Регистрация: 25.12.2012 Последняя активность: 23.06.2016 14:00
Сказал(а) спасибо: 249
http://www.sunwayman.com/ht...
Sunwayman D20A Gemini Dual Light Sources, 2 x AA Batteries in Parallel, 258 Lumens Features ● CREE XM-L2 and XP-E P2 LED, with a lifetime of up to 50,000 hours; ● Newest Stepped Dual-button Side Switch System, 6 output modes to select from: White Light Turbo: 258 Lumens (Automatically enter High mode after 3 mins continuous use to avoid overheat) High: 208 Lumens (2.3hrs.) Mid: 70 Lumens (9.3hrs.) Low: 4 Lumens (60hrs.) Strobe SOS Red Light High: 23 Lumens Mid: 10 Lumens Low: 4 Lumens Police Strobe Slow Flash ● Standby Current <100µA ● Constant current circuit, constant output ● Effective range of 126 meters ● Intensity: 4000cd ● Uses two AA batteries ● Working voltage: 0.9~3V ● White light uses high quality metal reflector, maintains great throw distance and spread with an ideal beam pattern; Red light uses high quality resin lens ● Dimensions: 21mm x 35mm x 102.5mm ● Weight: 119g(battery excluded) ● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top ● Military Specification Type III- hard anodized body ● Waterproof, in accordance with IPX-8 standard ● Ultra-clear tempered glass lens resists scratches and impacts ● Accessories: Lanyard, O-ring ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Поблагодарили: 16 раз(а) |
altur (10.10.2013), Angry Zeka (09.10.2013), asket32420 (09.10.2013), blindnick (09.10.2013), Dmitriyrus (09.10.2013), fnksb (09.10.2013), John Jack (09.10.2013), Joker (09.10.2013), m72 (09.10.2013), NazarSunrise (09.10.2013), nurlanchm (09.10.2013), Svetogor (09.10.2013), Virgo_Style (09.10.2013), vvvoland (09.10.2013), WallE (09.10.2013), Xenos (09.10.2013)
Реклама на форуме. | |
Разместить рекламу
Вот и фонарик с двумя параллельными AA...
Регистрация: 03.12.2012 Последняя активность: 05.05.2022 23:05 Адрес: СПб
Сказал(а) спасибо: 547
Поблагодарили: 496 раз(а) в 334 сообщениях
HID маньяк
Регистрация: 04.09.2010 Последняя активность: Сегодня 10:16 Адрес: Это Питер, детка (с)
Записей в дневнике: 2 Сказал(а) спасибо: 736
Поблагодарили: 2345 раз(а) в 792 сообщениях
Прикольный. Очень нравится. Как раз, такому место в бардачке автомобиля на всякий пожарный.
И красный свет тоже будет кстати. Скока стоит то ? И есть ли уже где нить в продаже ? |
Регистрация: 16.10.2012 Последняя активность: 22.02.2022 02:51 Адрес: Киев, Украина
Сказал(а) спасибо: 687
Поблагодарили: 2975 раз(а) в 1380 сообщениях
и клипса не на ту сторону опять :(
Поблагодарили: 6697 раз(а) в 4633 сообщениях
а D20C они не хотят сделать? 2*18650 без головы
трол. |
blindnick,
Sunwayman смело экспериментирует, можно им идейку подкинуть. D20C - вы имеете ввиду 2xCR123 с параллельным размещением? |
