Регистрация: 01.08.2011 Последняя активность: 09.06.2017 16:17
Сказал(а) спасибо: 4
Поблагодарили: 403 раз(а) в 87 сообщениях
![]() ![]() The Jet-μ and jet-1 MK are the current 1xAAA and 1xAA light, with a simple and easy to use twisty interface, from Jetbeam. The packaging is a small standard clear plastic packaging. . . ![]() The lights come with removable pocket clip (attached), spare o-ring, lanyard, user manual, and warranty card. . . Manufacturer Specifications from user manual : 1. Jet-μ • Small size, convenient for everyday carry, special design for hiking, camping, fixing, and emergency use • Three bright model with memory function, max output to 135 lumen • Max beam distance to 46 meters, max 518cd • Effective power management circuit ,max working time to 35hours • Battery reversed protection function • Waterproof levels to IPX8 (under water 2 meters) • 1 meter impact resistant • LED:Cree XP-G2 • Glass : Toughened ultra-clear mineral glass • Body material : Aircraft aluminum alloy • Surface anodize : Military hard III anodize • Battery : 1 units AAA battery ![]() 2. Jet-1 MK • Small size, convenient for everyday carry, special design for hiking, camping, fixing, and emergency use • Three bright model with memory function, max output to 480 lumen • Max beam distance to 130 meters, max 4200cd • Effective power management circuit ,max working time to 100hours • Battery reversed protection function • Waterproof levels to IPX8 (under water 2 meters) • 1 meter impact resistant • LED:Cree XP-G2 • Glass : Toughened ultra-clear mineral glass • Body material : Aircraft aluminum alloy • Surface anodize : Military hard III anodize • Battery : 1 units AA battery ![]() . . ![]() ![]() ![]() ![]() The lights look small for their respective classes. Both lights came with in dark gray anodizing and there is neither flaws nor blemishes on the body. Labels are sharp and clear in bright white against the background. The lights have no tail switch. Fit and finish look very good. . . ![]() The lights have 2 parts. The pocket clip works as a good anti-roll device. . . ![]() The Jet-μ comes with a TIR optic lens and Jet-1 MK has a smooth reflector with a glass lens. . . ![]() ![]() The head has a clean looking cylindrical design. The head is mostly covered in diamond-shaped knurling. Both lights have aggressive knurling, which makes it easier to use the twist feature one-handed. . . ![]() Note that the same reverse polarity detector in the head to both lights. . . ![]() ![]() The Jet-μ uses a XP-G2 S2 emitter. Centering of the emitter were nearly perfect on my sample. . . ![]() ![]() The Jet-1 MK uses the same XP-G2 S2 emitter as the Jet-μ. Centering of the emitter were not perfect on my sample, even though there is a centering disc. The light uses toughened ultra-clear mineral lens where the blue hue is reflected on it. The reflector has a smooth pattern, but not overly deep. It is well polished with no noticeable finishing flaws. . . ![]() ![]() There is a very sturdy removable single-direction clip attached to the tail region of the battery tube. It holds onto the light securely. It is not reversible. With the pocket clip attached, overall grip is very good. Mode changing with single-handed work fine. . . ![]() Like many other lights in this class, both lights use a removable spring for the negative contact, which reduce the risk of accidentally crushing a battery. The wall thickness of the body is 1.4mm (Jet-μ) and 2.8mm (Jet-1 MK) respectively. The light feels quite solid to use. . . ![]() The screw threads are square-cut of good quality. Threads are well machined, and anodized which allows the light to be locked-out. As supplied, threads are lubricated. Screw threads action is quite smooth with no cross-threading or squeaking in my samples. . . ![]() ![]() ![]() The lights come with a lanyard. There is thoughtfully two attachment points for a lanyard or key-ring at the tail end. The lights can tailstand. Note that a small female screws hole is recessed into the tail base of the Jet-1 MK. You can attach an attacking cone to the hole. This cone is used to beat a target, breaking glasses in emergency or self rescue. . . User Interface Jet-μ and Jet-1 MK have same UI. To turn the light on, fully tighten the head. To switch output modes, do a rapid twist off-on to advance to the next level. Mode sequence is Low -> Med. -> High, in repeating sequence. The lights have mode memory, and remember the last output level used when you turn the light off and back on, even after a battery change. There is no flashing modes (i.e., Strobe or SOS). . . ![]() ![]() From left to right, Panasonic Eneloop AAA (750mAh), Olight i3E EOS (Luxeon TX), Fenix E99 Ti (XP-E2), Bronte BT01 (XP-G2), Jetbeam Jet-μ (XP-G2 S2), Ultratac K18 (XP-G2 S2), Lumintop Tool AAA Copper (Nichia 219B). . . ![]() ![]() From left to right, Panasonic Eneloop AA (1900mAh), Fenix LD15 (XP-G R4), Jetbeam Jet-1 MK (XP-G2 S2), Xeno ES1 V2 (XP-G2 R5), Xeno E03 V2 (XP-G2 R4), Fenix LD11 (XP-G2 R5). . . Measured Dimensions 1xAAA lights ![]() . . 1xAA lights ![]() . . Jet-μ ![]() . . Jet-1 MK ![]() Both Jet-μ and Jet-1 MK are small lights, and good size to hold and use for your EDC. Overall build quality is excellent. . . PWM Jet-μ ![]() . . Jet-1 MK ![]() Jet-μ and Jet-1 MK show no sign of PWM at any output level. I can't hear any buzzing sound at any output. . . [New 16.09.10] ![]() However, Jet-1 MK shows flickering of PWM at Low and Med. output level with a rechargeable 14500. I can't hear any buzzing sound at any output. [New 16.09.10] . . Runtime The runtime to fall to 10% of its initial output from 30 seconds after the point the light is first turned on (i.e., based on ANSI FL-1) for High is as follows : Jet-μ on 1xEneloop AAA ![]() . . Jet-1 MK on 1xEneloop AA ![]() . . Jet-1 MK on 1xSoshine 14500 ![]() . . Jet-μ and Jet-1 MK ![]() As expected, the higher capacity cell gives you extended runtime in both lights. Regulation in Jet-μ is maintained nicely through High mode. Jet-1 MK maintains perfectly flat regulation for an extended period, before dropping output. 10440 Li-ion is not supported in the Jet-μ user manual. It's good 14500 is officially supported in the Jet-1 MK with very higher output. Both lights have good mode spacing. . . Beamshot Jet-μ 1. White door beamshot (about 50cm from the white door) on max. output on 1xPanasonic Eneloop AAA (750mAh) - ISO125, F/8.0, 1/25sec, Auto white balance ![]() ![]() ![]() ![]() . . ![]() ![]() ![]() ![]() . . - ISO125, F/8.0, 1/800sec, Auto white balance ![]() ![]() ![]() ![]() . . - ISO125, F/8.0, 1/2000sec, Auto white balance' ![]() ![]() ![]() ![]() Thanks to TIR optic, beam pattern is the focused hot spot for throw with very minimal side spill (i.e., not flood light). The light shows reasonably good beam quality. The hotspot shows yellowish white tint, and the side spill looks a bit bluish purple. The overall tint is slightly close to cool white. . . 2. 3.0m Indoor Beamshot on max. output on 1xPanasonic Eneloop AAA (750mAh) - ISO125, F/2.8, 1/5sec, Auto white balance ![]() . . ![]() . . 3. 3.5m Indoor Beamshot on max. output on 1xPanasonic Eneloop AAA (750mAh) - ISO125, F/2.8, 1/5sec, Auto white balance ![]() . . ![]() . . 4. 7.0m Indoor Beamshot on max. output on 1xPanasonic Eneloop AAA (750mAh) - ISO125, F/2.8, 1/5sec, Auto white balance ![]() . . ![]() . . Jet-1 MK 1. White door beamshot (about 50cm from the white door) on max. output on 1xPanasonic Eneloop AA (1900mAh) - ISO125, F/8.0, 1/25sec, Auto white balance ![]() ![]() ![]() ![]() . . ![]() ![]() ![]() ![]() . . - ISO125, F/8.0, 1/800sec, Auto white balance ![]() ![]() ![]() ![]() . . - ISO125, F/8.0, 1/2000sec, Auto white balance' ![]() ![]() ![]() ![]() Hard to see in the beamshots above, but there is a fairly noticeable ring around the hotspot and it's an irregular shape (i.e., not perfectly circle). I think it's due to the smooth reflector with non-accurate centering of the emitter and the round stain on the internal center of the lens. It is quite noticeable in practice and using the light illuminating a close-up white wall (up to around 4m distance). The light has a small sized bright hot spot. A soft corona surrounding the hotspot is very slightly greenish yellow. The hotspot is pure white, and the side spill shows a bit bluish purple. The overall beam profile is acceptable. The beam has a typical cool tint on my sample. . . 2. 3.0m Indoor Beamshot on max. output on 1xPanasonic Eneloop AA (1900mAh) - ISO125, F/2.8, 1/5sec, Auto white balance ![]() . . ![]() . . 3. 3.5m Indoor Beamshot on max. output on 1xPanasonic Eneloop AA (1900mAh) - ISO125, F/2.8, 1/5sec, Auto white balance ![]() . . ![]() . . 4. 7.0m Indoor Beamshot on max. output on 1xPanasonic Eneloop AA (1900mAh) - ISO125, F/2.8, 1/5sec, Auto white balance ![]() . . ![]() . . Overall Impressions Jet-μ • Excellent build quality • The light can tailstand • Anti-roll indentations on the body • Physical lockout function • Physical reverse polarity protection function • Regulation is maintained nicely on Eneloop through High mode • 10440 Li-ion is not officially supported • Mode memory • Good mode spacing • Lower low mode is available • No PWM at any output level • Overall beam tint is slightly close to cool white . . Jet-1 MK • Excellent build quality • The light can tailstand • Anti-roll indentations on the body • Physical lockout function • Physical reverse polarity protection function • Perfectly flat regulation for an extended period on Eneloop on High mode • 14500 Li-ion is officially supported • Mode memory • Good mode spacing • Lower low mode is available • No PWM at any output level with Ni-MH (but, PWM at Low and Med. with 14500 rechargeable cell) • Noticeable ringy beam around the hotspot • Overall beam tint is cool white Jetbeam Jet-μ and Jet-1 MK provided by Jetbeam for review. [Исправлено: candle lamp, 10.09.2016 в 17:17] Причина: [16.09.10] |
Поблагодарили: 11 раз(а) |
Angry Zeka (14.07.2016), Black Night (14.07.2016), fnksb (11.09.2016), GreyTooth (23.10.2016), MonsieuR (11.12.2016), Rocklight (13.09.2016), rpdoctor (07.09.2016), Tatamovich (07.09.2016), TimK (24.10.2016), UPz (07.03.2017), Сяв (15.11.2016)
Гамадрил
Регистрация: 17.01.2015 Последняя активность: 28.11.2016 17:30
Странно все это, шима тут нет, там есть...
Регистрация: 26.04.2012 Последняя активность: 14.06.2025 15:28
Регистрация: 08.03.2011 Последняя активность: Сегодня 15:05
Записей в дневнике: 4 Сказал(а) спасибо: 17478
Поблагодарили: 39174 раз(а) в 14521 сообщениях
Как вариант - он есть только на 14500.
Собственно, в том обзоре и написано PWM is pretty obivous in Low and Medium mode when you are using 14500 rechargeable battery. candle lamp ничего не пишет про ШИМ на 14500, freeme ничего не пишет про ШИМ на 1.5V ![]() |
I have checked and found ther is PWM flickering at Low and Med. output with a 14500 rechargeable. I have added this PWM flickering to my review.
fnksb (11.09.2016)
Регистрация: 30.04.2012 Последняя активность: 29.01.2019 00:00
Сказал(а) спасибо: 35
Подтверждаю насчет ШИМ. На литии есть, на никеле/щелочи нету. Шим заметный, но с заметно более высокой частотой, нежели у разнофаеров, хотя до Qlite не дотягивает (на "кулерном тесте" хорошо виден, тогда как у Qlite можно заметить только очень прилично поигравшись с оборотами). Короче, пользоваться норм, не раздражает.
Немного расчлененки в аттаче. Драйвер очень похож на таковой у Thrunite Saber 1A первого рана. Все три режима задаются резисторами возле соответствующих транзисторов (на фотке R6, R8, R10). Стоковые значения 0,27 ом; 1,5 ом; 22 ом. Конструкция башки - безпилюльная, диод сидит непосредственно на металле головы. Безель заклеен слабо (можно открутить просто руками с силой), драйвер вклеен за нижнюю плату по контуру. Надо греть, после чего выдавливается со стороны диода через отверстие минусового провода (там давите через один из транзисторов и индуктивность, жесткая передача давления. Если давить через плюсовой - рискуете согнуть соединительные проволочки, если через боковые - будете давить "в воздух".). Звезда под диод алюминиевая, 8 мм. Менять можно, но придется выпилить 4 углубления под провода и стойки центрирующей проставки. ВНИМАНИЕ! - углубления под провода и под стойки находятся на разном расстоянии, а последние проходят звезду насквозь и входят в отверстия в голове, так что звезду повернуть на 90* нельзя! Рефлектор центрируется проставкой по наружней стороне. Нужно быть очень внимательным с подпайкой проводов, не сделать толстые капли припоя. Иначе проставка своим внешним краем перекашивается и рефлектор сидит криво (как в обзоре выше) несмотря на ровную часть проставки непосредственно у диода. Рефлектор поджимается через о-ринг, так что прижим не жесткий. От звезды: проставка, рефлектор, о-ринг, стекло, безель. В общем, за 12 баксов прекрасная тушка с прямым теплоотводом и нормальным драйвером. Попробуем втулить ХПеЛь Привет и будет агрегат что надо! ![]() [Исправлено: The Lamer, 10.09.2016 в 20:17] |
Регистрация: 23.05.2016 Последняя активность: 26.03.2022 13:59
Сказал(а) спасибо: 41
Поблагодарили: 28 раз(а) в 16 сообщениях
![]() Цитата:
Я так понял, что проставка какая-то особенная с ногами для центровки звезды, следовательно мысли у меня такие: звезда меньше в диаметре, чем посадочное место. Что интересно, звезда такая-же как и у Fenix E05 2014, только на фениксе она 10 мм. [Исправлено: error702, 13.09.2016 в 16:28] |
Все верно, звезда меньше, чем выточка под нее на перегородке в голове. Саму проставку можно разглядеть на фото россыпью. Она собой представляет диск с квадратным отверстием под диод, от которого вверх идет конус, в который наружней стороной садится рефлектор, а вниз - две ноги, которые проходят в выемки звезды и далее в два отверстия на площадке, таким образом центрируя все. Но этот самый диск по диаметру такой, что накрывает где-то по трети контактных площадок на звезде, поэтому если при припайке проводов сделать каплю припоя на всю контактную площадку - проставка упрется в него, не сядет до конца, а затем при поджатии рефлектором согнется и перекосится, перекашивая и рефлектор. Из-за этого, кстати, у некоторых экземпляров фонаря (у меня их несколько) наблюдается расфокус (менее яркий хотспот с более яркой короной вокруг него), поскольку рефлектор оказывается не только криво, но еще и выше своего правильного положения.
error702 (13.09.2016)
The Lamer, если Вам не трудно, не могли бы Вы сделать фото проставки поближе? А то те снимки, что есть, на нах не очень видно. Вроде там какие-то прорези на проставке видны.
Да, конус не сплошной, а скорее в виде дополнительного кольца на двух "стойках". Сейчас фото сделать не могу, через неделю только.
Регистрация: 13.10.2015 Последняя активность: 22.07.2017 05:13
Сказал(а) спасибо: 7
The Lamer, Как идет замена XP-G2 на ХПеЛь?
Roche F6,Spark SG5,Olight S1,JetBeam Jet-1 MK |
Sol6843, ХПеЛь как раз идет.
Sol6843 (14.09.2016)
The Lamer А где ХПеЛь заказывали?,если не секрет конечно.
Что взять? Jetbeam Jet-μ или Jet-1 MK??? Не пойму я, в это состояние неопределённости ввели бимшоты.
Слева Jet-μ, справа Jet-1 MK Jet-μ с TIR оптикой, широким спотом, при чём угол тирки очень приятный, Jet-1 MK более дальнобойный, на бимшотах всё видно. Люмены: Разница (в пользу Jet-1 MK) 5 lm на среднем, 15 lm на высоком. Рантаймы: Разница (в пользу Jet-1 MK) 65 ч низкий, 5 ч средний, минут 20 на высоком. Из-за удачной тирки Jet-μ нравится больше, из-за рантаймов меньше (но есть куча ААА аккумуляторов). Из-за леса из-за гор, показал мужик топор гладкого рефлектора мне не нравится свет Jet-1 MK, но выгодные рантаймы нагоняют пелину и затмевают эти формы колец засветки и яркого хотспота. Ещё придётся покупать аккумуляторы АА, у меня как-то не сложилось с ними, одни ААА валяются. Вот и выводы: То ли светить подольше и подальше/поуже (при этом купив АА аккумуляторы и мерИться с ярким хотспотом в близи и смотреть на ореол кольца боковой засветки). То ли светить поменьше и поближе/пошире (при этом наслаждаться широким хотспотом без ореол боковой засветки, но менять почаще аккумуляторы). Разница несущественная в люменах, существенная разница в рантаймах. [Исправлено: error702, 19.09.2016 в 09:49] |
Бимшоты на литие:
Слева Jet-μ 10440, справа Jet-1 MK 14500. |
Sol6843 (19.09.2016)
Гамадрил
Купить оба, один на ключи, второй в сумку, если нужен широкий свет - покупаем и ставим широкую тирку
error702 (19.09.2016)
error702, Jet-μ поддерживает 10440 (литий)?Спасибо за инфу.Почему нет официальных данных?
Велика ли разница на глаз на литии между Jet-μ и Jet-1 ?А тирка мне не нравится.У меня есть OlightS1-на мой взгляд испортили отличный фонарь этой тиркой.Поставили бы рефлектор.Если Jet-μ поддерживает литий,точно куплю. Этим двум фонарям по соотношению цена/качество-равных нет (особенно Jet-1). [Исправлено: Sol6843, 19.09.2016 в 17:29] |
![]() Цитата:
По поводу лития: прочитал на каком-то англоязычном сайте, да и бимшоты на литие делали. Но писила, что греется сильно. Верить этому или нет, я не знаю. Официально не упомянули, что u AAA, поддерживает литий. Всё таки MK-1 поинтересней будет, по рантаймам, да и люмен чуть поболее, к тому же при желании можно поставить TIR оптику и как писали, тушка годная. |
Регистрация: 08.12.2014 Последняя активность: 12.10.2017 16:32
Сказал(а) спасибо: 30
![]() Цитата:
![]() Пришлось сделать еще один заказ. Расскажите про тирку. Мне не попадались на глаза такого диаметра. Специально для этих фонарей прикупил turnigy AA и AAA. 14500 один неприкаянный есть в хозяйстве, но это, я так понимаю, больше для баловства. Непрактично? |
Гамадрил
Да
Тирка - надо размеры рефлектора, они не стандартизированы, потом искать подходящие тут https://ru.aliexpress.com/s... |
