Просмотров в теме 194446   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 07.05.2019, 04:53 Автор темы   361
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Wotofo Recurve Dual RDA Rebuildable Dripping Atomizer with BF Pin $34.99
Wotofo Recurve Dual RDA is a 24mm rebuildable dripping atomizer that features adjustable side airflow, top filling and squonking juice feeding method, dual post build deck for single or dual coil builds. It is made from durable stainless steel and the insulator is made from German PEEK. The internal cap is reduced to help gather the vapor, providing you with massive and tasteful vapor. The 6 honeycomb air holes on both sides allow the airflow to hit the coils directly and will definitely bring you the original flavor of your favorite juice.
This RDA comes with bottom feeder pin. This item also has other color to choose.
Original Hellvape Passage RDA Rebuildable Dripping Atomizer with BF Pin $36.99
Hellvape Passage RDA is an intricate vaping system developed in collaboration with vaping reviewer Suck My Mod, incorporating a multiple adjustable airflow control system, dual post build deck with innovative separation blocks, and comes with a new AG+ antibacterial and antimicrobial 810 drip tip. Made of durable stainless steel, the Hellvape Passage RDA features a dual post expansive build deck on a 24mm base with two centered posts. Each post contains a single separation block that can slide vertically on a track, helping align coils to make installation simple and easy. Moreover, the airflow control system features a three-slot construct that is further separated into 19 smaller honeycomb style airflow holes. Each passageway on the airflow contains 5, 9, and 5 holes, respectively throttling or opening the airflow.
Original Footoon Aqua Master V2 RTA Rebuildable Tank Atomizer Original Price $35.99, Now Only $27.99
Footoon Aqua Master V2 RTA is a step up to the previous Aqua Master. Measuring 24mm in diameter, it can hold up to 4.5ml of e-juice. Thanks to its innovative build deck, you can build the coil without any pain. In addition, the Aqua Master V2 features a revolutionary new airflow design, the Interchangeable Flow System, which will bring you smoother vaping experience and enhance flavors. This RTA is compatible with Aqua Reboot and Aqua Master Tank section. This item also has other color to choose.
Original SXmini Mi Class 13W 400mAh YiHi SX290 Pod System Starter Kit Original Price $41.99, Now Only $36.99
The Original SXmini Mi Class Pod System Kit is powered by YiHi SX290 chipset, bringing great performance for your vaping. It has a 1.8ml pod cartridge with 1.0ohm resistance ceramic coil. The mod is powered by built-in 400mAh battery. The working power range is from 7 to 13W. This item also has other color to choose.
Original SXmini Replacement Pod Cartridge for Mi Class Pod System Kit $6.99
The SXmini Mi Class Replacement Pod Cartridge features 1.0ohm resistance and 1.8ml of juice capacity. It is suitable for Original SXmini Mi Class Pod System Kit.
Please note: This product comes with 2 PCS in 1 pack.
3FVAPE вне форума   Вверх
Реклама на форуме.
Разместить рекламу
Старый 08.05.2019, 04:49 Автор темы   362
3FVAPE
Avid Lyfe Swiss Hybrid Mechanical Mod Clone $12.99
The Swiss Mechanical Mod Clone is made from brass and Aluminum and powered by 1 x 18650 battery (NOT INCLUDED). The fixed 510 hybrid top is machined into the mod for enhanced conductivity. This item also has other style to choose.
Original Marvec Hardess Hybrid Mechanical Mod Original Price $73.99, Now Only $38.99
Hardess Hybrid Mechanical Mod is Marvec's latest mechanical mod. It is made of brass and copper. It measures 26.5mm in diameter. It is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). Deeply carved design, awesome pattern. Great hand feeling, super powerful.
Original OVNS JC02 650mAh CBD Pod System Starter Kit $25.59
Ovns JC02 Kit is an ultra-compact pod system device with eco-friendly resin plates on both sides. Powered by a built-in 650mAh, it can last a fairly long time before charging. At the top left of the device is a rounded preheating button. Sounded the button, there is a smart three-level battery life indicator to show you the different battery levels. As for refillable pod, it can hold up to 1ml of your favorite e-juice while housing a unique 1.2ohm ceramic coil. Anyway, the Ovns JC02 is worth a shot. This item also has other color to choose.
Avid Lyfe Double Cross Hybrid Mechanical Mod Clone + Battle RDA Atomizer Kit Clone $21.99
The Double Cross Mechanical Mod Clone is made from brass and Aluminum and powered by 1 x 18650 battery (NOT INCLUDED). The fixed 510 hybrid top is machined into the mod for enhanced conductivity. The Complyfe Battle RDA Clone is constructed from stainless steel dual-post deck, brass top cap and drip tip. It features two posts design and adjustable airflow. This item also has other Style to choose.
Vapeasy SteamTuners Top Fill Tank Kit Clone for 22mm KF Lite 2019 RTA Clone $5.69
The Vapeasy SteamTuners Top Fill Tank Kit Clone is constructed from 316SS top lid / chimney and PC tank tube. It is suitable for 22mm KF Lite 2019 RTA. This item also has other color to choose.
Original Vandy Vape Kylin M Replacement Kanthal A1 Mesh Coils $3.99
The VandyVape Kylin M Mesh Coil features 0.2ohm resistance and works well at 40~60W. It is suitable for VandyVape Kylin M RTA.
This product comes with 10 PCS in 1 pack. This item also has Other Resistance to choose.
Original Ovns JC02 Replacement Pod Cartridge $10.99
The Ovns JC02 Replacement Pod Cartridge can hold 1ml of juice capacity and comes with 1.2 ohm ceramic coil. It is suitable for Ovns JC02 Pod System Stater Kit.
This product comes with 4 PCS in 1 pack.
Старый 09.05.2019, 05:11 Автор темы   363
3FVAPE
Kali RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.79
Kali RDA Clone is a 25mm Rebuildable Dripping Atomizer made of stainless steel. It features side terminal postless deck, adjustable airflow, deep juice well and easy top dripping. This RDA comes with bottom feeder pin. This item also has other color to choose.
Coppervape VWM Integra RTA Rebuildable Tank Atomizer Clone $20.49
The Coppervape VWM Integra RTA Clone is a 22mm rebuildable tank atomizer with 4ml of juice capacity. It is constructed from 316 stainless steel and PC. It features recessed build deck, reduced evaporation chamber, and various side airflow combinations from tight MTL to restricted DL with the stock AFC ring. This item also has other color to choose.
Vapeasy Gevolution V2 Mesh RDTA Rebuildable Dripping Tank Atomizer Clone $21.99
The Vapeasy Gevolution V2 RDTA Clone is a 25mm Rebuildable Tank Atomizer. It is a self-winding mesh atomizer with adjustable airflow control for optimal flavor. The RDTA is made from 316 stainless steel and has 4ml of juice capacity. This item also has other Version to choose.
SteamTuners Top Fill Tank Kit Clone + Drip Tip for 22mm KF Lite 2019 RTA Clone $7.29
The SteamTuners Top Fill Tank Kit Clone is constructed from 316SS top lid / chimney and PC tank tube. It is suitable for 22mm KF Lite 2019 RTA. Made at 1:1 scale.
Coppervape 510 Replacement Drip Tip for VWM Integra RTA Clone $1.59
The Coppervape replacement 510 drip tip is made from PC. It is suitable for Coppervape Integra RTA Clone, and all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other color to choose.
Coppervape Tank Tube for VWM Integra RTA Clone $3.59
The Coppervape replacement tank tube is made from PEI and it has 4ml of juice capacity. It is suitable for Coppervape Integra RTA Clone. This item also has other color to choose.
Старый 10.05.2019, 05:21 Автор темы   364
3FVAPE
Original Eleaf iStick Rim 80W 3000mAh Mod $42.29
iStick Rim is an awesome new member of iStick series family. Small size and colorful design make it stunning. Equipped with a sustainable 3000mAh battery, the iStick Rim can deliver a max power of 80watts for your whole day vape. Paired with TYPE-C port and supported by QC3.0/PD3.0 charging protocol, iStick Rim can be fully charged in a high speed which just need 40mins. This item also has other color to choose.
Original Damn Vape DOOM Mesh RTA Rebuildable Tank Atomizer Original Price $31.99, Now Only $24.99
DOOM RTA is designed for mesh coil. 4ml e-liquid capacity. The main feature of this RTA is 3D Liquid Flow System which provides excellent liquid transmission to reduce overheating; The sloped upward airflow hits MESH coil with the angle that perfectly match with the MESH bending shape. It is easy to wick this RTA; Foxtail-M is with just right amount of cotton for MESH; You can easily cut off the cotton at the edge of the deck without any tricks. All in all, we hope to bring out an easy-to-use RTA with pure tasty flavor! This item also has other colo to choose.
Original Sikary FOX 400mAh Pod System Starter Kit $14.99
Sikary Fox Kit is a new pocket-friendly pod system with multiple wavy lines on the body. Powered by a built-in 400mAh battery, the kit will cater to your daily vaping needs effortlessly. And there is small a battery life indicator light integrated into the spindly firing button, which will show you the working condition and the battery level. As for the refillable pod, it can hold up to 1.5ml of e-juice and adopts a brand-new 2.0ohm coil which works perfectly with regular. With the Sikary Fox, you can start out a wonderful vaping trip straight away. This item also has other color to choose.
Original Eleaf iStick Rim 80W 3000mAh Mod + MELO 5 Tank Atomizer Kit $60.89
Eleaf iStick Rim Kit is a new compact device of iStick series which consists of the iStick Rim Mod and the Melo 5 Atomizer. Powered by a built-in 3000mAh battery, it can fire up to 80W while adopting an oversized firing button and large LED Screen. As for the Melo 5 Atomizer, it can hold up to 4ml of e-liquid and is assisted by new kinds of EC coils, catering to your different vaping needs breezily. Thanks to the top filling design, you can refill the atomizer without any pain. At last, the unique silicone rings will protect the atomizer from breaking to a certain extent. This item also has other color to choose.
Original Sikary Fox Replacement Pod Cartridges $2.59
The Sikary Fox Replacement Pod is a 1.5ml refillable cartridge specially designed for Sikary Fox Pod Kit. With the unique 2.0ohm coil, the Sikary Fox is fit for regular e-juice and optimal cloud.
Original Damn Vape DOOM Mesh RTA Replacement Glass Tank $2.48
The Damn Vape Doom Replacement Tank tube is made from glass and it has 4ml of juice capacity. It is suitable for Damn Vape Doom RTA Clone.
Старый 13.05.2019, 04:46 Автор темы   365
3FVAPE
Original ThinkVape Thor 200W TC VW Variable Wattage Box Mod $24.99
The Original ThinkVape Thor Box Mod is a versatile regulated device with aesthetic appearance. Powered by ST200 Chip, this mod can reach maximum output power to 200W with dual 18650 batteries (not included). There are multiple modes can be selected: VW / VT (Ni / Ti / SS) / TCR / Bypass. The atomizer resistance range is from 0.05 to 3.5ohm. This item also has other color to choose.
Kennedy Avengers Hollow Mechanical Mod Clone $22.89
Mod: Kennedy Avengers Hollow Mechanical Mod Clone is a hybrid mech mod made from brass. It comes with 26mm hybrid connector. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED), it features 510 threading connection and spring-loaded fire button. The button and battery connector are made from copper.
Kennedy Avengers Hollow Mechanical Mod Clone + Kennedy 25 RDA Kit Clone $28.89
RDA: Kennedy 25 RDA Clone is made from brass with 25mm diameter. The RDA comes with dual post build deck, bottom airflow and low profile PEI drip tip. It fits the Kennedy Avengers Hollow Style Mechanical Mod very well.
Armageddon Squonk Mechanical Box Mod Clone + Apocalypse RDA Kit Clone Original Price $18.99, Now Only $14.99
Mod: The Armageddon Squonk Box Mod Clone is constructed from ABS (chassis) and PC (back panel) with copper contact for better conductivity. The built-in bottle is made from super soft silicone and is capable of holding about 6ml e-juice. The front panel comes with magnets and is replaceable. This mod is powered by a single 18650 battery (not included).
RDA: The Apocalypse RDA Clone is with clamp design and has a massive space in each clamp which provides space for mounting the most complex and insane coil builds. Coupled with the deep juice well, wide build deck, durable post clamps and extended post screws, the RDA is a builder's dream.
Original Vapjoy Dragon Scale Alien NI80 Pre-built Coil Heating Resistance Wire $3.99
The Vapjoy Dragon Scale Alien coil is 100% handcrafted in the whole procedure. Including 2 pieces pre-made Ni80 coils, the the Vapjoy Dragon Scale Alien coil can provide unbeatable flavor and vapor. Best choice for DIY lovers. This item also has other Version to choose.
Старый 14.05.2019, 04:43 Автор темы   366
3FVAPE
Original Augvape Occula RDA Rebuildable Dripping Atomizer with BF Pin Original Price $39.99, Now Only $23.99
The Occula 24mm RDA by Augvape is a collaboration between Augvape and Twisted Messes, this is a project you will not want to miss. Featuring an innovative Dual Post captive clamp system to fit any size build with ease. Each post has 5.5mm width by 2.6mm in height, leaving space for even the beefiest coils. Utilizing two massive hex-shaped screws that work with flat-head and Philips screwdrivers, as well as pliers if needed. Clamps raise automatically with screws. The adjustable airflow system helps a lot in escalating the taste as well. This item also has other color to choose.
Original IJOY Saturn 1100mAh 15W Pod System Starter Kit $29.99
IJOY Saturn Kit is an elegant pod system that looks very like a hip flask. Constructed from a combination of zinc alloy, stainless steel, and curved glass, it maintains a breath-taking visual aesthetic while possessing an ergonomic exterior to naturally fit in the hand. Powered by a built-in 1100mAh battery, the Saturn can fire up to 15W and last for a rather long time of vaping with minimum recharging required. And there is a little LED indicator light embedded in the delicate round power button, which will show you the battery level clearly. As for the refillable pod, it can hold up to 3ml of your favorite e-juice and has three coil options. The 0.6ohm Saturn Mesh Coil focuses on specific tasks to create massive clouds, while the 1.0ohm and 1.2ohm Mercury Coils are optimized for nic salts. Anyway, the Saturn is really a decent choice if you're looking for an exquisite and easy to use pod system device. This item also has other color to choose.
Original Suorin AirPlus 22W 930mAh Pod System Starter Kit $26.90
Suorin AirPlus Kit is an updated version to the previous Suorin Air. Powered by a built-in 930mAh battery, it implementing a maximum output power of 25W and longer vaping time than the 400mAh Air. The battery can be fully charged in 50 minutes via the USB C type charging port on the bottom of the kit. Along one side of the kit, there are five battery life indicator lights that will turn off one by one depends on the battery level, 5 lights for above 80%, 4 for 60~80%, 3 for 40~60%, 2 for 20~40%, and 1 means the battery level is below 20%. As for the pod, it can hold up to 3.2ml of your favorite e-juice (2ml for TPD version) while adopting oil-baffle design. This time Suorin introduces the AirPlus pods of two kinds of coil resistance, one for 0.7ohm, and the other for 0.8ohm. Anyway, the AirPlus is worth a shot if you like the Suorin's pod system devices. This item also has other color to choose.
Original Vapesoon DT231-H 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.69
The Original Vapesoon 810 drip tip is made from resin with 12.5mm diameter 810 connector. It is suitable TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA. This item also has other Version to choose.
YFTK Replacement Tank Tube for EVL Reaper V3 RTA Clone $3.59
The Replacement Tank Tube is made from PCEG and suitable for EVL Reaper V3 RTA Clone. The PCEG tank is with 22mm diameter and 2ml capacity. This item also has other Version to choose.
Старый 15.05.2019, 05:48 Автор темы   367
3FVAPE
OriginalEhpro Cold Steel 200 TC Mod $99.90
As a cooperation between Ehpro and Nebelfee, the Ehpro Cold Steel 200 TC Box MOD is a perfectly vape MOD! Just as its name, the Ehpro Cold Steel is constructed with fine stainless steel and exquisite craftsmanship, making it a sturdy, durable and elegant device for daily use. The Ehpro Cold Steel adopts multiple working modes, PWR/ TEMP / CURVE / VOLT / BYPASS, for your selection to meet almost all of your vaping needs. The pop-up battery cap also brings you an easy cell installation. Plus the convenient TYPE-C USB port, you can enjoy a easier charging and firmware upgrade. Best partner for enthusiastic vapers.
Vapeasy La Le Dripper RDA Clone $9.99
This dripper RDA is with a diameter of 22 mm fits all mods. Discreet, this reconstructible clean design is designed with high-end materials: 316 stainless steel. Its easy assembly will allow you to savor your e-liquid for convenience that you like thanks to its adjustable airflow
SXK KA V8 RTA Clone Original Price $28.80, Now Only $19.99
Please log in to see the lower price.
The SXK KA V8 RTA Clone is a 22mm rebuildable tank atomizer with 5ml of juice capacity. It is made from 316 stainless steel. The RTA features dual post build deck, heat sink top cap and bottom adjustable airflow
SXK Caiman BF MTL RTA Clone Original Price $26.80, Now Only $18.59
The SXK Caiman BF MTL is an RTA designed for cheek throw (MTL), with dual post deck for single coil configuration and 22mm diameter. The tank is in PC with a replacement in black POM. The MTL RTA comes with Bottom Feeder pin to be used also in squonk mod.
The air can be regulated through the 6 holes (it can be totally open or closed) and it is also equipped with 3 adapters to customize the vape experience.
Vapesoon DT273 810 Replacement Drip Tip $1.99
The Vapesoon replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.
Vapesoon DT237-C 810 Replacement Drip Tip $1.99
The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.
Replacement Drip Tip for Lost Vape Orion Pod $1.99
The replacement drip tip is made from resin and is suitable for Lost Vape Orion Pod
Vapesoon DT271-H 810 Replacement Drip Tip $1.69
The OriginalVapesoon 810 drip tip is made from resin with 12.5mm diameter 810 connector. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Replacement Tank Tube for 22mm Petri RTA Clone $1.99
The Replacement Tank Tube is made from PC and suitable for Petri RTA Clone. The PC tank is with 21mm diameter and 2ml capacity
OriginalRincoe Mechman Replacement Dual Mesh Coil Head $12.99
The Rincoe Mechman Sub-Ohm Tank utilizes the Single Mesh Coil is rated at 0.25, perfect for 40 to 60W output. The coil is suitable for use with the Mechman Sub-Ohm Tank. These replacement coils use kanthal mesh heating material and organic cotton.
OriginalRincoe Mechman Replacement Single Mesh Coil Head $12.99
The Rincoe Mechman Sub-Ohm Tank utilizes proprietary coils the dual mesh coil is rated at 0.2 ohm with the output recommendation of 50 to 80W. The coil is suitable for use with the Mechman Sub-Ohm Tank. These replacement coils use kanthal mesh heating material and organic cotton.
Старый 16.05.2019, 05:02 Автор темы   368
3FVAPE
Original Cool Vapor STAN 200W TC VW Variable Wattage Box Mod Original Price $39.90, Now Only $33.99
The Cool Vapor STAN 200W VW box mod supports variable wattage form 5W to 200W. The is powered by dual 18650 batteries (not included) and supports 3 working modes: Power mode / Voltage mode / Mechanical mode. This mod is with multi-protection: Overtemperature protection / low load resistance protection / High load resistance protection / Battery reverse connection protection / Low battery voltage protection / High battery voltage protection.
Terk V2 RDA Rebuildable Dripping Atomizer Clone with BF Pin $11.59
The TERK V2 24mm Squonk RDA Clone creatively crafted for building enthusiasts, implementing a large two-post clamp configuration with AFC constructed onto the build deck and comes with two top cap options: 24mm and 25mm. The TERK V2 style RDA supports dual coil configuration on the expansive space of the build deck, calling on the clamping systems, top secured, to affix performance coils within the appropriate terminals. The dual slotted airflow system can be found on the mid cap, sending airflow from the side of the tank to the side of the coil, creating dense flavorful clouds. The additional support of two top cap options allows for user-customization and preference with squonk 510 pin to match best squonk mods.
Original Asmodus Minikin 3S 200W TC VW Variable Wattage Box Mod + Viento Tank Kit Original Price $109.95, Now Only $95.99
Minikin 3S Mod and the Viento Tank, it is an extremely powerful TC kit inherited from Minikin family with ergonomic design and advanced fingerprint sensor. Powered by dual 18650 batteries and assisted by the new GX-200-UTC Chipset, the Mod can fire up to 200W whilst implementing variable wattage modes and more accurate temperature control mode than Minikin. The batteries can be charged via either the TYPE-C USB port on the mod or the wireless charging base (sold separately). In addition, there is a high definition full-color touchscreen to display the essential vaping data clearly. As for the Viento tank, it features a capacity of 3.5ml, durable hinged top fill mechanism, triple adjustable airflow slots, and powerful 0.15ohm mesh coils. Moreover, it is compatible with the SMOK Baby series of replacement coil heads, providing you with various options. All that said, the Minikin 3S will bring you an extremely wonderful vaping experience with optimal flavor and excellent vapor production.
Original Yocan Trio 3-in-1 500mAh Pod System Starter Kit $17.92
Yocan Trio Vaporizer?is a well-designed 3-in-1 pod system device. As the name suggests, the Trio comes with 3 different types of pods, which enable you to easily swap around e-juices, oils, and concentrates. Powered by a built-in 500mAh battery, it implements an adjustable voltage setting with three different power levels, which allows for different vaping needs. After turning on the device, press the power button 3 times in rapid succession to adjust the voltage level. The LED indicator light under the power button will light up with different colors to show different power levels, white for Low, blue for Middle, and Green for High. Moreover, this light can show you the different battery levels during charging, White for below 75%, and Blue for 75~100%. To bring you better experiences, the Trio also features a 10S preheat function. Rapidly click the power button two times will put the device in preheat mode. To deactivate the preheat function, simply press the power button 2 times again. When it comes to the pods, the juice and oil pods work with ceramic coils to deliver pure and consistent flavors, while the concentrate pod adopts a quartz dual coil to guarantee a crystal clean and smooth essence. Overall, the Yocan Trio is definitely a worthy collection.
Vapesoon DT270-LB 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.69
The authentic Vapesoon 810 drip tip is made from resin with 16mm diameter 810 connector. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Original Vapesoon DT269-LB 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.69
Original Vapesoon DT263-R 810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.99
The authentic Vapesoon 810 drip tip is made from resin with 16.5mm diameter 810 connector. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
Старый 17.05.2019, 05:19 Автор темы   369
3FVAPE
Original Asmodus Minikin 3 200W Touch Screen TC VW Variable Wattage Box Mod $69.99
The Asmodus Mini Minikin 200W is a mod box that features never before seen asMODus products, all in one package. The Minikin Mini 200W, and an Efest 18500 sized battery are all included in it. The Minikin 200W is a petite box mod that accommodates a single 18500 sized battery (NOT INCLUDED) and features a two-tone body style for a unique look. The Mini Minikin is powered by a GX-50-HF chip that features power saving capabilities as well as a "flavor taste" boosting mode. The GX-50-HF chip has an efficiency rating of 97%.This Iteam also has many color a to choose.
Original Ambition-Mods GATE MTL RTA Rebuildable Tank Atomizer $39.99
This clever RTA has so many features which set it apart from the crowd. Starting from the top, the Gate has a POM 510 drip tip fitting snuggly into the adjustable juice control ring, all held by the top filling cap which once removed enables easy filling. The main body of the tank encompasses a stylish and beautifully finished dombed chimney, the glass is held securely at both ends with O-rings. The tank base also has some rather clever features, capable of accepting Clapton as well as round wire builds and a choice of two 510 inserts to offer a restricted 0.8mm draw or a looser 1.5mm draw. The adjustment options progress even further from there with the airflow control ring which has a choice of slits or circular holes for your vaping pleasure.This Iteam also has another color and a 3.5ml version to choose.
SXK D.VA RDTA Rebuildable Dripping Tank Atomizer Clone Original Price $19.90,Now Only $18.09
The SXK D.VA RDTA Clone is construction from PEI and PC tank. The SXK RDTA is 22mm diameter and 2.5ml capacity. This RDTA supports single coil and bottom airflow adjustable.
PitBull RDTA Rebuildable Dripping Tank Atomizer Clone Original Price $14.99,Now Only $5.99
The PitBull RDTA Clone is a rebuildable dripping tank atomizer features 22mm diameter. The PitBull Style RDTA is made from food grade 316 Stainless Steel. The small air holes on the sleeve can be adjustable. With the small size and unique deck design, this RTA atomizer will bring you a good vaping experience.
Reload RTA Silver Rebuildable Tank Atomizer Clone with Bubble Tank Original Price $14.99,Now Only $7.99
The Reload RTA Clone is constructed from stainless steel in 24mm base diameter with about 5ml capacity (with bubble tank). It features post-less deck design for single or dual coil build and gold plated 510 positive pin. Comes with bottom side adjustable air slots for airflow control, you can enjoy better flavor and cloud. The RDA comes with a wide bore ULTEM 810 drip tip.
SQX Squape X Dream RTA Silver 4ml Rebuildable Tank Atomizer Clone Original Price $28.99,Now Only $10.99
The SQX X Dream RTA Clone is a rebuildable tank atomizer with 22mm diameter. It features 4ml juice capacity. The SQX X Dream Style RTA is top filling with stepless airflow control.
Original Ambition-Mods Gate MTL RTA Replacement 510 Drip Tip $5.99
The Ambition-Mods 510 Drip Tip is made from PEI and suitable for Gate MTL RTA.
Original Ambition-Mods GATE MTL RTA Replacement Tank Tube $3.99
The Ambition-Mods Replacement Tank Tube is suitable for GATE MTL RTA. The Tank is make from glass and with 2ml capacity. This Iteam also has another color and a 3.5ml version to choose.
Original Ambition-Mods Glass Tank + Inner Chamber + Chimney Set for GATE MTL RTA $12.99
The Ambition-Mods Replacement Glass Tank + Inner Chamber + Chimney Set is suitable for GATE MTL RTA. The Tank is make from glass and with 2ml capacity. The Inner Chamber + Chimney Set are made from 316 stainless steel.
Старый 18.05.2019, 04:55 Автор темы   370
3FVAPE
Vapeasy La Le Dripper RDA Clone $8.99
Original Blitz Monstor Sub Ohm Tank Vape Atomizer with 6.5ml Bubble Glass $34.99
The Blitz Monstor Sub Ohm Tank vape atpmozer, with 28mm diameter, comes with 3 different size removable AFC rings (24mm / 25mm / 28mm) to be compatible with most mods on the market. The Blitz Monstor features 4.5ml juice capacity, which can be extended to 6.5ml with a bubble glass tube.
The Blitz Monstor adopts various coil with dual and triple coil mesh coil wraped with unique wood pulp natural flax fiber mixed cotton. The Monstor is compatible with Freemax Fireluke Pro & Mesh Pro coil, allowing vapers to choose their own favorite option with satisfied vapor and flavor.This item also has many color to choose.
Original Rincoe Ceto SE 650mAh Pod System Starter Kit $19.90
Rincoe Ceto SE Kit is powered by a built-in 650mAh battery, it keeps a badge shaped power button, with a shallow, satisfying click. The battery can be charged via the micro USB port at the base and there is a 3 spoked LED indicator light at the bottom, which will inform you of your battery levels and in the event of malfunctions. As for the refillable pod, it can hold up to 2ml of your favorite e-liquid. The 1.3ohm MTL coils on this device are absolutely outstanding, with unexpected flavor depth and a really decent vapor production for this resistance and style of pod. Airflow is perfect, with a slight crackle that's indicative of relatively heavy vaporisation happening, it sounds like flavour and it tastes like it too.This item also has many color to choose.
810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA RTA / Sub Ohm Tank Vape Atmizer $1.69
The 810 Drip Tip made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.This item also has many color to choose.
510 Drip Tip for RDA / RTA / RDTA / Clearomizer / Sub Ohm Tank Vape Atomizer $1.79
The universal 510 Drip Tip is suitable for RDA / RTA / RDTA / Clearomizer Vape Atomizer. The mouthpiece is made from resin and the base connector is stainless steel.This item also has many color to choose.
Старый 20.05.2019, 05:02 Автор темы   371
3FVAPE
ShenRay VG V6 S V6S RTA Rebuildable Tank Atomizer Clone $32.99
The ShenRay VG V6S RTA Clone is a 23mm rebuildable tank atomizer with 5.5ml of juice capacity. It is constructed from 316 stainless steel with glass / PEI tank tube. The tank features infinitely adjustable bottom airflow, which is adjusted via 6 lockable holes in the deck. The tank can be refilled from the top.
SXK KA V8 RTA Rebuildable Tank Atomizer Clone Original Price $29.80, Now Only $20.99
YFTK Speed Revolution 2019 RDA Rebuildable Dripping Atomizer Clone with BF Pin $13.99
The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product.
The YFTK Speed Revolution 2019 RDA Clone is construction from 316 stainless steel in 18mm diameter. The RDA is with dual pole for single coil. The bottom feeder pin.
Original Rincoe NESO X 350mAh Pod System Starter Kit $23.90
Rincoe NESO X Kit is a sleek and simple looking pod device. Powered by a built-in 350mAh battery, it adopts a draw-activated firing mechanism instead of buttons, thus very easy to operate. The battery can be charged via the micro USB port at the base, and there is a small 'N' branded at the bottom of the device which doubles as an LED indicator, it lights up when you vape and glows red when it's time to charge up. As for the refillable pod, it can hold up to 1.8ml of your favorite e-juice. The 1.3ohm included coil is a pleasure to vape on, providing above average flavor and outstanding vapor production for both MTL and DTL draws. Anyway, the Neso X is a perfect choice for beginners or salt nic lovers who are after an affordable device that still offers a quality experience.
Original Blitz Monstor Replacement Dual Mesh Coil Head (3PCS) $9.85
The coil is with Dual Mesh in 0.2 ohm (works with 60~80W). This coil is suitable for Blitz Monstor sub ohm tank. This item also has many versions to choose.
Original Yocan Trio Pod System Kit Replacement E-juice Pod Cartridge (4 PCS) $6.78
The replacement Yocan Trio E-juice Pod Cartridge is designed for Yocan Trio Pod Kit. The pod cartridge is with 1.0ml capacity and ceramic coil to satisfy your any vaping needs and provide you the purest and flavorful experience. Plus the advanced airflow system with leak-proof design, the Trio Pod Cartridge will bring you a great vaping. Get them for your Yocan Trio Pod System.
Display Base Holder Stand for RDA / RTA / Sub Ohm Tank Vape Atomizer $5.99
The display base stand is made out of stainless steel. It is suitable for all size atomizers. Fingerprints and scratches are not easy to be left on this stand. And the curve design holds e-juice, preventing your table being flooded with liquid. The thread is specially designed and will not get any atomizer stuck.
Original Ambition Mods Polymer V2 Multi-Tool Kit Coil Jigs + Trox Insert Bit Set for DIY Coil $24.99
The Ambition Mods Polymer V2 Multi-Tool Kit consists of coil jigs set, mid cap and Trox insert bit set. With this Tool Kit, it is easy to make your own coils and build them on your favorite rebuildable atomizers with ease.
Старый 22.05.2019, 05:29 Автор темы   372
3FVAPE
Original ThinkVape Orbit 1100mAh Pod System Starter Kit $19.00
The ThinkVape Orbit is powered by a 1000mAh long lasting internal battery with 3.0ml pod capacity. The fill port is accessible by removing the rubber plug in the bottom and a thin needle tip bottle is suggested. The ThinkVape Orbit utilizes 2 types of coils: 0.6ohm mesh coil (For sub ohm vaping) and 1.2 ohm regular coil (For MTL vaping).This product also has many color to choose.
Original IJOY AI EVO Resin 20W 1100mAh Pod System Starter Kit $35.99
IJOY AI EVO Kit brings a timeless and yet fashionable e-cig that will seduce your mind and ensnare your heart the longer you gaze upon it. Adopting stunning double-sided resin material, the AI EVO presents a sleek and condensed frame that is remarkable for its perpetual simplicity. Featuring an 1100mAh built-in battery and engineered to enable max 20W output to strive at your best. This product also has many color to choose.
IJOY AI EVO cartridge comes with 2.8ml e-juice capacity. It is the perfect choice for both DTL and MTL lovers and highlights the innovative bottom-press refill system. The AI EVO automatically detects the atomizers resistance. The pre-installed 0.7 ohm mesh MTL coil is made for intensive clouds chasers, while the additional 1.4 ohm coil is optimized for nic salts.
Replacement Color Change Drip Tip for Lost Vape Orion Pod $2.59
The replacement drip tip is made from resin and is suitable for Original Lost Vape Orion Pod System.This product also has many color to choose.
Coppervape Satin Nano PEI Tank Set for Hussar Single Coil / Hussar the End RTA $6.99
The Coppervape Hussar Nano tank set is a replacement tank set made from 316 stainless steel and PEI. The tank is suitable for Hussar Single coil RTA and Hussar the end RTA.
Coppervape Skyline Style RTA Replacement PEI Tank $2.99
The Coppervape Skyline RTA Clone Replacement Tank is made from Ultem in 22mm diameter and 4ml capacity.
Coppervape Replacement 510 Drip Tip for Dvarw 16 RTA $1.59
The Coppervape Replacement 510 Drip Tip is made from PEI and is suitable for Dvarw 16 RTA.This product also has many color to choose.
Original ThinkVape Orbit Pod System Replacement MTL Regular Coil $10.99
The ThinkVape Orbit replacement 1.2 ohm regular coil is specially designed for MTL vaping to meet different vaping demands. The coils comes with 5 PCS / Pack.This item also has a 0.6ohm version for you to choose.
Original ThinkVape Orbit Pod System Replacement Pod Cartridge with 0.6 Ohm Mesh Coil + 1.2 Ohm Regular Coil $7.99
The ThinkVape Orbit Pod Cartridge is designed for ThinkVape Orbit Pod System Kit. Orbit pod Cartridge comes with 3ml capacity and 1.2ohm MTL coil and 0.6 ohm mesh sub ohm coil.
Replacement Short Tank + Drip Tip Set for FOUR ONE FIVE 415 RTA $5.99
The Replacement Tank + Drip Tip Set is suitable for FOUR ONE FIVE 415 RTA. The tank is with 2.0mL capacity.
Старый 23.05.2019, 04:56 Автор темы   373
3FVAPE
Original Vaporesso GEN 220W TC VW Variable Wattage Box Mod $47.99
Vaporesso GEN Mod comes with an innovative casing which features 4 layers of coating, giving it soft rubber-like feel, yet still making it smooth to the touch. The final coating makes it scratch-proof and flame retardant. Powered by dual 18650 batteries and assisted by the advanced AXON chipset, the mod can fire from 5W to 220W whilst it implements the pulse mode and the power ECO mode. In the pulse mode, AXON will continuously give you a hit throughout your puff (every 0.02s) - not just from the initial fire - bringing you more powerful, flavorful clouds with every puff. When the power ECO mode is on, it can optimize your device's settings to give you that extra vaping time you need. At last, there is a 0.91" OLED screen to show the essential vaping data clearly.This Product also has many colors to choose.
SXK RAVE Mini 67 Mosfet Squonker Semi-Mechanical Box Mod Clone with 4ml Bottom Feeder Bottle Original Price $78.90, Now Only $65.99
SXK RAVE Mini 67 Mosfet Squonker Semi-Mechanical Box Mod Clone is constructed from stainless steel and PEI. The Mosfet contains all the necessary protections, such as reverse battery protection, on / off functionality, LED battery level indication, auto cut-off, and many other proprietary features
Original Cool Vapor Takit Mini Mechanical Mod Original Price $29.80, Now Only $24.85
The Cool Vapor Takit Mini Mechanical Mod is constructed from 316 stainless steel powered by 1 x 18350 battery (not included). The mod is 0.5 to 3.0 ohm resistance range and with 3.3 to 4.2V output voltage.
FOUR ONE FIVE 415 RTA Rebuildable Tank Atomizer Clone $10.99
The FOUR ONE FIVE 415 RTA Clone is construction from 316 stainless steel in 22mm diameter and 4.5ml capacity. The 415 RTA is with top-refilling system and supports single coil design.
Original Cool Vapor Takit Mini Mechanical Mod + BF RDA Kit Original Price $39.90, Now Only $30.99
The RDA is constructed from PEI and 316 stainless steel in 22mm diameter. The RDA is with dual pole and supports single coil.
The RDA comes with bottom feeder pin.
Original Coil Father Coil Trimming Tool for RDA / RTA / RDTA DIY Building $1.99
The Original Coil Father Coil Trimming Tool is a convenient tool for perfect coil builds. First, measure the post width, then put the coil into the corresponding slots, finally cut the leads.This Product also has many colors to choose.
Original Wotofo Foldable Coil Trimming Tool for RDA / RTA / RDTA DIY Building Original Price $4.99, Now Only $2.99
Wotofo Foldable coil trimming tool will measure the width of the deck posts then simply place the coil legs through the corresponding holes & cut the wire to its' desired length. Using this coil cutting template allows you to pre-cut your coil legs with confidence & precision.
Original Geekvape Frenzy Pod Cartridge with 0.7ohm NS Mesh KA1 + 1.2ohm NS SS316L $9.99
Geekvape Frenzy Pod Cartridge features convenient airflow adjustment and bottom-refilling design for easy operation. It comes with 2.0ml e-liquid capacity and adopts the 0.7ohm NS Mesh coil for a really pure and smooth vaping flavor. There is also a 1.2ohm NS Coil included in the package. 1 PC per pack.
Старый 24.05.2019, 04:53 Автор темы   374
3FVAPE
Original Vaporesso Target Mini 2 50W 2000mAh VW Variable Wattage Box Mod $35.99
The Vaporesso Target Mini 2 50W Box MOD shrinks its size to an extreme. The Vaporesso Target Mini 2 adopts inbuilt 2000mAh battery, making the Target Mini 2 a portable yet powerful device. The adjustable output meets your different vape needs from 5W to 50W.
Atoll Hybrid Mechanical Mod Clone $20.99
This Atoll Hybrid mechanical mod Clone is made from brass and powered by 1 x 18650 battery (not included). The mod is in 25mm diameter and with magnet fire button.
Original Teslacigs WYE 2 86W VW Variable Wattage Box Mod + CITRINE 24 Tank Kit $25.90
Tesla WYE 2 86W Kit comprises of the WYE II 86W Mod and the CITRINE 24 Tank. Inheriting the classic pyramid shape of Louvre, the mod adopts a unique triangular hollow-out design to pay tribute to art. Powered by a high-rate 18650 battery, it can fire up to 86W and comes with four working modes including Soft, Normal, Hard and CCW. In the CCW mode, users can adjust the output power curve to set the taste mode suitable for himself, and realize "private customization". The intelligent OLED display will clearly show the battery power, coil resistance, output voltage, and output wattage, allowing you to know the use situation anytime, anywhere. As for the tank, it can hold up to 4ml of e-juice. Pre-installed in the tank is the integrated 0.17 ohms coil head. Besides, you will also get a spare 0.15 ohms T-X5 head in the set. Plus the easy top fill solution and the adjustable system, the CITRINE 24 is a perfect match to the mod. Anyway, the WYE II 86W Kit is worth a shot!
Original Vaporesso Target Mini 2 50W 2000mAh VW Variable Wattage Box Mod with VM Tank $56.99
Vaporesso Target Mini 2 Kit comprises of the Target Mini 2 Mod and the VM Tank. Powered by a built-in 2000mAh battery, the mod has an output power range of 5~50W and the battery can be fully charged in 60 minutes. On the control face, you have a power button and two function keys to operate the device. Above the function keys, there is 0.66" OLED display to show the essential vaping data clearly. As for the VM tank, it can hold up to 2ml of e-juice and comes with two different coil head options. One is the 0.6ohm EUC MESHED Head which uses Tea Fiber, soaking in juice more evenly. The other is the patented 1.0ohm EUC CCELL Head that is perfect for both Nic-Salts and CBD Oils. To change coils, just turn over the tank and replace from the bottom, without any mess. Anyway, the Target Mini 2 is worth a shot!
Replacement Wide Bore 810 Drip Tip for Goon / Kennedy / Reload RDA $1.59
This is a wide bore 810 drip tip made from PEI. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
510 Drip Tip for SMOK Trinity Alpha Pod System $1.99
This 510 drip tip is made from resin and adopts the glow-in-the-dark design. The 510 drip tip is specially designed for SMOK Trinity Alpha Resin 1000mAh Pod Starter Kit. The drip tip intends to bring you the most amazing vaping experience.
Старый 27.05.2019, 05:19 Автор темы   375
3FVAPE
Original Vandy Vape Mutant RDA Rebuildable Dripping Atomizer with BF Pin Original Price $36.99,Now Only $27.99
Vandy Vape Mutant RDA is designed in collaboration with the senior youtube vape reviewer--VapingwithTwisted420. Measuring 25mm in diameter, the wide build deck comes with dual posts, which supports vertical single coil or dual coils installation. Differing from the Widowmaker RDA, the Mutant is equipped with an innovative airflow barrel which features four different kinds of airflow holes, that means you don't have to frequently swap around different barrels. In addition, the Mutant adopts top squonk feed and bottom juice return, effectively avoiding potential leaking while maintaining a flavorful experience. Plus the two 0.39 ohm coils in the set, everything is ready for you. 4 colors to choose from.This product also has many color to choose.
YFTK Haku Riviera RDTA Rebuildable Dripping Tank Atomizer Clone $19.99
This YFTK Haku Riviera RDTA Clone is made from 316 stainless steel with 22mm diameter. The rebuildable atomizer has large build deck with cut-outs for easy coil placement. The RDTA adopts bottom-feed pin for squonking use.
Original Reewape R9 10W 350mAh Refillable Pod System Starter Kit Original Price $28.00,Now Only $13.99
Reewape R9 Pod kit is a new refillable pod stytem product, using innovative top filling style Anti-leak technology which allows for easy filling and anti-leak. Featuring a sleek chassis design with sharp lines and futuristic styling for easy handling, possessing a stylish and elegant high-gloss finish that is used in iphone. Also using high quality Japanese organic cotton and imported 1.6 ohm coil offer you true ultimate vaping experience for nice clouds and amazing MTL flavor. Powered by a built-in 350 mAh lithium battery and can be charged by micro-usb up to 40 minutes. This pod has 1.3ml capacity, and you can drip your favorite e-liquid into them. Beside, Reewape R9 Pod kit has 6 safety protection functions using food grade cartridge material giving you safety using experience. Reewape R9 pod is a sure choice for those looking for simplicity and efficiency in their daily lives.This product also has many color to choose.
Original Reewape R9 Refillable Pod Cartridge for Reewape R9 Pod System Kit Original Price $12.00,Now Only $7.99
Reewape R9 Pod Cartridge is suitable for Reewape R9 Pod System Kit. The R9 Pod Cartridge comes with 1.3ml capacity and 1.6ohm Japanese organic cotton coil for pure flavor. Reewape R9 Pod features top filling design with e-juice leak proof system.
Старый 28.05.2019, 04:36 Автор темы   376
3FVAPE
Original OFRF NexMesh Sub-Ohm Tank Atomizer Original Price $34.99, Now Only $24.99
OFRF NexMesh Sub-Ohm Tank is the first conical mesh coil tank powered by NexMesh coil. It arms with large capacity of 4ml that is able to vape longer. With being equipped with A1 and 316L mesh coils, thicker mesh weave and smoother airflow would be massively given. The coil comes with double cotton design that elevates the flavor to a new level. What is more, the dual vapor compression system really shows you richer and fresher flavor that you have not experienced before. This products also has many color to choose.
Vapeasy Patibulum MTL RTA Rebuildable Tank Atomizer Clone $12.99
Vapeasy Patibulum RTA Clone is a 22mm rebuildable tank atomizer designed for mouth to lung vaping. It is made from 316 stainless steel and Ultem. It features disk type AFC system and juice tunnel which is ideal for straight wicking.
Original Vsticking Viy 12W 750mAh Pod Vape System Starter Kit $24.99
Vsticking Viy Pod Vape System Kit 750mAh is coming! Vsticking Viy Pod Vape System Kit 750mAh, an ultra-portable size and slim pod body with ergonomic workmanship for better hand feeling, which comes with lightweight and portable design. Equipped with internal 750mAh battery with max output voltage 3.5V, the Vsticking Viy Pod will offer you stable and durable vaping experience. Besides, powered by Yihi SX270 Chipset, the performance of Vsticking Viy Pod will be more outstanding. Vsticking Viy Pod utilizes temperature control with completed anti-dry burn technology to provide you multiple protection. In addition, ceramic coil produces pure taste. LED indicator reminds the battery level. Vsticking Viy Pod will bring you optimal vaping life. This products also has many color to choose.
Replacement Bulb Glass Tube 8ml for SMOK TFV12 Prince Tank Atomizer $1.99
The Replacement Glass tank is suitable for the SMOK TFV12 Prince Sub-Ohm Tank. Made of durable reinforcement Pyrex Glass, you might wonder why you would need a replacement. Accidents happen. If you find yourself using your classy TFV12 Prince Sub-Ohm Tank frequently, youre going to want to keep it looking fresh. With our TFV12 Prince replacement glass, you can swap out any glass that may have residue buildup, a crack, or even a scratch. At an affordable price, why not have a few spares in your arsenal of vaping tools and accessories? In a world where accidents happen, its always better to be prepared for the worst.
Replacement Bulb Bubble Glass Tube 5ml for SMOK TFV8 Baby V2 Tank Atomizer $1.99
Increase your e-liquid capacity and keep your tank looking fresh with the SMOK TFV8 Baby V2 Replacement Glass Tube. This durable reservoir has a massive 5ml e-liquid capacity so you can enjoy one vape after another without worrying about running out of juice. Allowing for this increased e-liquid capacity is the convex shape of the glass tube, which gives your tank a unique appearance. Made of durable Pyrex glass, the SMOK TFV8 Baby V2 Replacement Glass Tube can last a very long time.
Replacement Bulb Glass Tube 5ml for SMOK TFV8 Big Baby Tank Atomizer $1.99
Now available here at 3FVAPE are SMOK Bulb Replacement Pyrex Glass Tube No 1 made for the SMOK TFV8 Big Baby Tank. These E- liquid reservoirs are made of durable Pyrex Glass. This Bulb shaped tube has a capacity of 5ml for anyone that wants to replace their TFV8 Big Baby Beast eLiquid less frequently.
Original OFRF NexMesh Replacement SS316L Coil for NexMesh Sub-Ohm Tank Original Price $14.99, Now Only $7.99
OFRF NexMesh Coil is designed for powerful taste experience combined with NexMesh A1 and SS316L conical mesh coil. The NexMesh SS316L conical mesh coil is responsible for the temperature control with o.15ohm by showing smoother airflow and also massively brilliant clouds creating. Buy it right now and have an awesome taste. 2 PCS in a pack. This products also has a 0.2 Ohm version to choose.
Старый 29.05.2019, 04:48 Автор темы   377
3FVAPE
RH X RDA Rebuildable Dripping Atomizer Clone with BF Pin $5.99
The Royal Hunter X RDA Clone is constructed from stainless steel base and aluminum sleeve in 24mm diameter. The RH X style RDA is in dual-pole with quad holes design. The airflow is from the side. The RH X RDA Clone comes with BF pin. This products also has many colors to choose.
Original CoilART BRON 25W 950mAh POD System Starter Kit $24.99
The CoilART BRON pod system is powered by 950mAh built-in battery. The CoilART BRON pod system features a 2ml refillable cartridge and 1.0ohm resistance. The CoilART BRON pod system has 3 levels of voltage output. This products also has many colors to choose.
Original Vandy Vape Mesh Coil Organic Cotton Laces for RBA / RDA / RTA / RDTA Atomizer $2.99
Vandy Vape Mesh Coil Cotton Laces are made of high-quality organic cotton specially selected for vapers. These cotton laces deliver superior flavors and smooth throat hits. Just get some to enjoy easy and amazing vaping. 10 PCS per pack.
Original OFRF nexMESH Sub-Ohm Tank Replacement 4ml Glass Tube $1.99
For OFRF nexMesh Sub-Ohm Tank with 4ml e-juice capacity. Made of high quality Pyrex glass, the Glass Tube is durable and perfectly fitting for OFRF nexMesh Sub-Ohm Tank. Easy to replace and clean. This products also has a 5ml version to choose.
Original Wotofo Recurve Dual RDA Replacement Wide Bore 810 Drip Tip Original Price $4.99, Now Only $3.59
Drip tip seems to be a minor part in vape gears, but it can affect the entire look and feel of your overall setup. These Wotofo Recurve Dual RDA Drip Tips are the same as the one included in the Recurve Dual RDA package. Wide bore design, plus really smooth surface, it not only fits comfortably between your lips, but also looks decent in all occasions. 810 drip tip for Recurve Dual RDA, your indispensable vaping partner! This products also has many colors to choose.
Original Wotofo Recurve Dual RDA Replacement Conversion Cap Original Price $14.99, Now Only $8.49
This Wotofo 22mm Conversion Cap is suitable for Recurve Dual RDA. The conversion cap is easy to replace, which will keep your Recurve Dual RDA fresh and clean. This 24mm Conversion Cap Kit is made for the purpose of giving your Recurve Dual RDA a totally new decoration. Reserving the same adjustable air inlet design but paired with flavor enhancing drip tip for different preferences. And the word RECURVEis engraved at the bottom of the cap, and on the ring as well. This products also has many colors to choose.
SXK Replacement Ceramic Coil Head for Bantam Box BB Mini Box Mod $6.95
This SXK Bantam Box BB Mini Style Coil Head is made from ceramic with 1.2ohm resistance. The SXK Bantam Box BB Mini Style Coil Head is shipped 5 PCS per pack.
SXK Replacement 1.2ohm Ceramic Coil + Adapter + 0.8mm / 1.2mm Airflow Valve for Bantam Box BB Mini Box Mod $11.90
The SXK Replacement accessories set is suitable for Bantam Box BB Mini Box Mod kit. The set includes 1.2ohm Ceramic Coil + Adapter + 0.8mm / 1.2mm Airflow Valve. The 0.8mm Airflow Valve is Suitable for MTL Vaping and the 1.2mm Airflow Valve is Suitable for Nicotine salt Vaping
Original CoilART BRON Replacement 2ml Refillable POD Cartridge $7.59
This CoilART Refillable BRON POD Cartridge is made from stainless steel. The CoilART BRON POD Cartridge features 2ml capacity and 1.0ohm. The CoilART BRON POD Cartridge is shipped 2 PCS per pack.
Старый 30.05.2019, 04:44 Автор темы   378
3FVAPE
Original Onetop Pallas Mechancial Tube Mod Original Price $35.50, Now Only $22.99
This Onetop Pallas mechancial mod is made from resin and brass. The Onetop Pallas mechancial mod is powered by one 18650 battery (not included). The Onetop Pallas mechancial mod features unique appearance with a stylish owl ring embeded into the body.This item also has many color to choose.
Original Rincoe Mechman 80W TC VW Variable Wattage Mod $29.90
The Rincoe Mechman 80W Mod, constructed from durable zinc alloy, is powered by single 18650 battery. The Rincoe Mechman 80W Mod is well defined with futuristic accents and markings to upkeep a visually striking physical appearance while retaining a moderate degree of impact resistance.This item also has many color to choose.
SXK Poet RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $15.90, Now Only $13.49
This SXK Poet RDA Clone is made from 316 stainless steel. The RDA is with dual-pole for single coil. The SXK Poet Style RDA is 22mm diameter and comes with a bottom feeder pin.This item also has many color to choose.
Original Rincoe Mechman 80W TC VW Mod + Mechman Mesh Tank Starter Kit $49.99
Rincoe Mechman 80W Starter Kit is a visually striking pen style device that consists of the Mechman 80W VW Mod and the Mechman Mesh Tank. Powered by a high-amp 18650 battery, the mod can fire up to 80W and comes with several output modes, including VW, Bypass, and TC modes. Operationally, a single firing button along with two buttons to perform adjustments provides user-friendly operation, and the OLED display screen creates organized informational readouts. As for the tank, it can hold up to 4.5ml of e-juice, filling is a breeze due to the sliding top fill structure. Plus the dual slotted bottom adjustable airflow control ring, this tank will bring you incredible flavors and vapors. In each set, these is a pre-installed 0.25ohm single mesh coil head and a spare 0.2ohm dual mesh coil head, so you'll be ready for anything. All in all, the Mechman 80W is a worthy collection! This item also has many color to choose.
Старый 31.05.2019, 05:13 Автор темы   379
3FVAPE
Original CoilART BRON 25W 950mAh POD Mod $20.69
The CoilART Bron Pod Mod is powered by built-in 950mAh battery with 25W max output. The CoilART Bron Pod Mod features 3 levels of voltage output, you can adjust the voltage as you wish. Adopting the LED indicator, you can easily check the battery status.This item also has many color to choose.
Original CoilART JoyNabis T-BOX 900mAh VV Mod for Compatible Pod $24.99
CoilART JoyNabis T-BOX comes with 900mAh built-in battery. Also the voltage is adjustable. With the Sure fit pod technology, CoilART JoyNabis T-BOX is suitable for compatible pod. It will bring the pure vaping experience to you.This item also has many color to choose.
YFTK Hellfire Maverick Tank RDTA Rebuildable Dripping Tank Atomizer Clone with BF Pin $21.99
The YFTK Hellfire Maverick Tank RDTA Clone can be used with Bottom Feeder pin (including pin), giving impressive convenience in filling the tank. The quality of the atomizers and machining Hellfire is another incentive that makes this an essential RDTA. Made from 316 stainless steel, and with a lower 2ml tank, the Maverick is a side air RDTA which takes its air from the top internally through the channels and is controlled by an upper air ring.
510 Drip Tip for SMOK Trinity Alpha Pod System $2.99
This 510 drip tip is made from resin and stabilized wood. The 510 drip tip is specially designed for SMOK Trinity Alpha Resin 1000mAh Pod Starter Kit. The drip tip intends to bring you the most amazing vaping experience.This item comes in random color.
SXK Replacement Squonk Bottom Feeder BF Bottle for RAVE Mini 67 Mod $1.99
The SXK Replacement Squonk Bottle Clone is specially designed for RAVE Mini 67 Mod. The SXK Style Squonk Bottle Replacement features 4ml capacity and 29.3mm height.
Старый 04.06.2019, 05:25 Автор темы   380
3FVAPE
Original Ovns Zorro 250mAh Pod System Starter Kit $11.29
The new OVNS Zorro Pod Starter Kit is powered by a 250mAh built-in battery, and the Ovns Zorro pod system can be charged with the included USB cable. The Ovns Zorro pod system features ultra slim and portable design, making it perfect for stealth vaping. The Ovns Zorro pod system has three different voltage settings which are low, middle and high. There is one refillable cartridge which has an e-liquid capacity of 0.7ml. The Ovns Zorro pod system has coil resistance of 1.8 ohm, which is great for mouth to lung vaping and higher nicotine strength e-liquids. Organic cotton is used in these pods, so you'll get good flavor out of them.
Original Oukitel Bison 1000mAh 30W Pod System Starter Kit $26.99
Oukitel Bison Kit is a versatile pod system which suits for both Nic Salts and CBD oils. Powered by a built-in 1000mAh battery, the Oukitel Bison pod system features a power range of 10~30W. The battery can be charged via the USB port on one side of the device and the fire button is located on the other side. In addition, there is a high-definition LED screen which will orderly show the battery status, vaping time, resistance, and power. As for the refillable pod, it can hold up to 2ml of e-liquid and comes with two coil options. One is the 0.6ohm mesh steel coil, and the other is the 1.2ohm ceramic coil. They will meet your different vaping needs easily. E-liquid filling will also be a breeze thanks to the easy top fill structure. Plus the effortless PNP coil replacement design, the Bison is no doubt worth a shot!
Original Smoant Pasito Pod Replacement DTL Mesh Coil Head $5.19
Pasito DTL Mesh Coil from Smoant is designed for Smoant Pasito Pod Kit. The Smoant Pasito DTL mesh coil head comes with 0.6ohm resistance for DTL experience. Just get it as a spare part for your Smoant Pasito Pod Kit.
Original Smoant Pasito Pod Replacement MTL Ni80 Coil Head $5.19
Pasito MTL Ni-80 Coil from Smoant is designed for Smoant Pasito Pod Kit. The Smoant Pasito pod replacement coil head comes with 1.4ohm resistance for MTL experience. Just get it as a spare part for your Smoant Pasito Pod Kit.
Original Smoant Pasito Pod Cartridge with 0.6ohm DTL Mesh Coil + 1.4ohm MTL Ni80 Coil for Pasito Pod System $8.05
The Smoant Pasito Pod Cartridge comes with 3ml capacity and adopts a replaceable coil design, and three types of innovative interchangeable in-pod coils, MTL coil, DTL coil, and RBA coil, are available for your different demands of vaping. Additionally, the top filling design and top adjustable airflow construction prevents the Smoant Pasito from leakage and bring great convenience and good flavor. Come and buy one Smoant Pasito Pod Cartridge as a spare part for your Smoant Pasito Pod Kit.
Original Smoant Pasito Pod System Replacement RBA Single Coil Head $5.50
The Smoant Pasito RBA coil is suitable for Smoant Pasito pod kit. The resistance range is 0.5~1.0ohm. The Smoant Pasito RBA coil is packed one piece per pack.
Поиск в этой теме:
Copyright ©2007 - 2023, FONAREVKA.RU
Время генерации страницы 0.16242 секунды с 15 запросами
