4296 13 4 0 |
05.08.2017, 05:17 | 1 |
Acebeam L30 New Weapons-mountable Flashlight with Max 4000lms
There's a new sheriff in town! Acebeam's dazzling new L30 provides an unprecedented blast of 4,000 lumens from a weapons-mountable flashlight! Equipped with the very latest CREE XHP 70.2 chip and the micro USB direct charging system. Acebeam L30 work by both 18650 or 20700 rechargeable lithium-ion batteries. Optional remote pressure switch and range of filters make it an ideal companion for any kind of weapon.
Pls keep attention for more specifications through our official website: http://www.acebeam.com . sales@acebeam.com
www.acebeam.com [Исправлено: Acebeam Light, 05.08.2017 в 05:29] |
20.08.2017, 10:10 | 2 |
Регистрация: 14.08.2011 Последняя активность: Сегодня 07:06 Адрес: до Урала
Записей в дневнике: 10 Сказал(а) спасибо: 6842
Поблагодарили: 6965 раз(а) в 3311 сообщениях
Re: Acebeam L30 New Weapons-mountable Flashlight with Max 4000lms
Acebeam Light, "...and also 2*CR123 rechargeable lithium-ion batteries..."
PRODUCT DESCRIPTION Working voltage: 3V - 6V Will the driver withstand 8.4 volts? (2s 16340 or 2s 18350)
Do not buy if you do not know what you are doing! Убил - отпусти! [Исправлено: Медветь, 20.08.2017 в 10:11] |
26.08.2017, 11:52 | 4 |
Acebeam Light, Hide the micro-USB charging connector under the thread, or make a modification (option) without USB charging!
[Исправлено: Медветь, 26.08.2017 в 11:59] |
Кот_ученый (28.08.2017)
06.09.2017, 11:23 | 5 |
ser-kras (11.09.2017)
11.09.2017, 16:36 | 7 |
It's a pity.
For me it's very bad. I will not buy this flashlight. With this USB connector, it's not interesting for me and I do not need it. P.S. Make a modification (option) without USB charging! It will be easier to manufacture and cheaper, therefore in Russia it will find more buyers. Because the flashlight L30 itself is interesting. [Исправлено: Медветь, 11.09.2017 в 17:12] |
Поблагодарили: 2 раз(а) |
ser-kras (11.09.2017), Кот_ученый (12.09.2017)
11.09.2017, 17:39 | 8 |
Светят.Зашёл на огонёк :)
Регистрация: 20.01.2013 Последняя активность: 05.05.2022 05:01 Адрес: Ангарск
Сказал(а) спасибо: 1469
Медветь (11.09.2017)
13.09.2017, 10:09 | 10 | |
Let it be more expensive and more difficult, but neater and waterproof IPX8 without any rubber (silicone) plugs. I do not mind built-in charging, I'm against the extra hole in the head for the charging USB plug. [Исправлено: Медветь, 13.09.2017 в 11:00] |
Кот_ученый (13.09.2017)
13.09.2017, 11:12 | 11 |
Регистрация: 07.01.2016 Последняя активность: 17.11.2022 23:23 Адрес: Норильск
Сказал(а) спасибо: 202
Поблагодарили: 284 раз(а) в 203 сообщениях
Такой мощный светодиод разрядит 1 аккумулятор 18650/20700 очень быстро. более разумным, было бы использовать размер 26650. И, даМедветь прав- разъём микро USB можно было бы убрать под крышку батарейного отсека. Герметичность была бы лучше, и меньше шансов оторвать и потерять силиконовую заглушку.
Медветь (13.09.2017)
13.09.2017, 11:40 | 12 |
kugotoff, так я не зря спрашивал про 8.4v..
..у меня есть тубы от Т21 и Т25.. ..они должны отлично подойти к голове L30 *если, конечно, там не будет "дырочки в правом боку"(с)*.. ..получится хороший, мощный фонарь на питании 2s 20700 (18650) или 2s 26650 (без встроенной зарядки).. [Исправлено: Медветь, 13.09.2017 в 12:06] |
13.09.2017, 11:42 | 13 |
Кот_ученый (13.09.2017), Медветь (13.09.2017)
13.09.2017, 12:07 | 14 |
..если на L30 будет такой же разъём USB с заглушкой, как и на L16, то мне придётся *если, конечно, я его приобрету, в чём есть БОЛЬШИЕ сомнения* заливать гнездо USB эпоксидкой
..зачем переплачивать за встроенную зарядку и потом её выламывать и заглушать лишнее отверстие? ..или придётся снова ждать выхода нового аналогичного фонаря от Acebeam, T-класса, без USB.. ..а L30 - тогда мимо.. |
