Просмотров в теме 206199   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 13.11.2018, 04:57 Автор темы   241
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Asmodus Amighty 100W Touch Screen TC VW Variable Wattage Box Mod Original Price $79.95, Now Only $60.99
The Original Asmodus Amighty 100W TC VW box mod is powered by single 18650 / 21700 / 20700 battery (Not Included), it has many staple functions such as temperature control, TFR, TCR, and asMODus' Curve mode. The Amighty 100w Touch Screen mod can handle a wide variety of builds effortlessly, and if the user is a MTL vaper then that's more battery life to spare. The body and the battery door have spacers installed to ensure that the battery door wont go flying off when dropped. The Amighty 100W mod uses our new GX-100UTC chip with an UI (User interface) that is easy to navigate through with our "Swipe left of right to change firing modes". This item also has other colors to choose.
Original Smoktech SMOK SID 15W VW Variable Wattage Mod Original Price $14.99, Now Only $7.59
The SMOK SID features the latest e-cigarette technology innovations for a superior vaping experience. Not only is this design home to the best technical features, it's a good looking device as well. You'll find variable voltage and wattage and a 4 amp circuit to stand up to the most demanding cartomizers. The circuitry is contained in the head portion of the SID which can be removed from the battery tube. The battery connector is also located on the head and features a cone to dress up the connection. Smoktech's SID is eGo compatible and works with even tricky clearomizers like the Kanger T3. Combined with the advanced features, this should make SID one of the most versatile devices in your collection.
Original Sigelei Mini 30W VW Variable Wattage Box Mod Original Price $27.99, Now Only $13.99
The Original Sigelei Mini 30W Mod is a compact variable wattage vaping device with 0.8" OLED display. Powered by single 18650 battery (NOT INCLUDED), this mod can reach maximum output to 30W. It also comes with multiple protections to prevent danger.
Original Damn Vape Dread RDA Rebuildable Dripping Atomizer with BF Pin Original Price $32.99, Now Only $24.99
The Original Damn Vape Dread RDA is a 12-sided shape flavor chasing atomizer. It features 24mm diameter and is constructed from stainless steel. The honey comb airflow hits full surface of the LOLLY coil, the trident-post deck is designed for LOLLY coil build and wick. You may also build it with standard coils, this kit comes with easy LOLLY coil tool.
This RDA comes with bottom feeder pin. This item also has other colors to choose.
Original Damn Vape Fresia RTA Rebuildable Tank Atomizer Original Price $30.99, Now Only $22.99
The Original Damn Vape Fresia RTA is a 22mm MTL / Restrictive lung hit flavor RTA with a tank capacity of 2ml / 3.5ml. It is available for High / Med / Low concentration of Nic Salt or Regular e-liquid (Freebase e-liquid). It features the world's first T.I.T. (Tube in Tube) AFC system. You can switch freely between MTL and restrictive lung through AFC ring, but without changing any airflow reducer / cube. The MTL holes: 0.8mm 1.0mm 1.2mm 1.6mm; DL max flow: 2 x 9mm + 1.6mm (Diameter). It also comes with compact chamber, bottom airflow, raised build deck for closer throat hit. All for flavor. This item also has other colors to choose.
Original Eleaf Lemo II RTA Rebuildable Tank Atomizer Original Price $13.99, Now Only $6.99
The Lemo 2 is the advance version of the well-known Lemo series atomizers due to its new innovative design of a side e-liquid fill hole and the use of PEEK (the well-known high heat and corrosion resistance material) of insulating piece. Vaping becomes safer and more stable, and no more needs of detaching the atomizer during refilling. The fill process becomes easier and leakage can be avoided. The inheritance of RBA head also maximizes the fun of DIY experience and could bring cloud vapor production for you.
Original Ehpro eTank S2 Sub Ohm Tank Clearomizer Original Price $13.99, Now Only $6.99
The Original Ehpro eTank S2 Sub Ohm Tank is a 22mm clearomizer with 5ml of juice capacity. It comes with a 0.5ohm (5-35W) MSVC coil head. With the sliding adjustable airflow valve, it will bring you optimal flavor. This item also has other colors to choose.
Original Ehpro Billow V2 RTA Rebuildable Tank Atomizer Original Price $17.99, Now Only $8.99
The Ehpro Billow V2 RTA rebuildable tank atomizer is made from Stainless Steel and Glass. It features a 5ml capacity and 22mm diameter.
Original Bianty 2000mAh VW Variable Wattage Box Mod + Sub Ohm Tank Kit $30.99
The Original Bianty 2000mAh Kit consists of the Bianty 2000mAh Variable Woltage box mod and a sub ohm tank clearomizer. This item also has other colors to choose.
Mod:
The Original Bianty 2000mAh Variable Woltage box mod is constructed from zinc alloy. Powered by a 2000mAh built-in battery, it can fire up to an output wattage from 5W to 80W, the range of working resistance of common atomizer is 0.08~3.5ohm. The Bianty 2000mAh mod also comes with multiple protections: short circuit protection, low voltage protection, temperature protection, reverse connect protection, smoking overtime protects cigarettes for more than 10 seconds, and stops exporting.
Tank:
The included tank is a 24mm sub ohm tank, it is constructed from 303 stainless steel with high borosilicate transparent glass tank tube. It features 3ml juice capacity and 0.15ohm resistance. It also comes with Mess Skynet Fe Cr alloy heating network and simple top sliding cover which is convenient to operate.
Original Joyetech eGo One 1100mAh Starter Kit Original Price $27.99, Now Only $13.99
The Joyetech eGo ONE is petite yet powerful, eGo ONE is the One device for everyone. Adhering to this concept, eGo ONE stands out from different kinds of e-cig products by using two types of changeable atomizer head. The different types of atomizer will cater for different vaping methods. Mouth inhale, mouth to lung inhale or direct lung inhale. It is powered by built-in 1100mAh battery.
3M Wrapper Smart Skin Sticker for Juul $1.59
The Smart Skin Sticker is used for Juul, made from 3M material. It is designed as 2.5D stereoscopic cover film, which looks more vivid, and you can feel concave-convex when touch it. This item also has other colors to choose.
Original Damn Vape Lolly Coil Kanthal A1 Pre-built Wire for Dread RDA Original Price $3.99, Now Only $1.99
The Original Damn Vape Lolly Tool is used for DIY Lolly style coils. It features 16mm diameter and 28.5mm height and is constructed from stainless steel and aluminum alloy. It comes with a 0.7mm and a 1.1mm wire hole for wire from 19GA to 26GA (best 24GA). The Lolly Coils are suitable for Damn Vape Dread RDA.
Original Damn Vape Lolly Tool for DIY Lolly Style Coils Original Price $5.99, Now Only $3.99
Original Damn Vape Replacement Tank Tube for Fresia RTA Rebuildable Tank Atomizer $2.99
The Original Damn Vape replacement tank tube is made from glass with 2ml of juice capacity and is suitable for Fresia True rebuildable tank atomizer. This item also has other Version to choose.
3FVAPE вне форума   Вверх
Старый 14.11.2018, 05:04 Автор темы   242
3FVAPE
Original VapeMons Gearbox 222W Wireless Charging TC VW Variable Wattage Box Mod Original Price $99.00, Now Only $51.99
The Origianl VapeMons Gearbox 222W TC Mod is a high-end and stylish mod, which has IML panel with unique pattern and the vertical 0.96" OLED screen with 3D feel. The bullet point is the wireless charging function which support 1.5A fast charging, a charging pad is included. The VapeMons Gearbox mod is created in small size, and it has smooth round edges to offer you better touch feel. Powered by dual 18650 batteries (Not Included), it can fire up to an output wattage from 5W to 222W, supporting standard VW mode and TC mode. You can easily operate it with the large fire key and one-hand control knob buttons which enabled an LED light ring, and there are 5 profiles for you to change the interface. The back cover is designed to be magnetic, and you would never find it difficult to replace batteries. This item also has other colors to choose.
Original SmokTech SMOK FURY-S Mechanical Tube Mod Original Price $15.99, Now Only $7.99
The SMOK FURY-S Mechanical Mod is powered by single 18650 battery (NOT INCLUDED), with lockable bottom magnetic firing button, brass battery contacts, and telescoping positive contact.
Original NCR Garage Hero Coil-less RTA Rebuildable Tank Atomizer Original Price $30.00, Now Only $23.99
The Original NCR Garage RTA is a coil-less tank atomizer. It comes with SGS compliance heating element, CHS e-juice storing (camelback hydration system), and 0.2ohm (30~40W) safe power with one million puffs. The NCR Garage tank also has mellower taste which brings you stronger nicotine feeling, and features spit-free / easy build and dry-heating-cleaning.
Original Innokin iClear 30B BDC Bottom Dual Coil Clearomizer Original Price $9.99, Now Only $4.99
The Innokin iClear 30B Dual Coil Clearomizer features dual coils, bottom feeding design, an upgraded replaceable atomizer head, a large 3.0mL capacity, removable and rotatable mouthpiece, compatible with any 510 drip tip. The replaceable Dual Coil Head on the Innokin iClear 30b Dual Coil Clearomizer is bottom feeding, allows to keep your wick constantly saturated and takes away the need to twist and turn your device prior to every vape.
Original Justfog S14 Hybrid Clearomizer Original Price $9.99, Now Only $4.99
The Justfog S14 1.8ml Clearomizer has two different vaping modes for choice. And the airflow control comes in 12 levels for diversity. The problem of coil short is resolved by double protection system. Equipped with organic cotton coil, S14 Clearomizer offers you pure flavor without dry hits.
Original Ehpro eTank F1 RDTA Rebuildable Dripping Tank Atomizer Original Price $25.99, Now Only $12.99
The Ehpro eTank F1 RDTA is a 24mm rebuildable dripping tank atomizer. It has 4ml of juice capacity. It features creative pressing system design, quad terminals design for dual coil builds, top airflow control with 180-degree airflow circulation and bottom e-liquild filling.
Original Kanger Aerotank Mega Clearomizer Original Price $15.99, Now Only $7.99
The Kanger Aerotank Mega Clearomizer is a 22mm tank atomizer with 3.8ml juice capacity. It features adjustable airflow, with 1 airhole on the AFC ring to adjust for optimal flavor
Original Kanger Aerotank Giant 510 BDC Clearomizer Original Price $13.99, Now Only $6.99
The Kanger Aerotank Giant clearomizer is constructed from stainless steel and glass. The metal tube in the center of this Clearomizer leads from the mouthpiece to the battery end. Avoid getting liquid in this tube when filling the Clearomizer.
Original Vapeston Maganus Ni DVC Sub Ohm Tank Clearomizer Original Price $13.99, Now Only $6.99
The Maganus Ni by Vapeston is an updated version of its DVC tank. Using Exclusive Dual Vertical Coil (DVC) technology, the Ni supports 20~120W VV and temperature control devices. With adjustable airflow drip tip, 0.15 / 0.25 ohm Ni200 coil, Japanese Organic Cotton Wick, Refill from top and bottom, anti-leaking design, massive airflow ever, Maganus Ni meets all the needs to be the best sub ohm tank for temperature control devices. Its ability to keep the vapor cool as well as great flavor continuously over 60 watts is how the Maganus Ni distinguishes itself from over other tank in the market.
Original Desire CUT220 220W TC VW Box Mod + Bulldog Sub Ohm Tank Kit Original Price $79.99, Now Only $54.59
The Original Desire CUT220 220W Mod Kit consists of the Desire CUT220 220W variable wattage box mod and the Bulldog sub ohm tank. This item also has other colors to choose.
Mod:
The Original Desire CUT220 220W variable wattage box mod, powered by dual 18650 batteries (Not Included), is able to reach up to an output power from 5W to 220W with multi modes: Novice / VW / TC (Ti / SS) / TCR / PMG / Bypass. The smart breathing light can change color to display power: below 30% red, 30%~70% yellow, over 70% green. Equipped with 1.3inch TFT color screen, the CUT220 can display the detail clearly. Designed for novices or experienced vapers, the CUT220 mod features an innovative Novice Mode which can automatically detect what coil you use and lock in an ohm to effectively prevent burning of the coil.
Tank:
The included Bulldog sub ohm tank is a 24.5mm Clearomizer, it comes with 4.3ml capacity, 0.18ohm Mesh coil and 0.2ohm triple coil. It features push-top filling and bottom adjustable airflow system.
Original Vapethink Magic Shark 3M Wrapper Skin Sticker for IQOS $1.99
The Original Vapethink Magic Shark Wrapper Skin Sticker is used for IQOS, made from 3M material. It is designed as 2.5D stereoscopic cover film, which looks more vivid, and you can feel concave-convex when touch it. This item also has other colors to choose.
Original CoilART Replacement Pod Cartridge for UME U-1 240mAh Pod System $6.99
The Original CoilART pod cartridge is for UME U-1 240mAh pod system. It comes with a resistance of 1.8ohm and its refillable 0.8ml pod allows you to easily refill e-liquids.
This product comes with 4 pcs in a pack.
SXK Replacement Tank Tube for Doggystyle V2 2K18 RTA Clone $1.99
This replacement tank tube is made from PC and is suitable for SXK Doggystyle V2 2K18 RTA Clone. It features 22mm diameter and 3.5ml capacity.
Original Nitecore UM4 Intelligent USB Four-Slot Charger $27.99
The Original Nitecore UM4 Intelligent Charger is a brand new intelligent USB four-slot charger with a total max output of 3000mAh. A single slot max output of 1500mAh and it is capable of charging 4 batteries simultaneously and controlling each slot independently. It only takes 2 hours to charge 80% of a 3,500mAh battery. The included LCD screen can display a real-time information of Battery Health by "Good" or "Poor", Internal Resistance, Charging Current, Battery Voltage, Charged Volume and Charging time. Moreover, the UM4 incorporates an optimized IMR battery charging program, which is able to monitor the entire charging process, ensuring that the cut-off voltage is always within safe limits to extend the lifespan of the batteries.
Original Innokin Replacement Dual Coil Head for iClear30B Clearomizer Original Price $5.99, Now Only $2.99
The replacement coil head comes with 2.1ohm resistance and is suitable for Original Innokin iClear30B Clearomizer.
This product comes with 5 PCS in 1 pack.
Original Anlerr G1 2200mAh TC Heat Not Burn Vaporizer for Glo Heatstick $36.99
The Original Anlerr G1 2200mAh TC Vaporizer is a portable heat not burn device for dry herb, tobacco cartridges, heat sticks (Glo). It has very good taste like real cigarette, but no cigarette tar or second-hand smoke. Powered by a built-in 2200mah battery, it can support about 25 pcs cartridges in full charged. It comes with the advanced OLED display to help smokers get a more easy use, adjustable temperatures to match smokers different demands of smoke, food grade 306 stainless steel heating cup keep 360-degree full heating, aluminum alloy frame keep the device away from twist off or break off, and silicon anti-heat circle to keep the device is less hot. The Anlerr G1 has non sticky, leakage , big vapor, full heated and pure taste.
This product comes without any heatstick or slim cigarette.
Старый 15.11.2018, 04:56 Автор темы   243
3FVAPE
SOB OG Parallel Hybrid Mechanical Box Mod Clone $18.59
The SOB OG Parallel Mechanical box mod Clone is constructed from stainless steel and POM and is powered by dual 18650 batteries in parallel (NOT INCLUDED). The battery access door is easy to remove by hand. The venting holes are positioned at the access door. The logo and series number are on the mod. This item also has other colors to choose.
Original Joyetech Espion Tour 220W TC VW Variable Wattage Box Mod $39.03
The Original Joyetech Espion Tour 220W TC VW box mod is powered by dual 18650 batteries (Not Included), reaching an output wattage from 1W to 220W and 2A quick charge, providing you with huge vapor production. It feels super light when you hold it in hand. You can easily manage it with an intuitive 0.96inch display. It also comes with multiple protections for safety vaping. This item also has other colors to choose.
Original Kanger Subtank Mini Clearomizer Original Price $19.99, Now Only $9.99
KangerTech Subtank Mini Pyrex Glass Cartomizer, the biggest highlight is the new innovation Organic Cotton Coil (OCC) which offers huge vapor. It makes use of organic cotton which bring healthy and environmental vaping. E-juice vaporizing of OCC is as much as RBA.
Original Kanger T3D eGo Dual Bottom Coil Tank Clearomizer Original Price $3.99, Now Only $1.99
The Kanger T3D is with a Bottom-Dual-Coil design. The dual-coil system means double the vapor production as their single-coil counterparts. The T3D offers a truly robust flavor, couples with a magnificent vapor production, sure to please even the most particular of vapers. The Kanger T3D boasts a massive 2.5ml liquid capacity, requiring much fewer refills than smaller clearomizers on the market. However, Kanger brilliantly designed the T3D to balance this large capacity with length, making it easy to fit on a standard eGo-size battery. One important factor to keep in mind is that due to the dual-coil design, this clearomizer will not work optimally with constant voltage batteries, such as the eGo-C, eGo-T, and eVod. For optimal performance, we highly recommend using a variable voltage battery, such as the Joyetech eGo-C Twist, Kanger eVod VV Twist, and the Innokin iTaste VV batteries. This item also has other colors to choose.
Vapeasy 1:1 Kryten RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $9.99, Now Only $5.99
The Vapeasy Hadaly V2 Kryten RDA is constructed from 316 stainless steel and in 24mm diameter. The Kryten RDA is the updated version of its predecessor the Hadaly RDA. The Kryten RDA is with unique dual post coil clamping system for dual coil build. The RDA is compatible with 810 drip tips.
YFTK Salix V1.0 RDA Rebuildable Dripping Atomizer Clont with BF Pin $18.99
The YFTK Salix V1.0 RDA Clone is a 22mm rebuildable dripping atomizer. It is constructed from 316 stainless steel. It features single coil build deck and side airflow, with replaceable airflow insert to provide different vaping experience.
SOB OG Parallel Hybrid Mechanical Box Mod Clone + Outlaw RDA Kit Clone $20.99
The SOB OG Parallel Kit Clone consists of SOB Parallel Mech mod Clone and Outlaw RDA Clone. This item also has other colors to choose.
Mod:
The SOB OG Parallel Mechanical box mod Clone is constructed from stainless steel and PC and is powered by dual 18650 batteries in parallel (NOT INCLUDED). The battery access door is easy to remove by hand. The venting holes are positioned at the access door. The logo and series number are on the mod.
RDA:
The Outlaw RDA Clone is constructed from stainless steel with 24mm diameter. The deck features classic dual post style design and comes with a deep juice well. The airflow can be adjusted by dual airslots on each side.
Original Joyetech ESPION Tour 220W TC VW Box Mod + Cubis Max Tank Kit $61.29
The Joyetech ESPION Tour 220W kit consists of the Original Joyetech ESPION Tour 220W TC VW box mod and Cubis Max tank. This item also has other colors to choose.
Mod:
The Original Joyetech ESPION Tour 220W TC VW box mod is powered by dual 18650 batteries (Not Included), reaching an output wattage from 1W to 220W and 2A quick charge, providing you with huge vapor production. It feels super light when you hold it in hand. You can easily manage it with an intuitive 0.96inch display. It also comes with multiple protections for safety vaping.
Tank:
The Original Joyetech Cubis Max tank is a coil-less atomizer with 28mm diameter. It comes with the innovative Joyetech NCFilm heater, being a coil-less design, this NCFilm heater can be easily cleaned thus supports a long lifespan. The Cubis Max atomizer allows a simple replacement of cotton for a pure and delicate vaping experience. Having the top-fill and top-airflow system, you're free of any leakage. Best at 40W, you can enjoy a huge but flavor clouds.
Original Kanger Vertical OCC Coil Heads for Subtank Plus / Mini / Nano Original Price $6.99, Now Only $3.59
The Kanger Vertical OCC coil heads is suitable for Subtank Plus / Mini / Nano. It features 1.5 Ohm resistace that can support 10~26W power output.
Original Kanger Dual Coil Heads for Aerotank / Aerotank Mega / Protank 3 Clearomizer Original Price $5.99, Now Only $2.99
The Kanger Dual Coil Heads is suitable for Kanger Aerotank, Aerotank Mini, Aerotank Mega, Protank 3, Mini Protank 3, eVod 2, T3D, eVod Glass. It features 1.0 ohm of resistance.
Original Kanger Subtank Nickel Ni200 OCC Temperature Sensing Coils Original Price $9.99, Now Only $4.99
Kanger new OCC (Organic Cotton Coil) Ni200 Atomizers are designed to work with Kanger Subtank line of clearomizer tanks, specifically in DNA 40 based mods that have temperature sensing technology. Available in 0.15 ohm resistance, these OCC Ni200 Atomizers utilize nickel coils and are perfect for powerful vaping without the hassle of building. Kanger OCC Ni200 Atomizers are rated to work between 20W and 45W. Utilizing actual Japanese organic cotton, Kanger claims that these coils last longer, offer a larger heating surface, and create a purer taste than any coils that have come before them. Each pack comes with five genuine Kanger OCC Ni200 Atomizers.
Original Kanger Replacement Coil Heads for Protank Clearomizer Original Price $4.99, Now Only $2.59
The Kanger Replacement Coil Heads is suitable for Kanger Protank Clearomizer and features 2.5ohm resistance.
Original Kanger Replacement Coil Head for SubTank Clearomize Original Price $9.99, Now Only $4.99
The Kanger Replacement Coil Heads is suitable for Kanger SubTank Clearomizer and features 1.2ohm resistance.
Original Sense Ni200 Replacement Coil Heads for Herakles Clearomizer Original Price $9.99, Now Only $4.99
The Original Sense Herakles coil heads features a 0.2 ohm resistance that can support 15~50W power output. It is made from NI200. Hope this coil head will meet your demands.
Original Sense Replacement Coil Head for Herakles Hydra Clearomizer Original Price $7.99, Now Only $3.99
The Original Sense Herakles Hydra coil heads features a 0.2 ohm resistance.
Original Kanger Replacement Coil Heads for T3S / MT3S Clearomizer Original Price $3.99, Now Only $1.99
The Kanger Replacement Coil Heads is suitable for Kanger T3S / MT3S Clearomizer and features 2.5ohm resistance.
Original YouDe UD Zephyrus Ni200 OCC Coil Heads Original Price $7.99, Now Only $4.09
Youde UD Zephyrus Ni200 OCC Dual Coil uses 100% Japanese organic cotton and features 0.15 ohm resistance. It is suitable for the Youde Zephyrus and Goliath V2.
810 Drip Tip for 528 Goon / Kennedy / Reload RDA $1.99
The 810 drip tip is made from resin with 8.4mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA.
This drip tip will be shipped with random color. More color than what's on the image.
YFTK Replacement Tank Tube for Doggystyle V2 2K18 RTA Clone $5.99
This replacement tank tube is made from PC and is suitable for YFTK Doggystyle V2 2K18 RTA Clone. It features 22mm diameter and 3.5ml capacity. This item also has other colors to choose.
Старый 16.11.2018, 04:46 Автор темы   244
3FVAPE
Original REV Phantom 220W TC VW Variable Wattage Box Mod $56.09
The REV Phantom 220W mod cranks up a few more notches with its outstanding display and adrenaline-inducing vaping experience. Powered by dual 18650 batteries (NOT INCLUDED) and advanced REV chipset, the Phantom mod can fire up to the max output of 220W with 0.002s quick firing speed and complete output modes. It mainly features the 2.8 inch large LCD color screen covered by quartz-level panda glass with greater visibility and solidity. And the REV Phantom also comes with 32MB onboard memory for storing more high-res dashboards. Plus the customable LED around oversized button and 4 digits pin lock function, it will be very safe and convenient to operate the REV Phantom. This item also has other colors to choose.
Original Advken Owl Sub Ohm Tank Clearomizer $25.99
The Original Advken Owl tank is a 25mm diameter sub ohm tank which comes with a bullet-shaped appearance with exquisite carving and high-quality stainless steel and Pyrex glass construction. It is compatible with two types of coil, the 0.16ohm and the 0.2ohm mesh coil, which could bring great flavor and huge clouds. In addition, the top airflow system avoid leakage and condensation and top slide filling design makes refill easier. Plus the 810 heat-resistant PEI drip tip, you can form your own mini weather system each time you vape. This item also has other colors to choose.
Original Horizon Falcon Sub Ohm Tank Clearomizer $26.79
The Original Horizon Falcon tank is the latest sub ohm tank from HorizonTech, with 25mm diameter, which features a large 7ml e-juice capacity. It is comes with a preinstalled M2 0.16ohm (70~80W) coil head and a replacement M1 0.15ohm (70+/- 10W) coil head. Designed as top filling system and bottom airflow control system to bring you large vapors. It comes with 4 different coils for option: the F1 coil, which is a 0.2 ohm parallel coil head, rated at 80W, with a liquid guiding element of 70% organic cotton and 30% wood pulp, the F2 coil, which is a 0.2 ohm parallel coil head, rated at 80W, with a liquid guiding element of natural flax fiber, the F3 coil, which is a 0.2 ohm parallel coil head, rated at 70W, with a liquid guiding element of flax fiber and flax paper, and finally the M1, a 0.15 ohm mesh coil head, rated at 70W, with a liquid guiding element of 70% organic cotton and 30% wood pulp. This item also has other colors to choose.
Original Palmary Vapor Pontos RDA Rebuildable Dripping Atomizer with BF Pin $19.69
The Original Palmary Vapor Pontos RDA is a 25mm rebuildable atomizer, it is constructed from premium 304 stainless steel and comes with special 810 Ultem drip tip reduce condensate. Besides, there are multiple airflow style design (2~4 sides adjustable airflow), which will provide excellent flavor and clouds.
Amadeus MTL RDA Rebuildable Dripping Atomizer Clone with BF pin $19.49
The Amadeus MTL RDA Clone is a 24mm rebuildable dripping atomizer constructed from 316 stainless steel. It comes with classic velocity style build deck and supports dual coil builds. The bottom airflow will bring you great flavor.
Amadeus MTL RTA Rebuildable Tank Atomizer Clone $21.19
The Amadeus MTL RTA Clone is a 24mm rebuildable tank atomizer constructed from 316 stainless steel. It comes with 5ml and 2ml glass tube. The adjustable airflow will bring you optimal flavor.
YFTK Replacement Top Cap for Citadel RDA Rebuildable Dripping Atomizer Clone $5.99
The replacement top cap is made from PC and suitable for YFTK Citadel RDA Clone. This item also has other colors to choose.
Старый 17.11.2018, 04:41 Автор темы   245
3FVAPE
Original USV L USV-L 75W TC VW Variable Wattage Box Mod Original Price $69.99, Now Only $26.99
The Original USV L 75W Box Mod is a nice machined mod with compact design. It is equipped with VO 75 chipset and the max power output can reach 75W. The temperature control range is 100~300'C (212~572'F). The doors of both sides can be slided easily but it is not loose. This mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose.
20700 / 21700 Hybrid Mechanical Tube Mod $21.39
The mechanical tube mod is made from copper and features 25mm diameter, hybrid connection, lockable side firing button, and revolutionary firing mechanism. There is no spring nor magnet, just constant contact. It comes with two contact points for increased conductivity. Delrin insert is for heat dissipation. The mod is powered by single 20700 / 21700 battery (NOT INCLUDED). This item also has other colors to choose.
Goon 25 RDA Polished Version Rebuildable Dripping Atomizer Clone with BF Pin $10.99
The Goon 25 RDA Clone is constructed from stainless steel and in 24mm diameter. The Goon 25 RDA Clone is with unique dual post and bridge clamp posts coil clamping system for dual coil build. It comes with adjustable side airflow and 810 wide bore POM drip tip.
Original IJOY Mystique 162W TC VW Box Mod + Mesh Sub Ohm Tank Kit Original Price $45.99, Now Only $37.59
The Original IJOY Mystique 162W mod kit consists of the Original IJOY Mystique 162W TC box mod and the Mystique Mesh sub ohm tank Clearomizer. This item also has other colors to choose.
Mod:
The Original IJOY Mystique 162W TC box mod, powered by dual 18650 batteries (Not Included), can reach up to a max output wattage of 162W. It adopts PMODE / POWER / POD / MTL / TEMP and BYPASS modes for your selection, meeting your different vaping needs with outstanding performance, long-lasting battery and all-round protection.
Tank:
The included Mystique Mesh is a 24mm sub ohm tank. The perfect combination of the mesh coil and the fiber cotton makes the heating even and absorb e-juice effectively, the 0.15ohm coil resistance is optimized for best flavor with cloud production. The fully adjustable dual airflow control gives you a completely customizable experience.
PVC Wrapper Skin Sticker for 18650 Battery $1.49
The wrapper sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. It comes with Master Yoda pattern.
This product comes with 10 PCS in one pack. This item also has other colors to choose.
Vapeasy Replacement Top Cap + Drip Tip for Citadel RDA Rebuildable Dripping Atomizer Clone $2.99
The replacement top cap and drip tip is made from PC and suitable for Vapeasy Citadel RDA Clone. This item also has other colors to choose.
Старый 19.11.2018, 04:39 Автор темы   246
3FVAPE
Original Aspire Nepho Sub Ohm Tank Clearomizer Original Price $34.00, Now Only $29.89
The Original Aspire Nepho Tank has a relatively low-profile design, overall in 50mm height and 27mm in diameter, allowing a big 4ml capacity. With a 27mm diameter deck and wide bore comfortable Delrin drip tip, the Nepho tank is optimized for flavor and vapor production, and it looks great on any mod. The Nepho comes fitted with Aspire's new Kanthal mesh coil rated at 0.15 ohm, also included is a new Kanthal wire, 0.5ohm coil, both are 'press fit' for ease of replacement. Both coils have phenomenal wicking capability, which ensures increased vapor and flavor, just as youd expect from Aspire innovations. With the improved flavor and vapor production you can form your own mini weather system each time you vape. The Nepho also has a child resistant locking mechanism for extra safety. This item also has other colors to choose.
SXK Core RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $15.90, Now Only $12.99
The SXK Core RDA Clone is constructed from 316 stainless steel, it features 22mm diameter and dual post build deck. It comes with adjustable side airflow and Ultem airflow blocker for single coil build.
Original ECT COS DC 450mAh DC Vaporizer + CBD Atomizer Kit $7.59
The Original ECT COS DC CBD Kit consists of ECT COS DC 450mAh Vaporizer and ECT CBD Atomizer. This item also has other Version to choose.
Mod:
The Original ECT COS DC 450mAh Battery Vaporizer is a tiny device that designed for CBD Atomizer. It comes with three different voltage value for vaping, which are 3.3V, 3.6V and 4.0V.
CBD Atomizer:
The ECT CBD Atomizer comes with 0.5ml of juice capacity and a resistance of 1.2ohm. It is great for Cannabis / Marijuana / CBD oil vaping.
Replacement Top Cap for Narda RDA Clone $4.99
The replacement top cap is made from stainless steel with 22mm diameter. It is suitable for Narda RDA Clone.
Original Demon Killer Lanyard for Juul $2.99
The Original Demon Killer Lanyard is made from leather, plastic and magnet. It is suitable for Juul. The Juul can be attached to the lanyard by the magnet. This item also has other colors to choose.
Original Demon Killer Vape Tool Kit for Coil Building $14.99
This Original Demon Kille Vape Tool Kit provides a full coverage of your rebuilding needs. The kit contains a pair of flush cutter, a folding scissors, bent tip tweezers, hardened ceramic tweezers, coil jig, a screwdriver, cleaning brushes and a cleaning cloth. It is great for RDA / RTA coil building.
Старый 20.11.2018, 04:54 Автор темы   247
3FVAPE
Original GeekVape Baron RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.90, Now Only $21.99
The Original GeekVape Baron RDA is a 24mm RDA with multifunctional airflow system. It has a dual-post build deck for easy building. The airflow cover comes with retaining ring design to minimize leakage. The one-piece airflow cap is placed in a fixed position, which ensures airflows are always in the correct position and easy airflow adjustments. Resin drip tip and PMMA drip tip are included. Standard 510 and BF squonk 510 pin are included.
YFTK Ataman V4 RTA Rebuildable Tank Atomizer Clone $23.59
The YFTK Ataman V4 RTA Clone is a 22mm RTA rebuildable tank atomizer constructed from 316 stainless steel. It has about 4ml of juice capacity. The RTA features single coil build deck and replaceable airflow insert, with 0.8mm / 1.0mm / 1.2mm airhole size.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.89
The replacement 510 drip tip is made from PEI and is suitable for all atomizers that fit 510 drip tip.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.99
The replacement 810 drip tip is made from PEI. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
810 Replacement Drip Tip for Goon / Kennedy / Reload / Battle RDA $1.39
The replacement 810 drip tip is made from POM. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Original Starss Replacement Pod Cartridge for ICON Pod System Kit $9.99
The Starss ICON Replacement Pod Cartridge comes with 2.0ohm of resistance and 2ml capacity. It is suitable for Starss ICON Pod System Kit.
Старый 21.11.2018, 04:49 Автор темы   248
3FVAPE
Original Uwell Crown 4 IV 200W TC VW Variable Wattage Box Mod Original Price $65.99, Now Only $55.79
The Original Uwell Crown 4 IV Mod is constructed from zinc alloy, PC, ABS and aluminum. With dual 18650 batteries (NOT INCLUDED), the Uwell Crown IV Mod can work at between 5 and 200 Watts. The both sides adopts a two-step anodization process, making it more durable and colorful. The Baroque pattern is in correspondence with the crown pattern to create an elegant look. This item also has other colors to choose.
Original Wismec Reuleaux Tinker 300W TC VW Variable Wattage Box Mod $53.23
Inspired by Inspired by a classic sport shoe, Wismec launches another stunning box mod, REULEAUX TINKER, which perfectly combines the vaping and high-tech to bring you incomparable vaping experiences. REULEAUX TINKER has an ergonomical design with striking lines, which reflects its sportsmanship. Powered by triple 18650 cells (NOT INCLUDED), REULEAUX TINKER can supply up to 300W output and the 0.96inch TFT color screen with upgraded user interface offers you more vivid and clearer vaping data. This item also has other colors to choose.
Original 5GVape Peace RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.00, Now Only $26.99
The 5GVape Peace BF RDA is a 22mm RDA rebuildable dripping atomizer constructed from 316 stianless steel. It features an easy-to-build single coil deck and different bottom airflow configurations for optimal flavor. It comes with a decorative ring.
Original Uwell Crown 4 IV 200W TC VW Variable Wattage Box Mod + Crown 4 IV Tank Kit Original Price $99.99, Now Only $76.49
The Uwell Crown 4 IV Kit consists of Uwell Crown IV Mod and Uwell Crown IV Tank. This item also has other colors to choose.
Mod:
Tank:
The Original Uwell Crown 4 IV Tank is constructed by Stainless Steel and Pyrex Glass, it looks durable and gorgeous. With a bubble pyrex glass tube in the package, the tank can hold a 6ml large capacity of e-juice (5ml in the normal tube). The biggest highlight of the Crown 4 is the advanced patented self-cleaning technology, the Uwell Crown 4 can absorb the e-juice in the condensation holder through regular usage and vaporize it. Moreover, the Dual SS904L coil and Double helix mesh coil is available on the tank, which will achieve heating evenly and produce excellent flavor. Besides, with the top filling design and bottom adjustable airflow system, you could enjoy easier refilling method and smooth airflow.
Original Wismec Reuleaux Tinker 300W TC VW Variable Wattage Box Mod + Column Tank Kit $75.48
The Wismec Reuleaux Tinker Kit consists of Wismec Reuleaux Tinker 300W Mod and Wismec Column Tank. This item also has other colors to choose.
Mod:
Tank:
The newly developed COLUMN atomizer adopts powerful WL01 Single 0.15ohm coil with large heating area, fully satisfying the vapers' pursuit of dense flavor and massive cloud. In terms of appearance and performance, the REULEAUX TINKER with COLUMN will be a must-have setup for all vapers.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.79
The replacement 510 drip tip is made from stainless steel and is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.09
The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Старый 22.11.2018, 04:49 Автор темы   249
3FVAPE
1:1 Get Low Mods GLM V3 Hybrid Mechanical Tube Mod Clone $18.99
The Get Low Mods GLM V3 Mechanical Mod Clone is constructed from copper and made at 1:1 scale. It has hybrid connection and spring fire button. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose.
Comp Lyfe Skull HK Vegas Edition Hybrid Mechanical Tube Mod Clone $24.89
The Comp Lyfe Skull HK Vegas Edition Mod Clone is a mechanical tube mod with a diameter of 28mm which is constructed from brass. It is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). It comes with spring-loaded fire button. This item also has other colors to choose.
Original Asmodus Amighty 100W Touch Screen TC VW Variable Wattage Box Mod Original Price $84.95, Now Only $67.99
Doggystyle 2K18 V2 RTA Rebuildable Tank Atomizer Clone $11.99
The Doggystyle 2K18 RTA Clone is a 22mm rebuildable tank atomizer constructed from stainless steel with PC tank tube and POM drip tip. The tank has 3.5ml of juice capacity. It comes with single coil build deck, adjustable bottom airflow and 510 threading connection.
Original Augvape AIO 1500mAh All in One Starter Kit Original Price $34.99, Now Only $24.99
The Original Augvape AIO All in One Starter Kit is a small and convenient vape device for starters. It has 1500mAh built-in battery and supports Micro USB charging. The built-in tank has 2ml of juice capacity and 0.5ohm coil. You can handle this kit with single button operation, and it comes with many protections to ensure safe vaping. This item also has other colors to choose.
Ulton Replacement Tube for Hellfire Cobra Squonk Mechanical Box Mod Clone $0.99
This replacement tube is suitable for the Ulton Hellfire Cobra Squonk Box Mod Clone.
Original Vapethink Magic Shark 3M Wrapper Skin Sticker for IQO $1.99
Original Vivismoke Premium Vape Tool Kit for DIY Coil Building $32.99
The Original Vivismoke Premium Vape Tool Kit is a useful tool set for RDA / RTA DIY coil building. It contains Vivismoke Magic Stick, multifunction screwdriver, cleaning cloth, cotton express, ceramic tweezers, atomizer stand, coil jig, needle-nose pliers, diagonal pliers and stainless steel folding scissors.
Старый 23.11.2018, 05:30 Автор темы   250
3FVAPE
Juggerknot Mini RTA Rebuildable Tank Atomizer Clone $21.99
The Juggerknot Mini RTA is a 24mm rebuildable tank made from 316 Stainless Steel. It has 4.5ml of juice capacity and comes with 2ml glass tube for TPD compliant. It has a single coil deck with new design for more airflow and flavor. The triple channeled airflow hits the coil from top, side and bottom. It comes with random color 810 drip tip. This item also has other colors to choose.
Coppervape Hussar Project X RTA Rebuildable Tank Atomizer Clone $24.79
The Coppervape Hussar Project X RTA Clone is a 22mm rebuildable tank atomizer constructed from 316 stainless steel. It comes with 2ml juice capacity and Ultem PEI tank. It comes with adjustable bottom airflow and the airflow size is 3 x 1.5mm each side. The tank also has juice control function. This item also has other colors to choose.
Original Vapjoy 510 Replacement MTL Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.99
The Vapjoy CS5113 Mini 510 MTL drip tip is made from resin and is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
Original Vapjoy MTL Kanthal A1 Prebuilt Coil for RDA / RTA $3.09
The Original Vapjoy MTL A1 Prebuilt Coil is wrapped by Kanthal A1 26AWG wire, with 1.0ohm resistance, 3.0mm inner diameter and 9 wraps. It is great for MTL vaping.
This product comes with 20 PCS in 1 pack.
Original Vapjoy MTL Interlock Clapton Kanthal A1 Prebuilt Coil $5.99
The Original Vapjoy MTL Interlock Clapton Prebuilt Coil is wrapped by 28GA + 40GA (A1) & 28GA (A1) wire, with 0.8ohm resistance, 3.0mm inner diameter and 4 wraps. It is great for MTL vaping.
This product comes with 10 PCS in 1 pack. This item also has other Version to choose.
Original Vapefly Cotton Clouds Economical Durable Healthy Wick $2.29
The Original Vapefly Cotton Clouds is a cost-effective cotton product for coils with 3.0mm inner diameter. It has a nice design that you can take the cotton from the package as much as you need. The cotton is 100% organic cotton from Japan, which will bring you pure flavor.
Coppervape Replacement Spare Kit for Hussar Project X RTA Clone $1.29
The Coppervape Replacement Spare Kit is suitable for Coppervape Hussar Project X RTA Clone.
Coppervape Replacement 510 Drip Tip for Hussar Project X RTA Clone $1.99
The Coppervape replacement 510 drip tip is made from POM and 316 stainless steel, it is suitable for Hussar Project X RTA Clone and other atomizers that fit 510 drip tip. This item also has other colors to choose.
Старый 26.11.2018, 04:49 Автор темы   251
3FVAPE
Ulton Isolation Tank RTA Rebuildable Tank Atomizer Clone $32.50
The Ulton Isolation Tank RTA Clone is a 26mm rebuildable tank atomizer with two different chimney / chamber for different type of vaping. The RTA features dual-post build deck, perforated adjustable airflow ring with 32 airholes and two tank options.
Original Paradigm Modz Magma Tank RDTA Rebuildable Dripping Tank Atomizer Original Price $21.99, Now Only $10.99
The Original Paradigm Modz Magma Tank is a 24mm RDTA made from stainless steel. It has 5ml of juice capacity. The deck comes with dual post build deck and supports single or dual coil builds. The adjustable bottom airflow will bring you optimal flavor. This item also has other colors to choose.
18650 Battery Adapter Tube for 20700 / 21700 Battery Mod $1.99
The 18650 Battery Adapter Tube is suitable for 18650 battery, which made it possible to use 18650 in 20700 / 21700 battery mods. This item also has other colors to choose.
The replacement 510 drip tip is made from stainless steel and is suitable for all atomizers that fit 510 drip tip. This item also has other Version to choose.
Ulton Replacement Bottle for Hellfire Cobra Squonk Mechanical Box Mod Clone $4.59
This replacement squonk bottle is suitable for the Ulton Hellfire Cobra Squonk Box Mod Clone. It has 7ml of juice capacity.
Original Wotofo Replacement Squonk Bottle for Recurve Squonk Box Mod $2.99
The Recurve Squonk Bottle is made of baby feeder silicone materials with smooth and soft feel on the outside, super healthy to store any of your favorite e-liquid. It is very matching to the Wotofo Recurve squonk mod. Bottle capacity is 8ml. This item also has other colors to choose.
Старый 27.11.2018, 04:29 Автор темы   252
3FVAPE
Original IJOY Shogun Univ 180W TC VW Variable Wattage Box Mod Original Price $59.99, Now Only $42.99
The IJOY Shogun Univ Mod is a compact sized, dual 18650 mod (BATTERIES NOT INCLUDED) that utilizes a stylish streamlined design highlighted by exquisite artistry and workmanship. It is made of solid and textured materials and features beautiful double-sided resin panels for a high-end appearance. The Shogun Univ Mod can reach the beastly power of max 180W output and integrates multiple vape modes including POWER, POD, PMODE, and TEMP modes for a very capable and versatile platform. This item also has other colors to choose.
Original IJOY Shogun Univ 180W TC VW Variable Wattage Box Mod + Katana Tank Kit Original Price $78.99, Now Only $52.99
The Original IJOY SHOGUN UNIV KIT consists of IJOY Shogun Univ Mod and IJOY Katana Tank. This item also has other colors to choose.
Mod:
Tank:
The IJOY Katana Sub ohm Tank utilizes a Slide-n-Fill top cap design and a 5.5ml capacity bubble glass (4.0ml standard glass tube included). Compatible with KM1, DM-M2 and DM-M3 mesh wire coils to bring you outstanding flavor.
Original Artery PAL One Pro 1200mAh All in One Starter Kit Original Price $78.99, Now Only $43.99
The Original Artery PAL One Pro Starter Kit, designed in Italy, featured newly filling system and adjustable airflow, along with its new classic and compact design, which will bring you fantastic vaping experience. This item also has other colors to choose.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.59
The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA. This item also has other colors to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.59
The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This item also has other colors to choose.
Старый 28.11.2018, 05:05 Автор темы   253
3FVAPE
Original Desire RAGE 155W TC VW Variable Wattage Squonk Box Mod Original Price $99.99, Now Only $67.29
Designed and developed by Desire and Ohm Boy OC, the Original Desire RAGE Squonk Box Mod is a dual 18650 (battery not included) squonk box mod with powerful chip to support VW / TC / Bypass mode. The wattage can be varied from 5 to 155W. The silicone squeeze bottle has 7ml of juice capacity. With Desire RAGE Squonk Box Mod, you can enjoy vaping with ease. This item also has other colors to choose.
Original Vsticking Vmesh Sub Ohm Tank Clearomizer Original Price $27.99, Now Only $14.99
The VSticking VMesh Sub-ohm Tank is a 27mm clearomizer that utilizes mesh heating technology to bring out the best flavor of your favorite juice. It has 4ml of juice capacity. The VMesh Tank uses two coils, which are 0.2ohm coil (40~100W) and 0.1ohm coil (40~90W), bringing you great vaping experience. This item also has other colors to choose.
Ulton Amadeus RTA / RDA Rebuildable Tank / Dripping Atomizer Kit Clone $35.90
The Ulton Amadeus RTA/RDA Clone Combo Set consists of Ulton Amadeus RTA Clone and RDA caps. The Ulton Amadeus RTA/RDA Clone is 24mm rebuildable atomizer. The RTA comes with 5/2ml juice capcity. The RDA comes with bottom feeder pin. This kit will bring you two kinds of vaping experience.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.29
Original Sense Replacement Coil Heads for Herakles Hydra Clearomizer Original Price $9.99, Now Only $4.99
The Original Sense Herakles Hydra coil heads features a 1.8 ohm resistance that can support 15~50W power output. It is made from Kanthal. Hope this coil head will meet your demands.
Original Uwell Replacement FeCrAl UN2 Coil for Crown 4 IV Tank Original Price $15.99, Now Only $11.99
The Uwell Crown 4 Tank Replacement FeCrAl UN2 Coil features 0.23ohm resistance and works well at 60~70W. It is suitable for Original Uwell Crown IV Tank.
This product comes with 4 PCS in 1 pack.
Original Nikola Replacement Refillable Pod Cartridge for Delorean Pod System Kit Original Price $14.70, Now Only $10.59
The Nikola Delorean Replacement Refillable Pod features 2ml of juice capacity and 1.2ohm coil resistance. It is suitable for Original Nikola Delorean Pod System Kit.
This product comes with 3 PCS in 1 pack. This item also has other colors to choose.
Original Vsticking Replacement Coil for Vmesh Sub Ohm Tank Original Price $14.99, Now Only $10.99
The Vsticking Vmesh Replacement Coil features 0.1ohm resistance and works well at 40~90W. It is suitable for Original Vsticking Vmesh Sub Ohm Tank.
This product comes with 5 PCS in 1 pack. This item also has other Version to choose.
Старый 29.11.2018, 05:00 Автор темы   254
3FVAPE
Original Vandy Vape Pulse Dual 220W TC VW Squonk Box Mod Original Price $59.99, Now Only $49.99
The Original Vandy Vape Pulse Dual 220W TC VW Squonk box mod is the smallest dual battery squonk mod. Powered by an upgraded Vandy Chip, it can reach up to an output wattage from 5W to 220W. It also supports multiple protections and comes with a 7ml juice bottle. This item also has other colors to choose.
Avid Lyfe VM Hybrid Mechanical Tube Mod Clone $14.99
The Avid Lyfe VM Mechanical Mod Clone is made out of stainless steel with hybrid connection. It is powered by single 18650 battery (NOT INCLUDED). The middle part is knurled for easy grip. The bottom fire button is activated by magnets.
Original SMOKTech SMOK Stick V9 Max 4000mAh Mod + Stick V9 Tank Starter Kit $48.39
The Original SMOK Stick V9 Max kit, a new upgraded version of Stick V8 series, consists of built-in 4000mAh battery and Stick V9 Max tank, which are the best combo either from the appearance or the performance. For the "Max", you can tell from its 4000mAh battery capacity, and its large outside diameter in stick and tank, no doubt, they're perfectly compatible with each other. As for the tank, it has a gigantic e-liquid capacity with 8.5ml, and it's specially designed for Stick V9 Max by adopting Mini V2 S1 and Mini V2 S2, both of which are custom-made coils for Stick series battery, focusing on lower wattage but intense clouds and flavor. This item also has other colors to choose.
Original GeekVape Flint 950mAh All in One Portable MTL Starter Kit Original Price $39.90, Now Only $28.99
The Flint is an IPX5 super compact kit that is powered with our latest refined NS coil system, which is designed for both nicotine salt e-liquid and perfect MTL kit for regular e-liquid. It is powered with a 950mAh battery making it the perfect companion that lasts for days, comes with advanced coil and three different power adjustments to produce the best flavor possible. This item also has other colors to choose.
Avid Lyfe VM Hybrid Mechanical Mod Clone + Battle RDA Kit Clone $21.99
The Avid Lyfe VM Mech Kit Clone consists of Avid Lyfe VM Hybrid Mechanical Mod Clone and Battle RDA Clone.
Mod:
RDA:
The Battle RDA Clone is constructed from stainless steel. With the large post holes and flathead screws, the deck is easy for coil building. The cap has dual large airslots for side airflow.
Avid Lyfe Double Cross Hybrid Mechanical Mod Clone + Battle RDA Kit Clone $23.49
The Avid Lyfe Double Cross Mech Kit Clone consists of Avid Lyfe Double Cross Hybrid Mechanical Mod Clone and Battle RDA Clone. This item also has other colors to choose.
Mod:
The Avid Lyfe Double Cross Mechanical Mod Clone is made out of brass with hybrid connection. It is powered by single 18650 battery (NOT INCLUDED). The tube features regular geometric pattern. The bottom fire button is activated by magnets.
RDA:
The Battle RDA Clone is constructed from brass cap and stainless steel deck. With the large post holes and flathead screws, the deck is easy for coil building. The cap has dual large airslots for side airflow.
Avid Lyfe Swirl Hybrid Mechanical Mod Clone + Battle RDA Kit Clone $24.39
The Avid Lyfe Swirl Mech Kit Clone consists of Avid Lyfe Swirl Hybrid Mechanical Mod Clone and Battle RDA Clone. This item also has other colors to choose.
Mod:
The Avid Lyfe Swirl Mechanical Mod Clone is made out of copper with hybrid connection. It is powered by single 18650 battery (NOT INCLUDED). The tube features twisted swirl pattern. The bottom fire button is activated by magnets.
RDA:
The Battle RDA Clone is constructed from copper cap and stainless steel deck. With the large post holes and flathead screws, the deck is easy for coil building. The cap has dual large airslots for side airflow.
Original GeekVape Replacement NS Coil for Flint Tank / Flint Starter Kit Original Price $9.90, Now Only $6.99
The GeekVape Flint Replacement NS Coil is constructed from N80 heating material and food grade organic cotton, with 1.6ohm resistance. It features pure and clean flavor, high delivery of nicotine, longer lifespan and efficient wick to prevent dry hits. It is great for Nic salt liquid.
SXK Replacement 510 Drip Tip + Tank Tube for Doggystyle V2 2K18 RTA Clone Original Price $7.00, Now Only $5.99
This replacement tank tube is made from PEI and is suitable for SXK Doggystyle V2 2K18 RTA Clone. It features 22mm diameter and 3.5ml capacity. The 510 drip tip is made from PEI. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Старый 30.11.2018, 05:27 Автор темы   255
3FVAPE
1:1 Get Low Mods GLM V3 Hybrid Mechanical Tube Mod Clone $14.99
The Get Low Mods GLM V3 Mechanical Mod Clone is constructed from brass and made at 1:1 scale. It has hybrid connection and spring fire button. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose.
Original Tesla Stealth 100W 2200mAh Battery Mod Original Price $29.99, Now Only $14.99
The Tesla Stealth 100W Mod is a well-designed mod features a 2200mAh build-in LiPo battery, which is a surprise for a mod of this size. The Tesla Stealth 100W can match with different hidden tanks up to 22mm in diameter. The Tesla Stealth can fire up to 100W based on the resistance. And the resistance can be down to 0.1 ohms. It utilizes a pass-through vaping functionality which allows you to vape even when the device is on charging through a USB cable. The Tesla Stealth comes in a durable rubber finish and built-in safety features in the chipset such as protections against over voltage, over charging, long puffing, and low resistance. It is easy to carry out the device with you as there is no risk of auto firing due to its specially designed firing button. This item also has other colors to choose.
Bestia Fiera Hybrid Mechanical Tube Mod Clone $24.99
The Bestia Fiera Mod Clone is the smallest 20700 / 21700 mech mod. It is constructed from brass, with hybrid connection and side fire button. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). Delrin 18650 battery adapter is included. 24mm RDA will not overhang on this mod. This item also has other colors to choose.
Original Nikola Lapetus Sub Ohm Tank Clearomizer Original Price $29.90, Now Only $24.49
As the first atomizer by Nikola, Lapetus is compatible with most MOD devices by its stainless steel and aluminum alloy combo as well as its 25mm diameter. It makes e-juice filling easy and convenient by its top-fill design. You can use the 4.5ml or 6ml glass tubes as you wish. The Lapetus comes with a 0.18ohm Mesh coil and is switchable from 60W to 110W, a perfect vapor experience brought to vapors. Changing coils is easy with its Plug-N-Pull design. This item also has other colors to choose.
Original Artery PAL 1200mAh AIO All-in-One Starter Kit Original Price $49.30, Now Only $35.49
The Original Artery PAL Starter Kit is thin and portable in your hands. With 3ml liquid capacity and a built-in 1200mAh battery which means you can vape for a really long time. What's more, the Artery PAL kit comes with a unique LQC coil to bring great flavor and decent vapor production, and a new 1.8ohm ceramic coil which is perfect for high nicotine and nicotine salt e-juice. The innovative slide refilling system upgrades the juice filling to a new level. The cover of the PAL is also changeable too (Not Inclueded). This item also has other colors to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $2.29
Original Khree Replacement Pod Cartridge for UFO 2 Pod System Kit $2.99
The replacement pod cartridge features 2ml of juice capacity and 1.5ohm resistance coil. It is suitable for Original Khree UFO 2 Pod System Kit.
This product comes with 2 PCS in 1 pack.
Original Nikola Replacement Mesh Coil Head for Lapetus Tank Original Price $15.96, Now Only $10.99
The replacement mesh coil features 0.18ohm resistance and works well at 60 to 110W, best at 70 to 90W. It is suitable for Original Nikola Lapetus Tank.
Старый 01.12.2018, 05:05 Автор темы   256
3FVAPE
Original Digiflavor Edge 200W Wireless Charging TC VW Variable Wattage Box Mod Original Price $64.90, Now Only $52.99
The Edge is an elegant piece of device which powers up to 200W. It features an advanced fast wireless charging technology (9V/1.1A), which supports the Qi v1.2.4 communications protocol. Powered with the advanced AS chipset and dual 18650 batteries, the Edge is a masterpiece of power and elegance. The mod is powered by dual 18650 batteries (NOT INCLUDED). This item also has other colors to choose.
Original Asmodus Mini Minikin 50W TC VW Box Mod + Ohmlette Tank Kit with Battery Original Price $49.95, Now Only $34.99
The Asmodus Mini Minikin 50W Complete Kit is a full kit (mod, tank, and battery) that features never before seen asMODus products, all in one package. The Minikin Mini 50W, Ohmlette Sub Ohm Tank, and an Efest 18500 sized battery are all included in this kit. The Minikin 50W is a petite box mod that accommodates a single 18500 sized battery (INCLUDED) and features a two-tone body style for a unique look. The Mini Minikin is powered by a GX-50-HF chip that features power saving capabilities as well as a "flavor taste" boosting mode. The GX-50-HF chip has an efficiency rating of 97%. The Minikin 50W Kit is topped with the all new Ohmlette Sub Ohm Tank! The Ohmlette features two different coil options, both which provide great clouds with lower wattage making it the perfect companion for the Mini Minikin. The Minikin 50W Kit will include an Efest 18500 sized battery. This item also has other colors to choose.
Original Asmodus Oni Edition 80W 2800mAh VW Mod + Ohmlette Tank Kit Original Price $49.95, Now Only $29.99
The Asmodus Mini Minikin 50W Complete Kit consists of Oni 80W Mod and Ohmlette Sub Ohm Tank. The Oni 80W is equipped with GX-80-HM chipset. This chipset is a simple, easy to learn firmware anyone can use. The Oni 80W resistance range is from 0.1 to 2.5ohm and can go up as high as 80W making it so that anyone can use a plethora of tanks and builds. Accompanied with the Oni 80W is the Ohmlette tank. The Ohmlette tank uses a 0.8ohm coil that will make your battery life insanely long. The coil was designed just as much clouds and flavor as many other tanks out there whilst still boasting the longer battery life. This item also has other colors to choose.
Original SMOKTech SMOK SLM 250mAh Pod System Starter Kit $14.99
The Original SMOK SLM Pod System Kit is an ultra-portable vape kit. It is powered by built-in 250mAh battery. The pod cartridge has 0.8ml of juice capacity and 1.8ohm coil. It is an air-activated pod device, you can enjoy the puffs without any fire button. Equipped with an intelligent LED indicator, it can show the battery status clearly. This item also has other colors to choose.
Original Digiflavor Edge 200W Wireless Charging TC VW Box Mod + Specter Tank Kit Original Price $86.90, Now Only $66.99
The Original Digiflavor Edge Kit consists of Digiflavor Edge Mod and Specter Sub Ohm Tank. This item also has other colors to choose.
Mod:
Tank:
The Digiflavor Specter Sub Ohm Tank is a 24mm clearomizer with 5.5ml of juice capacity. It has top fill design and bottom airflow system. The tank utilizes Digimesh X1 Coil, which features 0.2ohm resistance and a working wattage range from 30 to 90W (best 60~80W), bringing you pure and nice flavor.
Original SMOKTech SMOK Replacement Pod Cartridge for SLM Pod System Kit $10.99
The replacement pod cartridge features 0.8ml of juice capacity and 1.8ohm resistance coil. It is suitable for Original SMOK SLM Pod System Kit.
Original Digiflavor Wireless Charging Fast Charger for Edge Mod / iphone 8 / iphone X $59.99
The Digiflavor Wireless Fast Charger is portable, lightweight, sleek design suitable for use in multiple locations. It supports the Qi V1.2.4 communications protocol. And Digiflavor Wireless Charger is compatible with Edge mod, Epsilon mod, iphone 8/8 plus, iphone X, SamsungS6 etc. This item also has other colors to choose.
Старый 03.12.2018, 04:40 Автор темы   257
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Apocalypse 25 RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99
The Apocalypse 25mm RDA Clone is a new Apocalypse RDA with 25mm outer diameter. It features teardrop airflow control, classic Apocalypse clamps with recessed screws and locking cap. It is suitable for fancy coil builds and will definitely bring you dense flavor and massive vapor. This item also has other other colors to choose.
Original Acevape MK RTA Rebuildable Tank Atomizer Original Price $33.50, Now Only $29.99
The Original Acevape MK RTA is a 25mm rebuildable tank atomizer with 3ml / 5ml of juice capacity. The postless build deck supports both single coil and dual coil. With the leak-proof top airflow system, the airflow hits directly on the coil for denser cloud and better flavor. This item also has other other colors to choose.
Original Yosta Ypod 500mAh Pod System Starter Kit $19.99
The Original Yosta Ypod Kit is an ultra-compact pod system kit with 500mAh built-in battery and 2ml e-jucie capacity. With draw activated design, you can just take a puff without any button. It is designed with top airflow holes which avoid leakage problems completely. It is equipped with a 0.49 OLED screen to show vaping status including power, puffs and vaping time. It also adopts 1.4ohm Ceramic Coil for healthier and purer taste. This item also has other colors to choose.
Original One Vape Lambo 360mAh Pod System Starter Kit $25.49
The Original One Vape Lambo Pod System Kit is an innovative draw activated system that features an intuitive air intake. It uses a circulating convection air passage, avoiding any reverse air intake to ensure that users will have a smooth and comfortable vape each time. The Lambo is powered by a 360 mAh battery, rechargeable via USB. The One Lambo utilizes a refillable pod system that can accommodate 2ml of nicotine salt E-Liquid (recommended VG/PG ratio is 7/3) and rated at 1.6 ohm. This item also has other colors to choose.
Original Voopoo N1 Replacement Coil for Uforce / Uforce T2 Tank $11.99
The Voopoo N1 replacement coil features 0.13ohm resistance and works well at 50~100W (best 70~80W). It is suitable for Original Voopoo Uforce/Uforce T1/Uforce T2 Tank.
Original Yosta Replacement Pod Cartridge for Ypod Pod System Starter Kit $6.69
The replacement pod cartridge features 2.0ml of juice capacity and 1.4ohm resistance coil. It is suitable for Original Yosta Ypod Pod System Kit.
Original One Vape Replacement Pod Cartridge for Lambo Pod System Starter Kit $6.99
The replacement pod cartridge features 2.0ml of juice capacity and 1.6ohm resistance coil. It is suitable for Original One Vape Lambo Pod System Kit.
Старый 04.12.2018, 04:42 Автор темы   258
3FVAPE
Original Oumier Rudder 200W TC VW Variable Wattage Box Mod Original Price $49.00, Now Only $46.69
The Original Oumier Rudder Mod is a versatile regulated mod with a large OLED screen and rotational button to adjust wattage. Powered by dual 18650 batteries (NOT INCLUDED), the Rudder supports an output range from 5 to 200 watts. The resistance range is from 0.05 to 3.0 ohm. The mod supports variable modes and 5V/2A fast charging. This item also has other colors to choose.
Original Smokjoy Amos Mini 400mAh Pod System Starter Kit $11.99
The Smokjoy Amos mini pod system adopts double air channels on two sides to meet both your mouth to lung(MTL) and direct to lung(DTL). It features 2ml e-liquid refillable pod and 400mah rechargeable battery, with durable horizontal ceramic coil and organic cotton wicked on top, giving you purer flavor taste. The battery has adjustable voltage function (2.6-3.3-4.0V) and 10 seconds Preheat function, so you can enjoy multi-layered flavor and also work for thick CBD oil. This item also has other colors to choose.
Replacement Drip Tip for SMOK TFV8 Baby V2 Clearomizer $2.59
The replacement drip tip is made from resin. It is suitable for SMOKTech SMOK TFV8 Baby V2 Clearomizer. This item also has other colors to choose.
Original Digiflavor Replacement Digimesh X1 Coil for Specter Tank / Edge Kit Original Price $19.90, Now Only $14.99
The Digiflavor Digimesh X1 Coil, which features 0.2ohm resistance and a working wattage range from 30 to 90W (best 60~80W), will bring you pure and nice flavor. It is suitable for Original Digiflavor Specter Tank / Digiflavor Edge Kit.
Original Smokjoy Replacement Pod Cartridge for Amos Mini Pod System Kit $6.99
The replacement pod cartridge features 2.0ml of juice capacity and 1.8ohm resistance coil. It is suitable for Original Smokjoy Amos Mini Pod System Kit.
3FVAPE вне форума   Вверх
Старый 05.12.2018, 04:46 Автор темы   259
3FVAPE
Original SMY Pluscig B3 1300mAh Heat Not Burn Device $34.99
The Original SMY Pluscig B3 is a Heat-Not-Burn device powered by built-in 1300mAh battery, with three-level temperature adjustment. It also features battery LED indicator light, vibration reminder, smart power saving and advanced cleaning function. This item also has other colors to choose.
Original SMY Pluscig B2S 2900mAh Heat Not Burn Device $50.29
The Original SMY Pluscig B2S is a Heat-Not-Burn device powered by built-in 2900mAh battery, with four-level temperature adjustment. It also features needle type heating element, battery LED indicator light, vibration reminder, smart power saving and advanced cleaning function. This item also has other colors to choose.
Original SMY Pluscig P2 1300mAh Heat Not Burn Device $45.99
The Original SMY Pluscig P2 is a Heat-Not-Burn device powered by built-in 1300mAh battery. It is the world's first heat not burn device to solve the liquid spill problem. P2 automatically shows cleaning smart prompt on LED display once user smoke 5 heat sticks. The short heating time, short warm-up time, high temperature for only 5~7 seconds, represents the higher industry level. This item also has other colors to choose.
Original Acevape Bomb Cat RDA Rebuildable Dripping Atomizer with BF Pin $29.99
The Acevape Bomb Cat RDA is a 24mm rebuildable dripping atomizer which brings you a variety of playable ways. The simple base allows you to build both horizontal and vertical coils. Besides, it also allows you to build with standard coils or mesh. When bottom feeding, the juice flows from the top holes down to cotton. For the airflow, this RDA supports both horizontal and vertical airflow control.
This RDA comes with bottom feeder pin. This item also has other colors to choose.
Original Acevape Magic Master RDA Rebuildable Dripping Atomizer with BF Pin $25.99
The Acevape Magic Master RDA is a 24mm rebuildable dripping atomizer with large build deck, giving more space for bigger coils. The dual post deck makes coil building really easy. The cap comes with anti-lock design, which can avoid the RDA being locked too tight on the mod. With side adjustable airflow, you can enjoy dense and rich flavor.
The Original Vapethink Magic Shark Wrapper Skin Sticker is used for IQOS, made from 3M material. It is designed as 2.5D stereoscopic cover film, which looks more vivid, and you can feel concave-convex when touch it. This item also has other Version to choose.
The replacement 810 drip tip is made from resin and stainless steel. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This item also has other colors to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.29
Старый 06.12.2018, 04:35 Автор темы   260
3FVAPE
Original GeekVape Lucid 80W TC VW Variable Wattage Box Mod Original Price $47.90, Now Only $30.99
Powered by the advanced AS chipset, LUCID is a compact and powerful mod that is capable of outputting a maximum power of 80W. LUCID is the most compact starter kit powered by a single 18650 (NOT INCLUDED) with OLED display screen that offers a concise and clear interface. Micro USB port is for a safe USB charging with removable battery, and it can also be used for firmware updates. This item also has other colors to choose.
Original Steam Crave Titan PWM VV Variable Voltage Box Mod $53.99
The Original Steam Crave Titan PWM Mod is a quad 18650 variable voltage box mod. Powered by quad 18650 batteries (NOT INCLUDED) in parallel / series, this mod can provide maximum output to 300W, which is very powerful. By Rotating the fire button you can adjust the voltage, and it comes with lock function. Besides, the mod has multiple protections to give you a safe vaping experience. This item also has other colors to choose.
ShenRay Comp Lyfe Skull HK Vegas Edition Hybrid Mechanical Tube Mod Clone $32.99
The ShenRay Comp Lyfe Skull HK Vegas Edition Mod Clone is a mechanical tube mod with a diameter constructed from brass. It is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). 18650 battery tube is included. It comes with magnetic fire button. This item also has other Version to choose.
Original GeekVape Lumi Disposable Sub Ohm Tank Clearomizer Original Price $6.90, Now Only $3.99
The GeekVape LUMI Tank is a 24mm pre-coiled sub ohm tank that is powered with Geekvape supermesh coil system (non-replaceable) to produce the best flavor and outstanding vapor production. The tank is built with FDA certified medical grade Polycarbonate which can withstand extremely high temperature and Stainless Steel and only weighs 16g. With the Supermesh coil system, Lumi can produce outstanding flavor and vapor production.
This tank is disposable. This item also has other colors to choose.
Original UltimaVape Scarlet RTA Rebuildable Tank Atomizer / Sub Ohm Tank Clearomizer Original Price $38.00, Now Only $32.99
The Original UltimaVape Scarlet Tank is a 24mm atomizer that can be used as RTA or clearomizer. When using RBA base, which features dual post design, the Scarlet is a rebuildable tank; when using OCC head base, the Scarlet is a sub ohm tank with 0.2ohm coil. It comes with adjustable bottom airflow. The OCC head brings you better flavor and cleaner taste, while the RBA base brings you fun of DIY coils.
Original GeekVape Lucid 80W TC VW Variable Wattage Box Mod + Lumi Tank Kit Original Price $49.90, Now Only $33.99
The GeekVape Lucid Kit consists of GeekVape Lucid Mod and GeekVape Lumi Tank. This item als has other colors to choose.
Mod:
Tank:
The LUMI is a 24mm pre-coiled sub ohm tank that is powered with Geekvape supermesh coil system (non-replaceable) to produce the best flavor and outstanding vapor production. The tank is built with FDA certified medical grade Polycarbonate which can withstand extremely high temperature and Stainless Steel and only weighs 16g. With the Supermesh coil system, Lumi can produce outstanding flavor and vapor production.
Original Yiloong Knerten Pod 600mAh CBD Starter Kit $39.99
The Yiloong Knerten Pod CBD Starter Kit is a compact vape kit for Nic salt and Cannabidiol CBD oil. It is powered by built-in 600mAh battery. The atomizer has 1.5ohm coils and 1ml of juice capacity.
This product will be shipped with random color. More option than whats on the image.
Поиск в этой теме:
Copyright ©2007 - 2023, FONAREVKA.RU
Время генерации страницы 0.23616 секунды с 19 запросами
