Вернуться   Форум FONAREVKA.RU Торговая площадка Производители/Дистрибьюторы/Дилеры фонарей и аксессуаров
Просмотров в теме 79216   Ответов в теме 91   Подписчиков на тему 12   Добавили в закладки 0
Старый 13.08.2010, 22:33 Автор темы   1
Аватар для SuperFonarik.ru
Последняя активность: 04.10.2024 12:03
Сказал(а) спасибо: 243
Lightbulb Анонс EagleTac M3C4
Сегодня EagleTac анонсировали обновленную линейку популярных фонарей Military-серии.
Перевод чуть позже.
Superseding the legendary EagleTac M2 series, the EagleTac M3C4 is a compact 11 Watt high output LED flashlight offering 800 O.T.F. lumen at turbo mode (SST-50 and triple XP-G R5 models) and a maximum of 100+ hours regulated runtime at the 15 lumen low output mode. Dial the operational switch behind the head to toggle the light on/off, adjust the brightness output, and access the hidden strobe/fast beacon/SOS features.
EagleTac M3C4 offers four LED options:
Luminus SST-50 W65S WJ LED (maximum output, single LED)
Triple CREE XP-G Cool White R5 LED (maximum output, three individual LEDs)
Triple CREE XR-E Cool White R2 LED (maximum far projecting performance)
CREE MC-E M LED (high output and smooth beam. No dark center hole is detected under the new ET55 reflector)
O.T.F. lumen output:
Luminus SST-50 W65S WJ LED: 16/56/172/376/800
Triple CREE XP-G Cool White R5 LED: 15/55/172/593/800
Triple CREE XR-E Cool White R2 LED: 16/60/165/320/600
CREE MC-E M LED: 16/52/148/312/625
Typical runtime:
1.5/3.5/8/28/100+ hours
*CREE triple XR-E R2 will have approximately 10% shorter runtime due to the higher LED forward voltage.
LED driver:
New C2800 II circuit. Dial the operational ring to turn the flashlight on/off, adjust between the five brightness levels, and access the three hidden modes (strobe, fast beacon, sos). To access the hidden blinking modes, turn the ring from the turbo mode to the off/standby mode, then back to the turbo mode.
New one-piece flashlight head design (from the top of the knurling area to the battery contact point behind the head)
This allows optimal LED heatsink capability and operational reliability. The flashlight head is not sealed and user can gain access to the inside of the lens and reflector.
New durable hard anodization coating
Available in HAIII finish in black and dark gray color (40 μm in thickness and 350-380 HV in hardness). Black color will ship first, follow by the gray color.
New Reflector design in L.O.P. finish
The CREE MC-E and the Luminus SST-50 versions feature a newly revised ET55 reflector that offers smooth and high output beam without artifacts or dark center spot in the beam. The triple CREE XP-G and the triple XR-E use a new parabolic reflective curve for maximum far projecting beam and high output brightness.
The tail-stand tail-cap receives a new durable protective coating. The package also come with a para-cord lanyard with darken holding clip that fits in the tail-cap lanyard hole. The controller ring also receives the new durable protective coating.
The Flashlight head and the body are o-rings and square-rings sealed for operating in harsh and wet environments. Reverse battery polarity protection has been implemented on the battery tray for each battery channel. The water-proof tail-cap now uses stainless steel 304 mounting screws with hex heads.
Included accessories:
CNC machined 304 Stainless steel bezel
Included diffuser filter. YRGB filter kit (yellow for fog and rain) is optional.
Paracord lanyard with darken pocket clips and split ring
M series nylon holster
Side notes: Lumen output at LED
CREE MC-E M LED: 20/65/185/390/750 lumen at LED*
Luminus SST-50 W65S WJ LED: 20/70/215/470/1000 MAX lumen at the LED
Triple CREE XR-E Cool White R2 LED: 20/74/205/390/725 at the LED*
Triple CREE XP-G Cool White R5 LED: 18/70/215/475/1000 at the LED*
Data is obtained from PCT CREE.
SuperFonarik.ru вне форума   Ответить с цитированием Вверх
Старый 12.09.2010, 22:39   2
Жуков
Аватар для Жуков
Сказал(а) спасибо: 1055
По умолчанию Re: Анонс EagleTac M3C4
Сделали бы корпус из квадратного профиля под 4 батареи, цены бы небыло...
Старый 14.09.2010, 07:02   3
awl
Аватар для awl
Сказал(а) спасибо: 208
Что-то с ним совсем всё плохо - http://light-reviews.com/ea...
Старый 14.09.2010, 11:15   4
xrennov
Флешоголик в завязке.
Аватар для xrennov
Сказал(а) спасибо: 16
Чего у EagleTac не отнять, так это комплектации. Катапульт по прежнему исключение.
А может в SST-50 дело?
Старый 14.09.2010, 13:22   5
Ektomorf
Сказал(а) спасибо: 157
Посмотреть сообщение Сообщение от awl :
Это потому что SST-50. Интересно, как себя покажет версия на 3хR5.
Люменов много не бывает
Ektomorf вне форума   Ответить с цитированием Вверх
Старый 14.09.2010, 13:34   6
Mauser
Аватар для Mauser
Сказал(а) спасибо: 354
Да. Непонятно назначение фонаря... 11к люкс в хотспоте - это смешно, на такую то мощность.
На 3хR5 будет рассеяный свет, скорее всего.
Старый 14.09.2010, 14:04   7
Ektomorf
Перечитал обзор, что-то совсем плохи дела. 400 люмен вместо обещанных 800 O.T.F., 9 минут рантайма на батарейках (они нафиг правда в таком фонаре не нужны, но ведь заявлена возможность работы от батареек, и даже трубочка для них в комплекте, зачем тогда все это?), ярко выраженная дыра в центре хотспота (любители светить на стенку в упор негодуют), люксов в 2 с лишним раза меньше чем у Катапульты, к тому же у нее и дырки такой в хотспоте нет. EagleTac вообще фонарь перед выпуском не тестировал?
З.Ы. Когда уже будут фонари на XM-L и закончится этот ужас с диодами от Luminus...
Старый 14.09.2010, 14:22   8
Mauser
Аватар для Mauser
Посмотреть сообщение Сообщение от Ektomorf :
и начнется ужас с новыми диодами
Там свои подводные камни "всплывут", гарантирую
Старый 14.09.2010, 18:17   9
awl
Аватар для awl
Как SST-50 может вообще слить SSC P7? Такое впечатление, что обзор первоапрельский, не верится в такой ужас.
Старый 14.09.2010, 20:13   10
xrennov
Аватар для xrennov
Да у них и второй катапульт тусклее первого, так что одно из трёх - либо у SST-50 дикий разброс характеристик, либо обзор написан специальным образом, лиюо всё так и есть.
Старый 14.09.2010, 20:23   11
awl
Аватар для awl
Про катапульт v2 всё правильно, читал обсуждение этой странности на CPF. Юзеры там вроде тоже не увидели преимущества V2 над V1.
Скорее всего EagleTac поторопились с тестовым экземпляром, подобное было с другими обзорами на light-reviews, например с Tiablo ACE-G.
Старый 14.09.2010, 20:52   12
xrennov
Аватар для xrennov
Если первый катапульт от второго не отличается, то с этим как быть - http://lygte-info.dk/review... ?
Старый 14.09.2010, 21:19   13
awl
Аватар для awl
Ну может после того обзора исправились... Кстати, насколько я помню, для обзора lights-reviews сам производитель (Thrunite) выделял тестовый фонарь.
Старый 14.09.2010, 21:41   14
xrennov
Аватар для xrennov
Мне вот интересно, тестовый экземпляр, выдающий малую мощность у кушающий батарейки круче чем М6 на тест посылать? Зачем оно надо? Антирекламу себе делать то? Вон там ещё на горизонте олайт М31 замаячил - который, судя по паре карликовых бимшотов ( http://www.candlepowerforum... конец страницы, буду любезен, если кто-нибудь расскажет, чего там говорят, а то я не грамотный), рвёт, как Тузик грелку, вообще всё на SST-50, что было до него. И вот тут такой EagleTac вылезает с бэта-версией своего сцуколастера, вот меня это повергает в смутные сомнения.
Старый 15.09.2010, 00:30   15
Mauser
Аватар для Mauser
Посмотреть сообщение Сообщение от xrennov :
да, получше катапульты будет по свету
Старый 15.09.2010, 10:27   16
Tymmmi
Аватар для Tymmmi
Последняя активность: 04.10.2021 09:16
Сказал(а) спасибо: 53
всегда знал что SST50 отстойный диод))) жду с нетерпением обзора R5 версии по сравнению с R2
Tymmmi вне форума   Ответить с цитированием Вверх
Старый 15.09.2010, 11:37   17
xrennov
Аватар для xrennov
Вот ещё крайне любопытно - чем они пожертвовали, чтобы такую яркость сделать? Временем работы - безусловно, вопрос в другом, как быстро вся эта конструкция будет вырубаться от перегрева? Катапульт-то уже является переносным обогревателем(рёбер пожалели, демоны), а тут, видимо, ещё круче будет. И вот тут мои рассуждения наталкивают меня на интереснейшую мысль - а куда в M3C4 тепло то девается? Рёбер - кот наплакал, поверхности по большому счёту тоже, так куда?
[Исправлено: xrennov, 15.09.2010 в 11:40]
Старый 15.09.2010, 18:05   18
awl
Аватар для awl
Если бы аномалия была только в люксах, люменах, и времени работы, это ещё можно списать на неудачный драйвер, но ведь ещё адский бублик на хотспоте, каких на серийных фонарях вообще не бывает ни у кого.
Хотя в первом сообщении написано:
Старый 15.09.2010, 19:01   19
xrennov
Аватар для xrennov
Шизойдненько как-то получается в целом, они чего? Сами себе противоречат выходит? Бэта-версия прямиком из ада, блин.
Старый 20.09.2010, 13:54   20
Ektomorf
Вот результаты тестов от selfbuilt по версии на SST-50. Обзор еще не вышел, правда, но он опубликовал некоторые цифры, чтобы успокоить панику по поводу этого фонаря. Выходит, на light-reviews был обзор какого-то недоделанного семпла или просто бракованного образца.
Честно спер картинки с CPF.
Время генерации страницы 0.14290 секунды с 16 запросами
