302440
822
181
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
ShenRay Mecanic Hybrid Mechanical Mod Clone $22.99
The ShenRay Mecanic Mechanical Mod Clone is a 25mm mech mod with hybrid top cap for more power hit. It is constructed from brass. It features 4 point contact system and soft pressure point for comfortable activation. The recessed button can reduce risk of auto firing. The mod is powered by single 18650 / 20650 / 20700 / 21700 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original SMOKTech SMOK TFV8 Baby V2 Sub Ohm Tank Clearomizer $21.39 The Original SMOKTech SMOK TFV8 Baby V2 tank adopts two powerful coils, Baby V2 A1 Coil with super large heating area and Baby V2 A2 Coil with dual heating cores, fully satisfying the vaping fans' pursuit of dense flavor and massive cloud. The tank comes with 5ml of juice capacity to meet your daily need. This item also has other colors to choose. ![]() Original Augvape Skynet Sub Ohm Tank Clearomizer $19.49 The Original Augvape Skynet Tank is a sub ohm tank that has 24mm diameter and 5.1ml of juice capacity (with bubble glass tube). It also has a standard glass tube, which has 3.6ml of juice capacity. The Skynet features threaded top fill system and triple adjustable air slots for smooth airflow. It utilizes Mesh 0.15 coil which works well at 60 to 80 Watts. This item also has other colors to choose. ![]() Original Wotofo Profile RDA Rebuildable Dripping Atomizer with BF Pin Original Price $32.99, Now Only $24.99 Designed by Wotofo and Mrjustright1, this RDA aims to free every single flavor in you juice to your taste sensation. It is the flavor profile interpreter for your juice. The original Wotofo Profile RDA is an innovative BF RDA that features unique clamp style dual post build deck, which is easy to switch between mesh and wire coils. The RDA has a 24mm sleeve with multiple airholes for accurate airflow. It supports up to 30 puffs at 75W before needing to re-saturate the wick when using pancake wicking method. What's more, this RDA supports both top refilling and bottom feeding. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original AFK Studio EUGENE Growl RTA Rebuildable Tank Atomizer Original Price $75.00, Now Only $62.99 Designed by AFK Studio, the EUGENE Growl RTA is made from high-quality Damascus steel, presenting a high-end rebuildable tank atomizer. It measures 24mm diameter and has 3.5ml of juice capacity. The Growl RTA is interchangeable between single coil and dual coil deck, meeting your different vaping needs for coil installation. And it comes with adjustable bottom airflow for super smooth vaping experience. This item also has other colors to choose. ![]() Original Tesla Punk Mini 85W TC VW Variable Wattage Box Mod + Resin Tank Kit $57.99 The Original Tesla Punk 85W Resin Tank Kit consists of Tesla Punk 85W Mod and Tesla Resin Tank. This item also has other colors to choose. Mod: The Original Tesla Punk Mini is the slim version of Punk 220W mod, which is powered by single 18650 battery (NOT INCLUDED) and the maximum output is 85W. It is constructed from zinc alloy, ABS and PC, and it still comes with the same steampunk style PCB, which you can see through the transparent PC panel. The portable size and retro looking will catch everyone's eyes when you show off this to your friends. Tank: The Original Tesla Resin Tank measures 25.5mm diameter and has 4ml of juice capacity with standard glass tube and 6ml with bulb glass tube. It adopts 0.18ohm TS-XX Coil for 60 to 110 Watts and 0.15ohm TS-120X Coil for 70 to 120 Watts. ![]() Original Tesla XT 220W TC VW Variable Wattage Mod + Tallica Mini Tank Kit $73.99 The Original Tesla XT Kit consists of Tesla XT Mod and Tallica Mini Tank. This item also has other colors to choose. Mod: The Original Tesla XT TC VW Box Mod is constructed from zinc alloy, with fancy lighting design and comfortable hand-feel. The Tesla XT Mod can fire up to 220W with dual 18650, 20700, 21700 batteries (NOT INCLUDED). With comprehensive temperature control suite and various of settings, you can enjoy the fun of regulated mod. There are 7 kinds of RGB LED display lights inside, providing a more stunning appearance when vaping. Tank: The Tesla Tallica Mini Tank is designed for the Tesla XT box mod, which has 4ml juice capacity and supports 110W max output. It has large airflow slots on the base, and the triangular airflow can easily adjusted to get different vaping experience. With slide refilling design, it is simple to fill e-liquid, and the plug-and-pull coil replacement design ensures easy coil installation. ![]() Vapeasy SteamTuners T9 510 Drip Tip Clone for RDA / RTA / Sub Ohm Tank $2.99 The Vapeasy SteamTuners T9 510 Drip Tip Clone is made from POM. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
182
SOB V2 Hybrid Mechanical Tube Mod CLone $8.99
The SOB V2 mechanical tube mod Clone is made from brass, resin and stainless steel. It has 27mm diameter and comes with hybrid top cap for more power hits. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Avid lyfe Optic II Hybrid Mechanical Tube Mod Clone $23.89 The Avid lyfe Optic II mechanical tube mod Clone is made from brass. It has 24mm diameter and comes with hybrid top cap for more power hits. The mod is powered by single 18650 battery (NOT INCLUDED). The fire button is activated by magnets. This item also has other colors to choose. ![]() Hussar The End RTA Rebuildable Tank Atomizer Clone $25.99 Hussar The End RTA Clone is a 22mm rebuildable tank atomizer with 3.5ml capacity. It is constructed from 316 stainless steel and ultem tank. The deck has dual posts design for single coil configuration. The tank comes with bottom airflow for optimal flavor. This RTA comes without any drip tip. This item also has other colors to choose. ![]() SOB Uno Bersikulo Hybrid Mechanical Mod Clone + Extension Tube Kit $21.99 This mod kit is combined by SOB Uno Bersikulo Hybrid Mechanical Mod Clone and Extension Tube Kit. The SOB Uno Bersikulo Mechanical Mod Clone features POM chassis, brass hybrid top cap and tube, Ultem fire button on the side and copper battery door. It is powered by single 18650 battery or dual 18650 batteries with extension tube (NOT INCLUDED). This item also has other Version to choose. ![]() Original SMOKTech SMOK Replacement A1 Coil Head for TFV8 Baby V2 Sub Ohm Tank $9.69 This A1 coil is used for SMOKTech TFV8 Baby V2 Sub Ohm Tank, it has a large hole inside for enlarging the area to cover the cotton. The Baby V2 A1 coil head is made of stainless steel, the resistance is 0.17ohm and will work well at 90~140 watts. This product comes with 3 PCS in 1 pack. This item also has other Version to choose. ![]() Original Wotofo Mesh Style Pre-built Coil $3.99 The Wotofo Mesh coil features fast heating process and 0.15 ohm resistance which supports 45~65W power output, it will bring you massive vapor. This product comes with 10 PCS in 1 pack. ![]() 18650 Extension Tube for SOB Uno Bersikulo Hybrid Mechanical Mod Clone $6.99 This Extension Tube is used for SOB Uno Bersikulo Mechanical Mod Clone, it is made of brass and can hold one more single 18650 battery (NOT INCLUDED).
183
Purge Slam Piece Hybrid Mechanical Tube Mod Clone Original Price $26.00, Now Only $24.99
The Purge Slam Piece Mod is a 30mm mechanical tube mod that is made from brass. It can be compatible with single 18650 / 20700 / 21700 battery (NOT INCLUDED), coming with hybrid top cap for more power hits. The fire button is activated by magnets. This item also has other colors to choose. ![]() Purge Pandora Hybrid Mechanical Tube Mod Clone $22.99 The Purge Pandora Mechanical Mod Clone is made from brass, powered by single 18650 or 20700 battery (NOT INCLUDED). It features hybrid connection and beautiful hollowed out pattern. It comes with a 18650 battery adapter. The fire button is activated by magnets. This item also has other colors to choose. ![]() Original Asmodus Oni 167W DNA250 TC VW Variable Wattage Box Mod Original Price $119.95, Now Only $95.99 The Original Asmodus Oni 167W Mod is powered by Official Evolv DNA250 Chip. Powered by dual 18650 batteries (NOT INCLUDED), the mod can reach maximum output to 167W. By exchanging the batteries to a LiPo battery pack (NOT INCLUDED), with the help of Escribe software, the mod can be boosted to 250W. This item also has other colors to choose. ![]() Hammer of God HOG V4 Parallel Full Mechanical Box Mod Clone $37.99 The Hammer of God HOG V4 full mechanical mod Clone is with dual parallel-series configuration granting both a doubled voltage output and a doubled amperage limit compared to simply a parallel or series configuration. The Hammer of God V4 box mod Clone accepts four 20700 batteries (not included). The mod is constructed from aluminum alloy (surface with anodic oxidation treatment process). This item also has other colors to choose. ![]() Original Eleaf iStick Amnis 900mAh 30W Starter Kit with GS Drive Tank $27.99 This iStick Amnis with GS Drive, a sleekly designed and ultra portable kit, presents an astounding vaping experience with the purest flavor by utilizing a new GS Air M (mesh) coil. The iStick Amnis features a rubber paint finish giving you a softer and smoother feel. Although small in size, the new GS Drive atomizer is skillfully engineered with retractable top fill solution for fast and easy refilling as well as a childproof system. The LED light on the iStick Amnis cycles through four colors to let you know at a glance how much battery life is remaining. Start vaping without compromise, and start with Eleaf iStick Amnis kit. This item also has other colors to choose. ![]() Original IJOY Avenger Baby 108W TC VV VW Mod + Diamond Baby tank Kit $75.59 This Original IJOY Avenger Baby Kit consists of IJOY Avenger Baby Mod and Diamond Baby Tank. This item also has other colors to choose. Mod IJOY AVENGER BABY is the world's first AI voice control mod supporting dual 20350 batteries (BATTERY INCLUDED). A Portable kit with cool appearance design and multi colors brings you the sense of High-Tech. Featuring with the big fire button on the side, colorful OLED screen and wave to voice RGB LED light. Supporting NI/TI/SS temperature control mode, POD mode, quick charging and firmware upgrade. Also, it can be compatible with big atomizer. Equipped with dual 20350 will give your longer time vaping experience. Tank The IJOY Avenger Diamond Baby Tank is a 30mm sub ohm tank that adopts a DMB-Mesh coil head (Pre-installed), which comes with 0.18ohm resistance and supports output at 40~80W. Another coil is DMB-DM coil head head with 0.15ohm resistance and supports output at 40~80W. The IJOY AVENGER BABY KIT will be your best choice for starter kit. ![]() Purge Pandora Hybrid Mechanical Mod Clone + Carnage RDA Kit Clone $28.99 The Purge Pandora Mech Kit consists of Purge Pandora Mechanical Mod Clone and Carnage RDA Clone. This item also has other colors to choose. Mod: The Purge Pandora Mechanical Mod Clone is made from brass, powered by single 18650 or 20700 battery (NOT INCLUDED). It features hybrid connection and beautiful hollowed out pattern. It comes with a 18650 battery adapter. The fire button is activated by magnets. RDA: The Carnage RDA Clone is constructed from stainless steel in 25mm diameter. The build deck features dual post design, and the posts are not the same style. The negative post utilizes flathead grub screw, while the positive post adopts clamp design with dual flathead heads. The internal cap comes with single-hole airslot and triple-hole airslot, which allows you to adjust the configuration to your favorite one. This RDA comes with bottom feeder pin. ![]() Original Vapesoon Replacement Glass Tank Tube for Vandy Vape Revolver RTA $1.69 The Vapesoon Replacement Glass Tank Tube has 3ml of juice capacity and is suitable for Original Vandy Vape Revolver RTA. This item also has other Version to choose.
184
Original Dovpo Punisher 90W TC VW Variable Wattage Box Mod $32.49
The Dovpo Punisher Mod is one of the most compact 21700 box mods and it can support maximum output power to 90 Watts with single 18650 / 20700 / 21700 battery (NOT INCLUDED). It has a 0.96 inch OLED display screen to view all necessary data. With an independent Menu button, it's way easier for you to go through menu and settings. This item also has other colors to choose. ![]() Original S-Body SBody Legend 2 DNA75 75W TC VW Variable Wattage Box Mod Original Price $150.00, Now Only $75.49 The Original Sbody Legend II Mod adopts Evolv DNA75 chipset and can reach maximum power to 75W with single 18650 / 26650 battery (NOT INCLUDED). Constructed from Zinc Alloy and Resin material, the S-body Legend 2 Mod feels smooth on the surface. It has spring 510 connector and ventilation holes on the battery door. This item also has other colors to choose. ![]() ULTON Salix MTL RDA Rebuildable Dripping Atomizer Clone with BF Pin + Extra Cap $21.39 The ULTON Salix MTL RDA Clone is a 22mm rebuildable squonking atomizer. It has staggered post heights, deep juice well and slotted posts so you don't have to pre-trim your coil legs. Besides, the ULTON Salix RDA also has bottom feed pin and ultra reduced chamber, it is designed for mouth to lung but also for restricted lung vape, and it can be vaped by fully open without cassette. ![]() Original OVNS JC01 400mAh Pod System Starter Kit $19.89 The Original OVNS JC01 Vape Pod System Starter Kit is for CBD Oil and features a compact design and small size. The JC01 has a built in battery with 400mAh capacity and is compatible with JC01 CBD tank. OVNS JC01 comes with 2 different pods including JC01 CBD Pod and JC01 E-Liquid Pod. CBD Pod equip with 1.5ohm resistance ceramic coil has 0.7ml e-juice capacity that bring pure flavor to you, and the JC01 E-Liquid Pod with 2.0ohm resistance and holds up to 0.7ml of e-juice with the same glass tank section. Not only are they can use JUUL battery, but the JUUL Pod also can br used on OVNS JC01. OVNS JC01 Starter Kit uses smart MCU chipset with airflow control which gives you better instant inhale experience. Moreover, the 4 LED lights will show working status, when JC01 is working, the No.4 LED light will be on, and above 3 LED lights are power indicators. This item also has other colors to choose. ![]() Original OVNS Duo 7.2W 400mAh Dual Vaping Pod System Starter Kit $22.99 This OVNS Duo Dual Vaping Pod System Kit comes with dual vaping pods, you can enjoy 2 flavors in one device. It features compact design and portable size, which looks like Cookie. It is powered by 400mah built-in battery and can be charged via Micro USB port. The cartridge can hold 2ml liquid and it equips 2.0ohm coil head for massive cloud and nice flavor especially designed for MTL vaping. This device has no fire button and is designed with air switch for vaping, easy to use. This item also has other colors to choose. ![]() Original Dovpo Punisher 90W TC VW Variable Wattage Box Mod + DJ Atomizer Kit $40.89 The Dovpo Punisher 90W Kit consists of Dovpo Punisher Mod and DJ Tank Atomizer. This item also has other colors to choose. Mod: The Dovpo Punisher Mod is one of the most compact 21700 box mods and it can support maximum output power to 90 Watts with single 18650 / 20700 / 21700 battery (NOT INCLUDED). It has a 0.96 inch OLED display screen to view all necessary data. With an independent Menu button, it's way easier for you to go through menu and settings. Tank: The Dovpo DJ Tank atomizer is a 24mm sub ohm tank which has a capacity of 2.3ml with regular glass tube and can be extended to 3.0ml with bubble glass tube. It adopts a Kanthal A1 Mesh coil with 0.15ohm resistance, which works well at 50 to 80 Watts. ![]() Original Vapor Storm Puma 200W TC VW Variable Wattage Box Mod + Hawk Tank Kit Original Price $65.00, Now Only $47.99 The Original Vapor Storm Puma Kit consists of Vapor Storm Puma Mod and Hawk Tank. This item also has other colors to choose. Mod: The Original Vapor Storm Puma Mod has sleek appearance and is versatile with its multiple output modes. Powered by dual high rate 18650 batteries (NOT INCLUDED), it is able to reach 200W in wattage mode. In temperature control mode, Puma supports Ni, Ti, SS316 and TCR. In bypass mode, the output can even be higher than 200W and the maximum is 230W. Puma will definitely provide you with different vaping experience. Tank: The Original Vapor Storm Hawk Tank is a 24mm sub ohm tank with 2ml of juice capacity. It comes with a 0.5ohm coil head and bottom airflow control for pure and optimal flavor.
185
The Purge Slam Piece Mod is a 30mm mechanical tube mod that is made from brass. It can be compatible with single 18650 / 20700 / 21700 battery (NOT INCLUDED), coming with hybrid top cap for more power hits. The fire button is activated by magnets. This item also has other colors to choose. ![]() Original IJOY Combo RDA Rebuildable Dripping Atomizer Original Price $27.99, Now Only $11.99 Designed by IJOY, the Combo RDA is a 25mm diameter atomizer with bottom airflow system. It comes with very innovative spring design deck which is a "tool-less" RDA, that means you don't need tweezers or tools for setting coils on posts, the 24K gold plating allows for greater conductivity. Deep juice wall can storage more juice. The Combo RDA is the perfect RDA for those looking for a simple, fashionable and flavor based RDA! This item also has other colors to choose. ![]() Original ThunderHead Creations THC Tauren RDTA Rebuildable Tank Atomizer with BF Pin Original Price $56.80, Now Only $26.99 The Original ThunderHead Creations THC Tauren RDTA is a 24mm rebuildable dripping tank atomizer with 2ml of juice capacity. It features simple and unique 45-degree build deck, 28 micro airholes on double sides for strong throat hit. The RDTA supports easy refill system and bottom feeding without leaking. 810 Ultem drip tip is included. This item also has other colors to choose. ![]() Original Civanpor Atena RDA Rebuildable Dripping Atomizer with BF Pin Original Price $45.00, Now Only $26.99 The Original Civanpor Atena RDA is a 24mm rebuildable squonking atomizer constructed from POM (cap) and 316 stainless steel (base). It features dual post build deck and has quad terminals for easy building. The RDA comes with side airflow for great flavor and massive clouds. This item also has other colors to choose. ![]() Caiman MTL RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.99 The Caiman RDA Clone is a 22mm RDA designed for MTL vaping. Constructed from 316 stainless steel, it comes with dual posts for easy coil building. The RDA has 5 airholes at both sides for adjustable bottom airflow. Besides, the airflow control set can be replaced with different one for different experience. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() YFTK Monarchy RDA Rebuildable Dripping Atomizer Clone with BF Pin $17.99 The YFTK Monarchy RDA Clone is a 22mm RDA constructed from 316 stainless steel. It comes with black Delrin removable drip tip, single post build deck and side airflow system. This RDA is squonk-ready. This RDA comes with bottom feeder pin and decorative ring. ![]() Original SMOKTech SMOK G-Priv 220W Touch Screen TC VW Mod + TFV8 Big Baby Kit $79.99 The Original SMOK G-Priv 220W Touch Screen Box Mod features maximum wattage of 220W, comprehensive temperature suite, and a modernized chassis with 2.4 Inch display and class-leading form factor. The G-Priv 220W measures 85mm by 58.5mm by 28mm, optimally constructed for durability and usability in-mind, utilizing a lightweight yet durable zinc alloy chassis with carbon fiber battery door for a striking impression. The visual prowess lies within the highly impressive 2.4 Inch Touch Screen display, providing intuitive visual interface and easy-to-read graphical UI for unprecedented operations. To synergize with the entire system, the addition of shatter-resistance glass and screen-lock button offers a simplified experience while providing a sophisticated output capability. Similar to other SMOK's output device line-up, performance is not hindered despite the plethora of functionalities. The G-Priv is capable of firing up to 220W with comprehensive temperature control, supporting Ni200 Nickel, Titanium, and Stainless Steel heating elements. Beautifully constructed with the integration of intelligent functionalities within a touch-screen form, the SMOK G-Priv 220W TC Box Mod is a technological breakthrough in output technology. The Original SMOKTech TFV8 Big Baby is a bigger baby beast that let you enjoy more clouds & more freedom & more fun. It adopts the same baby beast engines: V8 Baby-X4 Core, V8 Baby-T6 Core and V8 Baby RBA. Meanwhile, both 5ml bigger e-juice capacity and more vapors will let you enjoy pleasant vaping time. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.99 The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.99 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() Original Squid Industries Skin Sticker for Double Barrel V2.1 Box Mod $8.99 The Original Squid Industries Skin Sticker is used for Double Barrel V2.1 Box Mod, you can change the skin of your Double Barrel Mod according to your mood. This item also has other colors to choose. ![]() Original Squid Industries Silicone Sleeve Case for Double Barrel V2.1 Box Mod $6.99 The protective silicone sleeve case is suitable for Squid Industries Double Barrel V2.1 Box Mod. It will give your mod a perfect protection and give you a comfortable feeling. YFTK Replacement Top Cap for Monarchy RDA Clone $7.29 This replacement top cap is made from PEI and is suitable for YFTK Monarchy RDA Clone. This item also has other colors to choose. ![]() Original Vapesoon VSE 350mAh Electric Automatic Cleaner for IQOS $14.99 The Vapesoon VSE Electric Automatic Cleaner is designed for IQOS, it is the second generation, 2018 newest. This Vapesoon VSE Cleaner featured with a 350mAh battery capacity, giving you a highspeed rotation, which makes cleaning faster, easier and more thorough. Just one touch, the cleaning can be finished within 5~10 seconds.
186
Phoenix Mechanical Tube Mod Clone Original Price $25.99, Now Only $12.99
The Phoenix Mechanical Tube Mod Clone is a 22mm mech mod made from copper. It comes with a non-hybrid connector and lockable mechanism at the bottom. The tube has engraved grooves on it. There is three vent holes at the mod. The fire button is activated by spring. It is powered by single 18650 battery (NOT INCLUDED). ![]() Kratos Mechanical Box Mod Clone $19.99 The Kratos Mechanical Box Mod Clone is constructed from POM and brass. It has a non-hybrid 510 connector and a Ultem fire button on top. The mod is powered by dual 18650 batteries (NOT INCLUDED). This item also has other colors to choose. ![]() Original Blitz FP RTA Rebuilding Tank Atomizer Original Price $38.00, Now Only $29.99 The Original Blitz FP RTA, with big 30mm diameter, comes with a 4.0ml glass tube and a 6.0ml bubble Acrylic tube, meeting your vaping needs for huge liquid storage. The build deck adopts 30 tiny airflow holes, providing a smooth air inlet. The knurled chamber brings better juice flow too. The ceramic clamps on the posts supports better conductivity to the coils. This item also has other colors to choose. ![]() Original One Top Onetopvape Gemini RDTA Rebuildable Dripping Tank Atomizer $28.59 The Original One Top Onetopvape Gemini RDTA is a 26.5mm diameter RDTA which is especially two sizes cap designed you've never seen in vape market. Constructed by 304 Stainless Steel and PC, it is well-built and durable. With the dual post build deck and quad terminals, it is very easy to build. Together with the Quad terminal and side airflow system, Gemini RDTA will bring an excellent vaping experience for you. ![]() YFTK Sat22 RTA Rebuildable Tank Atomizer Clone $21.99 The YFTK Sat22 RTA Clone is a 22mm rebuildable tank atomizer with 3ml of juice capacity. It is constructed from 316 stainless steel. It is designed for single coil builds. With dual small airholes on the side, it will bring you restricted lung vaping or MTL vaping. ![]() Original Joyetech EXCEED Edge 650mAh Pod System Starter Kit Original Price $26.90, Now Only $21.99 The Original Joyetech Exceed Edge Pod Version Starter Kit features with an ergonomically pod design, but coil changeable. It also features a curved shape of sports car design, convenient side-filling system, battery indicator and TPD compliant. The robust and versatile pod mod with coil built system that perfectly fits the EXCEED Edge. Equipped with the atomizer head with 1.2ohm resistance, Joyetech Exceed Edge Pod Kit is made of eco-friendly PETG material, and can bring pure and smooth clouds for mouth-to-lung. The Joyetech Exceed Edge Pods with 2ml e juice capacity to satisfy your daily vaping, it also can compatible with high nicotine and nicotine salts and easy to hold different e juice inside. This item also has other colors to choose. ![]() Kratos Mechanical Box Mod Clone + Chronos RDA Kit Clone with Extension Tube $29.89 The Kratos Mech Kit Clone consists of Kratos Mechanical Box Mod Clone and Chronos RDA Clone. This item also has other colors to choose. Mod: The Kratos Mechanical Box Mod Clone is constructed from POM and brass. It has a non-hybrid 510 connector and a Ultem fire button on top. The mod is powered by dual / triple 18650 batteries (NOT INCLUDED). This mod comes with an extension battery tube. Tank: The Chronos RDA Clone is a 24mm RDA constructed from stainless steel. It has a dual post build deck for easy coil building. The juice well is deep. The side airflow is adjustable for optimal flavor. Wide bore Ultem drip tip is included. ![]() Kratos Mechanical Box Mod Clone + Chronos RDA Kit Clone $24.89 The Kratos Mech Kit Clone consists of Kratos Mechanical Box Mod Clone and Chronos RDA Clone. This item also has other colors to choose. Mod: The Kratos Mechanical Box Mod Clone is constructed from POM and brass. It has a non-hybrid 510 connector and a Ultem fire button on top. The mod is powered by dual 18650 batteries (NOT INCLUDED). Tank: The Chronos RDA Clone is a 24mm RDA constructed from stainless steel. It has a dual post build deck for easy coil building. The juice well is deep. The side airflow is adjustable for optimal flavor. Wide bore Ultem drip tip is included. ![]() ShenRay Replacement Tank Tube 1 for VG Extreme RTA Clone $3.99 The ShenRay Replacement Tank Tube is made from 316 stainless steel and PC and is suitable for ShenRay VG Extreme RTA Clone. This item also has other Version to choose. ![]() Original Vapefly Firebolt Cotton + KA1 MTL Fused Clapton Coil for Coil Wicking $2.62 Firebolt Cotton utilizes pure organic cotton. The pre-loaded cotton is very easy to wick. This cotton provides more capacity and clean pure flavor. The Ni80 MTL Fused Clapton Coil features 0.35ohm resistance and 26GA + 40GA x 2 x 16 wires. This item also has other Version to choose. ![]() YFTK Replacement Ultem Plug for Fuji 510 Drip Tip Clone $3.99 The replacement plug is made from PEI and is suitable for YFTK Fuji 510 Drip Tip Clone. ![]() YFTK Fuji 510 Drip Tip Clone with Ultem Plug for RDA / RTA / Sub Ohm Tank Atomizer $5.99 The YFTK Fuji 510 Drip Tip Clone is made from POM and is suitable for all atomizers that fit 510 drip tip. It comes with a removable Ultem plug. This item also has other colors to choose. ![]() Original Vapefly Long 510 Drip Tip for Galaxies MTL Squonk RDTA Original Price $2.99, Now Only $1.99 The Vapefly replacement long drip tip is made from Delrin and is suitable for Galaxies MTL RDTA. It is also suitable for all atomizers that fit 510 drip tip.
187
The ShenRay Mecanic Mechanical Mod Clone is a 25mm mech mod with hybrid top cap for more power hit. It is constructed from brass. It features 4 point contact system and soft pressure point for comfortable activation. The recessed button can reduce risk of auto firing. The mod is powered by single 18650 / 20650 / 20700 / 21700 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original Subversive Mechanical Tube Mod $247.99 The Original Subversive Mechanical Mod is made from Beryllium Bronze and features special bottom electrode structure. The bottom electrode can be adjusted manually. It is powered by single 18650 battery (NOT INCLUDED). The fire button is activated by magnets. ![]() Original XO Vapor Little Bee Sub Ohm Tank Clearomizer $22.49 The Original XO Vapor Little Bee Tank is a sub ohm tank that is constructed of stainless steel and resin, it has 24mm diameter and 5ml of juice capacity (with bubble glass tube). It also has a standard glass tube with 3ml of juice capacity. The XO Vapor Little Bee Sub Ohm Tank Clearomizer features threaded top fill system and adjustable air slots for smooth airflow. This item also has other colors to choose. ![]() Original Hugsvape Chalice MTL RTA Rebuildable Tank Atomizer Original Price $28.99, Now Only $28.29 The Original Hugsvape Chalice MTL RTA is a 24mm MTL rebuildable tank atomizer with 2ml of juice capacity. It comes with 0.8mm, 1.0mm,1.2mm, 1.6mm, 2.0mm airflow holes for tight or loose MTL vaping, giving you the feeling of real cigarette draw. The raised building deck makes sure no flavor loss. This RDA comes with smooth bottom airflow. This item also has other colors to choose. ![]() Original Tigertek Momentum RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.99, Now Only $24.99 The Original Tigertek Momentum RDA is the newest rebuildable drip atomizer which adopts the precise side airflow design. Together with easy dual coil build deck and resin 810 drip tip, the Momentum RDA will bring you an unbeatable flavor. Featuring a two-post build deck for easy single or dual coil building, the Momentum RDA is definitely an excellent tank for most DIY lovers. With the extra squonk pin and adjustable side airflow design, the Tigertek Momentum RDA will give you an amazing vaping experience. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Ultimavape Diggie RDA Rebuildable Dripping Atomizer with BF Pin Original Price $34.00, Now Only $25.99 The Original Ultimavape Diggie RDA is a nice single coil RDA with 22mm diameter. It comes with black stainless steel finished deck and dual top caps (Delrin and Ultem). The RDA features single coil build deck and single airflow. This RDA comes with bottom feeder pin. ![]() Original Phevanda MTL A2 RDTA Rebuildable Dripping Tank Atomizer with BF Pin Original Price $29.99, Now Only $25.99 The Original Phevanda MTL A2 RDTA is an updated version of Phevanda A1. It is made from 316 stainless steel and features deep juice well, easy-to-build deck and replaceable airflow set. The Phevanda MTL A2 RDTA will bring you great mouth-to-lung vaping experience. This RDTA comes with bottom feeder pin. ![]() Original ZK-Vape BZ 500mAh Pod System Starter Kit $28.89 The ZK-Vape BZ Pod System is just like a car key. Although it has a compact and ergonomic design, it can still hold 1.8ml e-juice capacity. It features with intelligent battery life indicator and the leak proof slot can significantly solve leaking problem. Powered by built-in 500mAh battery, its power range is 10W~12W. The pod cartridge is recommended for nicotine salt. This item also has other colors to choose. ![]() SOB Emperor Mechanical Box Mod Clone + Outlaw RDA Kit Clone $22.29 The SOB Emperor Mech Kit Clone consists of SOB Emperor Mech mod Clone and Outlaw RDA Clone. This item also has other colors to choose. Mod: The SOB Emperor Mechanical Mod Clone features Delrin chassis, copper 510 contact pin, Ultem fire button on the side and copper battery door. It has many cut-outs for heat dissipation. It is powered by dual 18650 batteries (NOT INCLUDED). RDA: The Outlaw RDA Clone is constructed from stainless steel with 24mm diameter. The deck features classic dual post style design and comes with a deep juice well. The airflow can be adjusted by dual airslots on each side. ![]() Original XO Vapor Little Bee 120W Starter Kit $36.89 The XO Vapor Little Bee Starter Kit includes a pen style Little Bee Mod and a Little Bee Tank. The Little Bee Mod, powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED), is able to reach up to a maximum output power of 120W. As for the Atomizer, it features a 5.0ml large juice capacity and the latest mesh coil that you can enjoy amazing vaping. This item also has other colors to choose. ![]() Original GeekVape MTL N80 Clapton Heating Resistance Wire $5.90 The Original GeekVape MTL N80 Clapton wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Nichrome 80. It features 28GA x 2 + 38GA wires, which will be a good choice for DIY. This item also has other Version to choose. ![]() Original GeekVape F208 MTL Fused Clapton Coil 2 in 1 Coil Kit $4.90 The Original GeekVape F208 MTL Fused Clapton Coil 2 in 1 Coil Kit comes with two types of Fused Clapton coils (N80 / KA1). These pre-coiled heating wires come with 28GA x 2 (=) + 40GA 0.6 ohm coils, 28GA x 2 (=) + 38GA 0.8 ohm coils. These heating wires will be a good vaping choice for DIY. This product comes with 4 PCS for each type, totally 8 PCS in 1 pack. This item also has other Version to choose. ![]() Original GeekVape Feather Cotton Pre-loaded Organic Cotton Original Price $5.90, Now Only $4.39 The Original GeekVape Feather Cotton utilizes pure organic cotton. The pre-loaded cotton is very easy to wick. This cotton provides more capacity and clean pure flavor. This product comes with 20 x Pre-loaded cotton. ![]() ShenRay Replacement Magnets for Mecanic Mechanical Mod Clone $1.99 The ShenRay Replacement Magnets are suitable for Mecanic Mechanical Mod Clone. This product comes with 2 PCS in 1 pack.
188
Original Pioneer4You IPV Xyanide 200W TC VW Variable Wattage Box Mod Original Price $99.99, Now Only $27.99
The Original Pioneer4You IPV Xyanide Mod features attracting appearance and powerful chipset. IPV Xyanide adopts YiHi SX-460 Chip which is capable of delivering output power from 10W to 200W. The mod also comes with Joules mode and temperature control mode. It is powered by dual 18650 batteries (NOT INCLUDED). This item also has other colors to choose. ![]() Original Tesla Tallica Mini Sub Ohm Tank Clearomizer $28.69 The Original Tesla Tallica Mini Tank Atomizer is designed for the Tesla XT box mod, which has a Stainless steel and aluminum alloy construction, 4.0ml capacity in normal glass tube (an extra 6ml bulb glass tube included) and supports 110W max output. It has large airflow slots on the base, users can easily adjust the triangular airflow to get different vaping experience. With slide refilling design, it's simple to fill e-liquid, and the plug-and-pull coil replacement design ensures easy coil installation. This item also has other colors to choose. ![]() Original Innokin CoolFire Mini Zenith-D22 1300mAh VV VW Box Mod Starter Kit $47.79 The Original Innokin CoolFire Mini Zenith Starter Kit is a compact kit to fit your palm comfortably, which is designed with sleek box appearance and glossy surface. The CoolFire Mini Zenith is a simple kit with 1300mAh built-in battery, Wattage Mode and Voltage Mode, and if you like such simple vaping without too much modes and settings, then this one is a great choice for you. It has 3.0~7.5V voltage range and 6.0~40W wattage range, and you can operate it with the fire key, UP and Down buttons and the clear display screen. Added with multiple protection, you needn't to worry about your safety. The CoolFire Mini Zenith Kit comes with a new tank from Zenith series, which features accurate airflow control, easy twist top filling and 2ml juice capacity. Through adopting chimney design, it prevents leaking problem and noises. Moreover, Plexus Z Coils will bring you long-lasting flavorful clouds. ![]() Original Again Teel 600mAh Pod System Starter Kit $10.89 The Original Again Teel Pod System is mainly made of PC, it has a refillable pod with an atomizer resistance of 2ohm and a maximum capacity of 0.7ml. A 600mAh built in battery supplies power for the device. The Again Teel Pod System can be charged via the proprietary USB charging cable. This item also has other colors to choose. ![]() Original Mowell Shake 400mAh 12W Pod System Starter Kit $20.89 The Mowell Shake Pod Kit comes with 400mAh built-in battery and 2ml cartridge. It is designed with a professional ergonomic smooth edge to provide maximum comfort during use, ultra-portable to carry anywhere you go. It features cobblestone design with portable size and can be charged via its Micro USB Port. G-sensor function, no button design, simple and easy, LED indicator shows the real time vaping status and battery status, you can shake it to wake the system and flashing green light indicators system is awakened. This item also has other colors to choose. ![]() VapeSMOD Dustproof Silicone Cap Sleeve for RTA / Sub Ohm Tank Clearomizer $1.39 The VapeSMOD Dustproof Silicone Cap Sleeve is made from soft silicone. With the cap, the drip tip on your tank can be protected from dust. It is suitable for most RTA / Sub Ohm Tank that come with bubble glass tube. This item also has other colors to choose. ShenRay 810 to 510 Drip Tip Adapter for RDA / RTA / Sub Ohm Tank $1.99 The ShenRay 810 to 510 Drip Tip Adapter is made from 316 Stainless Steel. With this adapter, you can use the standard 510 drip tip in the Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA. ![]() ShenRay 810 Replacement Drip Tip for 528 Goon / Reload / Battle RDA $1.99 The ShenRay 810 drip tip is made from PC. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() Original Skull Italian Organic Vaping Cotton Bacon for Coil Wicking $2.99 The Skull Italian Organic Vaping Cotton Bacon uses the best quality of organic cotton from Italy, which is suitable for both high ohm and sub ohm vaping. Every cotton is pre-cut with the size of 90mm by 15mm. This product comes with 10 PCS in 1 pack, each single package has 2 PCS of cotton in it.
189
Original Vapor Storm Puma 200W TC VW Variable Wattage Box Mod $35.99
The Original Vapor Storm Puma Mod has sleek appearance and is versatile with its multiple output modes. Powered by dual high rate 18650 batteries (NOT INCLUDED), it is able to reach 200W in wattage mode. In temperature control mode, Puma supports Ni, Ti, SS316 and TCR. In bypass mode, the output can even be higher than 200W and the maximum is 230W. Puma will definitely provide you with different vaping experience. This item also has other colors to choose. ![]() Original Vapor Storm Lion RDA Rebuildable Dripping Atomizer $14.69 The Original Vapor Storm Lion RDA made of stainless steel, it comes with 24mm diameter and dual post deck. And the Lion RDA features easy top fill design and adjustable bottom airflow control system for optimal flavor and huge cloud. It can support dual coils. This item also has other colors to choose. ![]() Vapesoon Protective Silicone Sleeve Case for SMOK Mag Mod Left Hand Edition $2.59 The Vapesoon Protective Sleeve Case is made from silicone and suitable for authentic SMOK Mag Mod (Left Hand Edition). This item also has other colors to choose. 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.59 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() 510 Fuji Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The 510 Fuji Drip Tip is made from resin and is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
190
Purge Suicide King Hybrid Mechanical Tube Mod Clone $23.49
The Purge Suicide King Mechanical Mod Clone is a 25mm mechanical tube mod made from brass. It features unique engraved artwork on the body. The hybrid top cap allows more power hit. It is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Complyfe Saw Mechanical Tube Mod Clone $23.49 The Complyfe Saw Mechanical Mod Clone is a 30.5mm diameter mech mod made from brass. It is powered by single 18650, 20650, 20700 battery (NOT INCLUDED). The fire button is activated by magnets. ![]() Original Vandy Vape Pulse X 90W TC VW Squonk Box Mod Original Price $58.90, Now Only $48.99 The Vandy Vape Pulse X Mod is made from Zinc Alloy, it has a maximum power output of 90 watts with single 18650 / 20700 / 21700 battery (NOT INCLUDED). It is powered by Vandy Chip, which has excellent quality and highest stability. The replaceable panel comes with magnetic structure design. This item also has other colors to choose. ![]() Original Vaporesso Drizzle Fit 40W 1400mAh All-in-one Starter Kit $52.69 The Vaporesso Drizzle Fit Style Starter Kit is a compact and portable all-in-one starter kit that allows you to freely switch from MTL to DTL. Powered by built-in 1400mAh battery with the lastest OMNI Board Mini, it can fire up to 40W maximum output with multiple extra protections. The drizzle tank features a 1.8ml capacity, with its top filling system and top adjustable airflow, you can fill the e-juice more easily and choose MTL or DTL through the switch of airflow without leakage. Moreover, the most important highlight is its long-lasting EUC CCELL coil which is optimized to absorb and vaporize high nicotine e-juice more efficiently, bringing purer and smoother flavors and a satisfying texture. This item also has other colors to choose. ![]() Original Aspire Nautilus AIO 12W 1000mAh Pod System Starter Kit Original Price $29.99, Now Only $27.99 The Original Aspire Nautilus AIO Pod Kit adopts a slim and stylish design. With its sleek, ergonomic, palm-sized design, it is comfortable in the hand to use and is very discreet. The Nautilus AIO Pod Kit is powered by a built-in battery with 1000mAh capacity and can fire up to 12W. The Aspire Nautilus AIO has an adjustable airflow system to suit your vaping preference. Moreover, it also comes with two coils both rated at 1.8ohm, one for regular e-liquid and one for use with nicotine salts. What's more, the replacement pod cartridge with 4.5ml e-juice to satisfy your daily vaping and has a window to know e-juice capacity. This item also has other colors to choose. ![]() Original Snowwolf O-100 100W TC VW Squonk Box Mod + RDA Kit $76.99 The SnowWolf O-100 100W Squonk Kit consists of SnowWolf O-100 Box Mod and SnowWolf BF RDA. This item also has other colors to choose. Mod: The SnowWolf O-100 100W Squonk Mod is the latest advanced squonk mod with luxurious design elements, featuring performance versatility with full temperature control suite and a 7ml capacity bottle. The smart chipset allows SnowWolf O-100 to fire up to 100W with single 18650 / 20700 / 21700 battery (NOT INCLUDED). The SnowWolf O-100 Squonk Box Mod is sturdily constructed with heavy-duty Zinc Alloy frame with magnetized panels in a range of visually striking designs. RDA: The SnowWolf BF RDA has a 24mm base and a dual-post deck with single terminal in each for a flavor-focused single coil configuration. Air enters via large adjustable dual airholes that can fully open for maximum customizability or with the provided tiny airslots for an MTL-orientated air channel. ![]() Original Vandy Vape Pulse X 90W TC VW Box Mod + BF RDA Kit High-End Version Original Price $79.90, Now Only $69.99 The Pulse X Kit comes with the colored translucent panels that were so popular with the Pulse BF Kit, and features the Pulse X RDA, co-designed by Tony B and Stefen Z. This item also has other colors to choose. Mod: The Vandy Vape Pulse X Mod has maximum power output of 90 watts with single 18650 / 20700 / 21700 battery (NOT INCLUDED). It is powered by Vandy Chip, which has excellent quality and highest stability. The replaceable panel comes with magnetic structure design. This Kit comes with a 30ml silicone refilling bottle. RDA: The Pulse X RDA feeds the juice directly to the top of your coils, giving you the experience you would get with typical dripping atomizers, and saturating your wicks and coils from the top. This ensures that your coils are always wet and ready to go. When squonking, the one-way-valve design allows excess juice to return to the bottole at the bottom. It also allows you to drip right onto the center through the drip tip for non-squonk usage, and the liquid rolls off the top center of the post and onto your coils. The "X" design for the post can be used effectively for vertical and horizontal builds, and can accommodate large or small coils. ![]() Original Aspire Replacement Pod Cartridge for Nautilus AIO Pod System Starter Kit Original Price $5.99, Now Only $3.99 The replacement Pod Cartridge has 4.5ml of juice capacity and is suitable for Aspire Nautilus AIO Pod System Starter Kit. ![]() Original Aspire Replacement Coil for Nautilus AIO Pod System Starter Kit Original Price $14.99, Now Only $11.99 The replacement Coil comes with 0.18ohm resistance, it works well at 10W to 12W and is suitable for Aspire Nautilus AIO Pod Cartridge. This product comes with 5 PCS in 1 pack.
191
BDSIDE Nashty Mechanical Tube Mod Clone $19.89
The BDSIDE Nashty Mech Mod Clone is constructed from brass and comes with 25mm diameter. It comes with non-spring and non-magnet design, which helps reduce hot button and misfires. The mod is powered by single 18650 / 20700 battery (NOT INCLUDED). A 18650 battery adapter is included. This item also has other colors to choose. ![]() Original Voopoo Vmate 200W TC VW Variable Wattage Box Mod $52.59 The Original Voopoo Vmate Box Mod, with ultra compact size, powered by dual 18650 battery (NOT INCLUDED), is able to reach up to a maximum output power of 200W. Inside Voopoo Vmate Mod is equipped with updated Voopoo 32-digit GENE. FAN Chip, which brings you instant firing, stable and safe vaping. At the same time, protected by a V0 class proofing material, its chip set is capable of blocking dust, liquid and fire. Designed with two side battery covers, top buttons and OLED screen, thus unique mod brings you outstanding vaping. This item also has other colors to choose. ![]() Limelight Freehand Gloom Squonk Mechanical Box Mod Clone $22.99 The Limelight Freehand Gloom Squonk Box Mod Clone is a light-weight and portable squonking device. It is powered by single 18650 battery (NOT INCLUDED). The internal squeeze bottle is made from silicone with 8ml of juice capacity. The mod is suitable for 24mm atomizer. This item also has other colors to choose. ![]() Ulton VG Extreme RTA Rebuildable Tank Atomizer Clone $26.99 The Ulton VG Extreme RTA Clone is a 23mm RTA made from 316 Stainless Steel and PEI. It comes with 23mm diameter and 5ml of juice capacity. The build deck is dual-post designed and the tank has air draft regulation in the top cap. With top filling design, you can refill your favorite juice easily. ![]() ShenRay VG M5 MTL RTA Rebuildable Tank Atomizer Clone $22.99 The ShenRay VG M5 MTL RTA Clone is a 23mm diameter rebuildable tank atomizer, made from 316 stainless steel (deck and top cap) and PEI (tank). It comes with small inner diameter drip tip for the best MTL draft. It has dual posts design for easy single coil building. What's more, it features 5ml capacity that can meet your daily vaping need, and the top fill system makes refilling e-juice quickly and simply. ![]() Coppervape Hussar Satin RTA Rebuildable Tank Atomizer Clone $21.99 The Coppervape Hussar Satin RTA Clone is a 22mm rebuildable tank atomizer made from 316 stainless steel. It comes with a Torpedo top cap and Ultem micro tank. The airflow is adjustable with 2.5mm airflow post inside. The build deck is desinged for single coil builds. It has high grade satin coating, which feels smooth and looks elegant. ![]() Original Ambition Mods Twister RDA Rebuildable Dripping Atomizer $25.99 The Original Ambition Mods Twister RDA is constructed from 316 stainless steel, it measures 24mm diameter and 35.88mm height. The RDA is built with a POM top cap and includes a wide bore POM drip tip. Adjustable airflow is located on the chuff cap and features two air slots that provide air directly to the deck. The Twister's build deck is constructed from stainless steel and is made with dual posts that have two wire terminals each. A vertical coil lock system can be found on both sides to ensure installation of coils is effortless and a deep juice well ensures the plenty of space for cotton and e-liquid storage. ![]() Original Kanger TOPBOX Mini 75W Platinum Edition TC VW Mod + TOPTANK Mini Kit Original Price $59.99, Now Only $37.99 The Kanger TOPBOX Mini Kit consists of TOPBOX Mini Mod and Toptank mini clearomizer. Mod: The Kanger TOPBOX Mini Platinum Edition is housed in a stainless steel chassis so you get a heavy-duty vaping device that is lightweight and easy to grip. It is powered by a single 18650 high-drain battery (NOT INCLUDED) that can easily be swapped through the magnetic battery cover at the back side. The removable rear door has its own vent to let your battery breathe. The Kanger TOPBOX Mini Mod can support Ni, Ti, SS and NiCr wire TC coils. The wattage can be switched from 7 to 75 Watts in 0.1W increments. Tank: Compared to the 3.2ml TOPTANK Nano, the TOPTANK Mini has a bigger capacity that can store up to 4ml of e-juice. The best thing about the TOPTANK is that it is both a top-filling and bottom-filling tank. The TOPBOX Mini tank features an intuitive coil replacement system that lets you use a wide variety of atomizer heads. After you've exhausted all the coil heads included in the starter kit or you simply want to try out new ones, just replace the atomizer with another sub-ohm build with resistance as low as 0.1 ohm. ![]() Cleaning Tool / Brush for RDA / RTA Coil $1.59 The cleaning tool / brush is perfect for RDA / RTA Coil. The highly attractive clean performance, prevent and clean the carbon deposition and the greasy dirty on the coil. It is great for healthy vaping. ![]() 510 Heat Dissipation Insulator Heat Sink for RDA / RTA / Sub Ohm Tank Atomizer $1.99 This heat dissipation insulator is made from stainless steel with copper pin. It is installed between mod and atomizer to insulate heat between mod and atomizer, and it can be a decorative ring for your device. ![]() Coppervape Replacement 510 Delrin Drip Tip for Penodat MTL RTA Clone $1.99 The replacement 510 drip tip is made from POM Delrin. It is designed for Coppervape Penodat MTL RTA Clone, but is also suitable for all atomizers that fit 510 drip tip. ![]() 510 Color Changing Fuji Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The 510 Fuji Drip Tip is made from resin and is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() Portable Carrying Storage Vape Bag for E-cigarette Mod / Atomizer / Accessory $5.99 The portable vape bag is a vaper pocket bag with great space yet small and easy carrying. You can put your vape products in it. It has a buckle so that you can carry it at your belt. ![]() Magic Cube Hand Spinner Fidget Toy EDC Clone $5.99 The Magic Cube Hand Spinner Clone is constructed from aluminum and stainless steel. The spinner is a small spinning device designed to keep your hands busy and your mind focused. It is pocket sized and can be spun in one hand by using the other hand to rapidly spin it from small continuous strikes. Great for people with Fidgety hands, ADHD, Anxiety & OCD sufferers. The bearing is made from stainless steel. This item also has other colors to choose. ![]() Vortecon Kinetic Desk Toy Spinner EDC Fidget Toy Clone $6.99 The Vortecon Kinetic Desk Toy Clone is constructed from stainless steel. The spinner is a small spinning device designed to keep your hands busy and your mind focused. It is pocket sized and can be spun on the desk by using your hand to rapidly spin it from small continuous strikes. Great for people with Fidgety hands, ADHD, Anxiety & OCD sufferers. ![]() Ulton Replacement Tank Tube + Drip Tip Kit for VG Extreme RTA Clone $5.99 The Ulton Replacement Tank Tube is made from 316 stainless steel and PC. The drip tip is made from PC. They are suitable for Ulton VG Extreme RTA Clone.
192
Purge Suicide Queen Hybrid Mechanical Tube Mod Clone $25.59
The Purge Suicide Queen Mechanical Mod Clone is a 26mm mech mod which tapers to 25mm on top. It features unique engraved artwork on the body. The hybrid top cap allows more power hit. It is powered by single 18650 or 20700 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original ThinkVape Thor 200W TC VW Variable Wattage Box Mod Original Price $41.90, Now Only $34.99 The Original ThinkVape Thor Box Mod is a versatile regulated device with aesthetic appearance. Powered by ST200 Chip, this mod can reach maximum output power to 200W with dual 18650 batteries (not included). There are multiple modes can be selected: VW / VT (Ni / Ti / SS) / TCR / Bypass. The atomizer resistance range is from 0.05 to 3.5ohm. This item also has other colors to choose. ![]() Original Augvape V200W TC VW Variable Wattage Box Mod Original Price $69.99, Now Only $54.99 Inspired by a classic and revolutionary car engine B18C, the original Augvape V200 Mod is the first device adopts this attractive design. The mod is a compact 200W device with hidden buttons design, which feels good in the hand. V200 keeps the car engine elements such as Wheel Hub being 510 connector and Oil Filling Cover being rotation button to adjust wattage. There are 3 output modes, the Normal, Bypass, V mode. This mod is powered by dual 18650 batteries (not included) and supports atomizer resistance from 0.05 to 3ohm. This item also has other colors to choose. ![]() Original GeekVape Loop V1.5 RDA Rebuildable Dripping Atomizer with BF Pin Original Price $30.90, Now Only $25.99 Geekvape Loop V1.5 RDA, updated upon the Loop RDA, comes with an innovative "W" shape build deck incorporated with surround airflow design, which ensures full effectiveness of the airflow that significantly enhances the flavor while minimizing leakage. The special "W" shape build deck supports both single and dual coil building to meet different needs. This RDA comes with BF pin This item also has other colors to choose. ![]() Noname Poledance Pole dance RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Noname Pole dance Poledance RDA Clone is a tiny 18mm BF RDA made from 316 stainless steel. It features long post structure and deep juice well. It is suitable for single coil builds. The cap has single air hole for tight or restricted vaping experience. Ultem drip tip and 316SS decorative ring are included. This RDA comes with bottom feeder pin. ![]() Original Hugo Vapor Submarine 850mAh TC Pod System Starter Kit $14.99 The Hugo Vapor Submarine Kit, with an 850mAh built-in battery, is a Pod System with the one button operation, it features a full LED with temperature control, battery life indicator, and an all-ceramic heating chamber. There are 3 shift temperature control: 200'C, 220'C, 240'C. 10 small openings to limit the heating of the battery and a central LED indicating the remaining level of autonomy. Designed for use in MTL (Mouth-to-lung), the Submarine Pod System will work with pods containing 0.7ohm coils. Once switched on, there is no need for the switch, the system only turns on during inhalation. With the small size, the Hugo Vapor Submarine Pod System Kit is compact on your hand. This item also has other colors to choose.
193
Original Voopoo Rimfire RTA Rebuildable Tank Atomizer $30.89
The Original VOOPOO Rimfire RTA is a 30mm diameter RTA with a user-friendly and highly-detachable structure. Constructed of stainless steel and glass, it has a 5ml e-liquid capacity to satisfy your daily vaping. The full-size build deck is easy to build coils, and it also supports single or double coils. It has dual tight airflows: the center airflow is for air down and side is for air up; the side airflow travels through two side cavities before getting up into the build deck, which can avoid leakage and bring the pure flavor. Moreover, the clip-on top cap is much easier than threading cap to the top filling. This item also has other colors to choose. ![]() Space5 RDA Rebuildable Dripping Atomizer Clone with BF Pin + PC Cap + PEI Cap $13.59 The Space5 RDA Clone is a 22mm rebuildable dripping atomizer made from 316 stainless steel. It has a dual-post build deck, which is designed for single coil builds. The side airflow is adjustable, bringing you optimal vaping experience. There is no drip tip included. This item also has other colors to choose. This RDA comes with bottom feeder pin. Spare PC cap and PEI cap are included. ![]() Space5 RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.49 The Space5 RDA Clone is a 22mm rebuildable dripping atomizer made from 316 stainless steel. It has a dual-post build deck, which is designed for single coil builds. The side airflow is adjustable, bringing you optimal vaping experience. There is no drip tip included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Pelso V3 RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Pelso V3 RDA Clone is a 22mm rebuildable dripping atomizer made from 316 stainless steel. It has a triple-post build deck, which is suitable for dual coil builds. The side airflow is adjustable with different levels, bringing you different vaping experience. Ultem drip tip is included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Tesla Falcons 2000mAh Battery Mod + Pod One Atomizer Starter Kit Original Price $39.90, Now Only $35.99 The Original Tesla Falcons 2000mAh Starter Kit consists of the Tesla Falcons 2000mAh MOD and the Pod One Atomizer. This item also has other Version to choose. Mod: Powered by built-in 2000mAh battery, the Tesla Falcons MOD can provide you a durable vaping experience. With the voltage indicator light and multiple protections including the low voltage, short circuit protection and others, the Tesla Falcons MOD can provide a safe vaping environment for you. Atomizer: The Tesla Pod One Atomizer is a 2ml innovative pod-style atomizer, featuring the easy-to-operate pluggable design by combining the Pod One Cartridge with the Pod One Adapter. Plus the unique 1.2ohm coil, the Tesla Pod One is perfectly used with Nicotine salt e-juice with optimal and pure flavor. ![]() Original Tesla Falcons 2000mAh Battery Mod + Resin Tank Starter Kit Original Price $48.90, Now Only $42.99 The Original Tesla Falcons Starter Kit with Resin Tank consists of Tesla Falcons 2000mAh mod and Resin Tank. This item also has other colors to choose. Mod: Powered by built-in 2000mAh battery, the Tesla Falcons MOD can provide you a durable vaping experience. With the voltage indicator light and multiple protections including the low voltage, short circuit protection and others, the Tesla Falcons MOD can provide a safe vaping environment for you. Tank: The Resin Tank is a 6ml innovative atomizer, features a 4ml capacity for standard and 6ml in bulb tube for you to choose. With the top-filling system and adjustable airflow, it will provide you a convenient vape experience with great flavor and big cloud. What's more, the Resin Tank utilizes the latest TS-XX coils that have a 0.18ohm resistance and fire in the range of 60~110 watts. ![]() Original Vapesoon 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.99 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() Replacement Top Cap for Pelso V3 RDA Clone $2.99 The replacement top cap is made from PC and is suitable for Pelso V3 RDA Clone. This item also has other colors to choose. ![]() Replacement Top Cap for Space5 RDA Clone $2.99 The replacement top cap is made from PEI and is suitable for Space5 RDA Clone. This item also has other colors to choose.
194
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Asmodus Dawg RTA Rebuildable Tank Atomizer Original Price $44.95, Now Only $36.99
The Asmodus Dawg RTA is wonderfully designed with a unique two-post build deck, juice capacity, and an adjustable grooved bottom airflow control. Constructed from superior stainless steel, the Dawg RTA exemplifies a high-quality build structure with intricate grooved designs on the top and bottom base. The build deck implements a two-post, dual terminal designs in which coils are side-secured via gold-plated hex screws. The bottom airflow control ring can be fully adjusted, precisely engineered to work with the triple squared slotted airslots design. The entire apparatus is built for maximal vapor production with excellent cooling properties and phenomenal flavor recreation of popular vape juice. This item also has other colors to choose. ![]() Original Asmodus Vice RDA Rebuildable Dripping Atomizer with BF Pin Original Price $39.95, Now Only $33.99 The Asmodus Vice RDA is constructed from premium stainless steel and anodized aluminum with a diameter of 24mm, this quality yet amazingly lightweight RDA will bring you amazing flavor and vapor production with an exceptionally easy to build deck. The build deck has been 24K gold plated for maximized conductivity and longevity. This RDA comes with BF pin. This item also has other colors to choose. ![]() Original Asmodus C4 RDA Rebuildable Dripping Atomizer with BF Pin Original Price $34.95, Now Only $28.99 The Original Asmodus C4 RDA is a 24mm diameter rebuildable dripping atomizer, with the main chassis being composed of 304 stainless steel, anodized 6063 Aluminum used for the top cap to provide a solid finish that is resistant to chipping and scratching, and a layer of 24K gold-plated on the build deck for a finish that not only offers an elegant accent to this pretty little powerhouse, but maximum conductivity to ensure that this little beast hits as hard as possible. The C4 RDA is a two posts design for easy single building. The 9 individual air inlets is on either side of the sleeve are machined into the body at a slight 25' angle, creating a cyclonic airflow within the chamber that maximizes the area of the coil that is contacted by the incoming air, creating a greater amount of vapor. It comes with a pre-installed 510 standard pin and bottom feeder pin. This item also has other colors to choose. ![]() ShenRay Vapor Giant Extreme RTA Rebuildable Tank Atomizer Clone $29.99 The ShenRay Vapor Giant Extreme RTA Clone is a 23mm RTA made from 316 Stainless Steel and PEI. It comes with 23mm diameter and 5ml of juice capacity. The build deck is dual-post designed and the tank has air draft regulation in the top cap. With top filling design, you can refill your favorite juice easily. This item also has other colors to choose. ![]() ShenRay AIOLOS V2 RTA Rebuildable Tank Atomizer Clone $20.99 The ShenRay AIOLOS V2 RTA Clone is a tiny rebuildable tank with 16mm diameter and 2ml of juice capacity. It is made from 316 stainless steel and comes with a spare PMMA tube. The tank features narrow chimney for tasty vapor, single coil build deck and bottom airflow. ![]() Original Auro Salt MTL Tank Clearomizer $14.99 The Original Auro Salt Tank is an MTL clearomizer designed for Nic salt e-liquid. It comes with 1.8ohm and 1.5ohm coil heads, which will bring you pure flavor. The tank has 22mm diameter and 2ml juice capacity. It will bring you optimal MTL experience. ![]() Original Vapesoon Replacement Drip Tip for Aspire Cleito 120 Tank Clearomizer $2.59 The replacement drip tip is made from POM and is suitable for Aspire Cleito 120 Tank. ![]() Original Vapesoon Anti-Spit 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.39 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original Vapesoon 810 Drip Tip for Goon / Kennedy / Reload RDA $2.39 The replacement 810 drip tip is made from resin. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original Vapesoon 510 Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.09 The replacement 510 drip tip is made from stainless steel. It is suitable for all atomizers that fit 510 drip tip. This item also has other Version to choose. ![]() Original Auro Replacement Coil Head for Salt Tank $9.99 The replacement coil head has 1.8ohm resistance and is recommend to be used under 7~12W to get a better MTL vaping experience. It is suitable for original Auro Salt Tank. This product comes with 5 PCS in 1 pack. This item also has other Version to choose.
195
Original Digiflavor Etna RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.90, Now Only $22.99
The Original Digiflavor Etna RDA is constructed from stainless steel with a 18mm diameter. It is designed for a tight MTL draw especially suitable for tobacco and fruity flavored e-liquids, and nicotine salts e-liquids. The airflow is not adjustable but modular, for a concentrated and intense airflow that improves its performance. Exchangeable air restrictions was supplied. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Reload X RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.59 The Reload X RDA Clone is a 24mm RDA constructed from stainless steel. It features a quad terminal postless deck designed for dual coil configurations and dual adjustable top-down bottom airflow system that minimizes leakage while providing intense flavor. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Footoon Aqua Master RTA Rebuildable Tank Atomizer $27.99 The Original Footoon Aqua Master RTA is a 24mm diameter RTA with beautiful stylish designs, which also comes with a standard 2.6ml glass tube and 4.4ml bubble tube. Besides, it can compatible with Footoon Aqua Reboot juice tank section. With the big 24mm build deck, it has enough space that easy to build coils. The revolutionary new airflow design of Aqua Master RTA is piston flow system that provide smoothest airflow and best taste for users. This item also has other colors to choose. ![]() Ulton Pelso V3 RDA Rebuildable Dripping Atomizer Clone with BF Pin $10.29 The Ulton Pelso V3 RDA Clone is a 22mm rebuildable dripping atomizer made from 316 stainless steel. It has a triple-post build deck, which is suitable for single or dual coil builds. The poles are adjustable for different builds. The airflow is adjustable for optimal flavor. Ultem drip tip is included. This RDA comes with bottom feeder pin. This item also has other Version to choose. ![]() Original Joyetech eGo AIO Mansion 30W 1300mAh All-in-One Pod System Starter Kit $28.99 The Original Joyetech eGo AIO Mansion Kit has a slim and portable size just like a lighter. Powered by 1300mah built-in battery, the Mansion kit has a 2ml liquid capacity. Besides, a 0.6ohm SS316 BF coil head is available in the cartridge which will bring nice flavor and large vaping production. Moreover, with top filling design and adjustable airflow system, you can enjoy DL and MTL vaping experience both. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.59 The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other Version to choose. This drip tip will be shipped in random color (1 piece will be shipped). More color than what's on the image. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.59 The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip. This drip tip will be shipped in random color (1 piece will be shipped). More color than what's on the image. This item also has other Version to choose. ![]() 810 Replacement Drip Tip for 528 Goon / Kennedy / Reload RDA $3.39 The replacement 810 drip tip is made from resin. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This drip tip will be shipped in random color (1 piece will be shipped). More color than what's on the image.
196
Vapeasy Mini Bestia MiniB Mechanical Tube Mod Clone $23.99
The Vapeasy Mini Bestia Mini B Mod Clone is the smallest 18650 mech mod. It is constructed from brass, with hybrid connection and side fire button. The mod is powered by only single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original ThinkVape Sailboat Baby 85W TC VW Variable Wattage Box Mod Original Price $49.00, Now Only $34.79 The Original ThinkVape Sailboat Baby 85W Mod Made of Kirsite and PC, it is the newest mod of Think Vape. Powered by single 18650 battery (NOT INCLUDED), the Sailboat Baby can reach up to max 85W output. It can support VW / Ni / Ti / SS / By pass modes. The Sailboat Baby comes with OLED 0.96 inch screen, which can clearly display the information to help you to use it. This item also has other colors to choose. ![]() Original SMOKTech SMOK Species 230W TC VW Variable Wattage Box Mod $51.29 The Original SMOKTech SMOK Species is an angular mod with hard lines, which reflects its sublime heroism. The front brand new 1.45" high-definition touch screen comes with upgraded user interface offers you more comprehensive and clearer vaping data, while the back has classic cobra pattern that reveals its domineering potential. Moreover, the screen locking button ensures a safe operation. And its output can be varied from 1 to 230W with dual 18650 batteries (NOT INCLUDED), which can meet your various demands. This item also has other colors to choose. ![]() Original Vaporesso Drizzle Fit 1400mAh VW Variable Wattage Box Mod $26.59 The Original Vaporesso Drizzle Mod Fit is a compact and portable box mod. Powered by built-in 1400mAh battery, it can fire with three output modes: 7W, 8.4W and 10W. It has multiple extra protections with one button to rule them all. Integrating the All in One Single Button as the firing button and LED indicator, makes this grip extremely comfortable. The Vaporesso Drizzle Mod also offers three power modes so you can customize your experience. This item also has other colors to choose. ![]() ShenRay Dome V2 RDTA Rebuildable Dripping Tank Atomize Clone Original Price $27.00, Now Only $24.99 The ShenRay Dome V2 RDTA Clone is a 2-in-1 rebuildable atomizer that can be used as RDA or RTA. It is made from Ultem and 316 stainless steel. This RDTA comes with 22mm diameter and 2.8ml of juice capacity. The RDTA also features dual post build deck and adjustable airflow. ![]() Original Vandy Vape NS 9W 650mAh All-in one Pen Starter Kit Original Price $29.99, Now Only $23.99 The Vandy Vape NS Pen Kit has a slim body with matte texture surface which is very comfortable to hold in hand. This Vandy Vape NS Pen Kit comes with one button for easy to operate. And it has a magnetic top cap on the drip tip which is dustproof. Powered by 650mah built-in battery, it has a 1.5ml liquid capacity with a top filling system, and support charge via Micro USB port on the bottom. This item also has other colors to choose. ![]() ShenRay Replacement Tank Tube for Vapor Giant Extreme RTA Clone $3.59 The ShenRay Replacement Tank Tube is made from PC and is suitable for ShenRay Vapor Giant Extreme RTA Clone. ![]() Avid Lyfe Captain Cap II Top Cap Clone for Battle RDA Clone $3.99 The Avid Lyfe Captain Cap II wide bore top cap Clone is made from aluminum and is suitable for Battle deck Clone. This item also has other colors to choose. ![]() Replacement Top Cap for Pelso V3 RDA Clone $2.99 The replacement top cap is made from PEI and is suitable for Pelso V3 RDA Clone. The airhole size is 1mm. This item also has other Version to choose.
197
Original Reload BF Squonk Mechanical Box Mod $91.79
The Original Reload Mod is a mechanical box mod constructed from anodized aluminum with a 9ml bottom feeder bottle. Powered by dual 18650 batteries (NOT INCLUDED), it can power up to 136W with a voltage range of 3.3V to 4.2V. The Reload Mod features colored LED light indicator, spring loaded 510 connector, tool-less battery access door, malfunction protection and PCB circuit board. ![]() Original Tesla Resin Sub Ohm Tank Clearomizer Original Price $38.90, Now Only $25.99 The Original Tesla Resin Tank is a 6ml innovative atomizer, features a 4ml capacity for standard and 6ml in bulb tube for you to choose. With the top-filling system and adjustable airflow, it will provide you a convenient vape experience with great flavor and big cloud. What's more, the Resin Tank utilizes the latest TS-XX coils that have a 0.18ohm resistance and fire in the range of 60~110 watts. This item also has other colors to choose. ![]() Original Vapesoon Replacement Seal O-Rings for SMOK TFV12 Prince Tank $1.09 This product consists of 4 replacement seal o-rings which is made from silicone. They are suitable for SMOK TFV12 Tank. This item also has other Version to choose. OriginalVapesoon Replacement Tank Tube + Seal O-Rings for SMOK TFV12 Prince Tank $1.99 This product consists of a 24.5mm diameter replacement glass tank tube and 4 replacement silicone seal o-rings. They are suitable for SMOK TFV12 Tank. This item also has other Version to choose. Original Coil Father 810 to 510 Drip Tip Adapter for RDA / RTA / Sub Ohm Tank $1.29 The Coil Father 810 to 510 Drip Tip Adapter is made from aluminum. With this adapter, you can use the standard 510 drip tip in the TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA. This item also has other colors to choose. ![]() Original Coil Father Display Base Stand for 18mm RDA / RTA / Sub Ohm Tank Atomizer $1.79 The Coil Father display base stand is made out of aluminum. It is suitable for atomizers with diameter not over 18mm. It can help you hold your favorite atomizer on the deck. This stand is for 18mm (or smaller) atomizers. This item also has other Version to choose. ![]() Original Vandy Vape Replacement Coil Head for NS Pen Starter Kit $6.79 The Original Vandy Vape Replacement Coil Head is constructed from 316L stainless steel, it features 1.2ohm resistance and works best at 9W. It is suitable for Vandy Vape NS Pen Starter Kit. This product comes with 5 pcs in 1 pack. ![]() Original Coil Father 810 Drip Tip for Goon / Kennedy / Reload RDA $1.99 The replacement 810 drip tip is made from PC. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
198
Ulton Kmkamo Hybrid Mechanical Tube Mod Clone $18.39
The Ulton Kmkamo Mechanical Mod Clone is a hard-hitting mech mod made from aluminum alloy and brass. It comes with extra 24mm hybrid connector. The mech mod features Innovative button, which changes pressing ways by the screw. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original Nikola Medea 218W TC VW Variable Wattage Box Mod Original Price $59.90, Now Only $48.89 The Original Nikola Medea Mod is a 218W mod constructed from zinc alloy. Powered by dual replaceable 18650 batteries (NOT INCLUDE), it features 0.96-inch OLED display, built-in memory mode and 4-tier output modes allow for different patterns and vaping experiences to vapers. Crafted by the exquisite workmanship, the beauty of streamline design is greatly shown in this Box Mod. This item also has other colors to choose. ![]() Original Sigelei GW 257W VW Variable Wattage Mod + F Tank Kit Original Price $65.99, Now Only $41.99 The Sigelei GW 257W Mod Kit consists of Sigelei GW 257W mod and F Tank atomizer. The Sigelei GW 257W Mod Kit is such powerful that the maximum output wattage can reach up to 257W. The temperature suite supports SS316 / SS317 / Ti1 / NI200 / TCR and the temperature range is 100 to 300 degrees Celsius / 200 to 570 degrees Fahrenheit. The mod is powered by 2 x 18650 batteries (not included) and supports 5V / 2.5A USB fast charging. ![]() Coil Father Single Port USB Charger for Juul Pod System Device $1.99 This USB charger has single port for charging. It is suitable for Juul device. ![]() Original Coil Father 5-Connector Display Base Stand for RDA / RTA / Sub Ohm Tank Atomizer $5.99 The Coil Father display base stand is made out of acrylic. It is suitable for all sizes of atomizers. It can help you hold your favorite atomizer on the deck. This item also has other Version to choose. ![]() Original Wotofo 22mm Conversion Cap for Profile RDA Original Price $12.99, Now Only $9.99 This Conversion Cap is made for the purpose of converting your 24mm Profile RDA into a 22mm buddy. Reserving the same adjustable air inlet design but paired with flavor enhancing drip tip for different preferences. The kit includes a removable decoration ring to give a choice of 24mm look if you like. And the word "Profile" is engraved noticeably on the sleeve. This item also has other colors to choose. ![]() Original Wotofo Agleted Organic Cotton for Coil Wicking $3.99 Wotofo Agleted Organic Cotton is inspired by the ever increasing needs of fast cotton preparation for your rebuilding convenience. The cotton we selected are of long fibers so that it wicks smooth and its not easy to pull apart. However, that's not the best part, the best part is that we put a sheath on one end of the cotton strip so as to function like the aglet on your shoelace, then its much easier to thread the cotton through the coils. Each cotton strip is ready-to-use with proper cotton amount especially for the Profile mesh RDA. The cotton features great absorption capability and better retention ability, freshly packaged to deliver the purest flavor. There are 10 pieces of agleted cotton strips in one little box, convenient to carry around and stored in a clean way.
199
SOB Uno Bersikulo Hybrid Mechanical Mod Clone $14.79
The SOB Uno Bersikulo Mechanical Mod Clone features resin chassis, brass hybrid top cap and tube, Ultem fire button on the side and copper battery door. It is powered by single 18650 battery (NOT INCLUDED). This product comes with random color. More options than what's on the image. ![]() Original Asmodus Lustro 200W Touch Screen TC VW Variable Wattage Box Mod Kodama Edition Original Price $269.95, Now Only $239.99 The Original Asmodus Lustro Box Mod is a versatile regulated mod powered by dual 18650 batteries (NOT INCLUDED), which can reach maximum output to 200W. With a capacitive touch screen, the operation on Lustro is very easy to vapers. Working with the latest GX-200-HUT chipset, Lustro Box Mod provides high performance in all aspects. The Curve output mode allows for detailed customization of the firing curve. The Lustro Box Mod will bring you the most comfortable vaping experience. This item also has other colors to choose. ![]() Original Asmodus EOS II 180W Touch Screen TC VW Variable Wattage Box Mod Original Price $149.95, Now Only $123.99 The EOS II features the GX-180-UTC, a chipset that packs a punch and saves battery life. With the new chipset equipped, you can really personalize your device to your liking from changing the color of your screen, how to unlock your settings mode, setting your puff limit, and much more. The new software in the GX-180-UTC features our "swipe left to right or right to left to change firing modes". We've also included a SOFT, NORMAL, and HARD firing modes. The EOS II is composed of beautiful stabilized wood, acrylic / resin on a lightweight aluminum frame to make a feather-like mode. There are 3 optional firmware files to cater to those who love the colored screen, or a basic and clean looking screen. The Base firmware that the EOS II comes with features our colorful screen that some of the community likes. The other 2 optional firmware files; one allows you to choose your favorite RGB color for your home menu, and change the brightness of your screen; the other firmware file is a nice and simple black screen with white text, but also allows you to change little bits of color personalize your mod in the simplest of ways, plus brightness settings. This item also has other colors to choose. ![]() Original Shield Cig Mark XLIV RDA Rebuildable Dripping Atomizer $22.99 The Original Shield Cig Mark XLIV RDA is a 30mm cloud beast rebuildable dripping atomizer. It features a cross style build deck, which allows you to make a quad-coil build or even 8-coil build! The whole deck is gold plated and the 510 pin is silver plated for great conductivity. It comes with adjustable side airflow on 4 sides. A wide bore POM drip tip is included. This item also has other colors to choose. ![]() Original Eleaf iJust ECM 40W 3000mAh Starter Kit $55.00 The Eleaf iJust ECM kit is a classic pen-style starter kit with a diameter of 25mm. Powered by the built-in 3000mAh battery with direct output mode, the iJust ECM kit can fire up to 40W maximum output with the colorful LED battery level indicator light and multiple circuit protections. Moreover, two new EC Mesh coils are available on the kit, the EC-N, and EC-M. The two coil heads are constructed using a different style of mesh, which provides a much bigger surface area allowing for better flavor and bigger clouds. To fill the tank, you just need to slide the drip tip back to reveal the fill port. This item also has other colors to choose. ![]() Original Asmodus Colossal 80W TC VW Box Mod + Wotofo Flow Pro Sub Ohm Tank Kit Original Price $74.95, Now Only $68.99 The Original Asmodus Colossal 80W Mod Kit consists of the Asmodus Colossal 80W TC VW Box Mod and Wotofo Flow Pro Sub Ohm Tank. This item also has other colors to choose. Mod: The Original Asmodus Colossal 80W Mod is a beast of a single battery mod (BATTERY NOT INCLUDED) that is perfect for when you are on the go. This petite mod features an advanced chipset with a new and improved UI and is sure to impress due to the incredible portability combined with the massive power. The Colossal features a full firing mode suite, including variable voltage, curve mode, temperature control presets for Ni200 nickel, titanium, and stainless steel heating elements as well as adjustable TCR and TFR modes. The Colossal also utilizes an Asmodus developed "battery safe connection" on the positive battery port which provides a safer, more secure connection by encasing the port with a plastic rim which forces the battery to stay in place. A USB port (for firmware updating) has been implemented as well to ensure that your mod is always up to date. Tank: The Wotofo Flow Pro Sub Ohm Tank is a 25mm diameter that fits perfectly on the colossal to make a beautiful combination. The Tank is an easy to fill tank that features a threaded top fill system, capable of holding up to 5ml of E-liquid. Additionally, it is compatible with SMOK TFV8 Baby Beast Coils for more versatility. Airflow enters the tank via dual adjustable bottom airflow with air slots measuring at 12mm by 2mm each, that can be fully closed. With its simplistic design and replacement coil versatility, it works beautifully with our Colossal 80w Box Mod. ![]() Original Zerovape Start Mechanical Mod Kit $35.99 The Original Zerovape Start Mechanical Mod Kit consists of Zerovape Start Mechanical Mod and RDA. This item also has other colors to choose. Mod: The Zerovape Start Mechanical Mod is made from brass and stainless steel. It is 24mm diameter, which fits most of mainstream atomizers. All contact elements are made from brass. The mod looks elegant and feels smooth when you hold it in your hand. The mod is powered by single 18650 battery (NOT INCLUDED). RDA: The RDA is a 24mm rebuildable dripping atomizer made from stainless steel. It has a clamp style post build deck and the clamp on top is made from PEEK. It supports dual coil builds. The airflow is adjustable on the side.
200
Original OBS Cube 80W 3000mAh VW Variable Wattage Built-in Battery Box Mod Original Price $45.00, Now Only $37.99
The Original OBS Cube Mod is constructed from zinc alloy, it is powered by a built-in 3000mAh 23600 A+ high rate battery, with the fire speed of 10 milliseconds, it is very safe and durable. It features 0.96-inch LED screen, high - tech appearance, ergonomic design, comfort grip and exquisite buttons. The 1.5A charge current makes it safe and efficient to charge within 2~3 hours. This item also has other colors to choose. ![]() Avid Lyfe Comp Lyfe Saw Mechanical Tube Mod Clone $25.99 The Avid Lyfe Complyfe Saw Tube Mod Clone is a mechanical mod with a diameter of 30.5mm which is constructed from brass. It is powered by single 18650, 20700 battery (NOT INCLUDED). The fire button is activated by magnets. This item also has other colors to choose. ![]() Original Dovpo Rogue 100W TC VW Variable Wattage Box Mod $36.99 The Original Dovpo Rogue Mod is a single 18650 / 26650 (NOT INCLUDED) versatile device with multiple modes and protection. The output wattage can be adjusted at between 5W and 100W. Rogue has full temperature control suite and supports CCW and CCT modes. The battery cover has stylish and aesthetic pattern, making this mod more unique. ![]() Original GeekVape Alpha Sub Ohm Tank Clearomizer Original Price $32.99, Now Only $27.99 The Original GeekVape Alpha Sub Ohm Tank is a clearomizer with 25mm diameter, 0.15ohm resistance and 4ml capacity. It is the flagship sub ohm tank fully developed by Geekvape Team, it presents unrivaled vaping experience to users with its meticulously made MeshMellow Coil System, which features the purest flavor from the very first inhale. Unlike any other coil of its kind, the MeshMellow coils uses the best cotton to ensure the perfect flavor. This item also has other colors to choose. ![]() Unfollow Momentous V2.1 RTA Rebuildable Tank Atomizer Clone $12.99 The Unfollow Momentous V2.1 RTA Clone is a 22mm rebuildable tank atomizer made from 316 stainless steel and PC tube. It features 3.7ml of juice capacity, narrow chimney and adjustable airflow control with three holes on each side. It can be refilled from the top. ![]() SOB Hybrid Mechanical Box Mod Clone + Outlaw RDA Kit Clone $22.99 The SOB Mech Kit Clone consists of SOB Mech mod Clone and Outlaw RDA Clone. Mod: The SOB Mechanical box mod Clone is constructed from brass and resin and is powered by single 18650 battery (NOT INCLUDED). The battery access door is easy to remove by hand and the inner battery tube is insulated. The venting holes are positioned at the access door. The logo and series number are on the mod. RDA: The Outlaw RDA Clone is constructed from stainless steel with 24mm diameter. The deck features classic dual post style design and comes with a deep juice well. The airflow can be adjusted by dual airslots on each side. The mod will come with random color. The drip tip will also come with random color. ![]() ShenRay Steam T Nano Kit Clone without Logo for Typhoon F GT4 RTA $8.99 The ShenRay Steam T Nano Kit Clone consists of 316 stainless steel top lid and chimney, Acrylic tank tube and POM drip tip. It is suitable for ShenRay Typhoon GT4 RTA Clone. This product comes without logo. This item also has other Version to choose. ![]() ShenRay Replacement Tank Tube + Top Cap + Drip Tip Kit for VG Extreme RTA Clone $7.99 The ShenRay Replacement Tank Tube, top cap and drip tip are made from PC and is suitable for ShenRay VG Extreme RTA Clone. ![]() Vapeasy SteamTuners T9 510 Drip Tip Clone for RDA / RTA / Sub Ohm Tank $2.99 The Vapeasy SteamTuners T9 510 Drip Tip Clone is made from stainless steel. It is suitable for all atomizers that fit 510 drip tip. ![]() Dee Mods Shorty V2 510 Drip Tip Clone for RDA / RTA / Sub Ohm Tank $2.99 The Dee Mods Shorty V2 510 Drip Tip Clone is made from POM. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
