Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02 Адрес: Shenzhen
Original Vapeccino Mate 2 450mAh Pod Kit $22.99
The Vapeccino Mate 2 Pod Kit features 450mAh built-in battery and 1.5ml liquid capacity. The battery only needs 30 minutes for a full charge. It adopts innovative GCT heating technology and 1.5ohm ceramic coil which drives the flavor better and clouds fresher. The innovative leak-proof function shines itself that users could taste the great flavor and discard the worries of leakage problem at the same time. Whats more, it is equipped with an LED indicator to remind users of the power condition. ![]() Original Ohm Vape AIO 42W Box Mod Pod Kit $42.99 The Ohm Vape AIO Pod System Box Mod Kit is a portable vaping pod system, which is powered by single 18650 rechangeable battery (Not included). This device is configured to stop firing if the chipset recognizes: short circuit, reverse battery connection, low voltage, battery overcharge, battery discharge or dry burn. The device has three types of charging indicator to indicate the battery capacity: Green (61%~100% Charge), Blue (21%~60% Charge), and Red (1%~20% Charge). While charging, the battery light will pulse. Once the device is fully charged, the battery light will stop pulsing and turn off after ten minutes. This device has four different power levels. Click the fire button once and then the power level button to start navigation through the four settings. Each click will change to the next setting. After three seconds, the Ohm Vape AIO will set the power to the mode selected and the light indicator will blink twice for confirmation. ![]() Hussar The End RTA Replacement PC Tank Tube Clone + Stainless Steel Drip Tip $4.99 The Hussar The End RTA Clone Replacement Set consists of PC Tank Tube and Stainless Steel Drip Tip. The set is suitable for Hussar The End Style RTA. ![]() Original Vapeccino Mate 2 Pod System Replacement Pod Cartridge with 1.5ohm Ceramic Coil $5.99 The Vapeccino Mate 2 Pod System Replacement Pod Cartridge is designed for Vapeccino Mate 2 Pod System Starter Kit. The pod comes with 1.5ml juice capacity and 1.5ohm MTL ceramic coil which provides a better and longer lasting flavor. More importantly, Vapeccino Mate 2 Pod MTL Ceramic Coil is a kind of material with high stability and high temperature resistance, which can produce rich vapor without burnt taste. 2 PCS / Pack. ![]() Original Damn Vape Diamond MTL RTA Replacement Tank Tube 2.59 The Damn Vape Diamond MTL RTA Replacement Tank Tube is designed for Damn Vape Diamond MTL RTA. The Tank Tube features 2ml juice capacity. ![]() Original Damn Vape Diamond MTL RTA Replacement Bubble Tank Tube $2.99 The Damn Vape Diamond MTL RTA Replacement Tank Tube is designed for Damn Vape Diamond MTL RTA. The Tank Tube features 3.5ml juice capacity. ![]() Original Ohm Vape AIO Pod System Replacement Pod Cartridge + Coil Head $7.99 The Original Ohm Vape AIO Pod System Replacement Pod Cartridge with Gold Coil is designed for Ohm Vape AIO Pod System Kit. ![]() Original Yocan Groote 350mAh Battery Box Mod for 510 Thread Atomizer $11.79 The Yocan Groote Box Mod is a super compact box mod which is highly compatible with 510 thread oil atomizers around 9~11.5mm in width. Small and discreet, it fits in the palm of your hand. It is powered by 350mAh built-in battery and supports Micro-USB charging. It can be fully charge in only 30 minutes. Having 3 voltage levels, it can meet your different vaping needs. It is specially built with hanging hole, you can use it with your lanyard. It boasts a 10-second pre-heat function giving you the advantage of pre-heating your cartridges when you vape. It is designed with an oil level window, which makes you know exactly when it's time to refill your oil. The magnetic 510 thread adapter is included. Atomizer is not included. ![]() Original Yocan Kodo 400mAh Battery Box Mod for 510 Thread Atomizer $7.15 The Yocan Kodo Battery Box Mod is a portable palm-sized atomizer battery mod. It is powered by 400mAh built-in battery. The Kodo Battery can match all the 510 threading oil atomizers on the market. It features 10s pre-heat function which will deliver you smooth and flavor vapor. The preheat function will turn off automatically once it's done. Featuring three different power levels at low voltage, it ensures the best vaping experience based on your needs. It is designed with the hanging hole, which provides the quick accessibility. It supports Micro-USB charging and can be fully charged in only 30 minutes. Atomizer is not included. ![]() Original Yocan Wit 500mAh Battery Box Mod for 510 Thread Atomizer $11.59 The Yocan Wit Box Mod is a compact, portable and stylish cartridge mod, which allows you to carry around with ease. Powered by 500mAh built-in battery and 10 second pre-heat function, it helps you achieve longer vaping sessions without having to sacrifice the quality of vapor. And it could be fully charged in only 30 minutes with a Micro-USB cable. It is also designed with an oil level window to provide convenience for you. Moreover, it uses a highly compatible 510 threading adapter with magnetic connection that can safely and securely fit with most 510 thread oil atomizers between the size of 9~11.5mm. Last but not least, to meet your individual demands better, it provides 3 different power levels: Low, Middle and High. Atomizer is not included. ![]() |
Reload MTL RTA Clone $8.99
The Reload MTL RTA Clone is constructed from stainless steel (Body) and glass (Tank) in 22mm diameter. It has a 2ml juice capacity tank. The RTA supports top filling system and bottom adjustable airflow. ![]() Original Vapor Storm Ares 12W 560mAh AIO Pod Kit original price$17.50, now only$11.89 The Vapor Storm Ares AIO Starter Kit is a portable and light kit that easy to hold. Powered by 560mAh built-in battery and comes with 1.6ml e-juice capacity, which will meet you need for long vaping. With the 1.3ohm coil resistance, 3.2V~4.0V Voltage Range and 12W Maximum Wattage, you can enjoy the great and various vaping experience. The different colors of the indicator can show the power status and there is a lanyard design, which will help you to use this kit more convenient. What' more, the four protection features: over puff protection, short circuit protection, over discharging protection and low power alert can ensure the safety when vaping. ![]() Original Wismec Preva DNA AIO 20W 1050mAh Box Mod Pod System Starter Kit $74.95 The Wismec Preva DNA is a new high-end pod device, which is powered by 1050mAh Built-in Battery and comes with a 3ml Pod Cartridge. With a large built-in 1050mAh battery, you can vape all day long without caring about your battery level. Four different LED lights indicate battery levels. Just press twice, you will get a clear battery information. The unique diagonal design with carbon fiber panel makes it especially eye-catching. It features not only a stylish appearance and compact size, but also a powerful Evolv DNA GO chip, which operating like a tiger with added wings. Whats more, the PREVA DNA also comes with a 0.25ohm cartridge and 0.5ohm cartridge, which will satisfy both massive cloud lovers and flavor pursuers. The Pod Kit supports adjustable top-airflow system, allowing you complete freedom to adjust the airflow. With the top-airflow system, DNA can prevent e-juice leakage effectively and make the vaping experience incomparable. Furthermore, DNA features siding cover top-filling design, it makes the refilling quite conveniently. Multiple protections provides you a better vaping use. ![]() Original Kangvape Klasik V2 650mAh VV Box Mod E-Cigarette Starter Kit with K5 Atomizer $11.85 The Kangvape Klasik V2 Kit consists of a Klasik V2 Box Mod and a 0.5ml Atomizer. Powered by a built-in 650mAh battery, Klasik V2 comes with intuitive LED light that can show voltage and battery status. The compact size is easy to operate when you hold it in the hand. Pressing the fire button twice, automatically preheat for 15 seconds. On the mod screen, you will see the different color that displays the current voltage. Red, blue, green and white shows current-voltage 3.2V / 3.5V / 3.8V / 4.1V. It can bring you simple yet amazing vape with durable working time. ![]() Original OBS Prow 11W 300mAh AIO E-cigarette Pod System Starter Kit original price$28.99, now only$17.99 The OBS Prow Pod Kit is an AIO e-cigarette with a cartridge system, for a comfortable handling and great vape results. the OBS Prow Kit is supple in the hand, is easy to use and is operated with only one button (Fire-Key). The Prow has a built-in 300mAh battery, the used capacity can be conveniently charged as usual with the included USB cable. The small LED lights transmit the current battery level. Thanks to the chipset, this kit has numerous protection circuits for safety and can be operated with an output power from 7W to 11W. On the one hand, the cartridge has a 1.5ml juice capacity, which is filled from below with liquid and, on the other hand, an integrated OCC Coil, with a resistance of 1.4ohm, for aromatic baking steaming (MTL). The internal Airflow ensures optimum steam temperature and the ideal airflow for ventilation of the coil. ![]() Kindbright 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $3.99 The Kindbright 510 Replacement Drip Tip is made of PEI (Mouthpiece) and Stainless Steel (Base). It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Vapor Storm Ares Pod Kit Replacement Pod Cartridge with 1.3ohm Coil - 1.6ml (3 PCS) original price$8.00, now only$5.99 The Vapor Storm Ares Pod Cartridge is designed for Vapor Storm Ares Kit. It features 1.6ml e-juice capacity and 1.3ohm coil. Just get it as spare parts for your Vapor Storm Ares Kit. 3 PCS / Pack. ![]() Original Smoant Replacement Ni80 Coil Head for Battlestar Baby Pod Kit - 1.2ohm (3 PCS) original price$6.99, now only$4.99 The Smoant Battlestar Baby Replacement Ni80 Coil Head is designed for Smoant Battlestar Baby Pod Kit, it features a 1.2ohm coil resistance. 3 PCS / Pack. ![]() Original Smoant Replacement Mesh Coil Head for Battlestar Baby Pod Kit - 0.6ohm (3 PCS) original price$6.99, now only$4.99 The Smoant Battlestar Baby Replacement Mesh Coil Head is designed for Smoant Battlestar Baby Pod Kit, it features a 0.6ohm coil resistance. 3 PCS / Pack. ![]() Original Smoant Battlestar Baby Pod Kit Replacement Pod Cartridge + with 0.6ohm Mesh + 1.2ohm Ni80 Coil original price$9.99, now only$5.99 The Smoant Pod Cartridge consists of a Replacement Pod and two replacement coils. They are designed for Smoant Battlestar Baby Pod Kit. ![]() Original Smoant Battlestar Baby Pod Kit Replacement USB-C Charging Cable / Lanyard $3.99 The Smoant Replacement USB-C Charging Cable is designed for Battlestar Baby Pod Kit. You can use it as a lanyard or the cable if necessary. ![]() Original Wismec Preva DNA Pod Kit Replacement Pod Cartridge with Coils $11.95 The Wismec Preva DNA Replacement Pod is designed for Wismec Preva DNA Pod Kit. It is a high-quality 3ml refillable cartridge built with a dynamic top airflow control drip tip and two types of coils: 0.25ohm DL (Vapor-Focused) and 0.5ohm MTL (Flavor-Focused). ![]() Original OBS Prow Pod Kit Replacement Pod Cartridge with 1.4ohm Coil original price$11.99, now only$7.99 The OBS Prow Replacement Pod is designed for OBS Prow Pod Kit, which is made of food-grade PCTG, featuring a single juice viewing window, 1.5ml pod juice capacity and comes with an integrated 1.4ohm OCC Coil, and can be bottom refilled via a hinged dual port filling system. 3 PCS / Pack. ![]() |
Original Timesvape Notion MTL Hybrid Mechanical Mod original price$48.99, now only$34.99
The Timesvape Notion MTL Mechanical Mod is a beautifully crafted Hybrid mod that has been designed for MTL users, which is constructed from stainless steel and powered by single 18350 / 20350 battery (Not included) The ergonomic design ensures a comfortable grip and fits 22mm or 24mm diameter atomizers to sit flush when using the supplied adaptors. Featuring a constant contact, spring-loaded button and hybrid 510, the Notion MTL Mod is definitely a pocket-friendly hard hitting device.The Notion MTL Mod will look great with almost any RDA / RTA that you decide to place on top. ![]() Immersion Atomizer for SXK MTL RBA / Vapeshell / Inders / Exocet $14.99 The Immersion Atomizer is constructed from stainless steel and PEI material in 22mm diameter. The Atomizer is suitable for SXK MTL RBA / Vapeshell / Inders / Exocet. This atomizer will change your SXK MTL RBA / Vapeshell / Inders / Exocet a RTA atomizer. ![]() Value Geek MTL RTA Clone $25.99 The Value Geek MTL RTA Clone is constructed from 316 Stainless Steel material in 22mm diameter. The RTA can provide you mouth to lung (MTL) vaping experience. It supports top refilling and bottom airflow control system. ![]() Original Bohr Pury 280mAh Pod System Starter Kit $14.99 The Bohr Pury Pod Kit is constructed from aluminum and plastic material, which has classic appearance which adopts fashionable brush finish and matt finish. Simple and elegant. No matter in meeting, party or home, Pury will be your best choice. The Pury cartridge refillable design which enable to use many times. Two filling ports are available in the top of cartridge and it is easy to refill. The cartridge adopts magnetic connection design and insert it into the Pury battery easily. The Pury Pod Kit is powered by 280mAh built-in battery, which comes with a 0.9ml pod and 1.3ohm coil to satisfy your daily vaping demands. Pury is equipped with a fast charging by Type-C, charging time less than 30 minutes. Passthrough technology supports charging while vaping. There are three colors LED light that show battery status when vaping. Moreover, it also comes with catridge detect function. Multiple protections make your vaping experience more safer. ![]() Original OBS Alter 70W 2500mAh VW Box Mod Pod System Starter Kit original price$59.90, now only$43.99 The OBS Alter Pod Kit is powered by 2500mAh built-in battery, it can bring you durable and stable vaping experience with 70W max output. Alter Pod Kit supports adjustable airflow system for Nic salt base and it features top filling design for easy refill. The Pod Kit comes with Sub-Ohm & Nic Salt base for both high / low package, it is compatible with M1 / M3 / NX / SX coils at the same time. There are two types of pod capacity : 3.5ml or 5ml for you to choose to meet your different vaping demands. The 2.5D toughened glass makes it durable and delicate. ![]() Original CoilART Blazar Mosfet Semi-Mechanical Tube Mod + MTL RTA Kit original price$80.99, now only$53.99 The CoilART Blazar is a small and neat "cigarette" kit, which is easy to carry. CoilART Blazar MTL RTA Kit is powered by a 18350 battery (Not included), which is constructed from stainless steel and resin.The Mod Kit features a 2ml E-juice capacity tank. CoilART Blazar MTL RTA Kit provides a pure flavor and an excellent atomization experience in a mouth-to-lung (MTL) manner. Thr Mod Kit features side mounted firing button and bottom adjustable battery cap. Also, it has function of child proof and leaking proof. What's more, the RTA comes with single coil build deck, and the mod kit is equipped with chip protection function. The Mosfet supports four kinds of protection: low / high resistance protection, over-heat protection, short circuit protection, reverse polarity protection. ![]() Original Squid Industries Squad VW Box Mod Pod System Starter Kit with RTA $56.99 The Squid Industries Squad Kit is a revolutionary multiple-functional VW pod system Kit which is compatible with three kinds of Atomizers: Refillable Metal Atomizer (not included), Disposable Pod (not included) and RTA Atomizer (included) to satisfy all your vaping needs. The 2ml RTA Atomizer supports single coil build. Powered by 950mAh built-in battery with innovative chipset, the Squid Industries Squad Battery supports 5 to 30W output with advanced VW working modes. And with the OLED Screen, you can know the working conditions clearly. Rebuildable Atomizer RTA / RBA Version ![]() Original Acrohm Fush Nano Pod System Replacement Pod Cartridge(2 PCS) $4.99 The Fush Nano Pod Cartridge is specially designed for Fush Nano Pod Kit. It comes with 1.5ml E-juice capacity. And it adopts top filling design to reduce e-juice leaking and provide you with great convenience. It could also switch from smooth to tight for different nicotine tastes. Besides, it features 7W output of airflow control and 10W output of button switch. 2 PCS / Pack. ![]() Original Bohr Pury Pod System Replacement Pod Cartridge(4 PCS) $7.99 The Bohr Pury Pod Cartridge is designed for Bohr Pury Pod Kit. It comes with 0.9ml E-juice capacity and supports 1.3ohm coil (Cotton). 4 PCS / Pack. ![]() Original OBS Alter Pod System Replacement Pod Cartridge w/o Coils - 5ml $3.99 The OBS Alter Pod Cartridge is designed for OBS Alter Pod Kit, it features 5ml juice capacity and compatible with SX / NX Coil (Nic Salt Base). The Coil is not included. ![]() Original OBS Replacement SX Coil Head for Alter Pod Kit - 0.15ohm (5 PCS) $9.99 The Replacement SX Coil Head is designed for OBS Alter Pod Kit, it is compatible with 2ml / 5ml OBS Alter Pod Cartridge and features 0.15ohm coil resistance. And the recommened wattage range is from 20W to 25W. 5 PCS / Pack. ![]() Original OBS Replacement NX Coil Head for Alter Pod Kit - 1.4ohm (5 PCS) $9.99 The Replacement NX Coil Head is designed for OBS Alter Pod Kit, it is compatible with 2ml / 5ml OBS Alter Pod Cartridge and features 1.4ohm coil resistance. And the recommened wattage range is from 8W to 12W. 5 PCS / Pack. ![]() |
Quake V2 Solo Hybrid Mechanical Mod Clone $14.99
The Quake V2 Solo Hybrid Mechanical Mod Clone is constructed from Brass. The compact hybrid mech mod is powered by 18350 battery (Not included). It features side button is designed and manufactured to be extremely comfortable and reduce its size to the minimum expression. ![]() Original Innokin Zenith MTL Sub Ohm Tank Atomizer $24.99 The Original Innokin Zenith Atomizer is constructed from stainless steel (body) and glass (tank) in 24.7mm diameter, which is a collaboration between Phil Busardo, Dimitris Agrafiotis, and Innokin which aims to create an easy and intuitive mouth to lung (MTL) vaping with replaceable coil heads. It adopts one 1.6ohm Kanthal coil for a cooler vape at lower wattage and one 0.8ohm Kanthal coil for a slightly warmer vape at higher wattage. Together with convenient top fill twist design that will automatically shut off the liquid flow when filling in order to prevent flooding and gurgling, adjustable bottom airflow control and easy replacement coil design, Zenith is absolutely a good choice for MTL lovers. ![]() Origianl Timesvape Diesel RTA original price$34.90, now only$24.99 The Timesvape Diesel RTA is constructed from stainless steel (body) and glass (tank) in 25mm diameter, which is machined at 27mm and tapers to 25mm at the top and bottom. Featuring a top fill, leak proof design, the Diesel incorporates a honeycomb style airflow to the coils for a smooth vape and intense flavor. It comes with a 2ml glass tank and can even hold up to 5ml of your favorite juice with the included Bubble Tank. ![]() Original asMODus x Thesis Barrage RDA with BF Pin original price$34.99, now only$25.99 The asMODus x Thesis Barrage RDA is constructed from stainless steel in 24mm diameter, which is a collaboration between asMODus and VapingWithThesis. With a large spack on the dual posts build deck, users can build the coils with ease. In addition, the Barrage utilizes a top airflow system which is hidden within the heat sink fins giving it a seamless design and features leakage proof. The Barrages airflow is non-adjustable, but provide the perfect amount of draw resistance for deep lung inhales. Plus the wide bore Goon-style 810 drip tip, Barrage will bring you more airflow and great taste. ![]() Original Fumytech Bdvape Precisio MTL DLC RTA $46.90 The Fumytech Precisio MTL RTA is constructed from stainless steel (Body) and Polish Ultem (Tank). The 22mm diameter RTA has a 2.7ml juice capacity tank. The airflow control can be used from MTL to middle DL. Double airflow hole inside provides more power and blow to the coil directly. ![]() Original Innokin Endura 13.5W 1300mAh Vape Pen with Prism T18 II Sub-Ohm Tank Starter Kit $26.99 The Innokin Endura T18 II Vape Pen Kit consists of Endura Vape Pen and T18 II Tank Atomizer, which is the reincarnation of the original Endura T18 vape pen, powered by an improved integrated 1300mAh rechargeable battery, plug "n" play coil system, and is paired with the Prism T18.II Sub-Ohm Tank. In addition, the Endura T18 II starter kit has access to the Innokin Prism T18 II coil family, utilizing the plug 'n' play system for faster and effortless coil changes. Aside from using the improved coils, this starter kit is compatible with T18 / T22 replaceable coil (1.5ohm). Furthermore, this starter kit comes with a nifty magnetic top cap, threaded top refill system, and metal cage to protect the inner glass from breaks from falls and drops. ![]() Original Innokin Endura 18W 1500mAh Battery with Prism T20-S Sub-Ohm Tank Starter Kit $24.99 The Innokin Endura T20-S Starter Kit consists of T20-S Battery and T20-S Sub-Ohm Tank, it presents an elegant, pen-style system with 1500mAh internal Li-Po battery along with a MTL focused atomizer tank with Prism S Coil Technology. The Endura T20-S measures 20mm in diameter with simplified design elements to create a beautiful system for every day. The device is single button operated with a tri-color LED power indicator that shows remaining power levels and charging status. The Endura T20-S integrates a direct voltage based output with a maximum wattage of 18W and a suite of safety protection. The included Prism T20-S Tank features a 2ml juice capacity, convenient threaded top-fill, dual bottom airslots, and the utilization of the Prism S Coil Technology. ![]() Original Innokin Plexus Z Replacement Coil Head for Zenith MTL Tank / Zlide D22 Tank - 0.8ohm (15~18W) (5 PCS) $8.99 The Plexus Z Coil features 0.8ohm coil resistance and comes with organic cotton, which is compatible with Innokin Zenith MTL Tank, Innokin Zenith D22 Tank, Innokin ZLIDE Tank, Innokin ZLIDE D22 Tank (Part of the Innokin ADEPT Kit). The wattage range of this coil is from 15W to 18W. 5 PCS / Pack. ![]() Original Innokin Plexus Z Replacement Coil Head for Zenith MTL Tank / Zlide D22 Tank - 1.6ohm (10~14W) (5 PCS) $8.99 The Plexus Z Coil features 1.6ohm coil resistance and comes with organic cotton, which is compatible with Innokin Zenith MTL Tank, Innokin Zenith D22 Tank, Innokin ZLIDE Tank, Innokin ZLIDE D22 Tank (Part of the Innokin ADEPT Kit). The wattage range of this coil is from 10W to 14W. 5 PCS / Pack. ![]() Original Innokin Plexus Z Replacement Coil Head for Zenith MTL Tank / Zlide D22 Tank - 0.5ohm (14~19W) (5 PCS) 10.59 The Plexus Z Coil features 0.5ohm coil resistance and comes with organic cotton, which is compatible with Innokin Zenith MTL Tank, Innokin Zenith D22 Tank, Innokin ZLIDE Tank, Innokin ZLIDE D22 Tank (Part of the Innokin ADEPT Kit). The wattage range of this coil is from 14W to 19W. 5 PCS / Pack. ![]() Original Ebossvape Replacement Pod Cartridge with 1.4ohm Ceramic Coil for Juul Pod Kit $1.99 The Ebossvape Replacement Pod Cartridge is designed for Juul Pod Kit, it features 0.5ml juice capacity and 1.4ohm ceramic coil. ![]() Original Ebossvape Replacement Pod Cartridge with 1.8ohm Cotton Coil for Juul Pod Kit $1.99 The Ebossvape Replacement Pod Cartridge is designed for Juul Pod Kit, it features 1.0ml juice capacity and 1.8ohm cotton coil. ![]() Original Aspire AVP AIO Kit Replacement Pod Mesh Coil Standard Version (2 PCS) original price$12.99, now only$7.99 The Aspire AVP Replacement Pods are a set of 2.0ml food-grade plastic pods, featuring a 0.6ohm integrated mesh coil, and is refilled via bottom fill system, with two silicone stoppers to prevent any pesky leaks and spills. This product is Chinese Version, which comes with manual / Package in Chinese. ![]() |
Original Wotofo Dyadic 200W VW Squonk Box Mod $59.99
The Wotofo Dyadic 200W Squonk Box Mod is powered by Dual High Amp 18650 battery (Not included), 5~200W output range, and can hold up to 8.5ml of E-Juice within the silicone confines of the bottom fed squonk bottle. Furthermore, the squonk bottle possesses a side refilling system, eliminating the need to remove the squonk bottle before refilling, instead, the side fill system facilitates refilling on-the-go. Constructed from durable zinc-alloy and velvet rubber coating, the Dyadic 200W Squonk Box Mod combines a durable and protective outer chassis with sleek manufacturing to create a highly desirable box mod that will survive drops and falls, while looking good doing so. Outputting in an ultra rapid 0.0001s fire rate, the Dyadic box mod can go as low as 0.05ohms to accommodate even the craziest of coil builds. ![]() Original Kamry K1000 MINI Epipe Kit Replacement Clearomizer with 1.4ohm Cotton Coil $2.99 The Kamry K1000 MINI Atomizer is especially designed for Kamry K1000 MINI Epipe Kit. It features a capacity of 1.2ml and 1.4ohm resistance for great taste and big clouds. ![]() Original HorizonTech Falcon II Sub Ohm Tank Atomizer $25.99 The Horizon Falcon II Sub Ohm Tank Atomizer is new version of HorizonTech Falcon series, which is constructed from stainless steel (Body) and Pyrex Glass (Tank Tube), it features large 5.5ml e-juice capacity can meet your daily vaping demand. Horizon Falcon II Tank adopts durable Pyrex glass and high quality stainless steel material, plus resin drip tip, looks very beautiful. The refilling design of Falcon II tank is very special, click the button to open top cap. The Falcon II Sub Ohm Tank supports bottom airflow control and top refilling system. ![]() Original Oumier Wasp Nano MTL RTA original price$16.00, now only$14.99 The Oumier Wasp Nano MTL RTA is constructed from stainless steel (Body) and Glass (Tank), it comes with 22mm diameter and 2ml juice capacity tank. It features adjustable double-sided airflow system for good flavor. It supports Single Coil Building. Adopting the easy top filling design with the detachable inner chamber, it effectively avoids leakage. ![]() Original Kamry K1000 Mini 900mAh Pipe Battery Mod with Clearomizer Kit $22.99 The Kamry K1000 Mini Kit consists of a K1000 Mini Pipe Battery and a K1000 Mini Clearomizer. With the small round ergonomically classic pipe shape design, the Kamry K1000 Mini Kit is constructed from high-quality 6063 aluminum alloy and plasitc material, comfortable to hold in the palm. The Kamry K1000 Mini Battery is powered by built-in 900mAh battery and can charge via the Micro-USB port, 3 levels working voltage adjustable, pressing the top firing button 3 times in 3 seconds to adjust the working voltage. And there is an intelligent LED indicator light to show the voltage level. What's more, the K1000 Mini Clearomizer comes with 1.2ml e-juice and pre-installed 1.4ohm coil to provide great taste and big clouds. ![]() Original Joyetech 1000mAh Battery Box Mod with Exceed X Atomizer Starter Kit $39.99 The Joyetech Exceed X Starter Kit consists of an Exceed X Battery and an Exceed X Atomizer, which is an updated starter kit with 1000mAh larger built-in battery. Highlighted by its minimalist and elegant design, the kit features a brilliant sheen-like colors embedded in a streamlined structure and it stands out from the others by its design, purity and elegance. Moreover, the Exceed X atomizer with 1.8ml e-juice capacity contains a childproof filling system which makes the filling more efficient and secure. With its compact size, you can bring the Exceed X everywhere with you. Besides, its power levels are adjustable and the color of the indicator light varies depending on the battery capacity. The power control indicator with three levels is designed for a better power monitoring. Compatible with all EX series coils, EX-M 0.4ohm Coil / EX 1.2ohm MTL Coil included. What's more, With TYPE-C fast charging port, it only takes 30 minutes to fully charge the battery. ![]() Original Sense Orbit Baby 460mAh Vape AIO Pod System Starter Kit $25.99 The Sense Orbit Baby Pod System Starter Kit is constructed from Zinc Alloy and PC material, which is a portable pod system vape AIO device with beautiful patterns and elegant design. Powered by 460mAh built-in battery, the Orbit Baby Pod Kit supports stable and high performance vaping with 2 working modes: Normal / Strong to meet your different vaping demands and bring you an excellent vaping experience. Moreover, it comes with a 2ml refillable pod with convenient Side Fill system and side open design for easy refilling. And it comes with Orbit XS 1.0ohm replaceable mesh coils. It is the best choice for DL and MTL lovers. ![]() Kindbright 5-in-1 Shortfill Cap Opener Tool for Juice / E-Liquid Bottle $2.99 The Kindbright 5-in-1 Shortfill Cap Opener Tool Clone is made of Zinc alloy, it is convenient to open juice cap of 10ml, 60ml, 120ml, and most 23~24mm caps can be opened by Reewape 5-in-1 shortfill. ![]() Kindbright 5-in-1 Shortfill Cap Opener Tool for Juice / E-Liquid Bottle $2.99 The Kindbright Clone 5-in-1 Shortfill Cap Opener Tool is made of Zinc alloy, it is convenient to open juice cap of 10ml, 60ml, 120ml, and most 23~24mm caps can be opened by Reewape 5-in-1 shortfill. ![]() Original HorizonTech Replacement Sector Mesh Coil Head for Falcon II Tank $10.99 The HorizonTech Sector Mesh Coil is designed for Falcon II Tank, it features bamboo fiber 0.16ohm coil resistance. 3 PCS / Pack. ![]() Original HorizonTech Replacement Bubble Tank Tube for Falcon II Tank $2.99 The HorizonTech Bubble Tank Tube is designed for Falcon II Tank, it features 5.5ml juice capacity. ![]() Original Sikary eFox Pod System Replacement Pod Cartridge with 2.0ohm Coil $2.59 The Sikary eFox Replacement Pod Cartridge is designed for Sikary eFox Pod Kit, it features a 1.5ml juice capacity. With the pre-installed 2.0ohm coil, the Sikary eFox Pod is fit for regular e-juice and nicotine salt e-juice with pure flavor and optimal cloud. ![]() Original eXvape Expromizer V4 Replacement Glass Tank Tube + SS Extension Kit $5.95 The eXvape Expromizer Replacements consist of a Glass tank tube, a Stainless Steel extension kit, and two O-rings. They fit for eXvape Expromizer as a replacement part. ![]() |
Original Steam Crave Hadron 220W TC VW Box Mod original price$109.99, now only$96.99
The Steam Crave Hadron 220 Mod, adopted the innovative YiHi SX480 chipset, is powered by Dual 18650 / 21700 batteries (Not included) with a maximum output power of 220W. The large OLED screen displays pertinent vaping data, including power output, battery life, puff, flavor mode, etc. Detailed and simple user interface. The Hadron 220 Mod is perfect match with Aromamizer Plus, Glaz V2 and other atomizers with diameter from 25mm to 35mm. ![]() Original Hippovape Kudos 80W VW Squonk Box Mod original price$54.90, now only$33.99 The Hippovape Kudos Box Mod is powered by external single 18650 battery and the power output of this mod is from 3W to 80W. The Kudos Squonker Mod comes with a 7ml bottle feeding tube capacity for ample juice storage. The Hippovape Kudos Mod supports slide-to-refill system for easy refilling and the Type-C charging system has a high compatibility. ![]() Original Uwell Evdilo 200W TC VW Box Mod $57.99 The Uwell Evdilo TC VW Box Mod is constructed from Zinc Alloy, PC, and Stainless Steel, it supports dual 18650 / 20700 / 21700 batteries (Not included). Press down the battery chamber switch to release the cover. Two battery sleeves are included in the battery chamber. The new BEIN chip offers reliable performance and 0.008s fast firing capabilities. It is also dust-proof and moist-proof, prolonging the product life, and protecting user safety. The dual batteries give more possibilities to the cloud chaser. ![]() ShenRay Value Greek MTL RTA Clone with BF Pin $30.50 The ShenRay Value Greek MTL RTA Clone is constructed from 316 stainless steel (Body) and glass (Tank) in 22mm diameter. The RTA supports top refilling system and adjustable bottom airflow and it comes with a 4ml juice capacity tank. It can provide you mouth-to-lung (MTL) vaping experience. ![]() Original Myvapors Roak 8W 1000mAh Pod System Box Mod Hiding Atomizer Starter Kit $21.99 The Myvapors Roak Box Pod Kit features a sliding key design and hiding construction which makes atomizer more sanitary. Roak Mod Kit is powered by a 1000mAh built-in battery with a durable power of capacity. Transportable and sleek, Roak box pod kit is designed to travel light. Adopting the principle of ergonomic design, it is equipped with a hanging chain that can be carried around. Roak Mod Kit comes with a 1.0ml juice capacity pod cartridge (Coil is not included) and the max output power of this mod kit is 8W. Multiple protections provide you a safe vaping experience. ![]() Original SMOKTech SMOK Fetch Mini 40W 1200mAh VW Box Mod Pod System Starter Kit $36.99 The SMOK Fetch Mini Pod Kit, powered by an built-in 1200mAh battery, is constructed from eco-friendly PCTG material body and featured with 2.5D arc edge glass panel. The Pod Kit comes with a 3.7ml pod cartridge to meet your daily vaping experience. Paired with convenient magnetic installation system, the Fetch Mini chamber also supports waterproof and dust proof functions. Fetch Mini Pod Kit is supported by advanced technology, allowing you to adjust wattage from 5W to 40W freely. Plus the 0.96" TFT Screen can display pertinent vaping data for you. The pod kit includes two sets of pods and coils -- RPM pod and RPM Mesh 0.4ohm Coil, Nord pod and Nord Regular DC 0.6ohm Coil, which are one-to-one correspondence. And Fetch Mini RPM Pod and Nord Pod are compatible with RPM coils and Nord coils respectively, you can choose the pod and coil according to your preference. ![]() Original Uwell Evdilo 200W TC VW Box Mod with Valyrian II Tank Atomizer Kit $85.99 The Uwell Evdilo Mod Kit consists of an comes with an Evdilo TC VW Box Mod and a Valyrian II Tank Atomizer. The Mod Kit comes with meshed coils for unparallel flavor and huge clouds, a variety of meshed coils (Single, Dual, Triple) are available, heat evenly and fully atomize the juice. And the Valyrian II Tank is compatible with 4 coils totally, including FeCrAl UN2 0.32ohm Single Meshed Coil to provides the smoothest and largest airflow; FeCrAl UN2-2 0.14ohm Dual Meshed Coil to provides huge and thick vapor; FeCrAl UN2-3 0.16ohm Triple Meshed Coil to present the full and original flavor; and the last one is 0.15ohm FeCrAl Quadruple Coil. What's more, Valyrian II atomizer can absorb the e-juice in the condensation holder through regular usage and vaporize it. It reduces juice leakage and lessens the cleaning frequency. Uwell Evdilo Mod is compatible with dual 18650 / 20700 / 21700 batteries.(Not included). Dual batteries give the kit a maximum 200 watts output and more possibilities to the cloud chaser. ![]() Original SMOKTech SMOK Fetch Mini Pod System Replacement Nord Pod Cartridge(2 PCS) (Standard Edition) $5.99 The SMOK Replacement Pod Cartridge is compatible with Fetch Mini Pod Kit, the Pod Cartridge has a juice capacity of 3.7ml for SMOK Nord Coil(coil not included). 2 PCS / Pack. ![]() Original SMOKTech SMOK Fetch Mini Pod System Replacement RPM Pod Cartridge(2 PCS) (Standard Edition) $5.99 The SMOK Replacement Pod Cartridge is compatible with Fetch Mini Pod Kit, the Pod Cartridge has a juice capacity of 3.7ml for SMOK RPM Coil(coil not included). 2 PCS / Pack. ![]() XK RTA Atomizer for SXK MTL RBA / Vapeshell / Inders / Exocet original price$22.90, now only$18.99 The SXK Rebuildable Atomizer is constructed from 316 stainless steel and PEI material in 22mm diameter. The Atomizer is suitable for SXK MTL RBA / Vapeshell / Inders / Exocet. This atomizer will change your SXK MTL RBA / Vape Shell / Inders / Exocet to be a RTA atomizer. ![]() |
Original Uwell Nunchaku 2 100W TC VW Vape Mod original price$70.49, now only$49.99
The Nunchaku 2 Vape Mod is powered by Single 18650 / 20700 / 21700 batteries (Not included) with included battery sleeve. It can fire up to 100W max output, which provides more possibilities to the flavor and cloud chaser. The ergonomic design makes it feel perfect in your hand. The 6-axis Motion sensor makes the device even more compact. Multiple work modes are available to make it perfect for beginners and advanced users alike. The new BEIN chip has multiple circuit protection functions to offer reliable performance and fast firing capabilities. What's more, the PCBA is dust-proof and moisture-proof, effectively protecting the core unit of the device. ![]() Original Advken Manta V2 MTL 2.0 RTA original price$32.99, now only$27.99 The Manta V2 MTL 2.0 RTA is constructed from Stainless Steel (Body) and Glass (Tank) in 22mm diameter. It comes with a 2ml juice capacity tank tube to meet your daily vaping needs. With 510 connector, it can fit most of the mods in the market. Equipped with an new airflow design, making this RTA not only provide great airflow, but prevent leakage. There are 4-level Bottom Airflow Control: "B" mark, "H" mark, "A" mark, "S" mark, which will provide you various and great vaping experience. ![]() Original Uwell Nunchaku 2 Kit 100W TC VW Vape Mod + Atomizer Tank original price$97.99, now only$69.99 The Nunchaku 2 Kit consists of Uwell Nunchaku 2 Mod and Nunchaku 2 Tank Atomizer. It is an upgraded version of Uwell Nunchaku Kit which is powered by single 18650 / 20700 / 21700 batteries (not included) with the max output of 100W. With the new PCBA of Uwell, it features dust-proof and moisture-proof which can effectively protecting the core unit of the device. It features 6-axis MEMS sensor for a new operating experience. With the 5V / 2A fast charging, it can effectively reducing the charge time. The included Nunchaku 2 Tank features patented self-cleaning technology, which reduces juice leakage and lessens the cleaning frequency. And it comes with 5ml large e-juice capacity for the whole day vaping. The filler holes have a silicone check valve to aid in filling. It is compatible with UN2 series coils for smooth airflow and great flavor. It has multiple protections to ensure your vaping safety. ![]() Original Hugo Vapor Planet 45W Box Mod Pod System Starter Kit original price$52.24, now only$29.99 The Hugo Vapor Planet Pod Kit is powered by Single 18650 battery (Not included) with pocket-friendly size.The Planet Pod Kit supports 45W wattage output. Furthermore, the Hugo Vapor Planet Pod Kit comes with 0.4ohm mesh coil, 1.4ohm dual regular DC coil and DIY RBA coil for DTL and MTL vaping to satisfy all your vaping demands and bring you an outstanding vaping experience. What's more, it is also comes with a 3ml juice capacity pod cartridge with easy refilling design, 510 drip tip and Type-C port. ![]() Original Aspire Mulus 80W VW Box Mod Pod System Starter Kit $49.99 The Mulus Pod Kit is powered by single 18650 battery (Not included) with 80W max output. It comes with a wide range of premium quality resin 510 drip tips available, allowing you to switch your look in seconds. The Mulus is designed to reduce hand fatigue and is lightweight, meaning you can easily carry the device for long periods with ease. You can easily switch between Tigon and Nautilus coil variants for a wide choice of performance styles. The inner pod tank system can be quickly refilled by simply removing the securely fitted silicone bung. Accessing the battery and electrical controls is made simple, with a magnetic rear door system that remains secure during usage, then can be quickly removed in seconds. It comes with 4.2ml large e-juice capacity for meeting daily vaping needs. ![]() Original Hugo Vapor Planet Pod Kit Replacement Dual Regular Coil Head(5 PCS) $9.99 The Hugo Vapor Replacement Dual Regular Coil is designed for Hugo Vapor Planet Pod Kit. The regular coil is good for vaping. It features 1.4ohm coil resistance. 5 PCS / Pack. ![]() Original Hugo Vapor Planet Pod Kit Replacement Mesh Coil Head(5 PCS) $9.99 The Hugo Vapor Replacement Mesh Coil is designed for Hugo Vapor Planet Pod Kit. The Mesh coil has a longer life span. It features 0.4ohm coil resistance. 5 PCS / Pack. ![]() 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.99 The 510 Replacement Drip Tip is made of Stainless Steel. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() |
Original Goforvape Double UP RTA $25.99
The Goforvape DOUBLE UP RTA is constructed from stainless steel (body) + glass (tank) material. The DOUBLE UP RTA comes with an innovative postless curved build deck and it supports top airflow ring controls side angled airflow, bottom airflow ring controls center airflow. The 360 degrees airflow design can prevent spitting effectively and produce a dense, flavorful vape. Furthermore, the postless deck makes it fast and easy to rewick and mount your coil. What's more, the threaded top cap makes refilling easily. ![]() Original Steam Crave Aromamizer Lite V1.5 MTL RTA original price$41.40, now only$33.29 The Steam Crave Aromamizer Lite RTA V1.5 is constructed from stainless steel (body) and glass (tank) in 23mm diameter. The RTA comes with a 3.5ml e-juice capacity glass tank (a 4.5ml extra glass tube included). The RTA adds 4mm chimney adaptor and 2 x 1mm air inserts as accessories to make the airflow be right for MTL. And it is also a great Single Coil RTA designed for flavor chasing lovers. With the easy single coil build deck and precise adjustable bottom airflow, the Aromamizer Lite RTA V1.5 brings excellent DL and MTL vaping experience for vapers. ![]() MLNM RTA Clone $17.99 The MLMM RTA Clone is constructed from 316 Stainless Steel in 22mm diameter, it comes with a 4ml juice capacity glass tank. The RTA supports top refilling and bottom airflow control. ![]() Original Ohm Vape AIO Pod System Replacement Pod Cartridge with 1.5ohm Coil Head $7.99 The Original Ohm Vape AIO Pod System Replacement Pod Cartridge (with 1.5ohm Gold Coil) is designed for Ohm Vape AIO Pod System Kit. ![]() Original Goforvape Monster Build Tool Coil Trimming Tool Vape Stand 510 Base for RDA / RBA / RTA / RDTA $5.99 The Goforvape Monster Build Tool is constructed from Zinc Alloy material, 510 threading connection compatible with RDA / RBA / RTA / RDTA atomizers as a 510 vape stand or base. Furthermore, it can be used to as a coil trimming tool to measure and cut coil legs to the perfect length easily and conveniently. With 11 different slots for options: 3.0 / 3.5 / 4.0 / 4.5 / 5.0 / 5.5 / 6.0 / 6.5 / 7.0 / 7.5 / 8.0mm ![]() Original Goforvape Universal Coil Build Kit - 6 in 1 Coil Jig + 316SS Scissors + Pliers + Ceramic Tweezers + Screwdrive + Coils $39.99 The Original Goforvape Universal Coil Build Kit is a multi-functional tool kit designed for vape. The kit includes many useful tools that can be used for coil building, wicking, adjusting. It will be a great helper for DIY lovers. ![]() |
Onyx Mechanical Mod Clone $13.89
The Onyx Mechanical Mod Clone is constructed from 316 Stainless Steel, and it is powered by Single 18350 battery (Not included). The Onyx Mech Mod Clone comes with Ergonomic design and comfortable hand feeling. It is compatible with 510 threading conncection. ![]() Original IJOY NIC Tank Clearomizer original price$29.99, now only$21.99 The IJOY NIC Tank is a upgraded tank featuring a leak-proof, slide-to-open top fill system with 2ml e-juice capacity and dual adjustable bottom airflow intake slots, which is constructed from stainless steel (body) and glass (tank). The Nic Tank applies the use of top quality, food-grade materials. The NIC tank adopts two coils, a 1.2ohm coil (pre-installed) optimized for nic salts, and a powerful 0.8ohm coil optimized for a strong throat-hit with full flavor and huge clouds, both produce the original flavor from the first to the last puff. ![]() Original Advken Artha V2 RDA original price$29.99, now only$22.99 The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product. The Artha V2 RDA is constructed from Stainless Steel, Aluminum, PEI, and PC material. The V2 RDA is a perfectly designed rebuildable tank atomizer with 24mm diameter. It also can be used on squonk mods. It is equipped with fully adjustable dual slotted airflow and a 24K gold-plated build deck with two-post. With the quadruple post design, it is easy for setting the complicated coils. The RDA supports Mid-airflow control. ![]() Original Uwell Nunchaku 2 Sub Ohm Tank Clearomizer $24.69 The Uwell Nunchaku 2 Clearomizer is constructed from Stainless Steel (body) and Pyrex Glass (Tank) in 29mm diameter. The Nunchaku 2 Clearomizer comes with a 5ml juice capacity tank and two coils: 0.2ohm FeCrAI UN2 Meshed-H Coil (50~60W) and 0.14ohm SS316L UN2 Meshed-H Coil (50~60W). The Optimized cap can refill e-juice with minimal effort by rotating the top cap 90 degrees and the filler holes have a silicone check valve to avoid e-liquid leakage and make the filling process cleaner. The Nunchaku 2 Clearomizer is equipped with patented self-cleaning technology: Nunchaku 2 atomizer can absorb the e-juice in the condensation holder through regular usage and vaporize it. It reduces juice leakage and lessens the cleaning frequency. What's more, the pro-FOCS flavor testing technology also gives you an unparalleled vaping experience. ![]() Original asMODus Pyke 480mAh Ultra-Portable Pod System Kit original price$29.99, now only$21.99 The asMODus Pyke Pod Kit is an ultra-portable pod device which is powered by built-in 480mAh battery and constructed from food-grade polymer. It can be easily chargeable with the included micro-USB charging. It adopts the 1.2ohm Ceramic Coil and features 2ml E-liquid capacity pod, which has airflow that works well with its relatively low resistance creating big clouds and flavor. And the included pod is designed to feel comfortable on the lip. The pod also has an easy-to-fill hole to make the refilling much easier. ![]() Orignial Marvec XPOD X POD 690mAh Pod System Starter Kit original price$29.00, now only$14.99 The Marvec XPOD Pod System Kit is constructed from Zinc alloy and PC material. The Marvec XPOD is powered by 690mAh built-in battery and comes with two 1.8ml juice capacity pods (One is pre-installed). The pod is equipped with a 1.2ohm coil to meet your daily vaping experience and the max output power is up to 12W. What's more, there are several protective functions to protect your device. ![]() Original Advken Wanderlust Lite 1000mAh Pod System Starter Kit original price$26.99, now only$18.99 The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product. The Advken Wanderlust Lite Pod Kit is a portable pod system kit. It is powered by 1000mAh built-in battery and comes with a 2ml E-juice capacity for whole day vaping. Small in size, it is easy to carry out or hang on your neck by a lanyard. With the intelligent power indicator light, it can show the different battery status. It is equipped with a 1.4ohm ceramic coil, which high compatible for regular juice, Nicotine salt. The Wanderlust Lite pods can be refilled via bottom fill system and snaps-in to connect to the device. It has multiple protections to ensure your vaping safety. ![]() Original BMI Micro 30W 1200mAh VW Box Mod Pod System Ultra Portable Starter Kit $114.99 The BMI Micro VW Box Mod Pod Kit is constructed from full stainless steel material. The BMI Micro Pod Kit is powered by 1200mAh built-in battery and comes with a 2ml juice capacity pod. The Pod Kit features a Sliding Door System, you can see a LCD Screen with the following indicators: Battery Meter / Wattage Setting / OHM Reader / Voltage Output to indicate your device's states. The Pod Kit supports adjustable airflow control to meet MTL or DL lovers' needs. ![]() Mini 800mAh Power Bank with Micro USB Plug for E-Cigarette / Pod System $7.99 The Mini Power Bank features 800mAh power capacity with Micro USB Plug and it is compatible for E-Cigarette / Pod System to charge. ![]() Original IJOY NIC-Q2 Dual Cotton Coil Head for NIC Tank(5 PCS) $9.99 The IJOY NIC-Q2 Dual Cotton Coil Head is designed for NIC Tank Atomizer. The power range of NIC-Q2 Dual Cotton Coil is from 15 to 20W and it's coil resistance is 1.2ohm. 5 PCS / Pack. ![]() |
Original IJOY NIC-Q3 Triple Cotton Coil Head for NIC Tank(5 PCS) $9.99
The IJOY NIC-Q3 Triple Cotton Coil Head is designed for NIC Tank Atomizer. The power range of NIC-Q3 Triple Cotton Coil is from 20 to 25W and it's coil resistance is 0.8ohm. 5 PCS / Pack. ![]() Original IJOY NIC-Q4 Quad Cotton Coil Head for NIC Tank(5 PCS) $9.99 The IJOY NIC-Q4 Quad Cotton Coil Head is designed for NIC Tank Atomizer. The power range of NIC-Q4 Quad Cotton Coil is from 25 to 30W and it's coil resistance is 0.6ohm. 5 PCS / Pack. ![]() Original IJOY RBA Rebuildable Deck for NIC Tank $8.99 The IJOY RBA Deck is designed for NIC Tank and it fits for DIY lovers. ![]() Original Advken Wanderlust Lite Pod System Replacement Pod Cartridge with 1.2ohm Parallel Coil(3 PCS) original price$13.99, now only$8.99 The Advken Pod Cartridge is designed for Wanderlust Lite Pod Kit, implementing a 2ml refillable reservoir, pod based dual airflow system, and bottom refill 1.2ohm Parallel Coil, high compatible for regular juice, nicotine salt, and thick oil e-juice. 3 PCS / Pack. ![]() Original Advken Wanderlust Lite Pod System Replacement Pod Cartridge with 1.4ohm Ceramic Coil(3 PCS) original price$13.99, now only$8.99 The Advken Pod Cartridge is designed for Wanderlust Lite Pod Kit, implementing a 2ml refillable reservoir, pod based dual airflow system, and bottom refill 1.4ohm Ceramic Coil, high compatible for regular juice, nicotine salt, and thick oil e-juice. 3 PCS / Pack. ![]() Original asMODus Pyke Pod System Replacement Empty Pod Cartridge with 1.2ohm Ceramic Coil(3 PCS) $8.99 The asMODus Pyke Replacement Empty Pod Cartridge is designed for asMODus Pyke Pod Kit and it features 2ml juice capacity. 3 PCS / Pack. ![]() Original Uwell Replacement UN2 Meshed-H Coil Head for Nunchaku 2 Tank(4 PCS) $9.85 The Uwell Replacement UN2 Meshed-H Coil Head is designed for Nunchaku 2 Tank and it features 0.14ohm coil resistance. 4 PCS / Pack. ![]() Original Marvec XPOD Pod System Replacement Pod Cartridge with 1.2ohm Coil(2 PCS) $6.90 The Marvec XPOD Replacement Pod is designed for XPOD Pod System Kit and it features 1.8ml juice capacity and 1.2ohm coil resistance. 2 PCS / Pack. ![]() |
AV Able SS Edition Mechanical Mod Clone original price$29.99, now only$12.99
The AV Able SS Edition mechanical mod Clone is made from Stainless Steel and Carbon Fiber. It is powered by 18650 battery (not included). The Bottom spring-loaded fire button will be very easy for you to use. Hope this mod will bring you good vaping experience. ![]() YFTK Squape S BF MTL / DL RDA Clone $18.99 The YFTK Squape S Seven BF RDA Clone is constructed from 316 stainless steel in 22mm diameter and 20mm height (without drip tip). The RDA is made by hand in small batches in Switzerland and it is compatible with many mods equipped with 510 threading connector. With the single coil build deck, it can provide stable smoke and good taste. The Squape S Style BF RDA supports mouth to lung (MTL) and direct lung (DL) vaping experience by a simple adjustment to swap from one to the other style. Furthermore, you can turn the cap to infinitely adjust how much airflow you would like. The MTL is two 1mm inlets and the DL is two 4mm inlets. It's important that the RDA supports temperature control and VV / VW modes as well. ![]() Original Cool Vapor Lava 1.5 Sub-Ohm Tank Atomizer Clearomizer original price$29.99, now only$12.99 The Cool Vapor Lava 1.5 Sub-Ohm Tank Clearomizer is constructed from stainless steel (body) and glass (tank) in 24mm diameter. The Lava 1.5 Sub-Ohm Tank comes with a 4.6ml juice capacity tank tube and features a 0.4ohm coil. Lava 1.5 supports top filling and bottom adjustable airflow. The POM drip tip is included which helps with preventing overheat issue and delivers a greater smoke with smooth taste. ![]() Original Cool Vapor MGTK BF RDA original price$29.99, now only$12.99 The Cool Vapor MGTK BF RDA is a 24mm diameter exquisite rebuildable drip atomizer. The MGTK RDA features a wide postless build deck, which is easy to make dual coils installation. Together with the adjustable side airflow design, the MGTK BF RDA will bring you a really smooth vaping experience. The RDA comes with a 0.22ohm Ni90 Coil to meet your daily vaping. It is perfectly compatible with most squonk Mods. The RDA comes with bottom feeding pin. ![]() Gata MTL / DLH RTA Clone $14.99 The Gata RTA Clone is constructed from stainless steel (body) and glass (tank) in 24mm diameter. The Gata RTA Clone comes with postless build deck for single coil and supports bottom airflow control to meet MTL and DLH lover different vaping needs. ![]() 510 Replacement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.89 The 510 replacement drip tip is made from PC material. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() 810 Replacement Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / CSMNT Cosmonaut / Reload RDA $1.89 The 810 replacement drip tip is made of PC and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original Reewape AS244 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / CSMNT Cosmonaut / Reload RDA $1.59 The Reewape AS244 drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() |
Orignal Reewape AS226 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / CSMNT Cosmonaut / Reload RDA $1.79
The Reewape AS226 drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA ![]() Original Reewape AS222 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / CSMNT Cosmonaut / Reload RDA $1.79 The Reewape AS222 drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original Reewape AS116 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Battle / CSMNT Cosmonaut / Reload RDA $1.59 The Reewape AS116 drip tip is made of resin and it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Original Reewape AS115E 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.69 The Reewape AS115E 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original Blitz Realm 30W Pod Kit Replacement Pod Cartridge(2 PCS) $5.99 The Replacement Pod Cartridge is designed for Blitz Realm 30W Pod Kit and it features a 3.5ml juice capacity. The Pod is compatible with 0.6ohm mesh coil (Not included). 2 PCS / Pack. ![]() Original Blitz Realm 30W Pod Kit Replacement Nord Mesh Coil Head(3 PCS) $5.99 The Replacement Coil is designed for Blitz Realm 30W Pod Kit / Pod Cartridge and it features a 0.6ohm coil resistance. 3 PCS / Pack. ![]() Original Cool Vapor Lava 1.5 Sub-Ohm Tank Replacement Coil Head(5 PCS) $5.99 The Cool Vapor Coil Head is designed for Lava 1.5 Sub-Ohm Tank Atomizer and it features 0.3ohm coil rasistance. The coil is compatible with SMOK TV8 Tank. 5 PCS / Pack. ![]() Original Cool Vapor Replacement Lava 1.5 Sub-Ohm Tank Coil Head(5 PCS) $5.99 The Cool Vapor Coil Head is designed for Lava 1.5 Sub-Ohm Tank Atomizer and it features 0.5ohm coil rasistance. The coil is compatible with SMOK TV8 Tank. 5 PCS / Pack. ![]() |
Original Dovpo MVV M VV II 280W VV Box Mod original price$34.99, now only$30.09
The Dovpo M VV II Box Mod is made of PC + Zinc Alloy, and powered by dual 18650 batteries (Not included),It features 1.0V to 8.0V voltage range,maximum 280W power wattage, and it has new aesthetic colorful look and a built-in USB Type-C port inside the box, battery reversal protection, a LED indicator that can show the life span of the battery.The thread type is 510 thread. ![]() Original Hugo Vapor Kylin 30W VW Box Mod Pod System Kit original price$49.95, now only$30.99 The Hugo Vapor Kylin 30W Pod System Box Mod Kit is a portable vaping pod system implementing a large 1000mAh rechargeable battery, magnetized chassis panels, and uses a 0.6ohm or 1.2ohm specialized refillable pod with nonreplaceable coil. The Kylin 30W Pod System Box Mod Kit is constructed from durable aluminium alloy and resin, offering a strong and dependable chassis making it lightweight and portable as well. In addition, the magnetized panels are made of Resin materials and are covered in visually striking artistic finish, facilitating easy removal while leaving cut outs for a juice level viewing window, nonadjustable airflow slotting, and a 0.49" OLED Display screen to relay critical vaping information such as ohms, voltage, or output levels. The color and the pattern may be various due to the Resin material. ![]() Original VEIIK Cracker MTL / DTL 500mAh Pod System Kit $22.99 The VEIIK Cracker Kit has a Cookie appearance, which makes it cpmpact and comfortable to hold in hand.The Cracker Pod Kit is powered by 500mAh internal battery, it has no button design and air-driven system for easy vaping. Furthermore, the pod kit comes with 1.2ohm ceramic coil and 2.5D tempered glass for excellent flavor taste and multiple protections to avoid any potential risk. It's important that the pod kit supports Loose MTL and Restricted DTL vaping experience. ![]() Original Golisi S43 IMR 4300mAh 35A 26650 High Drain Rechargeable Lithium Battery for E-cig VW / Mechanical / Mod Kit(1 PC) $12.69 The Golisi S43 IMR 26650 battery is a 4300mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 35A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 26650 batteies. ![]() Original Efest IMR 4200mAh 50A 26650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(1 PC) $11.99 The Efest IMR 26650 battery is a 4200mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 50A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 26650 batteies. ![]() Original Efest IMR 3000mAh 30A 20700 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(1 PC) $11.99 The Efest IMR 20700 battery is a 3000mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 30A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 20700 batteies. ![]() Origianl Golisi S35 IMR 3750mAh 40A 21700 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(1 PC) $12.59 The Golisi S35 IMR 21700 battery is a 3750mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 40A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 21700 batteies. ![]() Original Aweite AWT 3500mAh 35A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(1 PC) $10.79 The AWT 18650 battery is a 3500mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 35A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original Samsung 30Q 3000mAh 15A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(1 PC) $5.99 The Samsung 30Q 18650 battery is a 3000mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 15A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original LG HG2 3000mAh 20A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(1 PC) $6.99 The LG HG2 18650 battery is a 3000mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 20A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original Sony VTC5 2600mAh 30A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(1 PC) $6.99 The Sony VTC5 18650 battery is a 2600mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 30A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original Sony VTC6 3000mAh 30A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(1 PC) $7.59 The Sony VTC6 18650 battery is a 3000mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 30A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original Panasonic NCR 3400mAh 20A 18650 Rechargeable Lithium Battery for RX200S E-cig VW / Mechanical Mod / Mod Kit(1 PC) $7.59 The Panasonic NCR 18650 battery is a 3400mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 20A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies like RX200S / Kbox 200W / Joyetech Cuboid. ![]() Original Efest IMR 3000mAh 35A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(2 PCS) $14.99 The Efest IMR 18650 battery is a 3000mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 35A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() |
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02 Адрес: Shenzhen
Original Samsung INR 25R 2500mAh 35A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(2 PCS) $9.99
The Samsung INR 25R 18650 battery is a 2500mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 35A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original LG HG2 3000mAh 20A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(2 PCS) $12.99 The LG HG2 18650 battery is a 3000mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 20A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original Sony VTC5 2600mAh 30A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(2 PCS) $12.59 The Sony VTC5 18650 battery is a 2600mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 30A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original Sony VTC6 3000mAh 30A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(2 PCS) $12.99 The Sony VTC6 18650 battery is a 3000mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 30A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original Samsung INR 20S 2500mAh 30A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(2 PCS) $12.59 The Samsung INR 20S 18650 battery is a 2500mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 30A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original Sony VTC5A 2600mAh 30A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(2 PCS) $14.99 The Sony VTC5A 18650 battery is a 2600mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 30A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original IMREN 3500mAh 30A 18650 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(2 PCS) $13.99 The IMREN 18650 battery is a 3500mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 30A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 18650 batteies. ![]() Original Hellvape Fat Rabbit Tank Replacement Anti-Bacterial Drip Tip $4.59 The Fat Rabbit Replacement Drip Tip is designed for Hellvape Fat Rabbit Tank. It is made of innovative resin and AG material that is Anti-Bacterial and more healthier for vaping. In addition, it is easy to replace and clean. ![]() Original Hellvape Fat Rabbit Sub Ohm Tank Replacement Tank Tube $2.59 The Hellvape Fat Rabbit Replacement Glass Tank Tube is specifically designed for Hellvape Fat Rabbit Sub Ohm Tank. It features a 2ml juice capacity. It is very easy to clean and replace. ![]() |
Original Hellvape Fat Rabbit Sub Ohm Tank Replacement Bubble Tank Tube $2.99
The Hellvape Fat Rabbit Replacement Glass Bubble Tank Tube is specifically designed for Hellvape Fat Rabbit Sub Ohm Tank. It features a 5ml juice capacity. It is very easy to clean and replace. ![]() Original Steam Crave Aromamizer Lite V1.5 Replacement Tank Tube(2 PCS) $5.59 The Steam Crave Replacement Tank Tube is specifically designed for Aromamizer Lite V1.5 Tank. It features a 3.5ml juice capacity. ![]() Original Steam Crave Aromamizer Lite V1.5 Replacement Bubble Tank Tube(2 PCS) $5.99 The Steam Crave Replacement Bubble Tank Tube is specifically designed for Aromamizer Lite V1.5 Tank. It features a 4.5ml juice capacity. ![]() Original Steam Crave Aromamizer Lite V1.5 Replacement Airflow Chimney Adaptor + Air Inserts Conversion Kit $4.99 The Steam Crave Aromamizer Lite V1.5 Replacement Conversion Kit consists of one 4mm airflow chimney adaptor and two 1mm air inserts. The Conversion Kit is designed for Steam Crave Aromamizer Lite V1.5 Tank. ![]() Original Steam Crave Replacement RBA Rebuildable Deck for Aromamizer Lite V1.5 Tank $10.99 The Steam Crave Replacement RBA Deck is specifically designed for Aromamizer Lite V1.5 Tank. It fits for DIY lovers. ![]() Original Steam Crave Glaz Mini Replacement Tank Tube(2 PCS) $3.99 The Steam Crave Replacement Tank Tube is specifically designed for Glaz Mini Tank. It features a 2ml juice capacity. ![]() Original Steam Crave Glaz Mini Replacement Chamber(2 PCS) $5.59 The Steam Crave Replacement Chamber is specifically designed for Glaz Mini Tank. ![]() Original Steam Crave Replacement RBA Rebuildable Deck for Glaz Mini Tank $10.99 The Steam Crave Replacement RBA Deck is specifically designed for Glaz Mini Tank. It fits for DIY lovers. ![]() Original VEIIK Cracker Pod System Replacement Pod Cartridge(2 PCS) $5.99 The VEIIK Replacement Pod Cartridge is designed for VEIIK Cracker Pod System Kit, and it features 2ml juice capacity. 2 PCS / Pack. ![]() Original IMREN 3750mAh 40A 21700 Rechargeable Lithium Battery for E-cig VW / Mechanical Mod / Mod Kit(2 PCS) $20.99 The IMREN 21700 battery is a 3750mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 40A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 21700 batteies. ![]() |
AV Able Brass Edition Mechanical Mod Clone $12.99
The AV Able Mechanical Mod Clone is constructed from Brass. It is powered by interchangeable single 18650 battery (not included). The diameter of this mechanical mod is 24mm. ![]() Poke Vape 300W VV Box Mod Clone $14.99 The Poke Vape VV Box Mod Clone is constructed from PC and ABS material. The Poke Vape VV Box Mod is powered by dual 18650 batteries (Not included). The box mod is compatible with most of atomizers with 510 threading connerctor. The inside of the box mod has a Potentionmeter Dial which can adjust different output power (1~8V) to meet your different vaping needs. The box mod has 5 kinds of protections to provide you safer vaping experience. ![]() Original Vsticking SMI RADA for VKsma Mod Kit $10.99 The Vsticking VKsma Rebuildable Dripping Atomizers (RADA) is designed for Vsticking VKsma Auto Filling Yihi Chip TC Kit. The RADA Atomizer is constructed from Stainless Steel and PEI material, it only supports the TC coil whose resistance is 0.2ohm to 1.0ohm. The Vsticking VKsma Rebuildable Auto Dripping Atomizer only works with DIY Mode. ![]() Orignal Vsticking SMA ADA for VKsma Mod Kit $6.99 The Vsticking VKsma Dripping Atomizers (ADA) is designed for Vsticking VKsma Auto Filling Yihi Chip TC Kit. The ADA Atomizer is constructed from Brass and PP material, It not only can work by auto mode but also the DIY mode with 0.3ohm Ni211 coil and 1.0ohm SS316 to bring you fun and great flavor. ![]() Gata MTL / DLH RTA Clone $17.99 The Gata RTA Clone is constructed from 316 stainless steel (body) and glass (tank) in 24mm diameter. The Gata RTA Clone comes with postless build deck for single coil and supports bottom airflow control to meet MTL and DLH lover different vaping needs. ![]() Original Aivape Ohana RDA original price$33.99, now only$29.99 The Aivape Ohana RDA is constructed from stainless steel in 24mm diameter (25mm diameter replacement PC Top Cap). The RDA features single or dual coil build deck and it supports side-to-bottom airflow control. The RDA comes with an innovative side-to-bottom airflow channel, dome and smaller evaporation chamber, and easy coil installation and wicking. ![]() Gata MTL / DLH RTA Clone $14.99 The Coppervape Hussar QP Gata RTA Clone is constructed from 316 stainless steel (body) and glass (tank) in 24mm diameter. The Gata RTA Clone comes with postless build deck for single coil and supports bottom airflow control to meet MTL and DLH lover different vaping needs. ![]() AV Able Brass Edition Mechanical Mod Clone + Battle Style RDA Kit $19.99 The AV Able Mechanical Mod Clone is constructed from Brass. It is powered by interchangeable single 18650 battery (not included). The diameter of this mechanical mod is 24mm. The Battle RDA Clone is constructed from stainless steel dual-post deck, brass top cap and drip tip. ![]() Original Vsticking VKsma 25W 1400mAh YiHi Chip Auto Mode TC Mod Kit with SMA ADA Dripping Atomizer original price$89.90, now only$52.99 The Vsticking VKsma Auto Filling Kit is the vape device equipped with an automatical bottom filling system to make a great ease of vaping. The Vsticking VKsma Mod Kit is powered by 1400mAh built-in battery and works in auto mode. You can take control of the temperature and the power of the Kit, and E-juice refilling is also easier than ever. The Vsticking VKsma comes with a 3ml refillable E-liquid container and one nebulizer, VKsma automatic drip atomizer (ADA). Precise E-liquid control, automatic the e-liquid to the ADA return of excess to the tank, no leaking. What's more, the Mod Kit comes with the automatic drip atomizer (ADA) that supports adjustable airflow control. ![]() |
Original Vsticking VKsma 1400mAh YiHi Chip DIY Mode TC Mod Kit with SMI RADA original price$99.90, now only$58.99
The Vsticking VKsma Auto Filling Kit is the vape device equipped with an automatical bottom filling system to make a great ease of vaping. The Vsticking VKsma Mod Kit is powered by 1400mAh built-in battery and works in auto mode. You can take control of the temperature and the power of the Kit, and E-juice refilling is also easier than ever. The Vsticking VKsma comes with a 3ml refillable E-liquid container and one nebulizer, VKsma rebuildable automatic drip atomizer (RADA). Precise E-liquid control, automatic the e-liquid to the RADA return of excess to the tank, no leaking. What's more, the Mod Kit comes with the rebuildable automatic drip atomizer (RADA) that supports adjustable airflow control. ![]() Original OVNS JC01 Pod Vape Kit Replacement Pod Cartridges with 1.5ohm Coil(4 PCS) $7.99 The Ovns JC01 Replacement Pods are designed for Ovns JC01 Kit, the JC01 Pod hold up to 0.7ml of e-juice capacity and can use Juul battery. The Pod is ceramic coil equip with 1.5ohm resistance to ensure long lifespan. The JC01 Battery is compatible with JC01 Ceramic Tank, JC01 liquid Pods and Juul Pods. Besides, JC01 Pods and Ceramic Tank also can use Juul Battery. ![]() Original Voopoo DRAG Nano P1 Replacement Pod Cartridges with 1.5ohm Coil(2 PCS) $4.99 The Voopoo DRAG Nano P1 Pods are designed for VO Voopoo Drag Nano Pod Kit. It equipped with 1.5ohm resistance and 1.6ml E-juice capacity. With the easy top filling design, you can easy to inject the E-juice. E-liquid transferring system, built from all natural cotton coil,makes atomization finer and smoother. Smoke emitting tube, made of 304 stainless steel, achieves no condensed fluid leakage. Innovative design of double oil filling slots, makes it convenient to use, and saves much trouble when users adding e-liquid. ![]() [Ships from Battery Warehouse] Original IMREN IMR18350 800mAh 3.7V 18350 Rechargeable Li-Mn Batteries for Mod(2 PCS) $6.99 The IMREN IMR18350 battery is a 800mAh rechargeable Li-Mn battery. It is compatible with any E-cig vaping VW / Mechanical Mod / Mod Kit powered by 18350 batteies. ![]() [Ships from Battery Warehouse] Original Samsung INR21700 30T 3000mAh 35A 21700 Rechargeable Lithium Batteries(2 PCS) $14.99 The Samsung INR21700 21700 30T battery is a 3000mAh high performance rechargeable lithium battery and made for high continuous discharge current (max 35A) applications. It is compatible with any E-cig vaping mods / mod kit powered by 21700 batteies. ![]() Original Vandy Vape Superfine MTL Fused Clapton Ni80 Heating Resistance Wire(10 Feet) $5.99 The Vandy Vape Superfine MTL Fused Clapton Wire heating resistance wire is perfect for RBA / RDA atomizers. The wire is made from stainless steel. It features 32GA x 2 + 38GA gauge and 3.88ohm resistance value per feet, which will be a good choice for DIY. ![]() Original Hellvape Cotton Travel Set Organic Cotton + Scissor + Tweezer for RBA / RDA / RTA / RDTA Atomizer $1.39 The Hellvape Cotton Travel Set consists two 100% Organic Cotton and one small scissors and one small tweezer. The set is compatible with RBA / RDA / RTA / RDTA Atomizer. This cotton is perfect for DIY lovers. ![]() |
Original Ultroner Victory 60W VW Box Mod original price$199.90, now only$169.99
The Ultroner Victory VV VW Box Mod is constructed from Stabwood and Stainless steel material, integrating the SEVO-60 chip set, an ultra premium and user friendly output board that is more than capable to compete with some of the best chip sets in the industry, packed into a compact and beautiful chassis. The box mod is powered by single high amperage 18650 battery (Not included). With an output range of 5W to 60W and an atomizer resistance range of 0.1ohm to 3.0ohm, the Victory can drive output among the best in the single battery driven market segment. This chip also features wattage, voltage and bypass modes allowing users to use their preferred power set. To get into the various modes users can utilize the stainless steel fire button located above the OLED display. Clicking the firing button three times allows users to access the mode selection menu. Users may change the output via two small stainless steel up and down buttons. The SEVO-60 also features a lock in order to prevent any mishaps. This can be accessed by holding down the two up and down buttons. With the quality chassis constructed from Stabwood and Stainless Steel and the SEVO-60 chipset, the Victory 60W Box Mod is the essential high end system for vaping enthusiasts and advanced users. ![]() SXK Smuggler Hybrid Mechanical Mod Clone original price$16.90, now only$14.99 The SXK Smuggler Mechanical Mod Clone is constructed from 316 Stainless Steel, it is powered by Single 18650 battery (Not included). ![]() Overlord Hybrid Mechanical Mod Clone $20.99 The Overlord Hybrid Mechanical Mod Clone is constructed from Copper material in 28.2mm diameter and it is powered by single 18650 battery (Not included) ![]() SXK Monarch R RDTA Clone original price$22.90, now only$18.99 The SXK Monarch R RDTA is construction from 316 stainless steel in 24mm diameter. The RDA has a unique deck design with air flow on one side. Configurations air from a not too DL restricted to MTL. And the SXK Monarch R RDTA has an exclusive block-shaped swooping wave, which surrounds one side of the coil. The side airflow adjustable control allows the incoming air from the hole airflow provides maximum ventilation of the coil for added flavor potential. ![]() Original Advken Ayana S Box Mod with RDA Rebuildable Atomizer Kit original price$39.99, now only$29.99 The Ayana S-Kit consists of Ayana S Mod and Ayana RDA atomizer. The battery mod is compatible with 18650 / 20700 / 21700 battery (Not inclueded). There is magnetic back cover for battery change, making it convenient for you to change battery. The RDA is easy to use with the single coil design. With the intelligent power indicator light and 510 Drip Tip, you can enjoy a greater vaping experience. ![]() Original Veeape VPLUS 650mAh Box Mod Pod System AIO Starter Kit $26.99 The Veeape VPLUS Pod kit is a new fashionable AIO Pod system starter kit, which is constructed from Zinc Alloy and Plastic material, it is powered by 650mAh built-in battery and comes with 1.2ml e-juice capacity. A built-in ceramic evaporator, a ceramic coil with a 1.3ohm resistor is used to provide a purer taste. In addition, the Veeape VPLUS Pod kit also has a reminder function that will notify you every 50 breaths, which is useful for changing tobacco capsules and health management. Vplus uses IML technology on the body, the surface of the product is not easily scratched, and it is easy to clean. What's more, the Veeape VPLUS AIO Pod kit has multiple protection for your safe vaping. ![]() SL284 510 Repalcement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.99 The SL284 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() SL285 510 Repalcement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.99 The SL285 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() SL286 510 Repalcement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.99 The SL286 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() SL287 510 Repalcement Glow-in-the-Dark Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.99 The SL287 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() |
SL288 510 Repalcement Glow-in-the-Dark Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.99
The SL288 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() SL289 510 Repalcement Glow-in-the-Dark Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.99 The SL289 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() SL292 510 Repalcement Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Atomizer $1.99 The SL292 510 drip tip is made of resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. ![]() Original VOOPOO Replacement Tank Tube for Uforce T2 Tank $1.99 The VOOPOO Replacement Glass Tank Tube is designed for Uforce T2 Tank Atomizer and it features a 3.5ml juice capacity. ![]() Original VOOPOO Replacement Tank Tube for Uforce T2 Tank $1.99 The VOOPOO Replacement Glass Tank Tube is designed for Uforce T2 Tank Atomizer and it features a 5.5ml juice capacity. ![]() Replacement Tank Tube for SMOKTech SMOK Vape Pen 22 Kit $1.99 The Replacement Glass Tank Tube is designed for SMOK Vape Pen 22 Kit and it features 2ml juice capacity. ![]() Replacement Tank Tube for SMOKTech SMOK TFV8 Baby Tank $1.99 The Replacement Glass Tank Tube is designed for SMOK TFV8 Baby Tank Atomizer and it features 3ml juice capacity. ![]() Replacement Tank Tube for SMOKTech SMOK TFV8 Baby V2 Tank $1.99 The Replacement Glass Tank Tube is designed for SMOK TFV8 Baby V2 Tank Atomizer and it features 5ml juice capacity. ![]() Replacement Tank Tube for SMOKTech SMOK TFV8 Big Baby Tank $1.99 The Replacement Glass Tank Tube is designed for SMOK TFV8 Big Baby Tank Atomizer and it features 5ml juice capacity. ![]() Replacement Tank Tube for SMOKTech SMOK TFV12 Tank $1.99 The Replacement Glass Tank Tube is designed for SMOK TFV12 Tank Atomizer and it features 6ml juice capacity. ![]() Replacement Tank Tube for SMOKTech SMOK TFV12 Prince Tank $1.99 The Replacement Glass Tank Tube is designed for SMOK TFV12 Prince Tank Atomizer and it features 8ml juice capacity. ![]() Original Uwell Replacement Tank Tube for Crown 3 Tank $1.99 The Uwell Replacement Glass Tank Tube is designed for Uwell Crown 3 Tank Atomizer and it features 5ml juice capacity. ![]() Original SMOKTech SMOK Replacement Bubble Tank Tube for TFV12 Prince Tank $1.99 The SMOKTech Replacement Tank Tube is designed for TFV12 Prince Tank Atomizer and it features 8ml juice capacity. ![]() Original Veeape VPLUS Pod Kit Replacement Ceramic Coil Heads(3 PCS) $7.99 The Veeape VPLUS Pod kit replacement Ceramic Coil Heads is in 1.3ohm. 3 PCS Pack ![]() |
Original CIGPET Capo 126W VW Regulated Box Mod $22.99
The CIGPET Capo VW Box Mod is powered by dual 18650 batteries (Not included), it provides you an all day long vaping experience. The lightweight and durable design makes the CIGPET Capo Mod to be carried conveniently outside. Furthermore, the various protections of CIGPET Capo Mod will ensure a safe vaping experience. Moreover, it is equipped with a 0.91 inch OLED screen for vivid display. The Box Mod is compatible with the Mystique Mesh Black Tank (Not included). ![]() SXK NOI MTL RTA Clone original price$22.90, now only$19.99 The SXK NOI MTL RTA Clone is constructed from 316 Stainless Steel and PC material in 22mm diameter. The RTA supports bottom airflow control and top refilling. The MTL RTA supports single coil. ![]() Original FreeMax Twister 80W 2300mAh VW Battery with Fireluke 2 Tank Starter Kit $45.99 The Freemax Twister Kit consists of Twister Battery Mod and Fireluke 2 Tank Atomizer, which is powered by 2300mah built-in battery, it can fire up to 80W max output. Twister Kit features twist-style variable wattage function and an LED indicator to tell you the accurate conditions of itself. What's more, the Freemax Twister chip enables it with the fastest firing speed which less than 0.01s. The Fireluke 2 Tank features 5ml e-juice capacity and patented slide-to-open top fill design. Specially adopts X2 Mesh and X3 Mesh coils to offer a great flavor to you. ![]() Original CIGPET Capo 126W VW Regulated Box Mod with Mystique Mesh Black Tank Kit $24.99 The CIGPET Capo Kit consists of CIGPET Capo VW Box Mod and Mystique Mesh Black Tank Atomizer, which is powered by dual 18650 batteries (Not included), it provides you an all day long vaping experience. The lightweight and durable design makes the CIGPET Capo Mod to be carried conveniently outside. Furthermore, the various protections of CIGPET Capo Mod will ensure a safe vaping experience. Moreover, it is equipped with a 0.91 inch OLED screen for vivid display. The Mystique Mesh Black Tank adopts 3ml juice capacity. It features a convenient top filling design, 0.15ohm mesh coil with optimal flavor and dual adjustable airflows for huge clouds. ![]() Original Sigelei Chronus Shikra 200W TC VW Box Mod with Sub-Ohm Tank Kit original price$59.99, now only$28.99 The Sigelei Chronus Shikra TC Box Mod Starter Kit consists of 200W TC Box Mod and Shikra Sub-Ohm Tank Atomizer. It is powered by Dual High-Amp 18650 Batteries (Not included). The 1.3" TFT Display Screen is round and has a clock function built-in. In addition, the proprietary chipset within provides ample wattage up to a whopping 200W. The firing speed is at an ultra low 0.001s and can provide near instantaneous vapor output at the touch of the singular firing button. The Sigelei Shikra has multiple protections, such as temperature protection, high or low wattage protection, battery reverse protection, and an innovative 4-Digit PIN Lock to keep unwanted users out. The Chronus 200W Box Mod is compatible with the Shikra Tank, a 24mm diameter cloud beast that can accept a multitude of coils from various brands with the included pin and a 5.5ml maximum juice capacity. Furthermore, the Sigelei Shikra Tank has a knurled top refill system with dynamic dual slotted bottom airflow for excellent cooling properties. ![]() Original CIGPET Capo 126W VW Regulated Box Mod with Mystique Mesh Black Tank Kit $24.99 The CIGPET Capo Kit consists of CIGPET Capo VW Box Mod and Mystique Mesh Black Tank Atomizer, which is powered by dual 18650 batteries (Not included), it provides you an all day long vaping experience. The lightweight and durable design makes the CIGPET Capo Mod to be carried conveniently outside. Furthermore, the various protections of CIGPET Capo Mod will ensure a safe vaping experience. Moreover, it is equipped with a 0.91 inch OLED screen for vivid display. The Mystique Mesh Black Tank adopts 3ml juice capacity. It features a convenient top filling design, 0.15ohm mesh coil with optimal flavor and dual adjustable airflows for huge clouds. ![]() |
