Просмотров в теме 206193   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 31.07.2020, 04:31 Автор темы   701
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Hcigar VT INPOD Pod System Replacement Empty Pod Cartridge(1 PC) $2.99
The Original Hcigar VT INPOD Pod Cartridge is specially designed for the Hcigar VT INPOD Pod System Vape Starter Kit. It holds 4.5ml of e-juice and is refilled through the top filling port hidden under the non-leak silicone plug. The pod has a translucent design, so you can check the remaining juice level at any time. On the top of the Hcigar VT INPOD Pod, there is a detachable 510 drip tip. Hcigar VT INPOD Pod is firmly connected to the VT INPOD mod through strong magnetism, compatible with Hcigar VC-M1 0.3ohm Coil to maximize vapor and flavor. One per pack.
Original OBS Naze Pod System Replacement Empty Restricted DTL Pod Cartridge(2 PCS) $7.99
The Original OBS Naze Pod Cartridge is suitable for OBS Naze Mod Pod System Vape Kit. The pod holds 3.0ml Restricted DTL Pod and is compatible with 0.4ohm OM NA Mesh Coil. Designed for Restricted DTL vape respectively. Refillable e-liquid through the side and equipped with transparent pod design for easily viewing your juice levels. The 3.0ml Restricted DTL Pod mouthpiece and smaller air hole provide a tighter vaping experience. 2 PCS in each pack.
Original Artery XP Coil Head for Nugget+ / Nugget GT Pod System Kit - 0.4ohm(5 PCS) $8.99
The Original Artery XP Coil is specially designed for Nugget+ / Nugget GT Pod System Vape Kit. The XP 0.4ohm Coil (20~35W) is for more powerful and flavorful vaping. installed in a pod bottom press-fit connection. The XP coil provides a DTL draw. It is best to use with regular nicotine e-juices and not recommended for use with nicotine salts.
Original Artery XP Coil Head for Nugget+ / Nugget GT Pod System Kit - 0.15ohm(5 PCS) $8.99
The Original Artery XP Coil is specially designed for Nugget+ / Nugget GT Pod System Vape Kit. The XP 0.15ohm Coil (60~80W) is for more powerful and flavorful vaping. installed in a pod bottom press-fit connection. The XP coil provides a DTL draw. It is best to use with regular nicotine e-juices and not recommended for use with nicotine salts.
Original OBS Naze Mod Pod Kit Replacement ZE OM Mesh Coil Head - DTL 0.2ohm(5 PCS) $12.99
The Original OBS Naze Coil is compatible with OBS Naze Mod Pod Vape Kit. The is 0.2ohm ZE Mesh Coil is for DTL vape in 50 to 80W. Comes with 5 PCS / Pack.
Original OBS Naze Mod Pod Kit Replacement ZE OM Mesh Coil Head - Restricted DTL 0.4ohm(5 PCS) $11.99
The Original OBS Naze Coil is compatible with OBS Naze Mod Pod Vape Kit. The 0.4ohm NA Mesh Coil is for Restricted DTL vape in 30 to 40W. Comes with 5 PCS / Pack.
Original KIZOKU Limit RTA Replacement Glass Tank Tube $2.59
The Original KIZOKU Limit Glass Tube uses the most high-quality Glass Tube Material with clear Transparent color. The KIZOKU Limit Glass Tube is easy to clean and durable to use. It is suitable for KIZOKU Limit MTL RTA.
Original KIZOKU Limit MTL RTA Replacement Leak-proof Membrane $1.99
The leak proof membrane is specially designed for KIZOKU Limit MTL RTA. It is a useful spare part to make the e-juice filling easily and without leakage. Get one for your Limit RTA and enjoy the simple refilling. The KIZOKU Limit Leak-proof Membrane is easy for replacement.
Original KIZOKU Limit MTL RTA Replacement PC Tank Tube Kit with Drip Tip $7.99
The Kizoku LIMIT Cap with Drip Tip is Specially designed for KIZOKU Limit MTL RTA. The tank kit a useful spare part to replace easily. Get one for your Limit RTA and enjoy the simple refilling. The Kizoku LIMIT Cap with Drip Tip is made of the PC, so it is lighter than usual metal parts.
3FVAPE вне форума   Вверх
Старый 03.08.2020, 04:29 Автор темы   702
3FVAPE
Rincoe Manto Beast VV Box Mod $20.99
The Original Rincoe Manto Beast Mod is powered by dual 18650 batteries (not included) to provide 228W max power. Made of PC material, Manto Beast is elegant and 30% lighter than the usual mod. It comes with 5 levels of voltage to meet your different vaping requirements. There are multiple protections to ensure your safety: Overheating / Reverse Battery / Overload / Short-circuit / 10s Cut off / Low Voltage Protection.
Rincoe Mechman Lite TC VW Box Mod $23.99
The Rincoe Mechman Lite VW Box Mod adopts Mechman Chip and ultra-light material, which is born for not only new vapers but also for outdoor enthusiasts. With MECHMAN chip and dual 18650 high discharge batteries (not included), The Rincoe Mechman Lite Box mod can fire out 228W max output and provide a flash fire speed as fast as 0.002s. Moreover, the Rincoe Mechman Lite mod possesses adjustable temperature from 100'C to 315'C, and adjustable power from 1W to 228W. The Rincoe Mechman Lite VW Box Mod is equipped with a fast USB charging port, you can have a longer vaping experience.
Vaporesso LUXE II VW Box Mod $51.99
The original Introducing LUXE II VW Vape Box mod is equipped with the transformative AXON CHIP and a thoroughly upgraded UI. The PULSE MODE constantly satisfies you with throat hits. The most eye-catching 2.0 inch TFT color screen and the elegant design, making the LUXE II an impressive one from the first sight.
Rincoe Manto Beast RDA Kit $27.99
The Original Rincoe Manto Beast RDA Kit is consists of Manto Beast 228W Mod and Metis RDA. The Rincoe Manto Beast Mod is powered by dual 18650 batteries (not included) to provide 228W max power. Made of PC material, Manto Beast is elegant and 30% lighter than the usual mod. It comes with 5 levels of voltage to meet your different vaping requirements. There are multiple protections to ensure your safety: Overheating / Reverse Battery / Overload / Short-circuit / 10s Cut off / Low Voltage Protection. The Metis RDA features a simple deck that is easy to build and wick. With a wide bore 810 drip tip, the massive cloud is also provided to you.
Rincoe Mechman Lite RDA Kit $30.99
The Rincoe Mechman Lite VW Box Mod adopts Mechman Chip and ultra-light material, which is born for not only new vapers but also for outdoor enthusiasts. With MECHMAN chip and dual 18650 high discharge batteries (not included), The Rincoe Mechman Lite Box mod can fire out 228W max output and provide a flash fire speed as fast as 0.002s. Moreover, the Rincoe Mechman Lite mod possesses adjustable temperature from 100'C to 315'C, and adjustable power from 1W to 228W. The Rincoe Mechman Lite VW Box Mod is equipped with a fast USB charging port, you can have a longer vaping experience. The Rincoe Metis RDA has a simple deck to easily build and wick. And a wide bore 810 drip tip, the Metis RDA will bring you dense flavor and massive cloud.
Vaporesso LUXE II VW Mod Kit $69.99
The Original Introducing LUXE II VW Vape Box mod is equipped with the transformative AXON CHIP and a thoroughly upgraded UI. The PULSE MODE constantly satisfies you with throat hits. By adopting the NRG-S tank loaded GT MESH coils, LUXE II empowers a flavorful and powerful vaping experience. The most eye-catching 2.0 inch TFT color screen and the elegant design, making the LUXE II an impressive one from the first sight.
Старый 04.08.2020, 04:51 Автор темы   703
3FVAPE
SXK M-Atty V2 RDA Clone(Replica) with BF Pin original price $29.90, now only $27.90
The SXK M-Atty V2 RDA Clone is constructed from 316 stainless steel. This RDA supports single and dual coils building. And the deck of this RDA is designed around common vertical & horizontal builds.
Original Vladdin Chopin 500mAh Pod System Kit $19.99
The Original Vladdin Chopin Pod System Vape Starter kit is with a sleek pen-shaped a lightweight and compact body, and is made of zinc alloy, providing durability and portability. Vladdin Chopin is powered by a built-in 500mAh battery, using the type-c charging port to enjoy a more convenient and efficient vape experience. Except for a fire button and indicator light, there are no other buttons on the main body of the device. The simple design is also easy to use. As for Vladdin Chopin pod, featuring a 1.5mL refillable pod capacity, easily accessible by removing the pod and bottom-filled when removing the silicone plug. Vaporizing it within the integrated Kanthal 1.0ohm OCC coil to brings good flavor.
Original Innokin Sceptre Pod System Vape Kit Replacement Coil Head - 0.5ohm (5 PCS) $6.99
The 0.5ohm Coil Head is suitable for Original Innokin Sceptre Pod System / Pod Cartridge. The Original Innokin coil comes with 5 PCS / Pack.
Original Innokin Sceptre Pod System Vape Kit Replacement Coil Head - 1.2ohm (5 PCS) $6.99
The 1.2ohm Coil Head is suitable for Original Innokin Sceptre Pod System / Pod Cartridge. The Original Innokin coil comes with 5 PCS / Pack.
Original Innokin Sceptre Pod System Vape Kit Replacement Pod Cartridge with 0.5ohm Coil Head(1 PC) $6.99
The Original Innokin Replacement Pod Cartridge is compatible with Sceptre Pod System Vape Kit. Comes with 0.5ohm Coil Head and holds 3.0ml capacity.
Original Innokin Sceptre Pod System Vape Kit Replacement Pod Cartridge with 1.2ohm Coil Head(1 PC) $6.99
The Original Innokin Replacement Pod Cartridge is compatible with Sceptre Pod System Vape Kit. Comes with 1.2ohm Coil Head and holds 3.0ml capacity.
Original Auguse Era MTL RTA Replacement Tank Tube(3 PCS) $12.99
The Auguse Replacement Top Cap Tank Tube is designed for Auguse Era MTL RTA. It is made from PMMA and comes with 3 PCS / Pack.
Replacement Button for dotMod dotAIO Vape Pod System(1 PC) $5.99
The Replacement fire button is made from acrylic and is suitable for dotMod dotAIO Vape Pod System. 1 PC / Pack. (Button only, Pod system not included)
Original Vladdin Chopin Pod System Replacement Pod Cartridge(3 PCS) $11.99
The Original Vladdin Chopin Replacement Pod Cartridge is specially designed for Vladdin Chopin Pod System Vape Starter Kit that to deliver pure flavor taste and vaporous vaping satisfaction. Chopin Pod is made of PCTG, featuring an undetachable construction structure and possesses 1.5ml e-liquid capacity, bottom refill opening that stoppered by a silicone plug to offer an easy-to-access refilling way. In addition, integrated with a 1.0ohm Kanthal coil to deliver the fabulous MTL vaping experience.
Старый 05.08.2020, 04:36 Автор темы   704
3FVAPE
Original Steam Crave Titan PWM V1.5 300W VV Box Mod original price $79.99, now only $58.28
The Original Steam Crave Titan PWM V1.5 Mod is a powerful battery device, simple to use and very safe with full protection. Steam Crave Titan PWM V1.5 Box Mod is powered by four 18650 batteries (2 in series and 2 in parallel, not included) and can fire up to maximum 300W during 25ms. Steam Crave Titan PWM mod features adjustable voltage by rotating fire button and LCD display to show voltage, ohm, wattage and battery level. Steam Crave Titan PWM V1.5 Mod is compatible with big atomizers from diameter 30mm to 41mm, match with Aromamizer Titan 41mm RDTA perfectly. Titan PWM mod adopts lock / unlock voltage setting by pressing fire button 3 times quickly.
Original Hellvape & Wirice Launcher Sub Ohm Tank Clearomizer Vape Atomizer original price $32.99, now only $22.99
The Original Hellvape and WIRICE's Launcher Sub Ohm Tank is 26.5mm (bubble glass tank) in diameter and 25mm at the base. It comes with 4.0ml capacity and Bubble Glass Tube 5.0ml juice storage for selection. It comes 2 (0.15ohm (50~70W) and 0.21ohm (40~60W)) resistance mesh coil. And it's using SLDE-IN-LOADNG (S.i.L) System, It makes the installation of the coil much easier than ever. All you need to do is simply drop the coil into the LAUNCHER TANK, To ditch an old coil full of e-juice is also very easy. You just have to pour it out gently to replace it. Fingers will stay clean during the process. Giving you a better vaping experience.
Replacement Drip Tip for SMOKTech TFV16 Sub Ohm Tank Vape Atomizer $1.69
The Replacement Drip Tip is made from resin and it is suitable for SMOKTech TFV16 sub ohm Tank Clearomizer Vape Atomizer.
Replacement 510 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer $1.69
The Replacement 510 Drip Tip is made from resin and it is suitable for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer that compatible with 510 drip tip.
Replacement 810 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer $1.69
The Replacement 810 Drip Tip is made from resin and it is suitable for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer that compatible with 810 drip tip.
Replacement 810 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer $1.89
Replacement 810 Drip Tip with Anti Spit SS Mesh for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer $1.89
The Replacement 810 Drip Tip is made from resin + stainless steel and it is suitable for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer that compatible with 810 drip tip. Stainless steel base is with Spit SS Mesh Sheet.
Original Hellvape & Wirice Launcher W801 Replacement Mesh Coil Head(5 PCS) $12.99
The Original Hellvape & Wirice Launcher W801 Replacement mesh coil head is made from Kanthal A1 and with 0.15ohm for faster heating and purer flavor
Original Hellvape & Wirice Launcher W802 Replacement Mesh Coil Head(5 PCS) $12.99
The Original Hellvape & Wirice Launcher W802 Replacement mesh coil head is made from Kanthal A1 and with 0.21ohm for Faster heating and purer flavor
510 Thread Adapter Connector for SMOKTech SMOK Fetch Pro 80W Pod System Vape Kit $2.99
The 510 Thread Adapter Connector is designed for SMOKTech SMOK Fetch Pro 80W Pod System Vape Kit, it is made of stainless steel (510 threading connector) and POM (outer housing), which can switch your SMOKTech SMOK Fetch Pro 80W Pod System Vape Kit into a normal 510 thread box mod kit to use different atomizers as you like.
Старый 06.08.2020, 04:59 Автор темы   705
3FVAPE
Vapeasy Fire Bird RTA Clone(Replica) $21.99
The Fire Bird RTA Clone is a rebuildable tank atomizer with 22mm diameter and 5.0ml e-liquid capacity. It is made from 316 Stainless Steel. This FireBird RTA Clone comes with dual poles design for single coil build. The RTA is with AFC ring on the bottom for airflow adjustable.
SXK Haku Venna RDA Clone(Replica) with BF Pin original price $19.90, now only $17.90
The SXK Haku Venna RDA Clone is a low profile 22mm RDA with dual post design for single coil building. Constructed from 316 stainless steel, the RDA adopts sandblasting technology to make it feel smooth on the surface. The air enters the chamber via two different sizes of airholes on both side of the cap, hitting the coil directly. POM drip tip is included.
Original SMOKTech SMOK RPM160 160W Dual-18650 Pod System Kit $41.99
The Original SMOKTech SMOK RPM160 With V9 Pod Cartridge Vape Kit includes SMOK RPM160 Pod Mod Device and SMOK V9 Pod Cartridge. The SMOK RPM160 Pod Mod is powered by dual 18650 batteries (not included) with a maximum power output of 160W, you can press the up / down button to adjust the required power and get the preferred effect, and it comes standard with a 7.5ml pod cartridge and two 0.15ohm mesh coils. It has two versions, one is paired with RPM160 Pod with dual 0.15ohm mesh coils, and the other is a new combo used with the new RPM160 V9 Pod, which takes two V9 Meshed 0.15ohm coils. the RPM160 is lightweight and portable. It's zinc alloy frame is meticulously crafted on each corner, and the curves on the sides make full use of ergonomics. Innovation keeps changing the vaping experience! The compact structure and innovative design upgrade your visual pleasure and ergonomic comfort. Innovation keeps changing the vaping experience!
Replacement Drip Tip for SMOKTech TFV16 Sub Ohm Tank Vape Atomizer $1.59
Replacement 510 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer $1.59
Replacement 510 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer - 15.5mm $1.59
Replacement 810 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer - 12mm $1.59
Replacement 810 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer - 15.5mm $1.59
Старый 06.08.2020, 05:03 Автор темы   706
3FVAPE
Replacement 810 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer - 15.6mm $1.59
Replacement 810 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer - 17mm $1.59
Replacement 810 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer - 14mm $1.59
Replacement 810 Drip Tip for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer - 9mm $1.59
Original Hellvape & Wirice Launcher Vape Atomizer Replacement Tank Tube $1.69
The Original Hellvape & Wirice Launcher Sub Ohm Tank Vape Atomizer Replacement Tank Tube is made from PCTG and holds 2.0ml capacity.
Original Hellvape & Wirice Launcher Vape Atomizer Replacement Straight Tank Tube $1.69
The Original Hellvape & Wirice Launcher Sub Ohm Tank Vape Atomizer Replacement Straight Tank Tube is made from Glass and holds 4.0ml capacity.
Original Hellvape & Wirice Launcher Vape Atomizer Replacement Bubble Tank Tube $1.69
The Original Hellvape & Wirice Launcher Sub Ohm Tank Vape Atomizer Replacement Bubble Tank Tube is made from Glass and holds 5.0ml capacity.
Original SMOKTech SMOK RPM160 V9 Empty Pod Cartridge for SMOK RPM160 Dual-18650 Pod System Mod Vape Kit(1 PC) $3.99
The Original SMOK RPM160 V9 Empty Pod cartridge 7.5ml, paired with dual V9 Meshed 0.15ohm coil, and is compatible with TFV8 Mini coils, which maximizes the coil compatibility and gives full play to the versatile V8 Mini coils. The V9 empty pod cartridge is equipped with a bottom base with an adjustable airflow ring for free airflow adjustment. With an unprecedented 7.5ml e-liquid capacity, the pod mod can make a big difference. Also, the 50% increased. Since the rubber plug is located at the top of the pod, it is convenient and easy to fill the e-liquid without removing the pod.
Original Vandy Vape Superfine MTL Fused Clapton Coil for RDA / RTA / RDTA Vape Atomizer(10 PCS) $3.99
The Vandy Vape Superfine MTL Fused Clapton Wire Coil is made of Kanthal A1 material. It features 30GA x 2 + 38GA in 0.99ohm resistance, and could bring you better flavor. Just get it for your RBA / RDA / RTA / RDTA and enjoy DIY fun. 10 PCS / Bottle.
Старый 07.08.2020, 05:18 Автор темы   707
3FVAPE
Original OXVA Origin X 60W VW Pod System Kit original price $46.00, now only $33.99
The Original OXVA Origin X Pod Mod Vape Kit has excellent design and performance, an innovative triple system is a pod mod kit suitable for all vapers. It can play three different roles: A perfect pod AIO kit with the Unicoil system; A professional DIY kit with the RBA tank; A mod with the 510 connecter. This is an all-in-one device with a zinc alloy structure with ergonomic design. The carbon fiber is woven finish, which brings excellent hand feeling and ultra-portability. OXVA Origin X is powered by a single 18650 battery (not included) using a strong magnetic cover, the battery is installed and replaced by opening the battery cover through the label indication on the control panel. It can be charged at 2A through the type-c port on the bottom of the device. There is a large OLED screen for tracking device stats in real-time above the adjustment button. The Origin X's Photon chip has upgraded with new features, such us puff counter, puff clear, etc. And it also provides all standard safety features, including switch timeout and short circuit protection. The most innovative design of OXVA Origin X is its pod (Origin X Pod & Origin X RDTA Pod).
Original Sigelei Humvee 80W VW Pod System Kit original price $49.90, now only $35.99
The Original Sigelei Humvee 80 Pod System vape Kit is powered by single 18650 battery (not included), which can fire up to max 80W output, it is constructed by Alloy & PU Leather & PCTG, with 5.0ml capacity, innovative infinite airflow system, support the regulation of any size of airway, supports bypass mode, it has auto smart curve output. In combination with type-c flashtech super charging interface, so that you can completely get rid ofpower anxiety. Sigelei Humvee 80 can automatically recognize the coil and match the best wattage. Sigelei Humvee 80 cartridge comes with 5.0ml capacity and 0.15ohm / 0.3ohm resistance.
Base Holder Stand for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $1.99
The base holder stand is made of resin. It is used to display or place RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizers. The base diameter is 26mm and the top diameter is 22mm.
Original Coilology Pre-built MTL Alien Wire Coil for RDA / RTA / RDTA Vape Atomizer - 0.84ohm (10 PCS) $9.99
The Original Coilology Pre-built MTL Alien coils are made for the vapers who want enjoy better flavor with plenty of clouds at the same time. in the whole procedure, An Alien usually referred to as an Alien Clapton, is a de-cored Clapton, wrapped with dual parallel wires. It is similar to a fused Clapton, except the outer wrap has a very distinct texture. The Ni80 MTL Alien Wire Coil is made by 32 x 3GA + 38GA in 0.84ohm.
Original Coilology Pre-built MTL Alien Wire Coil for RDA / RTA / RDTA Vape Atomizer - 1.0ohm (10 PCS) $9.99
The Original Coilology Pre-built MTL Alien coils are made for the vapers who want enjoy better flavor with plenty of clouds at the same time. in the whole procedure, An Alien usually referred to as an Alien Clapton, is a de-cored Clapton, wrapped with dual parallel wires. It is similar to a fused Clapton, except the outer wrap has a very distinct texture. The KA1 MTL Alien Wire Coil is made by 32 x 3GA + 38GA in 1.0ohm.
Original Coilology MTL 4-in-1 Prebuilt MLT Coil + MTL Clapton Coil + MTL Fused Clapton + MTL Staple Coil Set - Ni80 (24 PCS) $7.99
The Original Coilology MTL 4-in-1 Prebuilt Coils Set is collectively crafted for Mouth-to-Lung builders looking for a range of coil builds with the convenience of pre-coiled setting. Each coil is machine-twisted for precise and consistent building material, presenting different types of structures optimized for flavor recreation and vapor-orientated performance. Each coil set comes in an efficient portable box to carry 4 different types of coils, with different amount of prebuilt coils in each that totals 24 ready-to-use coils. The Ni80 Resistance: 0.60ohm (MTL Coil) / 0.92ohm (MTL Clapton) / 0.8ohm (MTL Fused Clapton) / 0.68ohm (MTL Staple)
Original Coilology MTL 4-in-1 Prebuilt MLT Coil + MTL Clapton Coil + MTL Fused Clapton + MTL Staple Coil Set - SS316L (24 PCS) $7.99
The Original Coilology MTL 4-in-1 Prebuilt Coils Set is collectively crafted for Mouth-to-Lung builders looking for a range of coil builds with the convenience of pre-coiled setting. Each coil is machine-twisted for precise and consistent building material, presenting different types of structures optimized for flavor recreation and vapor-orientated performance. Each coil set comes in an efficient portable box to carry 4 different types of coils, with different amount of prebuilt coils in each that totals 24 ready-to-use coils. The SS316L Resistance: 0.90ohm (MTL Coil) / 0.70ohm (MTL Clapton) / 0.64ohm (MTL Fused Clapton) / 0.5ohm (MTL Staple)
Original Vandy Vape Superfine MTL Fused Clapton Wire Coil for Vape RBA / RDA / RTA - 0.65ohm (10 PCS) $4.99
The VandyVape Superfine MTL Fused Clapton Wire Coil is made of SS316 material. It features 30GA x 2 + 38GA in 0.65ohm resistance, and could bring you better flavor. Just get it for your RBA / RDA / RTA / RDTA Vape Atomizer and enjoy DIY fun. 10 PCS / Bottle.
Original Vandy Vape Superfine MTL Fused Clapton Wire Coil for Vape RBA / RDA / RTA - 1.03ohm (10 PCS) $4.99
The VandyVape Superfine MTL Fused Clapton Wire Coil is made of SS316 material. It features 30GA x 2 + 38GA in 1.03ohm resistance, and could bring you better flavor. Just get it for your RBA / RDA / RTA / RDTA Vape Atomizer and enjoy DIY fun. 10 PCS / Bottle.
Original OXVA Unicoil Regular Replacement Kanthal A1 Coil Head for OXVA Origin X Vape Kit - 1.0ohm (5 PCS) original price $15.70, now only $10.99
The Original OXVA Unicoil Replacement Coils are designed to release the liquid's flavor to its maximum. The MTL 1.0ohm Kanthal A1 Coil features effective nicotine delivery and great throat hit. It is the best choice for those who are newly switched from real cigarettes to vaping and mouth to lung vapers. OXVA Unicoil Replacement Coils are compatible with all vape devices no more than 60W from OXVA, including OXVA Origin X Kit, OXVA Origin Kit, OXVA X Kit. Additionally, the OXVA Unicoil Replacement Coils feature a simple plug and play installation process. Simply insert the coil head into compatible pod cartridge. 5 PCS / Pack.
Старый 07.08.2020, 08:46 Автор темы   708
3FVAPE
Original OXVA Unicoil Replacement Mesh Coil Head for OXVA Origin X Vape Kit - 0.2ohm (5 PCS) original price $15.70, now only $10.99
The Original OXVA Unicoil Replacement Coils are designed to release the liquid's flavor to its maximum. The sub ohm 0.2ohm mesh Coil features effective nicotine delivery and great throat hit. It is the best choice for those who are newly switched from real cigarettes to vaping and mouth to lung vapers. OXVA Unicoil Replacement Coils are compatible with all vape devices no more than 60W from OXVA, including OXVA Origin X Kit, OXVA Origin Kit, OXVA X Kit. Additionally, the OXVA Unicoil Replacement Coils feature a simple plug and play installation process. Simply insert the coil head into compatible pod cartridge. 5 PCS / Pack.
Original OXVA Unicoil Replacement Mesh Coil Head for OXVA Origin X Vape Kit - 0.3ohm(5 PCS) original price $15.70, now only $10.99
The Original OXVA Unicoil Replacement Coils are designed to release the liquid's flavor to its maximum. The DTL 0.3ohm mesh Coil features effective nicotine delivery and great throat hit. It is the best choice for those who are newly switched from real cigarettes to vaping and mouth to lung vapers. OXVA Unicoil Replacement Coils are compatible with all vape devices no more than 60W from OXVA, including OXVA Origin X Kit, OXVA Origin Kit, OXVA X Kit. Additionally, the OXVA Unicoil Replacement Coils feature a simple plug and play installation process. Simply insert the coil head into compatible pod cartridge. 5 PCS / Pack.
Original OXVA Unicoil Replacement Mesh Coil Head for OXVA Origin X Vape Kit - 0.5ohm (5 PCS) original price $15.70, now only $10.99
The Original OXVA Unicoil Replacement Coils are designed to release the liquid's flavor to its maximum. The DTL 0.5ohm mesh Coil features effective nicotine delivery and great throat hit. It is the best choice for those who are newly switched from real cigarettes to vaping and mouth to lung vapers. OXVA Unicoil Replacement Coils are compatible with all vape devices no more than 60W from OXVA, including OXVA Origin X Kit, OXVA Origin Kit, OXVA X Kit. Additionally, the OXVA Unicoil Replacement Coils feature a simple plug and play installation process. Simply insert the coil head into compatible pod cartridge. 5 PCS / Pack.
Original OXVA Unicoil Replacement RBA Deck Coil for OXVA Origin X Vape Kit(1 PC) original price $8.20, now only $6.99
The Original OXVA Unicoil RBA coil deck is compatible with all vape devices no more than 60W from OXVA, including OXVA Origin X Kit, OXVA Origin Kit, OXVA X Kit.
Original OXVA Origin X Pod Vape Kit Replacement Empty Pod Cartridge(2 PCS) original price $6.50, now only $5.99
The Original OXVA Origin X Replacement Pod Cartridge is a dual set of replacement empty pods for the OXVA Origin X Pod Mod Vape Kit that features a 3.0ml juice capacity. There is a raised silicone plug at the bottom of the Pod Cartridge. Push the plug open for juice refilling. Featuring plug and play coil installation, OXVA Origin X Pod Cartridge is able to be used with a wide range of coils. Origin X Pod Cartridge is compatible with all Unicoils (coils not included): new 0.2ohm mesh coil / 0.3ohm mesh coil for DTL vaping / 0.5ohm mesh coils for Light DTL & MTL vaping; 1.0ohm regular coil for MTL vaping, and dual coil RBA. Origin X Pod Cartridge is also connected to Origin X mod through strong magnetic support. To remove the pod, press the sides of the pod and pull it out. It's a smooth motion and its convenient. Per pack contains two empty Origin X replacement pods.
Original OXVA Origin X Pod Vape Kit Replacement Unicoil X DC RBA Pod Cartridge(1 PC) original price $16.99, now only $11.99
The Unicoil X DC RBA Pod Cartridge is designed especially for the authentic OXVA Origin X Pod Mod Vape Kit, coming with 3.2ml e-juice capacity.
Original OXVA Origin X Pod Vape Kit Replacement 510 Adapter Connector original price $5.90, now only $4.99
The 510 Thread Adapter Connector is designed for Authentic OXVA Origin X Pod Vape Kit. The 510 adapter can switch your S OXVA Origin X Pod Vape Kit into a normal 510 thread box mod kit to use different atomizers as you like.
Старый 08.08.2020, 04:20 Автор темы   709
3FVAPE
Timesvape X TenaciousTXVapes Ardent 27mm RDA original price $39.99, now only $25.99
The Original Timesvape Ardent RDA is made from 316 stainless steel and with 27mm diameter, the Ardent utilizes a unique spring loaded clamp system in the posts, for super easy installation of coils. Angled honeycomb side/bottom airflow for perfect flavor and intense vapor. The Ardent features a super deep juice well, locking barrel system, and a removable 510 for direct to Dreamer Mech Mod hybrid threading.
Replacement Tank Tube + Drip Tip Kit for SMOKTech TFV16 Sub Ohm Tank Vape Atomizer $2.99
The Replacement Tank Tube and Drip Tip Kit is made from resin and it is suitable for SMOKTech TFV16 sub ohm Tank Clearomizer Vape Atomizer.
Replacement Tank Tube for FreeMax Fireluke / Mesh Pro Vape Atomizer $1.99
The Replacement Tank Tube is made from resin and it is suitable for FreeMax Fireluke / Mesh Pro sub ohm Tank Clearomizer Vape Atomizer.
Replacement Tank Tube + Drip Tip Kit for FreeMax Fireluke Mesh Sub Ohm Tank Vape Atomizer $2.99
The Replacement Tank Tube and Drip Tip Kit is made from resin and it is suitable for FreeMax Fireluke Mesh sub ohm Tank Clearomizer Vape Atomizer.
Replacement Tank Tube + Drip Tip Kit for Uwell Valyrian Sub Ohm Tank Vape Atomizer $2.99
The Replacement Tank Tube and Drip Tip Kit is made from resin and it is suitable for Uwell Valyrian sub ohm Tank Clearomizer Vape Atomizer.
Replacement Front + Back Door Panel Plates for dotMod dotAIO Vape Pod System(2 PCS) $10.99
The Replacement Front and Back Door Panel Plates is made from PCTG and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included) 2 PCS / Pack
Старый 10.08.2020, 04:58 Автор темы   710
3FVAPE
Original Coilfreak Gemini 2 40W 1750mAh Pod System Kit $27.99
The Original Coilfreak Gemini 2 Pod System Vape Kit has a compact box style appearance, the matte surface prevents fingerprints and provides a good feel. Gemini 2 Vape Kit is built-in 1750mAh battery, with 2A Type-C fast charge, only 45 minutes for a full charge. On the control panel, there is a large intuitive fire button above Gemini 2, a 0.96-inch TFT colorful screen in the middle to show relevant vaping data, two wattage adjustment buttons, and a type-c charging port at the bottom. The maximum output of Gemini 2 Vape Kit is 40W and it can automatically control the power range to avoid dry burning. It also supports freely switching between voltage and wattage mode. Multiple protection functions ensure the stable and safe use of the device. The Coilfreak Gemini 2 Vape Kit features 4.0ml tank capacity and comes with two different tanks, coils, and mouthpieces to provide the users totally different MTL / DTL vaping experiences. Coilfreak uses Kanthal A1 as MTL coil and Mesh 316 as DTL coil. The coil base is equipped with an airflow adjustment ring, and there are many air intake holes at the bottom of the equipment, bringing you smooth airflow.
Original Justfog Q16 Clearomizer Vape Atomizer Replacement Glass Tank Tube $2.59
The Replacement Glass Tank Tube is suitable for Authentic Justfog Q16 Clearomizer vape atomizer.
Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer(1 PC) $2.59
The Replacement 510 Drip Tip is made from PEI and is suitable for RDA / RTA / RDTA / Sub Ohm Tank Clearomizer Vape Atomizer.
Original Coilology Framed Staple Spool Wire for RDA / RTA / RDTA Vape Atomizer $5.99
This Original Coilology Framed Staple Wire is 4 ply ribbon wire sandwiched and then wrapped with 36GA (0.127mm) that normal machine can't do on the market. The outer wire is wrapped to be tightest and consistent, thus the e-juice is less likely to escape from the gaps but to be vaporized. As a result the spilt back is avoided effectively. With the Framed Staple wire, the surface area is increased, which enables better flavor and huger vapor production as well. If you are tired of the normal prebuilt wire and looking for performance coil, this is going be your best choice. Come with 2-26GA / 4-0.4 x 0.1/36GA, 10 feet.
Original Coilology Fused Clapton Spool Wire for RDA / RTA / RDTA Vape Atomizer $4.99
The Original Coilology Fused Clapton Spool wire is made of a thinner gauge wire wrapped around two thicker gauge cores. The 2 cores give fused Clapton a faster ramp up time and arguably better flavor than non-fused Clapton, due to the increase in surface area. You can enjoying your joy of DIY with the spool wire and have a better vaping flavor experience. Come with 2-28 / 36GA, 10 feet.
Original Coilology Multi-Strands Fused Clapton Spool Wire for RDA / RTA /RDTA Vape $5.99
The Original Coilology Multi Strands Fused Clapton Coils feature 9 twisted strands of 38GA sandwiched between 2 strands of 28GA then wrapped with a 36GA Clapton. The outer wire is wrapped to the tightest and most consistent standard, thus liquid is less likely to escape from the gaps whilst being vaporized. Spit back is avoided effectively and with Clapton wire, the increased surface area enables better flavor and larger vapor production. Each spool of wire is cleaned with an Ultra Sonic cleaner to ensure nothing else comes with the wire. Available in both Stainless Steel and Nichrome. Come with 2-28GA / 9-38GA / 36GA, 10 feet (3 meter)
Original Coilology Quad-core Fused Clapton Spool Wire for RDA / RTA / RDTA Vape Atomizer $5.59
The Original Coilology Quad-Core Fused Clapton is a thinner gauge wire wrapped around 4 thicker gauge cores. The multiple cores give Fused Clapton a faster ramp up time and arguably better flavor than non-fused Clapton, due to the increase in surface area. Come with 4-28GA / 40GA, 10 feet (3 meter)
Старый 10.08.2020, 05:02 Автор темы   711
3FVAPE
Original Coilology Staple Spool Wire for RDA / RTA / RDTA Vape Atomizer $5.99
The Original Coilology staple coil is a 8 ply ribbon wire wrapped with 36GA wire. This variation of the fused Clapton has a quicker ramp-up time due to the stacked ribbon cores. The tiny grooves in between the wraps trap e-juice and contribute to its enhanced flavor. Comes with 8-0.1 x 0.4/36GA, 10 feet
Original Coilology Tri-Core Fused Clapton Spool Wire for RDA / RTA / RDTA Vape Atomizer $5.59
The Original Coilology Tri-Core Fused Clapton is 3 ply 28GA wire wrapped in a 40GA wire. The Tri-core give Fused Clapton a faster ramp up time and arguably better flavor than non-fused Clapton, due to the increase in surface area. The Tri-core fused Clapton spool is for the DIY lovers to spend your time exploring builds, get creative! Comes with 3-28GA / 40GA, 10 feet.
Original Vandy Vape Superfine MTL Fused Clapton Wire for RDA / RTA / RDTA Vape Atomizer $5.99
The Original Vandyvape Superfine MTL Fused Clapton Wire is made from Ni80 with 32GA x 2 + 38GA and features elasticity that you can build easily with twist and braid. It is suitable for RBA / RDA / RTA / RDTA Vape Atomizers.
Original Uwell Valyrian Vape Atomizer Replacement UN2 Mesh Coil Head(2 PCS) $7.99
The Original Uwell Valyrian 0.18ohm UN2 Mesh Coil Head utilize one of the most efficient coil designs to present highly efficient performance to the user. Wicked with organic cotton, large wick ports have been integrated into the stainless steel shell of the coil to improve wicking efficiency and provide excellent flavor recreation.
Original Uwell Juice Bank Refilling Dripping Bottle for E-juice Liquid $12.99
The Original Uwell Juice Bank is a refilling dripping bottle for e-liquid with a juice capacity of 15ml and the single refilling volume is about 0.1ml. Constructed from Stainless Steel and Quartz Glass, it has perfect protection from inside to outside. With the transparent windows on both sides of the bottle, you can check juice levels with a 15ml scale.
Original Coil Master Multifunctional Vape Tweezers for RDA / RTA / RDTA Vape Atomizer $4.99
The Original Coil Master Vape Tweezers is a highly efficient multi-functional tool, providing a combination of sturdy ceramic tweezer alongside a knurled base grip. The tweezer features a precision tip design, made with a wide base that allows for precise adjustment while having the strength for larger wire gauges or complex build configurations. The knurled base grip is highly intuitive, providing a clamp mechanism for easy base removal or replacement of RDA, RTA, and Sub-Ohm Tanks. It supports 22mm to 25mm, providing extended range of atomizer base. In addition, there is a 7mm to 12mm smaller non-knurled section for coil structures. Compact in size with incredible value that is a worthy addition to any vapers collection, the Coil Master Ceramic Tweezer is a handy accessory.
Старый 11.08.2020, 04:28 Автор темы   712
3FVAPE
Original Steam Crave Aromamizer Plus V2 DL RDTA Advanced Kit original price $62.99, now only $49.99
The Original Steam Crave Aromamizer Plus V2 DL RDTA is a great-looking, high-quality self-winding device that can be used both as an RTA and as an RDTA. The Aromamizer Plus V2 has a diameter of 30mm, it can hold 8ml of e-liquid and also get an 8ml extension set up. Enlarging the tank is possible so that a filling volume of up to an incredible 16 ml is achieved. A juice flow control system is also included to adjust the e-liquid to suit the mixture / temperature. As to the deck arrangement C the deck is a postless deck and also get a mesh build deck included. Regardless of which expansion height is filled from above, the pillarless deck is carefully designed without causing any confusion. The grid platform is also simple and well-designed, so you can also perform operations here successfully. Following on from the Steam Crave tradition of plenty of accessories you can also get a single coil deck, a series deck, and a velocity style deck to customize your Plus V2 even further (these decks are not including in the kit, sold separately). Airflow control has also been revised and optimized, especially for lower output steam. It is even more adjustable and has many options that have been significantly expanded, especially in more restrictive areas. The airflow is adjustable via the ring on the side which has honeycomb inlets. In addition, the ring has the option of 1, 2 or 3 slots and you can also turn the ring upside down to adjust this further. With Steam Crave's unique tank design, you will enjoy the incredible flavor and amazing cloud production.
Original VOOPOO Drag Mini Platinum 117W 4400mAh VW Box Mod Kit with PnP Tank(Refresh Standard Edition) $41.98
The VOOPOO Drag Mini Platinum Refresh Edition Kit consists of a 4.5ml Voopoo PnP Pod Tank and a Voopoo Drag Mini Platinum VW Box Mod, which is an updated edition of Drag Mini Series. It comes with higher performance and longer endurance. The Drag Mini Platinum Kit is powered by a 4400mAh Built-in Battery with 117W Max. Output Power. Both of them are large enough to provide long-lasting and powerful vaping experience. The pod tank can flexibly switch between Pod and Tank, and it is also compatible with all PnP coils, which will satisfy your different vaping demands. And adopting convenient bottom filling design, it supports adjustable air 510 base to match almost all your devices. Furthermore, driven by innovative GENE.FIT Chip, it features adjustable power in the range from 5W to 117W, allowing you to make beast clouds at once. And it is equipped with a screen to display clear information, making operation easier. Moreover, there are multiple protections to ensure your vaping safety.
Original VOOPOO Drag 2 Platinum 177W VW Mod Kit with PnP Tank(Refresh Standard Edition) $40.98
The VOOPOO Drag 2 Platinum Refresh Edition Kit consists of a 4.5ml VOOPOO PnP Pod Tank and VOOPOO Drag 2 Platinum Box Mod, which is the new version of Drag 2 Platinum that comes with and inherits the classic design of Drag 2 Platinum. The Drag 2 Kit is powered by dual 18650 batteries with 177W Max. power (Batteries are not included). Featuring innovative GENE.FIT Chip, it will provide fast ignition and high burst and support intelligent identification of coil to preventing the coil from burning out. Furthermore, the FIT mode will bring you better vaping experience with its safety design and long battery life. The PnP Pod Tank can flexibly switch between Pod and Tank and is designed with powerful magnetic absorption that makes coil replacement and oil filling never so simple. The adjustable air 510 base matches almost all of your devices. Drag 2 Platinum Refresh Edition is equipped with PnP-VM5 0.2ohm Coil and PnP-VM6 0.15ohm Coil. Moreover, it is compatible with ALL PnP Coils.
SXK Billet Box 70W All-in-One VW TC Box Mod Kit Clone(Replica) with USB Port original price $89.80, now only $85.90
The SXK Billet Box Mod Kit Clone is constructed from aluminum and PMMA with an all-in-one design. This version supports temperature control: 200~600'F / 100~300'C. This mod comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor.
Original Wotofo 810 Drip Tip for Profile RDTA Vape Atomizer $2.99
This 810 drip tip is Perfect for the Wotofo Profile RDTA, Which made from resin, better lip feel. with a metal ring, The 810 drip tip is more beautiful. It also matches the most of RDA / RTA / RDTA Vape Atomizer compatible with 810 drip tip without the silicone O-rings.
Steam Tuners Nano Bell Cap Clone + Chimney for Flash e-Vapor V4.5 RTA Tank Clone $6.99
The Steam Tuners Replacement Nano Bell Cap Clone is made of PC (bell cap) and SS (chimney), which is suitable for Flash e-Vapor E-Vapor V4.5 RTA Rebuildable Tank Vape Atomizer Clone. The cap is 23mm diameter. The bell cap has a 2.0ml E-juice capacity.
Original Coilfreak GEMINI Pod System Vape Kit Replacement MTL BVC Coil Head(4 PCS) $9.99
The Original Coilfreak GEMINI Replacement Coil is designed for Coilfreak GEMINI 40W Pod System Vape Kit. The Coilfreak GEMINI coil supports airflow adjustable, 1.2ohm BVC Coil is for MTL vaping.
Original Coilfreak GEMINI Pod System Vape Kit Replacement DL Mesh Coil Head(4 PCS) $8.99
The Original Coilfreak GEMINI Replacement Coil is designed for Coilfreak GEMINI 40W Pod System Vape Kit. The Coilfreak GEMINI coil supports airflow adjustable, 0.35ohm mesh Coil is for DL vaping.
Старый 12.08.2020, 04:48 Автор темы   713
3FVAPE
Original Timesvape Keen Hybrid Mechanical Mech Mod original price $75.00, now only $57.99
The Timesvape Keen Mechnical Mod is constructed from Copper in 30mm diameter and powered by single 18650 / 20700 / 21700 Battery (Not included), featuring a floating contact pin with ball head for hard fitting. The tube itself is 30mm at its widest point, tapering to 25mm or 27mm at the top. The contact pin is gold plated with a flat smooth button spring.
Original OneVape AirMod X 60W 1500mAh VW Pod System Kit $30.99
The Original OneVape AirMod X Pod System has the same slim and ultra-portable appearance as the original OneVape AirMod Vape Kit. The size and performance are exactly the same. The difference is that the device body embedded panel material is replaced with PU leather. The OneVape AirMod X Vape Kit comes with a compact structure, innovative coils, and great flavor. AirMod X Kit is only got 12.9mm thickness and is pretty small and light, so you can take it anywhere to you like with a lanyard included in the kit. It's built-in 1500mAh huge capacity battery with unique quick charge supports strong power up to 60W. It can be fully charged in 60min with 2A charging current through Type-C charging port. The AirMod X features an air sensor which allows the user to vape directly without any buttons, and a childproof locking system that can be locked / unlocked by pressing and holding the up / down buttons on the side of the device at the same time. In addition, AirMod X features 6.0ml pod capacity which is super large for a pod system, so you don't have to fill the pod frequently. AirMod X is compatible with all Air series coils such as Dual Mesh Coil 0.2ohm, Quadruple Coil 0.5ohm, Quadruple Coil 0.8ohm, offering the best flavor and excellent vapor production.
Original OVNS Gemini 40W VW Pod System Kit $26.99
The Original OVNS Gemini Pod System Vape Kit is a revolutionary new premium pod system. The Gemini Pod System has the ability to change coils with different resistances, for your choice will be available coil for 0.35Ohm and 1.2Ohm. In addition, for the Gemini Pod system, it has the ability to fine-tune the characteristics of the pod and change the power from 5W to 40 watts, so that you can customize the device to your taste preferences as much as possible. Naturally, such a "steam generator" requires a good battery and OVNS took care of this in full, because Gemini is equipped with a battery of as much as 1750mAh and Type-C charging with a charging current of 2A, which allows you to charge the Gemini Pod system up to 100% in just 48 minutes. The Gemini Pod System Vape Kit takes the very best from Pod systems and its predecessor vapes, not to mention the phenomenal durability of the cartridges.
Replacement Glass Tank Tube for Wotofo Profile RDTA Vape Atomizer $2.59
The Replacement Glass Tank Tube is suitable for Wotofo Profile RDTA Vape Atomizer. It features 6.2ml capacity.
Original OVNS Gemini Vape Kit Replacement Ncoil MTL BVC Coil Head(4 PCS) $9.99
The Original OVNS Gemini Replacement Ncoil 1.2ohm MTL BVC Coil Head is perfectly compatible with OVNS Gemini vape Kit. The 1.2ohm BVC coil supports MTL vaping experience.
Original OVNS Gemini Vape Kit Replacement Mcoil DL Mesh Coil Head(4 PCS) $9.99
The Original OVNS Gemini Replacement Mcoil 0.35ohm DL Mesh Coil Head is perfectly compatible with OVNS Gemini vape Kit. The 3.5ohm mesh coil supports DL vaping experience.
Original Hellvape Vape Building Mat Mouse Pad $14.99
The Original Hellvape Build Mat is made of high-quality and durable rubber construction to prevent the desktop from scratching. With soft surface, it allows you to DIY building or operate your vape equipment. In addition, the mat has a coating that can absorb droplets of juice. Besides, it can be used as a mouse pad.
Original SXK ETU Easy to Use Pod Cartridge to 510 Adapter for VOOPOO VINCI / VINCI X Mod Pod Cartridge original price $7.90, now only $5.90
The Original SXK ETU Easy to Use 510 Adapter is for VOOPOO VINCI / VINCI X Mod Pod Cartridge. With this ETU adapter, you can use your VOOPOO VINCI / VINCI X Mod Pod Cartridge on the normal box mod with 510 threading connection.
Старый 13.08.2020, 04:26 Автор темы   714
3FVAPE
Original VEIIK Cracker Pro 15W 500mAh Pod System Kit $14.99
VEIIK Cracker Pro Pod Vape Starter Kit is a refillable pod system kit. It has the same battery device with Cracker and designed with a new pod cartridge. It is powered by 500mAh built-in battery with 8~15W power range. USB charging port makes charging convenient. More detailed information waiting to be perfected.
Original SMOKTech SMOK Mag P3 Mini 80W 3000mAh VW Mod Kit $69.99
The Original SMOK Mag P3 Mini 80W Box mod Vape Starter Kit, the mini version of Mag P3, consists of SMOK Mag P3 Mini 80W Box Mod and SMOK TF Tank. SMOK Mag P3 Mini box mod also features smart chipset with IP67 waterproof, dustproof, shockproof and 0.001s fire speed. SMOK Mag P3 Mini box mod is powered by 3000mAh rechargeable built-in battery with output range of 1~80W. SMOK Mag P3 Mini 80W mod adopts 0.96 inch TFT screen with full-color menu, easy to read. SMOK TF Sub Ohm Tank comes with 810 replaceable resin drip tip and 6.0ml capacity with top rotary fill design. SMOK TF utilizes adjustable bottom airflow system with dual wide airflow slots.
Original Uwell Valyrian 25W 1250mAh Pod System Kit $26.99
The Original Uwell Valyrian pod system vape starter Kit is an exquisite and ergonomic pod system device, with integrated 1250mAh battery, and a 3.0ml refillable replacement pod. The Valyrian Pod System Vape Kit body is made of durable and lightweight Aluminum Alloy with a letter pattern on the surface, adding a stylish and exquisite atmosphere to the small and compact vape system. It is powered by a built-in 1250mAh battery, is more durable than most Pod devices, and can be easily charged via the micro USB port on the bottom. In addition, the 3.0ml refillable replacement box is made of PCTG with an integrated coil of 1.0ohm or 0.6ohm, which supports DTL vaping And MTL vaping. Convenient side-fill cap design for easier filling. Compatible with nicotine salt and regular e-liquid.
Original Uwell Valyrian 25W 1250mAh Pod System Replacement DL Coil Head(4 PCS) $9.99
The Original Uwell Valyrian 25W 1250mAh Pod System Replacement DL 0.6ohm Coil Head supports 18W to 25W. The coil can be replaced for more prolonged use and lower cost. The 0.6ohm DTL coil offers a smooth airflow and more cloud.
Original Uwell Valyrian 25W 1250mAh Pod System Replacement MTL Coil Head(4 PCS) $9.99
The Original Uwell Valyrian 25W 1250mAh Pod System Replacement MTL 1.0ohm Coil Head supports 8W to 15W. The 1.0ohm coil offers a tight draw to satisfy your need for real MTL vape.
Original Uwell Valyrian Pod System Replacement Empty Pod Cartridge(1 PC) $3.99
The Original Uwell Valyrian Pod System Empty Pod Cartridge is designed especially for the Uwell Valyrian Pod System Vape Starter Kit, coming with 3.0ml e-juice capacity. There is an airflow valve on the side of the pod. The airflow of the pod can be adjusted as you want to pursue a smoother airflow or tighter draw.
Original MECHLYFE Space Fused Clapton Pre-coiled Wire Coil for RDA / RTA /RDTA Vape Atomizer(6 PCS) $2.33
The Original MECHLYFE Space Fused Clapton Pre-coiled Wire Coil if made from N80 with 26 x 2 / 40GA in 0.3ohm resistance. It will be good replacement wire for RDA / RTA / RDTA Vape Atomizer.
Original MECHLYFE MTL Fused Clapton Pre-coiled Wire Coil for RDA / RTA /RDTA Vape Atomizer(6 PCS) $2.33
The Original MECHLYFE MTL Fused Clapton Pre-coiled Wire Coil if made from N80 with 30 x 2 / 40GA in 0.65ohm resistance. It will be good replacement wire for RDA / RTA / RDTA Vape Atomizer.
Original TonyB x MECHLYFE Link 510 Adaptor Connector for BB 60W / 70W / Billet Box Mod Vape Kit $10.00
The Original TonyB x MECHLYFE Link 510 Adaptor Connector is made from 304 stainless steel with golden plated center pin and spring loaded contact. It is suitable for SXK BB DNA 60W / 70W / Billet Box Mod Vape Kit. With this 510 adapter, you can use your 510 RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer on your SXK BB DNA 60W / 70W / Billet Box Mod Vape Kit.
Старый 14.08.2020, 04:28 Автор темы   715
3FVAPE
El Thunder MTLite Vape Mechanical Mod Clone(Replica) $14.99
The El Thunder MTLite Vape Mechanical Mod Clone is constructed from brass and powered by 1 x 18350 / 18650 battery (not included). The Electric pole is made from brass with silver-plating.
Original VapeSoon Z1 Mesh Coil Core Head for GeekVape Zeus Sub Ohm Tank Atomizer(5 PCS) $7.99
The VapeSoon Z1 Mesh Coil head is specially designed for GeekVape Zeus Sub Ohm Tank Atomizer. The Zeus mesh coil is constructed from KA1 which is a longer lifespan and the resistance of it is 0.4ohm. Output power is from 60 to 70W. Quick slide coil design allows for quick access coil replacement.
Original VapeSoon Z2 Mesh Coil Core Head for GeekVape Zeus Sub Ohm Tank Atomizer(5 PCS) $7.99
The VapeSoon Zeus Mesh Coil head is specially designed for GeekVape Zeus Sub Ohm Tank Atomizer. The Zeus mesh coil is constructed from KA1 which is a longer lifespan and the resistance of it is 0.2ohm. Output power is from 70 to 80W. Quick slide coil design allows for quick access coil replacement.
Original VapeSoon Replacement PnP-VM5 Mesh Coil Heads for VOOPOO DRAG S / DRAG X / PnP Pod Tank(5 PCS) $7.59
The Original VapeSoon PnP-VM5 Mesh Coil Head is suitable for VOOPOO DRAG S VW Mod Pod Vape Kit / VOOPOO DRAG X VW Mod Pod Vape Kit and other mod kit with PnP Pod Tank as replacement parts. The PnP-VM5 Mesh Coil features 0.2ohm coil resistance that power range from 40W to 60W, and the suggested E-liquid Nicotine < = 10mg. 5 PCS / Pack.
Original VapeSoon Replacement PnP-VM6 DL Mesh Coil Heads for VOOPOO DRAG X VW Mod Pod Vape Kit(5 PCS) $7.59
The VapeSoon Replacement PnP-VM6 DL Mesh Coil Heads is suitable for VOOPOO DRAG X VW Mod Pod Vape Kit as replacement parts. The PnP-VM6 Mesh Coil features 0.15ohm coil resistance that power range from 60W to 80W, and the suggested E-liquid Nicotine < = 10mg. 5 PCS / Pack.
Original VapeSoon MTL DC Coil for SMOKTech SMOK & OFRF nexMESH VW Mod Pod System Vape Kit(5 PCS) $7.59
The Original VapeSoon 0.4ohm MTL DC Coil is specially designed for SMOK & OFRF nexMESH VW Mod Pod System Vape Kit as a replacement part. It features 0.4ohm coil resistance and power output range from 12W to 25W. 5 PCS / Pack.
Original VapeSoon SS316 Coil for SMOKTech SMOK & OFRF nexMESH VW Mod Pod System Vape Kit / Cartridge(5 PCS) $7.59
The Original VapeSoon replacement SS316 Coil head is specially designed for SMOK & OFRF nexMESH VW Mod Pod System Vape Kit as a replacement part. It features 0.4ohm coil resistance and power output range from 15W to 20W. 5 PCS / Pack.
Whistle V2 510 Drip Tip Clone for DotMod DotAIO Pod / Billet BB Box Mod / RDA / RTA /RDTA Vape Atomizer $4.89
The Whistle V2 510 Drip Tip Clone is made from Acrylic and suitable for DotMod DotAIO Pod System / Billet BB Box Mod Kit / RDA / RTA / RDTA Vape Atomizer.
Original TonyB x MECHLYFE Link 510 Adaptor Connector for BB 60W / 70W / Billet Box Mod Vape Kit(2 PCS) $14.99
The Original TonyB x MECHLYFE Link 510 Adaptor Connector is made from 304 stainless steel with golden plated center pin and spring loaded contact. It is suitable for SXK BB DNA 60W / 70W / Billet Box Mod Vape Kit. With this 510 adapter, you can use your 510 RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer on your SXK BB DNA 60W / 70W / Billet Box Mod Vape Kit. 2 PCS / Pack
Старый 17.08.2020, 05:15 Автор темы   716
3FVAPE
Original SMOKTech SMOK Rigel 230W VW Box Mod $37.99
The Original SMOK Rigel 230W Vape Box Mod In terms of appearance, the back design of Rigel adopts a soft rubber coating, and the side design adopts classic carbon fiber, which is smooth and tough. The two sides of the device have ergonomic contours. There are countless honeycomb holes on the surface of the shell, providing a unique visual experience and a perfect hand feel. On the control panel, Rigel has an intuitive rectangular ignition button, an excellent display screen, a pair of wattage adjustment keys as well as a Type-C charging port. The SMOK Rigel Kit is powered by dual high-rate 18650 batteries (not included) with max output 230W, the 0.96 inch TFT display will show you the vaping data clearly, you could adjust the working wattage from 1W to 230W by pressing the adjust buttons freely. SMOK Rigel provides six theme colors, and you can personalize the user interface according to your preferences. You can change the style by pressing the fire button and the UP button at the same time. In addition, SMOK Rigel integrates an excellent chipset that perfectly combines performance and ease of use, providing an incredible 0.001s ignition speed and a variety of safety protection measures, you can get a strong flavor and a large amount of vapor at the first hit.
Original SMOKTech SMOK RPM 2S 80W VW Pod System Kit $34.99
The Original SMOK RPM 2S is power by single external 18650 battery (not included) to provide long-lasting power for the entire device, with a power of up to 80 watts. You can adjust the required power in the range of 1W to 80W by pressing the UP / DOWN button. RPM 2S Pod System uses a non-magnetic battery cap located on the back of the device, you can replace the battery quickly by pushing the cap to the right. The RPM 2S Pod System has a Type-C charging port, it can carry reliable power in faster transmission speed, and supports forward and reverse charging. The SMOK RPM 2S Pod System is also equipped with a 1.14-inch color TFT display and a redesigned user interface, which can provide you with more information and make it easier to read. As for the replacement of the filling Pod, RPM 2S uses two types: RPM 2 RPM 2 Pod and RPM 2 RPM Pod. RPM 2 RPM 2 Pod has a huge 7.0ml capacity and comes with a Mesh 0.16ohm coil preinstalled. The large mouthpiece allows more airflow, perfect for direct lung vaping. The RPM 2 RPM Pod with a huge 7.0ml capacity which houses an RPM Mesh 0.4ohm coil is perfect for mouth to lung (MTL) vaping. The RPM 2 Mesh Coils are designed for dense vapor and intense flavor, whereas the RPM Mesh Coils will bring you gentle throat hits and satisfying flavor. In addition, RPM 2 Pod with visible e-liquid level window makes it easy to check the remaining juice capacity at any time. The RPM 2 pod uses powerful magnets to make the pod perfectly match the device.
Original SMOKTech SMOK Nord X 60W 1500mAh VW Pod System Kit $36.99
The Original SMOK Nord X Pod System has higher quality and durability, higher power output, larger capacity Pod cartridge, and innovative RPM 2 coils, all these amazing features will exceed your expectations. Nord X integrates a 1500mAh battery with max. 60W output. In addition, Nord X Pod System maintains the same single-button layout and is also equipped with an OLED screen on the side to display relevant vape data. Nord X Pod System has developed a variety of functions you want. It adopts an IP67 waterproof design, can withstand 15cm to 1 meter of water for 30 minutes, and also has dustproof (IP67) and shockproof functions to prevent dust from entering and accidentally falling drop. Nord X pod System comes with two pods with a 6ml e-liquid capacity, which can accommodate both RPM 2 Mesh 0.16ohm coil and RPM Mesh 0.4ohm coil, and supports RPM 2 and RPM series coil options.
Original SMOKTech SMOK Rigel 230W VW Mod Kit $49.99
The Original SMOK Rigel 230W Vape Box Mod Kit is composed of exquisite high-performance Rigel Mod and powerful TFV9 Tank. In terms of appearance, the back design of Rigel adopts a soft rubber coating, and the side design adopts classic carbon fiber, which is smooth and tough. The two sides of the device have ergonomic contours. There are countless honeycomb holes on the surface of the shell, providing a unique visual experience and a perfect hand feel. On the control panel, Rigel has an intuitive rectangular ignition button, an excellent display screen, a pair of wattage adjustment keys as well as a Type-C charging port. The SMOK Rigel Kit is powered by dual high-rate 18650 batteries (not included) with max output 230W, the 0.96 inch TFT display will show you the vaping data clearly, you could adjust the working wattage from 1W to 230W by pressing the adjust buttons freely. SMOK Rigel provides six theme colors, and you can personalize the user interface according to your preferences. You can change the style by pressing the fire button and the UP button at the same time. In addition, SMOK Rigel integrates an excellent chipset that perfectly combines performance and ease of use, providing an incredible 0.001s ignition speed and a variety of safety protection measures, you can get a strong flavor and a large amount of vapor at the first hit.
Original SMOK Nord X Pod System Replacement Empty RPM 2 Pod Cartridge(3 PCS) $7.99
The Original SMOK Nord X Pod System Vape Starter Kit Replacement Empty RPM 2 Pod Cartridge is compatible with RPM 2 Mesh 0.16ohm coil head (not included). With an unprecedented 6.0ml e-liquid capacity, the pod system can make a big difference. It is designed with a transparent area through which you can clearly see the e-liquid level for better viewing the consumption of e-liquid.
Original SMOKTech SMOK Nord X Pod System Replacement Empty RPM Pod Cartridge(3 PCS) $7.99
The Original SMOK Nord X Pod System Vape Starter Kit Replacement Empty RPM Pod Cartridge is compatible with All RPM coil head (not included). With an unprecedented 6.0ml e-liquid capacity, the pod system can make a big difference. It is designed with a transparent area through which you can clearly see the e-liquid level for better viewing the consumption of e-liquid.
SXK Hood Top Cap Tank for Flash-e-Vapor V4.5S+ RTA $4.80
The SXK Hood Top Cap Tank is made from PMMA and it suitable for Flash-e-Vapor V4.5S+ RTA Vape Atomizer.
Original VOOPOO DRAG S 60W 2500mAh VW Pod System Kit original price $37.99, now only $32.79
The VOOPOO DRAG S VW Mod Pod Kit is a compact and ergonomic pod mod system kit that consists of a 4.5ml pod cartridge and a 2500mAh built-in battery. The pod cartridge adopts a bottom refilling design and innovative infinite airflow system for the most comfortable experience. The Kit comes with a PnP-VM1 0.3ohm Coil and a PnP-VM5 0.2ohm Coil, it is also compatible with the other PnP coils, which can bring you DL and MTL vaping experience. As for the mod, it features adjustable power in the range of 5W to 60W. Monitored by GENE.TT chip, it can ignite within 0.001s, and also provides intelligent functions such as PUFF recording, SCORE ranking, SMART switching start mode, and so on. Moreover, there are 7 safety protections to ensure your vaping safety.
Original VOOPOO DRAG X 80W VW Pod System Kit original price $39.99, now only $32.18
The VOOPOO DRAG X Pod Kit is made of metal and leather, so Drag X is not only soft, but also has advantages of anti scratch, anti perspiration and anti fingerprint. It is powered by Single 18650 battery (Not included). Equipped with the new GENE.TT Chip, Drag X features fast ignition (only takes 0.001s) and high burst. GENE.TT Chip also offers intelligent functions such as PUSS and SCORE ranking mode. In addition, the SCORE ranking mode helps you continuously unlock the new level from "IRON" to "KING" according to the cloud size of each suction. It comes with power range from 5W to 80W to fit your needs and the 80W max power will enable you to make bigger flavorful clouds. Drag X is designed with the innovative infinite airflow system that supports the regulation of any size of airway. Most importantly, you can enjoy the most comfortable experience through this system no matter which kind of coil or different parameters are set! As for the pod, it can hold 4.5ml E-juice capacity and adopt a wide range of coils, including RBA (RBA Coil is sold separately). The 510 adapters and other new technologies are also be added to this pod. Drag X is equipped with 0.15ohm and 0.3ohm PnP coil and it is compatible with all PnP coils. Moreover, there are 7 safety protections to ensure your vaping safety.
Старый 18.08.2020, 04:35 Автор темы   717
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Holy Atty Patibulum Unleashed MTL RTA Clone $14.99
Holy Atty Patibulum Unleashed MTL RTA rebuildable tank vape atomizer Clone is made from 316 stainless steel and PEI tank, in 22mm diameter and holds 3.5ml capacity. The HolyAtty Patibulum Unleashed MTL RTA Clone is with dual posts deck for single coil building. The single coil deck and redesigned chamber is dedicated to pure MTL use (indirect inhalation). The airflow system is hidden under the atomizer. The airflow of the Unleashed no longer having separate bearings, will be adjusted more finely than on its predecessor, still thanks to an air-disk ranging from 0.6mm to slightly more than 2.5mm opening. The air outlet located under the coil has 3 holes of 1.2 mm.
Original Suorin Trio 85 VW Pod System Kit $37.99
The Original Suorin Trio 85 Vape Mod Kit is a Pod Mod Kit that will redefine Pod Mod and bring you a new possibility of Pod Mod. It is powered by single 18650 battery (not included) with 5~85W adjustable wattage and comes with 5.0ml big e-juice capacity. With the Suorin TRI-Force series chip, it will bring a new experience of flavor and vapor. TRI-FORCE is an innovative atomization management system with a multi-channel atomization core, it is the central processor of the device. What's more, TRI-FORCE comes with the functions of voltage management, power distribution, temperature management and atomization monitoring, which can accurately control, intervene and manage the entire process of atomization. Trio 85 can match with different atomization coils, such as single mesh coil and triple mesh coil. It will maintain a professional performance without concerning about the battery life with boost convertor design. The coils are all designed with airflow adjustment function: TRI Single Mesh 0.4ohm help you enjoy the pure flavor, TRI Triple Mesh 0.2ohm help you explore rich sense of flavor and more vapor. TRI RBA Coil is also available for you (not included). Trio 85 makes Pod Mod no longer controlled by the limitation of the size, coil and power, just take it to enjoy a new and amazing vaping experience!
Replacement Drip Tip + Tank Tube + Top Cap for Patibulum Unleashed RTA Clone $3.98
The Replacement Drip Tip + Tank Tube + Top Cap holds 3.5ml and is suitable for Patibulum Unleashed RTA Clone.
Original Auguse Era RTA Vape Atomizer Replacement Tank Tube $1.59
The Original Auguse Era RTA Vape Atomizer Replacement Tank Tube is make from Glass and holds 3.0ml capacity.
SXK M-Atty FYF M-Atty V2 RDA Clone Replacement 510 Drip Tip + 510 Drip Tip Adapter(3PCS) original price $15.90, now only $13.90
The SXK M-Atty FYF M-Atty V2 RDA Vape Atomizer Clone Replacement 510 Drip Tip + 510 Drip Tip Adapter set comes with 3 PCS / Set. One is made from stainless steel, one is POM, and one is PEI.
SXK M-Atty FYF M-Atty V2 RDA Clone Replacement Decorative Rings Set(2 PCS) original price $9.90, now only $8.90
The SXK M-Atty FYF M-Atty V2 RDA Vape Atomizer Clone Replacement decorative rings set comes with 2 PCS / Set.
SXK M-Atty FYF M-Atty V2 RDA Clone Replacement Adjustable Airflow AFC Rings Set(2 PCS) original price $9.90, now only $8.90
The SXK M-Atty FYF M-Atty V2 RDA Vape Atomizer Clone Replacement Adjustable Airflow AFC rings set comes with 2 PCS / Set.
SXK M-Atty FYF M-Atty V2 RDA Clone Replacement Three holes Top Cap Chamber(3 PCS) original price $15.90, now only $13.90
The SXK M-Atty FYF M-Atty V2 RDA Vape Atomizer Clone Replacement Three holes Top Cap Chamber set comes with 3 PCS / Set.
SXK M-Atty FYF M-Atty V2 RDA Clone Replacement Airslots Top Cap Chamber(2 PCS) original price $12.90, now only $10.90
The SXK M-Atty FYF M-Atty V2 RDA Vape Atomizer Clone Replacement Airslots Top Cap Chamber set comes with 2 PCS / Set.
SXK M-Atty FYF M-Atty V2 RDA Clone Replacement One Piece Tank Tube Drip Tip original price $6.90, now only $5.90
The Replacement Top Cap Tank Tube and Drip Tip in One Piece is made from PMMa and is suitable for SXK M-Atty FYF M-Atty V2 RDA Vape Atomizer Clone
Original Suorin Trio 85 Vape Mod Kit Replacement Empty Pod Cartridge $2.99
The Original Suorin Trio 85 Empty Pod Cartridge is designed is suitable for Suorin Trio 85 Pod Kit. It comes with 5.0ml e-liquid capacity. It is an empty pod and cartridge is compatible with TRI Coils. 1 PC each pack.
510 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $1.59
The 510 Drip Tip is made from Acrylic and is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer.
510 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $2.29
The 510 Drip Tip is made from POM and stainless steel and is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer.
3FVAPE вне форума   Вверх
Старый 19.08.2020, 05:29 Автор темы   718
3FVAPE
Original 5GVAPE Rage RDA with BF Pin $22.99
The Original 5GVAPE Rage BF RDA Rebuildable Dripping Vape Atomizer is made from 316 stainless steel and in 24mm diameter. The building deck is with quad-pole for dual coil building. Comes with BF / Bottom Feeder / Squonker Pin.
Original Vandy Vape Kylin Mini V2 RTA original price $38.99, now only $30.99
The Original Vandy Vape Kylin Mini V2 RTA Vape Atomizer is an upgraded version of Kylin Mini V1. It is a Rebuildable tank atomizer with 24.4mm outer diameter. And it can hold 5.0ml e-juice capacity, which is able to provide you with long-lasting vaping experience. And it adopts top airflow design to prevent juice from leaking. Besides, it also utilizes 270 degree honeycomb airflow for good taste and smooth airflow. Moreover, with easier coil installation, it supports 0.3ohm Fused Clapton Coil.
Original VapX Geyser 100W VW Pod System Kit original price $56.90, now only $52.00
The Original VapX Geyser Pod System Vape Kit is a true revolutionary device to touch the top technology. Powered by a single 21700 battery (not included), the VapX Geyser reaches a maximum output of 100W. The VapX Geyser is also compatible with 18650 battery (not included, with a sleeve). The VapX Geyser 100W Pod System Vape Kit attaches two pods of 5.0ml 75W Air Pod and 6.5ml 45W Air Pod. The 5.0ml 75W Air Pod is best for Loose MTL / Loose DL vape while the 6.5ml 45W Air Pod is perfect for Tight MTL / Restricted DL vape. The buck-boost converter brings a real stale and consistent output to the VapX Geyser. The VapX Geyser Pod System Vape Kit adopts magnesium alloy construction for a lighter weight. So an external li-ion battery will not make the VapX Geyser heavy in palms.
Original Smoant VIKII 10W 370mAh Pod System Kit original price $13.99, now only $9.99
The Original Smoant VIKII Pod System Vape Kit is an ultra-portable all-in-one pod starter kit for starters. The Smoant VIKII Pod comes with built-in 370mAh battery and 2.0ml refillable pod cartridge. The Smoant VIKII Pod Cartridge features the internal 1.2ohm KA1 coil to bring you optimal flavor and great clouds. Plus the easy side refilling design and environmental food grade material, the Smoant VIKII Pod is definitely a great vaping device.
Original Smoant Pasito II 2 V2 80W 2500mAh TC VW Pod System Kit original price $43.90, now only $34.99
The Original Smoant Pasito II V2 2500mAh Pod System Mod Vape Kit is an upgrade of Smoant Pasito. The Smoant Pasito II Vape kit is powered by inbuilt 2500mAh large capacity battery to bring you all day using with maximum 80W output. With the intelligent battery, the Smoant Pasito II 2 device can provide VW / DVW / Bypass / TC Mode for meeting your different needs. Featuring 0.96" colorful TFT screen, you can clearly see the date of Smoant Pasito II device. The Smoant Pasito II Pod Cartridge has the 6.0ml lager juice capacity with a big visible juice level window for clearly seeing the juice level. The Smoant Pasito II cartridge possesses independent top air inflow system and side refill slot maximum prevent leaking. In addition, Pasito II is compatible with all Smoant Mesh Coil and Knight 80 coils, meanwhile we release new K-3 0.6ohm Half-DTL coil, meet all your needs. Moreover, the Smoant Pasito II Launches Pasito II 510 Adapter which is compatible with all kinds of atomizer for high-end vaper require (510 adapter not included). With 4 stylish color look, you will be love in the Smoant Pasito II Vape Mod Kit.
Original Vapx Geyser 100W Pod System Replacement XCoil Model 10n AIO Coil Head(5 PCS) $9.99
The Original VapX XCoil AIO Coil is designed for Vapx Geyser 100W Pod System Vape Kit. The 0.6ohm Model 10n Single Air Mesh coil supports Airflow for Tight MTL / Loose MTL vaping.
Старый 19.08.2020, 05:31 Автор темы   719
3FVAPE
Original Vapx Geyser 100W Pod System Replacement XCoil Model 15s AIO Coil Head(3 PCS) $8.99
The Original VapX XCoil AIO Coil is designed for Vapx Geyser 100W Pod System Vape Kit. The 0.23ohm Model 15s Single Air Mesh coil supports Airflow for Loose MTL / Restricted DTL / Loose DTL vaping.
Original VapX Geyser Pod System Replacement Empty 5.0ml 75W Air Mesh Pod Cartridge(1 PC) $6.99
VapX Geyser Replacement Empty Pod is designed for Vapx Geyser 100W Pod System Vape Mod Kit. VapX Geyser Empt pod cartridge, made of PC. VapX Geyser Empty Cartridge adopts dual pop switch for pod pop up & filling and dual AFC tech, variable stepless airflow control system. The 5.0ml 75W Air Mesh Pod is best for Loose MTL / Loose DL vape.
Original VapX Geyser Pod System Replacement Empty 6.5ml 45W Air Mesh Pod Cartridge(1 PC) $6.99
VapX Geyser Replacement Empty Pod is designed for Vapx Geyser 100W Pod System Vape Mod Kit. VapX Geyser Empt pod cartridge, made of PC. VapX Geyser Empty Cartridge adopts dual pop switch for pod pop up & filling and dual AFC tech, variable stepless airflow control system. The 6.5ml 45W Air Mesh Pod is perfect for Tight MTL / Restricted DL vape
Original VapX Geyser Pod System Replacement Empty 6.5ml 45W Pod Cartridge(1 PC) $6.99
VapX Geyser Replacement Empty Pod is designed for Vapx Geyser 100W Pod System Vape Mod Kit. VapX Geyser Empt pod cartridge, made of PC. VapX Geyser Empty Cartridge adopts dual pop switch for pod pop up & filling and dual AFC tech, variable stepless airflow control system. The 6.5ml 45W Air Pod is perfect for Tight MTL / Restricted DL vape
Original BP MODS Pioneer MTL RTA Replacement Blade Top Cap $9.99
The Original BP MODS Replacement Blade Top Cap is made from Stainless Steel with DCL Coating and Suitable for Pioneer MTL RTA Vape Atomizer.
Original BP MODS Pioneer MTL RTA Replacement MTL / DL Long Tank Kit $19.99
The Original BP MODS Replacement MTL / DL Long Tank Kit is made from Stainless Steel with DCL Coating and Suitable for Pioneer MTL RTA Vape Atomizer.
Original BP MODS Pioneer MTL RTA Replacement Tank Tube $3.50
The Original BP MODS Replacement Tank tube is made from PCTG and Suitable for Pioneer MTL RTA Vape Atomizer.
Original Auguse Era MTL RTA Vape Atomizer Replacement Hexagonal Tank Tube $4.99
The Auguse Replacement Top Cap Tank Tube is designed for Auguse Era MTL RTA. It is made from PCTG.
Original Auguse Era MTL RTA Vape Atomizer Replacement Round Tank Tube $4.99
The Auguse Replacement Top Cap Tank Tube is designed for Auguse Era MTL RTA Vape Atomizer. It is made from PCTG.
Старый 20.08.2020, 06:25 Автор темы   720
3FVAPE
Original GeekVape Aegis Boost 40W 1500mAh VW Pod System Kit Luxury Edition original price $40.99, now only $34.99
The Original GeekVape Aegis Boost Pod System Vape Kit Luxury Edition, constructed of Zinc Alloy & Leather & Silicone, is a lightest and toughest pod mod. GeekVape Aegis Boost Pod Vape Kit Luxury Edition works with 1500mAh battery with max 40W output. GeekVape Aegis Boost Luxury Edition adopts AS chip with IP67 waterproof, shockproof and dustproof and 0.42 inch OLED screen to show the vaping data clearly. Aegis Boost cartridge maintains two separate mesh coil (0.6ohm / 0.4ohm) to support MTL and DTL vaping. Aegis Boost pod comes with 3.7ml with top filling design.
Original Wotofo OFRF NexMESH Pro Sub Ohm Tank Clearomizer Vape Atomizer original price $34.95, now only $23.99
Original Wotofo OFRF NexMesh Pro Tank Vape Atomizer is an upgraded version of nexMESH Sub Ohm Vape Tank. It is famous as the first mesh coil and parallel coil combo core in the world, which will bring you the ultimate awesome taste. And it features ergonomic 810 Delrin drip tip, convenient top filling system and the most compatible 510 threading connection. Besides, it adopts adjustable bottom airflow so you can choose the flavor and cloud you like. Moreover, compatible with H15 Coil, H12 Coil, H11 Coil and H13 Coil (H15 Coil / H12 Coil included, H11 Coil / H13 Coil not included), you are allowed to obtain DIY fun via H17 RDC (RBA Deck not included). Last but not least, the tank features 4.5ml straight PCTG tube and 6.0ml bubble glass tube when it comes with single coil head, and 3.5ml straight PCTG tube and 5.0ml bubble glass tube when it utilizes dual coil head.
Original Smoant Pasito II 2 V2 Replacement Empty Pod Cartridge(1 PC) $5.99
The Original Smoant Pasito II Pod Cartridge is specially designed for Smoant Pasito II Pod System Vape Kit. It can hold 6.0ml large e-juice capacity, which can guarantee your long-lasting vape. And it features ergonomic 510 drip tip and the most compatible 510 connector. In addition, it adopts convenient side filling system and top airflow design for smooth flavor. Besides, it is compatible with all Pasito and Knight 80 Coils, and the newly designed K3 0.6ohm Half-DTL coil. 1 PC in each pack.
Original Smoant VIKII Pod System Replacement Pod Cartridge(2 PCS) $6.99
The Original Smoant VIKII Replacement Pod cartridge is suitable for Smoant VIKII Pod System Vape Kit. Smoant VIKII Pod cartridge is made of PCTG, and holds 2.0ml capacity with side filling design and 1.2ohm Kanthal wire with tea tree fiber cotton for pure flavor. Smoant VIKII adopts both-side connection design for stable vaping.
Original Smoant Pasito II 2 Pod System Replacement Coil Base(1 PC) $2.99
The Original Smoant Pasito II V2 2 Replacement Base is designed for Smoant Pasito II V2 2 Pod System Vape Kit. With the Smoant Pasito II V2 2 base, Smoant Pasito II V2 2 pods can be compatible with Smoant Pasito 2 coils. The Smoant Pasito II Base is specially designed for Smoant Pasito II Kit / Smoant Pasito II Cartridge. The Smoant Pasito II base is the most part between Smoant Pasito II battery and Smoant Pasito II pod.
Original Smoant Pasito II V2 2 510 Adapter Connector for 510 RDA / RTA / RDTA Sub Ohm Tank $4.99
The Smoant Pasito II V2 2 510 Adapter is suitable for Smoant Pasito II V2 2 Pod System Vape Starter Kit. With this 510 adapter, you can use RDA / RTA / Sub Ohm Tank Vape Atomizer on the Smoant Pasito II V2 2 Pod System.
Original Smoant K-1 Mesh Coil Head for Pasito II / Pasito / Knight 80 Pod System(3 PCS) $6.99
The Original Smoant K-1 0.3ohm Mesh Coil head is applicable to Smoant Pasito II Kit, Pasito Kit and Knight 80 Pod System Vape Kit.
Original Smoant K-2 Dual Mesh Coil Head for Pasito II / Pasito / Knight 80 Pod System(3 PCS) $7.99
The Original Smoant K-2 0.4ohm Dual Mesh Coil Head is applicable to Smoant Pasito II Kit, Pasito Kit and Knight 80 Pod System Vape Kit.
Original Smoant K-3 Half-DTL Mesh Coil Head for Pasito II / Pasito / Knight 80 Pod System(3 PCS) $6.99
The Original Smoant K-3 0.6ohm Half-DTL Mesh Coil Head is applicable to Smoant Pasito II Kit, Pasito Kit and Knight 80 Pod System Vape Kit.
Original Smoant K-RBA Coil Deck for Pasito II / Pasito / Knight 80 Pod System(1 PC) $6.99
The Original Smoant K-RBA Coil Deck is suitable for Pasito II / Pasito / Knight 80 Pod System Vape Starter Kit. The RBA is best for 0.3~2.0ohm.
Поиск в этой теме:
Copyright ©2007 - 2023, FONAREVKA.RU
Время генерации страницы 0.21737 секунды с 19 запросами
