8294 14 1 0 |
08.10.2013, 18:43 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Test/Review of Samsung INR18650-20Q 2000mAh (green)
Official specifications:
Thse are high power batteries for use in tools. The cells can deliver 20A with full capacity and the maximum difference in capacity is about 0.6%. The voltage at the lower currents is not very impressive, but in the 10A to 20A range it can match IMR cells, but with greater capacity. Conclusion This is a very good battery, but there is no reason to use it, except if you need a lot of current. The R version of the battery is slightly better. Notes and links How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Comparison to other LiIon batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
08.10.2013, 18:54 | 2 |
Регистрация: 25.04.2013 Последняя активность: 28.10.2018 13:54 Адрес: Украина
Сказал(а) спасибо: 589
Поблагодарили: 1070 раз(а) в 299 сообщениях
Re: Test/Review of Samsung INR18650-20Q 2000mAh (green)
08.10.2013, 19:16 | 3 |
my test:
Samsung-20Q-I (current) 3A discharge up to 3V Samsung-20Q-18650-2-(4,2-3A)1969mAh-7,05Wh Samsung-20Q-18650-4-(4,2-3A)1987mAh-7,12Wh Samsung-20Q-I (current) 10A discharge up to 3V Samsung-20Q-18650-2-(4,2-10A)1935mAh-6,59Wh Samsung-20Q-18650-1-(4,2-10A)1896mAh-6,44Wh |
MOHAPX (08.10.2013)
08.10.2013, 22:08 | 4 | |
vvvoland (08.10.2013)
08.10.2013, 22:19 | 5 |
Регистрация: 24.02.2013 Последняя активность: 20.04.2024 19:30 Адрес: Израиль
Сказал(а) спасибо: 144
Поблагодарили: 2408 раз(а) в 509 сообщениях
HKJ, have you started working on the XP4 review?
It is one of the most desired reviews at the moment thanks for the review, your hard work is very appriciated.
Olight Разные ZebraLight SC5W |
08.10.2013, 22:26 | 6 |
08.10.2013, 22:31 | 7 |
08.10.2013, 22:41 | 8 | |
this comparator http://lygte-info.dk/review... and that for smaller http://lygte-info.dk/review... but I'm wondering the study itself. method of measurement - I've read your reviews with pleasure I have for test: iCharger 208B, iCharger 3010B, iCharger 4010 DUO(4,35V), АRRAY 3710 Thank you very much. |
08.10.2013, 22:43 | 9 |
09.10.2013, 14:47 | 10 |
09.10.2013, 14:59 | 11 |
09.10.2013, 15:11 | 12 | |
If you got an adapter with it, the serial/usb adapter is usual not a problem. You might also be able to make your own usb cable, if it has one of the typical "ttl level" serial outputs. You could move the batteries to a charger |
09.10.2013, 15:27 | 13 |
09.10.2013, 15:37 | 14 |
09.10.2013, 18:17 | 15 | |
Resistance my wires (each) 1мОм 0,003[Ohm/m]*0,33м [Исправлено: vvvoland, 09.10.2013 в 18:31] |
