219705 822 2 0 |
12.10.2020, 04:35 | 761 |
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02 Адрес: Shenzhen
Re: 3FVape - New products & Deals Update
Think Vape AUXO DNA 250C Vape Box Mod original price $169.99, now only $129.99
The Original ThinkVape AUXO DNA 250C Vape Box Mod is with authentic Evolv DNA 250C chipset and is the latest creation from ThinkVape. Powered by Dual 18650 batteries (not Included), supports variable wattage from 1 to 200 Watts of power. BP Mods Pioneer MTL / DL RTA $119.99 The BP Mods Pioneer RTA is constructed from Titanium Alloy (body) and PC (tank tube) in 22mm Diameter. Pioneer RTA comes with innovative airflow design, it supports fantastic MTL vaping experience and Restricted DL vaping. (Extension Pack is Not included). The RTA also comes with a 3.7ml E-juice capacity PC tank tube for your daily vaping. Furthermore, there are two types of spare Drip Tips and Tank Tubes for options: 1 x Ultem Drip Tip, 1 x Clear Drip Tip; 1 x Ultem Tank Tube, and 1 x PCTG Tank Tube. You can choose different drip tip or tube for your RTA as you like. Moreover, there are three Airflow Control Pins that meet your different airflow adjustable needs. SMOKTech SMOK Scar-Mini Vape Mod Kit $44.99 The Original SMOKTech SMOK Scar-Mini Vape Mod Kit is a mini portable version of its predecessor Scar-18 Mod and has been optimized and innovated on this basis while taking into account excellent functions and high-quality design. SMOK Scar-Mini Mod is getting lighter and lighter, adopting a unified leather and metal design, ergonomic size, comfortable to hold, and the same support IP67 Waterproof & Dustproof & Shockproof. The difference from the external structure of Scar-18 is that SMOK Scar-Mini transfers the battery slot to the top, and the type-C port is placed at the bottom of the mod. This slot can hold a single external battery 18650 battery (not included). Changing the battery is more convenient and quicker. The maximum output power of Scar Mini is up to 80W, which is easy to adjust freely through the side buttons, and the power range of 1W~80W allows you to get along with each puff as you like. Scar-Mini is also equipped with a 0.69-inch display. Although it is small, every detail is complete. Provide multiple types of protection measures to avoid potential risks. An adaptive power output function has been added to ensure a constant power output during vaping. SMOKTech SMOK Thallo S Pod Mod Kit $32.99 The Original SMOKTech SMOK Thallo S Pod Mod Kit is the external single 21700 / 18650 battery (100W) version of the SMOK Thallo Pod Mod Kit. Almost the same size as Thallo, Thallo S is slightly taller, same structure and color, chipset, matching pods, compatible coils; the difference is that Thallo S has a wider range of wattage adjustment and different battery types, charging is also faster. The Thallo S is capable of producing impressive clouds whilst not compromising on flavor. The Thallo S works with the same IQ-XS chipset as the integrated battery version but features 100 watts of power for a more satisfying vape experience. Original SMOKTech SMOK Thallo / Thallo S RPM Replacement Empty Pod Cartridge(3 PCS) $7.99 The Original SMOKTech SMOK Thallo Replacement RPM Pod Cartridge, made of PCTG material, no harmful element to your health, holds 5.0ml e-juice capacity. The RPM Pod cartridge is compatible with RPM Series Coils. Yyou can choose the various Coils to meet the different vaping demands. The Pod cartridge with the convenient side e-juice refill design, easy to inject your favorite e-juice, the silicone stopper to prevent the juice leaking. with the transparent e-juice window, you will know how much juice left by one glance. the bottom with a strong magnet design for the easy Pod installation and removal reinforces the stability as a whole. SMOKTech SMOK Thallo / Thallo S RPM 2 Replacement Empty Pod Cartridge(3 PCS) $7.99 The Original SMOKTech SMOK Thallo Replacement RPM 2 Pod Cartridge, made of PCTG material, no harmful element to your health, holds 5.0ml e-juice capacity. The RPM 2 Pod cartridge is compatible with SMOK RPM 2 Series Coils. You can choose the various Coils to meet the different vaping demands. The Pod cartridge with the convenient side e-juice refill design, easy to inject your favorite e-juice, the silicone stopper to prevent the juice leaking. with the transparent e-juice window, you will know how much juice left by one glance. the bottom with a strong magnet design for the easy Pod installation and removal reinforces the stability as a whole. |
13.10.2020, 05:47 | 762 |
Vapeasy Experiment 3 MTL RTA Clone $21.99
The Vapeasy Experiment 3 MTL RTA Clone is made from 316 stainless steel in 22mm diameter. The MTL RTA comes with two air towers and two fireplaces with different geometries to obtain the optimal aromatic yield. This MTL RTA is with bottom airflow adjustment control, with holes 0.8mm / 1.0mm / 1.2mm / 1.4mm / 1.6mm. There are two filling ports on the top cap for top refilling conveniently. Vaporesso FORZ TX80 Box Mod Kit $55.99 The Original Vaporesso FORZ TX80 Vape Box Mod Kit with FORZ RDA is composed of Vaporesso FORZ TX80 Vape Box Mod with waterproof, shockproof, and dustproof functions and Vaporesso FORZ RDA for DIY vaping. The frame of FORZ TX80 Mod is made of light zinc alloy and utilizes silicone accents to add an additional layer to the military-grade protection, preventing drop damage and dust and water intrusion. As for the features, the FORZ TX80 box mod is powered by 1 x 18650 battery (not included) and supports fast charging with up to 2A current through the USB Type-C port. The familiar AXON chip acts as a board in the device. The mod is equipped with an AXON Chip 2.0 board with a maximum power of 80 watts and has a temperature control function. Offering the F(t) Mode, ramping up voltage and heating rate within a certain timeframe to deliver great flavor. Original Coil Father SS2 Mesh Sheet Coil(10 PCS) $1.99 The Original Coil Father SS2 Mesh Sheet Coil is made from SS316 in 0.15ohm and it suitable for RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack Original Coil Father SS1 Mesh Sheet Coil(10 PCS) $1.99 The Original Coil Father SS1 Mesh Sheet Coil is made from SS316 in 0.12ohm and it suitable for RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack Original Coil Father A12 Mesh Sheet Coil(10 PCS) $1.99 The Original Coil Father A12 Mesh Sheet Coil is made from Kanthal A1 in 0.18ohm and it suitable for RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack Original Coil Father A11 Mesh Sheet Coil(10 PCS) $1.99 The Original Coil Father A11 Mesh Sheet Coil is made from Kanthal A1 in 0.13ohm and it suitable for RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack Original Coil Father A10 Mesh Sheet Coil(10 PCS) $1.99 The Original Coil Father A10 Mesh Sheet Coil is made from Kanthal A1 in 0.2ohm and it suitable for RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack Original Coil Father N81 Mesh Sheet Coil(10 PCS) $1.99 The Original Coil Father N81 Mesh Sheet Coil is made from Ni80 in 0.16ohm and it suitable for RDA / RTA / RDTA Vape Atomizer. 10 PCS / Pack Original BP Mods Clapton Coil Wire(3m) $13.99 The Original BP Mods Clapton Coil Wire is with 26GA A1 x 2 + 40GA Ni80 and is suitable for RDA / RTA / RDTA Vape Atomizer. Length: 3m Replacement Small Button for dotMod dotAIO(1 PC) $4.99 The Replacement Small button is made from acrylic and is suitable for dotMod dotAIO Vape Pod System. 1 PC / Pack. (Button only, Pod system not included) |
13.10.2020, 05:51 | 763 |
Original Artery Cold Steel AIO Kit Replacement 510 Adapter Connector(1 PC) $4.99
The Original Artery Cold Steel 510 Adapter is designed for Artery Cold Steel AIO Vape Mod Kit. The Artery Cold Steel 510 Adapter switches your Artery Cold Steel AIO Kit to a 120W Box Mod. The Artery Cold Steel 510 Adapter helps your Cold Steel AIO be compatible with most tanks of 510 threading connection. Original Artery Cold Steel AIO Kit Replacement XP RBA coil Pod Cartridge(1 PC) $4.99 The Original Artery Cold Steel Replacement XP RBA Coil Empty Pod Cartridge is designed for Artery Cold Steel AIO Vape Kit. The Artery Cold Steel Cartridge is compatible with RBA coil deck (RBA coil not included). Original Artery Cold Steel AIO Kit Replacement XP Pod Cartridge(1 PC) $4.99 The Artery Cold Steel Replacement Empty Pod Cartridge is designed for Artery Cold Steel AIO Pod Vape Kit. The Artery Cold Steel Pod cartridge is compatible with XP coil heads (coil not included), the same coils from Artery Nugget GT Kit, bringing amazing flavor and taste to vapers. Original Artery Cold Steel AK47 Kit Replacement HP Empty Pod Cartridge(1 PC) $3.99 Original Artery Cold Steel AK47 Pod Vape Mod kit Replacement HP Pod Cartridge is an empty pod that is created for Artery Cold Steel AK47 Kit. The pod cartridge holds 4.0ml e-juice capacity and features bottom filling system. Besides, Cold Steel AK47 Pod comes with a new e-juice detectable technology to remind the e-juice capacity and avoid dry burn. HP Pod Cartridge is compatible with HP 0.7ohm / 1.2ohm Coil (coil not included). Original Artery Cold Steel AK47 Kit Replacement XP Empty Pod Cartridge(1 PC) $2.99 Original Artery Cold Steel AK47 Pod Vape Mod kit Replacement XP Pod Cartridge is an empty pod that is created for Artery Cold Steel AK47 Kit. The pod cartridge holds 4.0ml e-juice capacity and features bottom filling system. Besides, Cold Steel AK47 Pod comes with a new e-juice detectable technology to remind the e-juice capacity and avoid dry burn. XP Pod Cartridge is compatible with XP 0.4ohm / 0.15ohm Coil (coil not included). Original Artery Cold Steel AK47 Kit Replacement NP Empty Pod Cartridge(1 PC) $3.99 Original Artery Cold Steel AK47 Pod Vape Mod kit Replacement NP Pod Cartridge is an empty pod that is created for Artery Cold Steel AK47 Kit. The pod cartridge holds 4.0ml e-juice capacity and features bottom filling system. Besides, Cold Steel AK47 Pod comes with a new e-juice detectable technology to remind the e-juice capacity and avoid dry burn. NP Pod Cartridge is compatible with NP 0.7ohm / 1.2ohm Coil (also the Nautilus BVC Coil) (coil not included). Original Artery NP Mesh Coil Head for Cold Steel AK47 Empty Pod Cartridge / Cold Steel AK47 Kit(5 PCS) $7.99 The Original Artery NP 1.2ohm Mesh Coil Head is best compatible with NP Pod Cartridge. The NP coil is compatible with Artery Cold Steel AK47 NP Empty Pod cartridge / Artery Cold Steel AK47 Vape Mod Kit (NP Pod Cartridge). |
14.10.2020, 08:43 | 764 |
Original Dovpo Top Gear DNA250C 200W Box Mod $169.99
The Original Dovpo TOP GEAR 200W Box Mod constructed from solid CNC machined aluminum alloy, the Top Gear Mod offers a reliable chassis with an aesthetically pleasing profile. Dovpo Top Gear operates off a pair of 18650 batteries installed (not included) via a bottom hinged door to deliver ample power to allow the Top Gear to reach its 200W ceiling. Outfitted with the advanced Evolv DNA250C Chipset, the Top Gear Box Mod has an extensive temperature control suite, offering compatibility with nickel, titanium, and stainless steel wires. Dovpo Top Gear Mod can deliver exceptional power to a ceiling of 200W, displayed on a 0.96" TFT Color Display Screen. Equipped with the conventional adjustment buttons, the Dovpo Top Gear is also equipped with a rotating knob at the top to allow for faster on-the-fly adjustment of the wattage or temperature settings. Wotofo Manik 80W Pod System Kit original price $39.99, now only $23.99 The Original Wotofo Manik Pod System Vape Mod Kit is powered by single 18650 battery (not included). The 0.96-inch TFT Screen display brings a clear operation interface to users. The Manik Pod Mod Cartridge comes with large 4.5ml juice capacity, In terms of performance, carrying with the intelligent NEX chip, the maximum output of Manik can reach 80W, which will offer you huge vapor cloud and multiple circuit protections. It adopts NexM coils And Net M Coil of both DTL and restricted DTL options, satisfying various tastes and clouds preferences. Manvape MP Baco 100W Box Mod Kit $30.99 The Original Manvape MP Baco 100W Mod Kit is built-in 2000mAh battery and 2.0ml tank vape atomizer. The mod is a high solid quality. Value Vape box mod starter kit super power up to 100W, smartly gives you the possibility to get different vaping power adjustments you want. The Humanized Design combines with smooth mysterious black coating. Ergonomic curved contour gives you the greatest grip and hold. Full of Strength. Built-in 2000mAh capacity 100W output vaping kit, give a totally pure rich flavors. 2.0ml tank vape atomizer, Upgraded Top-filled leak-proof tank makes filling as easy as it gets. The mod kit is quite portable and compact e cig starter kit set, fits perfectly in your hand or pocket. Eleaf Glass Pen Pod System Kit $27.99 The Original Eleaf Glass Pen Kit is the world's first portable vaping pod system with glass pod while also is a simple and compact all-in-one MTL starter kit. Eleaf Glass Pen adopts a vape pen style structure, a smooth aluminum body, no extra decoration, and puts it in a pocket or bag like a pen. The Glass Pen Kit is powered by a built-in 650mAh battery, with a USB-C charge port. The intuitive rectangular single-button design is easy to operate. Two modes are provided: Manual & Auto modes, which can fire using the single firing button or draw activated firing system. Eleaf Glass Pen Kit designed for those who want the minimum of hassle. The only maintenance required is filling up, charging, and replacing the coil when required. The innovation of Eleaf Glass Pen Kit lies in the pod, made of glass + stainless steel, has a longer life span, good heat resistance, and high transparency. The pod capacity is 1.8ml, with juice added on the side. You can easily inject your favorite e-juice without leaking. and it accepts the new Eleaf GTL 1.2ohm Coil. The coil is replaced by a push-pull method, which is very convenient. In addition, Eleaf Glass Pen is very suitable for high-concentration nicotine juice. For the pursuit of pure taste, glass is always the best choice. Glass Pen is used with a glass pod to bring the pure flavor for vapers. In addition, a cover cap is specially designed for Glass Pen to prevent your pod from the dust. In addition, Eleaf Glass Pen also provides multiple protections, including: overtime protection, over-discharge protection, over-charge protection and short-circuit protection. VAPJOY DIY Rebuild Kit $3.99 The Original VAPJOY DIY Rebuild Kit is suitable for SMOK RPM2 Coil. The authentic Vapjoy DIY Rebuild Kit consists of Rod, Cottons and Ni80 mesh Coils (0.16ohm). It is compatible with SMOK RPM2 Kit / SCAR P3 Kit / Scar P5 Kit. Enjoy fun to Rebuild. It can meet most of DIY lovers' demand. |
14.10.2020, 08:50 | 765 |
VAPJOY VINCI-TM1 DIY Rebuild Kit for Vopoo PnP $3.99
The Original VAPJOY DIY Rebuild Kit is suitable for Vopoo PnP Series Coils. The Original Vapjoy DIY Rebuild Kit consists of Rod, Cottons and Ni80 mesh Coils (0.6ohm). It is designed to replace coil head economical, compatible with PnP Series Coils. Enjoy fun to Rebuild. It can meet most of DIY lovers' demand. Wotofo Manik Replacement Empty Pod Cartridge(1 PC) $2.99 The Original Manik Empty Pod Cartridge comes with 4.5ml capacity and is suitable for Wotofo Manik Pod System Vape Mod Kit. Wotofo Manik Pod Mod Kit Replacement D15 Single Clapton Mesh Coil Head(5 PCS) $10.99 The Original Wotofo Manik Pod Mod Replacement D15 Single Clapton Mesh Coil 0.2ohm is perfectly compatible with Wotofo Manik Pod Mod Kit & Wotofo Manik Pod Cartridge. Wotofo Manik Pod Mod Kit Replacement D14 A1 Conical nexMESH Coil Head(5 PCS) $9.99 The Original Wotofo Manik Pod Mod Replacement D14 A1 Conical nexMESH Coil 0.2ohm is perfectly compatible with Wotofo Manik Pod Mod Kit & Wotofo Manik Pod Cartridge. Wotofo Manik Pod Mod Kit Replacement D13 A1 nexMESH Coil Head(5 PCS) $9.99 The Original Wotofo Manik Pod Mod Replacement D13 A1 NexM Coil 0.2ohm is perfectly compatible with Wotofo Manik Pod Mod Kit & Wotofo Manik Pod Cartridge. Wotofo Manik Pod Mod Kit Replacement D11 Single Net Mesh Coil Head(5 PCS) $9.99 The Original Wotofo Manik Pod Mod Replacement D11 Single Net Mesh Coil 0.2ohm Coil is perfectly compatible with Wotofo Manik Pod Mod Kit & Wotofo Manik Pod Cartridge. Eleaf Glass Pen Kit Replacement Pod Cartridge(1 PC) $8.99 The Original Eleaf Glass Pen Pod Cartridge is the world's first glass pod made of glass and stainless steel that is perfectly compatible with the Eleaf Glass Pen Kit. The filling volume is 1.8ml, which is filled through the side filling system and firmly closed with a silicone plug. The drip tip is integrated on the pod and is also made of glass. As we all know, the real glass will neither change the taste nor present the taste. Therefore, Eleaf Glass Pen Pod Cartridge is very suitable for reproducing the pure liquid taste, thus providing a first-class taste experience. In addition, the Glass Pen Pod is matched with the 1.2ohm coil, bringing a good MTL experience. 1 PC each pack. Eleaf GTL Coil Head for Pico Compaq / iJust AIO / Glass Pen(5 PCS) $11.99 The Original Eleaf GTL Coil is a mesh coil head that combines high-quality kanthal mesh wire and organic cotton, suitable for Eleaf Pico Compaq / iJust AIO / Glass Pen Kit. The GTL 1.2ohm coil, specially designed for MTL flavor. |
14.10.2020, 14:16 | 766 |
SXK Insider DB Killer 70W Stealth Box Mod Clone original price $56.90,now only $52.90
The SXK Insider DB Killer 70W TC VW Variable Wattage Stealth Vape Box Mod is made from brushed 316 stainless steel and ABS carbon. The mod is powered by 1 x 18650 battery (not included) and supports wattage adjustable from 5W to 70W, temperature control (200~600'F / 100~300'C). SXK Experiment 3 V3 MTL RTA Clone original price $23.90, now only $21.90 The SXK Experiment 3 MTL RTA Clone is made from 316 stainless steel in 22mm diameter. The MTL RTA comes with two air towers and two fireplaces with different geometries to obtain the optimal aromatic yield. This MTL RTA is with bottom airflow adjustment control, with holes 0.8mm / 1.0mm / 1.2mm / 1.4mm / 1.6mm. There are two filling ports on the top cap for top refilling conveniently. Hussar Legacy II RDA Clone $8.99 The Hussar Legacy 2 II V2 RDA Clone is made from 316 stainless steel in 22mm diameter. The Legacy 2 RDA Clone is designed for DL vaping with single coil building deck. The Legacy II RDA Clone is with dual side airflow adjustable. Comes with Bottom Feeder / BF / Squonker Pin for Bottom Feeder Mod. Auguse Khaos RDTA $26.99 The Original Auguse Khaos RDTA Rebuildable Dripping Tank Vape Atomizer comes with bottom BF Pin for RDA to be compatible with bottom feeder mod. And comes with standard 510 center pin for RTA. Original Auguse Khaos RDTA Replacement Tank Tube $2.99 The Original Auguse Khaos RDTA Vape Atomizer Replacement Tank Tube is made from PC and holds 2.0ml. Hugo Vapor Boxer AIO Replacement Pod Cartridge with 0.4ohm Mesh Coil(2 PCS) $5.99 The Original Hugo Vapor Boxer AIO Pod Cartridge comes with a 3.5ml capacity and suitable for Hugo Vapor Boxer AIO Vape Kit. Hugo Vapor Boxer AIO Pod Cartridge is made of PCTG adopts a translucent design, pull out the rubber plug on the side of the pod, and add e-juice through the slot. The bottom press-fit coil installation and the top is an integrated drip tip. The pod is compatible with the BX coil & SMOK RPM series coils. With a special airflow system allowing the user to rotate the installed pod to access a restricted DL or MTL airflow. Comes with 0.4ohm Mesh coil, 2 PCS / Pack Hugo Vapor Boxer AIO Replacement Empty Pod Cartridge(2 PCS) $3.99 The Original Hugo Vapor Boxer AIO Pod Cartridge comes with a 3.5ml capacity and suitable for Hugo Vapor Boxer AIO Vape Kit. Hugo Vapor Boxer AIO Pod Cartridge is made of PCTG adopts a translucent design, pull out the rubber plug on the side of the pod, and add e-juice through the slot. The bottom press-fit coil installation and the top is an integrated drip tip. The pod is compatible with the BX coil & SMOK RPM series coils. With a special airflow system allowing the user to rotate the installed pod to access a restricted DL or MTL airflow. Empty Pod Cartridge without coil head, 2 PCS / Pack Hugo Vapor Boxer AIO Replacement BX Mesh Coil Head(4 PCS) $5.99 The Original Hugo Vapor Boxer BX Mesh Coil Head is suitable for Hugo Vapor Boxer AIO Vape Kit. The BX 0.4ohm mesh coil is designed for the best flavor and excellent vapor production. The mesh structure brings a rapid heating process to provide a balanced flavor. Each replacement Coil has two O-rings on the top and one O-ring on the base for a quick plug and play system. 4 PCS / Pack |
16.10.2020, 08:48 | 767 |
Vandy Vape Jackaroo Dual 188W Box Mod original price $69.99, now only $56.99
The Original Jackaroo Dual Mod is a TC Box Mod that comes with ergonomic anti-skidding handgrip design for comfortable hand feeling. As it features waterproof, shockproof and dustproof, you are free of worry for rains or dropping by accident. In addition, it adopts innovative anti-loss design to find your device on app under blue tooth connection. It is powered by dual 18650 batteries (not included) and Vandy Chip with 188W max output. And there are 6 modes for your option: Power Mode, Bypass Mode, Voltage Mode, TC-SS Mode and TC-TI Mode. In addition, to ensure your safety and health, it is designed with multiple protections. Auguse Khaos RDTA $28.99 The Original Auguse Khaos RDTA Rebuildable Dripping Tank Vape Atomizer comes with bottom BF Pin for RDA to be compatible with bottom feeder mod. And comes with standard 510 center pin for RTA. Auguse Khaos RDA / RTA RDTA is an exquisite MTL (mouth-to-lung) rebuildable tank atomizer that has a diameter of 22mm, made of stainless steel and glass tube and decorated with large knurling, which greatly facilitates all operations of the device. The top is a removable 510 heat-resistant Delrin drip tip. Horizon Gallop 50W Pod System Kit original price $64.99, now only $33.99 The Original Horizon Gallop 50W Pod System Vape Mod Kit is a stylish, intelligent, and strong performance pod mod system kit that provides an excellent vaping experience. The zinc alloy structure and its compact size allow it to be held comfortably in the palm of your hand. Gallop kit built-in 2000mAh battery and could charge via the Type-C port, provide lasting long vape. You could adjust the working wattage up to 50W by pressing the "+" and "-" buttons, the 0.96 inches colorful display will show you the vaping data clearly, press the fire button slightly and begin to enjoy the vape, and support all necessary safety systems to ensure stable operation. The pod cartridge capacity of the device is unknown, and e-juice is filled in the form of a hole under the side stopper. It can be perfectly matched with the 0.4ohm T mesh coil and 0.4ohm S mesh coil included in the package to produce strong aroma and vapor. Innokin Kroma Z Pod Mod Kit $36.99 The Innokin Kroma Z Pod System Vape Mod Kit is compatible with the entire Z-Coil heads series. Auto detection of coil resistance and recommend wattage. Variable Wattage from 6 to 40 watts including an all new 0.3ohm Z-Coil for RDL from 30W to 40W. Massive 3000mAh battery with USB type-C charging port. Sleek styling including the side firing bar with LCD screen. Adjust the airflow from a tight MTL draw to a loose RDL draw. Fill the pod with 4.5ml of e-liquid without removing the pod Cartridge. Innokin Endura M18 Pod System Kit $23.99 The Original Innokin Endura M18 pod system vape starter kit is the pod mod version of the acclaimed Endura kit series. Powered by a 700mAh built-in battery, this sleek pod device features a stripped back, lightweight design and boasts a range of innovative features to enhance the vaping experience. Employing the Endura M18 replacement pod cartridge, which feature an adjustable airflow feature by simply rotating which ways the pod is inserted. Due to its simple operation, the Endura M18 kit is ideal for users of all experience levels. Horizon Gallop Replacement Pod Cartridge(1 PC) original price $4.99, now only $2.99 The Original Horizon Gallop Pod Cartridge is designed especially for the Horizon Gallop Pod System Vape Starter Kit, holds 4.8ml e-juice capacity. Emptey Pod Cartridge, without coil Innokin Endura M18 Pod Cartridge for Endura M18 Pod System(1 PC) $6.59 The Original Innokin Endura M18 Pod Cartridge is designed especially for the Innokin Endura M18 Pod System Vape Mod Kit, coming with 4.0ml e-juice capacity. Upgraded Prism BVC Coils and compatible with T18E coils (coils not included). Turn the pod 180 degree for a tighter or more open draw. Easy side filling 4.0ml pod cartridge. Innokin Kroma Z Replacement Pod Cartridge with Z Coil(1 PC) $6.99 The Original Innokin Kroma Z Pod Cartridge is designed especially for the Innokin Kroma Z Pod System Vape Mod Kit. Interchangeable 510 drip tip. Easy side fill with 4.5ml e-liquid capacity. Compatible with the entire Z-Coil line. Including an all new 0.3ohm Z-Coil for RDL from 30W to 40W. Horizon Gallop Replacement T Mesh Coil for Gallop Pod System / Gallop Pod Cartridge(3 PCS) original price $14.99, now only $9.99 The Original Horizon Gallop Replacement T Mesh Coil 0.3ohm is perfectly compatible with Horizon Gallop Pod System Vape Starter Kit & Gallop Pod Cartridge. Horizon Gallop Replacement S Mesh Coil for Gallop Pod System / Gallop Pod Cartridge(3 PCS) original price $14.99, now only $9.99 The Original Horizon Gallop Replacement S Mesh Coil 0.3ohm is perfectly compatible with Horizon Gallop Pod System Vape Starter Kit & Gallop Pod Cartridge. Innokin Endura M18 Replacement Coil Head for Endura M18 Pod Vape Mod Kit / Endura M18 Pod Cartridge(5 PCS) $7.99 These Original Innokin Endura M18 Replacement BVC Coil head is perfectly compatible with Innokin Endura M18 Pod System Vape Mod Kit & Endura M18 Pod Cartridge. Innokin Kroma Z Replacement Coil Head for Kroma Z Pod System Vape Mod Kit & Kroma Z Pod Cartridge(5 PCS) $8.99 The Original Innokin Kroma Z Replacement Coil head is perfectly compatible with Innokin Kroma Z Pod System Vape Mod Kit & Kroma Z Pod Cartridge. |
17.10.2020, 05:34 | 768 |
SMOK Vape Pen V2 Mod Kit $20.99
The SMOKTech SMOK Vape Pen V2 Vape Mod Kit is a compact brand-new multifunctional AIO vape pen kit that brings the very best vaping experience to the forefront with total simplicity. SMOK Vape Pen V2 offers excellent flavor capabilities and massive vapor production, from a slim, portable device, minus the complications of working with most box mods. Built into this device is a long-lasting 1600mAh battery and the Vape Pen V2 utilizes mechanical output mode, the power is up to 60W, especially used to produce the pleasant taste and dense vapor. The Vape Pen V2 Kit features a simple one-button design with an intelligent LED indicator, clearly show you the current device status, battery life, charging status, etc. Vape Pen V2 Kit comes with a sub-ohm tank with a capacity of 3.0ml. The tank has a wide hole dripper and fixed large opening airflow slots. To fill the e-juice, just unscrew the top cap. Vape Pen V2 Kit also containing a 0.15ohm Meshed Coil head structure. The 0.15ohm Meshed coil has a faster heating process and higher flavor intensity. The airflow control system is utilized to offer increased open airflow or reduced tight airflow. Rotate the AFC ring to change the flavor, and then produce a fuller or stronger flavor. SMOK Vape Pen V2 Kit Replacement DC Coil Head(5 PCS) $13.99 The Original SMOKTech SMOK Vape Pen V2 Kit Replacement DC Coil Head is with 0.6ohm resistance and suitable for 12W to 25W. The DC coil supports Faster heating & plumper taste. SMOK Vape Pen V2 Kit Replacement Meshed Coil Head(5 PCS) $13.99 The Original SMOKTech SMOK Vape Pen V2 Kit Replacement Meshed Coil Head is with 0.15ohm resistance and suitable for 30W to 35W. The meshed coil supports Even heating & massive vapor. |
19.10.2020, 06:18 | 769 |
IJOY Cigpet Capo 126W Box Mod 19.99
The Original IJOY Cigpet Capo VW Vape Box Mod is a device created by the creative merger of IJOY and its sub-brand Cigpet. It has a lightweight body, stylish appearance, ergonomics, and durable. The Cigpet Capo Mod is the first dual 18650 regulated box mod that is manufactured using environment-friendly PCTJ material. Exceeding the industry level of quality requirements and safety standards. PCTJ (Polycarbonates) material giving Cigpet Capo very good heat, impact and shock resistance, and is environmentally friendly. The Cigpet Capo Mod is equipped with a magnetic panel with a pattern of Japanese manga elements, using traditional three-button control, and with a spacious 0.91-inch OLED display which offers an exceptional clarity of your vaping parameters and more. The Cigpet Capo Mod is powered by dual 18650 batteries (not included) and is equipped with a UNIV chipset. The maximum actual output power is 126W. The leading-edge UNIV chip-set generates direct performance upgrade of instant fire speed and power efficiency, which far surpasses the industry competition. With its top center 510 connector, IJOY Cigpet Capo Mod is compatible with atomizers with a maximum diameter of 25mm without overhang. Coil Master Wire Cutters $5.99 The Coil Master Wire Cutter provides a necessary flush cutter with clean and precise cut of wires of all types and specially designed to function near posts or tight spots. Constructed with Chrome-Vanadium Steel alongside spring-loaded control, the Coil Master Wire Cutter is a necessary handy-dandy tool for builders. Innokin Glim Pod System Replacement Pod Cartridge(1 PC) $2.99 The Original Innokin Glim Replacement Pod Cartridge is designed specifically for the Innokin Glim Pod System Vape Kit. This refillable pod cartridge holds up to 1.8ml capacity and uses an integrated long-lasting 1.2ohm coil for a smooth MTL (mouth-to-lung) vape. Refilling is quick and simple with a child-resistant push-to-fill silicone seal: simply push the e-liquid into the fill port to begin filling, then reattach the pod to the device, and you're ready to vape. The pod incorporates an integrated mouthpiece that feels comfortable every time you vape. Uwell Valyrian Coil Head for Valyrian Sub Ohm Tank Atomizer(2 PCS) $6.99 The Original Uwell Valyrian Coil Head features 0.15ohm resistance and rated for 95~120W. It is suitable for Valyrian Sub Ohm Tank Atomizer. Replacement Glass Tube for GeekVape Zeus Dual / Zeus X / Zeus Sub ohm Tank / Zeus X Mesh RTA $1.89 This Replacement Glass Tube is designed for GeekVape Zeus Dual RTA / Zeus X RTA / Zeus Sub ohm Tank / Zeus X Mesh RTA Vape Atomizer. It comes with 4.0ml capacity. Replacement Bubble Tank Tube for OFRF Gear RTA $1.89 The replacement bubble glass tank tube has 3.5ml of juice capacity and is suitable for OFRF Gear RTA. ZQ USB Lanyard for Xtal Pod System Vape Kit $3.59 This lanyard can is design for not only for ZQ Xtal Pod System Vape Kit and some pod like Xtal, but also as a Micro USB cable. It's fashionable and useful. (lanyard only, Pod System not included) Vaporesso USB to Type C Cable + PU Leather Case for Vaporesso Xros Pod System Vape Kit $3.99 The Original USB to Type C charging cable and PU Leather protective case is Suitable for Vaporesso Xros Pod System Vape Kit |
20.10.2020, 05:17 | 770 |
VapingGT GT Pen 40W Pod System Kit $22.29
The Original VapingGT GT Pen Pod Kit is a pod system kit that features compact and portable. It consists of a 2.0ml pod cartridge with side filling design and a 900mAh built-in battery that can fire up to 40W. And it is charged via a safe and fast Type-C port. In addition, it provides Overcharge protection, Short circuit protection and Security protection to ensure your safety. Besides, it supports 0.5ohm GT Pen coil. VapingGT GT Pen Replacement Pod Cartridge(1 PC) $9.39 The Original VapingGT GT Pen Pod Cartridge is suitable for VapingGT GT Pen Pod System Vape Starter Kit. It holds 2.0ml e-juice capacity and adopts side filling design. The Pod Cartridge comes with 0.5ohm GT Pen coil. 1 PC in each pack. VapingGT GT Pen Replacement Coil Head(5 PCS) $10.95 The Original GT Pen Coil is designed for VapingGT GT Pen Pod System Vape Starter Kit and GT Pen Pod Cartridge. It features 0.5ohm coil resistance. And comes with 5 PCS in each pack. Land Vape BF Mesh Replacement Coil for SMOK RPM / Fetch / Scar / Mag Pod System(5 PCS) $7.99 The Original Land Vape BF-Mesh Coil is specially designed for a lower power pod system. It's a single mesh coil which supports 25~30W, and are optimized for flavor seeking vapers, suitable for SMOK RPM / SMOK Fetch / SMOK Scar / SMOK Mag Pod System. BF-Mesh 0.4ohm Coil brings excellent surface quality, helps warm the cotton faster for a balanced pull and a longer lifespan. Land Vape BFV Mesh Coil for VOOPOO Vinci X / R / Drag X / S / Max / Vapresso Target PM80 / Wismec R80(5 PCS) $7.59 The Original Land Vape BFV-Mesh Coil is a single mesh coil with wide compatibility, suitable for VOOPOO Drag Max / Vinci / Vinci X / Vinci R / Drag X / Drag S / Navi; Vaporesso Target PM80 / Target PM80SE; Wismec R80 / R40. From the outside, it looks like most PnP coil heads. There is a 0.3ohm mesh grid inside, which ensures a good flavor and more vapor. The recommended wattage is 32~40 watts. Nitecore UI1 USB Charger for Li-ion / IMR 18650, 20700, 21700 Battery $7.99 The Nitecore UI1 is a portable USB battery charger with input 5W and max output of 0.8A, Powerful compatible with 3.7V rechargeable Li-ion batteries which is also available for large-sized 20700, 21700 Li-ion batteries and more. Moreover, It has multiple charging safeguards and automatic termination upon charging completion. |
21.10.2020, 07:31 | 771 |
Vaporesso Luxe PM40 Pod System Kit 29.99
The Original Vaporesso LUXE PM40 focusing on a good flavor experience, a multi-function device suitable for sub-ohm vape. LUXE PM40 has a stylish and compact appearance, with holographic IML panels on both sides, exquisite and elegant. Powered by a large 1800mAh built-in battery it offers up to a full day of vaping when charged, with 2A fast charging. Responsible for the outstanding performance of LUXE PM40 is the new AXON 2.0 chipset, which produces a maximum power of 40 watts. Not only a fast ramp-up, but also protection against issues including overcharging, overheating, and a 10-second cut-off. AXON 2.0 chipset has multiple modes and powerfully customizable functions. F(t) Mode - Increase the output voltage and cover a wider temperature range. Guarantee a better taste; Pulse Mode - Increase the current every 0.02 seconds to improve the taste; ECO Mode - Trying to extend battery life; VV - Manual voltage setting; POWER - Classic variable wattage; innovative turbo-boosting feature - for increased power output and consistent flavor. GeekVape Mero AIO Vape Kit original price $24.99, now only $20.99 Original GeekVape Mero AIO Vape Starter Kit is a multi-functional All-in-one Kit, with a vape pen structure, made of durable 304 stainless steel, compact and simple appearance, providing excellent grip and portability. Featuring a large 2100mAh rechargeable battery, the Mero AIO Kit can be used for two consecutive days without the need to recharge the spacious battery. Mero AIO Kit cannot manage wattage, it will automatically recognize and apply appropriate power. Supplying ample power to facilitate a voltage based direct output with three selectable power levels to fine-tune. Three power output (3.2V / 3.5V / 3.8V) adjustments to meet all your needs. The LED indicator light is located on the intuitive fire button. In addition, the Mero AIO Kit has a 510 connector that can be connected to 510 vape atomizer. Vaporbucks Simmi Pod System Kit $13.99 The Original Vaporbucks SIMMI Pod System Vape Starter Kit is an AIO opened Pod system. It is equipped with a 520mAh large-capacity built-in battery, a super-feeling Violence Output Fire Button, and a 1.8ml Pod with up to 5 times refillable lifespan, bringing the ultimate MTL (1.2ohm, 1.4ohm) & DTL (1.0ohm) atomization experience. Ultralight magnesium-silicon medical special aluminum alloy integrated body, duckbill-type suction dipper suitable for human mouth shape, double vortex suction + independent condensation collection space in order to prevent liquid leaking and climbing. SIMMI, a new generation of AIO opened Pod system, worthy of your expectations. Vaporbucks FreeSE Pod System Kit $8.99 Original Vaporbucks FreeSE Pod System Vape Starter Kit adopts ergonomic design and tiny size. Vaporbucks FreeSE Pod System Kit works with built-in 520mAh battery with type-C charging. Vaporbucks FreeSE features unparallel airflow design and dual vortex technology. Vaporbucks FreeSE Pod Cartridge has 1.5ohm MTL coil to bring MTL vaping. Vaporbucks Frees Pod System Kit $14.99 Original Vaporbucks Frees Pod System Vape Starter Kit is powered by built-in 520mAh battery and All-in-One dust cap for dustproof. It is made of Zinc Alloy material with specular technology, which is shiny, stylish and light.1.6ml FREES Pod cartridge adopts S-Type tunnel and smooth & hit straight to your head for better flavor. Pod Cartridge features organic cotton, leakproof and Anti-Blow protection design. Vaporbucks Frees Pod Kit features the oil core separation & Pampers oil locking system which can eliminate oil leakage. The structure of double scroll suction & condensate collection bin to collect condensate. SXK Supbox Box Mod Kit Replacement 18650 / 18350 Battery Tube + Atomizer Ring original price $19.90, now only $17.90 Original SXK Supbox Box Mod Kit Replacement Battery Tube is made from stainless steel and holds 1 x 18650 / 18350 battery (battery not included). Coms with 1 Atomizer Ring. Replacement Front + Back Door Panel Plates for dotMod dotAIO(2 PCS) $11.99 The Replacement Front and Back Door Panel Plates is made from PCTG and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included) 2 PCS / Pack Vaporbucks Frees Replacement Pod Cartridge with 1.4ohm Coil(4 PCS) $8.99 The Frees Pod Cartridge is designed especially for the Vaporbucks Frees Pod System Vape Starter Kit, coming with 1.6ml e-juice capacity. Vaporbucks FreeSE Replacement Pod Cartridge with 1.5ohm Coil(4 PCS) $6.99 The Vaporbucks FreeSE Pod Cartridge is designed especially for the Vaporbucks FreeSE Pod System Vape Kit, coming with 1.6ml e-juice capacity. The refillable pod cartridge is with 5.2mm Super slim dripper and dual Vortex Technology for condensation control. Unparallel airflow design brigs unparallel vape experience with truly splendid flavor. Vaporbucks Simmi Replacement Pod Cartridge with 1.0ohm RDL Coil(4 PCS) $7.99 The Vaporbucks Simmi Pod Cartridge is designed especially for the Vaporbucks Simmi Pod System Vape Starter Kit, coming with 1.8ml e-juice capacity and 1.0ohm RDL coil. Vaporbucks Simmi Replacement Pod Cartridge with 1.2ohm MTL Coil(4 PCS) $7.99 The Vaporbucks Simmi Pod Cartridge is designed especially for the Vaporbucks Simmi Pod System Vape Starter Kit, coming with 1.8ml e-juice capacity and 1.2ohm MTL coil. Vaporbucks Simmi Replacement Pod Cartridge with 1.4ohm MTL Coil(4 PCS) $7.99 The Vaporbucks Simmi Pod Cartridge is designed especially for the Vaporbucks Simmi Pod System Vape Starter Kit, coming with 1.8ml e-juice capacity and 1.4ohm MTL coil. |
22.10.2020, 05:26 | 772 |
Aspire MIXX 60W Box Mod Frosted original price $69.99, now only $59.99
The Aspire MIXX Vape Box Mod is constructed from Satin Anodized Aluminum and Surgical Grade Stainless Steel material and it is powered by 1 x 18350 or 18650 Battery (Battery is not included, sold separately). The Maxium Output is up to 60W, and it supports 3 Modes: VV, VW, and Bypass Mode. Equipped with a 0.91" OLED Screen, it can display all data of this device for you. IJOY Flash Tank vape atomizer original price $29.99, now only $21.99 The Original IJOY Flash Tank vape atomizer features top airflow control ring, and mesh coils delivering exquisitely flavored vapor. Outfitted with a 4.5ml capacity, the IJOY Flash Tank can be refilled from a threaded top filling system. The top of the IJOY Flash Tank is compatible with an 810 wide bore drip tip. The air inlet and rotating ring are placed directly under the top cap to reliably protect the equipment from accidental leakage. The ring is a leakproof dual slotted top airflow control ring, delivering airflow from a top to bottom path. The flavor is boosted by a high dynamic top-to-bottom airflow system. IJOY Flash Tank uses a new replaceable Clapton mesh coil, a combined evaporation element made of Mesh and Clapton, with improved weaving performance, more contact surface for e-liquid, outputting deliciously flavored vapor from your favorite e-juice. VOOPOO Argus Pro Pod System Kit $29.99 The original VOOPOO Argus Pro Pod Mod kit combines performance and aesthetics. It is made of zinc alloy and leather that has an elegant appearance and compact size, and its ergonomics in the hand is excellent. There is a fixing Hooks above the control panel of the device and can be worn with a lanyard. Easy to carry, vaping anytime, anywhere. The Argus Pro is powered by an internal, long-lasting 3000mAh battery. Powered by the upgraded GENE.TT Chipset enables Argus Pro Kit to ignite within 0.001s and provides a variety of smart functions such as PUFF recording, SCORE ranking, SMART switching start mode, etc. This intelligent chipset also features a maximum power output of 80W and a coil recognition system that automatically matches the installed coil with the best wattage. IJOY Flash Tank Replacement Clapton Mesh Coil Head(5 PCS) original price $13.99, now only $10.99 The Original IJOY Flash Replacement F0.15 Clapton Mesh Coil head is specially designed for IJOY Flash Tank vape atomizer in 0.15ohm. F0.15 Clapton Mesh Coil increases the heating surface and accelerates the heating process. The unique design of the Clapton Mesh Coil allows users to experience more flavor and a long-lasting coil life compared to traditional mesh. IJOY Flash Tank Replacement Mesh Coil Head(5 PCS) original price $12.99, now only $9.99 The Original IJOY Flash Replacement F0.5 Mesh Coil head is specially designed for IJOY Flash Tank vape atomizer in 0.5ohm. |
23.10.2020, 05:42 | 773 |
Hellvape Trishul V2 Mech Mod original price $67.40, now only $40.15
The Original Hellvape Trishul V2 Mechanical Mech Vape Mod Short is an updated version of Hellvape Trishul Mod. It features 27mm diameter tapers to 25mm. Adopting innovative, strong and stable magnet attraction button design, it is comfortable to use in a long term. Besides, it is powered by single 21700, 20700 or 18650 battery (battery not included). And it includes the 18650 battery adapter. Moreover, it is designed with built-in Canted Coil Spring and large copper contact with mirror polishing craft for better conductivity. KSL Box S 80W Box Mod $44.99 KSL Box S Mod boasts a single 18650 battery (not included) that delivers up to 80 watts of power. The S Mod is managed by the KSL V2.0 chipset, supports VW, TC (Ni, Ti, SS), and Bypass modes with 0.1s fire speed. You can check the settings via the OLED screen, it's very convenient. Made from zinc alloy and stainless steel, KSL Box S has a fine appearance, and it is durable. MISSION XV Quantum 510 Drip Tip Clone with 4 x Inserts for SXK BB / Billet Box / Dotod dotAIO $7.99 The MISSION XV Quantum 510 Drip tip Set Clone, the mouthpiece is made from PMMA and the 510 base connector is made from stainless steel, comes with 4 PCS inserts (4.5mm / 3.5mm / 2.5mm / 1.5mm). It is suitable for SXK BB / Billet Box Mod Kit, Dotod dotAIO mod kit. MISSION XV Quantum 510 Drip Tip Mouthpiece Clone for SXK BB / Billet Box / Dotod dotAIO $2.59 The MISSION XV Quantum 510 Drip tip mouthpiece Clone is made from POM and need to be used with the stainless steel 510 base connector and the inserts (the stainless steel base and the inserts are not included). It is suitable for SXK BB / Billet Box Mod Kit, Dotod dotAIO mod kit. |
24.10.2020, 05:15 | 774 |
Elite Experiment 3 MTL RTA Clone $13.99
The Elite Experiment 3 MTL RTA Clone is made from stainless steel in 22mm diameter. The MTL RTA comes with two air towers and two fireplaces with different geometries to obtain the optimal aromatic yield. This MTL RTA is with bottom airflow adjustment control, with holes 0.8mm / 1.0mm / 1.2mm / 1.4mm / 1.6mm. There are two filling ports on the top cap for top refilling conveniently. VOOPOO Argus Pod System Kit with PnP Pod $27.99 The Original VOOPOO Argus Pod Mod Kit is equipped with a GENE.AI chip and two different capacities PnP platform Pod cartridge. The innovative fusion of alloy and leather provides the vision and texture of love at first sight. Ergonomic design creates the most comfortable grip and ultralightweight brings a portable experience. The Argus is equipped with a 1500mAh battery, powerful and long-lasting to reduce frequent charging. This internal rechargeable lithium battery supports 5V / 1A charging by Type-C port. Argus Pod Mod Kit integrates GENE.AI Chipset to bring diversified vape. GENE.AI standing out by intelligent coil matching feature, 2-week usage record. Argus intelligently identifies the coil and matches the power and provides 5~40W power regulation. This feature also aids in preventing coil burnout, allowing you to get the most use out of each pod. Replacement PC Tank Tube + Stainless Steel 510 Drip Tip Kit for Elite Experiment 3 MTL RTA Clone $5.99 The Replacement PC Tank Tube holds 2.5ml capacity and comes with stainless steel 510 Drip Tip. It is suitable for Elite Experiment 3 MTL RTA Vape Atomizer Clone. Vandy Vape Kylin Mini V2 RTA Replacement Bubble Glass Tank Tube $2.99 The Original Vandy Vape Bubble Glass Tank Tube is suitable for Kylin Mini V2 RTA Vape Atomizer. It holds 5.0ml capacity. Vandy Vape Kylin Mini V2 RTA Replacement Straight Glass Tank Tube $1.99 The Original Vandy Vape Straight Glass Tank Tube is suitable for Kylin Mini V2 RTA Vape Atomizer. It holds 3.0ml capacity. Vandy Vape Pyro V3 RDTA Replacement Glass Tank Tube $1.99 The Original Vandy Vape Glass Tank Tube is suitable for Pyro V3 RDTA Vape Atomizer. It holds 4.0ml capacity. |
26.10.2020, 05:23 | 775 |
ThunderHead Creations THC Artemis RDTA original price $39.99, now only $31.99
Original Thunderhead Creations THC and Tony Vapes present in a cooperation to make the Artemis RDTA vape atomizer, a modern and optically very attractive single coil building, which is especially suitable for DL-vaping. With its diameter of 24mm the Artemis RDTA can be combined with a variety of mechanical mod and VW Box mod. It will certainly convince you all along the line with its perfect characteristics and the ideal vaping experience. The deck offers enough space to use even larger windings and special wires, handling is child's play and pleasant. With the tank volume of 4.5ml you will get through the day perfectly. The Artemis RDTA comes with bottom feeder / BF / Squonk pin to be used as a squonker atomizer. The airflow of the Artemis RDTA can easily be adjusted very precisely, which also allows a more restrictive draw. The single coil deck RDTA Vape atomizer is for DL vaping. Vaporesso Luxe PM40 Replacement Pod Cartridge(1 PC) $4.99 The Original Vaporesso Luxe PM40 Pod System Replacement Pod Cartridge holds 4.8ml capacity. Empty Pod Cartridge Only, without coil. Vaporesso GTX Mesh Coil Head for Luxe PM40 - Restricted DTL Vaping (5 PCS) $10.99 The Original Vaporesso GTX 0.6ohm Mesh coil is for restricted DTL vaping supports 20~30W. It is suitable for Vaporesso TARGET PM80, TARGET PM80 SE, TARGET PM30, GTX ONE, GEN NANO, XIRON, Luxe PM40 Pod System Vape Kit Replacement PC Tank Tube + POM 510 Drip Tip Kit for Elite Experiment 3 $5.99 The Replacement PC Tank Tube holds 2.5ml capacity and comes with POM 510 Drip Tip. It is suitable for Elite Experiment 3 V3 MTL RTA Vape Atomizer Clone. Replacement PC Tank Tube + Stainless Steel 510 Drip Tip Kit for Elite Experiment 3 $5.99 The Replacement PC Tank Tube holds 2.5ml capacity and comes with Stainelss Steel 510 Drip Tip. It is suitable for Elite Experiment 3 V3 MTL RTA Vape Atomizer Clone. |
27.10.2020, 05:25 | 776 |
GeekVape TALO X RDA original price $24.99, now only $18.99
Original GeekVape TALO X RDA vape atomizer is a signle / Dual Coil RDA with innovative postless deck for easy coil building. The GeekVape TALO X RDA supports adjustable airflow on both sides to control every single vape. The RDA is compatible with 810 drip tip and comes with 510 drip tip adapter (510 drip tip not included). Uwell Caliburn KOKO Prime Pod System Kit $24.99 Uwell Caliburn KOKO Prime pod kit utilizes a refillable pod cartridge system that pod cartridge has a 2.0ml capacity and uses a top filling system which is best for reducing leaks. Designed for salt nicotine e-liquids, supports smooth and consistent draws. Caliburn KOKO Prime also is compatible with Caliburn G pod cartridges and coils. Oumier Voocean 40 / Voocean 80 Pod / Cartridge Replacement Meshed Coil Head(5 PCS) $11.99 The Oumier Replacement Coil is designed for Oumier Voocean 40 / Voocean 80 Pod System Vape Kit / Cartridge, which features 0.2ohm coil resistance.5 PCS / Pack Asvape Hita Mech Mod Pod Kit / Hita Ink Kit Replacement DTL Mesh Coil Head(5 PCS) $11.99 The Original Asvape Hita Replacement DTL Mesh Coil Head is designed for Asvape Hita Mech Mod RBA Pod Vape Kit / Hita Ink Kit. It features 0.3ohm coil resistance. Disposable Drip Tip for Voopoo Drag X / S(10 PCS) $1.49 The Disposable Drip Tip is suitable for for Voopoo Drag X / Voopoo Drag S Pod System Vape kit. Innokin Zenith Pro Vape Atomizer Decorative Ring $2.99 This Decorative Ring was design for Innokin Zenith Pro Tank vape atomizer. Additional colored beauty rings to customize the look of your tank. Replacement Glass Tank Tube for SMOK Stick V9 Max $1.49 The Replacement Glass Tank Tube holds 8.5ml and is suitable for Stick V9 Max Vape Mod Kit. |
28.10.2020, 08:47 | 777 |
asMODus Lustro 200W Stabilized Wood Box Mod original price $299.99, now only $85.99
Original asMODus Lustro 200W Vape Box Mod is powered by dual 18650 cell (battery not included) with 200W max output. The Relic Edition features hybrid stabilized wood frame that intensifies the classy look. Adopting color-changing LED touch screen, it is easier for vapers to operate. It is driven by the GX-200-HUT chipset with high performance and features IR (infrared) sensor. asMODus Lustro 200W Mod is equipped with various modes: variable wattage, power curve, temperature control, adjustable TCR and TFR modes. You can enjoy easy operation with the single button design. Multiple protections are applied to guarantee safety and stability. Vapefly Siegfried Tube Mod original price $46.99, now only $33.99 Original Vapefly Siegfried Tube Mod is a compact tube mod that designed by German 103 & Vapefly, with a maximum diameter of 25.2mm, perfectly matching Siegfried Mesh RTA, and also suitable for other 510 vape atomizers. Siegfried tube mod has a high-quality process, forged and polished from the best quality stainless steel. After careful CNC processing, with a dragon-shaped carving pattern, it is in line with ergonomics and has an excellent hand feel. Vapefly Siegfried Mod is powered by 1 x 18650 / 20700 / 21700 battery (battery not included, 18650 battery adapter included). The LED above the fire button can quickly and easily read the battery level. The Siegfried Tube Mod will transfer the power provided to it in bypass mode to the connected tank and the coil used. This means that the power output depends on the coil resistance used and the current-voltage of the battery cell used. The core of Siegfried Mod is Vapefly's modern 3S chipset. This is also the main difference between Siegfried Tube Mod and pure mechanical mod. The chipset has a nano-coating to prevent the penetration of water, moisture, and liquids, and always reliably and safely monitor the work of the Siegfried Mod.Authentic Vapefly Siegfried Tube Mod is a compact tube mod that designed by German 103 & Vapefly, with a maximum diameter of 25.2mm, perfectly matching Siegfried Mesh RTA, and also suitable for other 510 vape atomizers. Siegfried tube mod has a high-quality process, forged and polished from the best quality stainless steel. After careful CNC processing, with a dragon-shaped carving pattern, it is in line with ergonomics and has an excellent hand feel. Vapefly Siegfried Mod is powered by 1 x 18650 / 20700 / 21700 battery (battery not included, 18650 battery adapter included). The LED above the fire button can quickly and easily read the battery level. The Siegfried Tube Mod will transfer the power provided to it in bypass mode to the connected tank and the coil used. This means that the power output depends on the coil resistance used and the current-voltage of the battery cell used. The core of Siegfried Mod is Vapefly's modern 3S chipset. This is also the main difference between Siegfried Tube Mod and pure mechanical mod. The chipset has a nano-coating to prevent the penetration of water, moisture, and liquids, and always reliably and safely monitor the work of the Siegfried Mod. Vapefly Siegfried Meshed RTA original price $55.99, now only $34.99 The Original Vapefly Siegfried RTA is the 5th project designed by German 103 and Vapefly. It is made of stainless steel, with CNC engraving and corrosion craftsmanship, making it more exquisite. In addition, it adopts anti-dry burn system, such as larger contact area between cotton and e-juice, shorter e-juice transfer distance, faster e-juice transfer and so on. And with innovative hollow deck design, it is simple for you to build coil. The firebolt M cotton is specially suitable for Siegfried Mesh RTA. To bring you huge cloud and fabulous flavor, it also utilizes side airflow. Moreover, it is compatible with 3 types of coil, like M1 Mesh Wire Ni80 0.2ohm, M2 Mesh Wire KA1 0.2ohm, and M4 Grid Mesh Wire KA1 0.18ohm (not included). Vapefly Siegfried Kit original price $92.49, now only $60.99 Original Vapefly Siegfried Kit is a new work launched by Vapefly and Germany 103 after Brunhilde and Kriemhild. Vapefly Siegfried Tube Kit consists of Siegfried Tube Mod and Siegfried RTA. The whole kit is made of stainless steel, with CNC engraving and corrosion craftsmanship, making it more exquisite. The surface of the fuselage adopts precise milling and numerical control dragon-shaped pattern, ergonomic rod-like size. Vapefly Siegfried Mod provides space to accommodate 20700 or 21700 size batteries, so it has a longer running time than similar 18650 battery boxes from other manufacturers. Of course, an adapter for the widely used 18650 battery is also included. The LED above the fire button can quickly and easily read the battery level. A special feature of Siegfried Mod is to operate by bypass instead of setting the output power by watts or volts, depending on the battery voltage and the coil resistance used in the atomizer. The Vapefly Siegfried tube mod also has a built-in Vapefly 3S chip protection to ensure the safe use of users. SXK Boropad MTL Airflow Plug Clone + Air Inserts for Billet Box / SXK BB original price $9.90, now only $8.50 The SXK Boropad MTL Airflow Plug Clone + Air Inserts is suitable for Billet Box Mod Kit / SXK BB Box Mod Kit. Comes with 4 PCS air inserts: 2.0mm / 2.5mm / 3.0mm / 3.5mm. SXK Boropad Standard Airflow Plug Clone + Air Inserts for Billet Box / SXK BB original price $9.90, now only $8.50 The SXK Boropad Standard Airflow Plug Clone + Air Inserts is suitable for Billet Box Mod Kit / SXK BB Box Mod Kit. Comes with 4 PCS air inserts: 2.0mm / 2.5mm / 3.0mm / 3.5mm. SMOK Alike Kit Nord Empty Pod Cartridge(3 PCS) $4.99 The SMOKTech Nord Empty Pod Cartridge is in 5.8ml capacity for SMOK Alike Kit. Empty pod cartridge, without coils The pod cartridge is compatible with SMOK Nord series coils. |
29.10.2020, 05:29 | 778 |
Augvape Druga RTA original price $34.99, now only $24.99
The Original Augvape Druga RTA Rebuildable Tank Vape Atomizer is made from stainless steel and with dual glass tank: 2.4ml straight tank / 3.5ml bubble glass tank. The 24mm Druga RTA is with dual coil building deck and bottom airflow. The Druga RTA with top filling system easy to refill. Augvape Intake MTL RTA original price $38.00, now only $25.99 The Original Augvape Intake MTL RTA vape atomizer is designed for MTL (Mouth To Lung) vapers, which generally gives a tighter precision airflow and is often used with low power high resistance coils. Comes with 24mm diameter and 3.1ml (Straight glass) / 4.6ml (Bubble glass). It adopts top filling design and leakproof design. The deck is designed for single coil building and with a decent 24mm diameter. 6 different size of bottom airholes to make sure you can choose how tight your draw is. Condensation Plugs dotPlug for dotMod dotAIO $5.99 The condensation plug dotPlug is suitable for the dotmod dotAIO Pod System to keep your dotAIO dry and manage any condensation build-up with ease.The dotPlug sits at the bottom of the dotAIOs tank / pod section between the airflow of the pod and the mod. The precision fit of the dotPlug ensures any excess vapor doesnt collect on the device without impacting the draw of the vape.Compatible with the stock dotAIO coils, dotRBA and the dotShell. Replacement Front + Back Door Panel Plates for dotMod dotAIO(2 PCS) $11.99 The Replacement Front and Back Door Panel Plates is made from PCTG and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included) Vapefly Siegfried M4 Grid Mesh Coils for Siegfried RTA(10 PCS) $2.99 The Original Vapefly Siegfried M4 KA1 0.18ohm Grid Mesh wire is suitable for the Vapefly Siegfried RTA vape atomizer and is designed for vaping via direct pull into lungs. Vapefly Siegfried M2 Mesh Coils for Siegfried RTA(10 PCS) $2.99 The Original Vapefly Siegfried M2 KA1 0.2ohm Mesh wire is suitable for the Vapefly Siegfried RTA vape atomizer and is designed for vaping via direct pull into lungs. Vapefly Siegfried M1 Mesh Coils for Siegfried RTA(10 PCS) $2.99 The Original Vapefly Siegfried M1 Ni80 0.2ohm Mesh wire is suitable for the Vapefly Siegfried RTA vape atomizer and is designed for vaping via direct pull into lungs. Vapefly Firebolt M Cotton(12 PCS) $3.99 The Original Vapefly Firebolt M Cotton is very easy to pinch and tear, fast wicking. Simply thread the tip, snip off the end, and tuck. Vapefly Siegfried RTA Replacement 810 Drip Tip $2.99 The Original Vapefly Replacement 810 Drip Tip is suitable for Siegfried RTA and compatible with other vape atomizer with 810 connector. Vapefly Siegfried Meshed RTA Replacement Chamber Tank Tube $2.59 The Original Vapefly Replacement Chamber Tank Tube is made from Glass and is suitable for Siegfried Meshed RTA Vape Atomizer. |
30.10.2020, 04:32 | 779 |
KayFun V5 RTA Clone original price $20.99, now only $12.99
The KF V5 RTA Clone is a rebuildable tank atomizer features 5.0ml e-liquid capacity and 22mm diameter. The top filling design with 7 juice holes will makes it easy to refill. The KF V5 RTA Clone comes with dual posts for single coil build, will bring you good vaping taste. Joyetech ObliQ 60W Pod System Kit $45.99 Original Joyetech ObliQ Pod System Vape Starter kit is an innovative pod device which can be utilized for both MTL (Mouth to Lung) and DL (Direct Lung) vaping. Joyetech ObliQ has a leaning shape and breeze patterned glass panel, refined metallic construction with a compact form factor, it can be completely controlled by one hand. ObliQ is powered by a 1800mAh built-in battery which can fully charge in 60 minutes, thanks to the 5V /2A charging current, so you can spend less time waiting and more time vaping. Along the side of the device, you'll find the fire button, a display screen, the up and down buttons, and the Type-C charging port. Easily navigate the settings and adjust the wattage to your preference, maximum wattage up to 60W. ObliQ integrates intelligent Avatar. AI Memory Chip, the device will give the optimum output automatically when the cartridge attached on. |
31.10.2020, 05:21 | 780 |
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02 Адрес: Shenzhen
Re: 3FVape - New products & Deals Update
Asmodus Minikin 3 200W Box Mod original price $69.99, now only $50.99
The Asmodus Minikin 3 V3 Box MOD is a new strong TC Box MOD from Asmodus Minikin family with ergonomic body design for comfortable grip and full-color touch screen for easy operation. Powered by dual 18650 batteries not included with the new GX-200-UTC Chipset, the Minikin 3 MOD supports 200W max powerful with variable wattage modes and more accurate temperature control mode than Minikin. Moreover, it features many customization options and new innovations to fine tune the user's preference. Plus the convenient TYPE-C charging port and a wireless charging base (sold separately), the Minikin 3 200W Box MOD supports both easy TYPE-C charging and advanced wireless charging. Get it and bring your vaping to a new level. Innokin GO S Disposable Tank orignal price $3.69, now only $3.16 The Go S is an MTL - Mouth to Lung disposable atomizer with a built-in 1.6ohm coil and 2.0ml tank capacity. Made of high quality PCTG plastic with high temperatures durability.The Adjustable Airflow System is inserted through the triple inlet provided by the atomizer and with the help of the rotating ring located at the bottom of the atomizer we can precisely adjust it to the level we want. [Ships from Battery Warehouse] Original Golisi S35 IMR 3750mAh 40A 21700 Rechargeable Lithium Battery for Mod(2 PCS) $22.99 The Golisi S35 IMR 21700 battery is a 3750mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 40A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 21700 batteries. Golisi L2 2A Smart USB Charger with LCD Screen for 18650 / 26650/ 21700 $10.99 The Original Golisi L2 2A Smart USB Charger with LCD Screen is a latest charger with 2-slot and 2A fast charging. It has a USB power port with DC 5V / 2A power input. What's more, it is compatible with almost all types of cylinder shape rechargeable batteries such as 18650, 21700 and 26650 batteries, even charging different batteries at the same time. Together with a large HD LCD display and 0.5A / 1.0A / 2.0A output options, the L2 Smart Charger will give you a faster and safer charging experience. Joyetech ObliQ Pod Replacement Empty EZ Pod Cartridge(2 PCS) $8.99 Original Joyetech ObliQ EZ Pod Cartridge is specially designed for Joyetech ObliQ Pod System Vape Kit, made of food-grade eco-friendly PCTG plastic, which can be refilled multiple times and features an anti-leak mechanism. The ObliQ EZ Pod Cartridge has a 3.5ml e-juice capacity and uses a top filling system. The Pod cartridge can be filled quickly by just lifting the top silicone plug, which also greatly reduces the chance of leakage. ObliQ EZ Pod Cartridge is compatible with the Joyetech EZ series coils (coil not included) and provides rich flavor. Enjoy Direct Lung& Mouth-to-Lung vaping. ObliQ EZ Pod Cartridge has an airflow valve on the side, adjustable airflow feature allows users to alter their inhale method, whilst a simple coil installation process makes for a hassle-free changeover of coils when necessary. |
