Вернуться   Форум FONAREVKA.RU Торговая площадка Производители/Дистрибьюторы/Дилеры фонарей и аксессуаров
Просмотров в теме 29490   Ответов в теме 15   Подписчиков на тему 5   Добавили в закладки 0
Старый 22.07.2011, 10:51 Автор темы   1
Аватар для ThruNite
Последняя активность: 14.08.2010 12:33
По умолчанию New models. TN10 and TN11 released
TN10 Features
² LED: Cree XM-L LED T6 with a lifespan of 50,000hours
² Use one 18650 or 2*CR123A batteries
² Rated operation voltage 2.7v to12v
² Crenellated SS bezel
² Removable SS clip
² Copper base plate for more efficient heat
² Shiny smooth reflector and get perfect beam
² Max light output:650lumens.When use 2Cr123A or 3 or 4 Cr123A or 2 18650 rechargeable batteries. 2.5A current for 4 minutes and then down to 2.2A (extended tube are not included in the package)
² Max runtime:706hours(0.2 lumens)
² Runtime: 98 minute for 1 18650 (2600MAH) down to 50%. 50minutes down to 50%(2CR123A )
² Max beam distance:245m
² Peak beam intensity:21348cd
² Impact resistance:1.2m
² Waterproof to IPX-8 standard
² 148mm(length)x35mm(bezel diameter)25.4mm(Body diameter)
² Weight:145g( without battery)
² Made of durable aircraft grade aluminum
² Premium Type III hard-anodized anti-abrasive finish
² Toughened ultra-clear glass lens with anti-reflective coating
Battery reverse protection function. And batteries low indication(it will flash when voltage down to 2.7v)
ThruNite вне форума   Ответить с цитированием Вверх
Старый 22.07.2011, 10:52 Автор темы   2
ThruNite
Аватар для ThruNite
По умолчанию Re: New models. TN10 and TN11 released
TN11 Features
² Use one 18650 or 2*CR123A batteries or 3 Cr123A.( one extended tube included )
² Removable SS clip
² Max light output:830lumens.When use 3 or 4 Cr123A or 2 18650 rechargeable batteries. Max output for 10 minutes and then down to 85%(extended tube are not included in the package)
² Max runtime:745hours(0.2 lumens)
² Runtime: 75 minute for 1 18650 (2600MAH) down to 50%. 47minutes down to 50%(3CR123A )
² Max beam distance:355m
² Peak beam intensity:28900cd
² 154mm(length)x41mm(bezel diameter)25.4mm(Body diameter)
² Weight:165g( without battery)
Старый 22.07.2011, 10:53 Автор темы   3
ThruNite
Аватар для ThruNite
Operation
Power on/off switch
Press the pushbutton halfway to momentarily activate the light.
Press the pushbutton completely (click) to turn on the flashlight. The light will stay on until the pushbutton is pressed fully to turn off.
Mode switch
At loosen station of head.Screw the ring on the body (tighten→loosen→tighten→within 2s)to have the output from firefly mode→infinite brightness from5% to 89%)→slow strobe→quick strobe, you can lock out to select any of the mode you need by screw the body tighten to loosen within 0.5s
Старый 22.07.2011, 11:03   4
serj_32
Обычный тактик. Надо вживю смотреть
Старый 22.07.2011, 11:09   5
den24
Аватар для den24
Последняя активность: 23.04.2015 08:57
Сказал(а) спасибо: 13
Отправить сообщение для den24 с помощью ICQ
Фото бы побольше, с разных ракурсов.
den24 вне форума   Ответить с цитированием Вверх
Старый 26.07.2011, 00:58   6
xrennov
Флешоголик в завязке.
Аватар для xrennov
Сказал(а) спасибо: 16
Пара вопросов - зачем в таких фонарях больше 450 люмен? Какие режимы в этих фонарях? И главное - что случилось с дизайнером катапульт в2? Фонари как-то убого и скучно выглядят.
Старый 26.07.2011, 09:50   7
selenopolis
Gaffer
Аватар для selenopolis
Последняя активность: Сегодня 00:03
Сказал(а) спасибо: 3228
Поблагодарили: 3109 раз(а) в 1005 сообщениях
Да-фонари совершенно банального вида,даже люмитоп выглядит интереснее.Единственное порадовал 11ый - можно взять в коллецию как современный компактный дальнобойник.Я запорол как то переполюсовкой раптор-1 и поменял по гарантии на кучку олайтовских АА-шников.С тех пор скучаю по маленьким "катапультам"
Старый 03.08.2011, 19:45   8
xrennov
Аватар для xrennov
Касательно TN10 - а так не лучше было бы?
Мне плевать - какое оно есть, я знаю каким оно должно быть!!!
P.S. Подайте страждущему флешаголику топовый фонарик на тестирование.
Старый 03.08.2011, 20:31   9
Децибел
Аватар для Децибел
Последняя активность: 12.03.2023 20:54
Сказал(а) спасибо: 26
Хм а мне одному кажется что они оба на гладиус похожи???
Децибел вне форума   Ответить с цитированием Вверх
Старый 03.08.2011, 22:33   10
RN4HKK
Любитель Surefire
Аватар для RN4HKK
Сказал(а) спасибо: 34
Мне кажется свет будет как у скорпиона. Разница только в обычной и турбо башке. Вот например моя турбо башка от скорпиона 1:1 как у TN11.
Старый 03.08.2011, 22:47   11
selenopolis
Gaffer
+1.Вот и я когда увидел - сразу вспомнил эту голову - ну один в один
Старый 04.08.2011, 02:10   12
Tim4r70
мне в обще все до фонаря
Последняя активность: 05.12.2014 00:29
Сказал(а) спасибо: 36
Поблагодарили: 31 раз(а) в 26 сообщениях
а ведь есть же 2С
вот его бы на 18650
а так то ли конкурент скорпиону, то ли замена
может хоть пояснят что хотели?
Tim4r70 вне форума   Ответить с цитированием Вверх
Старый 04.08.2011, 02:26   13
xrennov
Аватар для xrennov
Пусть сперва пояснят зачем в этом фонаре режимы не совместимые с жизнью одного 18650.
Старый 07.09.2011, 22:08   14
Admin
Администратор
Аватар для Admin
Сказал(а) спасибо: 4330
Старый 07.09.2011, 22:18   15
Admin
Администратор
Аватар для Admin
Konstantini4, я вынес Ваш обзор в отдельную тему Обзор ThruNite TN10.
Буду признателен, если Вы там будете оставлять Ваши отзывы о данном фонаре! Еще раз спасибо за обзор!
Старый 02.06.2020, 16:35   16
Konstantini4
Последняя активность: 24.08.2021 22:31
Перестал у меня Thrunite TN10 нормально работать, - после включения мигает 4 раза и средненько так светит, режимы не меняются, что не делай.
Может кто сталкивался, какой драйвер лучше поставить вместо штатного? Диаметр платки 25мм.
Konstantini4 вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.12626 секунды с 16 запросами
