. The SMPO OS Kit adopts a 650mAh build-in battery with quick charge capability. It just needs 40 mins to fully charge your SMPO OS device. And there is an indicator light that glows to show relevant battery levels. This item also has other colors to choose. ![]() Original Eleaf EC-M Replacement Coil Head For iJust ECM Starter Kit $14.99 The Original Eleaf EC-M Coil Head is a replacement coil head constructed from kanthal, which has a resistance of 0.15ohm and is rated at 30W to 75W. It is suitable for Eleaf iJust ECM 3000mAh Starter Kit. Using a new style of mesh, the Eleaf EC-M coil head provides a much bigger surface area, presenting an ultra flavorful taste with huge clouds and a longer lifespan than ever. This product comes with 5 PCS in a pack. This item also has other Version to choose. ![]() Original SMPO Replacement Pod Cartridge for OS 650mAh Pod System Starter Kit $10.50 The Original SMPO OS Replacement Pod Cartridge is designed for the SMPO OS pod system starter kit. It is a 1.8ml refillable pod cartridge with easy side filling design. Together with the innovative CCELL heating system, the OS refillable pod will bring you pure and great flavor. This product comes with 2 PCS in a pack. ![]() Original Vapor Storm Replacement Front + Back Panels for Subverter Mod $9.50 The replacement front and back panels are made from resin and is suitable for Original Vapor Storm Subverter Mod. This product comes with 1 x Front Panel, 1 x Back Panel, totally 2 PCS in 1 pack. This item also has other colors to choose.
202
Original GeekVape Nova 200W TC VW Variable Wattage Box Mod Original Price $63.99, Now Only $48.59
The Nova mod is a high-performance device that powers up to 200W with dual 18650 batteries (NOT INCLUDED). Powered by the advanced AS chipset that has unmatched speed and power. Designed with elegant aesthetics, Nova is built with premium quality aluminum alloy and beautifully crafted resin, delivering an exquisite contrast that portrays simplicity and elegance. This item also has other colors to choose. ![]() Rogue Purity Hybrid Mechanical Mod Clone $20.99 The Rogue Purity Mechanical Mod Clone is constructed from brass in 24mm diameter. It is powered by single 18650 /20700 battery (NOT INCLUDED). It features 510 hybrid top cap and spring fire button. 18650 battery adapter is included. This item also has other colors to choose. ![]() Broadside Nashty Mechanical Tube Mod Clone $18.99 The Broadside Nashty Mech Mod Clone is constructed from brass and tapers to 25mm diameter. It comes with non-spring and non-magnet design, which helps reduce hot button and misfires. The mod is powered by single 18650 / 20700 battery (NOT INCLUDED). A 18650 battery adapter is included. This item also has other colors to choose. ![]() Original XOMO EXO-Armor 300W TC VW Variable Wattage Box Mod Original Price $199.90, Now Only $126.99 The Original XOMO EXO-Armor Mod is a TC VW box mod constructed from zinc alloy and high-quality PC, designed by SJC and XOMO, the first dual 18650 battery (NOT INCLUDED) mod with 300W max output. Constructed by 9 pieces zinc alloy and high-quality PC, it's highly anti-scratch and fingerprint-resistant, and it's processed by UV protective surface treatment. On each side, it's decorated by 14 delicate stars in red and black colors. Powered by Yihi Chipset, EXO-Armor plays ultra stable and powerful vaping experience. The luxury golden ring surrounds the TFT HD screen, on which 16 small dots shine green in dark night. The UI interface suits both android and ios systems, and it has 10 selective wall papers for you to choose. This clock mod supports VW, TC and TCR Modes, and its SXi-Q Intelligent Taste Curve can be adjusted to have 5 options for taste. ![]() Original Aspire Cobble 700mAh All-in-one Pod System Starter Kit Original Price $24.99, Now Only $22.99 The Original Aspire Cobble Kit is a great new all-in-one device from Aspire, it is designed with comfort in mind and an easy filling method. The ergonomic design pod system holds a 1.8ml capacity of e-liquid, houses a nonreplaceable 1.4ohm BVC type nichrome coil for efficient vaping to give you a flavorful vape. The Cobble is small and very light but with plenty of power and fits easily into even a small pocket or purse. This item also has other colors to choose. ![]() Original GeekVape Nova 200W TC VW Variable Wattage Box Mod + Cerberus Tank Kit Original Price $88.99, Now Only $62.99 The Original GeekVape Nova Kit consists of GeekVape Nova Mod and Cerberus Sub Ohm Tank. This item also has other colors to choose. Mod: The Nova mod is a high-performance device that powers up to 200W with dual 18650 batteries (NOT INCLUDED). Powered by the advanced AS chipset that has unmatched speed and power. Designed with elegant aesthetics, Nova is built with premium quality aluminum alloy and beautifully crafted resin, delivering an exquisite contrast that portrays simplicity and elegance. Tank: The Cerberus sub ohm tank is optimized by the ultimate Super Mesh coil that maximizes heating contact surface area in order to provide maximum flavor and large vapor production. Super Mesh Coils are compatible with Aero Mesh tank too. The tank comes with 27mm diameter and 4ml of juice capacity. ![]() Rogue Purity Hybrid Mechanical Mod Clone + Force RDA Kit Clone $25.99 The Rogue Purity Mech Kit Clone consists of Rogue Purity Mod Clone and Rogue Force RDA Clone. This item also has other colors to choose. Mod: The Rogue Purity Mechanical Mod Clone is constructed from brass in 24mm diameter. It is powered by single 18650 /20700 battery (NOT INCLUDED). It features 510 hybrid top cap and spring fire button. 18650 battery adapter is included. RDA: The Rogue Force RDA Clone is a 24mm rebuildable dripping atomizer made from brass. It features triple-post build deck with quad terminals for easy dual coil builds. It comes with side airflow for smooth vapor and great flavor. ![]() Broadside Nashty Mechanical Tube Mod Clone + Culverin RDA Kit Clone $25.59 The Broadside Nashty Mech Kit FClone consists of Broadside Nashty Mech Mod Clone and Culverin RDA Clone. This item also has other colors to choose. Mod: The Broadside Nashty Mech Mod Clone is constructed from brass and tapers to 25mm diameter. It comes with non-spring and non-magnet design, which helps reduce hot button and misfires. The mod is powered by single 18650 / 20700 battery (NOT INCLUDED). A 18650 battery adapter is included. RDA: The Culverin RDA Clone is a 25mm atty constructed from stainless steel. The deck features dual post with teardrop post hole design. The side airflow offers great flavor and massive vapor production. ![]() Original Aspire Replacement Pod Cartridge for Cobble Pod System Starter Kit Original Price $12.99, Now Only $9.99 The Original Aspire Cobble pod is a TPD compliant replacement pod cartridge for Cobble Pod System Starter Kit. It comes with bottom fill system, 1.8ml capacity and a built in, nonreplaceable 1.4ohm Nichrome coil. It is designed for use with nic-salts but normal e-liquids can also be used. This product comes with 3PCS in 1 pack.
203
Bestia Fiera Hybrid Mechanical Tube Mod Clone $24.99
The Bestia Fiera Mod Clone is the smallest 20700 / 21700 mech mod. It is constructed from brass, with hybrid connection and side fire button. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). Delrin 18650 battery adapter is included. 24mm RDA will not overhang on this mod. This item also has other colors to choose. ![]() Original GeekVape Blade 235W TC VW Variable Wattage Box Mod Original Price $53.90, Now Only $42.99 The Original GeekVape Blade Mod, which maximizes the use of dual 18650, 20700 and 21700 batteries (NOT INCLUDED) and the maximum power can reach 235W, is a versatile device with high performance. Utilizing advanced aircraft grade material, it is very light and durable. This item also has other colors to choose. ![]() Original Vandy Vape Phobia V2 RDA Rebuildable Dripping Atimizer with BF Pin Original Price $39.90, Now Only $29.99 Vandy Vape Phobia V2 RDA is a 24mm diameter RDA with angled downward airflow holes, which is concentrated to the coil build to produce a denser taste through 3 adjustable intake holes. With big built posts has wide space, the Phobia V2 RDA is easy to build single coils or dual coils, and 8.8mm deep juice well can prevent leaking with a 1ml capacity. Three types of drip tip including 810 drip tip, PEI drip tip, and 510 adapters are compatible with the Phobia V2 RDA for your option. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() VapeBreed AB Mechanical Mod Clone + V2 RDA Kit $23.99 The VapeBreed AB Mod Kit Clone consists of a AB mechanical mod Clone and a 25mm VapeBreed V2 RDA Clone. Powered by single 18650 battery (NOT INCLUDED), the mod is a full mechanical mod made from brass and measures 25mm diameter. The RDA comes with dual posts design, adjustable airflow and adjustable center pin. This item also has other colors to choose. ![]() Original Akattak Black Label Alien Clapton Kanthal A1 Wire Pre-built Coils $13.39 The Original Akattak Black Label Alien Clapton Kanthal A1 Pre-built Coils Heating Wire is made from Kanthal A1 wires and features 0.2ohm resistance and 26GA x 3 + 32GA wires. This heating wire will be a good vaping choice for DIY. This product comes with 20 PCS in 1 pack. This item also has other Version to choose. ![]() Original Akattak Black Label Alien Clapton Kanthal + SS316L Heat Resistance Wire Spool $14.99 The Original Akattak Black Label Alien Clapton Wire heating resistance wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Kanthal A1 and Stainless Steel 316L. It features 3 x 28GA + 32GA wires and 10 feet length, which will be a good choice for DIY. This item also has other Version to choose. ![]() Original Akattak Stainless Steel 316L Wire 3-in-1 Pre-built Coils Kit $12.59 The Original Akattak 3 in 1 Coil Kit comes with 10 x Clapton Coils (0.25ohm), 10 x Flat Clapton Coils (0.3ohm) and 6 x Staggered Fused Clapton (0.3ohm). These heating wires are made from Kanthal material and will be a good vaping choice for DIY. This product comes with 3 types of coils, totally 26 PCS in 1 pack. This item also has other Version to choose. ![]() Original GeekVape Meshmellow Replacement Coil for Alpha Sub Ohm Tank Clearomizer Original Price $11.70, Now Only $8.99 The Original Geekvape Meshmellow Coil is specially designed for the Geekvape Alpha Subohm Tank. It is a 0.15ohm single core coil head with a output power range of 60~110W (Best for 75~95W). All cotton of MeshMellow coils are imported from Egypt, which delivers purest flavor from first inhale. The MeshMellow mesh coils maximizes heating contact surface area for pure flavor and huge & thick vapor. This product comes with 3 pieces in a pack. This item also has other Version to choose. ![]() Kindbright MTL RBA for Billet Box Mod Clone $13.99 The Kindbright MTL RBA is made from 316 stainless steel and PEEK insulator. It is suitable for SXK Billet Box Mod Clone/ YFTK Billet Box Mod Clone. It supports single coil builds.
204
Original Uwell Hypercar 80W TC VW Variable Wattage Box Mod Original Price $56.99, Now Only $47.19
The Original Uwell Hypercar 80W TC VW variable wattage box mod is designed with a "supercar" theme that includes a streamlined appearance and ergonomics. Constructed from zinc alloy, the Hypercar mod also adopts single switch and silicone fire button, which will give you a smooth and comfortable hand feeling. Powered by a single 18650 battery (NOT INCLUDED) with the magnetic battery cover, its maximum output can reach up to 80W and can operate in power mode, temperature control with nickel mode, temperature control with titanium mode and bypass mode. This item also has other colors to choose. ![]() Original Cool Vapor Madpul 200W VW Variable Wattage Box Mod $42.99 Inspired by the magazine of a gun, the Original Cool Vapor Madpul Mod features a cool military appearance. It is constructed by Nylon fiber and stainless steel. With dual 18650 battery (NOT INCLUDED), this mod can reach maximum output power to 200W. The Madpul Mod supports three working modes, which are Mech, Power and Voltage modes. It would be one of your coolest vape collections. This item also has other colors to choose. ![]() Original Uwell Whirl Sub Ohm Tank Clearomizer Original Price $31.99, Now Only $24.99 The Original Uwell Whirl Sub Ohm Tank is a 24.2mm clearomzer with 3.5ml e-juice capacity, 0.6ohm NiChrome dual coil and 1.8ohm NiChrome single coil. It is made from stainless steel and glass. They are both long-lasting low wattage coils that can save power and juice. This item also has other colors to choose. ![]() Original Uwell Hypercar 80W TC VW Variable Wattage Box Mod + Whirl Sub Ohm Tank Kit Original Price $81.99, Now Only $64.69 The Original Uwell Hypercar 80W TC VW Mod Kit consists of Uwell Hypercar 80W TC VW Variable Wattage Box Mod and Whirl Sub Ohm Tank Atomizer. This item also has other colors to choose. Mod: The Uwell Hypercar 80W TC VW variable wattage box mod is designed with a "supercar" theme that includes a streamlined appearance and ergonomics. Constructed from zinc alloy, the Hypercar mod also adopts single switch and silicone fire button, which will give you a smooth and comfortable hand feeling. Powered by a single 18650 battery (NOT INCLUDED) with the magnetic battery cover, its maximum output can reach up to 80W and can operate in power mode, temperature control with nickel mode, temperature control with titanium mode and bypass mode. Tank: The included Uwell Whirl Sub Ohm Tank is 24.2mm clearomizer with 3.5ml e-juice capacity, 0.6ohm NiChrome dual coil and 1.8ohm NiChrome single coil. They are both long-lasting low wattage coils that can save power and juice. ![]() Original Uwell Nunchaku 80W TC VW Variable Wattage Mod + RDA Kit Original Price $81.99, Now Only $62.49 The Original Uwell Nunchaku Mod Kit includes a 80W Nunchaku mod and Nunchaku RDA. This item also has other colors to choose. Mod: The Nunchaku mod can be switchable with Power / SS / Ni / Bypass mode to achieve different vaping experience. It is powered by a single 18650 battery (NOT INCLUDED) with an 80W maximum output. It also can be charged via USB port. Tabk: The Nunchaku RDA comes with a simple build deck for single or dual coils easy building. By using a squonk pin, it is also compatible with Squonk mod.This product comes with a bottom feeder pin. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The replacement 510 drip tip is made from resin and stainless steel. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.99 The replacement 810 drip tip is made from resin and stainless steel. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() Original Uwell Juice Bank Refilling Dripping Bottle for E-juice Liquid Original Price $29.99, Now Only $26.19 The Original Uwell Juice Bank is a refilling dripping bottle for e-liquid with a juice capacity of 15ml and the single refilling volume is about 0.1ml. Constructed from Stainless Steel and Quartz Glass, it has perfect protection from inside to outside. With the transparent windows on both sides of the bottle, you can check juice levels with a 15 ml scale. This item also has other colors to choose.
205
Original Smoant Naboo Sub Ohm Tank Clearomizer Original Price $28.99, Now Only $22.99
The Original Smoant Naboo Mesh Tank is a 25mm sub ohm tank with 4ml of juice capacity. It supports two kinds of mesh coils, the Mesh 0.18ohm coil for 40~80W power and the Mesh 0.17ohm coil for 60~100W power. The tank comes with adjustable airflow control system for optimal flavor. This item also has other colors to choose. ![]() Original 5GVape Freedom RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.00, Now Only $26.99 The Original 5GVape Freedom RDA is constructed from 316 stainless steel and PC cap with 22mm diameter and 30.5mm height. It can be refilled both from the top and bottom. The top adjustable surround intake mode makes the Strong taste. This RDA comes with a bottom feeder pin. This item also has other colors to choose. ![]() Original GeekVape Ammit MTL RTA Rebuildable Tank Atomizer Original Price $34.90, Now Only $28.99 The Original Ammit MTL RTA is a 24mm rebuildable tank atomizer which is constructed from stainless steel with 4ml capacity, featuring three dimensional airflow system transferring air from top to bottom producing unbeatable flavor while retaining leak-proof capability. 12 airflow adjustment options provide the most variable restrictions for different preferences. This item also has other colors to choose. ![]() AIOLOS V2 RTA Rebuildable Tank Atomizer Clone $11.99 The AIOLOS V2 RTA Clone is a tiny rebuildable tank with 16mm diameter and 2ml of juice capacity. It is made from 316 stainless steel and comes with a spare PMMA tube. The tank features narrow chimney for tasty vapor, single coil build deck and bottom airflow. ![]() Original 5GVape Freedom RDA Rebuildable Dripping Atomizer with BF Pin + Spare Caps $39.00 The Original 5GVape Freedom RDA Kit consists of a freedom RDA, 3 spare caps, 3 replacement drip tips and 3 decorative rings. The RDA is constructed from 316 stainless steel with 22mm diameter and 30.5mm height. It can be refilled both from the top and bottom. The top adjustable surround intake mode makes the Strong taste. This RDA comes with 3 caps, 3 drip tips, 3 decorative rings and a bottom feeder pin. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for 528 Goon / Reload / Battle RDA $2.29 The 810 drip tip is made from resin. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.59 The replacement 510 drip tip is made from wood. It is suitable for all atomizers that fit 510 drip tip. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.59 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() Coppervape SteamTuners Replacement Tank Tube Clone for Dvarw MTL RTA Clone $2.99 The Coppervape SteamTuners Replacement Tank Tube Clone is made from PC and has 3.5ml of juice capacity. It is suitable for Coppervape Dvarw MTL RTA Clone. This item also has other Version to choose. ![]() Original Hugsvape Snow Organic Cotton + 0.3 / 0.35 Ohm Pre-built Coil Kit $2.59 This product consists of two Snow organic cottons and two pre-built coils. One coil is a 0.3ohm clapton coil which is constructed from kanthal A1, the other is a 0.35ohm mix twisted coil made from Ni80. ![]() Original Hugsvape Snow Organic Cotton for Coil Wicking $3.89 The Original Hugsvape Snow Cotton utilizes 100% natural organic cotton, it is good and easy for DIY coil building and can provide a clean pure flavor. This product comes with 20 PCS in 1 pack. ![]() Original Coil Father Bravo Cotton for RDA / RTA / RDTA Atomizer $1.99 The Original Coil Father Bravo Cotton is designed for dripping lovers. It is made of 100% organic cotton and is took through a thorough purification process to remove impurities and natural oil. It doesn't require a "break in period", and provides a clean flavor from your first pull to the last. No boiling necessary, simply Pinch, Tear and Vape. This product comes with 15 PCS in a pack. ![]() Original Coil Father PUMP2 Liquid Dispenser for RDA / Squonk Mod $6.49 The Original Coil Father PUMP2 Liquid Dispenser is an oil injector for RDA and squonk mod with a 27mm diameter and 122.5mm height. It comes with plastic shell, soft silicone bottle and stainless steel cap. With the 30ml e-liquid capacity, it can feed the squonk mod with e-juice via 510 thread. This item also has other colors to choose. Original Smoant Replacement Coil for Naboo Sub Ohm Tank Clearomizer $9.09 The Original Smoant Replacement Coil is specially designed for the Naboo sub ohm tank Clearomizer. It is a 0.17ohm coil head with an output power range of 60~100W. This product comes with 3 PCS in a pack. This item also has other Type to choose.
206
ShenRay Vapor Giant Mechanical Tube Mod Clone $25.99
The ShenRay Vapor Giant Mod Clone is a mechanical tube mod constructed from stainless steel and powered by single or dual 26650 battery (NOT INCLUDED). It features spring fire button, bottom venting holes and adjustable 510 connector. ![]() Original Vapefly Pixie RDA Rebuildable Dripping Atomizer with BF Pin Original Price $24.06, Now Only $17.89 The Original Vapefly Pixie BF RDA is a 22mm RDA that constructed from stainless steel and Delrin. It features super easy building deck for single coil and side airflow system that easy to push and adjust. There are two different airflow hole including single airflow hole and multiple airflow hole for you option. Besides, with avoid heating deck design and triangle airflow path, this RDA will bring smooth air and massive cloud. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original One Top Onetopvape Gemini RDTA Rebuildable Dripping Tank Atomizer $24.99 The Original One Top Onetopvape Gemini RDTA is a 26.5mm diameter RDTA which is especially two sizes cap designed you've never seen in vape market. Constructed by 304 Stainless Steel and PC, it is well-built and durable. With the dual post build deck and quad terminals, it is very easy to build. Together with the Quad terminal and side airflow system, Gemini RDTA will bring an excellent vaping experience for you. ![]() Original IJOY Katana 81W 3000mAh ALM TC VW Variable Wattage Mod + Sub Ohm Tank Starter Kit $57.79 The Original IJOY Katana Starter Kit consists of the IJOY Katana ALM Mod and Katana Sub ohm Tank. This item also has other colors to choose. Mod: The IJOY Katana ALM Mod is powered by a built-in 3000mAh battery with the IWEPAL chip, the mod can fire up to 81W maximum output and supports Power, Pod, MTL, Bypass, PMode and Temp modes to satisfy your different vaping needs. What's more, the Katana Kit features fast ignition and quick charging function. And the 0.96inch OLED display will inform you essential parameters you need. Tank: The Katana Sub ohm Tank features a 25mm diameter and 0.2ohm resistance. It comes with a big capacity and the IJOY coil produces pure taste and large cloud. ![]() Original Arctic Dolphin ELUX 1300mAh TC VW Box Mod + Sub Ohm Tank Starter Kit $37.79 The Original Arctic Dolphin ELUX Starter Kit consists of Arctic Dolphin ELUX 1300mAh mod and Dolphin ELUX Sub Ohm Tank. This item also has other colors to choose. Mod: The Arctic Dolphin ELUX Mod is so lightweight that you can carry it everywhere and hold the compact device in hands. Powered by the 1300mAh built-in battery, the kit can fire up from 5W to 30W maximum output. Tank: The included sub ohm tank comes with 2ml juice capacity and 2.0ohm coil for dense flavor and optimal cloud. ![]() Original Akattak Clapton 2Core Nichrome 80 Wire Pre-built Coils $8.39 The Original Akattak Clapton 2Core Ni80 Pre-built Coils Heating Wire is made from Nichrome 80 wires and features 0.25ohm resistance and 26GA x 2 + 38GA wires. This heating wire will be a good vaping choice for DIY. This product comes with 10 PCS in 1 pack. This item also has other Version to choose.
207
Original Nikola Wolverine 230W TC VW Variable Wattage Box Mod Original Price $60.90, Now Only $46.99
The Original Nikola Wolverine is a TC VW box mod constructed from zinc alloy and ABS material to strengthen the overall texture while enhancing the fitness of grip. With its baking finish technique, the Wolverine is refined in workmanship, unified in gap and tight in installation, the new design offers an ergonomic hand feel for users. It features include 7~230W stable output, temp control switchable and 4 different taste modes. Its ultra long battery life is ensured by dual 18650 batteries (NOT INCLUDED) and large battery capacity. The Wolverine has 1.5A micro USB charging function, making it convenient for users to charge the battery. This item also has other colors to choose. ![]() Original Hugsvape Surge 80W TC VW Variable Wattage Squonk Box Mod Original Price $39.99, Now Only $34.99 The Original Hugsvape Surge Squonk Mod is a TC VW box mod constructed from PC and glass fiber. Powered by single 18650 / 20700 battery (NOT INCLUDED), it is able to reach up to a maximum output power of 80W. And the battery door is strongly held by magnets. The Surge Squonk Mod also support 4 working modes: Power, W-VPC, Bypass and TC to meet different vaping needs. This item also has other colors to choose. ![]() Original Squid Industries Detonator 120W TC VW Variable Wattage Box Mod Original Price $99.99, Now Only $73.99 The Original Squid Industries Detonator Mod, powered by single 20700 / 21700 battery (NOT INCLUDED), is an aggressively yet beautifully designed chassis with a unique trigger button and a sophisticated advanced board with extensive temperature control suite. The protruding firing button is intuitive and is ready to begin vaporizing e-juice at first touch. The two adjustment buttons sit below the brilliantly illuminated OLED display screen and sit above the on / off switch. This item also has other colors to choose. ![]() Original Hugsvape Piper RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.99, Now Only $23.19 The Original Hugsvape Piper BF RDA is constructed from stainless steel with 24mm diameter. It is a dual vertial coil RDA with both 510 pin and squonk pin, its bottom airflow transfers to side airflow through the tube and then hits the coils directly from inside. And the Piper RDA is perfectly matched with the Hugsvape Surge Squonk Mod. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Hugsvape Surge 80W TC VW Squonk Mod + Piper BF RDA Kit Original Price $59.99, Now Only $49.79 The Original Hugsvape Surge Squonk Mod Kit consists of Surge 80W squonk TC VW box mod and Piper BF RDA. This item also has other colors to choose. Mod: The Original Hugsvape Surge Squonk Mod is a TC VW box mod constructed from PC and glass fiber. Powered by single 18650 / 20700 battery (NOT INCLUDED), it is able to reach up to a maximum output power of 80W. And the battery door is strongly held by magnets. The Surge Squonk Mod also support 4 working modes: Power, W-VPC, Bypass and TC to meet different vaping needs. RDA: The Original Hugsvape Piper BF RDA is constructed from stainless steel with 24mm diameter. It is a dual vertial coil RDA with both 510 pin and squonk pin, its bottom airflow transfers to side airflow through the tube and then hits the coils directly from inside. And the Piper RDA is perfectly matched with the Hugsvape Surge Squonk Mod. This RDA comes with bottom feeder pin. ![]() Original Vapesoon Minions 810 Drip Tip with Cap for TFV8 / TFV12 Tank / Goon / Reload RDA $3.59 The Vapesoon 810 drip tip is made from resin and stainless steel and comes with a silicone cap to protect it from dust. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other Version to choose. |
208
Original Joyetech ULTEX T80 80W VW Varuable Wattage Tube Mod $41.61
The Original Joyetech ULTEX T80 80W mod comes with an exquisite carving appearance and portable pen-style body. For perfectly match with the Cubis Max tank, the ULTEX T80 mod adopts mechanical style design. Powered by single 18650 battery (NOT INCLUDED), it can fire up to 80W maximum wattage output, powerful as mesh mod. It also equips a 0.49-inch OLED screen which is located on the downside. Moreover, the mod supports upgrade firmware. This item also has other colors to choose. ![]() Original Aspire Cleito Pro Sub Ohm Tank Clearomizer Original Price $28.00, Now Only $24.29 The Original Cleito Pro Sub Ohm Tank comes with a 24mm diameter and new 0.5ohm coil (also compatible with the Cleito and the Cleito Exo tanks), with phenomenal wicking capability for this type of coil, it ensures increased vapor and flavor, just as you'd expect from Aspire innovations. Also included is Aspire new mesh coil rated at 0.15ohm. It features 3ml capacity and also can be extended to 4.2ml by using extra bubble glass tube. With the improved flavor and vapor production you can form your own mini weather system each time you vape. This item also has other colors to choose. ![]() Original Aspire Cleito 120 Pro Sub Ohm Tank Clearomizer Original Price $30.00, Now Only $25.69 The Original Aspire Cleito 120 Pro Tank is the latest addition of Cleito family. The tank continues the classic appearance and comes with 3ml capacity. It also can be extended to 4.2ml by using extra bubble glass tube. The Cleito 120 Pro tank features a 0.15ohm mesh coil and a 0.16ohm Cleito 120 coil. Both of them have phenomenal wicking capability and enhance flavor. It adopts bottom adjustable airflow design for produce huge vapor clouds and better vaping experience. Top side filling design makes refill easier and avoid leakage. This item also has other colors to choose. ![]() Original Joyetech ULTEX T80 80W VW Mod + Cubis Max Tank Kit $62.58 The Original Joyetech ULTEX T80 80W Kit is consisted of Joyetech ULTEX T80 vw mod and Cubis Max tank.This item also has other colors to choose. Mod: The Original Joyetech ULTEX T80 80W mod comes with an exquisite carving appearance and portable pen-style body. For perfectly match with the Cubis Max tank, the ULTEX T80 mod adopts mechanical style design. Powered by single 18650 battery (NOT INCLUDED), it can fire up to 80W maximum wattage output, powerful as mesh mod. It also equips a 0.49-inch OLED screen which is located on the downside. Moreover, the mod supports upgrade firmware. Tank: The Cubis Max tank equips innovative NCFilmTM heater which takes a horizontal building way in order to achieve great vaping experience. With the coil-less design, the NCFilmTM heater is easy to clean and supports more than 3 months lifespan. The tank features top filling design and top airflow system, it allows a simple replacement of cotton for a pure and delicate vaping experience. Having the top-fill and top-airflow system, youre free of any leakage. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.39 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This drip tip will be shipped with random color. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.59 The replacement 510 drip tip is made from resin and stainless steel. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() Original Aspire Replacement Coil Head for Cleito / Cleito EXO / Cleito Pro Sub Ohm Tank $17.29 The Original Aspire replacement coil features 0.5ohm resistance and is rated at 60W to 80W, it is excellent for vapor production and compatible with Cleito, Cleito Exo tanks and will further enhance flavor. This product comes with 5 PCS in a pack.
209
Original Steam Crave Titan PWM VV Variable Voltage Box Mod $53.99
The Original Steam Crave Titan PWM Mod is a quad 18650 variable voltage box mod. Powered by quad 18650 batteries (NOT INCLUDED) in parallel / series, this mod can provide maximum output to 300W, which is very powerful. By Rotating the fire button you can adjust the voltage, and it comes with lock function. Besides, the mod has multiple protections to give you a safe vaping experience. This item also has other colors to choose. ![]() Original Hellvape Drop Dead RDA Rebuildable Dripping Atomizer with BF Pin Original Price $39.99, Now Only $25.59 The Original Hellvape Drop Dead RDA is an epic collaboration by Hellvape, Vapin' Heathen, and TVC The Vapor Chronicles, creating a rebuildable masterpiece based on the designs of two of the best selling atomizers of the past year, the Hellvape Dead Rabbit RDA and Digiflavor DROP RDA. The Drop Dead RDA feature Drop style deck and Dead Rabbit style top cap, which brings fantastic chemistry, performing greatly in flavor and cloud production. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Steam Crave Glaz RTA Rebuildable Tank Atomizer $36.69 The Original Steam Crave Glaz RTA is a 31mm super huge rebuildable tank with 7ml of juice capacity. Using unique glass chamber / chimney section, the tank features brand new postless build deck and special bottom angled airflow design. The Semi restrictive airflow is for ultimate flavor chasing experience. This item also has other colors to choose. ![]() Original Hellvape Dead Rabbit RTA Rebuildable Tank Atomizer Original Price $36.99, Now Only $26.99 The Original Hellvape Dead Rabbit RTA Tank Atomizer is the brand new RTA tank, which is a collaboration by Vapin' Heathen and Hellvape. It is a 25mm RTA with 2ml / 4.5ml of juice capacity. Dead Rabbit RTA features large e-juice capacity and top airflow system for large vapor without e-juice leakage. Dead Rabbit RTA has an easy coil build deck offering a fantastic option for those after excellent performance from a rebuildable tank. There is Dead Rabbit Logo on the chamber. 810 wide bore drip tip is included. This item also has other colors to choose. ![]() Original Arctic Dolphin Kurve 220W TC VW Variable Wattage Box Mod + Sub Ohm Tank Kit $88.99 The Original Arctic Dolphin Kurve mod kit, powered by dual 18650 batteries (NOT INCLUDED), it is able to reach up to an output power from 5W to 220W. It has a 0.96inch OLED white screen, the screen display will inform you essential parameters you need. It also can be quickly charged via USB port. This item also has other colors to choose. ![]() Original Cool Vapor Madpul 200W VW Variable Wattage Box Mod + Lava Tank Kit Original Price $59.90, Now Only $53.99 The Cool Vapor Madpul Kit consists of a Madpul mod and a LAVA tank. This item also has other colors to choose. Mod: The Original Cool Vapor Madpul 200W VW mod is constructed by nylon fiber and stainless steel. With dual 18650 batteries (NOT INCLUDED), it can fire up to the max output of 200W with power mode, VV / VW mode and mechanical mode. The Cool Vapor Madpul also comes with the advanced SEVO 200W chipset, so it supports 0.08s quick firing speed with multiple protections for a stable and great vaping. Tank: The included Cool Vapor LAVA Tank is a 24mm diameter with 3ml e-juice capacity, and there are 0.3ohm and 0.5ohm coil for a different flavor. Moreover, the Cool Vapor LAVA tank also features the adjustable bottom airflow design, and SMOK TFV8 coils are available for the tank. ![]() Comp Lyfe Japan Mechanical Tube Mod Clone + RDA Kit $28.89 This Comp Lyfe Japan Mod Kit Clone consists of a Comp Lyfe Japan mechanical tube mod Clone and a RDA. This item also has other colors to choose Mod: The Comp Lyfe Japan mod Clone is a mechanical tube mod which features 25mm diameter and brass construction. It is powered by single 18650 battery (NOT INCLUDED). RDA: The included RDA is constructed from brass, it features 24mm diameter and adjustable airflow. It is suitable for Comp Lyfe Japan mechanical tube mod Clone. ![]() 810 Replacement Drip Tip A for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.59 The replacement 810 drip tip is made from Epoxy resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.39 The replacement 810 drip tip is made from Aluminum and POM. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() Original Vivismoke Cotton Jack Pre-built Vape Cotton Thread for Wicking $3.39 The Original Vivismoke Cotton Jack utilizes pure cotton. The pre-loaded cotton is very easy to wick. This cotton provides more capacity and clean pure flavor. This product comes with 20 PCS in 1 pack. ![]() Original Vivismoke Hip Hop Vape Cotton for Wicking $3.59 The Original Vivismoke Hip Hop Cotton utilizes pure cotton. The cotton is very easy to wick. This cotton provides more capacity and clean pure flavor. This product comes with 15 Feet length. ![]() Vapeasy BF Bottom Feeder Squonk Bottle Kit for Regulated Box Mod $7.99 The Vapeasy squonk bottle kit is constructed from aluminum frame and silicone bottle. It is designed for regulated box mod. The connector is 25mm diameter and the bottle comes with 7ml capacity. Simply installed it between your mod and atomizer and just enjoy squonking with your non-squonk device. This product is not suitable for mechanical mod. This item also has other colors to choose. Vapeasy Vehicle Mounted Vape Refilling Bottle Kit for E-cigarette $10.99 The Vapeasy Refilling Bottle Kit consists a vehicle mounted base and a refilling bottle. It is very convenient to use when you are in your car. This item also has other colors to choose.
210
Original Yosta Livepor 200W TC VW Variable Wattage Box Mod $28.89
This Original Yosta Livepor mod is a TC VW box mod constructed from PPS. With dual 18650 batteries (NOT INCLUDED), it can fire up to the wattage from 1W to 200W with VW / BYPASS / TC-Ni / TC-Ti / TC-SS / TCR mode. It features spring-loaded firing button and micro-USB charging function, making it convenient for users to charge the battery. And it has compact size with ergonomic design for better touch feeling. This item also has other colors to choose. ![]() Original Advken Notch RDA Rebuildable Dripping Atomizer with BF Pin Original Price $31.99, Now Only $24.39 The Original Advken Notch RDA is a 24mm RDA which is constructed from 304 stainless steel. It comes with deep juice well and bottom feed pin, which makes filling easier and offer smooth flavors. The side and bottom airflow in out system can prevent leaking effectively. With dual post design, there are large space to build coils and also can compatible with Notch coil or other rebuilding coils. This Notch RDA features installed 2 notch coils that is easy to use and 810 drip tip. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Advken Twirl RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.99, Now Only $24.19 The Original Advken Twirl RDA is a 24mm diameter RDA with a bottom feed pin. Constructed from high quality 304 stainless steel, it comes with black plated rebuild deck with a dual post that has more space to the built coil for vapors. With the inner chamber with slot design, it is easy for you to install. Moreover, the Twirl BF RDA features top airflow control and supports bottom feeding with a deep juice well design which will avoid leakage. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Coil Father King RDTA Rebuildable Dripping Tank Atomizer $9.49 The Original Coil Father King RDTA is a 25mm rebuildable tank atomizer with 3.5ml of juice capacity. The tank features dual post build deck with quad terminals for easy coil building. The filling port will be blocked by the plug in the cap. The bottom airflow is adjustable. 810 wide bore Delrin drip tip is included. This item also has other colors to choose. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.69 The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.99 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This drip tip will be shipped with random color (1 piece). More options than what's on the image. ![]() Original Asmodus Replacement Smart Siphon Box for Spruzza Squonk Box Mod $21.99 The Original Asmodus Spruzza Smart Siphon Box adopts Smart Siphon System (SSS), which is a pump system that is the first of its kind. It can hold about 6ml of juice capacity. It is suitable for Asmodus Spruzza squonk box mod. ![]() Vapeasy Liquid Dispenser Refilling Bottle $10.99 The Vapeasy Liquid Dispenser Refilling Bottle is an oil injector for RDA and squonk mod with a 25mm diameter and 115mm height. It comes with aluminum shell, soft silicone bottle and stainless steel cap. With the 30ml e-liquid capacity, it can feed the squonk mod with e-juice via 510 thread. This item also has other colors to choose. |
211
Original Augvape Skynet Pro Sub Ohm Tank Clearomizer Original Price $33.99, Now Only $25.89
The Augvape Skynet Pro Sub-Ohm Tank is a 25mm sub-ohm tank which features an upgraded 3.8ml juice capacity with the standard glass and a beefier 7.1ml extended juice capacity with the bubble glass tank section. Retaining the Skynet's predecessor, the Augvape Skynet Pro utilizes an easy to open threaded top fill system granting users the ease of refilling. It comes with a 0.15ohm triple mesh coil, rated at 90W to 120W, along with a 0.2ohm double mesh coil, rated at 65W to 100W. Located on the bottom of the Skynet Pro are three adjustable airflow slots enabling users to fine tune their preferred draw, on the top is a 9mm bore 810 drip tip. This item also has other colors to choose. ![]() Original Desire Bulldog Sub Ohm Tank Clearomizer Original Price $34.99, Now Only $29.99 Coming with 3.0ml juice capacity, which can be extended to 4.3ml with bubble glass, the Original Desire Bulldog Sub Ohm Tank utilizes high-quality raw material cotton to ensure long-term use and make vape uninterrupted under high power output. And it features push-top filling design and bottom dual holes intake. It adopts two different coils with 0.2ohm and 0.18ohm resistance.This item also has other colors to choose. ![]() Original Asmodus Luna 80W Squonk Box Mod + Nefarius TF / BF RDTA Kit $114.95 This Asmodus Luna 80W mod kit consists of the Original Asmodus Luna 80W squonk mechanical box mod and Nefarius TF / BF RDTA. This item also has other colors to choose. Mod: The Original Asmodus Luna Squonker box mod, a collaboration by Ultroner and Asmodus, is a single-battery unregulated Squonker mod with protection. The Asmodus Luna is constructed of 6063 aluminum alloy and Stabilized wood. The internal bottle has 6ml of juice capacity. The mod is powered by single 18650 battery (NOT INCLUDED). RDTA: The Original Asmodus Nefarius RDTA is a traditional Genesis style RDTA with removable micro hex screw, which makes it become a Top Fill / Bottom Fill (TF / BF) RDTA. You can bottom feeding the tank without worrying juice mess. The tank comes with centered airflow lock, 3 different airflow configurations and 2 drip tips for your option. With the help of different airflow, you can enjoy a tight and flavorful mouth-to-lung draw, or a nice airy cloudy draw. This RDTA comes with bottom feeder pin. ![]() Original Asmodus Pumper 18 Squonk Mechanical Box Mod + C4 BF RDA Kit $124.95 This Asmodus Pumper 18 mod kit consists of the Original Asmodus Pumper 18 squonk mechanical box mod and C4 BF RDA. This item also has other colors to choose. Mod: The Original Asmodus Pumper 18 squonk mod is a single battery mechanical mod constructed from high grade stainless steel and luxurious stabilized wood for a lightweight and beautiful design. The button proudly holds the Asmodus wheel logo and is recessed to better help the user from auto firing. The Pumper squonk bottle has an 8ml liquid capacity. The bottle removal system is amazingly easy to use. This mod is powered by single 18650 battery (NOT INCLUDED). RDA: The Original Asmodus C4 RDA is a 24mm diameter rebuildable dripping atomizer, with the main chassis being composed of 304 stainless steel, anodized 6063 aluminum used for the top cap to provide a solid finish that is resistant to chipping and scratching, and a layer of 24K gold-plated on the build deck for a finish that not only offers an elegant accent to this pretty little powerhouse, but maximum conductivity to ensure that this little beast hits as hard as possible. The C4 RDA is a two posts design for easy single building. This RDA comes with bottom feeder pin. ![]() Original Augvape Replacement Coil for Skynet Pro Sub Ohm Tank Clearomizer $10.89 The Original Augvape Pro Replacement Coil is a 0.2ohm double mesh coil head, capable of 65W to 100W. Internally the Augvape Skynet Replacement Coil uses mesh coils and organic cotton. It is used in conjunction with the Augvape Skynet Sub-Ohm Tank system. This product comes with 3 PCS in a pack. This item also has other colors to choose.
212
Original Arctic Dolphin Kurve 220W TC VW Variable Wattage Box Mod $60.99
The Original Arctic Dolphin Kurve mod is a TC VW box mod powered by dual 18650 batteries (NOT INCLUDED), is able to reach up to an output power from 5W to 220W. It has a 0.96inch OLED white screen, the screen display will inform you essential parameters you need. It also can be quickly charged via USB port. This item also has other colors to choose. ![]() Original OBS Cube 80W 3000mAh VW Variable Wattage Built-in Battery Box Mod $45.00 The Original OBS Cube Mod is constructed from zinc alloy, it is powered by a built-in 3000mAh 23600 A+ high rate battery, with the fire speed of 10 milliseconds, it is very safe and durable. It features 0.96-inch LED screen, high- tech appearance, ergonomic design, comfort grip and exquisite buttons. The 1.5A charge current makes it safe and efficient to charge within 2~3 hours. This item also has other colors to choose. ![]() Original GeekVape Aegis Mini 80W 2200mAh TC VW Variable Wattage Box Mod Original Price $45.00, Now Only $41.99 The Original GeekVape Aegis Mini is designed to be the most durable mod with extreme water, shock and dust protections. This mini beast is equipped with the advanced AS chipset, it powers from 5W to 80W and produces an outstanding power output accuracy in both power mode and temperature control mode. The mixture of alloy, leather and SLI silicon provides intense durability and great ergonomics. It is very compact and built in with a decent 2200mAh battery. This item also has other colors to choose. ![]() Original Ambition Mods C-Roll RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.99, Now Only $24.99 The Original Ambition Mods C-Roll RDA is a 22mm rebuildable dripping atomizer which is constructed from 316 stainless steel with Delrin drip tip. It features symmetric cyclic cool system, turn-Switch close air flow, single / dual adjustable airflow control, in order to give you great flavor with decent cloud. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original OBS Cube 80W 3000mAh VW Variable Wattage Starter Kit $59.00 The Original OBS Cube Starter Kit consists of OBS Cube Mod and OBS Cube Tank. This item also has other colors to choose. Mod: The Original OBS Cube Mod is constructed from zinc alloy, it is powered by a built-in 3000mAh 23600 A+ high rate battery, with the fire speed of 10 milliseconds, it is very safe and durable. It features 0.96-inch LED screen, high- tech appearance, ergonomic design, comfort grip and exquisite buttons. The 1.5A charge current makes it safe and efficient to charge within 2~3 hours. Tank: The Original OBS Cube Tank is made from stainless steel, it has 25.5mm diameter with a juice capacity of 4ml. with the pre-installed 0.2ohm M1 mash coil, it has a output wattage of 50~80W (BEST 65~75W), which can bring you smooth flavor and huge clouds. ![]() Original GeekVape Aegis Mini 80W 2200mAh TC VW Mod + Cerberus Tank Kit Original Price $65.00, Now Only $55.99 This product consists of the Original GeekVape Aegis Mini 80W TC VW mod and the Cerberus sub ohm tank. This item also has other colors to choose. Mod: The Original GeekVape Aegis Mini is designed to be the most durable mod with extreme water, shock and dust protections. This mini beast is equipped with the advanced AS chipset, it powers from 5W to 80W and produces an outstanding power output accuracy in both power mode and temperature control mode. The mixture of alloy, leather and SLI silicon provides intense durability and great ergonomics. It is very compact and built in with a decent 2200mAh battery. Tank: The included tank in the kit is the Cerberus sub ohm tank which comes with a 5.5ml bubble tank and is optimized by the ultimate 0.3ohm super mesh coil which can power up to 5~80W (best at 30~40W) that maximizes heating contact surface area in order to provide maximum flavor and large vapor production. ![]() SOB Parallel Hybrid Mechanical Box Mod Clone + Outlaw RDA Kit Clone $24.99 The SOB Parallel Mech Kit Clone consists of SOB Parallel Mech mod Clone and Outlaw RDA Clone. This item also has other colors to choose. Mod: The SOB Parallel Mechanical box mod Clone is constructed from stainless steel and resin and is powered by dual 18650 battery in parallel (NOT INCLUDED). The battery access door is easy to remove by hand. The venting holes are positioned at the access door. The logo and series number are on the mod. RDA: The Outlaw RDA Clone is constructed from stainless steel with 24mm diameter. The deck features classic dual post style design and comes with a deep juice well. The airflow can be adjusted by dual airslots on each side. ![]() Original OBS Replacement M6 Coil for Damo / Cube Tank $8.99 The Original OBS M6 Coil is a replacement coil head which has a resistance of 0.2ohm and is rated at 40W to 80W (best at 50~70W). It is suitable for OBS Cube 80W 3000mAh Starter Kit / OBS Damo Tank. This product comes with 5 PCS in a pack. ![]() Original OBS Replacement M1 Mesh Coil for Cube Tank $11.99 The Original OBS M1 Mesh Coil is a replacement coil head which has a resistance of 0.2ohm and is rated at 50W to 80W (best at 65~75W). It is suitable for OBS Cube 80W 3000mAh Starter Kit. Using a new style of mesh, the OBS M1 coil head provides a much bigger surface area, presenting an ultra flavorful taste with huge clouds and a longer lifespan than ever.This product comes with 5 PCS in a pack.
213
Original Vsticking VK530 200W TC VW Variable Wattage Box Mod $76.99
The Original Vsticking VK530 Mod is an ergonomic body mod with a visually striking graffiti print. There is a large TFT IPS display on the center that shows vape data in full color, and there has a car dashboard theme that features speedometer style wattage or temperature. Vape data on this display includes indicators for current temperature / power / resistance / voltage / battery indicator bars and more. You may also customize the background of the screen to your liking by uploading 5 to 10 wallpapers which is somewhat unique when it comes to mods. Powered by dual 18650 batteries (NOT INCLUDED) with the YiHi SX530 chip and the SXI-Q control system, the VK530 can fire up to 200W maximum output and supports SS316L, Ni200, Ti01, SX Pure, and Manual TCR Ni. The specification is in Chinese. This item also has other colors to choose. ![]() Avid Lyfe Dragon Mechanical Tube Mod Clone $26.99 The Avid Lyfe Dragon Mechanical Tube Mod Clone is a 24mm mech mod that is made from brass. It features a full engraved dragon pattern on the middle tube, which is very stunning. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original IJOY IVPC 9W 450mAh All-in-one Pod System Starter Kit Original Price $39.90, Now Only $28.89 The IJOY IVPC Kit is an updated easy-to-operate vaping kit with a mini body. Equipped with an OLED screen and an exclusive all-in-one button for convenient operation. The latest innovative POD structure with bottom e-liquid injection and side air intake, giving you a smoother MTL vaping experience without any leakage. The combination of organic fiber wicking material and ceramic heating elements to bring you pure flavor with good cloud production and a longer service life. Built-in IWEPAL control chip to offer you stable output. Newly increased short circuit / low voltage protection for safeguarding your vaping experience. Combined elegant aesthetic with beastly power and various functions. This item also has other colors to choose. ![]() Original IJOY Stick VPC 15W 1100mAh Mod + VPC 1.6 Pod System Starter Kit $29.90 The Original IJOY STICK VPC KIT consists of the Original IJOY Stick VPC 1100mAh mod and VPC 1.6 Pod. This item also has other colors to choose. Mod: The IJOY Stick VPC 1100mAh mod is a well-made pen-shaped vaping device with elegant and exquisite appearance and pocket friendly size, powered by 1100mAh rechargeable battery. It carries IWEPAL control chip internally to guarantee stable output The all-in-one metal button and indicator light not only give your hands generous feeling, but also illustrate the battery storage. Pod: The Stick VPC 1.6 Pod is equipped with a 2ml e-juice capacity VPC UNIPOD with an innovative side filling system for your easy operation. Built-in ceramic coil performs better than standard coils, giving you the tastier and purer flavor. ![]() CBD 320mAh All-in-one Vape Pen Starter Kit Clone $4.99 The CBD All-in-one Vape Pen Starter Kit Clone is a compact and convenient vape pen device for starters. It features 320mAh built-in battery, 1ml juice capacity, pre-installed 1.4ohm coil, 10mm diameter and USB charging port. Just fill some e-juice in and start to vape. It comes without any button, which means you just need to take a puff and it works automatically. This item also has other colors to choose. ![]() Replacement Tank Tube for Dvarw MTL RTA Clone $4.59 The replacement tank tube is made from PMMA and is suitable for Dvarw MTL RTA Clone. This item also has other colors to choose. ![]() Never Normal 510 Drip Tip Clone + Decorative Ring for 22mm Atomzier $4.79 The Never Normal 510 Drip Tip Clone and Decorative Ring are made from POM. The drip tip is suitable for all atomizers that fit 510 drip tip. The decorative ring is suitable for 22mm atomizers only. This item also has other colors to choose. ![]() Original Mowell Replacement Pod Cartridge for Shake 400mAh Starter Kit $4.60 The Original Mowell pod cartridge is a replacement pod cartridge for Mowell Shake 400mAh starter kit, it features PC construction and 2ml capacity.
214
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original IJOY AI 450mAh All-in-one Pod System Starter Kit Original Price $29.90, Now Only $23.39
The Original IJOY AI pod kit, with 450mAh built-in battery and 2.0ml refillable tank, is a portable and fashionable MTL starter kit best for nicotine salt. The pod coil adopts organic fiber cotton, which can make the liquid fully atomized and produce pure flavor, retaining the original taste and long lifetime. Moreover, the IJOY AI Pod Kit utilizes the advanced IWEPAL control chip for stable output and circuit protection. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.59 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() Original Vapesoon 810 Replacement Drip Tip for 528 Goon / Reload / Battle RDA $1.99 The 810 drip tip is made from resin with 11.7mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() Original Vapesoon 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.69 The 810 drip tip is made from resin with 12.3mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other Version to choose. ![]() Original Smoant Campbel Filter + Tank Clearomizer Original Price $42.99, Now Only $36.99 The Original Smoant Campbel Filter + Tank Clearomizer integrate innovatively as one piece, which allows vapers to vape with a mixture of e-liquid and soft drinks. The Filter comes with 3ml of capacity for soft drink, while the tank comes with 2ml of capacity for e-juice. The tank adopts Ni80 0.2ohm coil, which works well at 30 to 60 Watts. This item also has other colors to choose.
215
Original IJOY Captain 1865 162W TC VW Variable Wattage Box Mod Original Price $49.99,Now Only $42.99
The Original IJOY Captain 1865 TC VW BOX Mod is a new version of IJOY Captain. It is a fashionable and compact box mod with bright and large OLED screen. Powered by dual 18650 batteries (NOT INCLUDED), the IJOY Captain 1865 Box Mod can fire up to the max output of 162W with instant firing speed. Together with the features of the 6 optional vaping modes and NI / TI / SS / TCR temperature control, the IJOY Captain 1865 TC Mod will bring you amazing vaping experience. This item also has other colors to choose. ![]() The Goon 25 RDA Rebuildable Dripping Atomizer Clone $7.99 The Goon 25 RDA Clone is constructed from 304 stainless steel and in 25mm diameter. The Goon 25mm RDA Clone is with unique dual post and bridge clamp posts coil clamping system for dual coil build. It comes with adjustable side airflow and 810 wide bore POM drip tip. This item also has other colors to choose. ![]() Vertex Mechanical Box Mod Clone + RDA Kit $29.99 The Vertex Mechanical Mod Kit Clone consists of a Vertex Mechanical Box Mod Clone and a RDA. This item also has other colors to choose. Mod: The Vertex Mod Clone is a mechanical box mod constructed from POM and brass. Powered by quad 18650 batteries (NOT INCLUDED) in parallel and series, this mod is very powerful. And it features 510 threading connection and side venting holes. RDA: This RDA is constructed from Stainless steel. It features adjustable side airflow, wide bore POM drip tip and 510 threading connection. For the battery installation, please check the attached image. ![]() Original GeekVape Replacement Super Mesh X2 Coil for Aero Mesh Tank / Cerberus Tank $17.50 The authentic Geekvape Super Mesh X2 Coil is made of Kanthal and features 0.3ohm resistance which can reach the power from 30W to 45W (best at 30~40W). It can effectively enlarge the heating area and provide fast heating and huge vapor production. The Super Mesh X2 coil is compatible with Aero Mesh tank and Cerberus tank. This product comes with 5 PCS in a pack.
216
Original Riscle Pirate King V2 RDA Rebuildable Dripping Atomizer with BF Pin Original Price $36.90, Now Only $30.90
The Original Riscle Pirate King V2 RDA is a 24mm rebuildable dripping atomizer which use microporous airflow technology, with 527 air holes with a diameter of 0.2 mm, no leakage, cooling more uniform and taste better. The innovative smoke gathering adjustable e-liquid and gas mix structure, makes it's taste more rich. It supports the bottom filling and has a large storage capacity. The portable card cotton yarn design novice veteran is applicable. This RDA comes with a bottom feeder pin. This item also has other colors to choose. ![]() YFTK TIT Nipple V2 RDA Rebuildable Dripping Atomizer Clone $14.99 The YFTK TIT Nipple V2 RDA Clone is a 22mm rebuildable dripping atomizer which is constructed from 316 stainless steel. It features 510 threading connection and adjustable airflow. ![]() Coppervape Ubertoot UTA2 MTL RTA Rebuildable Tank Atomizer Clone with BF Pin $23.99 The Coppervape Ubertoot UTA2 RTA Clone is a 22mm MTL RTA constructed from 316 stainless steel. It features 5ml capacity, dual posts design, adjustable airflow and 510 threading connection. It also comes with POM drip tip and PEI tank tube. The Ubertoot UTA2 Style RTA allows the user to reduce the overall height of the device by 10mm and reduce the juice capacity to 2.5ml. This RTA comes with bottom feeder pin. ![]() Original Voopoo VFL 10W 650mAh Refillable Pod System Starter Kit $26.90 The Original Voopoo VFL Pod system, constructed of vacuum-plated aluminum alloy and plastic, it gives you smooth hand feeling. Powered by a built-in 650mAh battery, it can fire up to 10W maximum output with 0.8ml e-juice capacity. The VFL kit features 3 levels voltage to switch, you can always get your favorite taste with the 2.5V / 3.0V / 3.5V voltage options and preheating setting. Moreover, with the two different pore sizes of airflow, the pod can be placed accordingly to connect either airflow on both sides. Equipped with ceramic coil and U-shape airflow to bring pure air and keep the original flavor. This item also has other colors to choose. ![]() Coppervape Replacement 510 Drip Tip for Ubertoot UTA2 MTL RTA Clone $1.99 The Coppervape 510 Drip Tip is made from PEI, and it is suitable for Ubertoot UTA2 MTL RTA Clone and other atomizers compatible with 510 drip tip. ![]() Coppervape Replacemenr Tank Tube for Ubertoot UTA2 MTL RTA Clone $3.59 The replacement tank tube is made from PEI and is suitable for Coppervape Ubertoot UTA2 MTL RTA Clone. This item also has other Version to choose.
217
Original Vicious Ant 200W TC VW Variable Wattage Box Mod $49.99
The Original Vicious Ant Mod is a 200W TC VW box mod powered by dual 18650 batteries (NOT INCLUDED). the vaping data will be displayed on the bright OLED screen. Also, it has RGB LED lights built-in with five different lighting modes. Multiple modes including Ni / Ti / SS / TCR / KA are available to choose. This item also has other colors to choose. ![]() Original Fumytech Rodeo Mesh Sub Ohm Tank Clearomizer Original Price $18.90, Now Only $14.99 The Original Fumytech Rodeo Mesh Tank is a 28mm sub ohm tank Clearomizer with 6.5ml juice capacity with bubble tank. Convenient top fill design makes it simple to fill with your e-liquid. With three airflows on the bottom, it provides rich flavor, even heating, no burn and zero leaking. It is compatible with most powerful mods and the mesh coil effectively enlarge the heating area to enjoy the fast heating process and vapor production. ![]() ShenRay Vapor Giant V5 XL RTA Rebuildable Tank Atomizer Clone $29.99 The ShenRay Vapor Giant V5 XL RTA Clone is a rebuildable tank atomizer constructed from 316 stainless steel. It comes with ultem tank tube and drip tip. It features 14ml big capacity, 32.5mm diameter and adjustable airflow. The ShenRay Vapor Giant V5 XL RTA Clone has wider deck for easy coil building and threaded top lid for top filling. ![]() Original GeekVape Nova 200W TC VW Box Mod + Alpha Sub Ohm Tank Kit Original Price $92.90, Now Only $80.99 The Original GeekVape Nova 200W Mod Kit consists of the GeekVape Nova 200W TC VW Box Mod and Alpha Sub Ohm Tank. This item also has other colors to choose. Mod: The Nova mod is a high-performance device that powers up to 200W with dual 18650 batteries (NOT INCLUDED). Powered by the advanced AS chipset that has unmatched speed and power. Designed with elegant aesthetics, Nova is built with premium quality aluminum alloy and beautifully crafted resin, delivering an exquisite contrast that portrays simplicity and elegance. Tank: The Original GeekVape Alpha Sub Ohm Tank is a clearomizer with 25mm diameter, 0.2ohm resistance and 4ml capacity. It is the flagship sub ohm tank fully developed by Geekvape Team, it presents unrivaled vaping experience to users with its meticulously made MeshMellow Coil System, which features the purest flavor from the very first inhale. Unlike any other coil of its kind, the MeshMellow coils uses the best cotton to ensure the perfect flavor. ![]() Coppervape Replacement MTL Airflow Pin for Caiman V.4 RDA Clone $1.99 The replacement MTL airflow pin is made from 316 stainless steel with 1.2mm bore. It is suitable for Coppervape Caiman V.4 MTL RDA Clone. ![]() Original Fumytech Clapton Kanthal A1 Wire Pre-built Coils Original Price $6.99, Now Only $5.59 The Original Fumytech Clapton Kanthal A1 Pre-built Coils Heating Wire is made from Kanthal A1 wires and features 0.6ohm resistance and 24GA + 32GA wires. This heating wire will be a good vaping choice for DIY. This product comes with 10 PCS in 1 pack. This item also has other Version to choose. ![]() Original Fumytech Triple Fused Clapton Kanthal A1 Wire Pre-built Coils Original Price $10.90, Now Only $5.59 The Original Fumytech Triple Fused Clapton Kanthal A1 Pre-built Coils Heating Wire is made from Kanthal A1 wires and features 0.2ohm resistance and 24GA x 3 + 32GA wires. This heating wire will be a good vaping choice for DIY. This product comes with 4 PCS in 1 pack. This item also has other colors to choose. ![]() Original Fumytech Replacement Bubble Tank Tube for Rodeo Sub Ohm Tank Clearomizer $2.90 The replacement tank tube is made from glass with 6.5ml of juice capacity and is suitable for Fumytech Rodeo Sub Ohm Tank Clearomizer. ![]() Original Fumytech Replacement Mesh Coil for Rodeo Sub Ohm Tank Clearomizer Original Price $12.90, Now Only $9.99 The Fumytech Rodeo Mesh Coil comes with 0.13ohm resistance. It is suitable for Rodeo Sub Ohm Tank Clearomizer. The rodeo coil can be compatible with most popular tanks in the market, the mesh coil effectively enlarge the heating area to enjoy the fast heating process and vapor production. This product comes with 3 PCS in a pack.
218
Original Wismec Luxotic DF 200W TC VW Variable Wattage Squonk Box Mod $53.06
The Original Wismec Luxotic DF TC Box Mod, powered by dual 18650 batteries (NOT INCLUDED), can fire up to a output from 1W to 200W with advanced VW / TC modes. The Luxotic DF mod could be vaped as squonk mod with a 7ml refillable e-liquid bottle and regular box mod to satisfy your different vaping needs. The multiple protection systems are applied to make the device much safe and reliable. Together with a large 1.3-inch display, easy-to-go user interface, spring-loaded 510 pin and 2A fast charging, the Luxotic DF mod will bring you a really simple yet strong vape. This item also has other colors to choose. ![]() Original Vandy Vape Paradox RDA Rebuildable Dripping Atomizer with BF Pin Original Price $37.99, Now Only $27.99 The Original Vandy Vape Paradox RDA is a 24mm rebuildable atomizer, it adopts new annular airflow design which makes air flow into the annular, converge in the middle then to the mouth. This new airflow design will bring stronger taste and larger clouds. Top dome form bell struture makes the airflow more smooth. This RDA comes with three types of drip tips. You can enjoy different vaping experience by your preference. This RDA comes with BF pin. This item also has other colors to choose. ![]() Original IJOY Limitless LMC Sub Ohm Tank Clearomizer Original Price $12.99, Now Only $6.99 The Original iJoy Limitless Sub Ohm Tank expands upon iJoy's unique Chip Coil technology, designed to deliver superb performance while catering to a flavor-focused experienced, coupling with a convenient threaded top-fill. The iJoy Limitless Sub Ohm Tank features 2ml capacity and 25mm diameter, with an aesthetic that moves towards a compact yet streamlined design. It presents a disc conductor design that dramatically increase electricity conductivity, with pre-installed dual horizontal coils that can be rewicked as needed to extend the life of the coil. With no airflow present, the result is an astoundingly pure flavor recreation with a 0.3ohm Chip Coil with a range of 40W to 80W and a 0.6ohm Chip Coil with a range of 20W to 40W. A unique 510 drip tip adaptor is included in the tank, providing room for customizable and catering to user's top cap personalization. ![]() Original Joyetech RunAbout 480mAh Pod System Starter Kit $30.59 The Original Joyetech RunAbout kit is an innovative vape pod system kit which is inspired by a yacht with a sleek design. Constructed by stainless steel, Joyetech RunAbout pod kit has a comfortable hand feeling for better vaping experience, and its mouthpiece is designed ergonomically, it can fit your mouth perfectly. Powered by a 480mAh built-in battery, the RunAbout also features LED indicator to display battery status. Moreover, the pod cartridge features a 2ml e-juice capacity to satisfy your daily need, which supports side filling system and better MTL flavors. And inside there're two 2ml pods for your favorite e-juice. It has a fire key, and the battery indicator will inform you at low voltage, it's a perfect device for your relax time. This item also has other colors to choose. ![]() Original Wismec Luxotic DF 200W TC VW Squonk Box Mod + Guillotine V2 BF RDA Kit $72.96 The Original Wismec Luxotic DF kit consists of Luxotic DF 200W box mod and Guillotine V2 RDA. This item also has other colors to choose. Mod: The Original Wismec Luxotic DF TC Box Mod, powered by dual 18650 batteries (NOT INCLUDED), can fire up to a output from 1W to 200W with advanced VW / TC modes. The Luxotic DF mod could be vaped as squonk mod with a 7ml refillable e-liquid bottle and regular box mod to satisfy your different vaping needs. The multiple protection systems are applied to make the device much safe and reliable. Together with a large 1.3-inch display, easy-to-go user interface, spring-loaded 510 pin and 2A fast charging, the Luxotic DF mod will bring you a really simple yet strong vape. RDA: The Guillotine V2 RDA is a 24mm atomizer featuring the easy dual posts build deck and the bottom adjustable airflow control to bring you an extremely excellent vaping experience with optimal flavor and intense vapor. This RDA comes with bottom feeder pin. ![]() SteamTuners T8 510 Drip Tip Clone for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The SteamTuners T8 510 Drip Tip Clone is made from stainless steel. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() Original Advken Doctor Coil Pre-loaded Cotton Wick for RDA / RTA / RDTA $5.79 The Original Advken Doctor Coil Pre-loaded Cotton is made of 100% natural 129A organic cotton. It comes without any pesticides, and it is pure and unbleached, impeccable taste. It also has long fiber, wick fast and superior absorption. It is easy to wick and suitable for all RDA, RTA and RDTA. This product comes with 50 PCS in 1 pack. ![]() Vapeasy 18650 Battery Adapter Tube for 20700 Battery Mod $2.99 The Vapeasy 18650 Battery Adapter Tube is suitable for 18650 battery, which made it possible to use 18650 in 20700 battery mods. This product comes with only 1 piece.
219
SOB Uno Bersikulo Hybrid Mechanical Mod Clone $14.99
The SOB Uno Bersikulo Mechanical Mod Clone features Resin chassis, brass hybrid top cap and tube, Ultem fire button on the side and copper battery door. It is powered by single 18650 battery (NOT INCLUDED). There may be a little color difference due to resin material. This item also has other colors to choose. ![]() Comp Lyfe Skull HK Hybrid Mechanical Tube Mod Clone $25.49 The Comp Lyfe Skull HK Mod Clone is a mechanical tube mod with a diameter of 28.5mm which is constructed from brass. It is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). The fire button is activated by magnets. This item also has other colors to choose. ![]() Original Oumier Wasp Nano Mini RDA Rebuildable Dripping Atomizer with BF Pin $11.99 The Original Oumier Wasp Nano Mini RDA is constructed from stainless steel in 22mm diameter. The Original Oumier Wasp Nano Mini RDA is with large build deck design for single coil build. This RDA has direct side airflow design to ensure fabulous vaping experience. The RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Wismec Guillotine V2 RDA Rebuildable Dripping Atomizer with BF Pin $26.40 The Guillotine V2 RDA is a 24mm atomizer featuring the easy dual posts build deck and the bottom adjustable airflow control to bring you an extremely excellent vaping experience with optimal flavor and intense vapor. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() ShenRay Citadel RDA Rebuildable Dripping Atomizer Clone with BF Pin $12.88 The ShenRay Citadel RDA Clone is a rebuildable dripping atomizer which is constructed from 316 stainless steel with a diameter of 22mm. It comes with PEEK insulators and black Delrin drip tip. The Citadel RDA Clone has unique Ultem chamber reducer to enhance flavor and warmth, dual sided slotted post with large flathead securing set screws and Hadaly style airflow angled downward for minimizing leaks. This RDA comes with BF pin. ![]() Original Tesla GG 380mAh TC VV Pod System Starter Kit with Bluetooth $31.99 The Original Teslacigs GG kit is a tiny and compact vape pod system kit, which can contain 2ml e-liquid and is suitable for nicotine salt. Constructed by aluminum and PC material, it has super light weight and tiny size for easy carrying. Powered by a built-in 380mah battery, it only needs 1.3 hours to be fully charged. Moreover, with the innovative gravity induction boot mode, it is super easy to operate. The biggest highlight of the GG pod system is that it supports the connection to the APP on your phone via Bluetooth, you can adjust voltage, temperature, LED light colors on the APP and see more data about the device. Though it is compact, it still has multiple protections including over 10s protection, low-voltage alert, short-circuit protection. This item also has other colors to choose. ![]() SOB Uno Bersikulo Hybrid Mechanical Mod Clone + Outlaw RDA Kit Clone $21.99 The SOB Uno Bersikulo Mech Kit Clone consists of Uno Bersikulo Mech mod Clone and Outlaw RDA Clone. This item also has other colors to choose. Mod: The SOB Uno Bersikulo Mechanical Mod Clone features Resin chassis, brass hybrid top cap and tube, Ultem fire button on the side and copper battery door. It is powered by single 18650 battery (NOT INCLUDED). There may be a little color difference due to resin material. RDA: The Outlaw RDA Clone is constructed from stainless steel with 24mm diameter. The deck features classic dual post style design and comes with a deep juice well. The airflow can be adjusted by dual airslots on each side. The heat resistant POM drip tip can protect your mouth from heat. ![]() Original IJOY Replacement Coil for Limitless LMC Sub Ohm Tank Clearomizer Original Price $14.99, Now Only $7.99 The Original IJOY Limitless Coil is a dual twisted coil which features 0.6ohm resistance with an output power from 20W to 40W. It is compatible with Limitless LMC sub ohm tank. This product comes with 5 PCS in a pack.
220
Goon 25mm RDA Clone Rebuildable Dripping Atomizer with BF Pin $7.59
The Goon 25mm RDA Clone is constructed from stainless steel and in 24mm diameter. The Goon 25mm RDA Clone is with unique dual post and bridge clamp posts coil clamping system for dual coil build. It comes with adjustable side airflow and 810 wide bore POM drip tip. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Blitz Hermetic RDA Rebuildable Dripping Atomizer with BF Pin Original Price $30.00, Now Only $20.99 The Original Blitz Hermetic RDA is an exquisite and innovative rebuildable atomizer with 22mm diameter. It adopts a unique ceramic clamp system build deck with convenient single coil building and high compatibility with various heating coils. With a bottom feeder pin, the Hermetic RDA also can be compatible with Squonk Mods. Together with bottom airflow design utilizing Bridged Airflow Technology for huge vapor and e-juice leakage prevention, the Blitz Hermetic will bring you a magic vaping. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() ShenRay Wave RDA Rebuildable Dripping Atomizer Clone with BF Pin $10.99 The ShenRay Wave RDA Clone is a 22mm rebuildable dripping atomizer which is constructed from 316 stainless steel. It features dual post build deck, single coil configuration and adjustable side airflow. This RDA comes with bottom feeder pin. ![]() Ulton Citadel RDA Rebuildable Dripping Atomizer Clone with BF Pin $12.99 The Ulton Citadel RDA Clone is a rebuildable dripping atomizer which is constructed from 316 stainless steel with a diameter of 22mm. It comes with PEEK insulators and black Delrin drip tip. The Ulton RDA Clone has unique Ultem chamber reducer to enhance flavor and warmth, dual sided slotted post with large flathead securing set screws and Hadaly style airflow angled downward for minimizing leaks. This RDA comes with bottom feeder pin. ![]() Original AFK Studio Rock Crystal Small Waistline Hybrid Mechanical Tube Mod + RDA Kit Original Price $399.99, Now Only $388.88 The Original AFK Studio Rock Crystal Small Waistline kit's button is at the bottom, which reserves AFK the original case design at the bottom. Its structure is consistent with engraved series mechanical lever, the top of mechanical lever is the direct connect structure (atomizer directly contact with the battery). What's more, the outside of the body is Swarovski crystal inlaided by hand. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The replacement 510 drip tip is made from resin and is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() Original Digiflavor Replacement Airflow Module for Etna RDA $6.90 The Original Digiflavor Airflow Module is used to change the air restriction to provide a concentrated and intense airflow for Etna RDA. The air inlet duct with hexagonal profile, unscrewable for the installation of the modules. This product comes with 4 pcs in a pack. ![]() ShenRay Replacement Top Cap + 510 Drip Tip for Wave BF RDA Clone $3.99 The replacement top cap and 510 drip tip are made from POM and is suitable for ShenRay Wave BF RDA Clone. This item also has other colors to choose.
