233746
633
71
Регистрация: 26.12.2012 Последняя активность: 10.11.2022 15:58
Сказал(а) спасибо: 91
Поблагодарили: 132 раз(а) в 61 сообщениях
Предыдущая часть темы тут
https://forum.fonarevka.ru/... ------------------------------------- АААААААаааааааааааааааааааааааааа!!!! Харош спать! Тут такое, .... такое !!!!!! H32 CR123 Headlamp Cool White http://www.zebralight.com/H... LED: Cree XM-L2 Cool White (Nominal CCT 6300K) User Selectable Levels: 3 main levels (High, Medium and Low). Each main level can be programmed to one of its two sub-levels. The second sub-level of the each main levels can be further programmed to different brightness levels. Light Output (runtimes) High: H1 480 Lm (PID, approx 1.4 hr) or H2 262 Lm (1.6 hrs) / 108 Lm (4.1 hrs) Medium: M1 54 Lm (11 hrs) or M2 24 Lm (26 hrs) / 9 Lm (70 hrs) Low: L1 2.7 Lm (8 days) or L2 0.4 Lm (38 days) / 0.05 Lm (2.5 months) / 0.01 Lm (3 months) Beacon Strobe Mode: 0.2Hz Beacon at Low / 0.2Hz Beacon at H1 / 4Hz Strobe at H1 / 19Hz Strobe at H1 Light output are ANSI out the front (OTF) values. Runtimes tested (and parasitic drain estimated) using Panasonic CR123A batteries. Operating Voltage Range: 2.7V - 4.2V Battery: One CR123A or 3.6/3.7V 16340 li-ion rechargeable. Batteries are not included in the box. Parasitic Drain: Negligible (much less than the self discharging of a battery) Beam Type 80 degree spill 12 degree hot spot Dimensions Head Diameter: 0.9 inch (22.8 mm) Length: 2.7 inch (68.6 mm) H32w CR123 Headlamp Neutral White http://www.zebralight.com/H... Light Output (runtimes) High: H1 446 Lm (PID, approx 1.4 hr) or H2 245 Lm (1.6 hrs) / 100 Lm (4.1 hrs) Medium: M1 50 Lm (11 hrs) or M2 22 Lm (26 hrs) / 8.5 Lm (70 hrs) Low: L1 2.5 Lm (8 days) or L2 0.37 Lm (38 days) / 0.05 Lm (2.5 months) / 0.01 Lm (3 months) Beacon Strobe Mode: 0.2Hz Beacon at Low / 0.2Hz Beacon at H1 / 4Hz Strobe at H1 / 19Hz Strobe at H1 Pre-order. Estimated Shipping Date: Sept 19, 2014
Если есть Тьма, - должен быть Свет. (с) В. Цой. |
Регистрация: 03.01.2013 Последняя активность: 26.10.2025 09:51
Сказал(а) спасибо: 468
А помимо батареек CR123 поддерживаются аккумуляторы - "3.7V 16340 li-ion rechargeable", так что недорого совсем и на мой взгляд гораздо удобнее фонарей на АА. |
Можно использовать и аккумуляторы, но при их использовании время работы фонаря сокращаются в двое из-за их меньшей емкости, так как хорошая литиевая батарейка имеет емкость: 1300-1700 мАч, аккумулятор: 750 мАч емкости.
тады фонарик фтопку - нормальный линейник и в конвоях по 20 баксов найти можно, без навроченного интерфейса... |
Кроме того, в случае чего можно и 123-й элемент впихнуть (универсальность была бы, блин)
Флэшелузер
Регистрация: 08.06.2014 Последняя активность: 06.08.2025 22:32
Сказал(а) спасибо: 310
Поблагодарили: 195 раз(а) в 137 сообщениях
Сказал(а) спасибо: 27330
Не спорю, очень милый фонарик. Но я не понимаю налобников не на 18650. Зачем он нужен? Налобник подразумевает длительное время работы. И в чём плюс этого фонаря? Маленький? Для дистрофиков? Я использую 602 и тяжести и дискомфорта не испытываю. Зачем мне фонарь с меньшим в несколько раз рантаймом?
он очень лёгкий. мало того, что металла на батблок меньше уходит, так ещё и акум/батарейка чуть не втрое легче хорошего плотного брендового акума 18650 весом 50+ грамов
у меня самодел из китайского линзовика. с хоботом. я тоже могу его таскать без затруднений. но это же зебра... |
Он у меня теперь в качестве едц фонаря, всех выжил. Так что ещё один сг3 брать буду. Ну и этого карапуза - прикольный.А рантайм - а что рантайм? Еще пару 16340 в карман и всех делов. |
17
Регистрация: 06.12.2012 Последняя активность: 18.10.2025 14:39
Сказал(а) спасибо: 516
Неплохо, зебра!
Регистрация: 24.11.2013 Последняя активность: 06.05.2025 15:53
Сказал(а) спасибо: 474
Поблагодарили: 614 раз(а) в 310 сообщениях
20
Шурик с шуриком
да не, хэ32 давно просился родиться и правильно сделали, что его сделали) легкий, мелкий и одновременно мощный налобник мастхэв вес и правда, как сказал наш многоуважаемый апоссум, является его супер-преимуществом я бы спарк сг3 купил, но он какой-то дебильненький свиду) так что я рад, что хэ32 появилсо а замечания про крутость 18650 перед ср123а - это не к фонарю относится, а к вашему концепту в подборе своего набора от этого хэ32 хуже сам по себе стать не может) [Исправлено: asket32420, 31.08.2014 в 18:55] |
