Сказал(а) спасибо: 6571
Поблагодарили: 35634 раз(а) в 16461 сообщениях
вычеркиваю.
Регистрация: 17.03.2013 Последняя активность: 16.02.2020 22:41
Поблагодарили: 3 раз(а) в 1 сообщении
JETBeam JET III M 3M PRO Cree XP-L 67$ (hkequipment)
новый диод, драйвер и т.д. Обзоров пока нет.
Nitecore EC4S, JetBeam DC-R20, Fenix E12 etc. |
Регистрация: 26.12.2012 Последняя активность: 10.11.2022 15:58
Сказал(а) спасибо: 91
Поблагодарили: 132 раз(а) в 61 сообщениях
АААААААаааааааааааааааааааааааааа!!!!
Харош спать! Тут такое, .... такое !!!!!! ![]() H32 CR123 Headlamp Cool White http://www.zebralight.com/H... LED: Cree XM-L2 Cool White (Nominal CCT 6300K) User Selectable Levels: 3 main levels (High, Medium and Low). Each main level can be programmed to one of its two sub-levels. The second sub-level of the each main levels can be further programmed to different brightness levels. Light Output (runtimes) High: H1 480 Lm (PID, approx 1.4 hr) or H2 262 Lm (1.6 hrs) / 108 Lm (4.1 hrs) Medium: M1 54 Lm (11 hrs) or M2 24 Lm (26 hrs) / 9 Lm (70 hrs) Low: L1 2.7 Lm (8 days) or L2 0.4 Lm (38 days) / 0.05 Lm (2.5 months) / 0.01 Lm (3 months) Beacon Strobe Mode: 0.2Hz Beacon at Low / 0.2Hz Beacon at H1 / 4Hz Strobe at H1 / 19Hz Strobe at H1 Light output are ANSI out the front (OTF) values. Runtimes tested (and parasitic drain estimated) using Panasonic CR123A batteries. Operating Voltage Range: 2.7V - 4.2V Battery: One CR123A or 3.6/3.7V 16340 li-ion rechargeable. Batteries are not included in the box. Parasitic Drain: Negligible (much less than the self discharging of a battery) Beam Type 80 degree spill 12 degree hot spot Dimensions Head Diameter: 0.9 inch (22.8 mm) Length: 2.7 inch (68.6 mm) ![]() H32w CR123 Headlamp Neutral White http://www.zebralight.com/H... Light Output (runtimes) High: H1 446 Lm (PID, approx 1.4 hr) or H2 245 Lm (1.6 hrs) / 100 Lm (4.1 hrs) Medium: M1 50 Lm (11 hrs) or M2 22 Lm (26 hrs) / 8.5 Lm (70 hrs) Low: L1 2.5 Lm (8 days) or L2 0.37 Lm (38 days) / 0.05 Lm (2.5 months) / 0.01 Lm (3 months) Beacon Strobe Mode: 0.2Hz Beacon at Low / 0.2Hz Beacon at H1 / 4Hz Strobe at H1 / 19Hz Strobe at H1 Pre-order. Estimated Shipping Date: Sept 19, 2014
Если есть Тьма, - должен быть Свет. (с) В. Цой. [Исправлено: Lamiglas, 31.08.2014 в 11:33] |
Поблагодарили: 8 раз(а) |
abcom (31.08.2014), asket32420 (31.08.2014), havoc (01.09.2014), jakovjashin (01.09.2014), lem nau (31.08.2014), Linx (31.08.2014), selenopolis (31.08.2014), virus_59 (31.08.2014)
йопта! когда они поймут, что 18350 гораздо йомче, чем старый слизанный с батареек формат RCR123?!!! (я есигу на 18350 юзаю и потихоньку выкидываю старые 16340 в помойку, закупаясь новыми 18350...)
трол. [Исправлено: blindnick, 31.08.2014 в 11:43] |
Регистрация: 03.01.2013 Последняя активность: 29.06.2025 13:12
Сказал(а) спасибо: 465
Поблагодарили: 566 раз(а) в 338 сообщениях
![]() Цитата:
А помимо батареек CR123 поддерживаются аккумуляторы - "3.7V 16340 li-ion rechargeable", так что недорого совсем и на мой взгляд гораздо удобнее фонарей на АА. |
Можно использовать и аккумуляторы, но при их использовании время работы фонаря сокращаются в двое из-за их меньшей емкости, так как хорошая литиевая батарейка имеет емкость: 1300-1700 мАч, аккумулятор: 750 мАч емкости.
![]() Цитата:
тады фонарик фтопку - нормальный линейник и в конвоях по 20 баксов найти можно, без навроченного интерфейса... |
Флэшелузер
Регистрация: 08.06.2014 Последняя активность: 07.12.2024 12:37
Сказал(а) спасибо: 310
Поблагодарили: 195 раз(а) в 137 сообщениях
Поблагодарили: 2 раз(а) |
asket32420 (31.08.2014), blindnick (31.08.2014)
Регистрация: 05.08.2012 Последняя активность: Сегодня 00:19
Сказал(а) спасибо: 27052
Поблагодарили: 15045 раз(а) в 7696 сообщениях
Не спорю, очень милый фонарик. Но я не понимаю налобников не на 18650. Зачем он нужен? Налобник подразумевает длительное время работы. И в чём плюс этого фонаря? Маленький? Для дистрофиков? Я использую 602 и тяжести и дискомфорта не испытываю. Зачем мне фонарь с меньшим в несколько раз рантаймом?
Администратор
Сказал(а) спасибо: 4330
Поблагодарили: 10643 раз(а) в 2539 сообщениях
