8076
Прогуливаясь по просторам интернета, углядел довольно интересные Sunree. Визуально выглядят вполне пристойно, ценник гуманный. Эмиттеры, правда, не топовые..
Может кто держал в руках? Обзоров в сети не нашёл. Sunree Discover D3 Headlamp 3W Cree Headlight Survival One powerful CREE Q3 5C emitter Four lighting levels, one SOS mode (10hours) o Energy Saving (50hrs) o Low (18hrs) o Medium (8hrs, AA) o High (2.5hrs, AA) Max beam length: 70 meters Light beam can be directed Electronic switch Output automatic memory function Uses four 1.5V AA (Alkaline, Ni-MH, Lithium) batteries Weight: 152g (excluding battery) 247g (with AA batteries) Waterproof of IPX5 Standard ![]() ![]() Sunree Discover 9 Head Torch with CREE LEDs 540 Lumen Key Features The lamps provide more than 540 lumens light and offer a simple to choice of 5 lighting modes. Intense (540 Lumen) Can illuminate up to 200 meters. Medium (Approx 300 Lumen) Low (Approx 120 Lumen) Eco (Greater than 80 Lumen) SOS Mode Morse-code SOS @ 540 Lumen - Visible for 7 miles! Other great features include: Running times are between 6 hours on intense to over 72 hours in the energy saving position. This head light is rated to IPX5 which means it will withstand splashes and bounces, dust and rain. The battery pack has belt loop and can be hung on belt in order to reduce weight on the head. The weight of headlamp is just 155g and batteries weigh only 345g. The headlamp has received great reports from UK British Forces and Swedish Police dog section. Technical Specifications Three powerful CREE Q3 5A emitters Four lighting levels, one SOS mode: Energy saving (Over 72 hours) Low (25 hours) Medium (13 hours) Intense (6 hours) Max beam length: 200 meters Directional light Electronic switch Output automatic memory function Uses six Lithium-ion 18650 batteries, 11.1V - Car and (Mains Charger included) Weight: 155g (excluding battery) battery pack is 345g Waterproof to IPX5 standard
Как вело фару самое оно!
шикарный налобник
Регистрация: 25.09.2010 Последняя активность: 04.12.2014 09:41
Сказал(а) спасибо: 72
Вроде он http://kaidomain.com/Produc... 54$
но настолько ли он хорош? быть может лучше доплатить 10-20$ и купить действительно классный феникс... или на эту сумму купить 3-4 обычных китайских налобника на диодах 3Вт? |
Регистрация: 05.04.2014 Последняя активность: 01.04.2015 04:39
Выглядит как старый шахтерский.
А вот интересно, блок питания при ходьбе на затылке не прыгает?
Сказал(а) спасибо: 1116
А кто то уже подержал в руках этот кемпинговый чехол - рассеиватель для юды??? Что за зверь? И почему для зебр такого еще не сделали???
https://trektools.ru/catalo... Думается мне, что в такой можно запихнуть маленькую зебру! [Исправлено: Rocklight, 08.02.2016 в 22:30] |
