Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02 Адрес: Shenzhen
Ambition Mods x Galactika Mod AKIRA 75W Box Mod 59
The Original Ambition Mods x Galactika Mod AKIRA 75W Vape Box Mod is powered by single 18650 battery (not included) and can fire up to 75W output. Ambition Mods AKIRA 75W Box Mod supports VW / TC (Ni, Ti, SS) modes to meet different needs. Ambition Mods AKIRA 75W Mod features 0.91 inch OLED screen to show vaping data clearly. The 510 spring-loaded connector is best for 22mm to 25mm diameter vape atomizers. ![]() El Thunder V4 Vape Mechanical Mod Clone $13.99 The El Thunder V4 Vape Mechanical Mod Clone is constructed from stainless steel and powered by 1 x 18650 / 20700 / 21700 battery (not included). The Mechanical Mod is with spring-loaded fire button. ![]() |
OneVape AirMOD SE Pod System Kit $27.99
Original OneVape AirMOD SE is one of the most fashionable pod system vape starter kit, for vapers of all experience levels. The super sleek design measures just 13mm thickness it will happily slip into the smallest of pockets. This lightweight pod system weighs only 32g, perfect for on-the-go vaping takes you. Equipped with a built-in 700mAh battery, can support daily use for heavy users. Get rid of frequent charging and focus on your everyday vaping as you want. Quickly fully charge your AirMOD SE in just 60 minutes via the USB Type-C charging port at the bottom of the device. The AirMOD SE has variable wattage from 1W to 25W. It only has one button but it's multifunctional and it has an elegant 0.69" OLED Screen. Set-up and maintenance are quick thanks to the newly designed user interface. ![]() OVNS Saber III Pod System Kit $21.99 Original OVNS Saber III Pod System Vape Starter Kit is powered by 700mAh built-in battery with maximum 25W output. Equipped with OLED Screen to display the vaping data clearly. OVNS Saber III Pod Cartridge holds 2.5ml capacity, adopts airflow adjustment which comes with two coils. OVNS Saber III Pod System vape starter Kit charged by Type-C port for fast charging, only 40 mins for fully charged. Supports both button and pneumatic start modes, and either mode will give you plenty of cloud experience. ![]() OneVape AirMOD SE Replacement Pod Cartridge with 0.8ohm MTL DC Coil(3 PCS) $8.98 Original OneVape AirMOD SE Pod Cartridge is specially designed for OneVape AirMOD SE Pod System Vape Kit, with a capacity of 3.0ml ensures a delectable vaping experience. The translucent pod made of PCTG helps to observe the e-liquid more intuitively. The mouthpiece is smooth to find a shape that nice and naturally fits the lips. Within the pod cartridge is the 0.8ohm Dual Coil, an MTL coil that delivers optimal flavor and a satisfying throat hit. Two symmetrically distributed air inlets on the top that allow more air to enter. The two-way vertical airway brings the direct-to-coil airflow, enhancing the flavor rendering and providing rich vapor production. Designed for mouth-to-lung (MTL) users, the AirMOD SE DC 0.8ohm Pod cartridge is best used between 15W and 25W. The pod is firmly held in place by two strong magnets on the base of the pod. ![]() OVNS Saber III Replacement Pod Cartridge with 1.0ohm MTL Coil(4 PCS) $8.59 Original OVNS Saber III Pod Cartridge holds 2.5ml capacity, is specially designed for OVNS Saber III 700mAh Pod System Vape Starter Kit, adopts airflow adjustment which comes with 1.0ohm MTL coil. ![]() OVNS Saber III Replacement Pod Cartridge with 0.6ohm DTL Coil(4 PCS) $8.59 Original OVNS Saber III Pod Cartridge holds 2.5ml capacity, is specially designed for OVNS Saber III 700mAh Pod System Vape Starter Kit, adopts airflow adjustment which comes with 0.6ohm DTL coil. ![]() Xtar ANT MC1 Plus Charger for 17500 / 17670 / 18350 / 18490 / 18500 / 18650 / 18700 / 22650 / 25500 / 26650 $8.99 The Original XTAR ANT MC1 Plus battery charger has been upgraded with a tiny display to easily read the charging current, the battery power and the charging status. ANT automatically chooses the most suitable charging current (0.5A or 1A) for your batteries to ensure the longest lifespan of them. Mini but mighty, ANT can fully charge a VTC5 in 3 hours with 1A just like an ant can lift 20 times its own body weight. Inserting your battery, ANT will take care of the rest. ![]() XTAR PB2S Portable Power Bank Dual-role Fast Charger for 3.6V /3.7V Li-ion/IMR/INR/ICR/18650/18700/20700/21700 $24.99 The XTAR PB2S Portable Power Bank Charger is not an intelligent Li-ion battery charger, but also a portable power bank, charges your mobile devices anywhere and anytime in outdoors. Support the most popular QC3.0 + PD3.0 dual-protocol fast charging, compatible with most phones' fast-charging adapters on the market, easy for match and use. Apply to 3.6V / 3.7V Li-ion / IMR / INR / ICR: Unprotected 18650 / 18700 / 20700 / 21700 and protected 18650 batteries. Shows real-time charging / discharging current and voltage, and battery capacity percentage, and supports a one-handed button to check each battery' s charging voltage and current. Type-C and USB-A ports can both be used for output and charge two external devices at the same time, more convenient for outdoor usage. You can DIY the capacity of the power bank up to 10000mAh+. If there are enough batteries, PB2S is your outdoor charging station. The negative pole of PB2S applies high-quality metal material. Compared with the previous generation, it has a stronger conductivity and smaller impedance. PB2S comes with a magnetic cover, which can prevent dust and other things from falling in the slots, and prevent the batteries from dropping out of the slots. There are multiple protections that ensure your safety. ![]() [Ships from Battery Warehouse] Original Golisi S26 IMR 18650 2600mAh 3.7V 35A Flat Top Rechargeable Battery(2 PCS) $13.99 Golisi S26 IMR 18650 Battery, featuring a diameter of 18mm and a length of 65mm, has a 2600mAh large battery capacity with 35A max continuous discharging current. Long storage life, light weight and high energy density.This product comes with 2 pieces (2 PCS) of batteries. ![]() HD Screen Protector Privacy Technology High Hardness Protective Film for iPhone 12 / iPhone 12 Pro $5.99 HC F01 HD Screen Privacy Technology High Hardness Protective Film is suitable for iPhone 12 / iPhone 12 Pro. The iPhone 12 / iPhone 12 Pro privacy screen protector designed for iPhone 12 / iPhone 12 Pro 2020, great for elevator, bus, metro or other public occasions, block views from the left and right side, protect your privacy from people nearby. This privacy screen iPhone 12 / iPhone 12 Pro made of tempered glass, effectively protect your phone's screen from cracking, but not totally fit some cases friendly, which edges cover the phone's screen. Bubble-Free adhesive makes the privacy screen easy to install, removing dust firstly, then aligning it properly position. You can remove and reinstall the iPhone 12 / iPhone 12 Pro screen protector during installation process. This privacy screen featured by high touch sensitivity and anti-fingerprint, won't affect your Face ID recognition. Protective Film only (iPhone not included) ![]() HD Screen Protector Prevents Fingerprint Boundary Radian High Hardness Protective Film for iPhone 12 Pro / 12 $5.99 HC F03 HD Screen Prevents Fingerprint Boundary Radian High Hardness Protective Film is suitable for iPhone 12 Pro / iPhone 12. This iPhone 12 Pro glass screen protector made of super hard shatterproof sapphire glass, adopts undergoes an ion exchange tempering process, Its hardness has far exceeded the other screen protector on the market. Your screen is certified to survive even if it falls from a height of 6Ft (1.8 meters) to a hard ground. Not afraid of any challenge, give your phone screen a double security ![]() |
ULTON VG Extreme V2 RTA Version $29.50
The ULTON VG Extreme V2 RTA Rebuildable Tank Vape Atomizer Clone is in 23mm diameter and holds 6.5ml capacity. The ULTON VG Extreme V2 RTA Clone supports dual / single coil building and DL / RDL / MTL Vape. The airflow control is adjustable via Air Pins, Winding is supplied air from three sides (frontal, bottom, diagonal top). ![]() Ohm Vape Bape Pod Mod Kit $26.99 The Original Ohm Vape Bape Pod Vape Mod Kit is powered by 1 x 18350 / 18650 battery (not included). The pod tank is with bottom refilling and bottom airflow control. The coil is replaceable. ![]() SXK ETU Voopoo PnP VM / PnP R Series Coil + Vaporesso GTX Series Coil Adapter for dotMod dotAIO original price $6.90, now only $5.50 SXK ETU Voopoo PnP VM / PnP R Series Coil + Vaporesso GTX Series Coil Adapter is suitable for dotMod dotAIO Pod System Vape Kit. Comes with two adapters, one is for Voopoo PnP VM Series coil and Vaporesso GTX Series Coil. The other is for Voopoo PnP R Series Coil. With this two coil adapter, you can use Voopoo PnP VM Series coil, Vaporesso GTX Series Coil and Voopoo PnP R Series Coil in your dotMod dotAIO Pod Cartridge. ![]() Replacement Inner Door for dotMod dotAIO Pod(1 PC) $19.99 The Replacement Inner Door is made from Acrylic and is suitable for dotMod dotAIO Pod System Vape Kit. 1 PC / Pack. ![]() |
ULTRONER Alieno 70W Vape Box Mod original price $59.90, now only $53.90
The Original ULTRONER Alieno 70W TC VW Vape Box Mod is made from ABS and Stainless Steel. The Alieno box mod Powered by SEVO-70 chipset to supports max. 70W output. The Ergonomic design makes it more convenient to use and supports replacement battery tube (not included). The redesigned top cap adapts to 24mm atomizer. ![]() SMOKTech SMOK Scar-Mini 80W Box Mod $34.99 The Original SMOKTech SMOK Scar-Mini vape box Mod is a mini portable version of its predecessor Scar-18 Mod and has been optimized and innovated on this basis while taking into account excellent functions and high-quality design. SMOK Scar-Mini Mod is getting lighter and lighter, adopting a unified leather and metal design, ergonomic size, comfortable to hold, and the same support IP67 Waterproof & Dustproof & Shockproof. The difference from the external structure of Scar-18 is that SMOK Scar-Mini transfers the battery slot to the top, and the type-C port is placed at the bottom of the mod. This slot can hold a single external battery 18650 battery (not included). Changing the battery is more convenient and quicker. The maximum output power of Scar Mini is up to 80W, which is easy to adjust freely through the side buttons, and the power range of 1W~80W allows you to get along with each puff as you like. Scar-Mini is also equipped with a 0.69-inch display. Although it is small, every detail is complete. Provide multiple types of protection measures to avoid potential risks. An adaptive power output function has been added to ensure a constant power output during vaping. ![]() |
asMODus Minikin Reborn 168W TC VW Vape Box Mod $40.99
The Original asMODus Minikin Reborn 168W TC Box Modis with chassis design with touch screen functionality while upgrading the performance chipset with 168W of power and four different power modes. ![]() Original Uwell Caliburn KOKO Prime 15W Pod System Kit original pice $33.49 Now Only $23.85 Authetnic Uwell Caliburn KOKO Prime is an upgraded version of the original Uwell Caliburn KOKO, ![]() El Thunder V4 Mechanical Mod Clone $13.99 The El Thunder V4 Style Vape Mechanical Mod is constructed from brass and powered by 1 x 18650 / 20700 / 21700 battery (not included). The Mechanical Mod is with spring-loaded fire button. ![]() Original Vandy Vape Gaur-21 200W Dual 21700 Vape Box Mod original price $58.99, now only $44.99 The Vandy Vape Gaur-21 Box Mod is integrated with a smart Vandy chipset with various output modes ![]() SXK CinqueTerre 70W TC VW Variable Wattage Vape Box Mod Clone priginal price $63.90 now only $57.90 ![]() Original Augvape Foxy One 120 Vape Box Mod $39.99 OXY ONE MOD It is powered by a single 21700 / 20700 / 18650 battery (not included) and capable of firing up to 120W, ![]() Original Ultroner Luna 80W Squonk Vape Box Mod Original price $99.99,now only $25.99 UltronerLuna Squonker box mod, a collaboration by Ultroner and Asmodus, is a single-battery unregulated Squonker mod with protection ![]() Dvarw MTL FL Facelift 24 RTA Clone w/ 11 x Air Inserts $19.99 Dvarw MTL FL Facelift Style 6.0ml RTA has a diameter of 24mm and is pre-installed AFC inserts 1 x 1.2mm. ![]() Original SMOKTech SMOK Nfix-mate Pod System Kit 26.99 Original SMOKTech SMOK Nfix-mate 25 Pod System Vape Starter Kit is with optimized size, battery, firing mechanism, and new pod cartridge. ![]() Original Vapefly Manners Pod System Vape Starter Kit original price $19.99 now only $14.99 ![]() Original OFRF Nexmini Pod System Kit Original Price $33.99, Now only $21.99 ![]() Original FreeMax Maxpod Circle Pod System Kit Original Price $29.99, Now only $23.99 ![]() Original Augvape Flash Kit with Flash 21700 Tube Mod + Intake Sub Ohm Tank Original price $45.00, now only $23.99 Augvape Flash Kit is composed of a Flash 21700 tube vape mod and Intake sub-ohm tank vape atomizer. It is designed for beginners and medium vapers. ![]() Original KIZOKU Unlimit DL RTA Replacement KCU1 Single Mesh Coil Head - 0.15ohm (70~80W) (4 PCS) $10.99 This Original KIZOKU Unlimit Replacement Coil - KCU1 is born for your Unlimit DL RTA Vape Atomizer. The big wattage of 70~80W brings you amazing flavor. Super easy to replace it. ![]() Original FreeMax Maxpod Circle Replacement Pod Cartridge - 2.0ml, 1.5ohm (2 PCS) $6.39 It comes with 2.0ml e-juice capacity. It supports nic-salt e-juice and freebase. What's more, it is compatible with 99% flavor categories. A NS Mesh 1.5ohm Coil is pre-installed. 2 PCS / each pack. ![]() Original Yachtvape Pandora 30 Plus MTL RTA Replacement Bell Cap + Chimney + Drip Tip Set $8.99 The Original Yachtvape Pandora 30 Plus MTL RTA Replacement Tank Tube Bell Cap is made from PC and holds 3.0ml capacity. Comes with stainless steel chimney, top cap and drip tip. ![]() Original Yachtvape Pandora 30 Plus MTL RTA Replacement Tank Tube Bell Cap $4.99 The Original Yachtvape Pandora 30 Plus MTL RTA Replacement Tank Tube Bell Cap is made from PC and holds 3.0ml capacity ![]() Original OFRF Nexmini Pod System Replacement Empty Pod Cartridge $2.99 The Original OFRF Nexmini Pod System Replacement Empty Pod Cartridge holds 2.5ml e-juice capacity. It support side refilling port and with silicone plug ![]() Original OFRF Nexmini Pod Replacement M22 nexMESH Mesh Coil Head $8.99 The Original OFRF Nexmini Pod System Replacement M22 nexMESH Coil Head is with 0.6ohm resistance and supplies phenomenal MTL experience. ![]() SXK CinqueTerre 70W Mod Clone Replacement Case Shell Originla price $10.90, Now Only $8.90 The Replacement Case Shell is made from ABS and is suitable for SXK CinqueTerre Style 70W Vape Box Mod. ![]() SXK CinqueTerre Style 70W Mod Replacement 18650 Battery Tube Original price $13.90, Now only $11.90 ![]() Original SXK Supbox Replacement Tank for Mesh Coil $8.90 The Original SXK Supbox Replacement Tank is only compatible with 0.6ohm / 1.1ohm Mesh Coil and suitable for SXK Supbox mod kit. The tank holds 2.0ml capacity. ![]() Original Ohm Vape Bape Replacement Pod Cartridge $5.99 is suitable for Ohm Vape Bape Pod Vape Mod Kit. ![]() Original OBS Skye Replacement YE RDL Empty Pod Cartridge $4.99 4.0ml, Compatible with 0.4ohm OM YE Mesh Coil (2 PCS) ![]() Original OBS Skye Replacement SK MTL Empty Pod Cartridge $4.99 4.0ml, Compatible with OM SK 1.0ohm Regular Coil (2 PCS) ![]() Original OBS OM YE Mesh Coil for OBS Skye Kit / YE RDL Pod Cartridge $9.99 Compatible with OBS Skye YE RDL Empty Pod Cartridge and Suitable for OBS Skye Pod System Vape Kit. With 0.4ohm supports 30W to 40W 5 PCS / Pack ![]() Original OBS OM SK Regular Coil for OBS Skye Kit / SK MTL Pod Cartridge $9.99 Compatible with OBS Skye SK MTL Empty Pod Cartridge and Suitable for OBS Skye Pod System Vape Kit. With 1.0ohm supports 10W to 20W 5 PCS / Pack ![]() |
Original Uwell Crown 5 single Mesh Coil 0.23ohm (4 PCS) $14.99
Uwell Crown 5 FeCrAl UN2 Single Mesh Coil is applicable to Crown 5 Tank. The 0.23ohm single mesh coil is best for 65~70W ![]() Original Uwell Crown 5 dual Mesh Coil 0.3ohm (4 PCS) $14.99 Uwell Crown 5 FeCrAl UN2-2 Dual Mesh Coil is applicable to Crown 5 Tank. The 0. 3ohm dual mesh coil is best for 50~55W, suitable for a restricted direct-to-lung vape, providing warmer vapor and saturated flavor. With Uwell exclusive Pro-FOCS Flavor Testing Technology, it provides you with the ultimate vaping experience. ![]() Original Uwell Crown 5 triple Mesh Coil 0.2ohm (4 PCS) $14.99 Uwell Crown 5 FeCrAl UN2-3 Triple Mesh Coil is applicable to Crown 5 Tank. The 0. 2ohm triple mesh coil is best for 65~70W, bringing you slightly tight direct-to-lung vape, huge vapor and decent flavor. With Uwell exclusive Pro-FOCS Flavor Testing Technology, it provides you with the ultimate vaping experience. ![]() Original Uwell Crown 5 Tank Atomizer 5ml Standard Edition $29.99 Uwell Crown 5 Sub ohm Tank Vape Atomizer is 29mm in diameter, made of stainless steel and Pyrex Glass Tank with a 5.0ml e-liquid capacity. The Crown 5 Tank hosts a simplified quarter-turn threaded top fill system for faster refills. With the additional silicone seal, the e-liquid can stay in the tank and will not be lost during the filling process. Inside the Crown 5 Sub Ohm Tank is Uwell's patented self-cleaning technology that turns condensation into vapor before it can even build up within your atomizer, thus further protecting you from leaking problems. In addition, within the atomizers is the patented Pro Flavor Core Optimization System or Pro-FOCS for short. Pro-FOCS Flavor Testing Technology provides vapers with the ultimate vaping experience by properly controlling the heating temperature, strictly managing the material quality, and completely restoring the e-juice flavor. ![]() Original Uwell Crown 5 Tank Atomizer 5ml CRC Edition $29.99 Uwell Crown 5 sub ohm tank is used together with UN2 mesh coils. There are three types: UN2 0.23ohm Single Meshed Coil; UN2-2 0.3ohm Dual Meshed Coil; UN2-3 0.2ohm Triple Meshed Coil (not included). All versions use mesh instead of a regular coil. The package includes the UN2 0.23ohm Coil and UN2-2 0.3ohm Coil. With quick plug-in system, the installation of the coil can be completed immediately. Along the base of the Crown 5 Sub Ohm Tank is an adjustable airflow ring that can be fully closed for a more restricted vape. ![]() Original Uwell Aeglos Pod System Kit 1500mAh 3.5ml $39.99 The Uwell Aeglos Pod Cartridge is made of PCTG and holds 3.5ml capacity. To fill the e-liquid, simply remove the mouthpiece on the top of the pod cartridge, and then conveniently fill the pod with liquid from above without removing the pod from the Aeglos Mod. The battery and the pod are magnetically connected to each other. ![]() Original Auguse Draw RTA Pod Cartridge Replacement Tank Tube for Voopoo Drag S / X $4.99 The original Auguse Draw RTA Pod Cartridge Replacement Tank Tube is made from PC + Stainless steel and holds 4.0ml. It is compatible with Auguse Draw RTA Pod Cartridge for Voopoo Drag S / X Pod System. ![]() |
Original BP Mods Hilt Mosfet Mod Replacement 18350 Battery Shell $19.99
The Original BP Mods Hilt Mosfet Mod Replacement 18350 Battery Shell is made from aluminum alloy. It will change your BP Mods Hilt Mosfet Mod into 18350 mod. (battery not included) ![]() Original BP Mods Hilt Mosfet Mod $59.99 Original BP Mods Hilt Mosfet Mod is a specialized portable mod for MTL / RDL vapors. It supports 3 output levels: 3.5V, 3.8V and 4.2V max power.Semi-Mechanical, 1 x 18650 ![]() ShenRay Squape Arise RTA Clone $25.99 Silver, 316SS + PSU, 4.0ml, DL / MTL, 24mm Diameter. The Air Discs diameter: 1 x 1mm / 2 x 0.8mm / 3 x 0.8mm / 4 x 0.8mm. ![]() |
Original Damn Vape Mongrel RDA Original Price $29.99, Now Only $21.99.
25.4mm / 26mm, with BF Pin + Spare Top Cap ![]() Original UPENDS Uppen Vape Pen Pod System Vape Starter Kit Original Price $29.99, Now Only $27.99. 600mAh, 2.0ml, 1.2ohm, MTL, Antibacterial ![]() Original SMOKTech Nord 4 80W Pod System Vape Kit $31.99 2000mAh, VW 5~80W, 4.5ml, RPM 2 0.16ohm / RPM 0.4ohm ![]() Original SMOKTech Nord 4 80W Pod System Vape Kit Leather Series $31.99 Leather, 2000mAh, VW 5~80W, 4.5ml, RPM 2 0.16ohm / RPM 0.4ohm ![]() Original UPENDS Uppen Vape Pen Pod Cartridge Original Price $9.99, Now Only $6.99. 2.0ml, 1.2ohm, PCTG, (2 PCS) ![]() Original Uwell Aeglos Replacement Empty Pod Cartridge $3.99 3.5ml, PCTG (1 PC) ![]() Original Uwell Aeglos Replacement UN2 Meshed-H Coil Head $8.93 0.23ohm (40~45W), DL, (4 PCS) ![]() Original Uwell Aeglos Replacement Coil Head $7.88 0.8ohm (20~23W), MTL, (4 PCS) ![]() |
Original Eleaf iStick P100 100W Pod System Vape Mod Kit $46.99
Eleaf iStick P100 Pod System Vape Kit is equipped with a 4.5ml large-capacity Pod cartridge, made of environmentally friendly food-grade PCTG plastic. The built-in mouthpiece at the top of the cartridge provides simplicity and comfort when you go for a vape. ![]() Original Mechlyfe x Fallout Vape x Mrjustright1 Paramour SBS Mod Original Price $79, Now Only $75. The Original Mechlyfe x Fallout Vape x Mrjustright1 Paramour SBS Mod (side-by-side mod), made of 304 Stainless steel & aluminum, is powered by 1 x 18650 / 20700 / 21700 battery (not included) with max 80W output. Mechlyfe Paramour SBS Mod is equipped with OLED screen and provides VW / TC (Ni, Ti and SS) / Bypass modes to meet different needs. Paramour SBS Mod can match with up to 25mm atomizers. The mod is with USB Type-C port for fast charge. ![]() YFTK Squ Arise clone RTA Rebuildable Tank Vape Atomizer $27.99 The Air Discs diameter: 1 x 1mm / 2 x 0.8mm / 3 x 0.8mm / 4 x 0.8mm. This Squ A[rise] Arise clone RTA supports to convince both as Direct to lung (DL) and Mouth to lung (MTL). The easily convert from DL to MTL and thus offers you complete flexibility. ![]() YFTK Nextiny clone RDA Rebuildable Dripping Vape Atomizer $24.99 The YFTK Nextiny clone RDA is a rebuildable dripping vape atomizer with 22mm diameter. It is made from 316 Stainless Steel. Hope this RDA will bring you good vaping experience. ![]() Original SMOK Nord 4 Replacement Nord RPM Empty Pod Cartridge for RPM Series Coils - 4.5ml (3 PCS) $5.99 Original SMOK Nord 4 replaceable empty Pod Cartridge is suitable for SMOK Nord 4 Pod System vape Kit. The pod Cartridge is refillable and you can just replace the coils without discarding the entire pod Cartridge. ![]() Original SMOK Nord 4 Replacement Nord RPM 2 Empty Pod Cartridge for RPM 2 Series Coils - 4.5ml (3 PCS) $5.99 Original SMOK Nord 4 replaceable empty Pod Cartridge is suitable for SMOK Nord 4 Pod System vape Kit. The pod Cartridge is refillable and you can just replace the coils without discarding the entire pod Cartridge. ![]() Original Eleaf iStick P100 Replacement Pod Cartridge - 4.5ml, PCTG, (1 PC) $3.99 Original Eleaf iStick P100 Pod Cartridge is a replaceable cartridge suitable for Eleaf iStick P100 Pod System Vape Kit. With 4.5ml capacity, this highly transparent pod cartridge is made of eco-friendly, food-grade PCTG plastic. ![]() YFTK SQuip Tip Arise MTL clone 510 Drip Tip for MTL Vape Atomizer $2.99 The YFTK SQuip Tip A[rise] MTL 510 drip tip is perfect for your MTL vape atomizer. This SQuip Tip is made from stainless steel and POM. ![]() YFTK Squ Arise clone RTA Replacement 2.0ml Tank Tube + 2.0ml Airflow Insert $6.99 The 2.0ml Tank Tube and 2.0ml Airflow Insert is suitable for YFTK SQuape A Rise Squ A[rise] clone RTA Vape Atomizer. ![]() |
Original Smoant Santi 40W Pod System Kit Original Price $30.77, Now Only $24.99.
Original Smoant Santi Pod System Vape Kit comes with 1100mAh built-in battery and can fire up to 40W max. It is compatible with 4 dedicated coils: S-1 0.4ohm coil (not included) for DL, S-2 0.6ohm (pre-installed) for RDL, S-3 1.2ohm coil (not included)for MTL, S-RBA (not included)for DIY. In addition, it utilizes new wire material ERNiCrMo with mesh structure, which will bring pure flavor and extend the lifespan of wire. Designed with air-flow control system, you can enjoy DL, RDL or MTL freely. The mod comes with a 0.96 inch TFT screen with five colors theme display. Santi pod has 3.5ml e-juice capacity and features strong magnet to provide simplest vaping experience. Multiple protections are designed to protect your safety. ![]() Original Clear Frosted Ultroner x Fallout Vape Gaea 200W Vape Box Mod Original Price $59.8, Now Only $55.9. The Original Ultroner x Fallout Vape Gaea 200W Vape Box Mod features Sevo-200C chipset with ergonomic design and fashionable appearance. Ultroner Gaea Box Mod is powered by dual 21700 / 20700 / 18650 batteries (18650 battery adapter included. batteries not included) with max 200W output. Ultroner x Fallout Vape Gaea mod adopts high definition screen and supports max 33mm diameter tanks. The authentic Ultroner x Fallout Vape Gaea 200W VW Vape Box Mod supports variable wattage range from 5W to 200W. ![]() |
Smoant Santi Empty Pod Cartridge $4.99
Smoant ![]() Smoant Santi Pod S1 DL 0.4ohm Coil (3 PCS) $6.99 Smoant S-1 DL Mesh Coil is suitable for Smoant Santi Pod System / Pod Cartridge. The Mesh coil is 0.4ohm for DL Vaping. Comes with 3 PCS / Pack. ![]() Smoant Santi Pod S2 RDL 0.6ohm Coil (3 PCS) $6.99 Smoant S-2 RDL Mesh Coil is suitable for Smoant Santi Pod System / Pod Cartridge. The Mesh coil is 0.6ohm for DL Vaping. Comes with 3 PCS / Pack. ![]() Smoant Santi Pod S3 MTL 1.2ohm Coil (3 PCS) $6.99 Smoant S-3 MTL Mesh Coil is suitable for Smoant Santi Pod System / Pod Cartridge. The Mesh coil is 1.2ohm for MTL Vaping. Comes with 3 PCS / Pack. ![]() Smoant Santi Pod RBA Coil (1 PC) $6.99 Smoant RBA Coil Deck is suitable for Smoant Santi Pod System / Pod Cartridge. The RBA coil supports for MTL / DL / RDL Vaping. ![]() Damn Vape Mongrel Glass Cap $3.99 Damn Vape Mongrel RDA Vape Atomizer Replacement Glass Top Cap features side dual airflow holes for more air inlet to coils. Damn Vape Mongrel Glass Cap provides visible vaping due to transparent glass material. ![]() Damn Vape Mongrel Fused Clapton Coils (5 PCS) $1.99 Damn Vape Mongrel RDA Vape Atomizer Replacement Glass Top Cap features side dual airflow holes for more air inlet to coils. Damn Vape Mongrel Glass Cap provides visible vaping due to transparent glass material. ![]() Golisi S2 2.0A Smart Charger with LCD Screen US Plug - S2 Smart Charger $23.99 Golisi S2 Charger adopts an upgraded micro-processor which enables the large LCD screen to show the charging information clearly: output current, charging state, battery charging time and battery type. It can also display battery voltage and capacity information by clicking the side button. ![]() O Rings for Smok TFV8 Atomizer TFV8 - O Ring $1.99 SMOKTech Replacement O-Ring Set is suitable for SMOK TFV8 Vape Atomizer. ![]() Never Normal Whistle V2 Clone 510 Drip Tip + Button + Small Button for dotMod dotAIO Pod $12.99 The Never Normal Whistle V2 Clone 510 Drip Tip + Button + Small Button Set is made from PMMA and is suitable for dotMod dotAIO Pod System. ![]() dotaio screws (5 PCS) $3.59 Replacement Screws is made from stainless steel and is suitable for dotMod dotAIO Pod System. ![]() Cthulhu Hastur Mod 88W TC Mod Original Price $85, Now Only $75.99. Cthulhu Hastur 88W TC VW Vape Box Mod with simple and elegant appearance is made of 304 food-grade steel bat tery tube and aviation aluminum with high quality cnc machining technology, which is powered by single 18650 battery with 88W Max. ![]() |
SXK Alien EVL RAB Bridge Tank Clone for SXK BB / Billet Box Original Price $29.9, Now Only $27.5.
The SXK Alien EVL clone RBA Bridge Tank is a rebuildable atomizer designed for Billet Box / SXK BB 70W / 60W Box Mod Kit. The RBA is made from 316 stainless steel and PC tank with 4.0ml capacity, it is equipped with a single coil deck and an adjustable air inlet using inserts. Comes with 5 Airflow insert sizes: 1.0 / 1.5 / 2.0 / 2.5 / 3.0mm. ![]() SXK Replacement PEI Tank Tube for EVL Alien RBA Bridge Tank Original Price $11.9, Now Only $8.9. The SXK Replacement PEI Tank Tube is suitable for Alien EVL RBA Bridge Tank. Holds 4.0ml capacity. SXK Replacement PC Tank Tube for EVL Alien RBA Bridge Tank Original Price $9.9, Now Only $7.5. The SXK Replacement PC Tank Tube is suitable for EAlien VL RBA Bridge Tank. Holds 4.0ml capacity. Original Vandy Vape A1 Superfine MTL Fused Clapton Wire $4.89 The Original Vandy Vape A1 Superfine MTL Fused Clapton Wire is suitable for RDA / RTA / RDTA Vape Atomizer. The wire is with 32GA x 2(=) + 38GA and 10ft length.and 30GA x 2 + 38GA and 10ft length also available on 3fvape.com ![]() Original IJOY Aria Pro Pod System Kit 25W 900mAh w/ Aria Opod Open Pod Cartridge Original Price $30.99, Now Only $21.99. IJOY Aria Pro Kit is a compact vape kit with a Open pod cartridge. IJOY Aria Pro is made of durable zinc alloy and with compact size for comfortably in any pocket and is perfect for vaping on the go. IJOY Aria Pro equipped with a long-lasting with 900mAh battery that is conveniently fast recharged through a type-c port. On the side of the device, you will find the fire button and a 0.69-inch single-color display screen. Some rivet-like bumps thing on the other side is embedded in a panel. Additionally, the Aria Pro supports both draw-activated and button-activated vaping to let you control the way you vape. Built-in Univ.mini chipset, the maximum output power is 25W and has intelligent automatic matching technology, you can select the appropriate power according to the installed coil, so as to minimize the setup and maintenance work. ![]() Original IJOY Aria Opod Pod Cartridge $6.99 IJOY Aria Pro Kit comes with Aria Opod open pod cartridge with 1.0ohm coil. With 3.0ml capacity and use a transparent pod design for easily checking e-liquid levels in real-time. Aria Opod pod cartridge is a refillable pod cartridge, which is filled by opening the side plug and integrates two coils with different resistance values.0.6ohm version also available on 3fvape.com ![]() Original Xyzvape Disposable Drip Tip Taster Mouthpiece for Uwell Caliburn G Pod Cartridge $2.49 The Original Xyzvape Disposable Drip Tip Taster Mouthpiece is made from PC and is suitable for Uwell Caliburn G Pod System / Pod Cartridge. 1 PC / Pack ![]() |
Original SXK Supbox Pro 60W TC VW Vape Box Mod Kit $138.8
The Original SXK Supbox Pro 60W Box Mod Kit is built-in Evolv DNA 60 Chipset and adopts creative design, compatible with Most accessories for Billet Box and all 510 atomizers within 24mm diameter. Provide more personalized accessories such as battery tube and outside case. Comes with 1.1ohm and 0.6ohm cotton coil for choice. ![]() Original Uwell Caliburn G 18W Pod System Vape Starter Kit CRC Edition Original Price $29.99, Now Only $22.98. The original Uwell Caliburn G Pod System Vape starter Kit is the upgrade version of Caliburn, works with 690mAh built-in battery and can fire up to max 18W output. Uwell Caliburn G Pod System Vape kit can vape directly through air pressure sensor or manual button to start vaping. Uwell Caliburn G Pod cartridge comes with 2.0ml capacity with top-fill and leakproof design. Uwell Caliburn G pod cartridge supports two different airflows: restricted DTL vaping (when the air inlet of the pod and the air inlet of the device are close to each other) and MTL vaping (when the air inlet of the pod and the air inlet of the device are far away from each other). This is the CRC Version ![]() Original Uwell Replacement Pod Cartridge for Caliburn G / Koko Prime Pod System Original Price $10.63, Now Only $7.99. The original Uwell Caliburn G Pod Cartridge is suitable for Uwell Caliburn G / KOKO Prime Pod System Vape Kit. It comes with 1.0ohm Coil, holds 2.0ml e-juice capacity and comes with top filling design for easy refilling ![]() Original Uwell Replacement Coil Head for Caliburn G / Koko Prime Pod System Original Price $10.99, Now Only $7.99. The authentic Uwell Caliburn G Coil is designed for Caliburn G / Caliburn KOKO Prime Pod System Vape Starter Kit. Featuring 1.0ohm and 0.8ohm coil resistance (2 kinds optionsl), it will provide you great vaping experience. 4 PCS each pack. ![]() |
Original SXmini SL Class 100W SX485J TC VW Box Mod Original Price $174.99, Now Only $62.99.
The authentic YiHi SXmini SL Class SX485J 100W vape Box Mod is the next luxurious device from YiHi's unrivaled line-up, powered by 18650 / 20700 / 21700 battery (not included) platform with a premium frame chassis and high-end grip design. The high-end impression is complemented with ergonomic construction design, making the SXmini SL Class a phenomenal all-day vape option. Accessed via a threaded battery cover at the bottom of the device, the SL Class SX485J can support single 18650, 20700, or 21700 battery for wide range of vape battery options. The internal YiHi SX485J Chipset provides tremendous output range of 5 to 100W alongside a suite of functionality such as full temperature control support and efficient processor for accurate and customizable experience. The inclusion of SXi-Q Intelligent Taste Curve Technology features an algorithmic calculation that allows users to set, fine tune, and save 5-memory output curves. ![]() Squape Arise Clone RTA Rebuildable Tank Vape Atomizer $21.99 SQuape A Rise Squ A[rise] clone RTA Vape Atomizer is made from stainless steel and PSU. The 24mm RTA holds 4.0ml and supports DL / MTL Vaping.The Air Discs diameter: 1 x 1mm / 2 x 0.8mm / 3 x 0.8mm / 4 x 0.8mm.This Squ A[rise] Arise clone RTA supports to convince both as Direct to lung (DL) and Mouth to lung (MTL). The easily convert from DL to MTL and thus offers you complete flexibility. ![]() Squape Arise RTA Replacement 2.0ml Tank Tube + 2.0ml Airflow Insert $4.99 The 2.0ml Tank Tube and 2.0ml Airflow Insert is suitable for SQuape A Rise Squ A[rise] Style RTA Vape Atomizer. ![]() Original GeekVape Aegis Boost Pro Replacement Pod Cartridge $11.99 The Aegis Boost Pro Pod Cartridge is designed especially for the GeekVape Aegis Boost Pro 100W Pod system Vape Kit, coming with 6.0ml e-juice capacity and 0.2ohm / 0.4ohm Coil. ![]() Original Ohm Vape Bape Pod Kit Connector Adapter $3.99 The Bape Pod Kit Connector is designed for the Ohm Vape Bape AIO Pod Vape Mod Kit. ![]() Original Ohm Vape Bape AIO Pod Replacement Coil Head $8.99 The Authentic Ohm Vape Bape AIO Pod Mod Kit / Atomizer Cartridge Replacement Coil Head is with several resistance(0.4ohm, 0.7ohm, 1.0ohm optional). Comes with 5 PCS / Pack. ![]() |
Original VOOPOO Drag S & Vmate Pod System Limited Edition $43.99
The VOOPOO DRAG S VW Mod Pod Kit is a compact and ergonomic pod mod system kit that consists of a 4.5ml pod cartridge and a 2500mAh built-in battery. The pod cartridge adopts a bottom refilling design and innovative infinite airflow system for the most comfortable experience. The Kit comes with a PnP-VM1 0.3ohm Coil and a PnP-VM5 0.2ohm Coil, it is also compatible with the other PnP coils, which can bring you DL and MTL vaping experience. As for the mod, it features adjustable power in the range of 5W to 60W. Monitored by GENE.TT chip, it can ignite within 0.001s, and also provides intelligent functions such as PUFF recording, SCORE ranking, SMART switching start mode, and so on. Moreover, there are 7 safety protections to ensure your vaping safety. The Original VOOPOO Vmate Pod Kit has an integrated 900mAh battery, 3.0ml integrated coil cartridge, 17W maximum output power, with Type-C 5V / 1A fast charging, and adopts a new generation of atomization technology to produce a strong flavor. Vmate Pod Kit has an excellent flavor experience, coupled with an easy-to-use and lightweight design suitable for all experience levels vapers. ![]() GeekVape P Mesh Coil for Aegis Boost Pro Pod System / Pod Cartridge $11.99 GeekVape P Mesh Coil is compatible with Aegis Boost Pro System Vape Kit / Pod Cartridge. The 0.4ohm Mesh Coil will supply huge and smooth vapor clouds. 5 PCS each pack.The 0.2ohm Mesh Coil will supply huge and smooth vapor clouds. 5 PCS each pack. ![]() Uwell Tripod Pod System with 1000mAh Charging Case $36.99 Original Uwell Tripod Pod System Kit is a perfect combination of an excellent pod system and a powerful charging case. The Tripod Kit includes a lightweight and smart Tripod pod system, a portable charging case, and three refillable pod cartridge. With Uwell Tripod Kit, you can fully charge for long-lasting vaping anytime, anywhere, and enjoy your favorite e-liquid anytime. The charging case is compact and lightweight, with a removable smart pad inside, which is easy to open or close, integrate a Type-C port on the side, and an LED indicator plate at the bottom. When the LED indicator on the charging box is off, touch the center of the indicator board several times with your finger to wake up the indicator board to indicate the current power level and charging status. The capacity of the charging case is 1000mAh. Easy to hold in the palm of your hand or put in any pocket. When you are out and about, keep charging the pod system. ![]() Coilhome TNT-VM1 Single Mesh Coil for Voopoo VINCI / VINCI R / VINCI X $7.99 The original Coilhome TNT-VM1 Single Mesh Coil is with 0.3ohm Resistance and is suitable for Voopoo VINCI / VINCI R / VINCI X Pod System. Comes with 5 PCS / Pack. ![]() SMOKTech Morph 2 Kit 230W Box Mod with TFV18 Tank $53.99 The SMOK Morph 2 Kit is an updated version of its predecessor SMOK Morph 219 Kit. Through a more comfortable operating experience, more powerful performance, with a new sub-ohm tank and a new mesh coil to optimize all aspects, is a highly comprehensive user- friendly device. SMOK Morph 2 Kit is composed of SMOK Morph 2 230W Vape Box Mod and SMOK TFV18 Tank Vape Atomizer. Morph 2 is designed with zinc alloy to improve durability, while the soft leather covered on the surface has a comfortable touch. The front is decorated with a 0.96-inch display, control buttons, and charging port, and the fire button has been placed on the side. SMOK Morph 2 Box Mod is powered by 2 x 18650 batteries (not included). The dual 18650 battery has double battery life and sufficient power, creating conditions for immersive vaping. Through the USB Type-C port, you can run balanced charging at a maximum speed of 2.0A inside the mod, which not only extends the life of the battery but also shortens the charging time. Morph 2 is equipped with an IQ-S chip that not only provides a very fast 0.001 second firing time but also provides convenient functions such as password protection and customizable output modes (Power/TC) to support different vape styles. ![]() |
Original SMOKTech SMOK Morph 2 230W TC VW Vape Box Mod $37.99
The Original SMOKTech SMOK Morph 2 Vape Box Mod is designed with zinc alloy to improve durability, while the soft leather covered on the surface has a comfortable touch. The front is decorated with a 0.96-inch display, control buttons, and charging port, and the fire button has been placed on the side. SMOK Morph 2 Box Mod is powered by 2 x 18650 batteries (not included). The dual 18650 battery has double battery life and sufficient power, creating conditions for immersive vaping. Through the USB Type-C port, you can run balanced charging at a maximum speed of 2.0A inside the mod, which not only extends the life of the battery but also shortens the charging time. Morph 2 is equipped with an IQ-S chip that not only provides a very fast 0.001 second firing time but also provides convenient functions such as password protection and customizable output modes (Power/TC) to support different vape styles. ![]() Original Hellvape Hellbeast RDA Rebuildable Dripping Vape Atomizer w/ BF Pin Original Price $36.9, Now Only $25.99. The Original Hellvape Hellbeast RDA is an innovative 3-level airflow driven rebuildable dripping vape atomizer. The Hellbeast RDA is built for creating huge clouds of vapor. Hellbeast RDA is made of durable stainless steel in 24mm diameter, with a new build deck, and adopts a staggered column hole design, providing enough space for coil replacement. This build deck structure supports both clockwise or counterclockwise coil installation. Hellbeast RDA adopts innovative trinity stepped airflow and 72 x 1.2mm air holes for precise flavor. Trinity stepped honeycomb airflow hole+2 layers of shell airflow hole to provide 3 level airflow. Hellbeast RDA's top cap matches 810 drip tip, brings a great DL vaping. The pre-fitted 510 pin means the Hellbeast RDA can be used with standard vape devices straight out of the box. While the BF (Bottom Feeding) pin enables it to be used with squonk box mods. The Hellvape Hellbeast RDA provides an undeniably tasty vape with a balance of both flavor enhancement and massive cloud production. ![]() Original Uwell Tripod Replacement Pod Cartridge $7.99 Original Uwell Tripod PCC Pod Cartridge holds 2.0ml capacity and is suitable for Tripod PCC Pod System Vape Kit. It is built with a 1.2ohm coil and features side filling system. You can also enjoy great flavor, massive clouds and smooth throat hit with it. 4 PCS each pack. ![]() Original SMOKTech SMOK TFV18 Tank Replacement Meshed Coil Head $10.99 The SMOK TFV18 0.33ohm Meshed Coil is made of nickel-chromium alloy and organic cotton and have a large mesh design to promote the fastest and most uniform heating and optimize flavor. This makes TFV18 a high-performance atomizer and requires a lot of air cooling. This is achieved by a particularly high tank base, which allows the maximum amount of air to reach the coil.3 PCS / Pack. ![]() Original SMOKTech SMOK TFV18 Tank Replacement Dual Meshed Coil $11.99 The SMOK TFV18 0.15ohm Dual Meshed Coil is made of nickel-chromium alloy and organic cotton and have a large mesh design to promote the fastest and most uniform heating and optimize flavor. This makes TFV18 a high-performance atomizer and requires a lot of air cooling. This is achieved by a particularly high tank base, which allows the maximum amount of air to reach the coil.3 PCS / Pack. ![]() Original SMOKTech SMOK TFV18 Tank Replacement RBA Coil Deck $6.99 The Original SMOKTech TFV18 RBA Coil Deck is suitable for SMOK TFV18 Tank Atomizer. It will switch your TFV18 into a RTA for DIY fun. ![]() Original SMOKTech SMOK TFV18 Sub Ohm Tank Clearomizer Vape Atomizer $26.99 Original SMOK TFV18 TFV18 Tank has a diameter of 31.6mm and a raised base to ensure maximum airflow and maximum coil saturation. On the top is a wide-bore resin drip tip, which has anti-scaling and odorless performance, and can accurately capture streams of vapor, providing a comfortable vaping experience. SMOK TFV18 Tank is equipped with a bubble glass with a maximum capacity of 7.5ml (the storage capacity varies according to the different coils installed inside). It can be easily filled from above using the press-to-slide top filling system with a child-proof safety lock and improved sealing. You have to press the button and slide the top cap in the right way to expose the filling port, enhancing the security of use and ending juice leaking. ![]() |
Flash e-Vapor V4.5S+ RTA Clone $14.99
The Flash e-Vapor V4.5S+ clone RTA Rebuildable Tank Vape Atomizer is constructed from Stainless Steel in 23mm Diameter. The RTA comes with a 4.5ml E-juice capacity glass tank tube, 1 x air screw mounted sealed, 2 x 2.1mm airflow insert, 1 x 0.9mm airflow insert, and 1 x 1.0mm airflow inserts. The RTA features dual post build deck and adjustable airflow for MTL vaping.The Flash e-Vapor V4.5S+ comes with 2 x stainless steel wicks to make a Good Liquid Flow. ![]() ShenRay Squ Arise Clone RTA Replacement MTL Air Discs - 1 x 0.8mm, 1 x 1.0mm, 2 x 0.8mm, 3 x 0.8mm, 4 x 0.8mm, 5 x 0.8mm (6 PCS) $5.99 These MTL Air Discs is suitable for ShenRay SQuape A Rise Squ A[rise] clone RTA Vape Atomizer to reduce the airflow directly at the coil. Comes with 6 different size Air Discs. ![]() ShenRay Squ Arise Clone RTA Replacement 2.0ml Tank Tube + 2.0ml Airflow Insert $4.99 These MTL Air Discs is suitable for ShenRay SQuape A Rise Squ A[rise] clone RTA Vape Atomizer to reduce the airflow directly at the coil. Comes with 6 different size Air Discs. ![]() EVL Dot Spot Polycarbonate RBA Bridge Clone for the DotMod DotAIO AIO Pod $24.99 The EVL Dot Spot clone RBA is a bridge for the DotMod DotAIO AIO Pod. The Dot Spot clone RBA is made of stainless steel and polycarbonate to holds 2.0ml capacity. The tank has a refilling port on the side with silicone stopper.The air hole is located between the two posts through which the fresh air hits the winding directly from below. The various MTL reducers, which are available in sizes 1.0mm, 1.5mm, 2.0mm, 2.5mm and 3.0mm, can also be inserted into this hole. ![]() Original YiHi SXmini SL Class 100W SX485J TC VW Box Mod Original Price $174.99, Now Only $59.99. The original YiHi SXmini SL Class SX485J 100W vape Box Mod is the next luxurious device from YiHi's unrivaled line-up, powered by 18650 / 20700 / 21700 battery (not included) platform with a premium frame chassis and high-end grip design. The high-end impression is complemented with ergonomic construction design, making the SXmini SL Class a phenomenal all-day vape option. Accessed via a threaded battery cover at the bottom of the device, the SL Class SX485J can support single 18650, 20700, or 21700 battery for wide range of vape battery options. The internal YiHi SX485J Chipset provides tremendous output range of 5 to 100W alongside a suite of functionality such as full temperature control support and efficient processor for accurate and customizable experience. The inclusion of SXi-Q Intelligent Taste Curve Technology features an algorithmic calculation that allows users to set, fine tune, and save 5-memory output curves. ![]() Eleaf iStick T80 Kit 3000mAh 80W Box Mod with GTL Pod Tank $54.9 Original Eleaf iStick T80 Kit with GTL Pod Tank shows a multifunction starter vape kit consisting of a new color iStick T80 Mod and a GTL Pod Tank with a 510 thread base. ![]() Original SXK ETU for Supbox / Billet / BB / Bantam Revision - Compatible with Voopoo PnP Series / Vaporesso GTX Series Coil Original Price $9.9, Now Only $8.6. The SXK ETU is including PC Tank, Stainless Steel Connector and POM Base. The SXK ETU is Compatible with Voopoo PnP Series Coil head and Vaporesso GTX Coil Head. It is suitable for Billet Box / SXK BB 70W / DNA 60W, SXK Supbox Pro 60W / SXK Supbox 70W and SXK Bantam Revision 30W Mod Kit. Please Note: The ETU only, the coil and the mod on the image is not included. ![]() |
Original Rincoe Jellybox Mini 80W Box Mod with Jellytank Kit Original Price $49.9, Now Only $37.99.
The authentic Rincoe Jellybox Mini 80W Kit is combined with Jellybox Mini Mod and Jellytank.The Rincoe Jellybox Mini Box Mod is made of durable zinc alloy & high end PC, which is sturdy and anti-drop. The whole machine adopts a unique transparent design from the tank to mod, providing stunning aesthetics and strong visual impact. This compact, sleek, user-friendly device is powered by 1 x 18650 / 20700 / 21700 battery (not included). It's very easy to remove and install batteries and the doors all fit very stable. Fast charging through the Type-C port under the side. The Jellybox Mini mod has a proprietary RINCOE board on the internal side, which not only provides a variety of security protections but also provides a variety of modes for you to customize the performance of the device. Variable Wattage mode allows you to select precise power output, maximum support 80W. The temperature control suite can be used for more custom coil types, like Stainless Steel and Titanium. Jellybox also features 6 LED lights and shines through into the full device lighting it up.The Rincoe Jellytank is an adjustable translucent tank with a detachable threaded 510 connection. The Jellytank holds 4.8ml capacity and is made of environmentally friendly food-grade PCTG plastic, which has an excellent vaping experience. The built-in proprietary drip tip provides simplicity and comfort. The bottom of the pod has a filling port, unscrew the bottom base, open the white silicone case to fill the e-juice. There is a narrow slot on the thread base to control the incoming airflow. Jellytank features mesh coil 0.15ohm makes the clear flavor and dense cloud. ![]() Original Rincoe Jellybox 228W Box Mod with Jellytank Kit Original Price $54.9, Now Only $40.99. The original Rincoe Jellybox 228W Kit is combined with Rincoe Jellybox 228W Box Mod and Jellytank.The Rincoe Jellybox 228W vape box mod can provide a variety of sub-ohm experience and high power output. Rincoe Jellybox 228W vape box mod uses a transparent PC shell and a zinc alloy frame to make the entire mod highlight the visual beauty. The inside of the mod and the battery packaging can be seen directly from the outside. The innovative design of Jellybox makes it unique. The body size is compact while providing a comfortable grip. The complete control panel has a round fire button, a display screen, and a pair of adjustment buttons. The mod runs on two 18650 batteries (not included) and has an impressive maximum power output of 228W. To access the battery chamber, simply press and lift open the cap on the bottom of the device. And the Jellybox mod implements 5V / 2A quick-charging via the Type-C USB port, so you can spend less time charging. There are 6 LED lights on both sides of the transparent panel of Jellybox, the color of the lights can be changed by changing the UI settings. To turn off the LED light, just press the fire button and the right button together in VW mode.The Rincoe Jellytank is an adjustable translucent tank with a detachable threaded 510 connection. The Jellytank holds 4.8ml capacity and is made of environmentally friendly food-grade PCTG plastic, which has an excellent vaping experience. The built-in proprietary drip tip provides simplicity and comfort. The bottom of the pod has a filling port, unscrew the bottom base, open the white silicone case to fill the e-juice. There is a narrow slot on the thread base to control the incoming airflow. Jellytank features mesh coil 0.15ohm makes the clear flavor and dense cloud. ![]() Original Rincoe Jellybox Mini 80W Box Mod Original Price $39.9, Now Only $31.99. The Rincoe Jellybox Mini Box Mod is made of durable zinc alloy & high end PC, which is sturdy and anti-drop. The whole machine adopts a unique transparent design from the tank to mod, providing stunning aesthetics and strong visual impact. This compact, sleek, user-friendly device is powered by 1 x 18650 / 20700 / 21700 battery (not included). It's very easy to remove and install batteries and the doors all fit very stable. Fast charging through the Type-C port under the side. The Jellybox Mini mod has a proprietary RINCOE board on the internal side, which not only provides a variety of security protections but also provides a variety of modes for you to customize the performance of the device. Variable Wattage mode allows you to select precise power output, maximum support 80W. The temperature control suite can be used for more custom coil types, like Stainless Steel and Titanium. Jellybox also features 6 LED lights and shines through into the full device lighting it up. ![]() Original Rincoe Jellybox 228W Box Mod Original Price $44.9, Now Only $33.99. The original Rincoe Jellybox 228W vape box mod can provide a variety of sub-ohm experience and high power output. Rincoe Jellybox 228W vape box mod uses a transparent PC shell and a zinc alloy frame to make the entire mod highlight the visual beauty. The inside of the mod and the battery packaging can be seen directly from the outside. The innovative design of Jellybox makes it unique. The body size is compact while providing a comfortable grip. The complete control panel has a round fire button, a display screen, and a pair of adjustment buttons. The mod runs on two 18650 batteries (not included) and has an impressive maximum power output of 228W. To access the battery chamber, simply press and lift open the cap on the bottom of the device. And the Jellybox mod implements 5V / 2A quick-charging via the Type-C USB port, so you can spend less time charging. There are 6 LED lights on both sides of the transparent panel of Jellybox, the color of the lights can be changed by changing the UI settings. To turn off the LED light, just press the fire button and the right button together in VW mode. ![]() |
Original SMOKTech SMOK Rigel Mini Kit 80W Box Mod with TFV9 Mini Tank $34.99
Original SMOKTech SMOK Rigel Mini Box Mod Vape Kit is combined with SMOK Rigel Mini Box Mod and TFV9 Mini Tank. ![]() BY-kA V.9 V9 MTL RTA Full Kit w/ Nano Set + PEI Tank Clone $36.99 The BY-kA V.9 V9 MTL RTA Rebuildable Tank Atomizer full kit is including 5.0ml standard tank, 3.0ml Nano Set Tank tube and 5.0ml PEI long Tank Tube, holds 3.0 / 5.0ml capacity and in 22mm Diameter. The BY-kA V.9 V9 MTL RTA is with top refilling system for easy refilling and bottom airflow adjustable for MTL Vaping. This is the full kit Version including 5.0ml standard RTA, 3.0ml nano set and 5.0ml long PEI Tank Tube ![]() Vape Systems BY-kA V.9 V9 MTL RTA Clone 5ML Standard $24.99 The BY-kA V.9 V9 MTL RTA Rebuildable Tank Atomizer Standard Version holds 5.0ml capacity and in 22mm Diameter. The BY-kA V.9 V9 MTL RTA is with top refilling system for easy refilling and bottom airflow adjustable for MTL Vaping. This is the Standard Version in 5.0ml. ![]() Vape Systems BY-kA V.9 V9 MTL Nano Set Clone $23.99 The BY-kA V.9 V9 MTL RTA Rebuildable Tank Atomizer Nano Version holds 3.0ml capacity and in 22mm Diameter. The BY-kA V.9 V9 MTL RTA is with top refilling system for easy refilling and bottom airflow adjustable for MTL Vaping.This is the Nano Version in 3.0ml. ![]() Original Advken Potento X Pod System Vape Kit $24.99 Original Advken Potento-X Pod System Vape Kit is powered by 950mAh built-in battery, with max output power 4.2V. It is made of Aluminum Alloy and PCTG, holds 2.5ml e-juice capacity, fast type-c charging port. Comes with 1.0ohm and 1.2ohm mesh coil. Advken Potento-X Pod System Kit is lightweight, portable, provides better experience, better flavor. ![]() Replacement Standard Set Chimney + Tank Tube for KA V9 Clone RTA $7.99 The Replacement Standard Set including Chimney and Tank Tube is suitable for KA V9 clone RTA and holds 5.0ml capacity. ![]() Replacement Nano Set Chimney + Tank Tube for KA V9 Clone RTA - Silver, Stainless Steel + PC, 3.0ml $7.99 The Replacement Nano Set including Chimney and Tank Tube is suitable for KA V9 clone RTA and holds 3.0ml capacity. ![]() Replacement PEI Long Tank Tube for KA V9 Clone RTA $5.99 The Replacement PEI Long Tank Tube is suitable for KA V9 clone RTA and holds 5.0ml capacity. ![]() |
Original SMOKTech SMOK Rigel Mini Box Mod $25.99
The SMOK Rigel Mini Box Mod is made of durable zinc alloy, with an amazing texture. The outer layer is made of soft rubber coating, and it feels comfortable when holding Rigel Mini. Rigel Mini Box Mod is powered by 1 x 18650 battery (not included) to provide continuous power. Rigel Mini Box Mod uses Type-C for fast charging, thereby minimizing downtime, and the output current is as high as 1.4A. Using the brand's legendary chipset technology, consistent and reliable multiple functions can be achieved. The power range of 1W~80W allows you to enjoy the most satisfying clouds and flavors throughout the day according to your power preferences. There are a comprehensive 0.96 inch TFT color display and navigation buttons on the device, allowing you to easily customize the settings. ![]() Original SMOKTech SMOK TFV9 Mini Sub Ohm Tank Clearomizer Vape Atomizer $18.99 Original SMOK TFV9 Mini Tank Vape Atomizer is with 23mm diameter 23mm, it becomes lighter and smaller and holds 3.0ml of e-juice. With the child-safe filling design, this is a safer tank without sacrificing convenience. The top cover can be lifted and slid open so that a large filling port can be used for e-liquid filling. The tank is completely made of stainless steel, which is easy to clean without any problems and is also very suitable for compact devices. With internal mesh heating elements, the TFV9 Mini Tank consumes less power and can generate more steam and flavor from your favorite e-juice. The package includes two V9 Meshed 0.15ohm Coil. The TFV9 Mini Tank also cross-compatible with the TFV8 Baby Coil Technology (coils not included). The bottom airflow supports intense taste. Using the redesigned airflow system, the airflow can be adjusted by rotating the airflow ring at the bottom of the tank to meet different vaping needs. Since the inhaled air enters directly from below through the coil head, so it doesn't lose any aroma. There is a gold-plated 510 threading connection on the base of the TFV9 Mini tank, which can increase friction resistance and enhance conductivity. ![]() Original GeekVape Aegis Boost LE Bonus Pod System Vape Kit with 5 Coils Original Price $42.99, Now Only $32.99. Original GeekVape Aegis Boost LE Bonus Kit is the luxurious version of the original Aegis Boost 40W Pod System Vape Starter Kit with 5 GeekVape B series coils. It redefines the way luxury is integrated into the vaping experience, designed for the highest experience. The design in the Aegis Boost LE Bonus Kit is still applicable to the Aegis series. It consists of a stain-resistant and tear-resistant leather sleeve, rust-proof and corrosion-resistant zinc alloy body frame, Food grade silicone rubber for water-proofing. The Aegis Boost LE Bonus weighs only 120g and is the lightest kit. With the built-in 1500mAh battery, it can provide a lot of power even if you are outside. The core of the kit is the AS chipset, with an output power of up to 40 watts, providing instantaneous ignition speed, and various safety circuits on the board. All settings can be checked at any time through the 0.42-inch OLED display. ![]() Original OBS Pluck Pod Mod Vape Starter Kit $29.99 Original OBS Pluck is a small and intelligent Pod Mod starter kit with a compact mod and maintenance-free tank, suitable for MTL & RDL vaping. Constructed with durable zinc-alloy and leather, the OBS Pluck Kit takes on an ergonomic, cylinder design that promotes a firm grip every time you vape. Pluck kit has a simple control panel, and the long style fire button occupies the entire front. On its upper part, there is a small LED indicator. The LED light shows 3 battery power indications when vaping with Pluck Kit, which could let you know Pluck battery life more clearly. The Pluck is powered by an internal 1500mAh battery that you can charge up quickly due to the device's 5V / 1A quick-charging capability via the USB Type-C charging port. ![]() |
