10491 12 4 0 |
02.11.2011, 11:44 | 1 |
Flashlight surgeon
NEW Klarus XT1A, XT2A, XT1C, MiX5 The Midas Torch
Сегодня пришла информация от производителя по новым моделям.
Klarus MiX5 The Midas Torch Features: ※ One of smallest and brightest AAAA flashlight in the world ※ Durable, compact and reliable. Designed for every day carry ※ Digitally regulated output - maintains constant brightness, no PWM ※ Max output: 76 Lumens. Max run time: 26 hours ※ Reverse polarity protection Specification: ※ Emitter: Cree XP-E R2 LED with a lifespan of 50,000 hours ※ Four outputs, 25 lumens(2.2 hours) -- 2 lumens(26 hours) -- 76 lumens(40 minutes)-- Strobe (76 lumens, 1.2 hrs) ※ Battery: Single AAAA (Alkaline, Ni-MH) ※ Switch: Twist switch, Adjust output by rotating the flashlight head ※ Lens: Toughened ultra-clear glass ※ Material:Stainless steel ※ Dimensions:65.6mm (Length) x 9.2mm (Body) x 10.3mm(Head) ※ Net weight: 11g (Excluding battery) ※ Waterproof to IPX-8 standard Klarus XT1A The new XT series flashlights from Klarus are serious, precision-engineered illumination tools, which have been developed with tactical use and self-defense in mind. Part of the XT (Extreme Tactical) range, which includes the popular XT10 and XT20, this new XT1A is a true Tactical EDC. Being smaller than the XT10, it is easy to carry in a pocket or bag. Despite being small, the XT1A is very bright – outputting a maximum 150 ANSI lumens with a single AA battery. It uses Klarus's innovative dual-button tail switch (as seen on the XT10 and XT20 models) to allow for fast mode changes (from High to Medium and Low) and provide lightning-quick access to a super bright and disorientating strobe – making the XT1A an amazing self-defense flashlight. Specification 1.CREE XP-G R5 LED with a lifespan of up to 50,000 hours 2.Three lighting modes and 1 flashing mode: a)Lighting modes: 150 ANSI lumens (1hrs) b)30 lumens (6 hrs) c)4 lumens (50hrs) d)Variable frequency strobe: 150 lumens (2hrs) 3.Working Voltage: 0.9V-1.8V 4.Battery: 1pcs 1.5V AA Alkaline or Ni-MH (not included). 14500 lithium-ion battery will destroy the light 5.Body color: Military grey 6.Reflector: Textured orange peel reflector 7.Switch: Dual tail switch 8.Tactical main switch for turning the light on and off. Momentary activation from off. 9.Dedicated mode switch for instant access to strobe and changing modes 10.Lens: Toughened ultra-clear glass 11.Material:Aircraft grade aluminum 12.Dimensions: 116mm (Length) x24mm (Head) x22.6 (Body) 13.Net weight: 53g (Excluding battery) 14.Waterproof to IPX-8 Standard (underwater to 2 meters) 15.Included accessories: holster, lanyard, body clip and two spare o-rings Klarus XT2A Specification 1.CREE XP-G R5 LED with a lifespan of up to 50,000 hours 2.Three lighting modes and 1 flashing mode: a)Lighting modes: 245 ANSI lumens (1.5hrs) b)60 lumens (8 hrs) c)4 lumens (130hrs) d)Variable frequency strobe: 245 lumens (3hrs) 3.Working Voltage: 1.8-3.2V 4.Battery: 2pcs 1.5V AA Alkaline or Ni-MH (not included). 14500 lithium-ion batteries will destroy the light 5.Body color: Military grey 6.Reflector: Textured orange peel reflector 7.Switch: Dual tail switch 8.Tactical main switch for turning the light on and off. Momentary activation from off 9.Dedicated mode switch for instant access to strobe and changing modes 10.Lens: Toughened ultra-clear glass 11.Material:Aircraft grade aluminum 12.Dimensions: 163mm (Length) x24mm (Head) x22.6 (Body) 13.Net weight: 75g (Excluding battery) 14.Waterproof to IPX-8 Standard (underwater to 2 meters) 15.Included accessories: holster, lanyard, body clip and two spare o-rings Klarus XT1C Despite being small, the XT1C is very bright – outputting a maximum 245 ANSI lumens with a single CR123 battery. It uses Klarus's innovative dual-button tail switch (as seen on the XT10 and XT20 models) to allow for fast mode changes (from High to Medium and Low) and provide lightning-quick access to a super bright and disorientating strobe – making the XT1C an amazing self-defense flashlight. Specification 1.CREE XP-G R5 LED with a lifespan of up to 50,000 hours 2.Three lighting modes and 1 flashing mode: a)Lighting modes: 245 ANSI lumens (1hrs) b)60 lumens (4 hrs) c)4 lumens (70hrs) d)Variable frequency strobe: 245 lumens (2hrs) 3.Working Voltage: 1.8-3.2V 4.Battery: 1XCR123 5.Body color: Military grey 6.Reflector: Textured orange peel reflector 7.Switch: Dual button tail switch 8.Tactical main switch for turning the light on and off. Momentary activation from off 9.Dedicated mode switch for instant access to strobe and changing modes 10.Lens: Toughened ultra-clear glass 11.Material:Aircraft grade aluminum 12.Dimensions: 99mm (Length) x24mm (Head) x22.6 (Body) 13.Net weight: 47g (Excluding battery) 14.Waterproof to IPX-8 Standard (underwater to 2 meters) 15.Included accessories: holster, lanyard, body clip and two spare o-rings
Лечение флэшеголизма быстро, дорого. |
21.06.2012, 19:57 | 3 |
Регистрация: 02.01.2012 Последняя активность: 11.09.2014 21:31
Поблагодарили: 20 раз(а) в 8 сообщениях
Re: NEW Klarus XT1A, XT2A, XT1C, MiX5 The Midas Torch
XT!1X Я так понял не работает от аккумулятора, обломно
22.06.2012, 00:36 | 4 |
Flashlight surgeon
22.06.2012, 00:40 | 5 |
Регистрация: 21.10.2011 Последняя активность: 17.11.2018 09:26 Адрес: V R N
Сказал(а) спасибо: 80
Поблагодарили: 1100 раз(а) в 429 сообщениях
что за формат питания такой)
Sunwayman Thrunite Fenix и прочие по выгодной цене |
22.06.2012, 00:41 | 6 |
18.05.2013, 14:55 | 7 |
Регистрация: 26.03.2012 Последняя активность: 31.12.2013 09:54
Klarus XT1C, как я понимаю, работает только от батареек CR123?.. Аккумуляторы использовать нельзя?
20.05.2013, 14:22 | 8 |
Регистрация: 07.04.2012 Последняя активность: 18.04.2022 07:36 Адрес: Одесса, Украина
Сказал(а) спасибо: 356
Поблагодарили: 246 раз(а) в 106 сообщениях
21.05.2013, 21:07 | 9 |
Регистрация: 04.02.2011 Последняя активность: 26.01.2022 12:36 Адрес: Украина. Днепропетровск.
Поблагодарили: 4533 раз(а) в 2375 сообщениях
Александр Павлов, не слабо поговорили сами с собой) Все решили и всем довольны)
21.05.2013, 21:33 | 10 |
Регистрация: 29.11.2012 Последняя активность: 05.01.2018 02:18
Сказал(а) спасибо: 280
Это магазин приколов?).
21.05.2013, 21:37 | 11 |
На остальные цены глянь. ТК 35 - 1150р. катапульт 3 - 1500р и т.п. Мелкие зебры по 800. Распродажа посылок с почты?
Зы :На форуме уже было сообщение от пострадавшего на сайте-мошеннике dachnayatehnika.ru При поиске в Google по запросу "Телефон: 788-24-22, 788-21-29" открывается более 500 ссылок на различные интернет-магазины, имеющие эти контактные данные и одинаковый почтовый адрес: 43567, Россия,Москва, ул.Лазарева, 47, оф.21 http://forum.ozpp.ru/showth... [Исправлено: crus, 21.05.2013 в 21:42] |
28.05.2013, 11:30 | 12 | ||
Регистрация: 07.09.2012 Последняя активность: 29.08.2016 13:34
Сказал(а) спасибо: 4
Поблагодарили: 21 раз(а) в 7 сообщениях
Друзья, предлагаем небольший видеообзор XT1C KLARUS
03.06.2013, 10:49 | 13 |
Добрый день! Я так понимаю Вы имеете ввиду видеообзор фонарика MiX5Au.
Так вот- модель MiX5Au уже снята с производственной программы, распродаются остатки. Сняли с производства в виду редкости батареек АААА и полном отсутсвии в продаже аккумуляторов АААА. |
