7705 13 2 0 |
01.11.2012, 13:50 | 1 |
Регистрация: 01.11.2012 Последняя активность: 24.09.2019 12:00
Сгорел драйвер на SKYRAY 3T6
Здравствуйте!
Прошу помощи, сгорел драйвер на SKYRAY 3T6, сгорел героически, во время работы. Как понимаю, коротнул, ибо пружины - разогрело до отпуска. Все остальное - целое. Выбираю драйвер, и не знаю, насколько подойдут следующие: (попытка разместить ссылки, но увы, недостоин) Собственно, речь идет о раз два три Подробнее: 1. 6-18V 3000mA 3-Mode Circuit Board for XM-LT60 Emitters (- Current: 3000mA - Voltage: 6-18V - 3-Modes: high, low, fast strobe - Designed for XM-LT60 emitters) 2. 4-Mode 2500mA LED Driver Circuit Board for Flashlight (DC 5.0~8.4V) - Model: DL-004 - Voltage: DC 5.0~8.4V - Mode: 100%/50%/25%/SOS - Current: 2500mA - Diameter: 26mm - Thickness: 1.6mm - Great for DIY project or repair your flashlight 3. Boost/Buck 3-18V 5 Modes 24mm 30W Circuit Board This circuit comes with low voltage protection at 5.7V, so please use two or more li-ion for best result. Input Voltage: 3-18V (recommend use of 2-4pcs 4.2V 18650 or 4-6pcs 3V CR123A) Output current (single LED): 5A Output current (3 or 4 XM-L LED wired in serial): 3A Modes: High - Medium - Low - Strobe - SOS (cycle) (with Memory feature), shut off to cycle to next mode Low voltage Protection: When using single or two Li-ion batteries, input voltage becomes 5.7V, LED will flash twice per 3 seconds and then turn off after 3 minutes. Over-heat Protection: When internal temperature becomes too hot, driver will automatically ramp down its brightness, make sure you "heat-sinked" the driver. LED power output: single LED (8-10W), three or four LED wired in serial (25-30W) Input requirement: Input current is about 3-3.5A, make sure the wiring and switch is capable of handling this type of high current. *When driving 3 or 4 XML (serial) with 1-2 li-ion (serial), this circuit acts as boost circuit. When using 3-4 lion wired in serial, this circuit becomes a buck and temperature regulated circuit. Dimensions: Battery board measures 26mm Main driver measures 24mm Total heigh measures 17mm Кто разбирается, подскажите, что выбрать, или - предложите свой вариант. Спасибо! [Исправлено: Piter, 01.11.2012 в 14:35] |
01.11.2012, 14:04 | 2 |
Регистрация: 28.01.2011 Последняя активность: 25.12.2019 09:02 Адрес: Каменск-Шахтинский
Сказал(а) спасибо: 31
Re: Сгорел драйвер на SKYRAY 3T6
На SKYRAY 3T6 850 такой подходит.
http://kaidomain.com/produc... http://kaidomain.com/produc... https://forum.fonarevka.ru/... |
Piter (01.11.2012)
01.11.2012, 14:06 | 3 |
Регистрация: 27.05.2011 Последняя активность: Сегодня 15:02 Адрес: Россия, Пермский край
Сказал(а) спасибо: 5939
Поблагодарили: 32751 раз(а) в 15180 сообщениях
(невнимательность)
01.11.2012, 14:12 | 4 | |
выбор небогатый: кайдо 3 и 5 режимов соотвественно http://www.kaidomain.com/pr... http://www.kaidomain.com/pr... это если диаметр контактной платы 26 мм
трол. |
Piter (01.11.2012)
01.11.2012, 14:29 | 5 | |
01.11.2012, 14:32 | 6 | |
01.11.2012, 15:17 | 7 |
01.11.2012, 15:32 | 8 | |
Он, собственно, был куплен в подарок, одариваемый пищал от восторга, восторженное пищание оборвалось спустя 3 месяца поюза. Надеюсь, скоро возобновиться |
01.11.2012, 16:27 | 9 |
Еще
раз: http://www.intl-outdoor.com... - судя по всему, тот же, что и на КД два: http://www.intl-outdoor.com...
Hello there |
01.11.2012, 16:36 | 10 | |
01.11.2012, 17:26 | 11 |
Сказал(а) спасибо: 324
01.11.2012, 17:34 | 13 |
kruvas, http://fancyflashlights.com...
kruvas (01.11.2012)
01.11.2012, 17:48 | 14 |
спасибо. буду иметь в виду что на их сайте поиск не очень добрый, что странно для магазина )
искал "skyray", "sky-ray", "3t6" и один фиг. а надо было "sky ray" |
