111738
183
17
Petzl Nao
![]() https://youtu.be/M1Y-69Q8NCk ![]() LAS VEGAS, Nv. - The Petzl Nao is a new-generation head torch that represents a genuine step forward in hands-free lighting. The Nao uses Petzl's innovative Reactive Lighting technology, providing light that automatically adapts to your environment. A sensor constantly monitors reflected light from your direction of vision and adapts the head torch output accordingly. This means there is no need to manually adjust brightness when switching between close or distant objects. The dual benefit is automatic optimisation of battery output, giving extended burn times. The Petzl Nao gives you the right light when you need it - automatically. One of the big problems with today's head torches is the relationship between high-performance LED power consumption and battery capacity. The choices are limited; either unregulated light, giving rapidly diminishing light output, or regulated output where maximum power is only available for relatively short periods. Petzl's Reactive Lighting technology allows your battery to optimise its output, only providing the power you need for the environment you are operating in. The result is that battery life can last at least three times longer than it would do under constant full power*. The Petzl Nao features a front headset with twin LEDS and sensor, linked to the rear-mounted battery by the new Zephyr cord-lock headband. The battery is a 2300 mAh lithium-ion unit, rechargeable via an integrated USB plug. There is a belt kit version for the battery, plus a detachable top strap for additional stability when running. Lighting is controlled via a large rotating on/off switch, which can be locked in the 'off' position. The switch allows the user to choose between Reactive Lighting or Static modes, with high/low output options in each. Static lighting gives a fixed output (non-reactive). In Reactive Lighting mode the headset uses a single high-output LED in a wide-angled beam. In Static mode the headset uses both the wide-angled beam and a second high-output LED configured for a focused beam. Maximum power output is 355 lumens. Performance profiles can be customised via Petzl's OS 2.0 on your computer. For 'emergency use', the battery pack will accept 2 x conventional AAA batteries. The Petzl Nao will be available in the UK in July and retails for £135. источник http://flashlightnews.org/s... ![]() ![]() http://vimeo.com/petzl/nao ![]() Rechargeable headlamp with self-adjusting lighting - REACTIVE LIGHTING technology The rechargeable NAO headlamp adapts its two high power LEDs instantly and automatically to the lighting needs for greater comfort, fewer manual interventions and longer battery life. NAO is the first Petzl headlamp with REACTIVE LIGHTING technology. Available in July 2012 ![]() Optional belt kit for NAO allows the rechargeable battery to be moved to the belt to reduce the weight worn on the head, or to keep it warm in winter. Lithium Ion battery recharges easily with the integrated USB connection. ![]() ![]() ![]() ![]() Цитата:
[Исправлено: serj_32, 27.01.2012 в 01:48] |
Регистрация: 22.07.2011 Последняя активность: 18.11.2023 02:09
Сказал(а) спасибо: 91
Все это на понятном языке написали бы - сказал бы спасибо.
skorp777 (20.12.2015)
Администратор
Сказал(а) спасибо: 4330
Новый фонарь от Petzl – NAO.
Компания Petzl показала крайне интересный налобный фонарь. Интересен он прежде всего технологией автоматической подстройки яркости в зависимости от ситуации и универсальностью блока питания. Но обо всём по порядку. Общий вид фонаря достаточно необычен: во-первых, вместо классической резинки используется шнурок, который экономит место и более долговечен (резинка тоже есть, но ровно столько, чтобы давать комфорт), во-вторых, в налобном блоке появился Light-sensor, по сути это светочувствительный элемент, который на основе получаемой им информации регулирует мощность и тип освещения. Например, при нахождении в небольшом замкнутом помещении из-за большого количества отраженного света фонарь будет понижать мощность до средней и включать рассеянный свет, а на открытой местности, где отраженного света практически нет, будет задействован максимальный по мощности и направленности свет. Это позволит меньше использовать руки для управления фонарём и сэкономит заряд батареи. В качестве источника питания используется литий-ионный аккумулятор с зарядкой по USB. По USB, кстати, осуществляется не только зарядка батареи, но и возможно программировать фонарь с помощью OS by PETZL, которе также используется для управления фонарями с технологией CORE, такими как Tikka XP2 CORE. Настроить можно общий профиль работы: направленность на максимальную мощность или, ноборот, - экономичнасть. Сводная таблица характеристик фонаря мощность\продолжительнасть работы: Под Level1 и Level2 понимаются два принципиально разных режима работы фонаря. Level1 – это и есть технология Reactive Lighting, быстрый выбор режима, полный диапазон используемой мощности от минимальной до максимальной. Level2 же направлен на постоянное получение некой средней постоянной мощности. Для данного фонаря будет доступен пояной батарейный блок, который можно убрать в рюкзак или под одежду. Вес фонаря с аккумулятором составляет 187г. Фонарь протестирован на защиту от влаги по стандарту IP X4. В продаже ожидается в Июле 2012 года. [Исправлено: vaska, 27.01.2012 в 09:31] |
Gaffer
По мне куда интеоеснее HL30 будет
Все относительно.
Петцел в чем то уникальный, но в тоже время довольно усложнен. Заметил на видео интересный момент - когда свет попадает на лицо собеседника что то фонарик не уменьшает яркость. А вот фениксу уже давно пора сделать батарейный блок как у этого петцела или шура саинт (что бы и литиевые акумуляторы и АА батарейки можно было ставить)
Ну и гроб на затылке соорудили!!!! О компактности даже не думали, и это под 1х18650! Руки им в рот! Прям ужас пробежался по затылку). Это ж надо было.... сделать компактную голову и сзади чемодан с батарейкой!
всегда в дороге |
yeti (30.10.2013)
Сказал(а) спасибо: 5056
Даа. Аппарат интересный! Нравится необычностью.
Не знаю, насколько удобен новый шнурок - в варианте без каски он может доставлять дискомфорт на волосах головы. Чемоданчик с батарейками - дааа - какой-то как не от этого фонарика... |
Еще из инета на русском:
Источник: http://www.risk.ru/users/pe... ![]() Первый налобный фонарь с саморегулирующимися режимами освещения - технология REACTIVE LIGHTING Перезаряжаемый фонарь NAO мгновенно адаптирует два светодиода высокой мощности, подстраиваясь к потребностям в освещении. Минимум движений, максимум комфорта и экономия заряда аккумулятора. NAO является первым фонарем фирмы Petzl с технологией освещения REACTIVE LIGHTING. ![]() Дополнительный набор для NAO позволяет переносить аккумулятор на поясе, что бы уменьшить вес фонаря на голове и сохранять его в тепле зимой. ![]() Литий-ионная батарея легко перезаряжается при помощи встроенного USB выхода. Саморегулирующееся освещение. ![]() Встроенный световой сенсор ориентирован в направлении Вашего взгляда. Он измеряет и анализирует отраженный свет для того, что бы мгновенно настроить луч фонаря (широкий или сфокусированный) а также яркость освещения. Для ближнего освещения Когда вы смотрите на объект, находящийся вблизи, например на карту, работаете с веревкой или устанавливаете палатку, луч становится широким и менее ярким. Освещение подстраивается автоматически в зависимости от дистанции до объекта. Для движения Хогда вы ходите или бегаете - луч широкий и имеет среднюю мощность, достаточную для того что бы осветить препятствия на пути. Для дальнего освещения Когда вы поднимаете голову, что бы посмотреть вдаль в поисках маркера или точки страховки для подъема, световой поток усиливается и становится более сфокусированным. Преимущества саморегулирующейся технологии освещения REACTIVE LIGHTING. Технология REACTIVE LIGHTING это революция в сфере налобных фонарей. Встроенный световой сенсор мгновенно адаптирует луч фонаря и мощность светового потока к потребностям пользователя. Это означает, что пользователь получает идеальное количество света при минимуме ручной регулировки. Такой режим освещения также обеспечивает более продолжительную работу фонаря благодаря эффективному использованию аккумулятора. Адаптированное освещение. Форма и яркость луча мгновенно адаптируются для ближнего, среднего и дальнего освещения, так что пользователь всегда получает нужное количество света. Минимум ручной настройки Налобный фонарь автоматически адаптируется к изменениям окружающего освещения, позволяя пользователю сосредоточится на основной активности, а не заниматься настройкой фонаря. Увеличенное время работы Технология REACTIVE LIGHTING увеличивает время работы фонаря благодаря более эффективному использованию аккумулятора. Освещение адаптируется по мере надобности, снижая время бесполезного использования режима высокой яркости. ![]() Пример кривой освещения для саморегулирующегося фонаря. Освещенность меняется согласно тому, для чего используется фонарь. Режим REACTIVE LIGHTING Освещение автоматически адаптируется согласно необходимости (световой поток и ширина луча). Саморегулирующийся режим освещения увеличивает время работы фонаря, оптимизируя использование ресурсов аккумулятора. Средняя мощность освещения фонаря рассчитывается исходя из полевых испытаний. Режим постоянной яркости Освещение остается на постоянном уровне, обычно высоком, в течении определенного периода времени (в зависимости от настроек фонаря) и мгновенно снижается в конце этого периода. Этот режим освещения разработан, например, для трекинга, когда необходима максимальная мощность. https://www.youtube.com/watch?feature=player_embedded&v=FZb3k_x067w В продаже с Июля 2012 ---------------------------------------------------------------- Источник: http://www.radiomaster.ru/r... Petzl NAO – налобный фонарь с реактивным освещением Практически каждый может представить себе образ шахтера, который, рискуя жизнью и здоровьем, работает глубоко под землей с целью извлечь из недр какой-нибудь минерал. Люди этой профессии носят специальные налобные фонари, помогающие им видеть в темноте. Конечно, прикрепленный к ремню фонарь достаточно эффективно выполняет свои функции, и все же специалисты продолжают снова и снова изобретать это «колесо». Одной из новых вариаций такого приспособления стало устройство от французской компании Petzl, специализирующейся на производстве снаряжения для альпинистов и спелеологов. Новинка представляет собой налобный фонарь под названием NAO. От себе подобных устройство отличается, прежде всего, тем, что обладает так называемым «реактивным освещением». NAO – самый яркий фонарь в линии продуктов Petzl, поскольку может излучать световой поток, равный 355 лм. Однако новинка может похвастаться не только сильными «мускулами», но и «мозгами». Прямо над двумя светоизлучающими диодами расположен сенсор, способный измерять окружающий свет и на этой основе регулировать характер испускаемого луча, что позволяет пользователю получить оптимальное в данных условиях количество света, не тратя впустую заряд аккумулятора. Например, если вокруг темная безлунная ночь, и человек смотрит прямо перед собой, NAO осветит ему путь мощным и длинным лучом. Если же ситуация изменится, и пользователь опустит голову, чтобы посмотреть на карту, луч станет маломощным и широким. В сущности, компания Petzl рассчитывает, что технология реактивного освещения сможет заменить имеющиеся сейчас на рынке фонари с двумя режимами – гашения и постоянного освещения. Первый максимизирует время свечения фонаря за счет постепенного снижения количества света на выходе. В постоянном режиме интенсивность не меняется, но довольно быстро истощается аккумулятор. Реактивное освещение объединяет оба режима в одном решении, позволяя пользователю получать необходимое количество света в разных условиях. Petzl намерена начать поставки нового фонаря в июле по цене 175$. И видео:
https://www.youtube.com/watch?v 9t2LZMwXZ0Оф. сайт http://www.petzl.com/us/out... |
Рискнули Петцели сильно, скорее всего большинство будут материть эту автосистему регулировки), хотя если они туда поставят мощный процессор, интеллектуальную программу распознания обстановки по видео изображению...... )))))) Тут товарищи Петцель фаны загорелись, цена их не отпугивает, закажут, буду их пытать сильно на предмет впечатлений....
Gaffer
Многие брендовую фото/видеотехнику ругают за некорректную экспозицию, баланс белого итп. А у них опыт в создании фотоэлектроники гораздо больше. А тут вдруг пецль решил создать первый такой фонарь. Кто то должен был начать. Кенон, например, вряд ли когда нибудь начнеть конструировать фонари. Конечно будет много ошибок поначалу. Чтобы создать действительно интелектуальную систему нужны большие вложения,время, мощная электроника и хорошее питание для нее. Но спасибо, что не побоялись сделать первый шаг навстречу будущему фонарестроения, не смотря на неизбежную критику.
Dnv (01.04.2016)
Регистрация: 06.01.2012 Последняя активность: 21.07.2012 16:05
Сказал(а) спасибо: 28
да не надо все усложнять, у автоматики пецля задача тривиальная, обеспечить примерно одинаковый уровень на примерно фиксированном пятне.
Интересное решение, в качестве оптики на сенсор поставлен коллиматор, такой же как на дальнем свете. А автоматике да, достаточно поддерживать среднюю освещённость постоянной.
причем даже ошибка в 2 раза останется незамеченной, тоесть высокой точности тоже не требуется
Регистрация: 31.01.2012 Последняя активность: Сегодня 08:19
Сказал(а) спасибо: 1320
Поблагодарили: 549 раз(а) в 353 сообщениях
Пока нет ни одного обзора реальных образцов, рано делать выводы, и тем не менее.
1 или 2 ручных режима с постоянной яркостью - это мало, очень мало. 3-4 - разумный минимум, как показывает практика. Режимы настраиваются через усб порт - красиво в рекламе, но неудобно в жизни. А вот 2 излучателя, широкоугольный рассеянный и узкий луч - очень хорошо. Правда, вроде-бы написали, что в режимах с постоянной яркостью они всегда горят вместе - если так, то это плохо (думаю, всё же можно будет выключать) и уничтожает удобство 2х излучателей. ipx4 - маловато защиты. Такой фонарь носят в любую погоду, в тч. под проливным дождём. Например, Зебра выдерживает ливень без проблем. "Optional belt kit for NAO allows the rechargeable battery to be moved to the belt " Ну и жадность у Петцля - даже при такой цене дополн. шнурок всё равно за отдельные деньги. [Исправлено: Evgeniy1, 01.02.2012 в 21:13] |
не пробовал. Но ливень - это летящие капли, давление будет побольше, чем 30см воды (на что и сертифицирован Петцль). У Зебры - до 2м, кажется.
17
Дело в том, что на форуме есть сообщения, что Зебры текут...
Gaffer
20
Есть в сети сообщения что петцели текут) Постараться можно найти))) Такое бывет со всеми (я про сообщения, а не про течи). Мне было интересно, я испытывал часы на водопрочноть, заодно и Зебру н51, купался в аквапарке, там как раз такие полутемные тоннельчики по кругу, где есть течение. Они как раз подходят для купания и ныряния с фонарем на голове))))). Всем рекомендую попробовать))))
