13411 11 5 1 |
12.10.2013, 19:32 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Review of Charger Xtar XP4
Charger Xtar XP4
Xtar is known for flashlights and a couple of good LiIon chargers. This time they have also included NiMH capabilities in the charger and together with 3 current settings and USB output it looks like a charger that can do just about everything (Except analyze). The charger comes in a cardboard box with lots of specifications on the outside. The box contains the charger, a mains adapter, a car adapter (Probably optional), a manual and a warranty card. The front/top of the charger contains 8 leds and one button:
The charger has a 12 volt input, this input can be supply from the main adapter or from the car adapter. The usb output is rated at 1A and uses the battery in slot #4. It can only be activated when input power is disconnected. Xtar uses this label to avoid fakes. The battery + connection is slightly raised and worked with flat top batteries. The slider works fine. The slider can work with batteries between 30.5 mm and 71.8 mm. The charger can easily handle 70 mm long batteries, including flat top cells. (See my Small LiIon comparison for length of different brands). Measurements charger
Test with LiIon cells Charging a 3100mAh cell with 0.25A is slow, but works perfectly. Notice the low terminations current, this is good. Lower would be even better, when charging small batteries. Increasing the current to 0.5A does also look good. The termination current has increased slightly. At 1A is also good, the termination current is about 100mA which is fine. The other slots works just as well. The charge time for 2600mAh is slightly shorter than 3100mAh And 3400mAh has slightly longer charge time. My old LiIon cell is handled perfectly at full charge current. Charging a smaller cell with 0.25mA does, of course, also work. Charging 4 LiIon batteries at the same time does generate some heat. My probe measures 41°C on the batteries. M1: 51,5°C, HS1: 77,4°C The USB port on the back of the charger gets very hot, it is not recommended to touch it. M1: 50,3°C, HS1: 70,4°C There is also some hot spots between the batteries and I measure 50°C on the batteries. This is at the limit. After the charger is powered on it uses about 2 seconds on starting, then 1 second to sense battery type, before ramping up to charge current. Changing from 0.25A to 0.5A takes about 4 seconds. From 0.5A to 1A it takes about 8 seconds to ramp up. Reducing power is instantaneous. Note: These times are neither good nor bad, it is just the way the charger works. Test with NiMH cells A very slow charge of a 2000mAh AA cell and something went wrong. It terminates at 1.40 volt and has only filled 1250mAh into the cell, but then the charge current is too low for this cell, lets test with a AAA cell. Note: The risk with low charge current is usual overcharge, not premature termination. Again it terminates early, only about 460mAh has been filled into the cell. Let’s try 0.5A with a AA cell. Again I get about 1250mAh. This is not very good. With a AAA battery at 0.5A the charge is nearly ok. What about 1A? Again it looks nearly ok, it terminates after about 2000mAh (This is a tad early for a 2000mAh NiMH). When the charge is finished the charger continues with trickle charge. Notice the slow charge at the start of the curve, it is probably done to detect battery type. Here are 3. other channels. Looking at the voltage curve, it looks like #2 is terminating slightly early, #3 is good and #4 is early. With a eneloop XX (2500mAh), the charge curve looks perfect. The voltage has reached a maximum and started to drop, before the charge is terminated. My guess is that there is a bug in the "end of charge" detection algorithm, this means that it will not work correctly will all types/ages of NiMH batteries. A bit more work from Xtar will probably fit it. Starting a charge with a full battery, is stopped very fast. First the charger uses two minutes to analyze the battery, then it charges 2½ minutes, before it detects the battery is full and changes to trickle charging. With 4 batteries, there was also some premature termination, but as can be seen on the temperature curve, that battery did terminate properly. Even with one early termination I recorded a temperature of 51°C Note: I was measuring volt and current on battery #1 and temperature on battery #3. Let’s try once more, this time both the battery with voltage/current sensor and the battery with thermo sensor did terminate premature. This time, without proper termination, the temperature did only reach 43°C M1: 51,1°C, HS1: 74,1°C The USB port gets very hot with NiMH batteries. M1: 50,9°C, M2: 51,8°C, M3: 51,2°C, M4: 45,7°C, HS1: 81,9°C 3 batteries at 51°C, the last is charging, but is not as hot. Somewhere down on the PCB it gets really hot. It is probably not a problem for the electronic parts and it looks like the plastic can take it, but some heat is transferred to the batteries. In slot #1 the charger can also do a discharge. The battery I tested with was only half full. When charging there was no premature termination. When discharging the led is flashing red. The current is fairly low, a 2000mAh cell will take nearly 7 hours to discharge and then 2 hours to charge, because the charger only has one slot with discharge function it will take at least 35 hours to cycle a pack of four cells. At power on it takes two seconds before the charger starts at the low sense current. Here it switches from sense to full charge current. Manual switching between the currents happens instantaneous, with NiMH it does not use a ramp. Test with both LiIon and NiMH cells Charging both LiIon and eneloop does not change much. It looks like there is a bit more noise in the charge current. The NiMH does also look fine. Measurements USB output
The output is rated at 1A and can easily deliver 2A (To not blow the usb output I stopped at 2A). At 1A output it has a good efficiency and runs for about 1 3/4 hour. The output turns off when the battery is down to about 3.1 volt, but it still has a current drain of about 5mA from the battery. Reducing the current to 0.5A improves the efficiency slightly and more than doubles the time it can run. A 2600mAh gives shorter runtime. And a 3400mAh gives longer runtime. The usb output has very little noise, only about 7mV at 1A (67mVpp). At 0.5A the noise is about the same (6mV and 65mVpp). Testing with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems. Conclusion The charger has many functions of varying quality:
Generally it is a good quad LiIon charger, but the NiMH function is not very good before Xtar get it fixed. Notes The charger was supplied by Xtar for a review, I believe it is the second production batch. Here is an explanation on how I did the above charge curves: How do I test a charger Read more about how I test USB power supplies and chargers
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Поблагодарили: 22 раз(а) |
Alex TG (13.10.2013), andyz (13.10.2013), blindnick (12.10.2013), crus (13.10.2013), Dali (12.10.2013), Dnv (13.10.2013), Gary (13.10.2013), LEV-UA (06.11.2014), Lumin (22.10.2013), m72 (12.10.2013), molvinec (13.10.2013), NazarSunrise (12.10.2013), ne4epur (12.10.2013), OlegI (18.10.2013), rkromanrk (13.10.2013), rpdoctor (14.10.2013), stranix (03.09.2014), Svetogor (13.10.2013), tubudum (13.10.2013), viperxp (13.10.2013), vvvoland (13.10.2013), xpm (24.11.2013)
12.10.2013, 20:11 | 2 |
Turn Day into Night
Регистрация: 23.10.2012 Последняя активность: 25.09.2023 22:54 Адрес: Львів
Сказал(а) спасибо: 1744
Re: Review of Charger Xtar XP4
HKJ,
Thank you very much for this review!
Продам фонари Convoy S3 с разной TIR оптикой |
13.10.2013, 08:01 | 3 |
Регистрация: 24.02.2013 Последняя активность: 20.04.2024 19:30 Адрес: Израиль
Сказал(а) спасибо: 144
Поблагодарили: 2408 раз(а) в 509 сообщениях
HKJ , thank you very much. Another top-level review.
Question - have you tried another Ni-Mh batteries besides two types of eneloops? What was the situation with them?
Olight Разные ZebraLight SC5W |
24.11.2013, 21:48 | 5 |
Hi HKJ, do you have the updated XP4? When do you plan to review it? Another question, Xtar states that the charger uses pulse charge for NIMH cells. Can you confirm that? What is the length of the pulses?
24.11.2013, 22:05 | 6 | |
Look at the scope traces for NiMH, it does turn the current off at regular intervals (2 sec) to measure the voltage, this is one type of pulse charging |
24.11.2013, 23:11 | 7 |
Thank you. There is an updated version of the charger with improved thermal characteristics and improved end of charge for NIMH. I will review it, not like you of course but surely I will test the NIMH charge with 2000 maH eneloops.
06.11.2014, 22:14 | 8 |
Регистрация: 31.10.2014 Последняя активность: 15.10.2018 14:05 Адрес: Рязань
Сказал(а) спасибо: 5
Hi HKJ, One year is passed and I suppose Xtar company has fixed that bugs in XP4 charger (with HiMH end of charge detection and hi temperature). Did you test new sample? Thank you in advance.
06.11.2014, 22:20 | 9 | |
Hopefully it is the same as they uses in the XP4c, it work much better. Xtar has supplied me with other chargers and I will publish a few Xtar reviews in a couple of weeks. |
07.11.2014, 12:29 | 10 | |
Регистрация: 16.06.2013 Последняя активность: 20.05.2022 19:12 Адрес: Украина, Донецк
Сказал(а) спасибо: 211
Thank's for this information!
Zebralight: H600Fw MKII, H51c; Fenix: HL21, HL23, LD12 S2, E05 R2; Princeton Tec: Remix; Byte; Convoy: S2 T5-5C; Spark: SG5 CW; Xtar: WK41 Sirius AA; Petzl: Tikka 2, Tikkina 2; Olight: H1 Nova NW [Исправлено: Vyacheslav Demeshko, 07.11.2014 в 12:30] |
08.11.2014, 00:45 | 11 | |
My queue looks like this: Nitecore D2 3xEnova 3xXtar Maybe 2xNitecore Soshine (Low priority) 2xPanasonic (Low priority) Trustfire (Low priority) Low priority means that I might push the review if a dealer/manufacturer sends a charger for review. |
Vyacheslav Demeshko (08.11.2014)
08.11.2014, 10:32 | 12 |
HKJ, Thanks for detailed information!
