Просмотров в теме 27405   Ответов в теме 2   Подписчиков на тему 3   Добавили в закладки 0
Старый 04.08.2016, 20:46 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Sony US18650VTC6 3000mAh (Green)
Official specifications:
  • Typical capacity: 3120mAh
  • Minimum capacity: 3000mAh
  • Nominal voltage: 3.6V
  • Standard charge: CC/CV, 0.2C, 4.2V
  • Standard discharge: CC, 0.2C, 2.5V
  • End-of-charge voltage: 4.2V +/-0.05V
  • End-of-charge current: 0.02C (About 62mA)
  • End-of-discharge voltage: 2.00V
  • Continuous maximum discharge: 5C/10C (15A/30A) with temp cutoff at 80°C
  • Max. discharge current vs. time: 30A-40A > 44s, 55A > 19s, 80A > 6s (Never discharge above 80°C)
  • Cycle life: 300 cycles @ 0.5C to 80%
  • Initial impedance: 8mOhm - 18mOhm
  • Weight: 46.4g +/- 1.5g
  • Operating temperature: Charging 0°C ~45°C, discharging: -20°C ~ 60°C
  • Storage temperature: -5°C ~ 35°C
The latest and probably last high current battery from Sony and it was a very high capacity together with the high current.
There is no doubt this is a quality battery, the curves track perfectly and capacity is nearly constant with current.
At high current the battery gets hot and I stopped the 20A and 30A test due to that.
At 15A or greater Sony species that there must be a temperature cut-out at 80°C, I could just stay below that at 15A
But at 20A and 30A I hit 80°C or rather went above. Here I was up to 91°C.
Conclusion
Very few batteries can handle high current as well as Sony VTC batteries and this cell also high capacity.
But this cell is not "draw all the current you want and stay safe" (That type of battery do not exist), to stay safe some requirements must be fulfilled!
I will rate it a very good battery.
Notes and links
The batteries was supplied by ENERDan for review.
Sony are in the process of selling their battery division (Except alkaline) to Murata.
Поблагодарили: 10 раз(а)
alexsav (18.08.2024), awl (08.10.2016), Behram (16.11.2016), Garrik (04.08.2016), Kzakkttixx (31.08.2016), Labour (17.08.2016), PopovSergej (04.08.2016), sakost (13.01.2018), ser-kras (05.08.2016), Сумской (05.08.2016)
Старый 18.08.2024, 00:33   2
Последняя активность: Сегодня 19:47
Сказал(а) спасибо: 67
Поблагодарили: 7122 раз(а) в 3927 сообщениях
По умолчанию Re: Test/Review of Sony US18650VTC6 3000mAh (Green)
Четыре года назад брал на nkon комплект из 4 АКБ VTC6 для фонаря Astrolux MF02S.
С тех пор они лежат в фонаре, в среднем раз в год я их достаю и подзаряжаю.
Вот сегодня в очередной раз подзаряжал.
Они прямо как пловцы-синхронисты. У всех четырех один уровень напряжения 4.14 В, все четыре показали примерно одинаковое внутреннее сопротивление (на Vapcell S4+), все четыре дозарядились почти одновременно (чуть больше минуты между первым и последним).
Ляпота.
Drex (18.08.2024), fnksb (18.08.2024), Kr_Apis (19.08.2024), vorsmann (18.08.2024), Наиль Валиахметов (18.08.2024)
Старый 18.08.2024, 09:13   3
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Последняя активность: 02.11.2025 09:24
Сказал(а) спасибо: 10200
Аккумуляторы действительно хорошие. У меня 3 таких. Я ими очень доволен.
In Fino verytas
Время генерации страницы 0.09932 секунды с 15 запросами
