Просмотров в теме 20031   Ответов в теме 29   Подписчиков на тему 8   Добавили в закладки 0
Старый 13.12.2012, 15:16 Автор темы   1
Администратор
Аватар для Admin
Сказал(а) спасибо: 4330
Поблагодарили: 10643 раз(а) в 2539 сообщениях
По умолчанию Новинка! Olight I3S - AAA Light Using CREE XP-G2 - 80 Lumens
The iTP A3 was one of the most popular AAA lights ever and its successor, the Olight i3, added some often requested changes and improvements. One of the things that many of you have asked us to change back is the clip, so we are happy to announce the i3S, with a reversible clip.
While we were at it, we also switched out the LED for the CREE XP-G2, giving a nice 20% bump in output to 80 ANSI lumens. We also improved the keychain attachment point, allowing for better movement while still keep the point nice and sturdy. The i3S can still tailstand for those of you that like to use your lights to light up a room, tent, or any other area.
The i3S will be shipping to preferred dealers next week.
1. Utilizing the newest Cree XP-G2 LED, with the max output of 80 lumens (increased by 20%, based on the old i3)
2. Adjustable output levels: Moonlight, Low, High and Strobe mode (by rotating its head to shift models).
3. High quality stainless steel clip makes it durable and keeps a firm grip on your pocket.
4. The pocket clip is reversible, allowing for hat brim or similar attachment.
5. Aluminum body with scratch resistant type III Hard Anodizing (Only black is available).
6. Flat tail cap allows for tail-standing.
7. Adopt linear current regulation technology, no stroboscopic output.
8. Standard attachment: a triangle ring connects the tail hole with light body on one side
9. Orange reflector, comfortable light fit for close range lighting.
10. 96% transparency ultra-clear high optical lens.
11. Attractive gift box packaging.
Старый 13.12.2012, 16:18   2
Роман 83
Аватар для Роман 83
Последняя активность: 12.04.2023 17:16
По умолчанию Re: Новинка! Olight I3S - AAA Light Using CREE XP-G2 - 80 Lumens
Прикольно)))))Очень нравится обычный i3,а здесь еще и XP-G2 и клипса оборотная))))Как появится,сразу закажу))))))и коробочка ГУД))))))
fenix e05, olight i3,olight i3s, XENO E03 -(потерял),zebralight SC600 - и енто только начало
Роман 83 вне форума   Ответить с цитированием Вверх
Старый 13.12.2012, 16:24   3
Последняя активность: Сегодня 04:53
Сказал(а) спасибо: 17221
Поблагодарили: 38530 раз(а) в 14266 сообщениях
Да, интересно - и диод поновее, и клипсу поменяли, и коробочка хорошенькая...
Мунлайт вместо слабого смущает, но может иногда и полезен.
Интересно, что именно изменили в электронике.
Старый 13.12.2012, 17:47   4
Xenos
Аватар для Xenos
Сказал(а) спасибо: 326
Поблагодарили: 679 раз(а) в 184 сообщениях
Xenos вне форума   Ответить с цитированием Вверх
Admin (13.12.2012)
Старый 14.12.2012, 00:02   5
PASHA
вечный n00b
Аватар для PASHA
Сказал(а) спасибо: 5257
А что хорошего в этом XPG2 по сравнению с XPG?
Макс мощность 488 лм против 493 лм в XPG.
Угол засветки 115 против 125 градусов.
Больше похоже на оптимизацию производства под соусом инноваций. Аналогично с XPE и XPE2. Только XML2 прибавил в макс лм.
Просветите плиз.
Старый 14.12.2012, 00:33   6
John Jack
Аватар для John Jack
Записей в дневнике: 18
Сказал(а) спасибо: 1790
Яркость измеряется иначе, на горячем диоде. А это разница на 15% яркости, два бина. Из-за меньшего напряжения новые диоды в целом на 20% круче эффективнее.
Меньший угол засветки - скорее хорошо, чем плохо. В компактных рефлекторах без разницы, в больших даёт лучше дальнобойность.
Совершенно другая технология. Подложка из карбида кремния, а не нитрида галлия. И дешевле, и лучше.
Из малозаметного сильно эффективнее стали тёплые бины. У старых XP-G в шестой-седьмой группах были не выше Q5, у новых XP-G2 есть аж R3.
havoc (16.12.2012), PASHA (14.12.2012), Patho (11.03.2013), rpdoctor (16.05.2013)
Старый 14.12.2012, 07:40   7
Последняя активность: Вчера 19:54
Сказал(а) спасибо: 6604
Поблагодарили: 35775 раз(а) в 16530 сообщениях
насколько я помню, вся I-серия раньше страдала ШИМ (2.5кГц, емнип)
Старый 14.12.2012, 12:09   8
PASHA
вечный n00b
Аватар для PASHA
А где можно найти что означают всякие R3, R5, Q5?
Тут не соглашусь. В формате ААА канечно вообще все построено на компромиссах. Но дальность в ущерб широты это точно не лучшее решение. Нормальную дальнобойность на ААА все равно не достичь.
[Исправлено: PASHA, 14.12.2012 в 12:36]
Старый 14.12.2012, 13:24   9
John Jack
А я не так написал? В рефлекторе ААА разница между XP-G и XP-G2 непринципиальна. Предполагаю, что боковая засветка будет ярче при чуть более узком хотспоте той же интенсивности. Но всё ненамного.
http://www.cree.com/~/media...
PASHA (14.12.2012)
Старый 16.12.2012, 00:04   10
PASHA
вечный n00b
Аватар для PASHA
А между XPG и XPE?
Старый 16.12.2012, 02:42   11
John Jack
Тут размеры кристаллов отличаются в полтора раза. С XP-E хотспот будет заметно уже.
Старый 16.12.2012, 17:38   12
PASHA
вечный n00b
Аватар для PASHA
вроде и там и там 3.45 х 3.45. Или я где не там смотрю?
Старый 16.12.2012, 17:53   13
Поблагодарили: 10660 раз(а) в 5587 сообщениях
Размер подложки.
Имеется в виду размеры излучающей части (люминофора)
Старый 16.12.2012, 19:58   14
PASHA
вечный n00b
Аватар для PASHA
А где указан размер излучающей части, что-то не нашел?
Старый 16.12.2012, 20:02   15
PASHA, XP-E - 1 кв.мм, XP-G - 1,5 кв.мм, XM-L - 4 кв.мм.
кристаллы квадратные - размеры сам определишь
PASHA (17.12.2012)
Старый 09.03.2013, 22:28   16
Енот
Денис
Аватар для Енот
Последняя активность: 30.07.2025 16:44
Сказал(а) спасибо: 169
Купил себе такой! Давно ничего не радовало, а вот этот зацепил. Измена Е05.
Приятный, симпатичный, яркий. Мунлайт и стробоскоп не самые нужные режимы у наключника, но не мешают, даже наоборот интересно, т.к. управление грамотное. Поселился на джинсах вместе со Spartanom.
А тут я работаю
Енот вне форума   Ответить с цитированием Вверх
Admin (09.03.2013), havoc (09.03.2013), rpdoctor (16.05.2013)
Старый 09.03.2013, 23:28   17
dmn42
Аватар для dmn42
Последняя активность: Сегодня 01:57
Сказал(а) спасибо: 308
Поблагодарили: 245 раз(а) в 171 сообщениях
Енот, как там нащщот ШИМ? Заметно?
Старый 09.03.2013, 23:36   18
Енот
Денис
Аватар для Енот
dmn42, По мне нет. Да я быть честным могу увидеть только ярко выраженный. Если он и есть в этом фонаре, то я этого не знаю) Серьезно-не вижу я малый ШИМ не в каких фонарях.
Старый 30.03.2013, 15:06   19
_Leo_
Аватар для _Leo_
Последняя активность: 25.07.2025 22:15
Сказал(а) спасибо: 165
Поблагодарили: 121 раз(а) в 91 сообщениях
Что с режимами? Стартует с какого режима?
Fenix HL21NW
ZebraLight H31w, H51w, H51r, SC52w L2, H502c, H502r, H502w L2, H600w, H602w
_Leo_ вне форума   Ответить с цитированием Вверх
Старый 30.03.2013, 21:51   20
Енот
Денис
Аватар для Енот
Посмотреть сообщение Сообщение от _Leo_ :
средний-турбо-светлячок-средний-турбо-светлячок - строб.
Время генерации страницы 0.13310 секунды с 16 запросами
