7131 13 3 0 |
10.10.2013, 20:24 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Test/Review of Soshine RCR123 3.0V 650mAh (Black)
Official specifications:
This battery is a not a normal LiIon battery, it uses ICR chemistry, but the output voltage is closer to IFR chemistry, this is because there is a diode inside the battery to reduce output voltage. On Soshines website the charger voltage is specified as 3.6 volt, this is too low to get full capacity. I did my tests at 4.2 volt (3.6 volt nominal), 4.4 volt would probably have been better, but I will not go outside the specifications. With this battery I am really missing a charger specification printed on the battery. The two batteries does not match in capacity and without protection in the battery, avoid use them in series. The battery does not have any protection, i.e. if it is over discharged once, it will be damaged and might also be dangerous. The charge curve looks funny, due to the diodes and the low charge voltage. Conclusion The advantage of a diode is more capacity for a 3.2 volt battery, but I do not really believe it is a good idea, because the diode will generate heat at high loads and you can get real IFR batteries with about the same capacity (At least when you follow the charge specifications). Notes and links How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries CR123A and rechargeable substitutes
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
16.11.2015, 15:50 | 2 |
Enfant terrible
Регистрация: 01.11.2015 Последняя активность: 21.04.2024 08:20 Адрес: UWSS
Сказал(а) спасибо: 2837
Поблагодарили: 530 раз(а) в 289 сообщениях
Re: Test/Review of Soshine RCR123 3.0V 650mAh (Black)
Доброго всем времени суток!
А не можете подсказать, какая зарядка сможет нормально заряжать эти аккумуляторы? А то Soshine H4 в режиме LiFePO4 их заряжать отказывается. Выдает ошибку зарядки. Или такие аккумы только IMAX B6 или каким-нибудь похожим зарядить можно? |
16.11.2015, 16:42 | 3 |
Ветеринар Фонаревки
Регистрация: 19.03.2013 Последняя активность: Сегодня 14:28
Сказал(а) спасибо: 9642
Поблагодарили: 2233 раз(а) в 1450 сообщениях
Xtar VP2 http://lygte-info.dk/review... думаю хозяин обзора не будет против.
In Fino verytas [Исправлено: vorsmann, 16.11.2015 в 16:48] |
Mukcep (16.11.2015)
16.11.2015, 16:58 | 4 | |
Enfant terrible
Вообще за такую цену, которую просят за VP2, хотелось бы функцию разряда и измерение емкости аккумулятора. Или же я ошибаюсь и эти функции там есть? [Исправлено: Mukcep, 16.11.2015 в 17:08] |
16.11.2015, 18:45 | 5 |
Регистрация: 05.02.2013 Последняя активность: Сегодня 16:21 Адрес: Челябинск
Сказал(а) спасибо: 615
В зарядном устройстве XTAR VP2 тип заряжаемого аккумулятора (напряжение зарядки) устанавливает пользователь с помощью ползунка-переключателя напряжения, возможные значения 3.6V (для Soshine RCR123), 4.2V и 4.35V (обозначены как 3.2V - 3.6V - 3.8V).
Это также относится к бюджетной версии (без дисплея) XTAR WP2H.
Фонари, аккумуляторы, зарядные устройства [Исправлено: barena, 16.11.2015 в 18:47] |
Mukcep (16.11.2015)
16.11.2015, 19:02 | 6 | |
Enfant terrible
Я еще начинаю сомневаться - не обычный ли CR123 внутри торчит, а от Soshine только жестяная оболочка, потому что даже после 10 минут зарядки в любом режиме (на сей раз почему-то FAIL не выдает) ни один из параметров не меняется в принципе. А еще 1600 руб. потрачено на H4 и покупать за 2000 еще и VP2 (и куда потом девать H4?) как-то жаба душит. Впору взять такой комплект: http://ru.aliexpress.com/it... и то дешевле выйдет и результат будет гарантированный Тогда что уж там мелочиться - надо сразу Opus BT-C3100 закупать [Исправлено: Mukcep, 16.11.2015 в 19:19] |
16.11.2015, 19:47 | 7 |
Ветеринар Фонаревки
опус в попус хстар своих денег стоит
[Исправлено: vorsmann, 16.11.2015 в 19:50] |
Mukcep (16.11.2015)
16.11.2015, 21:27 | 8 |
Enfant terrible
Ну за 2 рубля и выше хочется чтобы все и сразу: чтобы и разрядник встроенный, и измерение емкости при разряде, и функция повербанки, и чтобы напряжение заряда было и 1.5, и 3.2, и 3.7, и 4.2 и чтобы понадежнее
17.11.2015, 09:06 | 9 |
Ветеринар Фонаревки
17.11.2015, 09:10 | 10 |
Ветеринар Фонаревки
для измерения емкости есть масса разных модельных зарядок дорого но делает и меряет все.
17.11.2015, 16:32 | 11 | |
Enfant terrible
Под тот же много раз помянутый и икающий IMAX B6 холдеров я не нашел. Отдавать не такие уж маленькие деньги, чтобы потом что-то паять или перекручивать - да ну на фиг. А можно все же немного подробностей? Потому что аналогов я не нашел. [Исправлено: Mukcep, 17.11.2015 в 18:01] |
19.11.2015, 11:32 | 13 | |
Enfant terrible
Ответ от Soshine по поводу зарядки сабжа с помощью H4:
29.10.2017, 06:46 | 14 | ||
Регистрация: 03.10.2013 Последняя активность: 05.02.2022 08:05 Адрес: Moscow Izmaylovo http://maps.yandex.ru/-/CND8ENIj
Поблагодарили: 28 раз(а) в 20 сообщениях
Сегодня купил фонарик и к нему акки
Soshine RCR123P 3V LiFePO4 16340
после распаковки тут же вставил после погонял 4 раза под самый ноль к счастью акк с защитно но к сожалению с не заявленной ёмкостью. заряжал на двух различных зарядках одна на автомате вторая - установил минимум 250 мА акки фонариком разряжал, разрядились за полчаса фонарик должен был светить по паспорту или слухам около часа Nitecore EX11
Ремонтирую всё что работает на и от электричества. |
