Регистрация: 25.12.2012 Последняя активность: 23.06.2016 14:00
Сказал(а) спасибо: 249
http://www.olightworld.com/...
Olight SR96 Intimidator The SR-series of flashlights from OLIGHT have re-defined the development process of high-power LED flashlights through constant innovation. The SR96, the newest masterpiece of the SR-series succeeding the SR95S-UT, pushes lumen output to 4800 lumens. Unlike high-powered LED Flashlights of the past that concentrated mainly long distance throw, the SR96 is designed for superior illumination. The new CREE MK-R LED built on CREE’s revolutionary SC3 platform provides consistent color temperature and efficient output with up to 200 lumens per watt. Three of the MK-R LEDs are used in the SR96 to boost the output to 4800 lumens! Product features a) Up to 4200 lumens. Utilizing 3 x CREE MK-R LEDs, each for 1400 lumens b) The three-dimensional heat dissipation. The hollow-out structure of the SR96 maximizes airflow to the heating element improving thermal radiation. Crisscrossed grooves form a convection channel to efficiently pull heat away. c) 7800mAh,7.4V large capacity battery pack. OLlight SR series are designed for commonly battery pack , making it perfect compatibility with the former SR-series flashlights. d) Based on the running time and thermal management system of real-time temperature detection. When the flashlight is on high brightness mode, the first 5 minutes the output will keep full brightness. In the subsequent 5 minutes, the output will gradually drop to 50% of the initial brightness. (pls check the output graph for details) The human visual sensitivity to light will almost unable to sense the changing process. A built-in temperature sensor prevents the flashlight from overheating to making a damage to the product or to the users. e) Battery protection: when the battery is charged enough, SR96 will performance the maximum potential to reach the highest brightness, with the battery voltage drops, the output will jump to low-range gear in order to protecting the battery and prolong runtime f) The key lock g) The large square surface texture in the body increases grip for a steady to hold Standard accessories flashlight strap AC charger power cable for charger Manual Warranty card Optional accessories(sold individually) 7800mAh 7.4V ![]() [Исправлено: uV3, 18.09.2013 в 15:15] |
havoc (18.09.2013)
Реклама на форуме. | |
Разместить рекламу
Регистрация: 09.03.2013 Последняя активность: 08.05.2019 00:22 Адрес: Украина
Сказал(а) спасибо: 297
Поблагодарили: 46 раз(а) в 32 сообщениях
Было уже :( на етой странице https://forum.fonarevka.ru/...
Регистрация: 11.11.2012 Последняя активность: 05.05.2022 09:14
Сказал(а) спасибо: 178
Поблагодарили: 169 раз(а) в 136 сообщениях
![]() Регистрация: 08.06.2011 Последняя активность: 02.02.2021 14:14 Адрес: Украина
Сказал(а) спасибо: 1934
Поблагодарили: 2282 раз(а) в 1025 сообщениях
фонарик для подсветки орального секса
Angry Zeka (18.09.2013)
Регистрация: 03.12.2012 Последняя активность: 05.05.2022 23:05 Адрес: СПб
Сказал(а) спасибо: 547
Поблагодарили: 496 раз(а) в 334 сообщениях
в жопу такую лотерею
Регистрация: 04.11.2011 Последняя активность: 08.04.2021 12:51 Адрес: Нимферополь, недалеко от моря и леса
Сказал(а) спасибо: 237
Поблагодарили: 227 раз(а) в 124 сообщениях
С человеком происходит то же, что и с деревом. Чем настойчивее стремится он вверх, к свету, тем с большей силой устремляются корни его в глубь земли, вниз, во мрак – во зло. (Ф.Ницше) |
Hoвичёк фонарёвки.
Регистрация: 18.08.2012 Последняя активность: 14.04.2022 16:52 Адрес: Калуга
Сказал(а) спасибо: 1984
Поблагодарили: 1429 раз(а) в 717 сообщениях
![]() Цитата:
Angry Zeka, да как там промахнешься-то?
![]() Интересно, а он HighCRI? ![]() ![]() ![]() |
Linx (19.09.2013)
