Вернуться   Форум FONAREVKA.RU Источники питания и зарядные устройства Batteries and Chargers. Reviews and tests. Battery chargers. Reviews and tests.
Просмотров в теме 10096   Ответов в теме 13   Подписчиков на тему 4   Добавили в закладки 1
Старый 29.05.2011, 18:30 Автор темы   1
Модератор своих разделов
Аватар для HKJ
Поблагодарили: 2982 раз(а) в 1024 сообщениях
По умолчанию Charger Xtar MP1
Charger Xtar MP1
This charger is a small single 18650 charger.
The charger is powered from a mini usb connector and only supplied with an usb cable.
As extras it is possible to get both car adapter and universal voltage (100-240VAC 50/60Hz) mains adapter.
The charger can handle 70 mm long batteries, including flat top cells.
Measurements
Below 2.8 volt the charger will charger with 60-70mA.
Between 2.8 volt and 4.18 volt the charger is applying regular charge current (See curve below).
At about 4.18 volt 90 mA charger current the led will change to green, but the charger will continue to charger until the current is below 33 mA.
If the voltage goes below 4.07 volt the charger will start charging again, but the led will stay green.
If the voltage goes below 4 volt the led changes to red.
When charger is disconnected from power, but with a battery in, it will draw below 35uA from the battery.
The charge curve shows a approximation to a CC/CV charger, but it starts reducing charger current at 4 volt, instead of 4.2 volt, this increases the charge time. It will also say "end of charge" before the battery is fully charged, this makes it possible to get a nearly full (95%) battery "fast", but there is missing some visual indication of when the battery is fully charged.
A new LiIon cell with a low internal resistance. The charger say ready after about 7 hours, but does first stop charging after about 9 hours.
My old RCR123 IMR cell.
Conclusion
The charger has a CC/CV charge profile, but not optimized for fast charging. The charge current is low enough to handle many battery sizes, but there are no spacers included. This charger, with its small size, is fine for a travel charger and for single cell use, but for frequently charging a couple of cells I would prefer a faster charger with more channels.
Notes
Here is an explanation on how I did the above charge curves: How do I test a charger
The charger was supplied by XTAR for a review.
Andretti (26.01.2012), ange (21.03.2012)
Старый 16.06.2012, 17:42   2
Rocklight
Аватар для Rocklight
Сказал(а) спасибо: 1116
Поблагодарили: 1650 раз(а) в 958 сообщениях
По умолчанию Re: Charger Xtar MP1
Кто - то с форума имеет этот девайс? Как он в реальности?
Старый 16.06.2012, 17:53   3
Labour
Аватар для Labour
Последняя активность: 07.02.2024 09:37
Сказал(а) спасибо: 572
Поблагодарили: 499 раз(а) в 218 сообщениях
Отправить сообщение для Labour с помощью ICQ
У меня есть. Нормальная зарядка. А что конкретно интересует или смущает?
Labour вне форума   Ответить с цитированием Вверх
Старый 16.06.2012, 18:06   4
Rocklight
Интересует, так как есть рядом в магазинчике лежит за 250 рублей, думаю взять так как заказывать что-то из сети нет времени.
1. до какого V реально заряжает?
2. Каков ток заряда в реальности от БП в комплекте?
3. И каков уровень безопасности на Ваш взгляд? (в плане заснуть и оставить аккум на зарядке).
Спасибо за ответы!
Старый 16.06.2012, 18:24   5
Labour
Аватар для Labour
Я думаю, что параметры заряда, приведенные в данном обзоре, соответствуют действительности (цифры хорошо видно на графиках).
Опасаться оставить аккумулятор на заряде не стоит.
За такие деньги это лучший выбор.
Старый 20.07.2012, 14:30   6
Scratch
Опаньки
Аватар для Scratch
Последняя активность: 07.12.2022 12:50
Сказал(а) спасибо: 110
Поблагодарили: 271 раз(а) в 108 сообщениях
а разряд она контролит? или мобилы заряжать надо тока если аккум стоит защищенный
Как говорила моя бабушка: лучше выстрелить, перезарядить и еще раз выстрелить, чем светить фонариком и спрашивать «кто тут?»
Scratch вне форума   Ответить с цитированием Вверх
Старый 20.07.2012, 15:50   7
Labour
Аватар для Labour
Посмотреть сообщение Сообщение от Scratch :
У нее нет функции разряда аккумулятора
Старый 21.07.2012, 15:32   8
Rocklight
Зарядка оказалась хороша, проста как три рубля и достаточно точно заряжает (до 4,17-4,19В) 2600 вгоняет за 5 часов с 2,75В.
Старый 21.07.2012, 15:51   9
Последняя активность: 04.02.2024 09:42
Вопрос к владельцам.
А каковы режимы режимы работы индикатора: подключаем к питанию - зелёный, вставляем разряженный аккумулятор - красный, по окончании заряда - зелёный, такие?
У меня пришла такая с HK, но что-то работает как-то странно.
Подключаю питание - ничего, ставлю 16340 - загорается красный, через несколько часов гаснет. Ставлю 18650 - красный, который минут через 15 гаснет и дальше ничего не загорается. Но, тем не менее, аккумы вроде бы заряжает, контролировать время только сложно.
Старый 21.07.2012, 16:00   10
mike
Аватар для mike
Последняя активность: Вчера 19:09
Сказал(а) спасибо: 86
Поблагодарили: 269 раз(а) в 182 сообщениях
Такие. Но бывает, что аккум уже долго заряжается, а всё красный. Если его отсоединить от зарядки и снова поставить - зелёный. Зависимость не понял.
Старый 21.07.2012, 16:25   11
Последняя активность: Вчера 21:03
Сказал(а) спасибо: 5939
Поблагодарили: 32753 раз(а) в 15181 сообщениях
высокое внутреннее сопротивление аккумулятора - напряжение растет быстро, ток зарядки соответственно падает, т.е большая часть заряда проходит в фазе CV, малым током.
во многих зарядках присутствует гистерезис порядка 0.1в, т.е если аккумулятор заряжается непрерывно - зарядит до 4.2в, если прервать заряд на напряжении выше 4.1в и включить повторно - заряд не возобновится
Старый 21.07.2012, 16:40   12
Rocklight
У меня индикация проста: пустой светиться при подкл.питании зеленым, вставляешь аккум красным, когда зарядиться опять зеленый и все. Иногда 18650-е защищенные передергивать приходиться для того что бы стартовал заряд но только защищенные, редко и не все (может особенность платы защиты).
Старый 21.07.2012, 17:43   13
Labour
Аватар для Labour
Так не должно быть. Это брак
Старый 25.07.2012, 17:17   14
Написал письмецо я в HK о странном поведении моей зарядки, а они и в несознанку спрятались - молчат.
Время генерации страницы 0.11471 секунды с 15 запросами
