62321 0 0 1 |
28.06.2010, 01:22 | 1 |
Зашел на огонек
Сообщений: n/a
The Big Flashlight Comparison Chart
Weights should be the weight of the light or system with batteries installed, but are not guaranteed correct.
Lum is the factory rated output in Lumens. XX/YY denotes two different bulbs avaible and their respective output or runtime. Bezel Diameter is the OD of the bezel. AA/BB means a bezel with AA diameter, but other restriction such as bumps or raised patterns that can make the effective diamter BB. The AA dimension would be used when choosing filters. SUREFIRE LARGE FRAMED HANDHELDS Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb SF G2_______________ 65/120 Lum___ _ 60/20 min___ _ 4.00 oz___ _ 5.0 in___ _ 1.25/1.3 in___ _ 6 V__ _ P60/61 SF G2Z______________ 65/120 Lum___ _ 60/20 min___ _ 4.10 oz___ _ 5.1 in___ _ 1.25/1.3 in___ _ 6 V__ _ P60/61 SF Z2 Combat Light____ 65/120 Lum___ _ 60/20 min___ _ 4.80 oz___ _ 5.1 in___ _ 1.25/1.3 in___ _ 6 V__ _ P60/61 SF 6P_______________ 65/120 Lum___ _ 60/20 min___ _ 5.20 oz___ _ 5.1 in___ _ 1.25/1.3 in___ _ 6 V__ _ P60/61 SF 9P_______________ 105/200 Lum__ _ 60/20 min___ _ 6.40 oz___ _ 6.7 in___ _ 1.25/1.3 in___ _ 9 V__ _ P90/91 SF C2 Centurion______ 65/120 Lum____ _ 60/20 min___ _ 5.30 oz___ _ 5.1 in___ _ 1.25/1.3 in___ _ 6 V__ _ P60/61 SF C3 Centurion______ 105/200 Lum___ _ 60/20 min___ _ 6.70 oz___ _ 6.4 in___ _ 1.25/1.3 in___ _ 9 V__ _ P90/91 SUREFIRE SMALL FRAMED HANDHELDS (EXECUTIVE SERIES) Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb SF E1L______________ 25 Lum_______ _ 60 min______ _ 2.90 oz___ _ 3.8 in___ _ 1 / 1.1 in____ _ 3 V__ _ KL1 SF E1E______________ 15 Lum_______ _ 90 min______ _ 2.20 oz___ _ 3.3 in___ _ 1 / 1.1 in____ _ 3 V__ _ MN01 SF E2L______________ 30 Lum_______ _ 180 min_____ _ 3.50 oz___ _ 5.3 in___ _ 1 / 1.1 in____ _ 6 V__ _ KL1 SF E2E______________ 25/60 Lum____ _ 150/75 min__ _ 3.10 oz___ _ 4.5 in___ _ 1 / 1.1 in____ _ 6 V__ _ MN02/03 SF E2O______________ 25/60 Lum____ _ 150/75 min__ _ 3.20 oz___ _ 4.5 in___ _ 1 / 1.1 in____ _ 6 V__ _ MN02/03 SF E2D______________ 25/60 Lum____ _ 150/75 min__ _ 3.30 oz___ _ 4.9 in___ _ 1 / 1.1 in____ _ 6 V__ _ MN02/03 SUREFIRE LED HANDHELDS (LUMIMAX SERIES + A2 AND U2) Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb SF L1_______________ 22/1 Lum_____ _ 240/5K min___ _ 2.90 oz___ _ 4.6 in___ _ 1 / 1.1 in____ _ 3 V__ _ LED SF L2_______________ 100/15 Lum___ _ 60/1K min____ _ 4.20 oz___ _ 6.1 in___ _ 1 / 1.1 in____ _ 6 V__ _ 5watt LED SF L4_______________ 65 Lum_______ _ 60 min______ _ 5.30 oz___ _ 4.0 in___ _ 1 / 1.1 in____ _ 6 V__ _ KL4 5watt SF L5_______________ 65 Lum_______ _ 60 min______ _ 7.20 oz___ _ 6.0 in___ _ 1.47 in______ _ 6 V__ _ KL5 5watt SF L6_______________ 65 Lum_______ _ 95 min______ _ 8.40 oz___ _ 7.7 in___ _ 1.62 in______ _ 6 V__ _ KL6 5watt SF L7_______________ 75 Lum_______ _ 60 min______ _ 11.30 oz__ _ 7.9 in___ _ 1.47 in______ _ B90 _ _ 5watt LED SF A2 led/krypt_______ 50 Lum_______ _ 60 min______ _ 4.10 oz___ _ 5.6 in___ _ 1.13 in______ _ 6 V__ _ MA/02 SF U2 ULTRA _________ 80var Lum____ _ _____ min___ _ 5.70 oz___ _ 6.1 in___ _ 1.47 in_____ _ 6 V__ _ 5wat LED SUREFIRE COMBAT LIGHTS (NOT WEAPONLIGHTS, BUT WORK WELL ON LIGHT RECOILING WEAPONS) Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb SF M1 IR Illuminator___ ______ Lum___ _ 900__ min___ _ 3.10 oz___ _ 3.8 in___ _ 1 / 1.1 in____ _ 3 V__ _ ____ SF M2 Centurion_______ 65/120 Lum___ _ 60/20 min___ _ 5.20 oz___ _ 5.8 in___ _ 1.47 in______ _ 6 V__ _ P60/61 SF M3 Combat Light____ 125/225 Lum__ _ 60/20 min___ _ 7.00 oz___ _ 7.1 in___ _ 1.62 in______ _ 9 V__ _ MN10/11 SF M3T Turbo Head____ 125/225 Lum__ _ 60/20 min___ _ 9.60 oz___ _ 7.8 in___ _ 2.50 in______ _ 9 V__ _ MN15/16 SF M4 Dominator______ 225/350 Lum__ _ 60/20 min___ _ 11.40 oz__ _ 8.3 in___ _ 2.50 in______ _ 12 V_ _ MN60/61 SF M6 Guardian_______ 250/500 Lum__ _ 60/20 min___ _ 15.00 oz__ _ 7.8 in___ _ 2.50 in______ _ 18 V_ _ MN20/21 SUREFIRE PISTOL LIGHTS Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb SF M1xx Millenium Series 125/225 Lum__ _ 60/20 min___ _ 0.00 oz___ _ 0.0 in___ _ 1.62 in______ _ 9 V__ _ MN10/11 SF P1xx Nitrolon Series_ 65/120 Lum___ _ 60/20 min___ _ 0.00 oz___ _ 0.0 in___ _ 1.47 in______ _ 6 V__ _ P60/61 SF W1xx Miltary Series_ 65/120 Lum___ _ 60/20 min___ _ 0.00 oz___ _ 0.0 in___ _ 1.36 in______ _ 6 V__ _ P60/61 SF 6xx Classic Series___ 65/120 Lum___ _ 60/20 min___ _ 0.00 oz___ _ 0.0 in___ _ 1.36 in______ _ 6 V__ _ P60/61 SF X200A LED TIght____ 65 Lum______ _ 60 min______ _ 4.00 oz___ _ 3.7 in___ _ ______ in____ _ 6 V__ _ 5watt LED SF X200B LED Flood____ 65 Lum______ _ 60 min______ _ 4.00 oz___ _ 3.7 in___ _ ______ in____ _ 6 V__ _ 5watt LED SUREFIRE DEDICATED WEAPONS LIGHTS Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb SF M500A Carbine_____ 125/225 Lum__ _ 60/20 min___ _ 20.80 oz__ _ 0.0 in___ _ 1.62 in______ _ 9 V__ _ MN10/11 SF M500AB Carbine ___ 125/225 Lum__ _ 60/20 min___ _ 22.10 oz__ _ 0.0 in___ _ 2.50 in______ _ 9 V__ _ MN15/16 SF M500B Carbine_____ 250/500 Lum__ _ 60/20 min___ _ 25.00 oz__ _ 0.0 in___ _ 2.50 in______ _ 18 V_ _ MN20/21 SF M510A Rifle________ 125/225 Lum__ _ 60/20 min___ _ ____ oz__ _ 0.0 in___ _ 1.62 in______ _ 9 V__ _ MN10/11 SF M510AB Rifle_______ 125/225 Lum__ _ 60/20 min___ _ ____ oz__ _ 0.0 in___ _ 2.50 in______ _ 9 V__ _ MN15/16 SF M510B Rifle________ 250/500 Lum__ _ 60/20 min___ _ ____ oz__ _ 0.0 in___ _ 2.50 in______ _ 18 V_ _ MN20/21 SF 951C_____________ 65/120 Lum___ _ 60/20 min___ _ 9.20 oz___ _ 0.0 in___ _ 1.47 in______ _ 6 V__ _ P60/61 SF 952C_____________ 65/120 Lum___ _ 60/20 min___ _ 10.00 oz__ _ 0.0 in___ _ 1.47 in______ _ 6 V__ _ P60/61 SF 961C_____________ 125/225 Lum__ _ 60/20 min___ _ 11.50 oz__ _ 0.0 in___ _ 1.62 in______ _ 9 V__ _ MN10/11 SF 962C_____________ 125/225 Lum__ _ 60/20 min___ _ 12.30 oz__ _ 0.0 in___ _ 1.62 in______ _ 9 V__ _ MN10/11 SF 96LZ48___________ 125/225 Lum__ _ 60/20 min___ _ 11.50 oz__ _ 0.0 in___ _ 1.62 in______ _ 9 V__ _ MN10/11 SF 971C_____________ 125/225 Lum__ _ 60/20 min___ _ 12.80 oz__ _ 0.0 in___ _ 2.50 in______ _ 9 V__ _ MN15/16 SF 972C_____________ 125/225 Lum__ _ 60/20 min___ _ 13.60 oz__ _ 0.0 in___ _ 2.50 in______ _ 9 V__ _ MN15/16 SF 981C_____________ 225/350 Lum__ _ 60/20 min___ _ 14.60 oz__ _ 0.0 in___ _ 2.50 in______ _ 12 V_ _ MN60/61 SF 982C_____________ 225/350 Lum__ _ 60/20 min___ _ 15.40 oz__ _ 0.0 in___ _ 2.50 in______ _ 12 V_ _ MN60/61 SF Classic Universal 6V_ 65/120 Lum___ _ 60/20 min___ _ 5.20 oz___ _ 5.1 in___ _ 1.36 in______ _ 6 V__ _ P60/61 SF Classic Universal 9V_ 105/200 Lum__ _ 60/20 min___ _ 6.40 oz___ _ 6.7 in___ _ 1.36 in______ _ 9 V__ _ P90/91 SF M60LZ61__________ 65/120 Lum___ _ 60/20 min___ _ 6.50 oz___ _ 0.0 in___ _ ______ in____ _ 6 V__ _ P60/61 SF M60LUE07_________ 65/120 Lum___ _ 60/20 min___ _ 7.30 oz___ _ 0.0 in___ _ ______ in____ _ 6 V__ _ P60/61 SF M600A scout_______ 30 Lum______ _ 180 min____ _ 6.50 oz___ _ 0.0 in___ _ ______ in____ _ 6 V__ _ KL1 3W SF M600A scout ______ 65 Lum_______ _ 60 min______ _ 6.50 oz___ _ 0.0 in___ _ ______ in____ _ 6 V__ _ KL4 5W SF M600A scout kit____ 65/120 Lum___ _ 60/20 min___ _ 6.50 oz___ _ 0.0 in____ _ ______ in___ _ 6 V__ _ KL4/P61 SUREFIRE VERTICAL GRIP BOTTOM RAIL MOUNTED LIGHTS Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb SF M900A vert grip____ 125/225 Lum__ _ 60/20 min___ _ 18.90 oz__ _ 0.0 in___ _ 1.62 in______ _ 9 V__ _ MN10/11 SF M910A vert grip____ 125/225 Lum__ _ 60/20 min___ _ 18.10 oz__ _ 0.0 in___ _ 1.62 in______ _ 9 V__ _ MN10/11 SF M900AB vert grip___ 125/225 Lum__ _ 60/20 min___ _ 20.20 oz__ _ 0.0 in___ _ 2.50 in______ _ 9 V__ _ MN15/16 SF M910AB vert grip___ 125/225 Lum__ _ 60/20 min___ _ 19.40 oz__ _ 0.0 in___ _ 2.50 in______ _ 9 V__ _ MN15/16 STREAMLIGHT Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb SL M3_______________ 80-90 Lum____ _ 60 min______ _ 3.30 oz___ _ 3.4 in___ _ ______ in___ _ 6 V__ _ ________ SL M3X______________ 125 Lum______ _ 60 min______ _ 0.00 oz___ _ 3.4 in___ _ ______ in___ _ 6 V__ _ ________ SL M6_______________ 100 Lum______ _ 60 min______ _ 0.00 oz___ _ 3.4 in___ _ ______ in___ _ 6 V__ _ ________ SL M6X______________ 126 Lum______ _ 60 min______ _ 0.00 oz___ _ 3.4 in___ _ ______ in___ _ 6 V__ _ ________ SL TL-2 1W LED_______ 42 Lum_______ _ _____ min___ _ 0.00 oz___ _ 0.0 in___ _ 0.90 in______ _ 6 V__ _ 1watt LED SL TL-2 Xenon________ ______ Lum___ _ _____ min___ _ 0.00 oz___ _ 0.0 in___ _ 0.90 in______ _ 6 V__ _ ________ SL TL-3 5W LED_______ ______ Lum___ _ _____ min___ _ 0.00 oz___ _ 0.0 in___ _ ______ in___ _ 9 V__ _ 5watt LED SL TL-3 Xenon________ 200 Lum______ _ ______ min__ _ 0.00 oz___ _ 0.0 in___ _ ______ in___ _ 9 V__ _ ________ SL Scorpion__________ ______ Lum___ _ _____ min___ _ 4.40 oz___ _ 4.9 in___ _ ______ in____ _ 6 V__ _ ________ LASER DEVICES Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb LD OP6______________ 95 Lum_______ _ 90 min_____ _ 0.00 oz___ _ 0.0 in___ _ ______ in____ _ 6 V__ _ ________ LD OP6 weapon________ 95 Lum______ _ 90 min_____ _ 4.60 oz___ _ 5.3 in___ _ 1.00 in______ _ 6 V__ _ ________ LD OP9______________ 120 Lum______ _ _____ min__ _ 0.00 oz___ _ 0.0 in___ _ ______ in____ _ 9 V__ _ ________ LD OP9 weapon________ 120 Lum_____ _ _____ min__ _ 0.00 oz___ _ 0.0 in___ _ ______ in____ _ 9 V__ _ ________ LD LAS/TAC2_________ 125 Lum______ _ 70 min______ _ 3.10 oz___ _ 0.0 in___ _ ______ in___ _ 6 V__ _ 5watt LED Pistol Mnt LED LD LAS/TAC2_________ 95 Lum_______ _ 60 min______ _ 3.10 oz___ _ 0.0 in___ _ ______ in___ _ 6 V__ _ ________ Pistol Mnt Xenon PENTAGON Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb Pentagon X2 krypton___ 70 Lum_______ _ 60 min_____ _ 5.20 oz___ _ 5.5 in___ _ 1.25 in______ _ 6 V__ _ BX-2 Pentagon X3 krypton___ 135 Lum______ _ 60 min_____ _ 6.90 oz___ _ 7.0 in___ _ 1.50 in______ _ 9 V__ _ BX-3 Pentagon X4 krypton ___ 250 Lum_____ _ 60 min______ _ 0.00 oz___ _ 0.0 in___ _ 2.50 in______ _ 12 V_ _ BX-4 Pentagon MS2 krypton _ 70 Lum_______ _ 60 min_____ _ 0.00 oz___ _ 5.5 in___ _ 1.25 in______ _ 6 V__ _ BX-2 Pentagon MS3 krypton__ 135 Lum_____ _ 60 min______ _ 8.40 oz___ _ 7.0 in___ _ 1.50 in______ _ 9 V__ _ BX-3 Pentagon MS4 krypton__ 250 Lum_____ _ 60 min______ _ 0.00 oz___ _ 0.0 in___ _ 2.50 in______ _ 12 V_ _ BX-4 Pentagon L2 3W LED___ 65 Lum_______ _ 60 min_____ _ 0.00 oz___ _ 0.0 in___ _ 1.25 in______ _ 6 V__ _ 3watt LED Pentagon L3 LED______ ______ Lum___ _ _____ min__ _ 0.00 oz___ _ 0.0 in___ _ ______ in____ _ 9 V__ _ ________ Pentagon L4 LED ______ ______ Lum___ _ _____ min__ _ 0.00 oz___ _ 0.0 in___ _ ______ in____ _ 12 V_ _ ________ Pentagon S2 19LED____ 19 Lum_______ _ _____ min__ _ 0.00 oz___ _ 0.0 in___ _ ______ in____ _ 6 V__ _ 19 LEDs Pentagon S2 3W LED___ 30 Lum_______ _ _____ min__ _ 0.00 oz___ _ 0.0 in___ _ ______ in____ _ 6 V__ _ 3watt LED VARIOUS HIGH QUALITY WEAPONS LIGHTS Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb Gladius LED___________ 80 Lum______ _ 90 min______ _ 5.50 oz___ _ 6.2 in___ _ 1.25 in______ _ 6 V__ _ 5watt LED LT Battle Light________ 100 Lum______ _ 90 min______ _ 12.50 oz__ _ 0.0 in___ _ 1.4/1.5 in____ _ 9 V__ _ 5watt LED LT Weapon Light ______ 70 Lum_______ _ 90 min_____ _ 0.00 oz___ _ 0.0 in___ _ ______ in____ _ 6 V__ _ 3watt LED OTHER VARIOUS LIGHTS Light__________________ Lumens ______ _ Run_ ______ _ Wt._ __ _ Length __ _ Bezzel Dia___ _ Volt __ _ Bulb Brinkman LX___________ ______ Lum__ _ _____ min__ _ 4.00 oz___ _ 0.0 in___ _ 1.32/1.37 in___ _ 6 V__ _ ________ Pelican M6 LED________ ______ Lum___ _ _____ min__ _ 0.00 oz___ _ 0.0 in___ _ ______ in____ _ 6 V__ _ 3watt LED Inova T3_____________ ______ Lum___ _ _____ min__ _ 0.00 oz___ _ 0.0 in___ _ ______ in____ _ 9 V__ _ LED THROW DISTANCE RATING CHART This Chart lists the bulbs/heads/LED's of various lights and ranks them by their ability to "throw" light over distance ID range will be considered as the max distance where you can still tell the difference between 2 peoples faces in complete darkness considering only light factors, not distance/eyesight factors. I own none of these lights, so comparisons and actual experiences/tests are welcome. Hotspot @ 10' is the diameter of the "hotspot" of the beam in inches measured from 10 ft away. Please don’t go on about my X is a lot better than Y without doing a physical, personal test and comparison. Im looking for actual comparison with comments like; " X and Y have the same throw" or " I could identify the target with X from 10 yards farther away than with Y". __ ____________________ __ ___ Lumens _ Run _ ___ _____ Hotspot _ __ 150 - blinding_________ Volt ___ Rated __ Time _ ID_ Range at 10' _ Comment________________________ _1 SF MN21 Turbo Head__ 18V __ 500 ____ 20 ___ 160 yd___ 0 in.____ ___________________________________ _2 SF MN61 Turbo Head__ 12V __ 350 ____ 20 ___ 130 yd___ 0 in.____ ___________________________________ _3 Pentagon BX-4________ 12v __ 250 ____ 60 ___ yd___ 0 in.____ Not released yet _4 SF MN20 Turbo Head__ 18v __ 250 ____ 60 ___ 100 yd___ 0 in.____ ___________________________________ _5 SF MN60 Turbo Head__ 12V __ 225 ____ 60 ___ 90 yd___ 0 in.____ ___________________________________ _6 SF MN16 Turbo Head__ 9V ___ 225 ____ 20 ___ 90 yd___ 0 in.____ ___________________________________ _7 SF MN11____________ 9V ___ 225 ____ 20 ___ 80 yd___ 0 in.____ Better throw due to reflector _8 SL TL-3______________ 9v ___ 200 ____ __ ___ 75 yd___ 0 in.____ ___________________________________ _9 SF P91______________ 9V ___ 200 ____ 20 ___ 70 yd___ 0 in.____ Lots of flood __ ____________________ __ ___ Lumens _ Run _ ___ _____ Hotspot _ __ 100 - 150 lumens_____ Volt ___ Rated __ Time _ ID_ Range at 10' _ Comment________________________ _1 SF MN15 Turbo head 9V ___ 125 ____ 60 ___ 70 yd___ 0 in.____ Awesome throw, tight hotspot _2 SF MN10____________ 9V ___ 125 ____ 60 ___ 60 yd___ 0 in.____ Better Throw due to reflector _3 Pentagon BX-3________ 9V ___ 135 ____ 60 ___ 60 yd___ 0 in.____ Much like theSF MN10 _4 SF N3 + LED_________ 9v ___ 140/20 __ 40/150 60 yd___ 0 in.____ ___________________________________ _5 SF N2_______________ 9V ___ 105 ____ 60 ___ 60 yd___ 0 in.____ Interchangeable with MN15/16 _6 SF N90 + LED________ ___ 140 ____ 40 ___ 60 yd___ 0 in.____ ___________________________________ _7 SF P61______________ 6V ___ 120 ____ 20 ___ 55 yd___ 12 in.___ Great outdoor weapons light _8 LD OP9_____________ 9V ___ 125 ____ 60 ___ 55 yd___ 0 in.____ Adjustable spot to flood, but overrated _9 LD Lac/Tac2 (5W)_____ 6V ___ 125 ____ 60 ___ 55 yd___ 0 in.____ Lots of flood 10 Streamlight M3X______ 6V ___ 125 ____ 60 ___ 55 yd___ 0 in.____ ___________________________________ 11 SF N5_______________ 9v ___ 110 ____ 50 ___ 55 yd___ 0 in.____ ___________________________________ 12 SF P90______________ 9V ___ 105 ____ 60 ___ 50 yd___ 0 in.____ Good flood. 13 Larue Tactical Light 5W 9V ___ 100 ____ 90 ___ 50 yd___ 0 in.____ Best LED __ ____________________ __ ___ Lumens _ Run _ ___ _____ Hotspot _ __ 60 to 100 lumens______ Volt ___ Rated __ Time _ ID_ Range at 10' _ Comment________________________ _1 LD Lac/Tac2 Xenon____ 6V ___ 95 _____ 60 ___ 45 yd___ 0 in.____ Adjustable spot to flood, but overrated _2 LD OP6_____________ 6V ___ 95 _____ 60 ___ 45 yd___ 0 in.____ Adjustable spot to flood, but overrated _3 Laser Devices OP-6____ 6V ___ 90 _____ 60 ___ 45 yd___ 0 in.____ Overrated Lumens and useful run time _4 Gladius (5W)_________ 6V ___ 80 _____ 90 ___ 45 yd___ 0 in.____ Great Throw for LED, adjustable intensity. _5 SF N1_______________ 6V ___ 65 _____ 60 ___ 45 yd___ 0 in.____ ___________________________________ _6 Streamlight M3X LED__ 6V ___ 125 ____ 60 ___ 40 yd___ 0 in.____ Great handgun light, lots of flood _7 Pentagon BX-2________ 6V ___ 70 _____ 60 ___ 40 yd___ 0 in.____ Like SF P60_______________________ _8 SF P60______________ 6V ___ 65 _____ 60 ___ 40 yd___ 12 in.___ Minimum Performance for weapons light _9 Brinkman LX__________ 6V ___ ?? ______ ?? ____ 40 yd___ 12 in.___ Not a quality beam, dark spots etc 10 Streamlight M3_______ 6V ___ 80-90 __ 60 ___ 40 yd___ 0 in.____ Great handgun light, lots of flood 11 Pentagon L-2 (5W)____ 6V ___ 70 _____ 60 ___ 40 yd___ 0 in.____ ___________________________________ 12 SF KL3 (3W)new______ 6/9V ___ 19 _____ 255 __ 40 yd___ 0 in.____ Very small hot shop, no real flood 13 Pelican M6 (3W) 6v ___ ___ _____ ___ ___ 40 yd___ 0 in.____ ___________________________________ 14 SF MN03____________ 6v ___ 60 _____ 75 ___ 35 yd___ 0 in.____ Small, very tough bulb. Great beam 15 SF KL6 (5W)_________ 9v ___ 65 _____ 95 ___ 35 yd___ 0 in.____ LED with larger head for more throw 16 SF KL5 (5W)_________ 6V ___ 65 _____ 60 ___ 35 yd___ 0 in.____ LED with flood and throw like P60 17 SF X200A (5W)_______ 6V ___ 65 _____ 60 ___ 35 yd___ 0 in.____ The throw model 18 SF KL1 (3W)_________ 6V ___ 30 _____ 180 __ 30 yd___ 0 in.____ Tight beam, great throw, long run __ ____________________ __ ___ Lumens _ Run _ ___ _____ Hotspot _ __ Indoors only_________ Volt ___ Rated __ Time _ ID_ Range at 10' _ Comment________________________ _1 SF X200B (5W)_______ 6V ___ 65 _____ 60 ___ 25 yd___ 0 in.____ The flood model _2 SF L7 LED___________ B90 ___ 75 _____ 60 ___ 25 yd___ 0 in.____ ___________________________________ _3 SF KL4 (5W)_________ 6V ___ 65 _____ 60 ___ 25 yd___ 0 in.____ Bright with lots of flood _4 SF L4 LED___________ 6v ___ 65 _____ 60 ___ 25 yd___ 0 in.____ ___________________________________ _5 SF L5 LED___________ 6v ___ 65 _____ 60 ___ 25 yd___ 0 in.____ ___________________________________ _6 SF L6 LED___________ 9v ___ 65 _____ 95 ___ 25 yd___ 0 in.____ ___________________________________ __ ____________________ __ ___ Lumens _ Run _ ___ _____ Hotspot _ __ Not bright enough___ Volt ___ Rated __ Time _ ID_ Range at 10' _ Comment________________________ _1 SF MA02 + LED______ 6v ___ 50 _____ 60 ___ 25 yd___ 0 in.____ ___________________________________ _2 SF MN02____________ 6v ___ 20 _____ 150 __ 20 yd___ 0 in.____ Long lasting, but very bright _3 SF KL3 (3W)Old______ 6/9V ___ 19 _____ 255 __ 20 yd___ 0 in.____ ___________________________________ _4 SF L1 LED___________ 3v ___ 22 _____ 240 __ 15 yd___ 0 in.____ ___________________________________ _5 SF MN01____________ 3v ___ 15 _____ 90 ___ 10 yd___ 0 in.____ ___________________________________ Surefire Standard Heads/Bezels/LED Heads/Turbo Kits Head __ _______________________________ Bezel ___ Shock _ ___________ Output Kit __ Description______________________ Dia.__ _____ Isolated Bulbs______ __ Lumens Run Time _ Body __ Fits_____________________________________ Z32 __ Classis Universal Syst. shock isolated bezel_ 1.36 in____ yes ___ P60/61/90/91 __ 65-200 ___ 60-20 ____ 6P Type __ 6P,9P,Z2,Z3,G2,G2Z,M1,M2,D2,D3,C2,C3,Classics G2 ___ G2 standard bezel________________ 1.25/1.3 in__ no ____ P60/61/90/91 __ 65-200 ___ 60-20 ____ 6P Type __ 6P,9P,Z2,Z3,G2,G2Z,M1,M2,D2,D3,C2,C3,Classics 6P ___ 6P standard bezel________________ 1.25/1.3 in__ no ____ P60/61/90/91 __ 65-200 ___ 60-20 ____ 6P Type __ 6P,9P,Z2,Z3,G2,G2Z,M1,M2,D2,D3,C2,C3,Classics E ____ Standard Executive Series bezel_____ 1/1.1 in___ N/A ___ MN01/02/03 ___ 15-60 ____ 150-70 ___ Exec___ __ E1L, E1E, E2, E2E, E2O, E2D, E2L, M600A LED Conversion Heads KL1 __ 3/6v LED Conversion Head__________ 1 / 1.1 in___ LED ___ 3 watt LED ____ 25/30 60/180 ___ Exec___ __ E1L, E1E, E2, E2E, E2O, E2D, E2L, M600A KL2 __ L2 Head adjustable ouput head______ 1 / 1.1 in___ LED ___ 5 watt LED ____ 100 _____ 60 ______ L2_____ __ L2 KL3 __ 6/9v LED Conversion Head__________ 1 / 1.1 in___ LED ___ 3 watt LED ____ 19/19.5 ____ 255/420 ___ 6P Type __ 6P,9P,Z2,Z3,G2,G2Z,M1,M2,D2,D3,C2,C3,Classics KL4 __ 6v LED Conversion Head___________ 1 / 1.1 in___ LED ___ 5 watt LED ____ 65 ______ 60 ______ Exec___ __ E1L, E1E, E2, E2E, E2O, E2D, E2L, M600A KL5 __ 6/9v LED Conversion Head__________ 1.47 in____ LED ___ 5 watt LED ____ 65 ______ 60 ______ 6P Type __ 6P,9P,Z2,Z3,G2,G2Z,M1,M2,D2,D3,C2,C3,Classics KL6 __ 6v LED Conversion Head___________ 1.63 in____ LED ___ 5 watt LED ____ 65 ______ 90 ______ Millen__ __ M3, M3T, M4, Millenium, M96x, M97x Turbo Head Conversion Kits KT1 __ 6v Turbo Head Conversion Kit________ 2.50 in____ no ____ N1,MN15/16 __ 65 ______ 60 ______ 6P Type __ 6P, C2, D2, Z2, M2 KT2 __ 9v Turbo Head Conversion Kit________ 2.50 in____ no ____ N1,MN15/16 __ 105 _____ 60 ______ 6P Type __ 9P, C3, D3, Z3 KT3 __ Turbo Head Conversion Kit + LED____ 2.50 in____ no ____ N3_________ __ 140/20 ____ 40/150 __ 9AN___ __ 9AN KT4 __ Turbo Head Conversion Kit__________ 2.50 in____ yes ___ MN15/16 ____ 125-225 ___ 60-20 ___ Millen__ __ Millenium, M3,M4, M9xx,M5xx KT5 __ 9v Turbo Head Conversion Kit________ 2.50 in____ no ____ N5_________ __ 110 _____ 50 ______ _______ __ 8AX, 8NX Standard Bezels for Millenium Series M2 ___ Shock isolated incandescent 6 volts__ 1.47 in____ yes ___ P60/61/90/91 __ 65-200 ___ 60-20 ____ 6P Type __ M2, M95x, or add battery exension for 9v bulbs L10 __ Shock isolated incandescent 9 volts__ 1.62 in____ yes ___ MN10/11 ____ 125-225 ___ 60-20 ____ Millen__ __ M3,M3T, M96x,M97x, M9x0 A/AB, M5x0 A/AB L15 __ Same but 9 volt Turbo Head_________ 2.50 in____ yes ___ MN15/16 ____ 125-225 ___ 60-20 ____ Millen__ __ M3,M3T, M96x,M97x, M9x0 A/AB, M5x0 A/AB M60 __ Same but 12 volt Turbo Head________ 2.50 in____ yes ___ MN60/61 ____ 225-350 ___ 60-20 ____ Millen__ __ M4, M98x,(M3,M3T, M96x,M97x w/batt ext), M9x0B, M5x0B Conversion Kits for putting Millennium Type Heads on 6P type bodies using special adapters. (indicates what bezel) LU10 __ 9V shock isolated conversion kit (M3)_ 1.62 in____ yes ___ MN10/11 __ 125-225 ___ 60-20 ____ 6P Adap __ 6P,9P,Z2,Z3,G2,G2Z,M1,M2,D2,D3,C2,C3,Classics LU15 __ 9V shock isolated turbo conv. kit (M3T) 2.50 in____ yes ___ MN15/16 __ 125-225 ___ 60-20 ____ 6P Adap __ 6P,9P,Z2,Z3,G2,G2Z,M1,M2,D2,D3,C2,C3,Classics LU60 __ 12V shock isolated turbo conv. kit (M4) 2.50 in____ yes ___ MN60/61 __ 225-350 ___ 60-20 ____ 6P Adap __ 6P,9P,Z2,Z3,G2,G2Z,M1,M2,D2,D3,C2,C3,Classics LU60A _ Incandescent Head for M600A_______ 0.00 in____ yes __ P60/61/90/91 __ 65-200 ____ 60-20 ____ Exec___ __ Scout Light (M600A), add battery ext. for 9v bulbs SUREFIRE HEAD/BODY/TAILCAP COMPATIBILITY The following Surefire bodies have bezels exchangeable with the 6P (6P Type) 6P,9P Z2, Z3 G2, G2Z M1, M2 C2, C3 D2, D3 M95x L5 (M2 body) All Classic Universal System Weaponlights (they use Z32 bezel) The following Surefire bodies have bezels exchangeable with the Millennium Series (Millennium Type) M3,M3T,M4,M6? M96x, M97x, M98x M500 series M900 series L6 (M3 body) All 6P and Milleniuim type bodies can share the same tailcaps. The Z41, Z48, Z49, Z58, Z59, SW01, SW02, SU0x, UM0x & XM0x tailcaps will all interchange with 6P or Millennium type bodies. The following Surefire bodies have exchangeable heads and tailcaps (Executive Type) E1E, E1L, E2E, E2D, E2L, E2O M600A Scout L4 The Z52, Z57, Z61, Z68 & UE tailcaps will all interchange on Executive type lights. The E series bezels, KL1 & KL4 LED heads & the LU60A module will all interchange. The L7 and the 8AX have the same body. SUREFIRE TAILCAPS LIST This is a partial Surefire Parts list that focuses on Tailcaps. I need help with the blanks. Tailcap __ Finish______ __ Button Shape___ __ Lockout __ Click on __ Cord_ __ Body __ __ Z10 _____ ___________ __ Protruding Switch __ Yes___ __ NA____ __ NA___ __ ____ __ __ Lockout switch for M900's Z41 _____ ___________ __ _______________ __ ______ __ ______ __ NA___ __ ____ __ __ ____________________ Z48 _____ HA gray_____ __ Protective Lip___ __ Yes___ __ Yes___ __ NA___ __ 6P__ __ __ ____________________ Z49 _____ BlacK______ __ Protective Lip___ __ Yes___ __ Yes___ __ NA___ __ 6P__ __ __ ____________________ Z52 _____ ___________ __ _______________ __ ______ __ ______ __ NA___ __ Exec __ __ ____________________ Z57 _____ HA Green___ __ Protruding Button __ Yes___ __ Yes___ __ NA___ __ Exec __ __ ____________________ Z58 _____ Hard Anodized __ _______________ __ No____ __ Yes___ __ NA___ __ 6P__ __ __ ____________________ Z59 _____ ___________ __ _______________ __ ______ __ ______ __ NA___ __ 6P__ __ __ ____________________ Z61 _____ HA black____ __ Protruding Button __ Yes___ __ Yes___ __ NA___ __ Exec __ __ ____________________ Z62 _____ ___________ __ _______________ __ ______ __ ______ __ NA___ __ ____ __ __ ____________________ Z68 _____ ___________ __ _______________ __ ______ __ ______ __ NA___ __ Exec __ __ ____________________ SW01 __ ___________ __ _______________ __ ______ __ ______ __ NA___ __ 6P__ __ __ ____________________ SW02 __ ___________ __ Protruding Button __ ______ __ Yes___ __ NA___ __ 6P__ __ __ ____________________ UE07 __ ___________ __ Tape Switch____ __ No____ __ No____ __ 7in___ __ Exec __ __ ____________________ XM0x __ ___________ __ botton/tape switch __ No____ __ No____ __ 5" - 7" __ 6P__ __ __ Push button + tapeswitch Su0x __ ___________ __ Tape Switch____ __ No____ __ No____ __ 5" - 7" __ 6P__ __ __ ____________________ UM0x __ ___________ __ Tape Switch____ __ ______ __ ______ __ NA___ __ 6P__ __ __ ____________________ The Z41, Z48, Z49, Z58, Z59, SW01, SW02, SU0x, UM0x & XM0x tailcaps will all interchange wit 6P or Millennium type bodies. The Z52, Z57, Z61, Z68 & UE tailcaps will all interchange on Executive type lights. A21 _____ Spacer: allows the use of 1 more battery A19 _____ Spacer: allows the use of 1 more battery A12 _____ Spacer: allows the use of 1 more battery original http://www.ar15.com |
